[GRASS-SVN] r60950 - in sandbox/wenzeslaus/gunittest: . testsuite
svn_grass at osgeo.org
Tue Jun 24 12:59:46 PDT 2014
Author: wenzeslaus
Date: 2014-06-24 12:59:46 -0700 (Tue, 24 Jun 2014)
New Revision: 60950
sandbox/wenzeslaus/gunittest/case.py
sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
gunittest: common function for r.info, r.univar and other comparisons (following r60948 and unintentional r60949)
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py 2014-06-24 19:27:40 UTC (rev 60949)
+++ sandbox/wenzeslaus/gunittest/case.py 2014-06-24 19:59:46 UTC (rev 60950)
@@ -32,7 +32,12 @@
# we dissable R0904 for all TestCase classes because their purpose is to
# provide a lot of assert methods
# pylint: disable=R0904
+ Always use keyword arguments for all parameters other than first two. For
+ the firt two, it is recommened to use keyword arguments but not required.
def assertLooksLike(self, actual, reference, msg=None):
self.assert_(isinstance(actual, basestring), (
'actual argument is not a string'))
@@ -43,14 +48,15 @@
safe_repr(reference))
self.fail(self._formatMessage(msg, standardMsg))
- def assertWithCommandKeyValue(self, module, parameters, reference, msg=None):
+ def assertWithCommandKeyValue(self, module, parameters, reference,
+ msg=None, sep='='):
if isinstance(reference, basestring):
reference = text_to_keyvalue(reference, sep='=')
stdout = gcore.read_command(module, **parameters)
raster_univar = text_to_keyvalue(stdout, sep='=')
- if not compare_keyvalue(dict_a=reference_univar, dict_b=raster_univar,
+ if not compare_keyvalue(dict_a=reference, dict_b=raster_univar,
a_is_subset=True):
- unused, missing, mismatch = diff_keyvalue(dict_a=reference_univar,
+ unused, missing, mismatch = diff_keyvalue(dict_a=reference,
a_is_subset=True)
if missing:
@@ -63,32 +69,17 @@
standardMsg += "mismatch values: %s\n" % mismatch
- def assertRasterFitsUnivar(self, raster, reference_univar, msg=None):
- if isinstance(reference_univar, basestring):
- reference_univar = text_to_keyvalue(reference_univar, sep='=')
- stdout = gcore.read_command('r.univar',
- map=raster, separator='=', flags='ge')
- raster_univar = text_to_keyvalue(stdout, sep='=')
- a_is_subset=True):
- dict_b=raster_univar,
- a_is_subset=True)
- standardMsg = "r.univar difference:\n"
- if mismatch:
- standardMsg += "mismatch values: %s\n" % mismatch
- if missing:
- raise ValueError("r.univar output does not contain"
- " the following keys"
- " provided in reference_univar"
- ": %s\n" % missing)
- self.fail(self._formatMessage(msg, standardMsg))
+ def assertRasterFitsUnivar(self, raster, reference, msg=None):
+ self.assertWithCommandKeyValue(module='r.univar',
+ parameters=dict(map=raster,
+ separator='=',
+ flags='ge'),
+ reference=reference, msg=msg, sep='=')
def assertRasterFitsInfo(self, raster, reference, msg=None):
self.assertWithCommandKeyValue(module='r.info',
- parameters=dict('r.univar', map=raster,
- separator='=', flags='ge'),
- reference, msg)
+ parameters=dict(map=raster, flags='ge'),
# the following lines are for code coverage
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py 2014-06-24 19:27:40 UTC (rev 60949)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py 2014-06-24 19:59:46 UTC (rev 60950)
@@ -34,6 +34,11 @@
bbb=156.329864501953
+R_INFO_ELEVATION_SUBSET = """rows=1350
+cols=1500
+cells=2025000
+datatype=FCELL
class TestRasterMapAssertations(GrassTestCase):
@@ -46,8 +51,11 @@
self.assertRasterFitsUnivar,
'elevation', RANDOM_KEYVALUES)
- def test_assertRasterFitsInfo(self):
- self.assertRasterFitsInfo('elevation', R_UNIVAR_ELEVATION_SUBSET)
- self.assertRaises(self.failureException,
+ def test_assertRasterFitsInfo(self):
+ self.assertRasterFitsInfo('elevation', R_INFO_ELEVATION_SUBSET)
+ self.assertRaises(self.failureException,
self.assertRasterFitsInfo,
- 'aspect', R_UNIVAR_ELEVATION_SUBSET)
\ No newline at end of file
+ 'elev_lid792_1m', R_INFO_ELEVATION_SUBSET)
+ self.assertRaises(ValueError,
+ self.assertRasterFitsInfo,
+ 'elevation', RANDOM_KEYVALUES)
