[GRASS-SVN] r60797 - grass/trunk/imagery/i.albedo
Thu Jun 12 04:03:48 PDT 2014
Author: ychemin
Date: 2014-06-12 04:03:48 -0700 (Thu, 12 Jun 2014)
New Revision: 60797
   grass/trunk/imagery/i.albedo/bb_alb_landsat8.c
   grass/trunk/imagery/i.albedo/main.c
better temporary fix
Modified: grass/trunk/imagery/i.albedo/bb_alb_landsat8.c
--- grass/trunk/imagery/i.albedo/bb_alb_landsat8.c	2014-06-11 21:49:13 UTC (rev 60796)
+++ grass/trunk/imagery/i.albedo/bb_alb_landsat8.c	2014-06-12 11:03:48 UTC (rev 60797)
@@ -3,14 +3,24 @@
  * Temporary until a publication creates an algorithm
 -* chan5 is OLI Band 6 (1.57-1.65)
  * chan7 is OLI band 7 (2.11-2.29)
+ * Temporary better fix than weighted average
+ * r.regression.multi
+ * mapx=LC81270512014115LGN00.toar.1,LC81270512014115LGN00.toar.2,
+ * LC81270512014115LGN00.toar.3,LC81270512014115LGN00.toar.4,
+ * LC81270512014115LGN00.toar.5,LC81270512014115LGN00.toar.6,
+ * LC81270512014115LGN00.toar.7
+ * mapy=MCD43_2014113
-double bb_alb_landsat8(double bluechan, double greenchan, double redchan,
-		      double nirchan, double chan5, double chan7)
+double bb_alb_landsat8(double shortbluechan, double bluechan, double greenchan, double redchan,
+              double nirchan, double chan5, double chan7)
     double result;
-    result =
-	(0.06 * bluechan + 0.06 * greenchan + 0.03 * redchan +
-	 0.03 * nirchan + 0.08 * chan5 + 0.18 * chan7)/0.44;
+    result = 0.058674+shortbluechan*2.153642+bluechan*(-2.242688)+
+    greenchan*(-0.520669)+redchan*0.622670+nirchan*0.129979+
+    chan5*(-0.047970)+chan7*0.152228;
     return result;
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c	2014-06-11 21:49:13 UTC (rev 60796)
+++ grass/trunk/imagery/i.albedo/main.c	2014-06-12 11:03:48 UTC (rev 60797)
@@ -9,7 +9,7 @@
  * COPYRIGHT:    (C) 2004-2008 by the GRASS Development Team
  *               This program is free software under the GNU Lesser General Public
- *   	    	 License. Read the file COPYING that comes with GRASS for details.
+ *                License. Read the file COPYING that comes with GRASS for details.
@@ -24,22 +24,23 @@
 #define MAXFILES 8
 double bb_alb_aster(double greenchan, double nirchan, double swirchan2,
-		    double swirchan3, double swirchan5, double swirchan6);
+    double swirchan3, double swirchan5, double swirchan6);
 double bb_alb_landsat(double bluechan, double greenchan, double redchan,
-		      double nirchan, double chan5, double chan7);
+    double nirchan, double chan5, double chan7);
+    double greenchan, double redchan,
 double bb_alb_noaa(double redchan, double nirchan);
 double bb_alb_modis(double redchan, double nirchan, double chan3,
-		    double chan4, double chan5, double chan6, double chan7);
+    double chan4, double chan5, double chan6, double chan7);
 int main(int argc, char *argv[])
-    struct Cell_head cellhd;	/*region+header info */
+    struct Cell_head cellhd;    /*region+header info */
     int nrows, ncols;
     int row, col;
     struct GModule *module;
@@ -47,12 +48,12 @@
     struct Flag *flag1, *flag2, *flag3;
     struct Flag *flag4, *flag5, *flag6;
     struct Flag *flag7;
-    struct History history;	/*metadata */
-    struct Colors colors;	/*Color rules */
+    struct History history;    /*metadata */
+    struct Colors colors;    /*Color rules */
-    char *name;			/*input raster name */
-    char *result;		/*output raster name */
+    char *name;            /*input raster name */
+    char *result;        /*output raster name */
     /*File Descriptors */
     int nfiles;
     int infd[MAXFILES];
@@ -65,7 +66,7 @@
     void *inrast[MAXFILES];
     unsigned char *outrast;
