[GRASS-SVN] r59443 - grass-addons/grass7/raster/r.stream.snap
Thu Mar 27 09:39:37 PDT 2014
Author: martinl
Date: 2014-03-27 09:39:36 -0700 (Thu, 27 Mar 2014)
New Revision: 59443
   grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html
r.stream.snap: manual syntax clean up
Modified: grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html
--- grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html	2014-03-27 16:32:22 UTC (rev 59442)
+++ grass-addons/grass7/raster/r.stream.snap/r.stream.snap.html	2014-03-27 16:39:36 UTC (rev 59443)
@@ -1,68 +1,84 @@
 <h2>DESCRIPTION</h2>
 <p>
-The module r.stream.snap is a supplementary module for r.stream.extract and
-r.stream.basins to correct position of outlets or stream initial points as they do
-not lie on the streamlines.
-<br>
-For outlets, the situation is clear. Points are snapped to nearest point which lies
-on the streamline. In situation where there can be a small tributuary nearer
-than main stream accumulation threshold shall be high enough to force the program
-ignoring this tributuary and snap to the main stream. If there is no
-accumulation map, the points will be snapped to the nearest stream line, which in
-particular situations may be wrong. Because the r.stream modules are prepared to work with
-MFD accumulation maps, both stream network and accumulation map are neccessary to resolve the
-problem.
-<br>
-While it is assumed that the accumulation map is a MFD map, if the stream network is not supplied,
-the snap point is calculated in different way: the threshold is used to select only these
-points in search radius which have accumulation value greater than the given threshold.
-The next mean value of these points is calculated and its value is taken as a new
-threshold. This procedure guarantees that points are snapped to the center of
-stream tube. While for inits small thresholds are in use, it is probable that
-points were snapped to the streamtube border instead of its center.
-</p>
+The module <em>r.stream.snap</em> is a supplementary module for
+<em><a href="r.stream.extract.html">r.stream.extract</a></em> and
+<em><a href="r.stream.basins.html">r.stream.basins</a></em> to correct
+position of outlets or stream initial points as they do not lie on the
+streamlines.
 <p>
-It is strongly recommended to use both stream network (even pre-generated with
-small accumulation threshold) and accumulation map, than accumulation or stream map only.
-</p>
+For outlets, the situation is clear. Points are snapped to nearest
+point which lies on the streamline. In situation where there can be a
+small tributuary nearer than main stream accumulation threshold shall
+be high enough to force the program ignoring this tributuary and snap
+to the main stream. If there is no accumulation map, the points will
+be snapped to the nearest stream line, which in particular situations
+may be wrong. Because the <em>r.stream.*</em> modules are prepared to
+work with MFD accumulation maps, both stream network and accumulation
+map are neccessary to resolve the problem.
+<p>
+While it is assumed that the accumulation map is a MFD map, if the
+stream network is not supplied, the snap point is calculated in
+different way: the threshold is used to select only these points in
+search radius which have accumulation value greater than the given
+threshold.  The next mean value of these points is calculated and its
+value is taken as a new threshold. This procedure guarantees that
+points are snapped to the center of stream tube. While for inits small
+thresholds are in use, it is probable that points were snapped to the
+streamtube border instead of its center.
+<p>
+It is strongly recommended to use both stream network (even
+pre-generated with small accumulation threshold) and accumulation
+raster map, than accumulation or stream raster map only.
 <h2>OPTIONS</h2>
 <dl>
 <dt><b>stream_rast</b></dt>
-<dd>Stream network created by r.stream.extract or r.watershed. If used, the points
-are snapped to the nearest streamline point whose accumulation is greater than
-threshold. If the accumulation is not used, the point is snapped to the nearest stream.
+<dd>Stream network created
+by <em><a href="r.stream.extract.html">r.stream.extract</a></em> or
+<em><a href="r.watershed.html">r.watershed</a></em>. If used, the
+points are snapped to the nearest streamline point whose accumulation
+is greater than threshold. If the accumulation is not used, the point
+is snapped to the nearest stream.
 </dd>
 <dt><b>accumulation</b></dt>
-<dd>Accumulation map created with r.watershed and used to generate the stream network
-with r.stream.extract. If the stream network is not used, the point is adaptively
-snapped to the point where the value is greater than mean values of accumulation
-greater than given threshold in a search radius. See description for details.
+<dd>Accumulation map created
+with <em><a href="r.watershed.html">r.watershed</a></em> and used to
+generate the stream network
+with <em><a href="r.stream.extract.html">r.stream.extract</a></em>. If
+the stream network is not used, the point is adaptively snapped to the
+point where the value is greater than mean values of accumulation
+greater than given threshold in a search radius. See description for
+details.
 </dd>
 <dt><b>radius</b></dt>
-<dd>Search radius (in cells). If there are no streams in the search radius, the point is
-not snapped. If there are no cells with accumulation greater than accumulation threshold, the
-point also is not snapped.
+<dd>Search radius (in cells). If there are no streams in the search
+radius, the point is not snapped. If there are no cells with
+accumulation greater than accumulation threshold, the point also is
+not snapped.
 </dd>
 <dt><b>threshold</b></dt>
-<dd>Minimum value of accumulation which cell must have to snap point. This
-option is added to snap stream inits to the stream tubes and to distinguish
-between local tributaries and main streams.
+<dd>Minimum value of accumulation which cell must have to snap
+point. This option is added to snap stream inits to the stream tubes
+and to distinguish between local tributaries and main streams.
 </dd>
 <dt><b>input</b></dt>
-<dd>Vector file containing outlets or inits as vector points. Only point's
-categories are used. Any table attached to it is ignored. Every point shall have his
-own unique category.
+<dd>Vector file containing outlets or inits as vector points. Only
+point's categories are used. Any table attached to it is
+ignored. Every point shall have his own unique category.
 </dd>
 </dl>
+<h3>OUTPUTS</h3>
-<h2>OUTPUTS</h2>
-<p>Vector file containing outlets or inits after snapping. On layer 1, the original
-categories are preserved, on layer 2 there are four categories which mean:</p>
+<p>Vector file containing outlets or inits after snapping. On layer 1,
+the original categories are preserved, on layer 2 there are four
+categories which mean:
 <ol>
 <li>skipped (not in use yet)
 <li>unresolved (points remain unsnapped due to lack of streams in search radius
@@ -97,5 +113,6 @@
 Jarek Jasiewicz, Adam Mickiewicz University, Geoecology and Geoinformation
 Institute.
-<p><i>Last changed: $Date$</i>
+<p>
+<i>Last changed: $Date$</i>
