[GRASS-SVN] r59154 - grass/trunk/vector/v.overlay
svn_grass at osgeo.org
Sat Mar 1 05:13:02 PST 2014
Author: martinl
Date: 2014-03-01 05:13:01 -0800 (Sat, 01 Mar 2014)
New Revision: 59154
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.overlay/v.overlay.html
v.overlay: implement `atype=auto`
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2014-03-01 12:30:14 UTC (rev 59153)
+++ grass/trunk/vector/v.overlay/main.c 2014-03-01 13:13:01 UTC (rev 59154)
@@ -11,7 +11,7 @@
* OGR support by Martin Landa <landa.martin gmail.com>
* Markus Metz
* PURPOSE:
- * COPYRIGHT: (C) 2003-2009, 2012-2013 by the GRASS Development Team
+ * COPYRIGHT: (C) 2003-2014 by the GRASS Development Team
* This program is free software under the GNU General
* Public License (>=v2). Read the file COPYING that
@@ -75,8 +75,8 @@
type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
type_opt[0]->label = _("Feature type (vector map A)");
type_opt[0]->key = "atype";
- type_opt[0]->options = "line,area";
- type_opt[0]->answer = "area";
+ type_opt[0]->options = "line,area,auto";
+ type_opt[0]->answer = "auto";
in_opt[1] = G_define_standard_option(G_OPT_V_INPUT);
in_opt[1]->label = _("Name of input vector map (B)");
@@ -144,8 +144,10 @@
for (input = 0; input < 2; input++) {
type[input] = Vect_option_to_types(type_opt[input]);
+ /* not needed
if (type[0] & GV_AREA)
type[0] = GV_AREA;
ofield[0] = ofield[1] = ofield[2] = 0;
i = 0;
@@ -165,17 +167,33 @@
else
G_fatal_error(_("Unknown operator '%s'"), operator_opt->answer);
+ Vect_check_input_output_name(in_opt[0]->answer, out_opt->answer,
+ G_FATAL_EXIT);
+ Vect_check_input_output_name(in_opt[1]->answer, out_opt->answer,
+ G_FATAL_EXIT);
+ for (input = 0; input < 2; input++) {
+ Vect_set_open_level(2);
+ Vect_open_old2(&(In[input]), in_opt[input]->answer, "", field_opt[input]->answer);
+ field[input] = Vect_get_field_number(&(In[input]), field_opt[input]->answer);
+ if (type[0] == 0) { /* atype=auto */
+ type[0] = Vect_read_next_line(&(In[0]), NULL, NULL);
+ if (type[0] == -1)
+ G_fatal_error(_("Unable to determine feature type for <%s>"),
+ in_opt[0]->key);
+ if (!(type[0] & (GV_LINE | GV_AREA)))
+ G_fatal_error(_("Invalid fearure type for <%s>. Only '%s' or '%s' supported."),
+ in_opt[0]->key, "line", "area");
+ G_debug(1, "auto -> atype=%d", type[0]);
/* OP_OR, OP_XOR is not supported for lines,
mostly because I'am not sure if they make enouhg sense */
if (type[0] == GV_LINE && (operator == OP_OR || operator == OP_XOR))
G_fatal_error(_("Operator '%s' is not supported for type line"),
- Vect_check_input_output_name(in_opt[0]->answer, out_opt->answer,
- G_FATAL_EXIT);
- Vect_check_input_output_name(in_opt[1]->answer, out_opt->answer,
- G_FATAL_EXIT);
snap_thresh = atof(snap_opt->answer);
Points = Vect_new_line_struct();
@@ -225,10 +243,6 @@
int ncats, index, nlines_out, newline;
- Vect_set_open_level(2);
- Vect_open_old2(&(In[input]), in_opt[input]->answer, "", field_opt[input]->answer);
- field[input] = Vect_get_field_number(&(In[input]), field_opt[input]->answer);
G_message(_("Copying vector features from <%s>..."),
Vect_get_full_name(&(In[input])));
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2014-03-01 12:30:14 UTC (rev 59153)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2014-03-01 13:13:01 UTC (rev 59154)
@@ -1,21 +1,21 @@
<h2>DESCRIPTION</h2>
<em>v.overlay</em> allows the user to overlay two vector maps. Features
-in <em>ainput</em> can be lines or areas and are cut with areas in
-<em>binput</em>. Simple clipping can be performed with the <em>and</em>
+in <b>ainput</b> can be lines or areas and are cut with areas in
+<b>binput</b>. Simple <i>clipping</i> can be performed with the <b>and</b>
oerator.
