[GRASS-SVN] r60952 - in sandbox/wenzeslaus/gunittest: . testsuite
Tue Jun 24 20:57:07 PDT 2014
Author: wenzeslaus
Date: 2014-06-24 20:57:07 -0700 (Tue, 24 Jun 2014)
New Revision: 60952
   sandbox/wenzeslaus/gunittest/case.py
   sandbox/wenzeslaus/gunittest/grass_py_static_check.py
   sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
   sandbox/wenzeslaus/gunittest/testsuite/test_checkers.py
gunittest: assertaion for vector map based on v.univar
Modified: sandbox/wenzeslaus/gunittest/case.py
--- sandbox/wenzeslaus/gunittest/case.py	2014-06-25 03:49:21 UTC (rev 60951)
+++ sandbox/wenzeslaus/gunittest/case.py	2014-06-25 03:57:07 UTC (rev 60952)
@@ -27,7 +27,6 @@
 cov = coverage.coverage(omit="*testsuite*")
 cov.start()
 class GrassTestCase(unittest.TestCase):
     # we dissable R0904 for all TestCase classes because their purpose is to
     # provide a lot of assert methods
@@ -48,12 +47,12 @@
        safe_repr(reference))
             self.fail(self._formatMessage(msg, standardMsg))
-    def assertWithCommandKeyValue(self, module, parameters, reference,
-                                  msg=None, sep='='):
+    def assertCommandKeyValue(self, module, parameters, reference, sep,
+                              msg=None):
         if isinstance(reference, basestring):
-            reference = text_to_keyvalue(reference, sep='=')
+            reference = text_to_keyvalue(reference, sep=sep)
         stdout = gcore.read_command(module, **parameters)
-        raster_univar = text_to_keyvalue(stdout, sep='=')
+        raster_univar = text_to_keyvalue(stdout, sep=sep)
         if not compare_keyvalue(dict_a=reference, dict_b=raster_univar,
                                 a_is_subset=True):
             unused, missing, mismatch = diff_keyvalue(dict_a=reference,
@@ -62,26 +61,45 @@
             if missing:
                 raise ValueError("%s output does not contain"
                                  " the following keys"
-                                 " provided in reference_univar"
-                                 ": %s\n" % (module, missing))
+                                 " provided in reference"
+                                 ": %s\n" % (module, ", ".join(missing)))
             standardMsg = "%s difference:\n" % module
             if mismatch:
                 standardMsg += "mismatch values: %s\n" % mismatch
     def assertRasterFitsUnivar(self, raster, reference, msg=None):
-        self.assertWithCommandKeyValue(module='r.univar',
-                                       parameters=dict(map=raster,
-                                                       separator='=',
-                                                       flags='ge'),
-                                       reference=reference, msg=msg, sep='=')
+        self.assertCommandKeyValue(module='r.univar',
+                                   parameters=dict(map=raster,
+                                                   separator='=',
+                                                   flags='g'),
+                                   reference=reference, msg=msg, sep='=')
     def assertRasterFitsInfo(self, raster, reference, msg=None):
-        self.assertWithCommandKeyValue(module='r.info',
-                                       parameters=dict(map=raster, flags='ge'),
+        self.assertCommandKeyValue(module='r.info',
+                                   parameters=dict(map=raster, flags='g'),
+    def assertVectorFitsUnivar(self, map, column, reference, msg=None,
+                               layer=None, type=None, where=None):
+        Use keyword arguments syntax for all function parameters.
+        Does not support -d (geometry distances) flag, -e (extended statistics)
+        flag and few other, use `assertCommandKeyValue` for the full interface.
