[GRASS-SVN] r59493 - grass/trunk/gui/wxpython/xml
svn_grass at osgeo.org
Fri Mar 28 06:23:01 PDT 2014
Author: hellik
Date: 2014-03-28 06:23:00 -0700 (Fri, 28 Mar 2014)
New Revision: 59493
grass/trunk/gui/wxpython/xml/toolboxes.xml
r.stream.*: add new modules to toolbox
Modified: grass/trunk/gui/wxpython/xml/toolboxes.xml
--- grass/trunk/gui/wxpython/xml/toolboxes.xml 2014-03-28 11:34:56 UTC (rev 59492)
+++ grass/trunk/gui/wxpython/xml/toolboxes.xml 2014-03-28 13:23:00 UTC (rev 59493)
@@ -860,6 +860,30 @@
<module-item name="r.water.outlet">
<label>Watershed basin creation</label>
</module-item>
+ <module-item name="r.stream.channel">
+ <label>River channel characteristics</label>
+ </module-item>
+ <module-item name="r.stream.distance">
+ <label>River distance and elevation characteristics</label>
+ </module-item>
+ <module-item name="r.stream.extract">
+ <label>Extraction of stream networks</label>
+ </module-item>
+ <module-item name="r.stream.order">
+ <label>River ordering and hierarchy</label>
+ </module-item>
+ <module-item name="r.stream.segment">
+ <label>River segment characteristics</label>
+ </module-item>
+ <module-item name="r.stream.slope">
+ <label>River elevation change</label>
+ </module-item>
+ <module-item name="r.stream.snap">
+ <label>Position correction of water outlet point</label>
+ </module-item>
+ <module-item name="r.stream.stats">
+ <label>Horton's statistics</label>
+ </module-item>
<separator/>
<module-item name="r.sim.water">
<label>SIMWE Overland flow modeling</label>
