[GRASS-SVN] r60944 - grass/trunk/lib/gis
Tue Jun 24 07:35:57 PDT 2014
Author: hcho
Date: 2014-06-24 07:35:57 -0700 (Tue, 24 Jun 2014)
New Revision: 60944
   grass/trunk/lib/gis/parser.c
   grass/trunk/lib/gis/parser_dependencies.c
libgis: G_parser() calls G__check_option_rules()
Modified: grass/trunk/lib/gis/parser.c
--- grass/trunk/lib/gis/parser.c	2014-06-24 09:26:56 UTC (rev 60943)
+++ grass/trunk/lib/gis/parser.c	2014-06-24 14:35:57 UTC (rev 60944)
@@ -277,15 +277,30 @@
  *  - G_define_module()
  *  - G_define_flag()
  *  - G_define_option()
+ *  - G_define_standard_flag()
  *  - G_define_standard_option()
  *  - G_disable_interactive()
+ *  - G_option_exclusive()
+ *  - G_option_required()
+ *  - G_option_requires()
+ *  - G_option_requires_all()
+ *  - G_option_excludes()
+ *  - G_option_collective()
  * The usual order a module calls functions is:
  *  # G_gisinit()
  *  # G_define_module()
+ *  # G_define_standard_flag()
+ *  # G_define_standard_option()
  *  # G_define_flag()
  *  # G_define_option()
+ *  # G_option_exclusive()
+ *  # G_option_required()
+ *  # G_option_requires()
+ *  # G_option_requires_all()
+ *  # G_option_excludes()
+ *  # G_option_collective()
  *  # G_parser()
  * \param argc number of arguments
@@ -560,6 +575,8 @@
     if (!st->suppress_required)
 	check_required();
+    G__check_option_rules();
     if (st->n_errors > 0) {
         if (G_verbose() > -1) {
             if (G_verbose() > G_verbose_min())
Modified: grass/trunk/lib/gis/parser_dependencies.c
--- grass/trunk/lib/gis/parser_dependencies.c	2014-06-24 09:26:56 UTC (rev 60943)
+++ grass/trunk/lib/gis/parser_dependencies.c	2014-06-24 14:35:57 UTC (rev 60944)
@@ -173,6 +173,12 @@
     return s;
+static void append_error(const char *msg)
+    st->error = G_realloc(st->error, sizeof(char *) * (st->n_errors + 1));
+    st->error[st->n_errors++] = G_store(msg);
 /* at most one option from a set */
 void G_option_exclusive(void *first, ...)
@@ -184,9 +190,12 @@
 static void check_exclusive(const struct rule *rule)
-    if (count_present(rule, 0) > 1)
-	G_fatal_error(_("Options %s are mutually exclusive"),
-		      describe_rule(rule, 0, 0));
+    if (count_present(rule, 0) > 1) {
+	char *err;
+	G_asprintf(&err, _("Options %s are mutually exclusive"),
+		   describe_rule(rule, 0, 0));
+	append_error(err);
 /* at least one option from a set */
@@ -200,9 +209,12 @@
 static void check_required(const struct rule *rule)
-    if (count_present(rule, 0) < 1)
-	G_fatal_error(_("At least one of %s is required"),
+    if (count_present(rule, 0) < 1) {
+	char *err;
+	G_asprintf(&err, _("At least one of %s is required"),
 /* if the first option is present, at least one of the other
@@ -219,9 +231,12 @@
     if (!is_present(rule->opts[0]))
 	return;
-    if (count_present(rule, 1) < 1)
-	G_fatal_error(_("Option %s requires at least one of %s"),
-		      get_name(rule->opts[0]), describe_rule(rule, 1, 1));
+    if (count_present(rule, 1) < 1) {
+	char *err;
+	G_asprintf(&err, _("Option %s requires at least one of %s"),
+		   get_name(rule->opts[0]), describe_rule(rule, 1, 1));
 /* if the first option is present, all the other options must also
@@ -238,9 +253,12 @@
 	return;
-    if (count_present(rule, 1) < rule->count - 1)
-	G_fatal_error(_("Option %s requires all of %s"),
-		      get_name(rule->opts[0]), describe_rule(rule, 1, 0));
+    if (count_present(rule, 1) < rule->count - 1) {
+	char *err;
+	G_asprintf(&err, _("Option %s requires all of %s"),
+		   get_name(rule->opts[0]), describe_rule(rule, 1, 0));
 /* if the first option is present, none of the other options may also
@@ -257,9 +275,12 @@
 	return;
-    if (count_present(rule, 1) > 0)
-	G_fatal_error(_("Option %s is mutually exclusive with all of %s"),
+    if (count_present(rule, 1) > 0) {
+	char *err;
+	G_asprintf(&err, _("Option %s is mutually exclusive with all of %s"),
 /* if any option is present, all the other options must also be present
@@ -275,9 +296,12 @@
 static void check_collective(const struct rule *rule)
     int count = count_present(rule, 0);
-    if (count > 0 && count < rule->count)
-	G_fatal_error(_("Either all or none of %s must be given"),
+    if (count > 0 && count < rule->count) {
+	char *err;
+	G_asprintf(&err, _("Either all or none of %s must be given"),
 void G__check_option_rules(void)
