[GRASS-SVN] r61007 - grass/branches/releasebranch_6_4/scripts/g.extension
svn_grass at osgeo.org
Fri Jun 27 04:16:17 PDT 2014
Author: hamish
Date: 2014-06-27 04:16:17 -0700 (Fri, 27 Jun 2014)
New Revision: 61007
grass/branches/releasebranch_6_4/scripts/g.extension/description.html
spelling (merge from devbr6)
Modified: grass/branches/releasebranch_6_4/scripts/g.extension/description.html
--- grass/branches/releasebranch_6_4/scripts/g.extension/description.html 2014-06-27 11:14:07 UTC (rev 61006)
+++ grass/branches/releasebranch_6_4/scripts/g.extension/description.html 2014-06-27 11:16:17 UTC (rev 61007)
@@ -31,7 +31,7 @@
The wxGUI contains a graphical extension manager separate to this version
of <em>g.extension</em>. The wxGUI Extension Manager can be found in the
-<i>Settings</i> menu. While they are generally interchangable, this help
+<i>Settings</i> menu. While they are generally interchangeable, this help
page describes the version of <em>g.extension</em> run from the GRASS
command line. If one method of installing the addon fails you might try
again with the other.