-    RASTER_MAP_TYPE in_data_type[MAXFILES];	/* 0=numbers  1=text */
+    RASTER_MAP_TYPE in_data_type[MAXFILES];    /* 0=numbers  1=text */
     RASTER_MAP_TYPE out_data_type = DCELL_TYPE;
     CELL val1, val2;
@@ -119,7 +120,7 @@
     flag4 = G_define_flag();
     flag4->key = '8';
-    flag4->description = _("Landsat 8 (6 input bands:2,3,4,5,6,7)");
+    flag4->description = _("Landsat 8 (7 input bands:1,2,3,4,5,6,7)");
     flag5 = G_define_flag();
     flag5->key = 'a';
@@ -129,21 +130,21 @@
     flag6->key = 'c';
     flag6->label = _("Agressive mode (Landsat)");
     flag6->description =
-	_("Albedo dry run to calculate some water to beach/sand/desert stretching, "
-	  "a kind of simple atmospheric correction");
+    _("Albedo dry run to calculate some water to beach/sand/desert stretching, "
+      "a kind of simple atmospheric correction");
     flag7 = G_define_flag();
     flag7->key = 'd';
     flag7->label = _("Soft mode (Modis)");
     flag7->description =
     /* FMEO init nfiles */
     nfiles = 1;
     if (G_parser(argc, argv))
-	exit(EXIT_FAILURE);
+    exit(EXIT_FAILURE);
     names = input->answers;
     ptr = input->answers;
@@ -157,22 +158,22 @@
     aster = (flag5->answer);
     for (; *ptr != NULL; ptr++) {
-	if (nfiles >= MAXFILES)
-	    G_fatal_error(_("Too many input maps. Only %d allowed."), MAXFILES);
-	name = *ptr;
-	/* Allocate input buffer */
-	in_data_type[nfiles] = Rast_map_type(name, "");
-	infd[nfiles] = Rast_open_old(name, "");
+    if (nfiles >= MAXFILES)
+        G_fatal_error(_("Too many input maps. Only %d allowed."), MAXFILES);
+    name = *ptr;
-	Rast_get_cellhd(name, "", &cellhd);
+    /* Allocate input buffer */
+    in_data_type[nfiles] = Rast_map_type(name, "");
+    infd[nfiles] = Rast_open_old(name, "");
-	inrast[nfiles] = Rast_allocate_buf(in_data_type[nfiles]);
-	nfiles++;
+    Rast_get_cellhd(name, "", &cellhd);
+    inrast[nfiles] = Rast_allocate_buf(in_data_type[nfiles]);
+    nfiles++;
     nfiles--;
     if (nfiles <= 1)
-	G_fatal_error(_("At least two raster maps are required"));
+    G_fatal_error(_("At least two raster maps are required"));
     /* Allocate output buffer, use input map data_type */
     nrows = Rast_window_rows();
@@ -186,217 +187,217 @@
     /*This is correcting contrast for water/sand */
     /*A poor man's atmospheric correction... */
     for (i = 0; i < 100; i++)
-	histogram[i] = 0;
+    histogram[i] = 0;
     if (flag6->answer || flag7->answer) {
-	DCELL de;
-	DCELL d[MAXFILES];
+    DCELL de;
+    DCELL d[MAXFILES];
-	/* Process pixels histogram */
-	for (row = 0; row < nrows; row++) {
-	    G_percent(row, nrows, 2);
-	    /* read input map */
-	    for (i = 1; i <= nfiles; i++)
-		Rast_get_row(infd[i], inrast[i], row, in_data_type[i]);
+    /* Process pixels histogram */
+    for (row = 0; row < nrows; row++) {
+        G_percent(row, nrows, 2);
+        /* read input map */
+        for (i = 1; i <= nfiles; i++)
+        Rast_get_row(infd[i], inrast[i], row, in_data_type[i]);
-	    /*process the data */
-	    for (col = 0; col < ncols; col++) {
-		for (i = 1; i <= nfiles; i++) {
-		    switch (in_data_type[i]) {
-		    case CELL_TYPE:
-			d[i] = (double)((CELL *) inrast[i])[col];
-			break;
-		    case FCELL_TYPE:
-			d[i] = (double)((FCELL *) inrast[i])[col];
-			break;
-		    case DCELL_TYPE:
-			d[i] = (double)((DCELL *) inrast[i])[col];
-			break;
-		if (modis) {
-		    de = bb_alb_modis(d[1],d[2],d[3],d[4],d[5],d[6],d[7]);
-		else if (avhrr) {
-		    de = bb_alb_noaa(d[1],d[2]);
-		else if (landsat) {
-		    de = bb_alb_landsat(d[1],d[2],d[3],d[4],d[5],d[6]);
-		else if (landsat8) {
-		    de = bb_alb_landsat8(d[1],d[2],d[3],d[4],d[5],d[6]);
