[GRASS-SVN] r59442 - grass-addons/grass7/raster/r.stream.stats
Thu Mar 27 09:32:22 PDT 2014
Author: martinl
Date: 2014-03-27 09:32:22 -0700 (Thu, 27 Mar 2014)
New Revision: 59442
   grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html
r.stream.stats: manual syntax clean up
Modified: grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html
--- grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html	2014-03-27 16:28:29 UTC (rev 59441)
+++ grass-addons/grass7/raster/r.stream.stats/r.stream.stats.html	2014-03-27 16:32:22 UTC (rev 59442)
@@ -1,3 +1,9 @@
+<h2>DESCRIPTION</h2>
+<p>
+The module <em>r.stream.stats</em> is prepared to calculate Horton's
+statistics of drainage network.
 <h2>OPTIONS</h2>
 <dl>
 <dt><b>-c</b></dt>
@@ -5,67 +11,79 @@
 or collecting data in external tables.</dd>
 <dt><b>-o</b></dt>
 <dd>Print only parameters for every order. Useful to visualise Horton's law with
-external software (see example).</dd>
+external software (see example bellow).</dd>
 <dt><b>-m</b></dt>
 <dd>Only for very large data sets. Use segment library to optimise memory
 consumption during analysis.</dd>
 <dt><b>stream_rast</b></dt>
-<dd>Stream network: name of input stream raster map produced by r.watershed or
-r.stream.extract, on which ordering will be performed. Because stream network produced by
-r.watershed and r.stream.extract may slighty differ in detail, it is required to
-use both stream_rast and direction map produced by the same module. Stream_rast background
-shall have NULL value or zero value. Background values of NULL are by default
-produced by r.watershed and r.stream.extract. If not 0 or NULL use <a
-href="r.mapcalc.html">r.mapcalc</a> to set background values to NULL.
+<dd>Stream network: name of input stream raster map produced
+by <em><a href="r.watershed.html">r.watershed</a></em> or
+  <em><a href="r.stream.extract.html">r.stream.extract</a></em>, on
+which ordering will be performed. Because stream network produced by
+<em><a href="r.watershed.html">r.watershed</a></em>
+and <em><a href="r.stream.extract.html">r.stream.extract</a></em> may
+slighty differ in detail, it is required to use
+both <b>stream_rast</b> and direction map produced by the same
+module. The <b>stream_rast</b> background shall have NULL value or
+zero value. Background values of NULL are by default produced by
+and <em><a href="r.stream.extract.html">r.stream.extract</a></em>. If
+not 0 or NULL use <em><a href="r.mapcalc.html">r.mapcalc</a></em> to
+set background values to NULL.
 </dd>
 <dt><b>direction</b></dt>
-<dd>Flow direction: name of input direction map produced by r.watershed or
-r.stream.extract. If r.stream.extract output map is used, it only has non-NULL
-values in places where streams occur. NULL (nodata) cells are ignored, zero and
-negative values are valid direction data if they vary from -8 to 8 (CCW from
-East in steps of 45 degrees). Direction map shall be of type CELL values. Region
-resolution and map resolution must be the same.
-Also <em>stream_rast</em> network map must have the same resolution. It is checked by
-default. If resolutions differ the module informs about it and stops. Region
-boundary and maps boundary may differ but it may lead to unexpected
-results.</dd>
+<dd>Flow direction: name of input direction raster map produced by
+<em><a href="r.watershed.html">r.watershed</a></em> or
+  <em><a href="r.stream.extract.html">r.stream.extract</a></em>. If
+<em><a href="r.stream.extract.html">r.stream.extract</a></em> output
+raster map is used, it only has non-NULL values in places where
+streams occur. NULL (nodata) cells are ignored, zero and negative
+values are valid direction data if they vary from -8 to 8 (CCW from
+East in steps of 45 degrees). Direction map shall be of type CELL
+values. Region resolution and map resolution must be the same.
