[GRASS-SVN] r60061 - grass/trunk/locale/po
svn_grass at osgeo.org
Sat May 3 14:04:35 PDT 2014
Author: hcho
Date: 2014-05-03 14:04:35 -0700 (Sat, 03 May 2014)
New Revision: 60061
Added:
grass/trunk/locale/po/grasswxpy_ko.po
grass/trunk/locale/po/grasslibs_ko.po
grass/trunk/locale/po/grassmods_ko.po
Added grasswxpy_ko.po template
Modified: grass/trunk/locale/po/grasslibs_ko.po
--- grass/trunk/locale/po/grasslibs_ko.po 2014-05-03 20:19:21 UTC (rev 60060)
+++ grass/trunk/locale/po/grasslibs_ko.po 2014-05-03 21:04:35 UTC (rev 60061)
@@ -8,7 +8,7 @@
msgstr ""
"Project-Id-Version: grasslibs_ko\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-31 21:29+0200\n"
+"POT-Creation-Date: 2014-05-03 16:44-0400\n"
"PO-Revision-Date: 2013-10-30 22:07-0500\n"
"Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -17,1783 +17,2093 @@
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-#: ../lib/raster/color_rules.c:125
-msgid "syntax error"
+#: ../lib/python/pygrass/functions.py:240
+msgid "Vector doesn't contain points"
msgstr ""
-#: ../lib/raster/color_rules.c:127
-msgid "R/G/B not in range 0-255"
+#: ../lib/python/pygrass/raster/category.py:83
+#, fuzzy
+msgid "Raser type: {0} not supported"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/python/pygrass/raster/category.py:168
+msgid "Error executing: Rast_get_ith_cat"
msgstr ""
-#: ../lib/raster/color_rules.c:129
+#: ../lib/python/pygrass/raster/category.py:196
#, fuzzy
-msgid "invalid color name"
-msgstr "잘못된 좌표"
+msgid "Null value detected"
-#: ../lib/raster/color_rules.c:131
-msgid "percentage not in range 0-100"
-msgstr ""
+#: ../lib/python/pygrass/raster/category.py:198
+#, fuzzy
+msgid "Error executing: Rast_set_cat"
-#: ../lib/raster/color_rules.c:133
-msgid "invalid value"
+#: ../lib/python/pygrass/raster/abstract.py:240
+msgid "Mode type: {0} not supported ('r', 'w')"
msgstr ""
-#: ../lib/raster/color_rules.c:135
-msgid "unknown error"
+#: ../lib/python/pygrass/raster/abstract.py:251
+msgid "Overwrite type: {0} not supported (True/False)"
msgstr ""
-#: ../lib/raster/color_rules.c:181
-#, c-format
-msgid "bad rule (%s): [%s]"
+#: ../lib/python/pygrass/raster/abstract.py:264
+#: ../lib/python/pygrass/vector/abstract.py:108
+msgid "Map name {0} not valid"
msgstr ""
-#: ../lib/raster/color_rules.c:328
-#, fuzzy, c-format
-msgid "Unable to load color rules <%s>"
+#: ../lib/python/pygrass/raster/__init__.py:180
+#, fuzzy
+msgid "Raster type not defined"
-#: ../lib/raster/color_read.c:103
-msgid "missing"
+#: ../lib/python/pygrass/raster/__init__.py:183
+#, fuzzy
+msgid "Raster map <{0}> already exists"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/python/pygrass/raster/__init__.py:189
+msgid "The map does not exist, I can't open in 'r' mode"
msgstr ""
-#: ../lib/raster/color_read.c:106
-msgid "invalid"
+#: ../lib/python/pygrass/raster/__init__.py:259
+msgid "Mode type: {0} not supported ('r', 'w','rw')"
msgstr ""
-#: ../lib/raster/color_read.c:112
-#, fuzzy, c-format
-msgid "Color support for <%s@%s> %s"
-msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 색상지원: %s"
+#: ../lib/python/pygrass/raster/__init__.py:278
+#, python-format
+msgid "Index out of range: %r."
+msgstr ""
-#: ../lib/raster/put_title.c:28
-#, c-format
-msgid "category information for [%s] in [%s] missing or invalid"
+#: ../lib/python/pygrass/raster/__init__.py:394
+#, fuzzy
+msgid "Raster map <{0}> already exists. Use overwrite."
+#: ../lib/python/pygrass/raster/__init__.py:425
+#, fuzzy
+msgid "Raster map <{0}> does not exists"
+msgstr "임시파일을 열 수 없습니다"
+#: ../lib/python/pygrass/raster/__init__.py:537
+msgid "Mode type: {0} not supported."
msgstr ""
-#: ../lib/raster/put_title.c:37
-msgid "G_put_title - can't create a temp file"
+#: ../lib/python/pygrass/raster/__init__.py:571
+#, fuzzy
+msgid "Invalid type {0}"
+#: ../lib/python/pygrass/raster/__init__.py:573
+#, fuzzy
+msgid "Invalid size {0}"
+#: ../lib/python/pygrass/vector/table.py:926
+#, python-format
+msgid "Deleting table <%s> which is attached to following map(s):"
msgstr ""
-#: ../lib/raster/put_title.c:53
-#, c-format
-msgid "category information for [%s] in [%s] invalid"
+#: ../lib/python/pygrass/vector/table.py:930
+msgid "You must use the force flag to actually remove it. Exiting."
msgstr ""
-#: ../lib/raster/put_title.c:60
-msgid "G_put_title - can't reopen temp file"
+#: ../lib/python/pygrass/errors.py:46
+msgid "The map is close!"
msgstr ""
-#: ../lib/raster/put_title.c:67
-#, c-format
-msgid "can't write category information for [%s] in [%s]"
+#: ../lib/python/script/raster3d.py:89
+msgid "An error occurred while running r3.mapcalc"
msgstr ""
-#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
-#, c-format
-msgid "Reading raster map <%s@%s> request for row %d is outside region"
+#: ../lib/python/script/db.py:48 ../lib/vector/Vlib/ascii.c:431
+#: ../lib/db/dbmi_client/column.c:136
+#, fuzzy, c-format, python-format
+msgid "Unable to describe table <%s>"
+#: ../lib/python/script/db.py:142
+#, python-format
+msgid ""
+"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
msgstr ""
-#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
-#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
-#: ../lib/raster/get_row.c:173 ../lib/raster/get_row.c:176
+#: ../lib/python/script/db.py:154
#, fuzzy
-msgid "Error reading raster data"
+msgid "Fetching data failed"
-#: ../lib/raster/get_row.c:211
+#: ../lib/python/script/raster.py:47
+#, fuzzy, python-format
+msgid ""
+"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
+"current mapset."
+#: ../lib/python/script/raster.py:105
+msgid "An error occurred while running r.mapcalc"
+msgstr ""
+#: ../lib/python/script/raster.py:162
#, fuzzy
-msgid "Error reading raster data via GDAL"
+msgid "No data"
-#: ../lib/raster/get_row.c:822 ../lib/raster/get_row.c:825
-#, fuzzy, c-format
-msgid "Error reading null row %d"
-msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
+#: ../lib/python/script/raster.py:170
+msgid "value"
+msgstr ""
-#: ../lib/raster/interp.c:211
-#, fuzzy, c-format
-msgid "Unknown interpolation method: %s"
+msgid "label"
+msgstr ""
+msgid "color"
+msgstr ""
+#: ../lib/python/script/task.py:52
+#, fuzzy
+msgid "unknown"
msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/raster/reclass.c:168
-#, fuzzy, c-format
-msgid "Too many reclass categories for <%s@%s>"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/python/script/task.py:166
+#, python-format
+msgid "Parameter element '%(element)s' not found: '%(value)s'"
+msgstr ""
-#: ../lib/raster/reclass.c:171
-#, fuzzy, c-format
-msgid "Illegal reclass format in header file for <%s@%s>"
-msgstr "임시파일을 열 수 없습니다"
+#: ../lib/python/script/task.py:181
+#, python-format
+msgid "Flag not found: %s"
+msgstr ""
-#: ../lib/raster/reclass.c:273
-msgid "Illegal reclass request"
+#: ../lib/python/script/task.py:200
+#, python-format
+msgid "Parameter '%(name)s' (%(desc)s) is missing."
msgstr ""
-#: ../lib/raster/reclass.c:278
-msgid "Illegal reclass type"
+#: ../lib/python/script/task.py:231
+msgid "<required>"
msgstr ""
-#: ../lib/raster/reclass.c:284
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s@%s>"
+#: ../lib/python/script/task.py:486 ../lib/python/script/task.py:490
+#, python-format
+msgid ""
+"Unable to fetch interface description for command '%(cmd)s'.\n"
+"\n"
+"Details: %(det)s"
+msgstr ""
-#: ../lib/raster/reclass.c:332
-#, fuzzy, c-format
-msgid "Unable to create dependency file in <%s@%s>"
+#: ../lib/python/script/vector.py:88
+#, python-format
+msgid "Database connection not defined for layer %s"
+msgstr ""
+#: ../lib/python/script/vector.py:238
+msgid "Missing layer %(layer)d in vector map <%(map)s>"
-#: ../lib/raster/put_cellhd.c:34
-#, fuzzy, c-format
-msgid "Unable to create header file for <%s>"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/python/script/vector.py:256
+msgid "vector_db_select() failed"
+msgstr ""
-#: ../lib/raster/cats.c:109
-#, fuzzy, c-format
-msgid "Category support for <%s@%s> missing"
+#: ../lib/python/script/core.py:934
+msgid "Mixing value types. Will try to compare after integer conversion"
+msgstr ""
-#: ../lib/raster/cats.c:112
-#, fuzzy, c-format
-msgid "Category support for <%s@%s> invalid"
+#: ../lib/python/script/core.py:1152
+#, python-format
+msgid "Element type should be \"cell\" and not \"%s\""
+msgstr ""
-#: ../lib/raster/cats.c:145
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> missing"
-msgstr "벡터맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
+#: ../lib/python/script/core.py:1181 ../lib/python/script/core.py:1271
+#: ../lib/python/script/core.py:1326
+#, python-format
+msgid "Element type should be \"rast\" and not \"%s\""
+msgstr ""
-#: ../lib/raster/cats.c:149
-#, fuzzy, c-format
-msgid "Category support for vector map <%s@%s> invalid"
+#: ../lib/python/script/core.py:1339 ../lib/python/temporal/gui_support.py:57
+#, python-format
+msgid "Invalid element '%s'"
+msgstr ""
-#: ../lib/raster/cats.c:968
-#, fuzzy, c-format
-msgid "Unable to open %s file for map <%s>"
+#: ../lib/python/script/core.py:1527
+#, fuzzy
+msgid "Unable to list mapsets"
-#: ../lib/raster/window.c:18
-msgid ""
-"Internal error: Rast_get_window() called with split window. Use "
-"Rast_get_input_window() or Rast_get_output_window() instead."
+#: ../lib/python/script/core.py:1563
+#, python-format
+msgid "Location <%s> already exists. Operation canceled."
msgstr ""
-#: ../lib/raster/window.c:77
-msgid ""
-"Internal error: Rast_window_rows() called with split window. Use "
-"Rast_input_window_rows() or Rast_output_window_rows() instead."
+#: ../lib/python/script/core.py:1566
+msgid "Location <%s> already exists and will be overwritten"
+#: ../lib/python/script/core.py:1698
+#, python-format
+msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
msgstr ""
-#: ../lib/raster/window.c:112
+#: ../lib/python/script/core.py:1707
+#, python-format
+msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+msgstr ""
+#: ../lib/python/temporal/temporal_algebra.py:826
+msgid "Space time %s dataset <%s> not found"
+#: ../lib/python/temporal/temporal_algebra.py:844
+#: ../lib/python/temporal/temporal_algebra.py:848
+#, python-format
msgid ""
-"Internal error: Rast_window_cols() called with split window. Use "
-"Rast_input_window_cols() or Rast_output_window_cols() instead."
+"Wrong temporal type of space time dataset <"
+"%s> <%s> time is required"
msgstr ""
-#: ../lib/raster/quant_rw.c:88
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
+#: ../lib/python/temporal/univar_statistics.py:54
+#: ../lib/python/temporal/univar_statistics.py:149
+msgid "Space time %(sp)s dataset <%(i)s> is empty"
+#: ../lib/python/temporal/univar_statistics.py:87
+msgid "Unable to get statistics for raster map <%s>"
-#: ../lib/raster/quant_rw.c:92
-#, fuzzy, c-format
-msgid "Raster map <%s> is empty"
+#: ../lib/python/temporal/univar_statistics.py:89
+msgid "Unable to get statistics for 3d raster map <%s>"
+#: ../lib/python/temporal/univar_statistics.py:139
+msgid "Space time %(sp)s dataset <%(i)s> not found"
-#: ../lib/raster/quant_rw.c:157
-#, fuzzy, c-format
-msgid "Unable to write quant rules: raster map <%s> is integer"
+#: ../lib/python/temporal/univar_statistics.py:190
+msgid "Unable to get statistics for vector map <%s>"
-#: ../lib/raster/quant_rw.c:166
-#, fuzzy, c-format
-msgid "Unable to write quant rules for raster map <%s>"
+#: ../lib/python/temporal/list_stds.py:178
+msgid "Empty map list."
+msgstr ""
-#: ../lib/raster/set_window.c:48
-msgid "Rast_set_window() called while window split"
+#: ../lib/python/temporal/list_stds.py:189
+msgid "Empty entry in map list, this should not happen."
msgstr ""
-#: ../lib/raster/set_window.c:131
+#: ../lib/python/temporal/spatial_extent.py:125
msgid ""
-"Rast_set_read_window(): projection/zone differs from that of currently open "
-"raster maps"
+"Projections are different. Unable to compute overlapping_2d for spatial "
+"extents"
msgstr ""
-#: ../lib/raster/set_window.c:158
-#, c-format
-msgid "Input window changed while maps are open for read. Map name <%s>"
+#: ../lib/python/temporal/spatial_extent.py:536
+msgid ""
+"Projections are different. Unable to compute is_in_2d for spatial extents"
msgstr ""
-#: ../lib/raster/set_window.c:174
-#, c-format
-msgid "Output window changed while maps are open for write. Map name <%s>"
+#: ../lib/python/temporal/spatial_extent.py:676
+msgid ""
+"Projections are different. Unable to compute equivalent_2d for spatial "
+"extents"
msgstr ""
-#: ../lib/raster/null_val.c:64
-msgid "EmbedGivenNulls: wrong data type"
+#: ../lib/python/temporal/spatial_extent.py:783
+msgid ""
+"Projections are different. Unable to compute cover_2d for spatial extents"
msgstr ""
-#: ../lib/raster/null_val.c:114
-msgid "Rast_set_null_value: wrong data type!"
+#: ../lib/python/temporal/spatial_extent.py:854
+msgid "Projections are different. Unable to compute cover for spatial extents"
msgstr ""
-#: ../lib/raster/mask_info.c:43
-#, c-format
-msgid "<%s> in mapset <%s>"
+#: ../lib/python/temporal/spatial_extent.py:1704
+msgid "Volume computation is not supported for LL projections"
msgstr ""
-#: ../lib/raster/mask_info.c:46
-msgid "none"
+#: ../lib/python/temporal/spatial_extent.py:1722
+msgid "Area computation is not supported for LL projections"
msgstr ""
-#: ../lib/raster/mask_info.c:49
-msgid "not known"
-msgstr ""
+#: ../lib/python/temporal/temporal_raster_algebra.py:85
+#, fuzzy
+msgid "Removing empty raster maps"
-#: ../lib/raster/sample.c:70
-msgid "Unknown interpolation type"
+#: ../lib/python/temporal/datetime_math.py:254
+#: ../lib/python/temporal/datetime_math.py:271
+#, python-format
+msgid "Wrong increment format: %s"
msgstr ""
-#: ../lib/raster/sample.c:327
-msgid "\"no data\" label found; setting to zero"
+#: ../lib/python/temporal/datetime_math.py:447
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1546
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1579
+#, python-format
+msgid "Wrong granularity format: %s"
msgstr ""
-#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
-#, c-format
-msgid "Qualified name <%s> doesn't match mapset <%s>"
+#: ../lib/python/temporal/datetime_math.py:725
+msgid "Time string seems to specify relative time"
msgstr ""
-#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
-#, fuzzy, c-format
-msgid "Unable to create <%s> file for map <%s>"
+#: ../lib/python/temporal/datetime_math.py:737
+#, fuzzy
+msgid "Dates Before Christ are not supported"
-#: ../lib/raster/put_row.c:120
-#, fuzzy, c-format
-msgid "Error writing uncompressed FP data for row %d of <%s>"
+#: ../lib/python/temporal/datetime_math.py:741
+#, fuzzy
+msgid "Time zones are not supported"
-#: ../lib/raster/put_row.c:130
-#, fuzzy, c-format
-msgid "Error writing compressed FP data for row %d of <%s>"
+#: ../lib/python/temporal/datetime_math.py:751
+msgid "Unable to parse time string: %s"
-#: ../lib/raster/put_row.c:389 ../lib/raster/put_row.c:395
-#, fuzzy, c-format
-msgid "Error writing compressed data for row %d of <%s>"
+#: ../lib/python/temporal/base.py:378
+msgid "Object <%s> not found in the temporal database"
-#: ../lib/raster/put_row.c:405
-#, fuzzy, c-format
-msgid "Error writing uncompressed data for row %d of <%s>"
+#: ../lib/python/temporal/base.py:459 ../lib/python/temporal/base.py:509
+msgid "Missing identifer"
+msgstr ""
-#: ../lib/raster/put_row.c:464
-#, fuzzy, c-format
-msgid "Error writing data via GDAL for row %d of <%s>"
+#: ../lib/python/temporal/base.py:615
+#, fuzzy
+msgid "Wrong identifier, the mapset is missing"
-#: ../lib/raster/put_row.c:488
-#, fuzzy, c-format
-msgid "No null file for <%s>"
+#: ../lib/python/temporal/temporal_raster_base_algebra.py:316
+msgid "Error computing map <%s>"
-#: ../lib/raster/put_row.c:502
-msgid "GDAL output doesn't support writing null rows separately"
+#: ../lib/python/temporal/mapcalc.py:105
+msgid "Start spatio-temporal sampling"
msgstr ""
-#: ../lib/raster/put_row.c:522
-#, fuzzy, c-format
-msgid "Unable to find a temporary null file <%s>"
+#: ../lib/python/temporal/mapcalc.py:107
+msgid "Start temporal sampling"
+msgstr ""
-#: ../lib/raster/put_row.c:527
-#, fuzzy, c-format
-msgid "Unable to open null file <%s>"
+#: ../lib/python/temporal/mapcalc.py:124
+msgid "No samples found for map calculation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:151
+msgid ""
+"Found more than a single map in a sample granule. Only the first map is used "
+"for computation. Use t.rast.aggregate.ds to create synchronous raster "
+"datasets."
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:169
+msgid "No maps in input dataset"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:185
+msgid "Start mapcalc computation"
+msgstr ""
+#: ../lib/python/temporal/mapcalc.py:235
+#: ../lib/python/temporal/open_stds.py:205
+#: ../lib/python/temporal/extract.py:112
+msgid ""
+"Map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/raster/put_row.c:554 ../lib/raster/put_row.c:557
-#, fuzzy, c-format
-msgid "Error writing null row %d"
+#: ../lib/python/temporal/mapcalc.py:255
+#, python-format
+msgid "Apply mapcalc expression: \"%s\""
+msgstr ""
-#: ../lib/raster/put_row.c:682
-#, c-format
-msgid "put_raster_row: raster map <%s> not open for write - request ignored"
+#: ../lib/python/temporal/mapcalc.py:274
+msgid "Error while mapcalc computation"
msgstr ""
-#: ../lib/raster/put_row.c:689
-msgid "put_raster_row: unopened file descriptor - request ignored"
+#: ../lib/python/temporal/mapcalc.py:280
+#, fuzzy
+msgid "Start map registration in temporal database"
+#: ../lib/python/temporal/mapcalc.py:430 ../lib/python/temporal/mapcalc.py:436
+#: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
+#: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
+#: ../lib/python/temporal/mapcalc.py:466 ../lib/python/temporal/mapcalc.py:472
+#: ../lib/python/temporal/mapcalc.py:478 ../lib/python/temporal/mapcalc.py:513
+#: ../lib/python/temporal/mapcalc.py:522 ../lib/python/temporal/mapcalc.py:531
+#: ../lib/python/temporal/mapcalc.py:540 ../lib/python/temporal/mapcalc.py:549
+#: ../lib/python/temporal/mapcalc.py:558 ../lib/python/temporal/mapcalc.py:567
+#: ../lib/python/temporal/mapcalc.py:576 ../lib/python/temporal/mapcalc.py:585
+#, python-format
+msgid "The temporal operators <%s> supports only absolutetime."
msgstr ""
-#: ../lib/raster/range.c:102 ../lib/raster/range.c:110
-#, fuzzy, c-format
-msgid "Unable to read fp range file for <%s>"
+#: ../lib/python/temporal/temporal_vector_algebra.py:641
+#, python-format
+msgid ""
+"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
+"file"
+msgstr ""
-#: ../lib/raster/range.c:169
-#, fuzzy, c-format
-msgid "Unable to read quant rules for raster map <%s>"
+#: ../lib/python/temporal/temporal_vector_algebra.py:673
+msgid ""
+"Error starting %s : \n"
+"%s"
+#: ../lib/python/temporal/temporal_vector_algebra.py:721
+msgid ""
+"Error vector map %s exist in temporal database. Use overwrite flag. : \n"
+"%s"
-#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
-#, fuzzy, c-format
-msgid "Unable to read range file for <%s>"
+#: ../lib/python/temporal/open_stds.py:60
+#: ../lib/python/temporal/open_stds.py:115
+msgid "Unkown type: %s"
+msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/python/temporal/open_stds.py:66
+msgid "Space time %(sp)s dataset <%(name)s> no found"
-#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
-#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
-#, fuzzy, c-format
-msgid "Unable to write range file for <%s>"
+#: ../lib/python/temporal/open_stds.py:104
+#, fuzzy
+msgid "Space time datasets can only be created in the current mapset"
-#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
-#, fuzzy, c-format
-msgid "Unable to get history information for <%s@%s>"
+#: ../lib/python/temporal/open_stds.py:121
+msgid ""
+"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
+"overwrite flag."
+#: ../lib/python/temporal/open_stds.py:155
+msgid "Overwrite space time %(sp)s dataset <%(name)s> and unregister all maps."
-#: ../lib/raster/history.c:162
-#, fuzzy, c-format
-msgid "Unable to write history information for <%s>"
+#: ../lib/python/temporal/open_stds.py:163
+msgid "Create new space time %s dataset."
-#: ../lib/raster/history.c:235
-#, c-format
-msgid "generated by %s"
-msgstr ""
-#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
-#, fuzzy, c-format
-msgid "Invalid descriptor: %d"
+#: ../lib/python/temporal/aggregation.py:124
+msgid "Aggregate %s raster maps"
-#: ../lib/raster/close.c:373
-#, fuzzy, c-format
-msgid "Unable to rename null file '%s' to '%s'"
+#: ../lib/python/temporal/aggregation.py:138
+msgid ""
+"Raster map <%s> is already in temporal database, use overwrite flag to "
+"overwrite"
-#: ../lib/raster/close.c:439
-#, fuzzy, c-format
-msgid "Unable to rename cell file '%s' to '%s'"
+#: ../lib/python/temporal/aggregation.py:142
+#, python-format
+msgid "Compute aggregation of maps between %(st)s - %(end)s"
+msgstr ""
-#: ../lib/raster/close.c:474
-msgid "unable to write f_format file for CELL maps"
+#: ../lib/python/temporal/aggregation.py:161
+msgid "Error while r.series computation"
msgstr ""
-#: ../lib/raster/auto_mask.c:69
-msgid "Unable to open automatic MASK file"
-msgstr "자동 MASK 파일을 열 수 없습니다."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:155
+#: ../lib/python/temporal/abstract_space_time_dataset.py:289
+msgid "Unknown temporal type \"%s\""
-#: ../lib/raster/raster_metadata.c:109
-#, fuzzy, c-format
-msgid "Unable to read <%s> for raster map <%s@%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:282
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1054
+#, python-format
+msgid "Wrong granularity: \"%s\""
+msgstr ""
-#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
-#, fuzzy, c-format
-msgid "Error closing <%s> metadata file for raster map <%s@%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:310
+msgid "Unsupported temporal unit: %s"
-#: ../lib/raster/raster_metadata.c:142
-#, fuzzy, c-format
-msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:359
+msgid "Created register table <%s> for space time %s dataset <%s>"
-#: ../lib/raster/alloc_cell.c:151
-#, c-format
-msgid "Rast__null_bitstream_size: cols (%d) is negative"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:678
+#: ../lib/python/temporal/abstract_space_time_dataset.py:924
+msgid "The space time datasets must be of the same temporal type"
msgstr ""
-#: ../lib/raster/get_cellhd.c:66
-#, fuzzy, c-format
-msgid ""
-"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
-"map <%s@%s> %s"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:683
+#: ../lib/python/temporal/abstract_space_time_dataset.py:929
+msgid "The temporal map type of the sample dataset must be interval"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1464
+msgid "Unable to get map ids from register table <%s>"
-#: ../lib/raster/get_cellhd.c:70
-msgid "which is missing."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1574
+#, python-format
+msgid ""
+"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+"The mapset of the dataset does not match the current mapset"
msgstr ""
-#: ../lib/raster/get_cellhd.c:71
-msgid "whose header file can't be opened."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1741
+#, python-format
+msgid ""
+"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
msgstr ""
-#: ../lib/raster/get_cellhd.c:76
-#, fuzzy, c-format
-msgid "Unable to open header file for raster map <%s@%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1841
+#, python-format
+msgid ""
+"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
-#: ../lib/raster/init.c:61
-msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1848
+msgid "Renaming of space time datasets is not supported for PostgreSQL."
msgstr ""
-#: ../lib/raster/quant_io.c:43
-#, fuzzy, c-format
-msgid "Floating data range for raster map <%s> is empty"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1911
+msgid "Delete space time %s dataset <%s> from temporal database"
-#: ../lib/raster/quant_io.c:52
-#, fuzzy, c-format
-msgid "Integer data range for raster map <%s> is empty"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1917
+#: ../lib/python/temporal/abstract_map_dataset.py:805
+#, python-format
+msgid ""
+"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
+"database. The mapset of the dataset does not match the current mapset"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1928
+msgid "Drop map register table: %s"
-#: ../lib/raster/quant_io.c:105
-#, fuzzy, c-format
-msgid "Attempt to open quantization table for CELL raster map <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:1983
+#, fuzzy
+msgid "Error in register table request"
-#: ../lib/raster/quant_io.c:135
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is missing"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2011
+msgid ""
+"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
+"the dataset does not match the current mapset"
-#: ../lib/raster/quant_io.c:145
-#, fuzzy, c-format
-msgid "Quantization file for raster map <%s> is empty"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2019
+msgid ""
+"Only a map that was inserted in the temporal database can be registered in a "
+"space time dataset"
+msgstr ""
-#: ../lib/raster/format.c:154
-#, c-format
-msgid "Fail of initial read of compressed file [%s in %s]"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2039
+#, python-format
+msgid "Map <%(id)s> with layer %(l)s has invalid time"
msgstr ""
-#: ../lib/raster/gdal.c:88
-#, fuzzy, c-format
-msgid "Unable to locate symbol <%s>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2042
+#, python-format
+msgid "Map <%s> has invalid time"
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2060
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
+"%(l)s are different"
-#: ../lib/raster/gdal.c:140
-#, fuzzy
-msgid "Unable to load GDAL library"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2065
+msgid ""
+"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
-#: ../lib/raster/gdal.c:370
-#, fuzzy
-msgid "Unable to open GDAL file"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2079
+msgid "Set temporal unit for space time %s dataset <%s> to %s"
-#: ../lib/raster/gdal.c:474 ../lib/raster/open.c:569
-#, fuzzy, c-format
-msgid "Invalid map type <%d>"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2088
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
+"layer %(l)s are different"
+msgstr ""
-#: ../lib/raster/gdal.c:480
-#, fuzzy, c-format
-msgid "Unable to get <%s> driver"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2094
+#, python-format
+msgid ""
+"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
+"different"
+msgstr ""
-#: ../lib/raster/gdal.c:489
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using <%s> driver"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2100
+msgid "Only maps from the same mapset can be registered"
+msgstr ""
-#: ../lib/raster/gdal.c:497
-#, c-format
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2105
+msgid "Map <%(map)s> with layer %(l)s is already registered."
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2109
+#, python-format
+msgid "Map <%s> is already registered."
+msgstr ""
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2156
+#, python-format
msgid ""
-"Driver <%s> does not support direct writing. Using MEM driver for "
-"intermediate dataset."
+"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
+"temporal database. The mapset of the dataset does not match the current "
+"mapset"
msgstr ""
-#: ../lib/raster/gdal.c:503
-#, fuzzy
-msgid "Unable to get in-memory raster driver"
-msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2167
+msgid ""
+"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
+"%(base)s>"
-#: ../lib/raster/gdal.c:510
-#, fuzzy, c-format
-msgid "Unable to create <%s> dataset using memory driver"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2172
+msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
-#: ../lib/raster/gdal.c:514
-#, c-format
-msgid "Driver <%s> does not support creating rasters"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2224
+#: ../lib/python/temporal/abstract_map_dataset.py:408
+#: ../lib/python/temporal/abstract_map_dataset.py:499
+#: ../lib/python/temporal/abstract_dataset.py:428
+#: ../lib/python/temporal/abstract_dataset.py:469
+#, python-format
+msgid ""
+"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
msgstr ""
-#: ../lib/raster/gdal.c:530
-#, fuzzy
-msgid "Unable to set geo transform"
+#: ../lib/python/temporal/abstract_space_time_dataset.py:2228
+#, python-format
+msgid ""
+"Update metadata, spatial and temporal extent from all registered maps of <%s>"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:223
+msgid "Unable to read timestamp file for raster map <%s>"
-#: ../lib/raster/gdal.c:534
-#, fuzzy
-msgid "Unable to set projection"
+#: ../lib/python/temporal/space_time_datasets.py:247
+msgid "Unable to create timestamp file for raster map <%s>"
-#: ../lib/raster/gdal.c:538
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
+#: ../lib/python/temporal/space_time_datasets.py:252
+msgid "Invalid datetime in timestamp for raster map <%s>"
-#: ../lib/raster/gdal.c:554
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
+#: ../lib/python/temporal/space_time_datasets.py:257
+#: ../lib/python/temporal/space_time_datasets.py:572
+msgid "Internal error"
+msgstr ""
+#: ../lib/python/temporal/space_time_datasets.py:274
+#: ../lib/python/temporal/space_time_datasets.py:586
+msgid "Unable to remove timestamp for raster map <%s>"
+#: ../lib/python/temporal/space_time_datasets.py:538
+msgid "Unable to read timestamp file for 3D raster map <%s>"
+#: ../lib/python/temporal/space_time_datasets.py:562
+msgid "Unable to create timestamp file for 3D raster map <%s>"
+#: ../lib/python/temporal/space_time_datasets.py:567
+msgid "Invalid datetime in timestamp for 3D raster map <%s>"
-#: ../lib/raster/gdal.c:602
-#, fuzzy, c-format
-msgid "Unable to create output file <%s> using driver <%s>"
+#: ../lib/python/temporal/space_time_datasets.py:812
+msgid "Unable to read timestamp file for vector map <%s>"
-#: ../lib/raster/histogram.c:55
-#, c-format
-msgid "Histogram for [%s in %s] missing (run r.support)"
+#: ../lib/python/temporal/space_time_datasets.py:835
+msgid "Unable to create timestamp file for vector map <%s>"
+#: ../lib/python/temporal/space_time_datasets.py:840
+msgid "Invalid datetime in timestamp for vector map <%s>"
+#: ../lib/python/temporal/space_time_datasets.py:856
+msgid "Unable to remove timestamp for vector map <%s>"
+#: ../lib/python/temporal/factory.py:51
+msgid "Unknown dataset type: %s"
+#: ../lib/python/temporal/register.py:77
+#, python-format
+msgid "%(m)s= and %(f)s= are mutually exclusive"
msgstr ""
-#: ../lib/raster/histogram.c:62
-#, c-format
-msgid "Can't read histogram for [%s in %s]"
+#: ../lib/python/temporal/register.py:81
+#, python-format
+msgid "%(e)s= and %(i)s= are mutually exclusive"
msgstr ""
-#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
-#, c-format
-msgid "Invalid histogram file for [%s in %s]"
+#: ../lib/python/temporal/register.py:85
+#, python-format
+msgid "Please specify %(st)s= and %(e)s="
msgstr ""
-#: ../lib/raster/histogram.c:331
-#, fuzzy, c-format
-msgid "Unable to create histogram file for <%s>"
-#: ../lib/raster/open.c:175 ../lib/raster/open.c:744 ../lib/raster/open.c:781
-#: ../lib/raster/open.c:833 ../lib/ogsf/Gs3.c:125 ../lib/ogsf/Gs3.c:189
-#: ../lib/ogsf/Gs3.c:264 ../lib/ogsf/Gs3.c:336 ../lib/ogsf/Gs3.c:442
-#: ../lib/ogsf/Gs3.c:529 ../lib/ogsf/Gs3.c:588 ../lib/ogsf/Gs3.c:645
-#: ../lib/ogsf/Gs3.c:716 ../lib/ogsf/Gs3.c:786 ../lib/ogsf/gsd_legend.c:239
-#: ../lib/manage/do_rename.c:71 ../lib/manage/do_remove.c:73
-#: ../lib/gis/legal_name.c:94 ../lib/gis/legal_name.c:97
-#: ../lib/rst/interp_float/resout2d.c:205
-#: ../lib/rst/interp_float/resout2d.c:253
-#: ../lib/rst/interp_float/resout2d.c:296
-#: ../lib/rst/interp_float/resout2d.c:327
-#: ../lib/rst/interp_float/resout2d.c:377
-#: ../lib/rst/interp_float/resout2d.c:395
-#: ../lib/rst/interp_float/resout2d.c:410
-#: ../lib/rst/interp_float/resout2d.c:426
-#: ../lib/rst/interp_float/output2d.c:236
-#: ../lib/rst/interp_float/output2d.c:317
-#: ../lib/rst/interp_float/output2d.c:386
-#: ../lib/rst/interp_float/output2d.c:436
-#: ../lib/rst/interp_float/output2d.c:450
-#: ../lib/rst/interp_float/output2d.c:464
-#: ../lib/rst/interp_float/output2d.c:480
-#, c-format
-msgid "Raster map <%s> not found"
+#: ../lib/python/temporal/register.py:89
+#, python-format
+msgid "Please specify %(m)s= or %(f)s="
msgstr ""
-#: ../lib/raster/open.c:190
-#, c-format
+#: ../lib/python/temporal/register.py:101
+#, python-format
msgid ""
-"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
-"%s> which does not exist"
+"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
+"relative unit set for %(sp)s maps"
msgstr ""
-#: ../lib/raster/open.c:195
-#, fuzzy, c-format
-msgid "Error reading reclass file for raster map <%s>"
+#: ../lib/python/temporal/register.py:167
+msgid "Gathering map informations"
+msgstr ""
-#: ../lib/raster/open.c:206
-#, fuzzy, c-format
-msgid "Error reading map type for raster map <%s>"
+#: ../lib/python/temporal/register.py:177
+msgid "Unable to update %(t)s map <%(id)s>. The map does not exists."
-#: ../lib/raster/open.c:214
-#, c-format
-msgid "Raster map <%s@%s>: format field in header file invalid"
-msgstr ""
+#: ../lib/python/temporal/register.py:196
+msgid ""
+"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
+"timestamp and the start time is not set."
-#: ../lib/raster/open.c:219
-#, c-format
+#: ../lib/python/temporal/register.py:202
msgid ""
-"Raster map <%s> is in different projection than current region. Found <%s>, "
-"should be <%s>."
-msgstr ""
+"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
+"start time is not set."
-#: ../lib/raster/open.c:226
-#, c-format
-msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
+#: ../lib/python/temporal/register.py:210
+#, python-format
+msgid "%(u)s= can only be set for relative time"
msgstr ""
-#: ../lib/raster/open.c:231
-#, c-format
-msgid "Raster map <%s>: bytes per cell (%d) too large"
+#: ../lib/python/temporal/register.py:212
+#, python-format
+msgid "%(u)s= must be set in case of relative time stamps"
msgstr ""
-#: ../lib/raster/open.c:256
-#, c-format
+#: ../lib/python/temporal/register.py:224
msgid ""
-"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
-msgstr ""
+"Map is already registered in temporal database. Unable to update %(t)s map <"
+"%(id)s> with layer %(l)s. Overwrite flag is not set."
-#: ../lib/raster/open.c:264
-#, fuzzy, c-format
-msgid "Unable to open %s file for raster map <%s@%s>"
+#: ../lib/python/temporal/register.py:231
+msgid ""
+"%(id)s>. Overwrite flag is not set."
-#: ../lib/raster/open.c:301
-#, fuzzy, c-format
-msgid "Error reading format for <%s@%s>"
+#: ../lib/python/temporal/register.py:255
+msgid ""
+"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
+"different."
-#: ../lib/raster/open.c:498
+#: ../lib/python/temporal/register.py:261
+msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
+#: ../lib/python/temporal/register.py:307
#, fuzzy
-msgid "Unable to create GDAL link"
+msgid "Register maps in the temporal database"
-#: ../lib/raster/open.c:574
-#, c-format
-msgid "Raster map <%s> is not in the current mapset (%s)"
-msgstr ""
+#: ../lib/python/temporal/register.py:314
+#, fuzzy
+msgid "Register maps in the space time raster dataset"
-#: ../lib/raster/open.c:581
-#, fuzzy, c-format
-msgid "<%s> is an illegal file name"
+#: ../lib/python/temporal/register.py:323
+msgid "Update space time raster dataset"
msgstr ""
-"\n"
-"**<%s> 잘못된 이름 **\n"
-#: ../lib/raster/open.c:595
-msgid "No temp files available"
+#: ../lib/python/temporal/register.py:375
+#: ../lib/python/temporal/register.py:383
+#, python-format
+msgid "Unable to convert string \"%s\"into a datetime object"
msgstr ""
-#: ../lib/raster/open.c:667
-msgid "no temp files available"
+#: ../lib/python/temporal/register.py:391
+#: ../lib/python/temporal/register.py:396
+msgid "Error in increment computation"
msgstr ""
-#: ../lib/raster/open.c:720
-msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
-msgstr ""
+#: ../lib/python/temporal/register.py:399
+msgid ""
+"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
+"%(end)s"
-#: ../lib/raster/open.c:778
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in mapset <%s>"
+#: ../lib/python/temporal/register.py:404
+msgid "Set absolute valid time for map <%s> to %s - %s"
-#: ../lib/raster/open.c:839
-#, fuzzy, c-format
-msgid "Unable to find '%s'"
+#: ../lib/python/temporal/register.py:421
+msgid ""
+"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
-#: ../lib/raster/open.c:850
-#, c-format
-msgid "Invalid type: field '%s' in file '%s'"
-msgstr ""
+#: ../lib/python/temporal/register.py:426
+msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
-#: ../lib/raster/open.c:855
-#, c-format
-msgid "Missing type: field in file '%s'"
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:96
+msgid "Unable to export raster map <%s>"
-#: ../lib/raster/open.c:860
-#, c-format
-msgid "Raster map <%s> is not xdr: byte_order: %s"
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:106
+msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-#: ../lib/raster/open.c:929
-msgid ""
-"Rast_set_quant_rules() can be called only for raster maps opened for reading"
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:128
+msgid "Unable to export raster map <%s> with r.pack"
-#: ../lib/raster/color_rand.c:33
-#, c-format
-msgid "Rast_make_random_colors: min (%d) > max (%d)"
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:154
+msgid "Unable to export vector map <%s> as GML with v.out.ogr"
-#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67
-#: ../lib/ogsf/gsd_img_mpeg.c:355 ../lib/segment/open.c:97
-#: ../lib/rst/interp_float/interp2d.c:121
-#: ../lib/rst/interp_float/interp2d.c:127
-#: ../lib/rst/interp_float/segmen2d.c:182
-#: ../lib/rst/interp_float/segmen2d.c:188
-#: ../lib/rst/interp_float/segmen2d.c:194
-#: ../lib/rst/interp_float/segmen2d.c:204 ../lib/vector/neta/spanningtree.c:99
-#: ../lib/vector/neta/flow.c:64 ../lib/vector/neta/flow.c:179
-#: ../lib/vector/neta/timetables.c:69 ../lib/vector/neta/timetables.c:168
-#: ../lib/vector/neta/timetables.c:178 ../lib/vector/neta/timetables.c:191
-#: ../lib/vector/neta/timetables.c:278 ../lib/vector/neta/timetables.c:413
-#: ../lib/vector/neta/timetables.c:425 ../lib/vector/neta/path.c:136
-#: ../lib/vector/neta/bridge.c:58 ../lib/vector/neta/centrality.c:63
-#: ../lib/vector/neta/centrality.c:145
-#: ../lib/vector/neta/articulation_point.c:60
-#: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
-#: ../lib/vector/Vlib/line.c:50 ../lib/vector/Vlib/line.c:154
-msgid "Out of memory"
-msgstr ""
+#: ../lib/python/temporal/stds_export.py:185
+msgid "Unable to export vector map <%s> with v.pack"
-#: ../lib/ogsf/GVL2.c:267
-#, fuzzy, c-format
-msgid "Loading 3d raster map <%s>..."
+#: ../lib/python/temporal/stds_export.py:210
+msgid "Unable to export raster map <%s> with r3.pack"
-#: ../lib/ogsf/gk.c:320
-msgid "Need at least 3 keyframes for spline"
-msgstr "스플라인을 위해서는 최소 3개의 키프레임이 필요합니다."
+#: ../lib/python/temporal/abstract_map_dataset.py:339
+msgid ""
+"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
+"%(l)s"
-#: ../lib/ogsf/gk.c:622
-msgid "Need at least 2 keyframes for interpolation"
-msgstr "보간을 위해서는 최소 2개의 키프레임이 필요합니다."
+#: ../lib/python/temporal/abstract_map_dataset.py:345
+msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
-#: ../lib/ogsf/Gv3.c:60 ../lib/ogsf/Gv3.c:326 ../lib/ogsf/Gp3.c:56
-#: ../lib/ogsf/Gp3.c:189 ../lib/manage/do_rename.c:54
-#: ../lib/manage/do_remove.c:57 ../lib/vector/Vlib/map.c:269
-#: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/legal_vname.c:124
-#: ../lib/vector/Vlib/open.c:235
-#, c-format
-msgid "Vector map <%s> not found"
-msgstr "벡터맵 <%s>을 찾을 수 없습니다."
+#: ../lib/python/temporal/abstract_map_dataset.py:352
+msgid ""
+"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
-#: ../lib/ogsf/Gv3.c:66 ../lib/ogsf/Gv3.c:331 ../lib/ogsf/Gp3.c:62
-#: ../lib/ogsf/Gp3.c:194 ../lib/python/temporal/c_libraries_interface.py:427
-#: ../lib/vector/Vlib/open.c:288 ../lib/vector/Vlib/open.c:425
-#, fuzzy, c-format, python-format
-msgid "Unable to open vector map <%s>"
+#: ../lib/python/temporal/abstract_map_dataset.py:358
+msgid "End time must be of type datetime for %(type)s map <%(id)s>"
-#: ../lib/ogsf/Gv3.c:262
-#, c-format
-msgid "No features from vector map <%s> fall within current region"
-msgstr "벡터맵 <%s>의 어떤 피쳐도 현재 영역 안에 있지 않습니다."
+#: ../lib/python/temporal/abstract_map_dataset.py:366
+msgid ""
+"End time must be greater than start time for %(type)s map <%(id)s> with "
+"layer: %(l)s"
+msgstr "동쪽경계는 서쪽경계보다 값이 커야합니다"
-#: ../lib/ogsf/Gv3.c:267
-#, c-format
-msgid "Vector map <%s> loaded (%d features)"
-msgstr "백터맵 <%s>을 읽었습니다. (%d 피쳐)"
+#: ../lib/python/temporal/abstract_map_dataset.py:373
+#: ../lib/python/temporal/abstract_map_dataset.py:462
+msgid "End time must be greater than start time for %(type)s map <%(id)s>"
-#: ../lib/ogsf/Gv3.c:337 ../lib/ogsf/Gp3.c:200
-#: ../lib/rst/interp_float/vinput2d.c:79 ../lib/vector/Vlib/map.c:177
-#: ../lib/vector/Vlib/map.c:305 ../lib/vector/Vlib/map.c:441
-#: ../lib/vector/Vlib/array.c:276 ../lib/vector/Vlib/net.c:175
-#: ../lib/vector/Vlib/net.c:353 ../lib/vector/Vlib/cats.c:589
-#: ../lib/vector/Vlib/ascii.c:398 ../lib/vector/Vlib/copy.c:595
-#: ../lib/vector/Vlib/copy.c:733
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr "레이어 %d를 위한 데이타베이스 접속이 정의되지 않았습니다."
-#: ../lib/ogsf/Gv3.c:343 ../lib/ogsf/Gp3.c:206 ../lib/sites/sites.c:279
-#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
-#: ../lib/db/dbmi_client/db.c:46 ../lib/rst/interp_float/vinput2d.c:88
-#: ../lib/vector/neta/timetables.c:133 ../lib/vector/neta/utils.c:119
-#: ../lib/vector/Vlib/map.c:206 ../lib/vector/Vlib/map.c:346
-#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/net.c:181
-#: ../lib/vector/Vlib/net.c:358 ../lib/vector/Vlib/write_pg.c:2893
-#: ../lib/vector/Vlib/cats.c:597 ../lib/vector/Vlib/ascii.c:410
-#: ../lib/vector/Vlib/copy.c:628 ../lib/vector/Vlib/write_ogr.c:197
-#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
-#: ../lib/ogsf/Gv3.c:346
-#, fuzzy, c-format
-msgid "Loading thematic vector layer <%s>..."
+#: ../lib/python/temporal/abstract_map_dataset.py:443
+msgid ""
+"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
+"%(l)s: %(u)s"
-#: ../lib/ogsf/Gv3.c:370 ../lib/ogsf/Gp3.c:233
-#, fuzzy, c-format
-msgid "No color rule defined for category %d"
+#: ../lib/python/temporal/abstract_map_dataset.py:448
+msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
-#: ../lib/ogsf/Gv3.c:385 ../lib/ogsf/Gp3.c:247
-#, fuzzy, c-format
-msgid "Invalid color definition (%s)"
-msgstr "잘못된 좌표"
+#: ../lib/python/temporal/abstract_map_dataset.py:457
+msgid ""
+"layer %(l)s"
-#: ../lib/ogsf/Gv3.c:407
-#, c-format
+#: ../lib/python/temporal/abstract_map_dataset.py:766
+#, python-format
msgid ""
-"%d features without category. Unable to determine color rules for features "
-"without category."
+"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
+"greater than end time"
msgstr ""
-"%d 피쳐들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 피쳐는 색상규칙을 "
-"정할 수 없습니다."
-#: ../lib/ogsf/gvl_file.c:103
-msgid "Maximum number of datafiles exceeded"
+#: ../lib/python/temporal/abstract_map_dataset.py:772
+#, python-format
+msgid ""
+"Map <%s> has incorrect time interval, start time is greater than end time"
msgstr ""
-#: ../lib/ogsf/gvl_file.c:427 ../lib/ogsf/Gvl3.c:40
-#: ../lib/gpde/N_arrays_io.c:273 ../lib/manage/do_rename.c:76
-#: ../lib/manage/do_remove.c:78
-#, c-format
-msgid "3D raster map <%s> not found"
-msgstr "3차원 라스터맵 <%s>을 찾을 수 없습니다."
+#: ../lib/python/temporal/abstract_map_dataset.py:777
+#, python-format
+msgid "Map <%s> has incorrect start time"
+msgstr ""
+#: ../lib/python/temporal/abstract_map_dataset.py:821
+msgid "Delete %s dataset <%s> from temporal database"
+#: ../lib/python/temporal/abstract_map_dataset.py:870
+#, python-format
+msgid ""
+"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+msgstr ""
+#: ../lib/python/temporal/c_libraries_interface.py:317
+#: ../lib/python/temporal/c_libraries_interface.py:334
+#, fuzzy
+msgid "Unable to read range file"
+#: ../lib/python/temporal/c_libraries_interface.py:395
#: ../lib/ogsf/gvl_file.c:436 ../lib/gpde/N_arrays_io.c:281
-#: ../lib/python/temporal/c_libraries_interface.py:358
msgid "Unable to open 3D raster map <%s>"
-#: ../lib/ogsf/gvl_file.c:442
-#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:410
+msgid "Unable to load range of 3D raster map <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:425
#: ../lib/ogsf/gvl_file.c:470 ../lib/raster3d/close.c:120
#: ../lib/raster3d/close.c:130 ../lib/raster3d/close.c:159
-#: ../lib/python/temporal/c_libraries_interface.py:388
msgid "Unable to close 3D raster map <%s>"
-#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/copy.c:168
-#: ../lib/vector/Vlib/copy.c:245
-#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
+#: ../lib/python/temporal/c_libraries_interface.py:464 ../lib/ogsf/Gv3.c:66
+#: ../lib/ogsf/Gv3.c:331 ../lib/ogsf/Gp3.c:62 ../lib/ogsf/Gp3.c:194
+#: ../lib/vector/Vlib/map.c:159 ../lib/vector/Vlib/map.c:169
+#: ../lib/vector/Vlib/map.c:282 ../lib/vector/Vlib/open.c:288
+#: ../lib/vector/Vlib/open.c:425 ../lib/sites/sites.c:263
+msgid "Unable to open vector map <%s>"
-#: ../lib/ogsf/Gp3.c:146
-#, c-format
-msgid "No points from vector map <%s> fall within current region"
-msgstr "벡터맵 <%s>의 어떤 점도 현재 영역 안에 있지 않습니다."
+#: ../lib/python/temporal/sampling.py:92 ../lib/python/temporal/sampling.py:96
+msgid "Dataset <%s> not found in temporal database"
-#: ../lib/ogsf/Gp3.c:151
-#, c-format
-msgid "Vector map <%s> loaded (%d points)"
-msgstr "벡터맵 <%s>을 읽었습니다. (%d 점)"
+#: ../lib/python/temporal/stds_import.py:84
+msgid "Unable to import/link raster map <%s> from file %s."
-#: ../lib/ogsf/Gp3.c:209
-#, fuzzy, c-format
-msgid "Loading thematic points layer <%s>..."
+#: ../lib/python/temporal/stds_import.py:94
+msgid "Unable to set the color rules for raster map <%s>."
-#: ../lib/ogsf/Gp3.c:286
-#, c-format
-msgid ""
-"%d points without category. Unable to determine color rules for features "
-msgstr ""
-"%d 점들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 점은 색상규칙을 정"
-"할 수 없습니다."
+#: ../lib/python/temporal/stds_import.py:118
+msgid "Unable to unpack raster map <%s> from file %s."
-#: ../lib/ogsf/trans.c:180
-msgid "Out of matrix stack space"
-msgstr "행렬 스택공간이 부족합니다."
+#: ../lib/python/temporal/stds_import.py:142
+msgid "Unable to import vector map <%s> from file %s."
-#: ../lib/ogsf/trans.c:200
-msgid "Tried to pop an empty stack"
-msgstr "빈 스택에서 끄집어 내려고 했습니다."
-#: ../lib/ogsf/GK2.c:216 ../lib/ogsf/gsd_img_ppm.c:52
-#: ../lib/ogsf/gsd_img_ppm.c:95 ../lib/ogsf/gsd_img_tif.c:64
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
+#: ../lib/python/temporal/stds_import.py:166
+msgid "Unable to unpack vector map <%s> from file %s."
-#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
-msgid "Check no. of frames requested and keyframes marked"
+#: ../lib/python/temporal/stds_import.py:204
+#, python-format
+msgid "Space time raster dataset archive <%s> not found"
msgstr ""
-#: ../lib/ogsf/gsds.c:109
-msgid "Maximum number of datasets exceeded"
-msgstr ""
+#: ../lib/python/temporal/stds_import.py:207
+msgid "Extraction directory <%s> not found"
-#: ../lib/ogsf/gsdrape.c:207
-#, fuzzy
-msgid "Unable to process vector map - out of memory"
+#: ../lib/python/temporal/stds_import.py:215
+msgid "Unable to find init file <%s>"
-#: ../lib/ogsf/gsd_label.c:58
-msgid "Max. number of labels reached!"
-msgstr "최대 레이블 개수에 도달했습니다."
+#: ../lib/python/temporal/stds_import.py:217
+msgid "Unable to find list file <%s>"
-#: ../lib/ogsf/gsd_img_mpeg.c:72
-#, fuzzy
-msgid "Unable to allocate stream"
+#: ../lib/python/temporal/stds_import.py:219
+msgid "Unable to find projection file <%s>"
-#: ../lib/ogsf/gsd_img_mpeg.c:175
-msgid "Video codec not found"
+#: ../lib/python/temporal/stds_import.py:244
+msgid "Projection information does not match. Proceeding..."
msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:185
-#, fuzzy
-msgid "Unable to open codec"
+#: ../lib/python/temporal/stds_import.py:248
+msgid ""
+"Difference between PROJ_INFO file of imported map and of current location:\n"
+"{diff}"
+msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:204
-#, fuzzy
-msgid "Unable to allocate picture"
+#: ../lib/python/temporal/stds_import.py:250
+msgid "Projection information does not match. Aborting."
+msgstr ""
+#: ../lib/python/temporal/stds_import.py:266
+msgid "Unable to create location %(l)s. Reason: %(e)s"
-#: ../lib/ogsf/gsd_img_mpeg.c:215
-#, fuzzy
-msgid "Unable to allocate temporary picture"
+#: ../lib/python/temporal/stds_import.py:273
+msgid "Unable to switch to location %s"
+#: ../lib/python/temporal/stds_import.py:277
+msgid "Unable to create default temporal database in new location %s"
-#: ../lib/ogsf/gsd_img_mpeg.c:282
-#, fuzzy
-msgid "Error while writing video frame"
+#: ../lib/python/temporal/stds_import.py:342
+#, python-format
+msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:328
-#, c-format
-msgid "Opening MPEG stream <%s>..."
+#: ../lib/python/temporal/stds_import.py:348
+msgid "Number of maps mismatch in init and list file."
msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:340
-msgid "Unable to deduce output format from file extension: using MPEG"
+#: ../lib/python/temporal/stds_import.py:359
+msgid "The archive file is of wrong space time dataset type"
msgstr ""
-#: ../lib/ogsf/gsd_img_mpeg.c:348
-#, fuzzy
-msgid "Unable to find suitable output format"
+#: ../lib/python/temporal/stds_import.py:366
+msgid "Unable to find geotiff raster file <%s> in archive."
-#: ../lib/ogsf/gsd_img_mpeg.c:379
-#, fuzzy
-msgid "Invalid output format parameters"
+#: ../lib/python/temporal/stds_import.py:372
+msgid "Unable to find AAIGrid raster file <%s> in archive."
-#: ../lib/ogsf/gsd_img_mpeg.c:401
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
+#: ../lib/python/temporal/stds_import.py:378
+msgid "Unable to find GML vector file <%s> in archive."
-#: ../lib/ogsf/gsd_img_mpeg.c:414
-msgid "OGSF library has not been built with MPEG output support"
-msgstr ""
+#: ../lib/python/temporal/stds_import.py:387
+msgid "Unable to find GRASS package file <%s> in archive."
-#: ../lib/ogsf/gsd_prim.c:146
-#, c-format
-msgid "Color Material: %d"
-msgstr "색상재료: %d"
+#: ../lib/python/temporal/stds_import.py:390
+#, fuzzy
+msgid "Unsupported input format"
-#: ../lib/ogsf/gsd_prim.c:630
-#, c-format
+#: ../lib/python/temporal/stds_import.py:396
msgid ""
-"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
-"advise GRASS developers of this error"
-msgstr ""
-"gsd_rot(): %c는 잘못된 좌표축 지정입니다. 회전을 무시합니다. GRASS 개발자들에"
-"게 조언을 구하세요."
+"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
+"overwrite flag."
-#: ../lib/ogsf/GS2.c:1211
-#, c-format
-msgid "no category info"
-msgstr "카테고리 정보가 없습니다."
+#: ../lib/python/temporal/stds_import.py:416
+msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-#: ../lib/ogsf/GS2.c:1230
-#, c-format
-msgid "no data"
-msgstr "자료가 없습니다."
+#: ../lib/python/temporal/stds_import.py:428
+msgid "Key word %s not found in init file."
-#: ../lib/ogsf/GS2.c:1655
-#, c-format
-msgid "Raster map <%s> is outside of current region. Load failed."
-msgstr "라스터맵 <%s>이 현재 영역 바깥입니다. 읽을 수 없습니다."
+#: ../lib/python/temporal/stds_import.py:432
+msgid "Create space time %s dataset."
-#: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
-#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
-#: ../lib/ogsf/GS2.c:1822
-msgid "GS_load_att_map(): Out of memory. Unable to load map"
-msgstr "GS_load_att_map(): 메모리가 모자랍니다. 맵을 읽을 수 없습니다."
+#: ../lib/python/temporal/abstract_dataset.py:391
+#, python-format
+msgid ""
+"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+msgstr ""
-#: ../lib/ogsf/GS2.c:1850
-msgid "Loading failed"
-msgstr "읽을 수 없습니다."
+#: ../lib/python/temporal/extract.py:54
+msgid "You need to specify the base name of new created maps"
+msgstr ""
-#: ../lib/ogsf/GS2.c:1854
-msgid "Error finding range"
-msgstr "범위를 찾지 못했습니다."
+#: ../lib/python/temporal/extract.py:119
+#, python-format
+msgid "Apply r.mapcalc expression: \"%s\""
+msgstr ""
-#: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
-#: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
-#, fuzzy, c-format
-msgid "Loading raster map <%s>..."
+#: ../lib/python/temporal/extract.py:124
+#, python-format
+msgid "Apply r3.mapcalc expression: \"%s\""
+msgstr ""
-#: ../lib/ogsf/Gs3.c:596
-#, c-format
-msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
+#: ../lib/python/temporal/extract.py:129
+#, python-format
+msgid "Apply v.extract where statement: \"%s\""
msgstr ""
-#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
-#, fuzzy, c-format
-msgid "Translating colors from raster map <%s>..."
+#: ../lib/python/temporal/extract.py:158
+msgid "Error while computation"
+msgstr ""
-#: ../lib/ogsf/Gs3.c:967
-msgid "View not saved by this program,there may be some inconsistancies"
+#: ../lib/python/temporal/core.py:514
+msgid ""
+"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
+"the driver and the database string"
msgstr ""
-#: ../lib/ogsf/gs_bm.c:124
-msgid "Bitmap mismatch"
-msgstr "비트맵이 일치하지 않습니다."
+#: ../lib/python/temporal/core.py:582
+msgid ""
+"Unable to receiving temporal database metadata.\n"
+"Current temporal database info:%(info)s"
-#: ../lib/ogsf/GP2.c:705
-msgid "Unknown icon marker, using \"sphere\""
+#: ../lib/python/temporal/core.py:586
+#, python-format
+msgid ""
+"Unsupported temporal database. Version mismatch.\n"
+" %(backup)sSupported temporal API version is: %(api)i.\n"
+"Please update your GRASS installation to the latest svn version.\n"
msgstr ""
-#: ../lib/ogsf/gsd_surf.c:1742
-msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
+#: ../lib/python/temporal/core.py:592
+#, python-format
+msgid ""
+" %(backup)sSupported temporal database version is: %(tdb)i\n"
msgstr ""
-#: ../lib/ogsf/gsd_legend.c:246
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
+#: ../lib/python/temporal/core.py:676
+msgid "Create temporal database: %s"
-#: ../lib/ogsf/gsd_legend.c:252
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
+#: ../lib/python/temporal/core.py:962
+msgid ""
+"Unable to execute transaction:\n"
+" %(sql)s"
-#: ../lib/ogsf/gsd_legend.c:269
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
+#: ../lib/python/temporal/temporal_raster3d_algebra.py:44
+#, fuzzy
+msgid "Removing empty 3D raster maps"
-#: ../lib/ogsf/gsd_legend.c:281
-#, fuzzy, c-format
-msgid "Unable to read range of raster map <%s>"
+#: ../lib/gmath/solvers_direct.c:45
+msgid "Starting direct gauss elimination solver"
+msgstr ""
-#: ../lib/ogsf/gsd_legend.c:295
-msgid "Range request error for legend"
+#: ../lib/gmath/solvers_direct.c:73
+msgid "Starting direct lu decomposition solver"
msgstr ""
-#: ../lib/ogsf/gsd_legend.c:385
-#, fuzzy
-msgid "Unable to show discrete FP range (use list)"
-#: ../lib/ogsf/gsd_legend.c:501
-msgid "Too many categories to show as discrete!"
+#: ../lib/gmath/solvers_direct.c:131
+msgid "Starting cholesky decomposition solver"
msgstr ""
-#: ../lib/ogsf/gsd_legend.c:503
-msgid "Try using smaller font!"
+#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
+#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
+msgid "Unable to solve the linear equation system"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:93
+#: ../lib/gmath/solvers_classic_iter.c:84
#, c-format
-msgid "Reading raster map <%s> into memory"
+msgid "sparse Jacobi -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:183
-msgid "N_array_2d * array is empty"
+#: ../lib/gmath/solvers_classic_iter.c:156
+#, c-format
+msgid "sparse SOR -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:202
+#: ../lib/gmath/solvers_classic_iter.c:218
#, c-format
-msgid "Write 2d array to raster map <%s>"
+msgid "Jacobi -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:309
+#: ../lib/gmath/solvers_classic_iter.c:275
#, c-format
-msgid "Read g3d map <%s> into the memory"
+msgid "SOR -- iteration %5i error %g\n"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
-msgid "Error closing g3d file"
+#: ../lib/gmath/test/test_ccmath_wrapper.c:37
+msgid ""
+"\n"
+"++ Running ccmath wrapper unit tests ++"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:420
-#, c-format
-msgid "Error opening g3d map <%s>"
+#: ../lib/gmath/test/test_ccmath_wrapper.c:42
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests failure --"
msgstr ""
-#: ../lib/gpde/N_arrays_io.c:422
-#, c-format
-msgid "Write 3d array to g3d map <%s>"
+#: ../lib/gmath/test/test_ccmath_wrapper.c:44
+msgid ""
+"\n"
+"-- ccmath wrapper unit tests finished successfully --"
msgstr ""
-#: ../lib/gpde/N_gwflow.c:436 ../lib/gpde/N_gwflow.c:715
-#, c-format
-msgid "The total sum of the water budget: %g\n"
+#: ../lib/gmath/test/bench_blas2.c:35
+msgid ""
+"\n"
+"++ Running blas level 2 benchmark ++"
msgstr ""
-#: ../lib/gpde/N_gwflow.c:438 ../lib/gpde/N_gwflow.c:717
-#, c-format
-msgid "The total sum of the water budget is significant larger then 0: %g\n"
+#: ../lib/gmath/test/bench_solver_krylov.c:34
+msgid ""
+"\n"
+"++ Running krylov solver benchmark ++"
msgstr ""
-#: ../lib/gpde/test/test_main.c:88
-msgid "Performs unit and integration tests for gpde library"
+#: ../lib/gmath/test/test_solvers.c:37
+msgid ""
+"\n"
+"++ Running solver unit tests ++"
msgstr ""
-#: ../lib/gpde/N_parse_options.c:106
-msgid "The calculation time in seconds"
+#: ../lib/gmath/test/test_solvers.c:42
+msgid ""
+"\n"
+"-- Solver unit tests failure --"
msgstr ""
-#: ../lib/segment/format.c:143
-msgid "Segment format: file size too large"
+#: ../lib/gmath/test/test_solvers.c:44
+msgid ""
+"\n"
+"-- Solver unit tests finished successfully --"
msgstr ""
-#: ../lib/segment/format.c:144
-msgid "Please recompile with Large File Support (LFS)"
+#: ../lib/gmath/test/test_blas3.c:38
+msgid ""
+"\n"
+"++ Running blas level 3 unit tests ++"
msgstr ""
-#: ../lib/segment/open.c:53
-msgid "Segment file name is NULL"
+#: ../lib/gmath/test/test_blas3.c:44
+msgid ""
+"\n"
+"-- blas level 3 unit tests failure --"
msgstr ""
-#: ../lib/segment/open.c:58
-msgid "Segment file exists already"
+#: ../lib/gmath/test/test_blas3.c:46
+msgid ""
+"\n"
+"-- blas level 3 unit tests finished successfully --"
msgstr ""
-#: ../lib/segment/open.c:66
-#, fuzzy
-msgid "Unable to create segment file"
-#: ../lib/segment/open.c:74
-#, fuzzy
-msgid "Could not write segment file"
-#: ../lib/segment/open.c:78
-msgid "Illegal segment configuration parameter(s)"
+#: ../lib/gmath/test/test_blas2.c:38
+msgid ""
+"\n"
+"++ Running blas level 2 unit tests ++"
msgstr ""
-#: ../lib/segment/open.c:86
-#, fuzzy
-msgid "Unable to re-open segment file"
-#: ../lib/segment/open.c:93
-msgid "Could not read segment file"
+#: ../lib/gmath/test/test_blas2.c:44
+msgid ""
+"\n"
+"-- blas level 2 unit tests failure --"
msgstr ""
-#: ../lib/cluster/c_begin.c:57
-#, c-format
-msgid "produced by i.cluster"
+#: ../lib/gmath/test/test_blas2.c:46
+msgid ""
+"\n"
+"-- blas level 2 unit tests finished successfully --"
msgstr ""
-#: ../lib/cluster/c_exec.c:44
-#, c-format
-msgid "Not enough data points (%d) in cluster"
+#: ../lib/gmath/test/test_matrix_conversion.c:37
+msgid ""
+"\n"
+"++ Running matrix conversion unit tests ++"
msgstr ""
-#: ../lib/proj/get_proj.c:148
-#, c-format
-msgid "Invalid zone %s specified"
+#: ../lib/gmath/test/test_matrix_conversion.c:42
+msgid ""
+"\n"
+"-- Matrix conversion unit tests failure --"
msgstr ""
-#: ../lib/proj/get_proj.c:228
-msgid "Unable to initialise PROJ.4 with the following parameter list:"
+#: ../lib/gmath/test/test_matrix_conversion.c:44
+msgid ""
+"\n"
+"-- Matrix conversion unit tests finished successfully --"
msgstr ""
-#: ../lib/proj/get_proj.c:236
-#, c-format
-msgid "The error message: %s"
+#: ../lib/gmath/test/test_blas1.c:40
+msgid ""
+"\n"
+"++ Running blas level 1 unit tests ++"
msgstr ""
-#: ../lib/proj/get_proj.c:294
-msgid "Option input overflowed option table"
+#: ../lib/gmath/test/test_blas1.c:47
+msgid ""
+"\n"
+"-- blas level 1 unit tests failure --"
msgstr ""
-#: ../lib/proj/get_proj.c:325
-#, fuzzy, c-format
-msgid "Unable to initialize pj cause: %s"
-#: ../lib/proj/get_proj.c:401
-msgid "Input Projection Parameters"
+#: ../lib/gmath/test/test_blas1.c:49
+msgid ""
+"\n"
+"-- blas level 1 unit tests finished successfully --"
msgstr ""
-#: ../lib/proj/get_proj.c:404
-msgid "Input Unit Factor"
+#: ../lib/gmath/test/test_main.c:47
+#: ../lib/vector/rtree/test_suite/test_main.c:45
+#: ../lib/db/dbmi_base/test/test_main.c:47
+msgid "Choose the unit tests to run"
msgstr ""
-#: ../lib/proj/get_proj.c:414
-msgid "Output Projection Parameters"
+#: ../lib/gmath/test/test_main.c:54 ../lib/db/dbmi_base/test/test_main.c:54
+msgid "Choose the integration tests to run"
msgstr ""
-#: ../lib/proj/get_proj.c:417
-msgid "Output Unit Factor"
+#: ../lib/gmath/test/test_main.c:61
+msgid "The size of the matrices and vectors for benchmarking"
msgstr ""
-#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
-#, fuzzy, c-format
-msgid "Unable to open datum table file <%s>"
-#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
-#, fuzzy, c-format
-msgid "Error in datum table file <%s>, line %d"
-msgstr "Datum 테이블파일의 %d번째 줄에 오류가 있습니다"
-#: ../lib/proj/ellipse.c:76
-#, c-format
-msgid "Invalid ellipsoid <%s> in file"
+#: ../lib/gmath/test/test_main.c:68
+msgid "Choose solver benchmark"
msgstr ""
-#: ../lib/proj/ellipse.c:103
-msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
+#: ../lib/gmath/test/test_main.c:75
+msgid "Choose blas benchmark"
msgstr ""
-#: ../lib/proj/ellipse.c:107
-msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
+#: ../lib/gmath/test/test_main.c:79
+#: ../lib/vector/rtree/test_suite/test_main.c:49
+#: ../lib/db/dbmi_base/test/test_main.c:58
+msgid "Run all unit tests"
msgstr ""
-#: ../lib/proj/ellipse.c:120
-msgid "No ellipsoid info given in file"
+#: ../lib/gmath/test/test_main.c:83 ../lib/db/dbmi_base/test/test_main.c:62
+msgid "Run all integration tests"
msgstr ""
-#: ../lib/proj/ellipse.c:220 ../lib/gis/get_ellipse.c:263
-#, fuzzy, c-format
-msgid "Unable to open ellipsoid table file <%s>"
-#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/field.c:660
-#: ../lib/vector/Vlib/read_ogr.c:56 ../lib/vector/Vlib/read_ogr.c:157
-#: ../lib/vector/Vlib/read_ogr.c:242 ../lib/vector/Vlib/write_sfa.c:291
-#: ../lib/vector/Vlib/build_sfa.c:711 ../lib/vector/Vlib/build_ogr.c:94
-#: ../lib/vector/Vlib/build_ogr.c:169 ../lib/vector/Vlib/simple_features.c:310
-#: ../lib/vector/Vlib/close.c:284 ../lib/vector/Vlib/open_ogr.c:121
-#: ../lib/vector/Vlib/open_ogr.c:154 ../lib/vector/Vlib/open_ogr.c:231
-#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
-#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
-#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
-#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/rewind_ogr.c:47
-#: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/write_ogr.c:69
-#: ../lib/vector/Vlib/write_ogr.c:105 ../lib/vector/Vlib/write_ogr.c:145
-msgid "GRASS is not compiled with OGR support"
+#: ../lib/gmath/test/test_main.c:87 ../lib/db/dbmi_base/test/test_main.c:66
+msgid "Run all unit and integration tests"
msgstr ""
-#: ../lib/proj/convert.c:120
-msgid "Unable parse GRASS PROJ_INFO file"
+#: ../lib/gmath/test/test_main.c:106
+#: ../lib/vector/rtree/test_suite/test_main.c:67
+msgid "Performs benchmarks, unit and integration tests for the gmath library"
msgstr ""
-#: ../lib/proj/convert.c:125
-msgid "Unable get PROJ.4-style parameter string"
+#: ../lib/gmath/test/bench_blas3.c:34
+msgid ""
+"\n"
+"++ Running blas level 3 benchmark ++"
msgstr ""
-#: ../lib/proj/convert.c:139
-#, c-format
+#: ../lib/gmath/test/bench_solver_direct.c:34
msgid ""
-"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
+"\n"
+"++ Running direct solver benchmark ++"
msgstr ""
-#: ../lib/proj/convert.c:146
-#, c-format
-msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
+#: ../lib/gmath/del2g.c:50
+msgid " taking FFT of image..."
msgstr ""
-#: ../lib/proj/convert.c:406
-msgid "No projection name! Projection parameters likely to be meaningless."
+#: ../lib/gmath/del2g.c:56
+msgid " computing del**2 g..."
msgstr ""
-#: ../lib/proj/convert.c:442
-#, c-format
-msgid "Datum <%s> not recognised by GRASS and no parameters found"
+#: ../lib/gmath/del2g.c:59
+msgid " taking FFT of del**2 g..."
msgstr ""
-#: ../lib/proj/convert.c:458
-#, c-format
-msgid ""
-"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
-"want to look into this."
+#: ../lib/gmath/del2g.c:63
+msgid " multiplying transforms..."
msgstr ""
-#: ../lib/proj/convert.c:462
-#, c-format
-msgid ""
-"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
-"transform parameters unspecified."
+#: ../lib/gmath/del2g.c:66
+msgid " taking inverse FFT..."
msgstr ""
-#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
-#, c-format
-msgid "pj_transform() failed: %s"
+#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
+msgid "Matrix dimensions out of range"
msgstr ""
-#: ../lib/nviz/position.c:56
-#, fuzzy
-msgid "Unable to set focus"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/gmath/la.c:149
+msgid "Matrix is not initialised fully."
+msgstr ""
-#: ../lib/nviz/render.c:106
-msgid "Bad server connection"
-msgstr "서버접속 오류입니다."
+#: ../lib/gmath/la.c:154
+msgid "Unable to allocate space for matrix copy"
+msgstr ""
-#: ../lib/nviz/render.c:112
-#, fuzzy
-msgid "Unable to get visual info"
+#: ../lib/gmath/la.c:243
+msgid "First scalar multiplier must be non-zero"
+msgstr ""
-#: ../lib/nviz/render.c:119
-#, fuzzy
-msgid "Unable to create rendering context"
+#: ../lib/gmath/la.c:249 ../lib/gmath/la.c:257 ../lib/gmath/la.c:322
+msgid "One or both input matrices uninitialised"
+msgstr ""
-#: ../lib/nviz/nviz.c:128
-#, c-format
-msgid "Invalid color (%s), using \"white\" as default"
-msgstr "잘못된 색상(%s)입니다. \"white\"를 기본값으로 사용합니다."
+#: ../lib/gmath/la.c:262 ../lib/gmath/la.c:327
+msgid "Matrix order does not match"
+msgstr ""
-#: ../lib/nviz/map_obj.c:59
-msgid "Maximum surfaces loaded!"
-msgstr "최대 표면 개수를 초과했습니다!"
+#: ../lib/gmath/la.c:268
+msgid "Unable to allocate space for matrix sum"
+msgstr ""
-#: ../lib/nviz/map_obj.c:88
-msgid "Maximum vector line maps loaded!"
-msgstr "최대 선벡터맵 개수를 초과했습니다!"
+#: ../lib/gmath/la.c:332
+msgid "Unable to allocate space for matrix product"
+msgstr ""
-#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
-#, fuzzy, c-format
-msgid "Error loading vector map <%s>"
+#: ../lib/gmath/la.c:444
+msgid "Input: one or both data matrices uninitialised"
+msgstr ""
-#: ../lib/nviz/map_obj.c:116
-msgid "Maximum vector point maps loaded!"
-msgstr "최대 점벡터지도 개수를 초과했습니다!"
+#: ../lib/gmath/la.c:449
+msgid "Principal matrix is not properly dimensioned"
+msgstr ""
-#: ../lib/nviz/map_obj.c:143
-msgid "Maximum volumes loaded!"
-msgstr "최대 부피를 초과했습니다!"
+#: ../lib/gmath/la.c:454
+msgid "Input: you must have at least one array to solve"
+msgstr ""
-#: ../lib/nviz/map_obj.c:152
-#, fuzzy, c-format
-msgid "Error loading 3d raster map <%s>"
+#: ../lib/gmath/la.c:460
+msgid "Could not allocate space for solution matrix"
+msgstr ""
-#: ../lib/nviz/map_obj.c:160
-msgid "Nviz_new_map_obj(): unsupported data type"
-msgstr "Nviz_new_map_obj(): 지원하지 않는 자료형입니다."
+#: ../lib/gmath/la.c:466 ../lib/gmath/la.c:474
+msgid "Could not allocate space for working matrix"
+msgstr ""
-#: ../lib/nviz/lights.c:171
-#, fuzzy
-msgid "Unable to define new light"
+#: ../lib/gmath/la.c:527
+msgid "Matrix (or submatrix is singular). Solution undetermined"
+msgstr ""
-#: ../lib/sites/sites.c:106
-#, c-format
-msgid "Attributes for category %d not found"
-msgstr "카테고리 %d를 위한 속성을 찾을 수 없습니다."
+#: ../lib/gmath/la.c:531
+msgid "Problem in LA routine."
+msgstr ""
-#: ../lib/sites/sites.c:151
-msgid "Category must be integer"
-msgstr "카테고리는 정수여야 합니다."
+#: ../lib/gmath/la.c:538
+msgid "Procedure not yet available for selected matrix type"
+msgstr ""
-#: ../lib/sites/sites.c:226
-msgid "Memory error in writing timestamp"
-msgstr "타임스탬프를 쓰는 중 메모리오류가 났습니다."
-#: ../lib/sites/sites.c:228
-msgid "Illegal TimeStamp string"
-msgstr "잘못된 타임스탬프 문자열입니다."
-#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:385
-msgid ""
-"Dev note: Adapted sites library used for vector points. (module should be "
-"updated to GRASS 6 vector library)"
+#: ../lib/gmath/la.c:572
+msgid "Matrix is not square. Cannot determine inverse"
msgstr ""
-"개발자 노트: 벡터점 지원을 위해 변형된 사이트 라이브러리를 사용했습니다. (모"
-"듈을 GRASS 6 벡터 라이브러리로 업데이트해야 합니다.)"
-#: ../lib/sites/sites.c:288 ../lib/db/dbmi_client/table.c:110
-#: ../lib/db/dbmi_client/copy_tab.c:218 ../lib/db/dbmi_client/copy_tab.c:295
-#: ../lib/vector/Vlib/write_ogr.c:210
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-#: ../lib/sites/sites.c:304
-#, fuzzy
-msgid "Cannot fetch row"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/sites/sites.c:440
-msgid "G_oldsite_new_struct: invalid # dims or fields"
-msgstr "G_oldsite_new_struct: 잘못된 차원 또는 필드 개수입니다."
-#: ../lib/sites/sites.c:668
-msgid ""
-"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
-msgstr "G_fopen_sites_old() 다음 즉시 G_oldsite_describe()를 호출해야 합니다."
-#: ../lib/db/dbmi_driver/d_error.c:35
-#, c-format
-msgid "DBMI-%s driver error:"
+#: ../lib/gmath/la.c:577
+msgid "Unable to allocate space for matrix"
msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:38
-#, c-format
-msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+#: ../lib/gmath/la.c:594
+msgid "Matrix is singular"
msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:45
-#, c-format
-msgid "Illegal table map name <%s>. Must start with a letter."
+#: ../lib/gmath/la.c:599
+msgid "Problem in LA procedure."
msgstr ""
-#: ../lib/db/dbmi_base/legal_dbname.c:54
-#, c-format
-msgid "Illegal table map name <%s>. Character <%c> not allowed."
+#: ../lib/gmath/la.c:687
+msgid "Element array has not been allocated"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:72
-msgid "<NULL error message>"
+#: ../lib/gmath/la.c:692
+msgid "Specified element is outside array bounds"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:91
-msgid "dbmi: Protocol error"
+#: ../lib/gmath/la.c:746
+msgid "Specified matrix column index is outside range"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:136
-msgid "dbmi: Out of Memory"
+#: ../lib/gmath/la.c:751 ../lib/gmath/la.c:792 ../lib/gmath/la.c:1105
+#: ../lib/gmath/la.c:1157 ../lib/gmath/la.c:1232
+msgid "Matrix is not initialised"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:149
-#, c-format
-msgid "dbmi: %s() not implemented"
+#: ../lib/gmath/la.c:756 ../lib/gmath/la.c:797
+msgid "Could not allocate space for vector structure"
msgstr ""
-#: ../lib/db/dbmi_base/error.c:163
-#, c-format
-msgid "dbmi: Invalid procedure %d"
+#: ../lib/gmath/la.c:787
+msgid "Specified matrix row index is outside range"
msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:52
-msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+#: ../lib/gmath/la.c:827
+msgid "Specified row index is outside range"
msgstr ""
-#: ../lib/db/dbmi_base/valuefmt.c:91
-msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+#: ../lib/gmath/la.c:832
+msgid "Specified column index is outside range"
msgstr ""
-#: ../lib/db/dbmi_base/xdrtable.c:109
-msgid "fetch: table has wrong number of columns"
+#: ../lib/gmath/la.c:852
+msgid "Unknown vector type."
msgstr ""
-#: ../lib/db/dbmi_base/xdrvalue.c:82
-msgid "send data: invalid C-type"
+#: ../lib/gmath/la.c:977
+msgid "Output vector is uninitialized"
msgstr ""
-#: ../lib/db/dbmi_base/index.c:180
-msgid "db_set_index_column_name(): invalid column number"
+#: ../lib/gmath/la.c:982
+msgid "Vectors are not of the same type"
msgstr ""
-#: ../lib/db/dbmi_base/index.c:197
-msgid "db_get_index_column_name(): invalid column number"
+#: ../lib/gmath/la.c:987
+msgid "Output vector is of incorrect type"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:47 ../lib/gmath/test/test_main.c:47
-#: ../lib/vector/rtree/test_suite/test_main.c:45
-msgid "Choose the unit tests to run"
+#: ../lib/gmath/la.c:992
+msgid "Matrices not allowed"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:54 ../lib/gmath/test/test_main.c:54
-msgid "Choose the integration tests to run"
+#: ../lib/gmath/la.c:998
+msgid "Vectors have differing dimensions"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:58 ../lib/gmath/test/test_main.c:79
-#: ../lib/vector/rtree/test_suite/test_main.c:49
-msgid "Run all unit tests"
+#: ../lib/gmath/la.c:1004
+msgid "Output vector has incorrect dimension"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:62 ../lib/gmath/test/test_main.c:83
-msgid "Run all integration tests"
+#: ../lib/gmath/la.c:1050
+msgid "Vector dimensions out of range"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:66 ../lib/gmath/test/test_main.c:87
-msgid "Run all unit and integration tests"
+#: ../lib/gmath/la.c:1055
+msgid "Row/column out of range"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_main.c:83
-msgid "Performs unit and integration tests for the dbmi base library"
+#: ../lib/gmath/la.c:1270
+msgid "Vector structure is not initialised"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:37
-msgid ""
-"\n"
-"++ Running column unit tests ++"
+#: ../lib/gmath/la.c:1391 ../lib/gmath/la.c:1399 ../lib/gmath/la.c:1404
+msgid "Input format error"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:42
-msgid ""
-"\n"
-"-- column unit tests failure --"
+#: ../lib/gmath/solvers_krylov.c:262
+#, c-format
+msgid "Sparse PCG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:44
-msgid ""
-"\n"
-"-- column unit tests finished successfully --"
+#: ../lib/gmath/solvers_krylov.c:264
+#, c-format
+msgid "PCG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:57
-msgid ""
-"\n"
-"++ Run test copy column ++"
+#: ../lib/gmath/solvers_krylov.c:490
+#, c-format
+msgid "Sparse CG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_columns.c:150
-msgid ""
-"\n"
-"++ Test copy column finished ++"
+#: ../lib/gmath/solvers_krylov.c:492
+#, c-format
+msgid "CG -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:38
-msgid ""
-"\n"
-"++ Running table unit tests ++"
+#: ../lib/gmath/solvers_krylov.c:695
+#, c-format
+msgid "Sparse BiCGStab -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:43
-msgid ""
-"\n"
-"-- Table unit tests failure --"
+#: ../lib/gmath/solvers_krylov.c:698
+#, c-format
+msgid "BiCGStab -- iteration %i error %g\n"
msgstr ""
-#: ../lib/db/dbmi_base/test/test_table.c:45
-msgid ""
-"\n"
-"-- Table unit tests finished successfully --"
+#: ../lib/gmath/solvers_direct_cholesky_band.c:33
+#, c-format
+msgid "Decomposition failed at row %i and col %i"
msgstr ""
-#: ../lib/db/dbmi_base/login.c:99
+#: ../lib/ogsf/GS2.c:1211
+#, c-format
+msgid "no category info"
+msgstr "카테고리 정보가 없습니다."
+#: ../lib/ogsf/GS2.c:1230
+#, c-format
+msgid "no data"
+msgstr "자료가 없습니다."
+#: ../lib/ogsf/GS2.c:1655
+#, c-format
+msgid "Raster map <%s> is outside of current region. Load failed."
+msgstr "라스터맵 <%s>이 현재 영역 바깥입니다. 읽을 수 없습니다."
+#: ../lib/ogsf/GS2.c:1733 ../lib/ogsf/GS2.c:1739 ../lib/ogsf/GS2.c:1747
+#: ../lib/ogsf/GS2.c:1756 ../lib/ogsf/GS2.c:1764 ../lib/ogsf/GS2.c:1774
+#: ../lib/ogsf/GS2.c:1822
+msgid "GS_load_att_map(): Out of memory. Unable to load map"
+msgstr "GS_load_att_map(): 메모리가 모자랍니다. 맵을 읽을 수 없습니다."
+#: ../lib/ogsf/GS2.c:1850
+msgid "Loading failed"
+msgstr "읽을 수 없습니다."
+#: ../lib/ogsf/GS2.c:1854
+msgid "Error finding range"
+msgstr "범위를 찾지 못했습니다."
+#: ../lib/ogsf/gs_bm.c:124
+msgid "Bitmap mismatch"
+msgstr "비트맵이 일치하지 않습니다."
+#: ../lib/ogsf/gsd_img_ppm.c:52 ../lib/ogsf/gsd_img_ppm.c:95
+#: ../lib/ogsf/gsd_img_tif.c:64 ../lib/ogsf/GK2.c:216
#, fuzzy, c-format
-msgid "Unable to read file '%s'"
+msgid "Unable to open file <%s> for writing"
-#: ../lib/db/dbmi_base/login.c:113
+#: ../lib/ogsf/gsd_prim.c:146
#, c-format
-msgid "Login file (%s) corrupted (line: %s)"
+msgid "Color Material: %d"
+msgstr "색상재료: %d"
+#: ../lib/ogsf/gsd_prim.c:630
+#, c-format
+msgid ""
+"gsd_rot(): %c is an invalid axis specification. Rotation ignored. Please "
+"advise GRASS developers of this error"
msgstr ""
+"gsd_rot(): %c는 잘못된 좌표축 지정입니다. 회전을 무시합니다. GRASS 개발자들에"
+"게 조언을 구하세요."
-#: ../lib/db/dbmi_base/login.c:142
+#: ../lib/ogsf/gsdrape.c:207
+#, fuzzy
+msgid "Unable to process vector map - out of memory"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/ogsf/GVL2.c:267
#, fuzzy, c-format
-msgid "Unable to write file '%s'"
+msgid "Loading 3d raster map <%s>..."
-#: ../lib/db/dbmi_base/default_name.c:136
-msgid "Programmer error"
+#: ../lib/ogsf/Gvl3.c:40 ../lib/ogsf/gvl_file.c:427
+#: ../lib/manage/do_rename.c:76 ../lib/manage/do_remove.c:78
+#: ../lib/gpde/N_arrays_io.c:273
+#, c-format
+msgid "3D raster map <%s> not found"
+msgstr "3차원 라스터맵 <%s>를 찾을 수 없습니다."
+#: ../lib/ogsf/gsd_label.c:58
+msgid "Max. number of labels reached!"
+msgstr "최대 레이블 개수에 도달했습니다."
+#: ../lib/ogsf/GK2.c:272 ../lib/ogsf/GK2.c:285
+msgid "Check no. of frames requested and keyframes marked"
msgstr ""
-#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
-#, fuzzy, c-format
-msgid "Unable open database <%s> by driver <%s>"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/ogsf/trans.c:180
+msgid "Out of matrix stack space"
+msgstr "행렬 스택공간이 부족합니다."
-#: ../lib/db/dbmi_client/copy_tab.c:91
+#: ../lib/ogsf/trans.c:200
+msgid "Tried to pop an empty stack"
+msgstr "빈 스택에서 끄집어 내려고 했습니다."
+#: ../lib/ogsf/gsds.c:109
+msgid "Maximum number of datasets exceeded"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:239 ../lib/ogsf/Gs3.c:125 ../lib/ogsf/Gs3.c:189
+#: ../lib/ogsf/Gs3.c:264 ../lib/ogsf/Gs3.c:336 ../lib/ogsf/Gs3.c:442
+#: ../lib/ogsf/Gs3.c:529 ../lib/ogsf/Gs3.c:588 ../lib/ogsf/Gs3.c:645
+#: ../lib/ogsf/Gs3.c:716 ../lib/ogsf/Gs3.c:786 ../lib/gis/legal_name.c:94
+#: ../lib/gis/legal_name.c:97 ../lib/manage/do_rename.c:71
+#: ../lib/manage/do_remove.c:73 ../lib/raster/open.c:175
+#: ../lib/raster/open.c:744 ../lib/raster/open.c:781 ../lib/raster/open.c:833
+#: ../lib/rst/interp_float/output2d.c:236
+#: ../lib/rst/interp_float/output2d.c:317
+#: ../lib/rst/interp_float/output2d.c:386
+#: ../lib/rst/interp_float/output2d.c:436
+#: ../lib/rst/interp_float/output2d.c:450
+#: ../lib/rst/interp_float/output2d.c:464
+#: ../lib/rst/interp_float/output2d.c:480
+#: ../lib/rst/interp_float/resout2d.c:205
+#: ../lib/rst/interp_float/resout2d.c:253
+#: ../lib/rst/interp_float/resout2d.c:296
+#: ../lib/rst/interp_float/resout2d.c:327
+#: ../lib/rst/interp_float/resout2d.c:377
+#: ../lib/rst/interp_float/resout2d.c:395
+#: ../lib/rst/interp_float/resout2d.c:410
+#: ../lib/rst/interp_float/resout2d.c:426
#, c-format
-msgid "Array of values to select from column <%s> is empty"
+msgid "Raster map <%s> not found"
msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:107 ../lib/db/dbmi_client/copy_tab.c:127
-#: ../lib/db/dbmi_client/db.c:41 ../lib/vector/Vlib/write_pg.c:2888
-#: ../lib/vector/Vlib/ascii.c:404 ../lib/vector/Vlib/write_ogr.c:192
+#: ../lib/ogsf/gsd_legend.c:246
#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
+msgid "Unable to read color file of raster map <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:151
+#: ../lib/ogsf/gsd_legend.c:252
#, fuzzy, c-format
-msgid "Unable to get list tables in database <%s>"
+msgid "Unable to read category file of raster map <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:167
+#: ../lib/ogsf/gsd_legend.c:269
#, fuzzy, c-format
-msgid "Table <%s> already exists in database and will be overwritten"
+msgid "Unable to read fp range of raster map <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:172
+#: ../lib/ogsf/gsd_legend.c:281
#, fuzzy, c-format
-msgid "Table <%s> already exists in database <%s>"
+msgid "Unable to read range of raster map <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:250
-#, fuzzy, c-format
-msgid "Column <%s> is not integer"
+#: ../lib/ogsf/gsd_legend.c:295
+msgid "Range request error for legend"
+msgstr ""
-#: ../lib/db/dbmi_client/copy_tab.c:267 ../lib/rst/interp_float/vinput2d.c:94
-#: ../lib/rst/interp_float/vinput2d.c:108
+#: ../lib/ogsf/gsd_legend.c:385
+#, fuzzy
+msgid "Unable to show discrete FP range (use list)"
+msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/ogsf/gsd_legend.c:501
+msgid "Too many categories to show as discrete!"
+msgstr ""
+#: ../lib/ogsf/gsd_legend.c:503
+msgid "Try using smaller font!"
+msgstr ""
+#: ../lib/ogsf/Gv3.c:60 ../lib/ogsf/Gv3.c:326 ../lib/ogsf/Gp3.c:56
+#: ../lib/ogsf/Gp3.c:189 ../lib/manage/do_rename.c:54
+#: ../lib/manage/do_remove.c:57 ../lib/vector/Vlib/map.c:271
+#: ../lib/vector/Vlib/legal_vname.c:121 ../lib/vector/Vlib/legal_vname.c:124
+#: ../lib/vector/Vlib/open.c:235
+#, c-format
+msgid "Vector map <%s> not found"
+msgstr "벡터맵 <%s>를 찾을 수 없습니다."
+#: ../lib/ogsf/Gv3.c:262
+#, c-format
+msgid "No features from vector map <%s> fall within current region"
+msgstr "벡터맵 <%s>의 어떤 피쳐도 현재 영역 안에 있지 않습니다."
+#: ../lib/ogsf/Gv3.c:267
+#, c-format
+msgid "Vector map <%s> loaded (%d features)"
+msgstr "백터맵 <%s>를 읽었습니다. (%d 피쳐)"
+#: ../lib/ogsf/Gv3.c:337 ../lib/ogsf/Gp3.c:200
+#: ../lib/rst/interp_float/vinput2d.c:79 ../lib/vector/Vlib/map.c:179
+#: ../lib/vector/Vlib/map.c:308 ../lib/vector/Vlib/map.c:444
+#: ../lib/vector/Vlib/ascii.c:398 ../lib/vector/Vlib/array.c:276
+#: ../lib/vector/Vlib/cats.c:589 ../lib/vector/Vlib/net_build.c:159
+#: ../lib/vector/Vlib/net_build.c:206 ../lib/vector/Vlib/net_build.c:490
+#: ../lib/vector/Vlib/net_build.c:788 ../lib/vector/Vlib/net_build.c:968
+#: ../lib/vector/Vlib/copy.c:595 ../lib/vector/Vlib/copy.c:733
+#, c-format
+msgid "Database connection not defined for layer %d"
+msgstr "레이어 %d를 위한 데이타베이스 접속이 정의되지 않았습니다."
+#: ../lib/ogsf/Gv3.c:343 ../lib/ogsf/Gp3.c:206
+#: ../lib/rst/interp_float/vinput2d.c:88 ../lib/vector/neta/utils.c:119
+#: ../lib/vector/neta/timetables.c:133 ../lib/vector/Vlib/map.c:208
+#: ../lib/vector/Vlib/map.c:349 ../lib/vector/Vlib/write_ogr.c:197
+#: ../lib/vector/Vlib/write_pg.c:2893 ../lib/vector/Vlib/ascii.c:410
+#: ../lib/vector/Vlib/array.c:282 ../lib/vector/Vlib/cats.c:597
+#: ../lib/vector/Vlib/net_build.c:165 ../lib/vector/Vlib/net_build.c:211
+#: ../lib/vector/Vlib/net_build.c:496 ../lib/vector/Vlib/net_build.c:794
+#: ../lib/vector/Vlib/net_build.c:973 ../lib/vector/Vlib/copy.c:628
+#: ../lib/db/dbmi_client/copy_tab.c:112 ../lib/db/dbmi_client/copy_tab.c:133
+#: ../lib/db/dbmi_client/db.c:46 ../lib/sites/sites.c:281
#, fuzzy, c-format
-msgid "Column <%s> not found"
+msgid "Unable to open database <%s> by driver <%s>"
-#: ../lib/db/dbmi_client/copy_tab.c:270
+#: ../lib/ogsf/Gv3.c:346
#, fuzzy, c-format
-msgid "Unable to create table <%s>"
+msgid "Loading thematic vector layer <%s>..."
-#: ../lib/db/dbmi_client/copy_tab.c:314 ../lib/vector/Vlib/write_pg.c:1997
-#: ../lib/vector/Vlib/write_ogr.c:585
+#: ../lib/ogsf/Gv3.c:370 ../lib/ogsf/Gp3.c:233
#, fuzzy, c-format
-msgid "Unable to fetch data from table <%s>"
+msgid "No color rule defined for category %d"
-#: ../lib/db/dbmi_client/copy_tab.c:370
+#: ../lib/ogsf/Gv3.c:385 ../lib/ogsf/Gp3.c:247
+#, fuzzy, c-format
+msgid "Invalid color definition (%s)"
+msgstr "잘못된 좌표"
+#: ../lib/ogsf/Gv3.c:407
#, c-format
-msgid "Unknown column type (column <%s>)"
+msgid ""
+"%d features without category. Unable to determine color rules for features "
+"without category."
msgstr ""
+"%d 피쳐들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 피쳐는 색상규칙을 "
+"정할 수 없습니다."
-#: ../lib/db/dbmi_client/column.c:136 ../lib/python/script/db.py:48
-#: ../lib/vector/Vlib/ascii.c:431
-msgid "Unable to describe table <%s>"
+#: ../lib/ogsf/Gp3.c:92 ../lib/vector/Vlib/copy.c:168
+#: ../lib/vector/Vlib/copy.c:245
+#, fuzzy, c-format
+msgid "Unable to read vector map <%s>"
-#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
-#: ../lib/db/dbmi_client/select.c:288
-msgid "Missing column name"
-msgstr ""
+#: ../lib/ogsf/Gp3.c:146
+#, c-format
+msgid "No points from vector map <%s> fall within current region"
+msgstr "벡터맵 <%s>의 어떤 점도 현재 영역 안에 있지 않습니다"
-#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
-msgid "Missing key column name"
-msgstr ""
+#: ../lib/ogsf/Gp3.c:151
+#, c-format
+msgid "Vector map <%s> loaded (%d points)"
+msgstr "벡터맵 <%s>를 읽었습니다 (%d 포인트)"
-#: ../lib/db/dbmi_client/select.c:317 ../lib/vector/Vlib/cats.c:603
+#: ../lib/ogsf/Gp3.c:209
#, fuzzy, c-format
-msgid "Unable select records from table <%s>"
+msgid "Loading thematic points layer <%s>..."
+msgstr "주제 포인트 레이어 <%s>를 읽는 중입니다..."
-#: ../lib/db/dbmi_client/select.c:333
-#, fuzzy
-msgid "Key column type is not integer"
+#: ../lib/ogsf/Gp3.c:286
+#, c-format
+msgid ""
+"%d points without category. Unable to determine color rules for features "
+msgstr ""
+"%d 포인트들이 카테고리를 가지고 있지 않습니다. 카테고리 없는 포인트는 "
+"색상규칙을 정할 수 없습니다."
-#: ../lib/db/dbmi_client/delete_tab.c:53
+#: ../lib/ogsf/Gs3.c:132 ../lib/ogsf/Gs3.c:196 ../lib/ogsf/Gs3.c:348
+#: ../lib/ogsf/Gs3.c:454 ../lib/ogsf/Gs3.c:540
#, fuzzy, c-format
-msgid "Unable to drop table: '%s'"
+msgid "Loading raster map <%s>..."
+msgstr "라스터 맵 <%s>를 읽는 중입니다..."
-#: ../lib/manage/do_list.c:30
+#: ../lib/ogsf/Gs3.c:596
#, c-format
-msgid "%s: invalid index %d"
+msgid "Color table range doesn't match data (mincol=%d, maxcol=%d"
msgstr ""
-#: ../lib/manage/option.c:47
-#, c-format
-msgid "%s to be %s"
-msgstr ""
+#: ../lib/ogsf/Gs3.c:658 ../lib/ogsf/Gs3.c:730
+#, fuzzy, c-format
+msgid "Translating colors from raster map <%s>..."
+msgstr "라스터 맵 <%s>로부터 색상을 변환 중입니다..."
-#: ../lib/manage/option.c:51
-msgid "Raster"
+#: ../lib/ogsf/Gs3.c:967
+msgid "View not saved by this program,there may be some inconsistancies"
msgstr ""
-#: ../lib/manage/option.c:55
-msgid "Vector"
+#: ../lib/ogsf/gsd_surf.c:1742
+msgid "Cut-plane points mis-match between surfaces. Check resolution(s)."
msgstr ""
-#: ../lib/manage/option.c:57
-msgid "Region"
+#: ../lib/ogsf/GP2.c:705
+msgid "Unknown icon marker, using \"sphere\""
msgstr ""
-#: ../lib/manage/option.c:59
-msgid "Group"
+#: ../lib/ogsf/gk.c:320
+msgid "Need at least 3 keyframes for spline"
+msgstr "스플라인을 위해서는 최소 3개의 키프레임이 필요합니다."
+#: ../lib/ogsf/gk.c:622
+msgid "Need at least 2 keyframes for interpolation"
+msgstr "보간을 위해서는 최소 2개의 키프레임이 필요합니다."
+#: ../lib/ogsf/gsd_img_mpeg.c:72
+#, fuzzy
+msgid "Unable to allocate stream"
+#: ../lib/ogsf/gsd_img_mpeg.c:175
+msgid "Video codec not found"
msgstr ""
-#: ../lib/manage/do_rename.c:42
-#, fuzzy, c-format
-msgid "Rename %s <%s> to <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:185
+#, fuzzy
+msgid "Unable to open codec"
-#: ../lib/manage/do_rename.c:62
-#, fuzzy, c-format
-msgid "Unable to rename vector map <%s> to <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:204
+#, fuzzy
+msgid "Unable to allocate picture"
-#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
-#, fuzzy, c-format
-msgid "Unable to rename %s"
+#: ../lib/ogsf/gsd_img_mpeg.c:215
+#, fuzzy
+msgid "Unable to allocate temporary picture"
-#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
-#: ../lib/manage/do_copy.c:63 ../lib/manage/do_remove.c:89
-#: ../lib/manage/do_remove.c:109
-#, c-format
-msgid "%s is missing"
-msgstr ""
+#: ../lib/ogsf/gsd_img_mpeg.c:282
+#, fuzzy
+msgid "Error while writing video frame"
+msgstr "임시파일을 열 수 없습니다"
-#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
+#: ../lib/ogsf/gsd_img_mpeg.c:328
#, c-format
-msgid "%s renamed"
+msgid "Opening MPEG stream <%s>..."
msgstr ""
-#: ../lib/manage/do_rename.c:119
-#, c-format
-msgid "<%s> nothing renamed"
+#: ../lib/ogsf/gsd_img_mpeg.c:340
+msgid "Unable to deduce output format from file extension: using MPEG"
msgstr ""
-#: ../lib/manage/do_copy.c:43
-#, fuzzy, c-format
-msgid "Copy %s <%s> to current mapset as <%s>"
+#: ../lib/ogsf/gsd_img_mpeg.c:348
+#, fuzzy
+msgid "Unable to find suitable output format"
-#: ../lib/manage/do_copy.c:52
-#, fuzzy, c-format
-msgid "Unable to copy <%s> to current mapset as <%s>"
-#: ../lib/manage/do_copy.c:72
-#, c-format
-msgid "%s copied"
+#: ../lib/ogsf/gsd_img_mpeg.c:355 ../lib/rst/interp_float/segmen2d.c:182
+#: ../lib/rst/interp_float/segmen2d.c:188
+#: ../lib/rst/interp_float/segmen2d.c:194
+#: ../lib/rst/interp_float/segmen2d.c:204
+#: ../lib/rst/interp_float/interp2d.c:121
+#: ../lib/rst/interp_float/interp2d.c:127 ../lib/vector/neta/bridge.c:58
+#: ../lib/vector/neta/centrality.c:63 ../lib/vector/neta/centrality.c:145
+#: ../lib/vector/neta/path.c:136 ../lib/vector/neta/articulation_point.c:60
+#: ../lib/vector/neta/spanningtree.c:99 ../lib/vector/neta/timetables.c:69
+#: ../lib/vector/neta/timetables.c:168 ../lib/vector/neta/timetables.c:178
+#: ../lib/vector/neta/timetables.c:191 ../lib/vector/neta/timetables.c:278
+#: ../lib/vector/neta/timetables.c:413 ../lib/vector/neta/timetables.c:425
+#: ../lib/vector/neta/flow.c:64 ../lib/vector/neta/flow.c:179
+#: ../lib/vector/neta/components.c:46 ../lib/vector/neta/components.c:113
+#: ../lib/vector/Vlib/line.c:50 ../lib/vector/Vlib/line.c:154
+#: ../lib/rowio/setup.c:61 ../lib/rowio/setup.c:67 ../lib/segment/open.c:97
+msgid "Out of memory"
msgstr ""
-#: ../lib/manage/do_remove.c:42
-#, fuzzy, c-format
-msgid "Removing %s <%s>"
-#: ../lib/manage/do_remove.c:65
+#: ../lib/ogsf/gsd_img_mpeg.c:379
#, fuzzy
-msgid "Unable to delete vector map"
+msgid "Invalid output format parameters"
-#: ../lib/manage/do_remove.c:85
+#: ../lib/ogsf/gsd_img_mpeg.c:401
#, fuzzy, c-format
-msgid "Unable to remove %s element"
+msgid "Unable to open <%s>"
-#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
-#, c-format
-msgid "%s removed"
+#: ../lib/ogsf/gsd_img_mpeg.c:414
+msgid "OGSF library has not been built with MPEG output support"
msgstr ""
-#: ../lib/manage/do_remove.c:105
+#: ../lib/ogsf/gvl_file.c:103
+msgid "Maximum number of datafiles exceeded"
+msgstr ""
+#: ../lib/ogsf/gvl_file.c:442
#, fuzzy, c-format
-msgid "Unable to remove %s"
+msgid "Unable to read range of 3D raster map <%s>"
-#: ../lib/manage/do_remove.c:121
+#: ../lib/arraystats/class.c:21
+msgid "Discont algorithm currently not available because of bugs"
+msgstr ""
+#: ../lib/arraystats/class.c:23
#, c-format
-msgid "<%s> nothing removed"
+msgid "%s: Unknown algorithm"
msgstr ""
-#: ../lib/manage/read_list.c:73
-#, fuzzy, c-format
-msgid "Unable to open data base element list '%s'"
-#: ../lib/manage/read_list.c:134
+#: ../lib/arraystats/class.c:26
#, c-format
-msgid "Format error: file ('%s') line (%d) - %s"
+msgid "%s: Error in classification algorithm"
msgstr ""
-#: ../lib/cairodriver/Text.c:46
-#, fuzzy, c-format
-msgid "Unable to convert from <%s> to UTF-8"
-#: ../lib/cairodriver/Text.c:56
-msgid "Some characters could not be converted to UTF-8"
+#: ../lib/arraystats/class.c:220
+#, c-format
+msgid ""
+"There are classbreaks outside the range min-max. Number of classes reduced "
+"to %i, but using probabilities for %i classes."
msgstr ""
-#: ../lib/cairodriver/Raster.c:72
-#, fuzzy
-msgid "Failed to create surface"
-#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
-#, fuzzy, c-format
-msgid "Cairo: unable to open output file <%s>"
-#: ../lib/cairodriver/write_ppm.c:34
-#, fuzzy, c-format
-msgid "Cairo: unable to open mask file <%s>"
#: ../lib/cairodriver/read_bmp.c:88 ../lib/cairodriver/read_ppm.c:28
#, fuzzy, c-format
msgid "Cairo: unable to open input file <%s>"
@@ -1809,25 +2119,11 @@
msgid "Cairo: Invalid BMP header for <%s>"
msgstr ""
-#: ../lib/cairodriver/Draw_bitmap.c:47
-msgid "Cairo_Bitmap: Failed to create source"
-msgstr ""
-#: ../lib/cairodriver/read_xid.c:14
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
+#: ../lib/cairodriver/Raster.c:72
+#, fuzzy
+msgid "Failed to create surface"
-#: ../lib/cairodriver/read_xid.c:17
-#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
-#: ../lib/cairodriver/read_xid.c:20
-#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
#: ../lib/cairodriver/read_ppm.c:38
#, c-format
msgid "Cairo: input file has incorrect dimensions: expected: %dx%d got: %dx%d"
@@ -1849,6 +2145,30 @@
"Cairo: input mask file has incorrect dimensions: expected: %dx%d got: %dx%d"
msgstr ""
+#: ../lib/cairodriver/write_xid.c:14
+#, fuzzy, c-format
+msgid "Unable to open output file <%s>"
+#: ../lib/cairodriver/write_xid.c:19
+#, fuzzy, c-format
+msgid "Unable to write output file <%s>"
+#: ../lib/cairodriver/write_ppm.c:27 ../lib/cairodriver/write_bmp.c:72
+#, fuzzy, c-format
+msgid "Cairo: unable to open output file <%s>"
+#: ../lib/cairodriver/write_ppm.c:34
+#, fuzzy, c-format
+msgid "Cairo: unable to open mask file <%s>"
+#: ../lib/cairodriver/Draw_bitmap.c:47
+msgid "Cairo_Bitmap: Failed to create source"
+msgstr ""
#: ../lib/cairodriver/Graph.c:67
#, fuzzy
msgid "Unable to open display"
@@ -1884,530 +2204,305 @@
msgid "Failed to initialize Cairo surface"
-#: ../lib/cairodriver/write_xid.c:14
+#: ../lib/cairodriver/read_xid.c:14
#, fuzzy, c-format
-msgid "Unable to open output file <%s>"
+msgid "Unable to open input file <%s>"
-#: ../lib/cairodriver/write_xid.c:19
+#: ../lib/cairodriver/read_xid.c:17
#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
+msgid "Unable to read input file <%s>"
-#: ../lib/pngdriver/Graph_set.c:84
-#, c-format
-msgid "png: truecolor status %s"
-msgstr ""
+#: ../lib/cairodriver/read_xid.c:20
+#, fuzzy, c-format
+msgid "Unable to parse input file <%s>"
-#: ../lib/pngdriver/Graph_set.c:85 ../lib/psdriver/Graph_set.c:200
-msgid "enabled"
-msgstr ""
+#: ../lib/cairodriver/Text.c:46
+#, fuzzy, c-format
+msgid "Unable to convert from <%s> to UTF-8"
-msgid "disabled"
+#: ../lib/cairodriver/Text.c:56
+msgid "Some characters could not be converted to UTF-8"
msgstr ""
-#: ../lib/pngdriver/Graph_set.c:132
-#, c-format
-msgid "png: collecting to file '%s'"
-msgstr ""
+#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
+#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
+#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
+#: ../lib/lidar/raster.c:175
+#, fuzzy, c-format
+msgid "Unable to access table <%s>"
-#: ../lib/pngdriver/Graph_set.c:133
+#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
+#, fuzzy, c-format
+msgid "<%s> created in database."
+#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
#, c-format
-msgid "png: image size %dx%d"
+msgid "<%s> has not been created in database."
msgstr ""
-#: ../lib/init/grass.py:74
-msgid "WARNING"
-msgstr ""
+#: ../lib/imagery/target.c:38
+#, fuzzy, c-format
+msgid "Unable to read target file for group [%s]"
-#: ../lib/init/grass.py:129 ../lib/gis/parser.c:569
-msgid "ERROR"
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:81
+#, fuzzy, c-format
+msgid "Unable to write header into category raster condition file <%s>."
-#: ../lib/init/grass.py:130
-msgid "Exiting..."
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:98
+#, fuzzy, c-format
+msgid "Unable to write into category raster condition file <%s>."
+msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/init/grass.py:202
-msgid "Usage"
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:255
+#, fuzzy, c-format
+msgid "Unable to open category raster condtions file <%s>."
-#: ../lib/init/grass.py:203 ../lib/gis/parser_html.c:143
-#: ../lib/gis/parser_rest.c:146
-msgid "Flags"
-msgstr ""
-#: ../lib/init/grass.py:204
-msgid "print this help message"
-msgstr ""
-#: ../lib/init/grass.py:205
-msgid "show version information and exit"
-msgstr ""
-#: ../lib/init/grass.py:206
-msgid "create given database, location or mapset if it doesn't exist"
-msgstr ""
-#: ../lib/init/grass.py:207
-msgid "use text based interface (skip welcome screen)"
-msgstr ""
-#: ../lib/init/grass.py:208 ../lib/init/grass.py:210 ../lib/init/grass.py:212
-msgid "and set as default"
-msgstr ""
-#: ../lib/init/grass.py:209
-msgid "use text based interface (show welcome screen)"
-msgstr ""
-#: ../lib/init/grass.py:211
-msgid "use $DEFAULT_GUI graphical user interface"
-msgstr ""
-#: ../lib/init/grass.py:213
-msgid "print GRASS configuration parameters"
-msgstr ""
-#: ../lib/init/grass.py:214
-msgid "options: arch,build,compiler,path,revision"
-msgstr ""
-#: ../lib/init/grass.py:215 ../lib/gis/parser_html.c:186
-#: ../lib/gis/parser_rest.c:179
-msgid "Parameters"
-msgstr ""
-#: ../lib/init/grass.py:216
-msgid "initial database (path to GIS data)"
-msgstr ""
-#: ../lib/init/grass.py:217
-msgid "initial location"
-msgstr ""
-#: ../lib/init/grass.py:218
-msgid "initial mapset"
-msgstr ""
-#: ../lib/init/grass.py:219
-msgid "fully qualified initial mapset directory"
-msgstr ""
-#: ../lib/init/grass.py:220
-msgid "Environment variables relevant for startup"
-msgstr ""
-#: ../lib/init/grass.py:221
-msgid "select GUI (text, gui)"
-msgstr ""
-#: ../lib/init/grass.py:222
-msgid "set html web browser for help pages"
-msgstr ""
-#: ../lib/init/grass.py:223
-msgid "set additional path(s) to local GRASS modules or user scripts"
-msgstr ""
-#: ../lib/init/grass.py:224
-msgid "set additional GISBASE for locally installed GRASS Addons"
-msgstr ""
-#: ../lib/init/grass.py:225
-msgid "shell script to be processed as batch job"
-msgstr ""
-#: ../lib/init/grass.py:226
-msgid "set python shell name to override 'python'"
-msgstr ""
-#: ../lib/init/grass.py:264
-#, fuzzy, python-format
-msgid ""
-"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+#: ../lib/imagery/iscatt_core.c:263
+#, fuzzy, c-format
+msgid "Unable to find patch raster <%s>."
-#: ../lib/init/grass.py:348
-#, python-format
-msgid "GUI <%s> not supported in this version"
+#: ../lib/imagery/iscatt_core.c:280
+#, c-format
+msgid "Resolutions of patch <%s> and patched file <%s> are not same."
msgstr ""
-#: ../lib/init/grass.py:492
-msgid "Searched for a web browser, but none found"
+#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
+#, c-format
+msgid "Corrupted category raster conditions file <%s> (fseek failed)"
msgstr ""
-#: ../lib/init/grass.py:500
-#, python-format
-msgid ""
-"\n"
-"WELCOME TO GRASS %s\n"
-"\n"
-" 1) Have at your side all available GRASS GIS tutorials\n"
-"\n"
-" 2) When working on your location, the following materials\n"
-" are extremely useful:\n"
-" - A topographic map of your area\n"
-" - Current catalog of available computer maps\n"
-"\n"
-" 3) heck the GRASS GIS web pages for supporting mailing lists and more:\n"
-" http://grass.osgeo.org\n"
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:338
+#, fuzzy, c-format
+msgid "Unable to write into category raster conditions file <%s>"
-#: ../lib/init/grass.py:516
+#: ../lib/imagery/iscatt_core.c:526
#, fuzzy
-msgid "Hit RETURN to continue"
-msgstr "취소를 원하시면 RETURN을 누르세요\n"
+msgid "Unable to read from category raster condtition file."
-#: ../lib/init/grass.py:545
-msgid ""
-"The python command does not work as expected!\n"
-"Please check your GRASS_PYTHON environment variable.\n"
-"Use the -help option for details.\n"
-"Switching to text based interface mode.\n"
-"\n"
-"Hit RETURN to continue.\n"
+#: ../lib/imagery/iscatt_core.c:533
+msgid "Invalid size of category raster conditions file."
msgstr ""
-#: ../lib/init/grass.py:557
+#: ../lib/imagery/iscatt_core.c:579
msgid ""
-"It appears that the X Windows system is not active.\n"
-"A graphical based user interface is not supported.\n"
-"\n"
-"Hit RETURN to continue"
+"Data inconsistent. Value computed for scatter plot is out of initialized "
+"range."
msgstr ""
-#: ../lib/init/grass.py:604 ../lib/gis/make_mapset.c:66
-msgid "Location <%s> doesn't exist"
+#: ../lib/imagery/iscatt_core.c:745
+#, fuzzy, c-format
+msgid "Unbale to read find raster <%s>"
-#: ../lib/init/grass.py:609
-#, python-format
-msgid "ERROR: <%s> is not a valid GRASS location"
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:755
+#, fuzzy, c-format
+msgid "Unbale to open raster <%s>"
-#: ../lib/init/grass.py:612
-#, python-format
-msgid ""
-"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
-"created by '-c' switch."
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:761
+#, fuzzy, c-format
+msgid "Raster <%s> type is not <%s>"
-#: ../lib/init/grass.py:631
-#, python-format
-msgid "Failed to create new location. The location <%s> already exists."
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:775
+#, fuzzy, c-format
+msgid "Unable to read range of raster <%s>"
-#: ../lib/init/grass.py:659
-msgid "Missing WIND file fixed"
-msgstr ""
+#: ../lib/imagery/iscatt_core.c:803
+#, fuzzy, c-format
+msgid "Unable to open category raster condtition file <%s>"
-#: ../lib/init/grass.py:671
-msgid ""
-"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
-"Interactive startup needed."
+#: ../lib/imagery/iscatt_core.c:817
+msgid "Corrupted category raster conditions file (fseek failed)"
msgstr ""
-#: ../lib/init/grass.py:686
-#, python-format
-msgid ""
-"Invalid user interface specified - <%s>. Use the --help option to see valid "
-"interface names."
+#: ../lib/imagery/iscatt_core.c:972 ../lib/imagery/iclass_statistics.c:227
+#, c-format
+msgid "prepare_signature: scan line %d has odd number of points."
msgstr ""
-#: ../lib/init/grass.py:700
-msgid ""
-"Error in GUI startup. If necessary, please report this error to the GRASS "
-"developers.\n"
-"Switching to text mode now.\n"
-"\n"
-"Hit RETURN to continue..."
+#: ../lib/imagery/iscatt_core.c:981 ../lib/imagery/iclass_statistics.c:237
+msgid "signature: perimeter points out of order."
msgstr ""
-#: ../lib/init/grass.py:710
-msgid ""
-"Received EXIT message from GUI.\n"
-"GRASS is not started. Bye."
+#: ../lib/imagery/iclass_perimeter.c:109
+#, c-format
+msgid "Get area %d failed"
msgstr ""
-#: ../lib/init/grass.py:713
-msgid ""
-"Invalid return code from GUI startup script.\n"
-"Please advise GRASS developers of this error."
+#: ../lib/imagery/iclass_perimeter.c:116
+msgid "Perimeter computation failed"
msgstr ""
-#: ../lib/init/grass.py:724
-msgid ""
-"Error reading data path information from g.gisenv.\n"
-"GISDBASE=%(gisbase)s\n"
-"LOCATION_NAME=%(location)s\n"
-"MAPSET=%(mapset)s\n"
-"\n"
-"Check the <%s(file)> file."
+#: ../lib/imagery/iclass_perimeter.c:208
+msgid "Absurd polygon."
msgstr ""
-#: ../lib/init/grass.py:851
-#, python-format
-msgid "Path '%s' doesn't exist"
+#: ../lib/imagery/iclass_perimeter.c:253
+msgid "Outlined area is too large."
msgstr ""
-#: ../lib/init/grass.py:859
-#, python-format
-msgid ""
-"%(user)s is currently running GRASS in selected mapset (file %(file)s "
-"found). Concurrent use not allowed."
+#: ../lib/imagery/iclass_statistics.c:218
+msgid "prepare_signature: outline has odd number of points."
msgstr ""
-#: ../lib/init/grass.py:863
-#, python-format
-msgid ""
-"Unable to properly access '%s'.\n"
-"Please notify system personel."
+#: ../lib/imagery/iclass_statistics.c:248
+#, c-format
+msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
msgstr ""
-#: ../lib/init/grass.py:880
-msgid "Building user fontcap..."
+#: ../lib/imagery/iclass_statistics.c:561
+#: ../lib/imagery/iclass_statistics.c:584
+#: ../lib/imagery/iclass_statistics.c:607
+#: ../lib/imagery/iclass_statistics.c:630
+#: ../lib/imagery/iclass_statistics.c:653
+#: ../lib/imagery/iclass_statistics.c:680
+#: ../lib/imagery/iclass_statistics.c:712
+#: ../lib/imagery/iclass_statistics.c:735
+#: ../lib/imagery/iclass_statistics.c:758
+msgid "Band index out of range"
msgstr ""
-#: ../lib/init/grass.py:925
-#, python-format
-msgid "Unsupported shell <%(sh)s>: %(env)s"
+#: ../lib/imagery/iclass_statistics.c:684
+msgid "Cell category value out of range"
msgstr ""
-#: ../lib/init/grass.py:930
-msgid "The SHELL variable is not set"
-msgstr ""
+#: ../lib/imagery/points.c:124
+#, fuzzy, c-format
+msgid "Unable to open control point file for group [%s in %s]"
-#: ../lib/init/grass.py:941
-#, python-format
-msgid ""
-"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
-"found. Exiting.\n"
-"\n"
-"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
-msgstr ""
+#: ../lib/imagery/points.c:132
+#, fuzzy, c-format
+msgid "Bad format in control point file for group [%s in %s]"
-#: ../lib/init/grass.py:946
-#, python-format
-msgid "Change file permission to 'executable' for '%s'"
-msgstr ""
+#: ../lib/imagery/points.c:159
+#, fuzzy, c-format
+msgid "Unable to create control point file for group [%s in %s]"
-#: ../lib/init/grass.py:948
-#, python-format
-msgid "Executing '%s' ..."
+#: ../lib/imagery/list_subgp.c:72
+#, c-format
+msgid "subgroup <%s> of group <%s> is empty\n"
msgstr ""
-#: ../lib/init/grass.py:953
-#, python-format
-msgid "Execution of '%s' finished."
+#: ../lib/imagery/list_subgp.c:85
+#, c-format
+msgid "subgroup <%s> of group <%s> references the following raster maps\n"
msgstr ""
-#: ../lib/init/grass.py:959
-#, python-format
-msgid "GRASS GUI should be <%s>"
+#: ../lib/imagery/georef_tps.c:219
+msgid "Calculating forward transformation coefficients"
msgstr ""
-#: ../lib/init/grass.py:988
-#, python-format
-msgid "Welcome to GRASS %s"
+#: ../lib/imagery/georef_tps.c:236
+msgid "Calculating backward transformation coefficients"
msgstr ""
-#: ../lib/init/grass.py:998
-msgid "GRASS homepage:"
+#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
+#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
+#: ../lib/imagery/georef_tps.c:293
+#, c-format
+msgid "%s: out of memory"
msgstr ""
-#: ../lib/init/grass.py:999
-msgid "This version running through:"
-msgstr ""
-#: ../lib/init/grass.py:1001
-msgid "Help is available with the command:"
-msgstr ""
-#: ../lib/init/grass.py:1002
-msgid "See the licence terms with:"
-msgstr ""
-#: ../lib/init/grass.py:1005
-msgid "If required, restart the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:1007
-msgid "Start the GUI with:"
-msgstr ""
-#: ../lib/init/grass.py:1009
-msgid "When ready to quit enter:"
-msgstr ""
-#: ../lib/init/grass.py:1122
-msgid "Failed to start shell '%s'"
+#: ../lib/imagery/iclass_signatures.c:120
+#, fuzzy, c-format
+msgid "Unable to open output signature file '%s'"
-#: ../lib/init/grass.py:1127
-#, python-format
-msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
-msgstr ""
-#: ../lib/init/grass.py:1128 ../lib/init/grass.py:1133
-msgid "Goodbye from GRASS GIS"
-msgstr ""
-#: ../lib/init/grass.py:1131
-msgid "Done."
-msgstr ""
-#: ../lib/init/grass.py:1138
-msgid "Cleaning up temporary files..."
-msgstr ""
-#: ../lib/init/grass.py:1182
-#, python-format
-msgid "Parameter <%s> not supported"
-msgstr ""
-#: ../lib/init/grass.py:1343
-#, python-format
+#: ../lib/imagery/sigsetfile.c:41
+#, c-format
msgid ""
-"Unable to start GRASS. You can:\n"
-" - Launch GRASS with '-gui' switch (`grass70 -gui`)\n"
-" - Create manually GISRC file (%s)\n"
-" - Launch GRASS with path to the location/mapset as an argument (`grass70 /"
-"path/to/location/mapset`)"
+"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
+"is not current mapset"
msgstr ""
-#: ../lib/init/grass.py:1352
-msgid "Starting GRASS GIS..."
-msgstr ""
+#: ../lib/imagery/sigsetfile.c:57
+#, fuzzy, c-format
+msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-#: ../lib/init/grass.py:1406
-#, python-format
-msgid "Launching <%s> GUI in the background, please wait..."
-msgstr ""
-#: ../lib/init/prompt.py:20
-msgid "[Raster and Volume MASKs present]"
-msgstr ""
-#: ../lib/init/prompt.py:22
-msgid "[Raster MASK present]"
-msgstr ""
-#: ../lib/init/prompt.py:24
-msgid "[Volume MASK present]"
-msgstr ""
-#: ../lib/init/lock.c:38
+#: ../lib/imagery/list_gp.c:34
#, c-format
-msgid "Usage: %s file pid"
+msgid "group <%s> is empty\n"
msgstr ""
-#: ../lib/init/lock.c:42
-msgid "Concurrent mapset locking is not supported on Windows"
-msgstr ""
-#: ../lib/init/lock.c:60
-#, fuzzy, c-format
-msgid "Unable to write lockfile %s (%s)"
-#: ../lib/display/icon.c:80
-#, fuzzy, c-format
-msgid "Unsupported icon %d"
-msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#: ../lib/imagery/list_gp.c:44
#, c-format
-msgid "[%s]: No such color"
+msgid "group <%s> references the following raster maps\n"
msgstr ""
-#: ../lib/display/r_raster.c:113
+#: ../lib/imagery/fopen.c:23
#, c-format
-msgid "%s variable defined, %s ignored"
+msgid "Unable to create file [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/display/r_raster.c:148
+#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
#, fuzzy, c-format
-msgid "Unknown display driver <%s>"
+msgid "Unable to open file [%s] of group [%s in %s]"
-#: ../lib/display/r_raster.c:149
-#, fuzzy, c-format
-msgid "Using display driver <%s>..."
-#: ../lib/display/r_raster.c:215
-#, fuzzy, c-format
-msgid "Unable to open file '%s'"
-#: ../lib/symbol/read.c:211
+#: ../lib/imagery/fopen.c:49
#, c-format
-msgid "Cannot read symbol line coordinates: %s"
-msgstr "심볼의 좌표를 읽을 수 없습니다: %s"
-#: ../lib/symbol/read.c:260
-#, c-format
-msgid ""
-"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgid "Unable to find file [%s] of group [%s in %s]"
msgstr ""
-"잘못된 심볼이름: '%s' (group/name 또는 group/name at mapset 중 하나여야 합니다.)"
-#: ../lib/symbol/read.c:284
+#: ../lib/imagery/fopen.c:79
#, c-format
-msgid "Cannot find/open symbol: '%s'"
-msgstr "심볼을 찾을 수 없거나 열 수 없습니다: '%s'"
-#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
-#: ../lib/symbol/read.c:435
-#, c-format
-msgid "Incorrect symbol color: '%s', using default."
-msgstr "잘못된 심볼색상: %s, 기본값을 사용합니다."
-#: ../lib/driver/parse_ftcap.c:84
-#, c-format
-msgid "%s: Unable to read font definition file; use the default"
+msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/driver/parse_ftcap.c:90
+#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
#, c-format
-msgid "%s: No font definition file"
+msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/raster3d/maskfn.c:77
+#: ../lib/imagery/fopen.c:116
#, c-format
-msgid "Adding rule: %lf - %lf"
+msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
msgstr ""
-#: ../lib/raster3d/maskfn.c:95
+#: ../lib/imagery/iclass.c:83
#, fuzzy, c-format
-msgid "%s: illegal value spec"
-msgstr "잘못된 row 값"
-#: ../lib/raster3d/range.c:73
-#, fuzzy, c-format
-msgid "Unable to open range file for [%s in %s]"
+msgid "No areas in category %d"
-#: ../lib/raster3d/range.c:88
+#: ../lib/imagery/iclass.c:127
#, fuzzy, c-format
-msgid "Error reading range file for [%s in %s]"
+msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
-#: ../lib/raster3d/range.c:150
+#: ../lib/imagery/iclass.c:131
#, fuzzy, c-format
-msgid "Unable to open range file for <%s>"
+msgid "Raster map <%s@%s> in group <%s> does not exist"
-#: ../lib/raster3d/history.c:43
+#: ../lib/imagery/iclass.c:143
#, c-format
-msgid "can't get history information for [%s] in mapset [%s]"
+msgid "Subgroup <%s> does not have enough files (it has %d files)"
msgstr ""
+#: ../lib/imagery/iclass.c:147
+#, c-format
+msgid "Group <%s> does not have enough files (it has %d files)"
+msgstr ""
#: ../lib/raster3d/close.c:47
#, fuzzy, c-format
msgid "Unable to write history for 3D raster map <%s>"
@@ -2460,11 +2555,36 @@
msgid "Window replacing the default"
msgstr ""
-#: ../lib/raster3d/color.c:354
+#: ../lib/raster3d/maskfn.c:77
#, c-format
-msgid "mapset <%s> is not the current mapset"
+msgid "Adding rule: %lf - %lf"
msgstr ""
+#: ../lib/raster3d/maskfn.c:95
+#, fuzzy, c-format
+msgid "%s: illegal value spec"
+msgstr "잘못된 row 값"
+#: ../lib/raster3d/history.c:43
+#, c-format
+msgid "can't get history information for [%s] in mapset [%s]"
+msgstr ""
+#: ../lib/raster3d/range.c:73
+#, fuzzy, c-format
+msgid "Unable to open range file for [%s in %s]"
+#: ../lib/raster3d/range.c:88
+#, fuzzy, c-format
+msgid "Error reading range file for [%s in %s]"
+#: ../lib/raster3d/range.c:150
+#, fuzzy, c-format
+msgid "Unable to open range file for <%s>"
#: ../lib/raster3d/open.c:20
msgid "Rast3d_open_cell_old_no_header: error in Rast3d_mask_open_old"
msgstr ""
@@ -2538,544 +2658,263 @@
msgid "Rast3d_open_cell_new: error in Rast3d_fill_header"
msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:97
+#: ../lib/raster3d/color.c:354
#, c-format
-msgid "html: collecting to file '%s'"
-msgstr "html: '%s' 파일로 모읍니다."
+msgid "mapset <%s> is not the current mapset"
+msgstr ""
-#: ../lib/htmldriver/Graph_Set.c:98
+#: ../lib/pngdriver/Graph_set.c:84
#, c-format
-msgid "html: image size %dx%d"
-msgstr "html: 그림크기 %dx%d"
-#: ../lib/htmldriver/Graph_Set.c:111 ../lib/htmldriver/Graph_Set.c:115
-#: ../lib/htmldriver/Graph_Set.c:119
-#, c-format
-msgid "html: type '%s'"
-msgstr "html: 타입 '%s'"
-#: ../lib/gmath/solvers_direct.c:45
-msgid "Starting direct gauss elimination solver"
+msgid "png: truecolor status %s"
msgstr ""
-#: ../lib/gmath/solvers_direct.c:73
-msgid "Starting direct lu decomposition solver"
+#: ../lib/pngdriver/Graph_set.c:85 ../lib/psdriver/Graph_set.c:200
+msgid "enabled"
msgstr ""
-#: ../lib/gmath/solvers_direct.c:131
-msgid "Starting cholesky decomposition solver"
+msgid "disabled"
msgstr ""
-#: ../lib/gmath/solvers_direct.c:134 ../lib/gmath/solvers_krylov.c:254
-#: ../lib/gmath/solvers_krylov.c:482 ../lib/gmath/solvers_krylov.c:646
-msgid "Unable to solve the linear equation system"
+#: ../lib/pngdriver/Graph_set.c:132
+#, c-format
+msgid "png: collecting to file '%s'"
msgstr ""
-#: ../lib/gmath/del2g.c:50
-msgid " taking FFT of image..."
+#: ../lib/pngdriver/Graph_set.c:133
+#, c-format
+msgid "png: image size %dx%d"
msgstr ""
-#: ../lib/gmath/del2g.c:56
-msgid " computing del**2 g..."
+#: ../lib/gis/parser_interface.c:329 ../lib/gis/parser_html.c:167
+#: ../lib/gis/parser_help.c:197 ../lib/gis/parser_rest.c:164
+msgid "Allow output files to overwrite existing files"
msgstr ""
-#: ../lib/gmath/del2g.c:59
-msgid " taking FFT of del**2 g..."
+#: ../lib/gis/parser_interface.c:337 ../lib/gis/parser_html.c:171
+#: ../lib/gis/parser_help.c:199
+msgid "Print usage summary"
msgstr ""
-#: ../lib/gmath/del2g.c:63
-msgid " multiplying transforms..."
+#: ../lib/gis/parser_interface.c:344 ../lib/gis/parser_html.c:174
+#: ../lib/gis/parser_help.c:200 ../lib/gis/parser_rest.c:168
+msgid "Verbose module output"
msgstr ""
-#: ../lib/gmath/del2g.c:66
-msgid " taking inverse FFT..."
+#: ../lib/gis/parser_interface.c:351 ../lib/gis/parser_html.c:177
+#: ../lib/gis/parser_help.c:201 ../lib/gis/parser_rest.c:171
+msgid "Quiet module output"
msgstr ""
-#: ../lib/gmath/la.c:60 ../lib/gmath/la.c:116
-msgid "Matrix dimensions out of range"
-msgstr ""
+#: ../lib/gis/mapset_msc.c:61
+#, fuzzy, c-format
+msgid "Unable to make mapset element %s (%s): %s"
-#: ../lib/gmath/la.c:149
-msgid "Matrix is not initialised fully."
-msgstr ""
+#: ../lib/gis/mapset_msc.c:65
+#, fuzzy, c-format
+msgid "Unable to access mapset element %s (%s): %s"
-#: ../lib/gmath/la.c:154
-msgid "Unable to allocate space for matrix copy"
+#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#, c-format
+msgid "Current region rows: %d, cols: %d"
msgstr ""
-#: ../lib/gmath/la.c:243
-msgid "First scalar multiplier must be non-zero"
+#: ../lib/gis/alloc.c:47
+#, c-format
+msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
msgstr ""
-#: ../lib/gmath/la.c:249 ../lib/gmath/la.c:257 ../lib/gmath/la.c:322
-msgid "One or both input matrices uninitialised"
+#: ../lib/gis/alloc.c:89
+#, c-format
+msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
msgstr ""
-#: ../lib/gmath/la.c:262 ../lib/gmath/la.c:327
-msgid "Matrix order does not match"
+#: ../lib/gis/alloc.c:135
+#, c-format
+msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
msgstr ""
-#: ../lib/gmath/la.c:268
-msgid "Unable to allocate space for matrix sum"
+#: ../lib/gis/parser_html.c:56 ../lib/gis/parser_rest.c:60
+msgid "NAME"
msgstr ""
-#: ../lib/gmath/la.c:332
-msgid "Unable to allocate space for matrix product"
+#: ../lib/gis/parser_html.c:69 ../lib/gis/parser_rest.c:73
+msgid "KEYWORDS"
msgstr ""
-#: ../lib/gmath/la.c:444
-msgid "Input: one or both data matrices uninitialised"
+#: ../lib/gis/parser_html.c:74 ../lib/gis/parser_rest.c:78
+msgid "SYNOPSIS"
msgstr ""
-#: ../lib/gmath/la.c:449
-msgid "Principal matrix is not properly dimensioned"
+#: ../lib/gis/parser_html.c:144 ../lib/gis/parser_rest.c:146
+#: ../lib/init/grass.py:203
+msgid "Flags"
msgstr ""
-#: ../lib/gmath/la.c:454
-msgid "Input: you must have at least one array to solve"
+#: ../lib/gis/parser_html.c:187 ../lib/gis/parser_rest.c:179
+#: ../lib/init/grass.py:215
+msgid "Parameters"
msgstr ""
-#: ../lib/gmath/la.c:460
-msgid "Could not allocate space for solution matrix"
+#: ../lib/gis/parser_html.c:231 ../lib/gis/parser_rest.c:223
+msgid "Options"
msgstr ""
-#: ../lib/gmath/la.c:466 ../lib/gmath/la.c:474
-msgid "Could not allocate space for working matrix"
+#: ../lib/gis/parser_html.c:237 ../lib/gis/parser_rest.c:230
+msgid "Default"
msgstr ""
-#: ../lib/gmath/la.c:527
-msgid "Matrix (or submatrix is singular). Solution undetermined"
+#: ../lib/gis/env.c:260
+msgid "GISRC - variable not set"
msgstr ""
-#: ../lib/gmath/la.c:531
-msgid "Problem in LA routine."
+#: ../lib/gis/env.c:292 ../lib/gis/env.c:318
+#, c-format
+msgid "Variable '%s' not set"
msgstr ""
-#: ../lib/gmath/la.c:538
-msgid "Procedure not yet available for selected matrix type"
-msgstr ""
+#: ../lib/gis/ls.c:103
+#, fuzzy, c-format
+msgid "Unable to open directory %s"
-#: ../lib/gmath/la.c:572
-msgid "Matrix is not square. Cannot determine inverse"
-msgstr ""
+#: ../lib/gis/datum.c:160
+#, c-format
+msgid "unable to open datum table file: %s"
+msgstr "데이텀 테이블파일 %s을 열 수 없습니다."
-#: ../lib/gmath/la.c:577
-msgid "Unable to allocate space for matrix"
-msgstr ""
+#: ../lib/gis/datum.c:182
+#, c-format
+msgid "error in datum table file, line %d"
+msgstr "데이텀 테이블파일의 %d번째 줄에 오류가 있습니다."
-#: ../lib/gmath/la.c:594
-msgid "Matrix is singular"
+#: ../lib/gis/parser_wps.c:490
+msgid "Multiple outputs are not supported by WPS 1.0.0"
msgstr ""
-#: ../lib/gmath/la.c:599
-msgid "Problem in LA procedure."
-msgstr ""
+#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
+#, fuzzy
+msgid "Unable to seek"
-#: ../lib/gmath/la.c:687
-msgid "Element array has not been allocated"
+#: ../lib/gis/seek.c:56
+msgid "Seek offset out of range"
msgstr ""
-#: ../lib/gmath/la.c:692
-msgid "Specified element is outside array bounds"
-msgstr ""
+#: ../lib/gis/mkstemp.c:132
+#, fuzzy
+msgid "Attempt to create read-only temporary file"
-#: ../lib/gmath/la.c:746
-msgid "Specified matrix column index is outside range"
+#: ../lib/gis/mkstemp.c:138
+#, c-format
+msgid "Unrecognised access mode: %o"
msgstr ""
-#: ../lib/gmath/la.c:751 ../lib/gmath/la.c:792 ../lib/gmath/la.c:1105
-#: ../lib/gmath/la.c:1157 ../lib/gmath/la.c:1232
-msgid "Matrix is not initialised"
+#: ../lib/gis/view.c:176
+#, c-format
+msgid "Unable to open %s for writing"
msgstr ""
-#: ../lib/gmath/la.c:756 ../lib/gmath/la.c:797
-msgid "Could not allocate space for vector structure"
+#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
+#, c-format
+msgid "Unable to open %s for reading"
msgstr ""
-#: ../lib/gmath/la.c:787
-msgid "Specified matrix row index is outside range"
+#: ../lib/gis/view.c:465
+#, c-format
+msgid "GRASS window when view was saved:\n"
msgstr ""
-#: ../lib/gmath/la.c:827
-msgid "Specified row index is outside range"
+#: ../lib/gis/view.c:545
+#, c-format
+msgid " Window saved in \"%s\" is completely outside of current GRASS window."
msgstr ""
-#: ../lib/gmath/la.c:832
-msgid "Specified column index is outside range"
-msgstr ""
-#: ../lib/gmath/la.c:852
-msgid "Unknown vector type."
-msgstr ""
-#: ../lib/gmath/la.c:977
-msgid "Output vector is uninitialized"
-msgstr ""
-#: ../lib/gmath/la.c:982
-msgid "Vectors are not of the same type"
-msgstr ""
-#: ../lib/gmath/la.c:987
-msgid "Output vector is of incorrect type"
-msgstr ""
-#: ../lib/gmath/la.c:992
-msgid "Matrices not allowed"
-msgstr ""
-#: ../lib/gmath/la.c:998
-msgid "Vectors have differing dimensions"
-msgstr ""
-#: ../lib/gmath/la.c:1004
-msgid "Output vector has incorrect dimension"
-msgstr ""
-#: ../lib/gmath/la.c:1050
-msgid "Vector dimensions out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1055
-msgid "Row/column out of range"
-msgstr ""
-#: ../lib/gmath/la.c:1270
-msgid "Vector structure is not initialised"
-msgstr ""
-#: ../lib/gmath/la.c:1391 ../lib/gmath/la.c:1399 ../lib/gmath/la.c:1404
-msgid "Input format error"
-msgstr ""
-#: ../lib/gmath/solvers_direct_cholesky_band.c:33
+#: ../lib/gis/view.c:549
#, c-format
-msgid "Decomposition failed at row %i and col %i"
+msgid ""
+" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:262
+#: ../lib/gis/spawn.c:386
#, c-format
-msgid "Sparse PCG -- iteration %i error %g\n"
+msgid "CreateProcess() failed: error = %d"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:264
+#: ../lib/gis/spawn.c:421
#, c-format
-msgid "PCG -- iteration %i error %g\n"
+msgid "G_spawn: unable to redirect descriptor %d"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:490
+#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
#, c-format
-msgid "Sparse CG -- iteration %i error %g\n"
+msgid "G_spawn: unable to open file %s"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:492
-#, c-format
-msgid "CG -- iteration %i error %g\n"
+#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
+msgid "Unable to execute command"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:695
+#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
#, c-format
-msgid "Sparse BiCGStab -- iteration %i error %g\n"
+msgid "G_spawn: unable to restore signal %d"
msgstr ""
-#: ../lib/gmath/solvers_krylov.c:698
+#: ../lib/gis/spawn.c:567
#, c-format
-msgid "BiCGStab -- iteration %i error %g\n"
+msgid "G_spawn: unable to reset signal %d"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:84
+#: ../lib/gis/spawn.c:576
#, c-format
-msgid "sparse Jacobi -- iteration %5i error %g\n"
+msgid "G_spawn: unable to ignore signal %d"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:156
+#: ../lib/gis/spawn.c:587
#, c-format
-msgid "sparse SOR -- iteration %5i error %g\n"
+msgid "G_spawn: unable to block signal %d"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:218
+#: ../lib/gis/spawn.c:595
#, c-format
-msgid "Jacobi -- iteration %5i error %g\n"
+msgid "G_spawn: unable to unblock signal %d"
msgstr ""
-#: ../lib/gmath/solvers_classic_iter.c:275
+#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
#, c-format
-msgid "SOR -- iteration %5i error %g\n"
+msgid "G_spawn: unable to duplicate descriptor %d to %d"
msgstr ""
-#: ../lib/gmath/test/test_main.c:61
-msgid "The size of the matrices and vectors for benchmarking"
+#: ../lib/gis/spawn.c:666
+msgid "Unable to create a new process"
msgstr ""
-#: ../lib/gmath/test/test_main.c:68
-msgid "Choose solver benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:75
-msgid "Choose blas benchmark"
-msgstr ""
-#: ../lib/gmath/test/test_main.c:106
-#: ../lib/vector/rtree/test_suite/test_main.c:67
-msgid "Performs benchmarks, unit and integration tests for the gmath library"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_direct.c:34
-msgid ""
-"\n"
-"++ Running direct solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:38
-msgid ""
-"\n"
-"++ Running blas level 2 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:44
-msgid ""
-"\n"
-"-- blas level 2 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas2.c:46
-msgid ""
-"\n"
-"-- blas level 2 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:37
-msgid ""
-"\n"
-"++ Running matrix conversion unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:42
-msgid ""
-"\n"
-"-- Matrix conversion unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_matrix_conversion.c:44
-msgid ""
-"\n"
-"-- Matrix conversion unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/bench_solver_krylov.c:34
-msgid ""
-"\n"
-"++ Running krylov solver benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_blas2.c:35
-msgid ""
-"\n"
-"++ Running blas level 2 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/bench_blas3.c:34
-msgid ""
-"\n"
-"++ Running blas level 3 benchmark ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:40
-msgid ""
-"\n"
-"++ Running blas level 1 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:47
-msgid ""
-"\n"
-"-- blas level 1 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas1.c:49
-msgid ""
-"\n"
-"-- blas level 1 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:37
-msgid ""
-"\n"
-"++ Running solver unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:42
-msgid ""
-"\n"
-"-- Solver unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_solvers.c:44
-msgid ""
-"\n"
-"-- Solver unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:38
-msgid ""
-"\n"
-"++ Running blas level 3 unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:44
-msgid ""
-"\n"
-"-- blas level 3 unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_blas3.c:46
-msgid ""
-"\n"
-"-- blas level 3 unit tests finished successfully --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:37
-msgid ""
-"\n"
-"++ Running ccmath wrapper unit tests ++"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:42
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests failure --"
-msgstr ""
-#: ../lib/gmath/test/test_ccmath_wrapper.c:44
-msgid ""
-"\n"
-"-- ccmath wrapper unit tests finished successfully --"
-msgstr ""
-#: ../lib/temporal/lib/default_name.c:69
-msgid "Programmer error - only SQLite driver is currently supported"
-msgstr ""
-#: ../lib/gis/debug.c:80
+#: ../lib/gis/spawn.c:681
#, c-format
-msgid "Cannot open debug file '%s'"
-msgstr "'%s' 디버그파일을 열 수 없습니다."
-#: ../lib/gis/worker.c:72
-msgid "Task already has a worker"
+msgid "Unable to change directory to %s"
msgstr ""
-#: ../lib/gis/proj2.c:64
-msgid "State Plane"
+#: ../lib/gis/error.c:344
+msgid "WARNING: "
msgstr ""
-#: ../lib/gis/proj2.c:66
-msgid "Latitude-Longitude"
+#: ../lib/gis/error.c:345
+msgid "ERROR: "
msgstr ""
-#: ../lib/gis/proj2.c:68
-msgid "Other Projection"
-msgstr ""
-#: ../lib/gis/parser_html.c:55 ../lib/gis/parser_rest.c:60
-msgid "NAME"
-msgstr ""
-#: ../lib/gis/parser_html.c:68 ../lib/gis/parser_rest.c:73
-msgid "KEYWORDS"
-msgstr ""
-#: ../lib/gis/parser_html.c:73 ../lib/gis/parser_rest.c:78
-msgid "SYNOPSIS"
-msgstr ""
-#: ../lib/gis/parser_html.c:166 ../lib/gis/parser_rest.c:164
-#: ../lib/gis/parser_interface.c:329 ../lib/gis/parser_help.c:197
-msgid "Allow output files to overwrite existing files"
-msgstr ""
-#: ../lib/gis/parser_html.c:170 ../lib/gis/parser_interface.c:337
-#: ../lib/gis/parser_help.c:199
-msgid "Print usage summary"
-msgstr ""
-#: ../lib/gis/parser_html.c:173 ../lib/gis/parser_rest.c:168
-#: ../lib/gis/parser_interface.c:344 ../lib/gis/parser_help.c:200
-msgid "Verbose module output"
-msgstr ""
-#: ../lib/gis/parser_html.c:176 ../lib/gis/parser_rest.c:171
-#: ../lib/gis/parser_interface.c:351 ../lib/gis/parser_help.c:201
-msgid "Quiet module output"
-msgstr ""
-#: ../lib/gis/parser_html.c:230 ../lib/gis/parser_rest.c:223
-msgid "Options"
-msgstr ""
-#: ../lib/gis/parser_html.c:236 ../lib/gis/parser_rest.c:230
-msgid "Default"
-msgstr ""
-#: ../lib/gis/color_rules.c:88
+#: ../lib/gis/home.c:37
#, fuzzy
-msgid "no description"
+msgid "Unable to determine user's home directory"
-#: ../lib/gis/seek.c:52 ../lib/gis/seek.c:58
-#, fuzzy
-msgid "Unable to seek"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/gis/seek.c:56
-msgid "Seek offset out of range"
-msgstr ""
-#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
-msgid ""
-"Incompatible library version for module. You need to rebuild GRASS or "
-"untangle multiple installations."
-msgstr ""
-#: ../lib/gis/gisinit.c:61
-#, c-format
-msgid "MAPSET %s - permission denied"
-msgstr ""
-#: ../lib/gis/gisinit.c:64
+#: ../lib/gis/home.c:118
#, fuzzy, c-format
-msgid "MAPSET %s not found at %s"
-#: ../lib/gis/gisinit.c:97
-msgid "System not initialized. Programmer forgot to call G_gisinit()."
-msgstr ""
-#: ../lib/gis/mapset_msc.c:61
-#, fuzzy, c-format
-msgid "Unable to make mapset element %s (%s): %s"
+msgid "Failed to create directory [%s]"
-#: ../lib/gis/mapset_msc.c:65
-#, fuzzy, c-format
-msgid "Unable to access mapset element %s (%s): %s"
-#: ../lib/gis/ls.c:103
-#, fuzzy, c-format
-msgid "Unable to open directory %s"
-#: ../lib/gis/datum.c:160
-#, c-format
-msgid "unable to open datum table file: %s"
-msgstr "데이텀 테이블파일 %s을 열 수 없습니다."
-#: ../lib/gis/datum.c:182
-#, c-format
-msgid "error in datum table file, line %d"
-msgstr "데이텀 테이블파일의 %d번째 줄에 오류가 있습니다."
#: ../lib/gis/adj_cellhd.c:42 ../lib/gis/adj_cellhd.c:191
msgid "Illegal n-s resolution value"
msgstr "잘못된 n-s 해상도값입니다."
@@ -3165,62 +3004,202 @@
msgid "Top must be larger than Bottom"
msgstr "북쪽경계는 남쪽경계보다 값이 커야합니다"
-#: ../lib/gis/home.c:37
-#, fuzzy
-msgid "Unable to determine user's home directory"
+#: ../lib/gis/proj2.c:64
+msgid "State Plane"
+msgstr ""
-#: ../lib/gis/home.c:118
-#, fuzzy, c-format
-msgid "Failed to create directory [%s]"
+#: ../lib/gis/proj2.c:66
+msgid "Latitude-Longitude"
+msgstr ""
-#: ../lib/gis/proj3.c:58 ../lib/gis/units.c:198
-msgid "units"
+#: ../lib/gis/proj2.c:68
+msgid "Other Projection"
msgstr ""
-msgid "unit"
+#: ../lib/gis/parser.c:376
+#, c-format
+msgid "BUG in descriptions, option '%s' in <%s> does not exist"
msgstr ""
-#: ../lib/gis/proj3.c:107 ../lib/vector/Vlib/header.c:557
-msgid "Unknown projection"
+#: ../lib/gis/parser.c:491
+msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
msgstr ""
-#: ../lib/gis/view.c:176
+#: ../lib/gis/parser.c:505
+msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+msgstr ""
+#: ../lib/gis/parser.c:536
#, c-format
-msgid "Unable to open %s for writing"
+msgid "Sorry <%s> is not a valid option"
msgstr ""
-#: ../lib/gis/view.c:262 ../lib/gis/view.c:479
+#: ../lib/gis/parser.c:569 ../lib/init/grass.py:129
+msgid "ERROR"
+msgstr ""
+#: ../lib/gis/parser.c:806
+msgid "Unable to determine program name"
+msgstr ""
+#: ../lib/gis/parser.c:822 ../lib/gis/parser.c:839
#, c-format
-msgid "Unable to open %s for reading"
+msgid "Sorry, <%c> is not a valid flag"
msgstr ""
-#: ../lib/gis/view.c:465
+#: ../lib/gis/parser.c:939
#, c-format
-msgid "GRASS window when view was saved:\n"
+msgid "Sorry, <%s=> is ambiguous"
msgstr ""
-#: ../lib/gis/view.c:545
+#: ../lib/gis/parser.c:946
#, c-format
-msgid " Window saved in \"%s\" is completely outside of current GRASS window."
+msgid "Sorry, <%s> is not a valid parameter"
msgstr ""
-#: ../lib/gis/view.c:549
+#: ../lib/gis/parser.c:954
#, c-format
+msgid "Option <%s> does not accept multiple answers"
+msgstr ""
+#: ../lib/gis/parser.c:1025
+#, c-format
msgid ""
-" Only %d%% of window saved in \"%s\" overlaps with current GRASS window."
+"Illegal range syntax for parameter <%s>\n"
+"\tPresented as: %s"
msgstr ""
-#: ../lib/gis/error.c:344
-msgid "WARNING: "
+#: ../lib/gis/parser.c:1031
+#, c-format
+msgid ""
+"Value <%s> out of range for parameter <%s>\n"
+"\tLegal range: %s"
msgstr ""
-#: ../lib/gis/error.c:345
-msgid "ERROR: "
+#: ../lib/gis/parser.c:1037
+#, fuzzy, c-format
+msgid "Missing value for parameter <%s>"
+#: ../lib/gis/parser.c:1043
+#, c-format
+msgid ""
+"Value <%s> ambiguous for parameter <%s>\n"
+"\tValid options: %s"
msgstr ""
+#: ../lib/gis/parser.c:1198
+#, c-format
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
+msgstr ""
+#: ../lib/gis/parser.c:1290
+#, c-format
+msgid ""
+"Option <%s> must be provided in multiples of %d\n"
+"\tYou provided %d item(s): %s"
+msgstr ""
+#: ../lib/gis/parser.c:1365
+#, c-format
+msgid "ERROR: option <%s>: <%s> exists.\n"
+msgstr ""
+#: ../lib/gis/parser.c:1449
+msgid "No separator given"
+msgstr ""
+#: ../lib/gis/paths.c:201
+#, fuzzy, c-format
+msgid "Unable to open file <%s> for reading"
+#: ../lib/gis/paths.c:217
+#, fuzzy, c-format
+msgid "Unable to fetch security info for <%s>"
+#: ../lib/gis/get_window.c:117
+#, fuzzy, c-format
+msgid "Unable to open element file <%s> for <%s@%s>"
+#: ../lib/gis/location.c:61
+#, c-format
+msgid "LOCATION <%s> not available"
+msgstr ""
+#: ../lib/gis/color_rules.c:88
+#, fuzzy
+msgid "no description"
+#: ../lib/gis/parser_help.c:79
+msgid "Description:"
+msgstr ""
+#: ../lib/gis/parser_help.c:89
+msgid "Keywords:"
+msgstr ""
+#: ../lib/gis/parser_help.c:97
+msgid "Usage:"
+msgstr ""
+#: ../lib/gis/parser_help.c:127
+msgid "ERROR: Option key not defined"
+msgstr ""
+#: ../lib/gis/parser_help.c:174
+msgid "Flags:"
+msgstr ""
+#: ../lib/gis/parser_help.c:209
+msgid "Parameters:"
+msgstr ""
+#: ../lib/gis/parser_help.c:232
+#, c-format
+msgid " %*s default: %s\n"
+msgstr ""
+#: ../lib/gis/parser_help.c:258
+#, c-format
+msgid " %*s options: "
+msgstr ""
+#: ../lib/gis/key_value3.c:33
+#, fuzzy, c-format
+msgid "Unable to open output file <%s>: %s"
+#: ../lib/gis/key_value3.c:36
+#, fuzzy, c-format
+msgid "Error writing file <%s>: %s"
+#: ../lib/gis/key_value3.c:39
+#, fuzzy, c-format
+msgid "Error closing output file <%s>: %s"
+#: ../lib/gis/key_value3.c:60
+#, fuzzy, c-format
+msgid "Unable to open input file <%s>: %s"
+#: ../lib/gis/key_value3.c:64
+#, fuzzy, c-format
+msgid "Error reading file <%s>: %s"
+#: ../lib/gis/key_value3.c:67
+#, fuzzy, c-format
+msgid "Error closing input file <%s>: %s"
#: ../lib/gis/parser_standard_options.c:140
msgid "SQL select statement"
msgstr ""
@@ -3642,84 +3621,299 @@
msgid "Do not build topology"
msgstr ""
-#: ../lib/gis/legal_name.c:39
+#: ../lib/gis/find_file.c:79
#, c-format
-msgid "Illegal filename <%s>. Cannot be '.' or 'NULL'."
+msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
msgstr ""
-#: ../lib/gis/legal_name.c:46
+#: ../lib/gis/find_file.c:87
+#, fuzzy, c-format
+msgid "Using <%s@%s>"
+#: ../lib/gis/gisinit.c:51 ../lib/gis/gisinit.c:83
+msgid ""
+"Incompatible library version for module. You need to rebuild GRASS or "
+"untangle multiple installations."
+msgstr ""
+#: ../lib/gis/gisinit.c:61
#, c-format
-msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
+msgid "MAPSET %s - permission denied"
msgstr ""
-#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
+#: ../lib/gis/gisinit.c:64
+#, fuzzy, c-format
+msgid "MAPSET %s not found at %s"
+#: ../lib/gis/gisinit.c:97
+msgid "System not initialized. Programmer forgot to call G_gisinit()."
+msgstr ""
+#: ../lib/gis/get_projinfo.c:34 ../lib/gis/get_projinfo.c:60
#, c-format
-msgid "Output raster map name <%s> is not valid map name"
+msgid "<%s> file not found for location <%s>"
msgstr ""
-#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
+#: ../lib/gis/get_ellipse.c:263 ../lib/proj/ellipse.c:220
+#, fuzzy, c-format
+msgid "Unable to open ellipsoid table file <%s>"
+#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
#, c-format
-msgid "Output raster map <%s> is used as input"
+msgid "Invalid a: field '%s' in file %s in <%s>"
msgstr ""
-#: ../lib/gis/spawn.c:386
+#: ../lib/gis/get_ellipse.c:356
#, c-format
-msgid "CreateProcess() failed: error = %d"
+msgid "Invalid ellipsoid '%s' in file %s in <%s>"
msgstr ""
-#: ../lib/gis/spawn.c:421
+#: ../lib/gis/get_ellipse.c:370
#, c-format
-msgid "G_spawn: unable to redirect descriptor %d"
+msgid "Invalid es: field '%s' in file %s in <%s>"
msgstr ""
-#: ../lib/gis/spawn.c:429 ../lib/gis/spawn.c:619
+#: ../lib/gis/get_ellipse.c:383
#, c-format
-msgid "G_spawn: unable to open file %s"
+msgid "No ellipsoid info given in file %s in <%s>"
msgstr ""
-#: ../lib/gis/spawn.c:503 ../lib/gis/spawn.c:689
-msgid "Unable to execute command"
+#: ../lib/gis/rd_cellhd.c:139 ../lib/gis/rd_cellhd.c:150
+#: ../lib/gis/rd_cellhd.c:160 ../lib/gis/rd_cellhd.c:177
+#: ../lib/gis/rd_cellhd.c:193 ../lib/gis/rd_cellhd.c:201
+#: ../lib/gis/rd_cellhd.c:209 ../lib/gis/rd_cellhd.c:217
+#: ../lib/gis/rd_cellhd.c:225 ../lib/gis/rd_cellhd.c:233
+#: ../lib/gis/rd_cellhd.c:241 ../lib/gis/rd_cellhd.c:243
+#: ../lib/gis/rd_cellhd.c:251 ../lib/gis/rd_cellhd.c:253
+#: ../lib/gis/rd_cellhd.c:261 ../lib/gis/rd_cellhd.c:263
+#: ../lib/gis/rd_cellhd.c:271 ../lib/gis/rd_cellhd.c:273
+#: ../lib/gis/rd_cellhd.c:281 ../lib/gis/rd_cellhd.c:283
+#: ../lib/gis/rd_cellhd.c:291 ../lib/gis/rd_cellhd.c:293
+#: ../lib/gis/rd_cellhd.c:301 ../lib/gis/rd_cellhd.c:303
+#: ../lib/gis/rd_cellhd.c:311 ../lib/gis/rd_cellhd.c:313
+#: ../lib/gis/rd_cellhd.c:321 ../lib/gis/rd_cellhd.c:323
+#: ../lib/gis/rd_cellhd.c:331 ../lib/gis/rd_cellhd.c:333
+#: ../lib/gis/rd_cellhd.c:341 ../lib/gis/rd_cellhd.c:349
+#: ../lib/gis/rd_cellhd.c:353
+msgid "Syntax error in cell header"
msgstr ""
-#: ../lib/gis/spawn.c:528 ../lib/gis/spawn.c:536
+#: ../lib/gis/rd_cellhd.c:147
+msgid "Duplicate projection field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:157
+msgid "Duplicate zone field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:167 ../lib/gis/rd_cellhd.c:169
+#: ../lib/gis/rd_cellhd.c:358 ../lib/gis/rd_cellhd.c:360
+#: ../lib/gis/rd_cellhd.c:362 ../lib/gis/rd_cellhd.c:364
+#: ../lib/gis/rd_cellhd.c:366 ../lib/gis/rd_cellhd.c:368
+#: ../lib/gis/rd_cellhd.c:379 ../lib/gis/rd_cellhd.c:381
+#: ../lib/gis/rd_cellhd.c:383 ../lib/gis/rd_cellhd.c:385
#, c-format
-msgid "G_spawn: unable to restore signal %d"
+msgid "Field <%s> missing"
msgstr ""
-#: ../lib/gis/spawn.c:567
+#: ../lib/gis/rd_cellhd.c:191
+msgid "Duplicate north field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:199
+msgid "Duplicate south field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:207
+msgid "Duplicate east field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:215
+msgid "Duplicate west field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:223
+msgid "Duplicate top field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:231
+msgid "Duplicate bottom field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:239
+#, fuzzy
+msgid "Duplicate e-w resolution field"
+msgstr "잘못된 e-w 해상도"
+#: ../lib/gis/rd_cellhd.c:249
+#, fuzzy
+msgid "Duplicate 3D e-w resolution field"
+#: ../lib/gis/rd_cellhd.c:259
+#, fuzzy
+msgid "Duplicate n-s resolution field"
+msgstr "잘못된 n-s 해상도"
+#: ../lib/gis/rd_cellhd.c:269
+#, fuzzy
+msgid "Duplicate 3D n-s resolution field"
+#: ../lib/gis/rd_cellhd.c:279
+#, fuzzy
+msgid "Duplicate t-b resolution field"
+msgstr "잘못된 t-b3 해상도"
+#: ../lib/gis/rd_cellhd.c:289
+msgid "Duplicate rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:299
+msgid "Duplicate 3D rows field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:309
+msgid "Duplicate cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:319
+msgid "Duplicate 3D cols field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:329
+msgid "Duplicate depths field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:339
+msgid "Duplicate format field"
+msgstr ""
+#: ../lib/gis/rd_cellhd.c:347
+msgid "Duplicate compressed field"
+msgstr ""
+#: ../lib/gis/proj3.c:58 ../lib/gis/units.c:198
+msgid "units"
+msgstr ""
+msgid "unit"
+msgstr ""
+#: ../lib/gis/proj3.c:107 ../lib/vector/Vlib/header.c:557
+msgid "Unknown projection"
+msgstr ""
+#: ../lib/gis/worker.c:72
+msgid "Task already has a worker"
+msgstr ""
+#: ../lib/gis/mapset.c:38
+msgid "MAPSET is not set"
+msgstr ""
+#: ../lib/gis/mapset.c:80
#, c-format
-msgid "G_spawn: unable to reset signal %d"
+msgid "MAPSET <%s> not available"
msgstr ""
-#: ../lib/gis/spawn.c:576
+#: ../lib/gis/done_msg.c:38
#, c-format
-msgid "G_spawn: unable to ignore signal %d"
+msgid "%s complete. %s"
msgstr ""
-#: ../lib/gis/spawn.c:587
+#: ../lib/gis/open.c:62
#, c-format
-msgid "G_spawn: unable to block signal %d"
+msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
msgstr ""
-#: ../lib/gis/spawn.c:595
+#: ../lib/gis/open.c:84
#, c-format
-msgid "G_spawn: unable to unblock signal %d"
+msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
msgstr ""
-#: ../lib/gis/spawn.c:624 ../lib/gis/spawn.c:633
+#: ../lib/gis/list.c:83
#, c-format
-msgid "G_spawn: unable to duplicate descriptor %d to %d"
+msgid "no %s files available in current mapset\n"
msgstr ""
-#: ../lib/gis/spawn.c:666
-msgid "Unable to create a new process"
+#: ../lib/gis/list.c:86
+#, c-format
+msgid "no %s files available in mapset <%s>\n"
msgstr ""
-#: ../lib/gis/spawn.c:681
+#: ../lib/gis/list.c:132
#, c-format
-msgid "Unable to change directory to %s"
+msgid "%s files available in mapset <%s>:\n"
msgstr ""
+#: ../lib/gis/list.c:204
+msgid "G_list: Unknown element type"
+msgstr ""
+#: ../lib/gis/make_mapset.c:66 ../lib/init/grass.py:607
+#, fuzzy, c-format, python-format
+msgid "Location <%s> doesn't exist"
+#: ../lib/gis/myname.c:46
+msgid "This location has no description."
+msgstr ""
+#: ../lib/gis/debug.c:80
+#, c-format
+msgid "Cannot open debug file '%s'"
+msgstr "'%s' 디버그파일을 열 수 없습니다."
+#: ../lib/gis/timestamp.c:292
+#, fuzzy, c-format
+msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/gis/timestamp.c:301
+#, fuzzy, c-format
+msgid "Invalid timestamp specified for %s map <%s@%s>"
+#: ../lib/gis/timestamp.c:331
+#, fuzzy, c-format
+msgid "Unable to open timestamp file for %s map <%s@%s>"
+#: ../lib/gis/timestamp.c:340
+#, fuzzy, c-format
+msgid "Invalid timestamp file for %s map <%s@%s>"
+#: ../lib/gis/timestamp.c:479
+#, fuzzy, c-format
+msgid "Unable to open timestamp file for vector map <%s@%s>"
+#: ../lib/gis/timestamp.c:488
+#, fuzzy, c-format
+msgid "Invalid timestamp file for vector map <%s@%s>"
+#: ../lib/gis/timestamp.c:524
+#, fuzzy, c-format
+msgid "Unable to create timestamp file for vector map <%s@%s>"
+#: ../lib/gis/timestamp.c:533
+#, fuzzy, c-format
+msgid "Invalid timestamp specified for vector map <%s@%s>"
+#: ../lib/gis/distance.c:154
+#, c-format
+msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgstr ""
#: ../lib/gis/units.c:196
msgid "square units"
msgstr ""
@@ -3872,1753 +4066,1391 @@
msgid "second"
msgstr ""
-#: ../lib/gis/parser_wps.c:490
-msgid "Multiple outputs are not supported by WPS 1.0.0"
+#: ../lib/gis/legal_name.c:39
+#, c-format
+msgid "Illegal filename <%s>. Cannot be '.' or 'NULL'."
msgstr ""
-#: ../lib/gis/alloc.c:44 ../lib/gis/alloc.c:86 ../lib/gis/alloc.c:132
+#: ../lib/gis/legal_name.c:46
#, c-format
-msgid "Current region rows: %d, cols: %d"
+msgid "Illegal filename <%s>. Character <%c> not allowed.\n"
msgstr ""
-#: ../lib/gis/alloc.c:47
+#: ../lib/gis/legal_name.c:77 ../lib/gis/legal_name.c:81
#, c-format
-msgid "G_malloc: unable to allocate %lu bytes of memory at %s:%d"
+msgid "Output raster map name <%s> is not valid map name"
msgstr ""
-#: ../lib/gis/alloc.c:89
+#: ../lib/gis/legal_name.c:118 ../lib/gis/legal_name.c:122
#, c-format
-msgid "G_calloc: unable to allocate %lu * %lu bytes of memory at %s:%d"
+msgid "Output raster map <%s> is used as input"
msgstr ""
-#: ../lib/gis/alloc.c:135
+#: ../lib/gis/open_misc.c:45
#, c-format
-msgid "G_realloc: unable to allocate %lu bytes of memory at %s:%d"
+msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
msgstr ""
-#: ../lib/gis/done_msg.c:38
+#: ../lib/gis/open_misc.c:67
#, c-format
-msgid "%s complete. %s"
+msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
msgstr ""
-#: ../lib/gis/env.c:260
-msgid "GISRC - variable not set"
+#: ../lib/init/grass.py:74
+msgid "WARNING"
msgstr ""
-#: ../lib/gis/env.c:292 ../lib/gis/env.c:318
-#, c-format
-msgid "Variable '%s' not set"
+#: ../lib/init/grass.py:130
+msgid "Exiting..."
msgstr ""
-#: ../lib/gis/list.c:83
-#, c-format
-msgid "no %s files available in current mapset\n"
+#: ../lib/init/grass.py:202
+msgid "Usage"
msgstr ""
-#: ../lib/gis/list.c:86
-#, c-format
-msgid "no %s files available in mapset <%s>\n"
+#: ../lib/init/grass.py:204
+msgid "print this help message"
msgstr ""
-#: ../lib/gis/list.c:132
-#, c-format
-msgid "%s files available in mapset <%s>:\n"
+#: ../lib/init/grass.py:205
+msgid "show version information and exit"
msgstr ""
-#: ../lib/gis/list.c:204
-msgid "G_list: Unknown element type"
+#: ../lib/init/grass.py:206
+msgid "create given database, location or mapset if it doesn't exist"
msgstr ""
-#: ../lib/gis/mapset.c:38
-msgid "MAPSET is not set"
+#: ../lib/init/grass.py:207
+msgid "use text based interface (skip welcome screen)"
msgstr ""
-#: ../lib/gis/mapset.c:80
-#, c-format
-msgid "MAPSET <%s> not available"
+#: ../lib/init/grass.py:208 ../lib/init/grass.py:210 ../lib/init/grass.py:212
+msgid "and set as default"
msgstr ""
-#: ../lib/gis/mkstemp.c:132
-#, fuzzy
-msgid "Attempt to create read-only temporary file"
-msgstr "임시파일을 열 수 없습니다"
+#: ../lib/init/grass.py:209
+msgid "use text based interface (show welcome screen)"
+msgstr ""
-#: ../lib/gis/mkstemp.c:138
-#, c-format
-msgid "Unrecognised access mode: %o"
+#: ../lib/init/grass.py:211
+msgid "use $DEFAULT_GUI graphical user interface"
msgstr ""
-#: ../lib/gis/find_file.c:79
-#, c-format
-msgid "'%s/%s' was found in more mapsets (also found in <%s>)"
+#: ../lib/init/grass.py:213
+msgid "print GRASS configuration parameters"
msgstr ""
-#: ../lib/gis/find_file.c:87
-#, fuzzy, c-format
-msgid "Using <%s@%s>"
-#: ../lib/gis/location.c:61
-#, c-format
-msgid "LOCATION <%s> not available"
+#: ../lib/init/grass.py:214
+msgid "options: arch,build,compiler,path,revision"
msgstr ""
-#: ../lib/gis/open_misc.c:45
-#, c-format
-msgid "G__open_misc(read): mapset <%s> doesn't match xmapset <%s>"
+#: ../lib/init/grass.py:216
+msgid "initial database (path to GIS data)"
msgstr ""
-#: ../lib/gis/open_misc.c:67
-#, c-format
-msgid "G__open_misc(write): xmapset <%s> != G_mapset() <%s>"
+#: ../lib/init/grass.py:217
+msgid "initial location"
msgstr ""
-#: ../lib/gis/get_ellipse.c:344 ../lib/gis/get_ellipse.c:367
-#, c-format
-msgid "Invalid a: field '%s' in file %s in <%s>"
+#: ../lib/init/grass.py:218
+msgid "initial mapset"
msgstr ""
-#: ../lib/gis/get_ellipse.c:356
-#, c-format
-msgid "Invalid ellipsoid '%s' in file %s in <%s>"
+#: ../lib/init/grass.py:219
+msgid "fully qualified initial mapset directory"
msgstr ""
-#: ../lib/gis/get_ellipse.c:370
-#, c-format
-msgid "Invalid es: field '%s' in file %s in <%s>"
+#: ../lib/init/grass.py:220
+msgid "Environment variables relevant for startup"
msgstr ""
-#: ../lib/gis/get_ellipse.c:383
-#, c-format
-msgid "No ellipsoid info given in file %s in <%s>"
+#: ../lib/init/grass.py:221
+msgid "select GUI (text, gui)"
msgstr ""
-#: ../lib/gis/parser.c:376
-#, c-format
-msgid "BUG in descriptions, option '%s' in <%s> does not exist"
+#: ../lib/init/grass.py:222
+msgid "set html web browser for help pages"
msgstr ""
-#: ../lib/gis/parser.c:491
-msgid "Use either --quiet or --verbose flag, not both. Assuming --verbose."
