[GRASS-SVN] r60745 - grass/branches/releasebranch_7_0/vector/v.out.ogr
Sun Jun 8 02:42:54 PDT 2014
Author: hcho
Date: 2014-06-08 02:42:54 -0700 (Sun, 08 Jun 2014)
New Revision: 60745
   grass/branches/releasebranch_7_0/vector/v.out.ogr/attrb.c
   grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c
   grass/branches/releasebranch_7_0/vector/v.out.ogr/export_lines.c
   grass/branches/releasebranch_7_0/vector/v.out.ogr/main.c
v.out.ogr: merge from r60692
1. Fixed counting # features written without category and related messages.
2. Fixed multi-feature export by checking all available cats, not just the first one.
3. Fixed multi-feature area export with no category.
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/attrb.c
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/attrb.c	2014-06-08 08:58:50 UTC (rev 60744)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/attrb.c	2014-06-08 09:42:54 UTC (rev 60745)
@@ -138,10 +138,7 @@
 	    OGR_F_SetFieldInteger(Ogr_feature, ogrfieldnum, cat);
-    else {
-	/* G_warning ("Line without cat of layer %d", field); */
-	nocat++;
+    /* else G_warning ("Line without cat of layer %d", field); */
     db_free_string(&dbstring);
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c	2014-06-08 08:58:50 UTC (rev 60744)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/export_areas.c	2014-06-08 09:42:54 UTC (rev 60745)
@@ -94,6 +94,7 @@
             if (j == -1) {
                 if (cat >= 0)
                     continue;	/* cat(s) exists */
+		(*n_nocat)++;
             else {
                 if (Cats->field[j] == field)
@@ -125,11 +126,11 @@
                        int *n_noatt, int *n_nocat)
     int i, n_exported, area;
-    int cat, lcat, ncats_field, line, type, findex, ipart;
+    int cat, ncats_field, line, type, findex, ipart;
     struct line_pnts *Points;
     struct line_cats *Cats;
-    struct ilist *cat_list, *line_list;
+    struct ilist *cat_list, *line_list, *lcats;
     OGRGeometryH Ogr_geometry, Ogr_geometry_part;
     OGRFeatureH Ogr_feature;
@@ -139,6 +140,7 @@
     Cats = Vect_new_cats_struct();
     cat_list = Vect_new_list();
     line_list = Vect_new_list();
+    lcats = Vect_new_list();
     n_exported = 0;
@@ -155,7 +157,12 @@
     ncats_field = Vect_cidx_get_unique_cats_by_index(In, findex, cat_list);
     G_debug(1, "n_cats = %d for layer %d", ncats_field, field);
+    if (donocat)
+	G_message(_("Exporting features with category..."));
     for (i = 0; i < cat_list->n_values; i++) {
+        G_percent(i, cat_list->n_values - 1, 5);
         cat = cat_list->value[i];
         /* find all centroids with given category */
         Vect_cidx_find_all(In, field, GV_CENTROID, cat, line_list);
@@ -171,11 +178,11 @@
             /* get centroid's category */
             Vect_read_line(In, NULL, Cats, line);
             /* check for category consistency */
-            Vect_cat_get(Cats, field, &lcat);
-            if (lcat > 0 && lcat != cat)
+            Vect_field_cat_get(Cats, field, lcats);
+	    if (!Vect_val_in_list(lcats, cat))
                 G_fatal_error(_("Unable to create multi-feature. "
-                                "Invalid category %d (should be %d)"),
-                              lcat, cat);
+                                "Category %d not found in line %d, field %d"),
+                              cat, line, field);
             /* find correspoding area */
             area = Vect_get_centroid_area(In, line);
@@ -210,6 +217,9 @@
         OGR_G_DestroyGeometry(Ogr_geometry);
+    if (donocat)
+	G_message(_("Exporting features without category..."));
     /* check lines without category, if -c flag is given write them as
      * one multi-feature */
     Ogr_geometry = OGR_G_CreateGeometry(wkbtype);
@@ -232,15 +242,18 @@
+	line = Vect_get_next_line_id(In);
         if (area == 0)
-                continue;
+            continue;
         /* create polygon from area */
         Ogr_geometry_part = create_polygon(In, area, Points);
