[GRASS-SVN] r59322 - grass-addons/grass6/raster/r.surf.nnbathy
svn_grass at osgeo.org
Tue Mar 25 01:19:25 PDT 2014
Author: hamish
Date: 2014-03-25 01:19:25 -0700 (Tue, 25 Mar 2014)
New Revision: 59322
grass-addons/grass6/raster/r.surf.nnbathy/r.surf.nnbathy
cleanup
Modified: grass-addons/grass6/raster/r.surf.nnbathy/r.surf.nnbathy
--- grass-addons/grass6/raster/r.surf.nnbathy/r.surf.nnbathy 2014-03-24 22:47:37 UTC (rev 59321)
+++ grass-addons/grass6/raster/r.surf.nnbathy/r.surf.nnbathy 2014-03-25 08:19:25 UTC (rev 59322)
@@ -6,10 +6,10 @@
# AUTHOR(S): Maciej Sieczka
-# PURPOSE: Interpolate raster surface using the "nnbathy" natural
+# PURPOSE: Interpolate raster surface using the "nnbathy" natural
# neighbor interpolation program.
-# VERSION: 1.95, developed over GRASS 6.3 CVS
+# VERSION: 1.95, developed over GRASS 6.3 CVS
# COPYRIGHT: (c) Maciej Sieczka
@@ -59,41 +59,38 @@
# - cosmetics
# - manual cleaned up
-#%Module
-#% description: Interpolate raster using the nnbathy natural neighbor interpolation program.
-#%END
+#%Module
+#% description: Interpolates a raster map using the nnbathy natural neighbor interpolation program.
+#%End
#%option
#% key: input
#% type: string
#% gisprompt: old,cell,raster
-#% description: The raster map to interpolate on
+#% description: Name of input raster map
#% required : yes
-#%END
+#%End
#%option
#% key: output
#% gisprompt: new,cell,raster
#% type: string
-#% description: Name of the output raster map
+#% description: Name for output raster map
#% required : yes
-#%END
+#%End
#%option
#% key: alg
#% type: string
#% options: l,nn,ns
#% answer: nn
-#% description: Interpolation algorithm for nnbathy to use
+#% descriptions: l;Linear;nn;Sibson natural neighbor;ns;Non-Sibsonian natural neighbor
+#% description: Interpolation algorithm
#% required : yes
-#%END
+#%End
# called from GRASS?
if [ -z "$GISBASE" ]; then
- echo
echo "ERROR: You must be in GRASS GIS to run this program." 1>&2
- echo
exit 1
fi
@@ -101,17 +98,16 @@
exec g.parser "$0" "$@"
fi
# check if we have awk
if [ ! -x "`which awk`" ]; then
- g.message -e '"awk" executable required but not found.' 1>&2
+ g.message -e '"awk" executable required but not found.'
exit 1
fi
# check if we have nnbathy
if [ ! -x "`which nnbathy`" ]; then
- echo
- g.message -e '"nnbathy" executable required but not found. Follow the instructions in r.surf.nnbathy manual to install it.' 1>&2
- echo
+ g.message -e '"nnbathy" executable required but not found. Follow the instructions in r.surf.nnbathy manual to install.'
exit 1
fi
@@ -127,9 +123,7 @@
# set up temporary files
TMP="`g.tempfile pid=$$`"
if [ $? -ne 0 ] || [ -z "$TMP" ]; then
- echo
g.message -e 'Unable to create temporary files.' 1>&2
- echo
exit 1
fi
@@ -145,22 +139,18 @@
# Reset traps before normal script termination to avoid bogus ERROR message, as
# we put a trap on signal 0.
trap - 0 2 3 15
- rm -f "$TMP" "$TMP.${PROG}.input_xyz" "$TMP.${PROG}.output_xyz" "$TMP.${PROG}.output_grd"
+ rm -f "$TMP" "$TMP.$PROG.input_xyz" "$TMP.$PROG.output_xyz" "$TMP.$PROG.output_grd"
# define run-time error handling procedure
proc_runtime_error() {
- echo
- g.message -e "There was an error at the script's run time. Please try to debug the problem if you can and let me know by email." 1>&2
- echo
+ g.message -e "There was an error at the script's run time. Please try to debug the problem if you can and let me know by email."
exit 1
# define user-break procedure
proc_user_break() {
- echo
- g.message -w "User break!"