-		else if (aster) {
-		    de = bb_alb_aster(d[1],d[2],d[3],d[4],d[5],d[6]);
-		if (Rast_is_d_null_value(&de)) {
-		    /*Do nothing */
-		else {
-		    int temp;
+        /*process the data */
+        for (col = 0; col < ncols; col++) {
+        for (i = 1; i <= nfiles; i++) {
+            switch (in_data_type[i]) {
+            case CELL_TYPE:
+            d[i] = (double)((CELL *) inrast[i])[col];
+            break;
+            case FCELL_TYPE:
+            d[i] = (double)((FCELL *) inrast[i])[col];
+            break;
+            case DCELL_TYPE:
+            d[i] = (double)((DCELL *) inrast[i])[col];
+            break;
+        if (modis) {
+            de = bb_alb_modis(d[1],d[2],d[3],d[4],d[5],d[6],d[7]);
+        else if (avhrr) {
+            de = bb_alb_noaa(d[1],d[2]);
+        else if (landsat) {
+            de = bb_alb_landsat(d[1],d[2],d[3],d[4],d[5],d[6]);
+        else if (landsat8) {
+            de = bb_alb_landsat8(d[1],d[2],d[3],d[4],d[5],d[6],d[7]);
+        else if (aster) {
+            de = bb_alb_aster(d[1],d[2],d[3],d[4],d[5],d[6]);
+        if (Rast_is_d_null_value(&de)) {
+            /*Do nothing */
+        else {
+            int temp;
-		    temp = (int)(de * 100);
-		    if (temp > 0) {
-			histogram[temp] = histogram[temp] + 1.0;
+            temp = (int)(de * 100);
+            if (temp > 0) {
+            histogram[temp] = histogram[temp] + 1.0;
-	G_message("Calculating histogram of albedo");
+    G_message("Calculating histogram of albedo");
-	peak1 = 0;
-	peak2 = 0;
-	peak3 = 0;
-	i_peak1 = 0;
-	i_peak2 = 0;
-	i_peak3 = 0;
-	for (i = 0; i < 100; i++) {
-	    /*Search for peaks of datasets (1) */
-	    if (i <= 10) {
-		if (histogram[i] > peak1) {
-		    peak1 = histogram[i];
-		    i_peak1 = i;
-	    /*Search for peaks of datasets (2) */
-	    if (i >= 10 && i <= 30) {
-		if (histogram[i] > peak2) {
-		    peak2 = histogram[i];
-		    i_peak2 = i;
-	    /*Search for peaks of datasets (3) */
-	    if (i >= 30) {
-		if (histogram[i] > peak3) {
-		    peak3 = histogram[i];
-		    i_peak3 = i;
+    peak1 = 0;
+    peak2 = 0;
+    peak3 = 0;
+    i_peak1 = 0;
+    i_peak2 = 0;
+    i_peak3 = 0;
+    for (i = 0; i < 100; i++) {
+        /*Search for peaks of datasets (1) */
+        if (i <= 10) {
+        if (histogram[i] > peak1) {
+            peak1 = histogram[i];
+            i_peak1 = i;
+        /*Search for peaks of datasets (2) */
+        if (i >= 10 && i <= 30) {
+        if (histogram[i] > peak2) {
+            peak2 = histogram[i];
+            i_peak2 = i;
+        /*Search for peaks of datasets (3) */
+        if (i >= 30) {
+        if (histogram[i] > peak3) {
+            peak3 = histogram[i];
+            i_peak3 = i;
-	bottom1a = 100000;
-	bottom1b = 100000;
-	bottom2a = 100000;
-	bottom2b = 100000;
-	bottom3a = 100000;
-	bottom3b = 100000;
-	i_bottom1a = 100;
-	i_bottom1b = 100;
-	i_bottom2a = 100;
-	i_bottom2b = 100;
-	i_bottom3a = 100;
-	i_bottom3b = 100;
-	/* Water histogram lower bound */
-	for (i = 0; i < i_peak1; i++) {
-	    if (histogram[i] <= bottom1a) {
-		bottom1a = histogram[i];
-		i_bottom1a = i;
-	/* Water histogram higher bound */
-	for (i = i_peak2; i > i_peak1; i--) {
-	    if (histogram[i] <= bottom1b) {
-		bottom1b = histogram[i];
-		i_bottom1b = i;
-	/* Land histogram lower bound */
-	for (i = i_peak1; i < i_peak2; i++) {
-	    if (histogram[i] <= bottom2a) {
-		bottom2a = histogram[i];
-		i_bottom2a = i;
-	/* Land histogram higher bound */
-	for (i = i_peak3; i > i_peak2; i--) {
-	    if (histogram[i] < bottom2b) {
-		bottom2b = histogram[i];
-		i_bottom2b = i;
-	/* Cloud/Snow histogram lower bound */
