[GRASS-SVN] r59258 - in grass/branches/releasebranch_6_4: raster/r.carve raster/r.flow raster/r.terraflow raster/r.watershed/front raster/simwe/r.sim.sediment raster/simwe/r.sim.water scripts/r.fillnulls vector/v.surf.rst vector/v.vol.rst visualization/nviz/html
Sat Mar 15 07:28:47 PDT 2014
Author: annakrat
Date: 2014-03-15 07:28:47 -0700 (Sat, 15 Mar 2014)
New Revision: 59258
   grass/branches/releasebranch_6_4/raster/r.carve/README
   grass/branches/releasebranch_6_4/raster/r.carve/description.html
   grass/branches/releasebranch_6_4/raster/r.flow/description.html
   grass/branches/releasebranch_6_4/raster/r.terraflow/description.html
   grass/branches/releasebranch_6_4/raster/r.watershed/front/description.html
   grass/branches/releasebranch_6_4/raster/simwe/r.sim.sediment/description.html
   grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html
   grass/branches/releasebranch_6_4/scripts/r.fillnulls/description.html
   grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html
   grass/branches/releasebranch_6_4/vector/v.vol.rst/description.html
   grass/branches/releasebranch_6_4/visualization/nviz/html/index.html
fix links pointing to skagit
Modified: grass/branches/releasebranch_6_4/raster/r.carve/README
--- grass/branches/releasebranch_6_4/raster/r.carve/README	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/r.carve/README	2014-03-15 14:28:47 UTC (rev 59258)
@@ -1,4 +1,4 @@
-http://skagit.meas.ncsu.edu/~helena/gmslab/reports/cerl99/rep99.html
+http://www4.ncsu.edu/~hmitaso/gmslab/reports/cerl99/rep99.html
 Terrain modeling and Soil Erosion Simulations for Fort Hood and Fort Polk
 test areas
@@ -21,7 +21,7 @@
 r.carve does not create a depressionless DEM because many depressions are in
 flat areas and not in the streams.
-http://skagit.meas.ncsu.edu/~helena/gmslab/reports/cerl99/demstr.gif
+http://www4.ncsu.edu/~hmitaso/gmslab/reports/cerl99/demstr.gif
 The program will take the vector stream data, transform them to raster, and
 subtracts a defaultdepth + additionaldepth from the DEM. If the given
Modified: grass/branches/releasebranch_6_4/raster/r.carve/description.html
--- grass/branches/releasebranch_6_4/raster/r.carve/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/r.carve/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -31,7 +31,7 @@
 <h2>REFERENCES</h2>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/reports/cerl99/rep99.html">Terrain
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/reports/cerl99/rep99.html">Terrain
 modeling and Soil Erosion Simulations for Fort Hood and Fort Polk test
 areas</a>, by Helena Mitasova, Lubos Mitas, William M. Brown, Douglas
 M.  Johnston, GMSL (Report for CERL 1999)
Modified: grass/branches/releasebranch_6_4/raster/r.flow/description.html
--- grass/branches/releasebranch_6_4/raster/r.flow/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/r.flow/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -1,8 +1,8 @@
 <h2>DESCRIPTION</h2>
 This program generates flowlines using a combined raster-vector
-approach (see <a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova and
-Hofierka 1993</a> and <a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/ijgis.html">Mitasova et
+approach (see <a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps">Mitasova and
+Hofierka 1993</a> and <a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/ijgis.html">Mitasova et
 al. 1995</a>) from an input elevation raster map <b>elevin</b>
 (integer or floating point), and optionally an input aspect raster map
 <b>aspin</b> and/or an input barrier raster map <b>barin</b>. There are
@@ -147,11 +147,11 @@
 <p>Mitasova, H., L. Mitas, 1993, Interpolation by regularized spline with
 tension : I. Theory and implementation. Mathematical Geology 25, p. 641-655.
-(<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/papers/lmg.rev1.ps>online</a>)
+(<a href=http://www4.ncsu.edu/~hmitaso/gmslab/papers/lmg.rev1.ps>online</a>)
 <p>Mitasova and Hofierka 1993 : Interpolation by Regularized Spline with
 Tension: II. Application to Terrain Modeling and Surface Geometry Analysis.