         /* add part */
         OGR_G_AddGeometryDirectly(Ogr_geometry, Ogr_geometry_part);
+        (*n_nocat)++;
     if (!OGR_G_IsEmpty(Ogr_geometry)) {
@@ -267,6 +280,7 @@
     Vect_destroy_cats_struct(Cats);
     Vect_destroy_list(cat_list);
     Vect_destroy_list(line_list);
+    Vect_destroy_list(lcats);
     return n_exported;
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/export_lines.c
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/export_lines.c	2014-06-08 08:58:50 UTC (rev 60744)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/export_lines.c	2014-06-08 09:42:54 UTC (rev 60745)
@@ -115,6 +115,7 @@
             if (j == -1) {
                 if (cat >= 0)
+		(*n_nocat)++;
             else {
@@ -147,11 +148,11 @@
     int i, n_exported;
     OGRGeometryH Ogr_geometry;
@@ -161,6 +162,7 @@
     n_exported = 0;
@@ -199,12 +201,12 @@
             type = Vect_read_line(In, Points, Cats, line);
-                              lcat, cat);
             /* add part */
             add_part(Ogr_geometry, wkbtype_part,
                      type == GV_LINE && force_poly, Points);
@@ -253,6 +255,8 @@
         /* add part */
+        (*n_nocat)++;
@@ -279,6 +283,7 @@
     return n_exported;
Modified: grass/branches/releasebranch_7_0/vector/v.out.ogr/main.c
--- grass/branches/releasebranch_7_0/vector/v.out.ogr/main.c	2014-06-08 08:58:50 UTC (rev 60744)
+++ grass/branches/releasebranch_7_0/vector/v.out.ogr/main.c	2014-06-08 09:42:54 UTC (rev 60745)
@@ -58,8 +58,8 @@
     dbString dbstring;
     dbColumn *Column;
-    int n_feat;                        /* number of written features */
-    int n_nocat, n_noatt, n_nocatskip; /* number of features without cats/atts written/skip */
+    int n_feat;           /* number of written features */
+    int n_nocat, n_noatt; /* number of features without cats/atts written/skip */
     /* OGR */
     int drn;
@@ -695,7 +695,7 @@
     Ogr_featuredefn = OGR_L_GetLayerDefn(Ogr_layer);
-    n_feat = n_nocat = n_noatt = n_nocatskip = 0;
+    n_feat = n_nocat = n_noatt = 0;
     if (OGR_L_TestCapability(Ogr_layer, OLCTransactions))
 	OGR_L_StartTransaction(Ogr_layer);
@@ -712,7 +712,7 @@
                                Ogr_featuredefn, Ogr_layer,
                                Fi, Driver, ncol, colctype,
                                colname, doatt, flags.nocat->answer ? TRUE : FALSE,
-                               &n_noatt, &n_nocatskip);
+                               &n_noatt, &n_nocat);
     /* Areas (run always to count features of different type) */
@@ -726,7 +726,7 @@
@@ -756,22 +756,23 @@
     /* Summary */
-    if (n_nocat > 0)
-	G_important_message(_n("%d feature without category was written",
-                               "%d features without category were written",
-                               n_nocat), n_nocat);
     if (n_noatt > 0)
 	G_important_message(_n("%d feature without attributes was written",
                                "%d features without attributes were written",
                                n_noatt), n_noatt);
-    if (n_nocatskip > 0)
-	G_warning(_n("%d feature without category was skipped. "
-                     "Features without category are written only when -%c flag is given.",
-                     "%d features without category were skipped. "
-                     n_nocatskip),
-		  n_nocatskip, flags.cat->key);
+    if (n_nocat > 0) {
+	if (donocat)
+	    G_important_message(_n("%d feature without category was written",
+				   "%d features without category were written",
+				   n_nocat), n_nocat);
+	else
+	    G_warning(_n("%d feature without category was skipped. "
+                         "Features without category are written only when -%c flag is given.",
+                         "%d features without category were skipped. "
+                         n_nocat), n_nocat, flags.cat->key);
     /* Enable this? May be confusing that for area type are not
      * reported all boundaries/centroids. OTOH why should be
