[GRASS-SVN] r59321 - grass/trunk/raster/r.contour
svn_grass at osgeo.org
Mon Mar 24 15:47:37 PDT 2014
Author: neteler
Date: 2014-03-24 15:47:37 -0700 (Mon, 24 Mar 2014)
New Revision: 59321
grass/trunk/raster/r.contour/r.contour.html
r.contour manual: +NC example
Modified: grass/trunk/raster/r.contour/r.contour.html
--- grass/trunk/raster/r.contour/r.contour.html 2014-03-24 21:06:25 UTC (rev 59320)
+++ grass/trunk/raster/r.contour/r.contour.html 2014-03-24 22:47:37 UTC (rev 59321)
@@ -25,7 +25,7 @@
raster cells eligilble to be included in a contour line written to the <b>output</b>
vector map. It acts like a filter, omitting spurs, single points, etc., making the output more generalized.
-<h2>EXAMPLE</h2>
+<h2>EXAMPLES</h2>
In the Spearfish location, produce a vector contour map from input raster <i>elevation.dem</i>
with contour levels from 1000m to 2000m, 100m contour step, and a minimum of 200 input raster
@@ -35,6 +35,15 @@
r.contour input=elevation.dem output=elevation_dem_contours minlevel=1000 maxlevel=2000 step=100 cut=200
</pre></div>
+<p>
+North Carolina example:
+<p>
+<div class="code"><pre>
+g.region rast=elev_lid792_1m -p
+r.contour input=elev_lid792_1m output=elev_lid792_1m_contours minlevel=100 maxlevel=150 step=10
+</pre></div>
<h2>AUTHORS</h2>
Terry Baker, U.S. Army Construction Engineering Research Laboratory<br>