-Mathematical Geology 25(6), 657-669. (<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps>online</a>)
+Mathematical Geology 25(6), 657-669. (<a href=http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps>online</a>)
 <p>Mitasova, H., Mitas, L., Brown, W.M., Gerdes, D.P., Kosinovsky, I.,
 Baker, T., 1995: Modeling spatially and temporally distributed phenomena:
@@ -187,7 +187,7 @@
 <p><i>The current version of the program (adapted for GRASS5.0)</i>:
 <br>Joshua Caplan, Mark Ruesink, Helena Mitasova, University of Illinois
 at Urbana-Champaign with support from USA CERL.<br>
-<a href=http://skagit.meas.ncsu.edu/~helena/gmslab/>GMSL/University of Illinois at
+<a href=http://www4.ncsu.edu/~hmitaso/gmslab/>GMSL/University of Illinois at
 Urbana-Champaign</a>
 <p><i>Last changed: $Date$</i>
Modified: grass/branches/releasebranch_6_4/raster/r.terraflow/description.html
--- grass/branches/releasebranch_6_4/raster/r.terraflow/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/r.terraflow/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -211,7 +211,7 @@
   <dt>Porting for GRASS, 2002:
     <dd> <a href="http://www.daimi.au.dk/~large/">Lars Arge</a>,
-	     <a href="http://skagit.meas.ncsu.edu/~helena/index.html">Helena Mitasova,</a>
+	     <a href="http://www4.ncsu.edu/~hmitaso/index.html">Helena Mitasova,</a>
 		 <a href="http://www.bowdoin.edu/~ltoma/">Laura Toma</a>.
 	<dt>Contact: <a href="mailto:ltoma at bowdoin.edu "> Laura Toma</a></dt>
Modified: grass/branches/releasebranch_6_4/raster/r.watershed/front/description.html
--- grass/branches/releasebranch_6_4/raster/r.watershed/front/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/r.watershed/front/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -443,8 +443,8 @@
 <i>GIS-based Stream Network Analysis for The Chagres River Basin,
 Republic of Panama</i>. <b>The Rio Chagres: A Multidisciplinary Profile of
 a Tropical Watershed</b>, R. Harmon (Ed.), Springer/Kluwer, p.83-95.<br>
-URL: <a href="http://skagit.meas.ncsu.edu/%7Ehelena/measwork/panama/panama.html">
-http://skagit.meas.ncsu.edu/~helena/measwork/panama/panama.html</a>
+URL: <a href="http://www4.ncsu.edu/~hmitaso/measwork/panama/panama.html">
+http://www4.ncsu.edu/~hmitaso/measwork/panama/panama.html</a>
 <p>
 McCool et al. (1987). <i>Revised Slope Steepness Factor for the Universal
Modified: grass/branches/releasebranch_6_4/raster/simwe/r.sim.sediment/description.html
--- grass/branches/releasebranch_6_4/raster/simwe/r.sim.sediment/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/simwe/r.sim.sediment/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -70,7 +70,7 @@
 <h2>
 REFERENCES</h2>
 <P>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/II.6.8_Mitasova_044.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/II.6.8_Mitasova_044.pdf">
 Mitasova, H., Thaxton, C., Hofierka, J., McLaughlin, R., Moore, A., Mitas L., 2004,</a>
 Path sampling method for modeling overland water flow, sediment transport
 and short term terrain evolution in Open Source GIS.
@@ -78,7 +78,7 @@
 Proceedings of the XVth International Conference on Computational Methods in Water
 Resources (CMWR XV), June 13-17 2004, Chapel Hill, NC, USA, Elsevier, pp. 1479-1490.
 <P>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/gisc00/duality.html">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/gisc00/duality.html">
 Mitasova H, Mitas, L., 2000, Modeling spatial processes in multiscale framework:
 exploring duality between particles and fields, </a>
 plenary talk at GIScience2000 conference, Savannah, GA.
@@ -86,7 +86,7 @@
 Mitas, L., and Mitasova, H., 1998, Distributed soil erosion simulation
 for effective erosion prevention. Water Resources Research, 34(3), 505-516.
 <P>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/LLEmiterev1.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/LLEmiterev1.pdf">
  Mitasova, H., Mitas, L., 2001, Multiscale soil erosion simulations for land use management, </a>
 In: Landscape erosion and landscape evolution modeling, Harmon R. and Doe W. eds.,
 Kluwer Academic/Plenum Publishers, pp. 321-347.
Modified: grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html
--- grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/raster/simwe/r.sim.water/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -21,7 +21,7 @@
 predefined direction of flow, map algebra can be used to replace terrain-derived
 partial derivatives with pre-defined partial derivatives in selected grid cells such
 as man-made channels, ditches or culverts. Equations (2) and (3) from
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/reports/cerl99/rep99.html">this report</a>
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/reports/cerl99/rep99.html">this report</a>
 can be used to compute partial derivates of the predefined flow using its direction given
 by aspect and slope.
