[GRASS-SVN] r60981 - in grass/trunk/gui/wxpython: . docs tplot xml
svn_grass at osgeo.org
Thu Jun 26 06:50:20 PDT 2014
Author: lucadelu
Date: 2014-06-26 06:50:20 -0700 (Thu, 26 Jun 2014)
New Revision: 60981
Added:
grass/trunk/gui/wxpython/tplot/
grass/trunk/gui/wxpython/tplot/Makefile
grass/trunk/gui/wxpython/tplot/__init__.py
grass/trunk/gui/wxpython/tplot/frame.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.html
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
grass/trunk/gui/wxpython/tplot/tplot.png
grass/trunk/gui/wxpython/Makefile
grass/trunk/gui/wxpython/docs/wxGUI.components.html
grass/trunk/gui/wxpython/xml/toolboxes.xml
wxgui: add new tool to plot the values of temporal datasets for a queried point
Modified: grass/trunk/gui/wxpython/Makefile
--- grass/trunk/gui/wxpython/Makefile 2014-06-26 13:32:32 UTC (rev 60980)
+++ grass/trunk/gui/wxpython/Makefile 2014-06-26 13:50:20 UTC (rev 60981)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass gcp timeline
+SUBDIRS = docs animation mapswipe gmodeler rlisetup psmap dbmgr vdigit iclass gcp timeline tplot
EXTRA_CLEAN_FILES = menustrings.py build_ext.pyc xml/menudata.xml xml/module_tree_menudata.xml
include $(MODULE_TOPDIR)/include/Make/Dir.make
@@ -13,7 +13,7 @@
$(wildcard animation/* core/*.py dbmgr/* gcp/*.py gmodeler/* \
gui_core/*.py iclass/* lmgr/*.py location_wizard/*.py mapwin/*.py mapdisp/*.py \
mapswipe/* modules/*.py nviz/*.py psmap/* rlisetup/* timeline/* vdigit/* \
- vnet/*.py web_services/*.py wxplot/*.py iscatt/*.py) \
+ vnet/*.py web_services/*.py wxplot/*.py iscatt/*.py tplot/*) \
gis_set.py gis_set_error.py wxgui.py README
DSTFILES := $(patsubst %,$(DSTDIR)/%,$(SRCFILES)) \
@@ -21,7 +21,7 @@
PYDSTDIRS := $(patsubst %,$(DSTDIR)/%,animation core dbmgr gcp gmodeler \
gui_core iclass lmgr location_wizard mapwin mapdisp modules nviz psmap \
- mapswipe vdigit wxplot web_services rlisetup vnet timeline iscatt)
+ mapswipe vdigit wxplot web_services rlisetup vnet timeline iscatt tplot)
DSTDIRS := $(patsubst %,$(DSTDIR)/%,icons scripts xml)
Modified: grass/trunk/gui/wxpython/docs/wxGUI.components.html
--- grass/trunk/gui/wxpython/docs/wxGUI.components.html 2014-06-26 13:32:32 UTC (rev 60980)
+++ grass/trunk/gui/wxpython/docs/wxGUI.components.html 2014-06-26 13:50:20 UTC (rev 60981)
@@ -23,6 +23,8 @@
<li>Configuration tool for r.li modules, <em><a href="g.gui.rlisetup.html">g.gui.rlisetup</a></em></li>
<li><a href="wxGUI.timeline.html">Timeline Tool</a>,
available also as a command line tool <em><a href="g.gui.timeline.html">g.gui.timeline</a></em></li>
+ <li><a href="wxGUI.tplot.html">Temporal Plot Tool</a>,
+ available also as a command line tool <em><a href="g.gui.tplot.html">g.gui.tplot</a></em></li>
<li><a href="wxGUI.vdigit.html">Vector Digitizer</a>,
available also as a command line tool <em><a href="g.gui.vdigit.html">g.gui.vdigit</a></em></li>
<li><a href="wxGUI.vnet.html">Vector Network Analysis Tool</a></li>
Added: grass/trunk/gui/wxpython/tplot/Makefile
--- grass/trunk/gui/wxpython/tplot/Makefile (rev 0)
+++ grass/trunk/gui/wxpython/tplot/Makefile 2014-06-26 13:50:20 UTC (rev 60981)
@@ -0,0 +1,5 @@
+MODULE_TOPDIR = ../../..
