[GRASS-SVN] r60951 - sandbox/annakrat/r3.flow
Tue Jun 24 20:49:21 PDT 2014
Author: annakrat
Date: 2014-06-24 20:49:21 -0700 (Tue, 24 Jun 2014)
New Revision: 60951
Added:
   sandbox/annakrat/r3.flow/gradient.py
r3.flow: gradient computation implemented
Added: sandbox/annakrat/r3.flow/gradient.py
--- sandbox/annakrat/r3.flow/gradient.py	                        (rev 0)
+++ sandbox/annakrat/r3.flow/gradient.py	2014-06-25 03:49:21 UTC (rev 60951)
@@ -0,0 +1,80 @@
+# -*- coding: utf-8 -*-
+ at brief Computing gradient
+ at author: Anna Petrasova
+import numpy as np
+import unittest
+def gradient(array, step):
+    """Computing gradient (second order approximation)
+    using central differencing scheme (plus forward and backward
+    difference of second order approx.)"""
+    size_z, size_y, size_x = array.shape
+    gradient_array_x = np.zeros(array.shape)
+    for depth in range(size_z):
+        for row in range(size_y):
+            col_array = array[depth, row, :]
+            gradient_array_x[depth, row, 0] = (-3 * col_array[0] +
+                                               4 * col_array[1] -
+                                               col_array[2]) / (2 * step[0])
+            gradient_array_x[depth, row, size_x - 1] = (col_array[size_x - 3] -
+                                                        4 * col_array[size_x - 2] +
+                                                        3 * col_array[size_x - 1]) / (2 * step[0])
+            for col in range(1, size_x - 1):
+                gradient_array_x[depth, row, col] = (col_array[col + 1] -
+                                                     col_array[col - 1]) / (2 * step[0])
+    gradient_array_y = np.zeros(array.shape)
+        for col in range(size_x):
+            row_array = array[depth, :, col]
+            gradient_array_y[depth, 0, col] = (-3 * row_array[0] +
+                                               4 * row_array[1] -
+                                               row_array[2]) / (2 * step[1])
+            gradient_array_y[depth, size_y - 1, col] = (row_array[size_y - 3] -
+                                                        4 * row_array[size_y - 2] +
+                                                        3 * row_array[size_y - 1]) / (2 * step[1])
+            for row in range(1, size_y - 1):
+                gradient_array_y[depth, row, col] = (row_array[row + 1] -
+                                                     row_array[row - 1]) / (2 * step[1])
+    gradient_array_z = np.zeros(array.shape)
+            depth_array = array[:, row, col]
+            gradient_array_z[0, row, col] = (-3 * depth_array[0] +
+                                             4 * depth_array[1] -
+                                             depth_array[2]) / (2 * step[2])
+            gradient_array_z[size_z - 1, row, col] = (depth_array[size_z - 3] -
+                                                      4 * depth_array[size_z - 2] +
+                                                      3 * depth_array[size_z - 1]) / (2 * step[2])
+            for depth in range(1, size_z - 1):
+                gradient_array_z[depth, row, col] = (depth_array[depth + 1] -
+                                                     depth_array[depth - 1]) / (2 * step[2])
+    return gradient_array_x, gradient_array_y, gradient_array_z
+class TestGradient(unittest.TestCase):
+    def test_gradient(self):
+        array = np.random.rand(10, 15, 3)
+        step = [2, 0.6, 1]
+        # numpy_gradient is function gradient which must be taken from numpy master branch
+        # https://github.com/numpy/numpy/blob/master/numpy/lib/function_base.py
+        # because 1.8 uses first order approx on edges, not second
+        numpy_gradient_z, numpy_gradient_y, numpy_gradient_x = numpy_gradient(array, step[2], step[1], step[0])
+        gradient_x, gradient_y, gradient_z = gradient(array, step)
+        self.assertEqual(True, np.allclose(gradient_z, numpy_gradient_z, atol=1e-8))
+        self.assertEqual(True, np.allclose(gradient_y, numpy_gradient_y, atol=1e-8))
+        self.assertEqual(True, np.allclose(gradient_x, numpy_gradient_x, atol=1e-8))
+if __name__ == '__main__':
+    unittest.main()