+#: ../lib/init/grass.py:223
+msgid "set additional path(s) to local GRASS modules or user scripts"
msgstr ""
-#: ../lib/gis/parser.c:505
-msgid "Use either --quiet or --verbose flag, not both. Assuming --quiet."
+#: ../lib/init/grass.py:224
+msgid "set additional GISBASE for locally installed GRASS Addons"
msgstr ""
-#: ../lib/gis/parser.c:536
-#, c-format
-msgid "Sorry <%s> is not a valid option"
+#: ../lib/init/grass.py:225
+msgid "shell script to be processed as batch job"
msgstr ""
-#: ../lib/gis/parser.c:806
-msgid "Unable to determine program name"
+#: ../lib/init/grass.py:226
+msgid "set python shell name to override 'python'"
msgstr ""
-#: ../lib/gis/parser.c:822 ../lib/gis/parser.c:839
-#, c-format
-msgid "Sorry, <%c> is not a valid flag"
+#: ../lib/init/grass.py:264
+#, fuzzy, python-format
+msgid ""
+"Unable to create temporary directory <grass7-%(user)s-%(lock)s>! Exiting."
+#: ../lib/init/grass.py:348
+#, python-format
+msgid "GUI <%s> not supported in this version"
msgstr ""
-#: ../lib/gis/parser.c:939
-#, c-format
-msgid "Sorry, <%s=> is ambiguous"
+#: ../lib/init/grass.py:495
+msgid "Searched for a web browser, but none found"
msgstr ""
-#: ../lib/gis/parser.c:946
-#, c-format
-msgid "Sorry, <%s> is not a valid parameter"
+#: ../lib/init/grass.py:503
+#, python-format
+msgid ""
+"\n"
+"WELCOME TO GRASS %s\n"
+"\n"
+" 1) Have at your side all available GRASS GIS tutorials\n"
+"\n"
+" 2) When working on your location, the following materials\n"
+" are extremely useful:\n"
+" - A topographic map of your area\n"
+" - Current catalog of available computer maps\n"
+"\n"
+" 3) Check the GRASS GIS web pages for supporting mailing lists and more:\n"
+" http://grass.osgeo.org\n"
msgstr ""
-#: ../lib/gis/parser.c:954
-#, c-format
-msgid "Option <%s> does not accept multiple answers"
+#: ../lib/init/grass.py:519
+#, fuzzy
+msgid "Hit RETURN to continue"
+msgstr "취소를 원하시면 RETURN을 누르세요\n"
+#: ../lib/init/grass.py:548
+msgid ""
+"The python command does not work as expected!\n"
+"Please check your GRASS_PYTHON environment variable.\n"
+"Use the -help option for details.\n"
+"Switching to text based interface mode.\n"
+"\n"
+"Hit RETURN to continue.\n"
msgstr ""
-#: ../lib/gis/parser.c:1025
-#, c-format
+#: ../lib/init/grass.py:560
msgid ""
-"Illegal range syntax for parameter <%s>\n"
-"\tPresented as: %s"
+"It appears that the X Windows system is not active.\n"
+"A graphical based user interface is not supported.\n"
+"\n"
+"Hit RETURN to continue"
msgstr ""
-#: ../lib/gis/parser.c:1031
-#, c-format
+#: ../lib/init/grass.py:612
+#, python-format
+msgid "ERROR: <%s> is not a valid GRASS location"
+msgstr ""
+#: ../lib/init/grass.py:615
+#, python-format
msgid ""
-"Value <%s> out of range for parameter <%s>\n"
-"\tLegal range: %s"
+"Mapset <%s> doesn't exist in GRASS location <%s>. A new mapset can be "
+"created by '-c' switch."
msgstr ""
-#: ../lib/gis/parser.c:1037
-#, fuzzy, c-format
-msgid "Missing value for parameter <%s>"
+#: ../lib/init/grass.py:634
+#, python-format
+msgid "Failed to create new location. The location <%s> already exists."
+msgstr ""
-#: ../lib/gis/parser.c:1043
-#, c-format
+#: ../lib/init/grass.py:662
+msgid "Missing WIND file fixed"
+msgstr ""
+#: ../lib/init/grass.py:674
msgid ""
-"Value <%s> ambiguous for parameter <%s>\n"
-"\tValid options: %s"
+"GISDBASE, LOCATION_NAME and MAPSET variables not set properly.\n"
+"Interactive startup needed."
msgstr ""
-#: ../lib/gis/parser.c:1198
-#, c-format
+#: ../lib/init/grass.py:689
+#, python-format
msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
+"Invalid user interface specified - <%s>. Use the --help option to see valid "
+"interface names."
msgstr ""
-#: ../lib/gis/parser.c:1290
-#, c-format
+#: ../lib/init/grass.py:702
msgid ""
-"Option <%s> must be provided in multiples of %d\n"
-"\tYou provided %d item(s): %s"
+"Error in GUI startup. If necessary, please report this error to the GRASS "
+"developers.\n"
+"Switching to text mode now.\n"
+"\n"
+"Hit RETURN to continue..."
msgstr ""
-#: ../lib/gis/parser.c:1365
-#, c-format
-msgid "ERROR: option <%s>: <%s> exists.\n"
+#: ../lib/init/grass.py:712
+msgid ""
+"Received EXIT message from GUI.\n"
+"GRASS is not started. Bye."
msgstr ""
-#: ../lib/gis/parser.c:1449
-msgid "No separator given"
+#: ../lib/init/grass.py:715
+msgid ""
+"Invalid return code from GUI startup script.\n"
+"Please advise GRASS developers of this error."
msgstr ""
-#: ../lib/gis/get_window.c:117
-#, fuzzy, c-format
-msgid "Unable to open element file <%s> for <%s@%s>"
-msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/init/grass.py:726
+msgid ""
+"Error reading data path information from g.gisenv.\n"
+"GISDBASE=%(gisbase)s\n"
+"LOCATION_NAME=%(location)s\n"
+"MAPSET=%(mapset)s\n"
+"\n"
+"Check the <%s(file)> file."
+msgstr ""
-#: ../lib/gis/key_value3.c:33
-#, fuzzy, c-format
-msgid "Unable to open output file <%s>: %s"
+#: ../lib/init/grass.py:869
+#, python-format
+msgid "Path '%s' doesn't exist"
+msgstr ""
-#: ../lib/gis/key_value3.c:36
-#, fuzzy, c-format
-msgid "Error writing file <%s>: %s"
+#: ../lib/init/grass.py:877
+#, python-format
+msgid ""
+"%(user)s is currently running GRASS in selected mapset (file %(file)s "
+"found). Concurrent use not allowed."
+msgstr ""
-#: ../lib/gis/key_value3.c:39
-#, fuzzy, c-format
-msgid "Error closing output file <%s>: %s"
+#: ../lib/init/grass.py:881
+#, python-format
+msgid ""
+"Unable to properly access '%s'.\n"
+"Please notify system personel."
+msgstr ""
-#: ../lib/gis/key_value3.c:60
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>: %s"
+#: ../lib/init/grass.py:896
+msgid "Building user fontcap..."
+msgstr ""
-#: ../lib/gis/key_value3.c:64
-#, fuzzy, c-format
-msgid "Error reading file <%s>: %s"
+#: ../lib/init/grass.py:941
+#, python-format
+msgid "Unsupported shell <%(sh)s>: %(env)s"
+msgstr ""
-#: ../lib/gis/key_value3.c:67
-#, fuzzy, c-format
-msgid "Error closing input file <%s>: %s"
+#: ../lib/init/grass.py:946
+msgid "The SHELL variable is not set"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:139 ../lib/gis/rd_cellhd.c:150
-#: ../lib/gis/rd_cellhd.c:160 ../lib/gis/rd_cellhd.c:177
-#: ../lib/gis/rd_cellhd.c:193 ../lib/gis/rd_cellhd.c:201
-#: ../lib/gis/rd_cellhd.c:209 ../lib/gis/rd_cellhd.c:217
-#: ../lib/gis/rd_cellhd.c:225 ../lib/gis/rd_cellhd.c:233
-#: ../lib/gis/rd_cellhd.c:241 ../lib/gis/rd_cellhd.c:243
-#: ../lib/gis/rd_cellhd.c:251 ../lib/gis/rd_cellhd.c:253
-#: ../lib/gis/rd_cellhd.c:261 ../lib/gis/rd_cellhd.c:263
-#: ../lib/gis/rd_cellhd.c:271 ../lib/gis/rd_cellhd.c:273
-#: ../lib/gis/rd_cellhd.c:281 ../lib/gis/rd_cellhd.c:283
-#: ../lib/gis/rd_cellhd.c:291 ../lib/gis/rd_cellhd.c:293
-#: ../lib/gis/rd_cellhd.c:301 ../lib/gis/rd_cellhd.c:303
-#: ../lib/gis/rd_cellhd.c:311 ../lib/gis/rd_cellhd.c:313
-#: ../lib/gis/rd_cellhd.c:321 ../lib/gis/rd_cellhd.c:323
-#: ../lib/gis/rd_cellhd.c:331 ../lib/gis/rd_cellhd.c:333
-#: ../lib/gis/rd_cellhd.c:341 ../lib/gis/rd_cellhd.c:349
-#: ../lib/gis/rd_cellhd.c:353
-msgid "Syntax error in cell header"
+#: ../lib/init/grass.py:957
+#, python-format
+msgid ""
+"Job file '%s' has been defined in the 'GRASS_BATCH_JOB' variable but not "
+"found. Exiting.\n"
+"\n"
+"Use 'unset GRASS_BATCH_JOB' to disable batch job processing."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:147
-msgid "Duplicate projection field"
+#: ../lib/init/grass.py:962
+#, python-format
+msgid "Change file permission to 'executable' for '%s'"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:157
-msgid "Duplicate zone field"
+#: ../lib/init/grass.py:964
+#, python-format
+msgid "Executing '%s' ..."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:167 ../lib/gis/rd_cellhd.c:169
-#: ../lib/gis/rd_cellhd.c:358 ../lib/gis/rd_cellhd.c:360
-#: ../lib/gis/rd_cellhd.c:362 ../lib/gis/rd_cellhd.c:364
-#: ../lib/gis/rd_cellhd.c:366 ../lib/gis/rd_cellhd.c:368
-#: ../lib/gis/rd_cellhd.c:379 ../lib/gis/rd_cellhd.c:381
-#: ../lib/gis/rd_cellhd.c:383 ../lib/gis/rd_cellhd.c:385
-#, c-format
-msgid "Field <%s> missing"
+#: ../lib/init/grass.py:969
+#, python-format
+msgid "Execution of '%s' finished."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:191
-msgid "Duplicate north field"
+#: ../lib/init/grass.py:975
+#, python-format
+msgid "GRASS GUI should be <%s>"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:199
-msgid "Duplicate south field"
+#: ../lib/init/grass.py:1004
+#, python-format
+msgid "Welcome to GRASS %s"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:207
-msgid "Duplicate east field"
+#: ../lib/init/grass.py:1023
+msgid "GRASS homepage:"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:215
-msgid "Duplicate west field"
+#: ../lib/init/grass.py:1024
+msgid "This version running through:"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:223
-msgid "Duplicate top field"
+#: ../lib/init/grass.py:1026
+msgid "Help is available with the command:"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:231
-msgid "Duplicate bottom field"
+#: ../lib/init/grass.py:1027
+msgid "See the licence terms with:"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:239
-#, fuzzy
-msgid "Duplicate e-w resolution field"
-msgstr "잘못된 e-w 해상도"
+#: ../lib/init/grass.py:1030
+msgid "If required, restart the GUI with:"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:249
-#, fuzzy
-msgid "Duplicate 3D e-w resolution field"
+#: ../lib/init/grass.py:1032
+msgid "Start the GUI with:"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:259
-#, fuzzy
-msgid "Duplicate n-s resolution field"
-msgstr "잘못된 n-s 해상도"
+#: ../lib/init/grass.py:1034
+msgid "When ready to quit enter:"
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:269
-#, fuzzy
-msgid "Duplicate 3D n-s resolution field"
+#: ../lib/init/grass.py:1147
+msgid "Failed to start shell '%s'"
-#: ../lib/gis/rd_cellhd.c:279
-#, fuzzy
-msgid "Duplicate t-b resolution field"
-msgstr "잘못된 t-b3 해상도"
+#: ../lib/init/grass.py:1152
+#, python-format
+msgid "Batch job '%s' (defined in GRASS_BATCH_JOB variable) was executed."
+msgstr ""
-#: ../lib/gis/rd_cellhd.c:289
-msgid "Duplicate rows field"
+#: ../lib/init/grass.py:1153 ../lib/init/grass.py:1158
+msgid "Goodbye from GRASS GIS"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:299
-msgid "Duplicate 3D rows field"
+#: ../lib/init/grass.py:1156
+msgid "Done."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:309
-msgid "Duplicate cols field"
+#: ../lib/init/grass.py:1163
+msgid "Cleaning up temporary files..."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:319
-msgid "Duplicate 3D cols field"
+#: ../lib/init/grass.py:1207
+#, python-format
+msgid "Parameter <%s> not supported"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:329
-msgid "Duplicate depths field"
+#: ../lib/init/grass.py:1368
+#, python-format
+msgid ""
+"Unable to start GRASS. You can:\n"
+" - Launch GRASS with '-gui' switch (`grass71 -gui`)\n"
+" - Create manually GISRC file (%s)\n"
+" - Launch GRASS with path to the location/mapset as an argument (`grass71 /"
+"path/to/location/mapset`)"
msgstr ""
-#: ../lib/gis/rd_cellhd.c:339
-msgid "Duplicate format field"
+#: ../lib/init/grass.py:1377
+msgid "Starting GRASS GIS..."
msgstr ""
-#: ../lib/gis/rd_cellhd.c:347
-msgid "Duplicate compressed field"
+#: ../lib/init/grass.py:1431
+#, python-format
+msgid "Launching <%s> GUI in the background, please wait..."
msgstr ""
-#: ../lib/gis/paths.c:201
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for reading"
+#: ../lib/init/lock.c:38
+#, c-format
+msgid "Usage: %s file pid"
+msgstr ""
-#: ../lib/gis/paths.c:217
-#, fuzzy, c-format
-msgid "Unable to fetch security info for <%s>"
+#: ../lib/init/lock.c:42
+msgid "Concurrent mapset locking is not supported on Windows"
+msgstr ""
-#: ../lib/gis/timestamp.c:292
+#: ../lib/init/lock.c:60
#, fuzzy, c-format
-msgid "Unable to create timestamp file for %s map <%s@%s>"
+msgid "Unable to write lockfile %s (%s)"
-#: ../lib/gis/timestamp.c:301
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for %s map <%s@%s>"
+#: ../lib/init/prompt.py:20
+msgid "[Raster and Volume MASKs present]"
+msgstr ""
-#: ../lib/gis/timestamp.c:331
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for %s map <%s@%s>"
-#: ../lib/gis/timestamp.c:340
-#, fuzzy, c-format
-msgid "Invalid timestamp file for %s map <%s@%s>"
-#: ../lib/gis/timestamp.c:479
-#, fuzzy, c-format
-msgid "Unable to open timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:488
-#, fuzzy, c-format
-msgid "Invalid timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:524
-#, fuzzy, c-format
-msgid "Unable to create timestamp file for vector map <%s@%s>"
-#: ../lib/gis/timestamp.c:533
-#, fuzzy, c-format
-msgid "Invalid timestamp specified for vector map <%s@%s>"
-#: ../lib/gis/get_projinfo.c:34 ../lib/gis/get_projinfo.c:60
-#, c-format
-msgid "<%s> file not found for location <%s>"
+#: ../lib/init/prompt.py:22
+msgid "[Raster MASK present]"
msgstr ""
-#: ../lib/gis/myname.c:46
-msgid "This location has no description."
+#: ../lib/init/prompt.py:24
+msgid "[Volume MASK present]"
msgstr ""
-#: ../lib/gis/parser_help.c:79
-msgid "Description:"
+#: ../lib/proj/convert.c:82 ../lib/vector/Vlib/write_ogr.c:69
+#: ../lib/vector/Vlib/write_ogr.c:105 ../lib/vector/Vlib/write_ogr.c:145
+#: ../lib/vector/Vlib/close.c:284 ../lib/vector/Vlib/field.c:660
+#: ../lib/vector/Vlib/build_sfa.c:711 ../lib/vector/Vlib/build_ogr.c:94
+#: ../lib/vector/Vlib/build_ogr.c:169 ../lib/vector/Vlib/rewind_ogr.c:47
+#: ../lib/vector/Vlib/rewind_ogr.c:71 ../lib/vector/Vlib/write_sfa.c:291
+#: ../lib/vector/Vlib/header_finfo.c:41 ../lib/vector/Vlib/header_finfo.c:80
+#: ../lib/vector/Vlib/header_finfo.c:113 ../lib/vector/Vlib/header_finfo.c:153
+#: ../lib/vector/Vlib/header_finfo.c:254 ../lib/vector/Vlib/read_ogr.c:56
+#: ../lib/vector/Vlib/read_ogr.c:157 ../lib/vector/Vlib/read_ogr.c:242
+#: ../lib/vector/Vlib/open_ogr.c:121 ../lib/vector/Vlib/open_ogr.c:154
+#: ../lib/vector/Vlib/open_ogr.c:231 ../lib/vector/Vlib/simple_features.c:310
+#: ../lib/vector/Vlib/close_ogr.c:77 ../lib/vector/Vlib/close_ogr.c:111
+msgid "GRASS is not compiled with OGR support"
msgstr ""
-#: ../lib/gis/parser_help.c:89
-msgid "Keywords:"
+#: ../lib/proj/convert.c:120
+msgid "Unable parse GRASS PROJ_INFO file"
msgstr ""
-#: ../lib/gis/parser_help.c:97
-msgid "Usage:"
+#: ../lib/proj/convert.c:125
+msgid "Unable get PROJ.4-style parameter string"
msgstr ""
-#: ../lib/gis/parser_help.c:127
-msgid "ERROR: Option key not defined"
+#: ../lib/proj/convert.c:139
+#, c-format
+msgid ""
+"OGR can't parse PROJ.4-style parameter string: %s (OGR Error code was %d)"
msgstr ""
-#: ../lib/gis/parser_help.c:174
-msgid "Flags:"
+#: ../lib/proj/convert.c:146
+#, c-format
+msgid "OGR can't get WKT-style parameter string (OGR Error code was %d)"
msgstr ""
-#: ../lib/gis/parser_help.c:209
-msgid "Parameters:"
+#: ../lib/proj/convert.c:406
+msgid "No projection name! Projection parameters likely to be meaningless."
msgstr ""
-#: ../lib/gis/parser_help.c:232
+#: ../lib/proj/convert.c:442
#, c-format
-msgid " %*s default: %s\n"
+msgid "Datum <%s> not recognised by GRASS and no parameters found"
msgstr ""
-#: ../lib/gis/parser_help.c:258
+#: ../lib/proj/convert.c:458
#, c-format
-msgid " %*s options: "
+msgid ""
+"Datum <%s> apparently recognised by GRASS but no parameters found. You may "
+"want to look into this."
msgstr ""
-#: ../lib/gis/open.c:62
+#: ../lib/proj/convert.c:462
#, c-format
-msgid "G__open(read): mapset <%s> doesn't match xmapset <%s>"
+msgid ""
+"Invalid transformation number %d; valid range is 1 to %d. Leaving datum "
+"transform parameters unspecified."
msgstr ""
-#: ../lib/gis/open.c:84
+#: ../lib/proj/datum.c:270 ../lib/proj/datum.c:350
+#, fuzzy, c-format
+msgid "Unable to open datum table file <%s>"
+#: ../lib/proj/datum.c:283 ../lib/proj/datum.c:364
+#, fuzzy, c-format
+msgid "Error in datum table file <%s>, line %d"
+msgstr "Datum 테이블파일의 %d번째 줄에 오류가 있습니다"
+#: ../lib/proj/do_proj.c:106 ../lib/proj/do_proj.c:180
#, c-format
-msgid "G__open(write): xmapset <%s> != G_mapset() <%s>"
+msgid "pj_transform() failed: %s"
msgstr ""
-#: ../lib/gis/distance.c:154
+#: ../lib/proj/ellipse.c:76
#, c-format
-msgid "%s: shouldn't happen: code=%d P=(%f,%f) S=(%f,%f)(%f,%f)"
+msgid "Invalid ellipsoid <%s> in file"
msgstr ""
-#: ../lib/arraystats/class.c:21
-msgid "Discont algorithm currently not available because of bugs"
+#: ../lib/proj/ellipse.c:103
+msgid "No secondary ellipsoid descriptor (rf, es or b) in file"
msgstr ""
-#: ../lib/arraystats/class.c:23
-#, c-format
-msgid "%s: Unknown algorithm"
+#: ../lib/proj/ellipse.c:107
+msgid "Invalid ellipsoid descriptors (a, rf, es or b) in file"
msgstr ""
-#: ../lib/arraystats/class.c:26
-#, c-format
-msgid "%s: Error in classification algorithm"
+#: ../lib/proj/ellipse.c:120
+msgid "No ellipsoid info given in file"
msgstr ""
-#: ../lib/arraystats/class.c:220
+#: ../lib/proj/get_proj.c:148
#, c-format
-msgid ""
-"There are classbreaks outside the range min-max. Number of classes reduced "
-"to %i, but using probabilities for %i classes."
+msgid "Invalid zone %s specified"
msgstr ""
-#: ../lib/lidar/zones.c:473 ../lib/lidar/zones.c:510
-#, fuzzy, c-format
-msgid "<%s> created in database."
+#: ../lib/proj/get_proj.c:228
+msgid "Unable to initialise PROJ.4 with the following parameter list:"
+msgstr ""
-#: ../lib/lidar/zones.c:477 ../lib/lidar/zones.c:514
+#: ../lib/proj/get_proj.c:236
#, c-format
-msgid "<%s> has not been created in database."
+msgid "The error message: %s"
msgstr ""
-#: ../lib/lidar/raster.c:74 ../lib/lidar/raster.c:89 ../lib/lidar/raster.c:102
-#: ../lib/lidar/raster.c:119 ../lib/lidar/raster.c:134
-#: ../lib/lidar/raster.c:147 ../lib/lidar/raster.c:162
-#: ../lib/lidar/raster.c:175
+#: ../lib/proj/get_proj.c:294
+msgid "Option input overflowed option table"
+msgstr ""
+#: ../lib/proj/get_proj.c:325
#, fuzzy, c-format
-msgid "Unable to access table <%s>"
+msgid "Unable to initialize pj cause: %s"
-#: ../lib/python/temporal/c_libraries_interface.py:280
-#: ../lib/python/temporal/c_libraries_interface.py:297
-#, fuzzy
-msgid "Unable to read range file"
+#: ../lib/proj/get_proj.c:401
+msgid "Input Projection Parameters"
+msgstr ""
-#: ../lib/python/temporal/c_libraries_interface.py:373
-#, fuzzy, python-format
-msgid "Unable to load range of 3D raster map <%s>"
+#: ../lib/proj/get_proj.c:404
+msgid "Input Unit Factor"
+msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:223
-msgid "Unable to read timestamp file for raster map <%s>"
+#: ../lib/proj/get_proj.c:414
+msgid "Output Projection Parameters"
+msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:247
-msgid "Unable to create timestamp file for raster map <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:252
-msgid "Invalid datetime in timestamp for raster map <%s>"
-#: ../lib/python/temporal/space_time_datasets.py:257
-#: ../lib/python/temporal/space_time_datasets.py:572
-msgid "Internal error"
+#: ../lib/proj/get_proj.c:417
+msgid "Output Unit Factor"
msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:274
-#: ../lib/python/temporal/space_time_datasets.py:586
-msgid "Unable to remove timestamp for raster map <%s>"
+#: ../lib/manage/do_rename.c:42
+#, fuzzy, c-format
+msgid "Rename %s <%s> to <%s>"
+msgstr "<%s>를 <%s>으로 이름을 바꿉니다"
-#: ../lib/python/temporal/space_time_datasets.py:538
-msgid "Unable to read timestamp file for 3D raster map <%s>"
+#: ../lib/manage/do_rename.c:62
+#, fuzzy, c-format
+msgid "Unable to rename vector map <%s> to <%s>"
+msgstr "벡터맵 <%s>의 이름을 <%s>으로 바꾸지 못 했습니다"
-#: ../lib/python/temporal/space_time_datasets.py:562
-msgid "Unable to create timestamp file for 3D raster map <%s>"
+#: ../lib/manage/do_rename.c:83 ../lib/manage/do_rename.c:103
+#, fuzzy, c-format
+msgid "Unable to rename %s"
+msgstr "%s의 이름을 바꾸지 못 했습니다"
-#: ../lib/python/temporal/space_time_datasets.py:567
-msgid "Invalid datetime in timestamp for 3D raster map <%s>"
+#: ../lib/manage/do_rename.c:87 ../lib/manage/do_rename.c:107
+#: ../lib/manage/do_copy.c:63 ../lib/manage/do_remove.c:89
+#: ../lib/manage/do_remove.c:109
+#, c-format
+msgid "%s is missing"
+msgstr "%s이 없습니다"
-#: ../lib/python/temporal/space_time_datasets.py:812
-msgid "Unable to read timestamp file for vector map <%s>"
+#: ../lib/manage/do_rename.c:90 ../lib/manage/do_rename.c:110
+#, c-format
+msgid "%s renamed"
+msgstr "%s의 이름을 바꾸었습니다"
-#: ../lib/python/temporal/space_time_datasets.py:835
-msgid "Unable to create timestamp file for vector map <%s>"
+#: ../lib/manage/do_rename.c:119
+#, c-format
+msgid "<%s> nothing renamed"
+msgstr "<%s> 어떤 이름도 바꾸지 않았습니다"
-#: ../lib/python/temporal/space_time_datasets.py:840
-msgid "Invalid datetime in timestamp for vector map <%s>"
+#: ../lib/manage/option.c:47
+#, c-format
+msgid "%s to be %s"
+msgstr ""
-#: ../lib/python/temporal/space_time_datasets.py:856
-msgid "Unable to remove timestamp for vector map <%s>"
+#: ../lib/manage/option.c:51
+msgid "Raster"
+msgstr "라스터"
-#: ../lib/python/temporal/sampling.py:92 ../lib/python/temporal/sampling.py:96
-msgid "Dataset <%s> not found in temporal database"
+#: ../lib/manage/option.c:55
+msgid "Vector"
+msgstr "벡터"
-#: ../lib/python/temporal/core.py:514
-msgid ""
-"Unable to initialize the temporal DBMI interface. Use t.connect to specify "
-"the driver and the database string"
-msgstr ""
+#: ../lib/manage/option.c:57
+msgid "Region"
+msgstr "지역"
-#: ../lib/python/temporal/core.py:582
-msgid ""
-"Unable to receiving temporal database metadata.\n"
-"Current temporal database info:%(info)s"
+#: ../lib/manage/option.c:59
+msgid "Group"
+msgstr "그룹"
-#: ../lib/python/temporal/core.py:586
-#, python-format
-msgid ""
-"Unsupported temporal database. Version mismatch.\n"
-" %(backup)sSupported temporal API version is: %(api)i.\n"
-"Please update your GRASS installation to the latest svn version.\n"
-msgstr ""
+#: ../lib/manage/do_copy.c:43
+#, fuzzy, c-format
+msgid "Copy %s <%s> to current mapset as <%s>"
+msgstr "<%s>를 현재 맵셋의 <%s>으로 복사합니다"
-#: ../lib/python/temporal/core.py:592
-#, python-format
-msgid ""
-" %(backup)sSupported temporal database version is: %(tdb)i\n"
-msgstr ""
+#: ../lib/manage/do_copy.c:52
+#, fuzzy, c-format
+msgid "Unable to copy <%s> to current mapset as <%s>"
+msgstr "<%s>를 현재 맵셋의 <%s>으로 복사 할 수 없습니다"
-#: ../lib/python/temporal/core.py:676
-msgid "Create temporal database: %s"
+#: ../lib/manage/do_copy.c:72
+#, c-format
+msgid "%s copied"
+msgstr "%s를 복사했습니다"
-#: ../lib/python/temporal/core.py:962
-msgid ""
-"Unable to execute transaction:\n"
-" %(sql)s"
+#: ../lib/manage/read_list.c:73
+#, fuzzy, c-format
+msgid "Unable to open data base element list '%s'"
+msgstr "데이타의 기본요소목록 '%s'를 열 수 없습니다"
-#: ../lib/python/temporal/temporal_raster_algebra.py:85
-#, fuzzy
-msgid "Removing empty raster maps"
+#: ../lib/manage/read_list.c:134
+#, c-format
+msgid "Format error: file ('%s') line (%d) - %s"
+msgstr ""
-#: ../lib/python/temporal/base.py:378
-msgid "Object <%s> not found in the temporal database"
+#: ../lib/manage/do_remove.c:42
+#, fuzzy, c-format
+msgid "Removing %s <%s>"
+msgstr "%s <%s>를 지우는 중입니다"
-#: ../lib/python/temporal/base.py:459 ../lib/python/temporal/base.py:509
-msgid "Missing identifer"
-msgstr ""
-#: ../lib/python/temporal/base.py:615
+#: ../lib/manage/do_remove.c:65
#, fuzzy
-msgid "Wrong identifier, the mapset is missing"
+msgid "Unable to delete vector map"
+msgstr "벡터맵을 지울 수 없습니다"
-#: ../lib/python/temporal/abstract_map_dataset.py:339
-msgid ""
-"Start time must be of type datetime for %(type)s map <%(id)s> with layer: "
-"%(l)s"
+#: ../lib/manage/do_remove.c:85
+#, fuzzy, c-format
+msgid "Unable to remove %s element"
+msgstr "%s 요소를 지울 수 없습니다"
-#: ../lib/python/temporal/abstract_map_dataset.py:345
-msgid "Start time must be of type datetime for %(type)s map <%(id)s>"
+#: ../lib/manage/do_remove.c:92 ../lib/manage/do_remove.c:112
+#, c-format
+msgid "%s removed"
+msgstr "%s를 지웠습니다"
-#: ../lib/python/temporal/abstract_map_dataset.py:352
-msgid ""
-"End time must be of type datetime for %(type)s map <%(id)s> with layer: %(l)s"
+#: ../lib/manage/do_remove.c:105
+#, fuzzy, c-format
+msgid "Unable to remove %s"
+msgstr "%s를 지울 수 없습니다"
-#: ../lib/python/temporal/abstract_map_dataset.py:358
-msgid "End time must be of type datetime for %(type)s map <%(id)s>"
+#: ../lib/manage/do_remove.c:121
+#, fuzzy, c-format
+msgid "<%s> nothing removed"
-#: ../lib/python/temporal/abstract_map_dataset.py:366
-msgid ""
-"End time must be greater than start time for %(type)s map <%(id)s> with "
-"layer: %(l)s"
-msgstr "동쪽경계는 서쪽경계보다 값이 커야합니다"
+#: ../lib/manage/do_list.c:30
+#, c-format
+msgid "%s: invalid index %d"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:373
-#: ../lib/python/temporal/abstract_map_dataset.py:462
-msgid "End time must be greater than start time for %(type)s map <%(id)s>"
+#: ../lib/gpde/N_gwflow.c:436 ../lib/gpde/N_gwflow.c:715
+#, c-format
+msgid "The total sum of the water budget: %g\n"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:408
-#: ../lib/python/temporal/abstract_map_dataset.py:499
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2226
-#: ../lib/python/temporal/abstract_dataset.py:428
-#: ../lib/python/temporal/abstract_dataset.py:469
-#, python-format
-msgid ""
-"Unable to update dataset <%(ds)s> of type %(type)s in the temporal database. "
-"The mapset of the dataset does not match the current mapset"
+#: ../lib/gpde/N_gwflow.c:438 ../lib/gpde/N_gwflow.c:717
+#, c-format
+msgid "The total sum of the water budget is significant larger then 0: %g\n"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:443
-msgid ""
-"Unsupported relative time unit type for %(type)s map <%(id)s> with layer "
-"%(l)s: %(u)s"
+#: ../lib/gpde/N_arrays_io.c:93
+#, c-format
+msgid "Reading raster map <%s> into memory"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:448
-msgid "Unsupported relative time unit type for %(type)s map <%(id)s>: %(u)s"
+#: ../lib/gpde/N_arrays_io.c:183
+msgid "N_array_2d * array is empty"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:457
-msgid ""
-"layer %(l)s"
+#: ../lib/gpde/N_arrays_io.c:202
+#, c-format
+msgid "Write 2d array to raster map <%s>"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:766
-#, python-format
-msgid ""
-"Map <%(id)s> with layer %(layer)s has incorrect time interval, start time is "
-"greater than end time"
+#: ../lib/gpde/N_arrays_io.c:309
+#, c-format
+msgid "Read g3d map <%s> into the memory"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:772
-#, python-format
-msgid ""
-"Map <%s> has incorrect time interval, start time is greater than end time"
+#: ../lib/gpde/N_arrays_io.c:364 ../lib/gpde/N_arrays_io.c:464
+msgid "Error closing g3d file"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:777
-#, python-format
-msgid "Map <%s> has incorrect start time"
+#: ../lib/gpde/N_arrays_io.c:420
+#, c-format
+msgid "Error opening g3d map <%s>"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:805
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1918
-#, python-format
-msgid ""
-"Unable to delete dataset <%(ds)s> of type %(type)s from the temporal "
-"database. The mapset of the dataset does not match the current mapset"
+#: ../lib/gpde/N_arrays_io.c:422
+#, c-format
+msgid "Write 3d array to g3d map <%s>"
msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:821
-msgid "Delete %s dataset <%s> from temporal database"
+#: ../lib/gpde/test/test_main.c:88
+msgid "Performs unit and integration tests for gpde library"
+msgstr ""
-#: ../lib/python/temporal/abstract_map_dataset.py:870
-#, python-format
-msgid ""
-"Unable to unregister dataset <%(ds)s> of type %(type)s from the temporal "
+#: ../lib/gpde/N_parse_options.c:106
+msgid "The calculation time in seconds"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:153
-#: ../lib/python/temporal/abstract_space_time_dataset.py:287
-msgid "Unknown temporal type \"%s\""
-msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/raster/quant_rw.c:88
+#, fuzzy, c-format
+msgid "Unable to read fp range for raster map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:280
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1055
-#, python-format
-msgid "Wrong granularity: \"%s\""
-msgstr ""
+#: ../lib/raster/quant_rw.c:92
+#, fuzzy, c-format
+msgid "Raster map <%s> is empty"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:308
-msgid "Unsupported temporal unit: %s"
+#: ../lib/raster/quant_rw.c:157
+#, fuzzy, c-format
+msgid "Unable to write quant rules: raster map <%s> is integer"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:360
-msgid "Created register table <%s> for space time %s dataset <%s>"
+#: ../lib/raster/quant_rw.c:166
+#, fuzzy, c-format
+msgid "Unable to write quant rules for raster map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:679
-#: ../lib/python/temporal/abstract_space_time_dataset.py:925
-msgid "The space time datasets must be of the same temporal type"
-msgstr ""
+#: ../lib/raster/close.c:74 ../lib/raster/close.c:107
+#, fuzzy, c-format
+msgid "Invalid descriptor: %d"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:684
-#: ../lib/python/temporal/abstract_space_time_dataset.py:930
-msgid "The temporal map type of the sample dataset must be interval"
-msgstr ""
+#: ../lib/raster/close.c:373
+#, fuzzy, c-format
+msgid "Unable to rename null file '%s' to '%s'"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1465
-msgid "Unable to get map ids from register table <%s>"
+#: ../lib/raster/close.c:439
+#, fuzzy, c-format
+msgid "Unable to rename cell file '%s' to '%s'"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1547
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1580
-#: ../lib/python/temporal/datetime_math.py:447
-#, python-format
-msgid "Wrong granularity format: %s"
+#: ../lib/raster/close.c:475
+msgid "unable to write f_format file for CELL maps"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1575
-#, python-format
-msgid ""
-"Unable to shift dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/raster/mask_info.c:43
+#, c-format
+msgid "<%s> in mapset <%s>"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1742
-#, python-format
-msgid ""
-"Unable to snap dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/raster/mask_info.c:46
+msgid "none"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1842
-#, python-format
-msgid ""
-"Unable to rename dataset <%(ds)s> of type %(type)s in the temporal database. "
+#: ../lib/raster/mask_info.c:49
+msgid "not known"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1849
-msgid "Renaming of space time datasets is not supported for PostgreSQL."
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1912
-msgid "Delete space time %s dataset <%s> from temporal database"
+#: ../lib/raster/quant_io.c:43
+#, fuzzy, c-format
+msgid "Floating data range for raster map <%s> is empty"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1929
-msgid "Drop map register table: %s"
+#: ../lib/raster/quant_io.c:52
+#, fuzzy, c-format
+msgid "Integer data range for raster map <%s> is empty"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:1984
-#, fuzzy
-msgid "Error in register table request"
+#: ../lib/raster/quant_io.c:105
+#, fuzzy, c-format
+msgid "Attempt to open quantization table for CELL raster map <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2012
-msgid ""
-"Unable to register map in dataset <%(ds)s> of type %(type)s. The mapset of "
-"the dataset does not match the current mapset"
+#: ../lib/raster/quant_io.c:135
+#, fuzzy, c-format
+msgid "Quantization file for raster map <%s> is missing"
+msgstr "임시파일을 열 수 없습니다"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2020
-msgid ""
-"Only a map that was inserted in the temporal database can be registered in a "
-"space time dataset"
+#: ../lib/raster/quant_io.c:145
+#, fuzzy, c-format
+msgid "Quantization file for raster map <%s> is empty"
+#: ../lib/raster/histogram.c:55
+#, c-format
+msgid "Histogram for [%s in %s] missing (run r.support)"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2040
-#, python-format
-msgid "Map <%(id)s> with layer %(l)s has invalid time"
+#: ../lib/raster/histogram.c:62
+#, c-format
+msgid "Can't read histogram for [%s in %s]"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2043
-#, python-format
-msgid "Map <%s> has invalid time"
+#: ../lib/raster/histogram.c:66 ../lib/raster/histogram.c:73
+#, c-format
+msgid "Invalid histogram file for [%s in %s]"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2061
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> with layer "
-"%(l)s are different"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2066
-msgid ""
-"Temporal type of space time dataset <%(id)s> and map <%(map)s> are different"
+#: ../lib/raster/histogram.c:331
+#, fuzzy, c-format
+msgid "Unable to create histogram file for <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2080
-msgid "Set temporal unit for space time %s dataset <%s> to %s"
+#: ../lib/raster/reclass.c:168
+#, fuzzy, c-format
+msgid "Too many reclass categories for <%s@%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2089
-#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> with "
-"layer %(l)s are different"
-msgstr ""
+#: ../lib/raster/reclass.c:171
+#, fuzzy, c-format
+msgid "Illegal reclass format in header file for <%s@%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2095
-#, python-format
-msgid ""
-"Relative time units of space time dataset <%(id)s> and map <%(map)s> are "
-"different"
+#: ../lib/raster/reclass.c:273
+msgid "Illegal reclass request"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2101
-msgid "Only maps from the same mapset can be registered"
+#: ../lib/raster/reclass.c:278
+msgid "Illegal reclass type"
msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2106
-msgid "Map <%(map)s> with layer %(l)s is already registered."
+#: ../lib/raster/reclass.c:284
+#, fuzzy, c-format
+msgid "Unable to create header file for <%s@%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2110
-#, python-format
-msgid "Map <%s> is already registered."
-msgstr ""
+#: ../lib/raster/reclass.c:332
+#, fuzzy, c-format
+msgid "Unable to create dependency file in <%s@%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2158
-#, python-format
-msgid ""
-"Unable to unregister map from dataset <%(ds)s> of type %(type)s in the "
-"temporal database. The mapset of the dataset does not match the current "
-"mapset"
-msgstr ""
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2169
-msgid ""
-"Map <%(map)s> with layer %(l)s is not registered in space time dataset <"
-"%(base)s>"
+#: ../lib/raster/put_cellhd.c:34
+#, fuzzy, c-format
+msgid "Unable to create header file for <%s>"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2174
-msgid "Map <%(map)s> is not registered in space time dataset <%(base)s>"
+#: ../lib/raster/interp.c:211
+#, fuzzy, c-format
+msgid "Unknown interpolation method: %s"
+msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/python/temporal/abstract_space_time_dataset.py:2230
-#, python-format
+#: ../lib/raster/get_cellhd.c:66
+#, fuzzy, c-format
msgid ""
-"Update metadata, spatial and temporal extent from all registered maps of <%s>"
-msgstr ""
+"Unable to read header file for raster map <%s@%s>.It is a reclass of raster "
+"map <%s@%s> %s"
-#: ../lib/python/temporal/register.py:77
-#, python-format
-msgid "%(m)s= and %(f)s= are mutually exclusive"
+#: ../lib/raster/get_cellhd.c:70
+msgid "which is missing."
msgstr ""
-#: ../lib/python/temporal/register.py:81
-#, python-format
-msgid "%(e)s= and %(i)s= are mutually exclusive"
+#: ../lib/raster/get_cellhd.c:71
+msgid "whose header file can't be opened."
msgstr ""
-#: ../lib/python/temporal/register.py:85
-#, python-format
-msgid "Please specify %(st)s= and %(e)s="
-msgstr ""
+#: ../lib/raster/get_cellhd.c:76
+#, fuzzy, c-format
+msgid "Unable to open header file for raster map <%s@%s>"
-#: ../lib/python/temporal/register.py:89
-#, python-format
-msgid "Please specify %(m)s= or %(f)s="
+#: ../lib/raster/set_window.c:48
+msgid "Rast_set_window() called while window split"
msgstr ""
-#: ../lib/python/temporal/register.py:101
-#, python-format
+#: ../lib/raster/set_window.c:131
msgid ""
-"Space time %(sp)s dataset <%(name)s> with relative time found, but no "
-"relative unit set for %(sp)s maps"
+"Rast_set_read_window(): projection/zone differs from that of currently open "
+"raster maps"
msgstr ""
-#: ../lib/python/temporal/register.py:167
-msgid "Gathering map informations"
+#: ../lib/raster/set_window.c:158
+#, c-format
+msgid "Input window changed while maps are open for read. Map name <%s>"
msgstr ""
-#: ../lib/python/temporal/register.py:177
-msgid "Unable to update %(t)s map <%(id)s>. The map does not exists."
+#: ../lib/raster/set_window.c:174
+#, c-format
+msgid "Output window changed while maps are open for write. Map name <%s>"
+msgstr ""
-#: ../lib/python/temporal/register.py:196
-msgid ""
-"Unable to register %(t)s map <%(id)s> with layer %(l)s. The map has "
-"timestamp and the start time is not set."
+#: ../lib/raster/cats.c:109
+#, fuzzy, c-format
+msgid "Category support for <%s@%s> missing"
+msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
-#: ../lib/python/temporal/register.py:202
-msgid ""
-"Unable to register %(t)s map <%(id)s>. The map has no timestamp and the "
-"start time is not set."
+#: ../lib/raster/cats.c:112
+#, fuzzy, c-format
+msgid "Category support for <%s@%s> invalid"
-#: ../lib/python/temporal/register.py:210
-#, python-format
-msgid "%(u)s= can only be set for relative time"
-msgstr ""
+#: ../lib/raster/cats.c:145
+#, fuzzy, c-format
+msgid "Category support for vector map <%s@%s> missing"
+msgstr "벡터맵 [%s], 맵셑 [%s]을(를) 위한 분류지원: %s"
-#: ../lib/python/temporal/register.py:212
-#, python-format
-msgid "%(u)s= must be set in case of relative time stamps"
-msgstr ""
+#: ../lib/raster/cats.c:149
+#, fuzzy, c-format
+msgid "Category support for vector map <%s@%s> invalid"
-#: ../lib/python/temporal/register.py:224
-msgid ""
-"Map is already registered in temporal database. Unable to update %(t)s map <"
-"%(id)s> with layer %(l)s. Overwrite flag is not set."
+#: ../lib/raster/cats.c:968
+#, fuzzy, c-format
+msgid "Unable to open %s file for map <%s>"
-#: ../lib/python/temporal/register.py:231
-msgid ""
-"%(id)s>. Overwrite flag is not set."
+#: ../lib/raster/gdal.c:88
+#, fuzzy, c-format
+msgid "Unable to locate symbol <%s>"
-#: ../lib/python/temporal/register.py:255
-msgid ""
-"Unable to update %(t)s map <%(id)s> with layer %(l)s. The temporal types are "
-"different."
-#: ../lib/python/temporal/register.py:261
-msgid "Unable to update %(t)s map <%(id)s>. The temporal types are different."
-#: ../lib/python/temporal/register.py:307
+#: ../lib/raster/gdal.c:140
#, fuzzy
-msgid "Register maps in the temporal database"
+msgid "Unable to load GDAL library"
-#: ../lib/python/temporal/register.py:314
+#: ../lib/raster/gdal.c:370
#, fuzzy
-msgid "Register maps in the space time raster dataset"
-#: ../lib/python/temporal/register.py:323
-msgid "Update space time raster dataset"
-msgstr ""
-#: ../lib/python/temporal/register.py:375
-#: ../lib/python/temporal/register.py:383
-#, python-format
-msgid "Unable to convert string \"%s\"into a datetime object"
-msgstr ""
-#: ../lib/python/temporal/register.py:391
-#: ../lib/python/temporal/register.py:396
-msgid "Error in increment computation"
-msgstr ""
-#: ../lib/python/temporal/register.py:399
-msgid ""
-"Set absolute valid time for map <%(id)s> with layer %(layer)s to %(start)s - "
-"%(end)s"
+msgid "Unable to open GDAL file"
-#: ../lib/python/temporal/register.py:404
-msgid "Set absolute valid time for map <%s> to %s - %s"
+#: ../lib/raster/gdal.c:474 ../lib/raster/open.c:569
+#, fuzzy, c-format
+msgid "Invalid map type <%d>"
-#: ../lib/python/temporal/register.py:421
-msgid ""
-"Set relative valid time for map <%s> with layer %s to %i - %s with unit %s"
+#: ../lib/raster/gdal.c:480
+#, fuzzy, c-format
+msgid "Unable to get <%s> driver"
-#: ../lib/python/temporal/register.py:426
-msgid "Set relative valid time for map <%s> to %i - %s with unit %s"
+#: ../lib/raster/gdal.c:489
+#, fuzzy, c-format
+msgid "Unable to create <%s> dataset using <%s> driver"
-#: ../lib/python/temporal/abstract_dataset.py:391
-#, python-format
+#: ../lib/raster/gdal.c:497
+#, c-format
msgid ""
-"Unable to insert dataset <%(ds)s> of type %(type)s in the temporal database. "
+"Driver <%s> does not support direct writing. Using MEM driver for "
+"intermediate dataset."
msgstr ""
-#: ../lib/python/temporal/stds_import.py:84
-msgid "Unable to import/link raster map <%s> from file %s."
+#: ../lib/raster/gdal.c:503
+#, fuzzy
+msgid "Unable to get in-memory raster driver"
+msgstr "자동 MASK파일을 열 수 없습니다"
-#: ../lib/python/temporal/stds_import.py:94
-msgid "Unable to set the color rules for raster map <%s>."
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/raster/gdal.c:510
+#, fuzzy, c-format
+msgid "Unable to create <%s> dataset using memory driver"
-#: ../lib/python/temporal/stds_import.py:118
-msgid "Unable to unpack raster map <%s> from file %s."
+#: ../lib/raster/gdal.c:514
+#, c-format
+msgid "Driver <%s> does not support creating rasters"
+msgstr ""
-#: ../lib/python/temporal/stds_import.py:142
-msgid "Unable to import vector map <%s> from file %s."
+#: ../lib/raster/gdal.c:530
+#, fuzzy
+msgid "Unable to set geo transform"
-#: ../lib/python/temporal/stds_import.py:166
-msgid "Unable to unpack vector map <%s> from file %s."
+#: ../lib/raster/gdal.c:534
+#, fuzzy
+msgid "Unable to set projection"
-#: ../lib/python/temporal/stds_import.py:204
-#, python-format
-msgid "Space time raster dataset archive <%s> not found"
-msgstr ""
+#: ../lib/raster/gdal.c:538
+#, fuzzy, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
-#: ../lib/python/temporal/stds_import.py:207
-msgid "Extraction directory <%s> not found"
+#: ../lib/raster/gdal.c:554
+#, fuzzy, c-format
+msgid "Error writing cell_misc/%s/gdal file"
-#: ../lib/python/temporal/stds_import.py:215
-msgid "Unable to find init file <%s>"
+#: ../lib/raster/gdal.c:602
+#, fuzzy, c-format
+msgid "Unable to create output file <%s> using driver <%s>"
-#: ../lib/python/temporal/stds_import.py:217
-msgid "Unable to find list file <%s>"
-#: ../lib/python/temporal/stds_import.py:219
-msgid "Unable to find projection file <%s>"
-#: ../lib/python/temporal/stds_import.py:244
-msgid "Projection information does not match. Proceeding..."
+#: ../lib/raster/alloc_cell.c:151
+#, c-format
+msgid "Rast__null_bitstream_size: cols (%d) is negative"
msgstr ""
-#: ../lib/python/temporal/stds_import.py:248
-#, python-brace-format
-msgid ""
-"Difference between PROJ_INFO file of imported map and of current location:\n"
-"{diff}"
-msgstr ""
+#: ../lib/raster/history.c:115 ../lib/raster/history.c:123
+#, fuzzy, c-format
+msgid "Unable to get history information for <%s@%s>"
-#: ../lib/python/temporal/stds_import.py:250
-msgid "Projection information does not match. Aborting."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:266
-msgid "Unable to create location %(l)s. Reason: %(e)s"
-#: ../lib/python/temporal/stds_import.py:273
-msgid "Unable to switch to location %s"
+#: ../lib/raster/history.c:162
+#, fuzzy, c-format
+msgid "Unable to write history information for <%s>"
-#: ../lib/python/temporal/stds_import.py:277
-msgid "Unable to create default temporal database in new location %s"
-#: ../lib/python/temporal/stds_import.py:342
-#, python-format
-msgid "Key words %(t)s, %(s)s or %(n)s not found in init file."
+#: ../lib/raster/history.c:235
+#, c-format
+msgid "generated by %s"
msgstr ""
-#: ../lib/python/temporal/stds_import.py:348
-msgid "Number of maps mismatch in init and list file."
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:359
-msgid "The archive file is of wrong space time dataset type"
-msgstr ""
-#: ../lib/python/temporal/stds_import.py:366
-msgid "Unable to find geotiff raster file <%s> in archive."
+#: ../lib/raster/raster_metadata.c:109
+#, fuzzy, c-format
+msgid "Unable to read <%s> for raster map <%s@%s>"
-#: ../lib/python/temporal/stds_import.py:372
-msgid "Unable to find AAIGrid raster file <%s> in archive."
+#: ../lib/raster/raster_metadata.c:119 ../lib/raster/raster_metadata.c:148
+#, fuzzy, c-format
+msgid "Error closing <%s> metadata file for raster map <%s@%s>"
-#: ../lib/python/temporal/stds_import.py:378
-msgid "Unable to find GML vector file <%s> in archive."
+#: ../lib/raster/raster_metadata.c:142
+#, fuzzy, c-format
+msgid "Unable to create <%s> metadata file for raster map <%s@%s>"
-#: ../lib/python/temporal/stds_import.py:387
-msgid "Unable to find GRASS package file <%s> in archive."
+#: ../lib/raster/auto_mask.c:69
+msgid "Unable to open automatic MASK file"
+msgstr "자동 MASK 파일을 열 수 없습니다."
-#: ../lib/python/temporal/stds_import.py:390
-#, fuzzy
-msgid "Unsupported input format"
-#: ../lib/python/temporal/stds_import.py:396
-msgid ""
-"Space time %(t)s dataset <%(sp)s> is already in the database. Use the "
-"overwrite flag."
-#: ../lib/python/temporal/stds_import.py:416
-msgid "Overwrite space time %(sp)s dataset <%(id)s> and unregister all maps."
-#: ../lib/python/temporal/stds_import.py:428
-msgid "Key word %s not found in init file."
-#: ../lib/python/temporal/stds_import.py:432
-msgid "Create space time %s dataset."
-#: ../lib/python/temporal/spatial_extent.py:125
-msgid ""
-"Projections are different. Unable to compute overlapping_2d for spatial "
-"extents"
+#: ../lib/raster/color_rules.c:125
+msgid "syntax error"
msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:536
-msgid ""
-"Projections are different. Unable to compute is_in_2d for spatial extents"
+#: ../lib/raster/color_rules.c:127
+msgid "R/G/B not in range 0-255"
msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:676
-msgid ""
-"Projections are different. Unable to compute equivalent_2d for spatial "
-"extents"
-msgstr ""
+#: ../lib/raster/color_rules.c:129
+#, fuzzy
+msgid "invalid color name"
+msgstr "잘못된 좌표"
-#: ../lib/python/temporal/spatial_extent.py:783
-msgid ""
-"Projections are different. Unable to compute cover_2d for spatial extents"
+#: ../lib/raster/color_rules.c:131
+msgid "percentage not in range 0-100"
msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:854
-msgid "Projections are different. Unable to compute cover for spatial extents"
+#: ../lib/raster/color_rules.c:133
+msgid "invalid value"
msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1704
-msgid "Volume computation is not supported for LL projections"
+#: ../lib/raster/color_rules.c:135
+msgid "unknown error"
msgstr ""
-#: ../lib/python/temporal/spatial_extent.py:1722
-msgid "Area computation is not supported for LL projections"
+#: ../lib/raster/color_rules.c:181
+#, c-format
+msgid "bad rule (%s): [%s]"
msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:641
-#, python-format
-msgid ""
-"Error vector maps with basename %s exist. Use --o flag to overwrite existing "
-"file"
-msgstr ""
-#: ../lib/python/temporal/temporal_vector_algebra.py:673
-msgid ""
-"Error starting %s : \n"
-"%s"
-#: ../lib/python/temporal/temporal_vector_algebra.py:721
-msgid ""
-"Error vector map %s exist in temporal database. Use overwrite flag. : \n"
-"%s"
+#: ../lib/raster/color_rules.c:328
+#, fuzzy, c-format
+msgid "Unable to load color rules <%s>"
-#: ../lib/python/temporal/factory.py:51
-msgid "Unknown dataset type: %s"
+#: ../lib/raster/format.c:154
+#, c-format
+msgid "Fail of initial read of compressed file [%s in %s]"
+msgstr ""
-#: ../lib/python/temporal/temporal_algebra.py:826
-msgid "Space time %s dataset <%s> not found"
-#: ../lib/python/temporal/temporal_algebra.py:844
-#: ../lib/python/temporal/temporal_algebra.py:848
-#, python-format
-msgid ""
-"Wrong temporal type of space time dataset <"
-"%s> <%s> time is required"
+#: ../lib/raster/init.c:61
+msgid "Raster library not initialized. Programmer forgot to call Rast_init()."
msgstr ""
-#: ../lib/python/temporal/list_stds.py:101
-msgid "Empty map list."
+#: ../lib/raster/put_title.c:28
+#, c-format
+msgid "category information for [%s] in [%s] missing or invalid"
msgstr ""
-#: ../lib/python/temporal/list_stds.py:112
-msgid "Empty entry in map list, this should not happen."
+#: ../lib/raster/put_title.c:37
+msgid "G_put_title - can't create a temp file"
msgstr ""
-#: ../lib/python/temporal/aggregation.py:124
-msgid "Aggregate %s raster maps"
-#: ../lib/python/temporal/aggregation.py:138
-msgid ""
-"Raster map <%s> is already in temporal database, use overwrite flag to "
-"overwrite"
-#: ../lib/python/temporal/aggregation.py:142
-#, python-format
-msgid "Compute aggregation of maps between %(st)s - %(end)s"
+#: ../lib/raster/put_title.c:53
+#, c-format
+msgid "category information for [%s] in [%s] invalid"
msgstr ""
-#: ../lib/python/temporal/aggregation.py:161
-msgid "Error while r.series computation"
+#: ../lib/raster/put_title.c:60
+msgid "G_put_title - can't reopen temp file"
msgstr ""
-#: ../lib/python/temporal/univar_statistics.py:54
-#: ../lib/python/temporal/univar_statistics.py:142
-msgid "Space time %(sp)s dataset <%(i)s> is empty"
-#: ../lib/python/temporal/univar_statistics.py:132
-msgid "Space time %(sp)s dataset <%(i)s> not found"
-#: ../lib/python/temporal/temporal_raster_base_algebra.py:316
-msgid "Error computing map <%s>"
-#: ../lib/python/temporal/mapcalc.py:105
-msgid "Start spatio-temporal sampling"
+#: ../lib/raster/put_title.c:67
+#, c-format
+msgid "can't write category information for [%s] in [%s]"
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:107
-msgid "Start temporal sampling"
+#: ../lib/raster/color_read.c:103
+msgid "missing"
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:124
-msgid "No samples found for map calculation"
+#: ../lib/raster/color_read.c:106
+msgid "invalid"
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:151
+#: ../lib/raster/color_read.c:112
+#, fuzzy, c-format
+msgid "Color support for <%s@%s> %s"
+msgstr "맵 [%s], 맵셑 [%s]을(를) 위한 색상지원: %s"
+#: ../lib/raster/window.c:18
msgid ""
-"Found more than a single map in a sample granule. Only the first map is used "
-"for computation. Use t.rast.aggregate.ds to create synchronous raster "
-"datasets."
+"Internal error: Rast_get_window() called with split window. Use "
+"Rast_get_input_window() or Rast_get_output_window() instead."
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:169
-msgid "No maps in input dataset"
+#: ../lib/raster/window.c:77
+msgid ""
+"Internal error: Rast_window_rows() called with split window. Use "
+"Rast_input_window_rows() or Rast_output_window_rows() instead."
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:185
-msgid "Start mapcalc computation"
-msgstr ""
-#: ../lib/python/temporal/mapcalc.py:235
-#: ../lib/python/temporal/open_stds.py:205
-#: ../lib/python/temporal/extract.py:112
+#: ../lib/raster/window.c:112
msgid ""
-"Map <%s> is already in temporal database, use overwrite flag to overwrite"
-#: ../lib/python/temporal/mapcalc.py:255
-#, python-format
-msgid "Apply mapcalc expression: \"%s\""
+"Internal error: Rast_window_cols() called with split window. Use "
+"Rast_input_window_cols() or Rast_output_window_cols() instead."
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:274
-msgid "Error while mapcalc computation"
+#: ../lib/raster/color_write.c:81 ../lib/vector/Vlib/color_write.c:71
+#, c-format
+msgid "Qualified name <%s> doesn't match mapset <%s>"
msgstr ""
-#: ../lib/python/temporal/mapcalc.py:280
-#, fuzzy
-msgid "Start map registration in temporal database"
+#: ../lib/raster/color_write.c:96 ../lib/vector/Vlib/color_write.c:91
+#, fuzzy, c-format
+msgid "Unable to create <%s> file for map <%s>"
-#: ../lib/python/temporal/mapcalc.py:430 ../lib/python/temporal/mapcalc.py:436
-#: ../lib/python/temporal/mapcalc.py:442 ../lib/python/temporal/mapcalc.py:448
-#: ../lib/python/temporal/mapcalc.py:454 ../lib/python/temporal/mapcalc.py:460
-#: ../lib/python/temporal/mapcalc.py:466 ../lib/python/temporal/mapcalc.py:472
-#: ../lib/python/temporal/mapcalc.py:478 ../lib/python/temporal/mapcalc.py:513
-#: ../lib/python/temporal/mapcalc.py:522 ../lib/python/temporal/mapcalc.py:531
-#: ../lib/python/temporal/mapcalc.py:540 ../lib/python/temporal/mapcalc.py:549
-#: ../lib/python/temporal/mapcalc.py:558 ../lib/python/temporal/mapcalc.py:567
-#: ../lib/python/temporal/mapcalc.py:576 ../lib/python/temporal/mapcalc.py:585
-#, python-format
-msgid "The temporal operators <%s> supports only absolutetime."
-msgstr ""
-#: ../lib/python/temporal/open_stds.py:60
-#: ../lib/python/temporal/open_stds.py:115
-msgid "Unkown type: %s"
-#: ../lib/python/temporal/open_stds.py:66
-msgid "Space time %(sp)s dataset <%(name)s> no found"
+#: ../lib/raster/range.c:102 ../lib/raster/range.c:110
+#, fuzzy, c-format
+msgid "Unable to read fp range file for <%s>"
-#: ../lib/python/temporal/open_stds.py:104
-#, fuzzy
-msgid "Space time datasets can only be created in the current mapset"
-#: ../lib/python/temporal/open_stds.py:121
-msgid ""
-"Space time %(sp)s dataset <%(name)s> is already in the database. Use the "
-"overwrite flag."
+#: ../lib/raster/range.c:169
+#, fuzzy, c-format
+msgid "Unable to read quant rules for raster map <%s>"
-#: ../lib/python/temporal/open_stds.py:155
-msgid "Overwrite space time %(sp)s dataset <%(name)s> and unregister all maps."
+#: ../lib/raster/range.c:206 ../lib/raster/range.c:226
+#, fuzzy, c-format
+msgid "Unable to read range file for <%s>"
-#: ../lib/python/temporal/open_stds.py:163
-msgid "Create new space time %s dataset."
+#: ../lib/raster/range.c:264 ../lib/raster/range.c:270
+#: ../lib/raster/range.c:300 ../lib/raster/range.c:314
+#, fuzzy, c-format
+msgid "Unable to write range file for <%s>"
-#: ../lib/python/temporal/datetime_math.py:254
-#: ../lib/python/temporal/datetime_math.py:271
-#, python-format
-msgid "Wrong increment format: %s"
+#: ../lib/raster/open.c:190
+#, c-format
+msgid ""
+"Unable to open raster map <%s@%s> since it is a reclass of raster map <%s@"
+"%s> which does not exist"
msgstr ""
-#: ../lib/python/temporal/datetime_math.py:725
-msgid "Time string seems to specify relative time"
-msgstr ""
+#: ../lib/raster/open.c:195
+#, fuzzy, c-format
+msgid "Error reading reclass file for raster map <%s>"
-#: ../lib/python/temporal/datetime_math.py:737
-#, fuzzy
-msgid "Dates Before Christ are not supported"
+#: ../lib/raster/open.c:206
+#, fuzzy, c-format
+msgid "Error reading map type for raster map <%s>"
-#: ../lib/python/temporal/datetime_math.py:741
-#, fuzzy
-msgid "Time zones are not supported"
-#: ../lib/python/temporal/datetime_math.py:751
-msgid "Unable to parse time string: %s"
-#: ../lib/python/temporal/gui_support.py:57 ../lib/python/script/core.py:1339
-#, python-format
-msgid "Invalid element '%s'"
+#: ../lib/raster/open.c:214
+#, c-format
+msgid "Raster map <%s@%s>: format field in header file invalid"
msgstr ""
-#: ../lib/python/temporal/temporal_raster3d_algebra.py:44
-#, fuzzy
-msgid "Removing empty 3D raster maps"
-#: ../lib/python/temporal/stds_export.py:96
-msgid "Unable to export raster map <%s>"
-#: ../lib/python/temporal/stds_export.py:106
-msgid "Unable to export color rules for raster map <%s> r.out.gdal"
-#: ../lib/python/temporal/stds_export.py:128
-msgid "Unable to export raster map <%s> with r.pack"
-#: ../lib/python/temporal/stds_export.py:154
-msgid "Unable to export vector map <%s> as GML with v.out.ogr"
-#: ../lib/python/temporal/stds_export.py:185
-msgid "Unable to export vector map <%s> with v.pack"
-#: ../lib/python/temporal/stds_export.py:210
-msgid "Unable to export raster map <%s> with r3.pack"
-#: ../lib/python/temporal/extract.py:54
-msgid "You need to specify the base name of new created maps"
+#: ../lib/raster/open.c:219
+#, c-format
+msgid ""
+"Raster map <%s> is in different projection than current region. Found <%s>, "
+"should be <%s>."
msgstr ""
-#: ../lib/python/temporal/extract.py:119
-#, python-format
-msgid "Apply r.mapcalc expression: \"%s\""
+#: ../lib/raster/open.c:226
+#, c-format
+msgid "Raster map <%s> is in different zone (%d) than current region (%d)"
msgstr ""
-#: ../lib/python/temporal/extract.py:124
-#, python-format
-msgid "Apply r3.mapcalc expression: \"%s\""
+#: ../lib/raster/open.c:231
+#, c-format
+msgid "Raster map <%s>: bytes per cell (%d) too large"
msgstr ""
-#: ../lib/python/temporal/extract.py:129
-#, python-format
-msgid "Apply v.extract where statement: \"%s\""
+#: ../lib/raster/open.c:256
+#, c-format
+msgid ""
+"Raster map <%s@%s> is a GDAL link but GRASS is compiled without GDAL support"
msgstr ""
-#: ../lib/python/temporal/extract.py:158
-msgid "Error while computation"
-msgstr ""
+#: ../lib/raster/open.c:264
+#, fuzzy, c-format
+msgid "Unable to open %s file for raster map <%s@%s>"
-#: ../lib/python/script/core.py:934
-msgid "Mixing value types. Will try to compare after integer conversion"
-msgstr ""
+#: ../lib/raster/open.c:301
+#, fuzzy, c-format
+msgid "Error reading format for <%s@%s>"
-#: ../lib/python/script/core.py:1152
-#, python-format
-msgid "Element type should be \"cell\" and not \"%s\""
-msgstr ""
-#: ../lib/python/script/core.py:1181 ../lib/python/script/core.py:1271
-#: ../lib/python/script/core.py:1326
-#, python-format
-msgid "Element type should be \"rast\" and not \"%s\""
-msgstr ""
-#: ../lib/python/script/core.py:1527
+#: ../lib/raster/open.c:498
#, fuzzy
-msgid "Unable to list mapsets"
+msgid "Unable to create GDAL link"
-#: ../lib/python/script/core.py:1563
-#, python-format
-msgid "Location <%s> already exists. Operation canceled."
+#: ../lib/raster/open.c:574
+#, c-format
+msgid "Raster map <%s> is not in the current mapset (%s)"
msgstr ""
-#: ../lib/python/script/core.py:1566
-msgid "Location <%s> already exists and will be overwritten"
-#: ../lib/python/script/core.py:1698
-#, python-format
-msgid "Illegal filename <%s>. Cannot be 'NULL' or start with '.'."
+#: ../lib/raster/open.c:581
+#, fuzzy, c-format
+msgid "<%s> is an illegal file name"
msgstr ""
+"\n"
+"**<%s> 잘못된 이름 **\n"
-#: ../lib/python/script/core.py:1707
-#, python-format
-msgid "Illegal filename <%(s)s>. <%(il)s> not allowed.\n"
+#: ../lib/raster/open.c:595
+msgid "No temp files available"
msgstr ""
-#: ../lib/python/script/vector.py:88
-#, python-format
-msgid "Database connection not defined for layer %s"
+#: ../lib/raster/open.c:667
+msgid "no temp files available"
msgstr ""
-#: ../lib/python/script/vector.py:238
-msgid "Missing layer %(layer)d in vector map <%(map)s>"
-#: ../lib/python/script/vector.py:256
-msgid "vector_db_select() failed"
+#: ../lib/raster/open.c:720
+msgid "Rast_set_fp_type(): can only be called with FCELL_TYPE or DCELL_TYPE"
msgstr ""
-#: ../lib/python/script/raster3d.py:89
-msgid "An error occurred while running r3.mapcalc"
-msgstr ""
+#: ../lib/raster/open.c:778
+#, fuzzy, c-format
+msgid "Raster map <%s> not found in mapset <%s>"
-#: ../lib/python/script/db.py:142
-#, python-format
-msgid ""
-"Programmer error: '%(sql)s', '%(filename)s', or '%(table)s' must be provided"
-msgstr ""
-#: ../lib/python/script/db.py:154
-#, fuzzy
-msgid "Fetching data failed"
+#: ../lib/raster/open.c:839
+#, fuzzy, c-format
+msgid "Unable to find '%s'"
-#: ../lib/python/script/task.py:52
-#, fuzzy
-msgid "unknown"
-#: ../lib/python/script/task.py:166
-#, python-format
-msgid "Parameter element '%(element)s' not found: '%(value)s'"
+#: ../lib/raster/open.c:850
+#, c-format
+msgid "Invalid type: field '%s' in file '%s'"
msgstr ""
-#: ../lib/python/script/task.py:181
-#, python-format
-msgid "Flag not found: %s"
+#: ../lib/raster/open.c:855
+#, c-format
+msgid "Missing type: field in file '%s'"
msgstr ""
-#: ../lib/python/script/task.py:200
-#, python-format
-msgid "Parameter '%(name)s' (%(desc)s) is missing."
+#: ../lib/raster/open.c:860
+#, c-format
+msgid "Raster map <%s> is not xdr: byte_order: %s"
msgstr ""
-#: ../lib/python/script/task.py:231
-msgid "<required>"
-msgstr ""
-#: ../lib/python/script/task.py:486 ../lib/python/script/task.py:490
-#, python-format
+#: ../lib/raster/open.c:929
msgid ""
-"Unable to fetch interface description for command '%(cmd)s'.\n"
-"\n"
-"Details: %(det)s"
+"Rast_set_quant_rules() can be called only for raster maps opened for reading"
msgstr ""
-#: ../lib/python/script/raster.py:47
-msgid ""
-"Unable to write history for <%(map)s>. Raster map <%(map)s> not found in "
-"current mapset."
-#: ../lib/python/script/raster.py:105
-msgid "An error occurred while running r.mapcalc"
+#: ../lib/raster/color_rand.c:33
+#, c-format
+msgid "Rast_make_random_colors: min (%d) > max (%d)"
msgstr ""
-#: ../lib/python/script/raster.py:162
-#, fuzzy
-msgid "No data"
+#: ../lib/raster/put_row.c:120
+#, fuzzy, c-format
+msgid "Error writing uncompressed FP data for row %d of <%s>"
-#: ../lib/python/script/raster.py:170
-msgid "value"
-msgstr ""
+#: ../lib/raster/put_row.c:130
+#, fuzzy, c-format
+msgid "Error writing compressed FP data for row %d of <%s>"
-msgid "label"
-msgstr ""
+#: ../lib/raster/put_row.c:389 ../lib/raster/put_row.c:395
+#, fuzzy, c-format
+msgid "Error writing compressed data for row %d of <%s>"
-msgid "color"
-msgstr ""
+#: ../lib/raster/put_row.c:405
+#, fuzzy, c-format
+msgid "Error writing uncompressed data for row %d of <%s>"
-#: ../lib/python/pygrass/raster/abstract.py:240
-msgid "Mode type: {0} not supported ('r', 'w')"
-msgstr ""
+#: ../lib/raster/put_row.c:464
+#, fuzzy, c-format
+msgid "Error writing data via GDAL for row %d of <%s>"
-#: ../lib/python/pygrass/raster/abstract.py:251
-msgid "Overwrite type: {0} not supported (True/False)"
-msgstr ""
+#: ../lib/raster/put_row.c:488
+#, fuzzy, c-format
+msgid "No null file for <%s>"
-#: ../lib/python/pygrass/raster/abstract.py:264
-#: ../lib/python/pygrass/vector/abstract.py:108
-msgid "Map name {0} not valid"
+#: ../lib/raster/put_row.c:502
+msgid "GDAL output doesn't support writing null rows separately"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:191
-#, fuzzy
-msgid "Raster type not defined"
+#: ../lib/raster/put_row.c:522
+#, fuzzy, c-format
+msgid "Unable to find a temporary null file <%s>"
-#: ../lib/python/pygrass/raster/__init__.py:194
-#, fuzzy, python-brace-format
-msgid "Raster map <{0}> already exists"
+#: ../lib/raster/put_row.c:527
+#, fuzzy, c-format
+msgid "Unable to open null file <%s>"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
-#: ../lib/python/pygrass/raster/__init__.py:200
-msgid "The map does not exist, I can't open in 'r' mode"
+#: ../lib/raster/put_row.c:554 ../lib/raster/put_row.c:557
+#, fuzzy, c-format
+msgid "Error writing null row %d"
+#: ../lib/raster/put_row.c:682
+#, c-format
+msgid "put_raster_row: raster map <%s> not open for write - request ignored"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:270
-msgid "Mode type: {0} not supported ('r', 'w','rw')"
+#: ../lib/raster/put_row.c:689
+msgid "put_raster_row: unopened file descriptor - request ignored"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:289
-#, python-format
-msgid "Index out of range: %r."
+#: ../lib/raster/sample.c:70
+msgid "Unknown interpolation type"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:405
-msgid "Raster map <{0}> already exists. Use overwrite."
+#: ../lib/raster/sample.c:327
+msgid "\"no data\" label found; setting to zero"
+msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:436
-msgid "Raster map <{0}> does not exists"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/python/pygrass/raster/__init__.py:550
-msgid "Mode type: {0} not supported."
+#: ../lib/raster/get_row.c:36 ../lib/raster/get_row.c:838
+#, c-format
+msgid "Reading raster map <%s@%s> request for row %d is outside region"
msgstr ""
-#: ../lib/python/pygrass/raster/__init__.py:584
-msgid "Invalid type {0}"
+#: ../lib/raster/get_row.c:95 ../lib/raster/get_row.c:100
+#: ../lib/raster/get_row.c:133 ../lib/raster/get_row.c:139
+#: ../lib/raster/get_row.c:173 ../lib/raster/get_row.c:176
+#, fuzzy
+msgid "Error reading raster data"
-#: ../lib/python/pygrass/raster/__init__.py:586
-msgid "Invalid size {0}"
+#: ../lib/raster/get_row.c:211
+#, fuzzy
+msgid "Error reading raster data via GDAL"
-#: ../lib/python/pygrass/raster/category.py:83
-msgid "Raser type: {0} not supported"
+#: ../lib/raster/get_row.c:822 ../lib/raster/get_row.c:825
+#, fuzzy, c-format
+msgid "Error reading null row %d"
-#: ../lib/python/pygrass/raster/category.py:168
-msgid "Error executing: Rast_get_ith_cat"
+#: ../lib/raster/null_val.c:64
+msgid "EmbedGivenNulls: wrong data type"
msgstr ""
-#: ../lib/python/pygrass/raster/category.py:196
-#, fuzzy
-msgid "Null value detected"
+#: ../lib/raster/null_val.c:114
+msgid "Rast_set_null_value: wrong data type!"
+msgstr ""
-#: ../lib/python/pygrass/raster/category.py:198
-#, fuzzy
-msgid "Error executing: Rast_set_cat"
-#: ../lib/python/pygrass/functions.py:239
-msgid "Vector doesn't contain points"
+#: ../lib/rst/interp_float/input2d.c:48
+#, c-format
+msgid "Mask raster map <%s> not found"
msgstr ""
-#: ../lib/python/pygrass/errors.py:46
-msgid "The map is close!"
+#: ../lib/rst/interp_float/input2d.c:70
+msgid "Bitmap mask created"
msgstr ""
-#: ../lib/python/pygrass/vector/table.py:927
-#, python-format
-msgid "Deleting table <%s> which is attached to following map(s):"
+#: ../lib/rst/interp_float/segmen2d.c:118
+msgid ""
+"Taking too long to find points for interpolation - please change the region "
+"to area where your points are. Continuing calculations..."
msgstr ""
-#: ../lib/python/pygrass/vector/table.py:931
-msgid "You must use the force flag to actually remove it. Exiting."
+#: ../lib/rst/interp_float/output2d.c:106
+#, c-format
+msgid "First change your rows number to nsizr! %d %d"
msgstr ""
-#: ../lib/rst/interp_float/interp2d.c:214
+#: ../lib/rst/interp_float/output2d.c:113
#, c-format
-msgid ""
-"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
-"cell. Z-value %f, zmin %f, zmax %f."
+msgid "First change your cols number to nsizc %d %d"
msgstr ""
#: ../lib/rst/interp_float/resout2d.c:77
@@ -5643,38 +5475,13 @@
msgid "Changing the region back to initial..."
msgstr ""
-#: ../lib/rst/interp_float/segmen2d.c:118
+#: ../lib/rst/interp_float/interp2d.c:214
+#, c-format
msgid ""
-"Taking too long to find points for interpolation - please change the region "
-"to area where your points are. Continuing calculations..."
+"Overshoot - increase in tension suggested. Overshoot occures at (%d,%d) "
+"cell. Z-value %f, zmin %f, zmax %f."
msgstr ""
-#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
-#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
-#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
-#, fuzzy
-msgid "Cannot write files"
-#: ../lib/rst/interp_float/input2d.c:48
-#, c-format
-msgid "Mask raster map <%s> not found"
-msgstr ""
-#: ../lib/rst/interp_float/input2d.c:70
-msgid "Bitmap mask created"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:106
-#, c-format
-msgid "First change your rows number to nsizr! %d %d"
-msgstr ""
-#: ../lib/rst/interp_float/output2d.c:113
-#, c-format
-msgid "First change your cols number to nsizc %d %d"
-msgstr ""
#: ../lib/rst/interp_float/vinput2d.c:73
#, fuzzy, c-format
msgid "Vector map <%s> is not 3D"
@@ -5684,6 +5491,12 @@
msgid "Loading data from attribute table ..."
msgstr ""
+#: ../lib/rst/interp_float/vinput2d.c:94
+#: ../lib/rst/interp_float/vinput2d.c:108 ../lib/db/dbmi_client/copy_tab.c:267
+#, fuzzy, c-format
+msgid "Column <%s> not found"
#: ../lib/rst/interp_float/vinput2d.c:97
#: ../lib/rst/interp_float/vinput2d.c:110
#, c-format
@@ -5772,283 +5585,183 @@
msgid "Unable to insert %f,%f,%f a = %d"
-#: ../lib/imagery/iclass.c:83
-#, fuzzy, c-format
-msgid "No areas in category %d"
-#: ../lib/imagery/iclass.c:127
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in subgroup <%s> does not exist"
+#: ../lib/rst/interp_float/write2d.c:40 ../lib/rst/interp_float/write2d.c:51
+#: ../lib/rst/interp_float/write2d.c:66 ../lib/rst/interp_float/write2d.c:75
+#: ../lib/rst/interp_float/write2d.c:83 ../lib/rst/interp_float/write2d.c:91
+#, fuzzy
+msgid "Cannot write files"
-#: ../lib/imagery/iclass.c:131
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> in group <%s> does not exist"
-#: ../lib/imagery/iclass.c:143
+#: ../lib/cluster/c_exec.c:44
#, c-format
-msgid "Subgroup <%s> does not have enough files (it has %d files)"
+msgid "Not enough data points (%d) in cluster"
msgstr ""
-#: ../lib/imagery/iclass.c:147
+#: ../lib/cluster/c_begin.c:57
#, c-format
-msgid "Group <%s> does not have enough files (it has %d files)"
+msgid "produced by i.cluster"
msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:109
-#, c-format
-msgid "Get area %d failed"
-msgstr ""
+#: ../lib/vector/vedit/cats.c:63
+#, fuzzy, c-format
+msgid "Unable to set category %d for (feature id %d)"
-#: ../lib/imagery/iclass_perimeter.c:116
-msgid "Perimeter computation failed"
+#: ../lib/vector/vedit/select.c:231
+msgid "Unknown query tool"
msgstr ""
-#: ../lib/imagery/iclass_perimeter.c:208
-msgid "Absurd polygon."
-msgstr ""
+#: ../lib/vector/vedit/delete.c:40
+#, fuzzy, c-format
+msgid "Attempt to delete dead feature (%d)"
-#: ../lib/imagery/iclass_perimeter.c:253
-msgid "Outlined area is too large."
-msgstr ""
+#: ../lib/vector/vedit/delete.c:72
+#, fuzzy, c-format
+msgid "No area found for centroid %d"
-#: ../lib/imagery/fopen.c:23
+#: ../lib/vector/vedit/delete.c:76
#, c-format
-msgid "Unable to create file [%s] of group [%s in %s]"
+msgid "Duplicate centroid %d, unable to delete area"
msgstr ""
-#: ../lib/imagery/fopen.c:36 ../lib/imagery/fopen.c:57
+#: ../lib/vector/vedit/delete.c:105
#, fuzzy, c-format
-msgid "Unable to open file [%s] of group [%s in %s]"
+msgid "Area %d without centroid"
-#: ../lib/imagery/fopen.c:49
-#, c-format
-msgid "Unable to find file [%s] of group [%s in %s]"
-msgstr ""
+#: ../lib/vector/vedit/delete.c:121
+#, fuzzy, c-format
+msgid "Area %d has no boundaries"
-#: ../lib/imagery/fopen.c:79
-#, c-format
-msgid "Unable to create file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/vector/diglib/file.c:159
+msgid "Writing to file loaded to memory not supported"
msgstr ""
-#: ../lib/imagery/fopen.c:101 ../lib/imagery/fopen.c:127
-#, c-format
-msgid "Unable to open file [%s] for subgroup [%s] of group [%s in %s]"
-msgstr ""
+#: ../lib/vector/diglib/file.c:197
+#, fuzzy
+msgid "Unable to load file to memory, file not open"
-#: ../lib/imagery/fopen.c:116
-#, c-format
-msgid "Unable to find file [%s] for subgroup [%s] of group [%s in %s]"
+#: ../lib/vector/diglib/file.c:212
+msgid "Vector memory mode not supported, using 'AUTO'"
msgstr ""
-#: ../lib/imagery/georef_tps.c:219
-msgid "Calculating forward transformation coefficients"
-msgstr ""
+#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
+#, fuzzy
+msgid "Topology file must be written before spatial index file"
-#: ../lib/imagery/georef_tps.c:236
-msgid "Calculating backward transformation coefficients"
+#: ../lib/vector/diglib/spindex_rw.c:302
+#, c-format
+msgid ""
+"This version of GRASS (%d.%d) is too old to read this spatial index format. "
+"Try to rebuild topology or upgrade GRASS to at least version %d."
msgstr ""
-#: ../lib/imagery/georef_tps.c:279 ../lib/imagery/georef_tps.c:282
-#: ../lib/imagery/georef_tps.c:285 ../lib/imagery/georef_tps.c:290
-#: ../lib/imagery/georef_tps.c:293
+#: ../lib/vector/diglib/spindex_rw.c:308
#, c-format
-msgid "%s: out of memory"
+msgid ""
+"Your GRASS version does not fully support spatial index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
-#: ../lib/imagery/target.c:38
-#, fuzzy, c-format
-msgid "Unable to read target file for group [%s]"
-#: ../lib/imagery/list_subgp.c:72
+#: ../lib/vector/diglib/spindex_rw.c:317
#, c-format
-msgid "subgroup <%s> of group <%s> is empty\n"
+msgid ""
+"Spatial index format version %d.%d is not supported by this release. Please "
+"rebuild topology."
msgstr ""
-#: ../lib/imagery/list_subgp.c:85
+#: ../lib/vector/diglib/plus_area.c:217 ../lib/vector/diglib/plus_area.c:719
#, c-format
-msgid "subgroup <%s> of group <%s> references the following raster maps\n"
+msgid "Line %d already has area/isle %d to left"
msgstr ""
-#: ../lib/imagery/sigsetfile.c:41
+#: ../lib/vector/diglib/plus_area.c:227 ../lib/vector/diglib/plus_area.c:727
#, c-format
-msgid ""
-"Unable to create signature file <%s> for subgroup <%s> of group <%s> - <%s> "
-"is not current mapset"
+msgid "Line %d already has area/isle %d to right"
msgstr ""
-#: ../lib/imagery/sigsetfile.c:57
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for subgroup <%s> of group <%s>"
-#: ../lib/imagery/points.c:124
-#, fuzzy, c-format
-msgid "Unable to open control point file for group [%s in %s]"
-#: ../lib/imagery/points.c:132
-#, fuzzy, c-format
-msgid "Bad format in control point file for group [%s in %s]"
-#: ../lib/imagery/points.c:159
-#, fuzzy, c-format
-msgid "Unable to create control point file for group [%s in %s]"
-#: ../lib/imagery/iclass_statistics.c:218
-msgid "prepare_signature: outline has odd number of points."
+#: ../lib/vector/diglib/plus_area.c:281
+msgid "Isle already registered in area"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:227 ../lib/imagery/iscatt_core.c:972
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
+#: ../lib/vector/diglib/plus_area.c:315
+msgid "Attempt to delete isle from dead area"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:237 ../lib/imagery/iscatt_core.c:981
-msgid "signature: perimeter points out of order."
-msgstr ""
-#: ../lib/imagery/iclass_statistics.c:248
+#: ../lib/vector/diglib/plus_area.c:332
#, c-format
-msgid "Data error preparing signatures: value (%d) > num of cats (%d)"
+msgid "Attempt to delete not registered isle %d from area %d"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:561
-#: ../lib/imagery/iclass_statistics.c:584
-#: ../lib/imagery/iclass_statistics.c:607
-#: ../lib/imagery/iclass_statistics.c:630
-#: ../lib/imagery/iclass_statistics.c:653
-#: ../lib/imagery/iclass_statistics.c:680
-#: ../lib/imagery/iclass_statistics.c:712
-#: ../lib/imagery/iclass_statistics.c:735
-#: ../lib/imagery/iclass_statistics.c:758
-msgid "Band index out of range"
+#: ../lib/vector/diglib/plus_area.c:371
+msgid "Attempt to delete dead area"
msgstr ""
-#: ../lib/imagery/iclass_statistics.c:684
-msgid "Cell category value out of range"
-msgstr ""
-#: ../lib/imagery/list_gp.c:34
+#: ../lib/vector/diglib/plus_area.c:412
#, c-format
-msgid "group <%s> is empty\n"
+msgid "Dead centroid %d registered for area (bug in the vector library)"
msgstr ""
-#: ../lib/imagery/list_gp.c:44
-#, c-format
-msgid "group <%s> references the following raster maps\n"
-msgstr ""
-#: ../lib/imagery/iclass_signatures.c:120
+#: ../lib/vector/diglib/plus_area.c:437
#, fuzzy, c-format
-msgid "Unable to open output signature file '%s'"
+msgid "Attempt to delete area %d info from dead isle %d"
-#: ../lib/imagery/iscatt_core.c:81
+#: ../lib/vector/diglib/plus_area.c:787
#, fuzzy, c-format
-msgid "Unable to write header into category raster condition file <%s>."
+msgid "Attempt to delete isle %d info from dead area %d"
-#: ../lib/imagery/iscatt_core.c:98
-#, fuzzy, c-format
-msgid "Unable to write into category raster condition file <%s>."
-msgstr "'%s' 디버그파일을 열 수 없습니다"
-#: ../lib/imagery/iscatt_core.c:255
-#, fuzzy, c-format
-msgid "Unable to open category raster condtions file <%s>."
+#: ../lib/vector/diglib/test.c:58
+#, fuzzy
+msgid "Unable to open test.tmp file"
-#: ../lib/imagery/iscatt_core.c:263
-#, fuzzy, c-format
-msgid "Unable to find patch raster <%s>."
-#: ../lib/imagery/iscatt_core.c:280
+#: ../lib/vector/diglib/test.c:75
#, c-format
-msgid "Resolutions of patch <%s> and patched file <%s> are not same."
+msgid ""
+"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
+"%.16e3E"
msgstr ""
-#: ../lib/imagery/iscatt_core.c:307 ../lib/imagery/iscatt_core.c:349
+#: ../lib/vector/diglib/test.c:89
#, c-format
-msgid "Corrupted category raster conditions file <%s> (fseek failed)"
+msgid ""
+"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
+"%.8e3E"
msgstr ""
-#: ../lib/imagery/iscatt_core.c:338
-#, fuzzy, c-format
-msgid "Unable to write into category raster conditions file <%s>"
-#: ../lib/imagery/iscatt_core.c:526
-#, fuzzy
-msgid "Unable to read from category raster condtition file."
-#: ../lib/imagery/iscatt_core.c:533
-msgid "Invalid size of category raster conditions file."
-msgstr ""
-#: ../lib/imagery/iscatt_core.c:579
+#: ../lib/vector/diglib/test.c:104
+#, c-format
msgid ""
-"Data inconsistent. Value computed for scatter plot is out of initialized "
-"range."
+"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
msgstr ""
-#: ../lib/imagery/iscatt_core.c:745
-#, fuzzy, c-format
-msgid "Unbale to read find raster <%s>"
-#: ../lib/imagery/iscatt_core.c:755
-#, fuzzy, c-format
-msgid "Unbale to open raster <%s>"
-#: ../lib/imagery/iscatt_core.c:761
-#, fuzzy, c-format
-msgid "Raster <%s> type is not <%s>"
-#: ../lib/imagery/iscatt_core.c:775
-#, fuzzy, c-format
-msgid "Unable to read range of raster <%s>"
-#: ../lib/imagery/iscatt_core.c:803
-#, fuzzy, c-format
-msgid "Unable to open category raster condtition file <%s>"
-#: ../lib/imagery/iscatt_core.c:817
-msgid "Corrupted category raster conditions file (fseek failed)"
-msgstr ""
-#: ../lib/psdriver/Graph_set.c:199
+#: ../lib/vector/diglib/test.c:119
#, c-format
-msgid "ps: truecolor status %s"
+msgid ""
+"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
msgstr ""
-#: ../lib/psdriver/Graph_set.c:214
+#: ../lib/vector/diglib/test.c:134
#, c-format
-msgid "ps: collecting to file '%s'"
+msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
msgstr ""
-#: ../lib/psdriver/Graph_set.c:215
+#: ../lib/vector/diglib/test.c:150
#, c-format
-msgid "ps: image size %dx%d"
+msgid ""
+"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
msgstr ""
-#: ../lib/vector/diglib/plus_node.c:214
+#: ../lib/vector/diglib/test.c:165
#, c-format
-msgid ""
-"Attempt to read line angle for the line which is not connected to the node: "
-"node %d, line %d"
+msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
msgstr ""
#: ../lib/vector/diglib/plus.c:222
@@ -6123,14 +5836,31 @@
msgstr ""
+#: ../lib/vector/diglib/plus_node.c:214
+#, c-format
+msgid ""
+"Attempt to read line angle for the line which is not connected to the node: "
+"node %d, line %d"
+msgstr ""
#: ../lib/vector/diglib/port_init.c:158
#, fuzzy, c-format
msgid "Unable to find '%x' in %s"
-#: ../lib/vector/diglib/portable.c:208 ../lib/vector/diglib/portable.c:241
-#: ../lib/vector/diglib/portable.c:683 ../lib/vector/diglib/plus_struct.c:563
-msgid "Vector exceeds supported file size limit"
+#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
+#, fuzzy, c-format
+msgid "Vector format not recognized: %s"
+#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
+#, fuzzy, c-format
+msgid "Vector format '%s' not supported"
+#: ../lib/vector/diglib/frmt.c:97
+#, c-format
+msgid "Format definition is not correct: %s"
msgstr ""
#: ../lib/vector/diglib/spindex.c:450
@@ -6158,53 +5888,6 @@
msgid "Unable to delete isle %d from spatial index"
-#: ../lib/vector/diglib/test.c:58
-#, fuzzy
-msgid "Unable to open test.tmp file"
-#: ../lib/vector/diglib/test.c:75
-#, c-format
-msgid ""
-"Error in read/write portable double, byte_order = %d Written: %.16e3E Read: "
-"%.16e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:89
-#, c-format
-msgid ""
-"Error in read/write portable float, byte_order = %d Written: %.8e3E Read: "
-"%.8e3E"
-msgstr ""
-#: ../lib/vector/diglib/test.c:104
-#, c-format
-msgid ""
-"Error in read/write portable off_t, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:119
-#, c-format
-msgid ""
-"Error in read/write portable long, byte_order = %d Written: %lu Read: %lu"
-msgstr ""
-#: ../lib/vector/diglib/test.c:134
-#, c-format
-msgid "Error in read/write portable int, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:150
-#, c-format
-msgid ""
-"Error in read/write portable short, byte_order = %d Written: %d Read: %d"
-msgstr ""
-#: ../lib/vector/diglib/test.c:165
-#, c-format
-msgid "Error in read/write portable char, byte_order = %d Written: %d Read: %d"
-msgstr ""
#: ../lib/vector/diglib/plus_struct.c:523
#, c-format
msgid ""
@@ -6226,139 +5909,15 @@
"rebuild topology."
msgstr ""
-#: ../lib/vector/diglib/frmt.c:45 ../lib/vector/diglib/frmt.c:70
-#, fuzzy, c-format
-msgid "Vector format not recognized: %s"
-#: ../lib/vector/diglib/frmt.c:79 ../lib/vector/diglib/frmt.c:88
-#, fuzzy, c-format
-msgid "Vector format '%s' not supported"
-#: ../lib/vector/diglib/frmt.c:97
-#, c-format
-msgid "Format definition is not correct: %s"
+#: ../lib/vector/diglib/plus_struct.c:563 ../lib/vector/diglib/portable.c:208
+#: ../lib/vector/diglib/portable.c:241 ../lib/vector/diglib/portable.c:683
+msgid "Vector exceeds supported file size limit"
msgstr ""
-#: ../lib/vector/diglib/file.c:159
-msgid "Writing to file loaded to memory not supported"
-msgstr ""
-#: ../lib/vector/diglib/file.c:197
-#, fuzzy
-msgid "Unable to load file to memory, file not open"
-#: ../lib/vector/diglib/file.c:212
-msgid "Vector memory mode not supported, using 'AUTO'"
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:98 ../lib/vector/diglib/spindex_rw.c:106
-#, fuzzy
-msgid "Topology file must be written before spatial index file"
-#: ../lib/vector/diglib/spindex_rw.c:302
-#, c-format
-msgid ""
-"This version of GRASS (%d.%d) is too old to read this spatial index format. "
-"Try to rebuild topology or upgrade GRASS to at least version %d."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:308
-#, c-format
-msgid ""
-"Your GRASS version does not fully support spatial index format %d.%d of the "
-"vector. Consider to rebuild topology or upgrade GRASS."
-msgstr ""
-#: ../lib/vector/diglib/spindex_rw.c:317
-#, c-format
-msgid ""
-"Spatial index format version %d.%d is not supported by this release. Please "
-"rebuild topology."
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:217 ../lib/vector/diglib/plus_area.c:719
-#, c-format
-msgid "Line %d already has area/isle %d to left"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:227 ../lib/vector/diglib/plus_area.c:727
-#, c-format
-msgid "Line %d already has area/isle %d to right"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:281
-msgid "Isle already registered in area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:315
-msgid "Attempt to delete isle from dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:332
-#, c-format
-msgid "Attempt to delete not registered isle %d from area %d"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:371
-msgid "Attempt to delete dead area"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:412
-#, c-format
-msgid "Dead centroid %d registered for area (bug in the vector library)"
-msgstr ""
-#: ../lib/vector/diglib/plus_area.c:437
-#, fuzzy, c-format
-msgid "Attempt to delete area %d info from dead isle %d"
-#: ../lib/vector/diglib/plus_area.c:787
-#, fuzzy, c-format
-msgid "Attempt to delete isle %d info from dead area %d"
#: ../lib/vector/diglib/struct_alloc.c:491
msgid "Out of memmory"
msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:40
-msgid ""
-"\n"
-"++ Running basic unit tests ++"
-msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:48
-msgid ""
-"\n"
-"-- Basic rtree unit tests failure --"
-msgstr ""
-#: ../lib/vector/rtree/test_suite/test_basics.c:50
-msgid ""
-"\n"
-"-- Basic rtree unit tests finished successfully --"
-msgstr ""
-#: ../lib/vector/neta/spanningtree.c:104
-msgid "Computing minimum spanning tree..."
-msgstr ""
-#: ../lib/vector/neta/flow.c:310 ../lib/vector/Vlib/net.c:444
-#: ../lib/vector/Vlib/graph.c:105
-msgid "GngFlatten error"
-msgstr ""
-#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
-#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
-#, fuzzy, c-format
-msgid "Unable to open select cursor: %s"
#: ../lib/vector/neta/utils.c:195
#, fuzzy, c-format
msgid "Point %d is not connected!"
@@ -6383,33 +5942,39 @@
msgid "Problem loading category values"
-#: ../lib/vector/Vlib/snap.c:213
-msgid "Snap vertices Pass 1: select points"
+#: ../lib/vector/neta/spanningtree.c:104
+msgid "Computing minimum spanning tree..."
msgstr ""
-#: ../lib/vector/Vlib/snap.c:267
-msgid "Snap vertices Pass 2: assign anchor vertices"
+#: ../lib/vector/neta/timetables.c:46 ../lib/vector/neta/timetables.c:203
+#: ../lib/vector/neta/timetables.c:244 ../lib/vector/neta/timetables.c:286
+#, fuzzy, c-format
+msgid "Unable to open select cursor: %s"
+#: ../lib/vector/neta/flow.c:310 ../lib/vector/Vlib/graph.c:105
+#: ../lib/vector/Vlib/net_build.c:661 ../lib/vector/Vlib/net_build.c:1064
+msgid "GngFlatten error"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:336
-msgid "Snap vertices Pass 3: snap to assigned points"
+#: ../lib/vector/rtree/test_suite/test_basics.c:40
+msgid ""
+"\n"
+"++ Running basic unit tests ++"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:518
-#, c-format
-msgid "Snapped vertices: %d"
+#: ../lib/vector/rtree/test_suite/test_basics.c:48
+msgid ""
+"\n"
+"-- Basic rtree unit tests failure --"
msgstr ""
-#: ../lib/vector/Vlib/snap.c:519
-#, fuzzy, c-format
-msgid "New vertices: %d"
+#: ../lib/vector/rtree/test_suite/test_basics.c:50
+msgid ""
+"\n"
+"-- Basic rtree unit tests finished successfully --"
+msgstr ""
-#: ../lib/vector/Vlib/snap.c:546
-#, fuzzy
-msgid "Reading features..."
#: ../lib/vector/Vlib/intersect.c:127
msgid "3D not supported by Vect_segment_intersection()"
msgstr ""
@@ -6429,7 +5994,7 @@
msgid "Error while adding point to array. Out of memory"
msgstr ""
-#: ../lib/vector/Vlib/map.c:106 ../lib/vector/Vlib/map.c:251
+#: ../lib/vector/Vlib/map.c:106 ../lib/vector/Vlib/map.c:253
msgid "Vector map name is not SQL compliant"
msgstr ""
@@ -6438,7 +6003,7 @@
msgid "Unable to find vector map <%s> in <%s>"
-#: ../lib/vector/Vlib/map.c:122 ../lib/vector/Vlib/map.c:255
+#: ../lib/vector/Vlib/map.c:122 ../lib/vector/Vlib/map.c:257
#: ../lib/vector/Vlib/open.c:812
#, c-format
msgid "Vector map <%s> already exists and will be overwritten"
@@ -6450,281 +6015,400 @@
msgid "Unable to delete vector map <%s>"
-#: ../lib/vector/Vlib/map.c:146 ../lib/vector/Vlib/map.c:273
+#: ../lib/vector/Vlib/map.c:146 ../lib/vector/Vlib/map.c:275
#, fuzzy, c-format
msgid "Unable to copy vector map <%s> to <%s>"
-#: ../lib/vector/Vlib/map.c:195 ../lib/vector/Vlib/map.c:322
+#: ../lib/vector/Vlib/map.c:197 ../lib/vector/Vlib/map.c:325
#: ../lib/vector/Vlib/copy.c:620 ../lib/vector/Vlib/copy.c:767
#, fuzzy, c-format
msgid "Unable to copy table <%s>"
-#: ../lib/vector/Vlib/map.c:211 ../lib/vector/Vlib/map.c:351
+#: ../lib/vector/Vlib/map.c:213 ../lib/vector/Vlib/map.c:354
#: ../lib/vector/Vlib/copy.c:633
#, c-format
msgid "Unable to create index for table <%s>, key <%s>"
msgstr ""
-#: ../lib/vector/Vlib/map.c:336 ../lib/vector/Vlib/map.c:461
+#: ../lib/vector/Vlib/map.c:339 ../lib/vector/Vlib/map.c:470
#, fuzzy, c-format
msgid "Unable to delete table <%s>"
-#: ../lib/vector/Vlib/map.c:407
+#: ../lib/vector/Vlib/map.c:410
#, c-format
msgid "Ignoring invalid mapset: %s"
msgstr ""
-#: ../lib/vector/Vlib/map.c:412
+#: ../lib/vector/Vlib/map.c:415
#, fuzzy, c-format
msgid "Invalid vector map name <%s>"
-#: ../lib/vector/Vlib/map.c:422
+#: ../lib/vector/Vlib/map.c:425
#, fuzzy, c-format
msgid "Unable to open header file for vector map <%s>"
-#: ../lib/vector/Vlib/map.c:451
+#: ../lib/vector/Vlib/map.c:457
#, fuzzy, c-format
msgid "Unable to find table <%s> linked to vector map <%s>"
-#: ../lib/vector/Vlib/map.c:468
+#: ../lib/vector/Vlib/map.c:480
#, fuzzy, c-format
msgid "Table <%s> linked to vector map <%s> does not exist"
-#: ../lib/vector/Vlib/map.c:482
+#: ../lib/vector/Vlib/map.c:494
#, fuzzy, c-format
msgid "Unable to open directory '%s'"
-#: ../lib/vector/Vlib/map.c:496
+#: ../lib/vector/Vlib/map.c:508
#, fuzzy, c-format
msgid "Unable to delete file '%s'"
-#: ../lib/vector/Vlib/map.c:510
+#: ../lib/vector/Vlib/map.c:522
#, fuzzy, c-format
msgid "Unable to rename directory '%s' to '%s'"
-#: ../lib/vector/Vlib/map.c:519
+#: ../lib/vector/Vlib/map.c:531
#, fuzzy, c-format
msgid "Unable to remove directory '%s'"
-#: ../lib/vector/Vlib/read_nat.c:144 ../lib/vector/Vlib/write_nat.c:265
-#: ../lib/vector/Vlib/write_nat.c:362 ../lib/vector/Vlib/write_nat.c:595
-#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:376
-#: ../lib/vector/Vlib/write_pg.c:391 ../lib/vector/Vlib/box.c:213
-#: ../lib/vector/Vlib/read.c:173 ../lib/vector/Vlib/write_sfa.c:155
-#: ../lib/vector/Vlib/write_sfa.c:204 ../lib/vector/Vlib/read_pg.c:331
-#: ../lib/vector/Vlib/read_sfa.c:50 ../lib/vector/Vlib/write.c:233
-#: ../lib/vector/Vlib/write.c:278 ../lib/vector/Vlib/write.c:319
-#, fuzzy, c-format
-msgid "Attempt to access feature with invalid id (%d)"
+#: ../lib/vector/Vlib/area.c:50
+#, fuzzy
+msgid "Attempt to read points of nonexistent area"
-#: ../lib/vector/Vlib/read_nat.c:150 ../lib/vector/Vlib/write_nat.c:271
-#: ../lib/vector/Vlib/write_nat.c:601 ../lib/vector/Vlib/write_pg.c:242
-#: ../lib/vector/Vlib/write_pg.c:397 ../lib/vector/Vlib/write_pg.c:2572
-#: ../lib/vector/Vlib/write_pg.c:2669 ../lib/vector/Vlib/read_pg.c:337
-#: ../lib/vector/Vlib/read_sfa.c:56
-#, fuzzy, c-format
-msgid "Attempt to access dead feature %d"
+#: ../lib/vector/Vlib/area.c:81
+#, fuzzy
+msgid "Attempt to read points of nonexistent isle"
-#: ../lib/vector/Vlib/open_pg.c:85 ../lib/vector/Vlib/open_pg.c:232
-#: ../lib/vector/Vlib/write_pg.c:1058
-msgid "Connection string not defined"
-msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:90 ../lib/vector/Vlib/open_pg.c:237
-#: ../lib/vector/Vlib/write_pg.c:1063 ../lib/vector/Vlib/write_pg.c:1204
-#: ../lib/vector/Vlib/write_pg.c:1354
-#, fuzzy
-msgid "PostGIS feature table not defined"
-#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
-#, fuzzy
-msgid "No feature tables found in database."
-#: ../lib/vector/Vlib/open_pg.c:133
-#, fuzzy, c-format
-msgid "Feature table <%s> not found in 'geometry_columns'"
-#: ../lib/vector/Vlib/open_pg.c:143 ../lib/vector/Vlib/open_pg.c:200
-#: ../lib/vector/Vlib/open_pg.c:299 ../lib/vector/Vlib/open_pg.c:349
-#: ../lib/vector/Vlib/write_pg.c:124 ../lib/vector/Vlib/write_pg.c:158
-#: ../lib/vector/Vlib/write_pg.c:197 ../lib/vector/Vlib/write_pg.c:289
-#: ../lib/vector/Vlib/write_pg.c:349 ../lib/vector/Vlib/write_pg.c:467
-#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:466
-#: ../lib/vector/Vlib/write_sfa.c:299 ../lib/vector/Vlib/build_sfa.c:718
-#: ../lib/vector/Vlib/simple_features.c:336 ../lib/vector/Vlib/close.c:275
+#: ../lib/vector/Vlib/area.c:94 ../lib/vector/Vlib/area.c:495
+#: ../lib/vector/Vlib/close.c:275 ../lib/vector/Vlib/write_pg.c:124
+#: ../lib/vector/Vlib/write_pg.c:158 ../lib/vector/Vlib/write_pg.c:197
+#: ../lib/vector/Vlib/write_pg.c:289 ../lib/vector/Vlib/write_pg.c:349
+#: ../lib/vector/Vlib/write_pg.c:467 ../lib/vector/Vlib/build_sfa.c:718
+#: ../lib/vector/Vlib/build_pg.c:117 ../lib/vector/Vlib/write_sfa.c:299
#: ../lib/vector/Vlib/header_finfo.c:47 ../lib/vector/Vlib/header_finfo.c:86
#: ../lib/vector/Vlib/header_finfo.c:123 ../lib/vector/Vlib/header_finfo.c:171
-#: ../lib/vector/Vlib/read_pg.c:91 ../lib/vector/Vlib/read_pg.c:214
-#: ../lib/vector/Vlib/read_pg.c:298 ../lib/vector/Vlib/read_pg.c:416
-#: ../lib/vector/Vlib/close_pg.c:96 ../lib/vector/Vlib/close_pg.c:144
-#: ../lib/vector/Vlib/copy.c:404 ../lib/vector/Vlib/build_pg.c:117
#: ../lib/vector/Vlib/rewind_pg.c:56 ../lib/vector/Vlib/rewind_pg.c:81
+#: ../lib/vector/Vlib/simple_features.c:336 ../lib/vector/Vlib/close_pg.c:96
+#: ../lib/vector/Vlib/close_pg.c:144 ../lib/vector/Vlib/read_pg.c:91
+#: ../lib/vector/Vlib/read_pg.c:214 ../lib/vector/Vlib/read_pg.c:298
+#: ../lib/vector/Vlib/read_pg.c:416 ../lib/vector/Vlib/copy.c:404
+#: ../lib/vector/Vlib/open_pg.c:143 ../lib/vector/Vlib/open_pg.c:200
+#: ../lib/vector/Vlib/open_pg.c:299 ../lib/vector/Vlib/open_pg.c:349
msgid "GRASS is not compiled with PostgreSQL support"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:181
-msgid "Topology schema not found."
-msgstr ""
+#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
+#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
+#, fuzzy, c-format
+msgid "Attempt to read topo for dead area (%d)"
+msgstr "임시파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/open_pg.c:193 ../lib/vector/Vlib/open_ogr.c:145
+#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
#, fuzzy, c-format
-msgid "Unable to open feature index file for vector map <%s>"
+msgid "Attempt to read topo for dead isle (%d)"
-#: ../lib/vector/Vlib/open_pg.c:273
+#: ../lib/vector/Vlib/write_ogr.c:96 ../lib/vector/Vlib/write_pg.c:188
+#: ../lib/vector/Vlib/write_pg.c:250 ../lib/vector/Vlib/write_sfa.c:161
+#, fuzzy
+msgid "Unable to rewrite feature (incompatible feature types)"
+#: ../lib/vector/Vlib/write_ogr.c:129 ../lib/vector/Vlib/open_ogr.c:65
+msgid "OGR layer not defined"
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:134
#, fuzzy, c-format
-msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
+msgid "Invalid offset (%d)"
-#: ../lib/vector/Vlib/open_pg.c:276
+#: ../lib/vector/Vlib/write_ogr.c:140 ../lib/vector/Vlib/write_pg.c:342
+#, fuzzy
+msgid "Unable to delete feature"
+#: ../lib/vector/Vlib/write_ogr.c:192 ../lib/vector/Vlib/write_pg.c:2888
+#: ../lib/vector/Vlib/ascii.c:404 ../lib/db/dbmi_client/copy_tab.c:107
+#: ../lib/db/dbmi_client/copy_tab.c:127 ../lib/db/dbmi_client/db.c:41
#, fuzzy, c-format
-msgid "Unable to delete PostGIS layer <%s>"
+msgid "Unable to start driver <%s>"
-#: ../lib/vector/Vlib/open_pg.c:282
+#: ../lib/vector/Vlib/write_ogr.c:210 ../lib/db/dbmi_client/copy_tab.c:218
+#: ../lib/db/dbmi_client/copy_tab.c:295 ../lib/db/dbmi_client/table.c:110
+#: ../lib/sites/sites.c:290
#, fuzzy, c-format
-msgid "PostGIS layer <%s.%s> already exists in database '%s'"
+msgid "Unable to open select cursor: '%s'"
-#: ../lib/vector/Vlib/open_pg.c:390
-#, fuzzy
-msgid "No key column detected."
+#: ../lib/vector/Vlib/write_ogr.c:239
+#, fuzzy, c-format
+msgid "Creating field <%s> failed"
-#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
+#: ../lib/vector/Vlib/write_ogr.c:304 ../lib/vector/Vlib/write_pg.c:1089
#, c-format
-msgid "Execution failed: %s"
+msgid "Unsupported geometry type (%d)"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:476
+#: ../lib/vector/Vlib/write_ogr.c:326
+#, fuzzy, c-format
+msgid "Unable to create OGR layer <%s> in '%s'"
+#: ../lib/vector/Vlib/write_ogr.c:338 ../lib/vector/Vlib/write_pg.c:1102
#, c-format
-msgid "PostGIS topology schema <%s> dropped"
+msgid "More layers defined, using driver <%s> and database <%s>"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:510
-msgid "Connection to PostgreSQL database failed."
+#: ../lib/vector/Vlib/write_ogr.c:344 ../lib/vector/Vlib/write_pg.c:1106
+msgid "Database connection not defined. Unable to write attributes."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:516
-#, fuzzy
-msgid "Unable to get database name"
+#: ../lib/vector/Vlib/write_ogr.c:408 ../lib/vector/Vlib/write_pg.c:1227
+#: ../lib/vector/Vlib/write_pg.c:1384
+#, c-format
+msgid "No category defined for layer %d"
+msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:521
+#: ../lib/vector/Vlib/write_ogr.c:410 ../lib/vector/Vlib/write_pg.c:1229
+#: ../lib/vector/Vlib/write_pg.c:1386
#, c-format
-msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
+msgid "Feature has more categories, using category %d (from layer %d)"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:530
+#: ../lib/vector/Vlib/write_ogr.c:424
+msgid "Feature is not a point. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:432
+msgid "Feature is not a line. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:439 ../lib/vector/Vlib/write_pg.c:1256
+msgid "Feature is not a polygon. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:446
+msgid "Feature is not a face. Skipping."
+msgstr ""
+#: ../lib/vector/Vlib/write_ogr.c:452
#, fuzzy, c-format
-msgid "PostGIS Topology extension not found in the database <%s>"
+msgid "Unsupported feature type (%d)"
+msgstr "알려지지 않은 벡터타입입니다"
-#: ../lib/vector/Vlib/open_pg.c:617
-msgid "Empty bounding box"
+#: ../lib/vector/Vlib/write_ogr.c:471
+msgid "Boundary is not closed. Feature skipped."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:718
+#: ../lib/vector/Vlib/write_ogr.c:500
+#, fuzzy
+msgid "Unable to writes feature attributes"
+#: ../lib/vector/Vlib/write_ogr.c:565
#, c-format
-msgid "Inconsistency in topology: unable to read node %d"
+msgid "Feature without category of layer %d"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:784
+#: ../lib/vector/Vlib/write_ogr.c:579 ../lib/vector/Vlib/write_pg.c:1993
#, fuzzy, c-format
-msgid "Inconsistency in topology: node %d - unexpected feature type %d"
-msgstr "알려지지 않은 벡터타입입니다"
+msgid "Unable to select attributes for category %d"
-#: ../lib/vector/Vlib/open_pg.c:954
+#: ../lib/vector/Vlib/write_ogr.c:585 ../lib/vector/Vlib/write_pg.c:1997
+#: ../lib/db/dbmi_client/copy_tab.c:314
#, fuzzy, c-format
-msgid "Area %d without boundary detected"
+msgid "Unable to fetch data from table <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1012
+#: ../lib/vector/Vlib/write_ogr.c:591 ../lib/vector/Vlib/write_pg.c:2002
#, c-format
-msgid "Isle %d without boundary detected"
+msgid "No database record for category %d, no attributes will be written"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1079
-#, fuzzy
-msgid "Unable to get map bounding box from topology"
+#: ../lib/vector/Vlib/write_ogr.c:624
+#, fuzzy, c-format
+msgid "Unable to create field <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1086
+#: ../lib/vector/Vlib/write_ogr.c:653 ../lib/vector/Vlib/write_pg.c:2062
#, fuzzy, c-format
+msgid "Unsupported column type %d"
+#: ../lib/vector/Vlib/dgraph.c:432
msgid ""
-"Unable to parse map bounding box:\n"
-"%s"
+"Trying to add more edges to the planar_graph than the initial allocation "
+"size allows"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/build.c:37
+#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/write.c:56
+#: ../lib/vector/Vlib/write.c:62 ../lib/vector/Vlib/read.c:32
+#: ../lib/vector/Vlib/open.c:59
+msgid "Requested format is not compiled in this version"
+msgstr ""
+#: ../lib/vector/Vlib/close.c:91 ../lib/sites/sites.c:394
+#, fuzzy, c-format
+msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/open_pg.c:1110
+#: ../lib/vector/Vlib/close.c:108
+#, fuzzy
+msgid "Copying features failed"
+#: ../lib/vector/Vlib/close.c:141
+#, fuzzy, c-format
+msgid "Unable to open %s file"
+#: ../lib/vector/Vlib/close.c:226
+#, fuzzy, c-format
+msgid "Unable to close vector <%s>"
+#: ../lib/vector/Vlib/close.c:257
#, c-format
-msgid "Different number of nodes detected (%d, %d)"
+msgid "Invalid request for writing frmt file - map format is %d"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1138 ../lib/vector/Vlib/open_pg.c:1160
-#, c-format
-msgid "Different number of areas detected (%d, %d)"
+#: ../lib/vector/Vlib/close.c:289
+#, fuzzy, c-format
+msgid "Link to vector map <%s> created"
+#: ../lib/vector/Vlib/field.c:91
+msgid "Layer number must be 1 or greater"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1331
-msgid "To be implemented: isles not attached in Topo-Geo-only mode"
+#: ../lib/vector/Vlib/field.c:96
+#, fuzzy
+msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
+#: ../lib/vector/Vlib/field.c:103
+#, fuzzy
+msgid "Unable to add attribute link"
+#: ../lib/vector/Vlib/field.c:109
+#, fuzzy
+msgid "Unable to write attribute links"
+#: ../lib/vector/Vlib/field.c:154
+#, fuzzy
+msgid "Unable to write database links"
+#: ../lib/vector/Vlib/field.c:178
+msgid "Database connection not defined. Skipping."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1436 ../lib/vector/Vlib/build_pg.c:212
-#, c-format
-msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+#: ../lib/vector/Vlib/field.c:185
+msgid ""
+"More DB links defined for input vector map. Using only first DB link for "
+"output."
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1520
+#: ../lib/vector/Vlib/field.c:261
#, c-format
-msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgid "Layer number %d or name <%s> already exists"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1565
+#: ../lib/vector/Vlib/field.c:345
#, c-format
-msgid "Inconsistency in topology: number of lines %d (should be %d)"
+msgid ""
+"Default driver / database set to:\n"
+"driver: %s\n"
+"database: %s"
msgstr ""
-#: ../lib/vector/Vlib/open_pg.c:1619
-#, c-format
-msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+#: ../lib/vector/Vlib/field.c:352
+msgid "Default driver is not set"
msgstr ""
-#: ../lib/vector/Vlib/array.c:96
+#: ../lib/vector/Vlib/field.c:355
+msgid "Default database is not set"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:412
#, c-format
-msgid "%d errors in category string"
+msgid "Requested dblink %d, maximum link number %d"
msgstr ""
-#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
-msgid "Mixed area and other type requested for vector array"
+#: ../lib/vector/Vlib/field.c:599 ../lib/vector/Vlib/field.c:607
+#, fuzzy, c-format
+msgid "Error in rule on row %d in <%s>"
+#: ../lib/vector/Vlib/field.c:675 ../lib/vector/Vlib/open_ogr.c:77
+#, fuzzy, c-format
+msgid "Unable to open OGR data source '%s'"
+#: ../lib/vector/Vlib/field.c:692
+#, fuzzy, c-format
+msgid "Unable to open OGR layer <%s>"
+#: ../lib/vector/Vlib/field.c:719
+#, fuzzy
+msgid "Unable to open OGR DBMI driver"
+#: ../lib/vector/Vlib/field.c:758
+msgid ""
+"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
+"available in OGR DB table"
msgstr ""
-#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
-#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
-msgid "Not enough space in vector array"
+#: ../lib/vector/Vlib/field.c:825
+#, c-format
+msgid ""
+"Feature table <%s> has no primary key defined. Unable to define DB links."
msgstr ""
-#: ../lib/vector/Vlib/array.c:292
+#: ../lib/vector/Vlib/field.c:845
+msgid "GRASS not compiled with PostgreSQL support"
+msgstr ""
+#: ../lib/vector/Vlib/field.c:877
+#, fuzzy
+msgid "Unknown vector map format"
+#: ../lib/vector/Vlib/field.c:911
#, fuzzy, c-format
-msgid "Unable to select record from table <%s> (key %s, where %s)"
-msgstr "Datum %s 테이블파일을 열 수 없습니다"
+msgid "Unable to create database definition file for vector map <%s>"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/field.c:1006
+msgid "Bug: attempt to update map which is not in current mapset"
+msgstr ""
+#: ../lib/vector/Vlib/constraint.c:150
+msgid "Layer constraint ignored for non-native vector formats"
+msgstr ""
#: ../lib/vector/Vlib/legal_vname.c:43
#, c-format
msgid "Illegal vector map name <%s>. May not contain '.' or 'NULL'."
@@ -6756,115 +6440,79 @@
msgid "Output vector map <%s> is used as input"
msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:368
-#, fuzzy, c-format
-msgid "Attempt to access alive feature %d"
-#: ../lib/vector/Vlib/write_nat.c:510 ../lib/vector/Vlib/write_nat.c:546
-#, c-format
-msgid "%s: Area %d does not exist"
+#: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
+#: ../lib/vector/Vlib/build_sfa.c:629
+msgid "Registering primitives..."
msgstr ""
-#: ../lib/vector/Vlib/write_nat.c:700
-#, fuzzy, c-format
-msgid "Attempt to access dead area %d"
-#: ../lib/vector/Vlib/merge_lines.c:240
-#, c-format
-msgid "%d boundaries merged"
-msgstr ""
-#: ../lib/vector/Vlib/merge_lines.c:241
-#, c-format
-msgid "%d new boundaries"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:117
-msgid "Building graph..."
-msgstr ""
-#: ../lib/vector/Vlib/net.c:159
+#: ../lib/vector/Vlib/build_nat.c:84
#, fuzzy
-msgid "Unable to build network graph"
+msgid "Unable to read vector map"
-#: ../lib/vector/Vlib/net.c:165
-msgid "Forward costs column not specified"
-msgstr ""
+#: ../lib/vector/Vlib/build_nat.c:117 ../lib/vector/Vlib/build_sfa.c:385
+#: ../lib/vector/Vlib/build_sfa.c:661
+#, c-format
+msgid "One primitive registered"
+msgid_plural "%d primitives registered"
+msgstr[0] ""
+msgstr[1] ""
-#: ../lib/vector/Vlib/net.c:172
-msgid "Arc field < 1"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:186 ../lib/vector/Vlib/net.c:203
-#: ../lib/vector/Vlib/net.c:363 ../lib/vector/Vlib/ascii.c:730
-#, fuzzy, c-format
-msgid "Column <%s> not found in table <%s>"
-#: ../lib/vector/Vlib/net.c:192 ../lib/vector/Vlib/net.c:209
-#: ../lib/vector/Vlib/net.c:369
+#: ../lib/vector/Vlib/build_nat.c:118 ../lib/vector/Vlib/build_sfa.c:386
+#: ../lib/vector/Vlib/build_sfa.c:662
#, c-format
-msgid "Data type of column <%s> not supported (must be numeric)"
-msgstr ""
+msgid "One vertex registered"
+msgid_plural "%d vertices registered"
+msgstr[0] ""
+msgstr[1] ""
-#: ../lib/vector/Vlib/net.c:222
-msgid "Registering arcs..."
+#: ../lib/vector/Vlib/build_nat.c:129
+msgid "Building areas..."
msgstr ""
-#: ../lib/vector/Vlib/net.c:251
+#: ../lib/vector/Vlib/build_nat.c:152
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, forward/both direction(s)) not found "
-"(forward/both direction(s) of line skipped)"
-msgstr ""
+msgid "One area built"
+msgid_plural "%d areas built"
+msgstr[0] ""
+msgstr[1] ""
-#: ../lib/vector/Vlib/net.c:270
+#: ../lib/vector/Vlib/build_nat.c:153
#, c-format
-msgid ""
-"Database record for line %d (cat = %d, backword direction) not "
-"found(direction of line skipped)"
-msgstr ""
+msgid "One isle built"
+msgid_plural "%d isles built"
+msgstr[0] ""
+msgstr[1] ""
-#: ../lib/vector/Vlib/net.c:319
-#, fuzzy
-msgid "Cannot add network arc"
-#: ../lib/vector/Vlib/net.c:349
-msgid "Setting node costs..."
+#: ../lib/vector/Vlib/build_nat.c:162
+msgid "Attaching islands..."
msgstr ""
-#: ../lib/vector/Vlib/net.c:412
-#, c-format
-msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
+#: ../lib/vector/Vlib/build_nat.c:178
+msgid "Attaching centroids..."
msgstr ""
-#: ../lib/vector/Vlib/net.c:441
-msgid "Flattening the graph..."
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:236 ../lib/vector/Vlib/write_pg.c:376
+#: ../lib/vector/Vlib/write_pg.c:391 ../lib/vector/Vlib/read_sfa.c:50
+#: ../lib/vector/Vlib/write_nat.c:265 ../lib/vector/Vlib/write_nat.c:362
+#: ../lib/vector/Vlib/write_nat.c:595 ../lib/vector/Vlib/read_nat.c:144
+#: ../lib/vector/Vlib/write_sfa.c:155 ../lib/vector/Vlib/write_sfa.c:204
+#: ../lib/vector/Vlib/write.c:233 ../lib/vector/Vlib/write.c:278
+#: ../lib/vector/Vlib/write.c:319 ../lib/vector/Vlib/read.c:173
+#: ../lib/vector/Vlib/read_pg.c:331 ../lib/vector/Vlib/box.c:213
+#, fuzzy, c-format
+msgid "Attempt to access feature with invalid id (%d)"
-#: ../lib/vector/Vlib/net.c:450
-msgid "Graph was built"
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:242 ../lib/vector/Vlib/write_pg.c:397
+#: ../lib/vector/Vlib/write_pg.c:2572 ../lib/vector/Vlib/write_pg.c:2669
+#: ../lib/vector/Vlib/read_sfa.c:56 ../lib/vector/Vlib/write_nat.c:271
+#: ../lib/vector/Vlib/write_nat.c:601 ../lib/vector/Vlib/read_nat.c:150
+#: ../lib/vector/Vlib/read_pg.c:337
+#, fuzzy, c-format
+msgid "Attempt to access dead feature %d"
-#: ../lib/vector/Vlib/net.c:533 ../lib/vector/Vlib/graph.c:226
-#, c-format
-msgid "dglShortestPath error: %s"
-msgstr ""
-#: ../lib/vector/Vlib/net.c:633
-msgid "Wrong line direction in Vect_net_get_line_cost()"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:188 ../lib/vector/Vlib/write_pg.c:250
-#: ../lib/vector/Vlib/write_sfa.c:161 ../lib/vector/Vlib/write_ogr.c:96
-#, fuzzy
-msgid "Unable to rewrite feature (incompatible feature types)"
-msgstr "자동 MASK파일을 열 수 없습니다"
#: ../lib/vector/Vlib/write_pg.c:280
#, fuzzy, c-format
msgid "Unable to rewrite feature %d"
@@ -6880,11 +6528,6 @@
msgid "Invalid offset (%ld)"
-#: ../lib/vector/Vlib/write_pg.c:342 ../lib/vector/Vlib/write_ogr.c:140
-#, fuzzy
-msgid "Unable to delete feature"
#: ../lib/vector/Vlib/write_pg.c:443
#, fuzzy, c-format
msgid "Unable to delete feature (%s) %d"
@@ -6896,7 +6539,7 @@
msgstr ""
#: ../lib/vector/Vlib/write_pg.c:602 ../lib/vector/Vlib/write_pg.c:863
-#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/open.c:1351
+#: ../lib/vector/Vlib/build_pg.c:411 ../lib/vector/Vlib/open.c:1354
#, fuzzy
msgid "Unable to open PG file"
@@ -6936,20 +6579,18 @@
msgid "Adding new topology column <%s>..."
-#: ../lib/vector/Vlib/write_pg.c:1089 ../lib/vector/Vlib/write_ogr.c:304
-#, c-format
-msgid "Unsupported geometry type (%d)"
+#: ../lib/vector/Vlib/write_pg.c:1058 ../lib/vector/Vlib/open_pg.c:85
+#: ../lib/vector/Vlib/open_pg.c:232
+msgid "Connection string not defined"
msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1102 ../lib/vector/Vlib/write_ogr.c:338
-#, c-format
-msgid "More layers defined, using driver <%s> and database <%s>"
-msgstr ""
+#: ../lib/vector/Vlib/write_pg.c:1063 ../lib/vector/Vlib/write_pg.c:1204
+#: ../lib/vector/Vlib/write_pg.c:1354 ../lib/vector/Vlib/open_pg.c:90
+#: ../lib/vector/Vlib/open_pg.c:237
+#, fuzzy
+msgid "PostGIS feature table not defined"
-#: ../lib/vector/Vlib/write_pg.c:1106 ../lib/vector/Vlib/write_ogr.c:344
-msgid "Database connection not defined. Unable to write attributes."
-msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1113
#, fuzzy
msgid "Unable to create new PostGIS feature table"
@@ -6960,18 +6601,6 @@
msgid "Unable to create new PostGIS topology schema"
-#: ../lib/vector/Vlib/write_pg.c:1227 ../lib/vector/Vlib/write_pg.c:1384
-#: ../lib/vector/Vlib/write_ogr.c:408
-#, c-format
-msgid "No category defined for layer %d"
-msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1229 ../lib/vector/Vlib/write_pg.c:1386
-#: ../lib/vector/Vlib/write_ogr.c:410
-#, c-format
-msgid "Feature has more categories, using category %d (from layer %d)"
-msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1240
#, fuzzy, c-format
msgid "Point skipped (output feature type: %s)"
@@ -6987,10 +6616,6 @@
msgid "Boundary/centroid skipped (output feature type: %s)"
msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:1256 ../lib/vector/Vlib/write_ogr.c:439
-msgid "Feature is not a polygon. Skipping."
-msgstr ""
#: ../lib/vector/Vlib/write_pg.c:1262
#, fuzzy, c-format
msgid "Face skipped (output feature type: %s)"
@@ -7019,26 +6644,11 @@
msgid "Unable to insert topological element into PostGIS Topology schema"
-#: ../lib/vector/Vlib/write_pg.c:1993 ../lib/vector/Vlib/write_ogr.c:579
-#, fuzzy, c-format
-msgid "Unable to select attributes for category %d"
-#: ../lib/vector/Vlib/write_pg.c:2002 ../lib/vector/Vlib/write_ogr.c:591
-#, c-format
-msgid "No database record for category %d, no attributes will be written"
-msgstr ""
#: ../lib/vector/Vlib/write_pg.c:2028
#, c-format
msgid "FID column must be integer, column <%s> ignored!"
msgstr ""
-#: ../lib/vector/Vlib/write_pg.c:2062 ../lib/vector/Vlib/write_ogr.c:653
-#, fuzzy, c-format
-msgid "Unsupported column type %d"
#: ../lib/vector/Vlib/write_pg.c:2069
msgid "Invalid value for FID column: NULL"
msgstr ""
@@ -7092,409 +6702,237 @@
msgid "Unable to delete node %d"
-#: ../lib/vector/Vlib/field.c:91
-msgid "Layer number must be 1 or greater"
+#: ../lib/vector/Vlib/build.c:115
+msgid "Area of size = 0.0 (less than 4 vertices) ignored"
msgstr ""
-#: ../lib/vector/Vlib/field.c:96
-#, fuzzy
-msgid "Unable to add attribute link, vector map is not opened in WRITE mode"
-#: ../lib/vector/Vlib/field.c:103
-#, fuzzy
-msgid "Unable to add attribute link"
-#: ../lib/vector/Vlib/field.c:109
-#, fuzzy
-msgid "Unable to write attribute links"
-#: ../lib/vector/Vlib/field.c:154
-#, fuzzy
-msgid "Unable to write database links"
-#: ../lib/vector/Vlib/field.c:178
-msgid "Database connection not defined. Skipping."
+#: ../lib/vector/Vlib/build.c:131
+msgid "Unable to add area (map closed, topo saved)"
msgstr ""
-#: ../lib/vector/Vlib/field.c:185
-msgid ""
-"More DB links defined for input vector map. Using only first DB link for "
-"output."
+#: ../lib/vector/Vlib/build.c:139
+msgid "Unable to add isle (map closed, topo saved)"
msgstr ""
-#: ../lib/vector/Vlib/field.c:261
-#, c-format
-msgid "Layer number %d or name <%s> already exists"
+#: ../lib/vector/Vlib/build.c:149
+msgid "Area of size = 0.0 ignored"
msgstr ""
-#: ../lib/vector/Vlib/field.c:345
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+#: ../lib/vector/Vlib/build.c:197
+msgid "Request to find area outside nonexistent isle"
msgstr ""
-#: ../lib/vector/Vlib/field.c:352
-msgid "Default driver is not set"
+#: ../lib/vector/Vlib/build.c:338
+msgid "Larger bbox but smaller area!!!"
msgstr ""
-#: ../lib/vector/Vlib/field.c:355
-msgid "Default database is not set"
+#: ../lib/vector/Vlib/build.c:584
+msgid "Checking for topological errors..."
msgstr ""
-#: ../lib/vector/Vlib/field.c:412
-#, c-format
-msgid "Requested dblink %d, maximum link number %d"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:599 ../lib/vector/Vlib/field.c:607
+#: ../lib/vector/Vlib/build.c:619
#, fuzzy, c-format
-msgid "Error in rule on row %d in <%s>"
+msgid "Number of lines of length zero: %d"
-#: ../lib/vector/Vlib/field.c:675 ../lib/vector/Vlib/open_ogr.c:77
+#: ../lib/vector/Vlib/build.c:621
#, fuzzy, c-format
-msgid "Unable to open OGR data source '%s'"
+msgid "Number of boundaries of length zero: %d"
-#: ../lib/vector/Vlib/field.c:692
+#: ../lib/vector/Vlib/build.c:630
#, fuzzy, c-format
-msgid "Unable to open OGR layer <%s>"
+msgid "Number of boundary intersections: %d"
-#: ../lib/vector/Vlib/field.c:719
+#: ../lib/vector/Vlib/build.c:654
#, fuzzy
-msgid "Unable to open OGR DBMI driver"
+msgid "Skipping further checks because of incorrect boundaries"
-#: ../lib/vector/Vlib/field.c:758
-msgid ""
-"All FID tests failed. Neither 'FID' nor 'ogc_fid' nor 'ogr_fid' nor 'gid' "
-"available in OGR DB table"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:704
+#, fuzzy, c-format
+msgid "Number of redundant holes: %d"
-#: ../lib/vector/Vlib/field.c:825
-#, c-format
-msgid ""
-"Feature table <%s> has no primary key defined. Unable to define DB links."
-msgstr ""
+#: ../lib/vector/Vlib/build.c:843 ../lib/vector/Vlib/open.c:354
+#: ../lib/vector/Vlib/open.c:863
+#, fuzzy, c-format
+msgid "Unable to open spatial index file for vector map <%s>"
-#: ../lib/vector/Vlib/field.c:845
-msgid "GRASS not compiled with PostgreSQL support"
-msgstr ""
-#: ../lib/vector/Vlib/field.c:877
-#, fuzzy
-msgid "Unknown vector map format"
-#: ../lib/vector/Vlib/field.c:911
+#: ../lib/vector/Vlib/build.c:849
#, fuzzy, c-format
-msgid "Unable to create database definition file for vector map <%s>"
-#: ../lib/vector/Vlib/field.c:1006
-msgid "Bug: attempt to update map which is not in current mapset"
-msgstr ""
-#: ../lib/vector/Vlib/graph.c:138
-#, fuzzy
-msgid "Unable to add network arc"
+msgid "Building topology for vector map <%s>..."
-#: ../lib/vector/Vlib/build_nat.c:74 ../lib/vector/Vlib/build_sfa.c:339
-#: ../lib/vector/Vlib/build_sfa.c:629
-msgid "Registering primitives..."
+#: ../lib/vector/Vlib/build.c:867
+msgid "Topology was built"
msgstr ""
-#: ../lib/vector/Vlib/build_nat.c:84
-#, fuzzy
-msgid "Unable to read vector map"
+#: ../lib/vector/Vlib/build.c:878
+#, fuzzy, c-format
+msgid "Number of nodes: %d"
-#: ../lib/vector/Vlib/build_nat.c:117 ../lib/vector/Vlib/build_sfa.c:385
-#: ../lib/vector/Vlib/build_sfa.c:661
-#, c-format
-msgid "One primitive registered"
-msgid_plural "%d primitives registered"
-msgstr[0] ""
-msgstr[1] ""
+#: ../lib/vector/Vlib/build.c:879
+#, fuzzy, c-format
+msgid "Number of primitives: %d"
-#: ../lib/vector/Vlib/build_nat.c:118 ../lib/vector/Vlib/build_sfa.c:386
-#: ../lib/vector/Vlib/build_sfa.c:662
-#, c-format
-msgid "One vertex registered"
-msgid_plural "%d vertices registered"
-msgstr[0] ""
-msgstr[1] ""
+#: ../lib/vector/Vlib/build.c:880
+#, fuzzy, c-format
+msgid "Number of points: %d"
-#: ../lib/vector/Vlib/build_nat.c:129
-msgid "Building areas..."
-msgstr ""
+#: ../lib/vector/Vlib/build.c:881
+#, fuzzy, c-format
+msgid "Number of lines: %d"
-#: ../lib/vector/Vlib/build_nat.c:152
-#, c-format
-msgid "One area built"
-msgid_plural "%d areas built"
-msgstr[0] ""
-msgstr[1] ""
+#: ../lib/vector/Vlib/build.c:882
+#, fuzzy, c-format
+msgid "Number of boundaries: %d"
-#: ../lib/vector/Vlib/build_nat.c:153
-#, c-format
-msgid "One isle built"
-msgid_plural "%d isles built"
-msgstr[0] ""
-msgstr[1] ""
+#: ../lib/vector/Vlib/build.c:883
+#, fuzzy, c-format
+msgid "Number of centroids: %d"
-#: ../lib/vector/Vlib/build_nat.c:162
-msgid "Attaching islands..."
-msgstr ""
+#: ../lib/vector/Vlib/build.c:886
+#, fuzzy, c-format
+msgid "Number of faces: %d"
-#: ../lib/vector/Vlib/build_nat.c:178
-msgid "Attaching centroids..."
-msgstr ""
+#: ../lib/vector/Vlib/build.c:889
+#, fuzzy, c-format
+msgid "Number of kernels: %d"
-#: ../lib/vector/Vlib/open_nat.c:57
+#: ../lib/vector/Vlib/build.c:935
#, fuzzy, c-format
-msgid "Unable to open coor file for vector map <%s>"
+msgid "Number of areas: %d"
-#: ../lib/vector/Vlib/open_nat.c:154
-#, c-format
-msgid ""
-"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
-"excess)"
-msgstr ""
-#: ../lib/vector/Vlib/open_nat.c:158
-#, c-format
-msgid ""
-"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
-msgstr ""
-#: ../lib/vector/Vlib/box.c:228
+#: ../lib/vector/Vlib/build.c:936
#, fuzzy, c-format
-msgid "Unable to determine bbox for feature %d"
+msgid "Number of isles: %d"
-#: ../lib/vector/Vlib/box.c:277 ../lib/vector/Vlib/box.c:323
+#: ../lib/vector/Vlib/build.c:941
#, fuzzy, c-format
-msgid "Attempt to access area with invalid id (%d)"
+msgid "Number of areas without centroid: %d"
-#: ../lib/vector/Vlib/box.c:289
+#: ../lib/vector/Vlib/build.c:946
#, fuzzy, c-format
-msgid "Unable to determine bbox for area %d"
+msgid "Number of centroids exceeds number of areas: %d > %d"
-#: ../lib/vector/Vlib/box.c:335
+#: ../lib/vector/Vlib/build.c:950
#, fuzzy, c-format
-msgid "Unable to determine bbox for isle %d"
+msgid "Number of incorrect boundaries: %d"
-#: ../lib/vector/Vlib/cats.c:45
-msgid "Vect_new_cats_struct(): Out of memory"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:127
-#, c-format
-msgid "Too many categories (%d), unable to set cat %d (layer %d)"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:419
-#, c-format
-msgid "Unable to convert category string '%s' (from '%s') to category range"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
-msgid "Layer number must be > 0 for category constraints"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:585
-#, c-format
-msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:593
+#: ../lib/vector/Vlib/build.c:954
#, fuzzy, c-format
-msgid "Loading categories from table <%s>..."
+msgid "Number of centroids outside area: %d"
-#: ../lib/vector/Vlib/cats.c:605
+#: ../lib/vector/Vlib/build.c:958
#, fuzzy, c-format
-msgid "One category loaded"
-msgid_plural "%d categories loaded"
-msgstr[0] "카테고리 정보가 없습니다."
-msgstr[1] "카테고리 정보가 없습니다."
+msgid "Number of duplicate centroids: %d"
-#: ../lib/vector/Vlib/cats.c:627
-#, c-format
-msgid "No categories selected with '%s' option"
-msgstr ""
-#: ../lib/vector/Vlib/cats.c:637
-#, c-format
-msgid "%d errors in '%s' option"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:109 ../lib/vector/Vlib/remove_areas.c:274
-msgid "Area is composed of dead boundary"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:196 ../lib/vector/Vlib/remove_areas.c:598
-#, c-format
-msgid "%d areas of total size %g removed"
-msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:401
+#: ../lib/vector/Vlib/build.c:962
#, fuzzy
-msgid "Could not delete line from coor"
+msgid "Number of areas: -"
-#: ../lib/vector/Vlib/remove_areas.c:458 ../lib/vector/Vlib/remove_areas.c:492
+#: ../lib/vector/Vlib/build.c:963
#, fuzzy
-msgid "Failed to build new area"
+msgid "Number of isles: -"
-#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:496
-msgid "Dissolve with neighbour area: corrupt topology"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:992
+#, fuzzy, c-format
+msgid "Unable to create topo file for vector map <%s>"
-#: ../lib/vector/Vlib/remove_areas.c:477 ../lib/vector/Vlib/remove_areas.c:560
-msgid "Neighbor boundaries should be complete"
-msgstr ""
+#: ../lib/vector/Vlib/build.c:1000
+#, fuzzy
+msgid "Error writing out topo file"
-#: ../lib/vector/Vlib/remove_areas.c:541 ../lib/vector/Vlib/remove_areas.c:568
+#: ../lib/vector/Vlib/build.c:1189
#, fuzzy
-msgid "Failed to build new isle"
+msgid ""
+"Unable to build spatial index from topology, vector map is not opened at "
+"topology level 2"
-#: ../lib/vector/Vlib/remove_areas.c:546 ../lib/vector/Vlib/remove_areas.c:573
-msgid "Dissolve with outer isle: corrupt topology"
+#: ../lib/vector/Vlib/build.c:1212
+#, c-format
+msgid "%s is no longer supported"
msgstr ""
-#: ../lib/vector/Vlib/remove_areas.c:579
-#, fuzzy
-msgid "Area merging failed"
-#: ../lib/vector/Vlib/constraint.c:150
-msgid "Layer constraint ignored for non-native vector formats"
+#: ../lib/vector/Vlib/build.c:1235
+msgid "Spatial index not available, can not be saved"
msgstr ""
-#: ../lib/vector/Vlib/bridges.c:213
+#: ../lib/vector/Vlib/build.c:1248
#, fuzzy, c-format
-msgid "Removed lines: %d"
+msgid "Unable to create spatial index file for vector map <%s>"
-#: ../lib/vector/Vlib/bridges.c:214
-#, fuzzy, c-format
-msgid "Removed bridges: %d"
+#: ../lib/vector/Vlib/build.c:1257
+#, fuzzy
+msgid "Error writing out spatial index file"
-#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#: ../lib/vector/Vlib/read_sfa.c:90
#, fuzzy, c-format
-msgid "Unable to get feature geometry, fid %ld"
+msgid "Unable to construct centroid for area %d. Skipped."
-#: ../lib/vector/Vlib/read_ogr.c:344 ../lib/vector/Vlib/read_ogr.c:578
-#: ../lib/vector/Vlib/build_sfa.c:603
+#: ../lib/vector/Vlib/read_sfa.c:95
#, c-format
-msgid "OGR feature type %d not supported"
+msgid "Centroid %d: invalid area %d"
msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
-msgid "Feature without geometry. Skipped."
-msgstr ""
+#: ../lib/vector/Vlib/read_sfa.c:117 ../lib/vector/Vlib/read_pg.c:192
+#, fuzzy, c-format
+msgid "Unexpected feature type (%d) - should be (%d)"
-#: ../lib/vector/Vlib/read_ogr.c:390
-msgid "OGR feature without ID"
+#: ../lib/vector/Vlib/read_sfa.c:124 ../lib/vector/Vlib/write_sfa.c:127
+#: ../lib/vector/Vlib/write_sfa.c:170 ../lib/vector/Vlib/write_sfa.c:266
+msgid "GRASS is not compiled with OGR/PostgreSQL support"
msgstr ""
-#: ../lib/vector/Vlib/read_ogr.c:514
-#, c-format
-msgid "OGR feature type '%s' not supported"
+#: ../lib/vector/Vlib/dangles.c:148
+msgid "Changed"
msgstr ""
-#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
-#: ../lib/vector/Vlib/line.c:250
-msgid "Index out of range in"
+#: ../lib/vector/Vlib/dangles.c:151
+msgid "Removed"
msgstr ""
-#: ../lib/vector/Vlib/line.c:550
-msgid "Segment outside line, no segment created"
+#: ../lib/vector/Vlib/dangles.c:154
+msgid "Selected"
msgstr ""
-#: ../lib/vector/Vlib/rewind.c:29 ../lib/vector/Vlib/read.c:32
-#: ../lib/vector/Vlib/close.c:38 ../lib/vector/Vlib/write.c:56
-#: ../lib/vector/Vlib/write.c:62 ../lib/vector/Vlib/open.c:59
-#: ../lib/vector/Vlib/build.c:37
-msgid "Requested format is not compiled in this version"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:25 ../lib/vector/Vlib/write.c:30
-#: ../lib/vector/Vlib/write.c:36 ../lib/vector/Vlib/write.c:42
-#: ../lib/vector/Vlib/write.c:49
-msgid "for this format/level not supported"
-msgstr ""
-#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
-#: ../lib/vector/Vlib/read.c:168
-#, fuzzy
-msgid "Vector map is not open for reading"
-#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#: ../lib/vector/Vlib/dangles.c:262
#, fuzzy, c-format
-msgid "Unable to read feature %d from vector map <%s>"
+msgid "%s lines: %d"
-#: ../lib/vector/Vlib/area.c:50
-#, fuzzy
-msgid "Attempt to read points of nonexistent area"
-msgstr "임시파일을 열 수 없습니다"
-#: ../lib/vector/Vlib/area.c:81
-#, fuzzy
-msgid "Attempt to read points of nonexistent isle"
-#: ../lib/vector/Vlib/area.c:121 ../lib/vector/Vlib/area.c:153
-#: ../lib/vector/Vlib/area.c:219 ../lib/vector/Vlib/area.c:248
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead area (%d)"
-#: ../lib/vector/Vlib/area.c:189 ../lib/vector/Vlib/area.c:275
-#, fuzzy, c-format
-msgid "Attempt to read topo for dead isle (%d)"
-#: ../lib/vector/Vlib/write_sfa.c:113
-#, fuzzy
-msgid "Unable to calculate centroid for area"
-#: ../lib/vector/Vlib/write_sfa.c:127 ../lib/vector/Vlib/write_sfa.c:170
-#: ../lib/vector/Vlib/write_sfa.c:266 ../lib/vector/Vlib/read_sfa.c:124
-msgid "GRASS is not compiled with OGR/PostgreSQL support"
+#: ../lib/vector/Vlib/dangles.c:263
+#, c-format
+msgid "%s dangles: %d"
msgstr ""
-#: ../lib/vector/Vlib/write_sfa.c:212
-#, fuzzy
-msgid "Attempt to delete dead feature"
-#: ../lib/vector/Vlib/write_sfa.c:304
-#, fuzzy, c-format
-msgid "Unsupported vector map format (%d)"
#: ../lib/vector/Vlib/build_sfa.c:279 ../lib/vector/Vlib/build_sfa.c:546
#, fuzzy, c-format
msgid "Unable to calculate centroid for area %d"
@@ -7511,6 +6949,12 @@
msgid "Feature %d without geometry skipped"
+#: ../lib/vector/Vlib/build_sfa.c:603 ../lib/vector/Vlib/read_ogr.c:344
+#: ../lib/vector/Vlib/read_ogr.c:578
+#, c-format
+msgid "OGR feature type %d not supported"
+msgstr ""
#: ../lib/vector/Vlib/build_sfa.c:665
#, fuzzy, c-format
msgid "One feature without geometry skipped"
@@ -7527,134 +6971,18 @@
msgid "Feature index is built only for non-native formats. Nothing to dump."
msgstr ""
-#: ../lib/vector/Vlib/geos.c:52
-#, fuzzy
-msgid "vector map is not opened"
-#: ../lib/vector/Vlib/geos.c:55
-#, c-format
-msgid ""
-"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
-"vector map <%s>: %d)"
+#: ../lib/vector/Vlib/overlay.c:72
+msgid "unknown operator"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:60
-msgid "only native format supported"
+#: ../lib/vector/Vlib/overlay.c:124
+msgid "Overlay: line/boundary types not supported by AND operator"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:256
-#, fuzzy
-msgid "Attempt to read dead line"
-#: ../lib/vector/Vlib/geos.c:90
-#, c-format
-msgid "Vect_read_area_geos(): unable to read area id %d"
+#: ../lib/vector/Vlib/overlay.c:127
+msgid "Overlay: area x area types not supported by AND operator"
msgstr ""
-#: ../lib/vector/Vlib/geos.c:104
-#, c-format
-msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
-msgstr ""
-#: ../lib/vector/Vlib/geos.c:203
-#, fuzzy, c-format
-msgid "Unable to read line offset %ld"
-#: ../lib/vector/Vlib/geos.c:410
-#, fuzzy, c-format
-msgid "Attempt to read points of nonexistent area id %d"
-#: ../lib/vector/Vlib/geos.c:470
-#, fuzzy, c-format
-msgid "Unable to read feature id %d"
-#: ../lib/vector/Vlib/level_two.c:23
-#, fuzzy, c-format
-msgid "Vector map <%s> is not open at topological level"
-#: ../lib/vector/Vlib/level_two.c:284
-#, fuzzy, c-format
-msgid "Invalid node id: %d"
-#: ../lib/vector/Vlib/level_two.c:316
-#, fuzzy, c-format
-msgid "Nodes not available for line %d"
-#: ../lib/vector/Vlib/level_two.c:357
-#, fuzzy, c-format
-msgid "Areas not available for line %d"
-#: ../lib/vector/Vlib/level_two.c:362
-#, fuzzy, c-format
-msgid "Line %d is not a boundary"
-#: ../lib/vector/Vlib/level_two.c:445
-#, fuzzy, c-format
-msgid "Topology info not available for feature %d"
-#: ../lib/vector/Vlib/build_ogr.c:69
-msgid "Empty OGR layer, nothing to build"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:80 ../lib/vector/Vlib/build_pg.c:93
-#, c-format
-msgid "Feature table <%s> has no primary key defined"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:82
-msgid ""
-"Random read is not supported by OGR for this layer. Unable to build topology."
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:101
-#, c-format
-msgid "Using external data format '%s' (feature type '%s')"
-msgstr ""
-#: ../lib/vector/Vlib/build_ogr.c:132
-#, fuzzy, c-format
-msgid "Unable to open fidx file for write <%s>"
-#: ../lib/vector/Vlib/cindex.c:32
-msgid "Category index is not up to date"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:38
-msgid "Layer index out of range"
-msgstr ""
-#: ../lib/vector/Vlib/cindex.c:268
-#, fuzzy
-msgid "Category index out of range"
-msgstr "카테고리는 정수여야 합니다."
-#: ../lib/vector/Vlib/cindex.c:489
-#, fuzzy, c-format
-msgid "Unable to create category index file for vector map <%s>"
-#: ../lib/vector/Vlib/cindex.c:498
-#, fuzzy
-msgid "Error writing out category index file"
-#: ../lib/vector/Vlib/cindex.c:542 ../lib/vector/Vlib/open.c:380
-#, fuzzy, c-format
-msgid "Unable to open category index file for vector map <%s>"
#: ../lib/vector/Vlib/ascii.c:84
#, fuzzy, c-format
msgid "Error reading ASCII file: (bad type) [%s]"
@@ -7745,6 +7073,14 @@
msgid "Unable to fetch data from table"
+#: ../lib/vector/Vlib/ascii.c:730 ../lib/vector/Vlib/net_build.c:216
+#: ../lib/vector/Vlib/net_build.c:501 ../lib/vector/Vlib/net_build.c:519
+#: ../lib/vector/Vlib/net_build.c:799 ../lib/vector/Vlib/net_build.c:817
+#: ../lib/vector/Vlib/net_build.c:978
+#, fuzzy, c-format
+msgid "Column <%s> not found in table <%s>"
#: ../lib/vector/Vlib/ascii.c:732
#, fuzzy, c-format
msgid "Column <%s>: unsupported data type"
@@ -7776,303 +7112,189 @@
"category use '%s=-1'."
msgstr ""
-#: ../lib/vector/Vlib/simple_features.c:225
-#, fuzzy, c-format
-msgid "Unknown Simple Features type (%d)"
-#: ../lib/vector/Vlib/simple_features.c:332
+#: ../lib/vector/Vlib/graph.c:138
#, fuzzy
-msgid "Unable to get number of simple features"
+msgid "Unable to add network arc"
-#: ../lib/vector/Vlib/simple_features.c:341
-#, fuzzy, c-format
-msgid "Unable to report simple features for vector map <%s>"
-#: ../lib/vector/Vlib/close.c:91
-#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
-#: ../lib/vector/Vlib/close.c:108
-#, fuzzy
-msgid "Copying features failed"
-#: ../lib/vector/Vlib/close.c:141
-#, fuzzy, c-format
-msgid "Unable to open %s file"
-#: ../lib/vector/Vlib/close.c:226
-#, fuzzy, c-format
-msgid "Unable to close vector <%s>"
-#: ../lib/vector/Vlib/close.c:257
+#: ../lib/vector/Vlib/graph.c:226 ../lib/vector/Vlib/net_analyze.c:198
#, c-format
-msgid "Invalid request for writing frmt file - map format is %d"
+msgid "dglShortestPath error: %s"
msgstr ""
-#: ../lib/vector/Vlib/close.c:289
-#, fuzzy, c-format
-msgid "Link to vector map <%s> created"
-#: ../lib/vector/Vlib/overlay.c:72
-msgid "unknown operator"
+#: ../lib/vector/Vlib/array.c:96
+#, c-format
+msgid "%d errors in category string"
msgstr ""
-#: ../lib/vector/Vlib/overlay.c:124
-msgid "Overlay: line/boundary types not supported by AND operator"
+#: ../lib/vector/Vlib/array.c:142 ../lib/vector/Vlib/array.c:267
+msgid "Mixed area and other type requested for vector array"
msgstr ""
-#: ../lib/vector/Vlib/overlay.c:127
-msgid "Overlay: area x area types not supported by AND operator"
+#: ../lib/vector/Vlib/array.c:152 ../lib/vector/Vlib/array.c:175
+#: ../lib/vector/Vlib/array.c:304 ../lib/vector/Vlib/array.c:336
+msgid "Not enough space in vector array"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:60
-msgid "OGR datasource not defined"
+#: ../lib/vector/Vlib/array.c:292
+#, fuzzy, c-format
+msgid "Unable to select record from table <%s> (key %s, where %s)"
+msgstr "Datum %s 테이블파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/cindex.c:32
+msgid "Category index is not up to date"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:65 ../lib/vector/Vlib/write_ogr.c:129
-msgid "OGR layer not defined"
+#: ../lib/vector/Vlib/cindex.c:38
+msgid "Layer index out of range"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:97
-#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
+#: ../lib/vector/Vlib/cindex.c:268
+#, fuzzy
+msgid "Category index out of range"
+msgstr "카테고리는 정수여야 합니다."
-#: ../lib/vector/Vlib/open_ogr.c:191
+#: ../lib/vector/Vlib/cindex.c:489
#, fuzzy, c-format
-msgid "Unable to get OGR driver <%s>"
+msgid "Unable to create category index file for vector map <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:199
+#: ../lib/vector/Vlib/cindex.c:498
+#, fuzzy
+msgid "Error writing out category index file"
+#: ../lib/vector/Vlib/cindex.c:542 ../lib/vector/Vlib/open.c:380
#, fuzzy, c-format
-msgid "Unable to create OGR data source '%s'"
+msgid "Unable to open category index file for vector map <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:211
-#, c-format
-msgid "OGR layer <%s> already exists and will be overwritten"
+#: ../lib/vector/Vlib/cats.c:45
+msgid "Vect_new_cats_struct(): Out of memory"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:215
-#, fuzzy, c-format
-msgid "Unable to delete OGR layer <%s>"
-#: ../lib/vector/Vlib/open_ogr.c:221
-#, fuzzy, c-format
-msgid "OGR layer <%s> already exists in datasource '%s'"
-#: ../lib/vector/Vlib/open_ogr.c:279
+#: ../lib/vector/Vlib/cats.c:127
#, c-format
-msgid ""
-"Feature index format version %d.%d is not supported by this release. Try to "
-"rebuild topology or upgrade GRASS."
+msgid "Too many categories (%d), unable to set cat %d (layer %d)"
msgstr ""
-#: ../lib/vector/Vlib/open_ogr.c:284
+#: ../lib/vector/Vlib/cats.c:419
#, c-format
-msgid ""
-"Your GRASS version does not fully support feature index format %d.%d of the "
+msgid "Unable to convert category string '%s' (from '%s') to category range"
msgstr ""
-#: ../lib/vector/Vlib/level.c:34
-msgid "Map structure was never initialized"
+#: ../lib/vector/Vlib/cats.c:572 ../lib/vector/Vlib/cats.c:668
+msgid "Layer number must be > 0 for category constraints"
msgstr ""
-#: ../lib/vector/Vlib/level.c:36
-msgid "Map structure has been closed"
-msgstr ""
-#: ../lib/vector/Vlib/close_ogr.c:104 ../lib/vector/Vlib/close_pg.c:137
-#, fuzzy, c-format
-msgid "Unable to save feature index file for vector map <%s>"
-#: ../lib/vector/Vlib/break_lines.c:563
+#: ../lib/vector/Vlib/cats.c:585
#, c-format
-msgid "Intersections: %d"
+msgid "'%s' and '%s' parameters were supplied, cats will be ignored"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:192 ../lib/vector/Vlib/read_sfa.c:117
+#: ../lib/vector/Vlib/cats.c:593
#, fuzzy, c-format
-msgid "Unexpected feature type (%d) - should be (%d)"
+msgid "Loading categories from table <%s>..."
-#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
+#: ../lib/vector/Vlib/cats.c:603 ../lib/db/dbmi_client/select.c:317
#, fuzzy, c-format
-msgid "Feature %ld without geometry skipped"
+msgid "Unable select records from table <%s>"
-#: ../lib/vector/Vlib/read_pg.c:365
-#, c-format
-msgid ""
-"Requesting invalid feature from cache (%d). Number of features in cache: %d"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:368
+#: ../lib/vector/Vlib/cats.c:605
#, fuzzy, c-format
-msgid "Feature %d: unexpected type (%d) - should be %d"
+msgid "One category loaded"
+msgid_plural "%d categories loaded"
+msgstr[0] "카테고리 정보가 없습니다."
+msgstr[1] "카테고리 정보가 없습니다."
-#: ../lib/vector/Vlib/read_pg.c:575
-msgid "No geometry or topo geometry column defined"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:585
-msgid "Random access not supported. Primary key not defined."
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:652
-msgid "Inconsistency in topology: detected centroid (should be point)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:662
-msgid "Inconsistency in topology: detected boundary (should be line)"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:787
+#: ../lib/vector/Vlib/cats.c:627
#, c-format
-msgid "Invalid WKB content: %d bytes"
+msgid "No categories selected with '%s' option"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:803
-msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1064
-#: ../lib/vector/Vlib/read_pg.c:1135
-msgid "Length of input WKB is too small"
-msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1075
+#: ../lib/vector/Vlib/cats.c:637
#, c-format
-msgid "Invalid cache index %d (max: %d)"
+msgid "%d errors in '%s' option"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1213
-#, c-format
-msgid "Corrupted data. %s."
+#: ../lib/vector/Vlib/level.c:34
+msgid "Map structure was never initialized"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1215
-msgid "Corrupted data"
+#: ../lib/vector/Vlib/level.c:36
+msgid "Map structure has been closed"
msgstr ""
-#: ../lib/vector/Vlib/read_pg.c:1403 ../lib/vector/Vlib/close_pg.c:66
+#: ../lib/vector/Vlib/write_nat.c:368
#, fuzzy, c-format
-msgid "Unable to close cursor %s"
+msgid "Attempt to access alive feature %d"
-#: ../lib/vector/Vlib/read_pg.c:1508 ../lib/vector/Vlib/read_pg.c:1539
-#, fuzzy, c-format
-msgid ""
-"Execution failed: %s\n"
-"Reason: %s"
-#: ../lib/vector/Vlib/read_pg.c:1668
-#, fuzzy, c-format
-msgid ""
-"Unable to read features. Reason:\n"
-"%s"
-#: ../lib/vector/Vlib/read_sfa.c:90
-#, fuzzy, c-format
-msgid "Unable to construct centroid for area %d. Skipped."
-#: ../lib/vector/Vlib/read_sfa.c:95
+#: ../lib/vector/Vlib/write_nat.c:510 ../lib/vector/Vlib/write_nat.c:546
#, c-format
-msgid "Centroid %d: invalid area %d"
+msgid "%s: Area %d does not exist"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:81
+#: ../lib/vector/Vlib/write_nat.c:700
#, fuzzy, c-format
-msgid "Unable to copy features. Input vector map <%s> is not open"
+msgid "Attempt to access dead area %d"
-#: ../lib/vector/Vlib/copy.c:104
-#, fuzzy, c-format
-msgid "Unable to create PostGIS layer <%s>"
-#: ../lib/vector/Vlib/copy.c:133
-#, fuzzy, c-format
-msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
-#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
-msgid "Copying features..."
+#: ../lib/vector/Vlib/build_ogr.c:69
+msgid "Empty OGR layer, nothing to build"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:231
+#: ../lib/vector/Vlib/build_ogr.c:80 ../lib/vector/Vlib/build_pg.c:93
#, c-format
-msgid "Copying features (%s)..."
+msgid "Feature table <%s> has no primary key defined"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:334
-msgid "Writing new feature failed"
+#: ../lib/vector/Vlib/build_ogr.c:82
+msgid ""
+"Random read is not supported by OGR for this layer. Unable to build topology."
msgstr ""
-#: ../lib/vector/Vlib/copy.c:340
-#, fuzzy, c-format
-msgid "%d features without category or from different layer skipped"
-#: ../lib/vector/Vlib/copy.c:372
-msgid "Exporting nodes..."
+#: ../lib/vector/Vlib/build_ogr.c:88 ../lib/vector/Vlib/build_pg.c:101
+#, c-format
+msgid "Using external data format '%s' (feature type '%s')"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:400
+#: ../lib/vector/Vlib/build_ogr.c:132
#, fuzzy, c-format
-msgid "Writing node %d failed"
+msgid "Unable to open fidx file for write <%s>"
-#: ../lib/vector/Vlib/copy.c:478
-msgid "Exporting areas..."
+#: ../lib/vector/Vlib/break_polygons.c:102
+msgid "Break polygons: Bug in binary tree!"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:505
-#, c-format
-msgid "No centroid defined for area %d. Area not exported."
+#: ../lib/vector/Vlib/break_polygons.c:156
+msgid "Break polygons Pass 1: select break points"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
-#, fuzzy, c-format
-msgid "Writing area %d failed"
+#: ../lib/vector/Vlib/break_polygons.c:286
+msgid "Break polygons Pass 2: break at selected points"
+msgstr ""
-#: ../lib/vector/Vlib/copy.c:550
+#: ../lib/vector/Vlib/break_polygons.c:398
+#: ../lib/vector/Vlib/break_polygons.c:650
#, c-format
-msgid "%d areas without category or from different layer skipped"
+msgid "Breaks: %d"
msgstr ""
-#: ../lib/vector/Vlib/copy.c:611 ../lib/vector/Vlib/copy.c:752
-#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
+#: ../lib/vector/Vlib/break_polygons.c:435
+msgid "Breaking polygons (pass 1: select break points)..."
+msgstr ""
-#: ../lib/vector/Vlib/dgraph.c:432
-msgid ""
-"Trying to add more edges to the planar_graph than the initial allocation "
-"size allows"
+#: ../lib/vector/Vlib/break_polygons.c:552
+msgid "Breaking polygons (pass 2: break at selected points)..."
msgstr ""
-#: ../lib/vector/Vlib/select.c:116
-#, fuzzy, c-format
-msgid "Unable to delete item %d from spatial index"
+#: ../lib/vector/Vlib/break_polygons.c:592
+msgid "Point not in search tree!"
+msgstr ""
#: ../lib/vector/Vlib/build_pg.c:88
msgid "No DB connection"
@@ -8092,6 +7314,11 @@
msgid "Building topology from PostGIS topology schema <%s>..."
+#: ../lib/vector/Vlib/build_pg.c:212 ../lib/vector/Vlib/open_pg.c:1436
+#, c-format
+msgid "Inconsistency in topology: number of nodes %d (should be %d)"
+msgstr ""
#: ../lib/vector/Vlib/build_pg.c:237
#, fuzzy
msgid "Cleaning-up topology schema..."
@@ -8160,41 +7387,136 @@
"Unable to build simple features from topogeometry data. Unsupported type %d."
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:361
+#: ../lib/vector/Vlib/write_sfa.c:113
#, fuzzy
-msgid "Line is not looped"
+msgid "Unable to calculate centroid for area"
-#: ../lib/vector/Vlib/buffer2.c:443
+#: ../lib/vector/Vlib/write_sfa.c:212
+#, fuzzy
+msgid "Attempt to delete dead feature"
+#: ../lib/vector/Vlib/write_sfa.c:304
+#, fuzzy, c-format
+msgid "Unsupported vector map format (%d)"
+#: ../lib/vector/Vlib/read_ogr.c:215 ../lib/vector/Vlib/read_ogr.c:224
+#, fuzzy, c-format
+msgid "Unable to get feature geometry, fid %ld"
+#: ../lib/vector/Vlib/read_ogr.c:382 ../lib/vector/Vlib/read_pg.c:482
+msgid "Feature without geometry. Skipped."
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:390
+msgid "OGR feature without ID"
+msgstr ""
+#: ../lib/vector/Vlib/read_ogr.c:514
#, c-format
-msgid "Unexpected result of line_intersection() res = %d"
+msgid "OGR feature type '%s' not supported"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:589
+#: ../lib/vector/Vlib/level_two.c:23
+#, fuzzy, c-format
+msgid "Vector map <%s> is not open at topological level"
+#: ../lib/vector/Vlib/level_two.c:284
+#, fuzzy, c-format
+msgid "Invalid node id: %d"
+#: ../lib/vector/Vlib/level_two.c:316
+#, fuzzy, c-format
+msgid "Nodes not available for line %d"
+#: ../lib/vector/Vlib/level_two.c:357
+#, fuzzy, c-format
+msgid "Areas not available for line %d"
+#: ../lib/vector/Vlib/level_two.c:362
+#, fuzzy, c-format
+msgid "Line %d is not a boundary"
+#: ../lib/vector/Vlib/level_two.c:445
+#, fuzzy, c-format
+msgid "Topology info not available for feature %d"
+#: ../lib/vector/Vlib/open_ogr.c:60
+msgid "OGR datasource not defined"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:97
+#, fuzzy, c-format
+msgid "OGR layer <%s> not found"
+#: ../lib/vector/Vlib/open_ogr.c:145 ../lib/vector/Vlib/open_pg.c:193
+#, fuzzy, c-format
+msgid "Unable to open feature index file for vector map <%s>"
+#: ../lib/vector/Vlib/open_ogr.c:191
+#, fuzzy, c-format
+msgid "Unable to get OGR driver <%s>"
+#: ../lib/vector/Vlib/open_ogr.c:199
+#, fuzzy, c-format
+msgid "Unable to create OGR data source '%s'"
+#: ../lib/vector/Vlib/open_ogr.c:211
+#, c-format
+msgid "OGR layer <%s> already exists and will be overwritten"
+msgstr ""
+#: ../lib/vector/Vlib/open_ogr.c:215
+#, fuzzy, c-format
+msgid "Unable to delete OGR layer <%s>"
+#: ../lib/vector/Vlib/open_ogr.c:221
+#, fuzzy, c-format
+msgid "OGR layer <%s> already exists in datasource '%s'"
+#: ../lib/vector/Vlib/open_ogr.c:279
+#, c-format
msgid ""
-"Next edge was visited (right) but it is not the first one !!! breaking loop"
+"Feature index format version %d.%d is not supported by this release. Try to "
+"rebuild topology or upgrade GRASS."
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:600
+#: ../lib/vector/Vlib/open_ogr.c:284
+#, c-format
msgid ""
-"Next edge was visited (left) but it is not the first one !!! breaking loop"
+"Your GRASS version does not fully support feature index format %d.%d of the "
+"vector. Consider to rebuild topology or upgrade GRASS."
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:648
-msgid "side != 0 feature not implemented"
+#: ../lib/vector/Vlib/merge_lines.c:240
+#, c-format
+msgid "%d boundaries merged"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
-msgid "zero area size"
+#: ../lib/vector/Vlib/merge_lines.c:241
+#, c-format
+msgid "%d new boundaries"
msgstr ""
-#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
-#, fuzzy
-msgid "Line was not closed"
-#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
-msgid "Vect_get_point_in_poly() failed"
+#: ../lib/vector/Vlib/write.c:30 ../lib/vector/Vlib/write.c:36
+#: ../lib/vector/Vlib/write.c:42 ../lib/vector/Vlib/write.c:49
+#: ../lib/vector/Vlib/read.c:25
+msgid "for this format/level not supported"
msgstr ""
#: ../lib/vector/Vlib/write.c:187 ../lib/vector/Vlib/write.c:339
@@ -8232,36 +7554,6 @@
msgid "Vector map <%s> is not opened in write mode"
-#: ../lib/vector/Vlib/break_polygons.c:102
-msgid "Break polygons: Bug in binary tree!"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:156
-msgid "Break polygons Pass 1: select break points"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:286
-msgid "Break polygons Pass 2: break at selected points"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:398
-#: ../lib/vector/Vlib/break_polygons.c:650
-#, c-format
-msgid "Breaks: %d"
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:435
-msgid "Breaking polygons (pass 1: select break points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:552
-msgid "Breaking polygons (pass 2: break at selected points)..."
-msgstr ""
-#: ../lib/vector/Vlib/break_polygons.c:592
-msgid "Point not in search tree!"
