[GRASS-SVN] r59511 - grass-addons/grass7/raster/r.basin
Sat Mar 29 10:41:32 PDT 2014
Author: madi
Date: 2014-03-29 10:41:32 -0700 (Sat, 29 Mar 2014)
New Revision: 59511
   grass-addons/grass7/raster/r.basin/r.basin.py
topologic diameter fixed
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py	2014-03-29 17:19:58 UTC (rev 59510)
+++ grass-addons/grass7/raster/r.basin/r.basin.py	2014-03-29 17:41:32 UTC (rev 59511)
@@ -308,7 +308,7 @@
                     ##"\n" +
                     ##"g.extension r.stream.distance")
-        grass.run_command('r.stream.distance', stream_raster = r_outlet,
+        grass.run_command('r.stream.distance', stream_rast = r_outlet,
                                            direction = r_drainage,
                                            flags = 'o',
                                            distance = r_distance,
@@ -432,7 +432,7 @@
                   r_hack = r_hack,
                   r_mainchannel = r_mainchannel)
-        grass.message("doing r.thin")
+        ##grass.message("thinning ..")
         grass.run_command("r.thin", input = r_mainchannel,
                                 output = r_mainchannel+'_thin',
                                 overwrite = True)
@@ -442,7 +442,7 @@
                                    verbose = True,
                                    overwrite = True)
-        grass.message("doing v.what")
+        ##grass.message("doing v.what")
         param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
                                                      coordinates = '%s,%s' % (east,north),
                                                      distance = 5 )
@@ -460,6 +460,7 @@
         grass.run_command('r.to.vect', input = r_mainchannel_dim + '_thin',
                                    output = v_mainchannel_dim,
                                    type = 'line',
+                                   flags = 'v',
                                    verbose = True,
                                    overwrite = True)
         try:
@@ -579,13 +580,13 @@
         grass.run_command('g.remove', rast = 'r_elevation_crop', quiet = True)
         grass.run_command('g.remove', rast = r_height_average, quiet = True)
         grass.run_command('g.remove', rast = r_aspect_mod, quiet = True)
-        grass.run_command('g.remove', rast = r_mainchannel, quiet = True)
+        ##grass.run_command('g.remove', rast = r_mainchannel, quiet = True)
         grass.run_command('g.remove', rast = r_stream_e, quiet = True)
         grass.run_command('g.remove', rast = r_drainage_e, quiet = True)
         grass.run_command('g.remove', rast = r_mask, quiet = True)
         grass.run_command('g.remove', rast = r_ord_1, quiet = True)
         grass.run_command('g.remove', rast = r_average_hillslope, quiet = True)
-        grass.run_command('g.remove', rast = r_mainchannel_dim, quiet = True)
+        ##grass.run_command('g.remove', rast = r_mainchannel_dim, quiet = True)
         grass.run_command('g.remove', rast = r_outlet, quiet = True)
         grass.run_command('g.remove', rast = r_basin, quiet = True)
         grass.run_command('g.remove', rast = prefix+'_mainchannel_thin', quiet = True)
@@ -593,7 +594,7 @@
         grass.run_command('g.remove', rast = prefix+'_ord_1_thin', quiet = True)
         grass.run_command('g.remove', rast = prefix+'_stream_e_thin', quiet = True)
         grass.run_command('g.remove', vect = v_mainchannel_dim+'_point', quiet = True)
-        grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
+        ##grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
         grass.run_command('g.remove', vect = v_ord_1, quiet = True)
         if nomap :
