[GRASS-SVN] r59513 - grass/trunk/lib/vector
svn_grass at osgeo.org
Sat Mar 29 13:04:45 PDT 2014
Author: neteler
Date: 2014-03-29 13:04:45 -0700 (Sat, 29 Mar 2014)
New Revision: 59513
grass/trunk/lib/vector/vectorlib.dox
vectorlib.dox: point to user wiki, mention boundaries and categories
Modified: grass/trunk/lib/vector/vectorlib.dox
--- grass/trunk/lib/vector/vectorlib.dox 2014-03-29 17:51:51 UTC (rev 59512)
+++ grass/trunk/lib/vector/vectorlib.dox 2014-03-29 20:04:45 UTC (rev 59513)
@@ -293,8 +293,10 @@
\section vlibAttributes Attributes
-The old GRASS 4.x 'dig_cats' files are not used any more and vectors'
-attributes are stored in external database. Connection with the
+For a user-centric view about attribute management, see the explanations
+in the <a href="http://grasswiki.osgeo.org/wiki/Vector_Database_Management">GRASS GIS Wiki</a>.
+The attribute data are stored in external database. Connection with the
database is done through drivers based on \ref dbmilib. Records in a
table are linked to vector entities by layer and category number. The
layer identifies table and the category identifies record. I.e., for
@@ -313,6 +315,8 @@
The general DBMI settings are defined in the '$MAPSET/VAR' text file
(maintained with <tt>db.connect</tt> command at user level).
+Note: vector boundaries are (typically) handled without category since adjacent
+parcels might have two different categories which prevents from a unique assignment.
\section vlibGeometry Vector library feature geometry