-msgstr ""
#: ../lib/vector/Vlib/header.c:87
#, fuzzy, c-format
msgid "Unable to create header file for vector map <%s>"
@@ -8282,87 +7574,256 @@
msgid "Unknown keyword '%s' in vector head"
msgstr ""
-#: ../lib/vector/Vlib/poly.c:222
-msgid "Unable to find point in polygon"
+#: ../lib/vector/Vlib/break_lines.c:563
+#, c-format
+msgid "Intersections: %d"
msgstr ""
-#: ../lib/vector/Vlib/poly.c:640
-msgid "conditions failed"
+#: ../lib/vector/Vlib/simple_features.c:225
+#, fuzzy, c-format
+msgid "Unknown Simple Features type (%d)"
+#: ../lib/vector/Vlib/simple_features.c:332
+#, fuzzy
+msgid "Unable to get number of simple features"
+#: ../lib/vector/Vlib/simple_features.c:341
+#, fuzzy, c-format
+msgid "Unable to report simple features for vector map <%s>"
+#: ../lib/vector/Vlib/read.c:93 ../lib/vector/Vlib/read.c:129
+#: ../lib/vector/Vlib/read.c:168
+#, fuzzy
+msgid "Vector map is not open for reading"
+#: ../lib/vector/Vlib/read.c:136 ../lib/vector/Vlib/read.c:180
+#, fuzzy, c-format
+msgid "Unable to read feature %d from vector map <%s>"
+#: ../lib/vector/Vlib/remove_areas.c:109 ../lib/vector/Vlib/remove_areas.c:274
+msgid "Area is composed of dead boundary"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:148
-msgid "Changed"
+#: ../lib/vector/Vlib/remove_areas.c:196 ../lib/vector/Vlib/remove_areas.c:598
+#, c-format
+msgid "%d areas of total size %g removed"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:151
-msgid "Removed"
+#: ../lib/vector/Vlib/remove_areas.c:401
+#, fuzzy
+msgid "Could not delete line from coor"
+#: ../lib/vector/Vlib/remove_areas.c:458 ../lib/vector/Vlib/remove_areas.c:492
+#, fuzzy
+msgid "Failed to build new area"
+#: ../lib/vector/Vlib/remove_areas.c:463 ../lib/vector/Vlib/remove_areas.c:496
+msgid "Dissolve with neighbour area: corrupt topology"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:154
-msgid "Selected"
+#: ../lib/vector/Vlib/remove_areas.c:477 ../lib/vector/Vlib/remove_areas.c:560
+msgid "Neighbor boundaries should be complete"
msgstr ""
-#: ../lib/vector/Vlib/dangles.c:262
-#, fuzzy, c-format
-msgid "%s lines: %d"
+#: ../lib/vector/Vlib/remove_areas.c:541 ../lib/vector/Vlib/remove_areas.c:568
+#, fuzzy
+msgid "Failed to build new isle"
-#: ../lib/vector/Vlib/dangles.c:263
+#: ../lib/vector/Vlib/remove_areas.c:546 ../lib/vector/Vlib/remove_areas.c:573
+msgid "Dissolve with outer isle: corrupt topology"
+msgstr ""
+#: ../lib/vector/Vlib/remove_areas.c:579
+#, fuzzy
+msgid "Area merging failed"
+#: ../lib/vector/Vlib/snap.c:213
+msgid "Snap vertices Pass 1: select points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:267
+msgid "Snap vertices Pass 2: assign anchor vertices"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:336
+msgid "Snap vertices Pass 3: snap to assigned points"
+msgstr ""
+#: ../lib/vector/Vlib/snap.c:518
#, c-format
-msgid "%s dangles: %d"
+msgid "Snapped vertices: %d"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:134
+#: ../lib/vector/Vlib/snap.c:519
#, fuzzy, c-format
-msgid "Invalid offset (%d)"
+msgid "New vertices: %d"
-#: ../lib/vector/Vlib/write_ogr.c:239
-#, fuzzy, c-format
-msgid "Creating field <%s> failed"
+#: ../lib/vector/Vlib/snap.c:546
+#, fuzzy
+msgid "Reading features..."
-#: ../lib/vector/Vlib/write_ogr.c:326
-#, fuzzy, c-format
-msgid "Unable to create OGR layer <%s> in '%s'"
+#: ../lib/vector/Vlib/net_build.c:101 ../lib/vector/Vlib/net_build.c:727
+msgid "Building graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:143 ../lib/vector/Vlib/net_build.c:772
+#, fuzzy
+msgid "Unable to build network graph"
-#: ../lib/vector/Vlib/write_ogr.c:424
-msgid "Feature is not a point. Skipping."
+#: ../lib/vector/Vlib/net_build.c:149 ../lib/vector/Vlib/net_build.c:778
+msgid "Forward costs column not specified"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:432
-msgid "Feature is not a line. Skipping."
+#: ../lib/vector/Vlib/net_build.c:156
+msgid "Turntable field < 1"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:446
-msgid "Feature is not a face. Skipping."
+#: ../lib/vector/Vlib/net_build.c:172
+#, fuzzy, c-format
+msgid "Turntable column <%s> not found in table <%s>"
+#: ../lib/vector/Vlib/net_build.c:182 ../lib/vector/Vlib/net_build.c:223
+#: ../lib/vector/Vlib/net_build.c:508 ../lib/vector/Vlib/net_build.c:526
+#: ../lib/vector/Vlib/net_build.c:806 ../lib/vector/Vlib/net_build.c:824
+#: ../lib/vector/Vlib/net_build.c:985
+#, c-format
+msgid "Data type of column <%s> not supported (must be numeric)"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:452
-#, fuzzy, c-format
-msgid "Unsupported feature type (%d)"
+#: ../lib/vector/Vlib/net_build.c:202 ../lib/vector/Vlib/net_build.c:964
+msgid "Setting node costs..."
+msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:471
-msgid "Boundary is not closed. Feature skipped."
+#: ../lib/vector/Vlib/net_build.c:277 ../lib/vector/Vlib/net_build.c:1029
+#, c-format
+msgid "Database record for node %d (cat = %d) not found (cost set to 0)"
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:500
+#: ../lib/vector/Vlib/net_build.c:332 ../lib/vector/Vlib/net_build.c:352
#, fuzzy
-msgid "Unable to writes feature attributes"
+msgid "Cannot add network arc for virtual node connection."
-#: ../lib/vector/Vlib/write_ogr.c:565
+#: ../lib/vector/Vlib/net_build.c:364
#, c-format
-msgid "Feature without category of layer %d"
+msgid ""
+"There exists more than one point of node <%d> with unique category field <"
+"%d>.\n"
+"The unique categories layer is not valid therefore you will probably get "
+"incorrect results."
msgstr ""
-#: ../lib/vector/Vlib/write_ogr.c:624
+#: ../lib/vector/Vlib/net_build.c:393
+#, c-format
+msgid ""
+"Unable to find point representing intersection <%d> in unique categories "
+"field <%d>.\n"
+"Cost for the intersection was set to 0.\n"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:407
+#, c-format
+msgid ""
+"Unable to find node for point representing intersection <%d> in unique "
+"categories field <%d>.\n"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:432
+#, c-format
+msgid ""
+"Database record for turn with cat = %d in not found. (The turn was skipped."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:465
+#, fuzzy
+msgid "Cannot add network arc representing turn."
+#: ../lib/vector/Vlib/net_build.c:487 ../lib/vector/Vlib/net_build.c:785
+msgid "Arc field < 1"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:539 ../lib/vector/Vlib/net_build.c:837
+msgid "Registering arcs..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:558
+#, c-format
+msgid ""
+"Line with id <%d> has more unique categories defined in field <%d>.\n"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:579
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, forward/both direction(s)) not found "
+"(cost was set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:596
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found(cost "
+"was set to 0)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:658 ../lib/vector/Vlib/net_build.c:1061
+msgid "Flattening the graph..."
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:667 ../lib/vector/Vlib/net_build.c:1070
+msgid "Graph was built"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:866
+#, c-format
+msgid ""
+"(forward/both direction(s) of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:885
+#, c-format
+msgid ""
+"Database record for line %d (cat = %d, backword direction) not found"
+"(direction of line skipped)"
+msgstr ""
+#: ../lib/vector/Vlib/net_build.c:934
+#, fuzzy
+msgid "Cannot add network arc"
+msgstr "임시파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/close_pg.c:66 ../lib/vector/Vlib/read_pg.c:1403
#, fuzzy, c-format
-msgid "Unable to create field <%s>"
+msgid "Unable to close cursor %s"
+#: ../lib/vector/Vlib/close_pg.c:137 ../lib/vector/Vlib/close_ogr.c:104
+#, fuzzy, c-format
+msgid "Unable to save feature index file for vector map <%s>"
#: ../lib/vector/Vlib/open.c:138
#, c-format
msgid "Programmer requested unknown access level %d"
@@ -8393,11 +7854,6 @@
msgid "Unable to open topology file for vector map <%s>"
-#: ../lib/vector/Vlib/open.c:354
-#, fuzzy, c-format
-msgid "Unable to open spatial index file for vector map <%s>"
#: ../lib/vector/Vlib/open.c:406 ../lib/vector/Vlib/open.c:428
#, fuzzy, c-format
msgid ""
@@ -8435,274 +7891,926 @@
msgid "Unable to open history file of vector map <%s>"
-#: ../lib/vector/Vlib/open.c:877
+#: ../lib/vector/Vlib/open.c:879
#, c-format
msgid "Using OGR/%s format"
msgstr ""
-#: ../lib/vector/Vlib/open.c:881
+#: ../lib/vector/Vlib/open.c:883
msgid "Using PostGIS Topology format"
msgstr ""
-#: ../lib/vector/Vlib/open.c:883
+#: ../lib/vector/Vlib/open.c:885
msgid "Using PostGIS format"
msgstr ""
-#: ../lib/vector/Vlib/open.c:886
+#: ../lib/vector/Vlib/open.c:888
#, fuzzy
msgid "Using native format"
msgstr "잘못된 좌표"
-#: ../lib/vector/Vlib/open.c:977
+#: ../lib/vector/Vlib/open.c:979
#, fuzzy, c-format
msgid "Unable to stat file <%s>"
-#: ../lib/vector/Vlib/open.c:1041
+#: ../lib/vector/Vlib/open.c:1043
#, c-format
msgid "unknown %d (update Vect_maptype_info)"
msgstr ""
-#: ../lib/vector/Vlib/open.c:1133
+#: ../lib/vector/Vlib/open.c:1135
msgid "Size of 'coor' file differs from value saved in topology file"
msgstr ""
-#: ../lib/vector/Vlib/open.c:1144 ../lib/vector/Vlib/open.c:1244
+#: ../lib/vector/Vlib/open.c:1146 ../lib/vector/Vlib/open.c:1247
#, fuzzy, c-format
msgid "Please rebuild topology for vector map <%s@%s>"
-#: ../lib/vector/Vlib/open.c:1233
+#: ../lib/vector/Vlib/open.c:1236
msgid "Size of 'coor' file differs from value saved in sidx file"
msgstr ""
-#: ../lib/vector/Vlib/open.c:1313
+#: ../lib/vector/Vlib/open.c:1316
#, fuzzy
msgid "Unable to open OGR file"
-#: ../lib/vector/Vlib/open.c:1339
+#: ../lib/vector/Vlib/open.c:1342
msgid "OGR output also detected, using OGR"
msgstr ""
-#: ../lib/vector/Vlib/build.c:115
-msgid "Area of size = 0.0 (less than 4 vertices) ignored"
+#: ../lib/vector/Vlib/bridges.c:213
+#, fuzzy, c-format
+msgid "Removed lines: %d"
+#: ../lib/vector/Vlib/bridges.c:214
+#, fuzzy, c-format
+msgid "Removed bridges: %d"
+#: ../lib/vector/Vlib/select.c:116
+#, fuzzy, c-format
+msgid "Unable to delete item %d from spatial index"
+#: ../lib/vector/Vlib/read_pg.c:272 ../lib/vector/Vlib/read_pg.c:471
+#, fuzzy, c-format
+msgid "Feature %ld without geometry skipped"
+#: ../lib/vector/Vlib/read_pg.c:365
+#, c-format
+msgid ""
+"Requesting invalid feature from cache (%d). Number of features in cache: %d"
msgstr ""
-#: ../lib/vector/Vlib/build.c:131
-msgid "Unable to add area (map closed, topo saved)"
+#: ../lib/vector/Vlib/read_pg.c:368
+#, fuzzy, c-format
+msgid "Feature %d: unexpected type (%d) - should be %d"
+#: ../lib/vector/Vlib/read_pg.c:575
+msgid "No geometry or topo geometry column defined"
msgstr ""
-#: ../lib/vector/Vlib/build.c:139
-msgid "Unable to add isle (map closed, topo saved)"
+#: ../lib/vector/Vlib/read_pg.c:585
+msgid "Random access not supported. Primary key not defined."
msgstr ""
-#: ../lib/vector/Vlib/build.c:149
-msgid "Area of size = 0.0 ignored"
+#: ../lib/vector/Vlib/read_pg.c:652
+msgid "Inconsistency in topology: detected centroid (should be point)"
msgstr ""
-#: ../lib/vector/Vlib/build.c:197
-msgid "Request to find area outside nonexistent isle"
+#: ../lib/vector/Vlib/read_pg.c:662
+msgid "Inconsistency in topology: detected boundary (should be line)"
msgstr ""
-#: ../lib/vector/Vlib/build.c:338
-msgid "Larger bbox but smaller area!!!"
+#: ../lib/vector/Vlib/read_pg.c:787
+#, c-format
+msgid "Invalid WKB content: %d bytes"
msgstr ""
-#: ../lib/vector/Vlib/build.c:584
-msgid "Checking for topological errors..."
+#: ../lib/vector/Vlib/read_pg.c:803
+msgid "Reading EWKB with 4-dimensional coordinates (XYZM) is not supported"
msgstr ""
-#: ../lib/vector/Vlib/build.c:619
-#, fuzzy, c-format
-msgid "Number of lines of length zero: %d"
+#: ../lib/vector/Vlib/read_pg.c:996 ../lib/vector/Vlib/read_pg.c:1064
+#: ../lib/vector/Vlib/read_pg.c:1135
+msgid "Length of input WKB is too small"
+msgstr ""
-#: ../lib/vector/Vlib/build.c:621
+#: ../lib/vector/Vlib/read_pg.c:1075
+#, c-format
+msgid "Invalid cache index %d (max: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1213
+#, c-format
+msgid "Corrupted data. %s."
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1215
+msgid "Corrupted data"
+msgstr ""
+#: ../lib/vector/Vlib/read_pg.c:1508 ../lib/vector/Vlib/read_pg.c:1539
#, fuzzy, c-format
-msgid "Number of boundaries of length zero: %d"
+msgid ""
+"Execution failed: %s\n"
+"Reason: %s"
-#: ../lib/vector/Vlib/build.c:630
+#: ../lib/vector/Vlib/read_pg.c:1668
#, fuzzy, c-format
-msgid "Number of boundary intersections: %d"
+msgid ""
+"Unable to read features. Reason:\n"
+"%s"
-#: ../lib/vector/Vlib/build.c:654
+#: ../lib/vector/Vlib/buffer2.c:361
#, fuzzy
-msgid "Skipping further checks because of incorrect boundaries"
+msgid "Line is not looped"
-#: ../lib/vector/Vlib/build.c:704
-#, fuzzy, c-format
-msgid "Number of redundant holes: %d"
+#: ../lib/vector/Vlib/buffer2.c:443
+#, c-format
+msgid "Unexpected result of line_intersection() res = %d"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:589
+msgid ""
+"Next edge was visited (right) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:600
+msgid ""
+"Next edge was visited (left) but it is not the first one !!! breaking loop"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:648
+msgid "side != 0 feature not implemented"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:890 ../lib/vector/Vlib/buffer2.c:937
+msgid "zero area size"
+msgstr ""
+#: ../lib/vector/Vlib/buffer2.c:896 ../lib/vector/Vlib/buffer2.c:943
+#, fuzzy
+msgid "Line was not closed"
-#: ../lib/vector/Vlib/build.c:846
+#: ../lib/vector/Vlib/buffer2.c:909 ../lib/vector/Vlib/buffer2.c:960
+msgid "Vect_get_point_in_poly() failed"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:224
+msgid "Unable to find point in polygon"
+msgstr ""
+#: ../lib/vector/Vlib/poly.c:642
+msgid "conditions failed"
+msgstr ""
+#: ../lib/vector/Vlib/open_nat.c:57
#, fuzzy, c-format
-msgid "Building topology for vector map <%s>..."
+msgid "Unable to open coor file for vector map <%s>"
-#: ../lib/vector/Vlib/build.c:864
-msgid "Topology was built"
+#: ../lib/vector/Vlib/open_nat.c:154
+#, c-format
+msgid ""
+"Coor file of vector map <%s@%s> is larger than it should be (%ld bytes "
+"excess)"
msgstr ""
-#: ../lib/vector/Vlib/build.c:875
+#: ../lib/vector/Vlib/open_nat.c:158
+#, c-format
+msgid ""
+"Coor file of vector <%s@%s> is shorter than it should be (%ld bytes missing)."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:81
#, fuzzy, c-format
-msgid "Number of nodes: %d"
+msgid "Unable to copy features. Input vector map <%s> is not open"
-#: ../lib/vector/Vlib/build.c:876
+#: ../lib/vector/Vlib/copy.c:104
#, fuzzy, c-format
-msgid "Number of primitives: %d"
+msgid "Unable to create PostGIS layer <%s>"
-#: ../lib/vector/Vlib/build.c:877
+#: ../lib/vector/Vlib/copy.c:133
#, fuzzy, c-format
-msgid "Number of points: %d"
+msgid "Vector map <%s> not open on topological level. Areas will be skipped!"
-#: ../lib/vector/Vlib/build.c:878
+#: ../lib/vector/Vlib/copy.c:229 ../lib/vector/Vlib/copy.c:234
+msgid "Copying features..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:231
+#, c-format
+msgid "Copying features (%s)..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:334
+msgid "Writing new feature failed"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:340
#, fuzzy, c-format
-msgid "Number of lines: %d"
+msgid "%d features without category or from different layer skipped"
-#: ../lib/vector/Vlib/build.c:879
+#: ../lib/vector/Vlib/copy.c:372
+msgid "Exporting nodes..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:400
#, fuzzy, c-format
-msgid "Number of boundaries: %d"
+msgid "Writing node %d failed"
-#: ../lib/vector/Vlib/build.c:880
+#: ../lib/vector/Vlib/copy.c:478
+msgid "Exporting areas..."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:505
+#, c-format
+msgid "No centroid defined for area %d. Area not exported."
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:534 ../lib/vector/Vlib/copy.c:542
#, fuzzy, c-format
-msgid "Number of centroids: %d"
+msgid "Writing area %d failed"
-#: ../lib/vector/Vlib/build.c:883
+#: ../lib/vector/Vlib/copy.c:550
+#, c-format
+msgid "%d areas without category or from different layer skipped"
+msgstr ""
+#: ../lib/vector/Vlib/copy.c:611 ../lib/vector/Vlib/copy.c:752
#, fuzzy, c-format
-msgid "Number of faces: %d"
+msgid "Unable to add database link for vector map <%s>"
-#: ../lib/vector/Vlib/build.c:886
+#: ../lib/vector/Vlib/net_analyze.c:288 ../lib/vector/Vlib/net_analyze.c:329
+#, c-format
+msgid "Unable to find point with defined unique category for node <%d>."
+msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:292 ../lib/vector/Vlib/net_analyze.c:333
+#, c-format
+msgid ""
+"There exists more than one point on node <%d> with unique category in field "
+"<%d>.\n"
+"The unique category layer may not be valid."
+msgstr ""
+#: ../lib/vector/Vlib/net_analyze.c:449
+msgid "Wrong line direction in Vect_net_get_line_cost()"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:184 ../lib/vector/Vlib/line.c:217
+#: ../lib/vector/Vlib/line.c:250
+msgid "Index out of range in"
+msgstr ""
+#: ../lib/vector/Vlib/line.c:550
+msgid "Segment outside line, no segment created"
+msgstr ""
+#: ../lib/vector/Vlib/box.c:228
#, fuzzy, c-format
-msgid "Number of kernels: %d"
+msgid "Unable to determine bbox for feature %d"
-#: ../lib/vector/Vlib/build.c:932
+#: ../lib/vector/Vlib/box.c:277 ../lib/vector/Vlib/box.c:323
#, fuzzy, c-format
-msgid "Number of areas: %d"
+msgid "Attempt to access area with invalid id (%d)"
+#: ../lib/vector/Vlib/box.c:289
+#, fuzzy, c-format
+msgid "Unable to determine bbox for area %d"
+#: ../lib/vector/Vlib/box.c:335
+#, fuzzy, c-format
+msgid "Unable to determine bbox for isle %d"
-#: ../lib/vector/Vlib/build.c:933
+#: ../lib/vector/Vlib/geos.c:52
+#, fuzzy
+msgid "vector map is not opened"
+#: ../lib/vector/Vlib/geos.c:55
+#, c-format
+msgid ""
+"Vect_read_line_geos(): feature id %d is not reasonable (max features in "
+"vector map <%s>: %d)"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:60
+msgid "only native format supported"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:65 ../lib/vector/Vlib/geos.c:256
+#, fuzzy
+msgid "Attempt to read dead line"
+#: ../lib/vector/Vlib/geos.c:90
+#, c-format
+msgid "Vect_read_area_geos(): unable to read area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:104
+#, c-format
+msgid "Vect_read_area_geos(): unable to read isle id %d of area id %d"
+msgstr ""
+#: ../lib/vector/Vlib/geos.c:203
#, fuzzy, c-format
-msgid "Number of isles: %d"
+msgid "Unable to read line offset %ld"
+#: ../lib/vector/Vlib/geos.c:410
+#, fuzzy, c-format
+msgid "Attempt to read points of nonexistent area id %d"
+#: ../lib/vector/Vlib/geos.c:470
+#, fuzzy, c-format
+msgid "Unable to read feature id %d"
-#: ../lib/vector/Vlib/build.c:938
+#: ../lib/vector/Vlib/open_pg.c:109 ../lib/vector/Vlib/open_pg.c:267
+#, fuzzy
+msgid "No feature tables found in database."
+#: ../lib/vector/Vlib/open_pg.c:133
#, fuzzy, c-format
-msgid "Number of areas without centroid: %d"
+msgid "Feature table <%s> not found in 'geometry_columns'"
+msgstr "'%s' 디버그파일을 열 수 없습니다"
+#: ../lib/vector/Vlib/open_pg.c:181
+msgid "Topology schema not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:273
+#, fuzzy, c-format
+msgid "PostGIS layer <%s.%s> already exists and will be overwritten"
-#: ../lib/vector/Vlib/build.c:943
+#: ../lib/vector/Vlib/open_pg.c:276
#, fuzzy, c-format
-msgid "Number of centroids exceeds number of areas: %d > %d"
+msgid "Unable to delete PostGIS layer <%s>"
-#: ../lib/vector/Vlib/build.c:947
+#: ../lib/vector/Vlib/open_pg.c:282
#, fuzzy, c-format
-msgid "Number of incorrect boundaries: %d"
+msgid "PostGIS layer <%s.%s> already exists in database '%s'"
-#: ../lib/vector/Vlib/build.c:951
+#: ../lib/vector/Vlib/open_pg.c:390
+#, fuzzy
+msgid "No key column detected."
+#: ../lib/vector/Vlib/open_pg.c:462 ../lib/vector/Vlib/open_pg.c:474
+#, c-format
+msgid "Execution failed: %s"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:476
+#, c-format
+msgid "PostGIS topology schema <%s> dropped"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:510
+msgid "Connection to PostgreSQL database failed."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:516
+#, fuzzy
+msgid "Unable to get database name"
+#: ../lib/vector/Vlib/open_pg.c:521
+#, c-format
+msgid "<%s> is not PostGIS database. DB table 'spatial_ref_sys' not found."
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:530
#, fuzzy, c-format
-msgid "Number of centroids outside area: %d"
+msgid "PostGIS Topology extension not found in the database <%s>"
-#: ../lib/vector/Vlib/build.c:955
+#: ../lib/vector/Vlib/open_pg.c:617
+msgid "Empty bounding box"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:718
+#, c-format
+msgid "Inconsistency in topology: unable to read node %d"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:784
#, fuzzy, c-format
-msgid "Number of duplicate centroids: %d"
+msgid "Inconsistency in topology: node %d - unexpected feature type %d"
+msgstr "알려지지 않은 벡터타입입니다"
+#: ../lib/vector/Vlib/open_pg.c:954
+#, fuzzy, c-format
+msgid "Area %d without boundary detected"
-#: ../lib/vector/Vlib/build.c:959
+#: ../lib/vector/Vlib/open_pg.c:1012
+#, c-format
+msgid "Isle %d without boundary detected"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1079
#, fuzzy
-msgid "Number of areas: -"
+msgid "Unable to get map bounding box from topology"
-#: ../lib/vector/Vlib/build.c:960
-#, fuzzy
-msgid "Number of isles: -"
+#: ../lib/vector/Vlib/open_pg.c:1086
+#, fuzzy, c-format
+msgid ""
+"Unable to parse map bounding box:\n"
+"%s"
-#: ../lib/vector/Vlib/build.c:989
+#: ../lib/vector/Vlib/open_pg.c:1110
+#, c-format
+msgid "Different number of nodes detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1138 ../lib/vector/Vlib/open_pg.c:1160
+#, c-format
+msgid "Different number of areas detected (%d, %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1331
+msgid "To be implemented: isles not attached in Topo-Geo-only mode"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1520
+#, c-format
+msgid "Inconsistency in topology: number of points %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1565
+#, c-format
+msgid "Inconsistency in topology: number of lines %d (should be %d)"
+msgstr ""
+#: ../lib/vector/Vlib/open_pg.c:1619
+#, c-format
+msgid "Inconsistency in topology: number of centroids %d (should be %d)"
+msgstr ""
+#: ../lib/display/icon.c:80
#, fuzzy, c-format
-msgid "Unable to create topo file for vector map <%s>"
+msgid "Unsupported icon %d"
+#: ../lib/display/tran_colr.c:107 ../lib/display/tran_colr.c:109
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../lib/display/r_raster.c:113
+#, c-format
+msgid "%s variable defined, %s ignored"
+msgstr ""
+#: ../lib/display/r_raster.c:148
+#, fuzzy, c-format
+msgid "Unknown display driver <%s>"
-#: ../lib/vector/Vlib/build.c:997
+#: ../lib/display/r_raster.c:149
+#, fuzzy, c-format
+msgid "Using display driver <%s>..."
+#: ../lib/display/r_raster.c:215
+#, fuzzy, c-format
+msgid "Unable to open file '%s'"
+#: ../lib/symbol/read.c:211
+#, c-format
+msgid "Cannot read symbol line coordinates: %s"
+msgstr "심볼의 좌표를 읽을 수 없습니다: %s"
+#: ../lib/symbol/read.c:260
+#, c-format
+msgid ""
+"Incorrect symbol name: '%s' (should be: group/name or group/name at mapset)"
+msgstr ""
+"잘못된 심볼이름: '%s' (group/name 또는 group/name at mapset 중 하나여야 합니다.)"
+#: ../lib/symbol/read.c:284
+#, c-format
+msgid "Cannot find/open symbol: '%s'"
+msgstr "심볼을 찾을 수 없거나 열 수 없습니다: '%s'"
+#: ../lib/symbol/read.c:389 ../lib/symbol/read.c:407 ../lib/symbol/read.c:417
+#: ../lib/symbol/read.c:435
+#, c-format
+msgid "Incorrect symbol color: '%s', using default."
+msgstr "잘못된 심볼색상: %s, 기본값을 사용합니다."
+#: ../lib/segment/format.c:143
+msgid "Segment format: file size too large"
+msgstr ""
+#: ../lib/segment/format.c:144
+msgid "Please recompile with Large File Support (LFS)"
+msgstr ""
+#: ../lib/segment/open.c:53
+msgid "Segment file name is NULL"
+msgstr ""
+#: ../lib/segment/open.c:58
+msgid "Segment file exists already"
+msgstr ""
+#: ../lib/segment/open.c:66
#, fuzzy
-msgid "Error writing out topo file"
+msgid "Unable to create segment file"
-#: ../lib/vector/Vlib/build.c:1186
+#: ../lib/segment/open.c:74
#, fuzzy
+msgid "Could not write segment file"
+msgstr "자동 MASK파일을 열 수 없습니다"
+#: ../lib/segment/open.c:78
+msgid "Illegal segment configuration parameter(s)"
+msgstr ""
+#: ../lib/segment/open.c:86
+#, fuzzy
+msgid "Unable to re-open segment file"
+#: ../lib/segment/open.c:93
+msgid "Could not read segment file"
+msgstr ""
+#: ../lib/psdriver/Graph_set.c:199
+#, c-format
+msgid "ps: truecolor status %s"
+msgstr ""
+#: ../lib/psdriver/Graph_set.c:214
+#, c-format
+msgid "ps: collecting to file '%s'"
+msgstr ""
+#: ../lib/psdriver/Graph_set.c:215
+#, c-format
+msgid "ps: image size %dx%d"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:84
+#, c-format
+msgid "%s: Unable to read font definition file; use the default"
+msgstr ""
+#: ../lib/driver/parse_ftcap.c:90
+#, c-format
+msgid "%s: No font definition file"
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:38
+#, c-format
+msgid "Illegal table map name <%s>. May not contain '.' or 'NULL'."
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:45
+#, c-format
+msgid "Illegal table map name <%s>. Must start with a letter."
+msgstr ""
+#: ../lib/db/dbmi_base/legal_dbname.c:54
+#, c-format
+msgid "Illegal table map name <%s>. Character <%c> not allowed."
+msgstr ""
+#: ../lib/db/dbmi_base/default_name.c:136
+msgid "Programmer error"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:37
msgid ""
-"Unable to build spatial index from topology, vector map is not opened at "
-"topology level 2"
+"\n"
+"++ Running column unit tests ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:42
+msgid ""
+"\n"
+"-- column unit tests failure --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:44
+msgid ""
+"\n"
+"-- column unit tests finished successfully --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:57
+msgid ""
+"\n"
+"++ Run test copy column ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_columns.c:150
+msgid ""
+"\n"
+"++ Test copy column finished ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_main.c:83
+msgid "Performs unit and integration tests for the dbmi base library"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:38
+msgid ""
+"\n"
+"++ Running table unit tests ++"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:43
+msgid ""
+"\n"
+"-- Table unit tests failure --"
+msgstr ""
+#: ../lib/db/dbmi_base/test/test_table.c:45
+msgid ""
+"\n"
+"-- Table unit tests finished successfully --"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:72
+msgid "<NULL error message>"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:91
+msgid "dbmi: Protocol error"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:136
+msgid "dbmi: Out of Memory"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:149
+#, c-format
+msgid "dbmi: %s() not implemented"
+msgstr ""
+#: ../lib/db/dbmi_base/error.c:163
+#, c-format
+msgid "dbmi: Invalid procedure %d"
+msgstr ""
+#: ../lib/db/dbmi_base/index.c:180
+msgid "db_set_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/db/dbmi_base/index.c:197
+msgid "db_get_index_column_name(): invalid column number"
+msgstr ""
+#: ../lib/db/dbmi_base/valuefmt.c:52
+msgid "db_convert_Cstring_to_value(): unrecognized sqltype"
+msgstr ""
+#: ../lib/db/dbmi_base/valuefmt.c:91
+msgid "db_convert_value_into_string(): unrecongized sqltype-type"
+msgstr ""
+#: ../lib/db/dbmi_base/xdrtable.c:109
+msgid "fetch: table has wrong number of columns"
+msgstr ""
+#: ../lib/db/dbmi_base/xdrvalue.c:82
+msgid "send data: invalid C-type"
+msgstr ""
+#: ../lib/db/dbmi_base/login.c:99
+#, fuzzy, c-format
+msgid "Unable to read file '%s'"
-#: ../lib/vector/Vlib/build.c:1209
+#: ../lib/db/dbmi_base/login.c:113
#, c-format
-msgid "%s is no longer supported"
+msgid "Login file (%s) corrupted (line: %s)"
msgstr ""
-#: ../lib/vector/Vlib/build.c:1232
-msgid "Spatial index not available, can not be saved"
+#: ../lib/db/dbmi_base/login.c:142
+#, fuzzy, c-format
+msgid "Unable to write file '%s'"
+#: ../lib/db/dbmi_client/copy_tab.c:91
+#, c-format
+msgid "Array of values to select from column <%s> is empty"
msgstr ""
-#: ../lib/vector/Vlib/build.c:1245
+#: ../lib/db/dbmi_client/copy_tab.c:151
#, fuzzy, c-format
-msgid "Unable to create spatial index file for vector map <%s>"
+msgid "Unable to get list tables in database <%s>"
-#: ../lib/vector/Vlib/build.c:1254
-#, fuzzy
-msgid "Error writing out spatial index file"
+#: ../lib/db/dbmi_client/copy_tab.c:167
+#, fuzzy, c-format
+msgid "Table <%s> already exists in database and will be overwritten"
-#: ../lib/vector/vedit/cats.c:63
+#: ../lib/db/dbmi_client/copy_tab.c:172
#, fuzzy, c-format
-msgid "Unable to set category %d for (feature id %d)"
+msgid "Table <%s> already exists in database <%s>"
-#: ../lib/vector/vedit/delete.c:40
+#: ../lib/db/dbmi_client/copy_tab.c:250
#, fuzzy, c-format
-msgid "Attempt to delete dead feature (%d)"
+msgid "Column <%s> is not integer"
-#: ../lib/vector/vedit/delete.c:72
+#: ../lib/db/dbmi_client/copy_tab.c:270
#, fuzzy, c-format
-msgid "No area found for centroid %d"
+msgid "Unable to create table <%s>"
-#: ../lib/vector/vedit/delete.c:76
+#: ../lib/db/dbmi_client/copy_tab.c:370
#, c-format
-msgid "Duplicate centroid %d, unable to delete area"
+msgid "Unknown column type (column <%s>)"
msgstr ""
-#: ../lib/vector/vedit/delete.c:105
+#: ../lib/db/dbmi_client/table.c:46 ../lib/db/dbmi_client/delete_tab.c:40
#, fuzzy, c-format
-msgid "Area %d without centroid"
+msgid "Unable open database <%s> by driver <%s>"
+#: ../lib/db/dbmi_client/delete_tab.c:53
+#, fuzzy, c-format
+msgid "Unable to drop table: '%s'"
-#: ../lib/vector/vedit/delete.c:121
+#: ../lib/db/dbmi_client/select.c:119 ../lib/db/dbmi_client/select.c:221
+#: ../lib/db/dbmi_client/select.c:288
+msgid "Missing column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:216 ../lib/db/dbmi_client/select.c:283
+msgid "Missing key column name"
+msgstr ""
+#: ../lib/db/dbmi_client/select.c:333
+#, fuzzy
+msgid "Key column type is not integer"
+#: ../lib/db/dbmi_driver/d_error.c:35
+#, c-format
+msgid "DBMI-%s driver error:"
+msgstr ""
+#: ../lib/htmldriver/Graph_Set.c:97
+#, c-format
+msgid "html: collecting to file '%s'"
+msgstr "html: '%s' 파일로 모읍니다."
+#: ../lib/htmldriver/Graph_Set.c:98
+#, c-format
+msgid "html: image size %dx%d"
+msgstr "html: 그림크기 %dx%d"
+#: ../lib/htmldriver/Graph_Set.c:111 ../lib/htmldriver/Graph_Set.c:115
+#: ../lib/htmldriver/Graph_Set.c:119
+#, c-format
+msgid "html: type '%s'"
+msgstr "html: 타입 '%s'"
+#: ../lib/nviz/lights.c:171
+#, fuzzy
+msgid "Unable to define new light"
+#: ../lib/nviz/nviz.c:128
+#, c-format
+msgid "Invalid color (%s), using \"white\" as default"
+msgstr "잘못된 색상(%s)입니다. \"white\"를 기본값으로 사용합니다."
+#: ../lib/nviz/position.c:56
+#, fuzzy
+msgid "Unable to set focus"
+#: ../lib/nviz/render.c:106
+msgid "Bad server connection"
+msgstr "서버접속 오류입니다."
+#: ../lib/nviz/render.c:112
+#, fuzzy
+msgid "Unable to get visual info"
+#: ../lib/nviz/render.c:119
+#, fuzzy
+msgid "Unable to create rendering context"
+#: ../lib/nviz/map_obj.c:59
+msgid "Maximum surfaces loaded!"
+msgstr "최대 표면 개수를 초과했습니다!"
+#: ../lib/nviz/map_obj.c:88
+msgid "Maximum vector line maps loaded!"
+msgstr "최대 선벡터맵 개수를 초과했습니다!"
+#: ../lib/nviz/map_obj.c:97 ../lib/nviz/map_obj.c:128
#, fuzzy, c-format
-msgid "Area %d has no boundaries"
+msgid "Error loading vector map <%s>"
-#: ../lib/vector/vedit/select.c:231
-msgid "Unknown query tool"
+#: ../lib/nviz/map_obj.c:116
+msgid "Maximum vector point maps loaded!"
+msgstr "최대 점벡터지도 개수를 초과했습니다!"
+#: ../lib/nviz/map_obj.c:143
+msgid "Maximum volumes loaded!"
+msgstr "최대 부피를 초과했습니다!"
+#: ../lib/nviz/map_obj.c:152
+#, fuzzy, c-format
+msgid "Error loading 3d raster map <%s>"
+#: ../lib/nviz/map_obj.c:160
+msgid "Nviz_new_map_obj(): unsupported data type"
+msgstr "Nviz_new_map_obj(): 지원하지 않는 자료형입니다."
+#: ../lib/sites/sites.c:106
+#, c-format
+msgid "Attributes for category %d not found"
+msgstr "카테고리 %d를 위한 속성을 찾을 수 없습니다."
+#: ../lib/sites/sites.c:151
+msgid "Category must be integer"
+#: ../lib/sites/sites.c:226
+msgid "Memory error in writing timestamp"
+msgstr "타임스탬프를 쓰는 중 메모리오류가 났습니다."
+#: ../lib/sites/sites.c:228
+msgid "Illegal TimeStamp string"
+msgstr "잘못된 타임스탬프 문자열입니다."
+#: ../lib/sites/sites.c:255 ../lib/sites/sites.c:387
+msgid ""
+"Dev note: Adapted sites library used for vector points. (module should be "
+"updated to GRASS 6 vector library)"
msgstr ""
+"개발자 노트: 벡터점 지원을 위해 변형된 사이트 라이브러리를 사용했습니다. (모"
+"듈을 GRASS 6 벡터 라이브러리로 업데이트해야 합니다.)"
+#: ../lib/sites/sites.c:306
#, fuzzy
+msgid "Cannot fetch row"
+#: ../lib/sites/sites.c:443
+msgid "G_oldsite_new_struct: invalid # dims or fields"
+msgstr "G_oldsite_new_struct: 잘못된 차원 또는 필드 개수입니다."
+#: ../lib/sites/sites.c:671
+msgid ""
+"G_oldsite_describe() must be called immediately after G_fopen_sites_old()."
+msgstr "G_fopen_sites_old() 다음 즉시 G_oldsite_describe()를 호출해야 합니다."
+#: ../lib/temporal/lib/default_name.c:69
+msgid "Programmer error - only SQLite driver is currently supported"
+msgstr ""
+#, fuzzy
#~ msgid "Unable to select space time dataset register table <%s>"
#~ msgstr "Datum %s 테이블파일을 열 수 없습니다"
Modified: grass/trunk/locale/po/grassmods_ko.po
--- grass/trunk/locale/po/grassmods_ko.po 2014-05-03 20:19:21 UTC (rev 60060)
+++ grass/trunk/locale/po/grassmods_ko.po 2014-05-03 21:04:35 UTC (rev 60061)
@@ -7,7 +7,7 @@
msgstr ""
"Project-Id-Version: grassmods_ko\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2014-03-31 21:29+0200\n"
+"POT-Creation-Date: 2014-05-03 16:44-0400\n"
"PO-Revision-Date: 2005-08-09 22:53-0500\n"
"Last-Translator: Huidae Cho\n"
"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
@@ -16,5433 +16,7005 @@
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-#: ../raster/r.out.pov/main.c:121 ../raster/r.out.vrml/main.c:47
-#: ../raster/r.regression.multi/main.c:128 ../raster/r.clump/main.c:49
-#: ../raster/r.sunhours/main.c:71 ../raster/r.external.out/main.c:214
-#: ../raster/r.in.arc/main.c:60 ../raster/r.stream.snap/main.c:49
-#: ../raster/r.usler/main.c:52 ../raster/r.mode/main.c:54
-#: ../raster/r.cost/main.c:140 ../raster/r.transect/main.c:103
-#: ../raster/r.support/main.c:55 ../raster/r.watershed/front/main.c:72
-#: ../raster/r.composite/main.c:72 ../raster/r.stats.zonal/main.c:101
-#: ../raster/r.category/main.c:52 ../raster/r.coin/main.c:66
-#: ../raster/r.tile/main.c:42 ../raster/r.in.xyz/main.c:159
-#: ../raster/r.series/main.c:133 ../raster/r.grow.distance/main.c:151
-#: ../raster/r.out.ppm3/main.c:56 ../raster/r.ros/main.c:213
-#: ../raster/r.null/main.c:59 ../raster/r.sunmask/main.c:116
-#: ../raster/r.latlong/main.c:56 ../raster/r.in.gridatb/main.c:45
-#: ../raster/r.in.poly/main.c:29 ../raster/r.what.color/main.c:88
-#: ../raster/r.support.stats/main.c:38 ../raster/r.out.arc/main.c:60
-#: ../raster/r.colors/edit_colors.c:63 ../raster/r.in.ascii/main.c:69
-#: ../raster/r.stream.segment/main.c:57 ../raster/r.out.ppm/main.c:53
-#: ../raster/r.random.cells/main.c:45 ../raster/r.grow/main.c:122
-#: ../raster/r.stats/main.c:105 ../raster/r.statistics/main.c:55
-#: ../raster/r.drain/main.c:109 ../raster/r.info/main.c:69
-#: ../raster/r.param.scale/interface.c:54 ../raster/r.buffer/main.c:66
-#: ../raster/r.covar/main.c:51 ../raster/r.mfilter/main.c:56
-#: ../raster/r.volume/main.c:75 ../raster/r.stream.stats/main.c:53
-#: ../raster/r.out.vtk/main.c:59 ../raster/r.gwflow/main.c:208
-#: ../raster/r.quant/main.c:47 ../raster/simwe/r.sim.sediment/main.c:111
-#: ../raster/simwe/r.sim.water/main.c:110 ../raster/r.region/main.c:51
-#: ../raster/r.timestamp/main.c:35 ../raster/r.mapcalc/main.c:111
-#: ../raster/r.out.ascii/main.c:59 ../raster/r.random.surface/main.c:57
-#: ../raster/r.resamp.bspline/main.c:80 ../raster/r.lake/main.c:150
-#: ../raster/r.quantile/main.c:255 ../raster/r.surf.idw/main.c:103
-#: ../raster/r.water.outlet/main.c:67 ../raster/r.stats.quantile/main.c:389
-#: ../raster/r.report/main.c:67 ../raster/r.le/r.le.patch/main.c:48
-#: ../raster/r.le/r.le.trace/main.c:55 ../raster/r.le/r.le.setup/main.c:57
-#: ../raster/r.le/r.le.pixel/main.c:45 ../raster/r.distance/main.c:38
-#: ../raster/r.out.gridatb/main.c:67 ../raster/r.out.gdal/main.c:129
-#: ../raster/r.random/main.c:51 ../raster/r.series.interp/main.c:64
-#: ../raster/r.spread/main.c:102 ../raster/r.series.accumulate/main.c:80
-#: ../raster/r.topidx/main.c:39 ../raster/r.stream.distance/main.c:53
-#: ../raster/r.basins.fill/main.c:54 ../raster/r.in.gdal/main.c:81
-#: ../raster/r.to.vect/main.c:70 ../raster/r.topmodel/main.c:48
-#: ../raster/r.circle/main.c:51 ../raster/r.rescale.eq/main.c:52
-#: ../raster/r.in.mat/main.c:91 ../raster/r.surf.gauss/main.c:38
-#: ../raster/r.regression.line/main.c:46 ../raster/r.out.mat/main.c:62
-#: ../raster/r.fill.dir/main.c:86 ../raster/r.walk/main.c:179
-#: ../raster/r.in.png/main.c:519 ../raster/r.stream.channel/main.c:56
-#: ../raster/r.his/main.c:62 ../raster/r.stream.slope/main.c:72
-#: ../raster/r.thin/main.c:56 ../raster/r.to.rast3/main.c:197
-#: ../raster/r.surf.idw2/main.c:61 ../raster/r.resamp.rst/main.c:148
-#: ../raster/r.carve/main.c:74 ../raster/r.rescale/main.c:48
-#: ../raster/r.resamp.stats/main.c:256 ../raster/r.cross/main.c:69
-#: ../raster/r.texture/main.c:101 ../raster/r.stream.extract/main.c:76
-#: ../raster/r.li/r.li.mpa/mpa.c:44 ../raster/r.li/r.li.renyi/renyi.c:47
-#: ../raster/r.li/r.li.patchdensity/main.c:51
-#: ../raster/r.li/r.li.patchnum/main.c:50
-#: ../raster/r.li/r.li.richness/richness.c:43
-#: ../raster/r.li/r.li.shape/main.c:49 ../raster/r.li/r.li.padsd/padsd.c:53
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:45
-#: ../raster/r.li/r.li.pielou/pielou.c:46 ../raster/r.li/r.li.padcv/padcv.c:53
-#: ../raster/r.li/r.li.shannon/shannon.c:46 ../raster/r.li/r.li.mps/mps.c:52
-#: ../raster/r.li/r.li.simpson/simpson.c:46
-#: ../raster/r.li/r.li.dominance/dominance.c:46
-#: ../raster/r.li/r.li.padrange/padrange.c:53
-#: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.what/main.c:98
-#: ../raster/r.to.rast3elev/main.c:361 ../raster/r.horizon/main.c:178
-#: ../raster/r.compress/main.c:62 ../raster/r.colors.out/raster_main.c:45
-#: ../raster/r.proj/main.c:144 ../raster/r.sun/main.c:237
-#: ../raster/r.profile/main.c:50 ../raster/r.solute.transport/main.c:229
-#: ../raster/r.slope.aspect/main.c:151 ../raster/r.resamp.interp/main.c:76
-#: ../raster/r.contour/main.c:86 ../raster/r.uslek/main.c:53
-#: ../raster/r.digit/main.c:44 ../raster/r.in.lidar/main.c:161
-#: ../raster/r.surf.contour/main.c:60 ../raster/r.shaded.relief/main.c:106
-#: ../raster/r.external/main.c:55 ../raster/r.out.png/main.c:112
-#: ../raster/r.out.tiff/main.c:92 ../raster/r.resamp.filter/main.c:384
-#: ../raster/r.resample/main.c:54 ../raster/r.in.bin/main.c:235
-#: ../raster/r.kappa/main.c:68 ../raster/r.out.mpeg/main.c:102
-#: ../raster/r.recode/main.c:48 ../raster/r.neighbors/main.c:139
-#: ../raster/r.spreadpath/main.c:89 ../raster/r.univar/r.univar_main.c:100
-#: ../raster/r.patch/main.c:52 ../raster/r.out.bin/main.c:279
-#: ../raster/r.surf.fractal/main.c:38 ../raster/r.bitpattern/main.c:63
-#: ../raster/r.stream.order/main.c:75 ../raster/r.reclass/main.c:50
-#: ../raster/r.surf.random/main.c:36 ../raster/r.surf.area/main.c:76
-#: ../raster/r.flow/main.c:422 ../raster/r.describe/main.c:54
-#: ../raster/r.los/main.c:93 ../doc/raster/r.example/main.c:83
-#: ../misc/m.nviz.image/main.c:52 ../misc/m.nviz.script/main.c:71
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
-#: ../locale/scriptstrings/i.spectral_to_translate.c:4
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
-#: ../locale/scriptstrings/v.krige_to_translate.c:4
-#: ../locale/scriptstrings/r.pack_to_translate.c:2
-#: ../locale/scriptstrings/r.tileset_to_translate.c:2
-#: ../locale/scriptstrings/r.mask_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:4
-#: ../locale/scriptstrings/r.rgb_to_translate.c:2
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
-#: ../locale/scriptstrings/r.grow_to_translate.c:2
-#: ../locale/scriptstrings/r.blend_to_translate.c:2
-#: ../locale/scriptstrings/r.plane_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:2
-#: ../display/d.rgb/main.c:55 ../display/d.colortable/main.c:61
-#: ../display/d.profile/main.c:193 ../display/d.what.rast/main.c:50
-#: ../display/d.rast.arrow/main.c:97 ../display/d.colors/main.c:42
-#: ../display/d.rast.num/main.c:77 ../display/d.rast/main.c:55
-#: ../raster3d/r3.cross.rast/main.c:230 ../raster3d/r3.to.rast/main.c:208
-#: ../visualization/ximgview/main.c:292 ../vector/v.what.rast3/main.c:66
-#: ../vector/v.sample/main.c:77 ../vector/v.what.rast/main.c:73
-#: ../vector/v.to.rast/main.c:46 ../vector/v.neighbors/main.c:52
-msgid "raster"
+#: ../general/g.mapsets/main.c:63 ../general/g.setproj/main.c:78
+#: ../general/g.rename/main.c:43 ../general/g.findetc/main.c:28
+#: ../general/g.access/main.c:37 ../general/g.proj/main.c:63
+#: ../general/g.region/main.c:63 ../general/g.dirseps/main.c:34
+#: ../general/g.remove/main.c:101 ../general/g.gui/main.c:37
+#: ../general/g.findfile/main.c:38 ../general/g.ppmtopng/main.c:117
+#: ../general/g.version/main.c:60 ../general/g.mapset/main.c:49
+#: ../general/g.message/main.c:33 ../general/g.mlist/main.c:62
+#: ../general/g.copy/main.c:41 ../general/g.cairocomp/main.c:196
+#: ../general/g.mkfontcap/main.c:71 ../general/g.tempfile/main.c:38
+#: ../general/g.gisenv/main.c:43 ../general/g.list/main.c:44
+#: ../general/g.pnmcomp/main.c:282 ../general/g.filename/main.c:39
+#: ../general/g.mremove/main.c:61 ../general/g.pnmcat/main.c:121
+#: ../locale/scriptstrings/g.extension_to_translate.c:3
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
+#: ../locale/scriptstrings/g.manual_to_translate.c:2
+msgid "general"
msgstr ""
-#: ../raster/r.out.pov/main.c:122 ../raster/r.out.vrml/main.c:48
-#: ../raster/r.external.out/main.c:215 ../raster/r.out.ppm3/main.c:57
-#: ../raster/r.out.arc/main.c:61 ../raster/r.out.ppm/main.c:54
-#: ../raster/r.out.vtk/main.c:60 ../raster/r.out.ascii/main.c:60
-#: ../raster/r.out.gridatb/main.c:68 ../raster/r.out.gdal/main.c:130
-#: ../raster/r.out.mat/main.c:63 ../raster/r.colors.out/raster3d_main.c:48
-#: ../raster/r.colors.out/raster_main.c:47 ../raster/r.out.png/main.c:113
-#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.mpeg/main.c:103
-#: ../raster/r.out.bin/main.c:280
-#: ../locale/scriptstrings/r.pack_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
-#: ../locale/scriptstrings/d.out.file_to_translate.c:3
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:3
-#: ../raster3d/r3.out.vtk/main.c:378 ../raster3d/r3.out.netcdf/main.c:587
-#: ../raster3d/r3.out.v5d/main.c:285 ../raster3d/r3.out.bin/main.c:206
-#: ../raster3d/r3.out.ascii/main.c:307 ../vector/v.out.dxf/main.c:57
-#: ../vector/v.out.ogr/main.c:81 ../vector/v.out.ascii/main.c:48
-#: ../vector/v.out.svg/main.c:78 ../vector/v.external.out/main.c:44
-#: ../vector/v.out.pov/main.c:47 ../vector/v.colors.out/main.c:51
-#: ../vector/v.out.vtk/main.c:48 ../vector/v.out.postgis/main.c:45
-msgid "export"
+#: ../general/g.mapsets/main.c:64 ../general/g.region/main.c:64
+#: ../general/g.mapset/main.c:50 ../general/g.gisenv/main.c:44
+#: ../display/d.font/main.c:46 ../display/d.fontlist/main.c:39
+#: ../display/d.colorlist/main.c:36
+#, fuzzy
+msgid "settings"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:65
+msgid "search path"
msgstr ""
-#: ../raster/r.out.pov/main.c:124
+#: ../general/g.mapsets/main.c:66
+msgid "Modifies/prints the user's current mapset search path."
+msgstr ""
+#: ../general/g.mapsets/main.c:67
+msgid ""
+"Affects the user's access to data existing under the other mapsets in the "
+"current location."
+msgstr ""
+#: ../general/g.mapsets/main.c:73
#, fuzzy
-msgid "Converts a raster map layer into a height-field file for POV-Ray."
+msgid "Name(s) of existing mapset(s) to add/remove or set"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.pov/main.c:131
-msgid "Name of output povray file (TGA height field file)"
+#: ../general/g.mapsets/main.c:74 ../general/g.mapsets/main.c:83
+msgid "Search path"
msgstr ""
-#: ../raster/r.out.pov/main.c:138
-msgid "Height-field type (0=actual heights 1=normalized)"
+#: ../general/g.mapsets/main.c:82
+#, fuzzy
+msgid "Operation to perform"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:87
+#, fuzzy
+msgid "Field separator for printing (-l and -p flags)"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:89 ../general/g.mapsets/main.c:94
+#: ../general/g.mapsets/main.c:100 ../general/g.proj/main.c:79
+#: ../general/g.proj/main.c:85 ../general/g.proj/main.c:91
+#: ../general/g.proj/main.c:97 ../general/g.proj/main.c:103
+#: ../general/g.proj/main.c:114 ../general/g.proj/main.c:119
+#: ../general/g.region/main.c:84 ../general/g.region/main.c:90
+#: ../general/g.region/main.c:95 ../general/g.region/main.c:101
+#: ../general/g.region/main.c:107 ../general/g.region/main.c:113
+#: ../general/g.region/main.c:119 ../general/g.region/main.c:127
+#: ../general/g.region/main.c:132 ../general/g.region/main.c:138
+#: ../general/g.region/main.c:143 ../general/g.mapset/main.c:89
+#: ../general/g.mapset/main.c:95 ../general/g.mlist/main.c:114
+#: ../general/g.mlist/main.c:119 ../general/g.mlist/main.c:124
+#: ../general/g.mlist/main.c:129 ../imagery/i.group/main.c:79
+#: ../imagery/i.group/main.c:84 ../imagery/i.group/main.c:89
+#: ../raster/r.out.gdal/main.c:135 ../raster/r.sunmask/main.c:231
+#: ../raster/r.sunmask/main.c:237 ../raster/r.proj/main.c:210
+#: ../raster/r.proj/main.c:220 ../raster/r.proj/main.c:226
+#: ../raster/r.in.gdal/main.c:152 ../raster/r.colors/edit_colors.c:128
+#: ../raster/r.external/main.c:94 ../raster/r.external.out/main.c:251
+#: ../raster/r.external.out/main.c:262 ../raster/r.what/main.c:124
+#: ../raster/r.what/main.c:132 ../raster/r.what/main.c:146
+#: ../raster/r.what/main.c:151 ../raster/r.what/main.c:156
+#: ../raster/r.what/main.c:161 ../raster/r.stream.stats/main.c:89
+#: ../raster/r.stream.stats/main.c:94 ../vector/v.in.ogr/main.c:249
+#: ../vector/v.in.ogr/main.c:255 ../vector/v.external.out/args.c:50
+#: ../vector/v.external.out/args.c:62 ../vector/v.external.out/args.c:68
+#: ../vector/v.db.connect/main.c:83 ../vector/v.db.connect/main.c:88
+#: ../vector/v.db.connect/main.c:95 ../vector/v.db.connect/main.c:102
+#: ../vector/v.external/args.c:41 ../vector/v.external/args.c:47
+#: ../vector/v.external/args.c:55 ../vector/v.colors/main.c:134
+#: ../vector/v.what/main.c:89 ../vector/v.what/main.c:94
+#: ../vector/v.what/main.c:99 ../vector/v.to.db/parse.c:116
+#: ../vector/v.to.db/parse.c:121 ../vector/v.to.db/parse.c:127
+#: ../vector/v.to.db/parse.c:133 ../vector/v.info/parse.c:25
+#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
+#: ../vector/v.info/parse.c:41 ../vector/v.info/parse.c:46
+#: ../display/d.mon/main.c:100 ../display/d.mon/main.c:105
+#: ../display/d.mon/main.c:110
+#: ../locale/scriptstrings/g.extension_to_translate.c:13
+#: ../locale/scriptstrings/g.extension_to_translate.c:15
+#: ../locale/scriptstrings/g.extension_to_translate.c:17
+#: ../locale/scriptstrings/g.extension_to_translate.c:19
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
+#: ../db/db.connect/main.c:53 ../db/db.connect/main.c:58
+#: ../temporal/t.connect/main.c:43
+msgid "Print"
msgstr ""
-#: ../raster/r.out.pov/main.c:144
-msgid "Elevation bias"
+#: ../general/g.mapsets/main.c:93
+msgid "List all available mapsets in alphabetical order"
msgstr ""
-#: ../raster/r.out.pov/main.c:150 ../raster/r.param.scale/interface.c:115
-msgid "Vertical scaling factor"
+#: ../general/g.mapsets/main.c:99
+msgid "Print mapsets in current search path"
msgstr ""
-#: ../raster/r.out.pov/main.c:170
-#, c-format
-msgid "Invalid output filename <%s>"
+#: ../general/g.mapsets/main.c:105
+msgid "Launch mapset selection GUI dialog"
msgstr ""
-#: ../raster/r.out.pov/main.c:173 ../raster/r.out.vrml/main.c:138
-#: ../raster/r.support/main.c:166 ../raster/r.topmodel/file_io.c:229
-#: ../raster/r.out.mat/main.c:91 ../raster/r.colors.out/raster3d_main.c:80
-#: ../raster/r.colors.out/raster_main.c:79 ../raster/r.out.png/main.c:205
-#: ../general/g.pnmcat/main.c:170 ../general/g.cairocomp/main.c:66
-#: ../raster3d/r3.support/main.c:152 ../vector/v.colors.out/main.c:103
+#: ../general/g.mapsets/main.c:128
+#, fuzzy, c-format
+msgid "Unknown operation '%s'"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:138 ../general/g.mapsets/main.c:140
+#: ../general/g.mapsets/main.c:150 ../display/d.mon/main.c:138
#, c-format
-msgid "Unable to open output file <%s>"
+msgid "Flag -%c ignored"
msgstr ""
-#: ../raster/r.out.pov/main.c:180
+#: ../general/g.mapsets/main.c:142 ../general/g.mapsets/main.c:152
+#: ../general/g.mapsets/main.c:160 ../display/d.mon/main.c:180
+#, fuzzy, c-format
+msgid "Option <%s> ignored"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:176 ../general/g.mapsets/main.c:210
+#, fuzzy, c-format
+msgid "Mapset <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:183 ../general/g.mapsets/main.c:242
#, c-format
-msgid "Raster map is too big! Exceeds %d columns or %d rows"
+msgid "Current mapset (<%s>) must always included in the search path"
msgstr ""
-#: ../raster/r.out.pov/main.c:201
-msgid "Negative elevation values in input"
+#: ../general/g.mapsets/main.c:205
+#, fuzzy, c-format
+msgid "Mapset <%s> already in the path"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/main.c:212
+#, c-format
+msgid "Mapset <%s> added to search path"
msgstr ""
-#: ../raster/r.out.vrml/main.c:49
-msgid "VRML"
+#: ../general/g.mapsets/main.c:245
+#, c-format
+msgid "Mapset <%s> removed from search path"
msgstr ""
-#: ../raster/r.out.vrml/main.c:51
-msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+#: ../general/g.mapsets/main.c:257
+msgid "Search path not modified"
msgstr ""
-#: ../raster/r.out.vrml/main.c:58
-msgid "Name of elevation map"
+#: ../general/g.mapsets/main.c:275
+#, fuzzy
+msgid "Unable to open SEARCH_PATH for write"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapsets/list.c:10
+msgid "Available mapsets:"
msgstr ""
-#: ../raster/r.out.vrml/main.c:65
-msgid "Name of color file"
+#: ../general/g.mapsets/list.c:35
+msgid "Accessible mapsets:"
msgstr ""
-#: ../raster/r.out.vrml/main.c:72 ../misc/m.nviz.image/args.c:572
-msgid "Vertical exaggeration"
+#: ../general/g.setproj/get_stp.c:43
+msgid "This should not happen see your system admin"
msgstr ""
-#: ../raster/r.out.vrml/main.c:76
+#: ../general/g.setproj/get_stp.c:99
#, fuzzy
-msgid "Name for output VRML file"
+msgid "Unable to open FIPS code file"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.vrml/main.c:95
+#: ../general/g.setproj/get_stp.c:125
#, c-format
-msgid "Range info for [%s] not available (run r.support)"
+msgid "No match of fips state %d county %d"
msgstr ""
-#: ../raster/r.out.vrml/main.c:104
+#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
+#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
+#: ../raster/r.in.arc/main.c:113 ../raster/r.in.ascii/main.c:128
+#: ../raster/r.in.ascii/main.c:158 ../raster/r.resamp.rst/main.c:558
+#: ../vector/v.in.ascii/main.c:255 ../vector/v.surf.rst/main.c:824
+#: ../display/d.title/main.c:117
#, fuzzy, c-format
-msgid "Range info for <%s> not available (run r.support)"
+msgid "Unable to open temporary file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.vrml/main.c:136
-#, c-format
-msgid "Opening %s for writing... "
+#: ../general/g.setproj/get_stp.c:179
+#, fuzzy
+msgid "Reading sf key_value temp file"
+msgstr "출력할 래스터맵"
+#: ../general/g.setproj/get_stp.c:212
+msgid "Invalid State FIPS code"
msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:38
-msgid "Writing vertices..."
+#: ../general/g.setproj/get_stp.c:302
+#, fuzzy
+msgid "Reading cf key_value temp file"
+msgstr "출력할 래스터맵"
+#: ../general/g.setproj/get_stp.c:336
+msgid "Invalid County FIPS code"
msgstr ""
-#: ../raster/r.out.vrml/put_grid.c:83
-msgid "Writing color file..."
+#: ../general/g.setproj/proj.c:168
+#, c-format
+msgid "Unrecognized 'ask' value in parms.table: %s"
msgstr ""
-#: ../raster/r.regression.multi/main.c:61
-msgid "Matrix is unsolvable"
+#: ../general/g.setproj/proj.c:178
+#, c-format
+msgid "Unrecognized default value in parms.table: %s"
msgstr ""
-#: ../raster/r.regression.multi/main.c:129 ../raster/r.clump/main.c:50
-#: ../raster/r.mode/main.c:56 ../raster/r.stats.zonal/main.c:102
-#: ../raster/r.coin/main.c:67 ../raster/r.support.stats/main.c:39
-#: ../raster/r.stats/main.c:106 ../raster/r.statistics/main.c:56
-#: ../raster/r.covar/main.c:52 ../raster/r.mfilter/main.c:58
-#: ../raster/r.quant/main.c:49 ../raster/r.quantile/main.c:257
-#: ../raster/r.stats.quantile/main.c:390 ../raster/r.report/main.c:68
-#: ../raster/r.regression.line/main.c:47 ../raster/r.cross/main.c:70
-#: ../raster/r.texture/main.c:103 ../raster/r.kappa/main.c:69
-#: ../raster/r.neighbors/main.c:141 ../raster/r.univar/r3.univar_main.c:99
-#: ../raster/r.univar/r.univar_main.c:101 ../raster/r.surf.area/main.c:78
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.report_to_translate.c:4
-#: ../locale/scriptstrings/db.univar_to_translate.c:3
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
-#: ../locale/scriptstrings/i.oif_to_translate.c:4
-#: ../locale/scriptstrings/d.correlate_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
-#: ../display/d.histogram/main.c:86 ../raster3d/r3.stats/main.c:569
-#: ../raster3d/r3.neighbors/main.c:211 ../imagery/i.cca/main.c:85
-#: ../vector/v.univar/main.c:93 ../vector/v.class/main.c:48
-#: ../vector/v.qcount/main.c:61 ../vector/v.normal/main.c:75
-#: ../vector/v.kcv/main.c:63 ../vector/v.perturb/main.c:63
-#: ../vector/v.random/main.c:87 ../vector/v.neighbors/main.c:51
-#: ../vector/v.outlier/main.c:70
+#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:64
+#: ../raster/r.proj/main.c:145 ../raster/r.latlong/main.c:59
+#: ../vector/v.proj/main.c:67 ../locale/scriptstrings/m.proj_to_translate.c:3
#, fuzzy
-msgid "statistics"
+msgid "projection"
msgstr "출력할 래스터맵"
-#: ../raster/r.regression.multi/main.c:131
-#, fuzzy
-msgid "Calculates multiple linear regression from raster maps."
-msgstr "출력할 래스터맵"
+#: ../general/g.setproj/main.c:81
+msgid "Interactively reset the location's projection settings."
+msgstr ""
-#: ../raster/r.regression.multi/main.c:136
-#: ../raster/r.regression.line/main.c:54
-msgid "Map for x coefficient"
+#: ../general/g.setproj/main.c:88
+msgid "You must be in the PERMANENT mapset to run g.setproj"
msgstr ""
-#: ../raster/r.regression.multi/main.c:140
-#: ../raster/r.regression.line/main.c:58
-msgid "Map for y coefficient"
+#: ../general/g.setproj/main.c:101
+msgid "PERMANENT: permission denied"
msgstr ""
-#: ../raster/r.regression.multi/main.c:145
-msgid "Map to store residuals"
+#: ../general/g.setproj/main.c:105
+msgid "Current region cannot be set"
msgstr ""
-#: ../raster/r.regression.multi/main.c:150
-msgid "Map to store estimates"
+#: ../general/g.setproj/main.c:108
+msgid "Retrieving and setting region failed"
msgstr ""
-#: ../raster/r.regression.multi/main.c:156
-#: ../raster/r.regression.line/main.c:64
+#: ../general/g.setproj/main.c:135
+msgid "Would you still like to change some of the parameters?"
+msgstr ""
+#: ../general/g.setproj/main.c:137
+msgid "The projection information will not be updated"
+msgstr ""
+#: ../general/g.setproj/main.c:148
+#, c-format
msgid ""
-"ASCII file for storing regression coefficients (output to screen if file not "
-"specified)."
+"Zone in default geographic region definition: %d\n"
+" is different from zone in PROJ_INFO file: %d"
msgstr ""
-#: ../raster/r.regression.multi/main.c:160
-#: ../raster/r.regression.line/main.c:68 ../general/g.region/main.c:142
-#: ../locale/scriptstrings/i.oif_to_translate.c:6 ../imagery/i.group/main.c:88
-msgid "Print in shell script style"
+#: ../general/g.setproj/main.c:158
+msgid "XY-location cannot be projected"
msgstr ""
-#: ../raster/r.regression.multi/main.c:168 ../raster/r.stats/main.c:231
-#: ../raster/r.regression.line/main.c:76 ../raster/r.what/main.c:174
-#: ../raster/r.univar/r3.univar_main.c:124
-#: ../raster/r.univar/r.univar_main.c:116 ../db/db.select/main.c:141
-#: ../vector/v.db.select/main.c:114
-#, fuzzy, c-format
-msgid "Unable to open file <%s> for writing"
-msgstr "출력할 래스터맵"
+#: ../general/g.setproj/main.c:192
+msgid "Unknown projection"
+msgstr ""
-#: ../raster/r.regression.multi/main.c:248
-#, fuzzy
-msgid "First pass..."
-msgstr "출력할 래스터맵"
+#: ../general/g.setproj/main.c:198
+#, c-format
+msgid "Projection %s is not specified in the file 'proj-parms.table'"
+msgstr ""
-#: ../raster/r.regression.multi/main.c:321
-#, fuzzy
-msgid "Not enough valid cells available"
-msgstr "출력할 래스터맵"
+#: ../general/g.setproj/main.c:205
+msgid "Do you wish to specify a geodetic datum for this location?"
+msgstr ""
-#: ../raster/r.regression.multi/main.c:335
-msgid "Multiple regression failed"
+#: ../general/g.setproj/main.c:214
+#, c-format
+msgid "The current datum is %s (%s)"
msgstr ""
-#: ../raster/r.regression.multi/main.c:340
-msgid "Second pass..."
+#: ../general/g.setproj/main.c:217
+msgid "Do you wish to change the datum (or datum transformation parameters)?"
msgstr ""
-#: ../raster/r.clump/main.c:51
-msgid "reclass"
+#: ../general/g.setproj/main.c:225
+msgid "The datum information has not been changed"
msgstr ""
-#: ../raster/r.clump/main.c:53
+#: ../general/g.setproj/main.c:288
+#, c-format
+msgid "The current ellipsoid is %s"
+msgstr ""
+#: ../general/g.setproj/main.c:290
+msgid "Do you want to change ellipsoid parameter?"
+msgstr ""
+#: ../general/g.setproj/main.c:294
+msgid "The ellipse information has not been changed"
+msgstr ""
+#: ../general/g.setproj/main.c:311
+#, c-format
+msgid "The radius is currently %f"
+msgstr ""
+#: ../general/g.setproj/main.c:312
+msgid "Do you want to change the radius?"
+msgstr ""
+#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
+msgid "Enter radius for the sphere in meters"
+msgstr ""
+#: ../general/g.setproj/main.c:336
+msgid "Invalid input ellipsoid"
+msgstr ""
+#: ../general/g.setproj/main.c:447
+#, c-format
+msgid "The UTM zone is now set to %d"
+msgstr ""
+#: ../general/g.setproj/main.c:450
+msgid "Do you want to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:451
+msgid "UTM zone information has not been updated"
+msgstr ""
+#: ../general/g.setproj/main.c:456
msgid ""
-"Recategorizes data in a raster map by grouping cells that form physically "
-"discrete areas into unique categories."
+"But if you change zone, all the existing data will be interpreted by "
+"projection software. GRASS will not automatically re-project or even change "
+"the headers for existing maps."
msgstr ""
-#: ../raster/r.clump/main.c:64 ../raster/r.recode/main.c:66
-#, fuzzy
-msgid "Title for output raster map"
+#: ../general/g.setproj/main.c:461
+msgid "Would you still like to change the UTM zone?"
+msgstr ""
+#: ../general/g.setproj/main.c:497
+#, fuzzy, c-format
+msgid "Error writing PROJ_INFO file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.clump/main.c:68
-msgid "Clump also diagonal cells"
+#: ../general/g.setproj/main.c:571
+#, c-format
+msgid "Enter plural form of units [meters]: "
msgstr ""
-#: ../raster/r.clump/main.c:69
-msgid "Clumps are also traced along diagonal neighboring cells"
+#: ../general/g.setproj/main.c:603
+#, c-format
+msgid "Enter singular for unit: "
msgstr ""
-#: ../raster/r.clump/main.c:110
+#: ../general/g.setproj/main.c:611
+#, c-format
+msgid "Enter conversion factor from %s to meters: "
+msgstr ""
+#: ../general/g.setproj/main.c:636
#, fuzzy, c-format
-msgid "%d clump."
-msgid_plural "%d clumps."
-msgstr[0] "출력할 래스터맵"
-msgstr[1] "출력할 래스터맵"
+msgid "Error writing into UNITS output file <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.clump/clump.c:72
+#: ../general/g.setproj/main.c:643
#, fuzzy
-msgid "Unable to open temp file"
+msgid "Unable to write to DEFAULT_WIND region file"
msgstr "출력할 래스터맵"
-#: ../raster/r.clump/clump.c:94
-msgid "Pass 1..."
+#: ../general/g.setproj/main.c:645
+#, c-format
+msgid ""
+"\n"
+"Projection information has been recorded for this location\n"
+"\n"
msgstr ""
-#: ../raster/r.clump/clump.c:207 ../raster/r.clump/clump.c:221
+#: ../general/g.setproj/main.c:647
+msgid "The geographic region information in WIND is now obsolete"
+msgstr ""
+#: ../general/g.setproj/main.c:648
+msgid "Run g.region -d to update it"
+msgstr ""
+#: ../general/g.rename/main.c:44 ../general/g.findetc/main.c:29
+#: ../general/g.access/main.c:38 ../general/g.dirseps/main.c:35
+#: ../general/g.remove/main.c:102 ../general/g.findfile/main.c:39
+#: ../general/g.mlist/main.c:63 ../general/g.copy/main.c:42
+#: ../general/g.list/main.c:45 ../general/g.filename/main.c:40
+#: ../general/g.mremove/main.c:62 ../imagery/i.target/main.c:46
+#: ../imagery/i.group/main.c:53 ../raster/r.compress/main.c:63
+#: ../locale/scriptstrings/t.remove_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
+#: ../locale/scriptstrings/t.register_to_translate.c:3
+#: ../locale/scriptstrings/t.create_to_translate.c:3
+#: ../locale/scriptstrings/t.rename_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
+#: ../locale/scriptstrings/t.unregister_to_translate.c:3
+#: ../locale/scriptstrings/t.list_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
#, fuzzy
-msgid "Unable to write to temp file"
+msgid "map management"
msgstr "출력할 래스터맵"
-#: ../raster/r.clump/clump.c:225
+#: ../general/g.rename/main.c:45
+#: ../locale/scriptstrings/t.rename_to_translate.c:4
#, fuzzy
-msgid "Generating renumbering scheme..."
+msgid "rename"
msgstr "출력할 래스터맵"
-#: ../raster/r.clump/clump.c:261
-msgid "Pass 2..."
+#: ../general/g.rename/main.c:47
+msgid "Renames data base element files in the user's current mapset."
msgstr ""
-#: ../raster/r.clump/clump.c:267
+#: ../general/g.rename/main.c:53
#, fuzzy
-msgid "Unable to read from temp file"
+msgid "renamed"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:72 ../raster/r.sunmask/main.c:117
-#: ../raster/r.horizon/main.c:179 ../raster/r.sun/main.c:238
-msgid "solar"
+#: ../general/g.rename/main.c:70
+#, fuzzy, c-format
+msgid "%s <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../general/g.rename/main.c:74
+#, c-format
+msgid "<%s> already exists in mapset <%s>"
msgstr ""
-#: ../raster/r.sunhours/main.c:73
-msgid "Calculates solar elevation, solar azimuth, and sun hours."
+#: ../general/g.rename/main.c:79 ../general/g.copy/main.c:80
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
+#: ../imagery/i.landsat.toar/main.c:561 ../imagery/i.landsat.acca/main.c:189
+#: ../raster/r.watershed/shed/com_line.c:231
+#: ../raster/r.watershed/shed/com_line.c:266
+#, c-format
+msgid "<%s> is an illegal file name"
msgstr ""
-#: ../raster/r.sunhours/main.c:74
-msgid ""
-"Solar elevation: the angle between the direction of the geometric center of "
-"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
-"angle from due north in clockwise direction."
+#: ../general/g.rename/main.c:84
+#, c-format
+msgid "%s=%s,%s: files could be the same, no rename possible"
msgstr ""
-#: ../raster/r.sunhours/main.c:80
+#: ../general/g.rename/main.c:94
#, fuzzy
-msgid "Output raster map with solar elevation angle"
+msgid "Renaming reclass maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:85
+#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
+msgid "have"
+msgstr ""
+#: ../general/g.access/exp_perms.c:12
+msgid "read "
+msgstr ""
+#: ../general/g.access/exp_perms.c:15
+msgid "Everyone"
+msgstr ""
+#: ../general/g.access/exp_perms.c:16
+msgid "has"
+msgstr ""
+#: ../general/g.access/exp_perms.c:19
+msgid "Only users in your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:22
+msgid "Only users outside your group"
+msgstr ""
+#: ../general/g.access/exp_perms.c:25
+msgid "Only you"
+msgstr ""
+#: ../general/g.access/exp_perms.c:31
+#, c-format
+msgid "%s %s %s %saccess to mapset %s"
+msgstr ""
+#: ../general/g.access/exp_perms.c:32
+msgid "will"
+msgstr ""
+msgid "now"
+msgstr ""
+#: ../general/g.access/main.c:39
#, fuzzy
-msgid "Output raster map with solar azimuth angle"
+msgid "permission"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:90
+#: ../general/g.access/main.c:41
+msgid "Controls access to the current mapset for other users on the system."
+msgstr ""
+#: ../general/g.access/main.c:42
#, fuzzy
-msgid "Output raster map with sunshine hours"
+msgid "If no option given, prints current status."
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:91
-msgid "Sunshine hours require solpos and Greenwich standard time"
+#: ../general/g.access/main.c:49
+msgid "Access for group"
msgstr ""
-#: ../raster/r.sunhours/main.c:98
-msgid "Year"
+#: ../general/g.access/main.c:50 ../general/g.access/main.c:58
+#: ../general/g.mapset/main.c:57 ../general/g.mapset/main.c:67
+#: ../general/g.mapset/main.c:77 ../imagery/i.landsat.toar/main.c:165
+#: ../imagery/i.landsat.toar/main.c:174 ../imagery/i.landsat.toar/main.c:184
+#: ../imagery/i.landsat.toar/main.c:193 ../imagery/i.landsat.toar/main.c:214
+#: ../imagery/i.cluster/main.c:103 ../imagery/i.cluster/main.c:120
+#: ../imagery/i.cluster/main.c:128 ../imagery/i.cluster/main.c:137
+#: ../imagery/i.cluster/main.c:145 ../imagery/i.cluster/main.c:153
+#: ../imagery/i.segment/parse_args.c:42 ../imagery/i.segment/parse_args.c:51
+#: ../imagery/i.segment/parse_args.c:62 ../imagery/i.segment/parse_args.c:73
+#: ../imagery/i.segment/parse_args.c:83 ../imagery/i.segment/parse_args.c:102
+#: ../imagery/i.segment/parse_args.c:129 ../imagery/i.segment/parse_args.c:135
+#: ../raster3d/r3.in.bin/main.c:269 ../raster3d/r3.in.bin/main.c:352
+#: ../raster3d/r3.in.bin/main.c:372 ../raster3d/r3.out.bin/main.c:228
+#: ../raster/r.in.bin/main.c:253 ../raster/r.in.bin/main.c:258
+#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:346
+#: ../raster/r.resamp.bspline/main.c:108 ../raster/r.resamp.bspline/main.c:116
+#: ../raster/r.resamp.bspline/main.c:122 ../raster/r.resamp.bspline/main.c:134
+#: ../raster/r.resamp.bspline/main.c:139 ../raster/r.slope.aspect/main.c:178
+#: ../raster/r.slope.aspect/main.c:187 ../raster/r.slope.aspect/main.c:245
+#: ../raster/r.slope.aspect/main.c:254 ../raster/r.slope.aspect/main.c:260
+#: ../raster/r.out.mpeg/main.c:133 ../raster/r.walk/main.c:275
+#: ../raster/r.walk/main.c:285 ../raster/r.walk/main.c:295
+#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
+#: ../raster/r.resamp.rst/main.c:240 ../raster/r.resamp.rst/main.c:248
+#: ../raster/r.resamp.rst/main.c:256 ../vector/v.colors.out/main.c:68
+#: ../vector/v.colors.out/main.c:73 ../vector/v.surf.bspline/main.c:140
+#: ../vector/v.surf.bspline/main.c:149 ../vector/v.surf.bspline/main.c:157
+#: ../vector/v.surf.bspline/main.c:169 ../vector/v.surf.bspline/main.c:176
+#: ../vector/v.vol.rst/main.c:271 ../vector/v.vol.rst/main.c:279
+#: ../vector/v.vol.rst/main.c:286 ../vector/v.vol.rst/main.c:314
+#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
+#: ../vector/v.vol.rst/main.c:340 ../vector/v.vol.rst/main.c:349
+#: ../vector/v.vol.rst/main.c:357 ../vector/v.db.connect/main.c:65
+#: ../vector/v.db.connect/main.c:71 ../vector/v.surf.idw/main.c:115
+#: ../vector/v.surf.idw/main.c:124 ../vector/v.surf.idw/main.c:132
+#: ../vector/v.lidar.edgedetection/main.c:95
+#: ../vector/v.lidar.edgedetection/main.c:104
+#: ../vector/v.lidar.edgedetection/main.c:113
+#: ../vector/v.lidar.edgedetection/main.c:122
+#: ../vector/v.lidar.edgedetection/main.c:131
+#: ../vector/v.lidar.edgedetection/main.c:139
+#: ../vector/v.lidar.edgedetection/main.c:148 ../display/d.mon/main.c:70
+#: ../display/d.mon/main.c:78 ../display/d.mon/main.c:86
+#: ../display/d.mon/main.c:89 ../display/d.mon/main.c:95
+#: ../display/d.mon/main.c:125 ../display/d.mon/main.c:131
+#: ../db/db.login/main.c:58 ../db/db.login/main.c:66
+msgid "Settings"
msgstr ""
-#: ../raster/r.sunhours/main.c:100 ../raster/r.sunhours/main.c:109
-#: ../raster/r.sunhours/main.c:117 ../raster/r.sunhours/main.c:126
-#: ../raster/r.sunhours/main.c:135 ../raster/r.sunhours/main.c:144
-#: ../raster/r.sunmask/main.c:152 ../raster/r.sunmask/main.c:160
-#: ../raster/r.sunmask/main.c:168 ../raster/r.sunmask/main.c:176
-#: ../raster/r.sunmask/main.c:184 ../raster/r.sunmask/main.c:192
-#: ../raster/r.sunmask/main.c:201 ../imagery/i.landsat.toar/main.c:212
-msgid "Time"
+#: ../general/g.access/main.c:57
+msgid "Access for others"
msgstr ""
-#: ../raster/r.sunhours/main.c:106
-msgid "Month"
+#: ../general/g.access/main.c:64
+msgid "UNIX filesystem access controls are not supported by MS-Windows"
msgstr ""
-#: ../raster/r.sunhours/main.c:107
-msgid "If not given, day is interpreted as day of the year"
+#: ../general/g.access/main.c:72
+msgid "Access to the PERMANENT mapset must be open, nothing changed"
msgstr ""
-#: ../raster/r.sunhours/main.c:115
-msgid "Day"
-msgstr ""
+#: ../general/g.access/main.c:76
+#, fuzzy
+msgid "Unable to determine mapset permissions"
+msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:123
-msgid "Hour"
+#: ../general/g.access/set_perms.c:26
+#, fuzzy
+msgid "Unable to change mapset permissions"
+msgstr "출력할 래스터맵"
+#: ../general/g.parser/parse.c:22
+#, c-format
+msgid "Unknown boolean value \"%s\" at line %d\n"
msgstr ""
-#: ../raster/r.sunhours/main.c:132
-msgid "Minutes"
+#: ../general/g.parser/parse.c:65
+#, fuzzy, c-format
+msgid "Unknown command \"%s\" at line %d\n"
+msgstr "출력할 래스터맵"
+#: ../general/g.parser/parse.c:97
+#, c-format
+msgid "Unknown module parameter \"%s\" at line %d\n"
msgstr ""
-#: ../raster/r.sunhours/main.c:141
-msgid "Seconds"
+#: ../general/g.parser/parse.c:134
+#, c-format
+msgid "Unknown flag parameter \"%s\" at line %d\n"
msgstr ""
-#: ../raster/r.sunhours/main.c:148
-msgid "Time is local sidereal time, not Greenwich standard time"
+#: ../general/g.parser/parse.c:149
+#, c-format
+msgid "Unknown type \"%s\" at line %d\n"
msgstr ""
-#: ../raster/r.sunhours/main.c:152
-msgid "Do not use solpos algorithm of NREL"
+#: ../general/g.parser/parse.c:227
+#, c-format
+msgid "Unknown option parameter \"%s\" at line %d\n"
msgstr ""
-#: ../raster/r.sunhours/main.c:164
-msgid "No output requested, exiting."
+#: ../general/g.parser/main.c:71
+msgid "Usage"
msgstr ""
-#: ../raster/r.sunhours/main.c:190
-msgid "NREL solpos algorithm uses Greenwich standard time."
+#: ../general/g.parser/main.c:81
+#, fuzzy
+msgid "Unable to open script file"
+msgstr "출력할 래스터맵"
+#: ../general/g.parser/main.c:96
+#, c-format
+msgid "Line too long or missing newline at line %d\n"
msgstr ""
-#: ../raster/r.sunhours/main.c:191 ../raster/r.sunhours/main.c:199
-msgid "Time will be interpreted as Greenwich standard time."
+#: ../general/g.parser/main.c:133
+#, fuzzy
+msgid "Error closing script file"
+msgstr "출력할 래스터맵"
+#: ../general/g.parser/revoke.c:63
+msgid "G_spawn() failed"
msgstr ""
-#: ../raster/r.sunhours/main.c:197
-msgid "Time will be interpreted as local sidereal time."
+#: ../general/g.parser/revoke.c:71
+msgid "execl() failed"
msgstr ""
-#: ../raster/r.sunhours/main.c:202
-msgid "Sunshine hours require NREL solpos."
+#: ../general/g.proj/input.c:91
+msgid "Error reading WKT projection description"
msgstr ""
-#: ../raster/r.sunhours/main.c:207
-msgid "Current projection is x,y (undefined)."
+#: ../general/g.proj/input.c:98
+#, fuzzy, c-format
+msgid "Unable to open file '%s' for reading"
+msgstr "출력할 래스터맵"
+#: ../general/g.proj/input.c:143
+msgid "Can't parse PROJ.4-style parameter string"
msgstr ""
-#: ../raster/r.sunhours/main.c:213
+#: ../general/g.proj/input.c:181
#, fuzzy
-msgid "Cannot get projection info of current location"
+msgid "Unable to translate EPSG code"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:216
+#: ../general/g.proj/input.c:218
+msgid "Trying to open with OGR..."
+msgstr ""
+#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
+msgid "...succeeded."
+msgstr ""
+#: ../general/g.proj/input.c:239
+msgid "Trying to open with GDAL..."
+msgstr ""
+#: ../general/g.proj/input.c:254
+#, c-format
+msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+msgstr ""
+#: ../general/g.proj/input.c:259
+#, c-format
+msgid ""
+"Read of file %s was successful, but it did not contain projection "
+"information. 'XY (unprojected)' will be used"
+msgstr ""
+#: ../general/g.proj/output.c:181
+#, c-format
+msgid "%s: Unable to convert to WKT"
+msgstr ""
+#: ../general/g.proj/main.c:65
#, fuzzy
-msgid "Cannot get projection units of current location"
+msgid "create location"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:219
+#: ../general/g.proj/main.c:68
+msgid ""
+"Prints and manipulates GRASS projection information files (in various co-"
+"ordinate system descriptions)."
+msgstr ""
+#: ../general/g.proj/main.c:71
+msgid "Can also be used to create new GRASS locations."
+msgstr ""
+#: ../general/g.proj/main.c:74
+msgid "Prints and manipulates GRASS projection information files."
+msgstr ""
+#: ../general/g.proj/main.c:81
+msgid "Print projection information in conventional GRASS format"
+msgstr ""
+#: ../general/g.proj/main.c:87
#, fuzzy
-msgid "Cannot get projection key values of current location"
+msgid "Print projection information in shell script style"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:229 ../general/g.region/printwindow.c:263
-#: ../general/g.region/printwindow.c:516 ../general/g.region/printwindow.c:647
-msgid "Unable to update lat/long projection parameters"
+#: ../general/g.proj/main.c:93
+msgid "Verify datum information and print transformation parameters"
msgstr ""
-#: ../raster/r.sunhours/main.c:293 ../raster/r.sunhours/main.c:388
-#: ../raster/r.sunmask/g_solposition.c:127
-#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
-#: ../general/g.region/printwindow.c:297 ../general/g.region/printwindow.c:305
-#: ../general/g.region/printwindow.c:534 ../general/g.region/printwindow.c:542
-#: ../general/g.region/printwindow.c:550 ../general/g.region/printwindow.c:558
-#: ../general/g.region/printwindow.c:676 ../general/g.region/printwindow.c:684
-#: ../general/g.region/printwindow.c:692 ../general/g.region/printwindow.c:700
-msgid "Error in pj_do_proj (projection of input coordinate pair)"
+#: ../general/g.proj/main.c:99
+msgid "Print projection information in PROJ.4 format"
msgstr ""
-#: ../raster/r.sunhours/main.c:321 ../raster/r.sunhours/main.c:332
-#: ../raster/r.sunhours/main.c:343 ../raster/r.mapcalc/map3.c:594
-#: ../imagery/i.landsat.acca/tools.c:136
-#: ../imagery/i.landsat.acca/algorithm.c:234
-#: ../imagery/i.landsat.acca/algorithm.c:388
-#: ../imagery/i.landsat.toar/main.c:564
-#, c-format
-msgid "Unable to create raster map <%s>"
+#: ../general/g.proj/main.c:105
+msgid ""
+"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
msgstr ""
-#: ../raster/r.sunhours/main.c:353
+#: ../general/g.proj/main.c:115
+msgid "Print projection information in WKT format"
+msgstr ""
+#: ../general/g.proj/main.c:121
+msgid "Use ESRI-style format (applies to WKT output only)"
+msgstr ""
+#: ../general/g.proj/main.c:128 ../general/g.proj/main.c:137
+#: ../general/g.proj/main.c:147 ../general/g.proj/main.c:157
#, fuzzy
-msgid "Calculating solar elevation and azimuth..."
+msgid "Specification"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:356
+#: ../general/g.proj/main.c:129
+msgid "Name of georeferenced data file to read projection information from"
+msgstr ""
+#: ../general/g.proj/main.c:138
#, fuzzy
-msgid "Calculating solar elevation..."
+msgid "Name of ASCII file containing a WKT projection description"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/main.c:359
+#: ../general/g.proj/main.c:140 ../general/g.proj/main.c:149
+#: ../raster/r.in.ascii/main.c:79 ../vector/v.segment/main.c:76
+#: ../db/db.select/main.c:207 ../db/db.execute/main.c:139
#, fuzzy
-msgid "Calculating solar azimuth..."
+msgid "'-' for standard input"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunhours/solpos00.c:994 ../raster/r.sunmask/solpos00.c:949
-#, c-format
-msgid "S_decode ==> Please fix the year: %d [1950-2050]"
+#: ../general/g.proj/main.c:148
+msgid "PROJ.4 projection description"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:997 ../raster/r.sunmask/solpos00.c:952
-#, c-format
-msgid "S_decode ==> Please fix the month: %d"
+#: ../general/g.proj/main.c:158
+msgid "EPSG projection code"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:999 ../raster/r.sunmask/solpos00.c:954
-#, c-format
-msgid "S_decode ==> Please fix the day-of-month: %d"
+#: ../general/g.proj/main.c:166 ../general/g.proj/main.c:179
+#: ../general/g.proj/main.c:185
+msgid "Datum"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1002 ../raster/r.sunmask/solpos00.c:957
-#, c-format
-msgid "S_decode ==> Please fix the day-of-year: %d"
+#: ../general/g.proj/main.c:168
+msgid "Datum (overrides any datum specified in input co-ordinate system)"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1005 ../raster/r.sunmask/solpos00.c:960
-#, c-format
-msgid "S_decode ==> Please fix the hour: %d"
+#: ../general/g.proj/main.c:170
+msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1007 ../raster/r.sunmask/solpos00.c:962
-#, c-format
-msgid "S_decode ==> Please fix the minute: %d"
+#: ../general/g.proj/main.c:180
+#, fuzzy
+msgid "Index number of datum transform parameters"
+msgstr "출력할 래스터맵"
+#: ../general/g.proj/main.c:181
+msgid "\"0\" for unspecified or \"-1\" to list and exit"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1009 ../raster/r.sunmask/solpos00.c:964
-#, c-format
-msgid "S_decode ==> Please fix the second: %d"
+#: ../general/g.proj/main.c:187
+msgid ""
+"Force override of datum transformation information in input co-ordinate "
+"system"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1011 ../raster/r.sunmask/solpos00.c:966
-#, c-format
-msgid "S_decode ==> Please fix the time zone: %f"
+#: ../general/g.proj/main.c:192 ../raster/r.null/main.c:73
+#: ../raster/r.null/main.c:81
+msgid "Modify"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1014 ../raster/r.sunmask/solpos00.c:969
-#, c-format
-msgid "S_decode ==> Please fix the interval: %d"
+#: ../general/g.proj/main.c:193
+#, fuzzy
+msgid "Create new projection files (modifies current location)"
+msgstr "출력할 래스터맵"
+#: ../general/g.proj/main.c:201 ../general/g.mapset/main.c:83
+#: ../locale/scriptstrings/r.mask_to_translate.c:18
+msgid "Create"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1017 ../raster/r.sunmask/solpos00.c:972
-#, c-format
-msgid "S_decode ==> Please fix the latitude: %f"
+#: ../general/g.proj/main.c:202
+msgid "Name of new location to create"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1020 ../raster/r.sunmask/solpos00.c:975
+#: ../general/g.proj/main.c:218
#, c-format
-msgid "S_decode ==> Please fix the longitude: %f"
+msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1023 ../raster/r.sunmask/solpos00.c:978
-#, c-format
-msgid "S_decode ==> Please fix the temperature: %f"
+#: ../general/g.proj/main.c:261
+msgid "Projection files missing"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1026 ../raster/r.sunmask/solpos00.c:981
+#: ../general/g.proj/main.c:281
#, c-format
-msgid "S_decode ==> Please fix the pressure: %f"
+msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1028 ../raster/r.sunmask/solpos00.c:983
+#: ../general/g.proj/main.c:308
#, c-format
-msgid "S_decode ==> Please fix the tilt: %f"
+msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1030 ../raster/r.sunmask/solpos00.c:985
+#: ../general/g.proj/main.c:312
#, c-format
-msgid "S_decode ==> Please fix the aspect: %f"
+msgid "No output format specified, define one of flags -%c, -%c, or -%c"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1032 ../raster/r.sunmask/solpos00.c:987
+#: ../general/g.proj/create.c:15 ../raster/r.in.gdal/main.c:353
+#: ../raster/r.in.gdal/main.c:698 ../vector/v.in.lidar/main.c:352
+#: ../vector/v.in.ogr/main.c:681
#, c-format
-msgid "S_decode ==> Please fix the shadowband width: %f"
+msgid "Location <%s> created"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1035 ../raster/r.sunmask/solpos00.c:990
+#: ../general/g.proj/create.c:17
+#, fuzzy, c-format
+msgid "Unable to create location <%s>: %s"
+msgstr "출력할 래스터맵"
+#: ../general/g.proj/create.c:20
#, c-format
-msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgid "Unable to create projection files: %s"
msgstr ""
-#: ../raster/r.sunhours/solpos00.c:1038 ../raster/r.sunmask/solpos00.c:993
+#: ../general/g.proj/create.c:24
+#, fuzzy, c-format
+msgid "Unable to create location <%s>"
+msgstr "출력할 래스터맵"
+#: ../general/g.proj/create.c:26
#, c-format
-msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+msgid ""
+"You can switch to the new location by\n"
+"`%s=%s`"
msgstr ""
-#: ../raster/r.external.out/main.c:38
+#: ../general/g.proj/create.c:36
#, c-format
-msgid "Supported Formats:\n"
+msgid ""
+"You must select the PERMANENT mapset before updating the current location's "
+"projection (current mapset is <%s>)."
msgstr ""
-#: ../raster/r.external.out/main.c:111
+#: ../general/g.proj/create.c:62
+msgid ""
+"Default region was updated to the new projection, but if you have multiple "
+"mapsets `g.region -d` should be run in each to update the region from the "
+"default"
+msgstr ""
+#: ../general/g.proj/create.c:66
#, fuzzy
-msgid "Unable to open GDAL file"
+msgid "Projection information updated"
msgstr "출력할 래스터맵"
-#: ../raster/r.external.out/main.c:135 ../vector/v.external.out/format.c:22
+#: ../general/g.proj/datumtrans.c:47
#, fuzzy, c-format
-msgid "Format <%s> not supported"
+msgid "Invalid datum code <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.external.out/main.c:141
-#, c-format
-msgid "Format <%s> does not support direct write"
-msgstr ""
-#: ../raster/r.external.out/main.c:145 ../vector/v.external.out/format.c:27
+#: ../general/g.proj/datumtrans.c:77
#, fuzzy, c-format
-msgid "Format <%s> does not support writing"
+msgid "Datum set to <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.external.out/main.c:193
-#, fuzzy
-msgid "Unable to create GDAL file"
+#: ../general/g.proj/datumtrans.c:79
+#, fuzzy, c-format
+msgid "Ellipsoid set to <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.external.out/main.c:196
-#, fuzzy
-msgid "Error writing GDAL file"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:66
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
-#: ../raster/r.external.out/main.c:216 ../vector/v.external.out/main.c:45
-msgid "output"
+#: ../general/g.region/main.c:72 ../raster/r.region/main.c:65
+msgid "Set from default region"
msgstr ""
-#: ../raster/r.external.out/main.c:217 ../raster/r.external/main.c:57
-#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:50
-msgid "external"
+#: ../general/g.region/main.c:73 ../general/g.region/main.c:79
+#: ../general/g.region/main.c:161 ../general/g.region/main.c:168
+#: ../general/g.region/main.c:177 ../general/g.region/main.c:185
+#: ../general/g.region/main.c:195 ../raster/r.region/main.c:61
+#: ../raster/r.region/main.c:66 ../raster/r.region/main.c:81
+#: ../raster/r.region/main.c:88 ../raster/r.region/main.c:95
+#: ../raster/r.region/main.c:105 ../raster/r.region/main.c:148
+msgid "Existing"
msgstr ""
-#: ../raster/r.external.out/main.c:219
-msgid "Defines raster output format utilizing GDAL library."
+#: ../general/g.region/main.c:77
+msgid "Save as default region"
msgstr ""
-#: ../raster/r.external.out/main.c:223
-#, fuzzy
-msgid "Name of output directory"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:78
+msgid "Only possible from the PERMANENT mapset"
+msgstr ""
-#: ../raster/r.external.out/main.c:230
-#, fuzzy
-msgid "Extension for output files"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:83
+msgid "Print the current region"
+msgstr ""
-#: ../raster/r.external.out/main.c:236
-#, fuzzy
-msgid "Format of output files"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:88
+msgid "Print the current region in lat/long using the current ellipsoid/datum"
+msgstr ""
-#: ../raster/r.external.out/main.c:243 ../vector/v.external.out/args.c:38
-#: ../vector/v.out.postgis/args.c:52
-msgid "Creation options"
+#: ../general/g.region/main.c:94
+msgid "Print the current region extent"
msgstr ""
-#: ../raster/r.external.out/main.c:250 ../raster/r.in.gdal/main.c:151
-#: ../raster/r.external/main.c:93 ../vector/v.external.out/args.c:49
-#: ../vector/v.external/args.c:40
-msgid "List supported formats and exit"
+#: ../general/g.region/main.c:100
+msgid "Print the current region map center coordinates"
msgstr ""
-#: ../raster/r.external.out/main.c:251 ../raster/r.external.out/main.c:262
-#: ../raster/r.sunmask/main.c:230 ../raster/r.sunmask/main.c:236
-#: ../raster/r.colors/edit_colors.c:128 ../raster/r.stream.stats/main.c:89
-#: ../raster/r.stream.stats/main.c:94 ../raster/r.out.gdal/main.c:135
-#: ../raster/r.in.gdal/main.c:152 ../raster/r.what/main.c:124
-#: ../raster/r.what/main.c:132 ../raster/r.what/main.c:146
-#: ../raster/r.what/main.c:151 ../raster/r.what/main.c:156
-#: ../raster/r.what/main.c:161 ../raster/r.proj/main.c:210
-#: ../raster/r.proj/main.c:220 ../raster/r.proj/main.c:226
-#: ../raster/r.external/main.c:94 ../general/g.proj/main.c:79
-#: ../general/g.proj/main.c:85 ../general/g.proj/main.c:91
-#: ../general/g.proj/main.c:97 ../general/g.proj/main.c:103
-#: ../general/g.proj/main.c:114 ../general/g.proj/main.c:119
-#: ../general/g.mlist/main.c:114 ../general/g.mlist/main.c:119
-#: ../general/g.mlist/main.c:124 ../general/g.mlist/main.c:129
-#: ../general/g.mapsets/main.c:89 ../general/g.mapsets/main.c:94
-#: ../general/g.mapsets/main.c:100 ../general/g.mapset/main.c:89
-#: ../general/g.mapset/main.c:95 ../general/g.region/main.c:84
-#: ../general/g.region/main.c:90 ../general/g.region/main.c:95
-#: ../general/g.region/main.c:101 ../general/g.region/main.c:107
-#: ../general/g.region/main.c:113 ../general/g.region/main.c:119
-#: ../general/g.region/main.c:127 ../general/g.region/main.c:132
-#: ../general/g.region/main.c:138 ../general/g.region/main.c:143
-#: ../db/db.connect/main.c:54 ../db/db.connect/main.c:59
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:16
-#: ../locale/scriptstrings/g.extension_to_translate.c:13
-#: ../locale/scriptstrings/g.extension_to_translate.c:15
-#: ../locale/scriptstrings/g.extension_to_translate.c:17
-#: ../locale/scriptstrings/g.extension_to_translate.c:19
-#: ../display/d.mon/main.c:100 ../display/d.mon/main.c:105
-#: ../display/d.mon/main.c:110 ../temporal/t.connect/main.c:43
-#: ../imagery/i.group/main.c:79 ../imagery/i.group/main.c:84
-#: ../imagery/i.group/main.c:89 ../vector/v.info/parse.c:25
-#: ../vector/v.info/parse.c:31 ../vector/v.info/parse.c:36
-#: ../vector/v.info/parse.c:41 ../vector/v.info/parse.c:46
-#: ../vector/v.external.out/args.c:50 ../vector/v.external.out/args.c:62
-#: ../vector/v.external.out/args.c:68 ../vector/v.colors/main.c:134
-#: ../vector/v.to.db/parse.c:116 ../vector/v.to.db/parse.c:121
-#: ../vector/v.to.db/parse.c:127 ../vector/v.to.db/parse.c:133
-#: ../vector/v.what/main.c:89 ../vector/v.what/main.c:94
-#: ../vector/v.what/main.c:99 ../vector/v.external/args.c:41
-#: ../vector/v.external/args.c:47 ../vector/v.external/args.c:55
-#: ../vector/v.db.connect/main.c:83 ../vector/v.db.connect/main.c:88
-#: ../vector/v.db.connect/main.c:95 ../vector/v.db.connect/main.c:102
-#: ../vector/v.in.ogr/main.c:234 ../vector/v.in.ogr/main.c:240
-msgid "Print"
+#: ../general/g.region/main.c:106
+msgid "Print the current region in GMT style"
msgstr ""
-#: ../raster/r.external.out/main.c:256
-msgid "Cease using GDAL and revert to native output"
+#: ../general/g.region/main.c:112
+msgid "Print the current region in WMS style"
msgstr ""
-#: ../raster/r.external.out/main.c:261 ../vector/v.external.out/args.c:61
-msgid "Print current status"
+#: ../general/g.region/main.c:118
+msgid "Print region resolution in meters (geodesic)"
msgstr ""
-#: ../raster/r.in.arc/main.c:61 ../raster/r.in.xyz/main.c:160
-#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.poly/main.c:30
-#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.gdal/main.c:82
-#: ../raster/r.in.mat/main.c:92 ../raster/r.in.png/main.c:520
-#: ../raster/r.in.lidar/main.c:162 ../raster/r.external/main.c:56
-#: ../raster/r.in.bin/main.c:236
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
-#: ../locale/scriptstrings/r.unpack_to_translate.c:3
-#: ../raster3d/r3.in.bin/main.c:253 ../raster3d/r3.in.ascii/main.c:318
-#: ../vector/v.in.dxf/main.c:65 ../vector/v.in.ascii/main.c:50
-#: ../vector/v.convert/main.c:37 ../vector/v.in.sites/main.c:58
-#: ../vector/v.in.lidar/main.c:155 ../vector/v.in.dwg/main.c:83
-#: ../vector/v.external/main.c:49 ../vector/v.in.db/main.c:53
-#: ../vector/v.in.ogr/main.c:128
-msgid "import"
+#: ../general/g.region/main.c:123
+msgid "Print the convergence angle (degrees CCW)"
msgstr ""
-#: ../raster/r.in.arc/main.c:64
+#: ../general/g.region/main.c:125
+msgid ""
+"The difference between the projection's grid north and true north, measured "
+"at the center coordinates of the current region."
+msgstr ""
+#: ../general/g.region/main.c:131
+msgid "Print also 3D settings"
+msgstr ""
+#: ../general/g.region/main.c:137
+msgid "Print the maximum bounding box in lat/long on WGS84"
+msgstr ""
+#: ../general/g.region/main.c:142 ../imagery/i.group/main.c:88
+#: ../raster/r.regression.multi/main.c:160
+#: ../raster/r.regression.line/main.c:68
+#: ../locale/scriptstrings/i.oif_to_translate.c:6
+msgid "Print in shell script style"
+msgstr ""
+#: ../general/g.region/main.c:148
+msgid ""
+"Align region to resolution (default = align to bounds, works only for 2D "
+"resolution)"
+msgstr ""
+#: ../general/g.region/main.c:150 ../general/g.region/main.c:204
+#: ../general/g.region/main.c:213 ../general/g.region/main.c:222
+#: ../general/g.region/main.c:231 ../general/g.region/main.c:240
+#: ../general/g.region/main.c:249 ../general/g.region/main.c:325
+#: ../general/g.region/main.c:336 ../raster3d/r3.in.bin/main.c:285
+#: ../raster3d/r3.in.bin/main.c:293 ../raster3d/r3.in.bin/main.c:301
+#: ../raster3d/r3.in.bin/main.c:309 ../raster3d/r3.in.bin/main.c:317
+#: ../raster3d/r3.in.bin/main.c:324 ../raster3d/r3.in.bin/main.c:331
+#: ../raster3d/r3.in.bin/main.c:338 ../raster3d/r3.in.bin/main.c:345
+#: ../raster/r.region/main.c:114 ../raster/r.region/main.c:123
+#: ../raster/r.region/main.c:132 ../raster/r.region/main.c:141
+#: ../raster/r.in.bin/main.c:263 ../raster/r.in.bin/main.c:301
+#: ../raster/r.in.bin/main.c:309 ../raster/r.in.bin/main.c:317
+#: ../raster/r.in.bin/main.c:325 ../raster/r.in.bin/main.c:332
+#: ../raster/r.in.bin/main.c:339
+msgid "Bounds"
+msgstr ""
+#: ../general/g.region/main.c:154
+msgid "Do not update the current region"
+msgstr ""
+#: ../general/g.region/main.c:155 ../general/g.region/main.c:347
+#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
+#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
+msgid "Effects"
+msgstr ""
+#: ../general/g.region/main.c:160
+msgid "Set current region from named region"
+msgstr ""
+#: ../general/g.region/main.c:167
#, fuzzy
-msgid ""
-"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgid "Set region to match raster map(s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.arc/main.c:68
+#: ../general/g.region/main.c:175
+msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
+msgstr ""
+#: ../general/g.region/main.c:183
#, fuzzy
-msgid "Name of ARC/INFO ASCII raster file (GRID) to be imported"
+msgid "Set region to match vector map(s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.arc/main.c:78 ../raster/r.in.xyz/main.c:189
-#: ../raster/r.in.ascii/main.c:88 ../raster/r.in.lidar/main.c:189
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
-msgid "Storage type for resultant raster map"
+#: ../general/g.region/main.c:193 ../raster/r.region/main.c:103
+msgid "Set region to match this 3dview file"
msgstr ""
-#: ../raster/r.in.arc/main.c:85 ../raster/r.in.poly/main.c:45
-#: ../raster/r.in.ascii/main.c:96 ../raster/r.in.gdal/main.c:120
-#: ../raster/r.external/main.c:88 ../raster/r.in.bin/main.c:277
-msgid "Title for resultant raster map"
+#: ../general/g.region/main.c:203 ../raster/r.region/main.c:113
+msgid "Value for the northern edge"
msgstr ""
-#: ../raster/r.in.arc/main.c:92 ../raster/r.in.ascii/main.c:103
-msgid "Multiplier for ASCII data"
+#: ../general/g.region/main.c:212 ../raster/r.region/main.c:122
+msgid "Value for the southern edge"
msgstr ""
-#: ../raster/r.in.arc/main.c:113 ../raster/r.in.ascii/main.c:128
-#: ../raster/r.in.ascii/main.c:158 ../raster/r.resamp.rst/main.c:554
-#: ../general/g.setproj/get_stp.c:162 ../general/g.setproj/get_stp.c:165
-#: ../general/g.setproj/get_stp.c:282 ../general/g.setproj/get_stp.c:286
-#: ../display/d.title/main.c:117 ../vector/v.in.ascii/main.c:253
-#: ../vector/v.surf.rst/main.c:821
-#, fuzzy, c-format
-msgid "Unable to open temporary file <%s>"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:221 ../raster/r.region/main.c:131
+msgid "Value for the eastern edge"
+msgstr ""
-#: ../raster/r.in.arc/main.c:123 ../raster/r.support/main.c:180
-#: ../raster/r.in.xyz/main.c:540 ../raster/r.series/main.c:211
-#: ../raster/r.mapcalc/main.c:91 ../raster/r.series.accumulate/main.c:223
-#: ../raster/r.topmodel/file_io.c:29 ../raster/r.topmodel/file_io.c:72
-#: ../raster/r.topmodel/file_io.c:181 ../raster/r.in.mat/main.c:125
-#: ../general/g.cairocomp/main.c:46 ../display/d.linegraph/main.c:205
-#: ../display/d.linegraph/main.c:221 ../display/d.linegraph/main.c:363
-#: ../display/d.where/main.c:163 ../display/d.text/main.c:366
-#: ../raster3d/r3.support/main.c:166 ../vector/v.net.path/path.c:49
-#: ../vector/v.segment/main.c:93 ../vector/v.lrs/v.lrs.segment/main.c:132
-#, fuzzy, c-format
-msgid "Unable to open input file <%s>"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:230 ../raster/r.region/main.c:140
+msgid "Value for the western edge"
+msgstr ""
-#: ../raster/r.in.arc/main.c:126 ../raster/r.in.ascii/main.c:188
-msgid "Can't get cell header"
+#: ../general/g.region/main.c:239
+msgid "Value for the top edge"
msgstr ""
-#: ../raster/r.in.arc/main.c:133 ../raster/r.in.ascii/main.c:195
-#: ../raster/r.horizon/main.c:611
-#, c-format
-msgid "OOPS: rows changed from %d to %d"
+#: ../general/g.region/main.c:248
+msgid "Value for the bottom edge"
msgstr ""
-#: ../raster/r.in.arc/main.c:136 ../raster/r.in.ascii/main.c:198
-#: ../raster/r.horizon/main.c:615
-#, c-format
-msgid "OOPS: cols changed from %d to %d"
+#: ../general/g.region/main.c:257
+msgid "Number of rows in the new region"
msgstr ""
-#: ../raster/r.in.arc/main.c:157 ../raster/r.in.ascii/main.c:210
-#, c-format
-msgid "Data conversion failed at row %d, col %d"
+#: ../general/g.region/main.c:258 ../general/g.region/main.c:267
+#: ../general/g.region/main.c:277 ../general/g.region/main.c:287
+#: ../general/g.region/main.c:296 ../general/g.region/main.c:305
+#: ../general/g.region/main.c:314
+msgid "Resolution"
msgstr ""
-#: ../raster/r.in.arc/main.c:224
-msgid "Failed to copy file"
+#: ../general/g.region/main.c:266
+msgid "Number of columns in the new region"
msgstr ""
-#: ../raster/r.in.arc/gethead.c:88
-msgid "Illegal line in header"
+#: ../general/g.region/main.c:276
+msgid "2D grid resolution (north-south and east-west)"
msgstr ""
-#: ../raster/r.in.arc/gethead.c:157 ../raster/r.in.ascii/gethead.c:248
-#, c-format
-msgid "Duplicate \"%s\" field in header"
+#: ../general/g.region/main.c:286
+msgid "3D grid resolution (north-south, east-west and top-bottom)"
msgstr ""
-#: ../raster/r.in.arc/gethead.c:162
-#, c-format
-msgid "Illegal \"%s\" value in header: \"%s\""
+#: ../general/g.region/main.c:295
+msgid "North-south 2D grid resolution"
msgstr ""
-#: ../raster/r.in.arc/gethead.c:170 ../raster/r.in.ascii/gethead.c:261
+#: ../general/g.region/main.c:304
+msgid "East-west 2D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:313
+msgid "Top-bottom 3D grid resolution"
+msgstr ""
+#: ../general/g.region/main.c:323
+msgid "Shrink region until it meets non-NULL data from this raster map"
+msgstr ""
+#: ../general/g.region/main.c:334
+msgid "Adjust region cells to cleanly align with this raster map"
+msgstr ""
+#: ../general/g.region/main.c:345
+msgid "Save current region settings in named region file"
+msgstr ""
+#: ../general/g.region/main.c:404
#, c-format
-msgid "\"%s\" field missing from header"
+msgid "Region <%s> not found"
msgstr ""
-#: ../raster/r.stream.snap/snap.c:133
+#: ../general/g.region/main.c:416
#, c-format
-msgid ""
-"Unable to snap point with cat %d, in a given radius. Increase search radius."
+msgid "3dview file <%s> not found"
msgstr ""
-#: ../raster/r.stream.snap/io.c:17 ../raster/r.stream.segment/io.c:17
-#: ../raster/r.stream.stats/io.c:17 ../raster/r.stream.channel/io.c:17
-#: ../raster/r.stream.order/io.c:17
-#, fuzzy
-msgid "Unable to create raster map of unrecognised type"
+#: ../general/g.region/main.c:421
+#, fuzzy, c-format
+msgid "Unable to open 3dview file <%s> in <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:71 ../raster/r.stream.snap/io.c:354
-#: ../raster/r.cost/main.c:352 ../raster/r.cost/main.c:662
-#: ../raster/r.category/main.c:119 ../raster/r.category/main.c:140
-#: ../raster/r.coin/main.c:127 ../raster/r.coin/main.c:129
-#: ../raster/r.ros/main.c:340 ../raster/r.ros/main.c:351
-#: ../raster/r.ros/main.c:356 ../raster/r.ros/main.c:361
-#: ../raster/r.ros/main.c:366 ../raster/r.ros/main.c:380
-#: ../raster/r.ros/main.c:384 ../raster/r.ros/main.c:399
-#: ../raster/r.ros/main.c:403 ../raster/r.ros/main.c:414
-#: ../raster/r.null/main.c:121 ../raster/r.colors/edit_colors.c:412
-#: ../raster/r.stream.segment/io.c:71 ../raster/r.stream.segment/io.c:354
-#: ../raster/r.info/main.c:100 ../raster/r.buffer/main.c:112
-#: ../raster/r.stream.stats/io.c:71 ../raster/r.stream.stats/io.c:354
-#: ../raster/simwe/simlib/output.c:360 ../raster/simwe/simlib/output.c:369
-#: ../raster/simwe/simlib/output.c:400 ../raster/simwe/simlib/output.c:409
-#: ../raster/simwe/simlib/output.c:455 ../raster/simwe/simlib/output.c:472
-#: ../raster/simwe/simlib/output.c:494 ../raster/simwe/simlib/output.c:538
-#: ../raster/simwe/simlib/output.c:580 ../raster/simwe/simlib/output.c:752
-#: ../raster/r.mapcalc/map.c:505 ../raster/r.report/parse.c:285
+#: ../general/g.region/main.c:427
+#, fuzzy, c-format
+msgid "Unable to read 3dview file <%s> in <%s>"
+msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:430
+#, c-format
+msgid "Old 3dview file. Region <%s> not found in <%s>"
+msgstr ""
+#: ../general/g.region/main.c:459 ../general/g.region/main.c:783
+#: ../general/g.region/main.c:791
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
+#: ../imagery/i.gensig/parse.c:38 ../imagery/i.pca/main.c:142
+#: ../imagery/i.gensigset/parse.c:44 ../misc/m.nviz.image/surface.c:50
+#: ../misc/m.nviz.image/surface.c:107 ../raster/r.flow/io.c:65
+#: ../raster/r.flow/io.c:242 ../raster/r.los/main.c:172
+#: ../raster/r.los/main.c:178 ../raster/r.cross/main.c:106
+#: ../raster/r.mapcalc/map.c:505 ../raster/r.stream.distance/io.c:71
+#: ../raster/r.stream.distance/io.c:354 ../raster/r.carve/main.c:165
+#: ../raster/r.info/main.c:100 ../raster/r.stream.snap/io.c:71
+#: ../raster/r.stream.snap/io.c:354 ../raster/r.univar/r.univar_main.c:219
#: ../raster/r.distance/parse.c:53 ../raster/r.distance/parse.c:60
+#: ../raster/r.kappa/stats.c:33 ../raster/r.kappa/stats.c:38
+#: ../raster/r.kappa/main.c:150 ../raster/r.stream.slope/main.c:117
+#: ../raster/r.stream.slope/main.c:133 ../raster/r.reclass/main.c:79
+#: ../raster/r.stream.extract/main.c:173 ../raster/r.stream.extract/main.c:177
+#: ../raster/r.stream.extract/main.c:182 ../raster/r.coin/main.c:127
+#: ../raster/r.coin/main.c:129 ../raster/simwe/simlib/output.c:363
+#: ../raster/simwe/simlib/output.c:372 ../raster/simwe/simlib/output.c:403
+#: ../raster/simwe/simlib/output.c:412 ../raster/simwe/simlib/output.c:458
+#: ../raster/simwe/simlib/output.c:475 ../raster/simwe/simlib/output.c:497
+#: ../raster/simwe/simlib/output.c:541 ../raster/simwe/simlib/output.c:583
+#: ../raster/simwe/simlib/output.c:755 ../raster/r.null/main.c:121
#: ../raster/r.spread/main.c:431 ../raster/r.spread/main.c:434
#: ../raster/r.spread/main.c:437 ../raster/r.spread/main.c:441
#: ../raster/r.spread/main.c:444 ../raster/r.spread/main.c:447
-#: ../raster/r.stream.distance/io.c:71 ../raster/r.stream.distance/io.c:354
+#: ../raster/r.colors/edit_colors.c:412 ../raster/r.stream.channel/io.c:71
+#: ../raster/r.stream.channel/io.c:354 ../raster/r.category/main.c:119
+#: ../raster/r.category/main.c:140 ../raster/r.cost/main.c:352
+#: ../raster/r.cost/main.c:662 ../raster/r.ros/main.c:340
+#: ../raster/r.ros/main.c:351 ../raster/r.ros/main.c:356
+#: ../raster/r.ros/main.c:361 ../raster/r.ros/main.c:366
+#: ../raster/r.ros/main.c:380 ../raster/r.ros/main.c:384
+#: ../raster/r.ros/main.c:399 ../raster/r.ros/main.c:403
+#: ../raster/r.ros/main.c:414 ../raster/r.buffer/main.c:112
#: ../raster/r.walk/main.c:442 ../raster/r.walk/main.c:447
-#: ../raster/r.walk/main.c:815 ../raster/r.stream.channel/io.c:71
-#: ../raster/r.stream.channel/io.c:354 ../raster/r.stream.slope/main.c:117
-#: ../raster/r.stream.slope/main.c:133 ../raster/r.carve/main.c:164
-#: ../raster/r.cross/main.c:106 ../raster/r.stream.extract/main.c:173
-#: ../raster/r.stream.extract/main.c:177 ../raster/r.stream.extract/main.c:182
-#: ../raster/r.kappa/stats.c:33 ../raster/r.kappa/stats.c:38
-#: ../raster/r.kappa/main.c:150 ../raster/r.univar/r.univar_main.c:219
+#: ../raster/r.walk/main.c:815 ../raster/r.report/parse.c:285
+#: ../raster/r.stream.segment/io.c:71 ../raster/r.stream.segment/io.c:354
#: ../raster/r.stream.order/io.c:71 ../raster/r.stream.order/io.c:354
-#: ../raster/r.stream.order/stream_init.c:90 ../raster/r.reclass/main.c:79
-#: ../raster/r.flow/io.c:65 ../raster/r.flow/io.c:242
-#: ../raster/r.los/main.c:172 ../raster/r.los/main.c:178
-#: ../general/g.region/main.c:459 ../general/g.region/main.c:783
-#: ../general/g.region/main.c:791 ../doc/raster/r.example/main.c:105
-#: ../misc/m.nviz.image/surface.c:50 ../misc/m.nviz.image/surface.c:107
-#: ../display/d.what.rast/main.c:119 ../display/d.what.rast/opencell.c:14
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:155
-#: ../imagery/i.gensigset/parse.c:44 ../imagery/i.gensig/parse.c:38
-#: ../imagery/i.pca/main.c:142 ../vector/v.vol.rst/main.c:615
-#: ../vector/v.colors/main.c:311
+#: ../raster/r.stream.order/stream_init.c:90 ../raster/r.stream.stats/io.c:71
+#: ../raster/r.stream.stats/io.c:354 ../vector/v.vol.rst/main.c:619
+#: ../vector/v.colors/main.c:313 ../display/d.what.rast/opencell.c:14
+#: ../display/d.what.rast/main.c:119 ../doc/raster/r.example/main.c:105
#, c-format
msgid "Raster map <%s> not found"
msgstr ""
-#: ../raster/r.stream.snap/io.c:79 ../raster/r.stream.snap/io.c:366
-#: ../raster/r.stream.segment/io.c:79 ../raster/r.stream.segment/io.c:366
-#: ../raster/r.stream.stats/io.c:79 ../raster/r.stream.stats/io.c:366
-#: ../raster/r.stream.distance/io.c:79 ../raster/r.stream.distance/io.c:366
-#: ../raster/r.stream.channel/io.c:79 ../raster/r.stream.channel/io.c:366
-#: ../raster/r.stream.slope/main.c:122 ../raster/r.stream.order/io.c:79
-#: ../raster/r.stream.order/io.c:366
+#: ../general/g.region/main.c:485 ../raster3d/r3.mask/main.c:57
+#: ../raster3d/r3.stats/main.c:612 ../raster3d/r3.null/main.c:102
+#: ../raster3d/r3.neighbors/main.c:225 ../raster3d/r3.retile/main.c:113
+#: ../raster3d/r3.out.v5d/main.c:306 ../raster3d/r3.out.vtk/main.c:142
+#: ../raster3d/r3.support/main.c:134 ../raster3d/r3.out.netcdf/main.c:599
+#: ../raster3d/r3.out.bin/main.c:299 ../raster3d/r3.to.rast/main.c:222
+#: ../raster3d/r3.timestamp/r3.timestamp.main.c:70
+#: ../raster3d/r3.out.ascii/main.c:329 ../raster3d/r3.cross.rast/main.c:245
+#: ../raster/r.univar/r3.univar_main.c:148
+#: ../raster/r.univar/r3.univar_main.c:186
+#: ../raster/r.colors/edit_colors.c:419 ../vector/v.colors/main.c:320
#, c-format
-msgid ""
-"Region resolution and raster map <%s> resolution differs. Run 'g.region rast="
-"%s' to set proper region resolution."
+msgid "3D raster map <%s> not found"
msgstr ""
-#: ../raster/r.stream.snap/io.c:90 ../raster/r.stream.snap/io.c:376
-#: ../raster/r.stream.segment/io.c:90 ../raster/r.stream.segment/io.c:376
-#: ../raster/r.stream.stats/io.c:90 ../raster/r.stream.distance/io.c:90
-#: ../raster/r.stream.channel/io.c:90 ../raster/r.stream.channel/io.c:376
-#: ../raster/r.stream.order/io.c:90 ../raster/r.stream.order/io.c:376
+#: ../general/g.region/main.c:488
#, fuzzy, c-format
-msgid "Raster map <%s> is not of type '%s'"
+msgid "Unable to read header of 3D raster map <%s@%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:120 ../raster/r.stream.snap/io.c:404
-#: ../raster/r.grow.distance/main.c:263 ../raster/r.stream.segment/io.c:120
-#: ../raster/r.stream.segment/io.c:404 ../raster/r.stream.stats/io.c:120
-#: ../raster/r.stream.stats/io.c:404 ../raster/r.surf.idw/main.c:708
-#: ../raster/r.series.accumulate/main.c:250
-#: ../raster/r.series.accumulate/main.c:275
-#: ../raster/r.series.accumulate/main.c:286
-#: ../raster/r.series.accumulate/main.c:294
-#: ../raster/r.series.accumulate/main.c:302
-#: ../raster/r.stream.distance/io.c:120 ../raster/r.stream.distance/io.c:404
-#: ../raster/r.stream.channel/io.c:120 ../raster/r.stream.channel/io.c:404
-#: ../raster/r.surf.idw2/read_cell.c:27 ../raster/r.out.mpeg/main.c:287
-#: ../raster/r.stream.order/io.c:120 ../raster/r.stream.order/io.c:404
-#: ../ps/ps.map/ps_raster.c:102
+#: ../general/g.region/main.c:508 ../misc/m.nviz.image/vector.c:86
+#: ../raster/r.carve/main.c:158 ../raster/r.cost/main.c:327
+#: ../raster/r.walk/main.c:417 ../vector/v.edit/main.c:152
+#: ../vector/v.surf.bspline/main.c:249 ../vector/v.surf.bspline/main.c:317
+#: ../vector/v.lidar.correction/main.c:178
+#: ../vector/v.clean/test/topocheck.c:63 ../vector/v.lidar.growing/main.c:126
+#: ../vector/v.lrs/v.lrs.create/main.c:251
+#: ../vector/v.lrs/v.lrs.create/main.c:260
+#: ../vector/v.lrs/v.lrs.label/main.c:287
+#: ../vector/v.lrs/v.lrs.segment/main.c:140
+#: ../vector/v.lrs/v.lrs.where/main.c:127
+#: ../vector/v.lrs/v.lrs.where/main.c:136 ../vector/v.colors/main.c:240
+#: ../vector/v.outlier/main.c:168 ../vector/v.convert/att.c:31
+#: ../vector/v.convert/old2new.c:26 ../vector/v.vect.stats/main.c:253
+#: ../vector/v.vect.stats/main.c:261
+#: ../vector/v.lidar.edgedetection/main.c:213
+#: ../display/d.what.vect/main.c:133 ../display/d.extract/main.c:98
+#: ../doc/vector/v.example/main.c:75
#, fuzzy, c-format
-msgid "Reading raster map <%s>..."
+msgid "Vector map <%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:148 ../raster/r.stream.snap/io.c:435
-#: ../raster/r.stream.segment/io.c:148 ../raster/r.stream.segment/io.c:435
-#: ../raster/r.stream.stats/io.c:148 ../raster/r.stream.stats/io.c:435
-#: ../raster/r.stream.distance/io.c:148 ../raster/r.stream.distance/io.c:435
-#: ../raster/r.stream.channel/io.c:148 ../raster/r.stream.channel/io.c:435
-#: ../raster/r.stream.order/io.c:148 ../raster/r.stream.order/io.c:435
-#, fuzzy
-msgid "Wrong internal data type"
+#: ../general/g.region/main.c:514 ../vector/v.out.postgis/main.c:110
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s> on topological level"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:195 ../raster/r.stream.snap/io.c:498
-#: ../raster/r.composite/main.c:191 ../raster/r.stream.segment/io.c:195
-#: ../raster/r.stream.segment/io.c:498 ../raster/r.random.cells/indep.c:134
-#: ../raster/r.drain/main.c:519 ../raster/r.stream.stats/io.c:195
-#: ../raster/r.stream.stats/io.c:498 ../raster/r.random.surface/save.c:98
-#: ../raster/r.stream.distance/io.c:195 ../raster/r.stream.distance/io.c:498
-#: ../raster/r.stream.channel/io.c:195 ../raster/r.stream.channel/io.c:498
-#: ../raster/r.stream.order/io.c:195 ../raster/r.stream.order/io.c:498
-#: ../imagery/i.ifft/main.c:208
+#: ../general/g.region/main.c:801
#, fuzzy, c-format
-msgid "Writing raster map <%s>..."
+msgid "Unable to set region <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:297 ../raster/r.stream.segment/io.c:297
-#: ../raster/r.stream.stats/io.c:297 ../raster/r.stream.distance/io.c:297
-#, fuzzy
-msgid "Unrecognisable data type"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:807
+msgid "Unable to update current region"
+msgstr ""
-#: ../raster/r.stream.snap/io.c:308 ../raster/r.stream.segment/io.c:308
-#: ../raster/r.stream.stats/io.c:308 ../raster/r.stream.distance/io.c:308
-#: ../raster/r.stream.channel/io.c:308 ../raster/r.stream.order/io.c:308
-#, fuzzy
-msgid "Unable to format segment"
-msgstr "출력할 래스터맵"
+#: ../general/g.region/main.c:815
+msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+msgstr ""
-#: ../raster/r.stream.snap/io.c:314 ../raster/r.stream.segment/io.c:314
-#: ../raster/r.stream.stats/io.c:314 ../raster/r.stream.distance/io.c:314
-#: ../raster/r.stream.channel/io.c:314 ../raster/r.stream.extract/seg.c:44
+#: ../general/g.region/main.c:832 ../raster/r.in.lidar/main.c:572
+#, c-format
+msgid "Invalid input <%s=%s>"
+msgstr ""
+#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
+#: ../general/g.region/printwindow.c:622 ../raster/r.sun/main.c:726
+#: ../raster/r.horizon/main.c:488 ../display/d.where/main.c:107
+msgid "Can't get projection info of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
+#: ../general/g.region/printwindow.c:625 ../raster/r.sun/main.c:730
+#: ../raster/r.horizon/main.c:491 ../display/d.where/main.c:110
+msgid "Can't get projection units of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
+#: ../general/g.region/printwindow.c:628 ../raster/r.sun/main.c:734
+#: ../raster/r.horizon/main.c:495 ../display/d.grid/plot.c:349
+#: ../display/d.where/main.c:113 ../ps/ps.map/do_geogrid.c:272
+msgid "Can't get projection key values of current location"
+msgstr ""
+#: ../general/g.region/printwindow.c:263 ../general/g.region/printwindow.c:516
+#: ../general/g.region/printwindow.c:647 ../raster/r.sunhours/main.c:229
+msgid "Unable to update lat/long projection parameters"
+msgstr ""
+#: ../general/g.region/printwindow.c:281 ../general/g.region/printwindow.c:289
+#: ../general/g.region/printwindow.c:297 ../general/g.region/printwindow.c:305
+#: ../general/g.region/printwindow.c:534 ../general/g.region/printwindow.c:542
+#: ../general/g.region/printwindow.c:550 ../general/g.region/printwindow.c:558
+#: ../general/g.region/printwindow.c:676 ../general/g.region/printwindow.c:684
+#: ../general/g.region/printwindow.c:692 ../general/g.region/printwindow.c:700
+#: ../raster/r.sunmask/g_solposition.c:127 ../raster/r.sunhours/main.c:293
+#: ../raster/r.sunhours/main.c:388
+msgid "Error in pj_do_proj (projection of input coordinate pair)"
+msgstr ""
+#: ../general/g.region/printwindow.c:410
+msgid "You are already in Lat/Long. Use the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:412
+msgid ""
+"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
+"the -p flag instead."
+msgstr ""
+#: ../general/g.region/printwindow.c:637
+msgid ""
+"WGS84 output not possible as this location does not contain datum "
+"transformation parameters. Try running g.setproj."
+msgstr ""
+#: ../general/g.region/printwindow.c:783
+msgid "Lat/Long calculations are not possible from a simple XY system"
+msgstr ""
+#: ../general/g.dirseps/main.c:37
+msgid "Internal GRASS utility for converting directory separator characters."
+msgstr ""
+#: ../general/g.remove/main.c:38 ../general/g.mremove/check_reclass.c:18
#, fuzzy, c-format
-msgid "Unable to re-open file '%s'"
+msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:319 ../raster/r.stream.segment/io.c:319
-#: ../raster/r.stream.stats/io.c:319 ../raster/r.stream.distance/io.c:319
-#: ../raster/r.stream.channel/io.c:319 ../raster/r.stream.order/io.c:319
+#: ../general/g.remove/main.c:41
+#, c-format
+msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
+msgstr ""
+#: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
+#, c-format
+msgid "Removing information about reclassed map from <%s@%s> failed"
+msgstr ""
+#: ../general/g.remove/main.c:103 ../general/g.mremove/main.c:63
+#: ../locale/scriptstrings/t.remove_to_translate.c:4
#, fuzzy
-msgid "Unable to init segment file or out of memory"
+msgid "remove"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:444 ../raster/r.stream.distance/io.c:444
-#: ../raster/r.stream.channel/io.c:444 ../raster/r.stream.extract/cseg.c:120
-#: ../raster/r.stream.order/io.c:444
-#, fuzzy, c-format
-msgid "Unable to segment put row %d for raster map <%s>"
-msgstr "출력할 래스터맵"
+#: ../general/g.remove/main.c:105
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
-#: ../raster/r.stream.snap/io.c:508 ../raster/r.stream.segment/io.c:508
-#: ../raster/r.stream.stats/io.c:508 ../raster/r.stream.distance/io.c:508
-#: ../raster/r.stream.channel/io.c:508 ../raster/r.stream.order/io.c:508
-#: ../raster/r.stream.order/stream_raster_close.c:95
-#, fuzzy, c-format
-msgid "Unable to segment read row %d for raster map <%s>"
+#: ../general/g.remove/main.c:110
+#, fuzzy
+msgid "Force removal for base raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/io.c:531 ../raster/r.stream.segment/io.c:531
-#: ../raster/r.stream.distance/io.c:531 ../raster/r.stream.channel/io.c:531
-#: ../raster/r.stream.order/io.c:531
-#, fuzzy, c-format
-msgid "Unable to convert to NULL at: %d %d"
-msgstr "출력할 래스터맵"
+#: ../general/g.gui/main.c:38
+msgid "gui"
+msgstr ""
-#: ../raster/r.stream.snap/main.c:47
+#: ../general/g.gui/main.c:39
+msgid "user interface"
+msgstr ""
+#: ../general/g.gui/main.c:41
+msgid "Launches a GRASS graphical user interface (GUI) session."
+msgstr ""
+#: ../general/g.gui/main.c:42
+msgid "And updates default user interface settings."
+msgstr ""
+#: ../general/g.gui/main.c:47
+msgid "User interface"
+msgstr ""
+#: ../general/g.gui/main.c:48
+msgid "Default value: GRASS_GUI if defined otherwise wxpython"
+msgstr ""
+#: ../general/g.gui/main.c:52
+msgid "wxPython based GUI (wxGUI)"
+msgstr ""
+#: ../general/g.gui/main.c:53
#, fuzzy
-msgid "Snap point to modelled river network."
+msgid "command line interface only"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:48
-msgid ""
-"Input can be stream network, point vector map with outlets or outlet "
-"coordinates."
+#: ../general/g.gui/main.c:56 ../general/g.message/main.c:43
+#: ../general/g.message/main.c:48 ../general/g.message/main.c:53
+#: ../general/g.message/main.c:58
+msgid "Type"
msgstr ""
-#: ../raster/r.stream.snap/main.c:50 ../raster/r.usler/main.c:53
-#: ../raster/r.watershed/front/main.c:73 ../raster/r.stream.segment/main.c:58
-#: ../raster/r.drain/main.c:110 ../raster/r.stream.stats/main.c:54
-#: ../raster/r.gwflow/main.c:210 ../raster/simwe/r.sim.sediment/main.c:112
-#: ../raster/simwe/r.sim.water/main.c:111 ../raster/r.lake/main.c:151
-#: ../raster/r.water.outlet/main.c:68 ../raster/r.topidx/main.c:40
-#: ../raster/r.stream.distance/main.c:54 ../raster/r.basins.fill/main.c:55
-#: ../raster/r.topmodel/main.c:49 ../raster/r.fill.dir/main.c:87
-#: ../raster/r.stream.channel/main.c:57 ../raster/r.stream.slope/main.c:73
-#: ../raster/r.carve/main.c:75 ../raster/r.stream.extract/main.c:77
-#: ../raster/r.solute.transport/main.c:230 ../raster/r.uslek/main.c:54
-#: ../raster/r.stream.order/main.c:76 ../raster/r.flow/main.c:423
-#: ../raster3d/r3.gwflow/main.c:162
-msgid "hydrology"
+#: ../general/g.gui/main.c:62
+msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
msgstr ""
-#: ../raster/r.stream.snap/main.c:51 ../raster/r.stream.segment/main.c:59
-#: ../raster/r.stream.stats/main.c:55 ../raster/r.stream.distance/main.c:55
-#: ../raster/r.stream.channel/main.c:58 ../raster/r.stream.slope/main.c:74
-#: ../raster/r.stream.extract/main.c:78 ../raster/r.stream.order/main.c:77
-msgid "stream network"
+#: ../general/g.gui/main.c:66
+msgid "Update default user interface settings"
msgstr ""
-#: ../raster/r.stream.snap/main.c:52
-#, fuzzy
-msgid "basins creation"
+#: ../general/g.gui/main.c:67 ../general/g.gui/main.c:73
+msgid "Default"
+msgstr ""
+#: ../general/g.gui/main.c:72
+msgid "Do not launch GUI after updating the default user interface settings"
+msgstr ""
+#: ../general/g.gui/main.c:100
+#, c-format
+msgid "<%s> is now the default GUI"
+msgstr ""
+#: ../general/g.gui/main.c:114
+#, c-format
+msgid "Launching <%s> GUI in the background, please wait..."
+msgstr ""
+#: ../general/manage/lister/vector.c:24 ../misc/m.nviz.image/vector.c:282
+#: ../raster/r.region/main.c:207 ../raster/r.carve/main.c:162
+#: ../raster/r.drain/main.c:268 ../raster/r.stream.snap/points_io.c:19
+#: ../raster/simwe/simlib/observation_points.c:39
+#: ../raster/r.random/support.c:63 ../raster/r.what/main.c:240
+#: ../raster/r.le/r.le.setup/sample.c:1037 ../raster/r.cost/main.c:530
+#: ../raster/r.cost/main.c:603 ../raster/r.walk/main.c:690
+#: ../raster/r.walk/main.c:756 ../vector/v.colors.out/scan_cats.c:20
+#: ../vector/v.colors.out/make_colors.c:23 ../vector/v.what.rast/main.c:130
+#: ../vector/v.edit/main.c:167 ../vector/v.edit/main.c:239
+#: ../vector/v.drape/main.c:142 ../vector/v.split/main.c:161
+#: ../vector/v.lidar.correction/main.c:182 ../vector/v.to.points/main.c:121
+#: ../vector/v.vol.rst/main.c:563 ../vector/v.proj/main.c:224
+#: ../vector/v.rectify/main.c:148 ../vector/v.net.allpairs/main.c:130
+#: ../vector/v.type/main.c:128 ../vector/v.to.rast/support.c:123
+#: ../vector/v.to.rast/support.c:282 ../vector/v.to.rast/support.c:434
+#: ../vector/v.to.rast/vect2rast.c:39 ../vector/v.voronoi/main.c:195
+#: ../vector/v.generalize/main.c:318 ../vector/v.univar/main.c:155
+#: ../vector/v.db.select/main.c:143 ../vector/v.net.timetable/main.c:353
+#: ../vector/v.net.salesman/main.c:224 ../vector/v.db.connect/main.c:151
+#: ../vector/v.class/main.c:102 ../vector/v.overlay/main.c:178
+#: ../vector/v.neighbors/main.c:87 ../vector/v.surf.rst/main.c:529
+#: ../vector/v.surf.rst/main.c:635 ../vector/v.net.visibility/main.c:79
+#: ../vector/v.net.visibility/main.c:88 ../vector/v.random/main.c:216
+#: ../vector/v.support/main.c:130 ../vector/v.kernel/main.c:310
+#: ../vector/v.kernel/main.c:323 ../vector/v.build.polylines/main.c:149
+#: ../vector/v.normal/main.c:111 ../vector/v.label/main.c:268
+#: ../vector/v.out.pov/main.c:97 ../vector/v.select/main.c:107
+#: ../vector/v.parallel/main.c:147 ../vector/v.buffer/main.c:331
+#: ../vector/v.clean/test/topocheck.c:67 ../vector/v.clean/test/topocheck.c:87
+#: ../vector/v.clean/main.c:278 ../vector/v.sample/main.c:124
+#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
+#: ../vector/v.lrs/v.lrs.create/main.c:254
+#: ../vector/v.lrs/v.lrs.create/main.c:263
+#: ../vector/v.lrs/v.lrs.label/main.c:291
+#: ../vector/v.lrs/v.lrs.segment/main.c:144
+#: ../vector/v.lrs/v.lrs.where/main.c:131
+#: ../vector/v.lrs/v.lrs.where/main.c:140
+#: ../vector/v.net.spanningtree/main.c:101 ../vector/v.hull/main.c:87
+#: ../vector/v.distance/main.c:292 ../vector/v.distance/main.c:311
+#: ../vector/v.out.postgis/main.c:100 ../vector/v.reclass/main.c:113
+#: ../vector/v.net.bridge/main.c:118 ../vector/v.external/main.c:191
+#: ../vector/v.net.flow/main.c:143 ../vector/v.label.sa/labels.c:58
+#: ../vector/v.out.svg/main.c:139 ../vector/v.net.alloc/main.c:141
+#: ../vector/v.patch/main.c:114 ../vector/v.patch/main.c:128
+#: ../vector/v.patch/main.c:157 ../vector/v.patch/main.c:253
+#: ../vector/v.patch/main.c:328 ../vector/v.extract/main.c:188
+#: ../vector/v.net.steiner/main.c:430 ../vector/v.extrude/main.c:190
+#: ../vector/v.colors/main.c:264 ../vector/v.what.rast3/main.c:113
+#: ../vector/v.surf.idw/read_sites.c:29 ../vector/v.net.iso/main.c:182
+#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
+#: ../vector/v.build/main.c:118 ../vector/v.build/main.c:128
+#: ../vector/v.net/main.c:66 ../vector/v.net/main.c:90
+#: ../vector/v.perturb/main.c:145 ../vector/v.perturb/main.c:170
+#: ../vector/v.net.centrality/main.c:209 ../vector/v.segment/main.c:104
+#: ../vector/v.to.3d/main.c:72 ../vector/v.vect.stats/main.c:257
+#: ../vector/v.vect.stats/main.c:268 ../vector/v.out.ogr/main.c:128
+#: ../vector/v.net.components/main.c:147 ../vector/v.to.db/main.c:49
+#: ../vector/v.out.dxf/main.c:79 ../vector/v.net.distance/main.c:176
+#: ../vector/v.net.path/main.c:131 ../vector/v.delaunay/main.c:120
+#: ../vector/v.to.rast3/main.c:73 ../vector/v.info/main.c:60
+#: ../vector/v.net.connectivity/main.c:130
+#: ../vector/v.lidar.edgedetection/main.c:219 ../vector/v.qcount/main.c:100
+#: ../vector/v.transform/main.c:178 ../display/d.vect.chart/main.c:247
+#: ../display/d.what.vect/main.c:111 ../display/d.extract/main.c:103
+#: ../display/d.path/main.c:188 ../doc/vector/v.example/main.c:87
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:55
+#: ../general/g.findfile/main.c:41
+msgid "Searches for GRASS data base files and sets variables for the shell."
+msgstr ""
+#: ../general/g.findfile/main.c:52 ../general/g.filename/main.c:49
+msgid "Name of an element"
+msgstr ""
+#: ../general/g.findfile/main.c:58
#, fuzzy
-msgid "Name of input vector points map"
+msgid "Name of an existing map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:58
+#: ../general/g.findfile/main.c:64
#, fuzzy
-msgid "Name of output vector points map"
+msgid "Name of a mapset (default: search path)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:63 ../raster/r.stream.segment/main.c:64
-#: ../raster/r.stream.stats/main.c:60 ../raster/r.stream.distance/main.c:60
-#: ../raster/r.stream.channel/main.c:64 ../raster/r.stream.order/main.c:32
+#: ../general/g.findfile/main.c:65
#, fuzzy
-msgid "Name for input raster map with stream network"
+msgid "'.' for current mapset"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:64 ../raster/r.stream.snap/main.c:70
-#: ../raster/r.spread/main.c:121 ../raster/r.spread/main.c:133
-#: ../raster/r.spread/main.c:146 ../raster/r.spread/main.c:160
-#: ../raster/r.spread/main.c:173 ../raster/r.spread/main.c:185
-#: ../raster/r.spread/main.c:197 ../raster/r.stream.distance/main.c:68
-#: ../raster/r.stream.extract/main.c:89 ../raster/r.stream.extract/main.c:97
-#: ../raster/r.stream.order/main.c:85
-#, fuzzy
-msgid "Input maps"
+#: ../general/g.findfile/main.c:69
+msgid "Don't add quotes"
+msgstr ""
+#: ../general/g.findfile/main.c:73
+msgid "List available elements and exit"
+msgstr ""
+#: ../general/g.findfile/main.c:96
+#, c-format
+msgid ""
+"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
+"%s> does not correspond"
+msgstr ""
+#: ../general/g.findfile/element.c:7
+msgid "List of available elements:"
+msgstr ""
+#: ../general/g.ppmtopng/main.c:34
+#, fuzzy, c-format
+msgid "Unable to open input file %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:69 ../raster/r.stream.extract/main.c:85
-#: ../raster/r.stream.order/main.c:35
-#, fuzzy
-msgid "Name of input accumulation raster map"
+#: ../general/g.ppmtopng/main.c:37
+#, fuzzy, c-format
+msgid "Invalid input file %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:77
+#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
+#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
#, fuzzy
-msgid "Minimum accumulation threshold to snap"
+msgid "Unable to allocate PNG structure"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:84
+#: ../general/g.ppmtopng/main.c:77
#, fuzzy
-msgid "Maximum distance to snap (in cells)"
+msgid "Error writing PNG file"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:91
-msgid "Max memory used (MB)"
+#: ../general/g.ppmtopng/main.c:81
+#, fuzzy, c-format
+msgid "Unable to open output file %s"
+msgstr "출력할 래스터맵"
+#: ../general/g.ppmtopng/main.c:118 ../general/g.cairocomp/main.c:197
+#: ../general/g.pnmcomp/main.c:283 ../display/d.labels/main.c:43
+#: ../display/d.vect.chart/main.c:63 ../display/d.font/main.c:45
+#: ../display/d.what.vect/main.c:56 ../display/d.thematic.area/main.c:77
+#: ../display/d.fontlist/main.c:38 ../display/d.legend/main.c:85
+#: ../display/d.extract/main.c:49 ../display/d.measure/main.c:46
+#: ../display/d.colorlist/main.c:35 ../display/d.northarrow/main.c:42
+#: ../display/d.erase/main.c:29 ../display/d.info/main.c:31
+#: ../display/d.rast.arrow/main.c:95 ../display/d.his/main.c:62
+#: ../display/d.grid/main.c:51 ../display/d.rhumbline/main.c:43
+#: ../display/d.colortable/main.c:60 ../display/d.mon/main.c:38
+#: ../display/d.rgb/main.c:53 ../display/d.linegraph/main.c:119
+#: ../display/d.what.rast/main.c:49 ../display/d.text/main.c:138
+#: ../display/d.histogram/main.c:84 ../display/d.title/main.c:49
+#: ../display/d.vect/main.c:70 ../display/d.barscale/main.c:54
+#: ../display/d.rast.num/main.c:76 ../display/d.profile/main.c:191
+#: ../display/d.where/main.c:43 ../display/d.rast/main.c:53
+#: ../display/d.zoom/main.c:61 ../display/d.colors/main.c:40
+#: ../display/d.graph/main.c:58 ../display/d.path/main.c:48
+#: ../display/d.geodesic/main.c:43
+#: ../locale/scriptstrings/d.redraw_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
+#: ../locale/scriptstrings/d.polar_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:2
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
+#: ../locale/scriptstrings/d.out.file_to_translate.c:2
+#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
+#: ../visualization/ximgview/main.c:290
+msgid "display"
msgstr ""
-#: ../raster/r.stream.snap/main.c:92 ../raster/r.stream.stats/main.c:73
-#: ../raster/r.stream.stats/main.c:83 ../raster/r.stream.distance/main.c:95
-#: ../raster/r.stream.distance/main.c:115
-#: ../raster/r.stream.channel/main.c:109 ../raster/r.stream.channel/main.c:127
-#: ../raster/r.stream.order/main.c:108 ../raster/r.stream.order/main.c:118
+#: ../general/g.ppmtopng/main.c:119
+msgid "Converts between PPM/PGM and PNG image formats."
+msgstr ""
+#: ../general/g.version/main.c:61 ../general/g.message/main.c:34
+#: ../general/g.tempfile/main.c:39
#, fuzzy
-msgid "Memory settings"
+msgid "support"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:107
-#, fuzzy, c-format
-msgid "<%s> is an illegal basin name"
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.snap/main.c:111
+#: ../general/g.version/main.c:62
#, fuzzy
-msgid "At least one of accumulation or streams raster maps is required"
+msgid "Displays GRASS version info."
msgstr "출력할 래스터맵"
-#: ../raster/r.usler/main.c:54
-msgid "rainfall"
+#: ../general/g.version/main.c:63
+msgid "Optionally also print build or copyright information."
msgstr ""
-#: ../raster/r.usler/main.c:55 ../raster/simwe/r.sim.sediment/main.c:114
-#: ../raster/r.uslek/main.c:56
-msgid "erosion"
+#: ../general/g.version/main.c:67
+msgid "Print also the copyright message"
msgstr ""
-#: ../raster/r.usler/main.c:56
-msgid "Computes USLE R factor, Rainfall erosivity index."
+#: ../general/g.version/main.c:68 ../general/g.version/main.c:73
+#: ../general/g.version/main.c:79 ../general/g.version/main.c:85
+msgid "Additional info"
msgstr ""
-#: ../raster/r.usler/main.c:59
+#: ../general/g.version/main.c:72
#, fuzzy
-msgid "Name of annual precipitation raster map [mm/year]"
+msgid "Print also the build information"
msgstr "출력할 래스터맵"
-#: ../raster/r.usler/main.c:62
-#, fuzzy
-msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
-msgstr "출력할 래스터맵"
+#: ../general/g.version/main.c:78
+msgid "Print also the GIS library revision number and date"
+msgstr ""
-#: ../raster/r.usler/main.c:69
+#: ../general/g.version/main.c:83
+msgid "Print also extended info for additional libraries"
+msgstr ""
+#: ../general/g.version/main.c:84
+msgid "GDAL/OGR, PROJ.4, GEOS"
+msgstr ""
+#: ../general/g.version/main.c:89
#, fuzzy
-msgid "Name of USLE R equation"
+msgid "Print info in shell script style (including SVN revision number)"
msgstr "출력할 래스터맵"
-#: ../raster/r.usler/main.c:74
-msgid "Roosle (1975)"
+#: ../general/g.version/main.c:90
+msgid "Shell"
msgstr ""
-#: ../raster/r.usler/main.c:75
-msgid "Morgan (1974)"
+#: ../general/g.version/main.c:157
+msgid "GRASS not compiled with GDAL/OGR support"
msgstr ""
-#: ../raster/r.usler/main.c:76
-msgid "Foster (1981)"
+#: ../general/g.version/main.c:168
+msgid "GRASS not compiled with GEOS support"
msgstr ""
-#: ../raster/r.usler/main.c:77
-msgid "El-Swaify (1985)"
+#: ../general/g.version/main.c:179
+msgid "GRASS not compiled with SQLite support"
msgstr ""
-#: ../raster/r.mode/main.c:55 ../raster/r.mfilter/main.c:57
-#: ../raster/r.mapcalc/main.c:112 ../raster/r.quantile/main.c:256
-#: ../raster/r.texture/main.c:102 ../raster/r.neighbors/main.c:140
-#: ../raster/r.bitpattern/main.c:64
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
-#: ../vector/v.neighbors/main.c:50
+#: ../general/g.mapset/main.c:51
#, fuzzy
-msgid "algebra"
+msgid "Changes/reports current mapset."
msgstr "출력할 래스터맵"
-#: ../raster/r.mode/main.c:58
+#: ../general/g.mapset/main.c:52
msgid ""
-"Finds the mode of values in a cover map within areas assigned the same "
-"category value in a user-specified base map."
+"Optionally create new mapset or list available mapsets in given location."
msgstr ""
-#: ../raster/r.mode/main.c:64
-msgid "Base map to be reclassified"
-msgstr ""
+#: ../general/g.mapset/main.c:56
+#, fuzzy
+msgid "Name of mapset where to switch"
+msgstr "출력할 래스터맵"
-#: ../raster/r.mode/main.c:71
-msgid "Coverage map"
+#: ../general/g.mapset/main.c:66
+msgid "Location name (not location path)"
msgstr ""
-#: ../raster/r.mode/main.c:78
-msgid "Output map"
+#: ../general/g.mapset/main.c:75
+msgid "GIS data directory"
msgstr ""
-#: ../raster/r.mode/main.c:91
-#, fuzzy, c-format
-msgid "%s: Unable to read category labels"
-msgstr "출력할 래스터맵"
-#: ../raster/r.mode/read_stats.c:14
-msgid "reading r.stats output"
+#: ../general/g.mapset/main.c:76
+msgid "Full path to the directory where the new location is"
msgstr ""
-#: ../raster/r.cost/main.c:141 ../raster/r.drain/main.c:111
-#: ../raster/r.walk/main.c:180
-msgid "cost surface"
+#: ../general/g.mapset/main.c:81
+msgid "Create mapset if it doesn't exist"
msgstr ""
-#: ../raster/r.cost/main.c:142 ../raster/r.walk/main.c:181
-#: ../raster/r.spreadpath/main.c:91
-msgid "cumulative costs"
+#: ../general/g.mapset/main.c:88
+msgid "List available mapsets and exit"
msgstr ""
-#: ../raster/r.cost/main.c:143
+#: ../general/g.mapset/main.c:94
#, fuzzy
-msgid "cost allocation"
+msgid "Print current mapset and exit"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:145
-msgid ""
-"Creates a raster map showing the cumulative cost of moving between different "
-"geographic locations on an input raster map whose cell category values "
-"represent cost."
+#: ../general/g.mapset/main.c:149
+#, fuzzy, c-format
+msgid "<%s> is already the current mapset"
+msgstr "출력할 래스터맵"
+#: ../general/g.mapset/main.c:158
+#, c-format
+msgid "You don't have permission to use the mapset <%s>"
msgstr ""
-#: ../raster/r.cost/main.c:152
-#, fuzzy
-msgid "Name of input raster map containing grid cell cost information"
+#: ../general/g.mapset/main.c:166
+#, fuzzy, c-format
+msgid "Unable to create new mapset <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:160
-#, fuzzy
-msgid "Name for output raster map with nearest start point"
+#: ../general/g.mapset/main.c:169
+#, fuzzy, c-format
+msgid "Mapset <%s> does not exist. Use -c flag to create it."
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:161 ../raster/r.cost/main.c:168
-#: ../raster/r.walk/main.c:206
+#: ../general/g.mapset/main.c:179
#, fuzzy
-msgid "Optional outputs"
+msgid "Unable to read GIS_LOCK environment variable"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:167 ../raster/r.walk/main.c:205
-#, fuzzy
-msgid "Name for output raster map to contain movement directions"
-msgstr "출력할 래스터맵"
+#: ../general/g.mapset/main.c:195
+#, c-format
+msgid "Lock file of mapset <%s> cannot be checked"
+msgstr ""
-#: ../raster/r.cost/main.c:173 ../raster/r.walk/main.c:211
+#: ../general/g.mapset/main.c:198
+#, c-format
+msgid "There appears to be an active GRASS session in selected mapset <%s>"
+msgstr ""
+#: ../general/g.mapset/main.c:204
#, fuzzy
-msgid "Name of starting vector points map"
+msgid "Cleaning up temporary files..."
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
-#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:244
-#: ../raster/r.drain/main.c:137 ../raster/r.drain/main.c:144
-#: ../raster/r.walk/main.c:212 ../raster/r.walk/main.c:224
-#: ../raster/r.walk/main.c:231 ../raster/r.walk/main.c:310
-msgid "Start"
+#: ../general/g.mapset/main.c:218
+msgid "Your shell continues to use the history for the old mapset"
msgstr ""
-#: ../raster/r.cost/main.c:179 ../raster/r.walk/main.c:217
-#, fuzzy
-msgid "Name of stopping vector points map"
-msgstr "출력할 래스터맵"
+#: ../general/g.mapset/main.c:223
+#, c-format
+msgid ""
+"You can switch the history by commands:\n"
+"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+msgstr ""
-#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
-#: ../raster/r.walk/main.c:218 ../raster/r.walk/main.c:238
-msgid "Stop"
+#: ../general/g.mapset/main.c:228
+#, c-format
+msgid ""
+"history -S; history -L %s/.history; setenv histfile=%s/.history"
msgstr ""
-#: ../raster/r.cost/main.c:185 ../raster/r.walk/main.c:223
-#, fuzzy
-msgid "Name of starting raster points map"
-msgstr "출력할 래스터맵"
+#: ../general/g.mapset/main.c:234
+#, c-format
+msgid "Your current mapset is <%s>"
+msgstr ""
-#: ../raster/r.cost/main.c:192 ../raster/r.drain/main.c:136
-#: ../raster/r.walk/main.c:230
+#: ../general/g.message/main.c:35
#, fuzzy
-msgid "Coordinates of starting point(s) (E,N)"
+msgid "scripts"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:199 ../raster/r.walk/main.c:237
-msgid "Coordinates of stopping point(s) (E,N)"
+#: ../general/g.message/main.c:37
+msgid ""
+"Prints a message, warning, progress info, or fatal error in the GRASS way."
msgstr ""
-#: ../raster/r.cost/main.c:209 ../raster/r.walk/main.c:246
-msgid "Maximum cumulative cost"
+#: ../general/g.message/main.c:39
+msgid "This module should be used in scripts for messages served to user."
msgstr ""
-#: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:254
-msgid "Cost assigned to null cells. By default, null cells are excluded"
+#: ../general/g.message/main.c:44
+msgid "Print message as warning"
msgstr ""
-#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:239
-#: ../raster/r.walk/main.c:255 ../raster/r.walk/main.c:305
-msgid "NULL cells"
+#: ../general/g.message/main.c:49
+msgid "Print message as fatal error"
msgstr ""
-#: ../raster/r.cost/main.c:229 ../raster/r.in.xyz/main.c:279
-#: ../raster/r.walk/main.c:264 ../raster/r.in.lidar/main.c:211
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
-msgid "Percent of map to keep in memory"
+#: ../general/g.message/main.c:54
+msgid "Print message as debug message"
msgstr ""
-#: ../raster/r.cost/main.c:234 ../raster/r.walk/main.c:300
-msgid "Use the 'Knight's move'; slower, but more accurate"
+#: ../general/g.message/main.c:59
+msgid "Print message as progress info"
msgstr ""
-#: ../raster/r.cost/main.c:238
-#, fuzzy
-msgid "Keep null values in output raster map"
-msgstr "출력할 래스터맵"
+#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
+#: ../general/g.message/main.c:85
+msgid "Level"
+msgstr ""
-#: ../raster/r.cost/main.c:243 ../raster/r.walk/main.c:309
-msgid "Start with values in raster map"
+#: ../general/g.message/main.c:64
+msgid "Print message in all modes except of quiet mode"
msgstr ""
-#: ../raster/r.cost/main.c:248
-msgid "Print info about disk space and memory requirements and exit"
+#: ../general/g.message/main.c:65
+msgid "Message is printed on GRASS_VERBOSE>=1"
msgstr ""
-#: ../raster/r.cost/main.c:298 ../raster/r.walk/main.c:363
-msgid "Must specify exactly one of start_points, start_rast or coordinate"
+#: ../general/g.message/main.c:70
+msgid "Print message only in verbose mode"
msgstr ""
-#: ../raster/r.cost/main.c:303 ../raster/r.cost/main.c:709
-#: ../raster/r.walk/main.c:368
-msgid "No start points"
+#: ../general/g.message/main.c:71
+msgid "Message is printed only on GRASS_VERBOSE>=3"
msgstr ""
-#: ../raster/r.cost/main.c:310 ../raster/r.walk/main.c:375
-#, c-format
-msgid "Inappropriate maximum cost: %d"
+#: ../general/g.message/main.c:78
+#, fuzzy
+msgid "Text of the message to be printed"
+msgstr "출력할 래스터맵"
+#: ../general/g.message/main.c:79
+msgid "Message is printed on GRASS_VERBOSE>=2"
msgstr ""
-#: ../raster/r.cost/main.c:314 ../raster/r.walk/main.c:379
-#, c-format
-msgid "Inappropriate percent memory: %d"
+#: ../general/g.message/main.c:88
+msgid "Level to use for debug messages"
msgstr ""
-#: ../raster/r.cost/main.c:327 ../raster/r.walk/main.c:417
-#: ../raster/r.carve/main.c:158 ../general/g.region/main.c:508
-#: ../doc/vector/v.example/main.c:75 ../misc/m.nviz.image/vector.c:86
-#: ../display/d.what.vect/main.c:133 ../display/d.extract/main.c:98
-#: ../vector/v.convert/old2new.c:26 ../vector/v.convert/att.c:31
-#: ../vector/v.lidar.growing/main.c:126 ../vector/v.clean/test/topocheck.c:63
-#: ../vector/v.vect.stats/main.c:253 ../vector/v.vect.stats/main.c:260
-#: ../vector/v.colors/main.c:240 ../vector/v.surf.bspline/main.c:249
-#: ../vector/v.surf.bspline/main.c:317
-#: ../vector/v.lidar.edgedetection/main.c:213 ../vector/v.edit/main.c:152
-#: ../vector/v.lrs/v.lrs.segment/main.c:139
-#: ../vector/v.lrs/v.lrs.create/main.c:251
-#: ../vector/v.lrs/v.lrs.create/main.c:258
-#: ../vector/v.lrs/v.lrs.where/main.c:127
-#: ../vector/v.lrs/v.lrs.where/main.c:135
-#: ../vector/v.lrs/v.lrs.label/main.c:287
-#: ../vector/v.lidar.correction/main.c:178 ../vector/v.outlier/main.c:168
-#, fuzzy, c-format
-msgid "Vector map <%s> not found"
+#: ../general/g.message/main.c:95
+msgid "Select only one message level"
+msgstr ""
+#: ../general/g.message/main.c:108
+#, fuzzy
+msgid "Unable to parse input message"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:332
-msgid "Assigning negative cost to null cell. Null cells excluded."
+#: ../general/g.mlist/main.c:64 ../general/g.list/main.c:46
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
+#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
+#: ../locale/scriptstrings/t.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
+msgid "list"
msgstr ""
-#: ../raster/r.cost/main.c:410 ../raster/r.cost/main.c:419
-#: ../raster/r.walk/main.c:523 ../raster/r.walk/main.c:533
-#, c-format
-msgid "Will need at least %.2f MB of disk space"
+#: ../general/g.mlist/main.c:66
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
msgstr ""
-#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:420
-#: ../raster/r.walk/main.c:524 ../raster/r.walk/main.c:534
-#, c-format
-msgid "Will need at least %.2f MB of memory"
+#: ../general/g.mlist/main.c:81
+msgid "Map name search pattern (default: all)"
msgstr ""
-#: ../raster/r.cost/main.c:424 ../raster/r.walk/main.c:545
+#: ../general/g.mlist/main.c:82 ../general/g.mlist/main.c:90
+#: ../general/g.mlist/main.c:103 ../general/g.mlist/main.c:109
+msgid "Pattern"
+msgstr ""
+#: ../general/g.mlist/main.c:89
+msgid "Map name exclusion pattern (default: none)"
+msgstr ""
+#: ../general/g.mlist/main.c:94
#, fuzzy
-msgid "Creating some temporary files..."
+msgid "Name of mapset to list (default: current search path)"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:428 ../raster/r.cost/main.c:433
-#: ../raster/r.resamp.bspline/main.c:307 ../raster/r.resamp.bspline/main.c:393
-#: ../raster/r.resamp.bspline/main.c:464 ../vector/v.surf.bspline/main.c:458
-#: ../vector/v.surf.bspline/main.c:486
+#: ../general/g.mlist/main.c:102 ../general/g.mremove/main.c:70
+msgid "Use basic regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.mlist/main.c:108 ../general/g.mremove/main.c:75
+msgid "Use extended regular expressions instead of wildcards"
+msgstr ""
+#: ../general/g.mlist/main.c:113
#, fuzzy
-msgid "Can not create temporary file"
+msgid "Print data types"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:438
+#: ../general/g.mlist/main.c:118
+msgid "Print fully-qualified map names (including mapsets)"
+msgstr ""
+#: ../general/g.mlist/main.c:123
+msgid "Pretty printing in human readable format"
+msgstr ""
+#: ../general/g.mlist/main.c:128 ../general/g.list/main.c:59
+msgid "Verbose listing (also list map titles)"
+msgstr ""
+#: ../general/g.mlist/main.c:135
+msgid "-r and -e are mutually exclusive"
+msgstr ""
+#: ../general/g.mlist/main.c:258
#, fuzzy, c-format
-msgid "Reading raster map <%s>, initializing output..."
+msgid "%s available in mapset <%s>:"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:483
-#, c-format
+#: ../general/g.copy/main.c:44
msgid ""
-"Negative cell value found at row %d, col %d. Setting negative value to "
-"null_cost value"
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
msgstr ""
-#: ../raster/r.cost/main.c:500
+#: ../general/g.copy/main.c:51
#, fuzzy
-msgid "Initializing directional output..."
+msgid "copied"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:530 ../raster/r.cost/main.c:603
-#: ../raster/r.drain/main.c:268 ../raster/simwe/simlib/observation_points.c:39
-#: ../raster/r.region/main.c:207 ../raster/r.walk/main.c:690
-#: ../raster/r.walk/main.c:756 ../raster/r.what/main.c:240
-#: ../doc/vector/v.example/main.c:87 ../misc/m.nviz.image/vector.c:282
-#: ../display/d.what.vect/main.c:111 ../vector/v.net.connectivity/main.c:130
-#: ../vector/v.surf.rst/main.c:529 ../vector/v.surf.rst/main.c:632
-#: ../vector/v.info/main.c:60 ../vector/v.net.bridge/main.c:118
-#: ../vector/v.out.ascii/main.c:87 ../vector/v.out.ascii/main.c:94
-#: ../vector/v.support/main.c:130 ../vector/v.net.distance/main.c:176
-#: ../vector/v.net/main.c:66 ../vector/v.net/main.c:90
-#: ../vector/v.lidar.growing/main.c:138 ../vector/v.lidar.growing/main.c:142
-#: ../vector/v.net.allpairs/main.c:130 ../vector/v.hull/main.c:87
-#: ../vector/v.net.visibility/main.c:79 ../vector/v.net.visibility/main.c:88
-#: ../vector/v.lidar.edgedetection/main.c:219 ../vector/v.to.3d/main.c:72
-#: ../vector/v.net.flow/main.c:143 ../vector/v.edit/main.c:167
-#: ../vector/v.net.spanningtree/main.c:101
-#: ../vector/v.net.timetable/main.c:353 ../vector/v.out.postgis/main.c:100
-#: ../vector/v.net.components/main.c:147 ../vector/v.net.centrality/main.c:209
-#: ../vector/v.generalize/main.c:318 ../vector/v.lidar.correction/main.c:182
+#: ../general/g.copy/main.c:66
#, fuzzy, c-format
-msgid "Unable to open vector map <%s>"
+msgid "<%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:532 ../raster/r.drain/main.c:270
-#: ../raster/r.walk/main.c:682
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with start points..."
-msgstr "출력할 래스터맵"
+#: ../general/g.copy/main.c:71
+#, c-format
+msgid "%s=%s,%s: files are the same, no copy required"
+msgstr ""
-#: ../raster/r.cost/main.c:545 ../raster/r.cost/main.c:615
-#: ../raster/r.drain/main.c:283 ../raster/r.walk/main.c:702
-#: ../raster/r.walk/main.c:768 ../display/d.vect/lines.c:143
-#: ../display/d.vect/dir.c:30 ../display/d.vect/topo.c:52
-#: ../display/d.vect/label.c:44 ../display/d.vect/attr.c:51
-#: ../display/d.vect/vert.c:27 ../vector/v.label/main.c:292
-#: ../vector/v.info/level1.c:37 ../vector/v.label.sa/labels.c:139
-#: ../vector/v.colors.out/scan_cats.c:30 ../vector/v.colors/scan_cats.c:24
-#: ../vector/v.colors/scan_z.c:36 ../vector/v.to.3d/trans3.c:85
-#: ../vector/v.to.3d/trans2.c:84 ../vector/v.perturb/main.c:176
-#, fuzzy
-msgid "Unable to read vector map"
-msgstr "출력할 래스터맵"
+#: ../general/g.copy/main.c:76
+#, c-format
+msgid "<%s> already exists"
+msgstr ""
-#: ../raster/r.cost/main.c:579
+#: ../general/g.cairocomp/main.c:46 ../raster3d/r3.support/main.c:166
+#: ../raster/r.mapcalc/main.c:91 ../raster/r.series/main.c:211
+#: ../raster/r.topmodel/file_io.c:29 ../raster/r.topmodel/file_io.c:72
+#: ../raster/r.topmodel/file_io.c:181 ../raster/r.series.accumulate/main.c:223
+#: ../raster/r.in.xyz/main.c:540 ../raster/r.support/main.c:180
+#: ../raster/r.in.arc/main.c:123 ../raster/r.in.mat/main.c:125
+#: ../vector/v.lrs/v.lrs.segment/main.c:133 ../vector/v.segment/main.c:94
+#: ../vector/v.net.path/path.c:49 ../display/d.linegraph/main.c:205
+#: ../display/d.linegraph/main.c:221 ../display/d.linegraph/main.c:363
+#: ../display/d.text/main.c:366 ../display/d.where/main.c:163
#, fuzzy, c-format
-msgid "No start points found in vector map <%s>"
+msgid "Unable to open input file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:581
+#: ../general/g.cairocomp/main.c:49
#, fuzzy, c-format
-msgid "%d point found"
-msgid_plural "%d points found"
-msgstr[0] "출력할 래스터맵"
-msgstr[1] "출력할 래스터맵"
-#: ../raster/r.cost/main.c:595 ../raster/r.walk/main.c:748
-#, fuzzy, c-format
-msgid "Reading vector map <%s> with stop points..."
+msgid "Unable to read input file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:649 ../raster/r.walk/main.c:802
+#: ../general/g.cairocomp/main.c:52
#, fuzzy, c-format
-msgid "No stop points found in vector <%s>"
+msgid "Unable to parse input file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:670 ../raster/r.walk/main.c:822
-#: ../raster/r.texture/h_measure.c:594 ../raster/r.stream.extract/load.c:44
-#: ../raster/r.stream.extract/load.c:53 ../imagery/i.smap/interp.c:68
-msgid "Unable to allocate memory"
+#: ../general/g.cairocomp/main.c:66 ../general/g.pnmcat/main.c:170
+#: ../raster3d/r3.support/main.c:152 ../raster/r.topmodel/file_io.c:229
+#: ../raster/r.out.pov/main.c:173 ../raster/r.out.mat/main.c:91
+#: ../raster/r.out.png/main.c:205 ../raster/r.support/main.c:166
+#: ../raster/r.colors.out/raster_main.c:79
+#: ../raster/r.colors.out/raster3d_main.c:80 ../raster/r.out.vrml/main.c:138
+#: ../vector/v.colors.out/main.c:103
+#, c-format
+msgid "Unable to open output file <%s>"
msgstr ""
-#: ../raster/r.cost/main.c:672
+#: ../general/g.cairocomp/main.c:71
#, fuzzy, c-format
-msgid "Reading raster map <%s> with start points..."