+include $(MODULE_TOPDIR)/include/Make/GuiScript.make
+default: guiscript
Property changes on: grass/trunk/gui/wxpython/tplot/Makefile
___________________________________________________________________
Added: svn:mime-type
+ text/x-makefile
Added: svn:eol-style
+ native
Added: grass/trunk/gui/wxpython/tplot/__init__.py
--- grass/trunk/gui/wxpython/tplot/__init__.py (rev 0)
+++ grass/trunk/gui/wxpython/tplot/__init__.py 2014-06-26 13:50:20 UTC (rev 60981)
@@ -0,0 +1,4 @@
+all = [
+ 'g.gui.tplot',
+ 'frame',
Property changes on: grass/trunk/gui/wxpython/tplot/__init__.py
+ text/x-python
+ native
Added: grass/trunk/gui/wxpython/tplot/frame.py
--- grass/trunk/gui/wxpython/tplot/frame.py (rev 0)
+++ grass/trunk/gui/wxpython/tplot/frame.py 2014-06-26 13:50:20 UTC (rev 60981)
@@ -0,0 +1,636 @@
+ at package frame
+ at brief Temporal Plot Tool
+Classes:
+ - frame::DataCursor
+ - frame::TplotFrame
+ - frame::LookUp
+(C) 2012-2014 by the GRASS Development Team
+This program is free software under the GNU General Public License
+(>=v2). Read the file COPYING that comes with GRASS for details.
+ at author Luca Delucchi
+from itertools import cycle
+import numpy as np
+import wx
+try:
+ import matplotlib
+ # The recommended way to use wx with mpl is with the WXAgg
+ # backend.
+ matplotlib.use('WXAgg')
+ from matplotlib.figure import Figure
+ from matplotlib.backends.backend_wxagg import \
+ FigureCanvasWxAgg as FigCanvas, \
+ NavigationToolbar2WxAgg as NavigationToolbar
+ import matplotlib.dates as mdates
+ from matplotlib import cbook
+except ImportError:
+ raise ImportError(_('The Temporal Plot Tool needs the "matplotlib" '
+ '(python-matplotlib) package to be installed.'))
+from core.utils import _
+import grass.temporal as tgis
+from core.gcmd import GError, GException, RunCommand
+from gui_core import gselect
+from core import globalvar
+from grass.pygrass.vector.geometry import Point
+from grass.pygrass.raster import RasterRow
+from collections import OrderedDict
+ALPHA = 0.5
+COLORS = ['b', 'g', 'r', 'c', 'm', 'y', 'k']
+def check_version(*version):
+ """Checks if given version or newer is installed"""
+ versionInstalled = []
+ for i in matplotlib.__version__.split('.'):
+ try:
+ v = int(i)
+ versionInstalled.append(v)
+ except ValueError:
+ versionInstalled.append(0)
+ if versionInstalled < list(version):
+ return False
+ else:
+ return True
+class TplotFrame(wx.Frame):
+ """The main frame of the application"""
+ def __init__(self, parent):
+ wx.Frame.__init__(self, parent, id=wx.ID_ANY,
+ title=_("GRASS GIS Temporal Plot Tool"))
+ tgis.init(True)
+ self.datasets = []
+ self.timeData = {}
+ self._layout()
+ self.temporalType = None
+ self.unit = None
+ # We create a database interface here to speedup the GUI
+ self.dbif = tgis.SQLDatabaseInterfaceConnection()
+ self.dbif.connect()
+ def __del__(self):
+ """Close the database interface and stop the messenger and C-interface
+ subprocesses.
+ if self.dbif.connected is True:
+ self.dbif.close()
+ tgis.stop_subprocesses()
+ def _layout(self):
+ """Creates the main panel with all the controls on it:
+ * mpl canvas
+ * mpl navigation toolbar
+ * Control panel for interaction
+ self.panel = wx.Panel(self)
+ # Create the mpl Figure and FigCanvas objects.
