[GRASS-SVN] r59405 - grass-addons/grass7/raster/r.stream.channel
Thu Mar 27 05:30:54 PDT 2014
Author: martinl
Date: 2014-03-27 05:30:49 -0700 (Thu, 27 Mar 2014)
New Revision: 59405
   grass-addons/grass7/raster/r.stream.channel/main.c
r.stream.channel: cosmetics
Modified: grass-addons/grass7/raster/r.stream.channel/main.c
--- grass-addons/grass7/raster/r.stream.channel/main.c	2014-03-27 12:29:36 UTC (rev 59404)
+++ grass-addons/grass7/raster/r.stream.channel/main.c	2014-03-27 12:30:49 UTC (rev 59405)
@@ -74,33 +74,33 @@
     out_identifier_opt->key = "identifier";
     out_identifier_opt->required = NO;
     out_identifier_opt->description = _("Name for output unique stream identifier raster map");
-    out_identifier_opt->guisection = _("Output settings");
+    out_identifier_opt->guisection = _("Output");
     out_distance_opt = G_define_standard_option(G_OPT_R_OUTPUT);
     out_distance_opt->key = "distance";
     out_distance_opt->required = NO;
     out_distance_opt->description = _("Name for output init/join/outlet distance raster map");
-    out_distance_opt->guisection = _("Output settings");
+    out_distance_opt->guisection = _("Output");
     out_difference_opt = G_define_standard_option(G_OPT_R_OUTPUT);
     out_difference_opt->key = "difference";
     out_difference_opt->required = NO;
     out_difference_opt->description =
         _("Name for output elevation init/join/outlet difference raster map");
-    out_difference_opt->guisection = _("Output settings");
+    out_difference_opt->guisection = _("Output");
     out_gradient_opt = G_define_standard_option(G_OPT_R_OUTPUT);
     out_gradient_opt->key = "gradient";
     out_gradient_opt->required = NO;
     out_gradient_opt->description =
 	_("Name for output mean init/join/outlet gradient of stream raster map");
-    out_gradient_opt->guisection = _("Output settings");
+    out_gradient_opt->guisection = _("Output");
     out_curvature_opt = G_define_standard_option(G_OPT_R_OUTPUT);
     out_curvature_opt->key = "curvature";
     out_curvature_opt->required = NO;
     out_curvature_opt->description = _("Name for output local stream curvature raster map");
-    out_curvature_opt->guisection = _("Output settings");
+    out_curvature_opt->guisection = _("Output");
     opt_swapsize = G_define_option();
     opt_swapsize->key = "memory";
