[GRASS-SVN] r59492 - in grass/branches/releasebranch_7_0/raster: r.stream.distance r.stream.order r.stream.stats
svn_grass at osgeo.org
Fri Mar 28 04:34:56 PDT 2014
Author: hellik
Date: 2014-03-28 04:34:56 -0700 (Fri, 28 Mar 2014)
New Revision: 59492
grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c
grass/branches/releasebranch_7_0/raster/r.stream.order/main.c
grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c
r.stream.*: cosmetics - merge from trunk
Modified: grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c 2014-03-28 10:52:49 UTC (rev 59491)
+++ grass/branches/releasebranch_7_0/raster/r.stream.distance/main.c 2014-03-28 11:34:56 UTC (rev 59492)
@@ -7,8 +7,8 @@
* PURPOSE: Calculate distance and elevation over the streams and outlets
* according user's input data. The elevation and distance is calculated
* along watercourses
- * It uses any stream map and r.watershed or .stream.extreact direction map.
- * Stram input map shall contains streams or points outlets with or
+ * It uses any stream map and r.watershed or .stream.extract direction map.
+ * Stream input map shall contains streams or points outlets with or
* without unique categories
* COPYRIGHT: (C) 2002,2009-2014 by the GRASS Development Team
Modified: grass/branches/releasebranch_7_0/raster/r.stream.order/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.order/main.c 2014-03-28 10:52:49 UTC (rev 59491)
+++ grass/branches/releasebranch_7_0/raster/r.stream.order/main.c 2014-03-28 11:34:56 UTC (rev 59492)
@@ -8,7 +8,7 @@
* It use r.stream.extract or r.watershed output files:
* stream, direction, accumulation and elevation.
* The output are set of raster maps and vector file containing
- * addational stream attributes.
+ * additional stream attributes.
* COPYRIGHT: (C) 2009-2014 by the GRASS Development Team
Modified: grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c
--- grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c 2014-03-28 10:52:49 UTC (rev 59491)
+++ grass/branches/releasebranch_7_0/raster/r.stream.stats/main.c 2014-03-28 11:34:56 UTC (rev 59492)
@@ -5,7 +5,7 @@
* AUTHOR(S): Jarek Jasiewicz jarekj amu.edu.pl
* PURPOSE: Calculate Horton's statistics according stream network and elevation map.
- * Program calculates: Bifuarcation ratio, length ratio, area ratio,
+ * Program calculates: Bifurcation ratio, length ratio, area ratio,
* slope ratio and drainage density.
* It uses r.stream.order stream map, r.watershed direction map and DEM
* Stream input map shall contain streams ordered according Strahler's or