+ # 5x4 inches, 100 dots-per-inch
+ # color = wx.SystemSettings.GetColour(wx.SYS_COLOUR_BACKGROUND)
+ self.fig = Figure((5.0, 4.0), facecolor=(1, 1, 1))
+ self.canvas = FigCanvas(self.panel, wx.ID_ANY, self.fig)
+ # axes are initialized later
+ self.axes2d = None
+ self.axes3d = None
+ # Create the navigation toolbar, tied to the canvas
+ self.toolbar = NavigationToolbar(self.canvas)
+ # Layout
+ self.vbox = wx.BoxSizer(wx.VERTICAL)
+ self.vbox.Add(self.canvas, 1, wx.LEFT | wx.TOP | wx.EXPAND)
+ self.vbox.Add(self.toolbar, 0, wx.EXPAND)
+ self.vbox.AddSpacer(10)
+ gridSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ self.datasetSelect = gselect.Select(parent=self.panel, id=wx.ID_ANY,
+# size=globalvar.DIALOG_GSELECT_SIZE,
+ type='stds', size=(150, -1))
+ self.drawButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Draw"))
+ self.drawButton.Bind(wx.EVT_BUTTON, self.OnRedraw)
+ self.helpButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Help"))
+ self.helpButton.Bind(wx.EVT_BUTTON, self.OnHelp)
+# self.view3dCheck = wx.CheckBox(self.panel, id=wx.ID_ANY,
+# label=_("3D plot of queried data"))
+# self.view3dCheck.Bind(wx.EVT_CHECKBOX, self.OnRedraw)
+# if not check_version(1, 0, 0):
+# self.view3dCheck.SetLabel(_("3D plot of queried data "
+# "(matplotlib >= 1.0.0)"))
+# self.view3dCheck.Disable()
+ self.xcoor = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=_('Insert longitude (x) coordinate'))
+ self.xcoorval = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY,
+ size=(150, -1))
+ self.ycoor = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
+ label=_('Insert latitude (y) coordinate'))
+ self.ycoorval = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY,
+ size=(150, -1))
+ gridSizer.Add(wx.StaticText(self.panel, id=wx.ID_ANY,
+ label=_("Select space time dataset(s):")),
+ pos=(0, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ gridSizer.Add(self.datasetSelect, pos=(1, 0), flag=wx.EXPAND)
+ gridSizer.Add(self.xcoor, pos=(2, 0), flag=wx.EXPAND)
+ gridSizer.Add(self.ycoor, pos=(2, 1), flag=wx.EXPAND)
+ gridSizer.Add(self.xcoorval, pos=(3, 0), flag=wx.EXPAND)
+ gridSizer.Add(self.ycoorval, pos=(3, 1), flag=wx.EXPAND)
+ gridSizer.Add(self.drawButton, pos=(3, 2), flag=wx.EXPAND)
+ gridSizer.Add(self.helpButton, pos=(3, 3), flag=wx.EXPAND)
+# gridSizer.Add(self.view3dCheck, pos=(4, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ self.vbox.Add(gridSizer, proportion=0, flag=wx.EXPAND | wx.ALL,
+ border=10)
+ self.panel.SetSizer(self.vbox)
+ self.vbox.Fit(self)
+ def _getData(self, timeseries):
+ """Load data and read properties
+ :param list timeseries: a list of timeseries
+ self.timeData = OrderedDict()
+ mode = None
+ unit = None
+ columns = ','.join(['name', 'start_time', 'end_time'])
+ for series in timeseries:
+ name = series[0]
+ fullname = name + '@' + series[1]
+ etype = series[2]
+ sp = tgis.dataset_factory(etype, fullname)
+ sp.select(dbif=self.dbif)
+ self.timeData[name] = OrderedDict()
+ if not sp.is_in_db(dbif=self.dbif):
+ GError(self, message=_("Dataset <%s> not found in temporal "
+ "database") % (fullname))
+ return
+ self.timeData[name]['temporalDataType'] = etype
+ self.timeData[name]['temporalType'] = sp.get_temporal_type()
+ self.timeData[name]['granularity'] = sp.get_granularity()
+ if mode is None:
+ mode = self.timeData[name]['temporalType']
+ elif self.timeData[name]['temporalType'] != mode:
+ GError(parent=self, message=_("Datasets have different temporal"
+ " type (absolute x relative), "
+ "which is not allowed."))