@@ -194,7 +194,7 @@
 <ul>
 <li> Mitasova, H., Thaxton, C., Hofierka, J., McLaughlin, R., Moore, A., Mitas L., 2004,
 and short term terrain evolution in Open Source GIS.</a>
 In: C.T. Miller, M.W. Farthing, V.G. Gray, G.F. Pinder eds.,
@@ -202,7 +202,7 @@
 <li> Mitasova H, Mitas, L., 2000,
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/gisc00/duality.html">Modeling spatial
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/gisc00/duality.html">Modeling spatial
 processes in multiscale framework: exploring duality between particles and fields,</a>
@@ -210,7 +210,7 @@
 <li> Mitasova, H., Mitas, L., 2001,
 Multiscale soil erosion simulations for land use management,</a>
Modified: grass/branches/releasebranch_6_4/scripts/r.fillnulls/description.html
--- grass/branches/releasebranch_6_4/scripts/r.fillnulls/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/scripts/r.fillnulls/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -89,11 +89,11 @@
 GIS</i>, 9 (4), special issue on Integrating GIS and Environmental modeling,
 433-446.
-<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/lmg.rev1.ps">Mitasova H.
+<p><a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/lmg.rev1.ps">Mitasova H.
 and Mitas L. 1993</a>: Interpolation by Regularized Spline with Tension: I.
 Theory and Implementation, <i>Mathematical Geology</i> 25, 641-655.
-<p><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova H.
+<p><a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps">Mitasova H.
 and Hofierka L. 1993</a>: Interpolation by Regularized Spline with Tension:
 II. Application to Terrain Modeling and Surface Geometry Analysis,
 <i>Mathematical Geology</i> 25, 657-667.
Modified: grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html
--- grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/vector/v.surf.rst/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -91,7 +91,7 @@
 function so that the important relationships between these parameters are
 preserved. The equations for computation of these parameters and their
 interpretation is described in
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/hmg.rev1.ps">Mitasova and Hofierka, 1993</a>
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps">Mitasova and Hofierka, 1993</a>
 or Neteler and Mitasova, 2004).
 Slopes and aspect are computed in degrees (0-90 and 1-360 respectively).
 The aspect raster map has value 0 assigned to flat areas (with slope less
@@ -276,8 +276,8 @@
 <p>For examples of applications see
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/">GRASS4 implementation</a> and
-<a href="http://skagit.meas.ncsu.edu/~helena/">GRASS5 and GRASS6 implementation</a>.
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/">GRASS4 implementation</a> and
+<a href="http://www4.ncsu.edu/~hmitaso/">GRASS5 and GRASS6 implementation</a>.
 <p>The user must run <a href="g.region.html">g.region</a> before the program
 to set the region and resolution for approximation.
@@ -304,7 +304,7 @@
 <h2> REFERENCES</h2>
 <p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/IEEEGRSL2005.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/IEEEGRSL2005.pdf">
 Mitasova, H., Mitas, L. and Harmon, R.S., 2005,</a>
 Simultaneous spline approximation and topographic analysis for
 lidar elevation data in open source GIS, IEEE GRSL 2 (4), 375- 379.
@@ -313,7 +313,7 @@
 pp. 16-01 to 16-13. DOI: 10.2104/ag050016
 <p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/TGIS2002_Hofierka_et_al.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/TGIS2002_Hofierka_et_al.pdf">
 Hofierka J., Parajka J.,  Mitasova H., Mitas L., 2002,</a>
 Multivariate Interpolation of Precipitation Using Regularized Spline with Tension.
 Transactions in GIS 6(2), pp. 135-150.
@@ -325,19 +325,19 @@
 GIS and Environmental modeling, 433-446.
 <p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/MG-I-93.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/MG-I-93.pdf">
 Mitasova, H. and Mitas, L., 1993</a>:
 I. Theory and Implementation, Mathematical Geology ,25, 641-655.
 <p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/MG-II-93.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/MG-II-93.pdf">
 Mitasova, H. and Hofierka, J., 1993</a>: Interpolation
 by Regularized Spline with Tension: II. Application to Terrain Modeling
 and Surface Geometry Analysis, Mathematical Geology 25, 657-667.
 <p>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/papers/CMA1988.pdf">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/CMA1988.pdf">
 Mitas, L., and Mitasova H., 1988, </a> General variational approach to the approximation
 problem, Computers and Mathematics with Applications, v.16, p. 983-992.
Modified: grass/branches/releasebranch_6_4/vector/v.vol.rst/description.html
--- grass/branches/releasebranch_6_4/vector/v.vol.rst/description.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/vector/v.vol.rst/description.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -232,13 +232,13 @@
 Transactions in
 GIS  6, pp. 135-150.
-<p><a href="http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/">Mitas, L.,
+<p><a href="http://www4.ncsu.edu/~hmitaso/gmslab/">Mitas, L.,
 Mitasova, H.</a>, 1999, Spatial Interpolation. In: P.Longley, M.F.