+msgid "Unable to write output file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:723 ../raster/r.walk/main.c:875
-msgid "Specified starting location outside database window"
-msgstr ""
+#: ../general/g.cairocomp/main.c:89 ../general/g.cairocomp/main.c:255
+#: ../visualization/ximgview/main.c:64
+#, fuzzy
+msgid "Unable to open display"
+msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:744
+#: ../general/g.cairocomp/main.c:113
#, fuzzy
-msgid "Finding cost path..."
+msgid "Unable to obtain visual"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:1019 ../raster/r.walk/main.c:1367
-msgid "Error, ct == pres_cell"
+#: ../general/g.cairocomp/main.c:129
+#, fuzzy
+msgid "Failed to initialize output surface"
+msgstr "출력할 래스터맵"
+#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
+#, c-format
+msgid "Invalid color: %s"
msgstr ""
-#: ../raster/r.cost/main.c:1043 ../raster/r.buffer/write_map.c:45
-#: ../raster/r.flow/io.c:207
-#, fuzzy, c-format
-msgid "Writing output raster map <%s>..."
+#: ../general/g.cairocomp/main.c:171
+#, fuzzy
+msgid "Failed to initialize input surface"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:1045
-#, fuzzy, c-format
-msgid "Writing raster map with nearest start point <%s>..."
+#: ../general/g.cairocomp/main.c:198
+#, fuzzy
+msgid "Overlays multiple X Pixmaps."
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:1140
-#, fuzzy, c-format
-msgid "Writing output movement direction raster map <%s>..."
+#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
+#, fuzzy
+msgid "Name of input file(s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.cost/main.c:1206 ../raster/r.walk/main.c:1492
-#, c-format
-msgid "Peak cost value: %f."
+#: ../general/g.cairocomp/main.c:212
+msgid "Output Visual XID"
msgstr ""
-#: ../raster/r.cost/main.c:1228 ../raster/r.walk/main.c:1517
-#, c-format
-msgid "Illegal x coordinate <%s>"
+#: ../general/g.cairocomp/main.c:218
+msgid "Output screen"
msgstr ""
-#: ../raster/r.cost/main.c:1230 ../raster/r.walk/main.c:1519
-#, c-format
-msgid "Illegal y coordinate <%s>"
+#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
+msgid "Layer opacities"
msgstr ""
-#: ../raster/r.cost/main.c:1234 ../raster/r.walk/main.c:1523
-#, c-format
-msgid "Warning, ignoring point outside window: %.4f,%.4f"
+#: ../general/g.cairocomp/main.c:230 ../general/g.pnmcomp/main.c:315
+#: ../general/g.pnmcat/main.c:149
+msgid "Image width"
msgstr ""
-#: ../raster/r.transect/main.c:84
-#, c-format
-msgid "End coordinate: %.15g, %.15g"
+#: ../general/g.cairocomp/main.c:236 ../general/g.pnmcomp/main.c:321
+#: ../general/g.pnmcat/main.c:155
+msgid "Image height"
msgstr ""
-#: ../raster/r.transect/main.c:104
-#, fuzzy
-msgid "transect"
-msgstr "출력할 래스터맵"
+#: ../general/g.cairocomp/main.c:239
+msgid "Background color (R:G:B:A)"
+msgstr ""
-#: ../raster/r.transect/main.c:106
+#: ../general/g.cairocomp/main.c:244
+msgid "Don't composite; just delete input Pixmaps"
+msgstr ""
+#: ../general/g.cairocomp/main.c:276
+msgid "input= and opacity= must have the same number of values"
+msgstr ""
+#: ../general/g.mkfontcap/main.c:73
msgid ""
-"Outputs raster map layer values lying along user defined transect line(s)."
+"Generates the font configuration file by scanning various directories for "
+"fonts."
msgstr ""
-#: ../raster/r.transect/main.c:110
-msgid "Raster map to be queried"
+#: ../general/g.mkfontcap/main.c:79
+msgid "Overwrite font configuration file if already existing"
msgstr ""
-#: ../raster/r.transect/main.c:116
-msgid "Transect definition"
+#: ../general/g.mkfontcap/main.c:84
+msgid ""
+"Write font configuration file to standard output instead of $GISBASE/etc"
msgstr ""
-#: ../raster/r.transect/main.c:125 ../raster/r.what/main.c:123
-#: ../raster3d/r3.out.ascii/main.c:100
-msgid "Char string to represent no data cell"
+#: ../general/g.mkfontcap/main.c:91
+msgid "List of extra directories to scan"
msgstr ""
-#: ../raster/r.transect/main.c:130 ../raster/r.profile/main.c:94
-msgid "Output easting and northing in first two columns of four column output"
+#: ../general/g.mkfontcap/main.c:93
+msgid ""
+"Comma-separated list of extra directories to scan for Freetype-compatible "
+"fonts as well as the defaults (see documentation)"
msgstr ""
-#: ../raster/r.support/main.c:56 ../raster/r.info/main.c:70
-#: ../raster/r.region/main.c:52 ../raster/r.timestamp/main.c:36
-#: ../raster/r.describe/main.c:55
-#: ../locale/scriptstrings/t.select_to_translate.c:3
-#: ../locale/scriptstrings/t.info_to_translate.c:3
-#: ../locale/scriptstrings/t.support_to_translate.c:3
-#: ../raster3d/r3.info/r3.info.main.c:76 ../raster3d/r3.support/main.c:50
-#: ../vector/v.info/main.c:38 ../vector/v.support/main.c:40
-#: ../vector/v.timestamp/main.c:36
-#, fuzzy
-msgid "metadata"
-msgstr "출력할 래스터맵"
+#: ../general/g.mkfontcap/main.c:110
+#, c-format
+msgid ""
+"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgstr ""
-#: ../raster/r.support/main.c:57
-msgid "Allows creation and/or modification of raster map layer support files."
+#: ../general/g.mkfontcap/main.c:122
+msgid ""
+"This GRASS installation was compiled without Freetype support, extradirs "
+"parameter ignored"
msgstr ""
-#: ../raster/r.support/main.c:67 ../raster3d/r3.support/main.c:61
-#, fuzzy
-msgid "Text to use for map title"
+#: ../general/g.mkfontcap/main.c:149
+#, fuzzy, c-format
+msgid "Cannot open %s for writing: %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.support/main.c:75 ../raster3d/r3.support/main.c:69
-msgid "Text to append to the next line of the map's metadata file"
+#: ../general/g.tempfile/main.c:41
+msgid "Creates a temporary file and prints it's file name."
msgstr ""
-#: ../raster/r.support/main.c:81
-msgid "Text to use for map data units"
+#: ../general/g.tempfile/main.c:47
+msgid "Process id to use when naming the tempfile"
msgstr ""
-#: ../raster/r.support/main.c:87
-msgid "Text to use for map vertical datum"
+#: ../general/g.tempfile/main.c:51
+msgid "Dry run - don't create a file, just prints it's file name"
msgstr ""
-#: ../raster/r.support/main.c:94 ../raster3d/r3.support/main.c:88
-msgid "Text to use for data source, line 1"
+#: ../general/g.gisenv/main.c:45
+msgid "variables"
msgstr ""
-#: ../raster/r.support/main.c:101 ../raster3d/r3.support/main.c:95
-msgid "Text to use for data source, line 2"
+#: ../general/g.gisenv/main.c:47
+msgid "Outputs and modifies the user's current GRASS variable settings."
msgstr ""
-#: ../raster/r.support/main.c:109 ../raster3d/r3.support/main.c:103
-msgid "Text to use for data description or keyword(s)"
+#: ../general/g.gisenv/main.c:48
+msgid "Prints all defined GRASS variables if no option is given."
msgstr ""
-#: ../raster/r.support/main.c:116 ../raster/r.category/main.c:80
-#: ../raster3d/r3.support/main.c:110
-#, fuzzy
-msgid "Raster map from which to copy category table"
-msgstr "출력할 래스터맵"
+#: ../general/g.gisenv/main.c:53
+msgid "GRASS variable to get"
+msgstr ""
-#: ../raster/r.support/main.c:121 ../raster3d/r3.support/main.c:115
-msgid "Text file from which to load history"
+#: ../general/g.gisenv/main.c:56
+msgid "Get"
msgstr ""
-#: ../raster/r.support/main.c:126 ../raster3d/r3.support/main.c:120
-msgid "Text file in which to save history"
+#: ../general/g.gisenv/main.c:61
+msgid "GRASS variable to set"
msgstr ""
-#: ../raster/r.support/main.c:130
-msgid "Update statistics (histogram, range)"
+#: ../general/g.gisenv/main.c:64 ../general/g.gisenv/main.c:72
+#: ../general/g.gisenv/main.c:81 ../db/db.connect/main.c:64
+#: ../db/db.connect/main.c:70 ../db/db.connect/main.c:75
+#: ../db/db.connect/main.c:79 ../db/db.connect/main.c:83
+#: ../db/db.connect/main.c:93 ../temporal/t.connect/main.c:49
+#: ../temporal/t.connect/main.c:55 ../temporal/t.connect/main.c:60
+#: ../temporal/t.connect/main.c:65 ../temporal/t.connect/main.c:69
+msgid "Set"
msgstr ""
-#: ../raster/r.support/main.c:134
-msgid "Create/reset the null file"
+#: ../general/g.gisenv/main.c:69
+msgid "GRASS variable to unset"
msgstr ""
-#: ../raster/r.support/main.c:138
-msgid "Delete the null file"
+#: ../general/g.gisenv/main.c:79
+msgid "Where GRASS variable is stored"
msgstr ""
-#: ../raster/r.support/main.c:148 ../raster/r.category/main.c:130
-#, fuzzy, c-format
-msgid "Raster map <%s> not found in current mapset"
-msgstr "출력할 래스터맵"
+#: ../general/g.gisenv/main.c:85
+msgid "Use shell syntax (for \"eval\")"
+msgstr ""
-#: ../raster/r.support/main.c:249 ../raster/r.statistics/main.c:109
-#: ../display/d.title/main.c:110 ../raster3d/r3.support/main.c:247
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s>"
-msgstr "출력할 래스터맵"
+#: ../general/g.gisenv/main.c:86 ../general/g.gisenv/main.c:91
+#: ../vector/v.db.select/main.c:69 ../vector/v.db.select/main.c:75
+#: ../vector/v.db.select/main.c:82 ../vector/v.db.select/main.c:99
+#: ../vector/v.db.select/main.c:104 ../db/db.select/main.c:226
+#: ../db/db.select/main.c:232 ../db/db.select/main.c:239
+#: ../db/db.select/main.c:249 ../db/db.select/main.c:259
+msgid "Format"
+msgstr ""
-#: ../raster/r.support/main.c:253 ../raster3d/r3.support/main.c:251
-#, c-format
-msgid "cats table for [%s] set to %s"
+#: ../general/g.gisenv/main.c:90
+msgid "Don't use shell syntax"
msgstr ""
-#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
+#: ../general/g.gisenv/main.c:97
#, c-format
-msgid "[%s] is a reclass of another map. Exiting."
+msgid "Flags -%c and -%c are mutually exclusive"
msgstr ""
-#: ../raster/r.support/main.c:288
+#: ../general/g.gisenv/main.c:131 ../vector/v.colors/main.c:222
#, c-format
-msgid "Writing new null file for [%s]... "
+msgid "Options <%s>, <%s>, and <%s> are mutually exclusive"
msgstr ""
-#: ../raster/r.support/main.c:309
+#: ../general/g.gisenv/main.c:161
#, c-format
-msgid "Removing null file for [%s]...\n"
+msgid "Value '%s' ignored when unsetting the GRASS variable"
msgstr ""
-#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:156
-msgid "Done."
+#: ../general/g.gisenv/main.c:198
+msgid "GRASS variable not defined"
msgstr ""
-#: ../raster/r.support/check.c:26
+#: ../general/g.gisenv/main.c:204
#, c-format
-msgid ""
-"\n"
-" Updating statistics for [%s]"
+msgid "GRASS variable must be uppercase. Using '%s'."
msgstr ""
-#: ../raster/r.support/check.c:69
-#, c-format
-msgid ""
-" Updating the number of categories for [%s]\n"
-"\n"
+#: ../general/g.list/main.c:48
+msgid "Lists available GRASS data base files of the user-specified data type."
msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:38
-#: ../raster/r.watershed/ram/close_maps2.c:34
-msgid "No basins were created. Verify threshold and region settings."
+#: ../general/g.pnmcomp/main.c:54 ../general/g.pnmcat/main.c:30
+msgid "Error reading PPM file"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:86
-msgid "Closing stream segments map"
+#: ../general/g.pnmcomp/main.c:69 ../general/g.pnmcomp/main.c:74
+#: ../general/g.pnmcomp/main.c:83 ../general/g.pnmcomp/main.c:134
+#: ../general/g.pnmcomp/main.c:147 ../general/g.pnmcat/main.c:46
+#: ../general/g.pnmcat/main.c:54 ../general/g.pnmcat/main.c:59
+msgid "Invalid PPM file"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps2.c:109
-#, fuzzy
-msgid "Closing basins map"
+#: ../general/g.pnmcomp/main.c:96 ../general/g.pnmcat/main.c:83
+#, fuzzy, c-format
+msgid "File <%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/seg/close_maps2.c:116
-msgid "Closing half basins map"
+#: ../general/g.pnmcomp/main.c:104
+msgid "Expecting PPM but got PGM"
msgstr ""
-#: ../raster/r.watershed/seg/main.c:90 ../raster/r.watershed/seg/main.c:105
-#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
-#, c-format
-msgid "SECTION %d: Closing Maps."
+#: ../general/g.pnmcomp/main.c:109
+msgid "Expecting PGM but got PPM"
msgstr ""
-#: ../raster/r.watershed/seg/main.c:103 ../raster/r.watershed/ram/main.c:96
+#: ../general/g.pnmcomp/main.c:112
#, c-format
-msgid "SECTION %d: Watershed determination."
+msgid "Invalid magic number: 'P%c'"
msgstr ""
-#: ../raster/r.watershed/seg/usage.c:9 ../raster/r.watershed/ram/usage.c:9
-#, c-format
-msgid ""
-"USAGE for basin delineation:\n"
-"%s -4 elevation=elevation_map threshold=swale_threshold "
-"[flow=overland_flow_map] [drainage=drain_direction_map] "
-"[depression=depression_map] [accumulation=accumulation_map] "
-"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
-"\n"
-"USAGE for slope length determination:\n"
-"%s [-4] elevation=elevation_map threshold=swale_threshold "
-"[drainage=drain_direction_map] [depression=depression_map] "
-"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
-"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
-"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
-"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
-"creation:\n"
-"[basin=watershed_basin_map] [stream=stream_segment_map] "
-"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
-"\n"
+#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
+msgid "Invalid PGM file"
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:132
-#, c-format
-msgid "SECTION 1 beginning: Initiating Variables. %d section total."
-msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
-msgstr[0] ""
-msgstr[1] ""
+#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
+#: ../misc/m.nviz.script/main.c:202 ../misc/m.transform/main.c:276
+#: ../raster/r.profile/main.c:154 ../raster/r.out.ascii/main.c:160
+#: ../raster/r.out.ppm3/main.c:133 ../raster/r.out.arc/main.c:129
+#: ../raster/r.category/main.c:173 ../raster/r.recode/main.c:89
+#: ../raster/r.in.lidar/main.c:284 ../raster/r.horizon/main.c:367
+#: ../vector/v.edit/main.c:78 ../vector/v.out.vtk/main.c:176
+#: ../vector/v.out.ascii/main.c:125 ../vector/v.net/main.c:98
+#, fuzzy, c-format
+msgid "Unable to open file <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/seg/init_vars.c:168
-msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
+#: ../general/g.pnmcomp/main.c:247
+msgid "Error writing PPM file"
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:245
-#: ../raster/r.stream.extract/main.c:318
-#, c-format
-msgid "Will need up to %.2f MB of disk space"
+#: ../general/g.pnmcomp/main.c:264
+msgid "Error writing PGM file"
msgstr ""
-#: ../raster/r.watershed/seg/init_vars.c:247
-#: ../raster/r.stream.extract/main.c:320
-#, c-format
-msgid "Will need up to %.2f GB (%.0f MB) of disk space"
-msgstr ""
+#: ../general/g.pnmcomp/main.c:285
+#, fuzzy
+msgid "Overlays multiple PPM image files."
+msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/seg/init_vars.c:457
-msgid "SECTION 1b: Determining Offmap Flow."
+#: ../general/g.pnmcomp/main.c:296
+#, fuzzy
+msgid "Name of input mask file(s)"
+msgstr "출력할 래스터맵"
+#: ../general/g.pnmcomp/main.c:309
+#, fuzzy
+msgid "Name for output mask file"
+msgstr "출력할 래스터맵"
+#: ../general/g.filename/main.c:41
+msgid "Prints GRASS data base file names."
msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:30
-#: ../raster/r.watershed/ram/do_astar.c:27
-msgid "SECTION 2: A* Search."
+#: ../general/g.filename/main.c:55
+msgid "Name of a database file"
msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:48
-msgid "No seeds for A* Search"
+#: ../general/g.filename/main.c:61
+msgid "Name of a mapset (default: current)"
msgstr ""
-#: ../raster/r.watershed/seg/do_astar.c:146
-msgid "bug in A* Search: doer %"
+#: ../general/g.mremove/main.c:65
+msgid ""
+"Removes data base element files from the user's current mapset using regular "
+"expressions."
msgstr ""
-#: ../raster/r.watershed/seg/sg_factor.c:14
-msgid "SECTION 5: RUSLE LS and/or S factor determination."
+#: ../general/g.mremove/main.c:80
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:4
+msgid "Force removal (required for actual deletion of files)"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:20
-msgid "Closing accumulation map"
+#: ../general/g.mremove/main.c:84
+#, fuzzy
+msgid "Remove base raster maps"
+msgstr "출력할 래스터맵"
+#: ../general/g.mremove/main.c:85
+#: ../locale/scriptstrings/r.mask_to_translate.c:5
+#: ../locale/scriptstrings/r.mask_to_translate.c:8
+msgid "Raster"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:132
+#: ../general/g.mremove/main.c:92
#, fuzzy
-msgid "Closing TCI map"
+msgid "removed"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/seg/close_maps.c:214
-msgid "Closing flow direction map"
+#: ../general/g.mremove/main.c:99
+#, c-format
+msgid "-%c and -%c are mutually exclusive"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:241
-msgid "Closing LS map"
+#: ../general/g.mremove/main.c:103
+msgid "The following data base element files would be deleted:"
msgstr ""
-#: ../raster/r.watershed/seg/close_maps.c:246
-msgid "Closing SL map"
+#: ../general/g.mremove/main.c:127
+#, fuzzy, c-format
+msgid "Unable to compile pattern <%s>"
+msgstr "출력할 래스터맵"
+#: ../general/g.mremove/main.c:152
+#, c-format
+msgid "You must use the force flag (-%c) to actually remove them. Exiting."
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:118
-#: ../raster/r.watershed/ram/do_cum.c:114
-msgid "SECTION 3: Accumulating Surface Flow with SFD."
+#: ../general/g.mremove/check_reclass.c:22
+#, fuzzy, c-format
+msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
+msgstr "출력할 래스터맵"
+#: ../general/g.mremove/check_reclass.c:45
+#: ../general/g.mremove/check_reclass.c:59
+#, c-format
+msgid "Removing information about reclassed map from [%s@%s] failed"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:283
-#: ../raster/r.watershed/ram/do_cum.c:272
-msgid "SECTION 3a: Accumulating Surface Flow with MFD."
+#: ../general/g.pnmcat/main.c:49
+msgid "Unsupported PPM file (format = P6 required)"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:473
-#: ../raster/r.watershed/ram/do_cum.c:437
-#: ../raster/r.stream.extract/streams.c:336
+#: ../general/g.pnmcat/main.c:62
+msgid "Unsupported PPM file (maxval = 255 required)"
+msgstr ""
+#: ../general/g.pnmcat/main.c:93
#, c-format
-msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgid "File <%s> has wrong height (expected %d, got %d"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:517
-msgid "MFD: A * path already processed when distributing flow: %d of %"
+#: ../general/g.pnmcat/main.c:128
+#, fuzzy
+msgid "Base name of input files"
+msgstr "출력할 래스터맵"
+#: ../general/g.pnmcat/main.c:137 ../raster3d/r3.in.bin/main.c:330
+#: ../raster/r.in.bin/main.c:331
+msgid "Number of rows"
msgstr ""
-#: ../raster/r.watershed/seg/do_cum.c:521
-#: ../raster/r.watershed/ram/do_cum.c:480
-msgid "SECTION 3b: Adjusting drainage directions."
+#: ../general/g.pnmcat/main.c:143 ../raster3d/r3.in.bin/main.c:337
+#: ../raster/r.in.bin/main.c:338
+msgid "Number of columns"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:56
-msgid "Beautify flat areas: priority queue error"
+#: ../general/g.pnmcat/main.c:181
+#, c-format
+msgid "Row <%d> has wrong width (expected %d, got %d"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:229
-msgid "flat cell escaped for uphill correction"
+#: ../general/g.pnmcat/main.c:186
+#, c-format
+msgid "Invalid height (expected %d, got %d"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:235
+#: ../general/g.pnmcat/main.c:194
+#, fuzzy, c-format
+msgid "Error reading PPM file for tile <%d,%d> at row <%d>"
+msgstr "출력할 래스터맵"
+#: ../general/g.pnmcat/main.c:200
+#, fuzzy, c-format
+msgid "Error writing PPM file for tile row <%d> at row <%d>"
+msgstr "출력할 래스터맵"
+#: ../general/g.pnmcat/main.c:209
#, c-format
-msgid "queue error: last uphill order %d > current uphill order %d"
+msgid "Incorrect height (expected %d, got %d"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:240
-msgid "uphill order not set"
+#: ../imagery/i.eb.netrad/main.c:56 ../imagery/i.evapo.time/main.c:77
+#: ../imagery/i.eb.evapfr/main.c:47 ../imagery/i.his.rgb/main.c:46
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:63
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
+#: ../imagery/i.landsat.toar/main.c:70 ../imagery/i.class/main.c:91
+#: ../imagery/i.target/main.c:45 ../imagery/i.modis.qc/main.c:118
+#: ../imagery/i.maxlik/main.c:61 ../imagery/i.evapo.pm/main.c:58
+#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.landsat.acca/main.c:105
+#: ../imagery/i.evapo.mh/main.c:69 ../imagery/i.aster.toar/main.c:97
+#: ../imagery/i.gensig/main.c:39 ../imagery/i.zc/main.c:52
+#: ../imagery/i.albedo/main.c:88 ../imagery/i.cluster/main.c:75
+#: ../imagery/i.eb.eta/main.c:43 ../imagery/i.fft/main.c:78
+#: ../imagery/i.smap/main.c:38 ../imagery/i.eb.h_sebal01/main.c:83
+#: ../imagery/i.rgb.his/main.c:46 ../imagery/i.pca/main.c:72
+#: ../imagery/i.emissivity/main.c:44 ../imagery/i.vpoints/main.c:94
+#: ../imagery/i.eb.soilheatflux/main.c:49 ../imagery/i.vi/main.c:89
+#: ../imagery/i.biomass/main.c:50 ../imagery/i.points/main.c:96
+#: ../imagery/i.ifft/main.c:77 ../imagery/i.cca/main.c:84
+#: ../imagery/i.group/main.c:52 ../imagery/i.rectify/main.c:99
+#: ../imagery/i.gensigset/main.c:40 ../imagery/i.topo.corr/main.c:47
+#: ../imagery/i.segment/main.c:35
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
+#: ../locale/scriptstrings/i.oif_to_translate.c:2
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
+#: ../locale/scriptstrings/i.spectral_to_translate.c:2
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
+msgid "imagery"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:266
-msgid "flat cell escaped in uphill correction"
+#: ../imagery/i.eb.netrad/main.c:57 ../imagery/i.eb.evapfr/main.c:48
+#: ../imagery/i.eb.eta/main.c:44 ../imagery/i.eb.h_sebal01/main.c:84
+#: ../imagery/i.emissivity/main.c:47 ../imagery/i.eb.soilheatflux/main.c:50
+msgid "energy balance"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:302
-msgid "downhill order: no more points in down queue"
+#: ../imagery/i.eb.netrad/main.c:58
+#, fuzzy
+msgid "net radiation"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:59 ../imagery/i.eb.evapfr/main.c:51
+#: ../imagery/i.eb.eta/main.c:46 ../imagery/i.eb.h_sebal01/main.c:87
+#: ../imagery/i.eb.soilheatflux/main.c:52
+msgid "SEBAL"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:310
-msgid "flat cell escaped for downhill correction"
+#: ../imagery/i.eb.netrad/main.c:61
+msgid "Net radiation approximation (Bastiaanssen, 1995)."
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:316
-#, c-format
-msgid "queue error: last downhill order %d > current downhill order %d"
+#: ../imagery/i.eb.netrad/main.c:65 ../imagery/i.eb.netrad/main.c:67
+#: ../imagery/i.albedo/main.c:89
+msgid "albedo"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:321
-msgid "downhill order: downhill order not set"
+#: ../imagery/i.eb.netrad/main.c:66
+#, fuzzy
+msgid "Name of the Albedo map [0.0;1.0]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.netrad/main.c:72
+msgid "ndvi"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:344
-msgid "flat cell escaped in downhill correction"
+#: ../imagery/i.eb.netrad/main.c:71
+#, fuzzy
+msgid "Name of the NDVI map [-1.0;+1.0]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:75 ../imagery/i.landsat.toar/main.c:577
+msgid "temperature"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:382
-msgid "flat cell escaped for adjustment"
+#: ../imagery/i.eb.netrad/main.c:77
+#, fuzzy
+msgid "Name of the surface temperature map [K]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:78
+msgid "tempk"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:389
-msgid "adjustment: uphill order not set"
+#: ../imagery/i.eb.netrad/main.c:81
+msgid "localutctime"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:391
-msgid "adjustment: downhill order not set"
+#: ../imagery/i.eb.netrad/main.c:83
+#, fuzzy
+msgid "Name of the map of local UTC time of satellite overpass [hh.hhh]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:84
+msgid "time"
msgstr ""
-#: ../raster/r.watershed/ram/do_flatarea.c:417
-msgid "flat cell escaped in adjustment"
+#: ../imagery/i.eb.netrad/main.c:87
+msgid "temperaturedifference2m"
msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:118
-#, c-format
-msgid "SECTION 1a (of %1d): Initiating Memory."
+#: ../imagery/i.eb.netrad/main.c:89
+msgid ""
+"Name of the difference map of temperature from surface skin to about 2 m "
+"height [K]"
msgstr ""
-#: ../raster/r.watershed/ram/init_vars.c:299
-#, c-format
-msgid "SECTION 1b (of %1d): Determining Offmap Flow."
+#: ../imagery/i.eb.netrad/main.c:90
+msgid "dtair"
msgstr ""
-#: ../raster/r.watershed/ram/do_astar.c:254
-msgid "heapsize too large"
+#: ../imagery/i.eb.netrad/main.c:93 ../imagery/i.eb.netrad/main.c:95
+#: ../imagery/i.emissivity/main.c:45
+msgid "emissivity"
msgstr ""
-#: ../raster/r.watershed/ram/sg_factor.c:14
-msgid "SECTION 4: RUSLE LS and/or S factor determination."
+#: ../imagery/i.eb.netrad/main.c:94
+#, fuzzy
+msgid "Name of the emissivity map [-]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:98
+msgid "transmissivitysingleway"
msgstr ""
-#: ../raster/r.watershed/ram/do_cum.c:474
-#, c-format
-msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
-msgid_plural ""
-"MFD: A * path already processed when distributing flow: %d of %d cells"
-msgstr[0] ""
-msgstr[1] ""
+#: ../imagery/i.eb.netrad/main.c:100
+#, fuzzy
+msgid "Name of the single-way atmospheric transmissivitymap [-]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/shed/intro.c:8
-#, c-format
-msgid "%s provides a text-based user-interface to the %s program."
+#: ../imagery/i.eb.netrad/main.c:101
+msgid "tsw"
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:10
-#, c-format
-msgid "%s also allows the user to prepare a report of map layers for each"
+#: ../imagery/i.eb.netrad/main.c:104
+msgid "dayofyear"
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:12
-#, c-format
-msgid "watershed basin determined in %s.\n"
+#: ../imagery/i.eb.netrad/main.c:105
+#, fuzzy
+msgid "Name of the Day Of Year (DOY) map [-]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:106
+msgid "doy"
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:14
-#, c-format
-msgid "%s will help the user determine which options to use for the"
+#: ../imagery/i.eb.netrad/main.c:109
+msgid "sunzenithangle"
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:16
-#, c-format
-msgid "%s program. %s will then ask for map layers that will be"
+#: ../imagery/i.eb.netrad/main.c:110
+#, fuzzy
+msgid "Name of the sun zenith angle map [degrees]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.netrad/main.c:111
+msgid "sunzangle"
msgstr ""
-#: ../raster/r.watershed/shed/intro.c:18
-#, c-format
-msgid "divided by basin. %s will then run %s and create the report."
+#: ../imagery/i.eb.netrad/main.c:114
+#, fuzzy
+msgid "Name of the output net radiation layer"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.time/main.c:78 ../imagery/i.evapo.pm/main.c:59
+#: ../imagery/i.evapo.pt/main.c:67 ../imagery/i.evapo.mh/main.c:70
+#, fuzzy
+msgid "evapotranspiration"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.time/main.c:79
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
msgstr ""
-#: ../raster/r.watershed/shed/valid.c:24
-msgid "accum file missing in valid_basins()"
+#: ../imagery/i.evapo.time/main.c:86
+#, fuzzy
+msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.time/main.c:91
+msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:12
-msgid ""
-"\n"
-"\n"
-"Please indicate which map layers you wish to use in the lumped"
+#: ../imagery/i.evapo.time/main.c:96
+msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:13
-msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
+#: ../imagery/i.evapo.time/main.c:102
+msgid "Value of DOY for ETo first day"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:14
-msgid "layers, one at a time, until all desired map layers are in."
+#: ../imagery/i.evapo.time/main.c:108
+msgid "Value of DOY for the first day of the period studied"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:15
-#, c-format
-msgid "You can have %s include a list of categories in each."
+#: ../imagery/i.evapo.time/main.c:114
+msgid "Value of DOY for the last day of the period studied"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:17
+#: ../imagery/i.evapo.time/main.c:142
+msgid "The DOY for end_period can not be smaller than start_period"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:146
+msgid "The DOY for start_period can not be smaller than eto_doy_min"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:151
#, c-format
-msgid ""
-"\n"
-"Hit <return> at the map prompt to continue with %s"
+msgid "Too many ETa files. Only %d allowed."
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:36
+#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
+#: ../imagery/i.evapo.time/main.c:200
+msgid "The min specified input map is two"
+msgstr ""
+#: ../imagery/i.evapo.time/main.c:167
#, c-format
-msgid ""
-"\n"
-"The output from %s will be divided into watershed"
+msgid "Too many ETa_doy files. Only %d allowed."
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:38
-msgid "basins. There are two possible methods of tabulating the information:"
+#: ../imagery/i.evapo.time/main.c:183
+msgid "ETa and ETa_DOY file numbers are not equal!"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:39
-msgid "1) by only including data pertaining to the basin itself, or 2) using"
+#: ../imagery/i.evapo.time/main.c:189
+#, c-format
+msgid "Too many ETo files. Only %d allowed."
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:40
-msgid "data from the basin, and all basins upstream of it."
+#: ../imagery/i.eb.evapfr/main.c:49 ../imagery/i.eb.h_sebal01/main.c:85
+msgid "soil moisture"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:43
-msgid ""
-"\n"
-"Would you like the data organized:"
+#: ../imagery/i.eb.evapfr/main.c:50 ../imagery/i.eb.h_sebal01/main.c:86
+msgid "evaporative fraction"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:44
+#: ../imagery/i.eb.evapfr/main.c:53
msgid ""
-"1) Basin only\n"
-"2) Upstream only\n"
-"3) Both\n"
-"OR 0) to cancel program"
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:45
-#, c-format
-msgid ""
-"\n"
-"Your choice: "
+#: ../imagery/i.eb.evapfr/main.c:59 ../imagery/i.eb.soilheatflux/main.c:71
+#, fuzzy
+msgid "Name of Net Radiation raster map [W/m2]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.evapfr/main.c:63
+#, fuzzy
+msgid "Name of soil heat flux raster map [W/m2]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.evapfr/main.c:67
+#, fuzzy
+msgid "Name of sensible heat flux raster map [W/m2]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.evapfr/main.c:72
+#, fuzzy
+msgid "Name for output evaporative fraction raster map"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.evapfr/main.c:78
+#, fuzzy
+msgid "Name for output root zone soil moisture raster map"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.evapfr/main.c:83
+msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
msgstr ""
-#: ../raster/r.watershed/shed/basin_maps.c:69
-#: ../raster/r.watershed/shed/basin_maps.c:73
-#, c-format
+#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
+#: ../raster/r.his/main.c:63 ../display/d.his/main.c:64
+#, fuzzy
+msgid "color transformation"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.his.rgb/main.c:52
msgid ""
-"\n"
-"OK, %s should start running now using the following form:\n"
-"%s"
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
msgstr ""
-#: ../raster/r.watershed/shed/main.c:41
-msgid "Slow version of water analysis program starting now"
-msgstr ""
+#: ../imagery/i.his.rgb/main.c:58
+#, fuzzy
+msgid "Name of input raster map (hue)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#: ../imagery/i.his.rgb/main.c:62
+#, fuzzy
+msgid "Name of input raster map (intensity)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.his.rgb/main.c:66
+#, fuzzy
+msgid "Name of input raster map (saturation)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.his.rgb/main.c:70
+#, fuzzy
+msgid "Name for output raster map (red)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.his.rgb/main.c:74
+#, fuzzy
+msgid "Name for output raster map (green)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.his.rgb/main.c:78
+#, fuzzy
+msgid "Name for output raster map (blue)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
+#: ../imagery/i.rectify/target.c:14 ../vector/v.rectify/target.c:18
#, c-format
-msgid "<<%s>> command line failed"
+msgid "Target information for group <%s> missing"
msgstr ""
-#: ../raster/r.watershed/shed/main.c:72
-msgid "unable to open output file"
-msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
+#: ../imagery/i.rectify/target.c:20 ../vector/v.rectify/target.c:29
+#, fuzzy, c-format
+msgid "Target location <%s> not found"
+msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/shed/read.c:23
-msgid "unable to open basin/half basin map"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
+#: ../imagery/i.rectify/target.c:32 ../raster/r.in.gdal/main.c:798
+#: ../vector/v.rectify/target.c:40
+#, fuzzy, c-format
+msgid "Mapset <%s> in target location <%s> - "
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
+#: ../imagery/i.rectify/target.c:33 ../raster/r.proj/main.c:286
+#: ../raster/r.in.gdal/main.c:800 ../vector/v.rectify/target.c:41
+msgid "permission denied"
msgstr ""
-#: ../raster/r.watershed/shed/file_in.c:15
-msgid "unable to open ARMSED file"
+#: ../imagery/i.rectify/target.c:33 ../raster/r.proj/main.c:287
+#: ../raster/r.in.gdal/main.c:801 ../vector/v.rectify/target.c:41
+#, fuzzy
+msgid "not found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:43
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
+#, fuzzy
+msgid "Could not open elevation raster"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
+#: ../imagery/i.rectify/report.c:10
+msgid "complete"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:23
-msgid ""
-"\n"
-"This set of questions will organize the command line for the"
+#: ../imagery/i.rectify/report.c:10 ../db/db.select/main.c:104
+msgid "failed"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:24
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
+#: ../imagery/i.rectify/report.c:20
#, c-format
-msgid "%s program to run properly for your application."
+msgid "%d rows, %d cols (%ld cells) completed in"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:26
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
+#: ../imagery/i.rectify/report.c:23
#, c-format
-msgid "The first question is whether you want %s to run"
+msgid "%d:%02d:%02ld hours"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:28
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:25
+#: ../imagery/i.rectify/report.c:25
#, c-format
-msgid "in its fast mode or its slow mode. If you run %s"
+msgid "%d:%02ld minutes"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:30
-msgid "in the fast mode, the computer will finish about 10 times faster"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
+#: ../imagery/i.rectify/report.c:27
+#, c-format
+msgid "%.1f cells per minute"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:31
-msgid "than in the slow mode, but will not allow other programs to run"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
+#: ../imagery/i.rectify/rectify.c:41
+#, fuzzy, c-format
+msgid "Rectify <%s@%s> (location <%s>)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:46
+#: ../imagery/i.rectify/rectify.c:44
+#, fuzzy, c-format
+msgid "into <%s@%s> (location <%s>) ..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:80
+#, c-format
+msgid "No elevation available at row = %d, col = %d"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:32
-msgid "at the same time. The fast mode also places all of the data into"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
+#: ../imagery/i.rectify/rectify.c:108
+#, fuzzy, c-format
+msgid "Raster map <%s@%s>: projection don't match current settings"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
+#: ../imagery/i.rectify/rectify.c:114
+#, fuzzy, c-format
+msgid "Raster map <%s@%s>: zone don't match current settings"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:89
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:389
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
+msgid "orthorectify"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:33
-msgid "RAM, which limits the size of window that can be run. The slow"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
+msgid ""
+"Orthorectifies an image by using the image to photo coordinate "
+"transformation matrix."
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:34
-msgid "mode uses disk space in the same hard disk partition as where GRASS is"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
+#: ../imagery/i.rectify/main.c:116
+#, fuzzy
+msgid "Output raster map(s) suffix"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:109
+#: ../imagery/i.rectify/main.c:130
+msgid "Target resolution (ignored if -c flag used)"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:35
-msgid "stored. Thus, if the program does not work in the slow mode, you will"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:117
+#: ../imagery/i.rectify/main.c:138
+msgid "Amount of memory to use in MB"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:36
-msgid "need to remove unnecessary files from that partition. The slow mode"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
+#: ../imagery/i.rectify/main.c:148 ../raster/r.proj/main.c:190
+msgid "Interpolation method to use"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:37
-#, c-format
-msgid "will allow other processes to run concurrently with %s.\n"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
+msgid "Raster map with camera angle relative to ground surface"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:69
-#: ../raster/r.watershed/shed/com_line.c:182
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
+#: ../imagery/i.rectify/main.c:153
msgid ""
-"\n"
-"If you hit <return> by itself for the next question, this"
+"Use current region settings in target location (def.=calculate smallest area)"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:70
-#: ../raster/r.watershed/shed/com_line.c:183
-msgid "program will terminate."
-msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
+#: ../imagery/i.rectify/main.c:157
+#, fuzzy
+msgid "Rectify all raster maps in group"
+msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/shed/com_line.c:81
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:152
+#: ../imagery/i.rectify/main.c:172 ../raster/r.statistics/main.c:117
+#: ../raster/r.proj/main.c:243 ../raster/r.stats.zonal/main.c:164
+#: ../vector/v.vect.stats/main.c:279
#, c-format
-msgid ""
-"\n"
-"One of the options for %s is a `depression map'. A"
+msgid "<%s=%s> unknown %s"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:83
-msgid ""
-"depression map indicates all the locations in the current map window where"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:180
+#: ../imagery/i.pca/main.c:151
+#, fuzzy, c-format
+msgid "Group <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
+#, fuzzy, c-format
+msgid "Could not read REF file for group <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:187
+#: ../imagery/i.rectify/main.c:212
+#, c-format
+msgid "Group <%s> contains no raster maps; run i.group"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:84
-msgid ""
-"water accumulates and does not leave by the edge of the map. Lakes without"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:241
+#, c-format
+msgid "No camera reference file selected for group <%s>"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:85
-msgid ""
-"outlet streams and sinkholes are examples of `depressions'. If you wish to"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
+#, fuzzy, c-format
+msgid "Bad format in camera file for group <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:251
+#, fuzzy, c-format
+msgid "Bad format in initial exposure station file for group <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:281
+#: ../imagery/i.rectify/main.c:287
+#, fuzzy, c-format
+msgid "Extension <%s> is illegal"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:284
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:293
+#: ../imagery/i.rectify/main.c:290
+#, fuzzy
+msgid "The following raster map already exists in"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:294
+#: ../imagery/i.rectify/main.c:291 ../vector/v.rectify/main.c:215
+#, c-format
+msgid "target LOCATION %s, MAPSET %s:"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:86
-msgid "have a depression map, prepare a map where non-zero values indicate the"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:288
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:297
+#: ../imagery/i.rectify/main.c:294
+msgid "Orthorectification cancelled."
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:87
-msgid "locations where depressions occur.\n"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:312
+#: ../imagery/i.rectify/main.c:309
+msgid "Target resolution must be > 0, ignored"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:88
-msgid ""
-"Hit <return> by itself for the next question if there is no depression map."
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:319
+#: ../imagery/i.rectify/main.c:320
+#, c-format
+msgid "Using region: N=%f S=%f, E=%f W=%f"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:99
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:327
#, c-format
-msgid ""
-"\n"
-"The %s program will divide the elevation map into a number of"
+msgid "No target elevation model selected for group <%s>"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:101
-msgid ""
-"watershed basins. The number of watershed basins is indirectly determined"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:386
+#: ../imagery/i.rectify/main.c:335
+#, fuzzy, c-format
+msgid "Input raster map <%s> does not exist in group <%s>."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:388
+#: ../imagery/i.rectify/main.c:337
+msgid "Try:"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:102
-msgid ""
-"by the `basin threshold' value. The basin threshold is the area necessary "
-"for"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:393
+#: ../imagery/i.rectify/main.c:342
+msgid "Exit!"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:103
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:13
#, c-format
-msgid "%s to define a unique watershed basin. This area only applies to"
+msgid ""
+"Control Z Point file for group [%s] in [%s] \n"
+" \n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:105
-msgid ""
-"`exterior drainage basins'. An exterior drainage basin does not have any"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:16
+#, fuzzy
+msgid "Computing equations..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
+msgid "Poorly placed Control Points!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:106
-msgid ""
-"drainage basins flowing into it. Interior drainage basin size is determined"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
+#, fuzzy
+msgid "Can not generate the transformation equation.\n"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:24
+msgid "Run OPTION 7 of i.ortho.photo again!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:107
-msgid ""
-"by the surface flow going into stream segments between stream interceptions."
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
+msgid "No active Control Points!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:108
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:29
+msgid "Run OPTION 7 of i.ortho.photo!\n"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
#, c-format
-msgid "Thus interior drainage basins can be of any size. The %s program"
+msgid ""
+"Reference Point file for group [%s] in [%s] \n"
+" \n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:110
-msgid "also allows the user to relate basin size to potential overland flow"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
+msgid "Poorly placed Reference Points!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:111
-msgid ""
-"(i.e., areas with low infiltration capacities will need smaller areas to"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
+msgid "Run OPTION 5 of i.ortho.photo again!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:112
-msgid ""
-"develop stream channels than neighboring areas with high infiltration rates)."
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
+msgid "No active Reference Points!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:113
-msgid ""
-"The user can create a map layer with potential overland flow values, and"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
+msgid "Run OPTION 5 of i.ortho.photo!\n"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:114
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
+#, fuzzy
+msgid "Calculating camera angle to local surface..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
+#: ../raster/r.slope.aspect/main.c:385
#, c-format
-msgid "%s will accumulate those values instead of area.\n"
+msgid "Converting units to meters, factor=%.6f"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:116
-msgid "What unit of measure will you use for the basin threshold:"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:62
+#: ../imagery/i.rectify/readcell.c:56 ../raster/r.proj/readcell.c:57
+#: ../raster/r.proj/readcell.c:127 ../raster/r.stats.zonal/main.c:481
+#: ../raster/r.stats.quantile/main.c:309
+#, fuzzy
+msgid "Unable to open temporary file"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:70
+#: ../imagery/i.rectify/readcell.c:62
+msgid "Allocating memory and reading input map..."
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:119
-msgid " 1) acres, 2) meters sq., 3) miles sq., 4) hectares,"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:98
+#: ../imagery/i.rectify/readcell.c:88 ../imagery/i.rectify/readcell.c:127
+#: ../raster/r.proj/readcell.c:90
+msgid "Error writing segment file"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:120
-msgid " 5) kilometers sq., 6) map cells, 7) overland flow units"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:128
+#: ../imagery/i.rectify/readcell.c:115 ../raster/r.proj/readcell.c:123
+msgid "Internal error: cache miss on fully-cached map"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:121
-#, c-format
-msgid "Choose 1-7 or 0 to exit this program: "
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:137
+#: ../imagery/i.rectify/readcell.c:124 ../raster/r.proj/readcell.c:136
+msgid "Error seeking on segment file"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:131
-msgid ""
-"\n"
-"How large an area (or how many overland flow units) must a drainage basin"
+#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:140
+#: ../raster/r.proj/readcell.c:139
+#, fuzzy
+msgid "Error reading segment file"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:66
+msgid "Select or modify the target elevation model."
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:132
-#, c-format
-msgid "be for it to be an exterior drainage basin: "
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:70
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
+#, fuzzy
+msgid "Name of imagery group for ortho-rectification"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:75
+#, fuzzy
+msgid "Name of elevation map to use for ortho-rectification"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
+msgid "List available raster maps in target mapset and exit"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:201
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
+#, fuzzy
+msgid "Print currently selected elevation map and exit"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:108
#, c-format
-msgid ""
-"\n"
-"%s must create a map layer of watershed basins"
+msgid "Please select a target for group [%s] first"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:203
-#: ../raster/r.watershed/shed/com_line.c:224
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:114
+#, fuzzy, c-format
+msgid "Target location [%s] not found\n"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:147
#, c-format
-msgid "before %s can run properly."
+msgid "Elevation map name is missing. Please set '%s' option"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:222
-#, c-format
-msgid ""
-"\n"
-"%s must create a file of watershed basin relationships"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:162
+#, fuzzy, c-format
+msgid "Elevation for group <%s> is already set to <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
+#, fuzzy, c-format
+msgid "Mapset [%s] in target location [%s] - %s "
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
+#, fuzzy
+msgid "permission denied\n"
+msgstr "출력할 래스터맵"
+#, fuzzy
+msgid "not found\n"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
+msgid "Select and modify the imagery group camera reference file."
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:228
-#: ../raster/r.watershed/shed/com_line.c:263
-#, c-format
-msgid ""
-"\n"
-"Please name this file:"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
+#, fuzzy
+msgid "Name of camera reference file"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
+msgid "Camera name"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:231
-#: ../raster/r.watershed/shed/com_line.c:266 ../general/g.rename/main.c:79
-#: ../general/g.copy/main.c:80
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:114
-#: ../imagery/i.landsat.acca/main.c:189 ../imagery/i.landsat.toar/main.c:561
-#, c-format
-msgid "<%s> is an illegal file name"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
+msgid "Camera id"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:257
-#, c-format
-msgid ""
-"\n"
-"%s will generate a lot of output. Indicate a file"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
+msgid "Calibrated focal length"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:259
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
+#, fuzzy
+msgid "Principal point coordinates"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
+#, fuzzy
+msgid "Fiducial coordinates"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
+#, fuzzy, c-format
+msgid "Can not read camera file '%s'"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
#, c-format
-msgid "name for %s to send the output to."
+msgid "Replacing camera name '%s' with '%s'"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:277
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:138
#, c-format
-msgid ""
-"\n"
-"The accumulation map from %s must be present for"
+msgid "Replacing camera cam_id '%s' with '%s'"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:279
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:146
#, c-format
-msgid "%s to work properly."
+msgid "Replacing calibrated focal length '%g' with '%g'"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:290
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
#, c-format
msgid ""
-"\n"
-"%s can produce several maps not necessary for"
+"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:292
-#, c-format
-msgid "%s to function (stream channels, overland flow aspect, and"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
+msgid "Please provide a camera name for a new camera definition"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:294
-#, c-format
-msgid "a display version of the accumulation map). %s also has the"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:168
+msgid "Please provide a camera ID for a new camera definition"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:296
-msgid ""
-"ability to generate several variables in the Revised Universal Soil Loss"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:172
+msgid "Please provide calibrated focal length for a new camera definition"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:297
-msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:176
+msgid "Using default coordinates 0.0, 0.0 for the principal point"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:348
-msgid ""
-"\n"
-"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
+msgid "Too many fiducials!"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:349
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
+#, fuzzy, c-format
+msgid "No group '%s' in current mapset"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
#, c-format
-msgid "disturbed land. %s reflects this with an optional map layer or value"
+msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:351
-msgid ""
-"where the value indicates the percent of disturbed (barren) land in that "
-"cell."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
+#: ../misc/m.transform/main.c:96
+#, fuzzy, c-format
+msgid "Error conducting transform (%d)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
+msgid "Poorly placed image to photo control points"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:352
-msgid "Type <return> if you do not have a disturbed land map layer."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
+msgid "Poorly placed image to target control points"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:364
-msgid ""
-"\n"
-"Type the value indicating the percent of disturbed land. This value will"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
+#: ../misc/m.transform/main.c:196
+msgid "Insufficient memory"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:365
-msgid "be used for every cell in the current region."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
+#: ../misc/m.transform/main.c:198
+msgid "Parameter error"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:368
-#, c-format
-msgid ""
-"\n"
-"Input value here [0-100]: "
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
+#: ../misc/m.transform/main.c:200
+msgid "No active control points"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:379
-msgid ""
-"\n"
-"Overland surface flow only occurs for a set distance before swales form."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
+#: ../misc/m.transform/main.c:295
+#, fuzzy, c-format
+msgid "Invalid coordinates: [%s]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
+#: ../imagery/i.fft/main.c:79 ../imagery/i.pca/main.c:73
+#: ../imagery/i.ifft/main.c:78 ../misc/m.transform/main.c:317
+#: ../raster/r.proj/main.c:146 ../vector/v.proj/main.c:68
+#: ../vector/v.transform/main.c:71
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
+#, fuzzy
+msgid "transformation"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
+msgid "GCP"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:380
-#, c-format
-msgid "Because of digital terrain model limitations, %s cannot pick up"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
+#: ../misc/m.transform/main.c:320
+msgid "Computes a coordinate transformation based on the control points."
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:382
-#, c-format
-msgid "these swales. %s allows for an input (warning: kludge factor)"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
+#: ../misc/m.transform/main.c:340
+#, fuzzy
+msgid "point index"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
+#: ../misc/m.transform/main.c:341
+#, fuzzy
+msgid "source coordinates"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
+#: ../misc/m.transform/main.c:342
+#, fuzzy
+msgid "destination coordinates"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
+#: ../misc/m.transform/main.c:343
+msgid "forward coordinates (destination)"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:384
-msgid ""
-"that prevents the surface flow distance from getting too long. Normally,"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
+#: ../misc/m.transform/main.c:344
+#, fuzzy
+msgid "reverse coordinates (source)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
+#: ../misc/m.transform/main.c:345
+msgid "forward coordinates difference (destination)"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:385
-msgid "maximum slope length is around 600 feet (about 183 meters)."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
+#: ../misc/m.transform/main.c:346
+msgid "reverse coordinates difference (source)"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:400
-msgid ""
-"\n"
-"Roads, ditches, changes in ground cover, and other factors will stop"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
+#: ../misc/m.transform/main.c:347
+#, fuzzy
+msgid "forward error (destination)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
+#: ../misc/m.transform/main.c:348
+msgid "reverse error (source)"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:401
-msgid ""
-"slope length. You may input a raster map indicating the locations of these"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
+#: ../misc/m.transform/main.c:351 ../vector/v.out.ascii/args.c:55
+msgid "Output format"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:402
-msgid "blocking factors.\n"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
+#: ../misc/m.transform/main.c:355
+msgid "Display summary information"
msgstr ""
-#: ../raster/r.watershed/shed/com_line.c:403
-msgid ""
-"Hit <return> by itself for the next question if there is no blocking map."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
+#: ../misc/m.transform/main.c:361
+#, fuzzy
+msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
+#: ../misc/m.transform/main.c:362
+msgid "Local x,y coordinates to target east,north"
msgstr ""
-#: ../raster/r.watershed/front/main.c:74 ../raster/r.water.outlet/main.c:69
-#: ../raster/r.basins.fill/main.c:56
-msgid "watershed"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
+#: ../misc/m.transform/main.c:366
+msgid "Reverse transform of coords file or coeff. dump"
msgstr ""
-#: ../raster/r.watershed/front/main.c:75
-msgid "Calculates hydrological parameters and RUSLE factors."
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
+#: ../misc/m.transform/main.c:367
+msgid "Target east,north coordinates to local x,y"
msgstr ""
-#: ../raster/r.watershed/front/main.c:78 ../raster/r.watershed/front/main.c:85
-#: ../raster/r.watershed/front/main.c:91 ../raster/r.watershed/front/main.c:98
-#: ../raster/r.watershed/front/main.c:107
-#: ../raster/r.watershed/front/main.c:115
-#: ../raster/r.watershed/front/main.c:124
-msgid "Inputs"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
+#: ../misc/m.transform/main.c:371
+msgid "Display transform matrix coefficients"
msgstr ""
-#: ../raster/r.watershed/front/main.c:82
-#, fuzzy
-msgid "Name of input depressions raster map"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
+#, fuzzy, c-format
+msgid "Can not read reference points for group <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:83
-msgid "All non-NULL and non-zero cells are considered as real depressions"
+#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
+#, fuzzy, c-format
+msgid "Can not read control points for group <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
+msgid ""
+"Interactively creates or modifies entries in a camera initial exposure "
+"station file for imagery group referenced by a sub-block."
msgstr ""
-#: ../raster/r.watershed/front/main.c:89
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
#, fuzzy
-msgid "Name of input raster representing amount of overland flow per cell"
+msgid "Initial Camera Exposure X-coordinate"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:95
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
#, fuzzy
-msgid "Name of input raster map percent of disturbed land"
+msgid "Initial Camera Exposure Y-coordinate"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:96
-#: ../raster/r.watershed/front/main.c:121
-msgid "For USLE"
-msgstr ""
-#: ../raster/r.watershed/front/main.c:103
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
#, fuzzy
-msgid "Name of input raster map blocking overland surface flow"
+msgid "Initial Camera Exposure Z-coordinate"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:105
-msgid ""
-"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
+msgid "X-coordinate standard deviation"
msgstr ""
-#: ../raster/r.watershed/front/main.c:112
-msgid "Minimum size of exterior watershed basin"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
+msgid "Y-coordinate standard deviation"
msgstr ""
-#: ../raster/r.watershed/front/main.c:120
-msgid "Maximum length of surface flow in map units"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
+msgid "Z-coordinate standard deviation"
msgstr ""
-#: ../raster/r.watershed/front/main.c:129
-#, fuzzy
-msgid "Name for output accumulation raster map"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
+msgid "Initial Camera Omega (roll) degrees"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:131
-#, fuzzy
-msgid "Number of cells that drain through each cell"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:97
+msgid "Initial Camera Phi (pitch) degrees"
+msgstr ""
-#: ../raster/r.watershed/front/main.c:133
-#: ../raster/r.watershed/front/main.c:140
-#: ../raster/r.watershed/front/main.c:146
-#: ../raster/r.watershed/front/main.c:154
-#: ../raster/r.watershed/front/main.c:160
-#: ../raster/r.watershed/front/main.c:168
-#: ../raster/r.watershed/front/main.c:176
-#: ../raster/r.watershed/front/main.c:183 ../raster/r.slope.aspect/main.c:163
-#: ../raster/r.slope.aspect/main.c:169 ../raster/r.slope.aspect/main.c:194
-#: ../raster/r.slope.aspect/main.c:201 ../raster/r.slope.aspect/main.c:208
-#: ../raster/r.slope.aspect/main.c:215 ../raster/r.slope.aspect/main.c:222
-#: ../raster/r.slope.aspect/main.c:229 ../raster/r.slope.aspect/main.c:236
-#: ../vector/v.surf.rst/main.c:167 ../vector/v.surf.rst/main.c:191
-#: ../vector/v.surf.rst/main.c:197 ../vector/v.surf.rst/main.c:203
-#: ../vector/v.surf.rst/main.c:209 ../vector/v.surf.rst/main.c:215
-#: ../vector/v.surf.rst/main.c:221 ../vector/v.surf.rst/main.c:227
-#: ../vector/v.surf.rst/main.c:234 ../vector/v.surf.rst/main.c:241
-#: ../vector/v.surf.rst/main.c:248 ../vector/v.vol.rst/main.c:294
-#: ../vector/v.vol.rst/main.c:300 ../vector/v.vol.rst/main.c:363
-#: ../vector/v.vol.rst/main.c:369 ../vector/v.vol.rst/main.c:375
-#: ../vector/v.vol.rst/main.c:382 ../vector/v.vol.rst/main.c:388
-#: ../vector/v.vol.rst/main.c:394 ../vector/v.vol.rst/main.c:400
-#: ../vector/v.vol.rst/main.c:406
-msgid "Outputs"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:102
+msgid "Initial Camera Kappa (yaw) degrees"
msgstr ""
-#: ../raster/r.watershed/front/main.c:138
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
+msgid "Omega (roll) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
+msgid "Phi (pitch) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
+msgid "Kappa (yaw) standard deviation"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
+msgid "Use initial values at run time"
+msgstr ""
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
#, fuzzy
-msgid "Topographic index ln(a / tan(b))"
+msgid "Print initial values"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:144
-#, fuzzy
-msgid "Name for output drainage direction raster map"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
+#, fuzzy, c-format
+msgid "Group [%s] not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:151
-#, fuzzy
-msgid "Name for basins raster map"
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:158
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:162
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:166
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:170
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:174
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:178
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:182
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
+#: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
+#, fuzzy, c-format
+msgid "Option '%s' is required for new exposure info"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:152
-msgid "Unique label for each watershed basin"
+#: ../imagery/i.landsat.toar/landsat_met.c:117
+#, fuzzy, c-format
+msgid "Metadata file <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.toar/main.c:69
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
msgstr ""
-#: ../raster/r.watershed/front/main.c:158
+#: ../imagery/i.landsat.toar/main.c:71 ../imagery/i.aster.toar/main.c:98
+msgid "radiometric conversion"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:72 ../imagery/i.landsat.toar/main.c:575
+#: ../imagery/i.aster.toar/main.c:100
#, fuzzy
-msgid "Name for output stream segments raster map"
+msgid "radiance"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:164
+#: ../imagery/i.landsat.toar/main.c:73 ../imagery/i.landsat.toar/main.c:577
+#: ../imagery/i.modis.qc/main.c:120 ../imagery/i.aster.toar/main.c:101
+#: ../imagery/i.albedo/main.c:90
#, fuzzy
-msgid "Name for output half basins raster map"
+msgid "reflectance"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:166
-msgid "Each half-basin is given a unique value"
+#: ../imagery/i.landsat.toar/main.c:74 ../imagery/i.aster.toar/main.c:102
+msgid "brightness temperature"
msgstr ""
-#: ../raster/r.watershed/front/main.c:172
+#: ../imagery/i.landsat.toar/main.c:75 ../imagery/i.landsat.acca/main.c:106
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
+msgid "Landsat"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:76
+msgid "atmospheric correction"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:82 ../imagery/i.landsat.acca/main.c:111
#, fuzzy
-msgid "Name for output slope length raster map"
+msgid "Base name of input raster bands"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:174
-msgid "Slope length and steepness (LS) factor for USLE"
+#: ../imagery/i.landsat.toar/main.c:83 ../imagery/i.landsat.acca/main.c:112
+msgid "Example: 'B.' for B.1, B.2, ..."
msgstr ""
-#: ../raster/r.watershed/front/main.c:180
+#: ../imagery/i.landsat.toar/main.c:89 ../imagery/i.pca/main.c:84
+#: ../locale/scriptstrings/i.tasscap_to_translate.c:15
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
#, fuzzy
-msgid "Name for output slope steepness raster map"
+msgid "Prefix for output raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.watershed/front/main.c:181
-msgid "Slope steepness (S) factor for USLE"
+#: ../imagery/i.landsat.toar/main.c:91
+msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
msgstr ""
-#: ../raster/r.watershed/front/main.c:190
-msgid "Convergence factor for MFD (1-10)"
+#: ../imagery/i.landsat.toar/main.c:98
+msgid "Name of Landsat metadata file (.met or MTL.txt)"
msgstr ""
-#: ../raster/r.watershed/front/main.c:192
-msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
+#: ../imagery/i.landsat.toar/main.c:99 ../imagery/i.landsat.toar/main.c:121
+#: ../imagery/i.landsat.toar/main.c:131 ../imagery/i.landsat.toar/main.c:140
+#: ../imagery/i.landsat.toar/main.c:148 ../imagery/i.landsat.toar/main.c:157
+#: ../raster/r.in.gdal/main.c:121 ../raster/r.in.gdal/main.c:129
+#: ../raster/r.external/main.c:89
+msgid "Metadata"
msgstr ""
-#: ../raster/r.watershed/front/main.c:199
-msgid "Maximum memory to be used with -m flag (in MB)"
+#: ../imagery/i.landsat.toar/main.c:104
+msgid "Spacecraft sensor"
msgstr ""
-#: ../raster/r.watershed/front/main.c:203
-msgid "SFD (D8) flow (default is MFD)"
+#: ../imagery/i.landsat.toar/main.c:105
+msgid "Required only if 'metfile' not given (recommended for sanity)"
msgstr ""
-#: ../raster/r.watershed/front/main.c:205
-msgid "SFD: single flow direction, MFD: multiple flow direction"
+#: ../imagery/i.landsat.toar/main.c:110
+msgid "Landsat-1 MSS"
msgstr ""
-#: ../raster/r.watershed/front/main.c:210
-msgid "Allow only horizontal and vertical flow of water"
+#: ../imagery/i.landsat.toar/main.c:111
+msgid "Landsat-2 MSS"
msgstr ""
-#: ../raster/r.watershed/front/main.c:215
-msgid "Enable disk swap memory option: Operation is slow"
+#: ../imagery/i.landsat.toar/main.c:112
+msgid "Landsat-3 MSS"
msgstr ""
-#: ../raster/r.watershed/front/main.c:217
-msgid ""
-"Only needed if memory requirements exceed available RAM; see manual on how "
-"to calculate memory requirements"
+#: ../imagery/i.landsat.toar/main.c:113
+msgid "Landsat-4 MSS"
msgstr ""
-#: ../raster/r.watershed/front/main.c:222
-msgid "Use positive flow accumulation even for likely underestimates"
+#: ../imagery/i.landsat.toar/main.c:114
+msgid "Landsat-5 MSS"
msgstr ""
-#: ../raster/r.watershed/front/main.c:224
-msgid "See manual for a detailed description of flow accumulation output"
+#: ../imagery/i.landsat.toar/main.c:115
+msgid "Landsat-4 TM"
msgstr ""
-#: ../raster/r.watershed/front/main.c:229
-msgid "Beautify flat areas"
+#: ../imagery/i.landsat.toar/main.c:116
+msgid "Landsat-5 TM"
msgstr ""
-#: ../raster/r.watershed/front/main.c:231
-msgid "Flow direction in flat areas is modified to look prettier"
+#: ../imagery/i.landsat.toar/main.c:117
+msgid "Landsat-7 ETM+"
msgstr ""
-#: ../raster/r.watershed/front/main.c:247
-msgid "Sorry, you must choose an output map."
+#: ../imagery/i.landsat.toar/main.c:118
+msgid "Landsat_8 OLI/TIRS"
msgstr ""
-#: ../raster/r.watershed/front/main.c:253
-msgid "The basin threshold must be a positive number."
+#: ../imagery/i.landsat.toar/main.c:128 ../imagery/i.landsat.toar/main.c:129
+msgid "Atmospheric correction method"
msgstr ""
-#: ../raster/r.watershed/front/main.c:269
-msgid ""
-"Sorry, if any of the following options are set:\n"
-" basin, stream, half_basin, length_slope, or slope_steepness\n"
-" you MUST provide a value for the basin threshold parameter."
+#: ../imagery/i.landsat.toar/main.c:138
+msgid "Image acquisition date (yyyy-mm-dd)"
msgstr ""
-#: ../raster/r.watershed/front/main.c:296
-msgid "Beautify flat areas is not yet supported for disk swap mode"
+#: ../imagery/i.landsat.toar/main.c:139 ../imagery/i.landsat.toar/main.c:147
+#: ../imagery/i.landsat.toar/main.c:156 ../imagery/i.landsat.toar/main.c:164
+msgid "Required only if 'metfile' not given"
msgstr ""
-#: ../raster/r.watershed/front/main.c:323
-#, c-format
-msgid "Subprocess failed with exit code %d"
-msgstr ""
-#: ../raster/r.composite/main.c:73
-#: ../locale/scriptstrings/r.blend_to_translate.c:3
+#: ../imagery/i.landsat.toar/main.c:146
#, fuzzy
-msgid "composite"
+msgid "Sun elevation in degrees"
msgstr "출력할 래스터맵"
-#: ../raster/r.composite/main.c:76
-msgid ""
-"Combines red, green and blue raster maps into a single composite raster map."
+#: ../imagery/i.landsat.toar/main.c:155
+msgid "Image creation date (yyyy-mm-dd)"
msgstr ""
-#: ../raster/r.composite/main.c:90 ../raster/r.out.ppm3/main.c:63
-#, c-format
-msgid "Name of raster map to be used for <%s>"
+#: ../imagery/i.landsat.toar/main.c:163
+msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
msgstr ""
-#: ../raster/r.composite/main.c:102
-msgid "Number of levels to be used for each component"
+#: ../imagery/i.landsat.toar/main.c:171
+msgid "Percent of solar radiance in path radiance"
msgstr ""
-#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
-msgid "Levels"
+#: ../imagery/i.landsat.toar/main.c:172 ../imagery/i.landsat.toar/main.c:182
+msgid "Required only if 'method' is any DOS"
msgstr ""
-#: ../raster/r.composite/main.c:118
-#, c-format
-msgid "Number of levels to be used for <%s>"
+#: ../imagery/i.landsat.toar/main.c:181
+msgid "Minimum pixels to consider digital number as dark object"
msgstr ""
-#: ../raster/r.composite/main.c:128
-msgid "Dither"
+#: ../imagery/i.landsat.toar/main.c:190
+msgid "Rayleigh atmosphere (diffuse sky irradiance)"
msgstr ""
-#: ../raster/r.composite/main.c:132
-msgid "Use closest color"
+#: ../imagery/i.landsat.toar/main.c:191
+msgid "Required only if 'method' is DOS3"
msgstr ""
-#: ../raster/r.composite/main.c:164
-#, fuzzy, c-format
-msgid "Unable to read color file of raster map <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.toar/main.c:200
+msgid "return value stored for a given metadata"
+msgstr ""
-#: ../raster/r.composite/main.c:262 ../raster/r.in.gdal/main.c:1329
-#: ../raster/r.circle/main.c:154 ../raster/r.li/r.li.daemon/daemon.c:178
-#: ../raster/r.surf.fractal/main.c:85
-#, fuzzy, c-format
-msgid "Raster map <%s> created."
+#: ../imagery/i.landsat.toar/main.c:201
+msgid "Required only if 'metfile' and -p given"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:207
+msgid "Landsat Number"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:208
+#, fuzzy
+msgid "Creation timestamp"
msgstr "출력할 래스터맵"
-#: ../raster/r.composite/main.c:286
+#: ../imagery/i.landsat.toar/main.c:209
+msgid "Date"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:210
#, fuzzy
-msgid "Creating color table for output raster map..."
+msgid "Sun Elevation"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:104
+#: ../imagery/i.landsat.toar/main.c:211
+msgid "Sensor"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:212
+msgid "Bands count"
+msgstr ""
+msgid "Sun Zenith Angle"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:212 ../raster/r.sunmask/main.c:152
+#: ../raster/r.sunmask/main.c:160 ../raster/r.sunmask/main.c:168
+#: ../raster/r.sunmask/main.c:176 ../raster/r.sunmask/main.c:184
+#: ../raster/r.sunmask/main.c:193 ../raster/r.sunmask/main.c:202
+#: ../raster/r.sunhours/main.c:100 ../raster/r.sunhours/main.c:109
+#: ../raster/r.sunhours/main.c:117 ../raster/r.sunhours/main.c:126
+#: ../raster/r.sunhours/main.c:135 ../raster/r.sunhours/main.c:144
+msgid "Time"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:220
+msgid "Output at-sensor radiance instead of reflectance for all bands"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:225
msgid ""
-"Calculates category or object oriented statistics (accumulator-based "
-"statistics)."
+"Input raster maps use as extension the number of the band instead the code"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:114 ../raster/r.statistics/main.c:68
-msgid "Method of object-based statistic"
+#: ../imagery/i.landsat.toar/main.c:229
+msgid "Print output metadata info"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:137 ../raster/r.statistics/main.c:91
-#, fuzzy
-msgid "Resultant raster map"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.toar/main.c:255 ../imagery/i.landsat.toar/main.c:263
+#, c-format
+msgid "Illegal date format: [%s] (yyyy-mm-dd)"
+msgstr ""
-#: ../raster/r.stats.zonal/main.c:143 ../raster/r.statistics/main.c:97
-msgid "Cover values extracted from the category labels of the cover map"
+#: ../imagery/i.landsat.toar/main.c:284
+msgid "Please use a metadata keyword with -p"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:148 ../raster/r.stats.quantile/main.c:425
-msgid "Create reclass map with statistics as category labels"
+#: ../imagery/i.landsat.toar/main.c:321
+msgid "Failed to identify satellite"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:164 ../raster/r.statistics/main.c:117
-#: ../raster/r.proj/main.c:243
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:152
-#: ../imagery/i.rectify/main.c:172 ../vector/v.vect.stats/main.c:277
+#: ../imagery/i.landsat.toar/main.c:335
#, c-format
-msgid "<%s=%s> unknown %s"
+msgid "Lacking '%s' and/or '%s' for this satellite"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:177
+#: ../imagery/i.landsat.toar/main.c:341
+msgid "Landsat-7 requires band gain with 9 (H/L) characters"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:361
+#, c-format
+msgid "Unknown satellite type (defined by '%s')"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:404 ../imagery/i.landsat.toar/main.c:542
+#: ../imagery/i.landsat.acca/algorithm.c:380
+#: ../imagery/i.landsat.acca/main.c:57 ../imagery/i.landsat.acca/tools.c:126
+#: ../raster/r.mapcalc/map3.c:515 ../raster/r.random/random.c:43
+#: ../raster/r.random/random.c:47 ../raster/r.le/r.le.trace/main.c:551
+#, c-format
+msgid "Unable to open raster map <%s>"
+msgstr ""
+#: ../imagery/i.landsat.toar/main.c:408 ../imagery/i.landsat.toar/main.c:557
#, fuzzy, c-format
-msgid "Unable to read category file of cover map <%s>"
+msgid "Unable to read data type of raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:180 ../raster/r.stats.quantile/main.c:478
+#: ../imagery/i.landsat.toar/main.c:532 ../raster/r.flow/main.c:316
+#: ../raster/r.topidx/new/topidx.c:41 ../raster/r.topidx/topidx.c:41
+#: ../raster/r.topidx/old/topidx.c:41
#, fuzzy
-msgid "The base map must be an integer (CELL) map"
+msgid "Calculating..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:183 ../raster/r.stats.quantile/main.c:481
+#: ../imagery/i.landsat.toar/main.c:546 ../raster/r.in.gdal/main.c:241
+#: ../vector/v.kernel/main.c:233
#, fuzzy, c-format
-msgid "Unable to read range of base map <%s>"
+msgid "Raster map <%s> already exists and will be overwritten"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:247
-msgid "First pass"
-msgstr ""
+#: ../imagery/i.landsat.toar/main.c:550
+#, fuzzy, c-format
+msgid "Raster map <%s> exists. Skipping."
+msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:326
-msgid "Second pass"
+#: ../imagery/i.landsat.toar/main.c:564
+#: ../imagery/i.landsat.acca/algorithm.c:234
+#: ../imagery/i.landsat.acca/algorithm.c:388
+#: ../imagery/i.landsat.acca/tools.c:136 ../raster/r.mapcalc/map3.c:594
+#: ../raster/r.sunhours/main.c:321 ../raster/r.sunhours/main.c:332
+#: ../raster/r.sunhours/main.c:343
+#, c-format
+msgid "Unable to create raster map <%s>"
msgstr ""
-#: ../raster/r.stats.zonal/main.c:473
-#, fuzzy
-msgid "Generating reclass map"
+#: ../imagery/i.landsat.toar/main.c:573
+#, fuzzy, c-format
+msgid "Writing %s of <%s> to <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:481 ../raster/r.stats.quantile/main.c:309
-#: ../raster/r.proj/readcell.c:57 ../raster/r.proj/readcell.c:128
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:62
-#: ../imagery/i.rectify/readcell.c:56
+#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
+msgid "Unable to allocate space for signature statistics."
+msgstr ""
+#: ../imagery/i.class/signature.c:82
+msgid "prepare_signature: outline has odd number of points."
+msgstr ""
+#: ../imagery/i.class/signature.c:113
+#, c-format
+msgid "prepare_signature: scan line %d has odd number of points."
+msgstr ""
+#: ../imagery/i.class/signature.c:123
+msgid "signature: perimeter points out of order."
+msgstr ""
+#: ../imagery/i.class/signature.c:132
+msgid "prepare_signature: data error."
+msgstr ""
+#: ../imagery/i.class/signature.c:234
+msgid "Unknown Menu selection in show_signature()."
+msgstr ""
+#: ../imagery/i.class/save_reg.c:14
+msgid "Region is not complete, can not save."
+msgstr ""
+#: ../imagery/i.class/remove_mask.c:15
+msgid "Error while removing the old MASK cell map."
+msgstr ""
+#: ../imagery/i.class/outline.c:57
+msgid "Absurd polygon."
+msgstr ""
+#: ../imagery/i.class/outline.c:99
+msgid "Outlined area is too large."
+msgstr ""
+#: ../imagery/i.class/curses.c:22
+#, c-format
+msgid "make_window(%d,%d,%d,%d): illegal screen values."
+msgstr ""
+#: ../imagery/i.class/curses.c:153
+#, c-format
+msgid "%s"
+msgstr ""
+#: ../imagery/i.class/complete_reg.c:12
+msgid "Too few points for region. Must have at least 3 points."
+msgstr ""
+#: ../imagery/i.class/complete_reg.c:14
+msgid "Area already completed."
+msgstr ""
+#: ../imagery/i.class/analyze_sig.c:12
+msgid "Cannot analyze until region is completed."
+msgstr ""
+#: ../imagery/i.class/main.c:92 ../imagery/i.maxlik/main.c:62
+#: ../imagery/i.gensig/main.c:40 ../imagery/i.cluster/main.c:76
+#: ../imagery/i.smap/main.c:39 ../imagery/i.gensigset/main.c:41
+#: ../imagery/i.segment/main.c:37 ../raster/r.kappa/main.c:70
+#: ../vector/v.class/main.c:46
#, fuzzy
-msgid "Unable to open temporary file"
+msgid "classification"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.zonal/main.c:495
+#: ../imagery/i.class/main.c:93 ../imagery/i.gensig/main.c:44
+#: ../imagery/i.cluster/main.c:77 ../imagery/i.gensigset/main.c:44
#, fuzzy
-msgid "Writing output map"
+msgid "signatures"
msgstr "출력할 래스터맵"
-#: ../raster/r.category/cats.c:47
-#, fuzzy, c-format
-msgid "Reading <%s> in <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:94 ../imagery/i.maxlik/main.c:63
+#: ../imagery/i.gensig/main.c:42
+msgid "Maximum Likelihood Classification"
+msgstr ""
-#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
-#, fuzzy
-msgid "category"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:96
+msgid ""
+"Generates spectral signatures for an image by allowing the user to outline "
+"regions of interest."
+msgstr ""
-#: ../raster/r.category/main.c:55
+#: ../imagery/i.class/main.c:99
msgid ""
-"Manages category values and labels associated with user-specified raster map "
-"layers."
+"The resulting signature file can be used as input for i.maxlik or as a seed "
+"signature file for i.cluster."
msgstr ""
-#: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
-#: ../locale/scriptstrings/v.report_to_translate.c:5
-#: ../locale/scriptstrings/t.list_to_translate.c:6
-#: ../locale/scriptstrings/t.list_to_translate.c:7
-#: ../locale/scriptstrings/t.list_to_translate.c:13
-#: ../locale/scriptstrings/t.list_to_translate.c:14
-#: ../display/d.thematic.area/main.c:135 ../display/d.thematic.area/main.c:138
-#: ../display/d.vect/main.c:80 ../display/d.vect/main.c:105
-#: ../display/d.vect/main.c:108 ../display/d.vect/main.c:111
-#: ../display/d.vect/main.c:307 ../display/d.vect.chart/main.c:74
-#: ../display/d.vect.chart/main.c:77 ../display/d.rast/main.c:70
-#: ../display/d.rast/main.c:87 ../vector/v.extrude/main.c:84
-#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
-#: ../vector/v.extrude/main.c:95 ../vector/v.surf.rst/main.c:173
-#: ../vector/v.surf.rst/main.c:185 ../vector/v.category/main.c:85
-#: ../vector/v.category/main.c:89 ../vector/v.category/main.c:93
-#: ../vector/v.out.ogr/args.c:12 ../vector/v.out.ogr/args.c:22
-#: ../vector/v.out.ogr/args.c:103 ../vector/v.out.ascii/args.c:24
-#: ../vector/v.out.ascii/args.c:28 ../vector/v.out.ascii/args.c:43
-#: ../vector/v.out.ascii/args.c:46 ../vector/v.to.points/main.c:67
-#: ../vector/v.to.points/main.c:71 ../vector/v.clean/main.c:60
-#: ../vector/v.clean/main.c:63 ../vector/v.db.select/main.c:60
-#: ../vector/v.db.select/main.c:63 ../vector/v.db.select/main.c:66
-#: ../vector/v.net.allpairs/main.c:75 ../vector/v.net.allpairs/main.c:81
-#: ../vector/v.net.allpairs/main.c:84 ../vector/v.net.allpairs/main.c:87
-#: ../vector/v.drape/main.c:66 ../vector/v.drape/main.c:69
-#: ../vector/v.drape/main.c:72 ../vector/v.drape/main.c:77
-#: ../vector/v.buffer/main.c:231 ../vector/v.buffer/main.c:234
-#: ../vector/v.buffer/main.c:237 ../vector/v.buffer/main.c:242
-#: ../vector/v.extract/main.c:95 ../vector/v.extract/main.c:100
-#: ../vector/v.extract/main.c:106 ../vector/v.extract/main.c:109
-#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:122
-#: ../vector/v.extract/main.c:132 ../vector/v.to.db/parse.c:45
-#: ../vector/v.to.3d/args.c:19 ../vector/v.to.3d/args.c:25
-#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
-#: ../vector/v.edit/args.c:112 ../vector/v.edit/args.c:116
-#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:134
-#: ../vector/v.edit/args.c:143 ../vector/v.edit/args.c:146
-#: ../vector/v.edit/args.c:164 ../vector/v.edit/args.c:199
-#: ../vector/v.in.db/main.c:94 ../vector/v.select/args.c:18
-#: ../vector/v.select/args.c:23 ../vector/v.select/args.c:32
-#: ../vector/v.select/args.c:37 ../vector/v.select/args.c:104
-#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
-#: ../vector/v.to.rast/main.c:57 ../vector/v.to.rast/main.c:60
-#: ../vector/v.to.rast/main.c:63 ../vector/v.out.postgis/args.c:15
-#: ../vector/v.out.postgis/args.c:19 ../vector/v.in.ogr/main.c:151
-#: ../vector/v.in.ogr/main.c:164 ../vector/v.in.ogr/main.c:169
-#: ../vector/v.in.ogr/main.c:178 ../vector/v.in.ogr/main.c:194
-#: ../vector/v.in.ogr/main.c:265 ../vector/v.net.centrality/main.c:121
-#: ../vector/v.net.centrality/main.c:123 ../vector/v.generalize/main.c:92
-#: ../vector/v.generalize/main.c:224 ../vector/v.generalize/main.c:227
+#: ../imagery/i.class/main.c:103 ../display/d.rast/main.c:61
#, fuzzy
-msgid "Selection"
+msgid "Name of raster map to be displayed"
msgstr "출력할 래스터맵"
-#: ../raster/r.category/main.c:69
-msgid "Comma separated value list"
+#: ../imagery/i.class/main.c:113 ../imagery/i.cca/main.c:95
+msgid "Name of input imagery subgroup"
msgstr ""
-#: ../raster/r.category/main.c:70
-msgid "Example: 1.4,3.8,13"
+#: ../imagery/i.class/main.c:118
+msgid "File to contain result signatures"
msgstr ""
-#: ../raster/r.category/main.c:81 ../raster/r.category/main.c:88
-#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
-#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
-#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
-#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
-#: ../raster/r.colors/edit_colors.c:148
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
-#: ../vector/v.colors/main.c:81 ../vector/v.colors/main.c:92
-#: ../vector/v.colors/main.c:99 ../vector/v.colors/main.c:106
-#: ../vector/v.colors/main.c:113 ../vector/v.colors/main.c:139
-#: ../vector/v.colors/main.c:144 ../vector/v.colors/main.c:149
-msgid "Define"
+#: ../imagery/i.class/main.c:123
+msgid "File containing input signatures (seed)"
msgstr ""
-#: ../raster/r.category/main.c:87
-msgid "File containing category label rules (or \"-\" to read from stdin)"
+#: ../imagery/i.class/main.c:131 ../imagery/i.points/main.c:124
+#: ../vector/v.label/main.c:233 ../display/d.what.vect/main.c:145
+#: ../display/d.extract/main.c:79 ../display/d.measure/main.c:85
+#: ../display/d.what.rast/main.c:99 ../display/d.zoom/redraw.c:38
+#: ../display/d.zoom/main.c:218
+msgid "No graphics device selected"
msgstr ""
-#: ../raster/r.category/main.c:95
-msgid "Default label or format string for dynamic labeling"
+#: ../imagery/i.class/main.c:135
+msgid "You have a mask set. Unset mask and run again"
msgstr ""
-#: ../raster/r.category/main.c:97
-msgid "Used when no explicit label exists for the category"
+#: ../imagery/i.class/main.c:144 ../imagery/i.target/main.c:80
+#: ../imagery/i.group/main.c:117
+#, fuzzy
+msgid "Group must exist in the current mapset"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:253
+#, c-format
+msgid "** The following raster maps in subgroup [%s] do not exist:"
msgstr ""
-#: ../raster/r.category/main.c:105
-msgid "Dynamic label coefficients"
+#: ../imagery/i.class/main.c:262
+#, c-format
+msgid "Subgroup [%s] does not have any files"
msgstr ""
-#: ../raster/r.category/main.c:107
-msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+#: ../imagery/i.class/main.c:263 ../imagery/i.class/main.c:267
+msgid "The subgroup must have at least 2 files to run"
msgstr ""
-#: ../raster/r.category/main.c:148 ../raster/r.category/main.c:230
-#: ../raster/r.mapcalc/map.c:216 ../raster/r.mapcalc/map3.c:188
-#: ../raster/r.report/parse.c:306
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s@%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:266
+#, c-format
+msgid "Subgroup [%s] only has 1 file"
+msgstr ""
-#: ../raster/r.category/main.c:152
-#, fuzzy, c-format
-msgid "Category table for <%s> set from <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:275
+msgid ""
+"\n"
+"RESULT SIGNATURE"
+msgstr ""
-#: ../raster/r.category/main.c:173 ../raster/r.out.ppm3/main.c:128
-#: ../raster/r.out.arc/main.c:129 ../raster/r.out.ascii/main.c:165
-#: ../raster/r.horizon/main.c:367 ../raster/r.profile/main.c:154
-#: ../raster/r.in.lidar/main.c:284 ../raster/r.recode/main.c:89
-#: ../general/g.pnmcomp/main.c:242 ../general/g.pnmcomp/main.c:259
-#: ../misc/m.transform/main.c:276 ../misc/m.nviz.script/main.c:202
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:348
-#: ../vector/v.out.ascii/main.c:122 ../vector/v.net/main.c:98
-#: ../vector/v.out.vtk/main.c:176 ../vector/v.edit/main.c:78
-#, fuzzy, c-format
-msgid "Unable to open file <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:280
+#, c-format
+msgid "Unable to open output signature file '%s'"
+msgstr ""
-#: ../raster/r.category/main.c:211
-#, c-format
+#: ../imagery/i.class/main.c:287
msgid ""
-"Incorrect format of input rules. Check separators. Invalid line is:\n"
-"%s"
+"\n"
+"SEED SIGNATURES"
msgstr ""
-#: ../raster/r.category/main.c:267
-#, fuzzy, c-format
-msgid "Unable to read category file of raster map <%s> in <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.class/main.c:292
+#, c-format
+msgid "Unable to read signature file [%s]"
+msgstr ""
-#: ../raster/r.category/main.c:283
-msgid "The map is floating point! Ignoring cats list, using vals list"
+#: ../imagery/i.class/main.c:295
+#, c-format
+msgid "** Unable to read signature file [%s] **"
msgstr ""
-#: ../raster/r.category/main.c:300
-msgid "vals argument is required for floating point map!"
+#: ../imagery/i.class/main.c:302
+#, c-format
+msgid "%s has too many signatures"
msgstr ""
-#: ../raster/r.coin/main.c:69
+#: ../imagery/i.class/restore_reg.c:15
+msgid "No region is saved, can not restore."
+msgstr ""
+#: ../imagery/i.class/draw_reg.c:89
+#, c-format
msgid ""
-"Tabulates the mutual occurrence (coincidence) of categories for two raster "
-"map layers."
+"\n"
+"Orig:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
msgstr ""
-#: ../raster/r.coin/main.c:77
-msgid "Name of first raster map"
+#: ../imagery/i.class/draw_reg.c:97
+#, c-format
+msgid ""
+"\n"
+"New:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
msgstr ""
-#: ../raster/r.coin/main.c:84
-msgid "Name of second raster map"
+#: ../imagery/i.class/redisplay.c:56
+msgid "No zoom window is defined."
msgstr ""
-#: ../raster/r.coin/main.c:90
-msgid "Unit of measure"
+#: ../imagery/i.class/erase_reg.c:10
+msgid "Can not erase an undefined region."
msgstr ""
-#: ../raster/r.coin/main.c:92
-msgid ""
-"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
-"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
+#: ../imagery/i.class/add_point.c:22
+#, c-format
+msgid "Can't mark another point. Only %d points allowed. Sorry."
msgstr ""
-#: ../raster/r.coin/main.c:99
-msgid "Wide report, 132 columns (default: 80)"
+#: ../imagery/i.target/main.c:48
+msgid "Targets an imagery group to a GRASS location and mapset."
msgstr ""
-#: ../raster/r.coin/print_coin.c:44
-#, c-format
-msgid "Preparing report ..."
+#: ../imagery/i.target/main.c:57
+msgid "Name of imagery target location"
msgstr ""
-#: ../raster/r.coin/make_coin.c:48
-#, c-format
-msgid "Tabulating Coincidence between '%s' and '%s'"
+#: ../imagery/i.target/main.c:63
+msgid "Name of target mapset"
msgstr ""
-#: ../raster/r.coin/make_coin.c:61
-msgid "Unable to create any tempfiles"
+#: ../imagery/i.target/main.c:68
+msgid "Set current location and mapset as target for of imagery group"
msgstr ""
-#: ../raster/r.coin/make_coin.c:65
-msgid "Unable to run r.stats"
+#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
+#: ../imagery/i.target/main.c:116
+#, c-format
+msgid "Group <%s> targeted for location [%s], mapset [%s]"
msgstr ""
-#: ../raster/r.coin/make_coin.c:72
-msgid "Unexpected output from r.stats"
+#: ../imagery/i.target/main.c:93
+#, c-format
+msgid "Group <%s> has no target"
msgstr ""
-#: ../raster/r.coin/make_coin.c:84
-msgid "Unable to open tempfile"
+#: ../imagery/i.target/main.c:101
+msgid ""
+"Use either the Current Mapset and Location Flag (-c)\n"
+" OR\n"
+" manually enter the variables"
msgstr ""
-#: ../raster/r.tile/main.c:43
-#: ../locale/scriptstrings/r.tileset_to_translate.c:3
-#: ../raster3d/r3.retile/main.c:97
-#, fuzzy
-msgid "tiling"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:119
+msgid "imagery quality assessment"
+msgstr ""
-#: ../raster/r.tile/main.c:45
+#: ../imagery/i.modis.qc/main.c:121
#, fuzzy
-msgid "Splits a raster map into tiles."
+msgid "land surface temperature"
msgstr "출력할 래스터맵"
-#: ../raster/r.tile/main.c:54
+#: ../imagery/i.modis.qc/main.c:122
#, fuzzy
-msgid "Output base name"
+msgid "vegetation"
msgstr "출력할 래스터맵"
-#: ../raster/r.tile/main.c:61
-msgid "Width of tiles"
+#: ../imagery/i.modis.qc/main.c:123
+msgid "MODIS"
msgstr ""
-#: ../raster/r.tile/main.c:68
-msgid "Height of tiles"
+#: ../imagery/i.modis.qc/main.c:125
+msgid "Extracts quality control parameters from Modis QC layers."
msgstr ""
-#: ../raster/r.tile/main.c:75
+#: ../imagery/i.modis.qc/main.c:130
#, fuzzy
-msgid "Overlap of tiles"
+msgid "Name of input surface reflectance QC layer [bit array]"
msgstr "출력할 래스터맵"
-#: ../raster/r.tile/main.c:177
-#, fuzzy, c-format
-msgid "Unable to read cats for %s"
+#: ../imagery/i.modis.qc/main.c:135
+#, fuzzy
+msgid "Name for output QC type classification layer"
msgstr "출력할 래스터맵"
-#: ../raster/r.tile/main.c:192 ../raster/r.resamp.stats/main.c:370
-#: ../raster/r.resamp.interp/main.c:353 ../raster/r.resamp.filter/main.c:552
-#, c-format
-msgid "Unable to read color table for %s"
+#: ../imagery/i.modis.qc/main.c:141
+msgid "Name of MODIS product type"
msgstr ""
-#: ../raster/r.in.xyz/main.c:161 ../raster/r.in.ascii/main.c:71
-#: ../raster/r.to.vect/main.c:71 ../raster/r.to.rast3/main.c:198
-#: ../raster/r.to.rast3elev/main.c:362
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
-#: ../raster3d/r3.in.ascii/main.c:319 ../raster3d/r3.out.ascii/main.c:308
-#: ../raster3d/r3.to.rast/main.c:207 ../vector/v.convert/main.c:38
-#: ../vector/v.to.rast3/main.c:49 ../vector/v.to.rast/main.c:45
-msgid "conversion"
+#: ../imagery/i.modis.qc/main.c:152
+msgid "surf. refl. 250m 8-days"
msgstr ""
-#: ../raster/r.in.xyz/main.c:163 ../raster/r.in.lidar/main.c:163
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
-#: ../vector/v.lidar.growing/main.c:76 ../vector/v.surf.bspline/main.c:94
-#: ../vector/v.in.lidar/main.c:156 ../vector/v.lidar.edgedetection/main.c:73
-#: ../vector/v.lidar.correction/main.c:69
-msgid "LIDAR"
+#: ../imagery/i.modis.qc/main.c:153
+msgid "surf. refl. 500m 8-days"
msgstr ""
-#: ../raster/r.in.xyz/main.c:165
-msgid ""
-"Creates a raster map from an assemblage of many coordinates using univariate "
-"statistics."
+#: ../imagery/i.modis.qc/main.c:154
+msgid "surf. refl. 500m 8-days, State QA"
msgstr ""
-#: ../raster/r.in.xyz/main.c:169
-msgid "ASCII file containing input data (or \"-\" to read from stdin)"
+#: ../imagery/i.modis.qc/main.c:155
+msgid "LST 1Km daily (Day/Night)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:177 ../raster/r.in.lidar/main.c:177
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
-msgid "Statistic to use for raster values"
+#: ../imagery/i.modis.qc/main.c:156
+msgid "LST 1Km 8-days (Day/Night)"
msgstr ""
-#: ../raster/r.in.xyz/main.c:181 ../raster/r.in.xyz/main.c:289
-#: ../raster/r.in.xyz/main.c:298 ../raster/r.in.lidar/main.c:181
-#: ../raster/r.in.lidar/main.c:221 ../raster/r.in.lidar/main.c:230
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
-msgid "Statistic"
+#: ../imagery/i.modis.qc/main.c:157
+msgid "VI 1Km 16-days"
msgstr ""
-#: ../raster/r.in.xyz/main.c:192 ../raster/r.in.xyz/main.c:201
-#: ../raster/r.in.xyz/main.c:209 ../raster/r.in.xyz/main.c:220
-#: ../raster/r.in.xyz/main.c:230 ../raster/simwe/r.sim.sediment/main.c:153
-#: ../raster/simwe/r.sim.sediment/main.c:161
-#: ../raster/simwe/r.sim.water/main.c:131
-#: ../raster/simwe/r.sim.water/main.c:140
-#: ../raster/simwe/r.sim.water/main.c:147
-#: ../raster/simwe/r.sim.water/main.c:156
-#: ../raster/simwe/r.sim.water/main.c:162
-#: ../raster/simwe/r.sim.water/main.c:170
-#: ../raster/simwe/r.sim.water/main.c:177 ../raster/r.external/main.c:64
-#: ../raster/r.external/main.c:72 ../raster/r.external/main.c:81
-#: ../locale/scriptstrings/i.spectral_to_translate.c:6
-#: ../locale/scriptstrings/i.spectral_to_translate.c:7
-#: ../locale/scriptstrings/i.spectral_to_translate.c:8
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
-#: ../locale/scriptstrings/t.register_to_translate.c:5
-#: ../locale/scriptstrings/t.register_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:8
-#: ../locale/scriptstrings/t.register_to_translate.c:10
-#: ../locale/scriptstrings/t.register_to_translate.c:20
-#: ../locale/scriptstrings/t.remove_to_translate.c:5
-#: ../locale/scriptstrings/t.remove_to_translate.c:8
-#: ../locale/scriptstrings/t.remove_to_translate.c:10
-#: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
-msgid "Input"
+#: ../imagery/i.modis.qc/main.c:158
+msgid "Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days"
msgstr ""
-#: ../raster/r.in.xyz/main.c:200
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
-msgid "Column number of x coordinates in input file (first column is 1)"
+#: ../imagery/i.modis.qc/main.c:159
+msgid "Brdf-Albedo Quality (BRDF SDS) 1Km 8-days"
msgstr ""
-#: ../raster/r.in.xyz/main.c:208
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
-msgid "Column number of y coordinates in input file"
+#: ../imagery/i.modis.qc/main.c:168
+#, fuzzy
+msgid "Name of QC type to extract"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:209
+msgid "mod09: Adjacency Correction"
msgstr ""
-#: ../raster/r.in.xyz/main.c:216
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
-msgid "Column number of data values in input file"
+#: ../imagery/i.modis.qc/main.c:210
+msgid "mod09: Atmospheric Correction"
msgstr ""
-#: ../raster/r.in.xyz/main.c:218
-msgid ""
-"If a separate value column is given, this option refers to the z-coordinate "
-"column to be filtered by the zrange option"
+#: ../imagery/i.modis.qc/main.c:211
+msgid "mod09: Cloud State"
msgstr ""
-#: ../raster/r.in.xyz/main.c:229
-#, fuzzy
-msgid "Number of header lines to skip at top of input file"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:212
+msgid "mod09: Band-Wise Data Quality Flag"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:237 ../raster/r.in.lidar/main.c:196
-msgid "Filter range for z data (min,max)"
+#: ../imagery/i.modis.qc/main.c:213
+msgid "mod09: 250m Band is at Different Orbit than 500m"
msgstr ""
-#: ../raster/r.in.xyz/main.c:238 ../raster/r.in.xyz/main.c:246
-#: ../raster/r.in.xyz/main.c:255 ../raster/r.in.xyz/main.c:263
-#: ../raster/r.in.xyz/main.c:271
-msgid "Advanced Input"
+#: ../imagery/i.modis.qc/main.c:214
+msgid "mod09: MODIS Land General Quality Assessment"
msgstr ""
-#: ../raster/r.in.xyz/main.c:245 ../raster/r.in.lidar/main.c:203
-msgid "Scale to apply to z data"
+#: ../imagery/i.modis.qc/main.c:215
+msgid "mod11A1: MODIS Land General Quality Assessment"
msgstr ""
-#: ../raster/r.in.xyz/main.c:253
-#, fuzzy
-msgid "Alternate column number of data values in input file"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:216
+msgid "mod11A1: Detailed Quality Indications"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:254
-msgid "If not given (or set to 0) the z-column data is used"
+#: ../imagery/i.modis.qc/main.c:217
+msgid "mod11A1: Average Emissivity Error Classes"
msgstr ""
-#: ../raster/r.in.xyz/main.c:262
-msgid "Filter range for alternate value column data (min,max)"
+#: ../imagery/i.modis.qc/main.c:218
+msgid "mod11A1: Average LST Error Classes"
msgstr ""
-#: ../raster/r.in.xyz/main.c:270
-msgid "Scale to apply to alternate value column data"
+#: ../imagery/i.modis.qc/main.c:219
+msgid "mod11A2: Detailed Quality Indications"
msgstr ""
-#: ../raster/r.in.xyz/main.c:288 ../raster/r.in.lidar/main.c:220
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
-msgid "pth percentile of the values"
+#: ../imagery/i.modis.qc/main.c:220
+msgid "mod11A2: Average Emissivity Error Classes"
msgstr ""
-#: ../raster/r.in.xyz/main.c:297 ../raster/r.in.lidar/main.c:229
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
-msgid ""
-"Discard <trim> percent of the smallest and <trim> percent of the largest "
-"observations"
+#: ../imagery/i.modis.qc/main.c:221
+msgid "mod11A2: MODIS Land General Quality Assessment"
msgstr ""
-#: ../raster/r.in.xyz/main.c:302 ../raster/r.in.lidar/main.c:257
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
-msgid "Scan data file for extent then exit"
+#: ../imagery/i.modis.qc/main.c:222
+msgid "mod11A2: Average LST Error Classes"
msgstr ""
-#: ../raster/r.in.xyz/main.c:307 ../raster/r.in.lidar/main.c:263
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
-msgid "In scan mode, print using shell script style"
+#: ../imagery/i.modis.qc/main.c:223 ../imagery/i.modis.qc/main.c:224
+#: ../imagery/i.modis.qc/main.c:225 ../imagery/i.modis.qc/main.c:226
+#: ../imagery/i.modis.qc/main.c:227 ../imagery/i.modis.qc/main.c:228
+#: ../imagery/i.modis.qc/main.c:229 ../imagery/i.modis.qc/main.c:230
+#: ../imagery/i.modis.qc/main.c:231 ../imagery/i.modis.qc/main.c:232
+#: ../imagery/i.modis.qc/main.c:233
+msgid "mod09A1s: StateQA Internal Snow Mask"
msgstr ""
-#: ../raster/r.in.xyz/main.c:311
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
-msgid "Ignore broken lines"
+#: ../imagery/i.modis.qc/main.c:234
+msgid "mod13A2: MODIS Land General Quality Assessment"
msgstr ""
-#: ../raster/r.in.xyz/main.c:332
-msgid "Please specify a reasonable column number."
+#: ../imagery/i.modis.qc/main.c:235
+msgid "mod13A2: Quality estimation of the pixel"
msgstr ""
-#: ../raster/r.in.xyz/main.c:344 ../vector/v.in.ascii/main.c:185
-msgid "Please specify reasonable number of lines to skip"
+#: ../imagery/i.modis.qc/main.c:236
+msgid "mod13A2: Quantity range of Aerosol"
msgstr ""
-#: ../raster/r.in.xyz/main.c:349 ../raster/r.in.lidar/main.c:428
-msgid "Invalid zrange"
+#: ../imagery/i.modis.qc/main.c:237
+msgid "mod13A2: if pixel is a cloud neighbour"
msgstr ""
-#: ../raster/r.in.xyz/main.c:363
-#, fuzzy
-msgid "Invalid vrange"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:238
+msgid "mod13A2: if BRDF correction performed"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:449 ../raster/r.in.lidar/main.c:521
-msgid "Unable to calculate percentile without the pth option specified!"
+#: ../imagery/i.modis.qc/main.c:239
+msgid "mod13A2: if pixel mixed with clouds"
msgstr ""
-#: ../raster/r.in.xyz/main.c:461 ../raster/r.in.lidar/main.c:533
-msgid "Unable to calculate trimmed mean without the trim option specified!"
+#: ../imagery/i.modis.qc/main.c:240
+msgid "mod13A2: separate land from various water objects"
msgstr ""
-#: ../raster/r.in.xyz/main.c:494 ../raster/r.in.lidar/main.c:608
-#, c-format
-msgid ""
-"Unable to process the hole map at once. Please set the %s option to some "
-"value lower than 100."
+#: ../imagery/i.modis.qc/main.c:241
+msgid "mod13A2: if snow/ice present in pixel"
msgstr ""
-#: ../raster/r.in.xyz/main.c:547
+#: ../imagery/i.modis.qc/main.c:242
+msgid "mod13A2: if shadow is present in pixel"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:243 ../imagery/i.modis.qc/main.c:244
+#: ../imagery/i.modis.qc/main.c:245
+msgid "mcd43B2: Quality of BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:246
+msgid "mcd43B2q: Quality of BRDF correction performed"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:256
msgid ""
-"If input is not from a file it is only possible to perform a single pass."
+"Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
msgstr ""
-#: ../raster/r.in.xyz/main.c:559
-msgid "Range filters will not be taken into account during scan"
+#: ../imagery/i.modis.qc/main.c:260
+msgid "Band 1: Red"
msgstr ""
-#: ../raster/r.in.xyz/main.c:596
-#, fuzzy
-msgid "Reading input data..."
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:261
+msgid "Band 2: NIR"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:603 ../raster/r.in.poly/poly2rast.c:55
-#: ../raster/r.in.lidar/main.c:665
-#, c-format
-msgid "Pass #%d (of %d) ..."
+#: ../imagery/i.modis.qc/main.c:262
+msgid "Band 3: Blue"
msgstr ""
-#: ../raster/r.in.xyz/main.c:681 ../raster/r.in.xyz/main.c:689
-#: ../raster/r.in.xyz/main.c:1198 ../raster/r.in.xyz/main.c:1206
-#, c-format
-msgid ""
-"Not enough data columns. Incorrect delimiter or column number? Found the "
-"following character(s) in row %lu:\n"
-"[%s]"
+#: ../imagery/i.modis.qc/main.c:263
+msgid "Band 4: Green"
msgstr ""
-#: ../raster/r.in.xyz/main.c:685 ../raster/r.in.xyz/main.c:1202
-msgid "Line ignored as requested"
+#: ../imagery/i.modis.qc/main.c:264
+msgid "Band 5: SWIR 1"
msgstr ""
-#: ../raster/r.in.xyz/main.c:704 ../raster/r.in.xyz/main.c:1236
-#, c-format
-msgid "Bad y-coordinate line %lu column %d. <%s>"
+#: ../imagery/i.modis.qc/main.c:265
+msgid "Band 6: SWIR 2"
msgstr ""
-#: ../raster/r.in.xyz/main.c:711 ../raster/r.in.xyz/main.c:1221
-#, c-format
-msgid "Bad x-coordinate line %lu column %d. <%s>"
+#: ../imagery/i.modis.qc/main.c:266
+msgid "Band 7: SWIR 3"
msgstr ""
-#: ../raster/r.in.xyz/main.c:718 ../raster/r.in.xyz/main.c:1251
-#, c-format
-msgid "Bad z-coordinate line %lu column %d. <%s>"
+#: ../imagery/i.modis.qc/main.c:285
+msgid "This flag is only available for MOD09Q1 @ 250m products"
msgstr ""
-#: ../raster/r.in.xyz/main.c:731 ../raster/r.in.xyz/main.c:1269
-#, fuzzy, c-format
-msgid "Bad data value line %lu column %d. <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:289 ../imagery/i.modis.qc/main.c:319
+msgid "Band number out of allowed range [1-7]"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:814
-#, fuzzy
-msgid "Writing to output raster map..."
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:291
+msgid "mod09Q1 product only has 2 bands"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:1154 ../raster/r.in.lidar/main.c:1146
-#, fuzzy, c-format
-msgid "%lu points found in region."
-msgstr "출력할 래스터맵"
+#: ../imagery/i.modis.qc/main.c:302
+msgid "This flag is only available for MOD09A1s @ 500m products"
+msgstr ""
-#: ../raster/r.in.xyz/main.c:1183 ../raster/r.in.lidar/main.c:1238
-msgid "Scanning data ..."
+#: ../imagery/i.modis.qc/main.c:309
+msgid "This flag is only available for MOD13A2 @ 1Km products"
msgstr ""
-#: ../raster/r.in.xyz/main.c:1289 ../raster/r.in.lidar/main.c:1280
+#: ../imagery/i.modis.qc/main.c:315
+msgid "This flag is only available for MCD43B2 @ 1Km products"
+msgstr ""
+#: ../imagery/i.modis.qc/main.c:504
+msgid "Unknown names and/or combination, please check spelling"
+msgstr ""
+#: ../imagery/i.maxlik/invert.c:28
#, c-format
-msgid "Range: min max\n"
+msgid "Signature %d is not valid (ill-conditioned) - ignored"
msgstr ""
-#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
-#: ../raster/r.neighbors/main.c:93 ../raster3d/r3.neighbors/main.c:94
+#: ../imagery/i.maxlik/invert.c:31
#, c-format
-msgid "Unknown method <%s>"
+msgid "Signature %d is not valid (singular) - ignored"
msgstr ""
-#: ../raster/r.series/main.c:134 ../raster/r.neighbors/main.c:142
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
-#: ../raster3d/r3.neighbors/main.c:210 ../vector/v.neighbors/main.c:53
-msgid "aggregation"
+#: ../imagery/i.maxlik/main.c:66
+msgid "Classifies the cell spectral reflectances in imagery data."
msgstr ""
-#: ../raster/r.series/main.c:135 ../raster/r.series.interp/main.c:65
-#: ../raster/r.series.accumulate/main.c:81
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
+#: ../imagery/i.maxlik/main.c:68
+msgid ""
+"Classification is based on the spectral signature information generated by "
+"either i.cluster, i.class, or i.gensig."
+msgstr ""
+#: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
#, fuzzy
-msgid "series"
+msgid "Name of input file containing signatures"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:137
-msgid ""
-"Makes each output cell value a function of the values assigned to the "
-"corresponding cells in the input raster map layers."
+#: ../imagery/i.maxlik/main.c:82
+msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
msgstr ""
-#: ../raster/r.series/main.c:146
+#: ../imagery/i.maxlik/main.c:86 ../imagery/i.smap/parse.c:28
+#, fuzzy
+msgid "Name for output raster map holding classification results"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.maxlik/main.c:92
+#, fuzzy
+msgid "Name for output raster map holding reject threshold results"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.maxlik/open.c:17 ../imagery/i.gensig/parse.c:41
+#: ../imagery/i.cluster/open_files.c:18 ../imagery/i.smap/parse.c:61
+#: ../imagery/i.gensigset/parse.c:47
+#, fuzzy, c-format
+msgid "Group <%s> not found in current mapset"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.maxlik/open.c:20 ../imagery/i.gensig/parse.c:44
+#: ../imagery/i.cluster/open_files.c:22 ../imagery/i.smap/parse.c:64
+#: ../imagery/i.gensigset/parse.c:50
+#, fuzzy, c-format
+msgid "Subgroup <%s> in group <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.maxlik/open.c:27
+#, c-format
msgid ""
-"Input file with one raster map name and optional one weight per line, field "
-"separator between name and weight is |"
+"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
+"have at least 2 raster maps."
msgstr ""
-#: ../raster/r.series/main.c:157 ../raster3d/r3.neighbors/main.c:119
-msgid "Aggregate operation"
+#: ../imagery/i.maxlik/open.c:30
+#, c-format
+msgid ""
+"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
+"least 2 raster maps."
msgstr ""
-#: ../raster/r.series/main.c:164 ../raster/r.resamp.stats/main.c:277
-#: ../raster/r.neighbors/main.c:209 ../raster3d/r3.neighbors/main.c:127
-#, fuzzy
-msgid "Quantile to calculate for method=quantile"
+#: ../imagery/i.maxlik/open.c:47
+#, fuzzy, c-format
+msgid "Unable to open signature file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:172
-msgid ""
-"Weighting factor for each input map, default value is 1.0 for each input map"
-msgstr ""
+#: ../imagery/i.maxlik/open.c:53 ../imagery/i.cluster/open_files.c:70
+#: ../imagery/i.smap/read_sig.c:23
+#, fuzzy, c-format
+msgid "Unable to read signature file <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:179 ../raster/r.series.accumulate/main.c:132
-msgid "Ignore values outside this range"
+#: ../imagery/i.maxlik/open.c:57 ../imagery/i.cluster/open_files.c:74
+#, c-format
+msgid "<%s> has too many signatures (limit is 255)"
msgstr ""
-#: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:163
-#: ../raster/r.resamp.stats/main.c:283 ../raster/r.resamp.filter/main.c:424
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
-msgid "Propagate NULLs"
+#: ../imagery/i.evapo.pm/main.c:61
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
msgstr ""
-#: ../raster/r.series/main.c:187 ../raster/r.series.accumulate/main.c:167
+#: ../imagery/i.evapo.pm/main.c:65
#, fuzzy
-msgid "Don't keep files open"
+msgid "Name of input elevation raster map [m a.s.l.]"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:198 ../raster/r.series.accumulate/main.c:210
-msgid "input= and file= are mutually exclusive"
-msgstr ""
+#: ../imagery/i.evapo.pm/main.c:69
+#, fuzzy
+msgid "Name of input temperature raster map [C]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:201 ../raster/r.series.accumulate/main.c:213
+#: ../imagery/i.evapo.pm/main.c:73
#, fuzzy
-msgid "Please specify input= or file="
+msgid "Name of input relative humidity raster map [%]"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:251 ../raster/r.series/main.c:294
-#, fuzzy, c-format
-msgid "Reading raster map <%s> using weight %f..."
+#: ../imagery/i.evapo.pm/main.c:77
+#, fuzzy
+msgid "Name of input wind speed raster map [m/s]"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:258 ../raster/r.series.accumulate/main.c:257
+#: ../imagery/i.evapo.pm/main.c:82
#, fuzzy
-msgid "No raster map name found in input file"
+msgid "Name of input net solar radiation raster map [MJ/m2/h]"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:268 ../raster/r.stats/main.c:289
-#: ../raster/r.series.accumulate/main.c:267
+#: ../imagery/i.evapo.pm/main.c:86
#, fuzzy
-msgid "Raster map not found"
+msgid "Name of input crop height raster map [m]"
msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:280
-msgid "input= and weights= must have the same number of values"
-msgstr ""
+#: ../imagery/i.evapo.pm/main.c:89
+#, fuzzy
+msgid "Name for output raster map [mm/h]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:309 ../raster/r.neighbors/main.c:262
-msgid "output= and method= must have the same number of values"
-msgstr ""
+#: ../imagery/i.evapo.pm/main.c:93
+#, fuzzy
+msgid "Set negative evapotranspiration to zero"
+msgstr "출력할 래스터맵"
-#: ../raster/r.series/main.c:337 ../raster/r.series.interp/main.c:329
-#: ../raster/r.series.accumulate/main.c:320
-#: ../raster/r.slope.aspect/main.c:541 ../raster/r.shaded.relief/main.c:303
-#: ../raster/r.patch/main.c:119
-msgid "Percent complete..."
+#: ../imagery/i.evapo.pm/main.c:97
+msgid "Use Night-time"
msgstr ""
-#: ../raster/r.grow.distance/main.c:152 ../raster/r.grow/main.c:123
-#: ../raster/r.distance/main.c:39 ../misc/m.cogo/main.c:228
-#: ../display/d.rhumbline/main.c:44 ../display/d.geodesic/main.c:44
-#: ../vector/v.distance/main.c:88
-msgid "distance"
+#: ../imagery/i.evapo.pt/main.c:69
+msgid ""
+"Computes evapotranspiration calculation Prestley and Taylor formulation, "
+"1972."
msgstr ""
-#: ../raster/r.grow.distance/main.c:154
+#: ../imagery/i.evapo.pt/main.c:75
#, fuzzy
-msgid "Generates a raster map containing distances to nearest raster features."
+msgid "Name of input net radiation raster map [W/m2]"
msgstr "출력할 래스터맵"
-#: ../raster/r.grow.distance/main.c:161
+#: ../imagery/i.evapo.pt/main.c:79
#, fuzzy
-msgid "Name for distance output raster map"
+msgid "Name of input soil heat flux raster map [W/m2]"
msgstr "출력할 래스터맵"
-#: ../raster/r.grow.distance/main.c:162 ../raster/r.grow.distance/main.c:168
-#: ../raster/simwe/r.sim.sediment/main.c:182
-#: ../raster/simwe/r.sim.sediment/main.c:188
-#: ../raster/simwe/r.sim.sediment/main.c:195
-#: ../raster/simwe/r.sim.sediment/main.c:202
-#: ../raster/simwe/r.sim.sediment/main.c:208
-#: ../raster/simwe/r.sim.sediment/main.c:215
-#: ../raster/simwe/r.sim.water/main.c:191
-#: ../raster/simwe/r.sim.water/main.c:197
-#: ../raster/simwe/r.sim.water/main.c:203
-#: ../raster/simwe/r.sim.water/main.c:209 ../raster/r.resamp.rst/main.c:176
-#: ../raster/r.resamp.rst/main.c:184 ../raster/r.resamp.rst/main.c:192
-#: ../raster/r.resamp.rst/main.c:200 ../raster/r.resamp.rst/main.c:208
-#: ../raster/r.resamp.rst/main.c:216 ../raster/r.resamp.rst/main.c:280
-#: ../locale/scriptstrings/i.spectral_to_translate.c:10
-#: ../locale/scriptstrings/i.spectral_to_translate.c:12
-#: ../locale/scriptstrings/m.proj_to_translate.c:10
-#: ../locale/scriptstrings/m.proj_to_translate.c:23
-#: ../locale/scriptstrings/m.proj_to_translate.c:25
-#: ../locale/scriptstrings/m.proj_to_translate.c:27
-#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
-#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:247
-#: ../vector/v.in.ogr/main.c:253
-msgid "Output"
+#: ../imagery/i.evapo.pt/main.c:83
+#, fuzzy
+msgid "Name of input air temperature raster map [K]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.pt/main.c:87
+#, fuzzy
+msgid "Name of input atmospheric pressure raster map [millibars]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.pt/main.c:93
+msgid "Prestley-Taylor coefficient"
msgstr ""
-#: ../raster/r.grow.distance/main.c:167
+#: ../imagery/i.evapo.pt/main.c:97
#, fuzzy
-msgid "Name for value output raster map"
+msgid "Name of output evapotranspiration raster map [mm/d]"
msgstr "출력할 래스터맵"
-#: ../raster/r.grow.distance/main.c:174 ../raster/r.grow/main.c:143
-#: ../locale/scriptstrings/r.grow_to_translate.c:5
-msgid "Metric"
+#: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
+msgid "Set negative ETa to zero"
msgstr ""
-#: ../raster/r.grow.distance/main.c:180
-msgid "Output distances in meters instead of map units"
+#: ../imagery/i.landsat.acca/algorithm.c:124
+msgid "Preliminary scene analysis:"
msgstr ""
-#: ../raster/r.grow.distance/main.c:190
-#, fuzzy
-msgid "At least one of distance= and value= must be given"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/algorithm.c:125
+#, c-format
+msgid "* Desert index: %.2lf"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:205
-msgid "metric=geodesic is only valid for lat/lon"
+#: ../imagery/i.landsat.acca/algorithm.c:126
+#, c-format
+msgid "* Snow cover: %.2lf %%"
msgstr ""
-#: ../raster/r.grow.distance/main.c:211
+#: ../imagery/i.landsat.acca/algorithm.c:127
#, c-format
-msgid "Unknown metric: '%s'"
+msgid "* Cloud cover: %.2lf %%"
msgstr ""
-#: ../raster/r.grow.distance/main.c:216
+#: ../imagery/i.landsat.acca/algorithm.c:128
+msgid "* Temperature of clouds:"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:129
#, c-format
-msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
+msgid "** Maximum: %.2lf K"
msgstr ""
-#: ../raster/r.grow.distance/main.c:236
-#, fuzzy, c-format
-msgid "Unable to create temporary file <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/algorithm.c:130
+#, c-format
+msgid "** Mean (%s cloud): %.2lf K"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:311 ../raster/r.fill.dir/main.c:250
-#: ../raster/r.stream.extract/close.c:246
-#, fuzzy
-msgid "Writing output raster maps..."
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/algorithm.c:132
+#, c-format
+msgid "** Minimum: %.2lf K"
+msgstr ""
-#: ../raster/r.grow.distance/main.c:368 ../raster/r.colors/edit_colors.c:415
-#: ../raster/r.fill.dir/main.c:150 ../raster/r.colors.out/raster_main.c:69
-#: ../display/d.colors/get_info.c:25 ../vector/v.colors/main.c:314
-#, fuzzy, c-format
-msgid "Unable to read color table for raster map <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/algorithm.c:142
+msgid "Histogram cloud signature:"
+msgstr ""
-#: ../raster/r.out.ppm3/main.c:58
-msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+#: ../imagery/i.landsat.acca/algorithm.c:148
+#, c-format
+msgid "* Mean temperature: %.2lf K"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:83
-msgid "Name for new PPM file. (use out=- for stdout)"
+#: ../imagery/i.landsat.acca/algorithm.c:149
+#, c-format
+msgid "* Standard deviation: %.2lf"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:87
-msgid "Add comments to describe the region"
+#: ../imagery/i.landsat.acca/algorithm.c:150
+#, c-format
+msgid "* Skewness: %.2lf"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:94 ../raster/r.out.ppm/main.c:100
+#: ../imagery/i.landsat.acca/algorithm.c:151
#, c-format
-msgid "row = %d"
-msgid_plural "rows = %d"
-msgstr[0] ""
-msgstr[1] ""
+msgid "* Histogram classes: %d"
+msgstr ""
-#: ../raster/r.out.ppm3/main.c:95 ../raster/r.out.ppm/main.c:101
+#: ../imagery/i.landsat.acca/algorithm.c:163
#, c-format
-msgid "col = %d"
-msgid_plural "cols = %d"
-msgstr[0] ""
-msgstr[1] ""
+msgid "* 98.75 percentile: %.2lf K"
+msgstr ""
-#: ../raster/r.out.ppm3/main.c:110 ../raster/r.his/main.c:140
-#: ../raster/r.his/main.c:156 ../raster/r.his/main.c:174
-#: ../display/d.legend/main.c:279 ../display/d.rgb/main.c:101
-#: ../display/d.colortable/main.c:137 ../display/d.histogram/main.c:174
-#: ../display/d.rast.num/main.c:219 ../display/d.his/main.c:141
-#: ../display/d.his/main.c:158 ../display/d.his/main.c:176
-#: ../display/d.rast/display.c:23
+#: ../imagery/i.landsat.acca/algorithm.c:164
#, c-format
-msgid "Color file for <%s> not available"
+msgid "* 97.50 percentile: %.2lf K"
msgstr ""
-#: ../raster/r.out.ppm3/main.c:155
-msgid "Converting ... "
+#: ../imagery/i.landsat.acca/algorithm.c:165
+#, c-format
+msgid "* 83.50 percentile: %.2lf K"
msgstr ""
-#: ../raster/r.ros/main.c:214 ../raster/r.spread/main.c:103
-#: ../raster/r.spreadpath/main.c:90
-msgid "fire"
+#: ../imagery/i.landsat.acca/algorithm.c:186
+msgid "Maximum temperature:"
msgstr ""
-#: ../raster/r.ros/main.c:215 ../raster/r.spread/main.c:104
-msgid "spread"
+#: ../imagery/i.landsat.acca/algorithm.c:187
+#, c-format
+msgid "* Cold cloud: %.2lf K"
msgstr ""
-#: ../raster/r.ros/main.c:216
-#, fuzzy
-msgid "rate of spread"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/algorithm.c:188
+#, c-format
+msgid "* Warm cloud: %.2lf K"
+msgstr ""
-#: ../raster/r.ros/main.c:217 ../raster/r.lake/main.c:152
-#: ../raster/r.spread/main.c:105
-msgid "hazard"
+#: ../imagery/i.landsat.acca/algorithm.c:193
+msgid "Result: Scene with clouds"
msgstr ""
-#: ../raster/r.ros/main.c:218
+#: ../imagery/i.landsat.acca/algorithm.c:200
+msgid "Result: Scene cloud free"
+msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:237
#, fuzzy
-msgid "Generates rate of spread raster maps."
+msgid "Processing first pass..."
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:220
-msgid ""
-"Generates three, or four raster map layers showing the base (perpendicular) "
-"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
-"maximum ROS, and optionally the maximum potential spotting distance for fire "
-"spread simulation."
-msgstr ""
+#: ../imagery/i.landsat.acca/algorithm.c:391
+#, fuzzy
+msgid "Removing ambiguous pixels..."
+msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:227
+#: ../imagery/i.landsat.acca/algorithm.c:393
#, fuzzy
-msgid "Raster map containing fuel models"
+msgid "Pass two processing..."
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:229
+#: ../imagery/i.landsat.acca/main.c:70
+#, c-format
msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the standard fuel models defined by the USDA Forest Service. "
-"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
+"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
+"to radiance first)"
msgstr ""
-#: ../raster/r.ros/main.c:238
-msgid "Raster map containing the 1-hour fuel moisture (%)"
+#: ../imagery/i.landsat.acca/main.c:104
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
msgstr ""
-#: ../raster/r.ros/main.c:240 ../raster/r.spread/main.c:201
-msgid ""
-"path containing the 1-hour (<.25\") fuel moisture (percentage content "
-"multiplied by 100)."
+#: ../imagery/i.landsat.acca/main.c:122
+msgid "B56composite (step 6)"
msgstr ""
-#: ../raster/r.ros/main.c:248
-msgid "Raster map containing the 10-hour fuel moisture (%)"
+#: ../imagery/i.landsat.acca/main.c:129
+msgid "B45ratio: Desert detection (step 10)"
msgstr ""
-#: ../raster/r.ros/main.c:250
-msgid ""
-"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+#: ../imagery/i.landsat.acca/main.c:137
+#, fuzzy
+msgid "Number of classes in the cloud temperature histogram"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
+#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
+#, fuzzy
+msgid "Cloud settings"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.landsat.acca/main.c:143
+msgid "Data is Landsat-5 TM"
msgstr ""
-#: ../raster/r.ros/main.c:258
-msgid "Raster map containing the 100-hour fuel moisture (%)"
+#: ../imagery/i.landsat.acca/main.c:144
+msgid "I.e. Thermal band is '.6' not '.61')"
msgstr ""
-#: ../raster/r.ros/main.c:260
-msgid ""
-"path containing the 100-hour (1-3\") fuel moisture (percentage content "
+#: ../imagery/i.landsat.acca/main.c:149
+msgid "Apply post-processing filter to remove small holes"
msgstr ""
-#: ../raster/r.ros/main.c:267
-msgid "Raster map containing live fuel moisture (%)"
+#: ../imagery/i.landsat.acca/main.c:153
+msgid "Always use cloud signature (step 14)"
msgstr ""
-#: ../raster/r.ros/main.c:269
+#: ../imagery/i.landsat.acca/main.c:159
msgid ""
-"path containing live (herbaceous) fuel moisture (percentage content "
+"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
msgstr ""
-#: ../raster/r.ros/main.c:277
-msgid "Raster map containing midflame wind velocitys (ft/min)"
+#: ../imagery/i.landsat.acca/main.c:164
+msgid "Include a category for cloud shadows"
msgstr ""
-#: ../raster/r.ros/main.c:279 ../raster/r.spread/main.c:189
+#: ../imagery/i.landsat.acca/tools.c:138
+msgid "Filling small holes in clouds..."
+msgstr ""
+#: ../imagery/i.evapo.mh/main.c:72
msgid ""
-"path containing wind velocities at half of the average flame height (feet/"
-"minute)."
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
msgstr ""
-#: ../raster/r.ros/main.c:287
+#: ../imagery/i.evapo.mh/main.c:78
#, fuzzy
-msgid "Name of raster map containing wind directions (degree)"
+msgid "Name of input diurnal net radiation raster map [W/m2/d]"
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:289
-msgid ""
-"path containing wind direction, clockwise from north (degree)."
+#: ../imagery/i.evapo.mh/main.c:82
+#, fuzzy
+msgid "Name of input average air temperature raster map [C]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.mh/main.c:86
+#, fuzzy
+msgid "Name of input minimum air temperature raster map [C]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.mh/main.c:90
+#, fuzzy
+msgid "Name of input maximum air temperature raster map [C]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.mh/main.c:96
+#, fuzzy
+msgid "Name of precipitation raster map [mm/month]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.evapo.mh/main.c:97
+msgid "Disabled for original Hargreaves (1985)"
msgstr ""
-#: ../raster/r.ros/main.c:297
+#: ../imagery/i.evapo.mh/main.c:100
#, fuzzy
-msgid "Name of raster map containing slope (degree)"
+msgid "Name for output raster map [mm/d]"
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:299
-msgid ""
-"path containing topographic slope (degree)."
+#: ../imagery/i.evapo.mh/main.c:109
+msgid "Use original Hargreaves (1985)"
msgstr ""
-#: ../raster/r.ros/main.c:307
-msgid "Raster map containing aspect (degree, CCW from E)"
+#: ../imagery/i.evapo.mh/main.c:113
+msgid "Use Hargreaves-Samani (1985)"
msgstr ""
-#: ../raster/r.ros/main.c:309
+#: ../imagery/i.aster.toar/main.c:99
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
+msgid "Terra-ASTER"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:104
msgid ""
-"path containing topographic aspect, counterclockwise from east (GRASS "
-"convention) in degrees."
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN.\n"
msgstr ""
-#: ../raster/r.ros/main.c:317
+#: ../imagery/i.aster.toar/main.c:108
+msgid "Names of ASTER DN layers (15 layers)"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:115
#, fuzzy
-msgid "Raster map containing elevation (m, required with -s)"
+msgid "Day of Year of satellite overpass [0-366]"
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:319
-msgid ""
-"path containing elevation (meters). Option is required from spotting "
-"distance computation (when -s flag is enabled)"
+#: ../imagery/i.aster.toar/main.c:122
+msgid "Sun elevation angle (degrees, < 90.0)"
msgstr ""
-#: ../raster/r.ros/main.c:326
+#: ../imagery/i.aster.toar/main.c:125
#, fuzzy
-msgid "Prefix for output raster maps (.base, .max, .maxdir, .spotdist)"
+msgid "Base name of the output layers (will add .x)"
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:330
-msgid "Also produce maximum spotting distance"
+#: ../imagery/i.aster.toar/main.c:130
+msgid "Output is radiance (W/m2)"
msgstr ""
-#: ../raster/r.ros/main.c:345
-msgid ""
-"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
-"moisture layers is required."
+#: ../imagery/i.aster.toar/main.c:134
+msgid "VNIR is High Gain"
msgstr ""
-#: ../raster/r.ros/main.c:369
+#: ../imagery/i.aster.toar/main.c:138
+msgid "SWIR is High Gain"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:142
+msgid "VNIR is Low Gain 1"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:146
+msgid "SWIR is Low Gain 1"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:150
+msgid "SWIR is Low Gain 2"
+msgstr ""
+#: ../imagery/i.aster.toar/main.c:229 ../imagery/i.albedo/main.c:150
#, c-format
-msgid ""
-"A wind direction layer should be given if the wind velocity layer <%s> has "
-"been given"
+msgid "Too many input maps. Only %d allowed."
msgstr ""
-#: ../raster/r.ros/main.c:374
+#: ../imagery/i.aster.toar/main.c:244
+msgid "The input band number should be 15"
+msgstr ""
+#: ../imagery/i.gensig/parse.c:14 ../imagery/i.gensigset/parse.c:13
+msgid "Ground truth training map"
+msgstr ""
+#: ../imagery/i.gensig/parse.c:26 ../imagery/i.cluster/main.c:95
+#: ../imagery/i.gensigset/parse.c:25
+#, fuzzy
+msgid "Name for output file containing result signatures"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/check.c:21
#, c-format
-msgid ""
-"A wind velocity layer should be given if the wind direction layer <%s> has "
-"been given"
+msgid "Signature %d not invertible"
msgstr ""
-#: ../raster/r.ros/main.c:388
+#: ../imagery/i.gensig/check.c:27
#, c-format
-msgid "An aspect layer should be given if the slope layer <%s> has been given"
+msgid "Signature %d unable to get eigen values"
msgstr ""
-#: ../raster/r.ros/main.c:393
+#: ../imagery/i.gensig/check.c:33
#, c-format
-msgid "A slope layer should be given if the aspect layer <%s> has been given"
+msgid "Signature %d not positive definite"
msgstr ""
-#: ../raster/r.ros/main.c:409
-msgid "An elevation layer should be given if considering spotting"
+#: ../imagery/i.gensig/means.c:26
+#, fuzzy
+msgid "Calculating class means..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/write_sig.c:15 ../imagery/i.gensigset/write_sig.c:13
+#, fuzzy, c-format
+msgid "Unable to create signature file <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/write_sig.c:18 ../imagery/i.gensigset/write_sig.c:16
+#, fuzzy
+msgid "Writing signatures..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/main.c:41 ../imagery/i.smap/main.c:40
+#: ../imagery/i.gensigset/main.c:42
+#, fuzzy
+msgid "supervised classification"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/main.c:46
+#, fuzzy
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/covariance.c:30
+msgid "Calculating class covariance matrices..."
msgstr ""
-#: ../raster/r.ros/main.c:427 ../raster/r.ros/main.c:431
-#: ../raster/r.ros/main.c:435 ../raster/r.ros/main.c:442
+#: ../imagery/i.gensig/get_train.c:32 ../imagery/i.gensigset/get_train.c:35
+#, fuzzy
+msgid "Finding training classes..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/get_train.c:55 ../imagery/i.gensigset/get_train.c:58
+#, c-format
+msgid "Training class %d only has one cell - this class will be ignored"
+msgstr ""
+#: ../imagery/i.gensig/get_train.c:60 ../imagery/i.gensigset/get_train.c:63
+#, fuzzy
+msgid "Training map has no classes"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/get_train.c:75 ../imagery/i.gensigset/get_train.c:79
+#, fuzzy
+msgid "1 class found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensig/get_train.c:77 ../imagery/i.gensigset/get_train.c:81
#, fuzzy, c-format
-msgid "Raster map <%s> already exists in mapset <%s>"
+msgid "%d classes found"
msgstr "출력할 래스터맵"
-#: ../raster/r.ros/main.c:863
+#: ../imagery/i.gensig/openfiles.c:19 ../imagery/i.smap/read_sig.c:13
+#: ../imagery/i.smap/openfiles.c:18 ../imagery/i.gensigset/openfiles.c:18
#, fuzzy, c-format
-msgid "Raster maps <%s>, <%s> and <%s> created."
+msgid "Unable to read REF file for subgroup <%s> in group <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:60
+#: ../imagery/i.gensig/openfiles.c:23 ../imagery/i.gensigset/openfiles.c:22
+#, fuzzy, c-format
+msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.zc/main.c:53 ../vector/v.lidar.edgedetection/main.c:74
+msgid "edges"
+msgstr ""
+#: ../imagery/i.zc/main.c:55
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../imagery/i.zc/main.c:65 ../raster/r.random/main.c:60
+#: ../raster/r.out.bin/main.c:290
+msgid "Name of input raster map"
+msgstr ""
+#: ../imagery/i.zc/main.c:73
#, fuzzy
-msgid "null data"
+msgid "Zero crossing raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:61
+#: ../imagery/i.zc/main.c:80
+msgid "x-y extent of the Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:88
+msgid "Sensitivity of Gaussian filter"
+msgstr ""
+#: ../imagery/i.zc/main.c:96
#, fuzzy
-msgid "Manages NULL-values of given raster map."
+msgid "Number of azimuth directions categorized"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:64
+#: ../imagery/i.zc/main.c:108
+msgid "Threshold less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:114
+msgid "Width less than or equal to zero not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:118
+msgid "Fewer than 1 orientation classes not allowed"
+msgstr ""
+#: ../imagery/i.zc/main.c:132
+#, c-format
+msgid "Power 2 values : %d rows %d columns"
+msgstr ""
+#: ../imagery/i.zc/main.c:142
+msgid "Initializing data..."
+msgstr ""
+#: ../imagery/i.zc/main.c:152 ../raster/r.carve/raster.c:13
+#: ../raster/r.texture/main.c:292
#, fuzzy
-msgid "Name of raster map for which to edit null values"
+msgid "Reading raster map..."
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:72 ../raster3d/r3.null/main.c:62
-msgid "List of cell values to be set to NULL"
+#: ../imagery/i.zc/main.c:172
+msgid "Writing transformed data to file..."
msgstr ""
-#: ../raster/r.null/main.c:73 ../raster/r.null/main.c:81
-#: ../general/g.proj/main.c:192
-msgid "Modify"
+#: ../imagery/i.zc/main.c:192
+msgid "Transform successful"
msgstr ""
-#: ../raster/r.null/main.c:80 ../raster3d/r3.null/main.c:69
-msgid "The value to replace the null value by"
+#: ../imagery/i.albedo/main.c:91
+msgid "Computes broad band albedo from surface reflectance."
msgstr ""
-#: ../raster/r.null/main.c:85
-msgid "Only do the work if the map is floating-point"
+#: ../imagery/i.albedo/main.c:104
+msgid "Modis (7 input bands:1,2,3,4,5,6,7)"
msgstr ""
-#: ../raster/r.null/main.c:86 ../raster/r.null/main.c:91
-#: ../raster/r.null/main.c:97
-msgid "Check"
+#: ../imagery/i.albedo/main.c:108
+msgid "NOAA AVHRR (2 input bands:1,2)"
msgstr ""
-#: ../raster/r.null/main.c:90
-msgid "Only do the work if the map is integer"
+#: ../imagery/i.albedo/main.c:112
+msgid "Landsat (6 input bands:1,2,3,4,5,7)"
msgstr ""
-#: ../raster/r.null/main.c:96
-msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
+#: ../imagery/i.albedo/main.c:116
+msgid "Aster (6 input bands:1,3,5,6,8,9)"
msgstr ""
-#: ../raster/r.null/main.c:102
-msgid "Create NULL-value bitmap file validating all data cells"
+#: ../imagery/i.albedo/main.c:120
+msgid "Agressive mode (Landsat)"
msgstr ""
-#: ../raster/r.null/main.c:106
-msgid "Remove NULL-value bitmap file"
+#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
+msgid ""
+"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
+"kind of simple atmospheric correction"
msgstr ""
-#: ../raster/r.null/main.c:107 ../raster/r.colors/edit_colors.c:116
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
-#: ../locale/scriptstrings/r.mask_to_translate.c:20
-#: ../locale/scriptstrings/g.extension_to_translate.c:27
-#: ../vector/v.colors/main.c:123
-msgid "Remove"
+#: ../imagery/i.albedo/main.c:127
+msgid "Soft mode (Modis)"
msgstr ""
-#: ../raster/r.null/main.c:125
+#: ../imagery/i.albedo/main.c:164
+#, fuzzy
+msgid "At least two raster maps are required"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/print6.c:11
#, c-format
+msgid "class distribution"
+msgstr ""
+#: ../imagery/i.cluster/print1.c:12
+#, c-format
msgid ""
-"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
-"with r.mapcalc. Exiting."
+"means and standard deviations for %d band%s\n"
+"\n"
msgstr ""
-#: ../raster/r.null/main.c:131
-#, fuzzy, c-format
-msgid "Raster map <%s> is not in your mapset <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/print1.c:14
+#, c-format
+msgid " means "
+msgstr ""
-#: ../raster/r.null/main.c:138
+#: ../imagery/i.cluster/print1.c:18
#, c-format
-msgid "%s is illegal entry for null"
+msgid " stddev "
msgstr ""
-#: ../raster/r.null/main.c:145
-#, fuzzy, c-format
-msgid "Raster map <%s> already has a null bitmap file"
+#: ../imagery/i.cluster/print5.c:15
+#, c-format
+msgid ""
+"\n"
+"class separability matrix\n"
+"\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:79
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm."
+msgstr ""
+#: ../imagery/i.cluster/main.c:82
+msgid ""
+"The resulting signature file is used as input for i.maxlik, to generate an "
+"unsupervised image classification."
+msgstr ""
+#: ../imagery/i.cluster/main.c:102
+msgid "Initial number of classes"
+msgstr ""
+#: ../imagery/i.cluster/main.c:111
+#, fuzzy
+msgid "Name of file containing initial signatures"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:149
-#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL)"
+#: ../imagery/i.cluster/main.c:119
+msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
+msgstr ""
+#: ../imagery/i.cluster/main.c:126 ../imagery/i.segment/parse_args.c:101
+msgid "Maximum number of iterations"
+msgstr ""
+#: ../imagery/i.cluster/main.c:135
+msgid "Percent convergence"
+msgstr ""
+#: ../imagery/i.cluster/main.c:143
+msgid "Cluster separation"
+msgstr ""
+#: ../imagery/i.cluster/main.c:151
+msgid "Minimum number of pixels in a class"
+msgstr ""
+#: ../imagery/i.cluster/main.c:158
+#, fuzzy
+msgid "Name for output file containing final report"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:153
+#: ../imagery/i.cluster/main.c:177
#, fuzzy, c-format
-msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgid "Illegal number of initial classes (%s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:159
+#: ../imagery/i.cluster/main.c:188
+#, c-format
+msgid "Illegal value(s) of sample intervals (%s)"
+msgstr ""
+#: ../imagery/i.cluster/main.c:202
#, fuzzy, c-format
-msgid "<%s> is floating pointing raster map"
+msgid "Illegal value of iterations (%s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:175
+#: ../imagery/i.cluster/main.c:208
#, fuzzy, c-format
-msgid "Writing new null file for raster map <%s>..."
+msgid "Illegal value of convergence (%s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:185 ../raster/r.null/main.c:198
+#: ../imagery/i.cluster/main.c:213
#, fuzzy, c-format
-msgid "Raster map <%s> modified."
+msgid "Illegal value of separation (%s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:192
+#: ../imagery/i.cluster/main.c:218
#, fuzzy, c-format
-msgid "Removing null file for raster map <%s>..."
+msgid "Illegal value of min_size (%s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:262
+#: ../imagery/i.cluster/main.c:227
#, fuzzy, c-format
-msgid "%s: %s: illegal value spec"
+msgid "Unable to create report file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.null/main.c:264
+#: ../imagery/i.cluster/main.c:235
#, c-format
-msgid "%s: illegal value spec"
+msgid ""
+"#################### CLUSTER (%s) ####################\n"
+"\n"
msgstr ""
-#: ../raster/r.null/main.c:325
-#, fuzzy, c-format
-msgid "Writing new data for raster map <%s>..."
-msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/main.c:237
+#, c-format
+msgid "Location: %s\n"
+msgstr ""
-#: ../raster/r.sunmask/main.c:118 ../raster/r.horizon/main.c:180
-msgid "sun position"
+#: ../imagery/i.cluster/main.c:238
+#, c-format
+msgid "Mapset: %s\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:119
-msgid ""
-"Calculates cast shadow areas from sun position and elevation raster map."
+#: ../imagery/i.cluster/main.c:239
+#, c-format
+msgid "Group: %s\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:120
-msgid ""
-"Either exact sun position (A) is specified, or date/time to calculate the "
-"sun position (B) by r.sunmask itself."
+#: ../imagery/i.cluster/main.c:240
+#, c-format
+msgid "Subgroup: %s\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:134
-msgid "Altitude of the sun above horizon, degrees (A)"
+#: ../imagery/i.cluster/main.c:242
+#, c-format
+msgid " %s\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:135 ../raster/r.sunmask/main.c:144
-#: ../raster/r.sunmask/main.c:211 ../raster/r.sunmask/main.c:221
-msgid "Position"
+#: ../imagery/i.cluster/main.c:245
+#, c-format
+msgid "Result signature file: %s\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:143
-msgid "Azimuth of the sun from the north, degrees (A)"
+#: ../imagery/i.cluster/main.c:247
+#, c-format
+msgid "Region\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:150
-msgid "Year (B)"
+#: ../imagery/i.cluster/main.c:248
+#, c-format
+msgid " North: %12.2f East: %12.2f\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:158
-msgid "Month (B)"
+#: ../imagery/i.cluster/main.c:250
+#, c-format
+msgid " South: %12.2f West: %12.2f\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:166
-msgid "Day (B)"
+#: ../imagery/i.cluster/main.c:252
+#, c-format
+msgid " Res: %12.2f Res: %12.2f\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:174
-msgid "Hour (B)"
+#: ../imagery/i.cluster/main.c:254
+#, c-format
+msgid " Rows: %12d Cols: %12d Cells: %d\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:182
-msgid "Minutes (B)"
+#: ../imagery/i.cluster/main.c:256
+#, c-format
+msgid "Mask: %s\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:190
-msgid "Seconds (B)"
+#: ../imagery/i.cluster/main.c:258
+#, c-format
+msgid "Cluster parameters\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:199
-msgid "Timezone"
+#: ../imagery/i.cluster/main.c:259
+#, c-format
+msgid " Number of initial classes: %d"
msgstr ""
-#: ../raster/r.sunmask/main.c:200
-msgid "East positive, offset from GMT, also use to adjust daylight savings"
+#: ../imagery/i.cluster/main.c:261
+#, c-format
+msgid " [from signature file %s]"
msgstr ""
-#: ../raster/r.sunmask/main.c:209
-msgid "Easting coordinate (point of interest)"
+#: ../imagery/i.cluster/main.c:263
+#, c-format
+msgid " Minimum class size: %d\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:210 ../raster/r.sunmask/main.c:220
-msgid "Default: map center"
+#: ../imagery/i.cluster/main.c:264
+#, c-format
+msgid " Minimum class separation: %f\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:219
-msgid "Northing coordinate (point of interest)"
+#: ../imagery/i.cluster/main.c:265
+#, c-format
+msgid " Percent convergence: %f\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:225
-msgid "Don't ignore zero elevation"
+#: ../imagery/i.cluster/main.c:266
+#, c-format
+msgid " Maximum number of iterations: %d\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:229
-msgid "Calculate sun position only and exit"
+#: ../imagery/i.cluster/main.c:268
+#, c-format
+msgid " Row sampling interval: %d\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:235
-msgid "Print the sun position output in shell script style"
+#: ../imagery/i.cluster/main.c:269
+#, c-format
+msgid " Col sampling interval: %d\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:249
-#, fuzzy, c-format
-msgid "Using map center coordinates: %f %f"
-msgstr "출력할 래스터맵"
-#: ../raster/r.sunmask/main.c:256
+#: ../imagery/i.cluster/main.c:278 ../imagery/i.ifft/main.c:142
+#: ../imagery/i.gensigset/read_data.c:22
#, fuzzy
-msgid "Empty east coordinate specified"
+msgid "Reading raster maps..."
msgstr "출력할 래스터맵"
-#: ../raster/r.sunmask/main.c:258
-msgid "Empty north coordinate specified"
+#: ../imagery/i.cluster/main.c:288
+msgid "Out of Memory. Please run again and choose a smaller sample size."
msgstr ""
-#: ../raster/r.sunmask/main.c:277
-msgid "Either define sun position or location/date/time parameters"
+#: ../imagery/i.cluster/main.c:294
+#, c-format
+msgid "Sample size: %d points\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:280
+#: ../imagery/i.cluster/main.c:297
msgid ""
-"Neither sun position nor east/north, date/time/timezone definition are "
-"complete"
+"Not enough sample points. Please run again and choose a larger sample size."
msgstr ""
-#: ../raster/r.sunmask/main.c:284
+#: ../imagery/i.cluster/main.c:301
+msgid ""
+"Not enough non-zero sample data points. Check your current region (and mask)."
+msgstr ""
+#: ../imagery/i.cluster/main.c:314
#, c-format
-msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
+msgid ""
+"\n"
+"########## final results #############\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:289
+#: ../imagery/i.cluster/main.c:315
+#, c-format
+msgid "%d classes (convergence=%.1f%%)\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:326
+#, fuzzy, c-format
+msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/main.c:331
+#, c-format
msgid ""
-"Using user defined sun azimuth, altitude settings (ignoring eventual other "
-"values)"
+"\n"
+"\n"
+"#################### CLASSES ####################\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:397
-#, fuzzy
-msgid "Please correct settings"
+#: ../imagery/i.cluster/main.c:332
+#, c-format
+msgid ""
+"\n"
+"%d classes, %.2f%% points stable\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:334
+#, c-format
+msgid ""
+"\n"
+"######## CLUSTER END (%s) ########\n"
+msgstr ""
+#: ../imagery/i.cluster/main.c:337 ../misc/m.nviz.image/main.c:241
+#, fuzzy, c-format
+msgid "File <%s> created."
msgstr "출력할 래스터맵"
-#: ../raster/r.sunmask/main.c:411
+#: ../imagery/i.cluster/checkpt.c:16
#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
+msgid "using seed means (%d files)\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:415
+#: ../imagery/i.cluster/checkpt.c:28
#, c-format
-msgid "Time (%02i:%02i:%02i) is before sunrise"
+msgid ""
+"\n"
+"######## iteration %d ###########\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:418 ../raster/r.sunmask/main.c:428
-msgid "Nothing to calculate. Please verify settings."
+#: ../imagery/i.cluster/checkpt.c:30
+#, c-format
+msgid "%d classes, %.2f%% points stable\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:422
+#: ../imagery/i.cluster/checkpt.c:40
#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
+msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
msgstr ""
-#: ../raster/r.sunmask/main.c:426
+#: ../imagery/i.cluster/print4.c:16
#, c-format
-msgid "Time (%02i:%02i:%02i) is after sunset"
+msgid "class centroids (sum/count=mean)\n"
msgstr ""
-#: ../raster/r.sunmask/main.c:437
-msgid "You already know the sun position"
+#: ../imagery/i.cluster/print4.c:18
+#, c-format
+msgid "band %d"
msgstr ""
-#: ../raster/r.sunmask/main.c:442 ../vector/v.colors/main.c:200
+#: ../imagery/i.cluster/open_files.c:34
#, fuzzy, c-format
-msgid "Option <%s> required"
+msgid "Raster map <%s> do not exists in subgroup <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunmask/main.c:454
+#: ../imagery/i.cluster/open_files.c:39
+#, fuzzy
+msgid "No raster maps found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/open_files.c:43
#, fuzzy, c-format
-msgid "Unable to open range file for raster map <%s>"
+msgid "Subgroup <%s> doesn't have any raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.sunmask/main.c:470
-msgid "Calculating shadows from DEM..."
+#: ../imagery/i.cluster/open_files.c:46
+#, c-format
+msgid "Subgroup <%s> only has 1 raster map"
msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:66
+#: ../imagery/i.cluster/open_files.c:47
+msgid "Subgroup must have at least 2 raster maps"
+msgstr ""
+#: ../imagery/i.cluster/open_files.c:64
+#, fuzzy, c-format
+msgid "Unable to open seed signature file <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/print3.c:16
+#, c-format
msgid ""
-"Unable to calculate sun position in un-projected locations. Specify "
-"sunposition directly."
+"\n"
+"initial means for each band\n"
+"\n"
msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:88
+#: ../imagery/i.cluster/print3.c:19
#, c-format
+msgid "class %-3d "
+msgstr ""
+#: ../imagery/i.cluster/print2.c:18
+#, c-format
msgid ""
-"Specified point %f, %f outside of current region, is that intended? Anyway, "
-"it will be used."
+"\n"
+"class means/stddev for each band\n"
+"\n"
msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
-#, fuzzy
-msgid "Unable to get projection info of current location"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/print2.c:22
+#, c-format
+msgid "class %d (%d)\n"
+msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
-#, fuzzy
-msgid "Unable to get projection units of current location"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/print2.c:23
+#, c-format
+msgid " means "
+msgstr ""
-#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
-#, fuzzy
-msgid "Unable to get projection key values of current location"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.cluster/print2.c:28
+#, c-format
+msgid " stddev"
+msgstr ""
-#: ../raster/r.latlong/main.c:57
-msgid "latitude"
+#: ../imagery/i.eb.eta/main.c:45
+msgid "actual evapotranspiration"
msgstr ""
-#: ../raster/r.latlong/main.c:58
-msgid "longitude"
+#: ../imagery/i.eb.eta/main.c:48
+msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
msgstr ""
-#: ../raster/r.latlong/main.c:59 ../raster/r.proj/main.c:145
-#: ../general/g.setproj/main.c:79 ../general/g.proj/main.c:64
-#: ../locale/scriptstrings/m.proj_to_translate.c:3 ../vector/v.proj/main.c:67
+#: ../imagery/i.eb.eta/main.c:53
#, fuzzy
-msgid "projection"
+msgid "Name of the diurnal Net Radiation map [W/m2]"
msgstr "출력할 래스터맵"
-#: ../raster/r.latlong/main.c:60
+#: ../imagery/i.eb.eta/main.c:58
#, fuzzy
-msgid "Creates a latitude/longitude raster map."
+msgid "Name of the evaporative fraction map [-]"
msgstr "출력할 래스터맵"
-#: ../raster/r.latlong/main.c:66
+#: ../imagery/i.eb.eta/main.c:63
#, fuzzy
-msgid "Name for output latitude or longitude raster map"
+msgid "Name of the surface skin temperature [K]"
msgstr "출력할 래스터맵"
-#: ../raster/r.latlong/main.c:70
-msgid "Longitude output"
-msgstr ""
+#: ../imagery/i.eb.eta/main.c:68
+#, fuzzy
+msgid "Name of the output actual evapotranspiration layer [mm/d]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.latlong/main.c:114 ../raster/r.horizon/main.c:505
-#: ../raster/r.sun/main.c:744 ../display/d.grid/plot.c:356
-#: ../display/d.grid/plot.c:383 ../display/d.where/main.c:120
-#: ../display/d.where/main.c:146 ../ps/ps.map/do_geogrid.c:278
-msgid "Unable to set up lat/long projection parameters"
+#: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
+msgid "Fast Fourier Transform"
msgstr ""
-#: ../raster/r.latlong/main.c:133 ../raster/r.horizon/main.c:803
-#: ../raster/r.horizon/main.c:821 ../display/d.grid/plot.c:201
-#: ../display/d.grid/plot.c:207 ../display/d.grid/plot.c:260
-#: ../display/d.grid/plot.c:266 ../display/d.grid/plot.c:430
-#: ../display/d.grid/plot.c:446 ../display/d.grid/plot.c:463
-#: ../display/d.grid/plot.c:480 ../ps/ps.map/do_geogrid.c:86
-#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
-#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
-#: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
-#: ../ps/ps.map/do_geogrid.c:322 ../ps/ps.map/do_geogrid.c:339
-#: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:412
-#: ../ps/ps.map/do_geogrid.c:418 ../ps/ps.map/do_geogrid.c:422
-#: ../ps/ps.map/do_geogrid.c:430 ../ps/ps.map/do_geogrid.c:434
-msgid "Error in pj_do_proj"
+#: ../imagery/i.fft/main.c:82
+msgid "Fast Fourier Transform (FFT) for image processing."
msgstr ""
-#: ../raster/r.in.gridatb/main.c:48
+#: ../imagery/i.fft/main.c:91
#, fuzzy
-msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgid "Name for output real part arrays stored as raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gridatb/main.c:51
-msgid "GRIDATB i/o map file"
-msgstr ""
+#: ../imagery/i.fft/main.c:95
+#, fuzzy
+msgid "Name for output imaginary part arrays stored as raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.in.gridatb/main.c:68
-#, c-format
-msgid "File not found: %s"
+#: ../imagery/i.fft/main.c:107
+msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:35
-msgid "Setting window header failed"
-msgstr ""
+#: ../imagery/i.fft/main.c:130
+#, fuzzy, c-format
+msgid "Reading the raster map <%s>..."
+msgstr "출력할 래스터맵"
-#: ../raster/r.in.gridatb/file_io.c:38
-msgid "Rows changed"
+#: ../imagery/i.fft/main.c:146
+msgid "Starting FFT..."
msgstr ""
-#: ../raster/r.in.gridatb/file_io.c:41
-msgid "Cols changed"
+#: ../imagery/i.fft/main.c:167 ../imagery/i.ifft/main.c:192
+msgid "Rotating data..."
msgstr ""
-#: ../raster/r.in.poly/poly2rast.c:77 ../raster/r.carve/raster.c:33
-#: ../vector/v.to.rast/vect2rast.c:181
+#: ../imagery/i.fft/main.c:175
#, fuzzy
-msgid "Writing raster map..."
+msgid "Writing transformed data..."
msgstr "출력할 래스터맵"
-#: ../raster/r.in.poly/main.c:32
-msgid "Creates raster maps from ASCII polygon/line/point data files."
+#: ../imagery/i.fft/main.c:201
+msgid " "
msgstr ""
-#: ../raster/r.in.poly/main.c:36
+#: ../imagery/i.smap/parse.c:21
+msgid "Generated by i.gensigset"
+msgstr ""
+#: ../imagery/i.smap/parse.c:33
#, fuzzy
-msgid "Name of input file; or \"-\" to read from stdin"
+msgid "Name for output raster map holding goodness of fit (lower is better)"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.poly/main.c:51 ../vector/v.to.rast/main.c:116
-msgid "Number of rows to hold in memory"
+#: ../imagery/i.smap/parse.c:37
+msgid "Size of submatrix to process at one time"
msgstr ""
-#: ../raster/r.in.poly/main.c:60
-msgid "Minimum number of rows to hold in memory is 1"
+#: ../imagery/i.smap/parse.c:45
+msgid "Use maximum likelihood estimation (instead of smap)"
msgstr ""
-#: ../raster/r.in.poly/get_item.c:76
+#: ../imagery/i.smap/read_sig.c:17 ../imagery/i.smap/openfiles.c:22
#, fuzzy, c-format
-msgid "Illegal coordinate <%s, %s>, skipping."
+msgid "Subgroup <%s> in group <%s> contains no raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.poly/get_item.c:81
+#: ../imagery/i.smap/read_sig.c:27
#, fuzzy, c-format
-msgid "Illegal north coordinate <%s>, skipping."
+msgid "Signature file <%s> is invalid"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.poly/get_item.c:86
+#: ../imagery/i.smap/read_sig.c:30
#, fuzzy, c-format
-msgid "Illegal east coordinate <%s>, skipping."
+msgid "Signature file <%s> is empty"
msgstr "출력할 래스터맵"
-#: ../raster/r.what.color/main.c:89 ../raster/r.what/main.c:99
-#: ../locale/scriptstrings/i.spectral_to_translate.c:3
-#: ../display/d.where/main.c:46 ../display/d.what.rast/main.c:52
-#: ../display/d.what.vect/main.c:59 ../vector/v.what.rast3/main.c:68
-#: ../vector/v.what/main.c:61 ../vector/v.what.rast/main.c:75
+#: ../imagery/i.smap/interp.c:68 ../raster/r.stream.extract/load.c:44
+#: ../raster/r.stream.extract/load.c:53 ../raster/r.texture/h_measure.c:594
+#: ../raster/r.cost/main.c:670 ../raster/r.walk/main.c:822
+msgid "Unable to allocate memory"
+msgstr ""
+#: ../imagery/i.smap/interp.c:233
+msgid "Invalid parameter values"
+msgstr ""
+#: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:36
#, fuzzy
-msgid "querying"
+msgid "segmentation"
msgstr "출력할 래스터맵"
-#: ../raster/r.what.color/main.c:90 ../raster/r.colors/edit_colors.c:67
-#: ../raster/r.colors.out/raster3d_main.c:47
-#: ../raster/r.colors.out/raster_main.c:46
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
-#: ../display/d.colors/main.c:41 ../vector/v.colors.out/main.c:50
-#: ../vector/v.colors/main.c:56
+#: ../imagery/i.smap/main.c:42 ../imagery/i.gensigset/main.c:43
+msgid "SMAP"
+msgstr ""
+#: ../imagery/i.smap/main.c:44
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../imagery/i.smap/write_img.c:15
#, fuzzy
-msgid "color table"
+msgid "Writing output raster map(s)..."
msgstr "출력할 래스터맵"
-#: ../raster/r.what.color/main.c:91
-msgid "Queries colors for a raster map layer."
+#: ../imagery/i.smap/model.c:43
+#, c-format
+msgid "Nonsymetric covariance for class %d subclass %d"
msgstr ""
-#: ../raster/r.what.color/main.c:99
+#: ../imagery/i.smap/model.c:55
+#, c-format
+msgid "Nonpositive eigenvalues for class %d subclass %d"
+msgstr ""
+#: ../imagery/i.smap/multialloc.c:115 ../raster3d/r3.to.rast/main.c:295
+#: ../raster/r.stream.extract/cseg.c:51 ../raster/r.stream.extract/bseg.c:50
+#: ../raster/r.stream.extract/dseg.c:51 ../raster/r.stream.extract/seg.c:55
+#: ../raster/r.li/r.li.daemon/list.c:49 ../raster/r.to.rast3/main.c:244
+#: ../vector/v.net.allpairs/main.c:200
+#: ../vector/v.generalize/simplification.c:33
+#: ../vector/v.generalize/simplification.c:40
+#: ../vector/v.generalize/simplification.c:306
+#: ../vector/v.generalize/simplification.c:314
+#: ../vector/v.generalize/simplification.c:338
+#: ../vector/v.generalize/smoothing.c:144
+#: ../vector/v.generalize/smoothing.c:231
+#: ../vector/v.generalize/smoothing.c:374
+#: ../vector/v.generalize/smoothing.c:528
+#: ../vector/v.generalize/smoothing.c:574
+#: ../vector/v.generalize/smoothing.c:578
+#: ../vector/v.generalize/smoothing.c:582
+#: ../vector/v.generalize/smoothing.c:586
+#: ../vector/v.generalize/smoothing.c:590
+#: ../vector/v.generalize/smoothing.c:594
+#: ../vector/v.generalize/smoothing.c:598 ../vector/v.generalize/matrix.c:144
+#: ../vector/v.generalize/network.c:96 ../vector/v.generalize/network.c:131
+#: ../vector/v.net.timetable/main.c:389 ../vector/v.net.timetable/main.c:399
+#: ../vector/v.mapcalc/list.c:55 ../vector/v.mapcalc/list.c:502
+#: ../vector/v.surf.rst/main.c:803 ../vector/v.net.flow/main.c:231
+#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
+#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
+#: ../vector/v.net.centrality/main.c:316 ../vector/v.net.components/main.c:169
+#: ../vector/v.net.distance/main.c:204 ../vector/v.mkgrid/write_grid.c:134
+#: ../vector/v.net.connectivity/main.c:186
+#: ../vector/v.net.connectivity/main.c:202 ../vector/v.kcv/main.c:231
+#: ../db/drivers/postgres/listdb.c:79 ../db/drivers/postgres/listtab.c:92
+#: ../db/drivers/sqlite/listdb.c:134
+msgid "Out of memory"
+msgstr ""
+#: ../imagery/i.smap/segment.c:67
#, fuzzy
-msgid "Name of existing raster map to query colors"
+msgid "Number of classes must be < 256"
msgstr "출력할 래스터맵"
-#: ../raster/r.what.color/main.c:106
-msgid "Values to query colors for"
+#: ../imagery/i.smap/segment.c:102
+#, c-format
+msgid "Processing rows %d-%d (of %d)..."
msgstr ""
-#: ../raster/r.what.color/main.c:113
-msgid "Output format (printf-style)"
+#: ../imagery/i.eb.h_sebal01/main.c:88
+msgid "Computes sensible heat flux iteration SEBAL 01."
msgstr ""
-#: ../raster/r.what.color/main.c:117
-msgid "Read values from stdin"
-msgstr ""
+#: ../imagery/i.eb.h_sebal01/main.c:94
+#, fuzzy
+msgid "Name of instantaneous Net Radiation raster map [W/m2]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.what.color/main.c:123
-msgid "Either \"-i\" or \"value=\" must be given"
+#: ../imagery/i.eb.h_sebal01/main.c:99
+#, fuzzy
+msgid "Name of instantaneous soil heat flux raster map [W/m2]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.h_sebal01/main.c:104
+#, fuzzy
+msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.h_sebal01/main.c:109
+#, fuzzy
+msgid "Name of altitude corrected surface temperature raster map [K]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.eb.h_sebal01/main.c:117
+msgid "Value of the height independent friction velocity (u*) [m/s]"
msgstr ""
-#: ../raster/r.support.stats/main.c:37
-msgid "Update raster map statistics"
+#: ../imagery/i.eb.h_sebal01/main.c:118 ../imagery/i.eb.h_sebal01/main.c:126
+#: ../imagery/i.eb.h_sebal01/main.c:133 ../imagery/i.eb.h_sebal01/main.c:140
+#: ../imagery/i.eb.h_sebal01/main.c:147 ../imagery/i.eb.h_sebal01/main.c:154
+#: ../raster/simwe/r.sim.water/main.c:224
+#: ../raster/simwe/r.sim.water/main.c:232
+#: ../raster/simwe/r.sim.water/main.c:241
+#: ../raster/simwe/r.sim.water/main.c:259
+#: ../raster/simwe/r.sim.water/main.c:269
+#: ../raster/simwe/r.sim.water/main.c:277
+#: ../raster/simwe/r.sim.water/main.c:286
+#: ../raster/simwe/r.sim.sediment/main.c:222
+#: ../raster/simwe/r.sim.sediment/main.c:230
+#: ../raster/simwe/r.sim.sediment/main.c:239
+#: ../raster/simwe/r.sim.sediment/main.c:257 ../vector/v.surf.rst/main.c:156
+#: ../vector/v.surf.rst/main.c:161 ../vector/v.surf.rst/main.c:182
+#: ../vector/v.surf.rst/main.c:254 ../vector/v.surf.rst/main.c:262
+#: ../vector/v.surf.rst/main.c:269 ../vector/v.surf.rst/main.c:277
+#: ../vector/v.surf.rst/main.c:285 ../vector/v.surf.rst/main.c:294
+#: ../vector/v.surf.rst/main.c:302 ../vector/v.surf.rst/main.c:310
+#: ../vector/v.surf.rst/main.c:319 ../vector/v.surf.rst/main.c:327
+#: ../vector/v.surf.rst/main.c:334
+msgid "Parameters"
msgstr ""
-#: ../raster/r.support.stats/main.c:49
-#, fuzzy, c-format
-msgid "Statistics for <%s> updated"
+#: ../imagery/i.eb.h_sebal01/main.c:125
+#, fuzzy
+msgid "Value of the actual vapour pressure (e_act) [KPa]"
msgstr "출력할 래스터맵"
-#: ../raster/r.support.stats/check.c:43
-#, c-format
-msgid "Updating statistics for [%s]..."
+#: ../imagery/i.eb.h_sebal01/main.c:132
+msgid "Row value of the wet pixel"
msgstr ""
-#: ../raster/r.support.stats/check.c:56
-msgid "Updating histogram range..."
+#: ../imagery/i.eb.h_sebal01/main.c:139
+msgid "Column value of the wet pixel"
msgstr ""
-#: ../raster/r.support.stats/check.c:88
-#, c-format
-msgid "Updating the number of categories for [%s]..."
+#: ../imagery/i.eb.h_sebal01/main.c:146
+msgid "Row value of the dry pixel"
msgstr ""
-#: ../raster/r.out.arc/main.c:64
-msgid "Converts a raster map layer into an ESRI ARCGRID file."
+#: ../imagery/i.eb.h_sebal01/main.c:153
+msgid "Column value of the dry pixel"
msgstr ""
-#: ../raster/r.out.arc/main.c:71
+#: ../imagery/i.eb.h_sebal01/main.c:157
#, fuzzy
-msgid "Name for output ARC-GRID file (use out=- for stdout)"
+msgid "Name for output sensible heat flux raster map [W/m2]"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.arc/main.c:78
-msgid "Number of decimal places"
+#: ../imagery/i.eb.h_sebal01/main.c:162
+msgid "Automatic wet/dry pixel (careful!)"
msgstr ""
-#: ../raster/r.out.arc/main.c:82 ../raster/r.out.ascii/main.c:103
-#: ../raster3d/r3.out.ascii/main.c:105
-msgid "Suppress printing of header information"
+#: ../imagery/i.eb.h_sebal01/main.c:167
+msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
msgstr ""
-#: ../raster/r.out.arc/main.c:88
-msgid "List one entry per line instead of full row"
+#: ../imagery/i.eb.h_sebal01/main.c:195
+msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
msgstr ""
-#: ../raster/r.out.arc/main.c:94
-msgid "Use cell center reference in header instead of cell corner"
+#: ../imagery/i.eb.h_sebal01/main.c:198
+msgid "Manual wet/dry pixels in image coordinates"
msgstr ""
-#: ../raster/r.colors/rules.c:40
+#: ../imagery/i.eb.h_sebal01/main.c:199
#, c-format
-msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
+msgid "Wet Pixel=> x:%f y:%f"
msgstr ""
-#: ../raster/r.colors/rules.c:49
+#: ../imagery/i.eb.h_sebal01/main.c:200
#, c-format
-msgid "fp: Data range is %s to %s\n"
+msgid "Dry Pixel=> x:%f y:%f"
msgstr ""
-#: ../raster/r.colors/rules.c:53
+#: ../imagery/i.eb.h_sebal01/main.c:204
+msgid "Automatic mode selected"
+msgstr ""
+#: ../imagery/i.eb.h_sebal01/main.c:206
#, c-format
-msgid "Data range is %ld to %ld\n"
+msgid "Wet Pixel=> row:%.0f col:%.0f"
msgstr ""
-#: ../raster/r.colors/rules.c:64
+#: ../imagery/i.eb.h_sebal01/main.c:207
#, c-format
+msgid "Dry Pixel=> row:%.0f col:%.0f"
+msgstr ""
+#: ../imagery/i.eb.h_sebal01/main.c:212
+#, fuzzy, c-format
+msgid "<%s> is an illegal name"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rgb.his/main.c:52
msgid ""
-"Your color rules do not cover the whole range of data!\n"
-" (rules %f to %f but data %f to %f)"
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
msgstr ""
-#: ../raster/r.colors/rules.c:104 ../raster/r.reclass/parse.c:41
+#: ../imagery/i.rgb.his/main.c:58
+#, fuzzy
+msgid "Name of input raster map (red)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rgb.his/main.c:62
+#, fuzzy
+msgid "Name of input raster map (green)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rgb.his/main.c:66
+#, fuzzy
+msgid "Name of input raster map (blue)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rgb.his/main.c:70
+#, fuzzy
+msgid "Name for output raster map (hue)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rgb.his/main.c:74
+#, fuzzy
+msgid "Name for output raster map (intensity)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rgb.his/main.c:78
+#, fuzzy
+msgid "Name for output raster map (saturation)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.find/main.c:63
#, c-format
-msgid "Enter a rule in one of these formats:\n"
+msgid "usage: %s location mapset element file."
msgstr ""
-#: ../raster/r.colors/rules.c:105
-#, c-format
-msgid " val color\n"
+#: ../imagery/i.find/main.c:83
+msgid "Unable to open temp file."
msgstr ""
-#: ../raster/r.colors/rules.c:106
-#, c-format
-msgid " n%% color\n"
+#: ../imagery/i.pca/support.c:50
+msgid "Eigen values, (vectors), and [percent importance]:"
msgstr ""
-#: ../raster/r.colors/rules.c:107
-#, c-format
-msgid " nv color\n"
+#: ../imagery/i.pca/main.c:74
+#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
+msgid "PCA"
msgstr ""
-#: ../raster/r.colors/rules.c:108
-#, c-format
-msgid " default color\n"
+#: ../imagery/i.pca/main.c:75
+msgid "Principal components analysis (PCA) for image processing."
msgstr ""
-#: ../raster/r.colors/rules.c:109
-#, c-format
-msgid "color can be one of:\n"
+#: ../imagery/i.pca/main.c:81
+#, fuzzy
+msgid "Name of two or more input raster maps or imagery group"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.pca/main.c:86
+msgid "A numerical suffix will be added for each component map"
msgstr ""
-#: ../raster/r.colors/rules.c:111
-#, c-format
-msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
+#: ../imagery/i.pca/main.c:99
+#, fuzzy
+msgid "Rescaling range for output maps"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.pca/main.c:101
+msgid "For no rescaling use 0,0"
msgstr ""
-#: ../raster/r.colors/rules.c:132
-#, c-format
-msgid "bad rule (%s); rule not added"
+#: ../imagery/i.pca/main.c:102
+msgid "Rescale"
msgstr ""
-#: ../raster/r.colors/rules.c:134
+#: ../imagery/i.pca/main.c:111
+msgid "Cumulative percent importance for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:112 ../imagery/i.pca/main.c:123
+#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
+msgid "Filter"
+msgstr ""
+#: ../imagery/i.pca/main.c:116
+msgid "Normalize (center and scale) input maps"
+msgstr ""
+#: ../imagery/i.pca/main.c:117
+msgid "Default: center only"
+msgstr ""
+#: ../imagery/i.pca/main.c:121
+#, fuzzy
+msgid "Output will be filtered input bands"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.pca/main.c:122
+msgid "Applies inverse PCA after PCA"
+msgstr ""
+#: ../imagery/i.pca/main.c:157
+msgid "Sorry, at least 2 input bands must be provided"
+msgstr ""
+#: ../imagery/i.pca/main.c:172
#, c-format
-msgid "bad rule (%s): [%s]"
+msgid "'%s' must be positive"
msgstr ""
-#: ../raster/r.colors/stats.c:39
+#: ../imagery/i.pca/main.c:174
#, fuzzy, c-format
-msgid "(%i/%i) Reading raster map <%s>..."
+msgid "'%s' must be < 100"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/stats.c:73
-msgid "Unable to use logarithmic scaling if range includes zero"
+#: ../imagery/i.pca/main.c:200 ../raster/r.covar/main.c:110
+msgid "No non-null values"
msgstr ""
-#: ../raster/r.colors/stats.c:118
-msgid "Error opening 3d raster map"
+#: ../imagery/i.pca/main.c:236
+msgid "Not enough principal components left for filtering"
msgstr ""
-#: ../raster/r.colors/stats.c:125
+#: ../imagery/i.pca/main.c:238
+#, c-format
+msgid "Using %d of %d principal components for filtering"
+msgstr ""
+#: ../imagery/i.pca/main.c:300
+msgid "Scale range length should be > 0. Using default values: 0,255."