+ return
+ # check topology
+ maps = sp.get_registered_maps_as_objects(dbif=self.dbif)
+ self.timeData[name]['validTopology'] = sp.check_temporal_topology(maps=maps, dbif=self.dbif)
+ self.timeData[name]['unit'] = None # only with relative
+ if self.timeData[name]['temporalType'] == 'relative':
+ start, end, self.timeData[name]['unit'] = sp.get_relative_time()
+ if unit is None:
+ unit = self.timeData[name]['unit']
+ elif self.timeData[name]['unit'] != unit:
+ GError(self, _("Datasets have different time unit which "
+ "is not allowed."))
+ return
+ rows = sp.get_registered_maps(columns=columns, where=None,
+ order='start_time', dbif=self.dbif)
+ for row in rows:
+ self.timeData[name][row[0]] = {}
+ self.timeData[name][row[0]]['start_datetime'] = row[1]
+ self.timeData[name][row[0]]['end_datetime'] = row[2]
+ r = RasterRow(row[0])
+ r.open()
+ val = r.get_value(self.poi)
+ r.close()
+ self.timeData[name][row[0]]['value'] = val
+ self.unit = unit
+ self.temporalType = mode
+ return
+ def _draw3dFigure(self):
+ """Draws 3d view (spatio-temporal extents).
+ Only for matplotlib versions >= 1.0.0.
+ Earlier versions cannot draw time ticks and alpha
+ and it has a slightly different API.
+ pass
+# self.axes3d.clear()
+# self.axes3d.grid(False)
+# # self.axes3d.grid(True)
+# if self.temporalType == 'absolute':
+# if check_version(1, 1, 0):
+# self.axes3d.zaxis_date()
+# convert = mdates.date2num
+# else:
+# convert = lambda x: x
+# colors = cycle(COLORS)
+# plots = []
+# for name in self.datasets:
+# name = name[0] + '@' + name[1]
+# startZ = convert(self.timeData[name]['start_datetime'])
+# mapType = self.timeData[name]['temporalMapType']
+# if mapType == 'interval':
+# dZ = convert(self.timeData[name]['end_datetime']) - startZ
+# else:
+# dZ = [0] * len(startZ)
+# startX = self.timeData[name]['west']
+# dX = self.timeData[name]['east'] - np.array(startX)
+# startY = self.timeData[name]['south']
+# dY = self.timeData[name]['north'] - np.array(startY)
+# color = colors.next()
+# plots.append(self.axes3d.bar3d(startX, startY, startZ, dX, dY, dZ,
+# color=color, alpha=ALPHA))
+# params = grass.read_command('g.proj', flags='g')
+# params = grass.parse_key_val(params)
+# if 'unit' in params:
+# self.axes3d.set_xlabel(_("X [%s]") % params['unit'])
+# self.axes3d.set_ylabel(_("Y [%s]") % params['unit'])
+# else:
+# self.axes3d.set_xlabel(_("X"))
+# self.axes3d.set_ylabel(_("Y"))
+# self.axes3d.set_zlabel(_('Time'))
+# self.axes3d.mouse_init()
+# self.canvas.draw()
+ def _draw2dFigure(self):
+ """Draws or print 2D plot (temporal extents)"""
+ self.axes2d.clear()
+ self.axes2d.grid(False)
+ if self.temporalType == 'absolute':
+ self.axes2d.xaxis_date()
+ self.fig.autofmt_xdate()
+ self.convert = mdates.date2num
+ self.invconvert = mdates.num2date