 Goodchild, D.J. Maguire, D.W.Rhind (Eds.), Geographical Information
 Systems: Principles, Techniques, Management and Applications, Wiley,
 pp.481-492
 <p>Mitas L., Brown W. M., Mitasova H., 1997, <a
- href="http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/lcgfin/cg-mitas.html">Role
+ href="http://www4.ncsu.edu/~hmitaso/gmslab/lcgfin/cg-mitas.html">Role
 of dynamic cartography in simulations of landscape processes based on
 multi-variate fields.</a> Computers and Geosciences, Vol. 23, No. 4,
 pp. 437-446 (includes CDROM and WWW: www.elsevier.nl/locate/cgvis)
@@ -250,15 +250,15 @@
 special issue on Integrating GIS and Environmental modeling, 433-446.
 <p> Mitasova, H., Mitas, L., Brown, B., Kosinovsky, I., Baker, T.,
 Gerdes, D. (1994): <a
- href="http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/viz/ches.html">Multidimensional
+ href="http://www4.ncsu.edu/~hmitaso/gmslab/viz/ches.html">Multidimensional
 interpolation and visualization in GRASS GIS</a>
 <p><a
- href="http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/papers/lmg.rev1.ps">Mitasova
+ href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/lmg.rev1.ps">Mitasova
 H. and Mitas L. 1993</a>: Interpolation by Regularized Spline with
 Tension: I. Theory and Implementation, <i>Mathematical Geology</i> 25,
 641-655.
 <p><a
- href="http://skagit.meas.ncsu.edu/%7Ehelena/gmslab/papers/hmg.rev1.ps">Mitasova
+ href="http://www4.ncsu.edu/~hmitaso/gmslab/papers/hmg.rev1.ps">Mitasova
 H. and Hofierka J. 1993</a>: Interpolation by Regularized Spline with
 Analysis, <i>Mathematical Geology</i> 25, 657-667.
Modified: grass/branches/releasebranch_6_4/visualization/nviz/html/index.html
--- grass/branches/releasebranch_6_4/visualization/nviz/html/index.html	2014-03-15 14:08:40 UTC (rev 59257)
+++ grass/branches/releasebranch_6_4/visualization/nviz/html/index.html	2014-03-15 14:28:47 UTC (rev 59258)
@@ -25,7 +25,7 @@
 <p><strong><a href="nviz_toc.html">Reference Manual</a></strong></p>
-<p><strong><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/viz97/brown/">Features - Slides from Visualization 97 Conference</a></strong></p>
+<p><strong><a href="http://www4.ncsu.edu/~hmitaso/gmslab/viz97/brown/">Features - Slides from Visualization 97 Conference</a></strong></p>
 <hr>
 <p>Maintained list of <a href="http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/src.contrib/gmsl/nviz2.2/bugs_todo">BUGS in NVIZ</a> (we are working on these bugs).</p>
@@ -35,15 +35,15 @@
 polygons, with render times of several seconds to a minute, we represent the surfaces with wire meshes as a rough approximation when a user is</p>
 <ul>
-<li><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/viz/movies/position.mpg">
+<li><a href="http://www4.ncsu.edu/~hmitaso/gmslab/viz/movies/position.mpg">
 positioning the viewpoint (324 K)</a>,</li>
-<li><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/viz/movies/mvsurf.mpg">
+<li><a href="http://www4.ncsu.edu/~hmitaso/gmslab/viz/movies/mvsurf.mpg">
 positioning the surfaces (152 K)</a> for a better view of data, or </li>
-<li><a href="http://skagit.meas.ncsu.edu/~helena/gmslab/viz/movies/cpwire.mpg">
+<li><a href="http://www4.ncsu.edu/~hmitaso/gmslab/viz/movies/cpwire.mpg">
 moving a cutting plane (220 K)</a>
 through the surfaces.</li>
 <li>By using scripts or keyframe animation,
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/viz/movies/hor_slice.mpg">fully rendered animations (125 K)</a> are generated.</li>
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/viz/movies/hor_slice.mpg">fully rendered animations (125 K)</a> are generated.</li>
 </ul>
 <hr>
@@ -71,7 +71,7 @@
 <hr>
 <a href="../index.html">Go back to GRASS Manual Pages</a>
 <hr>
-<a href="http://skagit.meas.ncsu.edu/~helena/gmslab/" target="_top">
+<a href="http://www4.ncsu.edu/~hmitaso/gmslab/" target="_top">
 <img hspace=5 align=left src="gmsmodviz.gif" alt="gmsl_viz_icon">
 GMSL Modeling & Visualization Home Page</a>