-	for (i = i_peak2; i < i_peak3; i++) {
-	    if (histogram[i] < bottom3a) {
-		bottom3a = histogram[i];
-		i_bottom3a = i;
-	/* Cloud/Snow histogram higher bound */
-	for (i = 100; i > i_peak3; i--) {
-	    if (histogram[i] < bottom3b) {
-		bottom3b = histogram[i];
-		i_bottom3b = i;
-	if (flag5->answer) {
-	    G_message("peak1 %d %d", peak1, i_peak1);
-	    G_message("bottom2b= %d %d", bottom2b, i_bottom2b);
-	    a = (0.36 - 0.05) / (i_bottom2b / 100.0 - i_peak1 / 100.0);
-	    b = 0.05 - a * (i_peak1 / 100.0);
-	    G_message("a= %f\tb= %f", a, b);
-	if (flag6->answer) {
-	    G_message("bottom1a %d %d", bottom1a, i_bottom1a);
-	    a = (0.36 - 0.05) / (i_bottom2b / 100.0 - i_bottom1a / 100.0);
-	    b = 0.05 - a * (i_bottom1a / 100.0);
-    }				/*END OF FLAG1 */
+    bottom1a = 100000;
+    bottom1b = 100000;
+    bottom2a = 100000;
+    bottom2b = 100000;
+    bottom3a = 100000;
+    bottom3b = 100000;
+    i_bottom1a = 100;
+    i_bottom1b = 100;
+    i_bottom2a = 100;
+    i_bottom2b = 100;
+    i_bottom3a = 100;
+    i_bottom3b = 100;
+    /* Water histogram lower bound */
+    for (i = 0; i < i_peak1; i++) {
+        if (histogram[i] <= bottom1a) {
+        bottom1a = histogram[i];
+        i_bottom1a = i;
+    /* Water histogram higher bound */
+    for (i = i_peak2; i > i_peak1; i--) {
+        if (histogram[i] <= bottom1b) {
+        bottom1b = histogram[i];
+        i_bottom1b = i;
+    /* Land histogram lower bound */
+    for (i = i_peak1; i < i_peak2; i++) {
+        if (histogram[i] <= bottom2a) {
+        bottom2a = histogram[i];
+        i_bottom2a = i;
+    /* Land histogram higher bound */
+    for (i = i_peak3; i > i_peak2; i--) {
+        if (histogram[i] < bottom2b) {
+        bottom2b = histogram[i];
+        i_bottom2b = i;
+    /* Cloud/Snow histogram lower bound */
+    for (i = i_peak2; i < i_peak3; i++) {
+        if (histogram[i] < bottom3a) {
+        bottom3a = histogram[i];
+        i_bottom3a = i;
+    /* Cloud/Snow histogram higher bound */
+    for (i = 100; i > i_peak3; i--) {
+        if (histogram[i] < bottom3b) {
+        bottom3b = histogram[i];
+        i_bottom3b = i;
+    if (flag5->answer) {
+        G_message("peak1 %d %d", peak1, i_peak1);
+        G_message("bottom2b= %d %d", bottom2b, i_bottom2b);
+        a = (0.36 - 0.05) / (i_bottom2b / 100.0 - i_peak1 / 100.0);
+        b = 0.05 - a * (i_peak1 / 100.0);
+        G_message("a= %f\tb= %f", a, b);
+    if (flag6->answer) {
+        G_message("bottom1a %d %d", bottom1a, i_bottom1a);
+        a = (0.36 - 0.05) / (i_bottom2b / 100.0 - i_bottom1a / 100.0);
+        b = 0.05 - a * (i_bottom1a / 100.0);
+    }                /*END OF FLAG1 */
     /* End of processing histogram */
     /* Process pixels */
-	DCELL de;
+    DCELL de;
-		case CELL_TYPE:
-		    break;
-		case FCELL_TYPE:
-		    break;
-		case DCELL_TYPE:
-		    break;
-	    if (modis) {
-	    else if (avhrr) {
-	    else if (aster) {
-	    if (flag6->answer || flag7->answer) {
-		/* Post-Process Albedo */
-		de = a * de + b;
-	    ((DCELL *) outrast)[col] = de;
-	Rast_put_row(outfd, outrast, out_data_type);
+        case CELL_TYPE:
+            break;
+        case FCELL_TYPE:
+            break;
+        case DCELL_TYPE:
+            break;
+        if (modis) {
+        else if (avhrr) {
+        else if (aster) {
+        if (flag6->answer || flag7->answer) {
+        /* Post-Process Albedo */
+        de = a * de + b;
+        ((DCELL *) outrast)[col] = de;
+    Rast_put_row(outfd, outrast, out_data_type);
-	G_free(inrast[i]);
-	Rast_close(infd[i]);
+    G_free(inrast[i]);
+    Rast_close(infd[i]);
     G_free(outrast);
     Rast_close(outfd);
