[GRASS-SVN] r59155 - grass/trunk/raster/r.li
Sat Mar 1 06:02:29 PST 2014
Author: neteler
Date: 2014-03-01 06:02:28 -0800 (Sat, 01 Mar 2014)
New Revision: 59155
   grass/trunk/raster/r.li/TODO
r.li tests simplified
Modified: grass/trunk/raster/r.li/TODO
--- grass/trunk/raster/r.li/TODO	2014-03-01 13:13:01 UTC (rev 59154)
+++ grass/trunk/raster/r.li/TODO	2014-03-01 14:02:28 UTC (rev 59155)
@@ -13,78 +13,34 @@
 Brute-force testing
-# TODO: change to 3x3 example
+# TODO: change to/add 3x3 example
+# 7x7 moving window test:
+# still Spearfish...
 # created as described in EXAMPLES, moving window, in gui/wxgui/rlisetup/g.gui.rlisetup.html:
 echo "SAMPLINGFRAME 0|0|1|1
 SAMPLEAREA -1|-1|0.015021459227467811|0.011058451816745656
 MOVINGWINDOW" > $HOME/.grass7/r.li/movwindow7
 export GRASS_OVERWRITE=1
-# still Spearfish...
 g.region rast=landcover.30m -p
 r.mapcalc "forests = if(landcover.30m >= 41 && landcover.30m <= 43,1,null())"
-echo "-------------------------"
-r.li.dominance input=forests conf=movwindow7 out=forests_dominance_mov7
-r.univar forests_dominance_mov7
+MEASURE="dominance edgedensity mpa mps padcv padrange padsd patchdensity patchnum pielou richness shannon shape simpson"
-r.li.edgedensity input=forests conf=movwindow7 out=forests_edgedens_mov7
-r.univar forests_edgedens_mov7
+for mymeasure in $MEASURE ; do
+  r.li.${mymeasure} input=forests conf=movwindow7 out=forests_${mymeasure}_mov7
+  r.univar forests_${mymeasure}_mov7
+done
-r.li.mpa input=forests conf=movwindow7 out=forests_mpa_mov7
-r.univar forests_mpa_mov7
-r.li.mps input=forests conf=movwindow7 out=forests_mps_mov7
-r.univar forests_mps_mov7
-r.li.padcv input=forests conf=movwindow7 out=forests_padcv_mov7
-r.univar forests_padcv_mov7
-r.li.padrange input=forests conf=movwindow7 out=forests_padrange_mov7
-r.univar forests_padrange_mov7
-r.li.padsd input=forests conf=movwindow7 out=forests_padsd_mov7
-r.univar forests_padsd_mov7
-r.li.patchdensity forests conf=movwindow7 out=forests_p_dens7
-r.univar forests_p_dens7
-r.li.patchnum input=forests conf=movwindow7 out=forests_patchnum_mov7
-r.univar forests_patchnum_mov7
-r.li.pielou input=forests conf=movwindow7 out=forests_pielou_mov7
-r.univar forests_pielou_mov7
+# also alpha:
 r.li.renyi input=forests conf=movwindow7 out=forests_renyi_mov7_a06 alpha=0.6
 r.univar forests_renyi_mov7_a06
-r.li.richness input=forests conf=movwindow7 out=forests_richness_mov7
-r.univar forests_richness_mov7
+echo "End of r.li tests"
-r.li.shannon input=forests conf=movwindow7 out=forests_shannon_mov7
-r.univar forests_shannon_mov7
-r.li.shape input=forests conf=movwindow7 out=forests_shape_mov7
-r.univar forests_shape_mov7
-r.li.simpson input=forests conf=movwindow7 out=forests_simpson_mov7
-r.univar forests_simpson_mov7
 GRASS 7: North Carolina tests