+Also <b>stream_rast</b> network map must have the same resolution. It
+is checked by default. If resolutions differ the module informs about
+it and stops. Region boundary and maps boundary may differ but it may
+lead to unexpected results.</dd>
 <dt><b>elevation</b></dt>
-<dd>Elevation: name of input elevation map. Map can be of type CELL, FCELL or
-DCELL. It is not restricted to resolution of region settings as stream_rast and
-direction.</dd>
+<dd>Elevation: name of input elevation map. Map can be of type CELL,
+FCELL or DCELL. It is not restricted to resolution of region settings
+as <b>stream_rast</b> and <b>direction</b> raster map.</dd>
-<h2>OUTPUTS</h2>
-Output statistics are send to standard output. To redirect output to file use
-redirection operators: > or >>. If redirection is used, output messages are
-printed on stderr (usually terminal) while statistics are written to the file.
-Statistics can be print as a formatted summary information with number of
-parameters or as a catchement's descriptive statistics and table with statistics
-for every order.
+<h3>OUTPUTS</h3>
+Output statistics are send to standard output. To redirect output to
+file use redirection operators: <tt><</tt> or <tt><<</tt>
+(Unix only). If redirection is used, output messages are printed on
+stderr (usually terminal) while statistics are written to the file.
+Statistics can be print as a formatted summary information with number
+of parameters or as a catchement's descriptive statistics and table
+with statistics for every order.
-<h2>DESCRIPTION</h2>
+<h2>NOTES</h2>
 <p>
-The module r.stream.stats is prepared to calculate Horton's statistics of drainage
-network.
-<p>
-These statistics are calculated according to formulas given by R.Horton (1945).
-Because Horton do not defined precisely what is stream slope, 2 different approaches
-have been proposed: the first (slope) uses cell-by-cell slope
-calculation; the second (gradient) uses the difference between elevation of outlet and
-source of every channel to its length to calculate formula. Bifurcation ratio
-for every order is calculated acording to the formula:
-<code>n_streams[1]/n_stream[i+1]</code>
-where i is the current order and i+1 is the next higher order. For max order of the map
-number of streams is zero. Rest of the ratios are calculated in similar mode.
-The bifurcation and other ratios for the whole catchment (map) is calculated as
-mean i.e. sum of all bifurcation ratio / max_order-1 (for max_order stream
-bifurcation ratio = 0).
-It is strongly recommended to extract the stream network using basin map created
-with r.stream.basins. If the whole stream order map is used, the calculation will be
-performed but results may not have hydrological sense.
+These statistics are calculated according to formulas given by
+R.Horton (1945). Because Horton do not defined precisely what is
+stream slope, 2 different approaches have been proposed: the first
+(slope) uses cell-by-cell slope calculation; the second (gradient)
+uses the difference between elevation of outlet and source of every
+channel to its length to calculate formula. Bifurcation ratio for
+every order is calculated acording to the formula:
+<tt>n_streams[1]/n_stream[i+1]</tt> where i is the current order
+and <tt>i+1</tt> is the next higher order. For max order of the cell
+value of streams is zero. Rest of the ratios are calculated in similar
+mode. The bifurcation and other ratios for the whole catchment (map)
+is calculated as mean i.e. sum of all bifurcation <tt>ratio /
+max_order-1</tt> (for max_order stream bifurcation <tt>ratio =
+0</tt>). It is strongly recommended to extract the stream network
+using basin map created with <em>r.stream.basins</em>. If the whole
+stream order raster map is used, the calculation will be performed but
+results may not have hydrological sense.
