[GRASS-SVN] r59512 - grass-addons/grass7/raster/r.basin
Sat Mar 29 10:51:51 PDT 2014
Author: madi
Date: 2014-03-29 10:51:51 -0700 (Sat, 29 Mar 2014)
New Revision: 59512
   grass-addons/grass7/raster/r.basin/r.basin.py
cleanup
Modified: grass-addons/grass7/raster/r.basin/r.basin.py
--- grass-addons/grass7/raster/r.basin/r.basin.py	2014-03-29 17:41:32 UTC (rev 59511)
+++ grass-addons/grass7/raster/r.basin/r.basin.py	2014-03-29 17:51:51 UTC (rev 59512)
@@ -137,12 +137,6 @@
         th = options['threshold']
     # Stream extraction
-    #### check if we have the r.stream.extract addon
-    ##if not grass.find_program('r.stream.extract', '--help'):
-        ##grass.fatal(_("The 'r.stream.extract' module was not found, install it first:") +
-                    ##"\n" +
-                    ##"g.extension r.stream.extract")
     grass.run_command('r.stream.extract', elevation = r_elevation,
                                           accumulation = r_accumulation,
                                           threshold = th,
@@ -155,7 +149,7 @@
     try:
         # Delineation of basin
-        #### check if we have the r.stream.basins addon
+        ## check if r.stream.basins addon is installed
         if not grass.find_program('r.stream.basins', '--help'):
             grass.fatal(_("The 'r.stream.basins' module was not found, install it first:") +
                         "\n" +
@@ -270,12 +264,6 @@
         # Creation of order maps: strahler, horton, hack, shreeve
         grass.message( "Creating %s" % r_hack )
-        #### check if we have the r.stream.order addon
-        ##if not grass.find_program('r.stream.order', '--help'):
-            ##grass.fatal(_("The 'r.stream.order' module was not found, install it first:") +
-                    ##"\n" +
-                    ##"g.extension r.stream.order")
         grass.run_command('r.stream.order', stream_rast = r_stream_e,
                                         direction = r_drainage_e,
@@ -302,11 +290,6 @@
                                    rows = 4096,
                                    overwrite = True)
-        #### check if we have the r.stream.distance addon
-        ##if not grass.find_program('r.stream.distance', '--help'):
-            ##grass.fatal(_("The 'r.stream.distance' module was not found, install it first:") +
-                    ##"\n" +
-                    ##"g.extension r.stream.distance")
         grass.run_command('r.stream.distance', stream_rast = r_outlet,
                                            direction = r_drainage,
@@ -319,7 +302,7 @@
         grass.message( "##################################" )
-        #### check if we have the r.hypso addon
+        #### check if r.hypso addon is installed
         if not grass.find_program('r.hypso', '--help'):
             grass.fatal(_("The 'r.hypso' module was not found, install it first:") +
                     "\n" +
@@ -333,7 +316,7 @@
-        #### check if we have the r.width.funct addon
+        #### check if r.width.funct addon is installed
         if not grass.find_program('r.width.funct', '--help'):
             grass.fatal(_("The 'r.width.funct' module was not found, install it first:") +
                     "\n" +
@@ -362,7 +345,7 @@
         grass.message("r.stats.zonal done")
         mean_elev = float(grass.read_command('r.info', flags = 'r',
-                                                   map = r_height_average).split('\n')[0].split('=')[1])
+                                                       map = r_height_average).split('\n')[0].split('=')[1])
         grass.message("r.info done")
@@ -403,12 +386,10 @@
         se = dict_region_basin['e'], dict_region_basin['s']
         grass.message("Rectangle containing basin done")
         east1,north1 = coordinates.split(',')
         east = float(east1)
         north = float(north1)
         # Directing vector
         delta_x = abs(float(basin_east) - east)
         delta_y = abs(float(basin_north) - north)
@@ -432,7 +413,6 @@
                   r_hack = r_hack,
                   r_mainchannel = r_mainchannel)
-        ##grass.message("thinning ..")
         grass.run_command("r.thin", input = r_mainchannel,
                                 output = r_mainchannel+'_thin',
                                 overwrite = True)
@@ -441,8 +421,7 @@
                                    type = 'line',
                                    verbose = True,
                                    overwrite = True)
-        ##grass.message("doing v.what")
         param_mainchannel = grass.read_command('v.what', map = v_mainchannel,
                                                      coordinates = '%s,%s' % (east,north),
                                                      distance = 5 )
@@ -508,7 +487,6 @@
         S_f = area_basin / mainchannel
         # Characteristic altitudes
-             # Characteristic altitudes
         height_basin_average = grass.read_command('r.what', map = r_height_average ,
                                                         cache = 500 ,
                                                         coordinates = '%s,%s' % (east , north ))
@@ -555,11 +533,6 @@
         FSF = magnitudo / area_basin
         # Statistics
-        #### check if we have the r.stream.stats addon
-        ##if not grass.find_program('r.stream.stats', '--help'):
-            ##grass.fatal(_("The 'r.stream.stats' module was not found, install it first:") +
-                    ##"\n" +
-                    ##"g.extension r.stream.stats")
         stream_stats = grass.read_command('r.stream.stats', stream_rast = r_strahler,
@@ -580,13 +553,13 @@
         grass.run_command('g.remove', rast = 'r_elevation_crop', quiet = True)
         grass.run_command('g.remove', rast = r_height_average, quiet = True)
         grass.run_command('g.remove', rast = r_aspect_mod, quiet = True)
-        ##grass.run_command('g.remove', rast = r_mainchannel, quiet = True)
+        grass.run_command('g.remove', rast = r_mainchannel, quiet = True)
         grass.run_command('g.remove', rast = r_stream_e, quiet = True)
         grass.run_command('g.remove', rast = r_drainage_e, quiet = True)
         grass.run_command('g.remove', rast = r_mask, quiet = True)
         grass.run_command('g.remove', rast = r_ord_1, quiet = True)
         grass.run_command('g.remove', rast = r_average_hillslope, quiet = True)
-        ##grass.run_command('g.remove', rast = r_mainchannel_dim, quiet = True)
+        grass.run_command('g.remove', rast = r_mainchannel_dim, quiet = True)
         grass.run_command('g.remove', rast = r_outlet, quiet = True)
         grass.run_command('g.remove', rast = r_basin, quiet = True)
         grass.run_command('g.remove', rast = prefix+'_mainchannel_thin', quiet = True)
@@ -594,7 +567,7 @@
         grass.run_command('g.remove', rast = prefix+'_ord_1_thin', quiet = True)
         grass.run_command('g.remove', rast = prefix+'_stream_e_thin', quiet = True)
         grass.run_command('g.remove', vect = v_mainchannel_dim+'_point', quiet = True)
-        ##grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
+        grass.run_command('g.remove', vect = v_mainchannel_dim, quiet = True)
         grass.run_command('g.remove', vect = v_ord_1, quiet = True)
         if nomap :
