[GRASS-SVN] r60982 - grass/trunk/gui/wxpython/tplot
svn_grass at osgeo.org
Thu Jun 26 08:24:22 PDT 2014
Author: annakrat
Date: 2014-06-26 08:24:21 -0700 (Thu, 26 Jun 2014)
New Revision: 60982
grass/trunk/gui/wxpython/tplot/frame.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
wxGUI/tplot: clean up
Modified: grass/trunk/gui/wxpython/tplot/frame.py
--- grass/trunk/gui/wxpython/tplot/frame.py 2014-06-26 13:50:20 UTC (rev 60981)
+++ grass/trunk/gui/wxpython/tplot/frame.py 2014-06-26 15:24:21 UTC (rev 60982)
@@ -40,7 +40,6 @@
import grass.temporal as tgis
from core.gcmd import GError, GException, RunCommand
from gui_core import gselect
-from core import globalvar
from grass.pygrass.vector.geometry import Point
from grass.pygrass.raster import RasterRow
from collections import OrderedDict
@@ -71,6 +70,7 @@
tgis.init(True)
self.datasets = []
+ self.output = None
self.timeData = {}
self._layout()
self.temporalType = None
@@ -121,19 +121,11 @@
gridSizer = wx.GridBagSizer(hgap=5, vgap=5)
self.datasetSelect = gselect.Select(parent=self.panel, id=wx.ID_ANY,
-# size=globalvar.DIALOG_GSELECT_SIZE,
- type='stds', size=(150, -1))
+ type='strds', multiple=True, size=(150, -1))
self.drawButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Draw"))
self.drawButton.Bind(wx.EVT_BUTTON, self.OnRedraw)
self.helpButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Help"))
self.helpButton.Bind(wx.EVT_BUTTON, self.OnHelp)
-# self.view3dCheck = wx.CheckBox(self.panel, id=wx.ID_ANY,
-# label=_("3D plot of queried data"))
-# self.view3dCheck.Bind(wx.EVT_CHECKBOX, self.OnRedraw)
-# if not check_version(1, 0, 0):
-# self.view3dCheck.SetLabel(_("3D plot of queried data "
-# "(matplotlib >= 1.0.0)"))
-# self.view3dCheck.Disable()
self.xcoor = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
label=_('Insert longitude (x) coordinate'))
@@ -159,7 +151,6 @@
gridSizer.Add(self.drawButton, pos=(3, 2), flag=wx.EXPAND)
gridSizer.Add(self.helpButton, pos=(3, 3), flag=wx.EXPAND)
-# gridSizer.Add(self.view3dCheck, pos=(4, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
self.vbox.Add(gridSizer, proportion=0, flag=wx.EXPAND | wx.ALL,
border=10)
@@ -228,60 +219,7 @@
self.temporalType = mode
return
- def _draw3dFigure(self):
- """Draws 3d view (spatio-temporal extents).
- Only for matplotlib versions >= 1.0.0.
- Earlier versions cannot draw time ticks and alpha
- and it has a slightly different API.