- echo
+ g.message -e "User break!"
proc_cleanup
exit 1
@@ -171,13 +161,13 @@
# trap user break
trap "proc_user_break" 2 3 15
# assign main variables from user's input
INPUT="$GIS_OPT_INPUT"
OUTPUT="$GIS_OPT_OUTPUT"
-ALG=$GIS_OPT_ALG
+ALG="$GIS_OPT_ALG"
### DO IT ###
# Make script terminate (ie. emit signal 0) if any statement returns a
@@ -188,34 +178,41 @@
set -e
# grab the current region settings
-eval `g.region -gp`
+eval `g.region -g`
# spit out non-null (-n) raster coords + values to be interpolated
-r.stats --q -1gn input="${INPUT}" > "$TMP.${PROG}.input_xyz"
+r.stats -1gn input="$INPUT" --quiet > "$TMP.$PROG.input_xyz"
# set the working region for nnbathy (it's cell-center oriented)
-nn_n=`echo $n | awk -v res="$nsres" '{printf "%.8f",$1-res/2.0}'`
-nn_s=`echo $s | awk -v res="$nsres" '{printf "%.8f",$1+res/2.0}'`
-nn_w=`echo $w | awk -v res="$ewres" '{printf "%.8f",$1+res/2.0}'`
-nn_e=`echo $e | awk -v res="$ewres" '{printf "%.8f",$1-res/2.0}'`
+nn_n=`echo $n | awk -v res="$nsres" '{printf "%.8f", $1 - res/2.0}'`
+nn_s=`echo $s | awk -v res="$nsres" '{printf "%.8f", $1 + res/2.0}'`
+nn_w=`echo $w | awk -v res="$ewres" '{printf "%.8f", $1 + res/2.0}'`
+nn_e=`echo $e | awk -v res="$ewres" '{printf "%.8f", $1 - res/2.0}'`
-null=NaN
-type=double
+null="NaN"
+type="double"
-# interpolate
-echo
-g.message -w '"nnbathy" is performing the interpolation now. This may take some time.' 1>&2
-echo
-g.message -w "Once it completes 'All done.' message will be printed." 1>&2
-echo
-nnbathy -W 0 -P alg=$ALG -n ${cols}x${rows} -x $nn_w $nn_e -y $nn_n $nn_s -i "$TMP.${PROG}.input_xyz" > "$TMP.${PROG}.output_xyz"
-# Y in "r.stats -1gn" output is in descending order, thus -y must be in MAX MIN order, not MIN MAX, for nnbathy not to produce a grid upside-down
+#### interpolate
+g.message ""
+g.message '"nnbathy" is performing the interpolation now. This may take some time.'
+g.message "Once it completes an 'All done.' message will be printed."
+g.message ""
+nnbathy -W 0 -P alg="$ALG" -n "${cols}x${rows}" \
+ -x "$nn_w" "$nn_e" -y "$nn_n" "$nn_s" \
+ -i "$TMP.$PROG.input_xyz" \
+ > "$TMP.$PROG.output_xyz"
+# Y in "r.stats -1gn" output is in descending order, thus -y must be in
+# MAX MIN order, not MIN MAX, for nnbathy not to produce a grid upside-down
# convert the X,Y,Z nnbathy output into a GRASS ASCII grid, then import with r.in.ascii:
# 1 create header
-cat << EOF > "$TMP.${PROG}.output_grd"
+cat << EOF > "$TMP.$PROG.output_grd"
north: $n
south: $s
east: $e
@@ -227,8 +224,8 @@
EOF
# 2 do the conversion
-echo "Converting nnbathy output to GRASS raster." 1>&2
-echo
+g.message "Converting nnbathy output to GRASS raster ..."
+g.message ""
awk -v cols="$cols" '
BEGIN {col_cur=1; ORS=" "}
@@ -236,30 +233,29 @@
if (col_cur==cols) {ORS="\n"; col_cur=0; print $3; ORS=" "}
else {print $3}
col_cur++
-}' "$TMP.${PROG}.output_xyz" >> "$TMP.${PROG}.output_grd"
+}' "$TMP.$PROG.output_xyz" >> "$TMP.$PROG.output_grd"
# 3 import
-r.in.ascii input="$TMP.${PROG}.output_grd" output="${OUTPUT}" > /dev/null
+r.in.ascii input="$TMP.$PROG.output_grd" output="$OUTPUT" --quiet
# store comand history in raster's metadata
-r.support map=${OUTPUT} history=""
-r.support map=${OUTPUT} history="script run syntax:"
-r.support map=${OUTPUT} history="r.surf.nnbathy alg=$ALG input=${INPUT} output=${OUTPUT}"
-r.support map=${OUTPUT} history="nnbathy run syntax:"
-r.support map=${OUTPUT} history="nnbathy -W 0 -P alg=$ALG -n ${cols}x${rows} "
-r.support map=${OUTPUT} history="-x $nn_w $nn_e "
-r.support map=${OUTPUT} history="-y $nn_n $nn_s "
-r.support map=${OUTPUT} history="-i tmp_in > tmp_out"
+r.support map="$OUTPUT" history=""
+r.support map="$OUTPUT" history="script run syntax:"
+r.support map="$OUTPUT" history="r.surf.nnbathy alg=$ALG input=$INPUT output=$OUTPUT"
+r.support map="$OUTPUT" history="nnbathy run syntax:"
+r.support map="$OUTPUT" history="nnbathy -W 0 -P alg=$ALG -n ${cols}x$rows "
+r.support map="$OUTPUT" history="-x $nn_w $nn_e "
+r.support map="$OUTPUT" history="-y $nn_n $nn_s "
+r.support map="$OUTPUT" history="-i tmp_in > tmp_out"
### ALL DONE ###
proc_cleanup
-echo
-echo "All done." 1>&2
-echo
+g.message "All done."