+        parameters = dict(map=map, column=column, flags='g')
+        if layer:
+            parameters.update(layer=layer)
+        if type:
+            parameters.update(type=type)
+        if where:
+            parameters.update(where=where)
+        self.assertCommandKeyValue(module='v.univar',
+                                   parameters=parameters,
 # the following lines are for code coverage
 def endcov(cov):
     cov.stop()
Modified: sandbox/wenzeslaus/gunittest/grass_py_static_check.py
--- sandbox/wenzeslaus/gunittest/grass_py_static_check.py	2014-06-25 03:49:21 UTC (rev 60951)
+++ sandbox/wenzeslaus/gunittest/grass_py_static_check.py	2014-06-25 03:57:07 UTC (rev 60952)
@@ -163,7 +163,7 @@
     # a lot of special treatment is needed to get packages nicely shown
     grass_packages = ['script', 'pygrass', 'temporal']
-                     #, 'imaging', 'pydispatch', 'lib']
+    # not included: 'imaging', 'pydispatch', 'lib'
     ensure_dir('pylint_report/grass')
     index = open('pylint_report/grass/index.html', 'w')
     for package in grass_packages:
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py	2014-06-25 03:49:21 UTC (rev 60951)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_assertions.py	2014-06-25 03:57:07 UTC (rev 60952)
@@ -19,8 +19,9 @@
         self.assertLooksLike("Generated map is <elevation>",
                              "Generated map is <...>")
         self.assertRaises(self.failureException,
-                          self.assertLooksLike, "Generated map is elevation.",
-                                                "Generated map is <...>")
+                          self.assertLooksLike,
+                          "Generated map is elevation.",
+                          "Generated map is <...>")
 R_UNIVAR_ELEVATION_SUBSET = """n=2025000
@@ -40,6 +41,16 @@
 datatype=FCELL
+V_UNIVAR_BRIDGES_WIDTH_SUBSET = """n=10938
+nmissing=0
+nnull=0
+min=0
+max=1451
+range=1451
+sum=2.6299e+06
+mean=240.437
 class TestRasterMapAssertations(GrassTestCase):
     # pylint: disable=R0904
     def test_assertRasterFitsUnivar(self):
@@ -59,3 +70,18 @@
         self.assertRaises(ValueError,
                           self.assertRasterFitsInfo,
                           'elevation', RANDOM_KEYVALUES)
+class TestVectorMapAssertations(GrassTestCase):
+    # pylint: disable=R0904
+    def test_assertVectorFitsUnivar(self):
+        self.assertVectorFitsUnivar(map='bridges', column='WIDTH',
+                                    reference=V_UNIVAR_BRIDGES_WIDTH_SUBSET)
+        self.assertRaises(self.failureException,
+                          self.assertVectorFitsUnivar,
+                          map='bridges', column='YEAR_BUILT',
+        self.assertRaises(ValueError,
+                          map='bridges', column='WIDTH',
+                          reference=RANDOM_KEYVALUES)
Modified: sandbox/wenzeslaus/gunittest/testsuite/test_checkers.py
--- sandbox/wenzeslaus/gunittest/testsuite/test_checkers.py	2014-06-25 03:49:21 UTC (rev 60951)
+++ sandbox/wenzeslaus/gunittest/testsuite/test_checkers.py	2014-06-25 03:57:07 UTC (rev 60952)
@@ -230,11 +230,11 @@
 class TestParseKeyvalue(GrassTestCase):
     def test_shell_script_style(self):
         self.assertDictEqual(parse_key_val(R_UNIVAR_KEYVAL_INT, val_type=int),
-                                           R_UNIVAR_KEYVAL_INT_DICT)
+                             R_UNIVAR_KEYVAL_INT_DICT)
 R_UNIVAR_ELEVATION = """n=2025000
@@ -300,7 +300,7 @@
                                                           sep='='),
                                          a_is_subset=True))
         self.assertFalse(compare_keyvalue(text_to_keyvalue(R_UNIVAR_ELEVATION,
-                                                          sep='='),
+                                                           sep='='),
                                           text_to_keyvalue(R_UNIVAR_ELEVATION_SUBSET,
                                                            sep='='),
                                           a_is_subset=True))