+ else:
+ self.convert = lambda x: x
+ self.invconvert = self.convert
+ colors = cycle(COLORS)
+ yticksNames = []
+ yticksPos = []
+ plots = []
+ lookUp = LookUp(self.timeData, self.invconvert)
+ for i, name in enumerate(self.datasets):
+ fullname = name[0] + '@' + name[1]
+ name = name[0]
+ yticksNames.append(name) # just name; with mapset it would be long
+ yticksPos.append(i)
+ xdata = []
+ ydata = []
+ for keys, values in self.timeData[name].iteritems():
+ if keys in ['temporalType', 'granularity', 'validTopology',
+ 'unit', 'temporalDataType']:
+ continue
+ xdata.append(self.convert(values['start_datetime']))
+ ydata.append(values['value'])
+ lookUp.AddDataset(yranges=ydata, xranges=xdata, datasetName=name)
+ color = colors.next()
+ plots.append(self.axes2d.plot(xdata, ydata, marker='o',
+ color=color, label=name)[0])
+ self.axes2d.set_xlabel(_("Temporal resolution: %s" % self.timeData[name]['granularity']))
+ else:
+ self.axes2d.set_xlabel(_("Time [%s]") % self.unit)
+ self.axes2d.set_ylabel(', '.join(yticksNames))
+ #legend
+ handles, labels = self.axes2d.get_legend_handles_labels()
+ self.axes2d.legend()
+ if self.output:
+ self.canvas.print_figure(filename=self.output, dpi=self.dpi)
+ else:
+ self.canvas.draw()
+ DataCursor(plots, lookUp, InfoFormat, self.convert)
+ def OnRedraw(self, event):
+ """Required redrawing."""
+ datasets = self.datasetSelect.GetValue().strip()
+ if not datasets:
+ return
+ datasets = datasets.split(',')
+ try:
+ datasets = self._checkDatasets(datasets)
+ if not datasets:
+ return
+ except GException:
+ GError(parent=self, message=_("Invalid input data"))
+ return
+ self.datasets = datasets
+ coors = [self.xcoorval.GetValue().strip(),
+ self.ycoorval.GetValue().strip()]
+ if coors:
+ try:
+ self.poi = Point(float(coors[0]), float(coors[1]))
+ GError(parent=self, message=_("Invalid input coordinates"))
+ return
+ self._redraw()
+ def _redraw(self):
+ """Readraw data.
+ Decides if to draw also 3D and adjusts layout if needed.
+ self._getData(self.datasets)
+ # axes3d are physically removed
+ if not self.axes2d:
+ self.axes2d = self.fig.add_subplot(1, 1, 1)
+ self._draw2dFigure()
+# if check_version(1, 0, 0):
+# if self.view3dCheck.IsChecked():
+# self.axes2d.change_geometry(2, 1, 1)
+# if not self.axes3d:
+# # do not remove this import - unused but it is required for 3D
+# from mpl_toolkits.mplot3d import Axes3D # pylint: disable=W0611
+# self.axes3d = self.fig.add_subplot(2, 1, 2, projection='3d')
+# self.axes3d.set_visible(True)
+# self._draw3dFigure()
+# else:
+# if self.axes3d:
+# self.fig.delaxes(self.axes3d)
+# self.axes3d = None
+# self.axes2d.change_geometry(1, 1, 1)
+ def _checkDatasets(self, datasets):
+ """Checks and validates datasets.
+ Reports also type of dataset (e.g. 'strds').
