[GRASS-SVN] r61006 - grass/branches/develbranch_6/scripts/g.extension
Fri Jun 27 04:14:07 PDT 2014
Author: hamish
Date: 2014-06-27 04:14:07 -0700 (Fri, 27 Jun 2014)
New Revision: 61006
   grass/branches/develbranch_6/scripts/g.extension/description.html
spelling
Modified: grass/branches/develbranch_6/scripts/g.extension/description.html
--- grass/branches/develbranch_6/scripts/g.extension/description.html	2014-06-27 06:22:32 UTC (rev 61005)
+++ grass/branches/develbranch_6/scripts/g.extension/description.html	2014-06-27 11:14:07 UTC (rev 61006)
@@ -31,7 +31,7 @@
 The wxGUI contains a graphical extension manager separate to this version
 of <em>g.extension</em>. The wxGUI Extension Manager can be found in the
-<i>Settings</i> menu. While they are generally interchangable, this help
+<i>Settings</i> menu. While they are generally interchangeable, this help
 page describes the version of <em>g.extension</em> run from the GRASS
 command line. If one method of installing the addon fails you might try
 again with the other.