- pass
-# self.axes3d.clear()
-# self.axes3d.grid(False)
-# # self.axes3d.grid(True)
-# if self.temporalType == 'absolute':
-# if check_version(1, 1, 0):
-# self.axes3d.zaxis_date()
-# convert = mdates.date2num
-# else:
-# convert = lambda x: x
-# colors = cycle(COLORS)
-# plots = []
-# for name in self.datasets:
-# name = name[0] + '@' + name[1]
-# startZ = convert(self.timeData[name]['start_datetime'])
-# mapType = self.timeData[name]['temporalMapType']
-# if mapType == 'interval':
-# dZ = convert(self.timeData[name]['end_datetime']) - startZ
-# else:
-# dZ = [0] * len(startZ)
-# startX = self.timeData[name]['west']
-# dX = self.timeData[name]['east'] - np.array(startX)
-# startY = self.timeData[name]['south']
-# dY = self.timeData[name]['north'] - np.array(startY)
-# color = colors.next()
-# plots.append(self.axes3d.bar3d(startX, startY, startZ, dX, dY, dZ,
-# color=color, alpha=ALPHA))
-# params = grass.read_command('g.proj', flags='g')
-# params = grass.parse_key_val(params)
-# if 'unit' in params:
-# self.axes3d.set_xlabel(_("X [%s]") % params['unit'])
-# self.axes3d.set_ylabel(_("Y [%s]") % params['unit'])
-# else:
-# self.axes3d.set_xlabel(_("X"))
-# self.axes3d.set_ylabel(_("Y"))
-# self.axes3d.set_zlabel(_('Time'))
-# self.axes3d.mouse_init()
-# self.canvas.draw()
- def _draw2dFigure(self):
+ def _drawFigure(self):
"""Draws or print 2D plot (temporal extents)"""
self.axes2d.clear()
self.axes2d.grid(False)
@@ -301,7 +239,6 @@
plots = []
lookUp = LookUp(self.timeData, self.invconvert)
for i, name in enumerate(self.datasets):
- fullname = name[0] + '@' + name[1]
name = name[0]
yticksNames.append(name) # just name; with mapset it would be long
yticksPos.append(i)
@@ -324,10 +261,10 @@
else:
self.axes2d.set_xlabel(_("Time [%s]") % self.unit)
self.axes2d.set_ylabel(', '.join(yticksNames))
#legend
handles, labels = self.axes2d.get_legend_handles_labels()
- self.axes2d.legend()
+ self.axes2d.legend(loc=0)
if self.output:
self.canvas.print_figure(filename=self.output, dpi=self.dpi)
else:
@@ -368,29 +305,13 @@
# axes3d are physically removed
if not self.axes2d:
self.axes2d = self.fig.add_subplot(1, 1, 1)
- self._draw2dFigure()
-# if check_version(1, 0, 0):
-# if self.view3dCheck.IsChecked():
-# self.axes2d.change_geometry(2, 1, 1)
-# if not self.axes3d:
-# # do not remove this import - unused but it is required for 3D
-# from mpl_toolkits.mplot3d import Axes3D # pylint: disable=W0611
-# self.axes3d = self.fig.add_subplot(2, 1, 2, projection='3d')
-# self.axes3d.set_visible(True)
-# self._draw3dFigure()
-# else:
-# if self.axes3d:
-# self.fig.delaxes(self.axes3d)
-# self.axes3d = None
-# self.axes2d.change_geometry(1, 1, 1)
+ self._drawFigure()
def _checkDatasets(self, datasets):
"""Checks and validates datasets.
Reports also type of dataset (e.g. 'strds').
:param list datasets: list of temporal dataset's name
:return: (mapName, mapset, type)
@@ -477,12 +398,7 @@
self.ycoorval.SetValue(str(coors[1]))
self._redraw()
-# def Show3D(self, show):
-# """Show also 3D if possible"""
-# self.view3dCheck.SetValue(show)
class LookUp:
"""Helper class for searching info by coordinates"""
def __init__(self, timeData, convert):
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2014-06-26 13:50:20 UTC (rev 60981)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2014-06-26 15:24:21 UTC (rev 60982)
@@ -34,20 +34,17 @@
#%end
#%option G_OPT_F_OUTPUT
#% required: no
+#% label: Name for output file
+#% description: Add extension to specify format (.png, .pdf, .svg)
#%end
#%option
#% key: dpi
#% type: integer
#% label: The DPI for output image
-#% description: To use only with output parameters
+#% description: To use only with output parameter
#% required: no
#%end
-## #%flag
-## #% key: 3
-## #% description: Show also 3D plot of spatio-temporal extents
-## #%end
import wx
import grass.script as grass
@@ -65,7 +62,7 @@
coords = options['coordinates'].strip().split(',')
output = options['output']
dpi = options['dpi']
-# view3d = flags['3']
+ dpi = int(dpi) if dpi else None
if dpi and not output:
grass.warning(_("No output filename set, so DPI option will not used"))
@@ -73,8 +70,8 @@
frame = TplotFrame(None)
frame.SetDatasets(datasets, coords, output, dpi)
if output:
- return
-# frame.Show3D(view3d)
+ return
frame.Show()
app.MainLoop()
