[GRASS-SVN] r60943 - grass-addons/grass7/raster/r.valley.bottom
Tue Jun 24 02:26:56 PDT 2014
Author: hellik
Date: 2014-06-24 02:26:56 -0700 (Tue, 24 Jun 2014)
New Revision: 60943
   grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: remove intermediate maps
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2014-06-24 08:20:29 UTC (rev 60942)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2014-06-24 09:26:56 UTC (rev 60943)
@@ -456,7 +456,7 @@
     grass.message( "----" )
 	# change resolution
-    grass.message( "Step 4: change to resolution to 3 x 3 step 3 resolution" )
+    grass.message( "Step 4: change to resolution to 3 x step 3 resolution" )
     grass.run_command('g.region', res = Xres_step4,
                                     flags = 'a')
@@ -572,9 +572,35 @@
     grass.message( "Step 4: Calculation of MRVBF4 done." )
+    # clean up some temporay files and maps
+    grass.message( "Some clean up ..." )
+    grass.run_command('g.remove', region = "base_region_MrVBF",
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["F1,F2,F3,F4"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["CF2,CF3,CF4"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["PCTL1,PCTL2,PCTL3,PCTL3_refined_base_resolution,PCTL4,PCTL4_refined_base_resolution"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["PVF1,PVF2,PVF3,PVF4"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["VF1,VF2,VF3,VF4"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["W2,W3,W4"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["r_slope_step1,r_slope_step3,r_slope_step4,r_slope_step4_refined_base_resolution"],
+                                     quiet = True)
+    grass.run_command('g.remove', rast = ["DEM_smoothed_step3,DEM_smoothed_step3_coarsed,DEM_smoothed_step4,DEM_smoothed_step4_coarsed"],
+                                     quiet = True)
+    grass.message( "Clean up done." )
+    grass.message( "----" )
+    # v.habitat.dem done!
+    grass.message( "r.valley.bottom done!" )
 if __name__ == "__main__":
     options, flags = grass.parser()
     sys.exit(main())