+msgstr ""
+#: ../imagery/i.pca/main.c:346
+#, fuzzy
+msgid "Computing covariance matrix..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.pca/main.c:459
#, fuzzy, c-format
-msgid "(%i/%i) Reading map <%s>..."
+msgid "Rescaling to range %d,%d..."
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:59 ../raster/r.to.rast3elev/main.c:363
-#: ../raster/r.colors.out/raster3d_main.c:46
-#: ../raster/r.univar/r3.univar_main.c:98 ../misc/m.nviz.image/main.c:54
-#: ../misc/m.nviz.script/main.c:72
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
-#: ../raster3d/r3.info/r3.info.main.c:75 ../raster3d/r3.cross.rast/main.c:228
-#: ../raster3d/r3.in.bin/main.c:252 ../raster3d/r3.stats/main.c:568
-#: ../raster3d/r3.in.ascii/main.c:316 ../raster3d/r3.out.vtk/main.c:376
-#: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.out.v5d/main.c:283
-#: ../raster3d/r3.out.bin/main.c:205 ../raster3d/r3.neighbors/main.c:208
-#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.retile/main.c:96
-#: ../raster3d/r3.out.ascii/main.c:305 ../raster3d/r3.support/main.c:49
-#: ../raster3d/r3.to.rast/main.c:206 ../raster3d/r3.gwflow/main.c:159
-#: ../raster3d/r3.in.v5d/main.c:192 ../raster3d/r3.mask/main.c:132
-#: ../raster3d/r3.null/main.c:185
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:43
+#: ../imagery/i.pca/main.c:467
#, fuzzy
-msgid "raster3d"
+msgid "Calculating principal components..."
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:61
+#: ../imagery/i.emissivity/main.c:46
+msgid "land flux"
+msgstr ""
+#: ../imagery/i.emissivity/main.c:49
+msgid "Computes emissivity from NDVI, generic method for sparse land."
+msgstr ""
+#: ../imagery/i.emissivity/main.c:53
#, fuzzy
-msgid "Creates/modifies the color table associated with a 3D raster map."
+msgid "Name of the NDVI map [-]"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:65
+#: ../imagery/i.emissivity/main.c:56
#, fuzzy
-msgid "Creates/modifies the color table associated with a raster map."
+msgid "Name of the output emissivity layer"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
-msgid "Map"
+#: ../imagery/i.vpoints/main.c:95 ../imagery/i.points/main.c:97
+#: ../raster/r.circle/main.c:52 ../raster/r.to.vect/main.c:72
+#: ../raster/r.thin/main.c:57 ../raster/r.patch/main.c:53
+#: ../vector/v.edit/main.c:56 ../vector/v.drape/main.c:57
+#: ../vector/v.split/main.c:56 ../vector/v.to.points/main.c:54
+#: ../vector/v.type/main.c:40 ../vector/v.voronoi/main.c:124
+#: ../vector/v.overlay/main.c:63 ../vector/v.build.polylines/main.c:114
+#: ../vector/v.select/main.c:48 ../vector/v.parallel/main.c:50
+#: ../vector/v.buffer/main.c:224 ../vector/v.clean/main.c:53
+#: ../vector/v.hull/main.c:53 ../vector/v.patch/main.c:69
+#: ../vector/v.extrude/main.c:68 ../vector/v.build/main.c:38
+#: ../vector/v.perturb/main.c:62 ../vector/v.segment/main.c:61
+#: ../vector/v.to.3d/main.c:37 ../vector/v.in.region/main.c:42
+#: ../vector/v.delaunay/main.c:86 ../vector/v.mkgrid/main.c:67
+#: ../display/d.measure/main.c:47
+#: ../locale/scriptstrings/v.report_to_translate.c:3
+#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
+msgid "geometry"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:81
-#, fuzzy
-msgid "Input file with one map name per line"
-msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:83
+#: ../imagery/i.vpoints/main.c:97
msgid ""
-"Input map names can be defined in an input file in case a large amount of "
-"maps must be specified. This option is mutual exclusive to the map option."
+"Set registration points for an imagery group from a vector map or keyboard "
+"entry."
msgstr ""
-#: ../raster/r.colors/edit_colors.c:96
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
-#: ../vector/v.colors/main.c:98
+#: ../imagery/i.vpoints/main.c:105 ../imagery/i.points/main.c:106
+msgid "Name of imagery group to be registered"
+msgstr ""
+#: ../imagery/i.vpoints/main.c:128 ../imagery/i.points/main.c:131
+#, c-format
+msgid "[%s] Only local groups may be used"
+msgstr ""
+#: ../imagery/i.vpoints/main.c:137 ../imagery/i.vpoints/main.c:141
+#: ../imagery/i.points/main.c:140 ../imagery/i.points/main.c:144
+#, c-format
+msgid "Group [%s] contains no maps, run i.group"
+msgstr ""
+#: ../imagery/i.vpoints/main.c:256 ../imagery/i.points/main.c:250
+#, c-format
+msgid "ERROR: %s"
+msgstr ""
+#: ../imagery/i.vpoints/main.c:258 ../imagery/i.points/main.c:252
+#, c-format
+msgid "WARNING: %s (click mouse to continue)"
+msgstr ""
+#: ../imagery/i.vpoints/plot.c:56 ../imagery/i.vpoints/plot.c:126
+#: ../display/d.graph/do_graph.c:377
+msgid "Cannot read symbol, cannot display points"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:51
+msgid "soil heat flux"
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:53
+msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../imagery/i.eb.soilheatflux/main.c:58
#, fuzzy
-msgid "Raster map from which to copy color table"
+msgid "Name of Albedo raster map [0.0;1.0]"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:103
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
-#: ../vector/v.colors/main.c:105
+#: ../imagery/i.eb.soilheatflux/main.c:62
#, fuzzy
-msgid "3D raster map from which to copy color table"
+msgid "Name of NDVI raster map [-1.0;+1.0]"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:109
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
-#: ../vector/v.colors/main.c:111
+#: ../imagery/i.eb.soilheatflux/main.c:67
#, fuzzy
-msgid "Path to rules file"
+msgid "Name of Surface temperature raster map [K]"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:110 ../vector/v.colors/main.c:112
+#: ../imagery/i.eb.soilheatflux/main.c:76
#, fuzzy
-msgid "\"-\" to read rules from stdin"
+msgid "Name of time of satellite overpass raster map [local time in UTC]"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:115 ../vector/v.colors/main.c:122
-msgid "Remove existing color table"
+#: ../imagery/i.eb.soilheatflux/main.c:83
+msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:121
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
-#: ../vector/v.colors/main.c:128
-msgid "Only write new color table if one doesn't already exist"
-msgstr ""
+#: ../imagery/i.vi/main.c:90
+#, fuzzy
+msgid "vegetation index"
+msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:126
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
-#: ../vector/v.colors/main.c:132
-msgid "List available rules then exit"
+#: ../imagery/i.vi/main.c:91
+msgid "biophysical parameters"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:132
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
-#: ../vector/v.colors/main.c:138
-msgid "Invert colors"
+#: ../imagery/i.vi/main.c:93
+msgid "Calculates different types of vegetation indices."
msgstr ""
-#: ../raster/r.colors/edit_colors.c:137
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
-#: ../vector/v.colors/main.c:143
-msgid "Logarithmic scaling"
+#: ../imagery/i.vi/main.c:94
+msgid ""
+"Uses red and nir bands mostly, and some indices require additional bands."
msgstr ""
-#: ../raster/r.colors/edit_colors.c:142
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
-#: ../vector/v.colors/main.c:148
-msgid "Logarithmic-absolute scaling"
-msgstr ""
+#: ../imagery/i.vi/main.c:101
+#, fuzzy
+msgid "Name of input red channel surface reflectance map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:147
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
-msgid "Histogram equalization"
+#: ../imagery/i.vi/main.c:102 ../imagery/i.vi/main.c:141
+#: ../imagery/i.vi/main.c:149 ../imagery/i.vi/main.c:157
+#: ../imagery/i.vi/main.c:165 ../imagery/i.vi/main.c:173
+msgid "Range: [0.0;1.0]"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:165 ../raster/r.colors/edit_colors.c:173
-#, c-format
-msgid "Options <%s> and <%s> options are mutually exclusive"
-msgstr ""
-#: ../raster/r.colors/edit_colors.c:169
-#, fuzzy, c-format
-msgid "Options <%s> or <%s> must be specified"
+#: ../imagery/i.vi/main.c:108
+#, fuzzy
+msgid "Type of vegetation index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:182
-#, fuzzy, c-format
-msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
-msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:187
-#, c-format
-msgid "Options <%s>, <%s>, and <%s> options are mutually exclusive"
+#: ../imagery/i.vi/main.c:113
+msgid "Atmospherically Resistant Vegetation Indices"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:192 ../vector/v.colors/main.c:227
-#, c-format
-msgid "Flags -%c and -%c flags are mutually exclusive"
-msgstr ""
+#: ../imagery/i.vi/main.c:114
+#, fuzzy
+msgid "Difference Vegetation Index"
+msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:205 ../raster/r.series.interp/main.c:170
-#, fuzzy, c-format
-msgid "Unable to open %s file <%s>"
+#: ../imagery/i.vi/main.c:115
+#, fuzzy
+msgid "Enhanced Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:248 ../raster/r.colors/edit_colors.c:281
-#, fuzzy, c-format
-msgid "%s map <%s> not found"
+#: ../imagery/i.vi/main.c:116
+#, fuzzy
+msgid "Enhanced Vegetation Index 2"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:254
-#, fuzzy, c-format
-msgid "No %s map name found in input file <%s>"
+#: ../imagery/i.vi/main.c:117
+#, fuzzy
+msgid "Green Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:297
-#, fuzzy, c-format
-msgid "Unable to remove color table of %s map <%s>"
+#: ../imagery/i.vi/main.c:118
+#, fuzzy
+msgid "Green Atmospherically Resistant Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:299
-#, fuzzy, c-format
-msgid "Color table of %s map <%s> not found"
+#: ../imagery/i.vi/main.c:119
+msgid "Global Environmental Monitoring Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:120
+#, fuzzy
+msgid "Infrared Percentage Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:321
-#, fuzzy, c-format
-msgid "Color table exists for %s map <%s>. Exiting."
+#: ../imagery/i.vi/main.c:121
+msgid "Modified Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:122
+msgid "second Modified Soil Adjusted Vegetation Index"
+msgstr ""
+#: ../imagery/i.vi/main.c:123
+#, fuzzy
+msgid "Normalized Difference Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:377
-#, fuzzy, c-format
-msgid "Color table 'random' is not supported for floating point %s map"
+#: ../imagery/i.vi/main.c:124
+#, fuzzy
+msgid "Perpendicular Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:381
-#, fuzzy, c-format
-msgid "Color table 'grey.eq' is not supported for floating point %s map"
+#: ../imagery/i.vi/main.c:125
+#, fuzzy
+msgid "Soil Adjusted Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:387
-#, fuzzy, c-format
-msgid "Color table 'grey.log' is not supported for floating point %s map"
+#: ../imagery/i.vi/main.c:126
+#, fuzzy
+msgid "Simple Ratio"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:395
-#, c-format
-msgid "Unknown color request '%s'"
+#: ../imagery/i.vi/main.c:127
+msgid "Visible Atmospherically Resistant Index"
msgstr ""
-#: ../raster/r.colors/edit_colors.c:405 ../vector/v.colors/make_colors.c:51
-#, fuzzy, c-format
-msgid "Unable to load rules file <%s>"
+#: ../imagery/i.vi/main.c:128
+#, fuzzy
+msgid "Weighted Difference Vegetation Index"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:419
-#: ../raster/r.univar/r3.univar_main.c:148
-#: ../raster/r.univar/r3.univar_main.c:186 ../general/g.region/main.c:485
-#: ../raster3d/r3.cross.rast/main.c:245 ../raster3d/r3.stats/main.c:612
-#: ../raster3d/r3.out.vtk/main.c:142 ../raster3d/r3.out.netcdf/main.c:599
-#: ../raster3d/r3.out.v5d/main.c:306 ../raster3d/r3.out.bin/main.c:299
-#: ../raster3d/r3.neighbors/main.c:225 ../raster3d/r3.retile/main.c:113
-#: ../raster3d/r3.out.ascii/main.c:329 ../raster3d/r3.support/main.c:134
-#: ../raster3d/r3.to.rast/main.c:222 ../raster3d/r3.mask/main.c:57
-#: ../raster3d/r3.null/main.c:102
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:70
-#: ../vector/v.colors/main.c:318
-#, c-format
-msgid "3D raster map <%s> not found"
-msgstr ""
+#: ../imagery/i.vi/main.c:132
+#, fuzzy
+msgid "type"
+msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:422 ../vector/v.colors/main.c:321
-#, fuzzy, c-format
-msgid "Unable to read color table for 3D raster map <%s>"
+#: ../imagery/i.vi/main.c:140
+#, fuzzy
+msgid "Name of input nir channel surface reflectance map"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors/edit_colors.c:466
-#, fuzzy, c-format
-msgid "Color table for %s map <%s> set to '%s'"
+#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
+#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
+#: ../imagery/i.vi/main.c:174 ../vector/v.vol.rst/main.c:257
+#: ../vector/v.vol.rst/main.c:306
+#, fuzzy
+msgid "Optional inputs"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.ascii/main.c:74
+#: ../imagery/i.vi/main.c:148
#, fuzzy
-msgid "Converts a GRASS ASCII raster file to binary raster map."
+msgid "Name of input green channel surface reflectance map"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.ascii/main.c:78 ../raster3d/r3.in.ascii/main.c:83
-#: ../vector/v.in.ascii/main.c:57
+#: ../imagery/i.vi/main.c:156
#, fuzzy
-msgid "Name of input file to be imported"
+msgid "Name of input blue channel surface reflectance map"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.ascii/main.c:79 ../general/g.proj/main.c:140
-#: ../general/g.proj/main.c:149 ../db/db.select/main.c:207
-#: ../db/db.execute/main.c:139 ../vector/v.segment/main.c:75
+#: ../imagery/i.vi/main.c:164
#, fuzzy
-msgid "'-' for standard input"
+msgid "Name of input 5th channel surface reflectance map"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.ascii/main.c:89
-msgid "Default: CELL for integer values, DCELL for floating-point values"
+#: ../imagery/i.vi/main.c:172
+#, fuzzy
+msgid "Name of input 7th channel surface reflectance map"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.vi/main.c:180
+msgid "Value of the slope of the soil line (MSAVI2 only)"
msgstr ""
-#: ../raster/r.in.ascii/main.c:101 ../raster/r.in.ascii/main.c:110
+#: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
+#: ../imagery/i.vi/main.c:195
#, fuzzy
-msgid "Default: read from header"
+msgid "MSAVI2 seetings"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.ascii/main.c:111
-msgid "String representing NULL value data cell"
+#: ../imagery/i.vi/main.c:187
+msgid "Value of the intercept of the soil line (MSAVI2 only)"
msgstr ""
-#: ../raster/r.in.ascii/main.c:112
-msgid "NULL data"
+#: ../imagery/i.vi/main.c:194
+msgid "Value of the factor of reduction of soil noise (MSAVI2 only)"
msgstr ""
-#: ../raster/r.in.ascii/main.c:117
-msgid "SURFER (Golden Software) ASCII file will be imported"
+#: ../imagery/i.vi/main.c:201
+msgid "Maximum bits for digital numbers"
msgstr ""
-#: ../raster/r.in.ascii/main.c:136
-#, c-format
-msgid "Wrong entry for multiplier: %s"
+#: ../imagery/i.vi/main.c:202
+msgid ""
+"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
+"for Landsat -> [0-255])"
msgstr ""
-#: ../raster/r.in.ascii/main.c:161
-msgid "Unable to read input from stdin"
+#: ../imagery/i.vi/main.c:227
+msgid "sr index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/main.c:168
-#, c-format
-msgid "Unable to read input from <%s>"
+#: ../imagery/i.vi/main.c:230
+msgid "ndvi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/main.c:283
-msgid "Unable to write to file"
+#: ../imagery/i.vi/main.c:233
+msgid "ipvi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:35
-msgid "input file is not a Surfer ascii grid file"
+#: ../imagery/i.vi/main.c:236
+msgid "dvi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:41
-msgid "error reading the column and row dimension from the Surfer grid file"
+#: ../imagery/i.vi/main.c:239
+msgid "pvi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:47
-msgid "error reading the X range from the Surfer grid file"
+#: ../imagery/i.vi/main.c:242
+msgid "wdvi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:53
-msgid "error reading the Y range from the Surfer grid file"
+#: ../imagery/i.vi/main.c:245
+msgid "savi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:59
-msgid "error reading the Z range from the Surfer grid file"
+#: ../imagery/i.vi/main.c:248
+msgid "msavi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:105
-msgid "error getting file position"
+#: ../imagery/i.vi/main.c:253
+msgid ""
+"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:164
-msgid "illegal type field: using type int"
+#: ../imagery/i.vi/main.c:256
+msgid "gemi index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:169
-msgid "ignoring type filed in header, type is set on command line"
+#: ../imagery/i.vi/main.c:260
+msgid "arvi index requires blue, red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:176
-msgid "illegal multiplier field: using 1.0"
+#: ../imagery/i.vi/main.c:264
+msgid "evi index requires blue, red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:181
-msgid "ignoring multiplier filed in header, multiplier is set on command line"
+#: ../imagery/i.vi/main.c:267
+msgid "evi2 index requires red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:189
-msgid "ignoring null filed in header, null string is set on command line"
+#: ../imagery/i.vi/main.c:271
+msgid "vari index requires blue, green and red maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:218
-msgid "error in ascii data format"
+#: ../imagery/i.vi/main.c:275
+msgid "gari index requires blue, green, red and nir maps"
msgstr ""
-#: ../raster/r.in.ascii/gethead.c:253
-#, c-format
-msgid "Illegal \"%s\" value in header: %s"
+#: ../imagery/i.vi/main.c:280
+msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
msgstr ""
-#: ../raster/r.stream.segment/io.c:444 ../raster/r.stream.stats/io.c:444
-#, c-format
-msgid "seg_read: Cannot segment put row %d for map %s"
+#: ../imagery/i.biomass/main.c:51
+msgid "biomass"
msgstr ""
-#: ../raster/r.stream.segment/main.c:56
-msgid ""
-"Divides network into near straight-line segments and calculate its order."
+#: ../imagery/i.biomass/main.c:53
+msgid "yield"
msgstr ""
-#: ../raster/r.stream.segment/main.c:60
-msgid "stream divide"
+#: ../imagery/i.biomass/main.c:55
+msgid "Computes biomass growth, precursor of crop yield calculation."
msgstr ""
-#: ../raster/r.stream.segment/main.c:68 ../raster/r.stream.distance/main.c:64
-#: ../raster/r.stream.channel/main.c:68 ../raster/r.stream.slope/main.c:80
+#: ../imagery/i.biomass/main.c:60
#, fuzzy
-msgid "Name for input raster map with flow direction"
+msgid "Name of fPAR raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:75 ../raster/r.stream.segment/main.c:80
+#: ../imagery/i.biomass/main.c:65
#, fuzzy
-msgid "Name for output vector map to write segment attributes"
+msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:84
+#: ../imagery/i.biomass/main.c:69
#, fuzzy
-msgid "Search length to calculate direction"
+msgid "Name of degree latitude raster map [dd.ddd]"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:85 ../raster/r.stream.segment/main.c:99
-#: ../raster/r.stream.extract/main.c:102
+#: ../imagery/i.biomass/main.c:73
#, fuzzy
-msgid "Must be > 0"
+msgid "Name of Day of Year raster map [1-366]"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:91
-msgid "Skip segments shorter than"
-msgstr ""
+#: ../imagery/i.biomass/main.c:78
+#, fuzzy
+msgid "Name of single-way transmissivity raster map [0.0-1.0]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:92
+#: ../imagery/i.biomass/main.c:83
#, fuzzy
-msgid "Must be >= 0"
+msgid "Value of water availability raster map [0.0-1.0]"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:98
-msgid "Max angle (degrees) between stream segments"
+#: ../imagery/i.biomass/main.c:87
+#, fuzzy
+msgid "Name for output daily biomass growth raster map [kg/ha/d]"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.points/main.c:99
+msgid "Mark ground control points on image to be rectified."
msgstr ""
-#: ../raster/r.stream.segment/main.c:107 ../raster/r.stream.stats/main.c:72
-#: ../raster/r.stream.distance/main.c:94 ../raster/r.stream.channel/main.c:108
-#: ../raster/r.stream.order/main.c:107
-msgid "Max memory used in memory swap mode (MB)"
+#: ../imagery/i.ifft/main.c:81
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
msgstr ""
-#: ../raster/r.stream.segment/main.c:108 ../raster/r.stream.segment/main.c:118
+#: ../imagery/i.ifft/main.c:86
#, fuzzy
-msgid "Memory setings"
+msgid "Name of input raster map (image fft, real part)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:113
-msgid "Output angles in radians (default: degrees)"
+#: ../imagery/i.ifft/main.c:90
+#, fuzzy
+msgid "Name of input raster map (image fft, imaginary part"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ifft/main.c:94
+#: ../locale/scriptstrings/v.krige_to_translate.c:8
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
+#, fuzzy
+msgid "Name for output raster map"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ifft/main.c:116
+msgid "The real and imaginary original windows did not match"
msgstr ""
-#: ../raster/r.stream.segment/main.c:117 ../raster/r.stream.stats/main.c:82
-#: ../raster/r.stream.distance/main.c:114
-#: ../raster/r.stream.channel/main.c:126 ../raster/r.stream.order/main.c:117
-msgid "Use memory swap (operation is slow)"
+#: ../imagery/i.ifft/main.c:158
+#, fuzzy
+msgid "Masking raster maps..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.ifft/main.c:201
+msgid "Starting Inverse FFT..."
msgstr ""
-#: ../raster/r.stream.segment/main.c:130
+#: ../imagery/i.ifft/main.c:208 ../raster/r.stream.distance/io.c:195
+#: ../raster/r.stream.distance/io.c:498 ../raster/r.drain/main.c:519
+#: ../raster/r.stream.snap/io.c:195 ../raster/r.stream.snap/io.c:498
+#: ../raster/r.stream.channel/io.c:195 ../raster/r.stream.channel/io.c:498
+#: ../raster/r.composite/main.c:191 ../raster/r.random.surface/save.c:98
+#: ../raster/r.random.cells/indep.c:134 ../raster/r.stream.segment/io.c:195
+#: ../raster/r.stream.segment/io.c:498 ../raster/r.stream.order/io.c:195
+#: ../raster/r.stream.order/io.c:498 ../raster/r.stream.stats/io.c:195
+#: ../raster/r.stream.stats/io.c:498
+#, fuzzy, c-format
+msgid "Writing raster map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.cca/transform.c:24
+msgid "Unable to allocate cell buffers."
+msgstr ""
+#: ../imagery/i.cca/transform.c:58
+msgid "Transform completed.\n"
+msgstr ""
+#: ../imagery/i.cca/main.c:85 ../raster3d/r3.stats/main.c:569
+#: ../raster3d/r3.neighbors/main.c:211 ../raster/r.statistics/main.c:56
+#: ../raster/r.surf.area/main.c:78 ../raster/r.neighbors/main.c:142
+#: ../raster/r.cross/main.c:70 ../raster/r.quantile/main.c:257
+#: ../raster/r.univar/r.univar_main.c:101
+#: ../raster/r.univar/r3.univar_main.c:99 ../raster/r.kappa/main.c:69
+#: ../raster/r.clump/main.c:50 ../raster/r.coin/main.c:67
+#: ../raster/r.stats/main.c:106 ../raster/r.quant/main.c:49
+#: ../raster/r.regression.multi/main.c:129
+#: ../raster/r.regression.line/main.c:47 ../raster/r.mode/main.c:56
+#: ../raster/r.stats.zonal/main.c:102 ../raster/r.support.stats/main.c:39
+#: ../raster/r.texture/main.c:103 ../raster/r.mfilter/main.c:58
+#: ../raster/r.covar/main.c:52 ../raster/r.report/main.c:68
+#: ../raster/r.stats.quantile/main.c:390 ../vector/v.univar/main.c:93
+#: ../vector/v.class/main.c:48 ../vector/v.neighbors/main.c:51
+#: ../vector/v.random/main.c:114 ../vector/v.normal/main.c:75
+#: ../vector/v.outlier/main.c:70 ../vector/v.perturb/main.c:63
+#: ../vector/v.kcv/main.c:63 ../vector/v.qcount/main.c:61
+#: ../display/d.histogram/main.c:86
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.report_to_translate.c:4
+#: ../locale/scriptstrings/i.oif_to_translate.c:4
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:3
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:3
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:3
+#: ../locale/scriptstrings/d.correlate_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:3
#, fuzzy
-msgid "Search's length must be > 0"
+msgid "statistics"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:132
+#: ../imagery/i.cca/main.c:88
+msgid "Canonical components analysis (CCA) program for image processing."
+msgstr ""
+#: ../imagery/i.cca/main.c:102
#, fuzzy
-msgid "Threshold must be between 0 and 180"
+msgid "File containing spectral signatures"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:134
+#: ../imagery/i.cca/main.c:105
+msgid "Output raster map prefix name"
+msgstr ""
+#: ../imagery/i.cca/main.c:113
+msgid "Unknown imagery group."
+msgstr ""
+#: ../imagery/i.cca/main.c:116
+msgid "Unable to find subgroup reference information."
+msgstr ""
+#: ../imagery/i.cca/main.c:122
+msgid "Unable to open the signature file"
+msgstr ""
+#: ../imagery/i.cca/main.c:126
+msgid "Error while reading the signatures file."
+msgstr ""
+#: ../imagery/i.cca/main.c:131
+msgid "Need at least two signatures in signature file."
+msgstr ""
+#: ../imagery/i.cca/main.c:225
+#, c-format
+msgid "The output cell map <%s.%d> has values outside the 0-255 range."
+msgstr ""
+#: ../imagery/i.group/main.c:55
+msgid "Creates, edits, and lists groups of imagery data."
+msgstr ""
+#: ../imagery/i.group/main.c:59
+msgid "Name of imagery group"
+msgstr ""
+#: ../imagery/i.group/main.c:63
#, fuzzy
-msgid "Segment's length must be >= 0"
+msgid "Name of imagery subgroup"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:149 ../raster/r.stream.stats/main.c:117
-#: ../raster/r.stream.order/main.c:170
+#: ../imagery/i.group/main.c:67
#, fuzzy
-msgid "All in RAM calculation..."
+msgid "Name of raster map(s) to include in group"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:187 ../raster/r.stream.stats/main.c:155
-#: ../raster/r.stream.order/main.c:224
+#: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
+msgid "Maps"
+msgstr ""
+#: ../imagery/i.group/main.c:73
+msgid "Remove selected files from specified group or subgroup"
+msgstr ""
+#: ../imagery/i.group/main.c:78
+msgid "List files from specified (sub)group"
+msgstr ""
+#: ../imagery/i.group/main.c:83
+msgid "List subgroups from specified group"
+msgstr ""
+#: ../imagery/i.group/main.c:109
#, fuzzy
-msgid "Memory swap calculation (may take some time)..."
+msgid "No input raster map(s) specified"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/main.c:238
+#: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
#, fuzzy
-msgid "Creating sectors and calculating attributes..."
+msgid "Specified group does not exist in current mapset"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:69
-#: ../raster/r.stream.segment/stream_vector.c:221
-#: ../raster/r.stream.extract/close.c:171 ../db/db.select/main.c:75
-#: ../db/db.execute/main.c:70 ../db/db.createdb/main.c:42
-#: ../db/db.describe/main.c:56 ../db/db.columns/main.c:50
-#: ../db/db.databases/main.c:48 ../db/db.dropdb/main.c:42
-#: ../db/db.tables/main.c:42 ../doc/vector/v.example/main.c:126
-#: ../display/d.thematic.area/main.c:205 ../display/d.vect/opt.c:147
-#: ../vector/v.out.svg/main.c:151 ../vector/v.in.sites/main.c:160
-#: ../vector/v.out.vtk/writeVTK.c:644 ../vector/v.edit/select.c:506
-#: ../vector/v.db.connect/main.c:216 ../vector/v.db.connect/main.c:282
+#: ../imagery/i.group/main.c:132
#, fuzzy, c-format
-msgid "Unable to start driver <%s>"
+msgid "Removing raster maps from subgroup <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:92
-#: ../raster/r.stream.extract/close.c:186 ../raster/r.contour/main.c:177
-#: ../vector/v.surf.rst/main.c:593 ../vector/v.net.distance/main.c:262
-#: ../vector/v.convert/att.c:81 ../vector/v.net.path/path.c:109
-#: ../vector/v.to.points/main.c:176 ../vector/v.net.allpairs/main.c:178
-#: ../vector/v.in.lidar/main.c:603 ../vector/v.distance/main.c:1287
-#: ../vector/v.in.dwg/main.c:237 ../vector/v.overlay/main.c:563
-#: ../vector/v.net.flow/main.c:180 ../vector/v.net.timetable/main.c:103
-#: ../vector/v.in.ogr/main.c:978 ../vector/v.net.components/main.c:189
-#: ../vector/v.net.centrality/main.c:266
+#: ../imagery/i.group/main.c:137
#, fuzzy, c-format
-msgid "Unable to create table: '%s'"
+msgid "Removing raster maps from group <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:96
+#: ../imagery/i.group/main.c:158
#, fuzzy, c-format
-msgid "Unable to create create index on table <%s>"
+msgid "Subgroup <%s> of group <%s> references the following raster maps:"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:100
-#: ../raster/r.to.vect/main.c:231 ../raster/r.stream.extract/close.c:194
-#: ../raster/r.contour/main.c:187 ../raster/r.stream.order/stream_vector.c:277
-#: ../vector/v.in.dxf/write_vect.c:237 ../vector/v.in.ascii/main.c:397
-#: ../vector/v.sample/main.c:186 ../vector/v.convert/att.c:91
-#: ../vector/v.patch/main.c:301 ../vector/v.in.sites/main.c:181
-#: ../vector/v.to.points/main.c:186 ../vector/v.mkgrid/main.c:256
-#: ../vector/v.in.lidar/main.c:614 ../vector/v.distance/main.c:1292
-#: ../vector/v.in.dwg/main.c:246 ../vector/v.overlay/main.c:573
-#: ../vector/v.reclass/main.c:316 ../vector/v.in.ogr/main.c:989
-#: ../vector/v.random/main.c:202
+#: ../imagery/i.group/main.c:173
#, fuzzy, c-format
-msgid "Unable to grant privileges on table <%s>"
+msgid "Group <%s> references the following raster maps:"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:141
-#: ../raster/r.stream.order/stream_vector.c:352
+#: ../imagery/i.group/main.c:185
#, fuzzy, c-format
-msgid "Unable to inset new row: '%s'"
+msgid "Group <%s> does not yet exist. Creating..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:254
+#: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
#, fuzzy, c-format
-msgid "Unable to create table '%s'"
+msgid "Adding raster maps to group <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:258
-#: ../raster/r.stream.extract/close.c:190
-#: ../raster/r.stream.order/stream_vector.c:273
+#: ../imagery/i.group/main.c:193
#, fuzzy, c-format
-msgid "Unable to create index on table <%s>"
+msgid "Adding raster maps to subgroup <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:262
+#: ../imagery/i.group/main.c:219 ../imagery/i.group/main.c:261
#, fuzzy, c-format
-msgid "Unable grant privileges on table <%s>"
+msgid "Raster map <%s> not found. Skipped."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_vector.c:320
-#: ../raster/r.stream.extract/close.c:211
+#: ../imagery/i.group/main.c:224
#, fuzzy, c-format
-msgid "Unable to insert new row: '%s'"
+msgid "Adding raster map <%s> to group"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_topology.c:50
-#: ../raster/r.stream.segment/stream_topology.c:99
-#: ../raster/r.stream.segment/stream_topology.c:175
-#: ../raster/r.stream.segment/stream_topology.c:291
-msgid "Error finding inits. Stream and direction maps probably do not match."
-msgstr ""
-#: ../raster/r.stream.segment/stream_topology.c:52
-#: ../raster/r.stream.segment/stream_topology.c:101
-#: ../raster/r.stream.order/stream_topology.c:21
-#: ../raster/r.stream.order/stream_topology.c:228
-msgid "Stream network may be too dense"
-msgstr ""
-#: ../raster/r.stream.segment/stream_topology.c:167
-#: ../raster/r.stream.segment/stream_topology.c:280
-#, fuzzy
-msgid "Finding inits..."
+#: ../imagery/i.group/main.c:230
+#, fuzzy, c-format
+msgid "Raster map <%s> exists in group. Skipped."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_topology.c:254
-#: ../raster/r.stream.segment/stream_topology.c:384
-#, fuzzy
-msgid "To much points in stream line"
+#: ../imagery/i.group/main.c:267
+#, fuzzy, c-format
+msgid "Adding raster map <%s> to subgroup"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.segment/stream_segment.c:260
+#: ../imagery/i.group/main.c:274
#, c-format
-msgid "Network topology error: cannot identify stream join for stream %d"
+msgid "Raster map <%s> exists in subgroup. Skipping..."
msgstr ""
-#: ../raster/r.out.ppm/main.c:55
+#: ../imagery/i.group/main.c:323
+#, fuzzy, c-format
+msgid "Removing raster map <%s> from group"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.group/main.c:340 ../imagery/i.group/main.c:399
#, fuzzy
-msgid "Converts a GRASS raster map to a PPM image file."
+msgid "No raster map removed"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.ppm/main.c:63
-msgid "Name for new PPM file (use '-' for stdout)"
-msgstr ""
+#: ../imagery/i.group/main.c:382
+#, fuzzy, c-format
+msgid "Removing raster map <%s> from subgroup"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ppm/main.c:67
-msgid "Output greyscale instead of color"
-msgstr ""
+#: ../imagery/i.group/main.c:418
+#, fuzzy, c-format
+msgid "Group <%s> does not contain any subgroup.\n"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ppm/main.c:71
-msgid "Suppress printing of PPM header"
-msgstr ""
-#: ../raster/r.out.ppm/main.c:120
+#: ../imagery/i.group/main.c:429
#, fuzzy, c-format
-msgid "Unable to open file <%s> for write"
+msgid "group <%s> references the following subgroups\n"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.ppm/main.c:150
-msgid "Converting..."
+#: ../imagery/i.rectify/target.c:35 ../vector/v.rectify/target.c:43
+msgid "Please run i.target for group."
msgstr ""
-#: ../raster/r.out.ppm/main.c:230
+#: ../imagery/i.rectify/get_wind.c:124
#, c-format
-msgid "File <%s> created"
+msgid "Region N=%f S=%f E=%f W=%f"
msgstr ""
-#: ../raster/r.random.cells/random.c:50
+#: ../imagery/i.rectify/get_wind.c:126
#, c-format
-msgid "RAN1: j == %d shouldn't happen"
+msgid "Resolution EW=%f NS=%f"
msgstr ""
-#: ../raster/r.random.cells/main.c:46 ../raster/r.random/main.c:52
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
-#: ../locale/scriptstrings/t.sample_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
-#: ../display/d.where/main.c:44 ../vector/v.extrude/main.c:69
-#: ../vector/v.what.rast3/main.c:65 ../vector/v.sample/main.c:76
-#: ../vector/v.drape/main.c:58 ../vector/v.what.rast/main.c:72
-#: ../vector/v.random/main.c:86
-msgid "sampling"
+#: ../imagery/i.rectify/main.c:100 ../vector/v.rectify/main.c:71
+msgid "rectify"
msgstr ""
-#: ../raster/r.random.cells/main.c:47 ../raster/r.random.surface/main.c:59
-#: ../raster/r.random/main.c:54 ../raster/r.surf.gauss/main.c:40
-#: ../raster/r.surf.random/main.c:38 ../vector/v.perturb/main.c:64
-#: ../vector/v.random/main.c:88
-msgid "random"
+#: ../imagery/i.rectify/main.c:102
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
msgstr ""
-#: ../raster/r.random.cells/main.c:48
-#, fuzzy
-msgid "autocorrelation"
-msgstr "출력할 래스터맵"
-#: ../raster/r.random.cells/main.c:50
-msgid "Generates random cell values with spatial dependence."
+#: ../imagery/i.rectify/main.c:124 ../vector/v.rectify/main.c:102
+msgid "Rectification polynom order (1-3)"
msgstr ""
-#: ../raster/r.random.cells/main.c:60
-msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
+#: ../imagery/i.rectify/main.c:161
+msgid "Use thin plate spline"
msgstr ""
-#: ../raster/r.random.cells/main.c:67
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
+#: ../imagery/i.rectify/main.c:199 ../vector/v.rectify/main.c:143
+#, c-format
+msgid "Invalid order (%d); please enter 1 to %d"
msgstr ""
-#: ../raster/r.random.cells/init.c:70
-msgid "Distance must be >= 0.0"
+#: ../imagery/i.rectify/main.c:206
+#, fuzzy, c-format
+msgid "Location: %s"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rectify/main.c:207
+#, c-format
+msgid "Mapset: %s"
msgstr ""
-#: ../raster/r.random.cells/init.c:89 ../raster/r.random.surface/main.c:128
+#: ../imagery/i.rectify/main.c:208
#, fuzzy, c-format
-msgid "Generating raster map <%s>..."
+msgid "Group <%s> does not exist"
msgstr "출력할 래스터맵"
-#: ../raster/r.grow/main.c:125 ../locale/scriptstrings/r.grow_to_translate.c:1
-msgid "Generates a raster map layer with contiguous areas grown by one cell."
+#: ../imagery/i.rectify/cp.c:14 ../vector/v.rectify/cp.c:350
+#, c-format
+msgid "Control Point file for group <%s@%s> - "
msgstr ""
-#: ../raster/r.grow/main.c:136 ../locale/scriptstrings/r.grow_to_translate.c:4
-msgid "Radius of buffer in raster cells"
+#: ../imagery/i.rectify/cp.c:21
+#, c-format
+msgid "Not enough active control points for thin plate spline."
msgstr ""
-#: ../raster/r.grow/main.c:152 ../locale/scriptstrings/r.grow_to_translate.c:6
-msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
+#: ../imagery/i.rectify/cp.c:24 ../imagery/i.rectify/cp.c:51
+#: ../vector/v.rectify/cp.c:363
+msgid "Poorly placed control points."
msgstr ""
-#: ../raster/r.grow/main.c:158 ../locale/scriptstrings/r.grow_to_translate.c:7
-msgid "Value to write for \"grown\" cells"
+#: ../imagery/i.rectify/cp.c:25 ../imagery/i.rectify/cp.c:52
+#: ../vector/v.rectify/cp.c:364
+#, fuzzy
+msgid " Can not generate the transformation equation."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:55
+#: ../vector/v.rectify/cp.c:367
+#, fuzzy
+msgid "Not enough memory to solve for transformation equation"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:58
+#: ../vector/v.rectify/cp.c:370
+msgid "Invalid order"
msgstr ""
-#: ../raster/r.grow/main.c:184
+#: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
#, c-format
-msgid "Unknown metric: [%s]."
+msgid "Not enough active control points for current order, %d are required."
msgstr ""
-#: ../raster/r.grow/main.c:193 ../display/d.colors/get_info.c:21
-#, fuzzy, c-format
-msgid "Error reading category file for <%s>"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.gensigset/parse.c:29
+msgid "Maximum number of sub-signatures in any class"
+msgstr ""
-#: ../raster/r.grow/main.c:198
+#: ../imagery/i.gensigset/parse.c:54
#, fuzzy, c-format
-msgid "Error in reading color file for <%s>"
+msgid "Illegal number of sub-signatures (%s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/raw_stats.c:118
+#: ../imagery/i.gensigset/main.c:46
#, fuzzy
-msgid "Invalid map type"
+msgid "Generates statistics for i.smap from raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:108
-#, fuzzy
-msgid "Generates area statistics for raster map."
+#: ../imagery/i.gensigset/main.c:56
+#, fuzzy, c-format
+msgid "Clustering class %d (%d pixels)..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:113 ../raster/r.report/parse.c:40
-#, fuzzy
-msgid "Name of raster map(s) to report on"
+#: ../imagery/i.gensigset/main.c:59
+#, fuzzy, c-format
+msgid "Number of subclasses is %d"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:118 ../raster/r.what/main.c:129
-#: ../raster/r.univar/r3.univar_main.c:42
-#: ../raster/r.univar/r.univar_main.c:41 ../db/db.select/main.c:244
-#: ../locale/scriptstrings/i.oif_to_translate.c:5
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
-#: ../vector/v.db.select/main.c:88
-msgid "Name for output file (if omitted or \"-\" output to stdout)"
+#: ../imagery/i.gensigset/subcluster.c:76
+#, c-format
+msgid "Not enough pixels in class %d"
msgstr ""
-#: ../raster/r.stats/main.c:122 ../raster/r.stats/main.c:131
-#: ../raster/r.stats/main.c:155 ../raster/r.report/parse.c:76
-#: ../raster/r.report/parse.c:85 ../raster/r.report/parse.c:94
-#: ../raster/r.report/parse.c:118 ../raster/r.report/parse.c:123
-#: ../raster/r.report/parse.c:128 ../raster/r.report/parse.c:133
-#: ../raster/r.kappa/main.c:104 ../raster/r.kappa/main.c:109
-#: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
-#: ../raster/r.univar/r.univar_main.c:72
-#: ../locale/scriptstrings/t.list_to_translate.c:10
-#: ../locale/scriptstrings/t.list_to_translate.c:16
-#: ../locale/scriptstrings/t.list_to_translate.c:18
-msgid "Formatting"
+#: ../imagery/i.gensigset/subcluster.c:86
+#, c-format
+msgid "Too many subclasses for class index %d"
msgstr ""
-#: ../raster/r.stats/main.c:130 ../raster/r.report/parse.c:75
-#: ../raster/r.describe/main.c:68
-msgid "String representing no data cell value"
+#: ../imagery/i.gensigset/subcluster.c:88
+#, fuzzy, c-format
+msgid "Number of subclasses set to %d"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.gensigset/subcluster.c:106
+#, c-format
+msgid "Combining subclasses (%d,%d)..."
msgstr ""
-#: ../raster/r.stats/main.c:140 ../raster/r.report/parse.c:103
-#, fuzzy
-msgid "Number of floating-point subranges to collect stats from"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.gensigset/subcluster.c:318
+#, c-format
+msgid "Subsignature %d only contains %.0f pixels"
+msgstr ""
-#: ../raster/r.stats/main.c:141 ../raster/r.stats/main.c:196
-#: ../raster/r.stats/main.c:201 ../raster/r.stats/main.c:216
-#: ../raster/r.stats/main.c:221 ../raster/r.report/parse.c:104
-#: ../raster/r.report/parse.c:148 ../raster/r.report/parse.c:154
-#, fuzzy
-msgid "Floating point"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.gensigset/subcluster.c:552
+msgid "Unreliable clustering. Try a smaller initial number of clusters"
+msgstr ""
-#: ../raster/r.stats/main.c:148 ../raster/r.report/parse.c:111
-msgid "Sort output statistics by cell counts"
+#: ../imagery/i.gensigset/subcluster.c:561
+#, c-format
+msgid "Removed a singular subsignature number %d (%d remain)"
msgstr ""
-#: ../raster/r.stats/main.c:149 ../raster/r.report/parse.c:112
+#: ../imagery/i.topo.corr/main.c:48 ../raster/r.slope.aspect/main.c:152
+#: ../raster/r.shaded.relief/main.c:108
#, fuzzy
-msgid "Default: sorted by categories or intervals"
+msgid "terrain"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:153 ../raster/r.report/parse.c:116
-msgid "Sort by cell counts in ascending order"
+#: ../imagery/i.topo.corr/main.c:49
+msgid "topographic correction"
msgstr ""
-#: ../raster/r.stats/main.c:154 ../raster/r.report/parse.c:117
-msgid "Sort by cell counts in descending order"
+#: ../imagery/i.topo.corr/main.c:50
+msgid "Computes topographic correction of reflectance."
msgstr ""
-#: ../raster/r.stats/main.c:161
-msgid "Print area totals in square meters"
-msgstr ""
+#: ../imagery/i.topo.corr/main.c:58
+#, fuzzy
+msgid "Name of reflectance raster maps to be corrected topographically"
+msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:162 ../raster/r.stats/main.c:167
-#: ../raster/r.stats/main.c:173 ../raster/r.report/parse.c:60
+#: ../imagery/i.topo.corr/main.c:62
#, fuzzy
-msgid "Statistics"
+msgid "Name (flag -i) or prefix for output raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:166
-msgid "Print cell counts (sortable)"
+#: ../imagery/i.topo.corr/main.c:66
+#, fuzzy
+msgid "Name of input base raster map (elevation or illumination)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.topo.corr/main.c:72
+msgid "Solar zenith in degrees"
msgstr ""
-#: ../raster/r.stats/main.c:172
-msgid "Print approximate (total percent may not be 100%) percents"
+#: ../imagery/i.topo.corr/main.c:78
+msgid "Solar azimuth in degrees (only if flag -i)"
msgstr ""
-#: ../raster/r.stats/main.c:177
-msgid "Print category labels"
+#: ../imagery/i.topo.corr/main.c:85
+msgid "Topographic correction method"
msgstr ""
-#: ../raster/r.stats/main.c:181
-msgid "One cell (range) per line"
+#: ../imagery/i.topo.corr/main.c:90
+msgid "Output sun illumination terrain model"
msgstr ""
-#: ../raster/r.stats/main.c:185
-msgid "Print grid coordinates (east and north)"
+#: ../imagery/i.topo.corr/main.c:94
+msgid "Scale output to input and copy color rules"
msgstr ""
-#: ../raster/r.stats/main.c:186 ../raster/r.stats/main.c:191
-#, fuzzy
-msgid "Coordinates"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.topo.corr/main.c:100
+msgid "Solar azimuth is necessary to calculate illumination terrain model"
+msgstr ""
-#: ../raster/r.stats/main.c:190
-msgid "Print x and y (column and row)"
+#: ../imagery/i.topo.corr/main.c:104
+msgid "Reflectance maps are necessary to make topographic correction"
msgstr ""
-#: ../raster/r.stats/main.c:195
-msgid "Print averaged values instead of intervals (floating-point maps only)"
+#: ../imagery/i.topo.corr/main.c:158 ../raster/r.resamp.interp/main.c:102
+#, c-format
+msgid "Invalid method: %s"
msgstr ""
-#: ../raster/r.stats/main.c:200
-msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+#: ../imagery/i.topo.corr/main.c:164
+msgid "Illumination model is of CELL type"
msgstr ""
-#: ../raster/r.stats/main.c:205 ../raster/r.report/parse.c:137
-#, fuzzy
-msgid "Do not report no data value"
-msgstr "출력할 래스터맵"
+#: ../imagery/i.topo.corr/main.c:167
+#, c-format
+msgid "Band %s: "
+msgstr ""
-#: ../raster/r.stats/main.c:206 ../raster/r.stats/main.c:211
-#: ../raster/r.report/parse.c:138 ../raster/r.report/parse.c:143
-#, fuzzy
-msgid "No data"
+#: ../imagery/i.topo.corr/main.c:175
+#, c-format
+msgid "Reflectance of <%s> is not of DCELL type - ignored."
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:244
+#, fuzzy, c-format
+msgid "Processing pass %d..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:210 ../raster/r.report/parse.c:142
-msgid "Do not report cells where all maps have no data"
+#: ../imagery/i.segment/create_isegs.c:522
+#, c-format
+msgid ""
+"Segmentation processes stopped at %d due to reaching max iteration limit, "
+"more merges may be possible"
msgstr ""
-#: ../raster/r.stats/main.c:215 ../raster/r.report/parse.c:147
-msgid "Report for cats floating-point ranges (floating-point maps only)"
+#: ../imagery/i.segment/create_isegs.c:524
+#, c-format
+msgid "Segmentation converged after %d iterations"
msgstr ""
-#: ../raster/r.stats/main.c:220 ../raster/r.report/parse.c:153
-msgid "Read floating-point map as integer (use map's quant rules)"
+#: ../imagery/i.segment/create_isegs.c:532
+#, c-format
+msgid "Merging segments smaller than %d cells..."
msgstr ""
-#: ../raster/r.stats/main.c:237
+#: ../imagery/i.segment/create_isegs.c:1075
#, c-format
-msgid "'%s' must be greater than zero; using %s=255"
+msgid "Region stats should go in tree, %d >= %d"
msgstr ""
-#: ../raster/r.stats/main.c:307
+#: ../imagery/i.segment/create_isegs.c:1082
+msgid "Region ids are different"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1086
+msgid "Region consists of only one cell, nothing to update"
+msgstr ""
+#: ../imagery/i.segment/create_isegs.c:1130
+#: ../imagery/i.segment/create_isegs.c:1555
#, c-format
-msgid ""
-"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
-"will be ignored."
+msgid "Region size is larger than 2: %d"
msgstr ""
-#: ../raster/r.stats/main.c:323
+#: ../imagery/i.segment/create_isegs.c:1197
#, c-format
-msgid ""
-"Cats for raster map <%s> are either missing or have no explicit labels. "
-"Using %s=%d."
+msgid "Region size is %d, should be %d"
msgstr ""
-#: ../raster/r.stats/main.c:329
+#: ../imagery/i.segment/create_isegs.c:1420
#, c-format
-msgid ""
-"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
-"option"
+msgid "Candidate flag is already %s"
msgstr ""
-#: ../raster/r.stats/main.c:335 ../raster/r.contour/main.c:146
-#, fuzzy, c-format
-msgid "Unable to read fp range of raster map <%s>"
+#, fuzzy
+msgid "set"
msgstr "출력할 래스터맵"
-#: ../raster/r.stats/main.c:362 ../raster/r.recode/read_rules.c:35
-#, fuzzy, c-format
-msgid "Unable to read range for map <%s>"
-msgstr "출력할 래스터맵"
+msgid "unset"
+msgstr ""
-#: ../raster/r.statistics/o_skew.c:91
-msgid "o_skew: No data in array"
+#: ../imagery/i.segment/create_isegs.c:1640
+#, c-format
+msgid "Region of size %d should be in search tree"
msgstr ""
-#: ../raster/r.statistics/o_kurt.c:91
-msgid "o_kurto: No data in array"
+#: ../imagery/i.segment/rclist.c:17
+msgid "rclist out of memory"
msgstr ""
-#: ../raster/r.statistics/main.c:58
-msgid "Calculates category or object oriented statistics."
+#: ../imagery/i.segment/parse_args.c:30
+msgid "Difference threshold between 0 and 1"
msgstr ""
-#: ../raster/r.statistics/main.c:103 ../raster/r.statistics/main.c:106
-msgid "This module currently only works for integer (CELL) maps"
+#: ../imagery/i.segment/parse_args.c:31
+msgid "Threshold = 0 merges only identical segments; threshold = 1 merges all"
msgstr ""
-#: ../raster/r.statistics/o_var.c:95 ../raster/r.statistics/o_sdev.c:94
-msgid "o_var: No data in array"
+#: ../imagery/i.segment/parse_args.c:41
+#, fuzzy
+msgid "Segmentation method"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:50
+msgid "Similarity calculation method"
msgstr ""
-#: ../raster/r.statistics/o_adev.c:93
-msgid "o_adev: No data in array"
+#: ../imagery/i.segment/parse_args.c:59
+#, fuzzy
+msgid "Minimum number of cells in a segment"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:61
+msgid "The final step will merge small segments with their best neighbor"
msgstr ""
-#: ../raster/r.statistics/read_stats.c:20
-msgid "Reading r.stats output"
+#: ../imagery/i.segment/parse_args.c:72
+msgid "Importance of radiometric (input raster) values relative to shape"
msgstr ""
-#: ../raster/r.drain/main.c:113
+#: ../imagery/i.segment/parse_args.c:82
+msgid "Importance of smoothness relative to compactness"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:91
+msgid "Memory in MB"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:109
#, fuzzy
-msgid ""
-"Traces a flow through an elevation model or cost surface on a raster map."
+msgid "Name for input raster map with starting seeds"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:116
+#: ../imagery/i.segment/parse_args.c:115
#, fuzzy
-msgid "Name of input elevation or cost surface raster map"
+msgid "Name of input bounding/constraining raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:121
-msgid "Name of input movement direction map associated with the cost surface"
+#: ../imagery/i.segment/parse_args.c:117
+msgid ""
+"Must be integer values, each area will be segmented independent of the others"
msgstr ""
-#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
-msgid "Cost surface"
+#: ../imagery/i.segment/parse_args.c:123
+#, fuzzy
+msgid "Name for output goodness of fit estimate map"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:128
+msgid ""
+"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
+"each pixel"
msgstr ""
-#: ../raster/r.drain/main.c:131
+#: ../imagery/i.segment/parse_args.c:134
+msgid "Weighted input, do not perform the default scaling of input raster maps"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:153
+msgid "Threshold should be >= 0 and <= 1"
+msgstr ""
+#: ../imagery/i.segment/parse_args.c:159
#, fuzzy
-msgid "Name for output drain vector map"
+msgid "Unable to assign segmentation method"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:132
-msgid "Recommended for cost surface made using knight's move"
+#: ../imagery/i.segment/parse_args.c:169
+msgid "Invalid similarity method"
msgstr ""
-#: ../raster/r.drain/main.c:142
+#: ../imagery/i.segment/parse_args.c:175
+#, fuzzy, c-format
+msgid "Option '%s' must be > 0"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:177 ../imagery/i.segment/parse_args.c:182
+#, fuzzy, c-format
+msgid "Option '%s' must be <= 1"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:180
+#, fuzzy, c-format
+msgid "Option '%s' must be >= 0"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:208
#, fuzzy
-msgid "Name of starting vector points map(s)"
+msgid "Seeds raster map not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:148
-msgid "Copy input cell values on output"
+#: ../imagery/i.segment/parse_args.c:212
+#, fuzzy
+msgid "Seeeds raster map must be CELL type (integers)"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:222
+#, fuzzy
+msgid "Segmentation constraint/boundary raster map not found"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/parse_args.c:226
+msgid "Segmentation constraint raster map must be CELL type (integers)"
msgstr ""
-#: ../raster/r.drain/main.c:152
-msgid "Accumulate input values along the path"
+#: ../imagery/i.segment/parse_args.c:241
+msgid "Invalid output raster name for goodness of fit"
msgstr ""
-#: ../raster/r.drain/main.c:153 ../raster/r.drain/main.c:158
+#: ../imagery/i.segment/parse_args.c:249
#, fuzzy
-msgid "Path settings"
+msgid "Invalid number of iterations, 100 will be used"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:157
-msgid "Count cell numbers along the path"
+#: ../imagery/i.segment/parse_args.c:259
+msgid "Invalid number of MB, 300 will be used"
msgstr ""
-#: ../raster/r.drain/main.c:163
-msgid ""
-"The input raster map is a cost surface (direction surface must also be "
-"specified)"
+#: ../imagery/i.segment/main.c:38
+msgid "object recognition"
msgstr ""
-#: ../raster/r.drain/main.c:175
-msgid "Directional drain selected... checking for direction raster map"
+#: ../imagery/i.segment/main.c:40
+msgid "Identifies segments (objects) from imagery data."
msgstr ""
-#: ../raster/r.drain/main.c:178
-msgid "Surface/Hydrology drain selected"
+#: ../imagery/i.segment/main.c:46
+#, fuzzy
+msgid "Error in reading data"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/main.c:50
+#, fuzzy
+msgid "Error in creating segments"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/main.c:54
+#, fuzzy
+msgid "Error in writing data"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/main.c:59
+#, fuzzy, c-format
+msgid "Number of segments created: %d"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/write_output.c:31
+#, fuzzy
+msgid "Writing out segment IDs..."
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/write_output.c:95 ../imagery/i.segment/open_files.c:40
+#, fuzzy, c-format
+msgid "Unable to read REF file for group <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/write_output.c:98 ../imagery/i.segment/open_files.c:44
+#, fuzzy, c-format
+msgid "Group <%s> contains no raster maps"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/write_output.c:110
+msgid "Writing out goodness of fit"
msgstr ""
-#: ../raster/r.drain/main.c:183
+#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
+#: ../imagery/i.segment/open_files.c:236
+#, fuzzy, c-format
+msgid "No min/max found in raster map <%s>"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/open_files.c:117
#, c-format
-msgid ""
-"Direction raster map <%s> not specified, if direction flag is on, a "
-"direction raster must be given"
+msgid "Non-NULL cells: %ld"
msgstr ""
-#: ../raster/r.drain/main.c:190
-#, c-format
-msgid ""
-"Direction raster map <%s> should not be specified for Surface/Hydrology "
-"drains"
+#: ../imagery/i.segment/open_files.c:119
+msgid "Insufficient number of non-NULL cells in current region"
msgstr ""
-#: ../raster/r.drain/main.c:197 ../raster/r.resamp.bspline/main.c:484
-#: ../raster/r.flow/io.c:178 ../doc/vector/v.example/main.c:98
-#: ../vector/v.in.dxf/main.c:144 ../vector/v.net.connectivity/main.c:136
-#: ../vector/v.surf.rst/main.c:726 ../vector/v.net.bridge/main.c:124
-#: ../vector/v.net.distance/main.c:182 ../vector/v.delaunay/main.c:125
-#: ../vector/v.net.path/main.c:134 ../vector/v.net.allpairs/main.c:136
-#: ../vector/v.surf.bspline/main.c:338 ../vector/v.mkgrid/main.c:216
-#: ../vector/v.hull/main.c:121 ../vector/v.net.visibility/main.c:83
-#: ../vector/v.lidar.edgedetection/main.c:241 ../vector/v.to.3d/main.c:87
-#: ../vector/v.net.flow/main.c:149 ../vector/v.net.flow/main.c:155
-#: ../vector/v.edit/main.c:104 ../vector/v.edit/main.c:119
-#: ../vector/v.net.spanningtree/main.c:107
-#: ../vector/v.net.timetable/main.c:359 ../vector/v.net.components/main.c:153
-#: ../vector/v.net.centrality/main.c:215 ../vector/v.generalize/main.c:324
-#: ../vector/v.lidar.correction/main.c:205
-#: ../vector/v.lidar.correction/main.c:211 ../vector/v.random/main.c:167
-#: ../vector/v.outlier/main.c:217 ../vector/v.outlier/main.c:222
-#: ../vector/v.outlier/main.c:228
-#, fuzzy, c-format
-msgid "Unable to create vector map <%s>"
+#: ../imagery/i.segment/open_files.c:140
+#, fuzzy
+msgid "Loading input bands..."
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:209
-msgid "Specify just one of the -c, -a and -n flags"
-msgstr ""
+#: ../imagery/i.segment/open_files.c:142
+#, fuzzy
+msgid "Loading input band..."
+msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:240
+#: ../imagery/i.segment/open_files.c:174 ../imagery/i.segment/open_files.c:201
+#: ../imagery/i.segment/open_files.c:260 ../imagery/i.segment/open_files.c:347
+#: ../imagery/i.segment/open_files.c:373 ../imagery/i.segment/open_files.c:413
+#: ../imagery/i.segment/open_files.c:469
+#, fuzzy
+msgid "Unable to write to temporary file"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/open_files.c:267
#, c-format
-msgid "Starting point %d is outside the current region"
+msgid "There are no boundary constraints in '%s'"
msgstr ""
-#: ../raster/r.drain/main.c:315
+#: ../imagery/i.segment/open_files.c:322
#, fuzzy, c-format
-msgid "Starting vector map <%s> contains no points in the current region"
+msgid "Loading seeds from '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:323
-msgid "No start/stop point(s) specified"
+#: ../imagery/i.segment/open_files.c:352
+#, fuzzy, c-format
+msgid "No seeds found in '%s'!"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/open_files.c:489
+#, fuzzy, c-format
+msgid "Segment %d is already registered!"
+msgstr "출력할 래스터맵"
+#: ../imagery/i.segment/open_files.c:538
+#, c-format
+msgid "Regions with at least %d cells are stored in memory"
msgstr ""
-#: ../raster/r.drain/main.c:398
+#: ../imagery/i.segment/open_files.c:563
+#, c-format
+msgid "Number of segments in memory: %d of %d total"
+msgstr ""
+#: ../imagery/i.segment/flag.c:21 ../imagery/i.segment/flag.c:28
+#: ../vector/v.distance/main.c:709 ../vector/v.distance/main.c:786
+#: ../vector/v.distance/main.c:982
+msgid "Out of memory!"
+msgstr ""
+#: ../raster3d/r3.info/r3.info.main.c:75 ../raster3d/r3.mask/main.c:132
+#: ../raster3d/r3.stats/main.c:568 ../raster3d/r3.null/main.c:185
+#: ../raster3d/r3.neighbors/main.c:208 ../raster3d/r3.in.ascii/main.c:316
+#: ../raster3d/r3.retile/main.c:96 ../raster3d/r3.out.v5d/main.c:283
+#: ../raster3d/r3.gwflow/main.c:159 ../raster3d/r3.out.vtk/main.c:376
+#: ../raster3d/r3.mkdspf/main.c:79 ../raster3d/r3.in.v5d/main.c:192
+#: ../raster3d/r3.support/main.c:49 ../raster3d/r3.in.bin/main.c:252
+#: ../raster3d/r3.out.netcdf/main.c:586 ../raster3d/r3.out.bin/main.c:205
+#: ../raster3d/r3.to.rast/main.c:206
+#: ../raster3d/r3.timestamp/r3.timestamp.main.c:43
+#: ../raster3d/r3.out.ascii/main.c:305 ../raster3d/r3.cross.rast/main.c:228
+#: ../misc/m.nviz.script/main.c:72 ../misc/m.nviz.image/main.c:54
+#: ../raster/r.univar/r3.univar_main.c:98 ../raster/r.to.rast3elev/main.c:363
+#: ../raster/r.colors.out/raster3d_main.c:46
+#: ../raster/r.colors/edit_colors.c:59
+#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:4
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:2
#, fuzzy
-msgid "Calculating flow directions..."
+msgid "raster3d"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:467
+#: ../raster3d/r3.info/r3.info.main.c:76 ../raster3d/r3.support/main.c:50
+#: ../raster/r.region/main.c:52 ../raster/r.timestamp/main.c:36
+#: ../raster/r.info/main.c:70 ../raster/r.support/main.c:56
+#: ../raster/r.describe/main.c:55 ../vector/v.timestamp/main.c:36
+#: ../vector/v.support/main.c:40 ../vector/v.info/main.c:38
+#: ../locale/scriptstrings/t.support_to_translate.c:3
+#: ../locale/scriptstrings/t.info_to_translate.c:3
+#: ../locale/scriptstrings/t.select_to_translate.c:3
#, fuzzy
-msgid "Writing output raster map..."
+msgid "metadata"
msgstr "출력할 래스터맵"
-#: ../raster/r.drain/main.c:689
-#, c-format
-msgid "direction read: %lf, neighbour found: %i"
-msgstr ""
-#: ../raster/r.info/main.c:71 ../raster3d/r3.info/r3.info.main.c:77
+#: ../raster3d/r3.info/r3.info.main.c:77 ../raster/r.info/main.c:71
#: ../vector/v.info/main.c:40
#, fuzzy
msgid "extent"
msgstr "출력할 래스터맵"
-#: ../raster/r.info/main.c:72 ../vector/v.info/main.c:41
-msgid "history"
+#: ../raster3d/r3.info/r3.info.main.c:78 ../raster3d/r3.mask/main.c:134
+#: ../raster3d/r3.null/main.c:186 ../raster3d/r3.in.ascii/main.c:317
+#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.out.v5d/main.c:284
+#: ../raster3d/r3.gwflow/main.c:161 ../raster3d/r3.out.vtk/main.c:377
+#: ../raster3d/r3.mkdspf/main.c:80 ../raster3d/r3.in.v5d/main.c:193
+#: ../raster3d/r3.to.rast/main.c:209
+#: ../raster3d/r3.timestamp/r3.timestamp.main.c:44
+#: ../raster3d/r3.out.ascii/main.c:306 ../raster3d/r3.cross.rast/main.c:231
+#: ../raster/r.to.rast3elev/main.c:364 ../raster/r.to.rast3/main.c:199
+#: ../vector/v.vol.rst/main.c:239 ../vector/v.to.rast3/main.c:50
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
+msgid "voxel"
msgstr ""
-#: ../raster/r.info/main.c:74
+#: ../raster3d/r3.info/r3.info.main.c:80
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../raster3d/r3.info/r3.info.main.c:86
#, fuzzy
-msgid "Outputs basic information about a raster map."
+msgid "Print raster3d information in shell style"
msgstr "출력할 래스터맵"
-#: ../raster/r.info/main.c:80
+#: ../raster3d/r3.info/r3.info.main.c:90
#, fuzzy
-msgid "Print raster array information only"
+msgid "Print range in shell style only"
msgstr "출력할 래스터맵"
-#: ../raster/r.info/main.c:84
-msgid "Print range only"
-msgstr ""
-#: ../raster/r.info/main.c:88
-msgid "Print extended metadata information only"
-msgstr ""
-#: ../raster/r.info/main.c:92 ../raster3d/r3.info/r3.info.main.c:94
+#: ../raster3d/r3.info/r3.info.main.c:94 ../raster/r.info/main.c:92
msgid "Print raster history instead of info"
msgstr ""
-#: ../raster/r.info/main.c:123
-#, fuzzy
-msgid "Unable to read range file"
+#: ../raster3d/r3.info/r3.info.main.c:103
+#, fuzzy, c-format
+msgid "3D Raster map <%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.info/main.c:286 ../raster/r.info/main.c:412
+#: ../raster3d/r3.info/r3.info.main.c:110 ../raster3d/r3.mask/main.c:63
+#: ../raster3d/r3.stats/main.c:619 ../raster3d/r3.null/main.c:109
+#: ../raster3d/r3.neighbors/main.c:262 ../raster3d/r3.neighbors/main.c:271
+#: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.out.v5d/main.c:311
+#: ../raster3d/r3.out.vtk/main.c:207 ../raster3d/r3.out.vtk/main.c:292
+#: ../raster3d/r3.out.vtk/main.c:513 ../raster3d/r3.mkdspf/main.c:167
+#: ../raster3d/r3.out.netcdf/main.c:616 ../raster3d/r3.out.bin/main.c:314
+#: ../raster3d/r3.to.rast/main.c:237 ../raster3d/r3.to.rast/main.c:261
+#: ../raster3d/r3.out.ascii/main.c:342 ../raster3d/r3.cross.rast/main.c:279
+#: ../raster/r.univar/r3.univar_main.c:155
+#: ../raster/r.univar/r3.univar_main.c:193
+#, fuzzy, c-format
+msgid "Unable to open 3D raster map <%s>"
+msgstr "출력할 래스터맵"
#: ../raster3d/r3.info/r3.info.main.c:138
#: ../raster3d/r3.info/r3.info.main.c:145
#: ../raster3d/r3.info/r3.info.main.c:151
@@ -5472,2523 +7044,2724 @@
#: ../raster3d/r3.info/r3.info.main.c:356
#: ../raster3d/r3.info/r3.info.main.c:361
#: ../raster3d/r3.info/r3.info.main.c:369
-#: ../raster3d/r3.info/r3.info.main.c:382
+#: ../raster3d/r3.info/r3.info.main.c:382 ../raster/r.info/main.c:286
+#: ../raster/r.info/main.c:412
msgid "Cannot allocate memory for string"
msgstr ""
-#: ../raster/r.param.scale/process.c:74
-msgid "E-W and N-S grid resolutions are different. Taking average."
-msgstr ""
-#: ../raster/r.param.scale/interface.c:55
-#, fuzzy
-msgid "geomorphology"
+#: ../raster3d/r3.info/r3.info.main.c:328
+#: ../raster3d/r3.info/r3.info.main.c:444 ../raster3d/r3.mkdspf/main.c:170
+#, fuzzy, c-format
+msgid "Unable to read range of 3D raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.param.scale/interface.c:56
-msgid "Extracts terrain parameters from a DEM."
+#: ../raster3d/r3.info/r3.info.main.c:472
+msgid "Error while reading history file"
msgstr ""
-#: ../raster/r.param.scale/interface.c:57
-msgid ""
-"Uses a multi-scale approach by taking fitting quadratic parameters to any "
-"size window (via least squares)."
-msgstr ""
+#: ../raster3d/r3.info/r3.info.main.c:479 ../raster3d/r3.null/main.c:168
+#: ../raster3d/r3.out.vtk/errorHandling.c:65
+#: ../raster3d/r3.cross.rast/main.c:343
+#, fuzzy, c-format
+msgid "Unable to close 3D raster map <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.param.scale/interface.c:75
-msgid "Output raster layer containing morphometric parameter"
-msgstr ""
+#: ../raster3d/r3.mask/main.c:74
+#, fuzzy
+msgid "Unable to open 3D raster mask file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.param.scale/interface.c:79
-msgid "Slope tolerance that defines a 'flat' surface (degrees)"
+#: ../raster3d/r3.mask/main.c:103
+msgid "makeMask: error flushing tiles in cube"
msgstr ""
-#: ../raster/r.param.scale/interface.c:86
-msgid "Curvature tolerance that defines 'planar' surface"
+#: ../raster3d/r3.mask/main.c:108
+msgid "makeMask: error flushing all tiles"
msgstr ""
-#: ../raster/r.param.scale/interface.c:93
-msgid "Size of processing window (odd number only)"
-msgstr ""
+#: ../raster3d/r3.mask/main.c:116
+#, fuzzy
+msgid "Unable to close 3D raster mask file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.param.scale/interface.c:101
-msgid "Morphometric parameter in 'size' window to calculate"
-msgstr ""
+#: ../raster3d/r3.mask/main.c:118
+#, fuzzy, c-format
+msgid "Unable to close raster map <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.param.scale/interface.c:109
-msgid "Exponent for distance weighting (0.0-4.0)"
+#: ../raster3d/r3.mask/main.c:133
+#: ../locale/scriptstrings/r.mask_to_translate.c:3
+msgid "mask"
msgstr ""
-#: ../raster/r.param.scale/interface.c:121
-msgid "Constrain model through central window cell"
+#: ../raster3d/r3.mask/main.c:136
+msgid "Establishes the current working 3D raster mask."
msgstr ""
-#: ../raster/r.param.scale/interface.c:164
-msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
-msgstr ""
+#: ../raster3d/r3.mask/main.c:144
+#, fuzzy
+msgid "3D raster map with reference values"
+msgstr "출력할 래스터맵"
-#: ../raster/r.param.scale/interface.c:172
-msgid "Inappropriate window size (too big or even)"
+#: ../raster3d/r3.mask/main.c:152
+msgid "List of cell values to be masked out"
msgstr ""
-#: ../raster/r.param.scale/main.c:42
-msgid "Lat/Long locations are not supported by this module"
+#: ../raster3d/r3.mask/main.c:158
+msgid "Cannot create mask file: RASTER3D_MASK already exists"
msgstr ""
-#: ../raster/r.buffer/parse_dist.c:54
-#, c-format
-msgid "%s: %s - illegal distance specification"
-msgstr ""
+#: ../raster3d/r3.stats/main.c:570
+#, fuzzy
+msgid "Generates volume statistics for 3D raster maps."
+msgstr "출력할 래스터맵"
-#: ../raster/r.buffer/main.c:67
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
-#: ../vector/v.buffer/main.c:223
+#: ../raster3d/r3.stats/main.c:581
#, fuzzy
-msgid "buffer"
+msgid "Number of subranges to collect stats from"
msgstr "출력할 래스터맵"
-#: ../raster/r.buffer/main.c:69
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
-msgid ""
-"Creates a raster map showing buffer zones surrounding cells that contain non-"
-"NULL category values."
+#: ../raster3d/r3.stats/main.c:587
+msgid "Calculate statistics based on equal value groups"
msgstr ""
-#: ../raster/r.buffer/main.c:81
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
-msgid "Distance zone(s)"
+#: ../raster3d/r3.stats/main.c:607
+msgid "The number of subranges has to be equal or greater than 1"
msgstr ""
-#: ../raster/r.buffer/main.c:88
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
-msgid "Units of distance"
+#: ../raster3d/r3.stats/main.c:666
+msgid "Sort non-null values"
msgstr ""
-#: ../raster/r.buffer/main.c:94
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
-msgid "Ignore zero (0) data cells instead of NULL cells"
+#: ../raster3d/r3.null/main.c:54
+msgid "3d raster map for which to modify null values"
msgstr ""
-#: ../raster/r.buffer/main.c:131
-msgid "Parse distances error"
+#: ../raster3d/r3.null/main.c:62 ../raster/r.null/main.c:72
+msgid "List of cell values to be set to NULL"
msgstr ""
-#: ../raster/r.buffer/main.c:150
-#, c-format
-msgid "Pass %d (of %d)"
+#: ../raster3d/r3.null/main.c:69 ../raster/r.null/main.c:80
+msgid "The value to replace the null value by"
msgstr ""
-#: ../raster/r.buffer/execute.c:34
-msgid "Finding buffer zones..."
+#: ../raster3d/r3.null/main.c:84
+msgid "Illegal value for null"
msgstr ""
-#: ../raster/r.buffer/read_map.c:52 ../raster/r.flow/io.c:89
-#: ../raster/r.flow/io.c:107
-#, fuzzy, c-format
-msgid "Reading input raster map <%s>..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.covar/main.c:54
-msgid ""
-"Outputs a covariance/correlation matrix for user-specified raster map "
-"layer(s)."
+#: ../raster3d/r3.null/main.c:121
+msgid "modifyNull: error opening tmp file"
msgstr ""
-#: ../raster/r.covar/main.c:61
-msgid "Print correlation matrix"
+#: ../raster3d/r3.null/main.c:155
+msgid "modifyNull: error flushing tiles in cube"
msgstr ""
-#: ../raster/r.covar/main.c:86
-#, c-format
-msgid "%s: complete ... "
+#: ../raster3d/r3.null/main.c:160
+msgid "modifyNull: error flushing all tiles"
msgstr ""
-#: ../raster/r.covar/main.c:110 ../imagery/i.pca/main.c:200
-msgid "No non-null values"
-msgstr ""
-#: ../raster/r.mfilter/getrow.c:23
+#: ../raster3d/r3.null/main.c:170
#, fuzzy
-msgid "Error reading temporary file"
+msgid "modifyNull: Unable to close tmp file"
msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/getfilt.c:27
-#, fuzzy, c-format
-msgid "Cannot open filter file '%s'"
-msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/getfilt.c:47
-msgid "Illegal filter matrix size specified"
+#: ../raster3d/r3.null/main.c:188
+msgid "Explicitly create the 3D NULL-value bitmap file."
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:50
-msgid "Even filter matrix size specified"
+#: ../raster3d/r3.neighbors/main.c:94 ../raster/r.neighbors/main.c:94
+#: ../raster/r.series/main.c:102 ../raster/r.resamp.stats/main.c:296
+#, c-format
+msgid "Unknown method <%s>"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:72
-msgid "Illegal filter matrix"
+#: ../raster3d/r3.neighbors/main.c:119 ../raster/r.series/main.c:157
+msgid "Aggregate operation"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
-#: ../raster/r.mfilter/getfilt.c:124
-msgid "Filter file format error"
-msgstr ""
+#: ../raster3d/r3.neighbors/main.c:127 ../raster/r.neighbors/main.c:210
+#: ../raster/r.series/main.c:164 ../raster/r.resamp.stats/main.c:277
+#, fuzzy
+msgid "Quantile to calculate for method=quantile"
+msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/getfilt.c:83
-msgid "Duplicate filter divisor specified"
+#: ../raster3d/r3.neighbors/main.c:137
+msgid ""
+"The size of the window in x, y and z direction, values must be odd integer "
+"numbers, eg: 3,3,3"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:101
-msgid "Illegal divisor matrix"
+#: ../raster3d/r3.neighbors/main.c:209
+msgid "neighbor"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:110
-msgid "Duplicate filter type specified"
+#: ../raster3d/r3.neighbors/main.c:210 ../raster/r.neighbors/main.c:143
+#: ../raster/r.series/main.c:134 ../vector/v.neighbors/main.c:53
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:4
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:3
+msgid "aggregation"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:117
-msgid "Illegal filter type specified"
+#: ../raster3d/r3.neighbors/main.c:212 ../raster/r.neighbors/main.c:144
+#: ../raster/r.mfilter/main.c:59
+msgid "filter"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:127
-msgid "Duplicate filter start specified"
+#: ../raster3d/r3.neighbors/main.c:214
+msgid ""
+"Makes each voxel value a function of the values assigned to the voxels "
+"around it, and stores new voxel values in an output 3D raster map"
msgstr ""
-#: ../raster/r.mfilter/getfilt.c:135
-#, c-format
-msgid "Filter start %s ignored, using UL"
-msgstr ""
-#: ../raster/r.mfilter/getfilt.c:157
-msgid "Illegal filter file format"
-msgstr ""
-#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
+#: ../raster3d/r3.neighbors/main.c:283
#, fuzzy
-msgid "Unable to create temporary file"
+msgid "Unable to allocate buffer"
msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/perform.c:81
-#, fuzzy, c-format
-msgid "Writing raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/main.c:59 ../raster/r.neighbors/main.c:143
-#: ../raster3d/r3.neighbors/main.c:212
-msgid "filter"
-msgstr ""
-#: ../raster/r.mfilter/main.c:60
+#: ../raster3d/r3.neighbors/main.c:305 ../raster3d/r3.in.bin/main.c:202
#, fuzzy
-msgid "Performs raster map matrix filter."
+msgid "Error flushing tiles"
msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/main.c:71
+#: ../raster3d/r3.in.ascii/main.c:83 ../raster/r.in.ascii/main.c:78
+#: ../vector/v.in.ascii/main.c:57
#, fuzzy
-msgid "Path to filter file"
+msgid "Name of input file to be imported"
msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/main.c:79
-msgid "Number of times to repeat the filter"
+#: ../raster3d/r3.in.ascii/main.c:94
+msgid "String representing NULL value data cell (use 'none' if no such value)"
msgstr ""
-#: ../raster/r.mfilter/main.c:80 ../raster/r.mfilter/main.c:99
-#: ../imagery/i.pca/main.c:112 ../imagery/i.pca/main.c:123
-msgid "Filter"
-msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:184
+#, fuzzy, c-format
+msgid "Unsupported GRASS version %s"
+msgstr "출력할 래스터맵"
-#: ../raster/r.mfilter/main.c:86
-msgid "Output raster map title"
+#: ../raster3d/r3.in.ascii/main.c:227
+#, c-format
+msgid "Loading data ... (%dx%dx%d)"
msgstr ""
-#: ../raster/r.mfilter/main.c:98
-msgid "Apply filter only to null data values"
+#: ../raster3d/r3.in.ascii/main.c:260
+msgid "End of file reached while still loading data."
msgstr ""
-#: ../raster/r.mfilter/main.c:125
+#: ../raster3d/r3.in.ascii/main.c:272
#, fuzzy
-msgid "Raster map too small for the size of the filter"
+msgid "Invalid value detected"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:76
-msgid "volume"
+#: ../raster3d/r3.in.ascii/main.c:284
+#, c-format
+msgid ""
+"Data exists in input file after fully importing expected data. [%.4f ...]"
msgstr ""
-#: ../raster/r.volume/main.c:77
-#, fuzzy
-msgid "clumps"
-msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:79
-msgid "Calculates the volume of data \"clumps\"."
+#: ../raster3d/r3.in.ascii/main.c:318 ../raster3d/r3.in.bin/main.c:253
+#: ../raster/r.in.bin/main.c:236 ../raster/r.in.xyz/main.c:160
+#: ../raster/r.in.gdal/main.c:82 ../raster/r.in.poly/main.c:30
+#: ../raster/r.in.arc/main.c:61 ../raster/r.external/main.c:56
+#: ../raster/r.in.ascii/main.c:70 ../raster/r.in.mat/main.c:92
+#: ../raster/r.in.gridatb/main.c:46 ../raster/r.in.lidar/main.c:162
+#: ../raster/r.in.png/main.c:520 ../vector/v.in.sites/main.c:58
+#: ../vector/v.in.db/main.c:53 ../vector/v.in.lidar/main.c:155
+#: ../vector/v.in.dwg/main.c:83 ../vector/v.in.dxf/main.c:65
+#: ../vector/v.in.ogr/main.c:132 ../vector/v.in.ascii/main.c:50
+#: ../vector/v.external/main.c:49 ../vector/v.convert/main.c:37
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:3
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:3
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:3
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:3
+#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:3
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:3
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:3
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:3
+#: ../locale/scriptstrings/r.unpack_to_translate.c:3
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:3
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:3
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:3
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:3
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:3
+msgid "import"
msgstr ""
-#: ../raster/r.volume/main.c:80
-msgid ""
-"Optionally produces a GRASS vector points map containing the calculated "
-"centroids of these clumps."
+#: ../raster3d/r3.in.ascii/main.c:319 ../raster3d/r3.to.rast/main.c:207
+#: ../raster3d/r3.out.ascii/main.c:308 ../raster/r.in.xyz/main.c:161
+#: ../raster/r.to.rast3elev/main.c:362 ../raster/r.to.vect/main.c:71
+#: ../raster/r.in.ascii/main.c:71 ../raster/r.to.rast3/main.c:198
+#: ../vector/v.to.rast/main.c:45 ../vector/v.convert/main.c:38
+#: ../vector/v.to.rast3/main.c:49
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:3
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:4
+msgid "conversion"
msgstr ""
-#: ../raster/r.volume/main.c:85
+#: ../raster3d/r3.in.ascii/main.c:322
#, fuzzy
-msgid ""
-"Name of input raster map representing data that will be summed within clumps"
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:91
+#: ../raster3d/r3.in.ascii/main.c:349 ../raster3d/r3.in.v5d/main.c:214
+#: ../raster3d/r3.in.bin/main.c:466
#, fuzzy
-msgid "Name of input clump raster map"
+msgid "Unable to open 3D raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:92
-msgid ""
-"Preferably the output of r.clump. If no clump map is given than MASK is used."
-msgstr ""
+#: ../raster3d/r3.in.ascii/main.c:355 ../raster3d/r3.out.v5d/main.c:54
+#: ../raster3d/r3.out.v5d/main.c:325 ../raster3d/r3.gwflow/main.c:412
+#: ../raster3d/r3.out.vtk/main.c:252 ../raster3d/r3.out.vtk/main.c:338
+#: ../raster3d/r3.in.v5d/main.c:219 ../raster3d/r3.in.bin/main.c:474
+#: ../raster3d/r3.out.netcdf/main.c:648 ../raster3d/r3.to.rast/main.c:55
+#: ../raster3d/r3.to.rast/main.c:383 ../raster3d/r3.out.ascii/main.c:62
+#: ../raster3d/r3.out.ascii/main.c:370 ../raster3d/r3.cross.rast/main.c:55
+#, fuzzy
+msgid "Unable to close 3D raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:98
+#: ../raster3d/r3.in.ascii/main.c:365
#, fuzzy
-msgid "Name for output vector points map to contain clump centroids"
+msgid "Unable to close ASCII file"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:103 ../raster/r.report/parse.c:65
+#: ../raster3d/r3.retile/main.c:49
#, fuzzy
-msgid "Name for output file to hold the report"
+msgid "Unable to close the 3D raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:105
+#: ../raster3d/r3.retile/main.c:71
#, fuzzy
-msgid "If no output file given report is printed to standard output"
+msgid "Name of the retiled 3D raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:109
-msgid "Generate unformatted report (items separated by colon)"
-msgstr ""
+#: ../raster3d/r3.retile/main.c:97 ../raster/r.tile/main.c:43
+#: ../locale/scriptstrings/r.tileset_to_translate.c:3
+#, fuzzy
+msgid "tiling"
+msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:142
+#: ../raster3d/r3.retile/main.c:99
msgid ""
-"No MASK found. If no clump map is given than the MASK is required. You need "
-"to define a clump raster map or create a MASK by r.mask command."
+"Retiles an existing 3D raster map with user defined x, y and z tile size."
msgstr ""
-#: ../raster/r.volume/main.c:144
-msgid "No clump map given, using MASK"
+#: ../raster3d/r3.retile/main.c:135
+msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
msgstr ""
-#: ../raster/r.volume/main.c:196
-#, c-format
-msgid "Invalid category value %d (max=%d): row=%d col=%d"
+#: ../raster3d/r3.retile/main.c:148
+#, fuzzy
+msgid "Error closing 3D raster map"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.v5d/main.c:72
+msgid "3D raster map to be converted to Vis5D (V5D) file"
msgstr ""
-#: ../raster/r.volume/main.c:229
-#, fuzzy, c-format
-msgid "Creating vector point map <%s>..."
+#: ../raster3d/r3.out.v5d/main.c:76
+#, fuzzy
+msgid "Name for V5D output file"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:231
-#, fuzzy, c-format
-msgid "From '%s' on raster map <%s> using clumps from <%s>"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.v5d/main.c:146
+#, c-format
+msgid "Vis5D allows %d columns, %d columns found"
+msgstr ""
-#: ../raster/r.volume/main.c:241 ../raster/r.random/random.c:74
-#: ../raster/r.to.vect/main.c:181 ../raster/r.contour/main.c:166
-#: ../doc/vector/v.example/main.c:131 ../misc/m.nviz.image/vector.c:295
-#: ../display/d.thematic.area/plot1.c:111 ../display/d.vect/shape.c:51
-#: ../display/d.vect/attr.c:43 ../display/d.vect.chart/plot.c:43
-#: ../ps/ps.map/catval.c:53 ../ps/ps.map/catval.c:115
-#: ../ps/ps.map/catval.c:181 ../vector/v.in.dxf/write_vect.c:211
-#: ../vector/v.extrude/main.c:224 ../vector/v.label/main.c:277
-#: ../vector/v.transform/trans_digit.c:40 ../vector/v.in.ascii/main.c:322
-#: ../vector/v.surf.rst/main.c:587 ../vector/v.info/print.c:147
-#: ../vector/v.what.rast3/main.c:124 ../vector/v.out.ogr/main.c:586
-#: ../vector/v.out.svg/main.c:158 ../vector/v.sample/main.c:170
-#: ../vector/v.net.distance/main.c:250 ../vector/v.vol.rst/main.c:599
-#: ../vector/v.vol.rst/user1.c:99 ../vector/v.patch/main.c:135
-#: ../vector/v.patch/main.c:165 ../vector/v.patch/main.c:279
-#: ../vector/v.patch/main.c:347 ../vector/v.in.sites/main.c:165
-#: ../vector/v.net.path/path.c:96 ../vector/v.to.points/main.c:161
-#: ../vector/v.label.sa/labels.c:77 ../vector/v.db.select/main.c:159
-#: ../vector/v.colors.out/make_colors.c:35
-#: ../vector/v.surf.idw/read_sites.c:53 ../vector/v.colors/read_rgb.c:28
-#: ../vector/v.colors/scan_attr.c:29 ../vector/v.colors/write_rgb.c:25
-#: ../vector/v.class/main.c:116 ../vector/v.net.allpairs/main.c:166
-#: ../vector/v.surf.bspline/main.c:379
-#: ../vector/v.surf.bspline/crosscorr.c:123 ../vector/v.buffer/main.c:406
-#: ../vector/v.mkgrid/main.c:230 ../vector/v.extract/main.c:258
-#: ../vector/v.out.vtk/writeVTK.c:649 ../vector/v.to.rast3/main.c:82
-#: ../vector/v.distance/main.c:423 ../vector/v.distance/main.c:458
-#: ../vector/v.distance/main.c:504 ../vector/v.distance/main.c:1208
-#: ../vector/v.distance/main.c:1229 ../vector/v.to.db/query.c:89
-#: ../vector/v.to.db/update.c:46 ../vector/v.in.dwg/main.c:212
-#: ../vector/v.to.3d/trans3.c:57 ../vector/v.to.3d/trans2.c:55
-#: ../vector/v.overlay/main.c:231 ../vector/v.overlay/main.c:391
-#: ../vector/v.net.flow/main.c:169 ../vector/v.normal/main.c:121
-#: ../vector/v.edit/select.c:513 ../vector/v.what.rast/main.c:142
-#: ../vector/v.kcv/main.c:150 ../vector/v.in.db/main.c:130
-#: ../vector/v.in.db/main.c:267 ../vector/v.lrs/v.lrs.create/main.c:288
-#: ../vector/v.lrs/v.lrs.create/main.c:296 ../vector/v.reclass/main.c:130
-#: ../vector/v.to.rast/vect2rast.c:58 ../vector/v.to.rast/support.c:131
-#: ../vector/v.to.rast/support.c:292 ../vector/v.to.rast/support.c:443
-#: ../vector/v.db.connect/main.c:222 ../vector/v.db.connect/main.c:330
-#: ../vector/v.net.timetable/main.c:93 ../vector/v.out.postgis/table.c:34
-#: ../vector/v.net.components/main.c:179 ../vector/v.net.centrality/main.c:246
-#: ../vector/v.random/main.c:177
+#: ../raster3d/r3.out.v5d/main.c:149
+#, c-format
+msgid "Vis5D allows %d rows, %d rows found"
+msgstr ""
+#: ../raster3d/r3.out.v5d/main.c:256
#, fuzzy, c-format
-msgid "Unable to open database <%s> by driver <%s>"
+msgid "Unable to create V5D file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:258 ../raster/r.to.vect/main.c:222
-#: ../vector/v.in.dxf/write_vect.c:232 ../vector/v.in.ascii/main.c:389
-#: ../vector/v.in.sites/main.c:172 ../vector/v.mkgrid/main.c:248
-#: ../vector/v.lrs/v.lrs.create/main.c:327 ../vector/v.random/main.c:194
-#, fuzzy, c-format
-msgid "Unable to create table: %s"
+#: ../raster3d/r3.out.v5d/main.c:261
+#, fuzzy
+msgid "Failed writing V5D file"
msgstr "출력할 래스터맵"
-#: ../raster/r.volume/main.c:264
-#, c-format
-msgid ""
-"\n"
-"Volume report on data from <%s> using clumps on <%s> raster map"
+#: ../raster3d/r3.out.v5d/main.c:285 ../raster3d/r3.out.vtk/main.c:378
+#: ../raster3d/r3.out.netcdf/main.c:587 ../raster3d/r3.out.bin/main.c:206
+#: ../raster3d/r3.out.ascii/main.c:307 ../raster/r.out.gdal/main.c:130
+#: ../raster/r.out.pov/main.c:122 ../raster/r.out.mat/main.c:63
+#: ../raster/r.out.ppm/main.c:55 ../raster/r.out.ascii/main.c:60
+#: ../raster/r.out.ppm3/main.c:58 ../raster/r.out.mpeg/main.c:103
+#: ../raster/r.out.png/main.c:113 ../raster/r.out.arc/main.c:61
+#: ../raster/r.colors.out/raster_main.c:47
+#: ../raster/r.colors.out/raster3d_main.c:48
+#: ../raster/r.external.out/main.c:215 ../raster/r.out.vtk/main.c:60
+#: ../raster/r.out.gridatb/main.c:68 ../raster/r.out.bin/main.c:280
+#: ../raster/r.out.tiff/main.c:93 ../raster/r.out.vrml/main.c:48
+#: ../vector/v.colors.out/main.c:51 ../vector/v.out.vtk/main.c:48
+#: ../vector/v.external.out/main.c:44 ../vector/v.out.pov/main.c:47
+#: ../vector/v.out.postgis/main.c:45 ../vector/v.out.svg/main.c:78
+#: ../vector/v.out.ascii/main.c:48 ../vector/v.out.ogr/main.c:81
+#: ../vector/v.out.dxf/main.c:57
+#: ../locale/scriptstrings/t.rast.export_to_translate.c:3
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:3
+#: ../locale/scriptstrings/r.pack_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.export_to_translate.c:3
+#: ../locale/scriptstrings/v.out.gps_to_translate.c:3
+#: ../locale/scriptstrings/d.out.file_to_translate.c:3
+msgid "export"
msgstr ""
-#: ../raster/r.volume/main.c:268
-#, c-format
-msgid "Category Average Data # Cells Centroid Total\n"
+#: ../raster3d/r3.out.v5d/main.c:287
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
msgstr ""
-#: ../raster/r.volume/main.c:270
-#, c-format
-msgid "Number in clump Total in clump Easting Northing Volume"
+#: ../raster3d/r3.out.v5d/main.c:294
+msgid "Use map coordinates instead of xyz coordinates"
msgstr ""
-#: ../raster/r.volume/main.c:294 ../raster/r.to.vect/areas_io.c:377
-#: ../raster/r.to.vect/util.c:157 ../vector/v.in.lidar/main.c:762
-#: ../vector/v.in.ogr/main.c:1086 ../vector/v.random/main.c:289
-#, c-format
-msgid "Cannot insert new row: %s"
+#: ../raster3d/r3.gwflow/main.c:54
+msgid "Input 3D raster map with initial piezometric heads in [m]"
msgstr ""
-#: ../raster/r.volume/main.c:316
-msgid "Total Volume"
+#: ../raster3d/r3.gwflow/main.c:60
+msgid ""
+"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
+"active, 2 - dirichlet"
msgstr ""
-#: ../raster/r.stream.stats/io.c:376 ../raster/r.stream.distance/io.c:376
-#, fuzzy, c-format
-msgid "Raster <%s> is not of type '%s'"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.gwflow/main.c:65
+msgid ""
+"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
-#: ../raster/r.stream.stats/io.c:531
-#, c-format
-msgid "ram_null:Cannot convert to null at: %d %d"
+#: ../raster3d/r3.gwflow/main.c:70
+msgid ""
+"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../raster/r.stream.stats/main.c:52
+#: ../raster3d/r3.gwflow/main.c:75
msgid ""
-"Calculates Horton's statistics for Strahler and Horton ordered networks "
-"created with r.stream.order."
+"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../raster/r.stream.stats/main.c:56
+#: ../raster3d/r3.gwflow/main.c:80
#, fuzzy
-msgid "Horton's statistics"
+msgid "Input 3D raster map with sources and sinks in [m^3/s]"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.stats/main.c:64 ../raster/r.stream.order/main.c:33
+#: ../raster3d/r3.gwflow/main.c:84
#, fuzzy
-msgid "Name of input flow direction raster map"
+msgid "Specific yield [1/m] input 3D raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.stats/main.c:78
+#: ../raster3d/r3.gwflow/main.c:89
#, fuzzy
-msgid "Name for output file (if omitted output to stdout)"
+msgid "Recharge input 3D raster map in m^3/s"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.stats/main.c:88
-msgid "Print only catchment's statistics"
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:93
+#, fuzzy
+msgid ""
+"Output 3D raster map storing the piezometric head result of the numerical "
+"calculation"
+msgstr "출력할 래스터맵"
-#: ../raster/r.stream.stats/main.c:93
+#: ../raster3d/r3.gwflow/main.c:99
#, fuzzy
-msgid "Print only orders' statistics"
+msgid ""
+"Output 3D raster map storing the groundwater filter velocity vector part in "
+"x direction [m/s]"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.stats/main.c:106 ../vector/v.rectify/main.c:182
-#: ../vector/v.net.salesman/main.c:516
-#, fuzzy, c-format
-msgid "Unable to open file '%s' for writing"
+#: ../raster3d/r3.gwflow/main.c:105
+#, fuzzy
+msgid ""
+"y direction [m/s]"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.stats/stats_prepare.c:7
-#: ../raster/r.stream.distance/distance_calc.c:7
-msgid "Circular buffer too small"
-msgstr ""
+#: ../raster3d/r3.gwflow/main.c:111
+#, fuzzy
+msgid ""
+"z direction [m/s]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.vtk/main.c:62
+#: ../raster3d/r3.gwflow/main.c:117
#, fuzzy
-msgid "Converts raster maps into the VTK-ASCII format."
+msgid ""
+"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.vtk/main.c:73
-msgid ""
-"No input maps specified. You need to specify at least one input map or three "
-"vector maps or three rgb maps."
+#: ../raster3d/r3.gwflow/main.c:127
+msgid "Use RASTER3D mask (if exists)"
msgstr ""
-#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
-#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
-#, c-format
-msgid "Open Raster file %s"
+#: ../raster3d/r3.gwflow/main.c:131 ../raster/r.solute.transport/main.c:192
+msgid ""
+"Use a full filled quadratic linear equation system, default is a sparse "
+"linear equation system."
msgstr ""
-#: ../raster/r.out.vtk/main.c:222
-msgid "Writing VTK ImageData\n"
+#: ../raster3d/r3.gwflow/main.c:160 ../raster/r.gwflow/main.c:209
+msgid "groundwater flow"
msgstr ""
-#: ../raster/r.out.vtk/main.c:232
-msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
+#: ../raster3d/r3.gwflow/main.c:162 ../raster/r.flow/main.c:423
+#: ../raster/r.usler/main.c:53 ../raster/r.stream.distance/main.c:54
+#: ../raster/r.topmodel/main.c:49 ../raster/r.carve/main.c:75
+#: ../raster/r.drain/main.c:110 ../raster/r.fill.dir/main.c:87
+#: ../raster/r.stream.snap/main.c:50 ../raster/r.lake/main.c:151
+#: ../raster/r.stream.slope/main.c:73 ../raster/r.solute.transport/main.c:230
+#: ../raster/r.stream.extract/main.c:77 ../raster/simwe/r.sim.water/main.c:111
+#: ../raster/simwe/r.sim.sediment/main.c:112
+#: ../raster/r.watershed/front/main.c:73 ../raster/r.basins.fill/main.c:55
+#: ../raster/r.stream.channel/main.c:57 ../raster/r.gwflow/main.c:210
+#: ../raster/r.uslek/main.c:54 ../raster/r.topidx/new/main.c:40
+#: ../raster/r.topidx/main.c:40 ../raster/r.topidx/old/main.c:40
+#: ../raster/r.stream.segment/main.c:58 ../raster/r.stream.order/main.c:76
+#: ../raster/r.water.outlet/main.c:68 ../raster/r.stream.stats/main.c:54
+msgid "hydrology"
msgstr ""
-#: ../raster/r.out.vtk/main.c:261
-msgid "Writing VTK Vector Data\n"
+#: ../raster3d/r3.gwflow/main.c:163
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
msgstr ""
-#: ../raster/r.out.vtk/main.c:271
+#: ../raster3d/r3.gwflow/main.c:180
msgid ""
-"Wrong vector maps. Maps should have the same type! Vector output not added!"
+"The cholesky solver does not work with sparse matrices.\n"
+"Consider to choose a full filled quadratic matrix with flag -f "
msgstr ""
-#: ../raster/r.out.vtk/main.c:283
-msgid "Error closing VTK-ASCII file"
+#: ../raster3d/r3.gwflow/main.c:279 ../raster/r.gwflow/main.c:546
+msgid "Unable to create and solve the linear equation system"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:75
-msgid "write_vtk_normal_header: Writing VTK-Header"
+#: ../raster3d/r3.gwflow/main.c:365
+#, fuzzy, c-format
+msgid "Unable to create 3D raster map <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/errorHandling.c:105
+#, fuzzy
+msgid "Unable to close input raster maps"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:122
+msgid "write_vtk_points: Writing point coordinates"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:108
-msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:256
+msgid "write_vtk_unstructured_grid_cells: Writing the cells"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:124
-msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:335
+#, c-format
+msgid ""
+"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
+"ascii file"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:139
-msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
+#: ../raster3d/r3.out.vtk/writeVTKData.c:441
+msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:148
-msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+#: ../raster3d/r3.out.vtk/main.c:117
+msgid "Specify top and bottom map"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:169
-msgid "write_vtk_structured_coordinates: Writing Coordinates"
+#: ../raster3d/r3.out.vtk/main.c:124
+#, c-format
+msgid "Top cell map <%s> not found"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:225
-msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
+#: ../raster3d/r3.out.vtk/main.c:133
+#, c-format
+msgid "Bottom cell map <%s> not found"
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:334
-msgid "write_vtk_data: Writing VTK-Data"
+#: ../raster3d/r3.out.vtk/main.c:152
+#, fuzzy, c-format
+msgid "3D raster map RGB map <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/main.c:155
+#, fuzzy
+msgid "Please provide three RGB 3D raster maps"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/main.c:165
+#, fuzzy, c-format
+msgid "3D vector map <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/main.c:168
+#, fuzzy
+msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/main.c:175
+msgid ""
+"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
+"geometry."
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:384
-msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+#: ../raster3d/r3.out.vtk/main.c:209
+msgid "No RGB Data will be created."
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:412
-msgid "Wrong map values! Values should in between 0 and 255!\n"
+#: ../raster3d/r3.out.vtk/main.c:294
+msgid "No vector data will be created."
msgstr ""
-#: ../raster/r.out.vtk/writeascii.c:442
-msgid "write_vtk_vector_data: Writing VTK-vector data"
+#: ../raster3d/r3.out.vtk/main.c:381
+#, fuzzy
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/main.c:392
+msgid "failed to interpret dp as an integer"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:34
+#: ../raster3d/r3.out.vtk/main.c:394 ../raster/r.out.ascii/main.c:119
+msgid "dp has to be from 0 to 20"
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:451 ../raster3d/r3.to.rast/main.c:271
+msgid ""
+"The 2D and 3D region settings are different. Using the 2D window settings to "
+"adjust the 2D part of the 3D region."
+msgstr ""
+#: ../raster3d/r3.out.vtk/main.c:542
#, fuzzy
-msgid "Raster map(s) to be converted to VTK-ASCII data format"
+msgid "Unable to close 3D raster map, the VTK file may be incomplete"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.vtk/parameters.c:38 ../raster3d/r3.out.vtk/parameters.c:34
+#: ../raster3d/r3.out.vtk/main.c:557
+#, fuzzy
+msgid "Unable to close VTK-ASCII file"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.vtk/parameters.c:30
+msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:34 ../raster/r.out.vtk/parameters.c:38
msgid "Name for VTK-ASCII output file"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:47
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
-msgid "Value to represent no data cell"
+#: ../raster3d/r3.out.vtk/parameters.c:41
+msgid "Float value to represent no data cell/points"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:55
-msgid "Elevation (if no elevation map is specified)"
+#: ../raster3d/r3.out.vtk/parameters.c:47
+msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:61
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
+#: ../raster3d/r3.out.vtk/parameters.c:56
+msgid "top surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:65
+msgid "bottom surface 2D raster map"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:71
msgid ""
-"Create VTK point data instead of VTK cell data (if no elevation map is given)"
+"Create 3d elevation output with a top and a bottom surface, both raster maps "
+"are required."
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:71
+#: ../raster3d/r3.out.vtk/parameters.c:82
msgid ""
-"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
+"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:81
-msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
+#: ../raster3d/r3.out.vtk/parameters.c:92
+msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:88 ../raster3d/r3.out.vtk/parameters.c:98
+#: ../raster3d/r3.out.vtk/parameters.c:98 ../raster/r.out.vtk/parameters.c:88
#: ../vector/v.out.vtk/main.c:74
msgid "Scale factor for elevation"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:100 ../raster/r.out.ascii/main.c:84
-#: ../display/d.rast.num/main.c:102 ../raster3d/r3.out.vtk/parameters.c:111
-#: ../vector/v.out.ascii/args.c:75 ../vector/v.out.vtk/main.c:68
+#: ../raster3d/r3.out.vtk/parameters.c:111 ../raster/r.out.ascii/main.c:79
+#: ../raster/r.out.vtk/parameters.c:100 ../vector/v.out.vtk/main.c:68
+#: ../vector/v.out.ascii/args.c:75 ../display/d.rast.num/main.c:103
msgid "Number of significant digits (floating point only)"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:106
-msgid "Use structured grid for elevation (not recommended)"
+#: ../raster3d/r3.out.vtk/parameters.c:116
+msgid "Use 3D raster mask (if exists) with input maps"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:112
-msgid "Use polydata-trianglestrips for elevation grid creation"
+#: ../raster3d/r3.out.vtk/parameters.c:121
+msgid "Scale factor effects the origin"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:118
+#: ../raster3d/r3.out.vtk/parameters.c:127
+#: ../raster/r.out.vtk/parameters.c:130 ../vector/v.out.vtk/main.c:87
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
+msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+msgstr ""
+#: ../raster3d/r3.out.vtk/parameters.c:133
msgid ""
-"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
+"Do not convert the top-bottom resolution in case of lat long projection to "
+"meters"
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:124
-msgid "Scale factor effects the origin (if no elevation map is given)"
+#: ../raster3d/r3.mkdspf/main.c:82
+msgid ""
+"Creates a display file from an existing grid3 file according to specified "
+"threshold levels."
msgstr ""
-#: ../raster/r.out.vtk/parameters.c:130
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:9
-#: ../raster3d/r3.out.vtk/parameters.c:127 ../vector/v.out.vtk/main.c:87
-msgid "Correct the coordinates to fit the VTK-OpenGL precision"
+#: ../raster3d/r3.mkdspf/main.c:90
+msgid "Name of an existing 3d raster map"
msgstr ""
-#: ../raster/r.gwflow/main.c:57
+#: ../raster3d/r3.mkdspf/main.c:95
#, fuzzy
-msgid "Name of input raster map with initial piezometric head in [m]"
+msgid "Name for output display file"
msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:62
-msgid ""
-"Name of input raster map providing Boundary condition status: 0-inactive, 1-"
-"active, 2-dirichlet"
+#: ../raster3d/r3.mkdspf/main.c:102
+msgid "List of thresholds for isosurfaces"
msgstr ""
-#: ../raster/r.gwflow/main.c:67
-msgid ""
-"Name of input raster map with x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../raster3d/r3.mkdspf/main.c:108
+msgid "Minimum isosurface level"
msgstr ""
-#: ../raster/r.gwflow/main.c:72
-msgid ""
-"Name of input raster map with y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../raster3d/r3.mkdspf/main.c:114
+msgid "Maximum isosurface level"
msgstr ""
-#: ../raster/r.gwflow/main.c:77
-#, fuzzy
-msgid "Name of input raster map with water sources and sinks in [m^3/s]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.mkdspf/main.c:120
+msgid "Positive increment between isosurface levels"
+msgstr ""
-#: ../raster/r.gwflow/main.c:81
-msgid ""
-"Name of input raster map with storativity for confined or effective porosity "
-"for unconfined groundwater flow booth in [-] "
+#: ../raster3d/r3.mkdspf/main.c:127
+msgid "Number of isosurface threshold levels"
msgstr ""
-#: ../raster/r.gwflow/main.c:86
-msgid "Recharge"
+#: ../raster3d/r3.mkdspf/main.c:131
+msgid "Suppress progress report & min/max information"
msgstr ""
-#: ../raster/r.gwflow/main.c:88
-#, fuzzy
-msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.mkdspf/main.c:135
+msgid "Use flat shading rather than gradient"
+msgstr ""
-#: ../raster/r.gwflow/main.c:92
-#, fuzzy
-msgid ""
-"Name of input raster map describing the top surface of the aquifer in [m]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.mkdspf/main.c:143
+#, c-format
+msgid "Region from getWindow: %d %d %d"
+msgstr ""
-#: ../raster/r.gwflow/main.c:96
-#, fuzzy
-msgid ""
-"Name of input raster map describing the bottom surface of the aquifer in [m]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.mkdspf/main.c:155
+#, c-format
+msgid "Not able to find grid3 file for [%s]"
+msgstr ""
-#: ../raster/r.gwflow/main.c:100
-#, fuzzy
-msgid "Output raster map storing the numerical result [m]"
+#: ../raster3d/r3.mkdspf/main.c:199
+#, fuzzy, c-format
+msgid "Unable to open display file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:106
-#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in x "
-"direction [m/s]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.mkdspf/main.c:220
+#, c-format
+msgid "Writing %s from %s..."
+msgstr ""
-#: ../raster/r.gwflow/main.c:112
-#, fuzzy
-msgid ""
-"Output raster map to store the groundwater filter velocity vector part in y "
-"direction [m/s]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.in.v5d/main.c:195
+msgid "Import 3-dimensional Vis5D files."
+msgstr ""
-#: ../raster/r.gwflow/main.c:118
-#, fuzzy
-msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+#: ../raster3d/r3.support/check.c:20
+#, fuzzy, c-format
+msgid "Updating statistics for <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:126
-msgid "The type of groundwater flow"
-msgstr ""
-#: ../raster/r.gwflow/main.c:132
-#, fuzzy
-msgid "Name of input raster map providing the height of the river bed in [m]"
+#: ../raster3d/r3.support/check.c:36
+#, fuzzy, c-format
+msgid "Updating the number of categories for <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:140
+#: ../raster3d/r3.support/main.c:51
msgid ""
-"Name of input raster map providing the water level (head) of the river with "
-"leakage connection in [m]"
+"Allows creation and/or modification of raster3d map layer support files."
msgstr ""
-#: ../raster/r.gwflow/main.c:147
+#: ../raster3d/r3.support/main.c:61 ../raster/r.support/main.c:67
#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the river bed "
-"in [1/s]."
+msgid "Text to use for map title"
msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:155
-#, fuzzy
-msgid ""
-"Name of input raster map providing the height of the drainage bed in [m]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.support/main.c:69 ../raster/r.support/main.c:75
+msgid "Text to append to the next line of the map's metadata file"
+msgstr ""
-#: ../raster/r.gwflow/main.c:162
-#, fuzzy
-msgid ""
-"Name of input raster map providing the leakage coefficient of the drainage "
-"bed in [1/s]"
-msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:167
-msgid "The maximum number of iterations in the linearization approach"
+#: ../raster3d/r3.support/main.c:75
+msgid "The map data unit"
msgstr ""
-#: ../raster/r.gwflow/main.c:176
-msgid ""
-"Allocate a full quadratic linear equation system, default is a sparse linear "
-"equation system."
+#: ../raster3d/r3.support/main.c:81
+msgid "The vertical unit of the map"
msgstr ""
-#: ../raster/r.gwflow/main.c:209 ../raster3d/r3.gwflow/main.c:160
-msgid "groundwater flow"
+#: ../raster3d/r3.support/main.c:88 ../raster/r.support/main.c:94
+msgid "Text to use for data source, line 1"
msgstr ""
-#: ../raster/r.gwflow/main.c:212
-msgid ""
-"Numerical calculation program for transient, confined and unconfined "
-"groundwater flow in two dimensions."
+#: ../raster3d/r3.support/main.c:95 ../raster/r.support/main.c:101
+msgid "Text to use for data source, line 2"
msgstr ""
-#: ../raster/r.gwflow/main.c:222 ../raster/r.topidx/main.c:55
-#: ../raster/r.solute.transport/main.c:244
-#, c-format
-msgid "Lat/Long location is not supported by %s. Please reproject map first."
+#: ../raster3d/r3.support/main.c:103 ../raster/r.support/main.c:109
+msgid "Text to use for data description or keyword(s)"
msgstr ""
-#: ../raster/r.gwflow/main.c:237
-msgid "Please provide river_head, river_leak and river_bed maps"
+#: ../raster3d/r3.support/main.c:110 ../raster/r.support/main.c:116
+#: ../raster/r.category/main.c:80
+#, fuzzy
+msgid "Raster map from which to copy category table"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.support/main.c:115 ../raster/r.support/main.c:121
+msgid "Text file from which to load history"
msgstr ""
-#: ../raster/r.gwflow/main.c:249
-msgid "Please provide drain_head and drain_leak maps"
+#: ../raster3d/r3.support/main.c:120 ../raster/r.support/main.c:126
+msgid "Text file in which to save history"
msgstr ""
-#: ../raster/r.gwflow/main.c:263
-msgid ""
-"The cholesky solver dos not work with sparse matrices. You may choose a full "
-"filled quadratic matrix, flag -f."
+#: ../raster3d/r3.support/main.c:124
+msgid "Update range"
msgstr ""
-#: ../raster/r.gwflow/main.c:293
+#: ../raster3d/r3.support/main.c:247 ../raster/r.statistics/main.c:109
+#: ../raster/r.support/main.c:249 ../display/d.title/main.c:110
#, fuzzy, c-format
-msgid "Calculation time: %g"
+msgid "Unable to read category file of raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.gwflow/main.c:380
+#: ../raster3d/r3.support/main.c:251 ../raster/r.support/main.c:253
#, c-format
-msgid "Calculation of unconfined groundwater flow loop %i"
+msgid "cats table for [%s] set to %s"
msgstr ""
-#: ../raster/r.gwflow/main.c:403
+#: ../raster3d/r3.in.bin/main.c:73
+#, fuzzy
+msgid "Error reading binary data"
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.in.bin/main.c:154
#, c-format
-msgid "Maximum difference between this and last increment: %g"
+msgid "Loading %s data with %i bytes ... (%dx%dx%d)"
msgstr ""
-#: ../raster/r.gwflow/main.c:546 ../raster3d/r3.gwflow/main.c:279
-msgid "Unable to create and solve the linear equation system"
-msgstr ""
+#: ../raster3d/r3.in.bin/main.c:255
+#, fuzzy
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr "출력할 래스터맵"
-#: ../raster/r.quant/read_rules.c:50
-msgid "Old data range is empty"
-msgstr ""
+#: ../raster3d/r3.in.bin/main.c:258
+#, fuzzy
+msgid "Name of binary 3D raster file to be imported"
+msgstr "출력할 래스터맵"
-#: ../raster/r.quant/read_rules.c:56
-#, c-format
-msgid "Old data range is %s to %s"
-msgstr ""
+#: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:227
+#, fuzzy
+msgid "Number of bytes per cell in binary file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.quant/read_rules.c:59
-msgid "Old integer data range is empty"
+#: ../raster3d/r3.in.bin/main.c:276
+msgid "Byte order in binary file"
msgstr ""
-#: ../raster/r.quant/read_rules.c:61
-#, c-format
-msgid "Old integer data range is %d to %d"
+#: ../raster3d/r3.in.bin/main.c:284 ../raster/r.in.bin/main.c:300
+msgid "Northern limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.quant/read_rules.c:83
-#, fuzzy, c-format
-msgid "unable to open input file <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.quant/read_rules.c:89
-#, c-format
-msgid ""
-"\n"
-"Enter the rule or 'help' for the format description or 'end' to exit:\n"
+#: ../raster3d/r3.in.bin/main.c:292 ../raster/r.in.bin/main.c:308
+msgid "Southern limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.quant/read_rules.c:112
-msgid "quant rules do not cover the whole range map"
+#: ../raster3d/r3.in.bin/main.c:300 ../raster/r.in.bin/main.c:316
+msgid "Eastern limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:131
-#, c-format
-msgid "%s is not a valid rule"
+#: ../raster3d/r3.in.bin/main.c:308 ../raster/r.in.bin/main.c:324
+msgid "Western limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.quant/main.c:48
-#, fuzzy
-msgid "quantization"
-msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:51
-msgid "Produces the quantization file for a floating-point map."
+#: ../raster3d/r3.in.bin/main.c:316
+msgid "Bottom limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.quant/main.c:59
-msgid "Raster map(s) to be quantized"
+#: ../raster3d/r3.in.bin/main.c:323
+msgid "Top limit of geographic region (outer edge)"
msgstr ""
-#: ../raster/r.quant/main.c:64
+#: ../raster3d/r3.in.bin/main.c:344
#, fuzzy
-msgid "Path to rules file (\"-\" to read from stdin)"
+msgid "Number of depths"
msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:70
-msgid "Base map to take quant rules from"
+#: ../raster3d/r3.in.bin/main.c:351 ../raster/r.in.bin/main.c:345
+msgid "Set Value to NULL"
msgstr ""
-#: ../raster/r.quant/main.c:75
-msgid "Floating point range: dmin,dmax"
+#: ../raster3d/r3.in.bin/main.c:356 ../raster3d/r3.out.bin/main.c:240
+#: ../raster3d/r3.out.ascii/main.c:109
+msgid "Switch the row order in output from north->south to south->north"
msgstr ""
-#: ../raster/r.quant/main.c:81
-msgid "Integer range: min,max"
+#: ../raster3d/r3.in.bin/main.c:361 ../raster3d/r3.out.bin/main.c:245
+#: ../raster3d/r3.out.ascii/main.c:113
+msgid "Switch the depth order in output from bottom->top to top->bottom"
msgstr ""
-#: ../raster/r.quant/main.c:86
-msgid "Truncate floating point data"
+#: ../raster3d/r3.in.bin/main.c:367
+msgid "Binary data is of type integer"
msgstr ""
-#: ../raster/r.quant/main.c:90
-msgid "Round floating point data"
+#: ../raster3d/r3.in.bin/main.c:371 ../raster/r.in.bin/main.c:252
+msgid "Signed data (two's complement)"
msgstr ""
-#: ../raster/r.quant/main.c:111
-msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
+#: ../raster3d/r3.in.bin/main.c:402
+#, c-format
+msgid "bytes=%d; must be 4 or 8 in case of floating point input"
msgstr ""
-#: ../raster/r.quant/main.c:119
-msgid "fprange= and range= must be used together"
+#: ../raster3d/r3.in.bin/main.c:412 ../raster/r.in.bin/main.c:404
+msgid "Integer input doesn't support size=8 in this build"
msgstr ""
-#: ../raster/r.quant/main.c:129
-#, c-format
-msgid "%s is integer map, it can't be quantized"
+#: ../raster3d/r3.in.bin/main.c:416 ../raster/r.in.bin/main.c:408
+msgid "bytes= must be 1, 2, 4 or 8"
msgstr ""
-#: ../raster/r.quant/main.c:137
-msgid "Truncating..."
+#: ../raster3d/r3.in.bin/main.c:427 ../raster/r.in.bin/main.c:433
+#: ../display/d.grid/main.c:247
+#, c-format
+msgid "Illegal north coordinate <%s>"
msgstr ""
-#: ../raster/r.quant/main.c:142
-msgid "Rounding..."
-msgstr ""
+#: ../raster3d/r3.in.bin/main.c:429 ../raster/r.in.bin/main.c:435
+#, fuzzy, c-format
+msgid "Illegal south coordinate <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:150
+#: ../raster3d/r3.in.bin/main.c:431 ../raster/r.in.bin/main.c:437
+#: ../display/d.grid/main.c:241
#, c-format
-msgid "%s is integer map, it can't be used as basemap"
+msgid "Illegal east coordinate <%s>"
msgstr ""
-#: ../raster/r.quant/main.c:154
+#: ../raster3d/r3.in.bin/main.c:433 ../raster/r.in.bin/main.c:439
#, fuzzy, c-format
-msgid "unable to read quant rules for basemap <%s>"
+msgid "Illegal west coordinate <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:161
+#: ../raster3d/r3.in.bin/main.c:441 ../raster/r.in.bin/main.c:445
#, fuzzy, c-format
-msgid "invalid value for fprange= <%s>"
+msgid "Unable to open <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:163
+#: ../raster3d/r3.in.bin/main.c:449
#, c-format
-msgid "invalid value for range= <%s>"
+msgid "File Size %lld ... Total Bytes %lld"
msgstr ""
-#: ../raster/r.quant/main.c:164
-#, c-format
-msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
+#: ../raster3d/r3.in.bin/main.c:451 ../raster/r.in.bin/main.c:489
+msgid "Bytes do not match file size"
msgstr ""
-#: ../raster/r.quant/main.c:177
-msgid "No rules specified. Quant table(s) not changed."
-msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:81
+#, fuzzy, c-format
+msgid "Unable to close 3D raster map while catching error: %s"
+msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:179 ../raster/r.recode/main.c:98
-#: ../raster/r.reclass/main.c:142
-msgid "No rules specified"
-msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:97
+#, fuzzy
+msgid "Name for netCDF output file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.quant/main.c:185
-#, c-format
-msgid "New quant table created for %s"
+#: ../raster3d/r3.out.netcdf/main.c:106
+msgid "The value to be used for null values, default is the netCDF standard"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:113
-msgid "sediment flow"
-msgstr ""
+#: ../raster3d/r3.out.netcdf/main.c:111
+#, fuzzy
+msgid "Export projection information as wkt and proj4 parameter"
+msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:115
-msgid "deposition"
+#: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.to.rast/main.c:91
+#: ../raster3d/r3.out.ascii/main.c:121 ../raster3d/r3.cross.rast/main.c:109
+#: ../raster/r.to.rast3elev/main.c:194
+msgid "Use 3D raster mask (if exists) with input map"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:117
-msgid ""
-"Sediment transport and erosion/deposition simulation using path sampling "
-"method (SIMWE)."
+#: ../raster3d/r3.out.netcdf/main.c:588
+msgid "netCDF"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:124
+#: ../raster3d/r3.out.netcdf/main.c:589
#, fuzzy
-msgid "Name of water depth raster map [m]"
+msgid "Export a 3D raster map as netCDF file."
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:128
-#: ../raster/simwe/r.sim.water/main.c:120
+#: ../raster3d/r3.out.bin/main.c:113 ../raster/r.mapcalc/map3.c:126
+#: ../raster/r.mapcalc/map3.c:140 ../raster/r.mapcalc/map3.c:154
+#: ../raster/r.out.bin/main.c:53 ../raster/r.out.bin/main.c:62
+#: ../raster/r.out.bin/main.c:462
#, fuzzy
-msgid "Name of x-derivatives raster map [m/m]"
+msgid "Error writing data"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:132
-#: ../raster/simwe/r.sim.water/main.c:124
+#: ../raster3d/r3.out.bin/main.c:207
#, fuzzy
-msgid "Name of y-derivatives raster map [m/m]"
+msgid "Exports a GRASS 3D raster map to a binary array."
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:137
-#, fuzzy
-msgid "Name of detachment capacity coefficient raster map [s/m]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:220 ../raster/r.out.bin/main.c:304
+msgid "Value to write out for null"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:142
+#: ../raster3d/r3.out.bin/main.c:235 ../raster/r.in.bin/main.c:292
+#: ../raster/r.out.bin/main.c:318
#, fuzzy
-msgid "Name of transport capacity coefficient raster map [s]"
+msgid "Output byte order"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:147
+#: ../raster3d/r3.out.bin/main.c:250
#, fuzzy
-msgid "Name of critical shear stress raster map [Pa]"
+msgid "Write data as integer"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:152
-#, fuzzy
-msgid "Name of mannings n raster map"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:256 ../raster/r.out.bin/main.c:345
+msgid "Invalid value for null (integers only)"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:160
-#, fuzzy
-msgid "Name of mannings n value"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:269 ../raster/r.out.bin/main.c:395
+msgid "Floating-point output requires bytes=4 or bytes=8"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:167
-#: ../raster/simwe/r.sim.water/main.c:215
-#, fuzzy
-msgid "Base name of the output walkers vector points map"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:273 ../raster/r.out.bin/main.c:399
+msgid "Integer output doesn't support bytes=8 in this build"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:168
-#: ../raster/simwe/r.sim.water/main.c:216 ../raster/r.horizon/main.c:273
-#: ../raster/r.horizon/main.c:283 ../raster/r.horizon/main.c:291
-#: ../raster/r.sun/main.c:393 ../raster/r.sun/main.c:402
-#: ../raster/r.sun/main.c:411 ../raster/r.sun/main.c:420
-#: ../raster/r.sun/main.c:429 ../raster/r.sun/main.c:438
-#, fuzzy
-msgid "Output options"
+#: ../raster3d/r3.out.bin/main.c:321 ../raster/r.out.bin/main.c:144
+#: ../raster/r.out.bin/main.c:228 ../raster/r.out.bin/main.c:408
+#, fuzzy, c-format
+msgid "Unable to create file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:174
-#: ../raster/simwe/r.sim.water/main.c:183
-#, fuzzy
-msgid "Name of the sampling locations vector points map"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:323 ../raster/r.out.bin/main.c:446
+msgid "Using the current region settings..."
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:175
-#: ../raster/simwe/r.sim.water/main.c:184 ../raster/r.horizon/main.c:199
-#: ../raster/r.horizon/main.c:208 ../raster/r.horizon/main.c:216
-#: ../raster/r.horizon/main.c:224 ../raster/r.horizon/main.c:232
-#: ../raster/r.horizon/main.c:240 ../raster/r.horizon/main.c:248
-#: ../raster/r.horizon/main.c:256 ../raster/r.horizon/main.c:264
-#: ../raster/r.sun/main.c:257 ../raster/r.sun/main.c:266
-#: ../raster/r.sun/main.c:275 ../raster/r.sun/main.c:284
-#: ../raster/r.sun/main.c:292 ../raster/r.sun/main.c:301
-#: ../raster/r.sun/main.c:311 ../raster/r.sun/main.c:321
-#: ../raster/r.sun/main.c:331 ../raster/r.sun/main.c:341
-#: ../raster/r.sun/main.c:350 ../raster/r.sun/main.c:359
-#: ../raster/r.sun/main.c:368 ../raster/r.sun/main.c:376
-#: ../raster/r.sun/main.c:384
-#, fuzzy
-msgid "Input options"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:324 ../raster/r.out.bin/main.c:447
+#, c-format
+msgid "north=%f"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:181
-msgid ""
-"Name of the sampling points output text file. For each observation vector "
-"point the time series of sediment transport is stored."
+#: ../raster3d/r3.out.bin/main.c:325 ../raster/r.out.bin/main.c:448
+#, c-format
+msgid "south=%f"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:187
-#, fuzzy
-msgid "Name for output transport capacity raster map [kg/ms]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:326 ../raster/r.out.bin/main.c:449
+#, c-format
+msgid "east=%f"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:194
-#, fuzzy
-msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:327 ../raster/r.out.bin/main.c:450
+#, c-format
+msgid "west=%f"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:201
-#, fuzzy
-msgid "Name for output sediment concentration raster map [particle/m3]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:328
+#, c-format
+msgid "top=%f"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:207
-#, fuzzy
-msgid "Name for output sediment flux raster map [kg/ms]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:329
+#, c-format
+msgid "bottom=%f"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:214
-#, fuzzy
-msgid "Name for output erosion-deposition raster map [kg/m2s]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.bin/main.c:330 ../raster/r.out.mat/main.c:180
+#: ../raster/r.in.mat/main.c:398
+#, c-format
+msgid "rows=%d"
+msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:221
-msgid "Number of walkers"
+#: ../raster3d/r3.out.bin/main.c:331 ../raster/r.out.mat/main.c:181
+#: ../raster/r.in.mat/main.c:399
+#, c-format
+msgid "cols=%d"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:222
-#: ../raster/simwe/r.sim.sediment/main.c:230
-#: ../raster/simwe/r.sim.sediment/main.c:239
-#: ../raster/simwe/r.sim.sediment/main.c:257
-#: ../raster/simwe/r.sim.water/main.c:224
-#: ../raster/simwe/r.sim.water/main.c:232
-#: ../raster/simwe/r.sim.water/main.c:241
-#: ../raster/simwe/r.sim.water/main.c:259
-#: ../raster/simwe/r.sim.water/main.c:269
-#: ../raster/simwe/r.sim.water/main.c:277
-#: ../raster/simwe/r.sim.water/main.c:286 ../imagery/i.eb.h_sebal01/main.c:118
-#: ../imagery/i.eb.h_sebal01/main.c:126 ../imagery/i.eb.h_sebal01/main.c:133
-#: ../imagery/i.eb.h_sebal01/main.c:140 ../imagery/i.eb.h_sebal01/main.c:147
-#: ../imagery/i.eb.h_sebal01/main.c:154 ../vector/v.surf.rst/main.c:156
-#: ../vector/v.surf.rst/main.c:161 ../vector/v.surf.rst/main.c:182
-#: ../vector/v.surf.rst/main.c:254 ../vector/v.surf.rst/main.c:262
-#: ../vector/v.surf.rst/main.c:269 ../vector/v.surf.rst/main.c:277
-#: ../vector/v.surf.rst/main.c:285 ../vector/v.surf.rst/main.c:294
-#: ../vector/v.surf.rst/main.c:302 ../vector/v.surf.rst/main.c:310
-#: ../vector/v.surf.rst/main.c:319 ../vector/v.surf.rst/main.c:327
-#: ../vector/v.surf.rst/main.c:334
-msgid "Parameters"
+#: ../raster3d/r3.out.bin/main.c:332
+#, c-format
+msgid "depths=%d"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:229
-#: ../raster/simwe/r.sim.water/main.c:231
-msgid "Time used for iterations [minutes]"
+#: ../raster3d/r3.to.rast/main.c:80
+msgid "3D raster map(s) to be converted to 2D raster slices"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:238
-#: ../raster/simwe/r.sim.water/main.c:240
-msgid "Time interval for creating output maps [minutes]"
+#: ../raster3d/r3.to.rast/main.c:86
+msgid "Basename for resultant raster slice maps"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:256
-#: ../raster/simwe/r.sim.water/main.c:258
-msgid "Water diffusion constant"
+#: ../raster3d/r3.to.rast/main.c:96
+msgid ""
+"Use the same resolution as the input 3D raster map for the 2D output maps, "
+"independent of the current region settings"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:336
-#: ../raster/simwe/r.sim.water/main.c:432
-msgid "More than 100 files are going to be created !!!!!"
+#: ../raster3d/r3.to.rast/main.c:208 ../raster3d/r3.cross.rast/main.c:230
+#: ../misc/m.nviz.script/main.c:71 ../misc/m.nviz.image/main.c:52
+#: ../raster/r.surf.contour/main.c:60 ../raster/r.spreadpath/main.c:89
+#: ../raster/r.statistics/main.c:55 ../raster/r.his/main.c:62
+#: ../raster/r.surf.area/main.c:76 ../raster/r.flow/main.c:422
+#: ../raster/r.out.gdal/main.c:129 ../raster/r.rescale/main.c:48
+#: ../raster/r.los/main.c:93 ../raster/r.usler/main.c:52
+#: ../raster/r.neighbors/main.c:140 ../raster/r.resamp.interp/main.c:76
+#: ../raster/r.transect/main.c:103 ../raster/r.cross/main.c:69
+#: ../raster/r.profile/main.c:50 ../raster/r.mapcalc/main.c:111
+#: ../raster/r.region/main.c:51 ../raster/r.param.scale/interface.c:54
+#: ../raster/r.volume/main.c:75 ../raster/r.series/main.c:133
+#: ../raster/r.compress/main.c:62 ../raster/r.stream.distance/main.c:53
+#: ../raster/r.sunmask/main.c:116 ../raster/r.surf.idw2/main.c:61
+#: ../raster/r.topmodel/main.c:48 ../raster/r.carve/main.c:74
+#: ../raster/r.timestamp/main.c:35 ../raster/r.out.pov/main.c:121
+#: ../raster/r.info/main.c:69 ../raster/r.quantile/main.c:255
+#: ../raster/r.drain/main.c:109 ../raster/r.circle/main.c:51
+#: ../raster/r.in.bin/main.c:235 ../raster/r.grow/main.c:126
+#: ../raster/r.series.accumulate/main.c:80 ../raster/r.in.xyz/main.c:159
+#: ../raster/r.fill.dir/main.c:86 ../raster/r.stream.snap/main.c:49
+#: ../raster/r.univar/r.univar_main.c:100 ../raster/r.resamp.filter/main.c:384
+#: ../raster/r.distance/main.c:38 ../raster/r.lake/main.c:150
+#: ../raster/r.kappa/main.c:68 ../raster/r.to.rast3elev/main.c:361
+#: ../raster/r.stream.slope/main.c:72 ../raster/r.reclass/main.c:50
+#: ../raster/r.resamp.stats/main.c:256 ../raster/r.solute.transport/main.c:229
+#: ../raster/r.clump/main.c:49 ../raster/r.stream.extract/main.c:76
+#: ../raster/r.out.mat/main.c:62 ../raster/r.coin/main.c:66
+#: ../raster/r.resamp.bspline/main.c:80 ../raster/simwe/r.sim.water/main.c:110
+#: ../raster/simwe/r.sim.sediment/main.c:111 ../raster/r.out.ppm/main.c:54
+#: ../raster/r.out.ascii/main.c:59 ../raster/r.stats/main.c:105
+#: ../raster/r.surf.fractal/main.c:38 ../raster/r.proj/main.c:144
+#: ../raster/r.quant/main.c:47 ../raster/r.in.gdal/main.c:81
+#: ../raster/r.null/main.c:59 ../raster/r.out.ppm3/main.c:57
+#: ../raster/r.series.interp/main.c:64 ../raster/r.tile/main.c:42
+#: ../raster/r.in.poly/main.c:29 ../raster/r.slope.aspect/main.c:151
+#: ../raster/r.resample/main.c:54 ../raster/r.out.mpeg/main.c:102
+#: ../raster/r.contour/main.c:86 ../raster/r.out.png/main.c:112
+#: ../raster/r.sunhours/main.c:71 ../raster/r.support/main.c:55
+#: ../raster/r.grow.distance/main.c:151 ../raster/r.watershed/front/main.c:72
+#: ../raster/r.out.arc/main.c:60 ../raster/r.rescale.eq/main.c:52
+#: ../raster/r.regression.multi/main.c:128 ../raster/r.basins.fill/main.c:54
+#: ../raster/r.to.vect/main.c:70 ../raster/r.colors.out/raster_main.c:45
+#: ../raster/r.bitpattern/main.c:63 ../raster/r.spread/main.c:102
+#: ../raster/r.colors/edit_colors.c:63 ../raster/r.regression.line/main.c:46
+#: ../raster/r.in.arc/main.c:60 ../raster/r.digit/main.c:44
+#: ../raster/r.li/r.li.padcv/padcv.c:53 ../raster/r.li/r.li.mpa/mpa.c:44
+#: ../raster/r.li/r.li.cwed/cwed.c:54 ../raster/r.li/r.li.renyi/renyi.c:47
+#: ../raster/r.li/r.li.patchnum/main.c:50
+#: ../raster/r.li/r.li.shannon/shannon.c:46
+#: ../raster/r.li/r.li.shape/main.c:49 ../raster/r.li/r.li.mps/mps.c:52
+#: ../raster/r.li/r.li.richness/richness.c:43
+#: ../raster/r.li/r.li.padsd/padsd.c:53
+#: ../raster/r.li/r.li.dominance/dominance.c:46
+#: ../raster/r.li/r.li.patchdensity/main.c:51
+#: ../raster/r.li/r.li.pielou/pielou.c:46
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:45
+#: ../raster/r.li/r.li.simpson/simpson.c:46
+#: ../raster/r.li/r.li.padrange/padrange.c:53 ../raster/r.external/main.c:55
+#: ../raster/r.random/main.c:51 ../raster/r.thin/main.c:56
+#: ../raster/r.shaded.relief/main.c:106 ../raster/r.stream.channel/main.c:56
+#: ../raster/r.external.out/main.c:214 ../raster/r.mode/main.c:54
+#: ../raster/r.stats.zonal/main.c:101 ../raster/r.in.ascii/main.c:69
+#: ../raster/r.to.rast3/main.c:197 ../raster/r.support.stats/main.c:38
+#: ../raster/r.gwflow/main.c:208 ../raster/r.surf.idw/main.c:103
+#: ../raster/r.surf.random/main.c:36 ../raster/r.category/main.c:52
+#: ../raster/r.uslek/main.c:53 ../raster/r.describe/main.c:54
+#: ../raster/r.what/main.c:98 ../raster/r.composite/main.c:72
+#: ../raster/r.topidx/new/main.c:39 ../raster/r.topidx/main.c:39
+#: ../raster/r.topidx/old/main.c:39 ../raster/r.out.vtk/main.c:59
+#: ../raster/r.texture/main.c:101 ../raster/r.random.surface/main.c:57
+#: ../raster/r.out.gridatb/main.c:67 ../raster/r.le/r.le.trace/main.c:55
+#: ../raster/r.le/r.le.patch/main.c:48 ../raster/r.le/r.le.setup/main.c:57
+#: ../raster/r.le/r.le.pixel/main.c:45 ../raster/r.mfilter/main.c:56
+#: ../raster/r.cost/main.c:140 ../raster/r.in.mat/main.c:91
+#: ../raster/r.random.cells/main.c:45 ../raster/r.ros/main.c:213
+#: ../raster/r.recode/main.c:48 ../raster/r.buffer/main.c:66
+#: ../raster/r.in.gridatb/main.c:45 ../raster/r.surf.gauss/main.c:38
+#: ../raster/r.out.bin/main.c:279 ../raster/r.walk/main.c:179
+#: ../raster/r.resamp.rst/main.c:148 ../raster/r.out.tiff/main.c:92
+#: ../raster/r.covar/main.c:51 ../raster/r.in.lidar/main.c:161
+#: ../raster/r.patch/main.c:52 ../raster/r.report/main.c:67
+#: ../raster/r.latlong/main.c:56 ../raster/r.stream.segment/main.c:57
+#: ../raster/r.out.vrml/main.c:47 ../raster/r.in.png/main.c:519
+#: ../raster/r.stream.order/main.c:75 ../raster/r.water.outlet/main.c:67
+#: ../raster/r.what.color/main.c:88 ../raster/r.sun/main.c:237
+#: ../raster/r.stream.stats/main.c:53 ../raster/r.horizon/main.c:178
+#: ../raster/r.stats.quantile/main.c:389 ../vector/v.what.rast/main.c:73
+#: ../vector/v.to.rast/main.c:46 ../vector/v.neighbors/main.c:52
+#: ../vector/v.sample/main.c:77 ../vector/v.what.rast3/main.c:66
+#: ../display/d.rast.arrow/main.c:97 ../display/d.colortable/main.c:61
+#: ../display/d.rgb/main.c:55 ../display/d.what.rast/main.c:50
+#: ../display/d.rast.num/main.c:78 ../display/d.profile/main.c:193
+#: ../display/d.rast/main.c:55 ../display/d.colors/main.c:42
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:4
+#: ../locale/scriptstrings/r.tileset_to_translate.c:2
+#: ../locale/scriptstrings/r.in.srtm_to_translate.c:2
+#: ../locale/scriptstrings/r.rgb_to_translate.c:2
+#: ../locale/scriptstrings/r.in.aster_to_translate.c:2
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:4
+#: ../locale/scriptstrings/r.reclass.area_to_translate.c:2
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:2
+#: ../locale/scriptstrings/r.plane_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:4
+#: ../locale/scriptstrings/r.mask_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:4
+#: ../locale/scriptstrings/v.krige_to_translate.c:4
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:4
+#: ../locale/scriptstrings/r.pack_to_translate.c:2
+#: ../locale/scriptstrings/r.grow_to_translate.c:2
+#: ../locale/scriptstrings/r.unpack_to_translate.c:2
+#: ../locale/scriptstrings/d.correlate_to_translate.c:4
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:2
+#: ../locale/scriptstrings/r.blend_to_translate.c:2
+#: ../locale/scriptstrings/t.rast.list_to_translate.c:4
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:4
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:2
+#: ../locale/scriptstrings/i.spectral_to_translate.c:4
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:2
+#: ../visualization/ximgview/main.c:292 ../doc/raster/r.example/main.c:83
+msgid "raster"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:342
-#: ../raster/simwe/r.sim.water/main.c:438
-#, c-format
-msgid "default nwalk=%d, rwalk=%f"
+#: ../raster3d/r3.to.rast/main.c:210
+msgid "Converts 3D raster maps to 2D raster maps"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:351
-#: ../raster/simwe/r.sim.water/main.c:448
+#: ../raster3d/r3.to.rast/main.c:297
#, c-format
-msgid "Using metric conversion factor %f, step=%f"
+msgid "Creating %i raster maps"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:357
-#, fuzzy
-msgid "You are not outputting any raster or site files"
+#: ../raster3d/r3.to.rast/main.c:303
+#, fuzzy, c-format
+msgid "Raster map %i Filename: %s"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.sediment/main.c:360
-#: ../raster/simwe/r.sim.water/main.c:455 ../vector/v.surf.rst/main.c:623
-#: ../vector/v.surf.rst/main.c:678 ../vector/v.vol.rst/main.c:875
-msgid "Input failed"
+#: ../raster3d/r3.to.rast/main.c:308
+#, fuzzy, c-format
+msgid ""
+"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
+msgstr "출력할 래스터맵"
+#: ../raster3d/r3.timestamp/r3.timestamp.main.c:46
+msgid "Print/add/remove a timestamp for a 3D raster map"
msgstr ""
-#: ../raster/simwe/r.sim.sediment/main.c:384
-#: ../raster/simwe/simlib/hydro.c:467
-msgid "Cannot write raster maps"
+#: ../raster3d/r3.timestamp/r3.timestamp.main.c:55
+msgid "Datetime, datetime1/datetime2, or none"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:113
-msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+#: ../raster3d/r3.timestamp/r3.timestamp.main.c:88
+msgid "Timestamp format is invalid"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:130
+#: ../raster3d/r3.out.ascii/main.c:81
#, fuzzy
-msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
+msgid "3D raster map to be converted to ASCII"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.water/main.c:139
-msgid "Rainfall excess rate unique value [mm/hr]"
+#: ../raster3d/r3.out.ascii/main.c:85
+msgid "Name for ASCII output file"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:146
-#, fuzzy
-msgid "Name of runoff infiltration rate raster map [mm/hr]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.ascii/main.c:94
+msgid "Number of decimal places for floats"
+msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:155
-msgid "Runoff infiltration rate unique value [mm/hr]"
+#: ../raster3d/r3.out.ascii/main.c:100 ../raster/r.transect/main.c:125
+#: ../raster/r.what/main.c:123
+msgid "Char string to represent no data cell"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:161
-#, fuzzy
-msgid "Name of the Manning's n raster map"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.out.ascii/main.c:105 ../raster/r.out.ascii/main.c:98
+#: ../raster/r.out.arc/main.c:82
+msgid "Suppress printing of header information"
+msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:169
-#, fuzzy
-msgid "Manning's n unique value"
-msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.water/main.c:176
-#, fuzzy
-msgid "Name of flow controls raster map (permeability ratio 0-1)"
-msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.water/main.c:190
-msgid ""
-"point the time series of water depth is stored."
+#: ../raster3d/r3.out.ascii/main.c:117
+msgid "Print grass6 compatible format. Flags -d and -r are ignored."
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:196
+#: ../raster3d/r3.out.ascii/main.c:311
#, fuzzy
-msgid "Name for output water depth raster map [m]"
+msgid "Converts a 3D raster map layer into a ASCII text file."
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.water/main.c:202
+#: ../raster3d/r3.out.ascii/main.c:374
#, fuzzy
-msgid "Name for output water discharge raster map [m3/s]"
+msgid "Unable to close new ASCII file"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/r.sim.water/main.c:208
-#, fuzzy
-msgid "Name for output simulation error raster map [m]"
-msgstr "출력할 래스터맵"
+#: ../raster3d/r3.cross.rast/main.c:90
+msgid "Input 3D raster map for cross section."
+msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:223
-msgid "Number of walkers, default is twice the no. of cells"
+#: ../raster3d/r3.cross.rast/main.c:97
+msgid "2D elevation map used to create the cross section map"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:267
-msgid "Threshold water depth [m]"
+#: ../raster3d/r3.cross.rast/main.c:104
+msgid "Resulting cross section 2D raster map"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:268
-msgid "Diffusion increases after this water depth is reached"
+#: ../raster3d/r3.cross.rast/main.c:229 ../raster/r.profile/main.c:51
+#: ../display/d.profile/main.c:192
+msgid "profile"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:276
-msgid "Diffusion increase constant"
+#: ../raster3d/r3.cross.rast/main.c:233
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:285
-msgid "Weighting factor for water flow velocity vector"
+#: ../raster3d/r3.cross.rast/main.c:259
+msgid ""
+"The 2D and 3D region settings are different. Using the 3D raster map "
+"settings to adjust the 2D region."
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:290
-msgid "Time-series output"
+#: ../raster3d/r3.cross.rast/main.c:302
+msgid "Output map already exists. Will be overwritten!"
msgstr ""
-#: ../raster/simwe/r.sim.water/main.c:452
+#: ../raster3d/r3.cross.rast/main.c:338
#, fuzzy
-msgid "You are not outputting any raster maps"
+msgid "Wrong 3D raster datatype! Cannot create raster map"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/simlib/hydro.c:205
-#, c-format
-msgid "nwalk (%d) > maxw (%d)!"
+#: ../misc/m.nviz.script/main.c:69 ../misc/m.cogo/main.c:227
+#: ../misc/m.measure/main.c:46 ../misc/m.transform/main.c:316
+#: ../locale/scriptstrings/m.proj_to_translate.c:2
+msgid "miscellaneous"
msgstr ""
-#: ../raster/simwe/simlib/hydro.c:400
+#: ../misc/m.nviz.script/main.c:70 ../misc/m.nviz.image/main.c:51
+#: ../display/d.erase/main.c:30 ../display/d.info/main.c:32
+#: ../display/d.his/main.c:63 ../display/d.mon/main.c:39
+#: ../display/d.rgb/main.c:54 ../display/d.vect/main.c:71
+#: ../display/d.rast/main.c:54
+#: ../locale/scriptstrings/d.redraw_to_translate.c:3
+#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
+#: ../visualization/ximgview/main.c:291
+msgid "graphics"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:73 ../misc/m.nviz.image/main.c:53
+#: ../raster/r.contour/main.c:89 ../raster/r.random/main.c:53
+#: ../vector/v.in.sites/main.c:57 ../vector/v.colors.out/main.c:49
+#: ../vector/v.what.rast/main.c:71 ../vector/v.edit/main.c:55
+#: ../vector/v.surf.bspline/main.c:91 ../vector/v.in.db/main.c:52
+#: ../vector/v.in.lidar/main.c:154 ../vector/v.drape/main.c:56
+#: ../vector/v.split/main.c:55 ../vector/v.lidar.correction/main.c:68
+#: ../vector/v.to.points/main.c:53 ../vector/v.vol.rst/main.c:238
+#: ../vector/v.proj/main.c:66 ../vector/v.rectify/main.c:70
+#: ../vector/v.net.allpairs/main.c:61 ../vector/v.in.dwg/main.c:82
+#: ../vector/v.type/main.c:39 ../vector/v.in.dxf/main.c:64
+#: ../vector/v.to.rast/main.c:44 ../vector/v.voronoi/main.c:123
+#: ../vector/v.in.ogr/main.c:131 ../vector/v.out.vtk/main.c:47
+#: ../vector/v.generalize/main.c:76 ../vector/v.in.ascii/main.c:49
+#: ../vector/v.external.out/main.c:43 ../vector/v.univar/main.c:92
+#: ../vector/v.db.select/main.c:52 ../vector/v.net.timetable/main.c:260
+#: ../vector/v.net.salesman/main.c:126 ../vector/v.db.connect/main.c:51
+#: ../vector/v.class/main.c:45 ../vector/v.overlay/main.c:62
+#: ../vector/v.neighbors/main.c:49 ../vector/v.surf.rst/main.c:142
+#: ../vector/v.timestamp/main.c:35 ../vector/v.net.visibility/main.c:45
+#: ../vector/v.random/main.c:112 ../vector/v.support/main.c:39
+#: ../vector/v.kernel/main.c:109 ../vector/v.build.polylines/main.c:112
+#: ../vector/v.normal/main.c:74 ../vector/v.category/main.c:75
+#: ../vector/v.label/main.c:59 ../vector/v.out.pov/main.c:46
+#: ../vector/v.select/main.c:47 ../vector/v.parallel/main.c:49
+#: ../vector/v.buffer/main.c:222 ../vector/v.clean/test/topocheck.c:42
+#: ../vector/v.clean/main.c:51 ../vector/v.sample/main.c:75
+#: ../vector/v.lidar.growing/main.c:75 ../vector/v.lrs/v.lrs.create/main.c:121
+#: ../vector/v.lrs/v.lrs.label/main.c:102
+#: ../vector/v.lrs/v.lrs.segment/main.c:71
+#: ../vector/v.lrs/v.lrs.where/main.c:57
+#: ../vector/v.net.spanningtree/main.c:46 ../vector/v.hull/main.c:52
+#: ../vector/v.distance/main.c:87 ../vector/v.out.postgis/main.c:44
+#: ../vector/v.reclass/main.c:67 ../vector/v.net.bridge/main.c:47
+#: ../vector/v.external/main.c:48 ../vector/v.net.flow/main.c:58
+#: ../vector/v.label.sa/main.c:38 ../vector/v.out.svg/main.c:77
+#: ../vector/v.net.alloc/main.c:60 ../vector/v.patch/main.c:68
+#: ../vector/v.extract/main.c:77 ../vector/v.net.steiner/main.c:345
+#: ../vector/v.extrude/main.c:67 ../vector/v.colors/main.c:55
+#: ../vector/v.what.rast3/main.c:64 ../vector/v.surf.idw/main.c:87
+#: ../vector/v.net.iso/main.c:72 ../vector/v.outlier/main.c:69
+#: ../vector/v.out.ascii/main.c:47 ../vector/v.convert/main.c:36
+#: ../vector/v.build/main.c:36 ../vector/v.net/main.c:45
+#: ../vector/v.what/main.c:60 ../vector/v.perturb/main.c:61
+#: ../vector/v.net.centrality/main.c:96 ../vector/v.segment/main.c:60
+#: ../vector/v.to.3d/main.c:36 ../vector/v.vect.stats/main.c:128
+#: ../vector/v.in.region/main.c:41 ../vector/v.out.ogr/main.c:80
+#: ../vector/v.net.components/main.c:71 ../vector/v.to.db/main.c:36
+#: ../vector/v.out.dxf/main.c:56 ../vector/v.net.distance/main.c:64
+#: ../vector/v.net.path/main.c:40 ../vector/v.delaunay/main.c:85
+#: ../vector/v.to.rast3/main.c:48 ../vector/v.mkgrid/main.c:66
+#: ../vector/v.info/main.c:37 ../vector/v.info/print.c:424
+#: ../vector/v.net.connectivity/main.c:52 ../vector/v.kcv/main.c:62
+#: ../vector/v.lidar.edgedetection/main.c:72 ../vector/v.qcount/main.c:60
+#: ../vector/v.transform/main.c:70 ../display/d.what.vect/main.c:57
+#: ../display/d.extract/main.c:50 ../display/d.vect/main.c:72
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.update_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
+#: ../locale/scriptstrings/v.report_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:4
+#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
+#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
+#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
+#: ../locale/scriptstrings/v.krige_to_translate.c:2
+#: ../locale/scriptstrings/v.db.join_to_translate.c:2
+#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
+#: ../locale/scriptstrings/v.build.all_to_translate.c:2
+#: ../locale/scriptstrings/v.out.gps_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
+#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
+#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:2
+#: ../visualization/ximgview/main.c:293 ../doc/vector/v.example/main.c:50
+msgid "vector"
+msgstr ""
+#: ../misc/m.nviz.script/main.c:74 ../misc/m.nviz.image/main.c:50
+#: ../visualization/ximgview/main.c:294
#, fuzzy
-msgid "Unable to write raster maps"
+msgid "visualization"
msgstr "출력할 래스터맵"
-#: ../raster/simwe/simlib/observation_points.c:59
-#, fuzzy, c-format
-msgid "Unable to read points from map %s"
-msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.script/main.c:75
+msgid "Creates fly-through script to run in NVIZ."
+msgstr ""
-#: ../raster/simwe/simlib/observation_points.c:80
-#, fuzzy, c-format
-msgid "Unable to open observation logfile %s for writing"
-msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.script/main.c:80
+msgid "Name of output script"
+msgstr ""
-#: ../raster/simwe/simlib/input.c:58
-#, c-format
-msgid ""
-"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
-"to process"
+#: ../misc/m.nviz.script/main.c:86
+msgid "Prefix of output images (default = NVIZ)"
msgstr ""
-#: ../raster/simwe/simlib/input.c:171
-msgid "Zero value in Mannings n"
+#: ../misc/m.nviz.script/main.c:94
+msgid "Route coordinates (east,north)"
msgstr ""
-#: ../raster/simwe/simlib/input.c:222
-msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
+#: ../misc/m.nviz.script/main.c:100
+msgid "Camera layback distance (in map units)"
msgstr ""
-#: ../raster/simwe/simlib/input.c:246
-#, c-format
-msgid ""
-"Min elevation \t= %.2f m\n"
-"Max elevation \t= %.2f m\n"
+#: ../misc/m.nviz.script/main.c:106
+msgid "Camera height above terrain"
msgstr ""
-#: ../raster/simwe/simlib/input.c:248
-#, c-format
-msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
+#: ../misc/m.nviz.script/main.c:112
+msgid "Number of frames"
msgstr ""
-#: ../raster/simwe/simlib/input.c:250
-#, c-format
-msgid "Mean flow velocity \t= %f m/s\n"
+#: ../misc/m.nviz.script/main.c:118
+msgid "Start frame number (default=0)"
msgstr ""
-#: ../raster/simwe/simlib/input.c:251
-#, c-format
-msgid "Mean Mannings \t= %f\n"
+#: ../misc/m.nviz.script/main.c:123
+msgid "Full render -- Save images"
msgstr ""
-#: ../raster/simwe/simlib/input.c:255
-#, fuzzy, c-format
-msgid "Number of iterations \t= %d cell\n"
-msgid_plural "Number of iterations \t= %d cells\n"
-msgstr[0] "출력할 래스터맵"
-msgstr[1] "출력할 래스터맵"
+#: ../misc/m.nviz.script/main.c:127
+msgid "Fly at constant elevation (ht)"
+msgstr ""
-#: ../raster/simwe/simlib/input.c:257
-#, c-format
-msgid "Time step \t= %.2f s\n"
+#: ../misc/m.nviz.script/main.c:132
+msgid "Include command in the script to output a KeyFrame file"
msgstr ""
-#: ../raster/simwe/simlib/input.c:259
-#, c-format
-msgid ""
-"Sigmax \t= %f\n"
-"Max velocity \t= %f m/s\n"
+#: ../misc/m.nviz.script/main.c:136
+msgid "Render images off-screen"
msgstr ""
-#: ../raster/simwe/simlib/input.c:261
-#, c-format
-msgid "Time step used \t= %.2f s\n"
+#: ../misc/m.nviz.script/main.c:140
+msgid "Enable vector and sites drawing"
msgstr ""
-#: ../raster/simwe/simlib/input.c:313
-#, fuzzy
-msgid "Unable to write et file"
-msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.script/main.c:148
+msgid "Either -i flag and/or route parameter must be used"
+msgstr ""
-#: ../raster/simwe/simlib/output.c:318 ../raster/simwe/simlib/output.c:326
-#, fuzzy, c-format
-msgid "FP raster map <%s> not found"
-msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.script/main.c:172
+msgid "Off-screen only available with full render mode"
+msgstr ""
-#: ../raster/r.region/main.c:54
-msgid "Sets the boundary definitions for a raster map."
+#: ../misc/m.nviz.script/main.c:250
+#, c-format
+msgid "You must provide at least four points %d"
msgstr ""
-#: ../raster/r.region/main.c:60
-msgid "Set from current region"
+#: ../misc/m.nviz.script/main.c:324
+#, c-format
+msgid "Created NVIZ script <%s>."
msgstr ""
-#: ../raster/r.region/main.c:61 ../raster/r.region/main.c:66
-#: ../raster/r.region/main.c:81 ../raster/r.region/main.c:88
-#: ../raster/r.region/main.c:95 ../raster/r.region/main.c:105
-#: ../raster/r.region/main.c:148 ../general/g.region/main.c:73
-#: ../general/g.region/main.c:79 ../general/g.region/main.c:161
-#: ../general/g.region/main.c:168 ../general/g.region/main.c:177
-#: ../general/g.region/main.c:185 ../general/g.region/main.c:195
-msgid "Existing"
+#: ../misc/m.nviz.script/main.c:439
+msgid ""
+"Skipping this point, selected point is outside region. Perhaps the camera "
+"setback distance puts it beyond the edge?"
msgstr ""
-#: ../raster/r.region/main.c:65 ../general/g.region/main.c:72
-msgid "Set from default region"
+#: ../misc/m.cogo/main.c:228 ../raster/r.grow/main.c:127
+#: ../raster/r.distance/main.c:39 ../raster/r.grow.distance/main.c:152
+#: ../vector/v.distance/main.c:88 ../display/d.rhumbline/main.c:44
+#: ../display/d.geodesic/main.c:44
+msgid "distance"
msgstr ""
-#: ../raster/r.region/main.c:71
-#, fuzzy
-msgid "Name of raster map to change"
-msgstr "출력할 래스터맵"
+#: ../misc/m.cogo/main.c:229
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa."
+msgstr ""
-#: ../raster/r.region/main.c:79
-msgid "Set region from named region"
+#: ../misc/m.cogo/main.c:231
+msgid "It assumes a cartesian coordinate system"
msgstr ""
-#: ../raster/r.region/main.c:87
-msgid "Set region to match this raster map"
+#: ../misc/m.cogo/main.c:235
+msgid "Lines are labelled"
msgstr ""
-#: ../raster/r.region/main.c:94
-msgid "Set region to match this vector map"
+#: ../misc/m.cogo/main.c:239
+msgid "Suppress warnings"
msgstr ""
-#: ../raster/r.region/main.c:103 ../general/g.region/main.c:193
-msgid "Set region to match this 3dview file"
+#: ../misc/m.cogo/main.c:244
+msgid "Convert from coordinates to bearing and distance"
msgstr ""
-#: ../raster/r.region/main.c:113 ../general/g.region/main.c:203
-msgid "Value for the northern edge"
+#: ../misc/m.cogo/main.c:249
+msgid "Repeat the starting coordinate at the end to close a loop"
msgstr ""
-#: ../raster/r.region/main.c:114 ../raster/r.region/main.c:123
-#: ../raster/r.region/main.c:132 ../raster/r.region/main.c:141
-#: ../raster/r.in.bin/main.c:263 ../raster/r.in.bin/main.c:301
-#: ../raster/r.in.bin/main.c:309 ../raster/r.in.bin/main.c:317
-#: ../raster/r.in.bin/main.c:325 ../raster/r.in.bin/main.c:332
-#: ../raster/r.in.bin/main.c:339 ../general/g.region/main.c:150
-#: ../general/g.region/main.c:204 ../general/g.region/main.c:213
-#: ../general/g.region/main.c:222 ../general/g.region/main.c:231
-#: ../general/g.region/main.c:240 ../general/g.region/main.c:249
-#: ../general/g.region/main.c:325 ../general/g.region/main.c:336
-#: ../raster3d/r3.in.bin/main.c:285 ../raster3d/r3.in.bin/main.c:293
-#: ../raster3d/r3.in.bin/main.c:301 ../raster3d/r3.in.bin/main.c:309
-#: ../raster3d/r3.in.bin/main.c:317 ../raster3d/r3.in.bin/main.c:324
-#: ../raster3d/r3.in.bin/main.c:331 ../raster3d/r3.in.bin/main.c:338
-#: ../raster3d/r3.in.bin/main.c:345
-msgid "Bounds"
+#: ../misc/m.cogo/main.c:264
+msgid "Starting coordinate pair"
msgstr ""
-#: ../raster/r.region/main.c:122 ../general/g.region/main.c:212
-msgid "Value for the southern edge"
+#: ../misc/m.cogo/main.c:274
+#, c-format
+msgid "Couldn't open COGO file <%s>"
msgstr ""
-#: ../raster/r.region/main.c:131 ../general/g.region/main.c:221
-msgid "Value for the eastern edge"
+#: ../misc/m.cogo/main.c:283
+#, c-format
+msgid "Couldn't open output file <%s>"
msgstr ""
-#: ../raster/r.region/main.c:140 ../general/g.region/main.c:230
-msgid "Value for the western edge"
+#: ../misc/m.cogo/main.c:313 ../misc/m.cogo/main.c:316
+msgid "Converting starting coordinate pair"
msgstr ""
-#: ../raster/r.region/main.c:147
-msgid "Raster map to align to"
+#: ../misc/m.cogo/main.c:332
+#, c-format
+msgid "Input parse error on line %lu"
msgstr ""
-#: ../raster/r.region/main.c:179
+#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
#, fuzzy, c-format
-msgid "Unable to open 3dview file <%s>"
+msgid "3d raster map <%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.region/main.c:183
+#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
#, fuzzy, c-format
-msgid "Unable to read 3dview file <%s>"
+msgid "Error tokenize '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.region/main.c:185
+#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
#, fuzzy, c-format
-msgid "Old 3dview file. Region <%s> not found"
+msgid "Volume set number %d is not available"
msgstr "출력할 래스터맵"
-#: ../raster/r.timestamp/main.c:37 ../vector/v.timestamp/main.c:37
-msgid "timestamp"
-msgstr ""
+#: ../misc/m.nviz.image/volume.c:108
+#, fuzzy, c-format
+msgid "Unable to add isosurface (volume set %d)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.timestamp/main.c:38
-#, fuzzy
-msgid "Modifies a timestamp for a raster map."
+#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
+#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
+#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
+#: ../misc/m.nviz.image/volume.c:205
+#, fuzzy, c-format
+msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
msgstr "출력할 래스터맵"
-#: ../raster/r.timestamp/main.c:39
-msgid "Print/add/remove a timestamp for a raster map."
+#: ../misc/m.nviz.image/volume.c:159 ../misc/m.nviz.image/surface.c:131
+#, c-format
+msgid "Color attribute not defined, using default <%s>"
msgstr ""
-#: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:49
-msgid "Datetime, datetime1/datetime2, or 'none' to remove"
-msgstr ""
+#: ../misc/m.nviz.image/volume.c:267
+#, fuzzy, c-format
+msgid "Wrong name for axis: %s"
+msgstr "출력할 래스터맵"
-#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
-msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
-msgstr ""
+#: ../misc/m.nviz.image/volume.c:276
+#, fuzzy, c-format
+msgid "Unable to add slice (volume set %d)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.timestamp/main.c:64
+#: ../misc/m.nviz.image/volume.c:288
#, fuzzy, c-format
-msgid "Raster map <%s> not found %s"
+msgid "Unable to set slice (%d) position of volume %d"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map.c:207 ../raster/r.mapcalc/map3.c:179
+#: ../misc/m.nviz.image/volume.c:294
#, fuzzy, c-format
-msgid "Unable to read color file for raster map <%s@%s>"
+msgid "Unable to set slice (%d) transparency of volume %d"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map.c:220 ../raster/r.mapcalc/map3.c:192
+#: ../misc/m.nviz.image/cplane.c:40
#, fuzzy, c-format
-msgid "Unable to create btree for raster map <%s@%s>"
+msgid "Cutting plane number <%d> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map.c:269 ../raster/r.mapcalc/map.c:481
-#: ../raster/r.mapcalc/map.c:522 ../raster/r.mapcalc/map.c:618
-#: ../raster/r.mapcalc/map3.c:237 ../raster/r.mapcalc/map3.c:421
-#: ../raster/r.mapcalc/map3.c:466 ../raster/r.mapcalc/map3.c:563
-#: ../raster/r.mapcalc/expression.c:353
+#: ../misc/m.nviz.image/surface.c:67
#, c-format
-msgid "Invalid map modifier: '%c'"
+msgid "Missing topography attribute for surface %d"
msgstr ""
-#: ../raster/r.mapcalc/map.c:412 ../raster/r.mapcalc/map3.c:351
-#: ../raster/r.mapcalc/evaluate.c:94 ../raster/r.mapcalc/evaluate.c:234
-#, c-format
-msgid "Unknown type: %d"
-msgstr ""
+#: ../misc/m.nviz.image/surface.c:137
+#, fuzzy, c-format
+msgid "Missing color attribute for surface %d"
+msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map3.c:126 ../raster/r.mapcalc/map3.c:140
-#: ../raster/r.mapcalc/map3.c:154 ../raster/r.out.bin/main.c:53
-#: ../raster/r.out.bin/main.c:62 ../raster/r.out.bin/main.c:462
-#: ../raster3d/r3.out.bin/main.c:113
-#, fuzzy
-msgid "Error writing data"
+#: ../misc/m.nviz.image/surface.c:217
+#, fuzzy, c-format
+msgid "Surface id %d doesn't exist"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map3.c:370
+#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
#, fuzzy, c-format
-msgid "Unable to close raster map <%s@%s>"
+msgid "Unable to set draw mode for surface id %d"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map3.c:515 ../raster/r.le/r.le.trace/main.c:551
-#: ../raster/r.random/random.c:43 ../raster/r.random/random.c:47
-#: ../imagery/i.landsat.acca/main.c:57 ../imagery/i.landsat.acca/tools.c:126
-#: ../imagery/i.landsat.acca/algorithm.c:380
-#: ../imagery/i.landsat.toar/main.c:404 ../imagery/i.landsat.toar/main.c:542
-#, c-format
-msgid "Unable to open raster map <%s>"
-msgstr ""
+#: ../misc/m.nviz.image/vector.c:295 ../raster/r.volume/main.c:242
+#: ../raster/r.contour/main.c:168 ../raster/r.to.vect/main.c:179
+#: ../raster/r.random/random.c:73 ../vector/v.in.sites/main.c:167
+#: ../vector/v.colors.out/make_colors.c:36 ../vector/v.what.rast/main.c:143
+#: ../vector/v.edit/select.c:516 ../vector/v.surf.bspline/main.c:379
+#: ../vector/v.surf.bspline/crosscorr.c:123 ../vector/v.in.db/main.c:164
+#: ../vector/v.in.db/main.c:302 ../vector/v.to.points/main.c:167
+#: ../vector/v.vol.rst/user1.c:99 ../vector/v.vol.rst/main.c:603
+#: ../vector/v.net.allpairs/main.c:166 ../vector/v.in.dwg/main.c:213
+#: ../vector/v.in.dxf/write_vect.c:211 ../vector/v.to.rast/support.c:132
+#: ../vector/v.to.rast/support.c:294 ../vector/v.to.rast/support.c:447
+#: ../vector/v.to.rast/vect2rast.c:60 ../vector/v.out.vtk/writeVTK.c:649
+#: ../vector/v.in.ascii/main.c:324 ../vector/v.db.select/main.c:160
+#: ../vector/v.net.timetable/main.c:93 ../vector/v.db.connect/main.c:223
+#: ../vector/v.db.connect/main.c:331 ../vector/v.class/main.c:117
+#: ../vector/v.overlay/main.c:236 ../vector/v.overlay/main.c:396
+#: ../vector/v.surf.rst/main.c:590 ../vector/v.random/main.c:255
+#: ../vector/v.normal/main.c:123 ../vector/v.label/main.c:278
+#: ../vector/v.buffer/main.c:410 ../vector/v.sample/main.c:178
+#: ../vector/v.lrs/v.lrs.create/main.c:296
+#: ../vector/v.lrs/v.lrs.create/main.c:304 ../vector/v.distance/main.c:428
+#: ../vector/v.distance/main.c:463 ../vector/v.distance/main.c:509
+#: ../vector/v.distance/main.c:1214 ../vector/v.distance/main.c:1235
+#: ../vector/v.out.postgis/table.c:34 ../vector/v.reclass/main.c:133
+#: ../vector/v.net.flow/main.c:169 ../vector/v.label.sa/labels.c:78
+#: ../vector/v.out.svg/main.c:159 ../vector/v.patch/main.c:137
+#: ../vector/v.patch/main.c:168 ../vector/v.patch/main.c:287
+#: ../vector/v.patch/main.c:356 ../vector/v.extract/main.c:260
+#: ../vector/v.extrude/main.c:229 ../vector/v.colors/scan_attr.c:29
+#: ../vector/v.colors/write_rgb.c:25 ../vector/v.colors/read_rgb.c:28
+#: ../vector/v.what.rast3/main.c:125 ../vector/v.surf.idw/read_sites.c:55
+#: ../vector/v.net.centrality/main.c:246 ../vector/v.to.3d/trans3.c:57
+#: ../vector/v.to.3d/trans2.c:55 ../vector/v.out.ogr/main.c:612
+#: ../vector/v.net.components/main.c:179 ../vector/v.to.db/update.c:46
+#: ../vector/v.to.db/query.c:89 ../vector/v.net.distance/main.c:250
+#: ../vector/v.net.path/path.c:96 ../vector/v.to.rast3/main.c:84
+#: ../vector/v.mkgrid/main.c:230 ../vector/v.info/print.c:147
+#: ../vector/v.kcv/main.c:150 ../vector/v.transform/trans_digit.c:40
+#: ../display/d.vect.chart/plot.c:43 ../display/d.thematic.area/plot1.c:111
+#: ../display/d.vect/attr.c:43 ../display/d.vect/shape.c:51
+#: ../ps/ps.map/catval.c:53 ../ps/ps.map/catval.c:115
+#: ../ps/ps.map/catval.c:181 ../doc/vector/v.example/main.c:131
+#, fuzzy, c-format
+msgid "Unable to open database <%s> by driver <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/map3.c:619
+#: ../misc/m.nviz.image/vector.c:302 ../misc/m.nviz.image/vector.c:311
+#: ../misc/m.nviz.image/vector.c:321 ../misc/m.nviz.image/vector.c:331
+#, fuzzy, c-format
+msgid "Column <%s> in table <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/vector.c:306
#, fuzzy
-msgid "Unable to close output raster map"
+msgid "Data type of color column must be character"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/expression.c:202
-#, c-format
-msgid "Undefined variable '%s'"
+#: ../misc/m.nviz.image/vector.c:316
+msgid "Data type of size column must be numeric"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:217
-#, c-format
-msgid "Invalid map <%s>"
+#: ../misc/m.nviz.image/vector.c:326
+msgid "Data type of width column must be numeric"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:258
-#, c-format
-msgid "Undefined function '%s'"
+#: ../misc/m.nviz.image/vector.c:337
+msgid "Data type of marker column must be character"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:263
-#, c-format
-msgid "Too few arguments (%d) to function %s()"
+#: ../misc/m.nviz.image/main.c:55
+msgid "Creates a 3D rendering of GIS data."
msgstr ""
-#: ../raster/r.mapcalc/expression.c:267
-#, c-format
-msgid "Too many arguments (%d) to function %s()"
+#: ../misc/m.nviz.image/main.c:56
+msgid ""
+"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
+"data) in 3D."
msgstr ""
-#: ../raster/r.mapcalc/expression.c:271
+#: ../misc/m.nviz.image/main.c:82
+#, fuzzy
+msgid "Unable to render data"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/main.c:141
#, c-format
-msgid "Incorrect argument types to function %s()"
+msgid "Vertical exaggeration not given, using calculated value %.0f"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:274
+#: ../misc/m.nviz.image/main.c:153
#, c-format
-msgid "Internal error for function %s()"
+msgid "Viewpoint height not given, using calculated value %.0f"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:449
-#, c-format
-msgid "Illegal number of arguments (%d) for operator '%s'"
+#: ../misc/m.nviz.image/main.c:239
+#, fuzzy
+msgid "Unsupported output format"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:51
+msgid "Use draw mode for all loaded surfaces"
msgstr ""
-#: ../raster/r.mapcalc/expression.c:489
-#, c-format
-msgid "Format_expression_prec: unknown type: %d"
+#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:130
+#: ../misc/m.nviz.image/args.c:140 ../misc/m.nviz.image/args.c:147
+#: ../misc/m.nviz.image/args.c:153 ../misc/m.nviz.image/args.c:161
+#: ../misc/m.nviz.image/args.c:170 ../misc/m.nviz.image/args.c:180
+#: ../misc/m.nviz.image/args.c:188 ../misc/m.nviz.image/args.c:198
+#: ../misc/m.nviz.image/args.c:206 ../misc/m.nviz.image/args.c:216
+msgid "Surfaces"
msgstr ""
-#: ../raster/r.mapcalc/main.c:113
+#: ../misc/m.nviz.image/args.c:89
#, fuzzy
-msgid "Raster map calculator."
