[GRASS-SVN] r60744 - grass/branches/releasebranch_7_0/vector/v.external.out
Sun Jun 8 01:58:50 PDT 2014
Author: martinl
Date: 2014-06-08 01:58:50 -0700 (Sun, 08 Jun 2014)
New Revision: 60744
   grass/branches/releasebranch_7_0/vector/v.external.out/args.c
   grass/branches/releasebranch_7_0/vector/v.external.out/format.c
   grass/branches/releasebranch_7_0/vector/v.external.out/link.c
   grass/branches/releasebranch_7_0/vector/v.external.out/local_proto.h
   grass/branches/releasebranch_7_0/vector/v.external.out/main.c
   grass/branches/releasebranch_7_0/vector/v.external.out/status.c
   grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html
 v.external.out: implement input/output options
                 (merge r60585 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/args.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/args.c	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/args.c	2014-06-08 08:58:50 UTC (rev 60744)
@@ -16,13 +16,13 @@
 				  "\t\tESRI Shapefile: directory containing a shapefile\n"
 				  "\t\tMapInfo File: directory containing a mapinfo file\n"
 				  "\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'");
-    options->dsn->required = YES;
+    options->dsn->required = NO;
+    options->dsn->guisection = _("Settings");
     options->format = G_define_option();
     options->format->key = "format";
     options->format->description = _("Format for output vector data");
-    options->format->required = YES;
+    options->format->required = NO;
     options->format->type = TYPE_STRING;
     options->format->options = format_options();
 #ifdef HAVE_OGR
@@ -32,7 +32,8 @@
     options->format->answer = "PostgreSQL";
 #endif /* HAVE_POSTGRES */
 #endif /* HAVE_OGR */
+    options->format->guisection = _("Settings");
     options->opts = G_define_option();
     options->opts->key = "options";
     options->opts->label = _("Creation options");
@@ -43,7 +44,17 @@
     options->opts->required = NO;
     options->opts->multiple = YES;
     options->opts->type = TYPE_STRING;
+    options->opts->guisection = _("Settings");
+    options->input = G_define_standard_option(G_OPT_F_INPUT);
+    options->input->required = NO;
+    options->input->description = _("Name of input file to read settings from");
+    options->input->guisection = _("Settings");
+    options->output = G_define_standard_option(G_OPT_F_OUTPUT);
+    options->output->required = NO;
+    options->output->description = _("Name for output file where to save current settings");
     flags->f = G_define_flag();
     flags->f->key = 'f';
     flags->f->description = _("List supported formats and exit");
@@ -70,4 +81,21 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
+    /* check options */
+    if (options->dsn->answer && options->format->answer &&
+        options->input->answer)
+        G_fatal_error(_("Options <%s/%s> and <%s> are mutually exclusive"),
+                      options->dsn->key, options->format->key,
+                      options->input->key);
+    if (flags->f->answer || flags->p->answer || flags->r->answer || flags->g->answer ||
+        options->output->answer)
+        return;
+    if (!options->dsn->answer && !options->input->answer)
+        G_fatal_error(_("One of options <%s> or <%s> must be specified"),
+                      options->dsn->key, options->input->key);
+    if (options->dsn->answer && !options->format->answer)
+        G_fatal_error(_("Option <%s> must be specified"),
+                      options->format->key);
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/format.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/format.c	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/format.c	2014-06-08 08:58:50 UTC (rev 60744)
@@ -7,23 +7,47 @@
 #include "ogr_api.h"
 #endif
+int is_ogr(const char *format)
+    int use_ogr = TRUE;
+    if(strcmp(format, "PostgreSQL") == 0) {
+#if defined HAVE_OGR && defined HAVE_POSTGRES
+        if (!getenv("GRASS_VECTOR_OGR"))
+            use_ogr  = FALSE;
+#else
+#ifdef HAVE_POSTGRES
+      if (getenv("GRASS_VECTOR_OGR"))
+	  G_warning(_("Environment variable GRASS_VECTOR_OGR defined, "
+		      "but GRASS is compiled with OGR support. "
+		      "Using GRASS-PostGIS data driver instead."));
+      use_ogr  = FALSE;
+#else /* -> force using OGR */
+      G_warning(_("GRASS is not compiled with PostgreSQL support. "
+		  "Using OGR-PostgreSQL driver instead of native "
+		  "GRASS-PostGIS data driver."));
+#endif /* HAVE_POSTRES */
