[GRASS-SVN] r60798 - grass-addons/grass7/raster/r.edm.eval
svn_grass at osgeo.org
Thu Jun 12 09:18:28 PDT 2014
Author: pvanbosgeo
Date: 2014-06-12 09:18:28 -0700 (Thu, 12 Jun 2014)
New Revision: 60798
grass-addons/grass7/raster/r.edm.eval/r.edm.eval
small corrections
Modified: grass-addons/grass7/raster/r.edm.eval/r.edm.eval
--- grass-addons/grass7/raster/r.edm.eval/r.edm.eval 2014-06-12 11:03:48 UTC (rev 60797)
+++ grass-addons/grass7/raster/r.edm.eval/r.edm.eval 2014-06-12 16:18:28 UTC (rev 60798)
@@ -394,6 +394,13 @@
if(preval>0){execGRASS("g.remove", rast=tmp.i)}
if(num.abs > 0 | num.pres > 0){execGRASS("g.remove", rast=tmp.j)}
+# the temporary files do not always get cleaned up, need to check why
+# this is a temporary fix!
+aa <- execGRASS("g.mlist", type="rast", pattern="tmp_r_model_evaluation_*", intern=TRUE)
+if(length(aa)>0){
+ execGRASS("g.mremove", rast="tmp_r_model_evaluation_*", flags="f")
# Calculate evaluation stats
a.cast <- cast(a, V2 ~ V1)
a.cast[] <- sapply(a.cast, function(x) replace(x,is.na(x),0))
@@ -439,8 +446,8 @@
cat(paste("log file =", paste(fnames, "log.txt", sep="_"))); cat("\n")
sink()
-b.stats <- cbind(roc.st[-1], a.stats)
-names(b.stats) <- c("steps", names(a.stats))
+b.stats <- cbind(sort(x2[-length(x2)], decreasing=TRUE), a.stats)
+names(b.stats) <- c("threshold", names(a.stats))
write.table(b.stats, file=paste(fnames, "stats.csv", sep="_"), append=TRUE, sep=";", row.names=FALSE)
EOF