+msgid "Name for output image file (without extension)"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/main.c:120
-msgid "Expression to evaluate"
+#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
+#: ../misc/m.nviz.image/args.c:114
+msgid "Image"
msgstr ""
-#: ../raster/r.mapcalc/main.c:121 ../raster/r.mapcalc/main.c:127
+#: ../misc/m.nviz.image/args.c:102
+#: ../locale/scriptstrings/d.out.file_to_translate.c:5
+msgid "Graphics file format"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:112
+msgid "Size (width, height) of output image"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:129
#, fuzzy
-msgid "Expression"
+msgid "Name of raster map(s) for elevation"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/main.c:126
+#: ../misc/m.nviz.image/args.c:139
+msgid "Constant elevation value(s) to use instead of a raster DEM"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:146
#, fuzzy
-msgid "File containing expression(s) to evaluate"
+msgid "Name of raster map(s) for color"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/main.c:145
-msgid "file= and expression= are mutually exclusive"
+#: ../misc/m.nviz.image/args.c:152
+msgid "Color value(s)"
msgstr ""
-#: ../raster/r.mapcalc/main.c:155
-msgid "parse error"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:160
+#, fuzzy
+msgid "Name of raster map(s) for mask"
+msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/main.c:164
-msgid "Floating point error(s) occurred in the calculation"
+#: ../misc/m.nviz.image/args.c:169
+#, fuzzy
+msgid "Name of raster map(s) for transparency"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:179
+msgid "Transparency value(s)"
msgstr ""
-#: ../raster/r.mapcalc/main.c:169
-msgid "Overflow occurred in the calculation"
+#: ../misc/m.nviz.image/args.c:187
+#, fuzzy
+msgid "Name of raster map(s) for shininess"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:197
+msgid "Shininess value(s)"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:140
-#, c-format
-msgid "Invalid type: %d"
+#: ../misc/m.nviz.image/args.c:205
+#, fuzzy
+msgid "Name of raster map(s) for emission"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:215
+msgid "Emission value(s)"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:179
-#, c-format
-msgid "Too few arguments for function '%s'"
+#: ../misc/m.nviz.image/args.c:227
+msgid "Draw mode"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:183
-#, c-format
-msgid "Too many arguments for function '%s'"
+#: ../misc/m.nviz.image/args.c:230 ../misc/m.nviz.image/args.c:241
+#: ../misc/m.nviz.image/args.c:252 ../misc/m.nviz.image/args.c:264
+#: ../misc/m.nviz.image/args.c:276 ../misc/m.nviz.image/args.c:285
+#: ../misc/m.nviz.image/args.c:295 ../misc/m.nviz.image/args.c:605
+#: ../misc/m.nviz.image/args.c:617 ../display/d.grid/main.c:121
+#: ../display/d.grid/main.c:127 ../display/d.grid/main.c:132
+#: ../display/d.grid/main.c:137 ../display/d.grid/main.c:142
+msgid "Draw"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:187
-#, c-format
-msgid "Invalid argument type for function '%s'"
+#: ../misc/m.nviz.image/args.c:239
+msgid "Fine resolution"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:191
-#, c-format
-msgid "Invalid return type for function '%s'"
+#: ../misc/m.nviz.image/args.c:250
+msgid "Coarse resolution"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:195
-#, c-format
-msgid "Unknown type for function '%s'"
+#: ../misc/m.nviz.image/args.c:261
+msgid "Draw style"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:198
-#, c-format
-msgid "Number of arguments for function '%s'"
+#: ../misc/m.nviz.image/args.c:273
+msgid "Shading"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:202
-#, c-format
-msgid "Unknown error for function '%s'"
+#: ../misc/m.nviz.image/args.c:282
+msgid "Wire color"
msgstr ""
-#: ../raster/r.mapcalc/evaluate.c:303
-#, fuzzy, c-format
-msgid "output map <%s> exists"
+#: ../misc/m.nviz.image/args.c:294
+#, fuzzy
+msgid "Surface position"
msgstr "출력할 래스터맵"
-#: ../raster/r.mapcalc/function.c:100
-#, c-format
-msgid "Known functions:"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:306
+#, fuzzy
+msgid "Name of line vector overlay map(s)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:63
+#: ../misc/m.nviz.image/args.c:307 ../misc/m.nviz.image/args.c:315
+#: ../misc/m.nviz.image/args.c:327 ../misc/m.nviz.image/args.c:336
+#: ../misc/m.nviz.image/args.c:345 ../misc/m.nviz.image/args.c:352
+#: ../misc/m.nviz.image/args.c:366 ../misc/m.nviz.image/args.c:376
+#: ../misc/m.nviz.image/args.c:388
#, fuzzy
-msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgid "Vector lines"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:72
-msgid "Name of an existing raster map"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:314 ../misc/m.nviz.image/args.c:407
+#, fuzzy
+msgid "Layer number or name for thematic mapping"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:77
-msgid "Name for output ASCII grid map (use out=- for stdout)"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:326
+#, fuzzy
+msgid "Vector line width"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:91
-msgid ""
-"Number of values printed before wrapping a line (only SURFER or MODFLOW "
-"format)"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:334 ../misc/m.nviz.image/args.c:446
+#, fuzzy
+msgid "Name of width definition column"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:99
-msgid "String to represent null cell (GRASS grid only)"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:342
+#, fuzzy
+msgid "Vector line color"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:107
-msgid "Write SURFER (Golden Software) ASCII grid"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:350 ../misc/m.nviz.image/args.c:462
+#, fuzzy
+msgid "Name of color definition column"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:111
-msgid "Write MODFLOW (USGS) ASCII array"
+#: ../misc/m.nviz.image/args.c:361
+msgid "Vector line display mode"
msgstr ""
-#: ../raster/r.out.ascii/main.c:115
-msgid "Force output of integer values"
+#: ../misc/m.nviz.image/args.c:363
+msgid "surface;drape on raster surface;flat;draw at constant elevation"
msgstr ""
-#: ../raster/r.out.ascii/main.c:122
-msgid "Failed to interpret dp as an integer"
+#: ../misc/m.nviz.image/args.c:375
+msgid "Vector line height"
msgstr ""
-#: ../raster/r.out.ascii/main.c:124 ../raster3d/r3.out.vtk/main.c:394
-msgid "dp has to be from 0 to 20"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:387
+#, fuzzy
+msgid "Vector lines position"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:130
-msgid "Failed to interpret width as an integer"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:399
+#, fuzzy
+msgid "Name of point vector overlay map(s)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:136
-msgid "Both -s and -h doesn't make sense"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:400 ../misc/m.nviz.image/args.c:408
+#: ../misc/m.nviz.image/args.c:420 ../misc/m.nviz.image/args.c:429
+#: ../misc/m.nviz.image/args.c:439 ../misc/m.nviz.image/args.c:448
+#: ../misc/m.nviz.image/args.c:457 ../misc/m.nviz.image/args.c:464
+#: ../misc/m.nviz.image/args.c:477 ../misc/m.nviz.image/args.c:485
+#: ../misc/m.nviz.image/args.c:500 ../misc/m.nviz.image/args.c:510
+#, fuzzy
+msgid "Vector points"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:139
-msgid "Use -M or -s, not both"
+#: ../misc/m.nviz.image/args.c:419
+msgid "Icon size (map units)"
msgstr ""
-#: ../raster/r.out.ascii/main.c:174
-#, fuzzy, c-format
-msgid "Unable to read fp range for <%s>"
+#: ../misc/m.nviz.image/args.c:427
+#, fuzzy
+msgid "Name of size definition column"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.ascii/main.c:190
-#, fuzzy, c-format
-msgid "Read failed at row %d"
-msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:438
+msgid "Icon width"
+msgstr ""
-#: ../raster/r.random.surface/main.c:58 ../raster/r.resamp.bspline/main.c:81
-#: ../raster/r.surf.idw/main.c:104 ../raster/r.surf.gauss/main.c:39
-#: ../raster/r.surf.idw2/main.c:62 ../raster/r.contour/main.c:87
-#: ../raster/r.surf.contour/main.c:61 ../raster/r.surf.fractal/main.c:39
-#: ../raster/r.surf.random/main.c:37 ../raster/r.surf.area/main.c:77
-#: ../vector/v.surf.rst/main.c:143 ../vector/v.vol.rst/main.c:240
-#: ../vector/v.surf.idw/main.c:87 ../vector/v.surf.bspline/main.c:92
-msgid "surface"
+#: ../misc/m.nviz.image/args.c:454
+msgid "Icon color"
msgstr ""
-#: ../raster/r.random.surface/main.c:61
-msgid "Generates random surface(s) with spatial dependence."
+#: ../misc/m.nviz.image/args.c:473
+msgid "Icon marker"
msgstr ""
-#: ../raster/r.random.surface/main.c:68
+#: ../misc/m.nviz.image/args.c:483
#, fuzzy
-msgid "Name for output raster map(s)"
+msgid "Name of marker definition column"
msgstr "출력할 래스터맵"
-#: ../raster/r.random.surface/main.c:77
-msgid "Maximum distance of spatial correlation (value >= 0.0)"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:494
+#, fuzzy
+msgid "3D vector point display mode"
+msgstr "출력할 래스터맵"
-#: ../raster/r.random.surface/main.c:85
-msgid "Distance decay exponent (value > 0.0)"
+#: ../misc/m.nviz.image/args.c:496
+msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
msgstr ""
-#: ../raster/r.random.surface/main.c:94
-msgid "Distance filter remains flat before beginning exponent"
-msgstr ""
+#: ../misc/m.nviz.image/args.c:509
+#, fuzzy
+msgid "Vector points position"
+msgstr "출력할 래스터맵"
-#: ../raster/r.random.surface/main.c:102
-msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+#: ../misc/m.nviz.image/args.c:526
+msgid "Viewpoint position (x,y model coordinates)"
msgstr ""
-#: ../raster/r.random.surface/main.c:108
-msgid "Maximum cell value of distribution"
+#: ../misc/m.nviz.image/args.c:527 ../misc/m.nviz.image/args.c:539
+#: ../misc/m.nviz.image/args.c:549 ../misc/m.nviz.image/args.c:561
+#: ../misc/m.nviz.image/args.c:583
+msgid "Viewpoint"
msgstr ""
-#: ../raster/r.random.surface/main.c:113
-msgid "Uniformly distributed cell values"
+#: ../misc/m.nviz.image/args.c:538
+msgid "Viewpoint height (in map units)"
msgstr ""
-#: ../raster/r.random.surface/init.c:73
-#, c-format
-msgid "High (%d) must be greater than 1"
+#: ../misc/m.nviz.image/args.c:548
+msgid "Viewpoint field of view (in degrees)"
msgstr ""
-#: ../raster/r.random.surface/init.c:82
-#, fuzzy, c-format
-msgid "Rastar map <%s> repeated, maps must be unique"
-msgstr "출력할 래스터맵"
-#: ../raster/r.random.surface/init.c:92
-#, fuzzy
-msgid "Output raster map required"
-msgstr "출력할 래스터맵"
-#: ../raster/r.random.surface/init.c:108
-#, c-format
-msgid "Seed (%d) larger than maximum (%d)"
+#: ../misc/m.nviz.image/args.c:560
+msgid "Viewpoint twist angle (in degrees)"
msgstr ""
-#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
-#, c-format
-msgid " seed is set to %d"
+#: ../misc/m.nviz.image/args.c:572 ../raster/r.out.vrml/main.c:72
+msgid "Vertical exaggeration"
msgstr ""
-#: ../raster/r.random.surface/init.c:116
-#, c-format
-msgid "Seed (%d) smaller than minimum (%d)"
+#: ../misc/m.nviz.image/args.c:582
+msgid "Focus to point on surface (from SW corner in map units)"
msgstr ""
-#: ../raster/r.random.surface/init.c:159
-#, c-format
-msgid "Distance value (%d): %lf must be >= 0.0"
+#: ../misc/m.nviz.image/args.c:592 ../misc/m.nviz.image/args.c:627
+#: ../misc/m.nviz.image/args.c:639 ../misc/m.nviz.image/args.c:649
+#: ../misc/m.nviz.image/args.c:658 ../misc/m.nviz.image/args.c:666
+#: ../misc/m.nviz.image/args.c:675 ../misc/m.nviz.image/args.c:686
+#: ../misc/m.nviz.image/args.c:695 ../misc/m.nviz.image/args.c:706
+#: ../misc/m.nviz.image/args.c:713 ../misc/m.nviz.image/args.c:719
+#: ../misc/m.nviz.image/args.c:731 ../misc/m.nviz.image/args.c:741
+#: ../misc/m.nviz.image/args.c:752
+msgid "Volumes"
msgstr ""
-#: ../raster/r.random.surface/init.c:187
-#, c-format
-msgid "Exponent value (%lf) must be > 0.0"
+#: ../misc/m.nviz.image/args.c:602
+msgid "Volume draw mode"
msgstr ""
-#: ../raster/r.random.surface/init.c:211
-#, c-format
-msgid "Flat value (%lf) must be less than distance value (%lf)"
+#: ../misc/m.nviz.image/args.c:614
+msgid "Volume shading"
msgstr ""
-#: ../raster/r.random.surface/init.c:232
-msgid "Must have a distance value for each filter"
+#: ../misc/m.nviz.image/args.c:626
+msgid "Volume position"
msgstr ""
-#: ../raster/r.random.surface/init.c:264
-msgid "Must have a exponent value for each filter"
+#: ../misc/m.nviz.image/args.c:637
+msgid "Volume resolution"
msgstr ""
-#: ../raster/r.random.surface/init.c:281
-msgid "Must have a weight value for each filter"
+#: ../misc/m.nviz.image/args.c:648
+msgid "Isosurface level"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:82 ../raster/r.resamp.rst/main.c:149
-#: ../raster/r.resamp.stats/main.c:257 ../raster/r.resamp.interp/main.c:77
-#: ../raster/r.resamp.filter/main.c:385 ../raster/r.resample/main.c:55
+#: ../misc/m.nviz.image/args.c:657
#, fuzzy
-msgid "resample"
+msgid "Name of volume for isosurface color"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:83 ../raster/r.surf.idw/main.c:105
-#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.idw2/main.c:63
-#: ../raster/r.resamp.interp/main.c:78 ../raster/r.surf.contour/main.c:62
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
-#: ../locale/scriptstrings/v.krige_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
-#: ../vector/v.surf.rst/main.c:144 ../vector/v.vol.rst/main.c:241
-#: ../vector/v.surf.idw/main.c:88 ../vector/v.surf.bspline/main.c:93
+#: ../misc/m.nviz.image/args.c:665
#, fuzzy
-msgid "interpolation"
+msgid "Isosurface color"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:85
-msgid ""
-"Performs bilinear or bicubic spline interpolation with Tykhonov "
-"regularization."
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:93
+#: ../misc/m.nviz.image/args.c:674
#, fuzzy
-msgid "Name for output vector map with interpolation grid"
+msgid "Name of 3D raster map(s) for isosurface transparency"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:98
+#: ../misc/m.nviz.image/args.c:685
+msgid "Transparency value(s)for isosurfaces"
+msgstr ""
+#: ../misc/m.nviz.image/args.c:694
#, fuzzy
-msgid "Name of raster map to use for masking"
+msgid "Name of 3D raster map(s) for shininess"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:99 ../vector/v.surf.bspline/main.c:130
-msgid "Only cells that are not NULL and not zero are interpolated"
+#: ../misc/m.nviz.image/args.c:705
+msgid "Shininess value(s) for isosurfaces"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:107
-msgid ""
-"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
+#: ../misc/m.nviz.image/args.c:712
+msgid "Toggles normal direction of all isosurfaces (changes light effect)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:108 ../raster/r.resamp.bspline/main.c:116
-#: ../raster/r.resamp.bspline/main.c:122 ../raster/r.resamp.bspline/main.c:134
-#: ../raster/r.resamp.bspline/main.c:139 ../raster/r.walk/main.c:275
-#: ../raster/r.walk/main.c:285 ../raster/r.walk/main.c:295
-#: ../raster/r.resamp.rst/main.c:224 ../raster/r.resamp.rst/main.c:232
-#: ../raster/r.resamp.rst/main.c:240 ../raster/r.resamp.rst/main.c:248
-#: ../raster/r.resamp.rst/main.c:256 ../raster/r.slope.aspect/main.c:178
-#: ../raster/r.slope.aspect/main.c:187 ../raster/r.slope.aspect/main.c:245
-#: ../raster/r.slope.aspect/main.c:254 ../raster/r.slope.aspect/main.c:260
-#: ../raster/r.in.bin/main.c:253 ../raster/r.in.bin/main.c:258
-#: ../raster/r.in.bin/main.c:285 ../raster/r.in.bin/main.c:346
-#: ../raster/r.out.mpeg/main.c:133 ../general/g.access/main.c:50
-#: ../general/g.access/main.c:58 ../general/g.mapset/main.c:57
-#: ../general/g.mapset/main.c:67 ../general/g.mapset/main.c:77
-#: ../db/db.login/main.c:58 ../db/db.login/main.c:66
-#: ../display/d.mon/main.c:70 ../display/d.mon/main.c:78
-#: ../display/d.mon/main.c:86 ../display/d.mon/main.c:89
-#: ../display/d.mon/main.c:95 ../display/d.mon/main.c:125
-#: ../display/d.mon/main.c:131 ../raster3d/r3.in.bin/main.c:269
-#: ../raster3d/r3.in.bin/main.c:352 ../raster3d/r3.in.bin/main.c:372
-#: ../raster3d/r3.out.bin/main.c:228 ../imagery/i.cluster/main.c:103
-#: ../imagery/i.cluster/main.c:120 ../imagery/i.cluster/main.c:128
-#: ../imagery/i.cluster/main.c:137 ../imagery/i.cluster/main.c:145
-#: ../imagery/i.cluster/main.c:153 ../imagery/i.segment/parse_args.c:42
-#: ../imagery/i.segment/parse_args.c:51 ../imagery/i.segment/parse_args.c:62
-#: ../imagery/i.segment/parse_args.c:73 ../imagery/i.segment/parse_args.c:83
-#: ../imagery/i.segment/parse_args.c:102 ../imagery/i.segment/parse_args.c:129
-#: ../imagery/i.segment/parse_args.c:135 ../imagery/i.landsat.toar/main.c:165
-#: ../imagery/i.landsat.toar/main.c:174 ../imagery/i.landsat.toar/main.c:184
-#: ../imagery/i.landsat.toar/main.c:193 ../imagery/i.landsat.toar/main.c:214
-#: ../vector/v.vol.rst/main.c:271 ../vector/v.vol.rst/main.c:279
-#: ../vector/v.vol.rst/main.c:286 ../vector/v.vol.rst/main.c:314
-#: ../vector/v.vol.rst/main.c:323 ../vector/v.vol.rst/main.c:332
-#: ../vector/v.vol.rst/main.c:340 ../vector/v.vol.rst/main.c:349
-#: ../vector/v.vol.rst/main.c:357 ../vector/v.colors.out/main.c:68
-#: ../vector/v.colors.out/main.c:73 ../vector/v.surf.idw/main.c:114
-#: ../vector/v.surf.idw/main.c:123 ../vector/v.surf.idw/main.c:131
-#: ../vector/v.surf.bspline/main.c:140 ../vector/v.surf.bspline/main.c:149
-#: ../vector/v.surf.bspline/main.c:157 ../vector/v.surf.bspline/main.c:169
-#: ../vector/v.surf.bspline/main.c:176
-#: ../vector/v.lidar.edgedetection/main.c:95
-#: ../vector/v.lidar.edgedetection/main.c:104
-#: ../vector/v.lidar.edgedetection/main.c:113
-#: ../vector/v.lidar.edgedetection/main.c:122
-#: ../vector/v.lidar.edgedetection/main.c:131
-#: ../vector/v.lidar.edgedetection/main.c:139
-#: ../vector/v.lidar.edgedetection/main.c:148 ../vector/v.db.connect/main.c:65
-#: ../vector/v.db.connect/main.c:71
-msgid "Settings"
+#: ../misc/m.nviz.image/args.c:718
+msgid "Draw volume box"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:115
-msgid ""
-"Length of each spline step in the north-south direction. Default: 1.5 * "
-"nsres."
+#: ../misc/m.nviz.image/args.c:730
+msgid "Volume slice parallel to given axis (x, y, z)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:119 ../vector/v.surf.bspline/main.c:153
-msgid "Spline interpolation algorithm"
+#: ../misc/m.nviz.image/args.c:740
+#, fuzzy
+msgid "Volume slice position"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:751
+msgid "Volume slice transparency"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:125 ../vector/v.surf.bspline/main.c:160
-#: ../vector/v.lidar.edgedetection/main.c:413
-#: ../vector/v.lidar.correction/main.c:399 ../vector/v.outlier/main.c:407
-msgid "Bilinear interpolation"
+#: ../misc/m.nviz.image/args.c:768
+msgid "Light position (x,y,z model coordinates)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:126 ../vector/v.surf.bspline/main.c:161
-#: ../vector/v.lidar.edgedetection/main.c:430
-msgid "Bicubic interpolation"
+#: ../misc/m.nviz.image/args.c:769 ../misc/m.nviz.image/args.c:775
+#: ../misc/m.nviz.image/args.c:784 ../misc/m.nviz.image/args.c:794
+msgid "Lighting"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:132 ../vector/v.surf.bspline/main.c:167
-msgid "Tykhonov regularization parameter (affects smoothing)"
+#: ../misc/m.nviz.image/args.c:774
+msgid "Light color"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:138
-#, fuzzy
-msgid "Only interpolate null cells in input raster map"
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
-msgid ""
-"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
-"cross validation method"
+#: ../misc/m.nviz.image/args.c:783
+msgid "Light brightness"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:151
-msgid "Maximum memory to be used (in MB)"
+#: ../misc/m.nviz.image/args.c:793
+msgid "Light ambient"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:186
-msgid "se must be positive"
+#: ../misc/m.nviz.image/args.c:807
+msgid "Cutting plane index (0-5)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:194
-msgid "sn must be positive"
+#: ../misc/m.nviz.image/args.c:808 ../misc/m.nviz.image/args.c:817
+#: ../misc/m.nviz.image/args.c:826 ../misc/m.nviz.image/args.c:838
+#: ../misc/m.nviz.image/args.c:849
+#, fuzzy
+msgid "Cutting planes"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:816
+#, fuzzy
+msgid "Cutting plane x,y,z coordinates"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:828
+msgid "Cutting plane rotation along the vertical axis"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:221
-#, c-format
-msgid "spline step in ew direction %g"
+#: ../misc/m.nviz.image/args.c:839
+#, fuzzy
+msgid "Cutting plane tilt"
+msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:851
+msgid "Cutting plane color (between two surfaces)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:222
-#, c-format
-msgid "spline step in ns direction %g"
+#: ../misc/m.nviz.image/args.c:867
+msgid "North-West edge"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:223
-#: ../vector/v.lidar.edgedetection/main.c:294
-#: ../vector/v.lidar.correction/main.c:274 ../vector/v.outlier/main.c:288
-#, c-format
-msgid "adjusted EW splines %d"
+#: ../misc/m.nviz.image/args.c:868
+msgid "North-East edge"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:224
-#: ../vector/v.lidar.edgedetection/main.c:295
-#: ../vector/v.lidar.correction/main.c:275 ../vector/v.outlier/main.c:289
-#, c-format
-msgid "adjusted NS splines %d"
+#: ../misc/m.nviz.image/args.c:869
+msgid "South-West edge"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:291 ../vector/v.surf.bspline/main.c:444
-msgid "Memory in MB must be >= 3"
+msgid "South-East edge"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:312 ../raster/r.resamp.bspline/main.c:398
-#: ../raster/r.resamp.bspline/main.c:469 ../vector/v.surf.bspline/main.c:463
-#: ../vector/v.surf.bspline/main.c:491
+#: ../misc/m.nviz.image/args.c:871
#, fuzzy
-msgid "Can not initialize temporary file"
+msgid "Fringe edges"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:318
-#, fuzzy, c-format
-msgid "Loading input raster <%s>"
-msgstr "출력할 래스터맵"
+#: ../misc/m.nviz.image/args.c:872 ../misc/m.nviz.image/args.c:878
+#: ../misc/m.nviz.image/args.c:887
+msgid "Fringe"
+msgstr ""
-#: ../raster/r.resamp.bspline/main.c:338
+#: ../misc/m.nviz.image/args.c:877
#, fuzzy
-msgid "Only NULL cells in input raster"
+msgid "Fringe color"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:362 ../vector/v.surf.bspline/main.c:298
-msgid "Cross validation didn't finish correctly"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:366
-#, c-format
-msgid "Cross validation finished for se = %f and sn = %f"
-msgstr ""
-#: ../raster/r.resamp.bspline/main.c:386
+#: ../misc/m.nviz.image/args.c:886
#, fuzzy
-msgid "Mark cells for interpolation"
+msgid "Fringe elevation"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:457
-msgid "No NULL cells found in input raster."
+#: ../misc/m.nviz.image/args.c:900
+msgid ""
+"Place north arrow at given position \t(in screen coordinates from bottom "
+"left corner)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:472 ../vector/v.surf.bspline/main.c:466
+#: ../misc/m.nviz.image/args.c:902 ../misc/m.nviz.image/args.c:912
+#: ../misc/m.nviz.image/args.c:919
#, fuzzy
-msgid "Initializing output..."
+msgid "Decoration"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/main.c:545 ../vector/v.lidar.growing/main.c:246
-#: ../vector/v.lidar.edgedetection/main.c:350
-#: ../vector/v.lidar.correction/main.c:330 ../vector/v.outlier/main.c:344
-#, c-format
-msgid "subregion %d of %d"
+#: ../misc/m.nviz.image/args.c:911
+msgid "North arrow size (in map units)"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:719
-msgid "No data within this subregion. Consider increasing the spline step."
+#: ../misc/m.nviz.image/args.c:918
+msgid "North arrow color"
msgstr ""
-#: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:883
-#, fuzzy
-msgid "Writing output..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.bspline/crosscorr.c:160
+#: ../misc/m.nviz.image/args.c:970
#, c-format
-msgid ""
-"%d are too many cells, recommended are < 100 cells. The cross validation "
-"would take too much time."
+msgid "At least one <%s> or <%s> required"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:169
-#, fuzzy, c-format
-msgid "%d point read in region"
-msgid_plural "%d points read in region"
-#: ../raster/r.resamp.bspline/crosscorr.c:174
-msgid "Maybe it takes too long.Consider reducing the region extends."
+#: ../misc/m.nviz.image/args.c:984 ../misc/m.nviz.image/args.c:1014
+#: ../misc/m.nviz.image/args.c:1020 ../misc/m.nviz.image/args.c:1026
+#: ../misc/m.nviz.image/args.c:1032 ../misc/m.nviz.image/args.c:1038
+#: ../misc/m.nviz.image/args.c:1044
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:194
-#: ../vector/v.surf.bspline/crosscorr.c:151
+#: ../misc/m.nviz.image/args.c:1055
#, c-format
-msgid ""
-"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:212
+#: ../misc/m.nviz.image/args.c:1061 ../misc/m.nviz.image/args.c:1067
+#: ../misc/m.nviz.image/args.c:1079 ../misc/m.nviz.image/args.c:1086
+#: ../misc/m.nviz.image/args.c:1093 ../misc/m.nviz.image/args.c:1100
+#: ../misc/m.nviz.image/args.c:1107 ../misc/m.nviz.image/args.c:1119
+#: ../misc/m.nviz.image/args.c:1124 ../misc/m.nviz.image/args.c:1161
#, c-format
-msgid "Begining cross validation with lambda_i=%.4f..."
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:297
-#: ../vector/v.surf.bspline/crosscorr.c:295
+#: ../misc/m.nviz.image/args.c:1143 ../misc/m.nviz.image/args.c:1153
#, c-format
-msgid "Mean = %.5lf"
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:298
+#: ../misc/m.nviz.image/args.c:1168
#, c-format
-msgid "Root Means Square (RMS) = %.5lf"
+msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:314
-#: ../vector/v.surf.bspline/crosscorr.c:313
-msgid ""
-"Different number of splines and lambda_i values have been taken for the "
-"cross correlation"
+#: ../misc/m.nviz.image/args.c:1180
+#, c-format
+msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:316
-#: ../vector/v.surf.bspline/crosscorr.c:315
-#, c-format
-msgid ""
-"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
+#: ../misc/m.measure/main.c:45
+msgid "Measures the lengths and areas of features."
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:324
-msgid "Results into a table:"
+#: ../misc/m.measure/main.c:47
+msgid "measurement"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:325
-msgid " lambda | mean | rms |"
+#: ../misc/m.measure/main.c:54
+msgid "Units"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:327
-#, c-format
-msgid " %-10.5f| %-12.4f| %-12.4f|"
+#: ../misc/m.measure/main.c:55
+msgid "Default: location map units"
msgstr ""
-#: ../raster/r.resamp.bspline/crosscorr.c:335
-#: ../vector/v.surf.bspline/crosscorr.c:334
+#: ../misc/m.measure/main.c:59
#, fuzzy
-msgid "No point lies into the current region"
+msgid "Shell script style"
msgstr "출력할 래스터맵"
-#: ../raster/r.lake/main.c:153
-msgid "flood"
+#: ../misc/m.measure/main.c:102
+msgid "Length:"
msgstr ""
-#: ../raster/r.lake/main.c:154
-msgid "Fills lake at given point to given level."
+#: ../misc/m.measure/main.c:113
+msgid "Area:"
msgstr ""
-#: ../raster/r.lake/main.c:160
-msgid "Water level"
+#: ../misc/m.transform/main.c:92
+#, c-format
+msgid "Not enough points, %d are required"
msgstr ""
-#: ../raster/r.lake/main.c:169
-msgid "Seed point coordinates"
+#: ../misc/m.transform/main.c:194
+msgid "Poorly placed control points"
msgstr ""
-#: ../raster/r.lake/main.c:170
+#: ../misc/m.transform/main.c:329
+msgid "Rectification polynomial order"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:61 ../raster/r.surf.area/main.c:77
+#: ../raster/r.surf.idw2/main.c:62 ../raster/r.resamp.bspline/main.c:81
+#: ../raster/r.surf.fractal/main.c:39 ../raster/r.contour/main.c:87
+#: ../raster/r.surf.idw/main.c:104 ../raster/r.surf.random/main.c:37
+#: ../raster/r.random.surface/main.c:58 ../raster/r.surf.gauss/main.c:39
+#: ../vector/v.surf.bspline/main.c:92 ../vector/v.vol.rst/main.c:240
+#: ../vector/v.surf.rst/main.c:143 ../vector/v.surf.idw/main.c:88
+msgid "surface"
+msgstr ""
+#: ../raster/r.surf.contour/main.c:62 ../raster/r.resamp.interp/main.c:78
+#: ../raster/r.surf.idw2/main.c:63 ../raster/r.resamp.bspline/main.c:83
+#: ../raster/r.series.interp/main.c:66 ../raster/r.surf.idw/main.c:105
+#: ../vector/v.surf.bspline/main.c:93 ../vector/v.vol.rst/main.c:241
+#: ../vector/v.surf.rst/main.c:144 ../vector/v.surf.idw/main.c:89
+#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:3
+#: ../locale/scriptstrings/v.krige_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:4
#, fuzzy
-msgid "Either this coordinates pair or a seed map have to be specified"
+msgid "interpolation"
msgstr "출력할 래스터맵"
-#: ../raster/r.lake/main.c:178
+#: ../raster/r.surf.contour/main.c:64
#, fuzzy
-msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
+msgid "Generates surface raster map from rasterized contours."
msgstr "출력할 래스터맵"
-#: ../raster/r.lake/main.c:180
+#: ../raster/r.surf.contour/main.c:67
#, fuzzy
-msgid "Either this parameter or a coordinates pair have to be specified"
+msgid "Name of input raster map containing contours"
msgstr "출력할 래스터맵"
-#: ../raster/r.lake/main.c:186
-msgid "Use negative depth values for lake raster map"
+#: ../raster/r.spreadpath/main.c:90 ../raster/r.spread/main.c:103
+#: ../raster/r.ros/main.c:214
+msgid "fire"
msgstr ""
-#: ../raster/r.lake/main.c:191
-msgid "Overwrite seed map with result (lake) map"
+#: ../raster/r.spreadpath/main.c:91 ../raster/r.cost/main.c:142
+#: ../raster/r.walk/main.c:181
+msgid "cumulative costs"
msgstr ""
-#: ../raster/r.lake/main.c:197
-msgid "Both seed map and coordinates cannot be specified"
+#: ../raster/r.spreadpath/main.c:93
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
msgstr ""
-#: ../raster/r.lake/main.c:200
-msgid "Seed map or seed coordinates must be set!"
+#: ../raster/r.spreadpath/main.c:102
+msgid "Name of raster map containing back-path easting information"
msgstr ""
-#: ../raster/r.lake/main.c:203
-msgid "Seed coordinates and output map lake= must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:206
-msgid "Both lake and overwrite cannot be specified"
-msgstr ""
-#: ../raster/r.lake/main.c:209
-msgid "Output lake map or overwrite flag must be set!"
-msgstr ""
-#: ../raster/r.lake/main.c:236
+#: ../raster/r.spreadpath/main.c:110
#, fuzzy
-msgid "Seed point outside the current region"
+msgid "Name of raster map containing back-path northing information"
msgstr "출력할 래스터맵"
-#: ../raster/r.lake/main.c:250
-msgid "G_malloc: out of memory"
+#: ../raster/r.spreadpath/main.c:118
+msgid "The map E and N grid coordinates of starting points"
msgstr ""
-#: ../raster/r.lake/main.c:272
-msgid ""
-"Given water level at seed point is below earth surface. Increase water level "
-"or move seed point."
+#: ../raster/r.spreadpath/main.c:125
+msgid "Name of spread path raster map"
msgstr ""
-#: ../raster/r.lake/main.c:351
-#, c-format
-msgid "Lake depth from %f to %f (specified water level is taken as zero)"
+#: ../raster/r.spreadpath/main.c:129
+msgid "Run verbosely"
msgstr ""
-#: ../raster/r.lake/main.c:352
-#, c-format
-msgid "Lake area %f square meters"
+#: ../raster/r.statistics/o_sdev.c:94 ../raster/r.statistics/o_var.c:95
+msgid "o_var: No data in array"
msgstr ""
-#: ../raster/r.lake/main.c:353
-#, c-format
-msgid "Lake volume %f cubic meters"
+#: ../raster/r.statistics/o_adev.c:93
+msgid "o_adev: No data in array"
msgstr ""
-#: ../raster/r.lake/main.c:354
-msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
+#: ../raster/r.statistics/o_skew.c:91
+msgid "o_skew: No data in array"
msgstr ""
-#: ../raster/r.quantile/main.c:63
-msgid "Computing histogram"
+#: ../raster/r.statistics/main.c:58
+msgid "Calculates category or object oriented statistics."
msgstr ""
-#: ../raster/r.quantile/main.c:97 ../raster/r.stats.quantile/main.c:111
-#, fuzzy
-msgid "Computing bins"
-msgstr "출력할 래스터맵"
+#: ../raster/r.statistics/main.c:68 ../raster/r.stats.zonal/main.c:114
+msgid "Method of object-based statistic"
+msgstr ""
-#: ../raster/r.quantile/main.c:134 ../raster/r.stats.quantile/main.c:166
+#: ../raster/r.statistics/main.c:91 ../raster/r.stats.zonal/main.c:137
#, fuzzy
-msgid "Binning data"
+msgid "Resultant raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.quantile/main.c:179 ../raster/r.stats.quantile/main.c:218
-#, fuzzy
-msgid "Sorting bins"
-msgstr "출력할 래스터맵"
+#: ../raster/r.statistics/main.c:97 ../raster/r.stats.zonal/main.c:143
+msgid "Cover values extracted from the category labels of the cover map"
+msgstr ""
-#: ../raster/r.quantile/main.c:189 ../raster/r.stats.quantile/main.c:257
-#, fuzzy
-msgid "Computing quantiles"
-msgstr "출력할 래스터맵"
+#: ../raster/r.statistics/main.c:103 ../raster/r.statistics/main.c:106
+msgid "This module currently only works for integer (CELL) maps"
+msgstr ""
-#: ../raster/r.quantile/main.c:258
-msgid "Compute quantiles using two passes."
+#: ../raster/r.statistics/o_kurt.c:91
+msgid "o_kurto: No data in array"
msgstr ""
-#: ../raster/r.quantile/main.c:266 ../raster/r.stats.quantile/main.c:401
-#, fuzzy
-msgid "Number of quantiles"
-msgstr "출력할 래스터맵"
+#: ../raster/r.statistics/read_stats.c:20
+msgid "Reading r.stats output"
+msgstr ""
-#: ../raster/r.quantile/main.c:274 ../raster/r.stats.quantile/main.c:407
-msgid "List of percentiles"
+#: ../raster/r.his/main.c:68
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
msgstr ""
-#: ../raster/r.quantile/main.c:280 ../raster/r.stats.quantile/main.c:414
-#, fuzzy
-msgid "Number of bins to use"
-msgstr "출력할 래스터맵"
+#: ../raster/r.his/main.c:77 ../display/d.his/main.c:78
+msgid "Name of layer to be used for HUE"
+msgstr ""
-#: ../raster/r.quantile/main.c:285
-msgid "Generate recode rules based on quantile-defined intervals."
+#: ../raster/r.his/main.c:84 ../display/d.his/main.c:85
+msgid "Name of layer to be used for INTENSITY"
msgstr ""
-#: ../raster/r.quantile/main.c:313
-#, fuzzy
-msgid "Too many quantiles"
-msgstr "출력할 래스터맵"
+#: ../raster/r.his/main.c:91 ../display/d.his/main.c:92
+msgid "Name of layer to be used for SATURATION"
+msgstr ""
-#: ../raster/r.surf.idw/main.c:106 ../raster/r.surf.idw2/main.c:64
-#: ../vector/v.surf.idw/main.c:89
-msgid "IDW"
+#: ../raster/r.his/main.c:98
+msgid "Name of output layer to be used for RED"
msgstr ""
-#: ../raster/r.surf.idw/main.c:108
-#, fuzzy
-msgid "Surface interpolation utility for raster map."
-msgstr "출력할 래스터맵"
+#: ../raster/r.his/main.c:105
+msgid "Name of output layer to be used for GREEN"
+msgstr ""
-#: ../raster/r.surf.idw/main.c:118 ../raster/r.surf.idw2/main.c:76
-#: ../vector/v.surf.idw/main.c:112
-msgid "Number of interpolation points"
+#: ../raster/r.his/main.c:112
+msgid "Name of output layer to be used for BLUE"
msgstr ""
-#: ../raster/r.surf.idw/main.c:123
-msgid "Output is the interpolation error"
+#: ../raster/r.his/main.c:116 ../display/d.his/main.c:103
+msgid "Respect NULL values while drawing"
msgstr ""
-#: ../raster/r.surf.idw/main.c:129
+#: ../raster/r.his/main.c:140 ../raster/r.his/main.c:156
+#: ../raster/r.his/main.c:174 ../raster/r.out.ppm3/main.c:115
+#: ../display/d.legend/main.c:279 ../display/d.his/main.c:141
+#: ../display/d.his/main.c:158 ../display/d.his/main.c:176
+#: ../display/d.colortable/main.c:137 ../display/d.rgb/main.c:101
+#: ../display/d.histogram/main.c:174 ../display/d.rast.num/main.c:224
+#: ../display/d.rast/display.c:23
#, c-format
-msgid "Illegal value for '%s' (%s)"
+msgid "Color file for <%s> not available"
msgstr ""
-#: ../raster/r.surf.idw/main.c:255
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s> (%d row)..."
-msgid_plural "Interpolating raster map <%s> (%d rows)..."
-#: ../raster/r.water.outlet/main.c:66
+#: ../raster/r.surf.area/main.c:79
#, fuzzy
-msgid "Creates watershed basins from a drainage direction map."
+msgid "area estimation"
msgstr "출력할 래스터맵"
-#: ../raster/r.water.outlet/main.c:72
+#: ../raster/r.surf.area/main.c:80
#, fuzzy
-msgid "Name of input drainage direction map"
+msgid "Prints estimation of surface area for raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.water.outlet/main.c:75
-#, fuzzy
-msgid "Name for output watershed basin map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.area/main.c:89
+msgid "Vertical scale"
+msgstr ""
-#: ../raster/r.water.outlet/main.c:78
+#: ../raster/r.surf.area/main.c:93
#, fuzzy
-msgid "Coordinates of outlet point"
+msgid "Output units"
msgstr "출력할 래스터맵"
-#: ../raster/r.water.outlet/main.c:91
-#, fuzzy, c-format
-msgid "Illegal east coordinate '%s'"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.area/main.c:94
+msgid "Default: square map units"
+msgstr ""
-#: ../raster/r.water.outlet/main.c:93
+#: ../raster/r.surf.area/main.c:102
#, fuzzy, c-format
-msgid "Illegal north coordinate '%s'"
+msgid "Output in '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.water.outlet/main.c:98
-#, c-format
-msgid "Ignoring point outside computation region: %.4f,%.4f"
+#: ../raster/r.surf.area/main.c:106
+msgid "Output in 'square map units'"
msgstr ""
-#: ../raster/r.stats.quantile/main.c:76
-#, fuzzy
-msgid "Computing histograms"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.area/main.c:151
+msgid "Null value area ignored in calculation:"
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:242
-#, fuzzy
-msgid "Printing quantiles"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.area/main.c:153
+msgid "Plan area used in calculation:"
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:294
-#, fuzzy
-msgid "Generating reclass maps"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.area/main.c:156
+msgid "Surface area calculation(low, high, avg):"
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:333
-#, fuzzy
-msgid "Writing output maps"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.area/main.c:161
+msgid "Current region plan area:"
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:391
-msgid "Compute category quantiles using two passes."
+#: ../raster/r.surf.area/main.c:163
+msgid "Estimated region Surface Area:"
msgstr ""
-#: ../raster/r.stats.quantile/main.c:418
-#, fuzzy
-msgid "Resultant raster map(s)"
+#: ../raster/r.flow/io.c:87
+msgid "Elevation raster map resolution differs from current region resolution"
+msgstr ""
+#: ../raster/r.flow/io.c:89 ../raster/r.flow/io.c:107
+#: ../raster/r.buffer/read_map.c:52
+#, fuzzy, c-format
+msgid "Reading input raster map <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stats.quantile/main.c:430
-msgid "Don't create output maps; just print statistics"
+#: ../raster/r.flow/io.c:104
+msgid "Resolution of aspect file differs from current region resolution"
msgstr ""
-#: ../raster/r.stats.quantile/main.c:442
-#, fuzzy
-msgid "Either -p or output= must be given"
-msgstr "출력할 래스터맵"
+#: ../raster/r.flow/io.c:121
+msgid "Reading input files: barrier"
+msgstr ""
-#: ../raster/r.stats.quantile/main.c:445
-msgid "-p and output= are mutually exclusive"
+#: ../raster/r.flow/io.c:149
+#, c-format
+msgid "Cannot create segment file %s"
msgstr ""
-#: ../raster/r.stats.quantile/main.c:469
+#: ../raster/r.flow/io.c:154
#, c-format
-msgid "Number of quantiles (%d) does not match number of output maps (%d)"
+msgid "Cannot format segment file %s"
msgstr ""
-#: ../raster/r.stats.quantile/main.c:486
+#: ../raster/r.flow/io.c:160
#, c-format
-msgid "Base map <%s> has too many categories (max: %d)"
+msgid "Cannot open segment file %s"
msgstr ""
-#: ../raster/r.report/stats.c:93
+#: ../raster/r.flow/io.c:178 ../raster/r.volume/main.c:154
+#: ../raster/r.carve/vect.c:32 ../raster/r.drain/main.c:197
+#: ../raster/r.stream.snap/points_io.c:88
+#: ../raster/r.stream.extract/close.c:37 ../raster/r.resamp.bspline/main.c:484
+#: ../raster/simwe/simlib/output.c:38 ../raster/simwe/simlib/output.c:44
+#: ../raster/r.contour/main.c:153 ../raster/r.to.vect/main.c:148
+#: ../raster/r.random/random.c:63
+#: ../raster/r.stream.segment/stream_vector.c:29
+#: ../raster/r.stream.segment/stream_vector.c:190
+#: ../raster/r.stream.order/stream_vector.c:22
+#: ../raster/r.stream.order/stream_vector.c:109
+#: ../vector/v.in.sites/main.c:123 ../vector/v.edit/main.c:104
+#: ../vector/v.edit/main.c:119 ../vector/v.surf.bspline/main.c:338
+#: ../vector/v.in.db/main.c:151 ../vector/v.in.lidar/main.c:493
+#: ../vector/v.drape/main.c:157 ../vector/v.split/main.c:166
+#: ../vector/v.lidar.correction/main.c:205
+#: ../vector/v.lidar.correction/main.c:211 ../vector/v.to.points/main.c:129
+#: ../vector/v.vol.rst/main.c:583 ../vector/v.vol.rst/main.c:586
+#: ../vector/v.proj/main.c:366 ../vector/v.rectify/main.c:227
+#: ../vector/v.net.allpairs/main.c:136 ../vector/v.in.dwg/main.c:200
+#: ../vector/v.in.dxf/main.c:144 ../vector/v.voronoi/main.c:214
+#: ../vector/v.in.ogr/main.c:861 ../vector/v.generalize/main.c:324
+#: ../vector/v.in.ascii/main.c:231 ../vector/v.net.timetable/main.c:359
+#: ../vector/v.net.salesman/main.c:492 ../vector/v.overlay/main.c:210
+#: ../vector/v.surf.rst/main.c:570 ../vector/v.surf.rst/main.c:573
+#: ../vector/v.surf.rst/main.c:729 ../vector/v.net.visibility/main.c:83
+#: ../vector/v.random/main.c:244 ../vector/v.kernel/main.c:329
+#: ../vector/v.build.polylines/main.c:154 ../vector/v.select/main.c:121
+#: ../vector/v.parallel/main.c:152 ../vector/v.buffer/main.c:384
+#: ../vector/v.clean/main.c:283 ../vector/v.clean/main.c:290
+#: ../vector/v.sample/main.c:161 ../vector/v.lrs/v.lrs.create/main.c:267
+#: ../vector/v.lrs/v.lrs.create/main.c:273
+#: ../vector/v.lrs/v.lrs.label/main.c:295
+#: ../vector/v.lrs/v.lrs.segment/main.c:148
+#: ../vector/v.net.spanningtree/main.c:107 ../vector/v.hull/main.c:121
+#: ../vector/v.distance/main.c:332 ../vector/v.reclass/main.c:117
+#: ../vector/v.net.bridge/main.c:124 ../vector/v.external/main.c:146
+#: ../vector/v.net.flow/main.c:149 ../vector/v.net.flow/main.c:155
+#: ../vector/v.net.alloc/main.c:243 ../vector/v.patch/main.c:262
+#: ../vector/v.patch/main.c:267 ../vector/v.extract/main.c:347
+#: ../vector/v.net.steiner/main.c:601 ../vector/v.extrude/main.c:196
+#: ../vector/v.net.iso/main.c:280 ../vector/v.outlier/main.c:217
+#: ../vector/v.outlier/main.c:222 ../vector/v.outlier/main.c:228
+#: ../vector/v.build/main.c:154 ../vector/v.perturb/main.c:151
+#: ../vector/v.net.centrality/main.c:215 ../vector/v.segment/main.c:110
+#: ../vector/v.to.3d/main.c:87 ../vector/v.in.region/main.c:75
+#: ../vector/v.net.components/main.c:153 ../vector/v.net.distance/main.c:182
+#: ../vector/v.net.path/main.c:135 ../vector/v.delaunay/main.c:126
+#: ../vector/v.mkgrid/main.c:216 ../vector/v.net.connectivity/main.c:136
+#: ../vector/v.lidar.edgedetection/main.c:241 ../vector/v.qcount/main.c:126
+#: ../vector/v.transform/main.c:246 ../display/d.extract/main.c:106
+#: ../doc/vector/v.example/main.c:98
#, fuzzy, c-format
-msgid "Unable to open result file <%s>"
+msgid "Unable to create vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.report/stats.c:128 ../raster/r.kappa/stats.c:14
-msgid "Problem reading r.stats output"
+#: ../raster/r.flow/io.c:207 ../raster/r.cost/main.c:1043
+#: ../raster/r.buffer/write_map.c:45
+#, fuzzy, c-format
+msgid "Writing output raster map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.flow/main.c:424
+msgid "Constructs flowlines."
msgstr ""
-#: ../raster/r.report/main.c:69
+#: ../raster/r.flow/main.c:426
+msgid ""
+"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
+"areas) from a elevation raster map."
+msgstr ""
+#: ../raster/r.flow/main.c:435
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
#, fuzzy
-msgid "Reports statistics for raster maps."
+msgid "Name of input aspect raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.report/label.c:13
-msgid "Page width is too small"
-msgstr ""
+#: ../raster/r.flow/main.c:436 ../raster/r.flow/main.c:442
+#: ../raster/r.stream.distance/main.c:69 ../raster/r.stream.snap/main.c:64
+#: ../raster/r.stream.snap/main.c:70 ../raster/r.stream.extract/main.c:89
+#: ../raster/r.stream.extract/main.c:97 ../raster/r.spread/main.c:121
+#: ../raster/r.spread/main.c:133 ../raster/r.spread/main.c:146
+#: ../raster/r.spread/main.c:160 ../raster/r.spread/main.c:173
+#: ../raster/r.spread/main.c:185 ../raster/r.spread/main.c:197
+#: ../raster/r.stream.order/main.c:85
+#, fuzzy
+msgid "Input maps"
+msgstr "출력할 래스터맵"
-#: ../raster/r.report/parse.c:47
+#: ../raster/r.flow/main.c:441
#, fuzzy
-msgid "Units to report"
+msgid "Name of input barrier raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.report/parse.c:51
-msgid "area in square miles"
+#: ../raster/r.flow/main.c:448
+msgid "Number of cells between flowlines"
msgstr ""
-#: ../raster/r.report/parse.c:52
-msgid "area in square meters"
+#: ../raster/r.flow/main.c:454
+msgid "Maximum number of segments per flowline"
msgstr ""
-#: ../raster/r.report/parse.c:53
-msgid "area in square kilometers"
-msgstr ""
+#: ../raster/r.flow/main.c:459
+#, fuzzy
+msgid "Name for output flow line vector map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.report/parse.c:54
+#: ../raster/r.flow/main.c:460 ../raster/r.flow/main.c:466
+#: ../raster/r.flow/main.c:472 ../raster/r.stream.distance/main.c:83
+#: ../raster/r.stream.distance/main.c:89 ../raster/r.stream.slope/main.c:89
+#: ../raster/r.stream.slope/main.c:95 ../raster/r.stream.slope/main.c:102
+#: ../raster/r.stream.slope/main.c:109 ../raster/r.stream.extract/main.c:148
+#: ../raster/r.stream.extract/main.c:155 ../raster/r.stream.extract/main.c:162
+#: ../raster/r.spread/main.c:272 ../raster/r.spread/main.c:284
+#: ../raster/r.spread/main.c:296 ../raster/r.stream.channel/main.c:76
+#: ../raster/r.stream.channel/main.c:82 ../raster/r.stream.channel/main.c:89
+#: ../raster/r.stream.channel/main.c:96 ../raster/r.stream.channel/main.c:102
+#: ../raster/r.stream.order/main.c:93 ../raster/r.stream.order/main.c:100
#, fuzzy
-msgid "area in acres"
+msgid "Output maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.report/parse.c:55
-msgid "area in hectares"
-msgstr ""
+#: ../raster/r.flow/main.c:465
+#, fuzzy
+msgid "Name for output flow path length raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.report/parse.c:56
+#: ../raster/r.flow/main.c:471
#, fuzzy
-msgid "number of cells"
+msgid "Name for output flow accumulation raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.report/parse.c:57
-msgid "percent cover"
+#: ../raster/r.flow/main.c:477
+msgid "Compute upslope flowlines instead of default downhill flowlines"
msgstr ""
-#: ../raster/r.report/parse.c:67
-msgid "If no output given report is printed to standard output"
+#: ../raster/r.flow/main.c:481
+msgid "3D lengths instead of 2D"
msgstr ""
-#: ../raster/r.report/parse.c:82
-#, c-format
-msgid "Page length (default: %d lines)"
+#: ../raster/r.flow/main.c:485
+msgid "Use less memory, at a performance penalty"
msgstr ""
-#: ../raster/r.report/parse.c:91
-#, c-format
-msgid "Page width (default: %d characters)"
+#: ../raster/r.flow/main.c:540
+msgid "You must select one or more output maps (flout, lgout, dsout)"
msgstr ""
-#: ../raster/r.report/parse.c:122
-msgid "Suppress page headers"
-msgstr ""
-#: ../raster/r.report/parse.c:127
-msgid "Use formfeeds between pages"
-msgstr ""
-#: ../raster/r.report/parse.c:132
-msgid "Scientific format"
-msgstr ""
-#: ../raster/r.report/parse.c:196
-msgid "nsteps has to be > 0; using nsteps=255"
-msgstr ""
-#: ../raster/r.report/parse.c:203
-msgid "Illegal page length"
-msgstr ""
-#: ../raster/r.report/parse.c:210
-msgid "Illegal page width"
-msgstr ""
-#: ../raster/r.report/parse.c:265
-#, c-format
-msgid "Only %d unit%s allowed"
-msgstr ""
-#: ../raster/r.report/parse.c:298
-#, fuzzy, c-format
-msgid "Unable to read fp range for raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.le/r.le.patch/main.c:50
+#: ../raster/r.flow/main.c:556
msgid ""
-"Calculates attribute, patch size, core (interior) size, shape, fractal "
-"dimension, and perimeter measures for sets of patches in a landscape."
+"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
+"calculating flow accumulation."
msgstr ""
-#: ../raster/r.le/r.le.trace/main.c:57
-msgid ""
-"Displays the boundary of each r.le patch and shows how the boundary is "
-"traced, displays the attribute, size, perimeter and shape indices for each "
-"patch and saves the data in an output file."
+#: ../raster/r.flow/precomp.c:48
+msgid "Precomputing e/w distances..."
msgstr ""
-#: ../raster/r.le/r.le.trace/user_input.c:35
-msgid "Include sampling area boundary as perimeter"
-msgstr ""
-#: ../raster/r.le/r.le.trace/user_input.c:39
-msgid "Use 4 neighbor tracing instead of 8 neighbor"
-msgstr ""
-#: ../raster/r.le/r.le.trace/user_input.c:42
+#: ../raster/r.flow/precomp.c:50
#, fuzzy
-msgid "Raster map to be analyzed"
+msgid "Precomputing quantization tolerances..."
msgstr "출력할 래스터맵"
-#: ../raster/r.le/r.le.trace/user_input.c:45
-#, fuzzy
-msgid "Name of output file to store patch data"
-msgstr "출력할 래스터맵"
+#: ../raster/r.flow/precomp.c:53
+msgid "Precomputing inverted elevations..."
+msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:59
-msgid ""
-"Interactive tool used to setup the sampling and analysis framework that will "
-"be used by the other r.le programs."
+#: ../raster/r.flow/precomp.c:57
+msgid "Precomputing interpolated border elevations..."
msgstr ""
-#: ../raster/r.le/r.le.setup/main.c:63
+#: ../raster/r.flow/precomp.c:63
#, fuzzy
-msgid "Raster map to use to setup sampling"
+msgid "Precomputing re-oriented aspects..."
msgstr "출력할 래스터맵"
-#: ../raster/r.le/r.le.setup/main.c:67
+#: ../raster/r.flow/precomp.c:67
#, fuzzy
-msgid "Vector map to overlay"
+msgid "Precomputing aspects..."
msgstr "출력할 래스터맵"
-#: ../raster/r.le/r.le.setup/sample.c:1049
-#, fuzzy
-msgid "Cannot read vector"
-msgstr "출력할 래스터맵"
-#: ../raster/r.le/r.le.pixel/main.c:47
+#: ../raster/r.flow/precomp.c:111
+#, c-format
msgid ""
-"Contains a set of measures for attributes, diversity, texture, "
-"juxtaposition, and edge."
+"Resolution too unbalanced:\n"
+"atan2(%f deg, %f deg) =%f < %f tolerance\n"
+"please resample input map"
msgstr ""
-#: ../raster/r.distance/report.c:43
-msgid "Processing..."
-msgstr ""
-#: ../raster/r.distance/main.c:41
-msgid "Locates the closest points between objects in two raster maps."
-msgstr ""
-#: ../raster/r.distance/edges.c:46
+#: ../raster/r.flow/precomp.c:116
#, c-format
-msgid "Reading map %s ..."
+msgid "Resolution too unbalanced (%f x %f); please resample input map"
msgstr ""
-#: ../raster/r.distance/parse.c:33
-#, fuzzy
-msgid "Name of two input raster maps for computing inter-class distances"
-msgstr "출력할 래스터맵"
-#: ../raster/r.distance/parse.c:40
-msgid "Include category labels in the output"
-msgstr ""
-#: ../raster/r.distance/parse.c:45
-msgid "Report zero distance if rasters are overlapping"
-msgstr ""
-#: ../raster/r.distance/distance.c:101
+#: ../raster/r.flow/mem.c:40
#, c-format
-msgid "Reading maps <%s,%s> while finding 0 distance ..."
+msgid "Unable to write segment file for %s"
msgstr ""
-#: ../raster/r.out.gridatb/main.c:70
-msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
-msgstr ""
#: ../raster/r.out.gdal/export_band.c:52
#: ../raster/r.out.gdal/export_band.c:348
#, fuzzy
@@ -8082,6 +9855,11 @@
msgid "GDAL datatype: %s, range: %g - %g"
msgstr ""
+#: ../raster/r.out.gdal/attr.c:90 ../raster/r.out.gdal/attr.c:128
+#, fuzzy
+msgid "Failed to set raster attribute table"
+msgstr "출력할 래스터맵"
#: ../raster/r.out.gdal/main.c:50
#, c-format
msgid "Supported formats:\n"
@@ -8106,14 +9884,14 @@
#: ../raster/r.out.gdal/main.c:142 ../raster/r.out.gdal/main.c:189
#: ../raster/r.out.gdal/main.c:200 ../raster/r.out.gdal/main.c:211
-#: ../raster/r.out.gdal/main.c:220 ../vector/v.out.ogr/args.c:51
+#: ../raster/r.out.gdal/main.c:220 ../vector/v.out.postgis/args.c:38
+#: ../vector/v.out.postgis/args.c:48 ../vector/v.out.postgis/args.c:61
+#: ../vector/v.out.postgis/args.c:67 ../vector/v.out.postgis/args.c:73
+#: ../vector/v.out.postgis/args.c:79 ../vector/v.out.ogr/args.c:51
#: ../vector/v.out.ogr/args.c:62 ../vector/v.out.ogr/args.c:72
#: ../vector/v.out.ogr/args.c:82 ../vector/v.out.ogr/args.c:96
#: ../vector/v.out.ogr/args.c:109 ../vector/v.out.ogr/args.c:116
#: ../vector/v.out.ogr/args.c:122 ../vector/v.out.ogr/args.c:129
-#: ../vector/v.out.postgis/args.c:38 ../vector/v.out.postgis/args.c:48
-#: ../vector/v.out.postgis/args.c:61 ../vector/v.out.postgis/args.c:67
-#: ../vector/v.out.postgis/args.c:73 ../vector/v.out.postgis/args.c:79
msgid "Creation"
msgstr ""
@@ -8344,697 +10122,1091 @@
msgid "GDAL datatype: %s, valid range: %g - %g"
msgstr ""
-#: ../raster/r.out.gdal/attr.c:90 ../raster/r.out.gdal/attr.c:128
+#: ../raster/r.rescale/get_range.c:24 ../raster/r.rescale.eq/get_stats.c:19
+#, c-format
+msgid "Reading %s ..."
+msgstr ""
+#: ../raster/r.rescale/main.c:49 ../raster/r.rescale.eq/main.c:53
#, fuzzy
-msgid "Failed to set raster attribute table"
+msgid "rescale"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/count.c:68
+#: ../raster/r.rescale/main.c:51
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../raster/r.rescale/main.c:56 ../raster/r.rescale.eq/main.c:61
+msgid "The name of the raster map to be rescaled"
+msgstr ""
+#: ../raster/r.rescale/main.c:64 ../raster/r.rescale.eq/main.c:69
+msgid "The input data range to be rescaled (default: full range of input map)"
+msgstr ""
+#: ../raster/r.rescale/main.c:67 ../raster/r.rescale.eq/main.c:72
+msgid "The resulting raster map name"
+msgstr ""
+#: ../raster/r.rescale/main.c:74 ../raster/r.rescale.eq/main.c:79
+msgid "The output data range"
+msgstr ""
+#: ../raster/r.rescale/main.c:81 ../raster/r.rescale.eq/main.c:86
+msgid "Title for new raster map"
+msgstr ""
+#: ../raster/r.rescale/main.c:110
+#, c-format
+msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+msgstr ""
+#: ../raster/r.los/main.c:94
+msgid "viewshed"
+msgstr ""
+#: ../raster/r.los/main.c:95
+msgid "line of sight"
+msgstr ""
+#: ../raster/r.los/main.c:96
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../raster/r.los/main.c:107
#, fuzzy
-msgid "Collecting Stats..."
+msgid "Coordinates of the viewing position"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/count.c:123
-msgid "Programmer error in get_stats/switch"
+#: ../raster/r.los/main.c:112
+#, fuzzy
+msgid "Binary (1/0) raster map to use as a mask"
+msgstr "출력할 래스터맵"
+#: ../raster/r.los/main.c:119
+msgid "Viewing position height above the ground"
msgstr ""
-#: ../raster/r.random/random.c:100
-msgid "Cannot create new table"
+#: ../raster/r.los/main.c:127
+msgid "Maximum distance from the viewing point (meters)"
msgstr ""
-#: ../raster/r.random/random.c:110
-#, fuzzy, c-format
-msgid "Writing raster map <%s> and vector map <%s> ..."
+#: ../raster/r.los/main.c:133
+msgid "Consider earth curvature (current ellipsoid)"
+msgstr ""
+#: ../raster/r.los/main.c:160
+msgid "Lat/Long support is not (yet) implemented for this module."
+msgstr ""
+#: ../raster/r.los/main.c:165
+msgid "Specified observer coordinate is outside current region bounds."
+msgstr ""
+#: ../raster/r.los/main.c:209
+msgid "Pattern map should be a binary 0/1 CELL map"
+msgstr ""
+#: ../raster/r.los/main.c:243
+msgid ""
+"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+msgstr ""
+#: ../raster/r.los/main.c:248
+#, c-format
+msgid "Using maximum distance from the viewing point (meters): %f"
+msgstr ""
+#: ../raster/r.usler/main.c:54
+msgid "rainfall"
+msgstr ""
+#: ../raster/r.usler/main.c:55 ../raster/simwe/r.sim.sediment/main.c:114
+#: ../raster/r.uslek/main.c:56
+msgid "erosion"
+msgstr ""
+#: ../raster/r.usler/main.c:56
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../raster/r.usler/main.c:59
+#, fuzzy
+msgid "Name of annual precipitation raster map [mm/year]"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/random.c:113
-#, fuzzy, c-format
-msgid "Writing raster map <%s> ..."
+#: ../raster/r.usler/main.c:62
+#, fuzzy
+msgid "Name for output USLE R raster map [MJ.mm/ha.hr.year]"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/random.c:115
+#: ../raster/r.usler/main.c:69
+#, fuzzy
+msgid "Name of USLE R equation"
+msgstr "출력할 래스터맵"
+#: ../raster/r.usler/main.c:74
+msgid "Roosle (1975)"
+msgstr ""
+#: ../raster/r.usler/main.c:75
+msgid "Morgan (1974)"
+msgstr ""
+#: ../raster/r.usler/main.c:76
+msgid "Foster (1981)"
+msgstr ""
+#: ../raster/r.usler/main.c:77
+msgid "El-Swaify (1985)"
+msgstr ""
+#: ../raster/r.neighbors/readweights.c:18
#, fuzzy, c-format
-msgid "Writing vector map <%s> ..."
+msgid "Unable to open weights file %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/random.c:190 ../vector/v.net.distance/main.c:325
-#: ../vector/v.net.path/path.c:313 ../vector/v.net.allpairs/main.c:270
-#: ../vector/v.net.flow/main.c:261 ../vector/v.net.timetable/main.c:134
-#: ../vector/v.net.timetable/main.c:156 ../vector/v.net.components/main.c:38
-#: ../vector/v.net.centrality/main.c:69
+#: ../raster/r.neighbors/readweights.c:23
#, fuzzy, c-format
-msgid "Cannot insert new record: %s"
+msgid "Error reading weights file %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/random.c:243
-#, c-format
-msgid "Only [%ld] random points created"
-msgstr ""
+#: ../raster/r.neighbors/main.c:141 ../raster/r.mapcalc/main.c:112
+#: ../raster/r.quantile/main.c:256 ../raster/r.bitpattern/main.c:64
+#: ../raster/r.mode/main.c:55 ../raster/r.texture/main.c:102
+#: ../raster/r.mfilter/main.c:57 ../vector/v.neighbors/main.c:50
+#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:3
+#, fuzzy
+msgid "algebra"
+msgstr "출력할 래스터맵"
-#: ../raster/r.random/main.c:53 ../raster/r.contour/main.c:89
-#: ../doc/vector/v.example/main.c:50 ../misc/m.nviz.image/main.c:53
-#: ../misc/m.nviz.script/main.c:73
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:2
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.db.join_to_translate.c:2
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:2
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:2
-#: ../locale/scriptstrings/v.krige_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:2
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:2
-#: ../locale/scriptstrings/v.report_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:2
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:2
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:4
-#: ../locale/scriptstrings/v.db.update_to_translate.c:2
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:2
-#: ../locale/scriptstrings/v.build.all_to_translate.c:2
-#: ../locale/scriptstrings/v.centroids_to_translate.c:2
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:2
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:2
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:2
-#: ../display/d.vect/main.c:72 ../display/d.what.vect/main.c:57
-#: ../display/d.extract/main.c:50 ../visualization/ximgview/main.c:293
-#: ../vector/v.in.dxf/main.c:64 ../vector/v.kernel/main.c:108
-#: ../vector/v.rectify/main.c:70 ../vector/v.extrude/main.c:67
-#: ../vector/v.label/main.c:59 ../vector/v.net.connectivity/main.c:52
-#: ../vector/v.out.dxf/main.c:56 ../vector/v.transform/main.c:70
-#: ../vector/v.in.ascii/main.c:49 ../vector/v.surf.rst/main.c:142
-#: ../vector/v.info/print.c:424 ../vector/v.info/main.c:37
-#: ../vector/v.net.bridge/main.c:47 ../vector/v.what.rast3/main.c:64
-#: ../vector/v.category/main.c:75 ../vector/v.out.ogr/main.c:80
-#: ../vector/v.out.ascii/main.c:47 ../vector/v.support/main.c:39
-#: ../vector/v.proj/main.c:66 ../vector/v.out.svg/main.c:77
-#: ../vector/v.sample/main.c:75 ../vector/v.net.distance/main.c:64
-#: ../vector/v.type/main.c:39 ../vector/v.build/main.c:36
-#: ../vector/v.vol.rst/main.c:238 ../vector/v.net/main.c:45
-#: ../vector/v.convert/main.c:36 ../vector/v.delaunay/main.c:85
-#: ../vector/v.lidar.growing/main.c:75 ../vector/v.patch/main.c:68
-#: ../vector/v.external.out/main.c:43 ../vector/v.in.sites/main.c:57
-#: ../vector/v.net.salesman/main.c:126 ../vector/v.build.polylines/main.c:112
-#: ../vector/v.net.path/main.c:40 ../vector/v.out.pov/main.c:46
-#: ../vector/v.to.points/main.c:53 ../vector/v.label.sa/main.c:38
-#: ../vector/v.clean/main.c:51 ../vector/v.clean/test/topocheck.c:42
-#: ../vector/v.db.select/main.c:52 ../vector/v.voronoi/main.c:123
-#: ../vector/v.vect.stats/main.c:128 ../vector/v.colors.out/main.c:49
-#: ../vector/v.univar/main.c:92 ../vector/v.surf.idw/main.c:86
-#: ../vector/v.colors/main.c:55 ../vector/v.class/main.c:45
-#: ../vector/v.net.allpairs/main.c:61 ../vector/v.surf.bspline/main.c:91
-#: ../vector/v.drape/main.c:56 ../vector/v.timestamp/main.c:35
-#: ../vector/v.buffer/main.c:222 ../vector/v.mkgrid/main.c:66
-#: ../vector/v.in.lidar/main.c:154 ../vector/v.extract/main.c:77
-#: ../vector/v.segment/main.c:59 ../vector/v.out.vtk/main.c:47
-#: ../vector/v.hull/main.c:52 ../vector/v.to.rast3/main.c:48
-#: ../vector/v.in.region/main.c:41 ../vector/v.split/main.c:55
-#: ../vector/v.distance/main.c:87 ../vector/v.qcount/main.c:60
-#: ../vector/v.net.visibility/main.c:45 ../vector/v.to.db/main.c:36
-#: ../vector/v.lidar.edgedetection/main.c:72 ../vector/v.in.dwg/main.c:82
-#: ../vector/v.to.3d/main.c:36 ../vector/v.overlay/main.c:62
-#: ../vector/v.net.flow/main.c:58 ../vector/v.what/main.c:60
-#: ../vector/v.external/main.c:48 ../vector/v.normal/main.c:74
-#: ../vector/v.edit/main.c:55 ../vector/v.net.alloc/main.c:60
-#: ../vector/v.net.spanningtree/main.c:46 ../vector/v.net.steiner/main.c:345
-#: ../vector/v.net.iso/main.c:72 ../vector/v.what.rast/main.c:71
-#: ../vector/v.kcv/main.c:62 ../vector/v.in.db/main.c:52
-#: ../vector/v.select/main.c:47 ../vector/v.lrs/v.lrs.segment/main.c:70
-#: ../vector/v.lrs/v.lrs.create/main.c:121
-#: ../vector/v.lrs/v.lrs.where/main.c:57
-#: ../vector/v.lrs/v.lrs.label/main.c:102 ../vector/v.reclass/main.c:67
-#: ../vector/v.to.rast/main.c:44 ../vector/v.db.connect/main.c:51
-#: ../vector/v.parallel/main.c:49 ../vector/v.net.timetable/main.c:260
-#: ../vector/v.out.postgis/main.c:44 ../vector/v.in.ogr/main.c:127
-#: ../vector/v.net.components/main.c:71 ../vector/v.perturb/main.c:61
-#: ../vector/v.net.centrality/main.c:96 ../vector/v.generalize/main.c:76
-#: ../vector/v.lidar.correction/main.c:68 ../vector/v.random/main.c:85
-#: ../vector/v.neighbors/main.c:49 ../vector/v.outlier/main.c:69
-msgid "vector"
+#: ../raster/r.neighbors/main.c:146
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
msgstr ""
-#: ../raster/r.random/main.c:56
+#: ../raster/r.neighbors/main.c:156
#, fuzzy
msgid ""
-"Creates a raster map layer and vector point map containing randomly located "
-"points."
+"Name of an input raster map to select the cells which should be processed"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/main.c:60 ../raster/r.out.bin/main.c:290
-#: ../imagery/i.zc/main.c:65
-msgid "Name of input raster map"
+#: ../raster/r.neighbors/main.c:175 ../vector/v.neighbors/main.c:71
+msgid "Neighborhood operation"
msgstr ""
-#: ../raster/r.random/main.c:65
+#: ../raster/r.neighbors/main.c:177 ../raster/r.neighbors/main.c:185
+#: ../raster/r.neighbors/main.c:221
+msgid "Neighborhood"
+msgstr ""
+#: ../raster/r.neighbors/main.c:183
+#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
+msgid "Neighborhood size"
+msgstr ""
+#: ../raster/r.neighbors/main.c:192
+msgid "Title of the output raster map"
+msgstr ""
+#: ../raster/r.neighbors/main.c:197
#, fuzzy
-msgid "Name of cover raster map"
+msgid "Text file containing weights"
msgstr "출력할 래스터맵"
-#: ../raster/r.random/main.c:72
-msgid "The number of points to allocate"
+#: ../raster/r.neighbors/main.c:203
+msgid "Sigma (in cells) for Gaussian filter"
msgstr ""
-#: ../raster/r.random/main.c:84
-msgid "Generate points also for NULL category"
+#: ../raster/r.neighbors/main.c:216
+msgid "Do not align output with the input"
msgstr ""
-#: ../raster/r.random/main.c:89
-msgid "Report information about input raster and exit"
+#: ../raster/r.neighbors/main.c:220
+msgid "Use circular neighborhood"
msgstr ""
-#: ../raster/r.random/main.c:93
-msgid "Generate vector points as 3D points"
+#: ../raster/r.neighbors/main.c:228
+msgid "Neighborhood size must be positive"
msgstr ""
-#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:165
-msgid "Do not build topology in points mode"
+#: ../raster/r.neighbors/main.c:230
+msgid "Neighborhood size must be odd"
msgstr ""
-#: ../raster/r.random/main.c:97
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
-#: ../vector/v.in.ascii/main.c:89 ../vector/v.in.ascii/main.c:96
-#: ../vector/v.in.ascii/main.c:108 ../vector/v.in.ascii/main.c:118
-#: ../vector/v.in.ascii/main.c:128 ../vector/v.in.ascii/main.c:138
-#: ../vector/v.in.ascii/main.c:162 ../vector/v.in.ascii/main.c:166
-#: ../vector/v.in.ascii/main.c:172 ../vector/v.out.ascii/args.c:40
-#: ../vector/v.out.ascii/args.c:66 ../vector/v.out.ascii/args.c:76
-#: ../vector/v.out.ascii/args.c:86 ../vector/v.out.ascii/args.c:92
-msgid "Points"
+#: ../raster/r.neighbors/main.c:234
+msgid "weight= and -c are mutually exclusive"
msgstr ""
-#: ../raster/r.random/main.c:133
-#, c-format
-msgid "Note: one (or both) of %s and %s must be specified"
+#: ../raster/r.neighbors/main.c:237
+msgid "weight= and gauss= are mutually exclusive"
msgstr ""
-#: ../raster/r.random/main.c:141
-#, c-format
-msgid "<%s=%s> invalid percentage"
+#: ../raster/r.neighbors/main.c:263 ../raster/r.series/main.c:309
+msgid "output= and method= must have the same number of values"
msgstr ""
-#: ../raster/r.random/main.c:148
+#: ../raster/r.neighbors/main.c:297
#, c-format
-msgid "<%s=%s> invalid number of points"
+msgid ""
+"Method %s not compatible with weighing window, using weight mask instead"
msgstr ""
-#: ../raster/r.random/main.c:161
+#: ../raster/r.neighbors/main.c:305
#, c-format
-msgid "There aren't [%ld] cells in the current region"
+msgid ""
+"Method %s not compatible with Gaussian filter, using unweighed version "
+"instead"
msgstr ""
-#: ../raster/r.random/main.c:164
-#, c-format
-msgid "There aren't [%ld] non-NULL cells in the current region"
+#: ../raster/r.neighbors/main.c:355
+#, fuzzy, c-format
+msgid "Opening selection map <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.interp/main.c:77 ../raster/r.resamp.filter/main.c:385
+#: ../raster/r.resamp.stats/main.c:257 ../raster/r.resamp.bspline/main.c:82
+#: ../raster/r.resample/main.c:55 ../raster/r.resamp.rst/main.c:149
+#, fuzzy
+msgid "resample"
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.interp/main.c:80
+#, fuzzy
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.interp/main.c:88
+msgid "Method"
msgstr ""
-#: ../raster/r.random/main.c:169
-msgid "There are no valid locations in the current region"
+#: ../raster/r.resamp.interp/main.c:353 ../raster/r.resamp.filter/main.c:552
+#: ../raster/r.resamp.stats/main.c:370 ../raster/r.tile/main.c:192
+#, c-format
+msgid "Unable to read color table for %s"
msgstr ""
-#: ../raster/r.series.interp/main.c:68
-msgid ""
-"Interpolate raster maps located (temporal or spatial) in between input "
-"raster maps at specific sampling positions."
+#: ../raster/r.transect/main.c:84
+#, c-format
+msgid "End coordinate: %.15g, %.15g"
msgstr ""
-#: ../raster/r.series.interp/main.c:78
+#: ../raster/r.transect/main.c:104
#, fuzzy
-msgid "Data point position for each input map"
+msgid "transect"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:83
+#: ../raster/r.transect/main.c:106
msgid ""
-"Input file with an input raster map name and data point position per line, "
-"field separator between name and sample point is |"
+"Outputs raster map layer values lying along user defined transect line(s)."
msgstr ""
-#: ../raster/r.series.interp/main.c:95
-#, fuzzy
-msgid "Sampling point position for each output map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.transect/main.c:110
+msgid "Raster map to be queried"
+msgstr ""
-#: ../raster/r.series.interp/main.c:99
+#: ../raster/r.transect/main.c:116
+msgid "Transect definition"
+msgstr ""
+#: ../raster/r.transect/main.c:130 ../raster/r.profile/main.c:94
+msgid "Output easting and northing in first two columns of four column output"
+msgstr ""
+#: ../raster/r.cross/main.c:72
msgid ""
-"Input infile with an output raster map name and sample point position per "
-"line, field separator between name and sample point is |"
+"Creates a cross product of the category values from multiple raster map "
+"layers."
msgstr ""
-#: ../raster/r.series.interp/main.c:109
-msgid "Interpolation method, currently only linear interpolation is supported"
+#: ../raster/r.cross/main.c:81
+#, c-format
+msgid "Names of 2-%d input raster maps"
msgstr ""
-#: ../raster/r.series.interp/main.c:116
-msgid "output= and outfile= are mutually exclusive"
+#: ../raster/r.cross/main.c:90
+msgid "Non-zero data only"
msgstr ""
-#: ../raster/r.series.interp/main.c:119
-msgid "samplingpos= and outfile= are mutually exclusive"
+#: ../raster/r.cross/main.c:103
+#, c-format
+msgid "More than %d files not allowed"
msgstr ""
-#: ../raster/r.series.interp/main.c:122
-#, fuzzy
-msgid "Please specify output= or outfile="
-msgstr "출력할 래스터맵"
+#: ../raster/r.cross/main.c:119
+msgid "Must specify 2 or more input maps"
+msgstr ""
-#: ../raster/r.series.interp/main.c:125
-#, fuzzy
-msgid "Please specify output= and samplingpos="
+#: ../raster/r.cross/main.c:136
+#, c-format
+msgid "%s: STEP 2 ..."
+msgstr ""
+#: ../raster/r.cross/main.c:169 ../raster/r.resample/main.c:125
+#: ../raster/r.basins.fill/main.c:146 ../raster/r.in.png/main.c:485
+#, fuzzy, c-format
+msgid "Creating support files for <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:128
-msgid "input= and infile= are mutually exclusive"
+#: ../raster/r.cross/main.c:179
+#, c-format
+msgid "%ld categories"
msgstr ""
-#: ../raster/r.series.interp/main.c:131
-msgid "datapos= and infile= are mutually exclusive"
+#: ../raster/r.cross/renumber.c:33
+#, c-format
+msgid "%s: STEP 3 ... "
msgstr ""
-#: ../raster/r.series.interp/main.c:134
+#: ../raster/r.cross/cross.c:65
+#, c-format
+msgid "%s: STEP 1 ... "
+msgstr ""
+#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
+#: ../raster/r.profile/input.c:60
+msgid "One coordinate pair per line, please"
+msgstr ""
+#: ../raster/r.profile/main.c:53
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../raster/r.profile/main.c:61 ../raster/r.horizon/main.c:297
+msgid "Name of file for output (use output=- for stdout)"
+msgstr ""
+#: ../raster/r.profile/main.c:66 ../display/d.profile/main.c:206
+msgid "Profile coordinate pairs"
+msgstr ""
+#: ../raster/r.profile/main.c:72
#, fuzzy
-msgid "Please specify input= or infile="
+msgid "Name of input file containing coordinate pairs"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:137
+#: ../raster/r.profile/main.c:74
#, fuzzy
-msgid "Please specify input= and datapos="
+msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:203
+#: ../raster/r.profile/main.c:82
+msgid "Resolution along profile (default = current region resolution)"
+msgstr ""
+#: ../raster/r.profile/main.c:89
+msgid "Character to represent no data cell"
+msgstr ""
+#: ../raster/r.profile/main.c:99
+msgid "Output RRR:GGG:BBB color values for each profile point"
+msgstr ""
+#: ../raster/r.profile/main.c:114
+msgid "Either use profile option or coordinate_file option, but not both"
+msgstr ""
+#: ../raster/r.profile/main.c:123
#, c-format
-msgid "Missing point position for %s map <%s> in file <%s> near line %i"
+msgid "Illegal resolution! [%g]"
msgstr ""
-#: ../raster/r.series.interp/main.c:218 ../raster/r.series.interp/main.c:252
+#: ../raster/r.profile/main.c:130
+#, c-format
+msgid "Using resolution [%g]"
+msgstr ""
+#: ../raster/r.profile/main.c:161
+msgid "Output Format:"
+msgstr ""
+#: ../raster/r.profile/main.c:164
+#, c-format
+msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
+msgstr ""
+#: ../raster/r.profile/main.c:166
+#, c-format
+msgid "[Along Track Dist.(m)] [Elevation]"
+msgstr ""
+#: ../raster/r.profile/main.c:168
+msgid " [RGB Color]"
+msgstr ""
+#: ../raster/r.profile/main.c:179
#, fuzzy, c-format
-msgid "Preparing %s map <%s> at position %g"
+msgid "Could not open <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:222
+#: ../raster/r.profile/main.c:186
+#, c-format
+msgid "Invalid coordinates %s %s"
+msgstr ""
+#: ../raster/r.profile/main.c:257
+#, c-format
+msgid "Approx. transect length [%f] m"
+msgstr ""
+#: ../raster/r.profile/main.c:260
+msgid "Endpoint coordinates are outside of current region settings"
+msgstr ""
+#: ../raster/r.mapcalc/map.c:207 ../raster/r.mapcalc/map3.c:179
#, fuzzy, c-format
-msgid "No raster map name found in %s file <%s>"
+msgid "Unable to read color file for raster map <%s@%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:233
+#: ../raster/r.mapcalc/map.c:216 ../raster/r.mapcalc/map3.c:188
+#: ../raster/r.category/main.c:148 ../raster/r.category/main.c:230
+#: ../raster/r.report/parse.c:306
#, fuzzy, c-format
-msgid "No %s raster map not found"
+msgid "Unable to read category file of raster map <%s@%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.interp/main.c:240
+#: ../raster/r.mapcalc/map.c:220 ../raster/r.mapcalc/map3.c:192
+#, fuzzy, c-format
+msgid "Unable to create btree for raster map <%s@%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.mapcalc/map.c:269 ../raster/r.mapcalc/map.c:481
+#: ../raster/r.mapcalc/map.c:522 ../raster/r.mapcalc/map.c:618
+#: ../raster/r.mapcalc/expression.c:353 ../raster/r.mapcalc/map3.c:237
+#: ../raster/r.mapcalc/map3.c:421 ../raster/r.mapcalc/map3.c:466
+#: ../raster/r.mapcalc/map3.c:563
#, c-format
-msgid "The number of %s maps and %s point positions must be equal"
+msgid "Invalid map modifier: '%c'"
msgstr ""
-#: ../raster/r.series.interp/main.c:269
+#: ../raster/r.mapcalc/map.c:412 ../raster/r.mapcalc/evaluate.c:94
+#: ../raster/r.mapcalc/evaluate.c:234 ../raster/r.mapcalc/map3.c:351
#, c-format
-msgid "Start interpolation run with %i input maps and %i output maps"
+msgid "Unknown type: %d"
msgstr ""
-#: ../raster/r.series.interp/main.c:289
+#: ../raster/r.mapcalc/evaluate.c:140
#, c-format
-msgid ""
-"map <%s> at position %g was not interpolated. Check the interpolation "
-"interval."
+msgid "Invalid type: %d"
msgstr ""
-#: ../raster/r.series.interp/main.c:309
-#, fuzzy
-msgid "At least 2 input maps are required for linear interpolation"
-msgstr "출력할 래스터맵"
+#: ../raster/r.mapcalc/evaluate.c:179
+#, c-format
+msgid "Too few arguments for function '%s'"
+msgstr ""
-#: ../raster/r.series.interp/main.c:327
+#: ../raster/r.mapcalc/evaluate.c:183
#, c-format
-msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
+msgid "Too many arguments for function '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:107
-msgid "Simulates elliptically anisotropic spread."
+#: ../raster/r.mapcalc/evaluate.c:187
+#, c-format
+msgid "Invalid argument type for function '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:109
-msgid ""
-"Generates a raster map of the cumulative time of spread, given raster maps "
-"containing the rates of spread (ROS), the ROS directions and the spread "
-"origins. It optionally produces raster maps to contain backlink UTM "
-"coordinates for tracing spread paths. Usable for fire spread simulations."
+#: ../raster/r.mapcalc/evaluate.c:191
+#, c-format
+msgid "Invalid return type for function '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:123
-msgid "Raster map containing maximal ROS (cm/min)"
+#: ../raster/r.mapcalc/evaluate.c:195
+#, c-format
+msgid "Unknown type for function '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:125
-msgid ""
-"Name of an existing raster map layer in the user's current mapset search "
-"path containing the maximum ROS values (cm/minute)."
+#: ../raster/r.mapcalc/evaluate.c:198
+#, c-format
+msgid "Number of arguments for function '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:135
-#, fuzzy
-msgid "Raster map containing directions of maximal ROS (degree)"
+#: ../raster/r.mapcalc/evaluate.c:202
+#, c-format
+msgid "Unknown error for function '%s'"
+msgstr ""
+#: ../raster/r.mapcalc/evaluate.c:303
+#, fuzzy, c-format
+msgid "output map <%s> exists"
msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:137
-msgid ""
-"path containing directions of the maximum ROSes, clockwise from north "
-"(degree)."
+#: ../raster/r.mapcalc/function.c:100
+#, c-format
+msgid "Known functions:"
msgstr ""
-#: ../raster/r.spread/main.c:148
-msgid "Raster map containing base ROS (cm/min)"
+#: ../raster/r.mapcalc/expression.c:202
+#, c-format
+msgid "Undefined variable '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:150
-msgid ""
-"path containing the ROS values in the directions perpendicular to maximum "
-"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
-"directional factors."
+#: ../raster/r.mapcalc/expression.c:217
+#, c-format
+msgid "Invalid map <%s>"
msgstr ""
-#: ../raster/r.spread/main.c:162
-#, fuzzy
-msgid "Raster map containing starting sources"
-msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:164
-msgid ""
-"path containing starting locations of the spread phenomenon. Any positive "
-"integers in this map are recognized as starting sources (seeds)."
+#: ../raster/r.mapcalc/expression.c:258
+#, c-format
+msgid "Undefined function '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:175
-msgid "Raster map containing maximal spotting distance (m, required with -s)"
+#: ../raster/r.mapcalc/expression.c:263
+#, c-format
+msgid "Too few arguments (%d) to function %s()"
msgstr ""
-#: ../raster/r.spread/main.c:177
-msgid ""
-"path containing the maximum potential spotting distances (meters)."
+#: ../raster/r.mapcalc/expression.c:267
+#, c-format
+msgid "Too many arguments (%d) to function %s()"
msgstr ""
-#: ../raster/r.spread/main.c:187
-msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
+#: ../raster/r.mapcalc/expression.c:271
+#, c-format
+msgid "Incorrect argument types to function %s()"
msgstr ""
-#: ../raster/r.spread/main.c:199
-msgid ""
-"Raster map containing fine fuel moisture of the cell receiving a spotting "
-"firebrand (%, required with -s)"
+#: ../raster/r.mapcalc/expression.c:274
+#, c-format
+msgid "Internal error for function %s()"
msgstr ""
-#: ../raster/r.spread/main.c:211
-msgid "Basic sampling window size needed to meet certain accuracy (3)"
+#: ../raster/r.mapcalc/expression.c:449
+#, c-format
+msgid "Illegal number of arguments (%d) for operator '%s'"
msgstr ""
-#: ../raster/r.spread/main.c:213
-msgid ""
-"An odd integer ranging 3 - 15 indicating the basic sampling window size "
-"within which all cells will be considered to see whether they will be "
-"reached by the current spread cell. The default number is 3 which means a "
-"3x3 window."
+#: ../raster/r.mapcalc/expression.c:489
+#, c-format
+msgid "Format_expression_prec: unknown type: %d"
msgstr ""
-#: ../raster/r.spread/main.c:223
-msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
-msgstr ""
+#: ../raster/r.mapcalc/main.c:113
+#, fuzzy
+msgid "Raster map calculator."
+msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:225
-msgid ""
-"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
-"be considered to see whether they will be reached by the current spread "
-"cell. The closer to 1.0 the decimal number is, the longer the program will "
-"run and the higher the simulation accuracy will be. The default number is "
-"0.5."
+#: ../raster/r.mapcalc/main.c:120
+msgid "Expression to evaluate"
msgstr ""
-#: ../raster/r.spread/main.c:236
-msgid "Initial time for current simulation (0) (min)"
+#: ../raster/r.mapcalc/main.c:121 ../raster/r.mapcalc/main.c:127
+#, fuzzy
+msgid "Expression"
+msgstr "출력할 래스터맵"
+#: ../raster/r.mapcalc/main.c:126
+#, fuzzy
+msgid "File containing expression(s) to evaluate"
+msgstr "출력할 래스터맵"
+#: ../raster/r.mapcalc/main.c:145
+msgid "file= and expression= are mutually exclusive"
msgstr ""
-#: ../raster/r.spread/main.c:238
-msgid ""
-"A non-negative number specifying the initial time for the current spread "
-"simulation (minutes). This is useful when multiple phase simulation is "
-"conducted. The default time is 0."
+#: ../raster/r.mapcalc/main.c:155
+msgid "parse error"
msgstr ""
-#: ../raster/r.spread/main.c:247
-msgid "Simulating time duration LAG (fill the region) (min)"
+#: ../raster/r.mapcalc/main.c:164
+msgid "Floating point error(s) occurred in the calculation"
msgstr ""
-#: ../raster/r.spread/main.c:249
-msgid ""
-"A non-negative integer specifying the simulating duration time lag "
-"(minutes). The default is infinite, but the program will terminate when the "
-"current geographic region/mask has been filled. It also controls the "
-"computational time, the shorter the time lag, the faster the program will "
-"run."
+#: ../raster/r.mapcalc/main.c:169
+msgid "Overflow occurred in the calculation"
msgstr ""
-#: ../raster/r.spread/main.c:261
-msgid "Name of raster map as a display backdrop"
+#: ../raster/r.mapcalc/map3.c:370
+#, fuzzy, c-format
+msgid "Unable to close raster map <%s@%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.mapcalc/map3.c:619
+#, fuzzy
+msgid "Unable to close output raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.region/main.c:54
+msgid "Sets the boundary definitions for a raster map."
msgstr ""
-#: ../raster/r.spread/main.c:263
-msgid ""
-"path to be used as the background on which the \"live\" movement will be "
-"shown."
+#: ../raster/r.region/main.c:60
+msgid "Set from current region"
msgstr ""
-#: ../raster/r.spread/main.c:272 ../raster/r.spread/main.c:284
-#: ../raster/r.spread/main.c:296 ../raster/r.stream.distance/main.c:82
-#: ../raster/r.stream.distance/main.c:88 ../raster/r.stream.channel/main.c:76
-#: ../raster/r.stream.channel/main.c:82 ../raster/r.stream.channel/main.c:89
-#: ../raster/r.stream.channel/main.c:96 ../raster/r.stream.channel/main.c:102
-#: ../raster/r.stream.slope/main.c:89 ../raster/r.stream.slope/main.c:95
-#: ../raster/r.stream.slope/main.c:102 ../raster/r.stream.slope/main.c:109
-#: ../raster/r.stream.extract/main.c:148 ../raster/r.stream.extract/main.c:155
-#: ../raster/r.stream.extract/main.c:162 ../raster/r.stream.order/main.c:93
-#: ../raster/r.stream.order/main.c:100
+#: ../raster/r.region/main.c:71
#, fuzzy
-msgid "Output maps"
+msgid "Name of raster map to change"
msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:274
-msgid "Raster map to contain output spread time (min)"
+#: ../raster/r.region/main.c:79
+msgid "Set region from named region"
msgstr ""
-#: ../raster/r.spread/main.c:276
-msgid ""
-"Name of the new raster map layer to contain the results of the cumulative "
-"spread time needed for a phenomenon to reach each cell from the starting "
-"sources (minutes)."
+#: ../raster/r.region/main.c:87
+msgid "Set region to match this raster map"
msgstr ""
-#: ../raster/r.spread/main.c:286
-#, fuzzy
-msgid "Name of raster map to contain X back coordinates"
+#: ../raster/r.region/main.c:94
+msgid "Set region to match this vector map"
+msgstr ""
+#: ../raster/r.region/main.c:147
+msgid "Raster map to align to"
+msgstr ""
+#: ../raster/r.region/main.c:179
+#, fuzzy, c-format
+msgid "Unable to open 3dview file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:288
-msgid ""
-"Name of the new raster map layer to contain the results of backlink "
-"information in UTM easting coordinates for each cell."
+#: ../raster/r.region/main.c:183
+#, fuzzy, c-format
+msgid "Unable to read 3dview file <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.region/main.c:185
+#, fuzzy, c-format
+msgid "Old 3dview file. Region <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../raster/r.param.scale/process.c:74
+msgid "E-W and N-S grid resolutions are different. Taking average."
msgstr ""
-#: ../raster/r.spread/main.c:298
+#: ../raster/r.param.scale/interface.c:55
#, fuzzy
-msgid "Name of raster map to contain Y back coordinates"
+msgid "geomorphology"
msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:300
-msgid ""
-"information in UTM northing coordinates for each cell."
+#: ../raster/r.param.scale/interface.c:56
+msgid "Extracts terrain parameters from a DEM."
msgstr ""
-#: ../raster/r.spread/main.c:307
-msgid "DISPLAY 'live' spread process on screen"
+#: ../raster/r.param.scale/interface.c:57
+msgid ""
+"Uses a multi-scale approach by taking fitting quadratic parameters to any "
+"size window (via least squares)."
msgstr ""
-#: ../raster/r.spread/main.c:309
+#: ../raster/r.param.scale/interface.c:75
#, fuzzy
-msgid "Display the "
+msgid "Name for output raster map containing morphometric parameter"
msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:312
-msgid "Live display - disabled and depreciated"
+#: ../raster/r.param.scale/interface.c:79
+msgid "Slope tolerance that defines a 'flat' surface (degrees)"
msgstr ""
-#: ../raster/r.spread/main.c:317
-msgid "Consider spotting effect (for wildfires)"
+#: ../raster/r.param.scale/interface.c:86
+msgid "Curvature tolerance that defines 'planar' surface"
msgstr ""
-#: ../raster/r.spread/main.c:329
-msgid "The display feature is disabled"
+#: ../raster/r.param.scale/interface.c:93
+msgid "Size of processing window (odd number only)"
msgstr ""
-#: ../raster/r.spread/main.c:494
+#: ../raster/r.param.scale/interface.c:101
+msgid "Morphometric parameter in 'size' window to calculate"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:109
+msgid "Exponent for distance weighting (0.0-4.0)"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:115 ../raster/r.out.pov/main.c:150
+msgid "Vertical scaling factor"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:121
+msgid "Constrain model through central window cell"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:164
+msgid "Morphometric parameter not recognised. Assuming 'Elevation'"
+msgstr ""
+#: ../raster/r.param.scale/interface.c:172
+msgid "Inappropriate window size (too big or even)"
+msgstr ""
+#: ../raster/r.param.scale/main.c:42
+msgid "Lat/Long locations are not supported by this module"
+msgstr ""
+#: ../raster/r.volume/main.c:76
+msgid "volume"
+msgstr ""
+#: ../raster/r.volume/main.c:77
#, fuzzy
-msgid "Reading inputs..."
+msgid "clumps"
msgstr "출력할 래스터맵"
-#: ../raster/r.spread/main.c:536
-#, c-format
-msgid "Reading %s..."
+#: ../raster/r.volume/main.c:79
+msgid "Calculates the volume of data \"clumps\"."
msgstr ""
-#: ../raster/r.series.accumulate/main.c:82
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+#: ../raster/r.volume/main.c:80
+msgid ""
+"Optionally produces a GRASS vector points map containing the calculated "
+"centroids of these clumps."
+msgstr ""
+#: ../raster/r.volume/main.c:85
#, fuzzy
-msgid "accumulation"
+msgid ""
+"Name of input raster map representing data that will be summed within clumps"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.accumulate/main.c:84
+#: ../raster/r.volume/main.c:91
+#, fuzzy
+msgid "Name of input clump raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.volume/main.c:92
msgid ""
-"Makes each output cell value a accumulationfunction of the values assigned "
-"to the corresponding cells in the input raster map layers."
+"Preferably the output of r.clump. If no clump map is given than MASK is used."
msgstr ""
-#: ../raster/r.series.accumulate/main.c:90
-msgid "Existing map to be added to output"
-msgstr ""
+#: ../raster/r.volume/main.c:98
+#, fuzzy
+msgid "Name for output vector points map to contain clump centroids"
+msgstr "출력할 래스터맵"
-#: ../raster/r.series.accumulate/main.c:98
+#: ../raster/r.volume/main.c:103 ../raster/r.report/parse.c:65
#, fuzzy
-msgid "Input file with raster map names, one per line"
+msgid "Name for output file to hold the report"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.accumulate/main.c:109
+#: ../raster/r.volume/main.c:105
#, fuzzy
-msgid "Scale factor for input"
+msgid "If no output file given report is printed to standard output"
msgstr "출력할 래스터맵"
-#: ../raster/r.series.accumulate/main.c:116
-msgid "Shift factor for input"
+#: ../raster/r.volume/main.c:109
+msgid "Generate unformatted report (items separated by colon)"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:121
+#: ../raster/r.volume/main.c:142
msgid ""
-"The raster map specifying the lower accumulation limit, also called baseline"
+"No MASK found. If no clump map is given than the MASK is required. You need "
+"to define a clump raster map or create a MASK by r.mask command."
msgstr ""
-#: ../raster/r.series.accumulate/main.c:126
-msgid ""
-"The raster map specifying the upper accumulation limit, also called cutoff. "
-"Only applied to BEDD computation."
+#: ../raster/r.volume/main.c:144
+msgid "No clump map given, using MASK"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:139
-msgid "Use these limits in case lower and/or upper input maps are not defined"
+#: ../raster/r.volume/main.c:197
+#, c-format
+msgid "Invalid category value %d (max=%d): row=%d col=%d"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:151
+#: ../raster/r.volume/main.c:230
+#, fuzzy, c-format
+msgid "Creating vector point map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.volume/main.c:232
+#, fuzzy, c-format
+msgid "From '%s' on raster map <%s> using clumps from <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.volume/main.c:259 ../raster/r.to.vect/main.c:220
+#: ../vector/v.in.sites/main.c:174 ../vector/v.in.dxf/write_vect.c:232
+#: ../vector/v.in.ascii/main.c:391 ../vector/v.random/main.c:272
+#: ../vector/v.lrs/v.lrs.create/main.c:335 ../vector/v.mkgrid/main.c:248
+#, fuzzy, c-format
+msgid "Unable to create table: %s"
+msgstr "출력할 래스터맵"
+#: ../raster/r.volume/main.c:265
+#, c-format
msgid ""
-"Growing Degree Days or Winkler indices: depending on the chosen average "
-"computation set with -a flag"
+"\n"
+"Volume report on data from <%s> using clumps on <%s> raster map"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:152
+#: ../raster/r.volume/main.c:269
+#, c-format
+msgid "Category Average Data # Cells Centroid Total\n"
+msgstr ""
+#: ../raster/r.volume/main.c:271
+#, c-format
+msgid "Number in clump Total in clump Easting Northing Volume"
+msgstr ""
+#: ../raster/r.volume/main.c:295 ../raster/r.to.vect/util.c:157
+#: ../raster/r.to.vect/areas_io.c:377 ../vector/v.in.lidar/main.c:763
+#: ../vector/v.in.ogr/main.c:1175 ../vector/v.random/main.c:495
+#: ../vector/v.random/main.c:615
+#, c-format
+msgid "Cannot insert new row: %s"
+msgstr ""
+#: ../raster/r.volume/main.c:317
+msgid "Total Volume"
+msgstr ""
+#: ../raster/r.series/main.c:135 ../raster/r.series.accumulate/main.c:81
+#: ../raster/r.series.interp/main.c:65
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:3
+#, fuzzy
+msgid "series"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series/main.c:137
msgid ""
-"Mean: either (min + max) / 2 or sum(input maps)/(number of input maps) set "
-"with -a flag"
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
msgstr ""
-#: ../raster/r.series.accumulate/main.c:153
-msgid "Biologically Effective Degree Days"
+#: ../raster/r.series/main.c:146
+msgid ""
+"Input file with one raster map name and optional one weight per line, field "
+"separator between name and weight is |"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:154
-msgid "Huglin Heliothermal index"
+#: ../raster/r.series/main.c:172
+msgid ""
+"Weighting factor for each input map, default value is 1.0 for each input map"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:159
-msgid "Use arithmetical mean instead of (min + max ) / 2"
+#: ../raster/r.series/main.c:179 ../raster/r.series.accumulate/main.c:132
+msgid "Ignore values outside this range"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:171
-msgid "Create a FCELL map (floating point single precision) as output"
+#: ../raster/r.series/main.c:183 ../raster/r.series.accumulate/main.c:163
+#: ../raster/r.resamp.filter/main.c:424 ../raster/r.resamp.stats/main.c:283
+#: ../locale/scriptstrings/t.rast.series_to_translate.c:7
+msgid "Propagate NULLs"
msgstr ""
-#: ../raster/r.series.accumulate/main.c:356
-#, fuzzy, c-format
-msgid "'%s'=%f must be > '%s'=%f"
+#: ../raster/r.series/main.c:187 ../raster/r.series.accumulate/main.c:167
+#, fuzzy
+msgid "Don't keep files open"
msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/topidx.c:41 ../raster/r.flow/main.c:316
-#: ../imagery/i.landsat.toar/main.c:532
+#: ../raster/r.series/main.c:198 ../raster/r.series.accumulate/main.c:210
+msgid "input= and file= are mutually exclusive"
+msgstr ""
+#: ../raster/r.series/main.c:201 ../raster/r.series.accumulate/main.c:213
#, fuzzy
-msgid "Calculating..."
+msgid "Please specify input= or file="
msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/topidx.c:277
+#: ../raster/r.series/main.c:251 ../raster/r.series/main.c:294
#, fuzzy, c-format
-msgid "Number of sinks or boundaries: %d"
+msgid "Reading raster map <%s> using weight %f..."
msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/main.c:42
+#: ../raster/r.series/main.c:258 ../raster/r.series.accumulate/main.c:257
#, fuzzy
-msgid "Creates topographic index map from elevation raster map."
+msgid "No raster map name found in input file"
msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/main.c:48
+#: ../raster/r.series/main.c:268 ../raster/r.series.accumulate/main.c:267
+#: ../raster/r.stats/main.c:289
#, fuzzy
-msgid "Name for output topographic index map"
+msgid "Raster map not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/file_io.c:35
+#: ../raster/r.series/main.c:280
+msgid "input= and weights= must have the same number of values"
+msgstr ""
+#: ../raster/r.series/main.c:337 ../raster/r.series.accumulate/main.c:320
+#: ../raster/r.series.interp/main.c:329 ../raster/r.slope.aspect/main.c:541
+#: ../raster/r.shaded.relief/main.c:303 ../raster/r.patch/main.c:119
+msgid "Percent complete..."
+msgstr ""
+#: ../raster/r.compress/main.c:64
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../raster/r.compress/main.c:72 ../display/d.what.rast/main.c:67
+msgid "Name of existing raster map(s)"
+msgstr ""
+#: ../raster/r.compress/main.c:76
+msgid "Uncompress the map"
+msgstr ""
+#: ../raster/r.compress/main.c:104
#, c-format
+msgid "[%s] not found"
+msgstr ""
+#: ../raster/r.compress/main.c:110
+#, c-format
+msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+msgstr ""
+#: ../raster/r.compress/main.c:112
+#, c-format
+msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
+msgstr ""
+#: ../raster/r.compress/main.c:117
+#, c-format
+msgid "[%s] is a GDAL-linked map - can't (un)compress"
+msgstr ""
+#: ../raster/r.compress/main.c:159
+#, c-format
+msgid "DONE: uncompressed file is %lu bytes smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:160
+#, c-format
+msgid "DONE: compressed file is %lu bytes smaller"
+msgstr ""
+#: ../raster/r.compress/main.c:164
+#, c-format
+msgid "DONE: uncompressed file is %lu bytes bigger"
+msgstr ""
+#: ../raster/r.compress/main.c:165
+#, c-format
+msgid "DONE: compressed file is %lu bytes bigger"
+msgstr ""
+#: ../raster/r.compress/main.c:183
+#, c-format
+msgid "[%s] already uncompressed"
+msgstr ""
+#: ../raster/r.compress/main.c:187
+#, c-format
+msgid "[%s] already compressed"
+msgstr ""
+#: ../raster/r.compress/main.c:191
+#, c-format
msgid ""
-"The current region resolution [%s x %s] is finer than the input map's "
-"resolution [%s x %s]. The current region resolution must be identical to, or "
-"coarser than, the input map's resolution."
+"\n"
+"%sCOMPRESS [%s]"
msgstr ""
-#: ../raster/r.topidx/file_io.c:42
+#: ../raster/r.stream.distance/io.c:17
#, fuzzy
-msgid "Reading elevation map..."
+msgid "Unable to create map of unrecognised type"
msgstr "출력할 래스터맵"
-#: ../raster/r.topidx/file_io.c:87
+#: ../raster/r.stream.distance/io.c:79 ../raster/r.stream.distance/io.c:366
+#: ../raster/r.stream.snap/io.c:79 ../raster/r.stream.snap/io.c:366
+#: ../raster/r.stream.slope/main.c:122 ../raster/r.stream.channel/io.c:79
+#: ../raster/r.stream.channel/io.c:366 ../raster/r.stream.segment/io.c:79
+#: ../raster/r.stream.segment/io.c:366 ../raster/r.stream.order/io.c:79
+#: ../raster/r.stream.order/io.c:366 ../raster/r.stream.stats/io.c:79
+#: ../raster/r.stream.stats/io.c:366
+#, c-format
+msgid ""
+"Region resolution and raster map <%s> resolution differs. Run 'g.region rast="
+"%s' to set proper region resolution."
+msgstr ""
+#: ../raster/r.stream.distance/io.c:90 ../raster/r.stream.snap/io.c:90
+#: ../raster/r.stream.snap/io.c:376 ../raster/r.stream.channel/io.c:90
+#: ../raster/r.stream.channel/io.c:376 ../raster/r.stream.segment/io.c:90
+#: ../raster/r.stream.segment/io.c:376 ../raster/r.stream.order/io.c:90
+#: ../raster/r.stream.order/io.c:376 ../raster/r.stream.stats/io.c:90
+#, fuzzy, c-format
+msgid "Raster map <%s> is not of type '%s'"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/io.c:120 ../raster/r.stream.distance/io.c:404
+#: ../raster/r.surf.idw2/read_cell.c:27
+#: ../raster/r.series.accumulate/main.c:250
+#: ../raster/r.series.accumulate/main.c:275
+#: ../raster/r.series.accumulate/main.c:286
+#: ../raster/r.series.accumulate/main.c:294
+#: ../raster/r.series.accumulate/main.c:302 ../raster/r.stream.snap/io.c:120
+#: ../raster/r.stream.snap/io.c:404 ../raster/r.out.mpeg/main.c:287
+#: ../raster/r.grow.distance/main.c:263 ../raster/r.stream.channel/io.c:120
+#: ../raster/r.stream.channel/io.c:404 ../raster/r.surf.idw/main.c:708
+#: ../raster/r.stream.segment/io.c:120 ../raster/r.stream.segment/io.c:404
+#: ../raster/r.stream.order/io.c:120 ../raster/r.stream.order/io.c:404
+#: ../raster/r.stream.stats/io.c:120 ../raster/r.stream.stats/io.c:404
+#: ../ps/ps.map/ps_raster.c:102
+#, fuzzy, c-format
+msgid "Reading raster map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/io.c:148 ../raster/r.stream.distance/io.c:435
+#: ../raster/r.stream.snap/io.c:148 ../raster/r.stream.snap/io.c:435
+#: ../raster/r.stream.channel/io.c:148 ../raster/r.stream.channel/io.c:435
+#: ../raster/r.stream.segment/io.c:148 ../raster/r.stream.segment/io.c:435
+#: ../raster/r.stream.order/io.c:148 ../raster/r.stream.order/io.c:435
+#: ../raster/r.stream.stats/io.c:148 ../raster/r.stream.stats/io.c:435
#, fuzzy
-msgid "Writing topographic index map..."
+msgid "Wrong internal data type"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/distance_calc.c:414
-#: ../raster/r.stream.distance/distance_calc.c:567
+#: ../raster/r.stream.distance/io.c:297 ../raster/r.stream.snap/io.c:297
+#: ../raster/r.stream.segment/io.c:297 ../raster/r.stream.stats/io.c:297
#, fuzzy
-msgid "Calculate upstream parameters..."
+msgid "Unrecognisable data type"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/distance_init.c:14
-#: ../raster/r.stream.distance/distance_init.c:78
-#: ../raster/r.stream.order/stream_topology.c:38
-#: ../raster/r.stream.order/stream_topology.c:248
+#: ../raster/r.stream.distance/io.c:308 ../raster/r.stream.snap/io.c:308
+#: ../raster/r.stream.channel/io.c:308 ../raster/r.stream.segment/io.c:308
+#: ../raster/r.stream.order/io.c:308 ../raster/r.stream.stats/io.c:308
#, fuzzy
-msgid "Finding nodes..."
+msgid "Unable to format segment"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/distance_init.c:24
-#: ../raster/r.stream.distance/distance_init.c:90
-msgid "Stream and direction maps probably do not match"
-msgstr ""
+#: ../raster/r.stream.distance/io.c:314 ../raster/r.stream.snap/io.c:314
+#: ../raster/r.stream.extract/seg.c:44 ../raster/r.stream.channel/io.c:314
+#: ../raster/r.stream.segment/io.c:314 ../raster/r.stream.stats/io.c:314
+#, fuzzy, c-format
+msgid "Unable to re-open file '%s'"
+msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/io.c:17
+#: ../raster/r.stream.distance/io.c:319 ../raster/r.stream.snap/io.c:319
+#: ../raster/r.stream.channel/io.c:319 ../raster/r.stream.segment/io.c:319
+#: ../raster/r.stream.order/io.c:319 ../raster/r.stream.stats/io.c:319
#, fuzzy
-msgid "Unable to create map of unrecognised type"
+msgid "Unable to init segment file or out of memory"
msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/io.c:376 ../raster/r.stream.stats/io.c:376
+#, fuzzy, c-format
+msgid "Raster <%s> is not of type '%s'"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/io.c:444 ../raster/r.stream.snap/io.c:444
+#: ../raster/r.stream.extract/cseg.c:120 ../raster/r.stream.channel/io.c:444
+#: ../raster/r.stream.order/io.c:444
+#, fuzzy, c-format
+msgid "Unable to segment put row %d for raster map <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/io.c:508 ../raster/r.stream.snap/io.c:508
+#: ../raster/r.stream.channel/io.c:508 ../raster/r.stream.segment/io.c:508
+#: ../raster/r.stream.order/io.c:508
+#: ../raster/r.stream.order/stream_raster_close.c:95
+#: ../raster/r.stream.stats/io.c:508
+#, fuzzy, c-format
+msgid "Unable to segment read row %d for raster map <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/io.c:531 ../raster/r.stream.snap/io.c:531
+#: ../raster/r.stream.channel/io.c:531 ../raster/r.stream.segment/io.c:531
+#: ../raster/r.stream.order/io.c:531
+#, fuzzy, c-format
+msgid "Unable to convert to NULL at: %d %d"
+msgstr "출력할 래스터맵"
#: ../raster/r.stream.distance/main.c:49
-msgid "Calculates distance to and elevation above streams and outlets."
+msgid "Calculates distance to and elevation above streams and outlet."
msgstr ""
#: ../raster/r.stream.distance/main.c:51
@@ -9043,698 +11215,919 @@
"where targets are outlets."
msgstr ""
+#: ../raster/r.stream.distance/main.c:55 ../raster/r.stream.snap/main.c:51
+#: ../raster/r.stream.slope/main.c:74 ../raster/r.stream.extract/main.c:78
+#: ../raster/r.stream.channel/main.c:58 ../raster/r.stream.segment/main.c:59
+#: ../raster/r.stream.order/main.c:77 ../raster/r.stream.stats/main.c:55
+msgid "stream network"
+msgstr ""
#: ../raster/r.stream.distance/main.c:56
msgid "watercourse distance"
msgstr ""
-#: ../raster/r.stream.distance/main.c:72
+#: ../raster/r.stream.distance/main.c:60
#, fuzzy
+msgid ""
+"Name for input raster map with stream network (in outlet mode is the name "
+"for outlet raster map)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/main.c:65 ../raster/r.stream.slope/main.c:80
+#: ../raster/r.stream.channel/main.c:68 ../raster/r.stream.segment/main.c:68
+#, fuzzy
+msgid "Name for input raster map with flow direction"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/main.c:73
+#, fuzzy
msgid "Calculation method"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/main.c:81
+#: ../raster/r.stream.distance/main.c:82
#, fuzzy
-msgid "Name for output distance/accumulation raster map"
+msgid "Name for output distance raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/main.c:87
+#: ../raster/r.stream.distance/main.c:88
#, fuzzy
msgid "Name for output elevation difference raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/main.c:100
+#: ../raster/r.stream.distance/main.c:95 ../raster/r.stream.channel/main.c:108
+#: ../raster/r.stream.segment/main.c:107 ../raster/r.stream.order/main.c:107
+#: ../raster/r.stream.stats/main.c:72
+msgid "Max memory used in memory swap mode (MB)"
+msgstr ""
+#: ../raster/r.stream.distance/main.c:96
+#: ../raster/r.stream.distance/main.c:116 ../raster/r.stream.snap/main.c:92
+#: ../raster/r.stream.channel/main.c:109 ../raster/r.stream.channel/main.c:127
+#: ../raster/r.stream.order/main.c:108 ../raster/r.stream.order/main.c:118
+#: ../raster/r.stream.stats/main.c:73 ../raster/r.stream.stats/main.c:83
+#, fuzzy
+msgid "Memory settings"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/main.c:101
msgid ""
"Calculate parameters for outlets (outlet mode) instead of (default) streams"
msgstr ""
-#: ../raster/r.stream.distance/main.c:105
+#: ../raster/r.stream.distance/main.c:106
#, fuzzy
msgid "Calculate parameters for subbasins (ignored in stream mode)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/main.c:110
+#: ../raster/r.stream.distance/main.c:111
msgid "Calculate nearest local maximum (ignored in downstream calculation)"
msgstr ""
-#: ../raster/r.stream.distance/main.c:121
+#: ../raster/r.stream.distance/main.c:115
+#: ../raster/r.stream.channel/main.c:126 ../raster/r.stream.segment/main.c:117
+#: ../raster/r.stream.order/main.c:117 ../raster/r.stream.stats/main.c:82
+msgid "Use memory swap (operation is slow)"
+msgstr ""
+#: ../raster/r.stream.distance/main.c:122
#: ../raster/r.stream.channel/main.c:139
#, fuzzy
msgid "You must select at least one output raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/main.c:123
+#: ../raster/r.stream.distance/main.c:124
msgid ""
"Output elevation difference raster map requires input elevation raster map "
"to be specified"
msgstr ""
-#: ../raster/r.stream.distance/main.c:144
+#: ../raster/r.stream.distance/main.c:145
#, c-format
msgid "All in RAM calculation - method <%s>..."
msgstr ""
-#: ../raster/r.stream.distance/main.c:177
-#: ../raster/r.stream.distance/main.c:262
+#: ../raster/r.stream.distance/main.c:178
+#: ../raster/r.stream.distance/main.c:263
#, fuzzy
msgid "Calculate downstream parameters..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.distance/main.c:200
-#: ../raster/r.stream.distance/main.c:286
+#: ../raster/r.stream.distance/main.c:201
+#: ../raster/r.stream.distance/main.c:287
msgid "Unrecognised method of processing"
msgstr ""
-#: ../raster/r.stream.distance/main.c:223
+#: ../raster/r.stream.distance/main.c:224
#: ../raster/r.stream.channel/main.c:234
#, fuzzy, c-format
msgid "Calculating segments in direction <%s> (may take some time)..."
msgstr "출력할 래스터맵"
-#: ../raster/r.basins.fill/main.c:58
+#: ../raster/r.stream.distance/distance_init.c:14
+#: ../raster/r.stream.distance/distance_init.c:78
+#: ../raster/r.stream.order/stream_topology.c:38
+#: ../raster/r.stream.order/stream_topology.c:248
#, fuzzy
-msgid "Generates watershed subbasins raster map."
+msgid "Finding nodes..."
msgstr "출력할 래스터맵"
-#: ../raster/r.basins.fill/main.c:62
-#, fuzzy
-msgid "Name of input coded stream network raster map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.stream.distance/distance_init.c:24
+#: ../raster/r.stream.distance/distance_init.c:90
+msgid "Stream and direction maps probably do not match"
+msgstr ""
-#: ../raster/r.basins.fill/main.c:66
+#: ../raster/r.stream.distance/distance_calc.c:7
+#: ../raster/r.stream.stats/stats_prepare.c:7
+msgid "Circular buffer too small"
+msgstr ""
+#: ../raster/r.stream.distance/distance_calc.c:414
+#: ../raster/r.stream.distance/distance_calc.c:567
#, fuzzy
-msgid "Name of input thinned ridge network raster map"
+msgid "Calculate upstream parameters..."
msgstr "출력할 래스터맵"
-#: ../raster/r.basins.fill/main.c:74
-msgid "Number of passes through the dataset"
+#: ../raster/r.sunmask/solpos00.c:949 ../raster/r.sunhours/solpos00.c:994
+#, c-format
+msgid "S_decode ==> Please fix the year: %d [1950-2050]"
msgstr ""
-#: ../raster/r.basins.fill/main.c:122
-msgid "Forward sweep complete"
+#: ../raster/r.sunmask/solpos00.c:952 ../raster/r.sunhours/solpos00.c:997
+#, c-format
+msgid "S_decode ==> Please fix the month: %d"
msgstr ""
-#: ../raster/r.basins.fill/main.c:139
-msgid "Reverse sweep complete"
+#: ../raster/r.sunmask/solpos00.c:954 ../raster/r.sunhours/solpos00.c:999
+#, c-format
+msgid "S_decode ==> Please fix the day-of-month: %d"
msgstr ""
-#: ../raster/r.basins.fill/main.c:146 ../raster/r.in.png/main.c:485
-#: ../raster/r.cross/main.c:169 ../raster/r.resample/main.c:125
-#, fuzzy, c-format
-msgid "Creating support files for <%s>..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.sunmask/solpos00.c:957 ../raster/r.sunhours/solpos00.c:1002
+#, c-format
+msgid "S_decode ==> Please fix the day-of-year: %d"
+msgstr ""
-#: ../raster/r.basins.fill/read_map.c:39
-#, fuzzy, c-format
-msgid "Reading <%s> ... "
+#: ../raster/r.sunmask/solpos00.c:960 ../raster/r.sunhours/solpos00.c:1005
+#, c-format
+msgid "S_decode ==> Please fix the hour: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:962 ../raster/r.sunhours/solpos00.c:1007
+#, c-format
+msgid "S_decode ==> Please fix the minute: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:964 ../raster/r.sunhours/solpos00.c:1009
+#, c-format
+msgid "S_decode ==> Please fix the second: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:966 ../raster/r.sunhours/solpos00.c:1011
+#, c-format
+msgid "S_decode ==> Please fix the time zone: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:969 ../raster/r.sunhours/solpos00.c:1014
+#, c-format
+msgid "S_decode ==> Please fix the interval: %d"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:972 ../raster/r.sunhours/solpos00.c:1017
+#, c-format
+msgid "S_decode ==> Please fix the latitude: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:975 ../raster/r.sunhours/solpos00.c:1020
+#, c-format
+msgid "S_decode ==> Please fix the longitude: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:978 ../raster/r.sunhours/solpos00.c:1023
+#, c-format
+msgid "S_decode ==> Please fix the temperature: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:981 ../raster/r.sunhours/solpos00.c:1026
+#, c-format
+msgid "S_decode ==> Please fix the pressure: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:983 ../raster/r.sunhours/solpos00.c:1028
+#, c-format
+msgid "S_decode ==> Please fix the tilt: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:985 ../raster/r.sunhours/solpos00.c:1030
+#, c-format
+msgid "S_decode ==> Please fix the aspect: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:987 ../raster/r.sunhours/solpos00.c:1032
+#, c-format
+msgid "S_decode ==> Please fix the shadowband width: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:990 ../raster/r.sunhours/solpos00.c:1035
+#, c-format
+msgid "S_decode ==> Please fix the shadowband radius: %f"
+msgstr ""
+#: ../raster/r.sunmask/solpos00.c:993 ../raster/r.sunhours/solpos00.c:1038
+#, c-format
+msgid "S_decode ==> Please fix the shadowband sky factor: %f"
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:66
+msgid ""
+"Unable to calculate sun position in un-projected locations. Specify "
+"sunposition directly."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:88
+#, c-format
+msgid ""
+"Specified point %f, %f outside of current region, is that intended? Anyway, "
+"it will be used."
+msgstr ""
+#: ../raster/r.sunmask/g_solposition.c:98 ../raster/r.latlong/main.c:101
+#, fuzzy
+msgid "Unable to get projection info of current location"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:84
+#: ../raster/r.sunmask/g_solposition.c:101 ../raster/r.latlong/main.c:103
#, fuzzy
-msgid "Imports raster data into a GRASS raster map using GDAL library."
+msgid "Unable to get projection units of current location"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:90
+#: ../raster/r.sunmask/g_solposition.c:104 ../raster/r.latlong/main.c:105
#, fuzzy
-msgid "Name of raster file to be imported"
+msgid "Unable to get projection key values of current location"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:98
-msgid "Band to select (default is all bands)"
+#: ../raster/r.sunmask/main.c:117 ../raster/r.sunhours/main.c:72
+#: ../raster/r.sun/main.c:238 ../raster/r.horizon/main.c:179
+msgid "solar"
msgstr ""
-#: ../raster/r.in.gdal/main.c:104 ../raster/r.proj/main.c:198
-msgid "Cache size (MiB)"
+#: ../raster/r.sunmask/main.c:118 ../raster/r.horizon/main.c:180
+msgid "sun position"
msgstr ""
-#: ../raster/r.in.gdal/main.c:110
-#, fuzzy
-msgid "Name of GCPs target location"
-msgstr "출력할 래스터맵"
+#: ../raster/r.sunmask/main.c:119
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map."
+msgstr ""
-#: ../raster/r.in.gdal/main.c:112
+#: ../raster/r.sunmask/main.c:120
msgid ""
-"Name of location to create or to read projection from for GCPs transformation"
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
msgstr ""
-#: ../raster/r.in.gdal/main.c:121 ../raster/r.in.gdal/main.c:129
-#: ../raster/r.external/main.c:89 ../imagery/i.landsat.toar/main.c:99
-#: ../imagery/i.landsat.toar/main.c:121 ../imagery/i.landsat.toar/main.c:131
-#: ../imagery/i.landsat.toar/main.c:140 ../imagery/i.landsat.toar/main.c:148
-#: ../imagery/i.landsat.toar/main.c:157
-msgid "Metadata"
+#: ../raster/r.sunmask/main.c:134
+msgid "Altitude of the sun above horizon, degrees (A)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:128
-msgid ""
-"The offset will be added to the band number while output raster map name "
-"creation"
+#: ../raster/r.sunmask/main.c:135 ../raster/r.sunmask/main.c:144
+#: ../raster/r.sunmask/main.c:212 ../raster/r.sunmask/main.c:222
+msgid "Position"
msgstr ""
-#: ../raster/r.in.gdal/main.c:135 ../vector/v.in.lidar/main.c:180
-#: ../vector/v.in.ogr/main.c:208
-msgid "Name for new location to create"
+#: ../raster/r.sunmask/main.c:143
+msgid "Azimuth of the sun from the north, degrees (A)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:141 ../raster/r.external/main.c:100
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
-msgid "Override projection (use location's projection)"
+#: ../raster/r.sunmask/main.c:150
+msgid "Year (B)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:145 ../raster/r.in.lidar/main.c:248
-#: ../raster/r.external/main.c:104 ../vector/v.in.lidar/main.c:213
-#: ../vector/v.in.ogr/main.c:271
-msgid "Extend region extents based on new dataset"
+#: ../raster/r.sunmask/main.c:158
+msgid "Month (B)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:147 ../raster/r.external/main.c:105
-#: ../vector/v.in.ogr/main.c:273
-msgid "Also updates the default region if in the PERMANENT mapset"
+#: ../raster/r.sunmask/main.c:166
+msgid "Day (B)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:158
-msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
+#: ../raster/r.sunmask/main.c:174
+msgid "Hour (B)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:163
-msgid "Keep band numbers instead of using band color names"
+#: ../raster/r.sunmask/main.c:182
+msgid "Minutes (B)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:168
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the raster file."
+#: ../raster/r.sunmask/main.c:190
+msgid "Seconds (B)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:193
-msgid "You have to specify a target location different from output location"
+#: ../raster/r.sunmask/main.c:200
+msgid "Timezone"
msgstr ""
-#: ../raster/r.in.gdal/main.c:197
-msgid "You need to specify valid location name."
+#: ../raster/r.sunmask/main.c:201
+msgid "East positive, offset from GMT, also use to adjust daylight savings"
msgstr ""
-#: ../raster/r.in.gdal/main.c:201
-msgid "The '-l' flag only works in Lat/Lon locations"
+#: ../raster/r.sunmask/main.c:210
+msgid "Easting coordinate (point of interest)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:219
-msgid "Available GDAL Drivers:"
+#: ../raster/r.sunmask/main.c:211 ../raster/r.sunmask/main.c:221
+msgid "Default: map center"
msgstr ""
-#: ../raster/r.in.gdal/main.c:241 ../imagery/i.landsat.toar/main.c:546
-#: ../vector/v.kernel/main.c:232
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists and will be overwritten"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:244 ../vector/v.kernel/main.c:235
-#, fuzzy, c-format
-msgid "Raster map <%s> already exists"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:262
-#, c-format
-msgid ""
-"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
-"plate spline transformation (%s or %s)."
+#: ../raster/r.sunmask/main.c:220
+msgid "Northing coordinate (point of interest)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:283
-msgid ""
-"Input raster map is flipped or rotated - cannot import. You may use "
-"'gdalwarp' to transform the map to North-up."
+#: ../raster/r.sunmask/main.c:226
+msgid "Don't ignore zero elevation"
msgstr ""
-#: ../raster/r.in.gdal/main.c:324
-msgid ""
-"Map bounds have been constrained to geographic coordinates. You will almost "
-"certainly want to check map bounds and resolution with r.info and reset them "
-"with r.region before going any further."
+#: ../raster/r.sunmask/main.c:230
+msgid "Calculate sun position only and exit"
msgstr ""
-#: ../raster/r.in.gdal/main.c:344 ../raster/r.in.gdal/main.c:668
-#: ../vector/v.in.lidar/main.c:343 ../vector/v.in.ogr/main.c:618
-msgid ""
-"Unable to convert input map projection to GRASS format; cannot create new "
-"location."
+#: ../raster/r.sunmask/main.c:236
+msgid "Print the sun position output in shell script style"
msgstr ""
-#: ../raster/r.in.gdal/main.c:350 ../raster/r.in.gdal/main.c:692
-#: ../vector/v.in.lidar/main.c:349 ../vector/v.in.ogr/main.c:624
+#: ../raster/r.sunmask/main.c:250
#, fuzzy, c-format
-msgid "Unable to create new location <%s>"
+msgid "Using map center coordinates: %f %f"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:353 ../raster/r.in.gdal/main.c:698
-#: ../general/g.proj/create.c:15 ../vector/v.in.lidar/main.c:352
-#: ../vector/v.in.ogr/main.c:627
-#, c-format
-msgid "Location <%s> created"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:365 ../raster/r.external/proj.c:18
-msgid ""
-"Unable to convert input raster map projection information to GRASS format "
-"for checking"
-msgstr ""
-#: ../raster/r.in.gdal/main.c:381 ../raster/r.in.lidar/main.c:334
-#: ../raster/r.external/proj.c:34 ../vector/v.in.lidar/main.c:386
-#: ../vector/v.in.ogr/main.c:658
+#: ../raster/r.sunmask/main.c:257
#, fuzzy
-msgid "Over-riding projection check"
+msgid "Empty east coordinate specified"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:391 ../raster/r.in.lidar/main.c:343
-#: ../raster/r.external/proj.c:42 ../vector/v.in.lidar/main.c:395
-#: ../vector/v.in.ogr/main.c:667
-msgid ""
-"Projection of dataset does not appear to match current location.\n"
-"\n"
+#: ../raster/r.sunmask/main.c:259
+msgid "Empty north coordinate specified"
msgstr ""
-#: ../raster/r.in.gdal/main.c:396 ../raster/r.external/proj.c:47
-msgid "Location PROJ_INFO is:\n"
+#: ../raster/r.sunmask/main.c:278
+msgid "Either define sun position or location/date/time parameters"
msgstr ""
-#: ../raster/r.in.gdal/main.c:407 ../raster/r.external/proj.c:58
-msgid "Dataset PROJ_INFO is:\n"
+#: ../raster/r.sunmask/main.c:281
+msgid ""
+"Neither sun position nor east/north, date/time/timezone definition are "
+"complete"
msgstr ""
-#: ../raster/r.in.gdal/main.c:443 ../raster/r.in.lidar/main.c:359
-#: ../raster/r.in.lidar/main.c:366 ../raster/r.external/proj.c:85
-#: ../vector/v.in.lidar/main.c:411 ../vector/v.in.lidar/main.c:418
-#: ../vector/v.in.ogr/main.c:683 ../vector/v.in.ogr/main.c:690
-msgid "Import dataset PROJ_INFO is:\n"
+#: ../raster/r.sunmask/main.c:285
+#, c-format
+msgid "Calculating sun position... (using solpos (V. %s) from NREL)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:465
+#: ../raster/r.sunmask/main.c:290
msgid ""
-"\n"
-"You can use the -o flag to r.in.gdal to override this check and use the "
-"location definition for the dataset.\n"
+"Using user defined sun azimuth, altitude settings (ignoring eventual other "
+"values)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:468 ../raster/r.external/proj.c:110
-msgid ""
-"Consider generating a new location from the input dataset using the "
-"'location' parameter.\n"
+#: ../raster/r.sunmask/main.c:398
+#, fuzzy
+msgid "Please correct settings"
+msgstr "출력할 래스터맵"
+#: ../raster/r.sunmask/main.c:412
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise (%02d:%02d:%02d)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:473 ../raster/r.in.lidar/main.c:417
-#: ../raster/r.external/proj.c:115 ../vector/v.in.lidar/main.c:469
-#: ../vector/v.in.ogr/main.c:741
-msgid "Projection of input dataset and current location appear to match"
+#: ../raster/r.sunmask/main.c:416
+#, c-format
+msgid "Time (%02i:%02i:%02i) is before sunrise"
msgstr ""
-#: ../raster/r.in.gdal/main.c:479 ../raster/r.external/main.c:176
-msgid "Proceeding with import..."
+#: ../raster/r.sunmask/main.c:419 ../raster/r.sunmask/main.c:429
+msgid "Nothing to calculate. Please verify settings."
msgstr ""
-#: ../raster/r.in.gdal/main.c:504 ../raster/r.external/main.c:192
+#: ../raster/r.sunmask/main.c:423
#, c-format
-msgid "Selected band (%d) does not exist"
+msgid "Time (%02i:%02i:%02i) is after sunset (%02d:%02d:%02d)"
msgstr ""
-#: ../raster/r.in.gdal/main.c:530
+#: ../raster/r.sunmask/main.c:427
+#, c-format
+msgid "Time (%02i:%02i:%02i) is after sunset"
+msgstr ""
+#: ../raster/r.sunmask/main.c:438
+msgid "You already know the sun position"
+msgstr ""
+#: ../raster/r.sunmask/main.c:443 ../vector/v.colors/main.c:200
#, fuzzy, c-format
-msgid "Unable to get raster band number %d"
+msgid "Option <%s> required"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:591
+#: ../raster/r.sunmask/main.c:455
#, fuzzy, c-format
-msgid "Copying %d GCPS in points file for <%s>"
+msgid "Unable to open range file for raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:599
-msgid "GCPs have the following OpenGIS WKT Coordinate System:"
+#: ../raster/r.sunmask/main.c:471
+msgid "Calculating shadows from DEM..."
msgstr ""
-#: ../raster/r.in.gdal/main.c:622
-#, fuzzy
-msgid "Re-projecting GCPs table:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.idw2/main.c:64 ../raster/r.surf.idw/main.c:106
+#: ../vector/v.surf.idw/main.c:90
+msgid "IDW"
+msgstr ""
-#: ../raster/r.in.gdal/main.c:623
-#, c-format
-msgid "* Input projection for GCP table: %s"
+#: ../raster/r.surf.idw2/main.c:65
+msgid "Surface generation program."
msgstr ""
-#: ../raster/r.in.gdal/main.c:625
-#, c-format
-msgid "* Output projection for GCP table: %s"
+#: ../raster/r.surf.idw2/main.c:76 ../raster/r.surf.idw/main.c:118
+#: ../vector/v.surf.idw/main.c:113
+msgid "Number of interpolation points"
msgstr ""
-#: ../raster/r.in.gdal/main.c:646
+#: ../raster/r.surf.idw2/main.c:84
+msgid ""
+"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+msgstr ""
+#: ../raster/r.surf.idw2/main.c:88
#, c-format
-msgid "Error in pj_do_proj (can't re-projection GCP %i)"
+msgid "%s=%s - illegal number of interpolation points"
msgstr ""
-#: ../raster/r.in.gdal/main.c:701
+#: ../raster/r.surf.idw2/main.c:97
#, c-format
-msgid ""
-"The target for the output group <%s> has been set to location <%s>, mapset "
-"<PERMANENT>."
+msgid "%s: no data points found"
msgstr ""
-#: ../raster/r.in.gdal/main.c:741 ../raster/r.external/window.c:93
-#: ../vector/v.in.ogr/main.c:1455
-msgid "Default region for this location updated"
+#: ../raster/r.surf.idw2/main.c:112
+#, fuzzy, c-format
+msgid "Interpolating raster map <%s>... %d row... "
+msgid_plural "Interpolating raster map <%s>... %d rows... "
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
+#: ../raster/r.topmodel/main.c:51
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
msgstr ""
-#: ../raster/r.in.gdal/main.c:744 ../raster/r.external/window.c:96
-#: ../vector/v.in.ogr/main.c:1458
+#: ../raster/r.topmodel/main.c:56
#, fuzzy
-msgid "Region for the current mapset updated"
+msgid "Name of TOPMODEL parameters file"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:774
+#: ../raster/r.topmodel/main.c:61
#, fuzzy
-msgid "Unable to translate projection key values of input GCPs"
+msgid "Name of topographic index statistics file"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:790
+#: ../raster/r.topmodel/main.c:65
+msgid "Name of rainfall and potential evapotranspiration data file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:68 ../raster/r.out.mpeg/main.c:122
+#: ../locale/scriptstrings/d.out.file_to_translate.c:4
+msgid "Name for output file"
+msgstr ""
+#: ../raster/r.topmodel/main.c:72
+msgid "Time step"
+msgstr ""
+#: ../raster/r.topmodel/main.c:73
#, fuzzy
-msgid "Unable to get projection info of target location"
+msgid "Generate output for this time step."
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:792
+#: ../raster/r.topmodel/main.c:79
#, fuzzy
-msgid "Unable to get projection units of target location"
+msgid "Topographic index class"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:794
+#: ../raster/r.topmodel/main.c:81
#, fuzzy
-msgid "Unable to get projection key values of target location"
+msgid "Generate output for this topographic index class."
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:798
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:31
-#: ../imagery/i.rectify/target.c:32 ../vector/v.rectify/target.c:40
-#, fuzzy, c-format
-msgid "Mapset <%s> in target location <%s> - "
+#: ../raster/r.topmodel/main.c:88
+#, fuzzy
+msgid "Name of input topographic index ln(a/tanB) raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:800 ../raster/r.proj/main.c:286
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:32
-#: ../imagery/i.rectify/target.c:33 ../vector/v.rectify/target.c:41
-msgid "permission denied"
+#: ../raster/r.topmodel/main.c:90
+msgid ""
+"Must be clipped to the catchment boundary. Used for generating "
+"outtopidxstats."
msgstr ""
-#: ../raster/r.in.gdal/main.c:801 ../raster/r.proj/main.c:287
+#: ../raster/r.topmodel/main.c:92 ../raster/r.topmodel/main.c:102
+#: ../raster/r.topmodel/main.c:111
+msgid "Preprocess"
+msgstr ""
+#: ../raster/r.topmodel/main.c:96
#, fuzzy
-msgid "not found"
+msgid "Number of topographic index classes"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:1241
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (8bit, full range)"
+#: ../raster/r.topmodel/main.c:98
+msgid "Used for generating outtopidxstats."
+msgstr ""
+#: ../raster/r.topmodel/main.c:107
+#, fuzzy
+msgid "Name for output topographic index statistics file"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.gdal/main.c:1255
+#: ../raster/r.topmodel/main.c:109
+msgid "Requires topidx and ntopidxclasses."
+msgstr ""
+#: ../raster/r.topmodel/main.c:116
+msgid "Preprocess only and stop after generating outtopidxstats"
+msgstr ""
+#: ../raster/r.topmodel/main.c:146
+msgid "ntopidxclasses must be positive."
+msgstr ""
+#: ../raster/r.topmodel/main.c:150
+msgid "Ignoring topidx because outtopidxstats is not specified."
+msgstr ""
+#: ../raster/r.topmodel/main.c:152
+msgid "Ignoring outtopidxstats because topidx is not specified."
+msgstr ""
+#: ../raster/r.topmodel/infiltration.c:69
+#: ../raster/r.topmodel/infiltration.c:108
#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (16bit, image range)"
+msgid "Maximum number of iterations exceeded at timestep %d."
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/lines_io.c:76
-msgid "write_line: found half a loop!"
+#: ../raster/r.carve/raster.c:33 ../raster/r.in.poly/poly2rast.c:77
+#: ../vector/v.to.rast/vect2rast.c:183
+#, fuzzy
+msgid "Writing raster map..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.carve/main.c:76
+msgid "Generates stream channels."
msgstr ""
-#: ../raster/r.to.vect/lines_io.c:132
-#, c-format
+#: ../raster/r.carve/main.c:77
msgid ""
-"write_line: line terminated unexpectedly\n"
-" previous (%d) point %p (%d,%d,%d) %p %p"
+"Takes vector stream data, transforms it to raster and subtracts depth from "
+"the output DEM."
msgstr ""
-#: ../raster/r.to.vect/lines.c:70
-msgid "Extracting lines..."
+#: ../raster/r.carve/main.c:82
+msgid "Name of input raster elevation map"
msgstr ""
-#: ../raster/r.to.vect/lines.c:499
-msgid ""
-"Raster map is not thinned properly.\n"
-"Please run r.thin."
+#: ../raster/r.carve/main.c:87
+#, fuzzy
+msgid "Name of input vector map containing stream(s)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.carve/main.c:95
+#, fuzzy
+msgid "Name for output vector map for adjusted stream points"
+msgstr "출력할 래스터맵"
+#: ../raster/r.carve/main.c:100
+msgid "Stream width (in meters)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:573
-msgid "join_lines: p front pointer not NULL!"
+#: ../raster/r.carve/main.c:101
+msgid "Default is raster cell width"
msgstr ""
-#: ../raster/r.to.vect/lines.c:579
-msgid "join_lines: q front pointer not NULL!"
+#: ../raster/r.carve/main.c:106
+msgid "Additional stream depth (in meters)"
msgstr ""
-#: ../raster/r.to.vect/lines.c:597
-msgid "extend line: p is NULL"
+#: ../raster/r.carve/main.c:110
+msgid "No flat areas allowed in flow direction"
msgstr ""
-#: ../raster/r.to.vect/lines.c:623
-msgid "extend_lines: p front pointer not NULL!"
+#: ../raster/r.carve/main.c:134
+#, c-format
+msgid "Invalid width value '%s' - using default."
msgstr ""
-#: ../raster/r.to.vect/lines.c:630
-msgid "extend_lines: q back pointer not NULL!"
+#: ../raster/r.carve/main.c:148
+#, c-format
+msgid "Invalid depth value '%s' - using default."
msgstr ""
-#: ../raster/r.to.vect/main.c:72 ../raster/r.circle/main.c:52
-#: ../raster/r.thin/main.c:57 ../raster/r.patch/main.c:53
-#: ../locale/scriptstrings/v.report_to_translate.c:3
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:3
-#: ../display/d.measure/main.c:47 ../imagery/i.vpoints/main.c:95
-#: ../imagery/i.points/main.c:97 ../vector/v.extrude/main.c:68
-#: ../vector/v.type/main.c:40 ../vector/v.build/main.c:38
-#: ../vector/v.delaunay/main.c:86 ../vector/v.patch/main.c:69
-#: ../vector/v.build.polylines/main.c:114 ../vector/v.to.points/main.c:54
-#: ../vector/v.clean/main.c:53 ../vector/v.voronoi/main.c:124
-#: ../vector/v.drape/main.c:57 ../vector/v.buffer/main.c:224
-#: ../vector/v.mkgrid/main.c:67 ../vector/v.segment/main.c:60
-#: ../vector/v.hull/main.c:53 ../vector/v.in.region/main.c:42
-#: ../vector/v.split/main.c:56 ../vector/v.to.3d/main.c:37
-#: ../vector/v.overlay/main.c:63 ../vector/v.edit/main.c:56
-#: ../vector/v.select/main.c:48 ../vector/v.parallel/main.c:50
-#: ../vector/v.perturb/main.c:62
-msgid "geometry"
+#: ../raster/r.carve/main.c:213
+msgid "lat/lon projection not supported at this time."
msgstr ""
-#: ../raster/r.to.vect/main.c:73
-#, fuzzy
-msgid "vectorization"
-msgstr "출력할 래스터맵"
+#: ../raster/r.carve/lobf.c:74
+msgid "trying to divide by zero...no unique solution for system...skipping..."
+msgstr ""
-#: ../raster/r.to.vect/main.c:74
-#, fuzzy
-msgid "Converts a raster map into a vector map."
-msgstr "출력할 래스터맵"
+#: ../raster/r.carve/enforce_ds.c:82
+msgid "Processing lines... "
+msgstr ""
-#: ../raster/r.to.vect/main.c:87
+#: ../raster/r.carve/enforce_ds.c:174
+msgid ""
+"Vect runs out of region and re-enters - this case is not yet implemented."
+msgstr ""
+#: ../raster/r.timestamp/main.c:37 ../vector/v.timestamp/main.c:37
+msgid "timestamp"
+msgstr ""
+#: ../raster/r.timestamp/main.c:38
#, fuzzy
-msgid "Name of attribute column to store value"
+msgid "Modifies a timestamp for a raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/main.c:88
-msgid "Name must be SQL compliant"
+#: ../raster/r.timestamp/main.c:39
+msgid "Print/add/remove a timestamp for a raster map."
msgstr ""
-#: ../raster/r.to.vect/main.c:93
-msgid "Smooth corners of area features"
+#: ../raster/r.timestamp/main.c:48 ../vector/v.timestamp/main.c:49
+msgid "Datetime, datetime1/datetime2, or 'none' to remove"
msgstr ""
-#: ../raster/r.to.vect/main.c:98
-msgid "Use raster values as categories instead of unique sequence (CELL only)"
+#: ../raster/r.timestamp/main.c:49 ../vector/v.timestamp/main.c:50
+msgid "Format: '15 jan 1994' (absolute) or '2 years' (relative)"
msgstr ""
-#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
-#: ../vector/v.buffer/main.c:304 ../vector/v.in.lidar/main.c:198
-#: ../vector/v.extract/main.c:90 ../vector/v.extract/main.c:142
-#: ../vector/v.overlay/main.c:129 ../vector/v.overlay/main.c:139
-#: ../vector/v.to.rast/main.c:88 ../vector/v.to.rast/main.c:94
-#: ../vector/v.to.rast/main.c:100 ../vector/v.in.ogr/main.c:219
-#: ../vector/v.in.ogr/main.c:229 ../vector/v.in.ogr/main.c:256
-#: ../vector/v.in.ogr/main.c:279 ../vector/v.generalize/main.c:236
-#, fuzzy
-msgid "Attributes"
+#: ../raster/r.timestamp/main.c:64
+#, fuzzy, c-format
+msgid "Raster map <%s> not found %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/main.c:103
+#: ../raster/r.out.pov/main.c:124
#, fuzzy
-msgid "Write raster values as z coordinate"
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/main.c:104
-msgid "Table is not created. Currently supported only for points."
+#: ../raster/r.out.pov/main.c:131
+msgid "Name of output povray file (TGA height field file)"
msgstr ""
-#: ../raster/r.to.vect/main.c:110
-#, fuzzy
-msgid "Do not build vector topology"
-msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/main.c:111
-msgid "Recommended for massive point conversion"
+#: ../raster/r.out.pov/main.c:138
+msgid "Height-field type (0=actual heights 1=normalized)"
msgstr ""
-#: ../raster/r.to.vect/main.c:124
-msgid "z flag is supported only for points"
+#: ../raster/r.out.pov/main.c:144
+msgid "Elevation bias"
msgstr ""
-#: ../raster/r.to.vect/main.c:135
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
-"table."
+#: ../raster/r.out.pov/main.c:170
+#, c-format
+msgid "Invalid output filename <%s>"
msgstr ""
-#: ../raster/r.to.vect/main.c:137
-msgid ""
-"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
+#: ../raster/r.out.pov/main.c:180
+#, c-format
+msgid "Raster map is too big! Exceeds %d columns or %d rows"
msgstr ""
-#: ../raster/r.to.vect/main.c:139
-msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
+#: ../raster/r.out.pov/main.c:201
+msgid "Negative elevation values in input"
msgstr ""
-#: ../raster/r.to.vect/main.c:144
-msgid "Categories will be unique sequence, raster values will be lost."
+#: ../raster/r.info/main.c:72 ../vector/v.info/main.c:41
+msgid "history"
msgstr ""
-#: ../raster/r.to.vect/main.c:226 ../vector/v.patch/main.c:296
-#: ../vector/v.mkgrid/main.c:252 ../vector/v.overlay/main.c:568
+#: ../raster/r.info/main.c:74
#, fuzzy
-msgid "Unable to create index"
+msgid "Outputs basic information about a raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/main.c:278
+#: ../raster/r.info/main.c:80
#, fuzzy
-msgid "Updating attributes..."
+msgid "Print raster array information only"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/main.c:302
-#, fuzzy, c-format
-msgid "Unable to insert into table: %s"
+#: ../raster/r.info/main.c:84
+msgid "Print range only"
+msgstr ""
+#: ../raster/r.info/main.c:88
+msgid "Print extended metadata information only"
+msgstr ""
+#: ../raster/r.info/main.c:123
+#, fuzzy
+msgid "Unable to read range file"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/areas_io.c:110
-#, c-format
-msgid ""
-"Line terminated unexpectedly\n"
-"previous (%d) point %p (%d,%d,%d) %p %p"
+#: ../raster/r.quantile/main.c:63
+msgid "Computing histogram"
msgstr ""
-#: ../raster/r.to.vect/areas_io.c:305
+#: ../raster/r.quantile/main.c:97 ../raster/r.stats.quantile/main.c:111
#, fuzzy
-msgid "Writing areas..."
+msgid "Computing bins"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/areas.c:120
+#: ../raster/r.quantile/main.c:134 ../raster/r.stats.quantile/main.c:166
#, fuzzy
-msgid "Extracting areas..."
+msgid "Binning data"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.vect/points.c:36
-msgid "Extracting points..."
-msgstr ""
+#: ../raster/r.quantile/main.c:179 ../raster/r.stats.quantile/main.c:218
+#, fuzzy
+msgid "Sorting bins"
+msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/infiltration.c:69
-#: ../raster/r.topmodel/infiltration.c:108
-#, fuzzy, c-format
-msgid "Maximum number of iterations exceeded at timestep %d."
+#: ../raster/r.quantile/main.c:189 ../raster/r.stats.quantile/main.c:257
+#, fuzzy
+msgid "Computing quantiles"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:51
-msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+#: ../raster/r.quantile/main.c:258
+msgid "Compute quantiles using two passes."
msgstr ""
-#: ../raster/r.topmodel/main.c:56
+#: ../raster/r.quantile/main.c:266 ../raster/r.stats.quantile/main.c:401
#, fuzzy
-msgid "Name of TOPMODEL parameters file"
+msgid "Number of quantiles"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:61
+#: ../raster/r.quantile/main.c:274 ../raster/r.stats.quantile/main.c:407
+msgid "List of percentiles"
+msgstr ""
+#: ../raster/r.quantile/main.c:280 ../raster/r.stats.quantile/main.c:414
#, fuzzy
-msgid "Name of topographic index statistics file"
+msgid "Number of bins to use"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:65
-msgid "Name of rainfall and potential evapotranspiration data file"
+#: ../raster/r.quantile/main.c:285
+msgid "Generate recode rules based on quantile-defined intervals."
msgstr ""
-#: ../raster/r.topmodel/main.c:68 ../raster/r.out.mpeg/main.c:122
-#: ../locale/scriptstrings/d.out.file_to_translate.c:4
-msgid "Name for output file"
-msgstr ""
+#: ../raster/r.quantile/main.c:313
+#, fuzzy
+msgid "Too many quantiles"
+msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:72
-msgid "Time step"
+#: ../raster/r.drain/main.c:111 ../raster/r.cost/main.c:141
+#: ../raster/r.walk/main.c:180
+msgid "cost surface"
msgstr ""
-#: ../raster/r.topmodel/main.c:73
+#: ../raster/r.drain/main.c:113
#, fuzzy
-msgid "Generate output for this time step."
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:79
+#: ../raster/r.drain/main.c:116
#, fuzzy
-msgid "Topographic index class"
+msgid "Name of input elevation or cost surface raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:81
+#: ../raster/r.drain/main.c:121
+msgid "Name of input movement direction map associated with the cost surface"
+msgstr ""
+#: ../raster/r.drain/main.c:123 ../raster/r.drain/main.c:164
+msgid "Cost surface"
+msgstr ""
+#: ../raster/r.drain/main.c:131
#, fuzzy
-msgid "Generate output for this topographic index class."
+msgid "Name for output drain vector map"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:88
+#: ../raster/r.drain/main.c:132
+msgid "Recommended for cost surface made using knight's move"
+msgstr ""
+#: ../raster/r.drain/main.c:136 ../raster/r.cost/main.c:192
+#: ../raster/r.walk/main.c:230
#, fuzzy
-msgid "Name of input topographic index ln(a/tanB) raster map"
+msgid "Coordinates of starting point(s) (E,N)"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:90
-msgid ""
-"Must be clipped to the catchment boundary. Used for generating "
-"outtopidxstats."
+#: ../raster/r.drain/main.c:137 ../raster/r.drain/main.c:144
+#: ../raster/r.cost/main.c:174 ../raster/r.cost/main.c:186
+#: ../raster/r.cost/main.c:193 ../raster/r.cost/main.c:244
+#: ../raster/r.walk/main.c:212 ../raster/r.walk/main.c:224
+#: ../raster/r.walk/main.c:231 ../raster/r.walk/main.c:310
+msgid "Start"
msgstr ""
-#: ../raster/r.topmodel/main.c:92 ../raster/r.topmodel/main.c:102
-#: ../raster/r.topmodel/main.c:111
-msgid "Preprocess"
-msgstr ""
-#: ../raster/r.topmodel/main.c:96
+#: ../raster/r.drain/main.c:142
#, fuzzy
-msgid "Number of topographic index classes"
+msgid "Name of starting vector points map(s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:98
-msgid "Used for generating outtopidxstats."
+#: ../raster/r.drain/main.c:148
+msgid "Copy input cell values on output"
msgstr ""
-#: ../raster/r.topmodel/main.c:107
+#: ../raster/r.drain/main.c:152
+msgid "Accumulate input values along the path"
+msgstr ""
+#: ../raster/r.drain/main.c:153 ../raster/r.drain/main.c:158
#, fuzzy
-msgid "Name for output topographic index statistics file"
+msgid "Path settings"
msgstr "출력할 래스터맵"
-#: ../raster/r.topmodel/main.c:109
-msgid "Requires topidx and ntopidxclasses."
+#: ../raster/r.drain/main.c:157
+msgid "Count cell numbers along the path"
msgstr ""
-#: ../raster/r.topmodel/main.c:116
-msgid "Preprocess only and stop after generating outtopidxstats"
+#: ../raster/r.drain/main.c:163
+msgid ""
+"The input raster map is a cost surface (direction surface must also be "
+"specified)"
msgstr ""
-#: ../raster/r.topmodel/main.c:146
-msgid "ntopidxclasses must be positive."
+#: ../raster/r.drain/main.c:175
+msgid "Directional drain selected... checking for direction raster map"
msgstr ""
-#: ../raster/r.topmodel/main.c:150
-msgid "Ignoring topidx because outtopidxstats is not specified."
+#: ../raster/r.drain/main.c:178
+msgid "Surface/Hydrology drain selected"
msgstr ""
-#: ../raster/r.topmodel/main.c:152
-msgid "Ignoring outtopidxstats because topidx is not specified."
+#: ../raster/r.drain/main.c:183
+#, c-format
+msgid ""
+"Direction raster map <%s> not specified, if direction flag is on, a "
+"direction raster must be given"
msgstr ""
+#: ../raster/r.drain/main.c:190
+#, c-format
+msgid ""
+"Direction raster map <%s> should not be specified for Surface/Hydrology "
+"drains"
+msgstr ""
+#: ../raster/r.drain/main.c:209
+msgid "Specify just one of the -c, -a and -n flags"
+msgstr ""
+#: ../raster/r.drain/main.c:240
+#, c-format
+msgid "Starting point %d is outside the current region"
+msgstr ""
+#: ../raster/r.drain/main.c:270 ../raster/r.cost/main.c:532
+#: ../raster/r.walk/main.c:682
+#, fuzzy, c-format
+msgid "Reading vector map <%s> with start points..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.drain/main.c:283 ../raster/r.cost/main.c:545
+#: ../raster/r.cost/main.c:615 ../raster/r.walk/main.c:702
+#: ../raster/r.walk/main.c:768 ../vector/v.colors.out/scan_cats.c:32
+#: ../vector/v.label/main.c:293 ../vector/v.label.sa/labels.c:140
+#: ../vector/v.colors/scan_cats.c:24 ../vector/v.colors/scan_z.c:36
+#: ../vector/v.perturb/main.c:179 ../vector/v.to.3d/trans3.c:85
+#: ../vector/v.to.3d/trans2.c:84 ../vector/v.info/level1.c:37
+#: ../display/d.vect/label.c:44 ../display/d.vect/vert.c:27
+#: ../display/d.vect/dir.c:30 ../display/d.vect/attr.c:51
+#: ../display/d.vect/lines.c:143 ../display/d.vect/topo.c:52
+#, fuzzy
+msgid "Unable to read vector map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.drain/main.c:315
+#, fuzzy, c-format
+msgid "Starting vector map <%s> contains no points in the current region"
+msgstr "출력할 래스터맵"
+#: ../raster/r.drain/main.c:323
+msgid "No start/stop point(s) specified"
+msgstr ""
+#: ../raster/r.drain/main.c:398
+#, fuzzy
+msgid "Calculating flow directions..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.drain/main.c:467
+#, fuzzy
+msgid "Writing output raster map..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.drain/main.c:689
+#, c-format
+msgid "direction read: %lf, neighbour found: %i"
+msgstr ""
#: ../raster/r.circle/main.c:54
msgid "Creates a raster map containing concentric rings around a given point."
msgstr ""
@@ -9767,270 +12160,486 @@
msgid "Please specify min and/or max radius when using the binary flag"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:53 ../raster/r.rescale/main.c:49
+#: ../raster/r.circle/main.c:154 ../raster/r.surf.fractal/main.c:85
+#: ../raster/r.in.gdal/main.c:1329 ../raster/r.li/r.li.daemon/daemon.c:178
+#: ../raster/r.composite/main.c:262
+#, fuzzy, c-format
+msgid "Raster map <%s> created."
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.bin/main.c:50 ../raster/r.in.bin/main.c:59
+#: ../raster/r.in.bin/main.c:510
#, fuzzy
-msgid "rescale"
+msgid "Error reading data"
msgstr "출력할 래스터맵"
-#: ../raster/r.rescale.eq/main.c:55
-msgid ""
-"Rescales histogram equalized the range of category values in a raster map "
-"layer."
+#: ../raster/r.in.bin/main.c:238
+msgid "Import a binary raster file into a GRASS raster map layer."
msgstr ""
-#: ../raster/r.rescale.eq/main.c:65 ../raster/r.rescale/main.c:60
-msgid "The name of the raster map to be rescaled"
+#: ../raster/r.in.bin/main.c:243
+msgid "Import as floating-point data (default: integer)"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:73 ../raster/r.rescale/main.c:68
-msgid "The input data range to be rescaled (default: full range of input map)"
+#: ../raster/r.in.bin/main.c:248
+msgid "Import as double-precision floating-point data (default: integer)"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:80 ../raster/r.rescale/main.c:75
-msgid "The resulting raster map name"
+#: ../raster/r.in.bin/main.c:257
+msgid "Byte Swap the Data During Import"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:87 ../raster/r.rescale/main.c:82
-msgid "The output data range"
+#: ../raster/r.in.bin/main.c:262
+msgid "Get region info from GMT style header"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:94 ../raster/r.rescale/main.c:89
-msgid "Title for new raster map"
+#: ../raster/r.in.bin/main.c:267
+msgid "Binary raster file to be imported"
msgstr ""
-#: ../raster/r.rescale.eq/main.c:123
+#: ../raster/r.in.bin/main.c:277 ../raster/r.in.gdal/main.c:120
+#: ../raster/r.in.poly/main.c:45 ../raster/r.in.arc/main.c:85
+#: ../raster/r.external/main.c:88 ../raster/r.in.ascii/main.c:96
+msgid "Title for resultant raster map"
+msgstr ""
+#: ../raster/r.in.bin/main.c:284 ../raster/r.out.bin/main.c:311
+#, fuzzy
+msgid "Number of bytes per cell"
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.bin/main.c:366
+msgid "order= and -b are mutually exclusive"
+msgstr ""
+#: ../raster/r.in.bin/main.c:381
+msgid "-f and -d are mutually exclusive"
+msgstr ""
+#: ../raster/r.in.bin/main.c:385
#, c-format
-msgid "Rescale %s[%d,%d] to %s[%d,%d]"
+msgid "-f incompatible with bytes=%d; must be 4 or 8"
msgstr ""
-#: ../raster/r.rescale.eq/get_stats.c:19 ../raster/r.rescale/get_range.c:24
+#: ../raster/r.in.bin/main.c:393
#, c-format
-msgid "Reading %s ..."
+msgid "-d incompatible with bytes=%d; must be 8"
msgstr ""
-#: ../raster/r.in.mat/main.c:94
-msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+#: ../raster/r.in.bin/main.c:400
+msgid "bytes= required for integer data"
msgstr ""
-#: ../raster/r.in.mat/main.c:101
+#: ../raster/r.in.bin/main.c:421
#, fuzzy
-msgid "Name of input MAT-File(v4)"
+msgid "Either -h or rows= and cols= must be given"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.mat/main.c:105
+#: ../raster/r.in.bin/main.c:426
#, fuzzy
-msgid "Name for output raster map (override)"
+msgid "Either all or none of north=, south=, east= and west= must be given"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.mat/main.c:149
-#, fuzzy
-msgid "Reading MAT-File..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.bin/main.c:464
+#, c-format
+msgid ""
+"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
+"significantly. Did you assign east= and west= correctly?"
+msgstr ""
-#: ../raster/r.in.mat/main.c:175
-msgid "Array contains no data"
+#: ../raster/r.in.bin/main.c:487
+msgid "File Size %"
msgstr ""
-#: ../raster/r.in.mat/main.c:180
-msgid "Array contains imaginary data"
+#: ../raster/r.grow/main.c:129 ../locale/scriptstrings/r.grow_to_translate.c:1
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
msgstr ""
-#: ../raster/r.in.mat/main.c:186
-msgid "Invalid array name"
+#: ../raster/r.grow/main.c:140 ../locale/scriptstrings/r.grow_to_translate.c:4
+msgid "Radius of buffer in raster cells"
msgstr ""
-#: ../raster/r.in.mat/main.c:206
-msgid "Invalid 'map_name' array"
+#: ../raster/r.grow/main.c:147 ../raster/r.grow.distance/main.c:174
+#: ../locale/scriptstrings/r.grow_to_translate.c:5
+msgid "Metric"
msgstr ""
-#: ../raster/r.in.mat/main.c:216
-msgid "Error reading 'map_name' array"
+#: ../raster/r.grow/main.c:156 ../locale/scriptstrings/r.grow_to_translate.c:6
+msgid "Value to write for input cells which are non-NULL (-1 => NULL)"
msgstr ""
-#: ../raster/r.in.mat/main.c:227
-msgid "Invalid 'map_northern_edge' array"
+#: ../raster/r.grow/main.c:162 ../locale/scriptstrings/r.grow_to_translate.c:7
+msgid "Value to write for \"grown\" cells"
msgstr ""
-#: ../raster/r.in.mat/main.c:236
-msgid "Invalid 'map_southern_edge' array"
+#: ../raster/r.grow/main.c:194
+#, c-format
+msgid "Unknown metric: [%s]."
msgstr ""
-#: ../raster/r.in.mat/main.c:245
-msgid "Invalid 'map_eastern_edge' array"
+#: ../raster/r.grow/main.c:203 ../display/d.colors/get_info.c:21
+#, fuzzy, c-format
+msgid "Error reading category file for <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.grow/main.c:208
+#, fuzzy, c-format
+msgid "Error in reading color file for <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.accumulate/main.c:82
+#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:3
+#, fuzzy
+msgid "accumulation"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.accumulate/main.c:84
+msgid ""
+"Makes each output cell value a accumulationfunction of the values assigned "
+"to the corresponding cells in the input raster map layers."
msgstr ""
-#: ../raster/r.in.mat/main.c:254
-msgid "Invalid 'map_western_edge' array"
+#: ../raster/r.series.accumulate/main.c:90
+msgid "Existing map to be added to output"
msgstr ""
-#: ../raster/r.in.mat/main.c:262
-msgid "Invalid 'map_title' array"
+#: ../raster/r.series.accumulate/main.c:98
+#, fuzzy
+msgid "Input file with raster map names, one per line"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.accumulate/main.c:109
+#, fuzzy
+msgid "Scale factor for input"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.accumulate/main.c:116
+msgid "Shift factor for input"
msgstr ""
-#: ../raster/r.in.mat/main.c:272
-msgid "Error reading 'map_title' array"
+#: ../raster/r.series.accumulate/main.c:121
+msgid ""
+"The raster map specifying the lower accumulation limit, also called baseline"
msgstr ""
-#: ../raster/r.in.mat/main.c:285
-msgid "Invalid 'map_data' array"
+#: ../raster/r.series.accumulate/main.c:126
+msgid ""
+"The raster map specifying the upper accumulation limit, also called cutoff. "
+"Only applied to BEDD computation."
msgstr ""
-#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
-#: ../raster/r.in.mat/main.c:522
-msgid "Please contact the GRASS development team"
+#: ../raster/r.series.accumulate/main.c:139
+msgid "Use these limits in case lower and/or upper input maps are not defined"
msgstr ""
-#: ../raster/r.in.mat/main.c:316
-#, c-format
-msgid "Skipping unknown array '%s'"
+#: ../raster/r.series.accumulate/main.c:151
+msgid ""
+"Growing Degree Days or Winkler indices: depending on the chosen average "
+"computation set with -a flag"
msgstr ""
-#: ../raster/r.in.mat/main.c:344
-#, c-format
-msgid "No 'map_data' array found in <%s>"
+#: ../raster/r.series.accumulate/main.c:152
+msgid ""
+"Mean: either (min + max) / 2 or sum(input maps)/(number of input maps) set "
+"with -a flag"
msgstr ""
-#: ../raster/r.in.mat/main.c:351
-#, c-format
-msgid "Setting map name to <%s> which overrides <%s>"
+#: ../raster/r.series.accumulate/main.c:153
+msgid "Biologically Effective Degree Days"
msgstr ""
-#: ../raster/r.in.mat/main.c:358
-#, c-format
-msgid "Setting map name to <%s>"
+#: ../raster/r.series.accumulate/main.c:154
+msgid "Huglin Heliothermal index"
msgstr ""
-#: ../raster/r.in.mat/main.c:362
-msgid "No 'map_name' array found; using <MatFile>"
+#: ../raster/r.series.accumulate/main.c:159
+msgid "Use arithmetical mean instead of (min + max ) / 2"
msgstr ""
-#: ../raster/r.in.mat/main.c:373
-msgid "Missing bound"
+#: ../raster/r.series.accumulate/main.c:171
+msgid "Create a FCELL map (floating point single precision) as output"
msgstr ""
-#: ../raster/r.in.mat/main.c:377
-msgid "Using default bounds"
+#: ../raster/r.series.accumulate/main.c:356
+#, fuzzy, c-format
+msgid "'%s'=%f must be > '%s'=%f"
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.xyz/main.c:163 ../raster/r.in.lidar/main.c:163
+#: ../vector/v.surf.bspline/main.c:94 ../vector/v.in.lidar/main.c:156
+#: ../vector/v.lidar.correction/main.c:69 ../vector/v.lidar.growing/main.c:76
+#: ../vector/v.lidar.edgedetection/main.c:73
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:5
+msgid "LIDAR"
msgstr ""
-#: ../raster/r.in.mat/main.c:391
-#, c-format
-msgid "Map <%s> bounds set to:"
+#: ../raster/r.in.xyz/main.c:165
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
msgstr ""
-#: ../raster/r.in.mat/main.c:392 ../raster/r.out.mat/main.c:174
-#, c-format
-msgid "northern edge=%f"
+#: ../raster/r.in.xyz/main.c:169
+msgid "ASCII file containing input data (or \"-\" to read from stdin)"
msgstr ""
-#: ../raster/r.in.mat/main.c:393 ../raster/r.out.mat/main.c:175
-#, c-format
-msgid "southern edge=%f"
+#: ../raster/r.in.xyz/main.c:177 ../raster/r.in.lidar/main.c:177
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:11
+msgid "Statistic to use for raster values"
msgstr ""
-#: ../raster/r.in.mat/main.c:394 ../raster/r.out.mat/main.c:176
-#, c-format
-msgid "eastern edge=%f"
+#: ../raster/r.in.xyz/main.c:181 ../raster/r.in.xyz/main.c:289
+#: ../raster/r.in.xyz/main.c:298 ../raster/r.in.lidar/main.c:181
+#: ../raster/r.in.lidar/main.c:221 ../raster/r.in.lidar/main.c:230
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:12
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:29
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:31
+msgid "Statistic"
msgstr ""
-#: ../raster/r.in.mat/main.c:395 ../raster/r.out.mat/main.c:177
-#, c-format
-msgid "western edge=%f"
+#: ../raster/r.in.xyz/main.c:189 ../raster/r.in.arc/main.c:78
+#: ../raster/r.in.ascii/main.c:88 ../raster/r.in.lidar/main.c:189
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:13
+msgid "Storage type for resultant raster map"
msgstr ""
-#: ../raster/r.in.mat/main.c:396 ../raster/r.out.mat/main.c:178
-#, c-format
-msgid "nsres=%f"
+#: ../raster/r.in.xyz/main.c:192 ../raster/r.in.xyz/main.c:201
+#: ../raster/r.in.xyz/main.c:209 ../raster/r.in.xyz/main.c:220
+#: ../raster/r.in.xyz/main.c:230 ../raster/simwe/r.sim.water/main.c:131
+#: ../raster/simwe/r.sim.water/main.c:140
+#: ../raster/simwe/r.sim.water/main.c:147
+#: ../raster/simwe/r.sim.water/main.c:156
+#: ../raster/simwe/r.sim.water/main.c:162
+#: ../raster/simwe/r.sim.water/main.c:170
+#: ../raster/simwe/r.sim.water/main.c:177
+#: ../raster/simwe/r.sim.sediment/main.c:153
+#: ../raster/simwe/r.sim.sediment/main.c:161 ../raster/r.external/main.c:64
+#: ../raster/r.external/main.c:72 ../raster/r.external/main.c:81
+#: ../vector/v.edit/args.c:90 ../vector/v.edit/args.c:209
+#: ../locale/scriptstrings/t.remove_to_translate.c:5
+#: ../locale/scriptstrings/t.remove_to_translate.c:8
+#: ../locale/scriptstrings/t.remove_to_translate.c:10
+#: ../locale/scriptstrings/t.register_to_translate.c:5
+#: ../locale/scriptstrings/t.register_to_translate.c:6
+#: ../locale/scriptstrings/t.register_to_translate.c:8
+#: ../locale/scriptstrings/t.register_to_translate.c:10
+#: ../locale/scriptstrings/t.register_to_translate.c:20
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:15
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:17
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:19
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:21
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:24
+#: ../locale/scriptstrings/i.spectral_to_translate.c:6
+#: ../locale/scriptstrings/i.spectral_to_translate.c:7
+#: ../locale/scriptstrings/i.spectral_to_translate.c:8
+msgid "Input"
msgstr ""
-#: ../raster/r.in.mat/main.c:397 ../raster/r.out.mat/main.c:179
-#, c-format
-msgid "ewres=%f"
+#: ../raster/r.in.xyz/main.c:200
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:16
+msgid "Column number of x coordinates in input file (first column is 1)"
msgstr ""
-#: ../raster/r.in.mat/main.c:398 ../raster/r.out.mat/main.c:180
-#: ../raster3d/r3.out.bin/main.c:330
-#, c-format
-msgid "rows=%d"
+#: ../raster/r.in.xyz/main.c:208
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:18
+msgid "Column number of y coordinates in input file"
msgstr ""
-#: ../raster/r.in.mat/main.c:399 ../raster/r.out.mat/main.c:181
-#: ../raster3d/r3.out.bin/main.c:331
-#, c-format
-msgid "cols=%d"
+#: ../raster/r.in.xyz/main.c:216
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:22
+msgid "Column number of data values in input file"
msgstr ""
-#: ../raster/r.in.mat/main.c:408
+#: ../raster/r.in.xyz/main.c:218
+msgid ""
+"If a separate value column is given, this option refers to the z-coordinate "
+"column to be filtered by the zrange option"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:229
#, fuzzy
-msgid "Writing new raster map..."