<p>
-If areas in <em>ainput</em> are overlaid with areas in <em>binput</em>,
-it is sometimes necessary to snap areas of <em>binput</em> to those of
-<em>ainput</em>, otherwise areas can go missing or many sliver areas
+If areas in <b>ainput</b> are overlaid with areas in <b>binput</b>,
+it is sometimes necessary to snap areas of <b>binput</b> to those of
+<b>ainput</b>, otherwise areas can go missing or many sliver areas
can be created. Snapping is enabled by default and can be disabled by
-setting the <em>snap</em> option to a negative value. Recommended values
+setting the <b>snap</b> option to a negative value. Recommended values
are between 0.00000001 and 0.0001. Using larger values for snapping can
have undesired side-effects, but may sometimes be necessary to get a
clean output (see example below). In general, it is recommended to start
with a small snapping threshold, gradually increasing the threshold until
the result is reasonably clean. Snapping modifies only boundaries in
-binput, which are snapped to boundaries in ainput. Boundaries in ainput
+binput, which are snapped to boundaries in ainput. Boundaries in <b>ainput</b>
are not modified.
<!-- This is outdated
There are 3 links attached to features in output map,
@@ -31,37 +31,41 @@
</ul>
<p>
-If the first number of the <em>olayer</em> option is > 0, then the
+If the <i>first</i> number of the <b>olayer</b> option is greater than 0, then the
resulting output map has a merged attribute table in the given layer
number. The original column names have a prefix (<em>a_</em> and
-<em>b_</em>) corresponding to <em>ainput</em> and <em>binput</em> map.
+<em>b_</em>) corresponding to <b>ainput</b> and <b>binput</b> map.
<p>
-If the second number of the <em>olayer</em> option is > 0, then the
-categories of <em>ainput</em> in layer <em>alayer</em> are transferred to
+If the <i>second</i> number of the <b>olayer</b> option is greater than 0, then the
+categories of <b>ainput</b> in layer <b>alayer</b> are transferred to
the output layer with the second number.
<p>
-If the third number of the <em>olayer</em> option is > 0, then the
-categories of <em>binput</em> in layer <em>blayer</em> are transferred to
+If the <i>third</i> number of the <b>olayer</b> option is greater than 0, then the
+categories of <b>binput</b> in layer <em>blayer</em> are transferred to
the output layer with the third number.
<h2>NOTES</h2>
-Currently only areas in <em>ainput</em> are supported for the operators
-<em>or</em> and <em>xor</em>! See also <a href="v.select.html">v.select</a>.
+Currently only areas in <b>ainput</b> are supported for the operators
+<em>or</em> and <em>xor</em>! See also <em><a href="v.select.html">v.select</a></em>.
The operator defines what kind of operation will be done. Features are
-written to output, if the result of an operation 'ainput operator binput'
+written to output, if the result of an operation <b>ainput</b> operator <b>binput</b>
is true.
<p>
-If the first number of the <em>olayer</em> option is > 0, then attributes
-of the tables from ainput and binput are joined into a new table linked
+If the <i>first</i> number of the <b>olayer</b> option is greater than 0, then attributes
+of the tables from <b>ainput</b> and <b>binput</b> are joined into a new table linked
to the output map with a new cat column.
<p>
-attribute table of ainput is copied to the output map.
+attribute table of <b>ainput</b> is copied to the output map.
<p>
-attribute table of binput is copied to the output map.
+attribute table of <b>binput</b> is copied to the output map.
+<p>
+If <b>atype</b>=auto is given than <em>v.overlay</em> determines
+feature type for <b>ainput</b> from the first found feature.
<p><div class="code"><pre>
v.db.connect map=outputmap table=ainput.dbf field=2
@@ -75,7 +79,7 @@
<h2>EXAMPLES</h2>
-<h4>Polygons overlaid with ploygons</h4>
+<h3>Polygons overlaid with ploygons</h3>
v.overlay ainput=lake binput=province output=lakeXprovince operator=or
</pre></div>
@@ -131,7 +135,7 @@
the urban areas do not match exactly the Census 2000 areas. In this case
a clean result can be obtained by snapping with a threshold of 0.1 m.
-<h4>Lines overlaid with polygons</h4>
+<h3>Lines overlaid with polygons</h3>
Using the North Carolina sample dataset, we clip the roads map to the area
of city of Raleigh, preserving road attributes in layer 1:
@@ -171,4 +175,5 @@
Radim Blazek, ITC-Irst, Trento, Italy<br>
Markus Metz
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