 For every order (std) means that statistics are calculated with standard deviation:
 <ul>
 <li>number of streams
 <li>total length of streams of a given order
@@ -79,57 +97,74 @@
 (std)
 <li>average area of basins of a given order (std)
 <li>avarage elevation difference of a given order (std)
-<p>ratios:
+</ul>
+Ratios:
+<ul>
 <li>bifuracation ratio
 <li>length ratio
 <li>slope and gradient ratios
 <li>area ratio
 </ul>
-for the whole basin:
+For the whole basin:
 <ul>
 <li>total number of streams
 <li>total basin area
 <li>drainage density
 <li>stream density
-<p>ratios:
+<ul>
+Ratios:
+</ul>
 <li>bifurcation ratio (std)
 <li>length ratio (std)
 <li>slope and gradient ratios (std)
 <li>area ratio (std)
 </ul>
 <p>
-For the whole basins ratios are calculated acording two formulas: as a mean of
-ratios for every order, or as a antilog of slope coefficient of the regression
-model: order vs. log10(parameter)
+For the whole basins ratios are calculated acording two formulas: as a
+mean of ratios for every order, or as a antilog of slope coefficient
+of the regression model: order vs. <tt>log10(parameter)</tt>
-<h2>NOTES</h2>
 <p>
-The module calculates statistics for all streams in input stream_rast map. It is strongly
-recommended to extract only network of one basin, but it is not necessary for
-computation. Streams for the desired basin can be extracted by the following
-r.mapcalc formula:
+The module calculates statistics for all streams in
+input <b>stream_rast</b> map. It is strongly recommended to extract
+only network of one basin, but it is not necessary for
+computation. Streams for the desired basin can be extracted by the
+following <em><a href="r.mapcalc.html">r.mapcalc</a></em> formula:
+<div class="code"<pre>
+echo 'sel_streams=if(basin==xxx,streams,null())' | r.mapcalc #xxx category of desired basin
+</pre></div>
 <p>
-<code>echo 'sel_streams=if(basin==xxx,streams,null())' | r.mapcalc #xxx category
-of desired basin</code>
-<p>
+It is also possible to calculate Horton's statistics for Shreve
+ordering but it has no hydrological sense. Hack (or Gravelius
+hierarchy) main stream is not the same what so called Horton's reverse
+ordering (see: Horton 1945).
-It is also possible to calculate Horton's statistics for Shreve ordering but it
-has no hydrological sense. Hack (or Gravelius hierarchy) main stream is not the
-same what so called Horton's reverse ordering (see: Horton 1945).
 <p>
-The module can work only if direction map, stream_rast map and region have the same
-settings. It is also required that stream_rast map and direction map come from the
-same source. For lots of reason this limitation probably cannot be omitted.
-This means that if stream_rast map comes from r.stream.extract also direction map from
-r.stream.extract must be used. If the stream network was generated with MFD method
-also MFD direction map must be used.
+The module can work only if <b>direction</b> raster
+map, <b>stream_rast</b> map and region have the same settings. It is
+also required that stream_rast map and direction map come from the
+same source. For lots of reason this limitation probably cannot be
+omitted.  This means that if stream_rast map comes from
+<em><a href="r.stream.extract.html">r.stream.extract</a></em> also
+direction map
+from <em><a href="r.stream.extract.html">r.stream.extract</a></em>
+must be used. If the stream network was generated with MFD method also
+MFD direction map must be used.
 <h2>EXAMPLE</h2>
-Create table with order statistics. This table can easily be sent to external
-program (like R) to be visualised:
+Create table with order statistics. This table can easily be sent to
+external program (like R) to be visualised:
 <div class="code"><pre>
 g.region -p -a rast=elevation align=elevation
 r.watershed elevation=elevation threshold=10000 drainage=direction stream=streams
@@ -153,12 +188,12 @@
 <a href="r.stream.extract.html">r.stream.extract</a>,
 <a href="r.stream.order.html">r.stream.order</a>,
 <a href="r.stream.basins.html">r.stream.basins</a>,
-<a href="r.mapcalc.html">r.mapcalc</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
 </em>
 <h2>AUTHOR</h2>
-Jarek Jasiewicz, Adam Mickiewicz University, Geoecology and Geoinformation
-Institute.
+Jarek Jasiewicz, Adam Mickiewicz University, Geoecology and Geoinformation Institute.
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
