[GRASS-SVN] r59406 - grass-addons/grass7/raster/r.stream.distance
svn_grass at osgeo.org
Thu Mar 27 05:33:42 PDT 2014
Author: martinl
Date: 2014-03-27 05:33:42 -0700 (Thu, 27 Mar 2014)
New Revision: 59406
grass-addons/grass7/raster/r.stream.distance/io.c
grass-addons/grass7/raster/r.stream.distance/main.c
r.stream.distance: guisection cosmetics
Modified: grass-addons/grass7/raster/r.stream.distance/io.c
--- grass-addons/grass7/raster/r.stream.distance/io.c 2014-03-27 12:30:49 UTC (rev 59405)
+++ grass-addons/grass7/raster/r.stream.distance/io.c 2014-03-27 12:33:42 UTC (rev 59406)
@@ -79,7 +79,7 @@
G_fatal_error(_("Region resolution and raster map <%s> resolution differs. "
"Run 'g.region rast=%s' to set proper region resolution."),
input_map_name, input_map_name);
+6
/* checking if input map is of required type */
if (check_data_type != map->data_type)
G_debug(1,
Modified: grass-addons/grass7/raster/r.stream.distance/main.c
--- grass-addons/grass7/raster/r.stream.distance/main.c 2014-03-27 12:30:49 UTC (rev 59405)
+++ grass-addons/grass7/raster/r.stream.distance/main.c 2014-03-27 12:33:42 UTC (rev 59406)
@@ -65,7 +65,7 @@
in_elev_opt = G_define_standard_option(G_OPT_R_ELEV);
in_elev_opt->required = NO;
- in_elev_opt->guisection = _("Input settings");
+ in_elev_opt->guisection = _("Input");
in_method_opt = G_define_option();
in_method_opt->key = "method";
@@ -79,13 +79,13 @@
out_dist_opt->key = "distance";
out_dist_opt->required = NO;
out_dist_opt->description = _("Name for output distance/accumulation raster map");
- out_dist_opt->guisection = _("Output settings");
+ out_dist_opt->guisection = _("Output");
out_diff_opt = G_define_standard_option(G_OPT_R_OUTPUT);
out_diff_opt->key = "difference";
out_diff_opt->required = NO;
out_diff_opt->description = _("Name for output elevation difference raster map");
- out_diff_opt->guisection = _("Output settings");
+ out_diff_opt->guisection = _("Output");
opt_swapsize = G_define_option();
opt_swapsize->key = "memory";