+ :param list datasets: list of temporal dataset's name
+ :return: (mapName, mapset, type)
+ validated = []
+ tDict = tgis.tlist_grouped('stds', group_type=True, dbif=self.dbif)
+ # nested list with '(map, mapset, etype)' items
+ allDatasets = [[[(map, mapset, etype) for map in maps]
+ for etype, maps in etypesDict.iteritems()]
+ for mapset, etypesDict in tDict.iteritems()]
+ # flatten this list
+ if allDatasets:
+ allDatasets = reduce(lambda x, y: x + y, reduce(lambda x, y: x + y,
+ allDatasets))
+ mapsets = tgis.get_tgis_c_library_interface().available_mapsets()
+ allDatasets = [i for i in sorted(allDatasets,
+ key=lambda l: mapsets.index(l[1]))]
+ for dataset in datasets:
+ errorMsg = _("Space time dataset <%s> not found.") % dataset
+ if dataset.find("@") >= 0:
+ nameShort, mapset = dataset.split('@', 1)
+ indices = [n for n, (mapName, mapsetName, etype) in enumerate(allDatasets)
+ if nameShort == mapName and mapsetName == mapset]
+ else:
+ indices = [n for n, (mapName, mapset, etype) in enumerate(allDatasets)
+ if dataset == mapName]
+ if len(indices) == 0:
+ raise GException(errorMsg)
+ elif len(indices) >= 2:
+ dlg = wx.SingleChoiceDialog(self,
+ message=_("Please specify the "
+ "space time dataset "
+ "<%s>." % dataset),
+ caption=_("Ambiguous dataset name"),
+ choices=[("%(map)s@%(mapset)s:"
+ " %(etype)s" % {'map': allDatasets[i][0],
+ 'mapset': allDatasets[i][1],
+ 'etype': allDatasets[i][2]})
+ for i in indices],
+ style=wx.CHOICEDLG_STYLE | wx.OK)
+ if dlg.ShowModal() == wx.ID_OK:
+ index = dlg.GetSelection()
+ validated.append(allDatasets[indices[index]])
+ else:
+ continue
+ else:
+ validated.append(allDatasets[indices[0]])
+ return validated
+ def OnHelp(self, event):
+ """Function to show help"""
+ RunCommand('g.manual', quiet=True, entry='g.gui.tplot')
+ def SetDatasets(self, datasets, coors, output, dpi):
+ """Set the data
+ :param list datasets: a list of temporal dataset's name
+ :param list coors: a list with x/y coordinates
+ :param str output: the name of output png file
+ :param int dpi: the dpi value for png file
+ if not datasets or not coors:
+ return
+ try:
+ if not datasets:
+ return
+ GError(parent=self, message=_("Invalid input temporal dataset"))
+ return
+ try:
+ return
+ self.output = output
+ self.dpi = dpi
+ self.datasetSelect.SetValue(','.join(map(lambda x: x[0] + '@' + x[1],
+ datasets)))
+ self.xcoorval.SetValue(str(coors[0]))
+ self.ycoorval.SetValue(str(coors[1]))
+ self._redraw()
+# def Show3D(self, show):
+# """Show also 3D if possible"""
+# self.view3dCheck.SetValue(show)
+class LookUp:
+ """Helper class for searching info by coordinates"""
+ def __init__(self, timeData, convert):
+ self.data = {}
+ self.timeData = timeData
+ self.convert = convert
+ def AddDataset(self, yranges, xranges, datasetName):
+ if len(yranges) != len(xranges):
+ GError(parent=self, message=_("Datasets have different number of"
+ "values"))
+ self.data[datasetName] = {}
+ for i in range(len(xranges)):
+ self.data[datasetName][xranges[i]] = yranges[i]
+ def GetInformation(self, x):
+ values = {}
+ for key, value in self.data.iteritems():
+ if value[x]:
+ values[key] = [self.convert(x), value[x]]
+ if len(values) == 0:
+ return None
+ return self.timeData, values
+def InfoFormat(timeData, values):
+ """Formats information about dataset"""
+ text = []
+ for key, val in values.iteritems():
+ etype = timeData[key]['temporalDataType']
+ if etype == 'strds':
+ text.append(_("Space time raster dataset: %s") % key)
+ elif etype == 'stvds':
+ text.append(_("Space time vector dataset: %s") % key)
+ elif etype == 'str3ds':
+ text.append(_("Space time 3D raster dataset: %s") % key)
+ text.append(_("Value for {date} is {val}".format(date=val[0], val=val[1])))
+ text.append('\n')
+ text.append(_("Press Del to dismiss."))
+ return '\n'.join(text)
+class DataCursor(object):
+ """A simple data cursor widget that displays the x,y location of a
+ matplotlib artist when it is selected.
+ Source: http://stackoverflow.com/questions/4652439/
+ is-there-a-matplotlib-equivalent-of-matlabs-datacursormode/4674445
+ def __init__(self, artists, lookUp, formatFunction, convert,
+ tolerance=5, offsets=(-30, 20), display_all=False):
+ """Create the data cursor and connect it to the relevant figure.