+msgid "Number of header lines to skip at top of input file"
msgstr "출력할 래스터맵"
-#: ../raster/r.surf.gauss/main.c:42
+#: ../raster/r.in.xyz/main.c:237 ../raster/r.in.lidar/main.c:196
+msgid "Filter range for z data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:238 ../raster/r.in.xyz/main.c:246
+#: ../raster/r.in.xyz/main.c:255 ../raster/r.in.xyz/main.c:263
+#: ../raster/r.in.xyz/main.c:271
+msgid "Advanced Input"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:245 ../raster/r.in.lidar/main.c:203
+msgid "Scale to apply to z data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:253
#, fuzzy
-msgid "Generates a raster map using gaussian random number generator."
+msgid "Alternate column number of data values in input file"
msgstr "출력할 래스터맵"
-#: ../raster/r.surf.gauss/main.c:44
+#: ../raster/r.in.xyz/main.c:254
+msgid "If not given (or set to 0) the z-column data is used"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:262
+msgid "Filter range for alternate value column data (min,max)"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:270
+msgid "Scale to apply to alternate value column data"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:279 ../raster/r.cost/main.c:229
+#: ../raster/r.walk/main.c:264 ../raster/r.in.lidar/main.c:211
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:27
+msgid "Percent of map to keep in memory"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:288 ../raster/r.in.lidar/main.c:220
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:28
+msgid "pth percentile of the values"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:297 ../raster/r.in.lidar/main.c:229
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:30
msgid ""
-"Mean and standard deviation of gaussian deviates can be expressed by the "
-"user."
+"Discard <trim> percent of the smallest and <trim> percent of the largest "
+"observations"
msgstr ""
-#: ../raster/r.surf.gauss/main.c:51
-msgid "Distribution mean"
+#: ../raster/r.in.xyz/main.c:302 ../raster/r.in.lidar/main.c:257
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:6
+msgid "Scan data file for extent then exit"
msgstr ""
-#: ../raster/r.surf.gauss/main.c:57
-msgid "Standard deviation"
+#: ../raster/r.in.xyz/main.c:307 ../raster/r.in.lidar/main.c:263
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:7
+msgid "In scan mode, print using shell script style"
msgstr ""
-#: ../raster/r.regression.line/main.c:49
-msgid "Calculates linear regression from two raster maps: y = a + b*x."
+#: ../raster/r.in.xyz/main.c:311
+#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:8
+msgid "Ignore broken lines"
msgstr ""
-#: ../raster/r.out.mat/main.c:64
-msgid "Exports a GRASS raster to a binary MAT-File."
+#: ../raster/r.in.xyz/main.c:332
+msgid "Please specify a reasonable column number."
msgstr ""
-#: ../raster/r.out.mat/main.c:73
+#: ../raster/r.in.xyz/main.c:344 ../vector/v.in.ascii/main.c:185
+msgid "Please specify reasonable number of lines to skip"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:349 ../raster/r.in.lidar/main.c:428
+msgid "Invalid zrange"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:363
#, fuzzy
-msgid "Name for output binary MAT file"
+msgid "Invalid vrange"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.mat/main.c:113
+#: ../raster/r.in.xyz/main.c:449 ../raster/r.in.lidar/main.c:521
+msgid "Unable to calculate percentile without the pth option specified!"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:461 ../raster/r.in.lidar/main.c:533
+msgid "Unable to calculate trimmed mean without the trim option specified!"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:494 ../raster/r.in.lidar/main.c:608
#, c-format
-msgid "Exporting <%s>"
+msgid ""
+"Unable to process the hole map at once. Please set the %s option to some "
+"value lower than 100."
msgstr ""
-#: ../raster/r.out.mat/main.c:173
-msgid "Using the Current Region settings:"
+#: ../raster/r.in.xyz/main.c:547
+msgid ""
+"If input is not from a file it is only possible to perform a single pass."
msgstr ""
-#: ../raster/r.out.mat/main.c:248
-msgid "Exporting raster as integer values"
+#: ../raster/r.in.xyz/main.c:559
+msgid "Range filters will not be taken into account during scan"
msgstr ""
-#: ../raster/r.out.mat/main.c:253
-msgid "Exporting raster as floating point values"
+#: ../raster/r.in.xyz/main.c:596
+#, fuzzy
+msgid "Reading input data..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.xyz/main.c:603 ../raster/r.in.poly/poly2rast.c:55
+#: ../raster/r.in.lidar/main.c:665
+#, c-format
+msgid "Pass #%d (of %d) ..."
msgstr ""
-#: ../raster/r.out.mat/main.c:258
-msgid "Exporting raster as double FP values"
+#: ../raster/r.in.xyz/main.c:681 ../raster/r.in.xyz/main.c:689
+#: ../raster/r.in.xyz/main.c:1198 ../raster/r.in.xyz/main.c:1206
+#, c-format
+msgid ""
+"Not enough data columns. Incorrect delimiter or column number? Found the "
+"following character(s) in row %lu:\n"
+"[%s]"
msgstr ""
-#: ../raster/r.out.mat/main.c:301
-msgid "Reading in map ... "
+#: ../raster/r.in.xyz/main.c:685 ../raster/r.in.xyz/main.c:1202
+msgid "Line ignored as requested"
msgstr ""
-#: ../raster/r.out.mat/main.c:314
+#: ../raster/r.in.xyz/main.c:704 ../raster/r.in.xyz/main.c:1236
+#, c-format
+msgid "Bad y-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:711 ../raster/r.in.xyz/main.c:1221
+#, c-format
+msgid "Bad x-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:718 ../raster/r.in.xyz/main.c:1251
+#, c-format
+msgid "Bad z-coordinate line %lu column %d. <%s>"
+msgstr ""
+#: ../raster/r.in.xyz/main.c:731 ../raster/r.in.xyz/main.c:1269
+#, fuzzy, c-format
+msgid "Bad data value line %lu column %d. <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.xyz/main.c:814
#, fuzzy
-msgid "Writing out map..."
+msgid "Writing to output raster map..."
msgstr "출력할 래스터맵"
-#: ../raster/r.out.mat/main.c:374
+#: ../raster/r.in.xyz/main.c:1154 ../raster/r.in.lidar/main.c:1146
#, fuzzy, c-format
-msgid "%ld bytes written to '%s'"
+msgid "%lu points found in region."
msgstr "출력할 래스터맵"
+#: ../raster/r.in.xyz/main.c:1183 ../raster/r.in.lidar/main.c:1238
+msgid "Scanning data ..."
+msgstr ""
+#: ../raster/r.in.xyz/main.c:1289 ../raster/r.in.lidar/main.c:1280
+#, c-format
+msgid "Range: min max\n"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:136
+#, c-format
+msgid "Downward pass %d"
+msgstr ""
+#: ../raster/r.fill.dir/resolve.c:173
+#, c-format
+msgid "Upward pass %d"
+msgstr ""
#: ../raster/r.fill.dir/wtrshed.c:95
#, c-format
msgid "Watershed pass %d"
@@ -10075,6 +12684,14 @@
msgid "Direction map is D8 resolution, i.e. 45 degrees"
msgstr ""
+#: ../raster/r.fill.dir/main.c:150 ../raster/r.grow.distance/main.c:368
+#: ../raster/r.colors.out/raster_main.c:69
+#: ../raster/r.colors/edit_colors.c:415 ../vector/v.colors/main.c:316
+#: ../display/d.colors/get_info.c:25
+#, fuzzy, c-format
+msgid "Unable to read color table for raster map <%s>"
+msgstr "출력할 래스터맵"
#: ../raster/r.fill.dir/main.c:187
#, fuzzy
msgid "Reading input elevation raster map..."
@@ -10092,16 +12709,12 @@
msgid "Repeat to get the final directions..."
msgstr ""
-#: ../raster/r.fill.dir/resolve.c:136
-#, c-format
-msgid "Downward pass %d"
-msgstr ""
+#: ../raster/r.fill.dir/main.c:250 ../raster/r.stream.extract/close.c:247
+#: ../raster/r.grow.distance/main.c:311
+#, fuzzy
+msgid "Writing output raster maps..."
+msgstr "출력할 래스터맵"
-#: ../raster/r.fill.dir/resolve.c:173
-#, c-format
-msgid "Upward pass %d"
-msgstr ""
#: ../raster/r.fill.dir/dopolys.c:84
#, c-format
msgid "Found %d unresolved area"
@@ -10109,1020 +12722,1103 @@
msgstr[0] ""
msgstr[1] ""
-#: ../raster/r.walk/main.c:183
+#: ../raster/r.stream.snap/io.c:17 ../raster/r.stream.channel/io.c:17
+#: ../raster/r.stream.segment/io.c:17 ../raster/r.stream.order/io.c:17
+#: ../raster/r.stream.stats/io.c:17
#, fuzzy
-msgid "Outputs a raster map showing the anisotropic cumulative cost."
+msgid "Unable to create raster map of unrecognised type"
msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:185
+#: ../raster/r.stream.snap/main.c:47
+#, fuzzy
+msgid "Snap point to modelled stream network."
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.snap/main.c:48
msgid ""
-"Computes anisotropic cumulative cost of moving between different geographic "
-"locations on an input elevation raster map whose cell category values "
-"represent elevation combined with an input raster map layer whose cell "
-"values represent friction cost."
+"Input can be stream network, point vector map with outlets or outlet "
+"coordinates."
msgstr ""
-#: ../raster/r.walk/main.c:196
-msgid "Name of input raster map containing friction costs"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:52
+#, fuzzy
+msgid "basins creation"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:199
+#: ../raster/r.stream.snap/main.c:55
#, fuzzy
-msgid "Name for output raster map to contain walking costs"
+msgid "Name of input vector points map"
msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:274
-msgid "Coefficients for walking energy formula parameters a,b,c,d"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:58
+#, fuzzy
+msgid "Name of output vector points map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:284
-msgid "Lambda coefficients for combining walking energy and friction cost"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:63 ../raster/r.stream.channel/main.c:64
+#: ../raster/r.stream.segment/main.c:64 ../raster/r.stream.order/main.c:32
+#: ../raster/r.stream.stats/main.c:60
+#, fuzzy
+msgid "Name for input raster map with stream network"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:294
-msgid "Slope factor determines travel energy cost per height step"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:69 ../raster/r.stream.extract/main.c:85
+#: ../raster/r.stream.order/main.c:35
+#, fuzzy
+msgid "Name of input accumulation raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:304
-msgid "Keep null values in output map"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:77
+#, fuzzy
+msgid "Minimum accumulation threshold to snap"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:314
-msgid "Only print info about disk space and memory requirements"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:84
+#, fuzzy
+msgid "Maximum distance to snap (in cells)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:384
-#, c-format
-msgid "Missing required value: got %d instead of 4"
+#: ../raster/r.stream.snap/main.c:91
+msgid "Max memory used (MB)"
msgstr ""
-#: ../raster/r.walk/main.c:387
-#, c-format
-msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:107
+#, fuzzy, c-format
+msgid "<%s> is an illegal basin name"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:392 ../raster/r.walk/main.c:400
-#, c-format
-msgid "Missing required value: %d"
-msgstr ""
+#: ../raster/r.stream.snap/main.c:111
+#, fuzzy
+msgid "At least one of accumulation or streams raster maps is required"
+msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:395
+#: ../raster/r.stream.snap/snap.c:133
#, c-format
-msgid "Lambda is %lf"
+msgid ""
+"Unable to snap point with cat %d, in a given radius. Increase search radius."
msgstr ""
-#: ../raster/r.walk/main.c:403
-#, c-format
-msgid "Slope_factor is %lf"
+#: ../raster/r.univar/r.univar_main.c:36
+msgid "Raster map used for zoning, must be of type CELL"
msgstr ""
-#: ../raster/r.walk/main.c:422
-msgid "Warning: assigning negative cost to null cell. Null cells excluded."
+#: ../raster/r.univar/r.univar_main.c:41
+#: ../raster/r.univar/r3.univar_main.c:42 ../raster/r.stats/main.c:118
+#: ../raster/r.what/main.c:129 ../vector/v.db.select/main.c:88
+#: ../locale/scriptstrings/i.oif_to_translate.c:5
+#: ../locale/scriptstrings/r.out.xyz_to_translate.c:6
+#: ../db/db.select/main.c:244
+msgid "Name for output file (if omitted or \"-\" output to stdout)"
msgstr ""
-#: ../raster/r.walk/main.c:573
-#, fuzzy, c-format
-msgid "Reading raster maps <%s> and <%s>, initializing output..."
+#: ../raster/r.univar/r.univar_main.c:42 ../raster/r.kappa/main.c:90
+#: ../raster/r.kappa/main.c:98
+#: ../locale/scriptstrings/r.unpack_to_translate.c:7
+#: ../locale/scriptstrings/r.unpack_to_translate.c:9 ../ps/ps.map/main.c:100
+#: ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
+#, fuzzy
+msgid "Output settings"
msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:658
-msgid "Initializing directional output "
+#: ../raster/r.univar/r.univar_main.c:52
+#: ../raster/r.univar/r3.univar_main.c:52 ../vector/v.univar/main.c:119
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
+#: ../locale/scriptstrings/db.univar_to_translate.c:6
+msgid "Percentile to calculate (requires extended statistics flag)"
msgstr ""
-#: ../raster/r.walk/main.c:736
-#, fuzzy, c-format
-msgid "No start points found in vector <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:824
-#, fuzzy, c-format
-msgid "Reading %s... "
-msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:861
-#, c-format
-msgid "No start points found in raster <%s>"
+#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
+msgid "Extended"
msgstr ""
-#: ../raster/r.walk/main.c:895
-msgid "Finding cost path"
+#: ../raster/r.univar/r.univar_main.c:56 ../raster/r.univar/r.univar_main.c:62
+#: ../raster/r.univar/r.univar_main.c:72 ../raster/r.kappa/main.c:104
+#: ../raster/r.kappa/main.c:109 ../raster/r.stats/main.c:122
+#: ../raster/r.stats/main.c:131 ../raster/r.stats/main.c:155
+#: ../raster/r.report/parse.c:76 ../raster/r.report/parse.c:85
+#: ../raster/r.report/parse.c:94 ../raster/r.report/parse.c:118
+#: ../raster/r.report/parse.c:123 ../raster/r.report/parse.c:128
+#: ../raster/r.report/parse.c:133
+#: ../locale/scriptstrings/t.list_to_translate.c:10
+#: ../locale/scriptstrings/t.list_to_translate.c:16
+#: ../locale/scriptstrings/t.list_to_translate.c:18
+msgid "Formatting"
msgstr ""
-#: ../raster/r.walk/main.c:1379
-#, fuzzy, c-format
-msgid "Writing output raster map %s... "
-msgstr "출력할 래스터맵"
-#: ../raster/r.walk/main.c:1443
-#, fuzzy, c-format
-msgid "Writing movement direction file %s..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:297
-#, fuzzy, c-format
-msgid "Unable to open PNG file '%s'"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:300
-msgid "Input file empty or too short"
+#: ../raster/r.univar/r.univar_main.c:61
+#: ../raster/r.univar/r3.univar_main.c:59 ../vector/v.univar/main.c:123
+#: ../vector/v.what/main.c:98
+msgid "Print the stats in shell script style"
msgstr ""
-#: ../raster/r.in.png/main.c:303
-msgid "Input file not a PNG file"
+#: ../raster/r.univar/r.univar_main.c:66
+#: ../raster/r.univar/r3.univar_main.c:63 ../vector/v.univar/main.c:127
+#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
+#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
+msgid "Calculate extended statistics"
msgstr ""
-#: ../raster/r.in.png/main.c:307 ../raster/r.in.png/main.c:311
-#: ../general/g.ppmtopng/main.c:70 ../general/g.ppmtopng/main.c:74
-#, fuzzy
-msgid "Unable to allocate PNG structure"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:314
-msgid "PNG error"
+#: ../raster/r.univar/r.univar_main.c:71
+#: ../raster/r.univar/r3.univar_main.c:67
+msgid "Table output format instead of standard output format"
msgstr ""
-#: ../raster/r.in.png/main.c:522
+#: ../raster/r.univar/r.univar_main.c:102
+#: ../raster/r.univar/r3.univar_main.c:100 ../vector/v.vect.stats/main.c:131
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
#, fuzzy
-msgid "Imports non-georeferenced PNG format image."
+msgid "univariate statistics"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:533
+#: ../raster/r.univar/r.univar_main.c:103 ../vector/v.vect.stats/main.c:132
+#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
#, fuzzy
-msgid "Title for created raster map"
+msgid "zonal statistics"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:539
-#, fuzzy
-msgid "Display gamma"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:545
-msgid "Alpha threshold"
+#: ../raster/r.univar/r.univar_main.c:105
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
msgstr ""
-#: ../raster/r.in.png/main.c:549
-#, fuzzy
-msgid "Create floating-point map (0.0 - 1.0)"
+#: ../raster/r.univar/r.univar_main.c:116
+#: ../raster/r.univar/r3.univar_main.c:124 ../raster/r.stats/main.c:231
+#: ../raster/r.regression.multi/main.c:168
+#: ../raster/r.regression.line/main.c:76 ../raster/r.what/main.c:174
+#: ../vector/v.db.select/main.c:114 ../db/db.select/main.c:141
+#, fuzzy, c-format
+msgid "Unable to open file <%s> for writing"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.png/main.c:553
-#, fuzzy
-msgid "Output image file header only and exit"
+#: ../raster/r.univar/r.univar_main.c:186 ../raster/r.out.png/main.c:272
+#, fuzzy, c-format
+msgid "Raster <%s> type mismatch"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.channel/io.c:297
-#, fuzzy
-msgid "Unrecognisabe data type"
-msgstr "출력할 래스터맵"
+#: ../raster/r.univar/r3.univar_main.c:37
+msgid "3D Raster map used for zoning, must be of type CELL"
+msgstr ""
-#: ../raster/r.stream.channel/main.c:60
-#, fuzzy
-msgid "Calculates local parameters for individual streams."
-msgstr "출력할 래스터맵"
+#: ../raster/r.univar/r3.univar_main.c:103
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
-#: ../raster/r.stream.channel/main.c:75
-#, fuzzy
-msgid "Name for output unique stream identifier raster map"
+#: ../raster/r.resamp.filter/main.c:142
+#, fuzzy, c-format
+msgid "Filter <%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.channel/main.c:81
+#: ../raster/r.resamp.filter/main.c:387
#, fuzzy
-msgid "Name for output init/join/outlet distance raster map"
+msgid "Resamples raster map layers using an analytic kernel."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.channel/main.c:88
-#, fuzzy
-msgid "Name for output elevation init/join/outlet difference raster map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.filter/main.c:398
+msgid "Filter kernel(s)"
+msgstr ""
-#: ../raster/r.stream.channel/main.c:95
-#, fuzzy
-msgid "Name for output mean init/join/outlet gradient of stream raster map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.filter/main.c:406
+msgid "Filter radius"
+msgstr ""
-#: ../raster/r.stream.channel/main.c:101
-#, fuzzy
-msgid "Name for output local stream curvature raster map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.filter/main.c:413
+msgid "Filter radius (horizontal)"
+msgstr ""
-#: ../raster/r.stream.channel/main.c:114
-msgid "Calculate parameters from outlet (downstream values)"
+#: ../raster/r.resamp.filter/main.c:420
+msgid "Filter radius (vertical)"
msgstr ""
-#: ../raster/r.stream.channel/main.c:118
-msgid "Calculate local values (for current cell)"
+#: ../raster/r.resamp.filter/main.c:431
+msgid "radius= and x_radius=/y_radius= are mutually exclusive"
msgstr ""
-#: ../raster/r.stream.channel/main.c:122
-msgid "Calculate distance in cell count (ignored local)"
+#: ../raster/r.resamp.filter/main.c:435
+msgid "Either radius= or x_radius=/y_radius= required"
msgstr ""
-#: ../raster/r.stream.channel/main.c:154
-#, fuzzy, c-format
-msgid "All in RAM calculation - direction <%s>..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.filter/main.c:437
+msgid "Both x_radius= and y_radius= required"
+msgstr ""
-#: ../raster/r.stream.channel/stream_topology.c:52
-#: ../raster/r.stream.channel/stream_topology.c:98
-#: ../raster/r.stream.channel/stream_topology.c:241
-#: ../raster/r.stream.channel/stream_topology.c:291
-msgid "Error finding inits. Stream and direction maps probably do not match..."
+#: ../raster/r.resamp.filter/main.c:459
+msgid "Differing number of values for filter= and [xy_]radius="
msgstr ""
-#: ../raster/r.stream.channel/stream_topology.c:54
-#: ../raster/r.stream.channel/stream_topology.c:243
-msgid "Stream network may be too dense..."
+#: ../raster/r.resamp.filter/main.c:462
+#, c-format
+msgid "Too many filters (max: %d)"
msgstr ""
-#: ../raster/r.stream.channel/stream_topology.c:173
-#: ../raster/r.stream.channel/stream_topology.c:379
+#: ../raster/r.resamp.filter/main.c:480
#, fuzzy
-msgid "To much points in stream line..."
+msgid "At least one filter must be finite"
msgstr "출력할 래스터맵"
-#: ../raster/r.his/main.c:63 ../display/d.his/main.c:64
-#: ../imagery/i.his.rgb/main.c:47 ../imagery/i.rgb.his/main.c:47
+#: ../raster/r.distance/parse.c:33
#, fuzzy
-msgid "color transformation"
+msgid "Name of two input raster maps for computing inter-class distances"
msgstr "출력할 래스터맵"
-#: ../raster/r.his/main.c:68
-msgid ""
-"Generates red, green and blue raster map layers combining hue, intensity and "
-"saturation (HIS) values from user-specified input raster map layers."
+#: ../raster/r.distance/parse.c:40
+msgid "Include category labels in the output"
msgstr ""
-#: ../raster/r.his/main.c:77 ../display/d.his/main.c:78
-msgid "Name of layer to be used for HUE"
+#: ../raster/r.distance/parse.c:45
+msgid "Report zero distance if rasters are overlapping"
msgstr ""
-#: ../raster/r.his/main.c:84 ../display/d.his/main.c:85
-msgid "Name of layer to be used for INTENSITY"
+#: ../raster/r.distance/report.c:43
+msgid "Processing..."
msgstr ""
-#: ../raster/r.his/main.c:91 ../display/d.his/main.c:92
-msgid "Name of layer to be used for SATURATION"
+#: ../raster/r.distance/main.c:41
+msgid "Locates the closest points between objects in two raster maps."
msgstr ""
-#: ../raster/r.his/main.c:98
-msgid "Name of output layer to be used for RED"
+#: ../raster/r.distance/edges.c:46
+#, c-format
+msgid "Reading map %s ..."
msgstr ""
-#: ../raster/r.his/main.c:105
-msgid "Name of output layer to be used for GREEN"
+#: ../raster/r.distance/distance.c:101
+#, c-format
+msgid "Reading maps <%s,%s> while finding 0 distance ..."
msgstr ""
-#: ../raster/r.his/main.c:112
-msgid "Name of output layer to be used for BLUE"
+#: ../raster/r.lake/main.c:152 ../raster/r.spread/main.c:105
+#: ../raster/r.ros/main.c:217
+msgid "hazard"
msgstr ""
-#: ../raster/r.his/main.c:116 ../display/d.his/main.c:103
-msgid "Respect NULL values while drawing"
+#: ../raster/r.lake/main.c:153
+msgid "flood"
msgstr ""
-#: ../raster/r.stream.slope/main.c:75
-msgid "stream local parameters"
+#: ../raster/r.lake/main.c:154
+msgid "Fills lake at given point to given level."
msgstr ""
-#: ../raster/r.stream.slope/main.c:76
-msgid "Calculates local parameters for slope subsystem."
+#: ../raster/r.lake/main.c:160
+msgid "Water level"
msgstr ""
-#: ../raster/r.stream.slope/main.c:88
-#, fuzzy
-msgid "Name for output local downstream elevation difference raster map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.lake/main.c:169
+msgid "Seed point coordinates"
+msgstr ""
-#: ../raster/r.stream.slope/main.c:94
+#: ../raster/r.lake/main.c:170
#, fuzzy
-msgid "Name for output local downstream gradient raster map"
+msgid "Either this coordinates pair or a seed map have to be specified"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.slope/main.c:101
+#: ../raster/r.lake/main.c:178
#, fuzzy
-msgid "Name for output local downstream maximum curvature raster map"
+msgid "Input raster map with given starting point(s) (at least 1 cell > 0)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.slope/main.c:108
+#: ../raster/r.lake/main.c:180
#, fuzzy
-msgid "Name for output local downstream minimum curvature raster map"
+msgid "Either this parameter or a coordinates pair have to be specified"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.slope/main.c:127
-#, fuzzy, c-format
-msgid "Raster <%s> is not of type CELL"
-msgstr "출력할 래스터맵"
+#: ../raster/r.lake/main.c:186
+msgid "Use negative depth values for lake raster map"
+msgstr ""
-#: ../raster/r.thin/io.c:96
-#, fuzzy
-msgid "Input raster must be of type CELL."
-msgstr "출력할 래스터맵"
+#: ../raster/r.lake/main.c:191
+msgid "Overwrite seed map with result (lake) map"
+msgstr ""
-#. GTC First is the file name, second and third - number of rows and cols
-#: ../raster/r.thin/io.c:102
-#, c-format
-msgid "File %s -- %s X %s"
+#: ../raster/r.lake/main.c:197
+msgid "Both seed map and coordinates cannot be specified"
msgstr ""
-#: ../raster/r.thin/io.c:103 ../raster/r.thin/io.c:166
-#: ../raster/r.thin/io.c:171 ../display/d.rast.num/main.c:180
-#, c-format
-msgid "%d row"
-msgid_plural "%d rows"
-msgstr[0] ""
-msgstr[1] ""
+#: ../raster/r.lake/main.c:200
+msgid "Seed map or seed coordinates must be set!"
+msgstr ""
-#: ../raster/r.thin/io.c:104 ../raster/r.thin/io.c:167
-#: ../raster/r.thin/io.c:172
-#, fuzzy, c-format
-msgid "%d column"
-msgid_plural "%d columns"
-msgstr[0] "출력할 래스터맵"
-msgstr[1] "출력할 래스터맵"
+#: ../raster/r.lake/main.c:203
+msgid "Seed coordinates and output map lake= must be set!"
+msgstr ""
-#: ../raster/r.thin/io.c:114
-#, c-format
-msgid "%s: Unable to create temporary file <%s> -- errno = %d"
+#: ../raster/r.lake/main.c:206
+msgid "Both lake and overwrite cannot be specified"
msgstr ""
-#: ../raster/r.thin/io.c:123 ../raster/r.thin/io.c:131
-#: ../raster/r.thin/io.c:141
-#, c-format
-msgid "%s: Error writing temporary file"
+#: ../raster/r.lake/main.c:209
+msgid "Output lake map or overwrite flag must be set!"
msgstr ""
-#. GTC %s will be replaced with number of rows and columns
-#: ../raster/r.thin/io.c:165
-#, fuzzy, c-format
-msgid "Output file %s X %s"
+#: ../raster/r.lake/main.c:236
+#, fuzzy
+msgid "Seed point outside the current region"
msgstr "출력할 래스터맵"
-#: ../raster/r.thin/io.c:170
-#, c-format
-msgid "Window %s X %s"
+#: ../raster/r.lake/main.c:250
+msgid "G_malloc: out of memory"
msgstr ""
-#: ../raster/r.thin/main.c:59
-msgid "Thins non-zero cells that denote linear features in a raster map layer."
+#: ../raster/r.lake/main.c:272
+msgid ""
+"Given water level at seed point is below earth surface. Increase water level "
+"or move seed point."
msgstr ""
-#: ../raster/r.thin/main.c:71
-msgid "Maximal number of iterations"
+#: ../raster/r.lake/main.c:351
+#, c-format
+msgid "Lake depth from %f to %f (specified water level is taken as zero)"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:68
+#: ../raster/r.lake/main.c:352
#, c-format
-msgid "%s: Unable to find bounding box for lines"
+msgid "Lake area %f square meters"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:71
+#: ../raster/r.lake/main.c:353
#, c-format
-msgid "Bounding box: l = %d, r = %d, t = %d, b = %d"
+msgid "Lake volume %f cubic meters"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:118
-#, c-format
-msgid "Pass number %d"
+#: ../raster/r.lake/main.c:354
+msgid "Volume is correct only if lake depth (terrain raster map) is in meters"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:169
+#: ../raster/r.kappa/stats.c:14 ../raster/r.report/stats.c:128
+msgid "Problem reading r.stats output"
+msgstr ""
+#: ../raster/r.kappa/prt_label.c:17
+#, fuzzy, c-format
+msgid "Can't open file <%s> to write label"
+msgstr "출력할 래스터맵"
+#: ../raster/r.kappa/calc_kappa.c:32
#, c-format
-msgid "Deleted %d pixel"
-msgid_plural "Deleted %d pixels"
-msgstr[0] ""
-msgstr[1] ""
-#: ../raster/r.thin/thin_lines.c:173
-msgid "Thinning completed successfully."
+msgid "Cannot open file <%s> to write kappa and relevant parameters"
msgstr ""
-#: ../raster/r.thin/thin_lines.c:175
-msgid "Thinning not completed, consider to increase 'iterations' parameter."
+#: ../raster/r.kappa/main.c:72
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
msgstr ""
-#: ../raster/r.to.rast3/main.c:59 ../raster/r.to.rast3elev/main.c:136
-msgid "Could not close the map"
+#: ../raster/r.kappa/main.c:78
+#, fuzzy
+msgid "Name of raster map containing classification result"
+msgstr "출력할 래스터맵"
+#: ../raster/r.kappa/main.c:83
+#, fuzzy
+msgid "Name of raster map containing reference classes"
+msgstr "출력할 래스터맵"
+#: ../raster/r.kappa/main.c:88
+#, fuzzy
+msgid "Name for output file containing error matrix and kappa"
+msgstr "출력할 래스터맵"
+#: ../raster/r.kappa/main.c:89
+#, fuzzy
+msgid "If not given, print to startdard output"
+msgstr "출력할 래스터맵"
+#: ../raster/r.kappa/main.c:96
+msgid "Title for error matrix and kappa"
msgstr ""
-#: ../raster/r.to.rast3/main.c:79
-msgid "2d raster maps which represent the slices"
+#: ../raster/r.kappa/main.c:102
+msgid "Wide report"
msgstr ""
-#: ../raster/r.to.rast3/main.c:84 ../raster/r.to.rast3elev/main.c:175
-msgid "The maximum tile size in kilo bytes. Default is 32KB."
+#: ../raster/r.kappa/main.c:103
+msgid "132 columns (default: 80)"
msgstr ""
-#: ../raster/r.to.rast3/main.c:93
-msgid "Use 3D raster mask (if exists) with output map"
+#: ../raster/r.kappa/main.c:108
+msgid "No header in the report"
msgstr ""
-#: ../raster/r.to.rast3/main.c:199 ../raster/r.to.rast3elev/main.c:364
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:4
-#: ../raster3d/r3.info/r3.info.main.c:78 ../raster3d/r3.cross.rast/main.c:231
-#: ../raster3d/r3.in.ascii/main.c:317 ../raster3d/r3.out.vtk/main.c:377
-#: ../raster3d/r3.out.v5d/main.c:284 ../raster3d/r3.mkdspf/main.c:80
-#: ../raster3d/r3.retile/main.c:98 ../raster3d/r3.out.ascii/main.c:306
-#: ../raster3d/r3.to.rast/main.c:209 ../raster3d/r3.gwflow/main.c:161
-#: ../raster3d/r3.in.v5d/main.c:193 ../raster3d/r3.mask/main.c:134
-#: ../raster3d/r3.null/main.c:186
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:44
-#: ../vector/v.vol.rst/main.c:239 ../vector/v.to.rast3/main.c:50
-msgid "voxel"
+#: ../raster/r.kappa/prt_hdr.c:18
+#, fuzzy, c-format
+msgid "Cannot open file <%s> to write header"
+msgstr "출력할 래스터맵"
+#: ../raster/r.kappa/prt_mat.c:39
+#, c-format
+msgid "Cannot open file <%s> to write cats and counts (error matrix)"
msgstr ""
-#: ../raster/r.to.rast3/main.c:201
-msgid "Converts 2D raster map slices to one 3D raster volume map."
+#: ../raster/r.to.rast3elev/main.c:99
+msgid "The number of input and elevation maps is not equal"
msgstr ""
-#: ../raster/r.to.rast3/main.c:213
-msgid "No output map"
+#: ../raster/r.to.rast3elev/main.c:136 ../raster/r.to.rast3/main.c:59
+msgid "Could not close the map"
msgstr ""
-#: ../raster/r.to.rast3/main.c:230 ../raster/r.to.rast3elev/main.c:427
-msgid ""
-"The 2D and 3D region settings are different. I will use the 3D region "
-"settings to adjust the 2D region."
+#: ../raster/r.to.rast3elev/main.c:165
+msgid "The value to fill the upper cells, default is null"
msgstr ""
-#: ../raster/r.to.rast3/main.c:244 ../raster/r.stream.extract/dseg.c:51
-#: ../raster/r.stream.extract/cseg.c:51 ../raster/r.stream.extract/seg.c:55
-#: ../raster/r.stream.extract/bseg.c:50 ../raster/r.li/r.li.daemon/list.c:49
-#: ../db/drivers/sqlite/listdb.c:134 ../db/drivers/postgres/listdb.c:79
-#: ../db/drivers/postgres/listtab.c:92 ../raster3d/r3.to.rast/main.c:295
-#: ../imagery/i.smap/multialloc.c:115 ../vector/v.net.connectivity/main.c:186
-#: ../vector/v.net.connectivity/main.c:202 ../vector/v.surf.rst/main.c:800
-#: ../vector/v.net.distance/main.c:204 ../vector/v.mapcalc/list.c:55
-#: ../vector/v.mapcalc/list.c:502 ../vector/v.net.allpairs/main.c:200
-#: ../vector/v.mkgrid/write_grid.c:134 ../vector/v.net.flow/main.c:231
-#: ../vector/v.kcv/main.c:231 ../vector/v.net.timetable/main.c:389
-#: ../vector/v.net.timetable/main.c:399 ../vector/v.net.components/main.c:169
-#: ../vector/v.net.centrality/main.c:293 ../vector/v.net.centrality/main.c:298
-#: ../vector/v.net.centrality/main.c:304 ../vector/v.net.centrality/main.c:310
-#: ../vector/v.net.centrality/main.c:316
-#: ../vector/v.generalize/smoothing.c:144
-#: ../vector/v.generalize/smoothing.c:231
-#: ../vector/v.generalize/smoothing.c:374
-#: ../vector/v.generalize/smoothing.c:528
-#: ../vector/v.generalize/smoothing.c:574
-#: ../vector/v.generalize/smoothing.c:578
-#: ../vector/v.generalize/smoothing.c:582
-#: ../vector/v.generalize/smoothing.c:586
-#: ../vector/v.generalize/smoothing.c:590
-#: ../vector/v.generalize/smoothing.c:594
-#: ../vector/v.generalize/smoothing.c:598 ../vector/v.generalize/matrix.c:144
-#: ../vector/v.generalize/simplification.c:33
-#: ../vector/v.generalize/simplification.c:40
-#: ../vector/v.generalize/simplification.c:306
-#: ../vector/v.generalize/simplification.c:314
-#: ../vector/v.generalize/simplification.c:338
-#: ../vector/v.generalize/network.c:96 ../vector/v.generalize/network.c:131
-msgid "Out of memory"
+#: ../raster/r.to.rast3elev/main.c:172
+msgid "The value to fill the lower cells, default is null"
msgstr ""
-#: ../raster/r.to.rast3/main.c:262
-#, c-format
-msgid "Open raster map %s - one time for each depth (%d/%d)"
+#: ../raster/r.to.rast3elev/main.c:175 ../raster/r.to.rast3/main.c:84
+msgid "The maximum tile size in kilo bytes. Default is 32KB."
msgstr ""
-#: ../raster/r.to.rast3/main.c:275
-msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
+#: ../raster/r.to.rast3elev/main.c:185
+msgid "Use the input map values to fill the upper cells"
msgstr ""
-#: ../raster/r.to.rast3/main.c:279 ../raster/r.to.rast3elev/main.c:457
-msgid "Creating 3D raster map"
+#: ../raster/r.to.rast3elev/main.c:190
+msgid "Use the input map values to fill the lower cells"
msgstr ""
-#: ../raster/r.to.rast3/main.c:291 ../raster/r.to.rast3elev/main.c:443
+#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
#, fuzzy
-msgid "Error opening 3D raster map"
+msgid "Error writing 3D raster double data"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.rast3/main.c:326 ../raster/r.to.rast3elev/main.c:501
-msgid "Error closing 3d raster map"
+#: ../raster/r.to.rast3elev/main.c:366
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
msgstr ""
-#: ../raster/r.surf.idw2/main.c:65
-msgid "Surface generation program."
+#: ../raster/r.to.rast3elev/main.c:400
+msgid "The upper value is not valid"
msgstr ""
-#: ../raster/r.surf.idw2/main.c:84
-msgid ""
-"Lat/long databases not supported by r.surf.idw2. Use r.surf.idw instead!"
+#: ../raster/r.to.rast3elev/main.c:410
+msgid "The lower value is not valid"
msgstr ""
-#: ../raster/r.surf.idw2/main.c:88
-#, c-format
-msgid "%s=%s - illegal number of interpolation points"
+#: ../raster/r.to.rast3elev/main.c:427 ../raster/r.to.rast3/main.c:230
+msgid ""
+"The 2D and 3D region settings are different. I will use the 3D region "
+"settings to adjust the 2D region."
msgstr ""
-#: ../raster/r.surf.idw2/main.c:97
-#, c-format
-msgid "%s: no data points found"
-msgstr ""
+#: ../raster/r.to.rast3elev/main.c:443 ../raster/r.to.rast3/main.c:291
+#, fuzzy
+msgid "Error opening 3D raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.surf.idw2/main.c:112
-#, fuzzy, c-format
-msgid "Interpolating raster map <%s>... %d row... "
-msgid_plural "Interpolating raster map <%s>... %d rows... "
-#: ../raster/r.resamp.rst/main.c:151
-msgid ""
-"Reinterpolates and optionally computes topographic analysis from input "
-"raster map to a new raster map (possibly with different resolution) using "
-"regularized spline with tension and smoothing."
+#: ../raster/r.to.rast3elev/main.c:457 ../raster/r.to.rast3/main.c:279
+msgid "Creating 3D raster map"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:162
-msgid "Desired east-west resolution"
+#: ../raster/r.to.rast3elev/main.c:501 ../raster/r.to.rast3/main.c:326
+msgid "Error closing 3d raster map"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:168
-msgid "Desired north-south resolution"
+#: ../raster/r.stream.slope/main.c:75
+msgid "stream local parameters"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:175
-msgid "Output z-file (elevation) map"
+#: ../raster/r.stream.slope/main.c:76
+msgid "Calculates local parameters for slope subsystem."
msgstr ""
-#: ../raster/r.resamp.rst/main.c:183
-msgid "Output slope map (or fx)"
-msgstr ""
+#: ../raster/r.stream.slope/main.c:88
+#, fuzzy
+msgid "Name for output local downstream elevation difference raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:191
-msgid "Output aspect map (or fy)"
-msgstr ""
+#: ../raster/r.stream.slope/main.c:94
+#, fuzzy
+msgid "Name for output local downstream gradient raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:199
-msgid "Output profile curvature map (or fxx)"
-msgstr ""
+#: ../raster/r.stream.slope/main.c:101
+#, fuzzy
+msgid "Name for output local downstream maximum curvature raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:207
-msgid "Output tangential curvature map (or fyy)"
-msgstr ""
+#: ../raster/r.stream.slope/main.c:108
+#, fuzzy
+msgid "Name for output local downstream minimum curvature raster map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:215
-msgid "Output mean curvature map (or fxy)"
-msgstr ""
+#: ../raster/r.stream.slope/main.c:127
+#, fuzzy, c-format
+msgid "Raster <%s> is not of type CELL"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:223
-msgid "Name of raster map containing smoothing"
+#: ../raster/r.reclass/parse.c:41 ../raster/r.colors/rules.c:104
+#, c-format
+msgid "Enter a rule in one of these formats:\n"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:231
-msgid "Name of raster map to be used as mask"
+#: ../raster/r.reclass/parse.c:42
+msgid "poor quality"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:239
-msgid "Rows/columns overlap for segmentation"
+#: ../raster/r.reclass/parse.c:44
+msgid "medium quality"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:247
-msgid "Multiplier for z-values"
+#: ../raster/r.reclass/parse.c:59
+msgid "Can't have null on the left-hand side of the rule"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:255
-msgid "Spline tension value"
+#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
+msgid "Can't have null on the right-hand side of the rule"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:262
-msgid "Anisotropy angle (in degrees)"
+#: ../raster/r.reclass/parse.c:196
+#, c-format
+msgid "%f rounded up to %d\n"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:263 ../raster/r.resamp.rst/main.c:270
-msgid "Anisotropy"
+#: ../raster/r.reclass/reclass.c:50 ../raster/r.reclass/reclass.c:110
+msgid "Too many categories"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:269 ../vector/v.surf.rst/main.c:333
-msgid "Anisotropy scaling factor"
-msgstr ""
+#: ../raster/r.reclass/reclass.c:215
+#, fuzzy, c-format
+msgid "Cannot read header file of <%s@%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:274
-msgid "Use dnorm independent tension"
-msgstr ""
+#: ../raster/r.reclass/reclass.c:230
+#, fuzzy, c-format
+msgid "Cannot create reclass file of <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:166
-msgid "Output partial derivatives instead of topographic parameters"
-msgstr ""
+#: ../raster/r.reclass/reclass.c:238
+#, fuzzy, c-format
+msgid "Cannot create raster map <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:313
+#: ../raster/r.reclass/main.c:51 ../vector/v.reclass/main.c:68
#, fuzzy
-msgid "Unable to read ew_res value"
+msgid "reclassification"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:316
+#: ../raster/r.reclass/main.c:52
#, fuzzy
-msgid "Unable to read ns_res value"
+msgid "Reclassify raster map based on category values."
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:319
-msgid "Invalid value for tension"
+#: ../raster/r.reclass/main.c:54
+msgid ""
+"Creates a new raster map whose category values are based upon a "
+"reclassification of the categories in an existing raster map."
msgstr ""
-#: ../raster/r.resamp.rst/main.c:322
-msgid "Invalid value for zmult"
-msgstr ""
+#: ../raster/r.reclass/main.c:59
+#, fuzzy
+msgid "Name of raster map to be reclassified"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:325
-msgid "Invalid value for overlap"
+#: ../raster/r.reclass/main.c:65
+msgid "File containing reclass rules"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:329
-msgid "Invalid value for theta"
-msgstr ""
+#: ../raster/r.reclass/main.c:66 ../raster/r.recode/main.c:60
+#, fuzzy
+msgid "\"-\" to read from stdin"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:333
-msgid "Invalid value for scalex"
+#: ../raster/r.reclass/main.c:72
+msgid "Title for the resulting raster map"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:335
-msgid "When using anisotropy both theta and scalex must be specified"
+#: ../raster/r.reclass/main.c:83
+msgid "Input map can NOT be the same as output map"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:375
+#: ../raster/r.reclass/main.c:89
+#, fuzzy, c-format
+msgid "Cannot open rules file <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.reclass/main.c:103
#, c-format
-msgid "Map <%s> is the wrong resolution"
+msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:383
-msgid "Smoothing values can not be negative or NULL"
+#: ../raster/r.reclass/main.c:105
+#, c-format
+msgid "FCELL: Data range is %.7g to %.7g\n"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:389
-msgid "Input map resolution differs from current region resolution!"
+#: ../raster/r.reclass/main.c:108
+#, c-format
+msgid "DCELL: Data range is %.15g to %.15g\n"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:407
-msgid "Processing all selected output files will require"
-msgstr ""
+#: ../raster/r.reclass/main.c:111
+#, fuzzy, c-format
+msgid "CELL: Data range is %ld to %ld\n"
+msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:411
+#: ../raster/r.reclass/main.c:119
#, c-format
-msgid "%.2f GB of disk space for temp files."
+msgid "Illegal reclass rule -"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:414
+#: ../raster/r.reclass/main.c:120
#, c-format
-msgid "%.2f MB of disk space for temp files."
+msgid " ignored\n"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:417
-#, c-format
-msgid "%.2f KB of disk space for temp files."
+#: ../raster/r.reclass/main.c:123
+msgid " - invalid reclass rule"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:420
+#: ../raster/r.reclass/main.c:139
#, c-format
-msgid "%d byte of disk space for temp files."
-msgid_plural "%d bytes of disk space for temp files."
-msgstr[0] ""
-msgstr[1] ""
-#: ../raster/r.resamp.rst/main.c:452
-msgid "Maximum value of a raster map is NULL."
+msgid "No rules specified. Raster map <%s> not created"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:480
-msgid "Temporarily changing the region to desired resolution ..."
+#: ../raster/r.reclass/main.c:142 ../raster/r.quant/main.c:179
+#: ../raster/r.recode/main.c:98
+msgid "No rules specified"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:485
-msgid "Changing back to the original region ..."
+#: ../raster/r.resamp.stats/main.c:259
+#, fuzzy
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.stats/main.c:269
+msgid "Aggregation method"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:490 ../raster/r.resample/main.c:112
-msgid "Percent complete: "
+#: ../raster/r.resamp.stats/main.c:287
+msgid "Weight according to area (slower)"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:502
-#, c-format
-msgid "dnorm in mainc after grid before out1= %f"
+#: ../raster/r.solute.transport/main.c:59
+msgid "The initial concentration in [kg/m^3]"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:506
-msgid "split_and_interpolate() failed"
+#: ../raster/r.solute.transport/main.c:63
+msgid "The piezometric head in [m]"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:521
-#, c-format
-msgid "dnorm in mainc after grid before out2= %f"
+#: ../raster/r.solute.transport/main.c:68
+msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
msgstr ""
-#: ../raster/r.resamp.rst/main.c:527
-#, fuzzy
-msgid "Unable to write raster maps -- try increasing cell size"
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.rst/main.c:559 ../vector/v.surf.rst/main.c:826
-#, fuzzy, c-format
-msgid "Error writing temporary file <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.carve/main.c:76
-msgid "Generates stream channels."
+#: ../raster/r.solute.transport/main.c:73
+msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
msgstr ""
-#: ../raster/r.carve/main.c:77
+#: ../raster/r.solute.transport/main.c:79
msgid ""
-"Takes vector stream data, transforms it to raster and subtracts depth from "
-"the output DEM."
+"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
+"dirichlet- and 3 - transfer boundary condition"
msgstr ""
-#: ../raster/r.carve/main.c:82
-msgid "Name of input raster elevation map"
+#: ../raster/r.solute.transport/main.c:85
+msgid "The x-part of the diffusion tensor in [m^2/s]"
msgstr ""
-#: ../raster/r.carve/main.c:87
-#, fuzzy
-msgid "Name of input vector map containing stream(s)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.solute.transport/main.c:90
+msgid "The y-part of the diffusion tensor in [m^2/s]"
+msgstr ""
-#: ../raster/r.carve/main.c:95
-#, fuzzy
-msgid "Name for output vector map for adjusted stream points"
-msgstr "출력할 래스터맵"
+#: ../raster/r.solute.transport/main.c:94
+#: ../raster/r.solute.transport/main.c:102
+#: ../raster/r.solute.transport/main.c:138
+#: ../raster/r.solute.transport/main.c:145
+msgid "Water flow"
+msgstr ""
-#: ../raster/r.carve/main.c:100
-msgid "Stream width (in meters)"
+#: ../raster/r.solute.transport/main.c:96
+msgid "Groundwater sources and sinks in [m^3/s]"
msgstr ""
-#: ../raster/r.carve/main.c:101
-msgid "Default is raster cell width"
+#: ../raster/r.solute.transport/main.c:103
+msgid ""
+"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
msgstr ""
-#: ../raster/r.carve/main.c:106
-msgid "Additional stream depth (in meters)"
+#: ../raster/r.solute.transport/main.c:112
+msgid ""
+"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
+"reaction)"
msgstr ""
-#: ../raster/r.carve/main.c:110
-msgid "No flat areas allowed in flow direction"
+#: ../raster/r.solute.transport/main.c:117
+msgid "Retardation factor [-]"
msgstr ""
-#: ../raster/r.carve/main.c:134
-#, c-format
-msgid "Invalid width value '%s' - using default."
+#: ../raster/r.solute.transport/main.c:121
+msgid "Effective porosity [-]"
msgstr ""
-#: ../raster/r.carve/main.c:148
-#, c-format
-msgid "Invalid depth value '%s' - using default."
+#: ../raster/r.solute.transport/main.c:125
+msgid "Top surface of the aquifer in [m]"
msgstr ""
-#: ../raster/r.carve/main.c:212
-msgid "lat/lon projection not supported at this time."
+#: ../raster/r.solute.transport/main.c:129
+msgid "Bottom surface of the aquifer in [m]"
msgstr ""
-#: ../raster/r.carve/enforce_ds.c:82
-msgid "Processing lines... "
+#: ../raster/r.solute.transport/main.c:132
+msgid ""
+"The resulting concentration of the numerical solute transport calculation "
+"will be written to this map. [kg/m^3]"
msgstr ""
-#: ../raster/r.carve/enforce_ds.c:174
+#: ../raster/r.solute.transport/main.c:140
msgid ""
-"Vect runs out of region and re-enters - this case is not yet implemented."
+"Calculate and store the groundwater filter velocity vector part in x "
+"direction [m/s]\n"
msgstr ""
-#: ../raster/r.carve/lobf.c:74
-msgid "trying to divide by zero...no unique solution for system...skipping..."
+#: ../raster/r.solute.transport/main.c:147
+msgid ""
+"Calculate and store the groundwater filter velocity vector part in y "
msgstr ""
-#: ../raster/r.carve/raster.c:13 ../raster/r.texture/main.c:292
-#: ../imagery/i.zc/main.c:152
-#, fuzzy
-msgid "Reading raster map..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.solute.transport/main.c:161
+msgid "The longditudinal dispersivity length. [m]"
+msgstr ""
-#: ../raster/r.rescale/main.c:51
-msgid "Rescales the range of category values in a raster map layer."
+#: ../raster/r.solute.transport/main.c:169
+msgid "The transversal dispersivity length. [m]"
msgstr ""
-#: ../raster/r.rescale/main.c:118
-#, c-format
-msgid "Rescale %s[%ld,%ld] to %s[%ld,%ld]"
+#: ../raster/r.solute.transport/main.c:177
+msgid ""
+"Use this number of time loops if the CFL flag is off. The timestep will "
+"become dt/loops."
msgstr ""
-#: ../raster/r.resamp.stats/main.c:259
-#, fuzzy
-msgid "Resamples raster map layers to a coarser grid using aggregation."
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.stats/main.c:269
-msgid "Aggregation method"
+#: ../raster/r.solute.transport/main.c:187
+msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
msgstr ""
-#: ../raster/r.resamp.stats/main.c:287
-msgid "Weight according to area (slower)"
+#: ../raster/r.solute.transport/main.c:199
+msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
msgstr ""
-#: ../raster/r.cross/main.c:72
+#: ../raster/r.solute.transport/main.c:231
+#, fuzzy
+msgid "solute transport"
+msgstr "출력할 래스터맵"
+#: ../raster/r.solute.transport/main.c:233
msgid ""
-"Creates a cross product of the category values from multiple raster map "
-"layers."
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
msgstr ""
-#: ../raster/r.cross/main.c:81
+#: ../raster/r.solute.transport/main.c:244 ../raster/r.gwflow/main.c:222
+#: ../raster/r.topidx/new/main.c:55 ../raster/r.topidx/main.c:55
+#: ../raster/r.topidx/old/main.c:55
#, c-format
-msgid "Names of 2-%d input raster maps"
+msgid "Lat/Long location is not supported by %s. Please reproject map first."
msgstr ""
-#: ../raster/r.cross/main.c:90
-msgid "Non-zero data only"
+#: ../raster/r.solute.transport/main.c:258
+msgid "The direct LU solver do not work with sparse matrices"
msgstr ""
-#: ../raster/r.cross/main.c:103
-#, c-format
-msgid "More than %d files not allowed"
+#: ../raster/r.solute.transport/main.c:260
+msgid "The direct Gauss solver do not work with sparse matrices"
msgstr ""
-#: ../raster/r.cross/main.c:119
-msgid "Must specify 2 or more input maps"
+#: ../raster/r.solute.transport/main.c:370
+#, c-format
+msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
msgstr ""
-#: ../raster/r.cross/main.c:136
+#: ../raster/r.solute.transport/main.c:371
#, c-format
-msgid "%s: STEP 2 ..."
+msgid "The largest stable time step is %g"
msgstr ""
-#: ../raster/r.cross/main.c:179
+#: ../raster/r.solute.transport/main.c:380
+#, fuzzy, c-format
+msgid "Number of inner loops is %g"
+msgstr "출력할 래스터맵"
+#: ../raster/r.solute.transport/main.c:381
#, c-format
-msgid "%ld categories"
+msgid "Time step for each loop %g"
msgstr ""
-#: ../raster/r.cross/renumber.c:33
+#: ../raster/r.solute.transport/main.c:385
#, c-format
-msgid "%s: STEP 3 ... "
+msgid ""
+"The time step is to large: %gs. The largest time step should be of size %gs."
msgstr ""
-#: ../raster/r.cross/cross.c:65
+#: ../raster/r.solute.transport/main.c:397
#, c-format
-msgid "%s: STEP 1 ... "
+msgid "Time step %i with time sum %g"
msgstr ""
-#: ../raster/r.texture/main.c:67
-#, fuzzy, c-format
-msgid "Unknown measure <%s>"
-msgstr "출력할 래스터맵"
+#: ../raster/r.solute.transport/main.c:543
+msgid "Could not create and solve the linear equation system"
+msgstr ""
-#: ../raster/r.texture/main.c:104
+#: ../raster/r.clump/clump.c:72
#, fuzzy
-msgid "texture"
+msgid "Unable to open temp file"
msgstr "출력할 래스터맵"
-#: ../raster/r.texture/main.c:106
-msgid "Generate images with textural features from a raster map."
+#: ../raster/r.clump/clump.c:94
+msgid "Pass 1..."
msgstr ""
-#: ../raster/r.texture/main.c:117
+#: ../raster/r.clump/clump.c:207 ../raster/r.clump/clump.c:221
#, fuzzy
-msgid "Prefix for output raster map(s)"
+msgid "Unable to write to temp file"
msgstr "출력할 래스터맵"
-#: ../raster/r.texture/main.c:124
-msgid "The size of moving window (odd and >= 3)"
-msgstr ""
-#: ../raster/r.texture/main.c:134
-msgid "The distance between two samples (>= 1)"
-msgstr ""
-#: ../raster/r.texture/main.c:150
+#: ../raster/r.clump/clump.c:225
#, fuzzy
-msgid "Textural measurement method"
+msgid "Generating renumbering scheme..."
msgstr "출력할 래스터맵"
-#: ../raster/r.texture/main.c:154
-msgid "Separate output for each angle (0, 45, 90, 135)"
+#: ../raster/r.clump/clump.c:261
+msgid "Pass 2..."
msgstr ""
-#: ../raster/r.texture/main.c:158
+#: ../raster/r.clump/clump.c:267
#, fuzzy
-msgid "Calculate all textural measurements"
+msgid "Unable to read from temp file"
msgstr "출력할 래스터맵"
-#: ../raster/r.texture/main.c:167
-msgid "Size of the moving window must be > 0"
+#: ../raster/r.clump/main.c:51
+msgid "reclass"
msgstr ""
-#: ../raster/r.texture/main.c:169
-msgid "Size of the moving window must be odd"
+#: ../raster/r.clump/main.c:53
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
msgstr ""
-#: ../raster/r.texture/main.c:172
-msgid "The distance between two samples must be > 0"
+#: ../raster/r.clump/main.c:64 ../raster/r.recode/main.c:66
+#, fuzzy
+msgid "Title for output raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.clump/main.c:68
+msgid "Clump also diagonal cells"
msgstr ""
-#: ../raster/r.texture/main.c:193
-msgid "Nothing to compute. Use at least one textural measure."
+#: ../raster/r.clump/main.c:69
+msgid "Clumps are also traced along diagonal neighboring cells"
msgstr ""
-#: ../raster/r.texture/main.c:331
+#: ../raster/r.clump/main.c:110
#, fuzzy, c-format
-msgid "Calculating %d texture measure"
-msgid_plural "Calculating %d texture measures"
+msgid "%d clump."
+msgid_plural "%d clumps."
-#: ../raster/r.texture/main.c:334
-#, fuzzy, c-format
-msgid "Calculating %s"
+#: ../raster/r.stream.extract/cseg.c:19 ../raster/r.stream.extract/bseg.c:19
+#: ../raster/r.stream.extract/seg.c:19
+#, fuzzy
+msgid "Unable to create segment file"
msgstr "출력할 래스터맵"
-#: ../raster/r.texture/h_measure.c:123
-#, c-format
-msgid ""
-"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
-"map"
-msgstr ""
+#: ../raster/r.stream.extract/cseg.c:29 ../raster/r.stream.extract/cseg.c:79
+#: ../raster/r.stream.extract/cseg.c:88 ../raster/r.stream.extract/bseg.c:28
+#: ../raster/r.stream.extract/bseg.c:78 ../raster/r.stream.extract/bseg.c:87
+#: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
+#: ../raster/r.stream.extract/dseg.c:88 ../raster/r.stream.extract/seg.c:33
+#: ../raster/r.stream.extract/seg.c:75
+#, fuzzy
+msgid "Unable to write segment file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/load.c:33
+#: ../raster/r.stream.extract/cseg.c:33 ../raster/r.stream.extract/bseg.c:32
+#: ../raster/r.stream.extract/seg.c:37
#, fuzzy
-msgid "Loading elevation raster map..."
+msgid "Illegal configuration parameter(s)"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/load.c:35
+#: ../raster/r.stream.extract/cseg.c:40 ../raster/r.stream.extract/bseg.c:39
+#: ../raster/r.stream.extract/dseg.c:40
#, fuzzy
-msgid "Loading input raster maps..."
+msgid "Unable to re-open segment file"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/load.c:95
-msgid "Elevation raster map is NULL but accumulation map is not NULL"
+#: ../raster/r.stream.extract/cseg.c:47 ../raster/r.stream.extract/bseg.c:46
+#: ../raster/r.stream.extract/bseg.c:96 ../raster/r.stream.extract/dseg.c:47
+#: ../raster/r.stream.extract/dseg.c:97 ../raster/r.stream.extract/seg.c:51
+#: ../raster/r.stream.extract/seg.c:93 ../raster/r.stream.extract/seg.c:102
+#, fuzzy
+msgid "Unable to read segment file"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.extract/cseg.c:97
+#, fuzzy
+msgid "Unabel to read segment file"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.extract/close.c:34
+#, fuzzy, c-format
+msgid "Writing vector map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.extract/close.c:117
+#, c-format
+msgid "Stream id %d not set, top is %d, parent is %d"
msgstr ""
-#: ../raster/r.stream.extract/load.c:120
-msgid "Accumulation raster map is NULL but elevation map is not NULL"
+#: ../raster/r.stream.extract/close.c:138
+msgid "Stream id not set while tracing"
msgstr ""
-#: ../raster/r.stream.extract/dseg.c:19
+#: ../raster/r.stream.extract/close.c:157
#, fuzzy
-msgid "dseg_open(): unable to create segment file"
+msgid "Writing attribute data..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/dseg.c:29 ../raster/r.stream.extract/dseg.c:79
-#: ../raster/r.stream.extract/dseg.c:88 ../raster/r.stream.extract/cseg.c:29
-#: ../raster/r.stream.extract/cseg.c:79 ../raster/r.stream.extract/cseg.c:88
-#: ../raster/r.stream.extract/seg.c:33 ../raster/r.stream.extract/seg.c:75
-#: ../raster/r.stream.extract/bseg.c:28 ../raster/r.stream.extract/bseg.c:78
-#: ../raster/r.stream.extract/bseg.c:87
-#, fuzzy
-msgid "Unable to write segment file"
+#: ../raster/r.stream.extract/close.c:172
+#: ../raster/r.stream.segment/stream_vector.c:71
+#: ../raster/r.stream.segment/stream_vector.c:225
+#: ../vector/v.in.sites/main.c:162 ../vector/v.edit/select.c:509
+#: ../vector/v.out.vtk/writeVTK.c:644 ../vector/v.db.connect/main.c:217
+#: ../vector/v.db.connect/main.c:283 ../vector/v.out.svg/main.c:152
+#: ../display/d.thematic.area/main.c:205 ../display/d.vect/opt.c:147
+#: ../db/db.columns/main.c:50 ../db/db.select/main.c:75
+#: ../db/db.describe/main.c:56 ../db/db.createdb/main.c:42
+#: ../db/db.dropdb/main.c:42 ../db/db.databases/main.c:48
+#: ../db/db.tables/main.c:42 ../db/db.execute/main.c:70
+#: ../doc/vector/v.example/main.c:126
+#, fuzzy, c-format
+msgid "Unable to start driver <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/dseg.c:33
-#, fuzzy
-msgid "Iillegal configuration parameter(s)"
+#: ../raster/r.stream.extract/close.c:187 ../raster/r.contour/main.c:179
+#: ../raster/r.stream.segment/stream_vector.c:94
+#: ../vector/v.in.lidar/main.c:604 ../vector/v.to.points/main.c:182
+#: ../vector/v.net.allpairs/main.c:178 ../vector/v.in.dwg/main.c:238
+#: ../vector/v.in.ogr/main.c:1061 ../vector/v.net.timetable/main.c:103
+#: ../vector/v.overlay/main.c:568 ../vector/v.surf.rst/main.c:596
+#: ../vector/v.distance/main.c:1293 ../vector/v.net.flow/main.c:180
+#: ../vector/v.convert/att.c:81 ../vector/v.net.centrality/main.c:266
+#: ../vector/v.net.components/main.c:189 ../vector/v.net.distance/main.c:262
+#: ../vector/v.net.path/path.c:109
+#, fuzzy, c-format
+msgid "Unable to create table: '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/dseg.c:40 ../raster/r.stream.extract/cseg.c:40
-#: ../raster/r.stream.extract/bseg.c:39
-#, fuzzy
-msgid "Unable to re-open segment file"
+#: ../raster/r.stream.extract/close.c:191
+#: ../raster/r.stream.segment/stream_vector.c:262
+#: ../raster/r.stream.order/stream_vector.c:277
+#, fuzzy, c-format
+msgid "Unable to create index on table <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/dseg.c:47 ../raster/r.stream.extract/dseg.c:97
-#: ../raster/r.stream.extract/cseg.c:47 ../raster/r.stream.extract/seg.c:51
-#: ../raster/r.stream.extract/seg.c:93 ../raster/r.stream.extract/seg.c:102
-#: ../raster/r.stream.extract/bseg.c:46 ../raster/r.stream.extract/bseg.c:96
-#, fuzzy
-msgid "Unable to read segment file"
+#: ../raster/r.stream.extract/close.c:195 ../raster/r.contour/main.c:189
+#: ../raster/r.to.vect/main.c:229
+#: ../raster/r.stream.segment/stream_vector.c:102
+#: ../raster/r.stream.order/stream_vector.c:281
+#: ../vector/v.in.sites/main.c:183 ../vector/v.in.lidar/main.c:615
+#: ../vector/v.to.points/main.c:192 ../vector/v.in.dwg/main.c:247
+#: ../vector/v.in.dxf/write_vect.c:237 ../vector/v.in.ogr/main.c:1068
+#: ../vector/v.in.ascii/main.c:399 ../vector/v.overlay/main.c:578
+#: ../vector/v.random/main.c:280 ../vector/v.sample/main.c:194
+#: ../vector/v.distance/main.c:1298 ../vector/v.reclass/main.c:319
+#: ../vector/v.patch/main.c:309 ../vector/v.convert/att.c:91
+#: ../vector/v.mkgrid/main.c:256
+#, fuzzy, c-format
+msgid "Unable to grant privileges on table <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/dseg.c:120
+#: ../raster/r.stream.extract/close.c:212
+#: ../raster/r.stream.segment/stream_vector.c:324
#, fuzzy, c-format
-msgid "Inable to segment put row %d for raster <%s>"
+msgid "Unable to insert new row: '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/cseg.c:19 ../raster/r.stream.extract/seg.c:19
-#: ../raster/r.stream.extract/bseg.c:19
+#: ../raster/r.stream.extract/close.c:312
+#, fuzzy, c-format
+msgid "Unable to write vector map <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.extract/thin.c:83
#, fuzzy
-msgid "Unable to create segment file"
+msgid "Thinning stream segments..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/cseg.c:33 ../raster/r.stream.extract/seg.c:37
-#: ../raster/r.stream.extract/bseg.c:32
+#: ../raster/r.stream.extract/thin.c:169
+#, c-format
+msgid "%d of %lld stream segments were thinned"
+msgstr ""
+#: ../raster/r.stream.extract/init_search.c:24
#, fuzzy
-msgid "Illegal configuration parameter(s)"
+msgid "Initializing A* search..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/cseg.c:97
+#: ../raster/r.stream.extract/streams.c:72
+#: ../raster/r.stream.extract/streams.c:668
+#, c-format
+msgid "Stream_no %d and n_stream_nodes %lld out of sync"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:128
+#, c-format
+msgid "BUG: stream node %d has only 1 tributary: %d"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:160
#, fuzzy
-msgid "Unabel to read segment file"
+msgid "Calculating flow accumulation..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/del_streams.c:130
+#: ../raster/r.stream.extract/streams.c:336
+#: ../raster/r.watershed/seg/do_cum.c:473
+#: ../raster/r.watershed/ram/do_cum.c:437
#, c-format
-msgid "Deleting stream segments shorter than %d cell..."
-msgid_plural "Deleting stream segments shorter than %d cells..."
-msgstr[0] ""
-msgstr[1] ""
+msgid "MFD: cumulative proportion of flow distribution not 1.0 but %f"
+msgstr ""
-#: ../raster/r.stream.extract/del_streams.c:193
+#: ../raster/r.stream.extract/streams.c:392
+#, fuzzy
+msgid "Extracting streams..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.extract/streams.c:469
+msgid "Bug in stream extraction"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:631
+msgid "Can't use Montgomery's method, no stream direction found"
+msgstr ""
+#: ../raster/r.stream.extract/streams.c:700
#, c-format
-msgid "%d stream segment deleted"
-msgid_plural "%d stream segments deleted"
-msgstr[0] ""
-msgstr[1] ""
+msgid ""
+"MFD: A * path already processed when setting drainage direction: %lld of "
+"%lld cells"
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:40
+msgid "A* Search..."
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:62
+#, c-format
+msgid "%lld surplus points"
+msgstr ""
+#: ../raster/r.stream.extract/do_astar.c:67
+#, c-format
+msgid "Too many points in heap %lld, should be %lld"
+msgstr ""
#: ../raster/r.stream.extract/main.c:79
#, fuzzy
msgid "Performs stream network extraction."
@@ -11148,6 +13844,12 @@
msgid "Minimum flow accumulation for streams"
msgstr "출력할 래스터맵"
+#: ../raster/r.stream.extract/main.c:102 ../raster/r.stream.segment/main.c:85
+#: ../raster/r.stream.segment/main.c:99
+#, fuzzy
+msgid "Must be > 0"
+msgstr "출력할 래스터맵"
#: ../raster/r.stream.extract/main.c:108
msgid "Use SFD above this threshold"
msgstr ""
@@ -11235,6 +13937,18 @@
msgid "%.2f%% of data are kept in memory"
msgstr ""
+#: ../raster/r.stream.extract/main.c:318
+#: ../raster/r.watershed/seg/init_vars.c:245
+#, c-format
+msgid "Will need up to %.2f MB of disk space"
+msgstr ""
+#: ../raster/r.stream.extract/main.c:320
+#: ../raster/r.watershed/seg/init_vars.c:247
+#, c-format
+msgid "Will need up to %.2f GB (%.0f MB) of disk space"
+msgstr ""
#: ../raster/r.stream.extract/main.c:324
#, fuzzy
msgid "Creating temporary files..."
@@ -11285,741 +13999,1104 @@
msgid "Unable to write output raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/thin.c:83
+#: ../raster/r.stream.extract/dseg.c:19
#, fuzzy
-msgid "Thinning stream segments..."
+msgid "dseg_open(): unable to create segment file"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/thin.c:169
-#, c-format
-msgid "%d of %lld stream segments were thinned"
-msgstr ""
+#: ../raster/r.stream.extract/dseg.c:33
+#, fuzzy
+msgid "Iillegal configuration parameter(s)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/close.c:34
+#: ../raster/r.stream.extract/dseg.c:120
#, fuzzy, c-format
-msgid "Writing vector map <%s>..."
+msgid "Inable to segment put row %d for raster <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/close.c:116
-#, c-format
-msgid "Stream id %d not set, top is %d, parent is %d"
+#: ../raster/r.stream.extract/seg.c:84
+msgid "seg_put_row(): could not write segment file"
msgstr ""
-#: ../raster/r.stream.extract/close.c:137
-msgid "Stream id not set while tracing"
-msgstr ""
-#: ../raster/r.stream.extract/close.c:156
+#: ../raster/r.stream.extract/load.c:33
#, fuzzy
-msgid "Writing attribute data..."
+msgid "Loading elevation raster map..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/close.c:311
-#, fuzzy, c-format
-msgid "Unable to write vector map <%s>"
+#: ../raster/r.stream.extract/load.c:35
+#, fuzzy
+msgid "Loading input raster maps..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/seg.c:84
-msgid "seg_put_row(): could not write segment file"
+#: ../raster/r.stream.extract/load.c:95
+msgid "Elevation raster map is NULL but accumulation map is not NULL"
msgstr ""
-#: ../raster/r.stream.extract/init_search.c:24
+#: ../raster/r.stream.extract/load.c:120
+msgid "Accumulation raster map is NULL but elevation map is not NULL"
+msgstr ""
+#: ../raster/r.stream.extract/del_streams.c:130
+#, c-format
+msgid "Deleting stream segments shorter than %d cell..."
+msgid_plural "Deleting stream segments shorter than %d cells..."
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.stream.extract/del_streams.c:193
+#, c-format
+msgid "%d stream segment deleted"
+msgid_plural "%d stream segments deleted"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.out.mat/main.c:64
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../raster/r.out.mat/main.c:73
#, fuzzy
-msgid "Initializing A* search..."
+msgid "Name for output binary MAT file"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/do_astar.c:40
-msgid "A* Search..."
+#: ../raster/r.out.mat/main.c:113
+#, c-format
+msgid "Exporting <%s>"
msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:62
+#: ../raster/r.out.mat/main.c:173
+msgid "Using the Current Region settings:"
+msgstr ""
+#: ../raster/r.out.mat/main.c:174 ../raster/r.in.mat/main.c:392
#, c-format
-msgid "%lld surplus points"
+msgid "northern edge=%f"
msgstr ""
-#: ../raster/r.stream.extract/do_astar.c:67
+#: ../raster/r.out.mat/main.c:175 ../raster/r.in.mat/main.c:393
#, c-format
-msgid "Too many points in heap %lld, should be %lld"
+msgid "southern edge=%f"
msgstr ""
-#: ../raster/r.stream.extract/streams.c:72
-#: ../raster/r.stream.extract/streams.c:668
+#: ../raster/r.out.mat/main.c:176 ../raster/r.in.mat/main.c:394
#, c-format
-msgid "Stream_no %d and n_stream_nodes %lld out of sync"
+msgid "eastern edge=%f"
msgstr ""
-#: ../raster/r.stream.extract/streams.c:128
+#: ../raster/r.out.mat/main.c:177 ../raster/r.in.mat/main.c:395
#, c-format
-msgid "BUG: stream node %d has only 1 tributary: %d"
+msgid "western edge=%f"
msgstr ""
-#: ../raster/r.stream.extract/streams.c:160
+#: ../raster/r.out.mat/main.c:178 ../raster/r.in.mat/main.c:396
+#, c-format
+msgid "nsres=%f"
+msgstr ""
+#: ../raster/r.out.mat/main.c:179 ../raster/r.in.mat/main.c:397
+#, c-format
+msgid "ewres=%f"
+msgstr ""
+#: ../raster/r.out.mat/main.c:248
+msgid "Exporting raster as integer values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:253
+msgid "Exporting raster as floating point values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:258
+msgid "Exporting raster as double FP values"
+msgstr ""
+#: ../raster/r.out.mat/main.c:301
+msgid "Reading in map ... "
+msgstr ""
+#: ../raster/r.out.mat/main.c:314
#, fuzzy
-msgid "Calculating flow accumulation..."
+msgid "Writing out map..."
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/streams.c:392
-#, fuzzy
-msgid "Extracting streams..."
+#: ../raster/r.out.mat/main.c:374
+#, fuzzy, c-format
+msgid "%ld bytes written to '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.extract/streams.c:469
-msgid "Bug in stream extraction"
+#: ../raster/r.coin/make_coin.c:48
+#, c-format
+msgid "Tabulating Coincidence between '%s' and '%s'"
msgstr ""
-#: ../raster/r.stream.extract/streams.c:631
-msgid "Can't use Montgomery's method, no stream direction found"
+#: ../raster/r.coin/make_coin.c:61
+msgid "Unable to create any tempfiles"
msgstr ""
-#: ../raster/r.stream.extract/streams.c:700
-#, c-format
+#: ../raster/r.coin/make_coin.c:65
+msgid "Unable to run r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:72
+msgid "Unexpected output from r.stats"
+msgstr ""
+#: ../raster/r.coin/make_coin.c:84
+msgid "Unable to open tempfile"
+msgstr ""
+#: ../raster/r.coin/main.c:69
msgid ""
-"MFD: A * path already processed when setting drainage direction: %lld of "
-"%lld cells"
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:43
-msgid "Calculates mean pixel attribute index on a raster map"
+#: ../raster/r.coin/main.c:77
+msgid "Name of first raster map"
msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:45 ../raster/r.li/r.li.renyi/renyi.c:48
-#: ../raster/r.li/r.li.patchdensity/main.c:52
-#: ../raster/r.li/r.li.patchnum/main.c:51
-#: ../raster/r.li/r.li.richness/richness.c:44
-#: ../raster/r.li/r.li.shape/main.c:50 ../raster/r.li/r.li.padsd/padsd.c:54
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:46
-#: ../raster/r.li/r.li.pielou/pielou.c:47 ../raster/r.li/r.li.padcv/padcv.c:54
-#: ../raster/r.li/r.li.shannon/shannon.c:47 ../raster/r.li/r.li.mps/mps.c:53
-#: ../raster/r.li/r.li.simpson/simpson.c:47
-#: ../raster/r.li/r.li.dominance/dominance.c:47
-#: ../raster/r.li/r.li.padrange/padrange.c:54
-#: ../raster/r.li/r.li.cwed/cwed.c:55
-#, fuzzy
-msgid "landscape structure analysis"
-msgstr "출력할 래스터맵"
+#: ../raster/r.coin/main.c:84
+msgid "Name of second raster map"
+msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:46 ../raster/r.li/r.li.patchdensity/main.c:53
-#: ../raster/r.li/r.li.patchnum/main.c:52 ../raster/r.li/r.li.shape/main.c:51
-#: ../raster/r.li/r.li.padsd/padsd.c:55
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
-#: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.mps/mps.c:54
-#: ../raster/r.li/r.li.padrange/padrange.c:55
-#: ../raster/r.li/r.li.cwed/cwed.c:56
-msgid "patch index"
+#: ../raster/r.coin/main.c:90
+msgid "Unit of measure"
msgstr ""
-#: ../raster/r.li/r.li.mpa/mpa.c:53 ../raster/r.li/r.li.renyi/renyi.c:57
-#: ../raster/r.li/r.li.patchdensity/main.c:61
-#: ../raster/r.li/r.li.patchnum/main.c:59
-#: ../raster/r.li/r.li.richness/richness.c:53
-#: ../raster/r.li/r.li.shape/main.c:59 ../raster/r.li/r.li.padsd/padsd.c:62
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:55
-#: ../raster/r.li/r.li.pielou/pielou.c:56 ../raster/r.li/r.li.padcv/padcv.c:62
-#: ../raster/r.li/r.li.shannon/shannon.c:56 ../raster/r.li/r.li.mps/mps.c:62
-#: ../raster/r.li/r.li.simpson/simpson.c:56
-#: ../raster/r.li/r.li.dominance/dominance.c:56
-#: ../raster/r.li/r.li.padrange/padrange.c:62
-#: ../raster/r.li/r.li.cwed/cwed.c:64
-msgid "Configuration file"
+#: ../raster/r.coin/main.c:92
+msgid ""
+"c(ells), p(ercent), x(percent of category [column]), y(percent of category "
+"[row]), a(cres), h(ectares), k(square kilometers), m(square miles)"
msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:46
+#: ../raster/r.coin/main.c:99
+msgid "Wide report, 132 columns (default: 80)"
+msgstr ""
+#: ../raster/r.coin/print_coin.c:44
+#, c-format
+msgid "Preparing report ..."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:85
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:93
#, fuzzy
-msgid "Calculates Renyi's diversity index on a raster map"
+msgid "Name for output vector map with interpolation grid"
msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.renyi/renyi.c:49
-#: ../raster/r.li/r.li.richness/richness.c:45
-#: ../raster/r.li/r.li.pielou/pielou.c:48
-#: ../raster/r.li/r.li.shannon/shannon.c:48
-#: ../raster/r.li/r.li.simpson/simpson.c:48
-#: ../raster/r.li/r.li.dominance/dominance.c:48
-msgid "diversity index"
+#: ../raster/r.resamp.bspline/main.c:98
+#, fuzzy
+msgid "Name of raster map to use for masking"
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/main.c:99 ../vector/v.surf.bspline/main.c:130
+msgid "Only cells that are not NULL and not zero are interpolated"
msgstr ""
-#: ../raster/r.li/r.li.renyi/renyi.c:63
-msgid "Alpha value is the order of the generalized entropy"
+#: ../raster/r.resamp.bspline/main.c:107
+msgid ""
+"Length of each spline step in the east-west direction. Default: 1.5 * ewres."
msgstr ""
-#: ../raster/r.li/r.li.patchdensity/main.c:50
+#: ../raster/r.resamp.bspline/main.c:115
msgid ""
-"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+"Length of each spline step in the north-south direction. Default: 1.5 * "
+"nsres."
msgstr ""
-#: ../raster/r.li/r.li.daemon/worker.c:135
-#, c-format
-msgid "unable to open <%s> mask ... continuing without!"
+#: ../raster/r.resamp.bspline/main.c:119 ../vector/v.surf.bspline/main.c:153
+msgid "Spline interpolation algorithm"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:99
-msgid "Cannot create random access file"
+#: ../raster/r.resamp.bspline/main.c:125 ../vector/v.surf.bspline/main.c:160
+#: ../vector/v.lidar.correction/main.c:403 ../vector/v.outlier/main.c:407
+#: ../vector/v.lidar.edgedetection/main.c:413
+msgid "Bilinear interpolation"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:107
-#, fuzzy, c-format
-msgid "Cannot create %s/.grass7/ directory"
+#: ../raster/r.resamp.bspline/main.c:126 ../vector/v.surf.bspline/main.c:161
+#: ../vector/v.lidar.edgedetection/main.c:430
+msgid "Bicubic interpolation"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:132 ../vector/v.surf.bspline/main.c:167
+msgid "Tykhonov regularization parameter (affects smoothing)"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:138
+#, fuzzy
+msgid "Only interpolate null cells in input raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.daemon/daemon.c:113
-#, c-format
-msgid "Cannot create %s/.grass7/r.li/ directory"
+#: ../raster/r.resamp.bspline/main.c:144 ../vector/v.surf.bspline/main.c:101
+msgid ""
+"Find the best Tykhonov regularizing parameter using a \"leave-one-out\" "
+"cross validation method"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:120
-#, c-format
-msgid "Cannot create %s/.grass7/r.li/output/ directory"
+#: ../raster/r.resamp.bspline/main.c:151
+msgid "Maximum memory to be used (in MB)"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:203
-#, fuzzy, c-format
-msgid "Cannot find configuration file <%s>"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/main.c:186
+msgid "se must be positive"
+msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:210
-#: ../raster/r.li/r.li.daemon/daemon.c:214
-msgid "Cannot read setup file"
+#: ../raster/r.resamp.bspline/main.c:194
+msgid "sn must be positive"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:218
-#, fuzzy
-msgid "Unable to parse configuration file (sampling frame)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/main.c:221
+#, c-format
+msgid "spline step in ew direction %g"
+msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:477
-msgid "Irregular MASKEDOVERLAY areas definition"
+#: ../raster/r.resamp.bspline/main.c:222
+#, c-format
+msgid "spline step in ns direction %g"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:481
+#: ../raster/r.resamp.bspline/main.c:223 ../vector/v.outlier/main.c:288
+#: ../vector/v.lidar.edgedetection/main.c:294
#, c-format
-msgid "The configuration file can only be used with the <%s> raster map"
+msgid "adjusted EW splines %d"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:487
+#: ../raster/r.resamp.bspline/main.c:224 ../vector/v.outlier/main.c:289
+#: ../vector/v.lidar.edgedetection/main.c:295
+#, c-format
+msgid "adjusted NS splines %d"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:291 ../vector/v.surf.bspline/main.c:444
+msgid "Memory in MB must be >= 3"
+msgstr ""
+#: ../raster/r.resamp.bspline/main.c:307 ../raster/r.resamp.bspline/main.c:393
+#: ../raster/r.resamp.bspline/main.c:464 ../raster/r.cost/main.c:428
+#: ../raster/r.cost/main.c:433 ../vector/v.surf.bspline/main.c:458
+#: ../vector/v.surf.bspline/main.c:486
#, fuzzy
-msgid "Unable to parse configuration file (sample area)"
+msgid "Can not create temporary file"
msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.daemon/daemon.c:522
-msgid "Too many units to place"
-msgstr ""
+#: ../raster/r.resamp.bspline/main.c:312 ../raster/r.resamp.bspline/main.c:398
+#: ../raster/r.resamp.bspline/main.c:469 ../vector/v.surf.bspline/main.c:463
+#: ../vector/v.surf.bspline/main.c:491
+#, fuzzy
+msgid "Can not initialize temporary file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.daemon/daemon.c:591
+#: ../raster/r.resamp.bspline/main.c:318
+#, fuzzy, c-format
+msgid "Loading input raster <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/main.c:338
#, fuzzy
-msgid "Too many stratified random sample for raster map"
+msgid "Only NULL cells in input raster"
msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.daemon/daemon.c:625
-msgid "Illegal areas disposition"
+#: ../raster/r.resamp.bspline/main.c:362 ../vector/v.surf.bspline/main.c:298
+msgid "Cross validation didn't finish correctly"
msgstr ""
-#: ../raster/r.li/r.li.daemon/daemon.c:697
-msgid "Cannot make lseek"
+#: ../raster/r.resamp.bspline/main.c:366
+#, c-format
+msgid "Cross validation finished for se = %f and sn = %f"
msgstr ""
-#: ../raster/r.li/r.li.patchnum/main.c:49
-msgid ""
-"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+#: ../raster/r.resamp.bspline/main.c:386
+#, fuzzy
+msgid "Mark cells for interpolation"
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/main.c:457
+msgid "No NULL cells found in input raster."
msgstr ""
-#: ../raster/r.li/r.li.richness/richness.c:42
+#: ../raster/r.resamp.bspline/main.c:472 ../vector/v.surf.bspline/main.c:466
#, fuzzy
-msgid "Calculates richness index on a raster map"
+msgid "Initializing output..."
msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.shape/main.c:48
-msgid "Calculates shape index on a raster map"
+#: ../raster/r.resamp.bspline/main.c:545
+#: ../vector/v.lidar.correction/main.c:334
+#: ../vector/v.lidar.growing/main.c:246 ../vector/v.outlier/main.c:344
+#: ../vector/v.lidar.edgedetection/main.c:350
+#, c-format
+msgid "subregion %d of %d"
msgstr ""
-#: ../raster/r.li/r.li.padsd/padsd.c:52
-msgid "Calculates standard deviation of patch area a raster map"
+#: ../raster/r.resamp.bspline/main.c:719
+msgid "No data within this subregion. Consider increasing the spline step."
msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:44
+#: ../raster/r.resamp.bspline/main.c:735 ../vector/v.surf.bspline/main.c:883
+#, fuzzy
+msgid "Writing output..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/crosscorr.c:160
+#, c-format
msgid ""
-"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+"%d are too many cells, recommended are < 100 cells. The cross validation "
+"would take too much time."
msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:65
-msgid "The value of the patch type"
+#: ../raster/r.resamp.bspline/crosscorr.c:169
+#, fuzzy, c-format
+msgid "%d point read in region"
+msgid_plural "%d points read in region"
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/crosscorr.c:174
+msgid "Maybe it takes too long.Consider reducing the region extends."
msgstr ""
-#: ../raster/r.li/r.li.edgedensity/edgedensity.c:66
+#: ../raster/r.resamp.bspline/crosscorr.c:194
+#: ../vector/v.surf.bspline/crosscorr.c:151
+#, c-format
msgid ""
-"It can be integer, double or float; it will be changed in function of map "
-"type"
+"Too many splines (%d x %d). Consider changing spline steps \"sie=\" \"sin=\"."
msgstr ""
-#: ../raster/r.li/r.li.pielou/pielou.c:45
-#, fuzzy
-msgid "Calculates Pielou's diversity index on a raster map"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.bspline/crosscorr.c:212
+#, c-format
+msgid "Begining cross validation with lambda_i=%.4f..."
+msgstr ""
-#: ../raster/r.li/r.li.padcv/padcv.c:52
-msgid "Calculates coefficient of variation of patch area on a raster map"
+#: ../raster/r.resamp.bspline/crosscorr.c:297
+#: ../vector/v.surf.bspline/crosscorr.c:295
+#, c-format
+msgid "Mean = %.5lf"
msgstr ""
-#: ../raster/r.li/r.li.shannon/shannon.c:45
-msgid "Calculates Shannon's diversity index on a raster map"
+#: ../raster/r.resamp.bspline/crosscorr.c:298
+#, c-format
+msgid "Root Means Square (RMS) = %.5lf"
msgstr ""
-#: ../raster/r.li/r.li.mps/mps.c:51
+#: ../raster/r.resamp.bspline/crosscorr.c:314
+#: ../vector/v.surf.bspline/crosscorr.c:313
msgid ""
-"Calculates mean patch size index on a raster map, using a 4 neighbour "
-"algorithm"
+"Different number of splines and lambda_i values have been taken for the "
+"cross correlation"
msgstr ""
-#: ../raster/r.li/r.li.simpson/simpson.c:45
-msgid "Calculates Simpson's diversity index on a raster map"
+#: ../raster/r.resamp.bspline/crosscorr.c:316
+#: ../vector/v.surf.bspline/crosscorr.c:315
+#, c-format
+msgid ""
+"The minimum value for the test (rms=%lf) was obtained with: lambda_i = %.3f"
msgstr ""
-#: ../raster/r.li/r.li.dominance/dominance.c:45
-msgid "Calculates dominance's diversity index on a raster map"
+#: ../raster/r.resamp.bspline/crosscorr.c:324
+msgid "Results into a table:"
msgstr ""
-#: ../raster/r.li/r.li.padrange/padrange.c:52
-msgid "Calculates range of patch area size on a raster map"
+#: ../raster/r.resamp.bspline/crosscorr.c:325
+msgid " lambda | mean | rms |"
msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:53
-msgid "Calculates contrast weighted edge density index on a raster map"
+#: ../raster/r.resamp.bspline/crosscorr.c:327
+#, c-format
+msgid " %-10.5f| %-12.4f| %-12.4f|"
msgstr ""
-#: ../raster/r.li/r.li.cwed/cwed.c:70
-msgid "Name of file that contains the weight to calculate the index"
-msgstr ""
+#: ../raster/r.resamp.bspline/crosscorr.c:335
+#: ../vector/v.surf.bspline/crosscorr.c:334
+#, fuzzy
+msgid "No point lies into the current region"
+msgstr "출력할 래스터맵"
-#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:454
-#: ../raster/r.li/r.li.cwed/cwed.c:601
-msgid "Row cache is too small"
+#: ../raster/simwe/simlib/hydro.c:205
+#, c-format
+msgid "nwalk (%d) > maxw (%d)!"
msgstr ""
-#: ../raster/r.what/main.c:100 ../display/d.where/main.c:45
-#: ../display/d.what.rast/main.c:51 ../display/d.what.vect/main.c:58
-#: ../vector/v.what.rast3/main.c:67 ../vector/v.what/main.c:62
-#: ../vector/v.what.rast/main.c:74
+#: ../raster/simwe/simlib/hydro.c:400
#, fuzzy
-msgid "position"
+msgid "Unable to write raster maps"
msgstr "출력할 래스터맵"
-#: ../raster/r.what/main.c:102
-#, fuzzy
-msgid "Queries raster maps on their category values and category labels."
-msgstr "출력할 래스터맵"
+#: ../raster/simwe/simlib/hydro.c:467
+#: ../raster/simwe/r.sim.sediment/main.c:384
+msgid "Cannot write raster maps"
+msgstr ""
-#: ../raster/r.what/main.c:106
-msgid "Name of existing raster map(s) to query"
+#: ../raster/simwe/simlib/input.c:58
+#, c-format
+msgid ""
+"Raster map <%s> not found, and manin_val undefined, choose one to be allowed "
+"to process"
msgstr ""
-#: ../raster/r.what/main.c:109 ../vector/v.what/main.c:75
-msgid "Coordinates for query"
+#: ../raster/simwe/simlib/input.c:171
+msgid "Zero value in Mannings n"
msgstr ""
-#: ../raster/r.what/main.c:110 ../raster/r.what/main.c:116
-#: ../db/db.select/main.c:202 ../db/db.select/main.c:208
-#: ../db/db.select/main.c:212 ../db/db.select/main.c:254
-#: ../db/db.select/main.c:264 ../vector/v.to.db/parse.c:104
-#: ../vector/v.to.db/parse.c:112
-msgid "Query"
+#: ../raster/simwe/simlib/input.c:222
+msgid "Infiltration exceeds the rainfall rate everywhere! No overland flow."
msgstr ""
-#: ../raster/r.what/main.c:114
-#, fuzzy
-msgid "Name of vector points map for query"
-msgstr "출력할 래스터맵"
+#: ../raster/simwe/simlib/input.c:246
+#, c-format
+msgid ""
+"Min elevation \t= %.2f m\n"
+"Max elevation \t= %.2f m\n"
+msgstr ""
-#: ../raster/r.what/main.c:139
-msgid "Size of point cache"
+#: ../raster/simwe/simlib/input.c:248
+#, c-format
+msgid "Mean Source Rate (rainf. excess or sediment) \t= %f m/s or kg/m2s \n"
msgstr ""
-#: ../raster/r.what/main.c:141 ../raster/r.what/main.c:166
-#: ../display/d.legend/main.c:105 ../display/d.legend/main.c:114
-#: ../display/d.legend/main.c:188 ../display/d.legend/main.c:193
-#: ../display/d.legend/main.c:198 ../display/d.legend/main.c:208
-msgid "Advanced"
+#: ../raster/simwe/simlib/input.c:250
+#, c-format
+msgid "Mean flow velocity \t= %f m/s\n"
msgstr ""
-#: ../raster/r.what/main.c:145
-msgid "Output header row"
+#: ../raster/simwe/simlib/input.c:251
+#, c-format
+msgid "Mean Mannings \t= %f\n"
msgstr ""
-#: ../raster/r.what/main.c:150
-#, fuzzy
-msgid "Show the category labels of the grid cell(s)"
-msgstr "출력할 래스터맵"
+#: ../raster/simwe/simlib/input.c:255
+#, fuzzy, c-format
+msgid "Number of iterations \t= %d cell\n"
+msgid_plural "Number of iterations \t= %d cells\n"
-#: ../raster/r.what/main.c:155
-msgid "Output color values as RRR:GGG:BBB"
+#: ../raster/simwe/simlib/input.c:257
+#, c-format
+msgid "Time step \t= %.2f s\n"
msgstr ""
-#: ../raster/r.what/main.c:160
-msgid "Output integer category values, not cell values"
+#: ../raster/simwe/simlib/input.c:259
+#, c-format
+msgid ""
+"Sigmax \t= %f\n"
+"Max velocity \t= %f m/s\n"
msgstr ""
-#: ../raster/r.what/main.c:165
-msgid "Turn on cache reporting"
+#: ../raster/simwe/simlib/input.c:261
+#, c-format
+msgid "Time step used \t= %.2f s\n"
msgstr ""
-#: ../raster/r.what/main.c:205
+#: ../raster/simwe/simlib/input.c:313
+#, fuzzy
+msgid "Unable to write et file"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/simlib/output.c:321 ../raster/simwe/simlib/output.c:329
#, fuzzy, c-format
-msgid "Can only do up to %d raster maps (%d given)"
+msgid "FP raster map <%s> not found"
msgstr "출력할 래스터맵"
-#: ../raster/r.what/main.c:221
+#: ../raster/simwe/simlib/observation_points.c:59
#, fuzzy, c-format
-msgid "Unable to read category file for <%s>"
+msgid "Unable to read points from map %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.what/main.c:300
+#: ../raster/simwe/simlib/observation_points.c:80
#, fuzzy, c-format
-msgid "Unable to read vector map <%s>"
+msgid "Unable to open observation logfile %s for writing"
msgstr "출력할 래스터맵"
-#: ../raster/r.what/main.c:304
-#, c-format
-msgid "Line %d is not point or centroid, skipped"
+#: ../raster/simwe/r.sim.water/main.c:113
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
msgstr ""
-#: ../raster/r.what/main.c:388
-#, fuzzy, c-format
-msgid "%s %s is outside your current region"
+#: ../raster/simwe/r.sim.water/main.c:120
+#: ../raster/simwe/r.sim.sediment/main.c:128
+#, fuzzy
+msgid "Name of x-derivatives raster map [m/m]"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.rast3elev/main.c:99
-msgid "The number of input and elevation maps is not equal"
-msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:124
+#: ../raster/simwe/r.sim.sediment/main.c:132
+#, fuzzy
+msgid "Name of y-derivatives raster map [m/m]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.to.rast3elev/main.c:165
-msgid "The value to fill the upper cells, default is null"
-msgstr ""
+#: ../raster/simwe/r.sim.water/main.c:130
+#, fuzzy
+msgid "Name of rainfall excess rate (rain-infilt) raster map [mm/hr]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.to.rast3elev/main.c:172
-msgid "The value to fill the lower cells, default is null"
+#: ../raster/simwe/r.sim.water/main.c:139
+msgid "Rainfall excess rate unique value [mm/hr]"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:185
-msgid "Use the input map values to fill the upper cells"
+#: ../raster/simwe/r.sim.water/main.c:146
+#, fuzzy
+msgid "Name of runoff infiltration rate raster map [mm/hr]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:155
+msgid "Runoff infiltration rate unique value [mm/hr]"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:190
-msgid "Use the input map values to fill the lower cells"
+#: ../raster/simwe/r.sim.water/main.c:161
+#, fuzzy
+msgid "Name of the Manning's n raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:169
+#, fuzzy
+msgid "Manning's n unique value"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:176
+#, fuzzy
+msgid "Name of flow controls raster map (permeability ratio 0-1)"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:183
+#: ../raster/simwe/r.sim.sediment/main.c:174
+#, fuzzy
+msgid "Name of the sampling locations vector points map"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:184
+#: ../raster/simwe/r.sim.sediment/main.c:175 ../raster/r.sun/main.c:257
+#: ../raster/r.sun/main.c:266 ../raster/r.sun/main.c:275
+#: ../raster/r.sun/main.c:284 ../raster/r.sun/main.c:292
+#: ../raster/r.sun/main.c:301 ../raster/r.sun/main.c:311
+#: ../raster/r.sun/main.c:321 ../raster/r.sun/main.c:331
+#: ../raster/r.sun/main.c:341 ../raster/r.sun/main.c:350
+#: ../raster/r.sun/main.c:359 ../raster/r.sun/main.c:368
+#: ../raster/r.sun/main.c:376 ../raster/r.sun/main.c:384
+#: ../raster/r.horizon/main.c:199 ../raster/r.horizon/main.c:208
+#: ../raster/r.horizon/main.c:216 ../raster/r.horizon/main.c:224
+#: ../raster/r.horizon/main.c:232 ../raster/r.horizon/main.c:240
+#: ../raster/r.horizon/main.c:248 ../raster/r.horizon/main.c:256
+#: ../raster/r.horizon/main.c:264
+#, fuzzy
+msgid "Input options"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:190
+msgid ""
+"Name of the sampling points output text file. For each observation vector "
+"point the time series of water depth is stored."
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:194 ../raster3d/r3.cross.rast/main.c:109
-#: ../raster3d/r3.out.netcdf/main.c:116 ../raster3d/r3.out.ascii/main.c:121
-#: ../raster3d/r3.to.rast/main.c:91
-msgid "Use 3D raster mask (if exists) with input map"
+#: ../raster/simwe/r.sim.water/main.c:191
+#: ../raster/simwe/r.sim.water/main.c:197
+#: ../raster/simwe/r.sim.water/main.c:203
+#: ../raster/simwe/r.sim.water/main.c:209
+#: ../raster/simwe/r.sim.sediment/main.c:182
+#: ../raster/simwe/r.sim.sediment/main.c:188
+#: ../raster/simwe/r.sim.sediment/main.c:195
+#: ../raster/simwe/r.sim.sediment/main.c:202
+#: ../raster/simwe/r.sim.sediment/main.c:208
+#: ../raster/simwe/r.sim.sediment/main.c:215
+#: ../raster/r.grow.distance/main.c:162 ../raster/r.grow.distance/main.c:168
+#: ../raster/r.resamp.rst/main.c:176 ../raster/r.resamp.rst/main.c:184
+#: ../raster/r.resamp.rst/main.c:192 ../raster/r.resamp.rst/main.c:200
+#: ../raster/r.resamp.rst/main.c:208 ../raster/r.resamp.rst/main.c:216
+#: ../raster/r.resamp.rst/main.c:280 ../vector/v.in.ogr/main.c:159
+#: ../vector/v.in.ogr/main.c:262 ../vector/v.in.ogr/main.c:268
+#: ../vector/v.out.ascii/args.c:35 ../vector/v.out.ascii/args.c:81
+#: ../locale/scriptstrings/m.proj_to_translate.c:10
+#: ../locale/scriptstrings/m.proj_to_translate.c:23
+#: ../locale/scriptstrings/m.proj_to_translate.c:25
+#: ../locale/scriptstrings/m.proj_to_translate.c:27
+#: ../locale/scriptstrings/i.spectral_to_translate.c:10
+#: ../locale/scriptstrings/i.spectral_to_translate.c:12
+msgid "Output"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:287 ../raster/r.to.rast3elev/main.c:320
+#: ../raster/simwe/r.sim.water/main.c:196
#, fuzzy
-msgid "Error writing 3D raster double data"
+msgid "Name for output water depth raster map [m]"
msgstr "출력할 래스터맵"
-#: ../raster/r.to.rast3elev/main.c:366
-msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+#: ../raster/simwe/r.sim.water/main.c:202
+#, fuzzy
+msgid "Name for output water discharge raster map [m3/s]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:208
+#, fuzzy
+msgid "Name for output simulation error raster map [m]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:215
+#: ../raster/simwe/r.sim.sediment/main.c:167
+#, fuzzy
+msgid "Base name of the output walkers vector points map"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:216
+#: ../raster/simwe/r.sim.sediment/main.c:168 ../raster/r.sun/main.c:393
+#: ../raster/r.sun/main.c:402 ../raster/r.sun/main.c:411
+#: ../raster/r.sun/main.c:420 ../raster/r.sun/main.c:429
+#: ../raster/r.sun/main.c:438 ../raster/r.horizon/main.c:273
+#: ../raster/r.horizon/main.c:283 ../raster/r.horizon/main.c:291
+#, fuzzy
+msgid "Output options"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:223
+msgid "Number of walkers, default is twice the no. of cells"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:400
-msgid "The upper value is not valid"
+#: ../raster/simwe/r.sim.water/main.c:231
+#: ../raster/simwe/r.sim.sediment/main.c:229
+msgid "Time used for iterations [minutes]"
msgstr ""
-#: ../raster/r.to.rast3elev/main.c:410
-msgid "The lower value is not valid"
+#: ../raster/simwe/r.sim.water/main.c:240
+#: ../raster/simwe/r.sim.sediment/main.c:238
+msgid "Time interval for creating output maps [minutes]"
msgstr ""
-#: ../raster/r.horizon/main.c:182
-msgid "Horizon angle computation from a digital elevation model."
+#: ../raster/simwe/r.sim.water/main.c:258
+#: ../raster/simwe/r.sim.sediment/main.c:256
+msgid "Water diffusion constant"
msgstr ""
-#: ../raster/r.horizon/main.c:184
-msgid ""
-"Computes horizon angle height from a digital elevation model. The module has "
-"two different modes of operation: 1. Computes the entire horizon around a "
-"single point whose coordinates are given with the 'coord' option. The "
-"horizon height (in radians). 2. Computes one or more raster maps of the "
-"horizon height in a single direction. The input for this is the angle (in "
-"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
-"output is the horizon height in radians."
+#: ../raster/simwe/r.sim.water/main.c:267
+msgid "Threshold water depth [m]"
msgstr ""
-#: ../raster/r.horizon/main.c:198 ../raster/r.sun/main.c:256
-msgid "Name of the input elevation raster map [meters]"
+#: ../raster/simwe/r.sim.water/main.c:268
+msgid "Diffusion increases after this water depth is reached"
msgstr ""
-#: ../raster/r.horizon/main.c:207
-msgid "Direction in which you want to know the horizon height"
+#: ../raster/simwe/r.sim.water/main.c:276
+msgid "Diffusion increase constant"
msgstr ""
-#: ../raster/r.horizon/main.c:215 ../raster/r.sun/main.c:383
-msgid "Angle step size for multidirectional horizon [degrees]"
+#: ../raster/simwe/r.sim.water/main.c:285
+msgid "Weighting factor for water flow velocity vector"
msgstr ""
-#: ../raster/r.horizon/main.c:223
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer around the present "
-"region"
+#: ../raster/simwe/r.sim.water/main.c:290
+msgid "Time-series output"
msgstr ""
-#: ../raster/r.horizon/main.c:231
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer eastward the present "
-"region"
+#: ../raster/simwe/r.sim.water/main.c:432
+#: ../raster/simwe/r.sim.sediment/main.c:336
+msgid "More than 100 files are going to be created !!!!!"
msgstr ""
-#: ../raster/r.horizon/main.c:239
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer westward the present "
-"region"
+#: ../raster/simwe/r.sim.water/main.c:438
+#: ../raster/simwe/r.sim.sediment/main.c:342
+#, c-format
+msgid "default nwalk=%d, rwalk=%f"
msgstr ""
-#: ../raster/r.horizon/main.c:247
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer northward the present "
-"region"
+#: ../raster/simwe/r.sim.water/main.c:448
+#: ../raster/simwe/r.sim.sediment/main.c:351
+#, c-format
+msgid "Using metric conversion factor %f, step=%f"
msgstr ""
-#: ../raster/r.horizon/main.c:255
-msgid ""
-"For horizon rasters, read from the DEM an extra buffer southward the present "
-"region"
+#: ../raster/simwe/r.sim.water/main.c:452
+#, fuzzy
+msgid "You are not outputting any raster maps"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.water/main.c:455
+#: ../raster/simwe/r.sim.sediment/main.c:360 ../vector/v.vol.rst/main.c:879
+#: ../vector/v.surf.rst/main.c:626 ../vector/v.surf.rst/main.c:681
+msgid "Input failed"
msgstr ""
-#: ../raster/r.horizon/main.c:263
-msgid "The maximum distance to consider when finding the horizon height"
+#: ../raster/simwe/r.sim.sediment/main.c:113
+msgid "sediment flow"
msgstr ""
-#: ../raster/r.horizon/main.c:272
+#: ../raster/simwe/r.sim.sediment/main.c:115
+msgid "deposition"
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:117
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:124
#, fuzzy
-msgid "Prefix of the horizon raster output maps"
+msgid "Name of water depth raster map [m]"
msgstr "출력할 래스터맵"
-#: ../raster/r.horizon/main.c:282
-msgid "Coordinate for which you want to calculate the horizon"
-msgstr ""
+#: ../raster/simwe/r.sim.sediment/main.c:137
+#, fuzzy
+msgid "Name of detachment capacity coefficient raster map [s/m]"
+msgstr "출력할 래스터맵"
-#: ../raster/r.horizon/main.c:290 ../raster/r.sun/main.c:491
-msgid "Sampling distance step coefficient (0.5-1.5)"
+#: ../raster/simwe/r.sim.sediment/main.c:142
+#, fuzzy
+msgid "Name of transport capacity coefficient raster map [s]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:147
+#, fuzzy
+msgid "Name of critical shear stress raster map [Pa]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:152
+#, fuzzy
+msgid "Name of mannings n raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:160
+#, fuzzy
+msgid "Name of mannings n value"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:181
+msgid ""
+"point the time series of sediment transport is stored."
msgstr ""
-#: ../raster/r.horizon/main.c:297 ../raster/r.profile/main.c:61
-msgid "Name of file for output (use output=- for stdout)"
+#: ../raster/simwe/r.sim.sediment/main.c:187
+#, fuzzy
+msgid "Name for output transport capacity raster map [kg/ms]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:194
+#, fuzzy
+msgid "Name for output transp.limited erosion-deposition raster map [kg/m2s]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:201
+#, fuzzy
+msgid "Name for output sediment concentration raster map [particle/m3]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:207
+#, fuzzy
+msgid "Name for output sediment flux raster map [kg/ms]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:214
+#, fuzzy
+msgid "Name for output erosion-deposition raster map [kg/m2s]"
+msgstr "출력할 래스터맵"
+#: ../raster/simwe/r.sim.sediment/main.c:221
+msgid "Number of walkers"
msgstr ""
-#: ../raster/r.horizon/main.c:302
-msgid "Write output in degrees (default is radians)"
+#: ../raster/simwe/r.sim.sediment/main.c:357
+#, fuzzy
+msgid "You are not outputting any raster or site files"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.ppm/main.c:56
+#, fuzzy
+msgid "Converts a GRASS raster map to a PPM image file."
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.ppm/main.c:64
+msgid "Name for new PPM file (use '-' for stdout)"
msgstr ""
-#: ../raster/r.horizon/main.c:350
-msgid "Can't read the coordinates from the \"coordinate\" option."
+#: ../raster/r.out.ppm/main.c:68
+msgid "Output greyscale instead of color"
msgstr ""
-#: ../raster/r.horizon/main.c:377
-msgid "You didn't specify a direction value or step size. Aborting."
+#: ../raster/r.out.ppm/main.c:72
+msgid "Suppress printing of PPM header"
msgstr ""
-#: ../raster/r.horizon/main.c:382
-msgid "You didn't specify a horizon raster name. Aborting."
+#: ../raster/r.out.ppm/main.c:101 ../raster/r.out.ppm3/main.c:95
+#, c-format
+msgid "row = %d"
+msgid_plural "rows = %d"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC Raster columns
+#: ../raster/r.out.ppm/main.c:102 ../raster/r.out.ppm3/main.c:97
+#, fuzzy, c-format
+msgid "column = %d"
+msgid_plural "columns = %d"
+#: ../raster/r.out.ppm/main.c:124
+#, fuzzy, c-format
+msgid "Unable to open file <%s> for write"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.ppm/main.c:154
+msgid "Converting..."
msgstr ""
-#: ../raster/r.horizon/main.c:392
-msgid "You didn't specify an angle step size. Aborting."
+#: ../raster/r.out.ppm/main.c:234
+#, c-format
+msgid "File <%s> created"
msgstr ""
-#: ../raster/r.horizon/main.c:405
+#: ../raster/r.out.ascii/main.c:63
#, fuzzy
-msgid "Could not read bufferzone size. Aborting."
+msgid "Converts a raster map layer into a GRASS ASCII text file."
msgstr "출력할 래스터맵"
-#: ../raster/r.horizon/main.c:410 ../raster/r.horizon/main.c:416
-#: ../raster/r.horizon/main.c:423 ../raster/r.horizon/main.c:430
-#, c-format
-msgid "Could not read %s bufferzone size. Aborting."
+#: ../raster/r.out.ascii/main.c:72
+msgid "Name for output ASCII grid map (use out=- for stdout)"
msgstr ""
-#: ../raster/r.horizon/main.c:411
-msgid "east"
+#: ../raster/r.out.ascii/main.c:86
+msgid ""
+"Number of values printed before wrapping a line (only SURFER or MODFLOW "
+"format)"
msgstr ""
-#: ../raster/r.horizon/main.c:417
-msgid "west"
+#: ../raster/r.out.ascii/main.c:94
+msgid "String to represent null cell (GRASS grid only)"
msgstr ""
-#: ../raster/r.horizon/main.c:424
-msgid "south"
+#: ../raster/r.out.ascii/main.c:102
+msgid "Write SURFER (Golden Software) ASCII grid"
msgstr ""
-#: ../raster/r.horizon/main.c:431
-msgid "north"
+#: ../raster/r.out.ascii/main.c:106
+msgid "Write MODFLOW (USGS) ASCII array"
msgstr ""
-#: ../raster/r.horizon/main.c:436
-msgid "Could not read maximum distance. Aborting."
+#: ../raster/r.out.ascii/main.c:110
+msgid "Force output of integer values"
msgstr ""
-#: ../raster/r.horizon/main.c:441
-msgid "The distance value must be 0.5-1.5. Aborting."
+#: ../raster/r.out.ascii/main.c:117
+msgid "Failed to interpret dp as an integer"
msgstr ""
-#: ../raster/r.horizon/main.c:488 ../raster/r.sun/main.c:726
-#: ../general/g.region/printwindow.c:247 ../general/g.region/printwindow.c:503
-#: ../general/g.region/printwindow.c:622 ../display/d.where/main.c:107
-msgid "Can't get projection info of current location"
+#: ../raster/r.out.ascii/main.c:125
+msgid "Failed to interpret width as an integer"
msgstr ""
-#: ../raster/r.horizon/main.c:491 ../raster/r.sun/main.c:730
-#: ../general/g.region/printwindow.c:250 ../general/g.region/printwindow.c:506
-#: ../general/g.region/printwindow.c:625 ../display/d.where/main.c:110
-msgid "Can't get projection units of current location"
+#: ../raster/r.out.ascii/main.c:131
+msgid "Both -s and -h doesn't make sense"
msgstr ""
-#: ../raster/r.horizon/main.c:495 ../raster/r.sun/main.c:734
-#: ../general/g.region/printwindow.c:253 ../general/g.region/printwindow.c:509
-#: ../general/g.region/printwindow.c:628 ../display/d.grid/plot.c:349
-#: ../display/d.where/main.c:113 ../ps/ps.map/do_geogrid.c:272
-msgid "Can't get projection key values of current location"
+#: ../raster/r.out.ascii/main.c:134
+msgid "Use -M or -s, not both"
msgstr ""
-#: ../raster/r.horizon/main.c:1122
+#: ../raster/r.out.ascii/main.c:169
#, fuzzy, c-format
-msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
+msgid "Unable to read fp range for <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.compress/main.c:63 ../general/g.list/main.c:45
-#: ../general/g.dirseps/main.c:35 ../general/g.rename/main.c:44
-#: ../general/g.access/main.c:38 ../general/g.copy/main.c:42
-#: ../general/g.mlist/main.c:63 ../general/g.remove/main.c:102
-#: ../general/g.findetc/main.c:29 ../general/g.filename/main.c:40
-#: ../general/g.findfile/main.c:39 ../general/g.mremove/main.c:62
-#: ../locale/scriptstrings/t.rename_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:3
-#: ../locale/scriptstrings/t.create_to_translate.c:3
-#: ../locale/scriptstrings/t.list_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:3
-#: ../locale/scriptstrings/t.unregister_to_translate.c:3
-#: ../locale/scriptstrings/t.register_to_translate.c:3
-#: ../locale/scriptstrings/t.remove_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:3
-#: ../imagery/i.group/main.c:53 ../imagery/i.target/main.c:46
+#: ../raster/r.out.ascii/main.c:185
+#, fuzzy, c-format
+msgid "Read failed at row %d"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:108
#, fuzzy
-msgid "map management"
+msgid "Generates area statistics for raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.compress/main.c:64
-msgid "Compresses and decompresses raster maps."
+#: ../raster/r.stats/main.c:113 ../raster/r.report/parse.c:40
+#, fuzzy
+msgid "Name of raster map(s) to report on"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:130 ../raster/r.describe/main.c:68
+#: ../raster/r.report/parse.c:75
+msgid "String representing no data cell value"
msgstr ""
-#: ../raster/r.compress/main.c:72 ../display/d.what.rast/main.c:67
-msgid "Name of existing raster map(s)"
+#: ../raster/r.stats/main.c:140 ../raster/r.report/parse.c:103
+#, fuzzy
+msgid "Number of floating-point subranges to collect stats from"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:141 ../raster/r.stats/main.c:196
+#: ../raster/r.stats/main.c:201 ../raster/r.stats/main.c:216
+#: ../raster/r.stats/main.c:221 ../raster/r.report/parse.c:104
+#: ../raster/r.report/parse.c:148 ../raster/r.report/parse.c:154
+#, fuzzy
+msgid "Floating point"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:148 ../raster/r.report/parse.c:111
+msgid "Sort output statistics by cell counts"
msgstr ""
-#: ../raster/r.compress/main.c:76
-msgid "Uncompress the map"
+#: ../raster/r.stats/main.c:149 ../raster/r.report/parse.c:112
+#, fuzzy
+msgid "Default: sorted by categories or intervals"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:153 ../raster/r.report/parse.c:116
+msgid "Sort by cell counts in ascending order"
msgstr ""
-#: ../raster/r.compress/main.c:104
-#, c-format
-msgid "[%s] not found"
+#: ../raster/r.stats/main.c:154 ../raster/r.report/parse.c:117
+msgid "Sort by cell counts in descending order"
msgstr ""
-#: ../raster/r.compress/main.c:110
-#, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't uncompress"
+#: ../raster/r.stats/main.c:161
+msgid "Print area totals in square meters"
msgstr ""
-#: ../raster/r.compress/main.c:112
-#, c-format
-msgid "[%s] is a reclass file of map <%s> in mapset <%s> - can't compress"
+#: ../raster/r.stats/main.c:162 ../raster/r.stats/main.c:167
+#: ../raster/r.stats/main.c:173 ../raster/r.report/parse.c:60
+#, fuzzy
+msgid "Statistics"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:166
+msgid "Print cell counts (sortable)"
msgstr ""
-#: ../raster/r.compress/main.c:117
-#, c-format
-msgid "[%s] is a GDAL-linked map - can't (un)compress"
+#: ../raster/r.stats/main.c:172
+msgid "Print approximate (total percent may not be 100%) percents"
msgstr ""
-#: ../raster/r.compress/main.c:159
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes smaller"
+#: ../raster/r.stats/main.c:177
+msgid "Print category labels"
msgstr ""
-#: ../raster/r.compress/main.c:160
-#, c-format
-msgid "DONE: compressed file is %lu bytes smaller"
+#: ../raster/r.stats/main.c:181
+msgid "One cell (range) per line"
msgstr ""
-#: ../raster/r.compress/main.c:164
-#, c-format
-msgid "DONE: uncompressed file is %lu bytes bigger"
+#: ../raster/r.stats/main.c:185
+msgid "Print grid coordinates (east and north)"
msgstr ""
-#: ../raster/r.compress/main.c:165
+#: ../raster/r.stats/main.c:186 ../raster/r.stats/main.c:191
+#, fuzzy
+msgid "Coordinates"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:190
+msgid "Print x and y (column and row)"
+msgstr ""
+#: ../raster/r.stats/main.c:195
+msgid "Print averaged values instead of intervals (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:200
+msgid "Print raw indexes of floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:205 ../raster/r.report/parse.c:137
+#, fuzzy
+msgid "Do not report no data value"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:206 ../raster/r.stats/main.c:211
+#: ../raster/r.report/parse.c:138 ../raster/r.report/parse.c:143
+#, fuzzy
+msgid "No data"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stats/main.c:210 ../raster/r.report/parse.c:142
+msgid "Do not report cells where all maps have no data"
+msgstr ""
+#: ../raster/r.stats/main.c:215 ../raster/r.report/parse.c:147
+msgid "Report for cats floating-point ranges (floating-point maps only)"
+msgstr ""
+#: ../raster/r.stats/main.c:220 ../raster/r.report/parse.c:153
+msgid "Read floating-point map as integer (use map's quant rules)"
+msgstr ""
+#: ../raster/r.stats/main.c:237
#, c-format
-msgid "DONE: compressed file is %lu bytes bigger"
+msgid "'%s' must be greater than zero; using %s=255"
msgstr ""
-#: ../raster/r.compress/main.c:183
+#: ../raster/r.stats/main.c:307
#, c-format
-msgid "[%s] already uncompressed"
+msgid ""
+"Raster map <%s> is reading as integer map! Flag '-%c' and/or '%s' option "
+"will be ignored."
msgstr ""
-#: ../raster/r.compress/main.c:187
+#: ../raster/r.stats/main.c:323
#, c-format
-msgid "[%s] already compressed"
+msgid ""
+"Cats for raster map <%s> are either missing or have no explicit labels. "
+"Using %s=%d."
msgstr ""
-#: ../raster/r.compress/main.c:191
+#: ../raster/r.stats/main.c:329
#, c-format
msgid ""
-"\n"
-"%sCOMPRESS [%s]"
+"Flag '-%c' was given, using cats fp ranges of raster map <%s>, ignoring '%s' "
+"option"
msgstr ""
-#: ../raster/r.colors.out/raster3d_main.c:50
-#, fuzzy
-msgid "Exports the color table associated with a 3D raster map."
+#: ../raster/r.stats/main.c:335 ../raster/r.contour/main.c:146
+#, fuzzy, c-format
+msgid "Unable to read fp range of raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors.out/raster3d_main.c:56
-#: ../raster/r.colors.out/raster_main.c:55 ../vector/v.colors.out/main.c:61
-#, fuzzy
-msgid "Path to output rules file"
+#: ../raster/r.stats/main.c:362 ../raster/r.recode/read_rules.c:35
+#, fuzzy, c-format
+msgid "Unable to read range for map <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors.out/raster3d_main.c:57
-#: ../raster/r.colors.out/raster_main.c:56 ../vector/v.colors.out/main.c:62
+#: ../raster/r.stats/raw_stats.c:118
#, fuzzy
-msgid "If not given write to standard output"
+msgid "Invalid map type"
msgstr "출력할 래스터맵"
-#: ../raster/r.colors.out/raster3d_main.c:62
-#: ../raster/r.colors.out/raster_main.c:61 ../vector/v.colors.out/main.c:72
+#: ../raster/r.surf.fractal/process.c:54
#, fuzzy
-msgid "Output values as percentages"
+msgid "Unable to allocate data buffer. Check current region with g.region."
msgstr "출력할 래스터맵"
-#: ../raster/r.colors.out/raster3d_main.c:70
+#: ../raster/r.surf.fractal/spec_syn.c:61
+msgid "Preliminary surface calculations..."
+msgstr ""
+#: ../raster/r.surf.fractal/spec_syn.c:120
#, fuzzy, c-format
-msgid "Unable to read color table for raster3d map <%s>"
+msgid "Calculating surface %d (of %d)..."
msgstr "출력할 래스터맵"
-#: ../raster/r.colors.out/raster_main.c:49
-#, fuzzy
-msgid "Exports the color table associated with a raster map."
-msgstr "출력할 래스터맵"
+#: ../raster/r.surf.fractal/main.c:40
+msgid "fractal"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:42
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:48
+msgid "Fractal dimension of surface (2 < D < 3)"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:55
+msgid "Number of intermediate images to produce"
+msgstr ""
+#: ../raster/r.surf.fractal/main.c:79
+#, c-format
+msgid "Fractal dimension of %.2lf must be between 2 and 3."
+msgstr ""
#: ../raster/r.proj/bordwalk.c:216
msgid "Input raster map is outside current region"
msgstr ""
-#: ../raster/r.proj/main.c:146 ../misc/m.transform/main.c:317
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:3
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:390
-#: ../imagery/i.fft/main.c:79 ../imagery/i.pca/main.c:73
-#: ../imagery/i.ifft/main.c:78 ../vector/v.transform/main.c:71
-#: ../vector/v.proj/main.c:68
-#, fuzzy
-msgid "transformation"
-msgstr "출력할 래스터맵"
#: ../raster/r.proj/main.c:148
#, fuzzy
msgid "Re-projects a raster map from given location to the current location."
@@ -12069,10 +15146,8 @@
msgid "Target"
msgstr "출력할 래스터맵"
-#: ../raster/r.proj/main.c:190
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:127
-#: ../imagery/i.rectify/main.c:148
-msgid "Interpolation method to use"
+#: ../raster/r.proj/main.c:198 ../raster/r.in.gdal/main.c:104
+msgid "Cache size (MiB)"
msgstr ""
#: ../raster/r.proj/main.c:204
@@ -12136,12 +15211,12 @@
msgid "Checking location <%s> mapset <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.proj/main.c:305 ../vector/v.proj/main.c:193
-#: ../vector/v.net/args.c:118 ../vector/v.net/args.c:124
-#: ../vector/v.net/args.c:130 ../vector/v.net/args.c:134
-#: ../vector/v.net/args.c:144 ../vector/v.external/main.c:116
-#: ../vector/v.edit/main.c:86 ../vector/v.what.rast/main.c:120
-#: ../vector/v.select/main.c:88 ../vector/v.in.ogr/main.c:322
+#: ../raster/r.proj/main.c:305 ../vector/v.what.rast/main.c:120
+#: ../vector/v.edit/main.c:86 ../vector/v.proj/main.c:193
+#: ../vector/v.in.ogr/main.c:337 ../vector/v.select/main.c:88
+#: ../vector/v.external/main.c:116 ../vector/v.net/args.c:118
+#: ../vector/v.net/args.c:124 ../vector/v.net/args.c:130
+#: ../vector/v.net/args.c:134 ../vector/v.net/args.c:144
#, c-format
msgid "Required parameter <%s> not set"
msgstr ""
@@ -12220,530 +15295,736 @@
msgid "Output:"
msgstr ""
-#: ../raster/r.proj/main.c:497
+#: ../raster/r.proj/main.c:498
#, fuzzy
msgid "Projecting..."
msgstr "출력할 래스터맵"
#: ../raster/r.proj/readcell.c:65
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:70
-#: ../imagery/i.rectify/readcell.c:62
-msgid "Allocating memory and reading input map..."
+#, fuzzy
+msgid "Allocating memory and reading input raster map..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.quant/read_rules.c:50
+msgid "Old data range is empty"
msgstr ""
-#: ../raster/r.proj/readcell.c:91
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:98
-#: ../imagery/i.rectify/readcell.c:88 ../imagery/i.rectify/readcell.c:127
-msgid "Error writing segment file"
+#: ../raster/r.quant/read_rules.c:56
+#, c-format
+msgid "Old data range is %s to %s"
msgstr ""
-#: ../raster/r.proj/readcell.c:124
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:128
-#: ../imagery/i.rectify/readcell.c:115
-msgid "Internal error: cache miss on fully-cached map"
+#: ../raster/r.quant/read_rules.c:59
+msgid "Old integer data range is empty"
msgstr ""
-#: ../raster/r.proj/readcell.c:137
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:137
-#: ../imagery/i.rectify/readcell.c:124
-msgid "Error seeking on segment file"
+#: ../raster/r.quant/read_rules.c:61
+#, c-format
+msgid "Old integer data range is %d to %d"
msgstr ""
-#: ../raster/r.proj/readcell.c:140
-#: ../imagery/i.ortho.photo/i.ortho.rectify/readcell.c:140
+#: ../raster/r.quant/read_rules.c:83
+#, fuzzy, c-format
+msgid "unable to open input file <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.quant/read_rules.c:89
+#, c-format
+msgid ""
+"\n"
+"Enter the rule or 'help' for the format description or 'end' to exit:\n"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:112
+msgid "quant rules do not cover the whole range map"
+msgstr ""
+#: ../raster/r.quant/read_rules.c:158 ../raster/r.recode/read_rules.c:131
+#, c-format
+msgid "%s is not a valid rule"
+msgstr ""
+#: ../raster/r.quant/main.c:48
#, fuzzy
-msgid "Error reading segment file"
+msgid "quantization"
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:239
-msgid "sun energy"
+#: ../raster/r.quant/main.c:51
+msgid "Produces the quantization file for a floating-point map."
msgstr ""
-#: ../raster/r.sun/main.c:240
-msgid "Solar irradiance and irradiation model."
+#: ../raster/r.quant/main.c:59
+msgid "Raster map(s) to be quantized"
msgstr ""
-#: ../raster/r.sun/main.c:242
-msgid ""
-"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
-"for given day, latitude, surface and atmospheric conditions. Solar "
-"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
-"irradiance, daylight length) are saved in the map history file. "
-"Alternatively, a local time can be specified to compute solar incidence "
-"angle and/or irradiance raster maps. The shadowing effect of the topography "
-"is optionally incorporated."
+#: ../raster/r.quant/main.c:64
+#, fuzzy
+msgid "Path to rules file (\"-\" to read from stdin)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.quant/main.c:70
+msgid "Base map to take quant rules from"
msgstr ""
-#: ../raster/r.sun/main.c:265
-msgid ""
-"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
-"[decimal degrees]"
+#: ../raster/r.quant/main.c:75
+msgid "Floating point range: dmin,dmax"
msgstr ""
-#: ../raster/r.sun/main.c:274
-msgid "A single value of the orientation (aspect), 270 is south"
+#: ../raster/r.quant/main.c:81
+msgid "Integer range: min,max"
msgstr ""
-#: ../raster/r.sun/main.c:283
-msgid ""
-"Name of the input slope raster map (terrain slope or solar panel "
-"inclination) [decimal degrees]"
+#: ../raster/r.quant/main.c:86
+msgid "Truncate floating point data"
msgstr ""
-#: ../raster/r.sun/main.c:291
-msgid "A single value of inclination (slope)"
+#: ../raster/r.quant/main.c:90
+msgid "Round floating point data"
msgstr ""
-#: ../raster/r.sun/main.c:300
-msgid ""
-"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
+#: ../raster/r.quant/main.c:111
+msgid "-t, -r, rules=, basemap= and fprange= are mutually exclusive"
msgstr ""
-#: ../raster/r.sun/main.c:310
-msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
+#: ../raster/r.quant/main.c:119
+msgid "fprange= and range= must be used together"
msgstr ""
-#: ../raster/r.sun/main.c:320
-msgid "Name of the ground albedo coefficient input raster map [-]"
+#: ../raster/r.quant/main.c:129
+#, c-format
+msgid "%s is integer map, it can't be quantized"
msgstr ""
-#: ../raster/r.sun/main.c:330
-msgid "A single value of the ground albedo coefficient [-]"
+#: ../raster/r.quant/main.c:137
+msgid "Truncating..."
msgstr ""
-#: ../raster/r.sun/main.c:340
-#, fuzzy
-msgid "Name of input raster map containing latitudes [decimal degrees]"
+#: ../raster/r.quant/main.c:142
+msgid "Rounding..."
+msgstr ""
+#: ../raster/r.quant/main.c:150
+#, c-format
+msgid "%s is integer map, it can't be used as basemap"
+msgstr ""
+#: ../raster/r.quant/main.c:154
+#, fuzzy, c-format
+msgid "unable to read quant rules for basemap <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:349
-#, fuzzy
-msgid "Name of input raster map containing longitudes [decimal degrees]"
+#: ../raster/r.quant/main.c:161
+#, fuzzy, c-format
+msgid "invalid value for fprange= <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:358
+#: ../raster/r.quant/main.c:163
+#, c-format
+msgid "invalid value for range= <%s>"
+msgstr ""
+#: ../raster/r.quant/main.c:164
+#, c-format
+msgid "Setting quant rules for input map(s) to (%f,%f) -> (%d,%d)"
+msgstr ""
+#: ../raster/r.quant/main.c:177
+msgid "No rules specified. Quant table(s) not changed."
+msgstr ""
+#: ../raster/r.quant/main.c:185
+#, c-format
+msgid "New quant table created for %s"
+msgstr ""
+#: ../raster/r.in.gdal/main.c:84
#, fuzzy
-msgid ""
-"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
-"[0-1]"
+msgid "Imports raster data into a GRASS raster map using GDAL library."
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:367
+#: ../raster/r.in.gdal/main.c:90
#, fuzzy
-msgid ""
-"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
+msgid "Name of raster file to be imported"
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:375
-msgid "The horizon information input map prefix"
+#: ../raster/r.in.gdal/main.c:98
+msgid "Band to select (default is all bands)"
msgstr ""
-#: ../raster/r.sun/main.c:392
-msgid "Output incidence angle raster map (mode 1 only)"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:110
+#, fuzzy
+msgid "Name of GCPs target location"
+msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:401
+#: ../raster/r.in.gdal/main.c:112
msgid ""
-"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+"Name of location to create or to read projection from for GCPs transformation"
msgstr ""
-#: ../raster/r.sun/main.c:410
+#: ../raster/r.in.gdal/main.c:128
msgid ""
-"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
-"day-1] (mode 2)"
+"The offset will be added to the band number while output raster map name "
+"creation"
msgstr ""
-#: ../raster/r.sun/main.c:419
-msgid ""
-"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
-"map [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.in.gdal/main.c:135 ../vector/v.in.lidar/main.c:180
+#: ../vector/v.in.ogr/main.c:212
+msgid "Name for new location to create"
msgstr ""
-#: ../raster/r.sun/main.c:428
-msgid ""
-"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
-"irradiation raster map [Wh.m-2.day-1] (mode 2)"
+#: ../raster/r.in.gdal/main.c:141 ../raster/r.external/main.c:100
+#: ../locale/scriptstrings/t.vect.import_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.import_to_translate.c:13
+msgid "Override projection (use location's projection)"
msgstr ""
-#: ../raster/r.sun/main.c:437
-msgid "Output insolation time raster map [h] (mode 2 only)"
+#: ../raster/r.in.gdal/main.c:145 ../raster/r.external/main.c:104
+#: ../raster/r.in.lidar/main.c:248 ../vector/v.in.lidar/main.c:213
+#: ../vector/v.in.ogr/main.c:286
+msgid "Extend region extents based on new dataset"
msgstr ""
-#: ../raster/r.sun/main.c:444
-msgid "No. of day of the year (1-365)"
+#: ../raster/r.in.gdal/main.c:147 ../raster/r.external/main.c:105
+#: ../vector/v.in.ogr/main.c:288
+msgid "Also updates the default region if in the PERMANENT mapset"
msgstr ""
-#: ../raster/r.sun/main.c:453
-msgid "Time step when computing all-day radiation sums [decimal hours]"
+#: ../raster/r.in.gdal/main.c:151 ../raster/r.external/main.c:93
+#: ../raster/r.external.out/main.c:250 ../vector/v.external.out/args.c:49
+#: ../vector/v.external/args.c:40
+msgid "List supported formats and exit"
msgstr ""
-#: ../raster/r.sun/main.c:460
-msgid "Declination value (overriding the internally computed value) [radians]"
+#: ../raster/r.in.gdal/main.c:158
+msgid "Force Lat/Lon maps to fit into geographic coordinates (90N,S; 180E,W)"
msgstr ""
-#: ../raster/r.sun/main.c:468
-msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+#: ../raster/r.in.gdal/main.c:163
+msgid "Keep band numbers instead of using band color names"
msgstr ""
-#: ../raster/r.sun/main.c:499
-msgid "Read the input files in this number of chunks"
+#: ../raster/r.in.gdal/main.c:168
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the raster file."
msgstr ""
-#: ../raster/r.sun/main.c:506
-msgid "Civil time zone value, if none, the time will be local solar time"
+#: ../raster/r.in.gdal/main.c:193
+msgid "You have to specify a target location different from output location"
msgstr ""
-#: ../raster/r.sun/main.c:512
-msgid "Do not incorporate the shadowing effect of terrain"
+#: ../raster/r.in.gdal/main.c:197
+msgid "You need to specify valid location name."
msgstr ""
-#: ../raster/r.sun/main.c:517
-msgid "Use the low-memory version of the program"
+#: ../raster/r.in.gdal/main.c:201
+msgid "The '-l' flag only works in Lat/Lon locations"
msgstr ""
-#: ../raster/r.sun/main.c:558
-msgid "You must give the longitude raster if you use civil time"
+#: ../raster/r.in.gdal/main.c:219
+msgid "Available GDAL Drivers:"
msgstr ""
-#: ../raster/r.sun/main.c:561
-#, fuzzy
-msgid "Error reading civil time zone value"
+#: ../raster/r.in.gdal/main.c:244 ../vector/v.kernel/main.c:236
+#, fuzzy, c-format
+msgid "Raster map <%s> already exists"
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:564
-msgid "Invalid civil time zone value"
+#: ../raster/r.in.gdal/main.c:262
+#, c-format
+msgid ""
+"Input seems to be NOAA/AVHRR data which needs to be georeferenced with thin "
+"plate spline transformation (%s or %s)."
msgstr ""
-#: ../raster/r.sun/main.c:589
-msgid "insol_time and incidout are incompatible options"
+#: ../raster/r.in.gdal/main.c:283
+msgid ""
+"Input raster map is flipped or rotated - cannot import. You may use "
+"'gdalwarp' to transform the map to North-up."
msgstr ""
-#: ../raster/r.sun/main.c:594
-#, fuzzy
-msgid "Error reading time step size"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.gdal/main.c:324
+msgid ""
+"Map bounds have been constrained to geographic coordinates. You will almost "
+"certainly want to check map bounds and resolution with r.info and reset them "
+"with r.region before going any further."
+msgstr ""
-#: ../raster/r.sun/main.c:596
-#, fuzzy
-msgid "Invalid time step size"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.gdal/main.c:344 ../raster/r.in.gdal/main.c:668
+#: ../vector/v.in.lidar/main.c:343 ../vector/v.in.ogr/main.c:672
+msgid ""
+"Unable to convert input map projection to GRASS format; cannot create new "
+"location."
+msgstr ""
-#: ../raster/r.sun/main.c:600
-#, fuzzy
-msgid "Error reading horizon step size"
+#: ../raster/r.in.gdal/main.c:350 ../raster/r.in.gdal/main.c:692
+#: ../vector/v.in.lidar/main.c:349 ../vector/v.in.ogr/main.c:678
+#, fuzzy, c-format
+msgid "Unable to create new location <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:604
-msgid "The horizon step size must be greater than 0."
-msgstr ""
-#: ../raster/r.sun/main.c:607
+#: ../raster/r.in.gdal/main.c:365 ../raster/r.external/proj.c:18
msgid ""
-"If you use the horizon option you must also set the 'horizonstep' parameter."
+"Unable to convert input raster map projection information to GRASS format "
+"for checking"
msgstr ""
-#: ../raster/r.sun/main.c:613
-msgid "Time and insol_time are incompatible options"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:381 ../raster/r.external/proj.c:34
+#: ../raster/r.in.lidar/main.c:334 ../vector/v.in.lidar/main.c:386
+#: ../vector/v.in.ogr/main.c:712
+#, fuzzy
+msgid "Over-riding projection check"
+msgstr "출력할 래스터맵"
-#: ../raster/r.sun/main.c:615
+#: ../raster/r.in.gdal/main.c:391 ../raster/r.external/proj.c:42
+#: ../raster/r.in.lidar/main.c:343 ../vector/v.in.lidar/main.c:395
+#: ../vector/v.in.ogr/main.c:721
msgid ""
-"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
-"time"
+"Projection of dataset does not appear to match current location.\n"
+"\n"
msgstr ""
-#: ../raster/r.sun/main.c:620
-msgid "incidout requires time parameter to be set"
+#: ../raster/r.in.gdal/main.c:396 ../raster/r.external/proj.c:47
+msgid "Location PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.sun/main.c:622
-msgid "Mode 2: integrated daily irradiation for a given day of the year"
+#: ../raster/r.in.gdal/main.c:407 ../raster/r.external/proj.c:58
+msgid "Dataset PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.sun/main.c:668
-msgid "If you use -s and no horizon rasters, numpartitions must be =1"
+#: ../raster/r.in.gdal/main.c:443 ../raster/r.external/proj.c:85
+#: ../raster/r.in.lidar/main.c:359 ../raster/r.in.lidar/main.c:366
+#: ../vector/v.in.lidar/main.c:411 ../vector/v.in.lidar/main.c:418
+#: ../vector/v.in.ogr/main.c:737 ../vector/v.in.ogr/main.c:744
+msgid "Import dataset PROJ_INFO is:\n"
msgstr ""
-#: ../raster/r.sun/main.c:681
+#: ../raster/r.in.gdal/main.c:465
msgid ""
-"If you want to save memory and to use shadows, you must use pre-calculated "
-"horizons."
+"\n"
+"You can use the -o flag to r.in.gdal to override this check and use the "
+"location definition for the dataset.\n"
msgstr ""
-#: ../raster/r.sun/main.c:748
-msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
+#: ../raster/r.in.gdal/main.c:468 ../raster/r.external/proj.c:110
+msgid ""
+"Consider generating a new location from the input dataset using the "
+"'location' parameter.\n"
msgstr ""
-#: ../raster/r.sun/main.c:753
-msgid "Both latin and longin raster maps must be given, or neither"
+#: ../raster/r.in.gdal/main.c:473 ../raster/r.external/proj.c:115
+#: ../raster/r.in.lidar/main.c:417 ../vector/v.in.lidar/main.c:469
+#: ../vector/v.in.ogr/main.c:795
+msgid "Projection of input dataset and current location appear to match"
msgstr ""
-#: ../raster/r.profile/main.c:51 ../display/d.profile/main.c:192
-#: ../raster3d/r3.cross.rast/main.c:229
-msgid "profile"
+#: ../raster/r.in.gdal/main.c:479 ../raster/r.external/main.c:176
+msgid "Proceeding with import..."
msgstr ""
-#: ../raster/r.profile/main.c:53
-msgid "Outputs the raster map layer values lying on user-defined line(s)."
+#: ../raster/r.in.gdal/main.c:504 ../raster/r.external/main.c:192
+#, c-format
+msgid "Selected band (%d) does not exist"
msgstr ""
-#: ../raster/r.profile/main.c:66 ../display/d.profile/main.c:206
-msgid "Profile coordinate pairs"
-msgstr ""
-#: ../raster/r.profile/main.c:72
-#, fuzzy
-msgid "Name of input file containing coordinate pairs"
+#: ../raster/r.in.gdal/main.c:530
+#, fuzzy, c-format
+msgid "Unable to get raster band number %d"
msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:74
-#, fuzzy
-msgid "Use instead of the 'coordinates' option. \"-\" reads from stdin."
+#: ../raster/r.in.gdal/main.c:591
+#, fuzzy, c-format
+msgid "Copying %d GCPS in points file for <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:82
-msgid "Resolution along profile (default = current region resolution)"
+#: ../raster/r.in.gdal/main.c:599
+msgid "GCPs have the following OpenGIS WKT Coordinate System:"
msgstr ""
-#: ../raster/r.profile/main.c:89
-msgid "Character to represent no data cell"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:622
+#, fuzzy
+msgid "Re-projecting GCPs table:"
+msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:99
-msgid "Output RRR:GGG:BBB color values for each profile point"
+#: ../raster/r.in.gdal/main.c:623
+#, c-format
+msgid "* Input projection for GCP table: %s"
msgstr ""
-#: ../raster/r.profile/main.c:114
-msgid "Either use profile option or coordinate_file option, but not both"
+#: ../raster/r.in.gdal/main.c:625
+#, c-format
+msgid "* Output projection for GCP table: %s"
msgstr ""
-#: ../raster/r.profile/main.c:123
+#: ../raster/r.in.gdal/main.c:646
#, c-format
-msgid "Illegal resolution! [%g]"
+msgid "Error in pj_do_proj (can't re-projection GCP %i)"
msgstr ""
-#: ../raster/r.profile/main.c:130
+#: ../raster/r.in.gdal/main.c:701
#, c-format
-msgid "Using resolution [%g]"
+msgid ""
+"The target for the output group <%s> has been set to location <%s>, mapset "
+"<PERMANENT>."
msgstr ""
-#: ../raster/r.profile/main.c:161
-msgid "Output Format:"
+#: ../raster/r.in.gdal/main.c:741 ../raster/r.external/window.c:93
+#: ../vector/v.in.ogr/main.c:1550
+msgid "Default region for this location updated"
msgstr ""
-#: ../raster/r.profile/main.c:164
-#, c-format
-msgid "[Easting] [Northing] [Along Track Dist.(m)] [Elevation]"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:744 ../raster/r.external/window.c:96
+#: ../vector/v.in.ogr/main.c:1553
+#, fuzzy
+msgid "Region for the current mapset updated"
+msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:166
-#, c-format
-msgid "[Along Track Dist.(m)] [Elevation]"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:774
+#, fuzzy
+msgid "Unable to translate projection key values of input GCPs"
+msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:168
-msgid " [RGB Color]"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:790
+#, fuzzy
+msgid "Unable to get projection info of target location"
+msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:179
+#: ../raster/r.in.gdal/main.c:792
+#, fuzzy
+msgid "Unable to get projection units of target location"
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.gdal/main.c:794
+#, fuzzy
+msgid "Unable to get projection key values of target location"
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.gdal/main.c:1241
#, fuzzy, c-format
-msgid "Could not open <%s>"
+msgid "Setting grey color table for <%s> (8bit, full range)"
msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:186
-#, c-format
-msgid "Invalid coordinates %s %s"
-msgstr ""
+#: ../raster/r.in.gdal/main.c:1255
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (16bit, image range)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.profile/main.c:257
-#, c-format
-msgid "Approx. transect length [%f] m"
+#: ../raster/r.null/main.c:60
+#, fuzzy
+msgid "null data"
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:61
+#, fuzzy
+msgid "Manages NULL-values of given raster map."
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:64
+#, fuzzy
+msgid "Name of raster map for which to edit null values"
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:85
+msgid "Only do the work if the map is floating-point"
msgstr ""
-#: ../raster/r.profile/main.c:260
-msgid "Endpoint coordinates are outside of current region settings"
+#: ../raster/r.null/main.c:86 ../raster/r.null/main.c:91
+#: ../raster/r.null/main.c:97
+msgid "Check"
msgstr ""
-#: ../raster/r.profile/input.c:30 ../raster/r.profile/input.c:47
-#: ../raster/r.profile/input.c:60
-msgid "One coordinate pair per line, please"
+#: ../raster/r.null/main.c:90
+msgid "Only do the work if the map is integer"
msgstr ""
-#: ../raster/r.solute.transport/main.c:59
-msgid "The initial concentration in [kg/m^3]"
+#: ../raster/r.null/main.c:96
+msgid "Only do the work if the map doesn't have a NULL-value bitmap file"
msgstr ""
-#: ../raster/r.solute.transport/main.c:63
-msgid "The piezometric head in [m]"
+#: ../raster/r.null/main.c:102
+msgid "Create NULL-value bitmap file validating all data cells"
msgstr ""
-#: ../raster/r.solute.transport/main.c:68
-msgid "The x-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.null/main.c:106
+msgid "Remove NULL-value bitmap file"
msgstr ""
-#: ../raster/r.solute.transport/main.c:73
-msgid "The y-part of the hydraulic conductivity tensor in [m/s]"
+#: ../raster/r.null/main.c:107 ../raster/r.colors/edit_colors.c:116
+#: ../vector/v.colors/main.c:123
+#: ../locale/scriptstrings/g.extension_to_translate.c:27
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:13
+#: ../locale/scriptstrings/r.mask_to_translate.c:20
+msgid "Remove"
msgstr ""
-#: ../raster/r.solute.transport/main.c:79
+#: ../raster/r.null/main.c:125
+#, c-format
msgid ""
-"The status for each cell, = 0 - inactive cell, 1 - active cell, 2 - "
-"dirichlet- and 3 - transfer boundary condition"
+"Raster map <%s> is a reclass of map <%s@%s>. Consider to generate a copy "
+"with r.mapcalc. Exiting."
msgstr ""
-#: ../raster/r.solute.transport/main.c:85
-msgid "The x-part of the diffusion tensor in [m^2/s]"
-msgstr ""
+#: ../raster/r.null/main.c:131
+#, fuzzy, c-format
+msgid "Raster map <%s> is not in your mapset <%s>"
+msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:90
-msgid "The y-part of the diffusion tensor in [m^2/s]"
+#: ../raster/r.null/main.c:138
+#, c-format
+msgid "%s is illegal entry for null"
msgstr ""
-#: ../raster/r.solute.transport/main.c:94
-#: ../raster/r.solute.transport/main.c:102
-#: ../raster/r.solute.transport/main.c:138
-#: ../raster/r.solute.transport/main.c:145
-msgid "Water flow"
-msgstr ""
+#: ../raster/r.null/main.c:145
+#, fuzzy, c-format
+msgid "Raster map <%s> already has a null bitmap file"
+msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:96
-msgid "Groundwater sources and sinks in [m^3/s]"
-msgstr ""
+#: ../raster/r.null/main.c:149
+#, fuzzy, c-format
+msgid "<%s> is integer raster map (CELL)"
+msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:103
-msgid ""
-"Concentration sources and sinks bounded to a water source or sink in [kg/s]"
+#: ../raster/r.null/main.c:153
+#, fuzzy, c-format
+msgid "<%s> is integer raster map (CELL). Using null=%d."
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:159
+#, fuzzy, c-format
+msgid "<%s> is floating pointing raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:175
+#, fuzzy, c-format
+msgid "Writing new null file for raster map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:185 ../raster/r.null/main.c:198
+#, fuzzy, c-format
+msgid "Raster map <%s> modified."
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:192
+#, fuzzy, c-format
+msgid "Removing null file for raster map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:262
+#, fuzzy, c-format
+msgid "%s: %s: illegal value spec"
+msgstr "출력할 래스터맵"
+#: ../raster/r.null/main.c:264
+#, c-format
+msgid "%s: illegal value spec"
msgstr ""
-#: ../raster/r.solute.transport/main.c:112
-msgid ""
-"Concentration of inner sources and inner sinks in [kg/s] (i.e. a chemical "
-"reaction)"
+#: ../raster/r.null/main.c:325
+#, fuzzy, c-format
+msgid "Writing new data for raster map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.ppm3/main.c:59
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
msgstr ""
-#: ../raster/r.solute.transport/main.c:117
-msgid "Retardation factor [-]"
+#: ../raster/r.out.ppm3/main.c:64 ../raster/r.composite/main.c:90
+#, c-format
+msgid "Name of raster map to be used for <%s>"
msgstr ""
-#: ../raster/r.solute.transport/main.c:121
-msgid "Effective porosity [-]"
+#: ../raster/r.out.ppm3/main.c:84
+msgid "Name for new PPM file. (use out=- for stdout)"
msgstr ""
-#: ../raster/r.solute.transport/main.c:125
-msgid "Top surface of the aquifer in [m]"
+#: ../raster/r.out.ppm3/main.c:88
+msgid "Add comments to describe the region"
msgstr ""
-#: ../raster/r.solute.transport/main.c:129
-msgid "Bottom surface of the aquifer in [m]"
+#: ../raster/r.out.ppm3/main.c:160
+msgid "Converting ... "
msgstr ""
-#: ../raster/r.solute.transport/main.c:132
+#: ../raster/r.series.interp/main.c:68
msgid ""
-"The resulting concentration of the numerical solute transport calculation "
-"will be written to this map. [kg/m^3]"
+"Interpolate raster maps located (temporal or spatial) in between input "
+"raster maps at specific sampling positions."
msgstr ""
-#: ../raster/r.solute.transport/main.c:140
+#: ../raster/r.series.interp/main.c:78
+#, fuzzy
+msgid "Data point position for each input map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:83
msgid ""
-"Calculate and store the groundwater filter velocity vector part in x "
-"direction [m/s]\n"
+"Input file with an input raster map name and data point position per line, "
+"field separator between name and sample point is |"
msgstr ""
-#: ../raster/r.solute.transport/main.c:147
+#: ../raster/r.series.interp/main.c:95
+#, fuzzy
+msgid "Sampling point position for each output map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:99
msgid ""
-"Calculate and store the groundwater filter velocity vector part in y "
+"Input infile with an output raster map name and sample point position per "
+"line, field separator between name and sample point is |"
msgstr ""
-#: ../raster/r.solute.transport/main.c:161
-msgid "The longditudinal dispersivity length. [m]"
+#: ../raster/r.series.interp/main.c:109
+msgid "Interpolation method, currently only linear interpolation is supported"
msgstr ""
-#: ../raster/r.solute.transport/main.c:169
-msgid "The transversal dispersivity length. [m]"
+#: ../raster/r.series.interp/main.c:116
+msgid "output= and outfile= are mutually exclusive"
msgstr ""
-#: ../raster/r.solute.transport/main.c:177
-msgid ""
-"Use this number of time loops if the CFL flag is off. The timestep will "
-"become dt/loops."
+#: ../raster/r.series.interp/main.c:119
+msgid "samplingpos= and outfile= are mutually exclusive"
msgstr ""
-#: ../raster/r.solute.transport/main.c:187
-msgid "Set the flow stabilizing scheme (full or exponential upwinding)."
-msgstr ""
+#: ../raster/r.series.interp/main.c:122
+#, fuzzy
+msgid "Please specify output= or outfile="
+msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:192 ../raster3d/r3.gwflow/main.c:131
-msgid ""
-"Use a full filled quadratic linear equation system, default is a sparse "
-"linear equation system."
+#: ../raster/r.series.interp/main.c:125
+#, fuzzy
+msgid "Please specify output= and samplingpos="
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:128
+msgid "input= and infile= are mutually exclusive"
msgstr ""
-#: ../raster/r.solute.transport/main.c:199
-msgid "Use the Courant-Friedrichs-Lewy criteria for time step calculation"
+#: ../raster/r.series.interp/main.c:131
+msgid "datapos= and infile= are mutually exclusive"
msgstr ""
-#: ../raster/r.solute.transport/main.c:231
+#: ../raster/r.series.interp/main.c:134
#, fuzzy
-msgid "solute transport"
+msgid "Please specify input= or infile="
msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:233
-msgid ""
-"Numerical calculation program for transient, confined and unconfined solute "
-"transport in two dimensions"
-msgstr ""
+#: ../raster/r.series.interp/main.c:137
+#, fuzzy
+msgid "Please specify input= and datapos="
+msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:258
-msgid "The direct LU solver do not work with sparse matrices"
+#: ../raster/r.series.interp/main.c:170 ../raster/r.colors/edit_colors.c:205
+#, fuzzy, c-format
+msgid "Unable to open %s file <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:203
+#, c-format
+msgid "Missing point position for %s map <%s> in file <%s> near line %i"
msgstr ""
-#: ../raster/r.solute.transport/main.c:260
-msgid "The direct Gauss solver do not work with sparse matrices"
+#: ../raster/r.series.interp/main.c:218 ../raster/r.series.interp/main.c:252
+#, fuzzy, c-format
+msgid "Preparing %s map <%s> at position %g"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:222
+#, fuzzy, c-format
+msgid "No raster map name found in %s file <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:233
+#, fuzzy, c-format
+msgid "No %s raster map not found"
+msgstr "출력할 래스터맵"
+#: ../raster/r.series.interp/main.c:240
+#, c-format
+msgid "The number of %s maps and %s point positions must be equal"
msgstr ""
-#: ../raster/r.solute.transport/main.c:370
+#: ../raster/r.series.interp/main.c:269
#, c-format
-msgid "The Courant-Friedrichs-Lewy criteria is %g it should be within [0:1]"
+msgid "Start interpolation run with %i input maps and %i output maps"
msgstr ""
-#: ../raster/r.solute.transport/main.c:371
+#: ../raster/r.series.interp/main.c:289
#, c-format
-msgid "The largest stable time step is %g"
+msgid ""
+"map <%s> at position %g was not interpolated. Check the interpolation "
+"interval."
msgstr ""
-#: ../raster/r.solute.transport/main.c:380
-#, fuzzy, c-format
-msgid "Number of inner loops is %g"
+#: ../raster/r.series.interp/main.c:309
+#, fuzzy
+msgid "At least 2 input maps are required for linear interpolation"
msgstr "출력할 래스터맵"
-#: ../raster/r.solute.transport/main.c:381
+#: ../raster/r.series.interp/main.c:327
#, c-format
-msgid "Time step for each loop %g"
+msgid "Interpolate map <%s> at position %g in interval (%g;%g)"
msgstr ""
-#: ../raster/r.solute.transport/main.c:385
-#, c-format
-msgid ""
-"The time step is to large: %gs. The largest time step should be of size %gs."
+#: ../raster/r.tile/main.c:45
+#, fuzzy
+msgid "Splits a raster map into tiles."
+msgstr "출력할 래스터맵"
+#: ../raster/r.tile/main.c:54
+#, fuzzy
+msgid "Output base name"
+msgstr "출력할 래스터맵"
+#: ../raster/r.tile/main.c:61
+msgid "Width of tiles"
msgstr ""
-#: ../raster/r.solute.transport/main.c:397
-#, c-format
-msgid "Time step %i with time sum %g"
+#: ../raster/r.tile/main.c:68
+msgid "Height of tiles"
msgstr ""
-#: ../raster/r.solute.transport/main.c:543
-msgid "Could not create and solve the linear equation system"
+#: ../raster/r.tile/main.c:75
+#, fuzzy
+msgid "Overlap of tiles"
+msgstr "출력할 래스터맵"
+#: ../raster/r.tile/main.c:177
+#, fuzzy, c-format
+msgid "Unable to read cats for %s"
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.poly/get_item.c:76
+#, fuzzy, c-format
+msgid "Illegal coordinate <%s, %s>, skipping."
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.poly/get_item.c:81
+#, fuzzy, c-format
+msgid "Illegal north coordinate <%s>, skipping."
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.poly/get_item.c:86
+#, fuzzy, c-format
+msgid "Illegal east coordinate <%s>, skipping."
+msgstr "출력할 래스터맵"
+#: ../raster/r.in.poly/main.c:32
+msgid "Creates raster maps from ASCII polygon/line/point data files."
msgstr ""
-#: ../raster/r.slope.aspect/main.c:152 ../raster/r.shaded.relief/main.c:108
-#: ../imagery/i.topo.corr/main.c:48
+#: ../raster/r.in.poly/main.c:36
#, fuzzy
-msgid "terrain"
+msgid "Name of input file; or \"-\" to read from stdin"
msgstr "출력할 래스터맵"
+#: ../raster/r.in.poly/main.c:51 ../vector/v.to.rast/main.c:116
+msgid "Number of rows to hold in memory"
+msgstr ""
+#: ../raster/r.in.poly/main.c:60
+msgid "Minimum number of rows to hold in memory is 1"
+msgstr ""
#: ../raster/r.slope.aspect/main.c:153
msgid ""
"Generates raster maps of slope, aspect, curvatures and partial derivatives "
@@ -12759,6 +16040,31 @@
msgid "Name for output slope raster map"
msgstr "출력할 래스터맵"
+#: ../raster/r.slope.aspect/main.c:163 ../raster/r.slope.aspect/main.c:169
+#: ../raster/r.slope.aspect/main.c:194 ../raster/r.slope.aspect/main.c:201
+#: ../raster/r.slope.aspect/main.c:208 ../raster/r.slope.aspect/main.c:215
+#: ../raster/r.slope.aspect/main.c:222 ../raster/r.slope.aspect/main.c:229
+#: ../raster/r.slope.aspect/main.c:236 ../raster/r.watershed/front/main.c:133
+#: ../raster/r.watershed/front/main.c:140
+#: ../raster/r.watershed/front/main.c:146
+#: ../raster/r.watershed/front/main.c:152
+#: ../raster/r.watershed/front/main.c:158
+#: ../raster/r.watershed/front/main.c:166
+#: ../raster/r.watershed/front/main.c:174
+#: ../raster/r.watershed/front/main.c:181 ../vector/v.vol.rst/main.c:294
+#: ../vector/v.vol.rst/main.c:300 ../vector/v.vol.rst/main.c:363
+#: ../vector/v.vol.rst/main.c:369 ../vector/v.vol.rst/main.c:375
+#: ../vector/v.vol.rst/main.c:382 ../vector/v.vol.rst/main.c:388
+#: ../vector/v.vol.rst/main.c:394 ../vector/v.vol.rst/main.c:400
+#: ../vector/v.vol.rst/main.c:406 ../vector/v.surf.rst/main.c:167
+#: ../vector/v.surf.rst/main.c:191 ../vector/v.surf.rst/main.c:197
+#: ../vector/v.surf.rst/main.c:203 ../vector/v.surf.rst/main.c:209
+#: ../vector/v.surf.rst/main.c:215 ../vector/v.surf.rst/main.c:221
+#: ../vector/v.surf.rst/main.c:227 ../vector/v.surf.rst/main.c:234
+#: ../vector/v.surf.rst/main.c:241 ../vector/v.surf.rst/main.c:248
+msgid "Outputs"
+msgstr ""
#: ../raster/r.slope.aspect/main.c:168 ../vector/v.surf.rst/main.c:202
#, fuzzy
msgid "Name for output aspect raster map"
@@ -12840,12 +16146,6 @@
msgid "Wrong raster type: %s"
msgstr "출력할 래스터맵"
-#: ../raster/r.slope.aspect/main.c:385
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:66
-#, c-format
-msgid "Converting units to meters, factor=%.6f"
-msgstr ""
#: ../raster/r.slope.aspect/main.c:965
#, fuzzy, c-format
msgid "Elevation products for mapset <%s> in <%s>"
@@ -12906,20 +16206,87 @@
msgid "Dxy raster map <%s> complete"
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.interp/main.c:80
+#: ../raster/r.resample/main.c:57
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../raster/r.resample/main.c:66
+msgid "Name of an input layer"
+msgstr ""
+#: ../raster/r.resample/main.c:73
+msgid "Name of an output layer"
+msgstr ""
+#: ../raster/r.resample/main.c:112 ../raster/r.resamp.rst/main.c:494
+msgid "Percent complete: "
+msgstr ""
+#: ../raster/r.resample/main.c:138
#, fuzzy
-msgid "Resamples raster map to a finer grid using interpolation."
+msgid "Creating new cats file..."
msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.interp/main.c:88
-msgid "Method"
+#: ../raster/r.out.mpeg/main.c:104
+#, fuzzy
+msgid "animation"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.mpeg/main.c:107
+#, fuzzy
+msgid "Converts raster map series to MPEG movie."
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.mpeg/main.c:115
+#, fuzzy, c-format
+msgid "Name of input raster map(s) for view no.%d"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.mpeg/main.c:117
+msgid "Views"
msgstr ""
-#: ../raster/r.resamp.interp/main.c:102 ../imagery/i.topo.corr/main.c:158
-#, c-format
-msgid "Invalid method: %s"
+#: ../raster/r.out.mpeg/main.c:132
+msgid "Quality factor (1 = highest quality, lowest compression)"
msgstr ""
+#: ../raster/r.out.mpeg/main.c:137
+msgid "Convert on the fly, uses less disk space"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:138
+msgid "Requires r.out.ppm with stdout option"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:161
+msgid "Either mpeg_encode or ppmtompeg must be installed"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:292
+#, fuzzy, c-format
+msgid "Unable to read color table for <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.mpeg/main.c:342 ../raster/r.out.mpeg/main.c:375
+msgid "mpeg_encode ERROR"
+msgstr ""
+#: ../raster/r.out.mpeg/main.c:418
+msgid "Error reading wildcard"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
+msgid "Size mismatch error!"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
+msgid "Unable to open output file"
+msgstr ""
+#: ../raster/r.out.mpeg/write.c:215
+msgid "Unable to create temporary files."
+msgstr ""
#: ../raster/r.contour/main.c:88
msgid "contours"
msgstr ""
@@ -12958,55 +16325,55 @@
msgid "Neither <%s> nor <%s> option must be specified"
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:182 ../vector/v.in.dxf/write_vect.c:240
-#: ../vector/v.in.ascii/main.c:501 ../vector/v.convert/att.c:86
-#: ../vector/v.in.sites/main.c:176 ../vector/v.to.points/main.c:181
-#: ../vector/v.in.lidar/main.c:608 ../vector/v.in.dwg/main.c:241
-#: ../vector/v.reclass/main.c:311 ../vector/v.in.ogr/main.c:983
+#: ../raster/r.contour/main.c:184 ../vector/v.in.sites/main.c:178
+#: ../vector/v.in.lidar/main.c:609 ../vector/v.to.points/main.c:187
+#: ../vector/v.in.dwg/main.c:242 ../vector/v.in.dxf/write_vect.c:240
+#: ../vector/v.in.ogr/main.c:1511 ../vector/v.in.ascii/main.c:503
+#: ../vector/v.reclass/main.c:314 ../vector/v.convert/att.c:86
#, fuzzy, c-format
msgid "Unable to create index for table <%s>, key <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:196 ../vector/v.voronoi/main.c:379
-#: ../vector/v.extract/copy_tab.c:53 ../vector/v.select/copy_tabs.c:17
-#: ../vector/v.generalize/misc.c:124
+#: ../raster/r.contour/main.c:198 ../vector/v.voronoi/main.c:383
+#: ../vector/v.generalize/misc.c:124 ../vector/v.select/copy_tabs.c:17
+#: ../vector/v.extract/copy_tab.c:53
#, fuzzy
msgid "Writing attributes..."
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:208 ../vector/v.convert/att.c:111
-#: ../vector/v.to.points/write.c:52 ../vector/v.overlay/line_area.c:410
-#: ../vector/v.overlay/area_area.c:343
+#: ../raster/r.contour/main.c:210 ../vector/v.to.points/write.c:52
+#: ../vector/v.overlay/line_area.c:410 ../vector/v.overlay/area_area.c:345
+#: ../vector/v.convert/att.c:111
#, fuzzy, c-format
msgid "Unable to insert new record: '%s'"
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:229 ../vector/v.generalize/displacement.c:78
+#: ../raster/r.contour/main.c:231 ../vector/v.generalize/displacement.c:78
#, fuzzy
msgid "Reading data..."
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:255
+#: ../raster/r.contour/main.c:257
#, fuzzy, c-format
msgid "Range of data: min=%f, max=%f"
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:257
+#: ../raster/r.contour/main.c:259
#, fuzzy
msgid "Range of data: empty"
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:285 ../raster/r.contour/main.c:288
+#: ../raster/r.contour/main.c:287 ../raster/r.contour/main.c:290
#, fuzzy
msgid "This step value is not allowed"
msgstr "출력할 래스터맵"
-#: ../raster/r.contour/main.c:313
+#: ../raster/r.contour/main.c:315
#, c-format
msgid "Range of levels: min = %f, max = %f"
msgstr ""
-#: ../raster/r.contour/main.c:342
+#: ../raster/r.contour/main.c:344
#, fuzzy
msgid "Displacing data..."
msgstr "출력할 래스터맵"
@@ -13033,19039 +16400,16169 @@
msgid "Edge number out of range"
msgstr ""
-#: ../raster/r.uslek/main.c:55
-msgid "soil"
-msgstr ""
+#: ../raster/r.out.png/main.c:116
+#, fuzzy
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgstr "출력할 래스터맵"
-#: ../raster/r.uslek/main.c:57
-msgid "Computes USLE Soil Erodibility Factor (K)."
+#: ../raster/r.out.png/main.c:122
+msgid "Name for new PNG file (use out=- for stdout)"
msgstr ""
-#: ../raster/r.uslek/main.c:62
+#: ../raster/r.out.png/main.c:130
#, fuzzy
-msgid "Name of soil sand fraction raster map [0.0-1.0]"
+msgid "Compression level of PNG file"
msgstr "출력할 래스터맵"
-#: ../raster/r.uslek/main.c:66
-#, fuzzy
-msgid "Name of soil clay fraction raster map [0.0-1.0]"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.png/main.c:131
+msgid "(0 = none, 1 = fastest, 9 = best)"
+msgstr ""
-#: ../raster/r.uslek/main.c:70
-#, fuzzy
-msgid "Name of soil silt fraction raster map [0.0-1.0]"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.png/main.c:138
+msgid "Make NULL cells transparent"
+msgstr ""
-#: ../raster/r.uslek/main.c:74
-#, fuzzy
-msgid "Name of soil organic matter raster map [0.0-1.0]"
+#: ../raster/r.out.png/main.c:142
+msgid "Output world file"
+msgstr ""
+#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:162
+#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
+#: ../display/d.graph/main.c:106 ../display/d.graph/do_graph.c:105
+#: ../display/d.graph/do_graph.c:355 ../display/d.graph/do_graph.c:370
+#, c-format
+msgid "[%s]: No such color"
+msgstr ""
+#: ../raster/r.out.png/main.c:257
+#, fuzzy, c-format
+msgid "Converting <%s>..."
msgstr "출력할 래스터맵"
-#: ../raster/r.uslek/main.c:77
+#: ../raster/r.out.png/main.c:422
#, fuzzy
-msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
+msgid "Writing world file"
msgstr "출력할 래스터맵"
-#: ../raster/r.digit/digitize.c:49
-msgid "Quit without creating a map?? "
+#: ../raster/r.out.png/main.c:425 ../raster/r.out.tiff/main.c:421
+msgid "Got null file name"
msgstr ""
-#: ../raster/r.digit/main.c:46
-msgid ""
-"Interactive tool used to draw and save vector features on a graphics monitor "
-"using a pointing device (mouse) and save to a raster map."
+#: ../raster/r.out.png/main.c:427 ../raster/r.out.tiff/main.c:423
+msgid "Got null region struct"
msgstr ""
-#: ../raster/r.digit/main.c:55
-msgid "Display commands to be used for canvas backdrop (separated by ';')"
-msgstr ""
+#: ../raster/r.out.png/main.c:429
+#, fuzzy
+msgid "Unable to open world file for writing"
+msgstr "출력할 래스터맵"
-#: ../raster/r.digit/main.c:78
-msgid "No graphics device selected!"
+#: ../raster/r.sunhours/main.c:73
+msgid "Calculates solar elevation, solar azimuth, and sun hours."
msgstr ""
-#: ../raster/r.digit/main.c:97
-msgid "No map created"
+#: ../raster/r.sunhours/main.c:74
+msgid ""
+"Solar elevation: the angle between the direction of the geometric center of "
+"the sun's apparent disk and the (idealized) horizon. Solar azimuth: the "
+"angle from due north in clockwise direction."
msgstr ""
-#: ../raster/r.digit/get_type.c:31
-#, c-format
-msgid "Please choose one of the following\n"
-msgstr ""
+#: ../raster/r.sunhours/main.c:80
+#, fuzzy
+msgid "Output raster map with solar elevation angle"
+msgstr "출력할 래스터맵"
-#: ../raster/r.digit/get_type.c:32
-#, c-format
-msgid " A define an area\n"
-msgstr ""
+#: ../raster/r.sunhours/main.c:85
+#, fuzzy
+msgid "Output raster map with solar azimuth angle"
+msgstr "출력할 래스터맵"
-#: ../raster/r.digit/get_type.c:33
-#, c-format
-msgid " C define a circle\n"
-msgstr ""
+#: ../raster/r.sunhours/main.c:90
+#, fuzzy
+msgid "Output raster map with sunshine hours"
+msgstr "출력할 래스터맵"
-#: ../raster/r.digit/get_type.c:34
-#, c-format
-msgid " L define a line\n"
+#: ../raster/r.sunhours/main.c:91
+msgid "Sunshine hours require solpos and Greenwich standard time"
msgstr ""
-#: ../raster/r.digit/get_type.c:35
-#, c-format
-msgid " X exit (and create map)\n"
+#: ../raster/r.sunhours/main.c:98
+msgid "Year"
msgstr ""
-#: ../raster/r.digit/get_type.c:36
-#, c-format
-msgid " Q quit (without creating map)\n"
+#: ../raster/r.sunhours/main.c:106
+msgid "Month"
msgstr ""
-#: ../raster/r.digit/get_label.c:31
-#, c-format
-msgid "Enter the category number for this %s: "
+#: ../raster/r.sunhours/main.c:107
+msgid "If not given, day is interpreted as day of the year"
msgstr ""
-#: ../raster/r.digit/get_label.c:46
-#, c-format
-msgid "Enter a label for category %ld [%s] "
+#: ../raster/r.sunhours/main.c:115
+msgid "Day"
msgstr ""
-#: ../raster/r.digit/get_label.c:68
-msgid "Look ok? "
+#: ../raster/r.sunhours/main.c:123
+msgid "Hour"
msgstr ""
-#: ../raster/r.in.lidar/main.c:165
-msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
+#: ../raster/r.sunhours/main.c:132
+msgid "Minutes"
msgstr ""
-#: ../raster/r.in.lidar/main.c:168 ../vector/v.in.lidar/main.c:160
-#, fuzzy
-msgid "LAS input file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.lidar/main.c:169 ../vector/v.in.lidar/main.c:161
-msgid "LiDAR input files in LAS format (*.las or *.laz)"
+#: ../raster/r.sunhours/main.c:141
+msgid "Seconds"
msgstr ""
-#: ../raster/r.in.lidar/main.c:237
-#, fuzzy
-msgid "Output raster resolution"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.lidar/main.c:242 ../vector/v.in.lidar/main.c:194
-msgid "Print LAS file info and exit"
+#: ../raster/r.sunhours/main.c:148
+msgid "Time is local sidereal time, not Greenwich standard time"
msgstr ""
-#: ../raster/r.in.lidar/main.c:253 ../vector/v.in.lidar/main.c:203
-#: ../vector/v.in.ogr/main.c:261
-msgid "Override dataset projection (use location's projection)"
+#: ../raster/r.sunhours/main.c:152
+msgid "Do not use solpos algorithm of NREL"
msgstr ""
-#: ../raster/r.in.lidar/main.c:279 ../vector/v.in.lidar/main.c:234
-#, fuzzy, c-format
-msgid "Input file <%s> does not exist"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.lidar/main.c:289 ../vector/v.in.lidar/main.c:241
-#, c-format
-msgid "Input file <%s> is not a LAS LiDAR point cloud"
+#: ../raster/r.sunhours/main.c:164
+msgid "No output requested, exiting."
msgstr ""
-#: ../raster/r.in.lidar/main.c:319 ../vector/v.in.lidar/main.c:371
-#: ../vector/v.in.ogr/main.c:643
-msgid ""
-"Unable to convert input map projection information to GRASS format for "
-"checking"
+#: ../raster/r.sunhours/main.c:190
+msgid "NREL solpos algorithm uses Greenwich standard time."
msgstr ""
-#: ../raster/r.in.lidar/main.c:349 ../vector/v.in.lidar/main.c:401
-#: ../vector/v.in.ogr/main.c:673
-msgid "GRASS LOCATION PROJ_INFO is:\n"
+#: ../raster/r.sunhours/main.c:191 ../raster/r.sunhours/main.c:199
+msgid "Time will be interpreted as Greenwich standard time."
msgstr ""
-#: ../raster/r.in.lidar/main.c:409 ../vector/v.in.lidar/main.c:461
-#: ../vector/v.in.ogr/main.c:733
-#, c-format
-msgid ""
-"\n"
-"You can use the -o flag to %s to override this projection check.\n"
+#: ../raster/r.sunhours/main.c:197
+msgid "Time will be interpreted as local sidereal time."
msgstr ""
-#: ../raster/r.in.lidar/main.c:412 ../vector/v.in.lidar/main.c:464
-#: ../vector/v.in.ogr/main.c:736
-msgid ""
-"Consider generating a new location with 'location' parameter from input data "
-"set.\n"
+#: ../raster/r.sunhours/main.c:202
+msgid "Sunshine hours require NREL solpos."
msgstr ""
-#: ../raster/r.in.lidar/main.c:554
-msgid "zrange will not be taken into account during scan"
+#: ../raster/r.sunhours/main.c:207
+msgid "Current projection is x,y (undefined)."
msgstr ""
-#: ../raster/r.in.lidar/main.c:572 ../general/g.region/main.c:832
-#, c-format
-msgid "Invalid input <%s=%s>"
-msgstr ""
-#: ../raster/r.in.lidar/main.c:575
-#, fuzzy, c-format
-msgid "Option '%s' must be > 0.0"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.lidar/main.c:653
+#: ../raster/r.sunhours/main.c:213
#, fuzzy
-msgid "Reading data ..."
