[GRASS-SVN] r60685 - grass/branches/releasebranch_7_0/scripts/i.pansharpen
Tue Jun 3 01:04:09 PDT 2014
Author: neteler
Date: 2014-06-03 01:04:09 -0700 (Tue, 03 Jun 2014)
New Revision: 60685
   grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
i.pansharpen manual: NC example added
Modified: grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html
--- grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html	2014-06-03 08:03:51 UTC (rev 60684)
+++ grass/branches/releasebranch_7_0/scripts/i.pansharpen/i.pansharpen.html	2014-06-03 08:04:09 UTC (rev 60685)
@@ -78,12 +78,13 @@
 While the resulting color image will be at the higher resolution in all cases,
 the 3 pan sharpening algorithms differ in terms of spectral response.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
 Pan sharpening of a Landsat image from Boulder, Colorado, USA:
 <div class="code"><pre>
 # R, G, B composite at 30m
+g.region rast=p034r032_7dt20010924_z13_10 -p
 d.rgb b=p034r032_7dt20010924_z13_10 g=lp034r032_7dt20010924_z13_20
     r=p034r032_7dt20010924_z13_30
@@ -93,6 +94,7 @@
     output_prefix=ihs321 sharpen=ihs
 # display at 15m
+g.region rast=ihs321_blue -p
 d.rgb b=ihs321_blue g=ihs321_green r=ihs321_red
 </pre></div>
@@ -138,6 +140,32 @@
 <br>
+Example: LANDSAT ETM+ (Landsat 7), North Carolina sample dataset:
+<div class="code"><pre>
+# original at 28m
+g.region rast=lsat7_2002_10 -p
+d.mon wx0
+d.rgb b=lsat7_2002_10 g=lsat7_2002_20 r=lsat7_2002_30
+# i.pansharpen with IHS algorithm
+i.pansharpen ms3=lsat7_2002_30 at PERMANENT \
+  ms2=lsat7_2002_20 ms1=lsat7_2002_10 \
+  pan=lsat7_2002_80 sharpen=ihs \
+  output_prefix=lsat7_2002_ihs
+# display at 14.25m
+g.region rast=lsat7_2002_ihs_red -p
+d.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
+# compare before/after (RGB support in "Advanced"):
+g.gui.mapswipe
+# optionally color balancing:
+i.landsat.rgb r=lsat7_2002_ihs_red g=lsat7_2002_ihs_green b=lsat7_2002_ihs_blue
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