+#endif /* HAVE_OGR && HAVE_POSTGRES */
+    return use_ogr;
 void check_format(char *format)
-    if(strcmp(format, "PostgreSQL") == 0)
-	return;
+    if (!is_ogr(format))
+        return;
 #ifdef HAVE_OGR
     OGRSFDriverH driver;
     G_strchg(format, '_', ' ');
     driver = OGRGetDriverByName(format);
     if (!driver)
-	G_fatal_error(_("Format <%s> not supported"), format);
-    if (OGR_Dr_TestCapability(driver, ODrCCreateDataSource))
-	return;
-    G_fatal_error(_("Format <%s> does not support writing"), format);
+        G_fatal_error(_("Format <%s> not supported"), format);
+    if (!OGR_Dr_TestCapability(driver, ODrCCreateDataSource))
+        G_fatal_error(_("Format <%s> does not support writing"), format);
 #endif
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/link.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/link.c	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/link.c	2014-06-08 08:58:50 UTC (rev 60744)
@@ -4,6 +4,8 @@
 #include <grass/gis.h>
 #include <grass/glocale.h>
+#include "local_proto.h"
 static int parse_option_pg(const char *, char **, char **);
 void make_link(const char *dsn_opt,
@@ -25,44 +27,16 @@
                     "format (\"%s\" given)"), format);
     /* use OGR ? */
-    if (strcmp(format, "PostgreSQL") == 0) {
-#if defined HAVE_OGR && defined HAVE_POSTGRES
-      if (getenv("GRASS_VECTOR_OGR")) {
-	  use_ogr  = TRUE;
-	  filename = "OGR";
-	  G_remove("", "PG");
-      else {
-	  use_ogr  = FALSE;
-	  filename = "PG";
-	  G_remove("", "OGR");
-#else
-#ifdef HAVE_POSTGRES
-	  G_warning(_("Environment variable GRASS_VECTOR_OGR defined, "
-		      "but GRASS is compiled with OGR support. "
-		      "Using GRASS-PostGIS data driver instead."));
-      use_ogr  = FALSE;
-      filename = "PG";
-#else /* -> force using OGR */
-      G_warning(_("GRASS is not compiled with PostgreSQL support. "
-		  "Using OGR-PostgreSQL driver instead of native "
-		  "GRASS-PostGIS data driver."));
-      use_ogr  = TRUE;
-      filename = "OGR";
-#endif /* HAVE_POSTRES */
-#endif /* HAVE_OGR && HAVE_POSTGRES */
-    } /* format=PostgreSQL */
+    use_ogr = is_ogr(format);
+    if (use_ogr) {
+        filename = "OGR";
+        G_remove("", "PG");
     else {
-	use_ogr  = TRUE;
-	filename = "OGR";
+        filename = "PG";
+        G_remove("", "OGR");
     /* be friendly, ignored 'PG:' prefix for GRASS-PostGIS data driver */
     if (!use_ogr && strcmp(format, "PostgreSQL") == 0 &&
 	G_strncasecmp(dsn_opt, "PG:", 3) == 0) {
@@ -99,21 +73,22 @@
 	    G_set_key_value("conninfo", dsn, key_val);
-    /* OGR only */
-    if (use_ogr) {
+    if (use_ogr) { /* OGR */
         if (format)
             G_set_key_value("format", format, key_val);
         if (option_str)
             G_set_key_value("options", option_str, key_val);
+    else {        /* PG */
+        G_set_key_value("format", "PostgreSQL", key_val);
     /* save file - OGR or PG */
     fp = G_fopen_new("", filename);
     if (!fp)
-	G_fatal_error(_("Unable to create <%s> file"), filename);
+	G_fatal_error(_("Unable to create settings file"));
     if (G_fwrite_key_value(fp, key_val) < 0)
-	G_fatal_error(_("Error writing <%s> file"), filename);
+	G_fatal_error(_("Error writing settings file"));
     fclose(fp);
@@ -146,3 +121,4 @@
     return 0;
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/local_proto.h
--- grass/branches/releasebranch_7_0/vector/v.external.out/local_proto.h	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/local_proto.h	2014-06-08 08:58:50 UTC (rev 60744)
@@ -2,7 +2,7 @@
 #define V_EXTERNAL_OUT_LOCAL_PROTO_H
 struct _options {
-    struct Option *dsn, *format, *opts;
+    struct Option *dsn, *format, *opts, *input, *output;
 struct _flags {
@@ -14,11 +14,12 @@
 		struct _options *, struct _flags*);
 /* format.c */
-void check_format(char *);
+int check_format(char *);
+int is_ogr(const char *);
 /* link.c */
 void make_link(const char *,
-	       const char *, const char *, char **);
+	       const char *, char *, char **);
 /* list.c */
 char *format_options(void);
@@ -26,5 +27,7 @@
 /* status.c */
 void print_status(int);
+int save_status_file(const struct Option *);
+int read_status_file(const struct Option *);
 #endif
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/main.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/main.c	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/main.c	2014-06-08 08:58:50 UTC (rev 60744)
@@ -79,10 +79,17 @@
 	make_link(options.dsn->answer, format,
 		  options.opts->answer, options.opts->answers);