+ "artists" is the matplotlib artist or sequence of artists that will be
+ selected.
+ "tolerance" is the radius (in points) that the mouse click must be
+ within to select the artist.
+ "offsets" is a tuple of (x,y) offsets in points from the selected
+ point to the displayed annotation box
+ "display_all" controls whether more than one annotation box will
+ be shown if there are multiple axes. Only one will be shown
+ per-axis, regardless.
+ self.lookUp = lookUp
+ self.formatFunction = formatFunction
+ self.offsets = offsets
+ self.display_all = display_all
+ if not cbook.iterable(artists):
+ artists = [artists]
+ self.artists = artists
+ self.axes = tuple(set(art.axes for art in self.artists))
+ self.figures = tuple(set(ax.figure for ax in self.axes))
+ self.annotations = {}
+ for ax in self.axes:
+ self.annotations[ax] = self.annotate(ax)
+ for artist in self.artists:
+ artist.set_picker(tolerance)
+ for fig in self.figures:
+ fig.canvas.mpl_connect('pick_event', self)
+ fig.canvas.mpl_connect('key_press_event', self.keyPressed)
+ def keyPressed(self, event):
+ """Key pressed - hide annotation if Delete was pressed"""
+ if event.key != 'delete':
+ return
+ self.annotations[ax].set_visible(False)
+ event.canvas.draw()
+ def annotate(self, ax):
+ """Draws and hides the annotation box for the given axis "ax"."""
+ annotation = ax.annotate(self.formatFunction, xy=(0, 0), ha='center',
+ xytext=self.offsets, va='bottom',
+ textcoords='offset points',
+ bbox=dict(boxstyle='round,pad=0.5',
+ fc='yellow', alpha=0.7),
+ arrowprops=dict(arrowstyle='->',
+ connectionstyle='arc3,rad=0'),
+ annotation_clip=False, multialignment='left')
+ annotation.set_visible(False)
+ return annotation
+ def __call__(self, event):
+ """Intended to be called through "mpl_connect"."""
+ # Rather than trying to interpolate, just display the clicked coords
+ # This will only be called if it's within "tolerance", anyway.
+ x, y = event.mouseevent.xdata, event.mouseevent.ydata
+ annotation = self.annotations[event.artist.axes]
+ if x is not None:
+ if not self.display_all:
+ # Hide any other annotation boxes...
+ for ann in self.annotations.values():
+ ann.set_visible(False)
+ if 'Line2D' in str(type(event.artist)):
+ xData = []
+ for a in event.artist.get_xdata():
+ try:
+ d = self.convert(a)
+ except:
+ d = a
+ xData.append(d)
+ x = xData[np.argmin(abs(xData - x))]
+ info = self.lookUp.GetInformation(x)
+ ys = zip(*info[1].values())[1]
+ if not info:
+ return
+ # Update the annotation in the current axis..
+ annotation.xy = x, max(ys)
+ text = self.formatFunction(*info)
+ annotation.set_text(text)
+ annotation.set_visible(True)
+def run(parent=None, datasets=None):
+ frame = TplotFrame(parent)
+ if datasets:
+ frame.SetDatasets(datasets)
+ frame.Show()
+if __name__ == '__main__':
+ run()
Property changes on: grass/trunk/gui/wxpython/tplot/frame.py
+ text/x-python
+ native
Added: grass/trunk/gui/wxpython/tplot/g.gui.tplot.html
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.html (rev 0)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.html 2014-06-26 13:50:20 UTC (rev 60981)
@@ -0,0 +1,41 @@
+<!-- meta page description: wxGUI Temporal Plot Tool -->
+<!-- meta page index: topic_gui|GUI -->
+<h2>DESCRIPTION</h2>
+The <b>Temporal Plot Tool</b> is a <em><a href="wxGUI.html">wxGUI</a></em> component
+which allows the user to see in a plot the values of one or more temporal datasets (strds, stvds,
+str3ds) for a queried point defined by a coordinate pair.
