[GRASS-SVN] r60684 - grass/trunk/scripts/i.pansharpen
svn_grass at osgeo.org
Tue Jun 3 01:03:51 PDT 2014
Author: neteler
Date: 2014-06-03 01:03:51 -0700 (Tue, 03 Jun 2014)
New Revision: 60684
grass/trunk/scripts/i.pansharpen/i.pansharpen.html
i.pansharpen manual: NC example added
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.html
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.html 2014-06-03 07:54:06 UTC (rev 60683)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.html 2014-06-03 08:03:51 UTC (rev 60684)
@@ -78,12 +78,13 @@
While the resulting color image will be at the higher resolution in all cases,
the 3 pan sharpening algorithms differ in terms of spectral response.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
Pan sharpening of a Landsat image from Boulder, Colorado, USA:
<div class="code"><pre>
# R, G, B composite at 30m
+g.region rast=p034r032_7dt20010924_z13_10 -p
d.rgb b=p034r032_7dt20010924_z13_10 g=lp034r032_7dt20010924_z13_20
r=p034r032_7dt20010924_z13_30
@@ -93,6 +94,7 @@
output_prefix=ihs321 sharpen=ihs
# display at 15m
+g.region rast=ihs321_blue -p
d.rgb b=ihs321_blue g=ihs321_green r=ihs321_red
</pre></div>
@@ -138,6 +140,32 @@
<br>
+Example: LANDSAT ETM+ (Landsat 7), North Carolina sample dataset:
+<div class="code"><pre>
+# original at 28m
+g.region rast=lsat7_2002_10 -p
+d.mon wx0
+d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
+# i.pansharpen with IHS algorithm
+i.pansharpen ms3=lsat7_2002_30 at PERMANENT \
+ ms2=lsat7_2002_20 ms1=lsat7_2002_10 \
+ pan=lsat7_2002_80 sharpen=ihs \
+ output_prefix=lsat7_2002_ihs
+# display at 14.25m
+g.region rast=lsat7_2002_ihs_red -p
+d.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
+# compare before/after (RGB support in "Advanced"):
+g.gui.mapswipe
+# optionally color balancing:
+i.landsat.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
+</pre></div>
<h2>SEE ALSO</h2>
<em>
