[GRASS-SVN] r60980 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Thu Jun 26 06:32:32 PDT 2014
Author: lucadelu
Date: 2014-06-26 06:32:32 -0700 (Thu, 26 Jun 2014)
New Revision: 60980
grass/trunk/gui/wxpython/xml/menudata.README
wxgui: update readme how to add new item in the menu
Modified: grass/trunk/gui/wxpython/xml/menudata.README
--- grass/trunk/gui/wxpython/xml/menudata.README 2014-06-26 04:17:20 UTC (rev 60979)
+++ grass/trunk/gui/wxpython/xml/menudata.README 2014-06-26 13:32:32 UTC (rev 60980)
@@ -1,31 +1,3 @@
-menudata.xml is in part maintained by this script:
- gui/wxpython/tools/update_menudata.py
+Find more info about how to add item in the menu:
+http://grass.osgeo.org/programming7/wxguitoolboxes.html
-which updates the description and keywords (based on module's
-module->label or module->description, module->keywords), and is in
-part maintained by editing the file directly.
-Other items (menu structure, menu item label descriptions) are
-untouched by the update_menudata.py script and should be edited
-in the menudata.xml file directly.
-menuitem breakdown:
-<command> The name of the executable. e.g. "r.info".
-<label> The menu short description. [maintained in this file]
-<handler> The python function that handles the command.
- e.g.OnMenuCmd, many others..
-<help> automatically populated by update_menudata.py from
- the <command> module's module->description (or if
- it exists, module->label). [do not edit]
-<keywords> automatically populated by update_menudata.py from
- the <command> module's module->keywords. [do not edit]
- (G_add_keyword() in GRASS 7+)
-<icon> optional icon to be shown in the menu