+    else if (options.input->answer) {
+	read_status_file(options.input);
     if (flags.p->answer || flags.g->answer) {
 	print_status(flags.g->answer ? TRUE : FALSE);
+    if (options.output->answer) {
+        save_status_file(options.output);
     exit(EXIT_SUCCESS);
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/status.c
--- grass/branches/releasebranch_7_0/vector/v.external.out/status.c	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/status.c	2014-06-08 08:58:50 UTC (rev 60744)
@@ -4,8 +4,11 @@
 static int print_status_file(const char *, int);
 static void print_key_value(const char *, const char *, int);
+static void check_required_options(struct Key_Value *, int);
 void print_status(int shell)
@@ -37,7 +40,6 @@
     int i;
     FILE *fp;
-    const char *p;
     struct Key_Value *key_val;
@@ -49,18 +51,71 @@
     fclose(fp);
     /* check required options */
-    if (strcmp(file, "OGR") == 0) {
+    check_required_options(key_val, strcmp(file, "OGR") == 0);
+    /* print all options */
+    for (i = 0; i < key_val->nitems; i++)
+        print_key_value(key_val->key[i], key_val->value[i], shell);
+    G_free_key_value(key_val);
+    return TRUE;
+int save_status_file(const struct Option *file)
+    int use_ogr;
+    FILE *fp_input, *fp_output;
+    struct Key_Value *key_val;
+    /* read settings file */
+    use_ogr = FALSE;
+    fp_input = G_fopen_old("", "PG", G_mapset());
+    if (!fp_input) {
+        use_ogr = TRUE;
+        fp_input = G_fopen_old("", "OGR", G_mapset());
+    if (!fp_input)
+        G_fatal_error(_("No settings defined"));
+    /* read settings from file */
+    key_val = G_fread_key_value(fp_input);
+    fclose(fp_input);
+    /* check required options */
+    check_required_options(key_val, use_ogr);
+    /* open output file */
+    fp_output = G_open_option_file(file);
+    /* write settings to output file */
+    G_fwrite_key_value(fp_output, key_val);
+    G_close_option_file(fp_output);
+    return TRUE;
+void check_required_options(struct Key_Value *key_val, int use_ogr)
+    const char *p;
+    /* format (required) */
+    p = G_find_key_value("format", key_val);
+    if (!p)
+        G_fatal_error(_("Format not defined"));
 	/* dsn (required) */
 	p = G_find_key_value("dsn", key_val);
 	if (!p)
 	    G_fatal_error(_("OGR datasource (dsn) not defined"));
-	/* format (required) */
-	p = G_find_key_value("format", key_val);
-	if (!p)
-	    G_fatal_error(_("OGR format not defined"));
-    else { /* PG */
+    else {         /* PG */
         char dsn_name[GNAME_MAX];
 	/* conninfo (required) */
@@ -68,17 +123,43 @@
 	if (!p)
 	    G_fatal_error(_("PG connection info (conninfo) not defined"));
-        /* print also dsn for compatibility */
+        /* add dsn for compatibility */
         sprintf(dsn_name, "PG:%s", p);
         G_set_key_value("dsn", dsn_name, key_val);
-        /* force format */
-        print_key_value("format", "PostgreSQL", shell);
-    /* print all options */
-    for (i = 0; i < key_val->nitems; i++)
-        print_key_value(key_val->key[i], key_val->value[i], shell);
+int read_status_file(const struct Option *file)
+    int use_ogr;
+    const char *format;
+    fp_input = G_open_option_file(file);
+    G_close_option_file(fp_input);
+    format = G_find_key_value("format", key_val);
+    if (!format)
+    fp_output = G_fopen_new("", use_ogr ? "OGR" : "PG");
+    if (!fp_output)
+    if (G_fwrite_key_value(fp_output, key_val) < 0)
+    fclose(fp_output);
     return TRUE;
Modified: grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html
--- grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html	2014-06-08 08:54:37 UTC (rev 60743)
+++ grass/branches/releasebranch_7_0/vector/v.external.out/v.external.out.html	2014-06-08 08:58:50 UTC (rev 60744)
@@ -147,6 +147,33 @@
 v.external.out -r
 </pre></div>
+<h3>Restore settings</h3>
+Current settings can be stored to file by specifying <b>output</b> option.
+<div class="code"><pre>
+# define output PostGIS database for GRASS calculation results stored as topological elements:
+v.external.out dsn=PG:dbname=gisdb format=PostgreSQL options=topology=YES output=gisdb_topo.txt
+# do some processing in PostGIS Topology
+</pre></div>
+Back to native format:
+v.external.out -r
+# do some processing in native format
+</pre></div>
+Restore previous settings from "gisdb_topo.txt" file by specifying <b>input</b> option.
+v.external.out input=gisdb_topo.txt
+</pre></div>
 <h2>REFERENCES</h2>
 <ul>