+<p>
+Supported features:
+<ul>
+ <li>temporal datasets with interval/point and absolute/relative time,</li>
+ <li>2D plots,</li>
+ <!-- <li>3D plots - spatio-temporal extent (matplotlib >= 1.0.0)</li> -->
+ <li>pop-up annotations with values information,</li>
+ <li>automatic output to query several point.</li>
+</ul>
+<center>
+<img src="tplot.png" border="1" alt="Temporal Plot Tool">
+</center>
+<h2>NOTES</h2>
+<em>g.gui.tplot</em> requires the Python plotting library
+<a href="http://matplotlib.org/">Matplotlib</a>.
+<h2>SEE ALSO</h2>
+<em>
+ <a href="temporal.html">Temporal data processing</a><br>
+ <a href="wxGUI.html">wxGUI</a><br>
+ <a href="wxGUI.components.html">wxGUI components</a>
+</em>
+<h2>AUTHOR</h2>
+Luca Delucchi,
+<a href="http://www.gis.cri.fmach.it">Fondazione Edmund Mach</a>, Italy
+<p>
+<i>$Date$</i>
Property changes on: grass/trunk/gui/wxpython/tplot/g.gui.tplot.html
+ text/html
Added: svn:keywords
+ Author Date Id
+ native
Added: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py (rev 0)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2014-06-26 13:50:20 UTC (rev 60981)
@@ -0,0 +1,85 @@
+#!/usr/bin/env python
+# MODULE: g.gui.tplot.py
+# AUTHOR(S): Luca Delucchi
+# PURPOSE: Temporal Plot Tool is a wxGUI component (based on matplotlib)
+# the user to see in a plot the values of one or more temporal
+# datasets for a queried point defined by a coordinate pair.
+# COPYRIGHT: (C) 2014 by Luca Delucchi, and the GRASS Development Team
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2 of the License, or
+# (at your option) any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+#%module
+#% description: Allows the user to see in a plot the values of one or more temporal datasets for a queried point defined by a coordinate pair.
+#% keywords: general
+#% keywords: GUI
+#% keywords: temporal
+#%end
+#%option G_OPT_STDS_INPUTS
+#% required: no
+#%end
+#%option G_OPT_M_COORDS
+#% required: no
+#%end
+#%option G_OPT_F_OUTPUT
+#% required: no
+#%end
+#%option
+#% key: dpi
+#% type: integer
+#% label: The DPI for output image
+#% description: To use only with output parameters
+#% required: no
+#%end
+## #%flag
+## #% key: 3
+## #% description: Show also 3D plot of spatio-temporal extents
+## #%end
+import wx
+import grass.script as grass
+from core.utils import GuiModuleMain
+def main():
+ try:
+ from tplot.frame import TplotFrame
+ except ImportError as e:
+ grass.fatal(e.message)
+ datasets = options['inputs'].strip().split(',')
+ datasets = [data for data in datasets if data]
+ coords = options['coordinates'].strip().split(',')
+ output = options['output']
+ dpi = options['dpi']
+# view3d = flags['3']
+ if dpi and not output:
+ grass.warning(_("No output filename set, so DPI option will not used"))
+ app = wx.App()
+ frame = TplotFrame(None)
+ frame.SetDatasets(datasets, coords, output, dpi)
+ if output:
+ return
+# frame.Show3D(view3d)
+ frame.Show()
+ app.MainLoop()
+ options, flags = grass.parser()
+ GuiModuleMain(main)
Property changes on: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
Added: svn:executable
+ text/x-python
+ native
Added: grass/trunk/gui/wxpython/tplot/tplot.png
(Binary files differ)
Property changes on: grass/trunk/gui/wxpython/tplot/tplot.png
+ image/png
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2014-06-26 13:32:32 UTC (rev 60980)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2014-06-26 13:50:20 UTC (rev 60981)
@@ -1981,6 +1981,9 @@
<module-item name="g.gui.timeline">
<label>Plot temporal extents</label>
</module-item>
+ <module-item name="g.gui.tplot">
+ <label>Plot temporal values</label>
+ </module-item>
</items>
</toolbox>
<toolbox name="GuiTools">