+msgid "Cannot get projection info of current location"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.lidar/main.c:670
+#: ../raster/r.sunhours/main.c:216
#, fuzzy
-msgid "Could not rewind input file"
+msgid "Cannot get projection units of current location"
msgstr "출력할 래스터맵"
-#: ../raster/r.in.lidar/main.c:800
-msgid "Writing to map ..."
-msgstr ""
-#: ../raster/r.surf.contour/main.c:64
+#: ../raster/r.sunhours/main.c:219
#, fuzzy
-msgid "Generates surface raster map from rasterized contours."
+msgid "Cannot get projection key values of current location"
msgstr "출력할 래스터맵"
-#: ../raster/r.surf.contour/main.c:67
+#: ../raster/r.sunhours/main.c:353
#, fuzzy
-msgid "Name of input raster map containing contours"
+msgid "Calculating solar elevation and azimuth..."
msgstr "출력할 래스터맵"
-#: ../raster/r.shaded.relief/main.c:107
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
-#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#: ../raster/r.sunhours/main.c:356
#, fuzzy
-msgid "elevation"
+msgid "Calculating solar elevation..."
msgstr "출력할 래스터맵"
-#: ../raster/r.shaded.relief/main.c:109
-msgid "Creates shaded relief map from an elevation map (DEM)."
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:115
+#: ../raster/r.sunhours/main.c:359
#, fuzzy
-msgid "Name for output shaded relief map"
+msgid "Calculating solar azimuth..."
msgstr "출력할 래스터맵"
-#: ../raster/r.shaded.relief/main.c:116
-msgid "Default: <input_map>.shade"
+#: ../raster/r.support/check.c:26
+#, c-format
+msgid ""
+"\n"
+" Updating statistics for [%s]"
msgstr ""
-#: ../raster/r.shaded.relief/main.c:124
-msgid "Altitude of the sun in degrees above the horizon"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:133
-msgid "Azimuth of the sun in degrees to the east of north"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:140
-msgid "Factor for exaggerating relief"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:148
-msgid "Scale factor for converting meters to elevation units"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:155
-msgid "Elevation units (overrides scale factor)"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:160
-#, fuzzy
-msgid "international feet"
-msgstr "출력할 래스터맵"
-#: ../raster/r.shaded.relief/main.c:161
-msgid "survey feet"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:202
+#: ../raster/r.support/check.c:69
#, c-format
-msgid "%s=%s - must not be zero"
-msgstr ""
-#: ../raster/r.shaded.relief/main.c:461
-#, fuzzy, c-format
-msgid "Shaded relief raster map <%s> complete"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/proj.c:107
msgid ""
+" Updating the number of categories for [%s]\n"
"\n"
-"You can use the -o flag to r.external to override this check and use the "
-"location definition for the dataset.\n"
msgstr ""
-#: ../raster/r.external/window.c:23
-msgid ""
-"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
-"transform the map to North-up."
+#: ../raster/r.support/main.c:57
+msgid "Allows creation and/or modification of raster map layer support files."
msgstr ""
-#: ../raster/r.external/window.c:26
-msgid "Applying horizontal flip"
+#: ../raster/r.support/main.c:81
+msgid "Text to use for map data units"
msgstr ""
-#: ../raster/r.external/window.c:30
-msgid "Applying vertical flip"
+#: ../raster/r.support/main.c:87
+msgid "Text to use for map vertical datum"
msgstr ""
-#: ../raster/r.external/main.c:59
-#, fuzzy
-msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/main.c:62
-#, fuzzy
-msgid "Name of raster file to be linked"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/main.c:68
-#, fuzzy
-msgid "Name of non-file GDAL data source"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/main.c:80
-msgid "Band to select (default: all)"
+#: ../raster/r.support/main.c:130
+msgid "Update statistics (histogram, range)"
msgstr ""
-#: ../raster/r.external/main.c:109
-msgid "Flip horizontally"
+#: ../raster/r.support/main.c:134
+msgid "Create/reset the null file"
msgstr ""
-#: ../raster/r.external/main.c:113
-msgid "Flip vertically"
+#: ../raster/r.support/main.c:138
+msgid "Delete the null file"
msgstr ""
-#: ../raster/r.external/main.c:143
+#: ../raster/r.support/main.c:148 ../raster/r.category/main.c:130
#, fuzzy, c-format
-msgid "One of options <%s> or <%s> must be given"
+msgid "Raster map <%s> not found in current mapset"
msgstr "출력할 래스터맵"
-#: ../raster/r.external/main.c:147
+#: ../raster/r.support/main.c:277 ../raster/r.support/main.c:305
#, c-format
-msgid "Option <%s> and <%s> are mutually exclusive"
+msgid "[%s] is a reclass of another map. Exiting."
msgstr ""
-#: ../raster/r.external/main.c:180
-#, fuzzy, c-format
-msgid "Imagery group <%s> already exists and will be overwritten."
-msgstr "출력할 래스터맵"
+#: ../raster/r.support/main.c:288
+#, c-format
+msgid "Writing new null file for [%s]... "
+msgstr ""
-#: ../raster/r.external/main.c:187
-#, fuzzy, c-format
-msgid "Reading band %d of %d..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.support/main.c:309
+#, c-format
+msgid "Removing null file for [%s]...\n"
+msgstr ""
-#: ../raster/r.external/main.c:224
-#, fuzzy, c-format
-msgid "Imagery group <%s> created"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:48
-msgid "Complex types not supported"
+#: ../raster/r.support/main.c:316 ../display/d.what.vect/main.c:156
+msgid "Done."
msgstr ""
-#: ../raster/r.external/link.c:63
-#, fuzzy, c-format
-msgid "Copying color table for %s"
+#: ../raster/r.grow.distance/main.c:154
+#, fuzzy
+msgid "Generates a raster map containing distances to nearest raster features."
msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:81
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (full 8bit range)"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:87
-#, fuzzy, c-format
-msgid "Setting grey color table for <%s> (data range)"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:101
-#, fuzzy, c-format
-msgid "Unable to create cell/%s file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:110
-#, fuzzy, c-format
-msgid "Unable to create fcell/%s file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:146
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/gdal file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:149
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/gdal file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:174
-#, fuzzy, c-format
-msgid "Unable to create cell_misc/%s/f_format file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:177
-#, fuzzy, c-format
-msgid "Error writing cell_misc/%s/f_format file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:224
-#, fuzzy, c-format
-msgid "Creating support files for %s"
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/link.c:236
-#, fuzzy, c-format
-msgid "Link to raster map <%s> created."
-msgstr "출력할 래스터맵"
-#: ../raster/r.external/list.c:22
+#: ../raster/r.grow.distance/main.c:161
#, fuzzy
-msgid "Supported formats:"
+msgid "Name for distance output raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.png/main.c:116
+#: ../raster/r.grow.distance/main.c:167
#, fuzzy
-msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgid "Name for value output raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.png/main.c:122
-msgid "Name for new PNG file (use out=- for stdout)"
+#: ../raster/r.grow.distance/main.c:180
+msgid "Output distances in meters instead of map units"
msgstr ""
-#: ../raster/r.out.png/main.c:130
+#: ../raster/r.grow.distance/main.c:190
#, fuzzy
-msgid "Compression level of PNG file"
+msgid "At least one of distance= and value= must be given"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.png/main.c:131
-msgid "(0 = none, 1 = fastest, 9 = best)"
+#: ../raster/r.grow.distance/main.c:205
+msgid "metric=geodesic is only valid for lat/lon"
msgstr ""
-#: ../raster/r.out.png/main.c:138
-msgid "Make NULL cells transparent"
+#: ../raster/r.grow.distance/main.c:211
+#, c-format
+msgid "Unknown metric: '%s'"
msgstr ""
-#: ../raster/r.out.png/main.c:142
-msgid "Output world file"
-msgstr ""
-#: ../raster/r.out.png/main.c:175 ../raster/r.out.tiff/main.c:162
-#: ../display/d.graph/do_graph.c:105 ../display/d.graph/do_graph.c:355
-#: ../display/d.graph/do_graph.c:370 ../display/d.graph/main.c:106
-#: ../display/d.labels/color.c:68 ../display/d.rast/display.c:27
+#: ../raster/r.grow.distance/main.c:216
#, c-format
-msgid "[%s]: No such color"
+msgid "Output distance in meters for lat/lon is only possible with '%s=%s'"
msgstr ""
-#: ../raster/r.out.png/main.c:257
+#: ../raster/r.grow.distance/main.c:236
#, fuzzy, c-format
-msgid "Converting <%s>..."
+msgid "Unable to create temporary file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.png/main.c:272 ../raster/r.univar/r.univar_main.c:186
-#, fuzzy, c-format
-msgid "Raster <%s> type mismatch"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.png/main.c:422
-#, fuzzy
-msgid "Writing world file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.png/main.c:425 ../raster/r.out.tiff/main.c:421
-msgid "Got null file name"
+#: ../raster/r.watershed/shed/file_in.c:15
+msgid "unable to open ARMSED file"
msgstr ""
-#: ../raster/r.out.png/main.c:427 ../raster/r.out.tiff/main.c:423
-msgid "Got null region struct"
+#: ../raster/r.watershed/shed/basin_maps.c:12
+msgid ""
+"\n"
+"\n"
+"Please indicate which map layers you wish to use in the lumped"
msgstr ""
-#: ../raster/r.out.png/main.c:429
-#, fuzzy
-msgid "Unable to open world file for writing"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.tiff/main.c:95
-msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
+#: ../raster/r.watershed/shed/basin_maps.c:13
+msgid "parameter hydrologic/soil erosion model. Continue inputing cell map"
msgstr ""
-#: ../raster/r.out.tiff/main.c:102
-#, fuzzy
-msgid "Name for output TIFF file"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.tiff/main.c:109
-msgid "TIFF file compression"
+#: ../raster/r.watershed/shed/basin_maps.c:14
+msgid "layers, one at a time, until all desired map layers are in."
msgstr ""
-#: ../raster/r.out.tiff/main.c:114
-msgid "TIFF Palette output (8bit instead of 24bit)."
+#: ../raster/r.watershed/shed/basin_maps.c:15
+#, c-format
+msgid "You can have %s include a list of categories in each."
msgstr ""
-#: ../raster/r.out.tiff/main.c:123
-msgid "Output TIFF world file"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:127
-msgid "Output Tiled TIFF"
-msgstr ""
-#: ../raster/r.out.tiff/main.c:175
+#: ../raster/r.watershed/shed/basin_maps.c:17
#, c-format
msgid ""
-"Raster map <%s>> is a floating point map. Fractional values will be rounded "
-"to integer"
+"\n"
+"Hit <return> at the map prompt to continue with %s"
msgstr ""
-#: ../raster/r.out.tiff/main.c:181
+#: ../raster/r.watershed/shed/basin_maps.c:36
+#, c-format
msgid ""
-"Color map for palette must have less than 256 colors for the available range "
-"of data"
+"\n"
+"The output from %s will be divided into watershed"
msgstr ""
-#: ../raster/r.out.tiff/main.c:195
-#, fuzzy, c-format
-msgid "Unable to open TIFF file <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.tiff/main.c:418
-msgid "Writing TIFF World file"
+#: ../raster/r.watershed/shed/basin_maps.c:38
+msgid "basins. There are two possible methods of tabulating the information:"
msgstr ""
-#: ../raster/r.out.tiff/main.c:426
-#, fuzzy
-msgid "Unable to open TIFF world file for writing"
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.filter/main.c:142
-#, fuzzy, c-format
-msgid "Filter <%s> not found"
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.filter/main.c:387
-#, fuzzy
-msgid "Resamples raster map layers using an analytic kernel."
-msgstr "출력할 래스터맵"
-#: ../raster/r.resamp.filter/main.c:398
-msgid "Filter kernel(s)"
+#: ../raster/r.watershed/shed/basin_maps.c:39
+msgid "1) by only including data pertaining to the basin itself, or 2) using"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:406
-msgid "Filter radius"
+#: ../raster/r.watershed/shed/basin_maps.c:40
+msgid "data from the basin, and all basins upstream of it."
msgstr ""
-#: ../raster/r.resamp.filter/main.c:413
-msgid "Filter radius (horizontal)"
+#: ../raster/r.watershed/shed/basin_maps.c:43
+msgid ""
+"\n"
+"Would you like the data organized:"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:420
-msgid "Filter radius (vertical)"
+#: ../raster/r.watershed/shed/basin_maps.c:44
+msgid ""
+"1) Basin only\n"
+"2) Upstream only\n"
+"3) Both\n"
+"OR 0) to cancel program"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:431
-msgid "radius= and x_radius=/y_radius= are mutually exclusive"
+#: ../raster/r.watershed/shed/basin_maps.c:45
+#, c-format
+msgid ""
+"\n"
+"Your choice: "
msgstr ""
-#: ../raster/r.resamp.filter/main.c:435
-msgid "Either radius= or x_radius=/y_radius= required"
+#: ../raster/r.watershed/shed/basin_maps.c:69
+#: ../raster/r.watershed/shed/basin_maps.c:73
+#, c-format
+msgid ""
+"\n"
+"OK, %s should start running now using the following form:\n"
+"%s"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:437
-msgid "Both x_radius= and y_radius= required"
+#: ../raster/r.watershed/shed/intro.c:8
+#, c-format
+msgid "%s provides a text-based user-interface to the %s program."
msgstr ""
-#: ../raster/r.resamp.filter/main.c:459
-msgid "Differing number of values for filter= and [xy_]radius="
+#: ../raster/r.watershed/shed/intro.c:10
+#, c-format
+msgid "%s also allows the user to prepare a report of map layers for each"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:462
+#: ../raster/r.watershed/shed/intro.c:12
#, c-format
-msgid "Too many filters (max: %d)"
+msgid "watershed basin determined in %s.\n"
msgstr ""
-#: ../raster/r.resamp.filter/main.c:480
-#, fuzzy
-msgid "At least one filter must be finite"
-msgstr "출력할 래스터맵"
-#: ../raster/r.resample/main.c:57
-msgid "GRASS raster map layer data resampling capability."
+#: ../raster/r.watershed/shed/intro.c:14
+#, c-format
+msgid "%s will help the user determine which options to use for the"
msgstr ""
-#: ../raster/r.resample/main.c:66
-msgid "Name of an input layer"
+#: ../raster/r.watershed/shed/intro.c:16
+#, c-format
+msgid "%s program. %s will then ask for map layers that will be"
msgstr ""
-#: ../raster/r.resample/main.c:73
-msgid "Name of an output layer"
+#: ../raster/r.watershed/shed/intro.c:18
+#, c-format
+msgid "divided by basin. %s will then run %s and create the report."
msgstr ""
-#: ../raster/r.resample/main.c:138
-#, fuzzy
-msgid "Creating new cats file..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:50 ../raster/r.in.bin/main.c:59
-#: ../raster/r.in.bin/main.c:510
-#, fuzzy
-msgid "Error reading data"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:238
-msgid "Import a binary raster file into a GRASS raster map layer."
+#: ../raster/r.watershed/shed/main.c:41
+msgid "Slow version of water analysis program starting now"
msgstr ""
-#: ../raster/r.in.bin/main.c:243
-msgid "Import as floating-point data (default: integer)"
+#: ../raster/r.watershed/shed/main.c:46 ../raster/r.watershed/shed/main.c:55
+#, c-format
+msgid "<<%s>> command line failed"
msgstr ""
-#: ../raster/r.in.bin/main.c:248
-msgid "Import as double-precision floating-point data (default: integer)"
+#: ../raster/r.watershed/shed/main.c:72
+msgid "unable to open output file"
msgstr ""
-#: ../raster/r.in.bin/main.c:252 ../raster3d/r3.in.bin/main.c:371
-msgid "Signed data (two's complement)"
+#: ../raster/r.watershed/shed/read.c:23
+msgid "unable to open basin/half basin map"
msgstr ""
-#: ../raster/r.in.bin/main.c:257
-msgid "Byte Swap the Data During Import"
+#: ../raster/r.watershed/shed/com_line.c:23
+msgid ""
+"\n"
+"This set of questions will organize the command line for the"
msgstr ""
-#: ../raster/r.in.bin/main.c:262
-msgid "Get region info from GMT style header"
+#: ../raster/r.watershed/shed/com_line.c:24
+#, c-format
+msgid "%s program to run properly for your application."
msgstr ""
-#: ../raster/r.in.bin/main.c:267
-msgid "Binary raster file to be imported"
+#: ../raster/r.watershed/shed/com_line.c:26
+#, c-format
+msgid "The first question is whether you want %s to run"
msgstr ""
-#: ../raster/r.in.bin/main.c:284 ../raster/r.out.bin/main.c:311
-#, fuzzy
-msgid "Number of bytes per cell"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:292 ../raster/r.out.bin/main.c:318
-#: ../raster3d/r3.out.bin/main.c:235
-#, fuzzy
-msgid "Output byte order"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:300 ../raster3d/r3.in.bin/main.c:284
-msgid "Northern limit of geographic region (outer edge)"
+#: ../raster/r.watershed/shed/com_line.c:28
+#, c-format
+msgid "in its fast mode or its slow mode. If you run %s"
msgstr ""
-#: ../raster/r.in.bin/main.c:308 ../raster3d/r3.in.bin/main.c:292
-msgid "Southern limit of geographic region (outer edge)"
+#: ../raster/r.watershed/shed/com_line.c:30
+msgid "in the fast mode, the computer will finish about 10 times faster"
msgstr ""
-#: ../raster/r.in.bin/main.c:316 ../raster3d/r3.in.bin/main.c:300
-msgid "Eastern limit of geographic region (outer edge)"
+#: ../raster/r.watershed/shed/com_line.c:31
+msgid "than in the slow mode, but will not allow other programs to run"
msgstr ""
-#: ../raster/r.in.bin/main.c:324 ../raster3d/r3.in.bin/main.c:308
-msgid "Western limit of geographic region (outer edge)"
+#: ../raster/r.watershed/shed/com_line.c:32
+msgid "at the same time. The fast mode also places all of the data into"
msgstr ""
-#: ../raster/r.in.bin/main.c:331 ../general/g.pnmcat/main.c:137
-#: ../raster3d/r3.in.bin/main.c:330
-msgid "Number of rows"
+#: ../raster/r.watershed/shed/com_line.c:33
+msgid "RAM, which limits the size of window that can be run. The slow"
msgstr ""
-#: ../raster/r.in.bin/main.c:338 ../general/g.pnmcat/main.c:143
-#: ../raster3d/r3.in.bin/main.c:337
-msgid "Number of columns"
+#: ../raster/r.watershed/shed/com_line.c:34
+msgid "mode uses disk space in the same hard disk partition as where GRASS is"
msgstr ""
-#: ../raster/r.in.bin/main.c:345 ../raster3d/r3.in.bin/main.c:351
-msgid "Set Value to NULL"
+#: ../raster/r.watershed/shed/com_line.c:35
+msgid "stored. Thus, if the program does not work in the slow mode, you will"
msgstr ""
-#: ../raster/r.in.bin/main.c:366
-msgid "order= and -b are mutually exclusive"
+#: ../raster/r.watershed/shed/com_line.c:36
+msgid "need to remove unnecessary files from that partition. The slow mode"
msgstr ""
-#: ../raster/r.in.bin/main.c:381
-msgid "-f and -d are mutually exclusive"
-msgstr ""
-#: ../raster/r.in.bin/main.c:385
+#: ../raster/r.watershed/shed/com_line.c:37
#, c-format
-msgid "-f incompatible with bytes=%d; must be 4 or 8"
+msgid "will allow other processes to run concurrently with %s.\n"
msgstr ""
-#: ../raster/r.in.bin/main.c:393
-#, c-format
-msgid "-d incompatible with bytes=%d; must be 8"
+#: ../raster/r.watershed/shed/com_line.c:69
+#: ../raster/r.watershed/shed/com_line.c:182
+msgid ""
+"\n"
+"If you hit <return> by itself for the next question, this"
msgstr ""
-#: ../raster/r.in.bin/main.c:400
-msgid "bytes= required for integer data"
+#: ../raster/r.watershed/shed/com_line.c:70
+#: ../raster/r.watershed/shed/com_line.c:183
+msgid "program will terminate."
msgstr ""
-#: ../raster/r.in.bin/main.c:404 ../raster3d/r3.in.bin/main.c:412
-msgid "Integer input doesn't support size=8 in this build"
-msgstr ""
-#: ../raster/r.in.bin/main.c:408 ../raster3d/r3.in.bin/main.c:416
-msgid "bytes= must be 1, 2, 4 or 8"
-msgstr ""
-#: ../raster/r.in.bin/main.c:421
-#, fuzzy
-msgid "Either -h or rows= and cols= must be given"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:426
-#, fuzzy
-msgid "Either all or none of north=, south=, east= and west= must be given"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:433 ../display/d.grid/main.c:247
-#: ../raster3d/r3.in.bin/main.c:427
+#: ../raster/r.watershed/shed/com_line.c:81
#, c-format
-msgid "Illegal north coordinate <%s>"
+msgid ""
+"\n"
+"One of the options for %s is a `depression map'. A"
msgstr ""
-#: ../raster/r.in.bin/main.c:435 ../raster3d/r3.in.bin/main.c:429
-#, fuzzy, c-format
-msgid "Illegal south coordinate <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:437 ../display/d.grid/main.c:241
-#: ../raster3d/r3.in.bin/main.c:431
-#, c-format
-msgid "Illegal east coordinate <%s>"
+#: ../raster/r.watershed/shed/com_line.c:83
+msgid ""
+"depression map indicates all the locations in the current map window where"
msgstr ""
-#: ../raster/r.in.bin/main.c:439 ../raster3d/r3.in.bin/main.c:433
-#, fuzzy, c-format
-msgid "Illegal west coordinate <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:445 ../raster3d/r3.in.bin/main.c:441
-#, fuzzy, c-format
-msgid "Unable to open <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.in.bin/main.c:464
-#, c-format
+#: ../raster/r.watershed/shed/com_line.c:84
msgid ""
-"East-West (ewres: %f) and North-South (nwres: %f) resolution differ "
-"significantly. Did you assign east= and west= correctly?"
+"water accumulates and does not leave by the edge of the map. Lakes without"
msgstr ""
-#: ../raster/r.in.bin/main.c:487
-msgid "File Size %"
+#: ../raster/r.watershed/shed/com_line.c:85
+msgid ""
+"outlet streams and sinkholes are examples of `depressions'. If you wish to"
msgstr ""
-#: ../raster/r.in.bin/main.c:489 ../raster3d/r3.in.bin/main.c:451
-msgid "Bytes do not match file size"
+#: ../raster/r.watershed/shed/com_line.c:86
+msgid "have a depression map, prepare a map where non-zero values indicate the"
msgstr ""
-#: ../raster/r.kappa/calc_kappa.c:32
-#, c-format
-msgid "Cannot open file <%s> to write kappa and relevant parameters"
+#: ../raster/r.watershed/shed/com_line.c:87
+msgid "locations where depressions occur.\n"
msgstr ""
-#: ../raster/r.kappa/main.c:70 ../imagery/i.cluster/main.c:76
-#: ../imagery/i.class/main.c:92 ../imagery/i.maxlik/main.c:62
-#: ../imagery/i.smap/main.c:39 ../imagery/i.gensigset/main.c:41
-#: ../imagery/i.gensig/main.c:40 ../imagery/i.segment/main.c:37
-#: ../vector/v.class/main.c:46
-#, fuzzy
-msgid "classification"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/main.c:72
+#: ../raster/r.watershed/shed/com_line.c:88
msgid ""
-"Calculates error matrix and kappa parameter for accuracy assessment of "
-"classification result."
+"Hit <return> by itself for the next question if there is no depression map."
msgstr ""
-#: ../raster/r.kappa/main.c:78
-#, fuzzy
-msgid "Name of raster map containing classification result"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/main.c:83
-#, fuzzy
-msgid "Name of raster map containing reference classes"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/main.c:88
-#, fuzzy
-msgid "Name for output file containing error matrix and kappa"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/main.c:89
-#, fuzzy
-msgid "If not given, print to startdard output"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/main.c:90 ../raster/r.kappa/main.c:98
-#: ../raster/r.univar/r.univar_main.c:42
-#: ../locale/scriptstrings/r.unpack_to_translate.c:7
-#: ../locale/scriptstrings/r.unpack_to_translate.c:9 ../ps/ps.map/main.c:100
-#: ../ps/ps.map/main.c:113 ../ps/ps.map/main.c:135
-#, fuzzy
-msgid "Output settings"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/main.c:96
-msgid "Title for error matrix and kappa"
+#: ../raster/r.watershed/shed/com_line.c:99
+#, c-format
+msgid ""
+"\n"
+"The %s program will divide the elevation map into a number of"
msgstr ""
-#: ../raster/r.kappa/main.c:102
-msgid "Wide report"
+#: ../raster/r.watershed/shed/com_line.c:101
+msgid ""
+"watershed basins. The number of watershed basins is indirectly determined"
msgstr ""
-#: ../raster/r.kappa/main.c:103
-msgid "132 columns (default: 80)"
+#: ../raster/r.watershed/shed/com_line.c:102
+msgid ""
+"by the `basin threshold' value. The basin threshold is the area necessary "
+"for"
msgstr ""
-#: ../raster/r.kappa/main.c:108
-msgid "No header in the report"
-msgstr ""
-#: ../raster/r.kappa/prt_hdr.c:18
-#, fuzzy, c-format
-msgid "Cannot open file <%s> to write header"
-msgstr "출력할 래스터맵"
-#: ../raster/r.kappa/prt_mat.c:39
+#: ../raster/r.watershed/shed/com_line.c:103
#, c-format
-msgid "Cannot open file <%s> to write cats and counts (error matrix)"
+msgid "%s to define a unique watershed basin. This area only applies to"
msgstr ""
-#: ../raster/r.kappa/prt_label.c:17
-#, fuzzy, c-format
-msgid "Can't open file <%s> to write label"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.mpeg/main.c:104
-#, fuzzy
-msgid "animation"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.mpeg/main.c:107
-#, fuzzy
-msgid "Converts raster map series to MPEG movie."
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.mpeg/main.c:115
-#, fuzzy, c-format
-msgid "Name of input raster map(s) for view no.%d"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.mpeg/main.c:117
-msgid "Views"
+#: ../raster/r.watershed/shed/com_line.c:105
+msgid ""
+"`exterior drainage basins'. An exterior drainage basin does not have any"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:132
-msgid "Quality factor (1 = highest quality, lowest compression)"
+#: ../raster/r.watershed/shed/com_line.c:106
+msgid ""
+"drainage basins flowing into it. Interior drainage basin size is determined"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:137
-msgid "Convert on the fly, uses less disk space"
+#: ../raster/r.watershed/shed/com_line.c:107
+msgid ""
+"by the surface flow going into stream segments between stream interceptions."
msgstr ""
-#: ../raster/r.out.mpeg/main.c:138
-msgid "Requires r.out.ppm with stdout option"
+#: ../raster/r.watershed/shed/com_line.c:108
+#, c-format
+msgid "Thus interior drainage basins can be of any size. The %s program"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:161
-msgid "Either mpeg_encode or ppmtompeg must be installed"
+#: ../raster/r.watershed/shed/com_line.c:110
+msgid "also allows the user to relate basin size to potential overland flow"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:292
-#, fuzzy, c-format
-msgid "Unable to read color table for <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.mpeg/main.c:342 ../raster/r.out.mpeg/main.c:375
-msgid "mpeg_encode ERROR"
+#: ../raster/r.watershed/shed/com_line.c:111
+msgid ""
+"(i.e., areas with low infiltration capacities will need smaller areas to"
msgstr ""
-#: ../raster/r.out.mpeg/main.c:418
-msgid "Error reading wildcard"
+#: ../raster/r.watershed/shed/com_line.c:112
+msgid ""
+"develop stream channels than neighboring areas with high infiltration rates)."
msgstr ""
-#: ../raster/r.out.mpeg/write.c:81 ../raster/r.out.mpeg/write.c:178
-msgid "Size mismatch error!"
+#: ../raster/r.watershed/shed/com_line.c:113
+msgid ""
+"The user can create a map layer with potential overland flow values, and"
msgstr ""
-#: ../raster/r.out.mpeg/write.c:139 ../raster/r.out.mpeg/write.c:181
-msgid "Unable to open output file"
+#: ../raster/r.watershed/shed/com_line.c:114
+#, c-format
+msgid "%s will accumulate those values instead of area.\n"
msgstr ""
-#: ../raster/r.out.mpeg/write.c:215
-msgid "Unable to create temporary files."
+#: ../raster/r.watershed/shed/com_line.c:116
+msgid "What unit of measure will you use for the basin threshold:"
msgstr ""
-#: ../raster/r.recode/read_rules.c:20
-#, fuzzy, c-format
-msgid "Unable to read f_range for map %s"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:149
-#, fuzzy
-msgid "Data range is empty"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/read_rules.c:30
-#, fuzzy, c-format
-msgid "Data range of %s is %s to %s (entire map)"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/read_rules.c:39
-#, fuzzy, c-format
-msgid "Integer data range of %s is empty"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/read_rules.c:41
-#, fuzzy, c-format
-msgid "Integer data range of %s is %d to %d"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/read_rules.c:60
-msgid "Enter the rule or 'help' for the format description"
+#: ../raster/r.watershed/shed/com_line.c:119
+msgid " 1) acres, 2) meters sq., 3) miles sq., 4) hectares,"
msgstr ""
-#: ../raster/r.recode/read_rules.c:84
-msgid "Enter a rule in one of these formats:"
+#: ../raster/r.watershed/shed/com_line.c:120
+msgid " 5) kilometers sq., 6) map cells, 7) overland flow units"
msgstr ""
-#: ../raster/r.recode/read_rules.c:86
-msgid "old_low:old_high:new_low:new_high"
+#: ../raster/r.watershed/shed/com_line.c:121
+#, c-format
+msgid "Choose 1-7 or 0 to exit this program: "
msgstr ""
-#: ../raster/r.recode/read_rules.c:87
-msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
+#: ../raster/r.watershed/shed/com_line.c:131
+msgid ""
+"\n"
+"How large an area (or how many overland flow units) must a drainage basin"
msgstr ""
-#: ../raster/r.recode/read_rules.c:88
-msgid "*:old_val:new_val (interval [inf, old_val])"
+#: ../raster/r.watershed/shed/com_line.c:132
+#, c-format
+msgid "be for it to be an exterior drainage basin: "
msgstr ""
-#: ../raster/r.recode/read_rules.c:89
-msgid "old_val:*:new_val (interval [old_val, inf])"
+#: ../raster/r.watershed/shed/com_line.c:201
+#, c-format
+msgid ""
+"\n"
+"%s must create a map layer of watershed basins"
msgstr ""
-#: ../raster/r.recode/read_rules.c:91
-msgid "When finished type \"end\"."
+#: ../raster/r.watershed/shed/com_line.c:203
+#: ../raster/r.watershed/shed/com_line.c:224
+#, c-format
+msgid "before %s can run properly."
msgstr ""
-#: ../raster/r.recode/main.c:49
-#, fuzzy
-msgid "recode categories"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/main.c:50
-#, fuzzy
-msgid "Recodes categorical raster maps."
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/main.c:53
-#, fuzzy
-msgid "Name of raster map to be recoded"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/main.c:59
-msgid "File containing recode rules"
+#: ../raster/r.watershed/shed/com_line.c:222
+#, c-format
+msgid ""
+"\n"
+"%s must create a file of watershed basin relationships"
msgstr ""
-#: ../raster/r.recode/main.c:60 ../raster/r.reclass/main.c:66
-#, fuzzy
-msgid "\"-\" to read from stdin"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/main.c:70
-#, fuzzy
-msgid "Align the current region to the input raster map"
-msgstr "출력할 래스터맵"
-#: ../raster/r.recode/main.c:74
-msgid "Force output to 'double' raster map type (DCELL)"
-msgstr ""
-#: ../raster/r.recode/main.c:95
+#: ../raster/r.watershed/shed/com_line.c:228
+#: ../raster/r.watershed/shed/com_line.c:263
#, c-format
-msgid "No rules specified. Raster map <%s> not created."
-msgstr ""
-#: ../raster/r.neighbors/main.c:145
msgid ""
-"Makes each cell category value a function of the category values assigned to "
-"the cells around it, and stores new cell values in an output raster map "
-"layer."
+"\n"
+"Please name this file:"
msgstr ""
-#: ../raster/r.neighbors/main.c:155
-#, fuzzy
+#: ../raster/r.watershed/shed/com_line.c:257
+#, c-format
msgid ""
-"Name of an input raster map to select the cells which should be processed"
-msgstr "출력할 래스터맵"
-#: ../raster/r.neighbors/main.c:174 ../vector/v.neighbors/main.c:71
-msgid "Neighborhood operation"
+"\n"
+"%s will generate a lot of output. Indicate a file"
msgstr ""
-#: ../raster/r.neighbors/main.c:176 ../raster/r.neighbors/main.c:184
-#: ../raster/r.neighbors/main.c:220
-msgid "Neighborhood"
+#: ../raster/r.watershed/shed/com_line.c:259
+#, c-format
+msgid "name for %s to send the output to."
msgstr ""
-#: ../raster/r.neighbors/main.c:182
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:4
-msgid "Neighborhood size"
+#: ../raster/r.watershed/shed/com_line.c:277
+#, c-format
+msgid ""
+"\n"
+"The accumulation map from %s must be present for"
msgstr ""
-#: ../raster/r.neighbors/main.c:191
-msgid "Title of the output raster map"
+#: ../raster/r.watershed/shed/com_line.c:279
+#, c-format
+msgid "%s to work properly."
msgstr ""
-#: ../raster/r.neighbors/main.c:196
-#, fuzzy
-msgid "Text file containing weights"
-msgstr "출력할 래스터맵"
-#: ../raster/r.neighbors/main.c:202
-msgid "Sigma (in cells) for Gaussian filter"
+#: ../raster/r.watershed/shed/com_line.c:290
+#, c-format
+msgid ""
+"\n"
+"%s can produce several maps not necessary for"
msgstr ""
-#: ../raster/r.neighbors/main.c:215
-msgid "Do not align output with the input"
+#: ../raster/r.watershed/shed/com_line.c:292
+#, c-format
+msgid "%s to function (stream channels, overland flow aspect, and"
msgstr ""
-#: ../raster/r.neighbors/main.c:219
-msgid "Use circular neighborhood"
+#: ../raster/r.watershed/shed/com_line.c:294
+#, c-format
+msgid "a display version of the accumulation map). %s also has the"
msgstr ""
-#: ../raster/r.neighbors/main.c:227
-msgid "Neighborhood size must be positive"
+#: ../raster/r.watershed/shed/com_line.c:296
+msgid ""
+"ability to generate several variables in the Revised Universal Soil Loss"
msgstr ""
-#: ../raster/r.neighbors/main.c:229
-msgid "Neighborhood size must be odd"
+#: ../raster/r.watershed/shed/com_line.c:297
+msgid "Equation (Rusle): Slope Length (LS), and Slope Steepness (S).\n"
msgstr ""
-#: ../raster/r.neighbors/main.c:233
-msgid "weight= and -c are mutually exclusive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:236
-msgid "weight= and gauss= are mutually exclusive"
-msgstr ""
-#: ../raster/r.neighbors/main.c:296
-#, c-format
+#: ../raster/r.watershed/shed/com_line.c:348
msgid ""
-"Method %s not compatible with weighing window, using weight mask instead"
+"\n"
+"The Slope Length factor (LS) and Slope Steepness (S) are influenced by"
msgstr ""
-#: ../raster/r.neighbors/main.c:304
+#: ../raster/r.watershed/shed/com_line.c:349
#, c-format
-msgid ""
-"Method %s not compatible with Gaussian filter, using unweighed version "
-"instead"
+msgid "disturbed land. %s reflects this with an optional map layer or value"
msgstr ""
-#: ../raster/r.neighbors/main.c:352
-#, fuzzy, c-format
-msgid "Opening selection map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.neighbors/readweights.c:18
-#, fuzzy, c-format
-msgid "Unable to open weights file %s"
-msgstr "출력할 래스터맵"
-#: ../raster/r.neighbors/readweights.c:23
-#, fuzzy, c-format
-msgid "Error reading weights file %s"
-msgstr "출력할 래스터맵"
-#: ../raster/r.spreadpath/main.c:93
+#: ../raster/r.watershed/shed/com_line.c:351
msgid ""
-"Recursively traces the least cost path backwards to cells from which the "
-"cumulative cost was determined."
+"where the value indicates the percent of disturbed (barren) land in that "
+"cell."
msgstr ""
-#: ../raster/r.spreadpath/main.c:102
-msgid "Name of raster map containing back-path easting information"
+#: ../raster/r.watershed/shed/com_line.c:352
+msgid "Type <return> if you do not have a disturbed land map layer."
msgstr ""
-#: ../raster/r.spreadpath/main.c:110
-#, fuzzy
-msgid "Name of raster map containing back-path northing information"
-msgstr "출력할 래스터맵"
-#: ../raster/r.spreadpath/main.c:118
-msgid "The map E and N grid coordinates of starting points"
+#: ../raster/r.watershed/shed/com_line.c:364
+msgid ""
+"\n"
+"Type the value indicating the percent of disturbed land. This value will"
msgstr ""
-#: ../raster/r.spreadpath/main.c:125
-msgid "Name of spread path raster map"
+#: ../raster/r.watershed/shed/com_line.c:365
+msgid "be used for every cell in the current region."
msgstr ""
-#: ../raster/r.spreadpath/main.c:129
-msgid "Run verbosely"
+#: ../raster/r.watershed/shed/com_line.c:368
+#, c-format
+msgid ""
+"\n"
+"Input value here [0-100]: "
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:37
-msgid "3D Raster map used for zoning, must be of type CELL"
+#: ../raster/r.watershed/shed/com_line.c:379
+msgid ""
+"\n"
+"Overland surface flow only occurs for a set distance before swales form."
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:52
-#: ../raster/r.univar/r.univar_main.c:52
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:6
-#: ../locale/scriptstrings/db.univar_to_translate.c:6
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:11
-#: ../vector/v.univar/main.c:119
-msgid "Percentile to calculate (requires extended statistics flag)"
+#: ../raster/r.watershed/shed/com_line.c:380
+#, c-format
+msgid "Because of digital terrain model limitations, %s cannot pick up"
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:59
-#: ../raster/r.univar/r.univar_main.c:61 ../vector/v.univar/main.c:123
-#: ../vector/v.what/main.c:98
-msgid "Print the stats in shell script style"
+#: ../raster/r.watershed/shed/com_line.c:382
+#, c-format
+msgid "these swales. %s allows for an input (warning: kludge factor)"
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:63
-#: ../raster/r.univar/r.univar_main.c:66
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:6
-#: ../vector/v.univar/main.c:127
-msgid "Calculate extended statistics"
+#: ../raster/r.watershed/shed/com_line.c:384
+msgid ""
+"that prevents the surface flow distance from getting too long. Normally,"
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:67
-#: ../raster/r.univar/r.univar_main.c:71
-msgid "Table output format instead of standard output format"
+#: ../raster/r.watershed/shed/com_line.c:385
+msgid "maximum slope length is around 600 feet (about 183 meters)."
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:100
-#: ../raster/r.univar/r.univar_main.c:102
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:5
-#: ../vector/v.vect.stats/main.c:131
-#, fuzzy
-msgid "univariate statistics"
-msgstr "출력할 래스터맵"
-#: ../raster/r.univar/r3.univar_main.c:103
+#: ../raster/r.watershed/shed/com_line.c:400
msgid ""
-"Calculates univariate statistics from the non-null 3d cells of a raster3d "
-"map."
+"\n"
+"Roads, ditches, changes in ground cover, and other factors will stop"
msgstr ""
-#: ../raster/r.univar/r3.univar_main.c:155
-#: ../raster/r.univar/r3.univar_main.c:193
-#: ../raster3d/r3.info/r3.info.main.c:110 ../raster3d/r3.cross.rast/main.c:279
-#: ../raster3d/r3.stats/main.c:619 ../raster3d/r3.out.vtk/main.c:207
-#: ../raster3d/r3.out.vtk/main.c:292 ../raster3d/r3.out.vtk/main.c:513
-#: ../raster3d/r3.out.netcdf/main.c:616 ../raster3d/r3.out.v5d/main.c:311
-#: ../raster3d/r3.out.bin/main.c:314 ../raster3d/r3.neighbors/main.c:262
-#: ../raster3d/r3.neighbors/main.c:271 ../raster3d/r3.mkdspf/main.c:167
-#: ../raster3d/r3.retile/main.c:127 ../raster3d/r3.out.ascii/main.c:342
-#: ../raster3d/r3.to.rast/main.c:237 ../raster3d/r3.to.rast/main.c:261
-#: ../raster3d/r3.mask/main.c:63 ../raster3d/r3.null/main.c:109
-#, fuzzy, c-format
-msgid "Unable to open 3D raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.univar/r.univar_main.c:36
-msgid "Raster map used for zoning, must be of type CELL"
+#: ../raster/r.watershed/shed/com_line.c:401
+msgid ""
+"slope length. You may input a raster map indicating the locations of these"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:53 ../raster/r.univar/r.univar_main.c:67
-msgid "Extended"
+#: ../raster/r.watershed/shed/com_line.c:402
+msgid "blocking factors.\n"
msgstr ""
-#: ../raster/r.univar/r.univar_main.c:103
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:6
-#: ../vector/v.vect.stats/main.c:132
-#, fuzzy
-msgid "zonal statistics"
-msgstr "출력할 래스터맵"
-#: ../raster/r.univar/r.univar_main.c:105
+#: ../raster/r.watershed/shed/com_line.c:403
msgid ""
-"Calculates univariate statistics from the non-null cells of a raster map."
+"Hit <return> by itself for the next question if there is no blocking map."
msgstr ""
-#: ../raster/r.patch/main.c:55
-msgid ""
-"Creates a composite raster map layer by using known category values from one "
-"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+#: ../raster/r.watershed/shed/valid.c:24
+msgid "accum file missing in valid_basins()"
msgstr ""
-#: ../raster/r.patch/main.c:62
-msgid "Name of raster maps to be patched together"
+#: ../raster/r.watershed/seg/do_cum.c:118
+#: ../raster/r.watershed/ram/do_cum.c:114
+msgid "SECTION 3: Accumulating Surface Flow with SFD."
msgstr ""
-#: ../raster/r.patch/main.c:65
-#, fuzzy
-msgid "Name for resultant raster map"
-msgstr "출력할 래스터맵"
-#: ../raster/r.patch/main.c:72
-msgid "Use zero (0) for transparency instead of NULL"
+#: ../raster/r.watershed/seg/do_cum.c:283
+#: ../raster/r.watershed/ram/do_cum.c:272
+msgid "SECTION 3a: Accumulating Surface Flow with MFD."
msgstr ""
-#: ../raster/r.patch/main.c:88
-msgid "The minimum number of input raster maps is two"
+#: ../raster/r.watershed/seg/do_cum.c:517
+msgid "MFD: A * path already processed when distributing flow: %d of %"
msgstr ""
-#: ../raster/r.patch/main.c:144
-#, fuzzy, c-format
-msgid "Creating support files for raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.bin/main.c:139
-#, c-format
-msgid "Header File = %s"
+#: ../raster/r.watershed/seg/do_cum.c:521
+#: ../raster/r.watershed/ram/do_cum.c:480
+msgid "SECTION 3b: Adjusting drainage directions."
msgstr ""
-#: ../raster/r.out.bin/main.c:144 ../raster/r.out.bin/main.c:228
-#: ../raster/r.out.bin/main.c:408 ../raster3d/r3.out.bin/main.c:321
-#, fuzzy, c-format
-msgid "Unable to create file <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.bin/main.c:223
-#, c-format
-msgid "World File = %s"
+#: ../raster/r.watershed/seg/close_maps2.c:38
+#: ../raster/r.watershed/ram/close_maps2.c:34
+msgid "No basins were created. Verify threshold and region settings."
msgstr ""
-#: ../raster/r.out.bin/main.c:281
-msgid "Exports a GRASS raster to a binary array."
+#: ../raster/r.watershed/seg/close_maps2.c:86
+msgid "Closing stream segments map"
msgstr ""
-#: ../raster/r.out.bin/main.c:297
-msgid "Name for output binary map (use output=- for stdout)"
-msgstr ""
-#: ../raster/r.out.bin/main.c:304 ../raster3d/r3.out.bin/main.c:220
-msgid "Value to write out for null"
-msgstr ""
-#: ../raster/r.out.bin/main.c:323
+#: ../raster/r.watershed/seg/close_maps2.c:109
#, fuzzy
-msgid "Generate integer output"
+msgid "Closing basins map"
msgstr "출력할 래스터맵"
-#: ../raster/r.out.bin/main.c:327
-#, fuzzy
-msgid "Generate floating-point output"
-msgstr "출력할 래스터맵"
-#: ../raster/r.out.bin/main.c:331
-msgid "Export array with GMT compatible header"
+#: ../raster/r.watershed/seg/close_maps2.c:116
+msgid "Closing half basins map"
msgstr ""
-#: ../raster/r.out.bin/main.c:335
-msgid "Generate BIL world and header files"
+#: ../raster/r.watershed/seg/close_maps.c:20
+msgid "Closing accumulation map"
msgstr ""
-#: ../raster/r.out.bin/main.c:339
-msgid "Byte swap output"
-msgstr ""
+#: ../raster/r.watershed/seg/close_maps.c:132
+#, fuzzy
+msgid "Closing TCI map"
+msgstr "출력할 래스터맵"
-#: ../raster/r.out.bin/main.c:345 ../raster3d/r3.out.bin/main.c:256
-msgid "Invalid value for null (integers only)"
+#: ../raster/r.watershed/seg/close_maps.c:214
+msgid "Closing flow direction map"
msgstr ""
-#: ../raster/r.out.bin/main.c:367
-msgid "order= and -s are mutually exclusive"
+#: ../raster/r.watershed/seg/close_maps.c:241
+msgid "Closing LS map"
msgstr ""
-#: ../raster/r.out.bin/main.c:376
-msgid "-i and -f are mutually exclusive"
+#: ../raster/r.watershed/seg/close_maps.c:246
+msgid "Closing SL map"
msgstr ""
-#: ../raster/r.out.bin/main.c:395 ../raster3d/r3.out.bin/main.c:269
-msgid "Floating-point output requires bytes=4 or bytes=8"
+#: ../raster/r.watershed/seg/sg_factor.c:14
+msgid "SECTION 5: RUSLE LS and/or S factor determination."
msgstr ""
-#: ../raster/r.out.bin/main.c:399 ../raster3d/r3.out.bin/main.c:273
-msgid "Integer output doesn't support bytes=8 in this build"
+#: ../raster/r.watershed/seg/do_astar.c:30
+#: ../raster/r.watershed/ram/do_astar.c:27
+msgid "SECTION 2: A* Search."
msgstr ""
-#: ../raster/r.out.bin/main.c:413
-msgid "GMT grid doesn't support 64-bit integers"
+#: ../raster/r.watershed/seg/do_astar.c:48
+msgid "No seeds for A* Search"
msgstr ""
-#: ../raster/r.out.bin/main.c:419
-msgid "Creating BIL support files..."
+#: ../raster/r.watershed/seg/do_astar.c:146
+msgid "bug in A* Search: doer %"
msgstr ""
-#: ../raster/r.out.bin/main.c:436
+#: ../raster/r.watershed/seg/main.c:90 ../raster/r.watershed/seg/main.c:105
+#: ../raster/r.watershed/ram/main.c:82 ../raster/r.watershed/ram/main.c:98
#, c-format
-msgid "Exporting raster as floating values (bytes=%d)"
+msgid "SECTION %d: Closing Maps."
msgstr ""
-#: ../raster/r.out.bin/main.c:438
-msgid "Writing GMT float format ID=1"
+#: ../raster/r.watershed/seg/main.c:103 ../raster/r.watershed/ram/main.c:96
+#, c-format
+msgid "SECTION %d: Watershed determination."
msgstr ""
-#: ../raster/r.out.bin/main.c:441
+#: ../raster/r.watershed/seg/usage.c:9 ../raster/r.watershed/ram/usage.c:9
#, c-format
-msgid "Exporting raster as integer values (bytes=%d)"
+msgid ""
+"USAGE for basin delineation:\n"
+"%s -4 elevation=elevation_map threshold=swale_threshold "
+"[flow=overland_flow_map] [drainage=drain_direction_map] "
+"[depression=depression_map] [accumulation=accumulation_map] "
+"[basin=watershed_basin_map] [stream=stream_segment_map]\n"
+"\n"
+"USAGE for slope length determination:\n"
+"%s [-4] elevation=elevation_map threshold=swale_threshold "
+"[drainage=drain_direction_map] [depression=depression_map] "
+"[accumulation=accumulation_map] [max_slope_length=max_slope_length] "
+"[blocking=overland_blocking_map] [slope_steepness=slope_steepness_map] "
+"length_slope=length_slope_map [disturbed_land=rill_erosion_map] "
+"[slope_deposition=slope_deposition value or map]USAGE for ARMSED FILE "
+"creation:\n"
+"[basin=watershed_basin_map] [stream=stream_segment_map] "
+"[half_basin=half_basin_map] ar=ARMSED_file_name\n"
+"\n"
msgstr ""
-#: ../raster/r.out.bin/main.c:443
-msgid "Writing GMT integer format ID=2"
-msgstr ""
-#: ../raster/r.out.bin/main.c:446 ../raster3d/r3.out.bin/main.c:323
-msgid "Using the current region settings..."
-msgstr ""
-#: ../raster/r.out.bin/main.c:447 ../raster3d/r3.out.bin/main.c:324
+#: ../raster/r.watershed/seg/init_vars.c:132
#, c-format
-msgid "north=%f"
-msgstr ""
+msgid "SECTION 1 beginning: Initiating Variables. %d section total."
+msgid_plural "SECTION 1 beginning: Initiating Variables. %d sections total."
+msgstr[0] ""
+msgstr[1] ""
-#: ../raster/r.out.bin/main.c:448 ../raster3d/r3.out.bin/main.c:325
-#, c-format
-msgid "south=%f"
+#: ../raster/r.watershed/seg/init_vars.c:168
+msgid "Maximum memory to be used was smaller than 3 MB, set to 3 MB."
msgstr ""
-#: ../raster/r.out.bin/main.c:449 ../raster3d/r3.out.bin/main.c:326
-#, c-format
-msgid "east=%f"
+#: ../raster/r.watershed/seg/init_vars.c:457
+msgid "SECTION 1b: Determining Offmap Flow."
msgstr ""
-#: ../raster/r.out.bin/main.c:450 ../raster3d/r3.out.bin/main.c:327
-#, c-format
-msgid "west=%f"
+#: ../raster/r.watershed/front/main.c:74 ../raster/r.basins.fill/main.c:56
+#: ../raster/r.water.outlet/main.c:69
+msgid "watershed"
msgstr ""
-#: ../raster/r.out.bin/main.c:451
-#, c-format
-msgid "r=%d"
+#: ../raster/r.watershed/front/main.c:75
+msgid "Calculates hydrological parameters and RUSLE factors."
msgstr ""
-#: ../raster/r.out.bin/main.c:452
-#, c-format
-msgid "c=%d"
+#: ../raster/r.watershed/front/main.c:78 ../raster/r.watershed/front/main.c:85
+#: ../raster/r.watershed/front/main.c:91 ../raster/r.watershed/front/main.c:98
+#: ../raster/r.watershed/front/main.c:107
+#: ../raster/r.watershed/front/main.c:115
+#: ../raster/r.watershed/front/main.c:124
+msgid "Inputs"
msgstr ""
-#: ../raster/r.surf.fractal/process.c:54
+#: ../raster/r.watershed/front/main.c:82
#, fuzzy
-msgid "Unable to allocate data buffer. Check current region with g.region."
+msgid "Name of input depressions raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.surf.fractal/spec_syn.c:61
-msgid "Preliminary surface calculations..."
+#: ../raster/r.watershed/front/main.c:83
+msgid "All non-NULL and non-zero cells are considered as real depressions"
msgstr ""
-#: ../raster/r.surf.fractal/spec_syn.c:120
-#, fuzzy, c-format
-msgid "Calculating surface %d (of %d)..."
+#: ../raster/r.watershed/front/main.c:89
+#, fuzzy
+msgid "Name of input raster representing amount of overland flow per cell"
msgstr "출력할 래스터맵"
-#: ../raster/r.surf.fractal/main.c:40
-msgid "fractal"
-msgstr ""
+#: ../raster/r.watershed/front/main.c:95
+#, fuzzy
+msgid "Name of input raster map percent of disturbed land"
+msgstr "출력할 래스터맵"
-#: ../raster/r.surf.fractal/main.c:42
-msgid "Creates a fractal surface of a given fractal dimension."
+#: ../raster/r.watershed/front/main.c:96
+#: ../raster/r.watershed/front/main.c:121
+msgid "For USLE"
msgstr ""
-#: ../raster/r.surf.fractal/main.c:48
-msgid "Fractal dimension of surface (2 < D < 3)"
-msgstr ""
+#: ../raster/r.watershed/front/main.c:103
+#, fuzzy
+msgid "Name of input raster map blocking overland surface flow"
+msgstr "출력할 래스터맵"
-#: ../raster/r.surf.fractal/main.c:55
-msgid "Number of intermediate images to produce"
+#: ../raster/r.watershed/front/main.c:105
+msgid ""
+"For USLE. All non-NULL and non-zero cells are considered as blocking terrain."
msgstr ""
-#: ../raster/r.surf.fractal/main.c:79
-#, c-format
-msgid "Fractal dimension of %.2lf must be between 2 and 3."
+#: ../raster/r.watershed/front/main.c:112
+msgid "Minimum size of exterior watershed basin"
msgstr ""
-#: ../raster/r.bitpattern/main.c:65
-msgid "Compares bit patterns with a raster map."
+#: ../raster/r.watershed/front/main.c:120
+msgid "Maximum length of surface flow in map units"
msgstr ""
-#: ../raster/r.bitpattern/main.c:77
-msgid "Bit pattern position(s)"
-msgstr ""
-#: ../raster/r.bitpattern/main.c:83
-msgid "Bit pattern value"
-msgstr ""
-#: ../raster/r.bitpattern/main.c:89
-msgid "Quiet"
-msgstr ""
-#: ../raster/r.stream.order/io.c:297
+#: ../raster/r.watershed/front/main.c:129
#, fuzzy
-msgid "Uunrecognisable data type"
+msgid "Name for output accumulation raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/io.c:314
-#, fuzzy, c-format
-msgid "Unable re-open file '%s'"
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:34
+#: ../raster/r.watershed/front/main.c:131
#, fuzzy
-msgid "Name of input elevation raster map"
+msgid "Number of cells that drain through each cell"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:45
+#: ../raster/r.watershed/front/main.c:138
#, fuzzy
-msgid "Name for output Strahler's stream order raster map"
+msgid "Topographic index ln(a / tan(b))"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:46
+#: ../raster/r.watershed/front/main.c:144
#, fuzzy
-msgid "Name for output original Hortons's stream order raster map"
+msgid "Name for output drainage direction raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:47
+#: ../raster/r.watershed/front/main.c:150
#, fuzzy
-msgid "Name for output Shereve's stream magnitude raster map"
+msgid "Name for basins raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:48
+#: ../raster/r.watershed/front/main.c:156
#, fuzzy
-msgid "Name for output Hack's streams or Gravelius stream hierarchy raster map"
+msgid "Name for output stream segments raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:49
+#: ../raster/r.watershed/front/main.c:162
#, fuzzy
-msgid "Name for output topological dimension of streams raster map"
+msgid "Name for output half basins raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:72
-#, fuzzy
-msgid "Calculates Strahler's and more streams hierarchy."
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:74
-msgid "Basic module for topological analysis of drainage network."
+#: ../raster/r.watershed/front/main.c:164
+msgid "Each half-basin is given a unique value"
msgstr ""
-#: ../raster/r.stream.order/main.c:78
-msgid "stream order"
-msgstr ""
-#: ../raster/r.stream.order/main.c:92
+#: ../raster/r.watershed/front/main.c:170
#, fuzzy
-msgid "Name for output vector map to write stream attributes"
+msgid "Name for output slope length raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:113
-msgid "Create zero-valued background instead of NULL"
+#: ../raster/r.watershed/front/main.c:172
+msgid "Slope length and steepness (LS) factor for USLE"
msgstr ""
-#: ../raster/r.stream.order/main.c:123
+#: ../raster/r.watershed/front/main.c:178
#, fuzzy
-msgid "Use flow accumulation to trace horton and hack models"
+msgid "Name for output slope steepness raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/main.c:140
-msgid ""
-"To calculate vector map both accumulation and elevation raster maps are "
-"required"
+#: ../raster/r.watershed/front/main.c:179
+msgid "Slope steepness (S) factor for USLE"
msgstr ""
-#: ../raster/r.stream.order/main.c:143
-msgid "Flag -a (use accumulation) accumulation raster map is required"
+#: ../raster/r.watershed/front/main.c:188
+msgid "Convergence factor for MFD (1-10)"
msgstr ""
-#: ../raster/r.stream.order/main.c:152
-msgid ""
-"You must select one or more output orders raster maps or insert the table "
-"name"
+#: ../raster/r.watershed/front/main.c:190
+msgid "1 = most diverging flow, 10 = most converging flow. Recommended: 5"
msgstr ""
-#: ../raster/r.stream.order/stream_order.c:16
-#, fuzzy
-msgid "Calculating Strahler's stream order..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.watershed/front/main.c:197
+msgid "Maximum memory to be used with -m flag (in MB)"
+msgstr ""
-#: ../raster/r.stream.order/stream_order.c:68
-msgid ""
-"Calculating Shreve's stream magnitude, Scheidegger's consistent integer and "
-"Drwal's streams hierarchy (old style)..."
+#: ../raster/r.watershed/front/main.c:201
+msgid "SFD (D8) flow (default is MFD)"
msgstr ""
-#: ../raster/r.stream.order/stream_order.c:122
-#, fuzzy
-msgid "Calculating Hortons's stream order..."
-msgstr "출력할 래스터맵"
+#: ../raster/r.watershed/front/main.c:203
+msgid "SFD: single flow direction, MFD: multiple flow direction"
+msgstr ""
-#: ../raster/r.stream.order/stream_order.c:211
-#, fuzzy
-msgid "Calculating Hack's main streams and topological dimension..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/stream_vector.c:78
-#: ../raster/r.stream.order/stream_vector.c:170
-#, fuzzy, c-format
-msgid "Unable to add attribute table to vector map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/stream_vector.c:249
-#: ../raster/r.stream.order/stream_vector.c:328
-#, fuzzy
-msgid "Error with number of tributuaries"
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/stream_topology.c:18
-#: ../raster/r.stream.order/stream_topology.c:65
-#: ../raster/r.stream.order/stream_topology.c:77
-#: ../raster/r.stream.order/stream_topology.c:90
-#: ../raster/r.stream.order/stream_topology.c:225
-#: ../raster/r.stream.order/stream_topology.c:283
-#: ../raster/r.stream.order/stream_topology.c:295
-#: ../raster/r.stream.order/stream_topology.c:309
-msgid "Error finding nodes. Stream and direction maps probably do not match."
+#: ../raster/r.watershed/front/main.c:208
+msgid "Allow only horizontal and vertical flow of water"
msgstr ""
-#: ../raster/r.stream.order/stream_topology.c:126
-#: ../raster/r.stream.order/stream_topology.c:350
-#, fuzzy
-msgid "Finding longest streams..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/stream_init.c:8
-#, fuzzy
-msgid "Empty stream input raster map"
-msgstr "출력할 래스터맵"
-#: ../raster/r.stream.order/stream_init.c:10
-#, fuzzy
-msgid "Stream map has negative values"
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/reclass.c:50 ../raster/r.reclass/reclass.c:110
-msgid "Too many categories"
+#: ../raster/r.watershed/front/main.c:213
+msgid "Enable disk swap memory option: Operation is slow"
msgstr ""
-#: ../raster/r.reclass/reclass.c:215
-#, fuzzy, c-format
-msgid "Cannot read header file of <%s@%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/reclass.c:230
-#, fuzzy, c-format
-msgid "Cannot create reclass file of <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/reclass.c:238
-#, fuzzy, c-format
-msgid "Cannot create raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/main.c:51 ../vector/v.reclass/main.c:68
-#, fuzzy
-msgid "reclassification"
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/main.c:52
-#, fuzzy
-msgid "Reclassify raster map based on category values."
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/main.c:54
+#: ../raster/r.watershed/front/main.c:215
msgid ""
-"Creates a new raster map whose category values are based upon a "
-"reclassification of the categories in an existing raster map."
+"Only needed if memory requirements exceed available RAM; see manual on how "
+"to calculate memory requirements"
msgstr ""
-#: ../raster/r.reclass/main.c:59
-#, fuzzy
-msgid "Name of raster map to be reclassified"
-msgstr "출력할 래스터맵"
+#: ../raster/r.watershed/front/main.c:220
+msgid "Use positive flow accumulation even for likely underestimates"
+msgstr ""
-#: ../raster/r.reclass/main.c:65
-msgid "File containing reclass rules"
+#: ../raster/r.watershed/front/main.c:222
+msgid "See manual for a detailed description of flow accumulation output"
msgstr ""
-#: ../raster/r.reclass/main.c:72
-msgid "Title for the resulting raster map"
+#: ../raster/r.watershed/front/main.c:227
+msgid "Beautify flat areas"
msgstr ""
-#: ../raster/r.reclass/main.c:83
-msgid "Input map can NOT be the same as output map"
+#: ../raster/r.watershed/front/main.c:229
+msgid "Flow direction in flat areas is modified to look prettier"
msgstr ""
-#: ../raster/r.reclass/main.c:89
-#, fuzzy, c-format
-msgid "Cannot open rules file <%s>"
-msgstr "출력할 래스터맵"
+#: ../raster/r.watershed/front/main.c:245
+msgid "Sorry, you must choose an output map."
+msgstr ""
-#: ../raster/r.reclass/main.c:103
-#, c-format
-msgid "Enter rule(s), \"end\" when done, \"help\" if you need it\n"
+#: ../raster/r.watershed/front/main.c:251
+msgid "The basin threshold must be a positive number."
msgstr ""
-#: ../raster/r.reclass/main.c:105
-#, c-format
-msgid "FCELL: Data range is %.7g to %.7g\n"
+#: ../raster/r.watershed/front/main.c:267
+msgid ""
+"Sorry, if any of the following options are set:\n"
+" basin, stream, half_basin, length_slope, or slope_steepness\n"
+" you MUST provide a value for the basin threshold parameter."
msgstr ""
-#: ../raster/r.reclass/main.c:108
-#, c-format
-msgid "DCELL: Data range is %.15g to %.15g\n"
+#: ../raster/r.watershed/front/main.c:294
+msgid "Beautify flat areas is not yet supported for disk swap mode"
msgstr ""
-#: ../raster/r.reclass/main.c:111
-#, fuzzy, c-format
-msgid "CELL: Data range is %ld to %ld\n"
-msgstr "출력할 래스터맵"
-#: ../raster/r.reclass/main.c:119
+#: ../raster/r.watershed/front/main.c:321
#, c-format
-msgid "Illegal reclass rule -"
+msgid "Subprocess failed with exit code %d"
msgstr ""
-#: ../raster/r.reclass/main.c:120
+#: ../raster/r.watershed/ram/do_cum.c:474
#, c-format
-msgid " ignored\n"
-msgstr ""
+msgid "MFD: A * path already processed when distributing flow: %d of %d cell"
+msgid_plural ""
+"MFD: A * path already processed when distributing flow: %d of %d cells"
+msgstr[0] ""
+msgstr[1] ""
-#: ../raster/r.reclass/main.c:123
-msgid " - invalid reclass rule"
+#: ../raster/r.watershed/ram/sg_factor.c:14
+msgid "SECTION 4: RUSLE LS and/or S factor determination."
msgstr ""
-#: ../raster/r.reclass/main.c:139
-#, c-format
-msgid "No rules specified. Raster map <%s> not created"
+#: ../raster/r.watershed/ram/do_astar.c:254
+msgid "heapsize too large"
msgstr ""
-#: ../raster/r.reclass/parse.c:42
-msgid "poor quality"
+#: ../raster/r.watershed/ram/do_flatarea.c:56
+msgid "Beautify flat areas: priority queue error"
msgstr ""
-#: ../raster/r.reclass/parse.c:44
-msgid "medium quality"
+#: ../raster/r.watershed/ram/do_flatarea.c:229
+msgid "flat cell escaped for uphill correction"
msgstr ""
-#: ../raster/r.reclass/parse.c:59
-msgid "Can't have null on the left-hand side of the rule"
+#: ../raster/r.watershed/ram/do_flatarea.c:235
+#, c-format
+msgid "queue error: last uphill order %d > current uphill order %d"
msgstr ""
-#: ../raster/r.reclass/parse.c:88 ../raster/r.reclass/parse.c:100
-msgid "Can't have null on the right-hand side of the rule"
+#: ../raster/r.watershed/ram/do_flatarea.c:240
+msgid "uphill order not set"
msgstr ""
-#: ../raster/r.reclass/parse.c:196
-#, c-format
-msgid "%f rounded up to %d\n"
+#: ../raster/r.watershed/ram/do_flatarea.c:266
+msgid "flat cell escaped in uphill correction"
msgstr ""
-#: ../raster/r.surf.random/main.c:40
-msgid ""
-"Produces a raster surface map of uniform random deviates with defined range."
+#: ../raster/r.watershed/ram/do_flatarea.c:302
+msgid "downhill order: no more points in down queue"
msgstr ""
-#: ../raster/r.surf.random/main.c:46
-msgid "Minimum random value"
+#: ../raster/r.watershed/ram/do_flatarea.c:310
+msgid "flat cell escaped for downhill correction"
msgstr ""
-#: ../raster/r.surf.random/main.c:52
-msgid "Maximum random value"
+#: ../raster/r.watershed/ram/do_flatarea.c:316
+#, c-format
+msgid "queue error: last downhill order %d > current downhill order %d"
msgstr ""
-#: ../raster/r.surf.random/main.c:58
-#, fuzzy
-msgid "Create an integer raster map"
-msgstr "출력할 래스터맵"
-#: ../raster/r.surf.random/main.c:66
-#, fuzzy, c-format
-msgid "Raster map <%s> generated."
-msgstr "출력할 래스터맵"
-#: ../raster/r.surf.area/main.c:79
-#, fuzzy
-msgid "area estimation"
-msgstr "출력할 래스터맵"
-#: ../raster/r.surf.area/main.c:80
-#, fuzzy
-msgid "Prints estimation of surface area for raster map."
-msgstr "출력할 래스터맵"
-#: ../raster/r.surf.area/main.c:89
-msgid "Vertical scale"
+#: ../raster/r.watershed/ram/do_flatarea.c:321
+msgid "downhill order: downhill order not set"
msgstr ""
-#: ../raster/r.surf.area/main.c:93
-#, fuzzy
-msgid "Output units"
-msgstr "출력할 래스터맵"
-#: ../raster/r.surf.area/main.c:94
-msgid "Default: square map units"
+#: ../raster/r.watershed/ram/do_flatarea.c:344
+msgid "flat cell escaped in downhill correction"
msgstr ""
-#: ../raster/r.surf.area/main.c:102
-#, fuzzy, c-format
-msgid "Output in '%s'"
-msgstr "출력할 래스터맵"
-#: ../raster/r.surf.area/main.c:106
-msgid "Output in 'square map units'"
+#: ../raster/r.watershed/ram/do_flatarea.c:382
+msgid "flat cell escaped for adjustment"
msgstr ""
-#: ../raster/r.surf.area/main.c:151
-msgid "Null value area ignored in calculation:"
+#: ../raster/r.watershed/ram/do_flatarea.c:389
+msgid "adjustment: uphill order not set"
msgstr ""
-#: ../raster/r.surf.area/main.c:153
-msgid "Plan area used in calculation:"
+#: ../raster/r.watershed/ram/do_flatarea.c:391
+msgid "adjustment: downhill order not set"
msgstr ""
-#: ../raster/r.surf.area/main.c:156
-msgid "Surface area calculation(low, high, avg):"
+#: ../raster/r.watershed/ram/do_flatarea.c:417
+msgid "flat cell escaped in adjustment"
msgstr ""
-#: ../raster/r.surf.area/main.c:161
-msgid "Current region plan area:"
+#: ../raster/r.watershed/ram/init_vars.c:118
+#, c-format
+msgid "SECTION 1a (of %1d): Initiating Memory."
msgstr ""
-#: ../raster/r.surf.area/main.c:163
-msgid "Estimated region Surface Area:"
+#: ../raster/r.watershed/ram/init_vars.c:299
+#, c-format
+msgid "SECTION 1b (of %1d): Determining Offmap Flow."
msgstr ""
-#: ../raster/r.flow/io.c:87
-msgid "Elevation raster map resolution differs from current region resolution"
+#: ../raster/r.out.arc/main.c:64
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
msgstr ""
-#: ../raster/r.flow/io.c:104
-msgid "Resolution of aspect file differs from current region resolution"
+#: ../raster/r.out.arc/main.c:71
+#, fuzzy
+msgid "Name for output ARC-GRID file (use out=- for stdout)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.arc/main.c:78
+msgid "Number of decimal places"
msgstr ""
-#: ../raster/r.flow/io.c:121
-msgid "Reading input files: barrier"
+#: ../raster/r.out.arc/main.c:88
+msgid "List one entry per line instead of full row"
msgstr ""
-#: ../raster/r.flow/io.c:149
-#, c-format
-msgid "Cannot create segment file %s"
+#: ../raster/r.out.arc/main.c:94
+msgid "Use cell center reference in header instead of cell corner"
msgstr ""
-#: ../raster/r.flow/io.c:154
-#, c-format
-msgid "Cannot format segment file %s"
+#: ../raster/r.rescale.eq/main.c:55
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
msgstr ""
-#: ../raster/r.flow/io.c:160
+#: ../raster/r.rescale.eq/main.c:115
#, c-format
-msgid "Cannot open segment file %s"
+msgid "Rescale %s[%d,%d] to %s[%d,%d]"
msgstr ""
-#: ../raster/r.flow/precomp.c:48
-msgid "Precomputing e/w distances..."
+#: ../raster/r.regression.multi/main.c:61
+msgid "Matrix is unsolvable"
msgstr ""
-#: ../raster/r.flow/precomp.c:50
+#: ../raster/r.regression.multi/main.c:131
#, fuzzy
-msgid "Precomputing quantization tolerances..."
+msgid "Calculates multiple linear regression from raster maps."
msgstr "출력할 래스터맵"
-#: ../raster/r.flow/precomp.c:53
-msgid "Precomputing inverted elevations..."
+#: ../raster/r.regression.multi/main.c:136
+#: ../raster/r.regression.line/main.c:54
+msgid "Map for x coefficient"
msgstr ""
-#: ../raster/r.flow/precomp.c:57
-msgid "Precomputing interpolated border elevations..."
+#: ../raster/r.regression.multi/main.c:140
+#: ../raster/r.regression.line/main.c:58
+msgid "Map for y coefficient"
msgstr ""
-#: ../raster/r.flow/precomp.c:63
-#, fuzzy
-msgid "Precomputing re-oriented aspects..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.flow/precomp.c:67
-#, fuzzy
-msgid "Precomputing aspects..."
-msgstr "출력할 래스터맵"
-#: ../raster/r.flow/precomp.c:111
-#, c-format
-msgid ""
-"Resolution too unbalanced:\n"
-"atan2(%f deg, %f deg) =%f < %f tolerance\n"
-"please resample input map"
+#: ../raster/r.regression.multi/main.c:145
+msgid "Map to store residuals"
msgstr ""
-#: ../raster/r.flow/precomp.c:116
-#, c-format
-msgid "Resolution too unbalanced (%f x %f); please resample input map"
+#: ../raster/r.regression.multi/main.c:150
+msgid "Map to store estimates"
msgstr ""
-#: ../raster/r.flow/main.c:424
-msgid "Constructs flowlines."
-msgstr ""
-#: ../raster/r.flow/main.c:426
+#: ../raster/r.regression.multi/main.c:156
+#: ../raster/r.regression.line/main.c:64
msgid ""
-"Computes flowlines, flowpath lengths, and flowaccumulation (contributing "
-"areas) from a elevation raster map."
+"ASCII file for storing regression coefficients (output to screen if file not "
+"specified)."
msgstr ""
-#: ../raster/r.flow/main.c:435
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:5
+#: ../raster/r.regression.multi/main.c:248
#, fuzzy
-msgid "Name of input aspect raster map"
+msgid "First pass..."
msgstr "출력할 래스터맵"
-#: ../raster/r.flow/main.c:440
+#: ../raster/r.regression.multi/main.c:321
#, fuzzy
-msgid "Name of input barrier raster map"
+msgid "Not enough valid cells available"
msgstr "출력할 래스터맵"
-#: ../raster/r.flow/main.c:446
-msgid "Number of cells between flowlines"
+#: ../raster/r.regression.multi/main.c:335
+msgid "Multiple regression failed"
msgstr ""
-#: ../raster/r.flow/main.c:452
-msgid "Maximum number of segments per flowline"
+#: ../raster/r.regression.multi/main.c:340
+msgid "Second pass..."
msgstr ""
-#: ../raster/r.flow/main.c:457
+#: ../raster/r.basins.fill/main.c:58
#, fuzzy
-msgid "Name for output flowline vector map"
+msgid "Generates watershed subbasins raster map."
msgstr "출력할 래스터맵"
-#: ../raster/r.flow/main.c:462
+#: ../raster/r.basins.fill/main.c:62
#, fuzzy
-msgid "Name for output flowpath length raster map"
+msgid "Name of input coded stream network raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.flow/main.c:467
+#: ../raster/r.basins.fill/main.c:66
#, fuzzy
-msgid "Name for output flowaccumulation raster map"
+msgid "Name of input thinned ridge network raster map"
msgstr "출력할 래스터맵"
-#: ../raster/r.flow/main.c:472
-msgid "Compute upslope flowlines instead of default downhill flowlines"
+#: ../raster/r.basins.fill/main.c:74
+msgid "Number of passes through the dataset"
msgstr ""
-#: ../raster/r.flow/main.c:476
-msgid "3D lengths instead of 2D"
+#: ../raster/r.basins.fill/main.c:122
+msgid "Forward sweep complete"
msgstr ""
-#: ../raster/r.flow/main.c:480
-msgid "Use less memory, at a performance penalty"
+#: ../raster/r.basins.fill/main.c:139
+msgid "Reverse sweep complete"
msgstr ""
-#: ../raster/r.flow/main.c:535
-msgid "You must select one or more output maps (flout, lgout, dsout)"
+#: ../raster/r.basins.fill/read_map.c:39
+#, fuzzy, c-format
+msgid "Reading <%s> ... "
+msgstr "출력할 래스터맵"
+#: ../raster/r.to.vect/points.c:36
+msgid "Extracting points..."
msgstr ""
-#: ../raster/r.flow/main.c:551
+#: ../raster/r.to.vect/areas_io.c:110
+#, c-format
msgid ""
-"lat/long projection not supported by r.flow. Please use 'r.watershed' for "
-"calculating flow accumulation."
+"Line terminated unexpectedly\n"
+"previous (%d) point %p (%d,%d,%d) %p %p"
msgstr ""
-#: ../raster/r.flow/mem.c:40
-#, c-format
-msgid "Unable to write segment file for %s"
+#: ../raster/r.to.vect/areas_io.c:305
+#, fuzzy
+msgid "Writing areas..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.to.vect/lines_io.c:76
+msgid "write_line: found half a loop!"
msgstr ""
-#: ../raster/r.describe/main.c:57
-msgid "Prints terse list of category values found in a raster map layer."
+#: ../raster/r.to.vect/lines_io.c:132
+#, c-format
+msgid ""
+"write_line: line terminated unexpectedly\n"
+" previous (%d) point %p (%d,%d,%d) %p %p"
msgstr ""
-#: ../raster/r.describe/main.c:76
-msgid "Number of quantization steps"
+#: ../raster/r.to.vect/lines.c:70
+msgid "Extracting lines..."
msgstr ""
-#: ../raster/r.describe/main.c:82
-msgid "Print the output one value per line"
+#: ../raster/r.to.vect/lines.c:499
+msgid ""
+"Raster map is not thinned properly.\n"
+"Please run r.thin."
msgstr ""
-#: ../raster/r.describe/main.c:86
-msgid "Only print the range of the data"
+#: ../raster/r.to.vect/lines.c:573
+msgid "join_lines: p front pointer not NULL!"
msgstr ""
-#: ../raster/r.describe/main.c:90
-msgid "Suppress reporting of any NULLs"
+#: ../raster/r.to.vect/lines.c:579
+msgid "join_lines: q front pointer not NULL!"
msgstr ""
-#: ../raster/r.describe/main.c:94
-msgid "Use the current region"
+#: ../raster/r.to.vect/lines.c:597
+msgid "extend line: p is NULL"
msgstr ""
-#: ../raster/r.describe/main.c:98
-msgid "Read fp map as integer"
+#: ../raster/r.to.vect/lines.c:623
+msgid "extend_lines: p front pointer not NULL!"
msgstr ""
-#: ../raster/r.describe/main.c:110
-#, c-format
-msgid "%s = %s -- must be greater than zero"
+#: ../raster/r.to.vect/lines.c:630
+msgid "extend_lines: q back pointer not NULL!"
msgstr ""
-#: ../raster/r.describe/describe.c:94
-#, fuzzy, c-format
-msgid "Reading <%s> ..."
+#: ../raster/r.to.vect/areas.c:120
+#, fuzzy
+msgid "Extracting areas..."
msgstr "출력할 래스터맵"
-#: ../raster/r.los/main.c:94
-msgid "viewshed"
+#: ../raster/r.to.vect/main.c:73
+#, fuzzy
+msgid "vectorization"
+msgstr "출력할 래스터맵"
+#: ../raster/r.to.vect/main.c:74
+#, fuzzy
+msgid "Converts a raster map into a vector map."
+msgstr "출력할 래스터맵"
+#: ../raster/r.to.vect/main.c:87
+#, fuzzy
+msgid "Name of attribute column to store value"
+msgstr "출력할 래스터맵"
+#: ../raster/r.to.vect/main.c:88
+msgid "Name must be SQL compliant"
msgstr ""
-#: ../raster/r.los/main.c:95
-msgid "line of sight"
+#: ../raster/r.to.vect/main.c:93
+msgid "Smooth corners of area features"
msgstr ""
-#: ../raster/r.los/main.c:96
-msgid "Line-of-sight raster analysis program."
+#: ../raster/r.to.vect/main.c:98
+msgid "Use raster values as categories instead of unique sequence (CELL only)"
msgstr ""
-#: ../raster/r.los/main.c:107
+#: ../raster/r.to.vect/main.c:99 ../raster/r.to.vect/main.c:106
+#: ../vector/v.in.lidar/main.c:198 ../vector/v.to.rast/main.c:88
+#: ../vector/v.to.rast/main.c:94 ../vector/v.to.rast/main.c:100
+#: ../vector/v.in.ogr/main.c:223 ../vector/v.in.ogr/main.c:233
+#: ../vector/v.in.ogr/main.c:243 ../vector/v.in.ogr/main.c:244
+#: ../vector/v.in.ogr/main.c:271 ../vector/v.in.ogr/main.c:294
+#: ../vector/v.generalize/main.c:236 ../vector/v.overlay/main.c:129
+#: ../vector/v.overlay/main.c:139 ../vector/v.buffer/main.c:304
+#: ../vector/v.extract/main.c:90 ../vector/v.extract/main.c:142
#, fuzzy
-msgid "Coordinates of the viewing position"
+msgid "Attributes"
msgstr "출력할 래스터맵"
-#: ../raster/r.los/main.c:112
+#: ../raster/r.to.vect/main.c:103
#, fuzzy
-msgid "Binary (1/0) raster map to use as a mask"
+msgid "Write raster values as z coordinate"
msgstr "출력할 래스터맵"
-#: ../raster/r.los/main.c:119
-msgid "Viewing position height above the ground"
+#: ../raster/r.to.vect/main.c:104
+msgid "Table is not created. Currently supported only for points."
msgstr ""
-#: ../raster/r.los/main.c:127
-msgid "Maximum distance from the viewing point (meters)"
-msgstr ""
+#: ../raster/r.to.vect/main.c:110
+#, fuzzy
+msgid "Do not build vector topology"
+msgstr "출력할 래스터맵"
-#: ../raster/r.los/main.c:133
-msgid "Consider earth curvature (current ellipsoid)"
+#: ../raster/r.to.vect/main.c:111
+msgid "Recommended for massive point conversion"
msgstr ""
-#: ../raster/r.los/main.c:160
-msgid "Lat/Long support is not (yet) implemented for this module."
+#: ../raster/r.to.vect/main.c:124
+msgid "z flag is supported only for points"
msgstr ""
-#: ../raster/r.los/main.c:165
-msgid "Specified observer coordinate is outside current region bounds."
+#: ../raster/r.to.vect/main.c:135
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be written to the "
+"table."
msgstr ""
-#: ../raster/r.los/main.c:209
-msgid "Pattern map should be a binary 0/1 CELL map"
+#: ../raster/r.to.vect/main.c:137
+msgid ""
+"Raster is not CELL, '-v' flag ignored, raster values will be z coordinate."
msgstr ""
-#: ../raster/r.los/main.c:243
-msgid ""
-"Problem to obtain current ellipsoid parameters, using sphere (6370997.0)"
+#: ../raster/r.to.vect/main.c:139
+msgid "Raster is not CELL, '-v' flag ignored, raster values will be lost."
msgstr ""
-#: ../raster/r.los/main.c:248
-#, c-format
-msgid "Using maximum distance from the viewing point (meters): %f"
+#: ../raster/r.to.vect/main.c:144
+msgid "Categories will be unique sequence, raster values will be lost."
msgstr ""
-#: ../general/g.ppmtopng/main.c:34
-#, fuzzy, c-format
-msgid "Unable to open input file %s"
+#: ../raster/r.to.vect/main.c:224 ../vector/v.overlay/main.c:573
+#: ../vector/v.patch/main.c:304 ../vector/v.mkgrid/main.c:252
+#: ../db/drivers/postgres/index.c:59
+#, fuzzy
+msgid "Unable to create index"
msgstr "출력할 래스터맵"
-#: ../general/g.ppmtopng/main.c:37
+#: ../raster/r.to.vect/main.c:276
+#, fuzzy
+msgid "Updating attributes..."
+msgstr "출력할 래스터맵"
+#: ../raster/r.to.vect/main.c:300
#, fuzzy, c-format
-msgid "Invalid input file %s"
+msgid "Unable to insert into table: %s"
msgstr "출력할 래스터맵"
-#: ../general/g.ppmtopng/main.c:77
+#: ../raster/r.colors.out/raster_main.c:46
+#: ../raster/r.colors.out/raster3d_main.c:47
+#: ../raster/r.colors/edit_colors.c:67 ../raster/r.what.color/main.c:90
+#: ../vector/v.colors.out/main.c:50 ../vector/v.colors/main.c:56
+#: ../display/d.colors/main.c:41
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:3
+#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:3
#, fuzzy
-msgid "Error writing PNG file"
+msgid "color table"
msgstr "출력할 래스터맵"
-#: ../general/g.ppmtopng/main.c:81
-#, fuzzy, c-format
-msgid "Unable to open output file %s"
+#: ../raster/r.colors.out/raster_main.c:49
+#, fuzzy
+msgid "Exports the color table associated with a raster map."
msgstr "출력할 래스터맵"
-#: ../general/g.ppmtopng/main.c:117 ../general/g.list/main.c:44
-#: ../general/g.setproj/main.c:78 ../general/g.dirseps/main.c:34
-#: ../general/g.rename/main.c:43 ../general/g.message/main.c:33
-#: ../general/g.access/main.c:37 ../general/g.pnmcat/main.c:121
-#: ../general/g.proj/main.c:63 ../general/g.copy/main.c:41
-#: ../general/g.mlist/main.c:62 ../general/g.remove/main.c:101
-#: ../general/g.gui/main.c:37 ../general/g.version/main.c:60
-#: ../general/g.findetc/main.c:28 ../general/g.filename/main.c:39
-#: ../general/g.cairocomp/main.c:196 ../general/g.findfile/main.c:38
-#: ../general/g.mapsets/main.c:63 ../general/g.mremove/main.c:61
-#: ../general/g.mapset/main.c:49 ../general/g.region/main.c:63
-#: ../general/g.pnmcomp/main.c:282 ../general/g.tempfile/main.c:38
-#: ../general/g.gisenv/main.c:43 ../general/g.mkfontcap/main.c:71
-#: ../locale/scriptstrings/g.manual_to_translate.c:2
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:3
-#: ../locale/scriptstrings/g.extension_to_translate.c:3
-msgid "general"
-msgstr ""
+#: ../raster/r.colors.out/raster_main.c:55
+#: ../raster/r.colors.out/raster3d_main.c:56 ../vector/v.colors.out/main.c:61
+#, fuzzy
+msgid "Path to output rules file"
+msgstr "출력할 래스터맵"
-#: ../general/g.ppmtopng/main.c:118 ../general/g.cairocomp/main.c:197
-#: ../general/g.pnmcomp/main.c:283
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:2
-#: ../locale/scriptstrings/d.redraw_to_translate.c:2
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:2
-#: ../locale/scriptstrings/d.polar_to_translate.c:2
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:2
-#: ../locale/scriptstrings/d.correlate_to_translate.c:2
-#: ../locale/scriptstrings/d.out.file_to_translate.c:2
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:2
-#: ../display/d.path/main.c:48 ../display/d.graph/main.c:58
-#: ../display/d.rhumbline/main.c:43 ../display/d.legend/main.c:85
-#: ../display/d.labels/main.c:43 ../display/d.rgb/main.c:53
-#: ../display/d.grid/main.c:51 ../display/d.linegraph/main.c:119
-#: ../display/d.thematic.area/main.c:77 ../display/d.erase/main.c:29
-#: ../display/d.vect/main.c:70 ../display/d.geodesic/main.c:43
-#: ../display/d.where/main.c:43 ../display/d.colorlist/main.c:35
-#: ../display/d.fontlist/main.c:38 ../display/d.text/main.c:138
-#: ../display/d.colortable/main.c:60 ../display/d.info/main.c:31
-#: ../display/d.northarrow/main.c:42 ../display/d.profile/main.c:191
-#: ../display/d.what.rast/main.c:49 ../display/d.rast.arrow/main.c:95
-#: ../display/d.colors/main.c:40 ../display/d.what.vect/main.c:56
-#: ../display/d.barscale/main.c:54 ../display/d.histogram/main.c:84
-#: ../display/d.rast.num/main.c:75 ../display/d.font/main.c:45
-#: ../display/d.mon/main.c:38 ../display/d.his/main.c:62
-#: ../display/d.extract/main.c:49 ../display/d.vect.chart/main.c:63
-#: ../display/d.measure/main.c:46 ../display/d.title/main.c:49
-#: ../display/d.zoom/main.c:61 ../display/d.rast/main.c:53
-#: ../visualization/ximgview/main.c:290
-msgid "display"
-msgstr ""
+#: ../raster/r.colors.out/raster_main.c:56
+#: ../raster/r.colors.out/raster3d_main.c:57 ../vector/v.colors.out/main.c:62
+#, fuzzy
+msgid "If not given write to standard output"
+msgstr "출력할 래스터맵"
-#: ../general/g.ppmtopng/main.c:119
-msgid "Converts between PPM/PGM and PNG image formats."
-msgstr ""
+#: ../raster/r.colors.out/raster_main.c:61
+#: ../raster/r.colors.out/raster3d_main.c:62 ../vector/v.colors.out/main.c:72
+#, fuzzy
+msgid "Output values as percentages"
+msgstr "출력할 래스터맵"
-#: ../general/g.list/main.c:46 ../general/g.mlist/main.c:64
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:5
-#: ../locale/scriptstrings/t.list_to_translate.c:4
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:5
-msgid "list"
-msgstr ""
+#: ../raster/r.colors.out/raster3d_main.c:50
+#, fuzzy
+msgid "Exports the color table associated with a 3D raster map."
+msgstr "출력할 래스터맵"
-#: ../general/g.list/main.c:48
-msgid "Lists available GRASS data base files of the user-specified data type."
-msgstr ""
+#: ../raster/r.colors.out/raster3d_main.c:70
+#, fuzzy, c-format
+msgid "Unable to read color table for raster3d map <%s>"
+msgstr "출력할 래스터맵"
-#: ../general/g.list/main.c:59 ../general/g.mlist/main.c:128
-msgid "Verbose listing (also list map titles)"
+#: ../raster/r.bitpattern/main.c:65
+msgid "Compares bit patterns with a raster map."
msgstr ""
-#: ../general/g.setproj/proj.c:168
-#, c-format
-msgid "Unrecognized 'ask' value in parms.table: %s"
+#: ../raster/r.bitpattern/main.c:77
+msgid "Bit pattern position(s)"
msgstr ""
-#: ../general/g.setproj/proj.c:178
-#, c-format
-msgid "Unrecognized default value in parms.table: %s"
+#: ../raster/r.bitpattern/main.c:83
+msgid "Bit pattern value"
msgstr ""
-#: ../general/g.setproj/main.c:81
-msgid "Interactively reset the location's projection settings."
+#: ../raster/r.bitpattern/main.c:89
+msgid "Quiet"
msgstr ""
-#: ../general/g.setproj/main.c:88
-msgid "You must be in the PERMANENT mapset to run g.setproj"
+#: ../raster/r.spread/main.c:104 ../raster/r.ros/main.c:215
+msgid "spread"
msgstr ""
-#: ../general/g.setproj/main.c:101
-msgid "PERMANENT: permission denied"
+#: ../raster/r.spread/main.c:107
+msgid "Simulates elliptically anisotropic spread."
msgstr ""
-#: ../general/g.setproj/main.c:105
-msgid "Current region cannot be set"
+#: ../raster/r.spread/main.c:109
+msgid ""
+"Generates a raster map of the cumulative time of spread, given raster maps "
+"containing the rates of spread (ROS), the ROS directions and the spread "
+"origins. It optionally produces raster maps to contain backlink UTM "
+"coordinates for tracing spread paths. Usable for fire spread simulations."
msgstr ""
-#: ../general/g.setproj/main.c:108
-msgid "Retrieving and setting region failed"
+#: ../raster/r.spread/main.c:123
+msgid "Raster map containing maximal ROS (cm/min)"
msgstr ""
-#: ../general/g.setproj/main.c:135
-msgid "Would you still like to change some of the parameters?"
+#: ../raster/r.spread/main.c:125
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the maximum ROS values (cm/minute)."
msgstr ""
-#: ../general/g.setproj/main.c:137
-msgid "The projection information will not be updated"
-msgstr ""
+#: ../raster/r.spread/main.c:135
+#, fuzzy
+msgid "Raster map containing directions of maximal ROS (degree)"
+msgstr "출력할 래스터맵"
-#: ../general/g.setproj/main.c:148
-#, c-format
+#: ../raster/r.spread/main.c:137
msgid ""
-"Zone in default geographic region definition: %d\n"
-" is different from zone in PROJ_INFO file: %d"
+"path containing directions of the maximum ROSes, clockwise from north "
+"(degree)."
msgstr ""
-#: ../general/g.setproj/main.c:158
-msgid "XY-location cannot be projected"
+#: ../raster/r.spread/main.c:148
+msgid "Raster map containing base ROS (cm/min)"
msgstr ""
-#: ../general/g.setproj/main.c:192
-msgid "Unknown projection"
+#: ../raster/r.spread/main.c:150
+msgid ""
+"path containing the ROS values in the directions perpendicular to maximum "
+"ROSes' (cm/minute). These ROSes are also the ones without the effect of "
+"directional factors."
msgstr ""
-#: ../general/g.setproj/main.c:198
-#, c-format
-msgid "Projection %s is not specified in the file 'proj-parms.table'"
-msgstr ""
+#: ../raster/r.spread/main.c:162
+#, fuzzy
+msgid "Raster map containing starting sources"
+msgstr "출력할 래스터맵"
-#: ../general/g.setproj/main.c:205
-msgid "Do you wish to specify a geodetic datum for this location?"
+#: ../raster/r.spread/main.c:164
+msgid ""
+"path containing starting locations of the spread phenomenon. Any positive "
+"integers in this map are recognized as starting sources (seeds)."
msgstr ""
-#: ../general/g.setproj/main.c:214
-#, c-format
-msgid "The current datum is %s (%s)"
+#: ../raster/r.spread/main.c:175
+msgid "Raster map containing maximal spotting distance (m, required with -s)"
msgstr ""
-#: ../general/g.setproj/main.c:217
-msgid "Do you wish to change the datum (or datum transformation parameters)?"
+#: ../raster/r.spread/main.c:177
+msgid ""
+"path containing the maximum potential spotting distances (meters)."
msgstr ""
-#: ../general/g.setproj/main.c:225
-msgid "The datum information has not been changed"
+#: ../raster/r.spread/main.c:187
+msgid "Raster map containing midflame wind speed (ft/min, required with -s)"
msgstr ""
-#: ../general/g.setproj/main.c:288
-#, c-format
-msgid "The current ellipsoid is %s"
+#: ../raster/r.spread/main.c:189 ../raster/r.ros/main.c:279
+msgid ""
+"path containing wind velocities at half of the average flame height (feet/"
+"minute)."
msgstr ""
-#: ../general/g.setproj/main.c:290
-msgid "Do you want to change ellipsoid parameter?"
+#: ../raster/r.spread/main.c:199
+msgid ""
+"Raster map containing fine fuel moisture of the cell receiving a spotting "
+"firebrand (%, required with -s)"
msgstr ""
-#: ../general/g.setproj/main.c:294
-msgid "The ellipse information has not been changed"
+#: ../raster/r.spread/main.c:201 ../raster/r.ros/main.c:240
+msgid ""
+"path containing the 1-hour (<.25\") fuel moisture (percentage content "
+"multiplied by 100)."
msgstr ""
-#: ../general/g.setproj/main.c:311
-#, c-format
-msgid "The radius is currently %f"
+#: ../raster/r.spread/main.c:211
+msgid "Basic sampling window size needed to meet certain accuracy (3)"
msgstr ""
-#: ../general/g.setproj/main.c:312
-msgid "Do you want to change the radius?"
+#: ../raster/r.spread/main.c:213
+msgid ""
+"An odd integer ranging 3 - 15 indicating the basic sampling window size "
+"within which all cells will be considered to see whether they will be "
+"reached by the current spread cell. The default number is 3 which means a "
+"3x3 window."
msgstr ""
-#: ../general/g.setproj/main.c:314 ../general/g.setproj/main.c:320
-msgid "Enter radius for the sphere in meters"
+#: ../raster/r.spread/main.c:223
+msgid "Sampling density for additional computing (range: 0.0 - 1.0 (0.5))"
msgstr ""
-#: ../general/g.setproj/main.c:336
-msgid "Invalid input ellipsoid"
+#: ../raster/r.spread/main.c:225
+msgid ""
+"A decimal number ranging 0.0 - 1.0 indicating additional sampling cells will "
+"be considered to see whether they will be reached by the current spread "
+"cell. The closer to 1.0 the decimal number is, the longer the program will "
+"run and the higher the simulation accuracy will be. The default number is "
+"0.5."
msgstr ""
-#: ../general/g.setproj/main.c:447
-#, c-format
-msgid "The UTM zone is now set to %d"
+#: ../raster/r.spread/main.c:236
+msgid "Initial time for current simulation (0) (min)"
msgstr ""
-#: ../general/g.setproj/main.c:450
-msgid "Do you want to change the UTM zone?"
+#: ../raster/r.spread/main.c:238
+msgid ""
+"A non-negative number specifying the initial time for the current spread "
+"simulation (minutes). This is useful when multiple phase simulation is "
+"conducted. The default time is 0."
msgstr ""
-#: ../general/g.setproj/main.c:451
-msgid "UTM zone information has not been updated"
+#: ../raster/r.spread/main.c:247
+msgid "Simulating time duration LAG (fill the region) (min)"
msgstr ""
-#: ../general/g.setproj/main.c:456
+#: ../raster/r.spread/main.c:249
msgid ""
-"But if you change zone, all the existing data will be interpreted by "
-"projection software. GRASS will not automatically re-project or even change "
-"the headers for existing maps."
+"A non-negative integer specifying the simulating duration time lag "
+"(minutes). The default is infinite, but the program will terminate when the "
+"current geographic region/mask has been filled. It also controls the "
+"computational time, the shorter the time lag, the faster the program will "
+"run."
msgstr ""
-#: ../general/g.setproj/main.c:461
-msgid "Would you still like to change the UTM zone?"
+#: ../raster/r.spread/main.c:261
+msgid "Name of raster map as a display backdrop"
msgstr ""
-#: ../general/g.setproj/main.c:497
-#, fuzzy, c-format
-msgid "Error writing PROJ_INFO file <%s>"
-msgstr "출력할 래스터맵"
-#: ../general/g.setproj/main.c:571
-#, c-format
-msgid "Enter plural form of units [meters]: "
+#: ../raster/r.spread/main.c:263
+msgid ""
+"path to be used as the background on which the \"live\" movement will be "
+"shown."
msgstr ""
-#: ../general/g.setproj/main.c:603
-#, c-format
-msgid "Enter singular for unit: "
+#: ../raster/r.spread/main.c:274
+msgid "Raster map to contain output spread time (min)"
msgstr ""
-#: ../general/g.setproj/main.c:611
-#, c-format
-msgid "Enter conversion factor from %s to meters: "
+#: ../raster/r.spread/main.c:276
+msgid ""
+"Name of the new raster map layer to contain the results of the cumulative "
+"spread time needed for a phenomenon to reach each cell from the starting "
+"sources (minutes)."
msgstr ""
-#: ../general/g.setproj/main.c:636
-#, fuzzy, c-format
-msgid "Error writing into UNITS output file <%s>"
-msgstr "출력할 래스터맵"
-#: ../general/g.setproj/main.c:643
+#: ../raster/r.spread/main.c:286
#, fuzzy
-msgid "Unable to write to DEFAULT_WIND region file"
+msgid "Name of raster map to contain X back coordinates"
msgstr "출력할 래스터맵"
-#: ../general/g.setproj/main.c:645
-#, c-format
+#: ../raster/r.spread/main.c:288
msgid ""
-"\n"
-"Projection information has been recorded for this location\n"
-"\n"
+"Name of the new raster map layer to contain the results of backlink "
+"information in UTM easting coordinates for each cell."
msgstr ""
-#: ../general/g.setproj/main.c:647
-msgid "The geographic region information in WIND is now obsolete"
-msgstr ""
+#: ../raster/r.spread/main.c:298
+#, fuzzy
+msgid "Name of raster map to contain Y back coordinates"
+msgstr "출력할 래스터맵"
-#: ../general/g.setproj/main.c:648
-msgid "Run g.region -d to update it"
+#: ../raster/r.spread/main.c:300
+msgid ""
+"information in UTM northing coordinates for each cell."
msgstr ""
-#: ../general/g.setproj/get_stp.c:43
-msgid "This should not happen see your system admin"
+#: ../raster/r.spread/main.c:307
+msgid "DISPLAY 'live' spread process on screen"
msgstr ""
-#: ../general/g.setproj/get_stp.c:99
+#: ../raster/r.spread/main.c:309
#, fuzzy
-msgid "Unable to open FIPS code file"
+msgid "Display the "
msgstr "출력할 래스터맵"
-#: ../general/g.setproj/get_stp.c:125
-#, c-format
-msgid "No match of fips state %d county %d"
+#: ../raster/r.spread/main.c:312
+msgid "Live display - disabled and depreciated"
msgstr ""
-#: ../general/g.setproj/get_stp.c:179
-#, fuzzy
-msgid "Reading sf key_value temp file"
-msgstr "출력할 래스터맵"
-#: ../general/g.setproj/get_stp.c:212
-msgid "Invalid State FIPS code"
+#: ../raster/r.spread/main.c:317
+msgid "Consider spotting effect (for wildfires)"
msgstr ""
-#: ../general/g.setproj/get_stp.c:302
-#, fuzzy
-msgid "Reading cf key_value temp file"
-msgstr "출력할 래스터맵"
-#: ../general/g.setproj/get_stp.c:336
-msgid "Invalid County FIPS code"
+#: ../raster/r.spread/main.c:329
+msgid "The display feature is disabled"
msgstr ""
-#: ../general/g.dirseps/main.c:37
-msgid "Internal GRASS utility for converting directory separator characters."
-msgstr ""
-#: ../general/g.rename/main.c:45
-#: ../locale/scriptstrings/t.rename_to_translate.c:4
+#: ../raster/r.spread/main.c:494
#, fuzzy
-msgid "rename"
+msgid "Reading inputs..."
msgstr "출력할 래스터맵"
-#: ../general/g.rename/main.c:47
-msgid "Renames data base element files in the user's current mapset."
+#: ../raster/r.spread/main.c:536
+#, c-format
+msgid "Reading %s..."
msgstr ""
-#: ../general/g.rename/main.c:53
-#, fuzzy
-msgid "renamed"
-msgstr "출력할 래스터맵"
-#: ../general/g.rename/main.c:70
+#: ../raster/r.colors/stats.c:39
#, fuzzy, c-format
-msgid "%s <%s> not found"
+msgid "(%i/%i) Reading raster map <%s>..."
msgstr "출력할 래스터맵"
-#: ../general/g.rename/main.c:74
-#, c-format
-msgid "<%s> already exists in mapset <%s>"
+#: ../raster/r.colors/stats.c:73
+msgid "Unable to use logarithmic scaling if range includes zero"
msgstr ""
-#: ../general/g.rename/main.c:84
-#, c-format
-msgid "%s=%s,%s: files could be the same, no rename possible"
+#: ../raster/r.colors/stats.c:118
+msgid "Error opening 3d raster map"
msgstr ""
-#: ../general/g.rename/main.c:94
-#, fuzzy
-msgid "Renaming reclass maps"
+#: ../raster/r.colors/stats.c:125
+#, fuzzy, c-format
+msgid "(%i/%i) Reading map <%s>..."
msgstr "출력할 래스터맵"
-#: ../general/g.message/main.c:34 ../general/g.version/main.c:61
-#: ../general/g.tempfile/main.c:39
+#: ../raster/r.colors/edit_colors.c:61
#, fuzzy
-msgid "support"
+msgid "Creates/modifies the color table associated with a 3D raster map."
msgstr "출력할 래스터맵"
-#: ../general/g.message/main.c:35
+#: ../raster/r.colors/edit_colors.c:65
#, fuzzy
-msgid "scripts"
+msgid "Creates/modifies the color table associated with a raster map."
msgstr "출력할 래스터맵"
-#: ../general/g.message/main.c:37
-msgid ""
-"Prints a message, warning, progress info, or fatal error in the GRASS way."
+#: ../raster/r.colors/edit_colors.c:75 ../raster/r.colors/edit_colors.c:87
+msgid "Map"
msgstr ""
-#: ../general/g.message/main.c:39
-msgid "This module should be used in scripts for messages served to user."
-msgstr ""
-#: ../general/g.message/main.c:43 ../general/g.message/main.c:48
-#: ../general/g.message/main.c:53 ../general/g.message/main.c:58
-#: ../general/g.gui/main.c:54
-msgid "Type"
-msgstr ""
-#: ../general/g.message/main.c:44
-msgid "Print message as warning"
-msgstr ""
-#: ../general/g.message/main.c:49
-msgid "Print message as fatal error"
-msgstr ""
-#: ../general/g.message/main.c:54
-msgid "Print message as debug message"
-msgstr ""
-#: ../general/g.message/main.c:59
-msgid "Print message as progress info"
-msgstr ""
-#: ../general/g.message/main.c:63 ../general/g.message/main.c:69
-#: ../general/g.message/main.c:85
-msgid "Level"
-msgstr ""
-#: ../general/g.message/main.c:64
-msgid "Print message in all modes except of quiet mode"
-msgstr ""
-#: ../general/g.message/main.c:65
-msgid "Message is printed on GRASS_VERBOSE>=1"
-msgstr ""
-#: ../general/g.message/main.c:70
-msgid "Print message only in verbose mode"
-msgstr ""
-#: ../general/g.message/main.c:71
-msgid "Message is printed only on GRASS_VERBOSE>=3"
-msgstr ""
-#: ../general/g.message/main.c:78
+#: ../raster/r.colors/edit_colors.c:81
#, fuzzy
-msgid "Text of the message to be printed"
+msgid "Input file with one map name per line"
msgstr "출력할 래스터맵"
-#: ../general/g.message/main.c:79
-msgid "Message is printed on GRASS_VERBOSE>=2"
+#: ../raster/r.colors/edit_colors.c:83
+msgid ""
+"Input map names can be defined in an input file in case a large amount of "
+"maps must be specified. This option is mutual exclusive to the map option."
msgstr ""
-#: ../general/g.message/main.c:88
-msgid "Level to use for debug messages"
+#: ../raster/r.colors/edit_colors.c:90 ../raster/r.colors/edit_colors.c:97
+#: ../raster/r.colors/edit_colors.c:104 ../raster/r.colors/edit_colors.c:111
+#: ../raster/r.colors/edit_colors.c:122 ../raster/r.colors/edit_colors.c:133
+#: ../raster/r.colors/edit_colors.c:138 ../raster/r.colors/edit_colors.c:143
+#: ../raster/r.colors/edit_colors.c:148 ../raster/r.category/main.c:81
+#: ../raster/r.category/main.c:88 ../vector/v.colors/main.c:81
+#: ../vector/v.colors/main.c:92 ../vector/v.colors/main.c:99
+#: ../vector/v.colors/main.c:106 ../vector/v.colors/main.c:113
+#: ../vector/v.colors/main.c:139 ../vector/v.colors/main.c:144
+#: ../vector/v.colors/main.c:149
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:5
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:7
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:9
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:11
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:18
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:20
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:22
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:24
+msgid "Define"
msgstr ""
-#: ../general/g.message/main.c:95
-msgid "Select only one message level"
-msgstr ""
-#: ../general/g.message/main.c:108
+#: ../raster/r.colors/edit_colors.c:96 ../vector/v.colors/main.c:98
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:6
#, fuzzy
-msgid "Unable to parse input message"
+msgid "Raster map from which to copy color table"
msgstr "출력할 래스터맵"
-#: ../general/g.access/main.c:39
+#: ../raster/r.colors/edit_colors.c:103 ../vector/v.colors/main.c:105
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:8
#, fuzzy
-msgid "permission"
+msgid "3D raster map from which to copy color table"
msgstr "출력할 래스터맵"
-#: ../general/g.access/main.c:41
-msgid "Controls access to the current mapset for other users on the system."
-msgstr ""
-#: ../general/g.access/main.c:42
+#: ../raster/r.colors/edit_colors.c:109 ../vector/v.colors/main.c:111
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:10
#, fuzzy
-msgid "If no option given, prints current status."
+msgid "Path to rules file"
msgstr "출력할 래스터맵"
-#: ../general/g.access/main.c:49
-msgid "Access for group"
-msgstr ""
-#: ../general/g.access/main.c:57
-msgid "Access for others"
-msgstr ""
-#: ../general/g.access/main.c:64
-msgid "UNIX filesystem access controls are not supported by MS-Windows"
-msgstr ""
-#: ../general/g.access/main.c:72
-msgid "Access to the PERMANENT mapset must be open, nothing changed"
-msgstr ""
-#: ../general/g.access/main.c:76
+#: ../raster/r.colors/edit_colors.c:110 ../vector/v.colors/main.c:112
#, fuzzy
-msgid "Unable to determine mapset permissions"
+msgid "\"-\" to read rules from stdin"
msgstr "출력할 래스터맵"
-#: ../general/g.access/set_perms.c:26
-#, fuzzy
-msgid "Unable to change mapset permissions"
-msgstr "출력할 래스터맵"
-#: ../general/g.access/exp_perms.c:11 ../general/g.access/exp_perms.c:29
-msgid "have"
+#: ../raster/r.colors/edit_colors.c:115 ../vector/v.colors/main.c:122
+msgid "Remove existing color table"
msgstr ""
-#: ../general/g.access/exp_perms.c:12
-msgid "read "
+#: ../raster/r.colors/edit_colors.c:121 ../vector/v.colors/main.c:128
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:14
+msgid "Only write new color table if one doesn't already exist"
msgstr ""
-#: ../general/g.access/exp_perms.c:15
-msgid "Everyone"
+#: ../raster/r.colors/edit_colors.c:126 ../vector/v.colors/main.c:132
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:15
+msgid "List available rules then exit"
msgstr ""
-#: ../general/g.access/exp_perms.c:16
-msgid "has"
+#: ../raster/r.colors/edit_colors.c:132 ../vector/v.colors/main.c:138
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:17
+msgid "Invert colors"
msgstr ""
-#: ../general/g.access/exp_perms.c:19
-msgid "Only users in your group"
+#: ../raster/r.colors/edit_colors.c:137 ../vector/v.colors/main.c:143
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:19
+msgid "Logarithmic scaling"
msgstr ""
-#: ../general/g.access/exp_perms.c:22
-msgid "Only users outside your group"
+#: ../raster/r.colors/edit_colors.c:142 ../vector/v.colors/main.c:148
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:21
+msgid "Logarithmic-absolute scaling"
msgstr ""
-#: ../general/g.access/exp_perms.c:25
-msgid "Only you"
+#: ../raster/r.colors/edit_colors.c:147
+#: ../locale/scriptstrings/t.rast.colors_to_translate.c:23
+msgid "Histogram equalization"
msgstr ""
-#: ../general/g.access/exp_perms.c:31
+#: ../raster/r.colors/edit_colors.c:165 ../raster/r.colors/edit_colors.c:173
#, c-format
-msgid "%s %s %s %saccess to mapset %s"
+msgid "Options <%s> and <%s> options are mutually exclusive"
msgstr ""
-#: ../general/g.access/exp_perms.c:32
-msgid "will"
-msgstr ""
-msgid "now"
-msgstr ""
-#: ../general/g.pnmcat/main.c:30 ../general/g.pnmcomp/main.c:54
-msgid "Error reading PPM file"
-msgstr ""
-#: ../general/g.pnmcat/main.c:46 ../general/g.pnmcat/main.c:54
-#: ../general/g.pnmcat/main.c:59 ../general/g.pnmcomp/main.c:69
-#: ../general/g.pnmcomp/main.c:74 ../general/g.pnmcomp/main.c:83
-#: ../general/g.pnmcomp/main.c:134 ../general/g.pnmcomp/main.c:147
-msgid "Invalid PPM file"
-msgstr ""
-#: ../general/g.pnmcat/main.c:49
-msgid "Unsupported PPM file (format = P6 required)"
-msgstr ""
-#: ../general/g.pnmcat/main.c:62
-msgid "Unsupported PPM file (maxval = 255 required)"
-msgstr ""
-#: ../general/g.pnmcat/main.c:83 ../general/g.pnmcomp/main.c:96
+#: ../raster/r.colors/edit_colors.c:169
#, fuzzy, c-format
-msgid "File <%s> not found"
+msgid "Options <%s> or <%s> must be specified"
msgstr "출력할 래스터맵"
-#: ../general/g.pnmcat/main.c:93
-#, c-format
-msgid "File <%s> has wrong height (expected %d, got %d"
-msgstr ""
-#: ../general/g.pnmcat/main.c:128
-#, fuzzy
-msgid "Base name of input files"
+#: ../raster/r.colors/edit_colors.c:182
+#, fuzzy, c-format
+msgid "One of -%c or options <%s>, <%s> or <%s> must be specified"
msgstr "출력할 래스터맵"
-#: ../general/g.pnmcat/main.c:149 ../general/g.cairocomp/main.c:230
-#: ../general/g.pnmcomp/main.c:315
-msgid "Image width"
-msgstr ""
-#: ../general/g.pnmcat/main.c:155 ../general/g.cairocomp/main.c:236
-#: ../general/g.pnmcomp/main.c:321
-msgid "Image height"
-msgstr ""
-#: ../general/g.pnmcat/main.c:181
+#: ../raster/r.colors/edit_colors.c:187
#, c-format
-msgid "Row <%d> has wrong width (expected %d, got %d"
+msgid "Options <%s>, <%s>, and <%s> options are mutually exclusive"
msgstr ""
-#: ../general/g.pnmcat/main.c:186
+#: ../raster/r.colors/edit_colors.c:192 ../vector/v.colors/main.c:227
#, c-format
-msgid "Invalid height (expected %d, got %d"
+msgid "Flags -%c and -%c flags are mutually exclusive"
msgstr ""
-#: ../general/g.pnmcat/main.c:194
+#: ../raster/r.colors/edit_colors.c:248 ../raster/r.colors/edit_colors.c:281
#, fuzzy, c-format
-msgid "Error reading PPM file for tile <%d,%d> at row <%d>"
+msgid "%s map <%s> not found"
msgstr "출력할 래스터맵"
-#: ../general/g.pnmcat/main.c:200
+#: ../raster/r.colors/edit_colors.c:254
#, fuzzy, c-format
-msgid "Error writing PPM file for tile row <%d> at row <%d>"
+msgid "No %s map name found in input file <%s>"
msgstr "출력할 래스터맵"
-#: ../general/g.pnmcat/main.c:209
-#, c-format
-msgid "Incorrect height (expected %d, got %d"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:297
+#, fuzzy, c-format
+msgid "Unable to remove color table of %s map <%s>"
+msgstr "출력할 래스터맵"
-#: ../general/g.proj/datumtrans.c:47
+#: ../raster/r.colors/edit_colors.c:299
#, fuzzy, c-format
-msgid "Invalid datum code <%s>"
+msgid "Color table of %s map <%s> not found"
msgstr "출력할 래스터맵"
-#: ../general/g.proj/datumtrans.c:77
+#: ../raster/r.colors/edit_colors.c:321
#, fuzzy, c-format
-msgid "Datum set to <%s>"
+msgid "Color table exists for %s map <%s>. Exiting."
msgstr "출력할 래스터맵"
-#: ../general/g.proj/datumtrans.c:79
+#: ../raster/r.colors/edit_colors.c:377
#, fuzzy, c-format
-msgid "Ellipsoid set to <%s>"
+msgid "Color table 'random' is not supported for floating point %s map"
msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:65
-#, fuzzy
-msgid "create location"
+#: ../raster/r.colors/edit_colors.c:381
+#, fuzzy, c-format
+msgid "Color table 'grey.eq' is not supported for floating point %s map"
msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:68
-msgid ""
-"Prints and manipulates GRASS projection information files (in various co-"
-"ordinate system descriptions)."
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:387
+#, fuzzy, c-format
+msgid "Color table 'grey.log' is not supported for floating point %s map"
+msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:71
-msgid "Can also be used to create new GRASS locations."
+#: ../raster/r.colors/edit_colors.c:395
+#, c-format
+msgid "Unknown color request '%s'"
msgstr ""
-#: ../general/g.proj/main.c:74
-msgid "Prints and manipulates GRASS projection information files."
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:405 ../vector/v.colors/make_colors.c:51
+#, fuzzy, c-format
+msgid "Unable to load rules file <%s>"
+msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:81
-msgid "Print projection information in conventional GRASS format"
-msgstr ""
+#: ../raster/r.colors/edit_colors.c:422 ../vector/v.colors/main.c:323
+#, fuzzy, c-format
+msgid "Unable to read color table for 3D raster map <%s>"
+msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:87
-#, fuzzy
-msgid "Print projection information in shell script style"
+#: ../raster/r.colors/edit_colors.c:466
+#, fuzzy, c-format
+msgid "Color table for %s map <%s> set to '%s'"
msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:93
-msgid "Verify datum information and print transformation parameters"
+#: ../raster/r.colors/rules.c:40
+#, c-format
+msgid "Enter rules, \"end\" when done, \"help\" if you need it.\n"
msgstr ""
-#: ../general/g.proj/main.c:99
-msgid "Print projection information in PROJ.4 format"
+#: ../raster/r.colors/rules.c:49
+#, c-format
+msgid "fp: Data range is %s to %s\n"
msgstr ""
-#: ../general/g.proj/main.c:105
+#: ../raster/r.colors/rules.c:53
+#, c-format
+msgid "Data range is %ld to %ld\n"
+msgstr ""
+#: ../raster/r.colors/rules.c:64
+#, c-format
msgid ""
-"Print 'flat' output with no linebreaks (applies to WKT and PROJ.4 output)"
+"Your color rules do not cover the whole range of data!\n"
+" (rules %f to %f but data %f to %f)"
msgstr ""
-#: ../general/g.proj/main.c:115
-msgid "Print projection information in WKT format"
+#: ../raster/r.colors/rules.c:105
+#, c-format
+msgid " val color\n"
msgstr ""
-#: ../general/g.proj/main.c:121
-msgid "Use ESRI-style format (applies to WKT output only)"
+#: ../raster/r.colors/rules.c:106
+#, c-format
+msgid " n%% color\n"
msgstr ""
-#: ../general/g.proj/main.c:128 ../general/g.proj/main.c:137
-#: ../general/g.proj/main.c:147 ../general/g.proj/main.c:157
-#, fuzzy
-msgid "Specification"
-msgstr "출력할 래스터맵"
+#: ../raster/r.colors/rules.c:107
+#, c-format
+msgid " nv color\n"
+msgstr ""
-#: ../general/g.proj/main.c:129
-msgid "Name of georeferenced data file to read projection information from"
+#: ../raster/r.colors/rules.c:108
+#, c-format
+msgid " default color\n"
msgstr ""
-#: ../general/g.proj/main.c:138
-#, fuzzy
-msgid "Name of ASCII file containing a WKT projection description"
-msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:148
-msgid "PROJ.4 projection description"
+#: ../raster/r.colors/rules.c:109
+#, c-format
+msgid "color can be one of:\n"
msgstr ""
-#: ../general/g.proj/main.c:158
-msgid "EPSG projection code"
+#: ../raster/r.colors/rules.c:111
+#, c-format
+msgid "or an R:G:B triplet, e.g.: 0:127:255\n"
msgstr ""
-#: ../general/g.proj/main.c:166 ../general/g.proj/main.c:179
-#: ../general/g.proj/main.c:185
-msgid "Datum"
+#: ../raster/r.colors/rules.c:132
+#, c-format
+msgid "bad rule (%s); rule not added"
msgstr ""
-#: ../general/g.proj/main.c:168
-msgid "Datum (overrides any datum specified in input co-ordinate system)"
+#: ../raster/r.colors/rules.c:134
+#, c-format
+msgid "bad rule (%s): [%s]"
msgstr ""
-#: ../general/g.proj/main.c:170
-msgid "Accepts standard GRASS datum codes, or \"list\" to list and exit"
+#: ../raster/r.regression.line/main.c:49
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
msgstr ""
-#: ../general/g.proj/main.c:180
+#: ../raster/r.in.arc/main.c:64
#, fuzzy
-msgid "Index number of datum transform parameters"
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:181
-msgid "\"0\" for unspecified or \"-1\" to list and exit"
-msgstr ""
-#: ../general/g.proj/main.c:187
-msgid ""
-"Force override of datum transformation information in input co-ordinate "
-"system"
-msgstr ""
-#: ../general/g.proj/main.c:193
+#: ../raster/r.in.arc/main.c:68
#, fuzzy
-msgid "Create new projection files (modifies current location)"
+msgid "Name of ARC/INFO ASCII raster file (GRID) to be imported"
msgstr "출력할 래스터맵"
-#: ../general/g.proj/main.c:201 ../general/g.mapset/main.c:83
-#: ../locale/scriptstrings/r.mask_to_translate.c:18
-msgid "Create"
+#: ../raster/r.in.arc/main.c:92 ../raster/r.in.ascii/main.c:103
+msgid "Multiplier for ASCII data"
msgstr ""
-#: ../general/g.proj/main.c:202
-msgid "Name of new location to create"
+#: ../raster/r.in.arc/main.c:126 ../raster/r.in.ascii/main.c:188
+msgid "Can't get cell header"
msgstr ""
-#: ../general/g.proj/main.c:218
+#: ../raster/r.in.arc/main.c:133 ../raster/r.in.ascii/main.c:195
+#: ../raster/r.horizon/main.c:611
#, c-format
-msgid "Only one of '%s', '%s', '%s' or '%s' options may be specified"
+msgid "OOPS: rows changed from %d to %d"
msgstr ""
-#: ../general/g.proj/main.c:261
-msgid "Projection files missing"
+#: ../raster/r.in.arc/main.c:136 ../raster/r.in.ascii/main.c:198
+#: ../raster/r.horizon/main.c:615
+#, c-format
+msgid "OOPS: cols changed from %d to %d"
msgstr ""
-#: ../general/g.proj/main.c:281
+#: ../raster/r.in.arc/main.c:157 ../raster/r.in.ascii/main.c:210
#, c-format
-msgid "Only one of -%c, -%c, -%c, -%c, -%c or -%c flags may be specified"
+msgid "Data conversion failed at row %d, col %d"
msgstr ""
-#: ../general/g.proj/main.c:308
+#: ../raster/r.in.arc/main.c:224
+msgid "Failed to copy file"
+msgstr ""
+#: ../raster/r.in.arc/gethead.c:88
+msgid "Illegal line in header"
+msgstr ""
+#: ../raster/r.in.arc/gethead.c:157 ../raster/r.in.ascii/gethead.c:248
#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, -%c, or -%c"
+msgid "Duplicate \"%s\" field in header"
msgstr ""
-#: ../general/g.proj/main.c:312
+#: ../raster/r.in.arc/gethead.c:162
#, c-format
-msgid "No output format specified, define one of flags -%c, -%c, or -%c"
+msgid "Illegal \"%s\" value in header: \"%s\""
msgstr ""
-#: ../general/g.proj/create.c:17
-#, fuzzy, c-format
-msgid "Unable to create location <%s>: %s"
-msgstr "출력할 래스터맵"
-#: ../general/g.proj/create.c:20
+#: ../raster/r.in.arc/gethead.c:170 ../raster/r.in.ascii/gethead.c:261
#, c-format
-msgid "Unable to create projection files: %s"
+msgid "\"%s\" field missing from header"
msgstr ""
-#: ../general/g.proj/create.c:24
-#, fuzzy, c-format
-msgid "Unable to create location <%s>"
-msgstr "출력할 래스터맵"
-#: ../general/g.proj/create.c:26
+#: ../raster/r.digit/get_label.c:31
#, c-format
-msgid ""
-"You can switch to the new location by\n"
-"`%s=%s`"
+msgid "Enter the category number for this %s: "
msgstr ""
-#: ../general/g.proj/create.c:36
+#: ../raster/r.digit/get_label.c:46
#, c-format
-msgid ""
-"You must select the PERMANENT mapset before updating the current location's "
-"projection (current mapset is <%s>)."
+msgid "Enter a label for category %ld [%s] "
msgstr ""
-#: ../general/g.proj/create.c:62
-msgid ""
-"Default region was updated to the new projection, but if you have multiple "
-"mapsets `g.region -d` should be run in each to update the region from the "
-"default"
+#: ../raster/r.digit/get_label.c:68
+msgid "Look ok? "
msgstr ""
-#: ../general/g.proj/create.c:66
-#, fuzzy
-msgid "Projection information updated"
-msgstr "출력할 래스터맵"
+#: ../raster/r.digit/digitize.c:49
+msgid "Quit without creating a map?? "
+msgstr ""
-#: ../general/g.proj/input.c:91
-msgid "Error reading WKT projection description"
+#: ../raster/r.digit/main.c:46
+msgid ""
+"Interactive tool used to draw and save vector features on a graphics monitor "
+"using a pointing device (mouse) and save to a raster map."
msgstr ""
-#: ../general/g.proj/input.c:98
-#, fuzzy, c-format
-msgid "Unable to open file '%s' for reading"
-msgstr "출력할 래스터맵"
+#: ../raster/r.digit/main.c:55
+msgid "Display commands to be used for canvas backdrop (separated by ';')"
+msgstr ""
-#: ../general/g.proj/input.c:143
-msgid "Can't parse PROJ.4-style parameter string"
+#: ../raster/r.digit/main.c:78
+msgid "No graphics device selected!"
msgstr ""
-#: ../general/g.proj/input.c:181
-#, fuzzy
-msgid "Unable to translate EPSG code"
-msgstr "출력할 래스터맵"
+#: ../raster/r.digit/main.c:97
+msgid "No map created"
+msgstr ""
-#: ../general/g.proj/input.c:218
-msgid "Trying to open with OGR..."
+#: ../raster/r.digit/get_type.c:31
+#, c-format
+msgid "Please choose one of the following\n"
msgstr ""
-#: ../general/g.proj/input.c:226 ../general/g.proj/input.c:245
-msgid "...succeeded."
+#: ../raster/r.digit/get_type.c:32
+#, c-format
+msgid " A define an area\n"
msgstr ""
-#: ../general/g.proj/input.c:239
-msgid "Trying to open with GDAL..."
+#: ../raster/r.digit/get_type.c:33
+#, c-format
+msgid " C define a circle\n"
msgstr ""
-#: ../general/g.proj/input.c:254
+#: ../raster/r.digit/get_type.c:34
#, c-format
-msgid "Could not read georeferenced file %s using either OGR nor GDAL"
+msgid " L define a line\n"
msgstr ""
-#: ../general/g.proj/input.c:259
+#: ../raster/r.digit/get_type.c:35
#, c-format
-msgid ""
-"Read of file %s was successful, but it did not contain projection "
-"information. 'XY (unprojected)' will be used"
+msgid " X exit (and create map)\n"
msgstr ""
-#: ../general/g.proj/output.c:181
+#: ../raster/r.digit/get_type.c:36
#, c-format
-msgid "%s: Unable to convert to WKT"
+msgid " Q quit (without creating map)\n"
msgstr ""
-#: ../general/g.copy/main.c:44
-msgid ""
-"Copies available data files in the current mapset search path to the user's "
-"current mapset."
+#: ../raster/r.li/r.li.padcv/padcv.c:52
+msgid "Calculates coefficient of variation of patch area on a raster map"
msgstr ""
-#: ../general/g.copy/main.c:51
+#: ../raster/r.li/r.li.padcv/padcv.c:54 ../raster/r.li/r.li.mpa/mpa.c:45
+#: ../raster/r.li/r.li.cwed/cwed.c:55 ../raster/r.li/r.li.renyi/renyi.c:48
+#: ../raster/r.li/r.li.patchnum/main.c:51
+#: ../raster/r.li/r.li.shannon/shannon.c:47
+#: ../raster/r.li/r.li.shape/main.c:50 ../raster/r.li/r.li.mps/mps.c:53
+#: ../raster/r.li/r.li.richness/richness.c:44
+#: ../raster/r.li/r.li.padsd/padsd.c:54
+#: ../raster/r.li/r.li.dominance/dominance.c:47
+#: ../raster/r.li/r.li.patchdensity/main.c:52
+#: ../raster/r.li/r.li.pielou/pielou.c:47
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:46
+#: ../raster/r.li/r.li.simpson/simpson.c:47
+#: ../raster/r.li/r.li.padrange/padrange.c:54
#, fuzzy
-msgid "copied"
+msgid "landscape structure analysis"
msgstr "출력할 래스터맵"
-#: ../general/g.copy/main.c:66
-#, fuzzy, c-format
-msgid "<%s> not found"
-msgstr "출력할 래스터맵"
-#: ../general/g.copy/main.c:71
-#, c-format
-msgid "%s=%s,%s: files are the same, no copy required"
+#: ../raster/r.li/r.li.padcv/padcv.c:55 ../raster/r.li/r.li.mpa/mpa.c:46
+#: ../raster/r.li/r.li.cwed/cwed.c:56 ../raster/r.li/r.li.patchnum/main.c:52
+#: ../raster/r.li/r.li.shape/main.c:51 ../raster/r.li/r.li.mps/mps.c:54
+#: ../raster/r.li/r.li.padsd/padsd.c:55
+#: ../raster/r.li/r.li.patchdensity/main.c:53
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:47
+#: ../raster/r.li/r.li.padrange/padrange.c:55
+msgid "patch index"
msgstr ""
-#: ../general/g.copy/main.c:76
-#, c-format
-msgid "<%s> already exists"
+#: ../raster/r.li/r.li.padcv/padcv.c:62 ../raster/r.li/r.li.mpa/mpa.c:53
+#: ../raster/r.li/r.li.cwed/cwed.c:64 ../raster/r.li/r.li.renyi/renyi.c:57
+#: ../raster/r.li/r.li.patchnum/main.c:59
+#: ../raster/r.li/r.li.shannon/shannon.c:56
+#: ../raster/r.li/r.li.shape/main.c:59 ../raster/r.li/r.li.mps/mps.c:62
+#: ../raster/r.li/r.li.richness/richness.c:53
+#: ../raster/r.li/r.li.padsd/padsd.c:62
+#: ../raster/r.li/r.li.dominance/dominance.c:56
+#: ../raster/r.li/r.li.patchdensity/main.c:61
+#: ../raster/r.li/r.li.pielou/pielou.c:56
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:55
+#: ../raster/r.li/r.li.simpson/simpson.c:56
+#: ../raster/r.li/r.li.padrange/padrange.c:62
+msgid "Configuration file"
msgstr ""
-#: ../general/g.mlist/main.c:66
-msgid ""
-"Lists available GRASS data base files of the user-specified data type "
-"optionally using the search pattern."
+#: ../raster/r.li/r.li.mpa/mpa.c:43
+msgid "Calculates mean pixel attribute index on a raster map"
msgstr ""
-#: ../general/g.mlist/main.c:81
-msgid "Map name search pattern (default: all)"
+#: ../raster/r.li/r.li.cwed/cwed.c:53
+msgid "Calculates contrast weighted edge density index on a raster map"
msgstr ""
-#: ../general/g.mlist/main.c:82 ../general/g.mlist/main.c:90
-#: ../general/g.mlist/main.c:103 ../general/g.mlist/main.c:109
-msgid "Pattern"
+#: ../raster/r.li/r.li.cwed/cwed.c:70
+msgid "Name of file that contains the weight to calculate the index"
msgstr ""
-#: ../general/g.mlist/main.c:89
-msgid "Map name exclusion pattern (default: none)"
+#: ../raster/r.li/r.li.cwed/cwed.c:306 ../raster/r.li/r.li.cwed/cwed.c:454
+#: ../raster/r.li/r.li.cwed/cwed.c:601
+msgid "Row cache is too small"
msgstr ""
-#: ../general/g.mlist/main.c:94
+#: ../raster/r.li/r.li.renyi/renyi.c:46
#, fuzzy
-msgid "Name of mapset to list (default: current search path)"
+msgid "Calculates Renyi's diversity index on a raster map"
msgstr "출력할 래스터맵"
-#: ../general/g.mlist/main.c:102 ../general/g.mremove/main.c:70
-msgid "Use basic regular expressions instead of wildcards"
+#: ../raster/r.li/r.li.renyi/renyi.c:49
+#: ../raster/r.li/r.li.shannon/shannon.c:48
+#: ../raster/r.li/r.li.richness/richness.c:45
+#: ../raster/r.li/r.li.dominance/dominance.c:48
+#: ../raster/r.li/r.li.pielou/pielou.c:48
+#: ../raster/r.li/r.li.simpson/simpson.c:48
+msgid "diversity index"
msgstr ""
-#: ../general/g.mlist/main.c:108 ../general/g.mremove/main.c:75
-msgid "Use extended regular expressions instead of wildcards"
+#: ../raster/r.li/r.li.renyi/renyi.c:63
+msgid "Alpha value is the order of the generalized entropy"
msgstr ""
-#: ../general/g.mlist/main.c:113
-#, fuzzy
-msgid "Print data types"
-msgstr "출력할 래스터맵"
+#: ../raster/r.li/r.li.patchnum/main.c:49
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
-#: ../general/g.mlist/main.c:118
-msgid "Print fully-qualified map names (including mapsets)"
+#: ../raster/r.li/r.li.shannon/shannon.c:45
+msgid "Calculates Shannon's diversity index on a raster map"
msgstr ""
-#: ../general/g.mlist/main.c:123
-msgid "Pretty printing in human readable format"
+#: ../raster/r.li/r.li.shape/main.c:48
+msgid "Calculates shape index on a raster map"
msgstr ""
-#: ../general/g.mlist/main.c:135
-msgid "-r and -e are mutually exclusive"
+#: ../raster/r.li/r.li.daemon/daemon.c:99
+msgid "Cannot create random access file"
msgstr ""
-#: ../general/g.mlist/main.c:258
+#: ../raster/r.li/r.li.daemon/daemon.c:107
#, fuzzy, c-format
-msgid "%s available in mapset <%s>:"
+msgid "Cannot create %s/.grass7/ directory"
msgstr "출력할 래스터맵"
-#: ../general/g.remove/main.c:38 ../general/g.mremove/check_reclass.c:18
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> is a base map for <%s>. Remove forced."
-msgstr "출력할 래스터맵"
-#: ../general/g.remove/main.c:41
+#: ../raster/r.li/r.li.daemon/daemon.c:113
#, c-format
-msgid "Raster <%s@%s> is a base map. Remove reclassed map <%s> first."
+msgid "Cannot create %s/.grass7/r.li/ directory"
msgstr ""
-#: ../general/g.remove/main.c:63 ../general/g.remove/main.c:76
+#: ../raster/r.li/r.li.daemon/daemon.c:120
#, c-format
-msgid "Removing information about reclassed map from <%s@%s> failed"
+msgid "Cannot create %s/.grass7/r.li/output/ directory"
msgstr ""
-#: ../general/g.remove/main.c:103 ../general/g.mremove/main.c:63
-#: ../locale/scriptstrings/t.remove_to_translate.c:4
-#, fuzzy
-msgid "remove"
+#: ../raster/r.li/r.li.daemon/daemon.c:203
+#, fuzzy, c-format
+msgid "Cannot find configuration file <%s>"
msgstr "출력할 래스터맵"
-#: ../general/g.remove/main.c:105
-msgid "Removes data base element files from the user's current mapset."
+#: ../raster/r.li/r.li.daemon/daemon.c:210
+#: ../raster/r.li/r.li.daemon/daemon.c:214
+msgid "Cannot read setup file"
msgstr ""
-#: ../general/g.remove/main.c:110
+#: ../raster/r.li/r.li.daemon/daemon.c:218
#, fuzzy
-msgid "Force removal for base raster maps"
+msgid "Unable to parse configuration file (sampling frame)"
msgstr "출력할 래스터맵"
-#: ../general/g.gui/main.c:38
-msgid "gui"
+#: ../raster/r.li/r.li.daemon/daemon.c:477
+msgid "Irregular MASKEDOVERLAY areas definition"
msgstr ""
-#: ../general/g.gui/main.c:40
-msgid "Launches a GRASS graphical user interface (GUI) session."
+#: ../raster/r.li/r.li.daemon/daemon.c:481
+#, c-format
+msgid "The configuration file can only be used with the <%s> raster map"
msgstr ""
-#: ../general/g.gui/main.c:45
-msgid "GUI type"
-msgstr ""
+#: ../raster/r.li/r.li.daemon/daemon.c:487
+#, fuzzy
+msgid "Unable to parse configuration file (sample area)"
+msgstr "출력할 래스터맵"
-#: ../general/g.gui/main.c:46
-msgid "Default value: GRASS_GUI if defined otherwise wxpython"
+#: ../raster/r.li/r.li.daemon/daemon.c:522
+msgid "Too many units to place"
msgstr ""
-#: ../general/g.gui/main.c:50
-msgid "wxPython based GUI (wxGUI)"
-msgstr ""
-#: ../general/g.gui/main.c:51
+#: ../raster/r.li/r.li.daemon/daemon.c:591
#, fuzzy
-msgid "command line interface only"
+msgid "Too many stratified random sample for raster map"
msgstr "출력할 래스터맵"
-#: ../general/g.gui/main.c:60
-msgid "Name of workspace file to load on start-up (valid only for wxGUI)"
+#: ../raster/r.li/r.li.daemon/daemon.c:625
+msgid "Illegal areas disposition"
msgstr ""
-#: ../general/g.gui/main.c:64
-msgid "Update default GUI setting"
+#: ../raster/r.li/r.li.daemon/daemon.c:697
+msgid "Cannot make lseek"
msgstr ""
-#: ../general/g.gui/main.c:65 ../general/g.gui/main.c:71
-msgid "Default"
-msgstr ""
-#: ../general/g.gui/main.c:70
-msgid "Do not launch GUI after updating the default GUI setting"
-msgstr ""
-#: ../general/g.gui/main.c:98
+#: ../raster/r.li/r.li.daemon/worker.c:135
#, c-format
-msgid "<%s> is now the default GUI"
+msgid "unable to open <%s> mask ... continuing without!"
msgstr ""
-#: ../general/g.gui/main.c:112
-#, c-format
-msgid "Launching <%s> GUI in the background, please wait..."
+#: ../raster/r.li/r.li.mps/mps.c:51
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
msgstr ""
-#: ../general/g.version/main.c:62
+#: ../raster/r.li/r.li.richness/richness.c:42
#, fuzzy
-msgid "Displays GRASS version info."
+msgid "Calculates richness index on a raster map"
msgstr "출력할 래스터맵"
-#: ../general/g.version/main.c:63
-msgid "Optionally also print build or copyright information."
+#: ../raster/r.li/r.li.padsd/padsd.c:52
+msgid "Calculates standard deviation of patch area a raster map"
msgstr ""
-#: ../general/g.version/main.c:67
-msgid "Print also the copyright message"
+#: ../raster/r.li/r.li.dominance/dominance.c:45
+msgid "Calculates dominance's diversity index on a raster map"
msgstr ""
-#: ../general/g.version/main.c:68 ../general/g.version/main.c:73
-#: ../general/g.version/main.c:79 ../general/g.version/main.c:85
-msgid "Additional info"
+#: ../raster/r.li/r.li.patchdensity/main.c:50
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../general/g.version/main.c:72
+#: ../raster/r.li/r.li.pielou/pielou.c:45
#, fuzzy
-msgid "Print also the build information"
+msgid "Calculates Pielou's diversity index on a raster map"
msgstr "출력할 래스터맵"
-#: ../general/g.version/main.c:78
-msgid "Print also the GIS library revision number and date"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:44
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
msgstr ""
-#: ../general/g.version/main.c:83
-msgid "Print also extended info for additional libraries"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:65
+msgid "The value of the patch type"
msgstr ""
-#: ../general/g.version/main.c:84
-msgid "GDAL/OGR, PROJ.4, GEOS"
+#: ../raster/r.li/r.li.edgedensity/edgedensity.c:66
+msgid ""
+"It can be integer, double or float; it will be changed in function of map "
+"type"
msgstr ""
-#: ../general/g.version/main.c:89
-#, fuzzy
-msgid "Print info in shell script style (including SVN revision number)"
-msgstr "출력할 래스터맵"
-#: ../general/g.version/main.c:90
-msgid "Shell"
+#: ../raster/r.li/r.li.simpson/simpson.c:45
+msgid "Calculates Simpson's diversity index on a raster map"
msgstr ""
-#: ../general/g.version/main.c:157
-msgid "GRASS not compiled with GDAL/OGR support"
+#: ../raster/r.li/r.li.padrange/padrange.c:52
+msgid "Calculates range of patch area size on a raster map"
msgstr ""
-#: ../general/g.version/main.c:168
-msgid "GRASS not compiled with GEOS support"
+#: ../raster/r.external/proj.c:107
+msgid ""
+"\n"
+"You can use the -o flag to r.external to override this check and use the "
+"location definition for the dataset.\n"
msgstr ""
-#: ../general/g.version/main.c:179
-msgid "GRASS not compiled with SQLite support"
+#: ../raster/r.external/link.c:48
+msgid "Complex types not supported"
msgstr ""
-#: ../general/g.filename/main.c:41
-msgid "Prints GRASS data base file names."
-msgstr ""
+#: ../raster/r.external/link.c:63
+#, fuzzy, c-format
+msgid "Copying color table for %s"
+msgstr "출력할 래스터맵"
-#: ../general/g.filename/main.c:49 ../general/g.findfile/main.c:52
-msgid "Name of an element"
-msgstr ""
+#: ../raster/r.external/link.c:81
+#, fuzzy, c-format
+msgid "Setting grey color table for <%s> (full 8bit range)"
+msgstr "출력할 래스터맵"
-#: ../general/g.filename/main.c:55
-msgid "Name of a database file"
-msgstr ""
-#: ../general/g.filename/main.c:61
-msgid "Name of a mapset (default: current)"
-msgstr ""
-#: ../general/g.cairocomp/main.c:49
+#: ../raster/r.external/link.c:87
#, fuzzy, c-format
-msgid "Unable to read input file <%s>"
+msgid "Setting grey color table for <%s> (data range)"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:52
+#: ../raster/r.external/link.c:101
#, fuzzy, c-format
-msgid "Unable to parse input file <%s>"
+msgid "Unable to create cell/%s file"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:71
+#: ../raster/r.external/link.c:110
#, fuzzy, c-format
-msgid "Unable to write output file <%s>"
+msgid "Unable to create fcell/%s file"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:89 ../general/g.cairocomp/main.c:255
-#: ../visualization/ximgview/main.c:64
-#, fuzzy
-msgid "Unable to open display"
+#: ../raster/r.external/link.c:146
+#, fuzzy, c-format
+msgid "Unable to create cell_misc/%s/gdal file"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:113
-#, fuzzy
-msgid "Unable to obtain visual"
+#: ../raster/r.external/link.c:149
+#, fuzzy, c-format
+msgid "Error writing cell_misc/%s/gdal file"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:129
-#, fuzzy
-msgid "Failed to initialize output surface"
+#: ../raster/r.external/link.c:174
+#, fuzzy, c-format
+msgid "Unable to create cell_misc/%s/f_format file"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:150 ../general/g.pnmcomp/main.c:38
-#, c-format
-msgid "Invalid color: %s"
-msgstr ""
-#: ../general/g.cairocomp/main.c:171
-#, fuzzy
-msgid "Failed to initialize input surface"
+#: ../raster/r.external/link.c:177
+#, fuzzy, c-format
+msgid "Error writing cell_misc/%s/f_format file"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:198
-#, fuzzy
-msgid "Overlays multiple X Pixmaps."
+#: ../raster/r.external/link.c:224
+#, fuzzy, c-format
+msgid "Creating support files for %s"
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:203 ../general/g.pnmcomp/main.c:290
-#, fuzzy
-msgid "Name of input file(s)"
+#: ../raster/r.external/link.c:236
+#, fuzzy, c-format
+msgid "Link to raster map <%s> created."
msgstr "출력할 래스터맵"
-#: ../general/g.cairocomp/main.c:212
-msgid "Output Visual XID"
+#: ../raster/r.external/main.c:57 ../raster/r.external.out/main.c:217
+#: ../vector/v.external.out/main.c:46 ../vector/v.external/main.c:50
+msgid "external"
msgstr ""
-#: ../general/g.cairocomp/main.c:218
-msgid "Output screen"
-msgstr ""
-#: ../general/g.cairocomp/main.c:224 ../general/g.pnmcomp/main.c:302
-msgid "Layer opacities"
-msgstr ""
-#: ../general/g.cairocomp/main.c:239
-msgid "Background color (R:G:B:A)"
-msgstr ""
-#: ../general/g.cairocomp/main.c:244
-msgid "Don't composite; just delete input Pixmaps"
-msgstr ""
-#: ../general/g.cairocomp/main.c:276
-msgid "input= and opacity= must have the same number of values"
-msgstr ""
-#: ../general/g.findfile/main.c:41
-msgid "Searches for GRASS data base files and sets variables for the shell."
-msgstr ""
-#: ../general/g.findfile/main.c:58
+#: ../raster/r.external/main.c:59
#, fuzzy
-msgid "Name of an existing map"
+msgid "Links GDAL supported raster data as a pseudo GRASS raster map."
msgstr "출력할 래스터맵"
-#: ../general/g.findfile/main.c:64
+#: ../raster/r.external/main.c:62
#, fuzzy
-msgid "Name of a mapset (default: search path)"
+msgid "Name of raster file to be linked"
msgstr "출력할 래스터맵"
-#: ../general/g.findfile/main.c:65
+#: ../raster/r.external/main.c:68
#, fuzzy
-msgid "'.' for current mapset"
+msgid "Name of non-file GDAL data source"
msgstr "출력할 래스터맵"
-#: ../general/g.findfile/main.c:69
-msgid "Don't add quotes"
+#: ../raster/r.external/main.c:80
+msgid "Band to select (default: all)"
msgstr ""
-#: ../general/g.findfile/main.c:73
-msgid "List available elements and exit"
+#: ../raster/r.external/main.c:109
+msgid "Flip horizontally"
msgstr ""
-#: ../general/g.findfile/main.c:96
-#, c-format
-msgid ""
-"Parameter 'file' contains reference to <%s> mapset, but mapset parameter <"
-"%s> does not correspond"
+#: ../raster/r.external/main.c:113
+msgid "Flip vertically"
msgstr ""
-#: ../general/g.findfile/element.c:7
-msgid "List of available elements:"
-msgstr ""
-#: ../general/g.mapsets/main.c:64 ../general/g.mapset/main.c:50
-#: ../general/g.region/main.c:64 ../general/g.gisenv/main.c:44
-#: ../display/d.colorlist/main.c:36 ../display/d.fontlist/main.c:39
-#: ../display/d.font/main.c:46
-#, fuzzy
-msgid "settings"
+#: ../raster/r.external/main.c:143
+#, fuzzy, c-format
+msgid "One of options <%s> or <%s> must be given"
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:65
-msgid "search path"
+#: ../raster/r.external/main.c:147
+#, c-format
+msgid "Option <%s> and <%s> are mutually exclusive"
msgstr ""
-#: ../general/g.mapsets/main.c:66
-msgid "Modifies/prints the user's current mapset search path."
-msgstr ""
-#: ../general/g.mapsets/main.c:67
-msgid ""
-"Affects the user's access to data existing under the other mapsets in the "
-"current location."
-msgstr ""
-#: ../general/g.mapsets/main.c:73
-#, fuzzy
-msgid "Name(s) of existing mapset(s) to add/remove or set"
+#: ../raster/r.external/main.c:180
+#, fuzzy, c-format
+msgid "Imagery group <%s> already exists and will be overwritten."
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:74 ../general/g.mapsets/main.c:83
-msgid "Search path"
-msgstr ""
-#: ../general/g.mapsets/main.c:82
-#, fuzzy
-msgid "Operation to perform"
+#: ../raster/r.external/main.c:187
+#, fuzzy, c-format
+msgid "Reading band %d of %d..."
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:87
-#, fuzzy
-msgid "Field separator for printing (-l and -p flags)"
+#: ../raster/r.external/main.c:224
+#, fuzzy, c-format
+msgid "Imagery group <%s> created"
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:93
-msgid "List all available mapsets in alphabetical order"
+#: ../raster/r.external/window.c:23
+msgid ""
+"Input raster map is rotated - cannot import. You may use 'gdalwarp' to "
+"transform the map to North-up."
msgstr ""
-#: ../general/g.mapsets/main.c:99
-msgid "Print mapsets in current search path"
+#: ../raster/r.external/window.c:26
+msgid "Applying horizontal flip"
msgstr ""
-#: ../general/g.mapsets/main.c:105
-msgid "Launch mapset selection GUI dialog"
+#: ../raster/r.external/window.c:30
+msgid "Applying vertical flip"
msgstr ""
-#: ../general/g.mapsets/main.c:128
-#, fuzzy, c-format
-msgid "Unknown operation '%s'"
+#: ../raster/r.external/list.c:22
+#, fuzzy
+msgid "Supported formats:"
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:138 ../general/g.mapsets/main.c:140
-#: ../general/g.mapsets/main.c:150 ../display/d.mon/main.c:138
-#, c-format
-msgid "Flag -%c ignored"
+#: ../raster/r.random/random.c:99
+msgid "Cannot create new table"
msgstr ""
-#: ../general/g.mapsets/main.c:142 ../general/g.mapsets/main.c:152
-#: ../general/g.mapsets/main.c:160 ../display/d.mon/main.c:180
+#: ../raster/r.random/random.c:109
#, fuzzy, c-format
-msgid "Option <%s> ignored"
+msgid "Writing raster map <%s> and vector map <%s> ..."
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:176 ../general/g.mapsets/main.c:210
+#: ../raster/r.random/random.c:112
#, fuzzy, c-format
-msgid "Mapset <%s> not found"
+msgid "Writing raster map <%s> ..."
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:183 ../general/g.mapsets/main.c:242
-#, c-format
-msgid "Current mapset (<%s>) must always included in the search path"
-msgstr ""
+#: ../raster/r.random/random.c:114
+#, fuzzy, c-format
+msgid "Writing vector map <%s> ..."
+msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:205
+#: ../raster/r.random/random.c:189 ../vector/v.net.allpairs/main.c:270
+#: ../vector/v.net.timetable/main.c:134 ../vector/v.net.timetable/main.c:156
+#: ../vector/v.net.flow/main.c:261 ../vector/v.net.centrality/main.c:69
+#: ../vector/v.net.components/main.c:38 ../vector/v.net.distance/main.c:325
+#: ../vector/v.net.path/path.c:313
#, fuzzy, c-format
-msgid "Mapset <%s> already in the path"
+msgid "Cannot insert new record: %s"
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/main.c:212
+#: ../raster/r.random/random.c:242
#, c-format
-msgid "Mapset <%s> added to search path"
+msgid "Only [%ld] random points created"
msgstr ""
-#: ../general/g.mapsets/main.c:245
-#, c-format
-msgid "Mapset <%s> removed from search path"
+#: ../raster/r.random/main.c:52 ../raster/r.random.cells/main.c:46
+#: ../vector/v.what.rast/main.c:72 ../vector/v.drape/main.c:58
+#: ../vector/v.random/main.c:113 ../vector/v.sample/main.c:76
+#: ../vector/v.extrude/main.c:69 ../vector/v.what.rast3/main.c:65
+#: ../display/d.where/main.c:44
+#: ../locale/scriptstrings/t.sample_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:3
+#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:3
+msgid "sampling"
msgstr ""
-#: ../general/g.mapsets/main.c:257
-msgid "Search path not modified"
+#: ../raster/r.random/main.c:54 ../raster/r.surf.random/main.c:38
+#: ../raster/r.random.surface/main.c:59 ../raster/r.random.cells/main.c:47
+#: ../raster/r.surf.gauss/main.c:40 ../vector/v.random/main.c:115
+#: ../vector/v.perturb/main.c:64
+msgid "random"
msgstr ""
-#: ../general/g.mapsets/main.c:275
+#: ../raster/r.random/main.c:56
#, fuzzy
-msgid "Unable to open SEARCH_PATH for write"
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
msgstr "출력할 래스터맵"
-#: ../general/g.mapsets/list.c:10
-msgid "Available mapsets:"
+#: ../raster/r.random/main.c:65
+#, fuzzy
+msgid "Name of cover raster map"
+msgstr "출력할 래스터맵"
+#: ../raster/r.random/main.c:72
+msgid "The number of points to allocate"
msgstr ""
-#: ../general/g.mapsets/list.c:35
-msgid "Accessible mapsets:"
+#: ../raster/r.random/main.c:84
+msgid "Generate points also for NULL category"
msgstr ""
-#: ../general/g.mremove/main.c:65
-msgid ""
-"Removes data base element files from the user's current mapset using regular "
-"expressions."
+#: ../raster/r.random/main.c:89
+msgid "Report information about input raster and exit"
msgstr ""
-#: ../general/g.mremove/main.c:80
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:4
-msgid "Force removal (required for actual deletion of files)"
+#: ../raster/r.random/main.c:93
+msgid "Generate vector points as 3D points"
msgstr ""
-#: ../general/g.mremove/main.c:84
-#, fuzzy
-msgid "Remove base raster maps"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random/main.c:96 ../vector/v.in.ascii/main.c:165
+msgid "Do not build topology in points mode"
+msgstr ""
-#: ../general/g.mremove/main.c:85
-#: ../locale/scriptstrings/r.mask_to_translate.c:5
-#: ../locale/scriptstrings/r.mask_to_translate.c:8
-msgid "Raster"
+#: ../raster/r.random/main.c:97 ../vector/v.in.ascii/main.c:89
+#: ../vector/v.in.ascii/main.c:96 ../vector/v.in.ascii/main.c:108
+#: ../vector/v.in.ascii/main.c:118 ../vector/v.in.ascii/main.c:128
+#: ../vector/v.in.ascii/main.c:138 ../vector/v.in.ascii/main.c:162
+#: ../vector/v.in.ascii/main.c:166 ../vector/v.in.ascii/main.c:172
+#: ../vector/v.out.ascii/args.c:40 ../vector/v.out.ascii/args.c:66
+#: ../vector/v.out.ascii/args.c:76 ../vector/v.out.ascii/args.c:86
+#: ../vector/v.out.ascii/args.c:92
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:16
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:19
+#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:21
+msgid "Points"
msgstr ""
-#: ../general/g.mremove/main.c:92
-#, fuzzy
-msgid "removed"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random/main.c:133
+#, c-format
+msgid "Note: one (or both) of %s and %s must be specified"
+msgstr ""
-#: ../general/g.mremove/main.c:99
+#: ../raster/r.random/main.c:141
#, c-format
-msgid "-%c and -%c are mutually exclusive"
+msgid "<%s=%s> invalid percentage"
msgstr ""
-#: ../general/g.mremove/main.c:103
-msgid "The following data base element files would be deleted:"
+#: ../raster/r.random/main.c:148
+#, c-format
+msgid "<%s=%s> invalid number of points"
msgstr ""
-#: ../general/g.mremove/main.c:127
-#, fuzzy, c-format
-msgid "Unable to compile pattern <%s>"
-msgstr "출력할 래스터맵"
-#: ../general/g.mremove/main.c:152
+#: ../raster/r.random/main.c:161
#, c-format
-msgid "You must use the force flag (-%c) to actually remove them. Exiting."
+msgid "There aren't [%ld] cells in the current region"
msgstr ""
-#: ../general/g.mremove/check_reclass.c:22
-#, fuzzy, c-format
-msgid "Raster map <%s@%s> is a base map. Remove reclassed map first: %s"
-msgstr "출력할 래스터맵"
-#: ../general/g.mremove/check_reclass.c:45
-#: ../general/g.mremove/check_reclass.c:59
+#: ../raster/r.random/main.c:164
#, c-format
-msgid "Removing information about reclassed map from [%s@%s] failed"
+msgid "There aren't [%ld] non-NULL cells in the current region"
msgstr ""
-#: ../general/g.mapset/main.c:51
-#, fuzzy
-msgid "Changes/reports current mapset."
-msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:52
-msgid ""
-"Optionally create new mapset or list available mapsets in given location."
+#: ../raster/r.random/main.c:169
+msgid "There are no valid locations in the current region"
msgstr ""
-#: ../general/g.mapset/main.c:56
+#: ../raster/r.random/count.c:68
#, fuzzy
-msgid "Name of mapset where to switch"
+msgid "Collecting Stats..."
msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:66
-msgid "Location name (not location path)"
+#: ../raster/r.random/count.c:123
+msgid "Programmer error in get_stats/switch"
msgstr ""
-#: ../general/g.mapset/main.c:75
-msgid "GIS data directory"
+#: ../raster/r.thin/thin_lines.c:68
+#, c-format
+msgid "%s: Unable to find bounding box for lines"
msgstr ""
-#: ../general/g.mapset/main.c:76
-msgid "Full path to the directory where the new location is"
+#: ../raster/r.thin/thin_lines.c:71
+#, c-format
+msgid "Bounding box: l = %d, r = %d, t = %d, b = %d"
msgstr ""
-#: ../general/g.mapset/main.c:81
-msgid "Create mapset if it doesn't exist"
+#: ../raster/r.thin/thin_lines.c:118
+#, c-format
+msgid "Pass number %d"
msgstr ""
-#: ../general/g.mapset/main.c:88
-msgid "List available mapsets and exit"
+#: ../raster/r.thin/thin_lines.c:169
+#, c-format
+msgid "Deleted %d pixel"
+msgid_plural "Deleted %d pixels"
+msgstr[0] ""
+msgstr[1] ""
+#: ../raster/r.thin/thin_lines.c:173
+msgid "Thinning completed successfully."
msgstr ""
-#: ../general/g.mapset/main.c:94
+#: ../raster/r.thin/thin_lines.c:175
+msgid "Thinning not completed, consider to increase 'iterations' parameter."
+msgstr ""
+#: ../raster/r.thin/io.c:97
#, fuzzy
-msgid "Print current mapset and exit"
+msgid "Input raster must be of type CELL."
msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:149
-#, fuzzy, c-format
-msgid "<%s> is already the current mapset"
-msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:158
+#. GTC Count of raster rows
+#. GTC Count of window rows
+#: ../raster/r.thin/io.c:104 ../raster/r.thin/io.c:174
+#: ../raster/r.thin/io.c:183 ../vector/v.kernel/main.c:299
+#: ../vector/v.surf.idw/main.c:259 ../display/d.rast.num/main.c:176
#, c-format
-msgid "You don't have permission to use the mapset <%s>"
-msgstr ""
+msgid "%d row"
+msgid_plural "%d rows"
+msgstr[0] ""
+msgstr[1] ""
-#: ../general/g.mapset/main.c:166
+#. GTC Count of raster columns
+#. GTC Count of window columns
+#: ../raster/r.thin/io.c:106 ../raster/r.thin/io.c:176
+#: ../raster/r.thin/io.c:185 ../vector/v.kernel/main.c:300
+#: ../vector/v.surf.idw/main.c:261
#, fuzzy, c-format
-msgid "Unable to create new mapset <%s>"
-msgstr "출력할 래스터맵"
+msgid "%d column"
+msgid_plural "%d columns"
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../general/g.mapset/main.c:169
+#. GTC First argument is the raster map name, second and third - a string representing number of rows and cols
+#: ../raster/r.thin/io.c:108
#, fuzzy, c-format
-msgid "Mapset <%s> does not exist. Use -c flag to create it."
+msgid "Raster map <%s> - %s X %s"
msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:179
-#, fuzzy
-msgid "Unable to read GIS_LOCK environment variable"
-msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:195
+#: ../raster/r.thin/io.c:121
#, c-format
-msgid "Lock file of mapset <%s> cannot be checked"
+msgid "%s: Unable to create temporary file <%s> -- errno = %d"
msgstr ""
-#: ../general/g.mapset/main.c:198
+#: ../raster/r.thin/io.c:130 ../raster/r.thin/io.c:138
+#: ../raster/r.thin/io.c:148
#, c-format
-msgid "There appears to be an active GRASS session in selected mapset <%s>"
+msgid "%s: Error writing temporary file"
msgstr ""
-#: ../general/g.mapset/main.c:204
-#, fuzzy
-msgid "Cleaning up temporary files..."
+#. GTC %s will be replaced with number of rows and columns
+#: ../raster/r.thin/io.c:178
+#, fuzzy, c-format
+msgid "Output map %s X %s"
msgstr "출력할 래스터맵"
-#: ../general/g.mapset/main.c:218
-msgid "Your shell continues to use the history for the old mapset"
-msgstr ""
-#: ../general/g.mapset/main.c:223
+#: ../raster/r.thin/io.c:187
#, c-format
-msgid ""
-"You can switch the history by commands:\n"
-"history -w; history -r %s/.bash_history; HISTFILE=%s/.bash_history"
+msgid "Window %s X %s"
msgstr ""
-#: ../general/g.mapset/main.c:228
-#, c-format
-msgid ""
-"history -S; history -L %s/.history; setenv histfile=%s/.history"
+#: ../raster/r.thin/main.c:59
+msgid "Thins non-zero cells that denote linear features in a raster map layer."
msgstr ""
-#: ../general/g.mapset/main.c:234
-#, c-format
-msgid "Your current mapset is <%s>"
+#: ../raster/r.thin/main.c:71
+msgid "Maximal number of iterations"
msgstr ""
-#: ../general/g.region/main.c:66
-msgid "Manages the boundary definitions for the geographic region."
-msgstr ""
+#: ../raster/r.shaded.relief/main.c:107
+#: ../locale/scriptstrings/d.shadedmap_to_translate.c:3
+#: ../locale/scriptstrings/r.plane_to_translate.c:3
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:3
+#, fuzzy
+msgid "elevation"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:77
-msgid "Save as default region"
+#: ../raster/r.shaded.relief/main.c:109
+msgid "Creates shaded relief map from an elevation map (DEM)."
msgstr ""
-#: ../general/g.region/main.c:78
-msgid "Only possible from the PERMANENT mapset"
-msgstr ""
+#: ../raster/r.shaded.relief/main.c:115
+#, fuzzy
+msgid "Name for output shaded relief map"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:83
-msgid "Print the current region"
+#: ../raster/r.shaded.relief/main.c:116
+msgid "Default: <input_map>.shade"
msgstr ""
-#: ../general/g.region/main.c:88
-msgid "Print the current region in lat/long using the current ellipsoid/datum"
+#: ../raster/r.shaded.relief/main.c:124
+msgid "Altitude of the sun in degrees above the horizon"
msgstr ""
-#: ../general/g.region/main.c:94
-msgid "Print the current region extent"
+#: ../raster/r.shaded.relief/main.c:133
+msgid "Azimuth of the sun in degrees to the east of north"
msgstr ""
-#: ../general/g.region/main.c:100
-msgid "Print the current region map center coordinates"
+#: ../raster/r.shaded.relief/main.c:140
+msgid "Factor for exaggerating relief"
msgstr ""
-#: ../general/g.region/main.c:106
-msgid "Print the current region in GMT style"
+#: ../raster/r.shaded.relief/main.c:148
+msgid "Scale factor for converting meters to elevation units"
msgstr ""
-#: ../general/g.region/main.c:112
-msgid "Print the current region in WMS style"
+#: ../raster/r.shaded.relief/main.c:155
+msgid "Elevation units (overrides scale factor)"
msgstr ""
-#: ../general/g.region/main.c:118
-msgid "Print region resolution in meters (geodesic)"
-msgstr ""
+#: ../raster/r.shaded.relief/main.c:160
+#, fuzzy
+msgid "international feet"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:123
-msgid "Print the convergence angle (degrees CCW)"
+#: ../raster/r.shaded.relief/main.c:161
+msgid "survey feet"
msgstr ""
-#: ../general/g.region/main.c:125
-msgid ""
-"The difference between the projection's grid north and true north, measured "
-"at the center coordinates of the current region."
+#: ../raster/r.shaded.relief/main.c:202
+#, c-format
+msgid "%s=%s - must not be zero"
msgstr ""
-#: ../general/g.region/main.c:131
-msgid "Print also 3D settings"
-msgstr ""
+#: ../raster/r.shaded.relief/main.c:461
+#, fuzzy, c-format
+msgid "Shaded relief raster map <%s> complete"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:137
-msgid "Print the maximum bounding box in lat/long on WGS84"
-msgstr ""
+#: ../raster/r.stream.channel/io.c:297
+#, fuzzy
+msgid "Unrecognisabe data type"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:148
-msgid ""
-"Align region to resolution (default = align to bounds, works only for 2D "
-"resolution)"
+#: ../raster/r.stream.channel/stream_topology.c:52
+#: ../raster/r.stream.channel/stream_topology.c:98
+#: ../raster/r.stream.channel/stream_topology.c:241
+#: ../raster/r.stream.channel/stream_topology.c:291
+msgid "Error finding inits. Stream and direction maps probably do not match..."
msgstr ""
-#: ../general/g.region/main.c:154
-msgid "Do not update the current region"
+#: ../raster/r.stream.channel/stream_topology.c:54
+#: ../raster/r.stream.channel/stream_topology.c:243
+msgid "Stream network may be too dense..."
msgstr ""
-#: ../general/g.region/main.c:155 ../general/g.region/main.c:347
-#: ../vector/v.label/main.c:90 ../vector/v.label/main.c:95
-#: ../vector/v.label/main.c:170 ../vector/v.label/main.c:183
-msgid "Effects"
-msgstr ""
+#: ../raster/r.stream.channel/stream_topology.c:173
+#: ../raster/r.stream.channel/stream_topology.c:379
+#, fuzzy
+msgid "To much points in stream line..."
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:160
-msgid "Set current region from named region"
-msgstr ""
+#: ../raster/r.stream.channel/main.c:60
+#, fuzzy
+msgid "Calculates local parameters for individual streams."
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:167
+#: ../raster/r.stream.channel/main.c:75
#, fuzzy
-msgid "Set region to match raster map(s)"
+msgid "Name for output unique stream identifier raster map"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:175
-msgid "Set region to match 3D raster map(s) (both 2D and 3D values)"
-msgstr ""
+#: ../raster/r.stream.channel/main.c:81
+#, fuzzy
+msgid "Name for output init/join/outlet distance raster map"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:183
+#: ../raster/r.stream.channel/main.c:88
#, fuzzy
-msgid "Set region to match vector map(s)"
+msgid "Name for output elevation init/join/outlet difference raster map"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:239
-msgid "Value for the top edge"
-msgstr ""
+#: ../raster/r.stream.channel/main.c:95
+#, fuzzy
+msgid "Name for output mean init/join/outlet gradient of stream raster map"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:248
-msgid "Value for the bottom edge"
-msgstr ""
+#: ../raster/r.stream.channel/main.c:101
+#, fuzzy
+msgid "Name for output local stream curvature raster map"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:257
-msgid "Number of rows in the new region"
+#: ../raster/r.stream.channel/main.c:114
+msgid "Calculate parameters from outlet (downstream values)"
msgstr ""
-#: ../general/g.region/main.c:258 ../general/g.region/main.c:267
-#: ../general/g.region/main.c:277 ../general/g.region/main.c:287
-#: ../general/g.region/main.c:296 ../general/g.region/main.c:305
-#: ../general/g.region/main.c:314
-msgid "Resolution"
+#: ../raster/r.stream.channel/main.c:118
+msgid "Calculate local values (for current cell)"
msgstr ""
-#: ../general/g.region/main.c:266
-msgid "Number of columns in the new region"
+#: ../raster/r.stream.channel/main.c:122
+msgid "Calculate distance in cell count (ignored local)"
msgstr ""
-#: ../general/g.region/main.c:276
-msgid "2D grid resolution (north-south and east-west)"
-msgstr ""
+#: ../raster/r.stream.channel/main.c:154
+#, fuzzy, c-format
+msgid "All in RAM calculation - direction <%s>..."
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:286
-msgid "3D grid resolution (north-south, east-west and top-bottom)"
+#: ../raster/r.external.out/main.c:38
+#, c-format
+msgid "Supported Formats:\n"
msgstr ""
-#: ../general/g.region/main.c:295
-msgid "North-south 2D grid resolution"
-msgstr ""
+#: ../raster/r.external.out/main.c:111
+#, fuzzy
+msgid "Unable to open GDAL file"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:304
-msgid "East-west 2D grid resolution"
-msgstr ""
+#: ../raster/r.external.out/main.c:135 ../vector/v.external.out/format.c:22
+#, fuzzy, c-format
+msgid "Format <%s> not supported"
+msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:313
-msgid "Top-bottom 3D grid resolution"
-msgstr ""
-#: ../general/g.region/main.c:323
-msgid "Shrink region until it meets non-NULL data from this raster map"
-msgstr ""
-#: ../general/g.region/main.c:334
-msgid "Adjust region cells to cleanly align with this raster map"
-msgstr ""
-#: ../general/g.region/main.c:345
-msgid "Save current region settings in named region file"
-msgstr ""
-#: ../general/g.region/main.c:404
+#: ../raster/r.external.out/main.c:141
#, c-format
-msgid "Region <%s> not found"
+msgid "Format <%s> does not support direct write"
msgstr ""
-#: ../general/g.region/main.c:416
-#, c-format
-msgid "3dview file <%s> not found"
-msgstr ""
-#: ../general/g.region/main.c:421
+#: ../raster/r.external.out/main.c:145 ../vector/v.external.out/format.c:27
#, fuzzy, c-format
-msgid "Unable to open 3dview file <%s> in <%s>"
+msgid "Format <%s> does not support writing"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:427
-#, fuzzy, c-format
-msgid "Unable to read 3dview file <%s> in <%s>"
+#: ../raster/r.external.out/main.c:193
+#, fuzzy
+msgid "Unable to create GDAL file"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:430
-#, c-format
-msgid "Old 3dview file. Region <%s> not found in <%s>"
+#: ../raster/r.external.out/main.c:196
+#, fuzzy
+msgid "Error writing GDAL file"
+msgstr "출력할 래스터맵"
+#: ../raster/r.external.out/main.c:216 ../vector/v.external.out/main.c:45
+msgid "output"
msgstr ""
-#: ../general/g.region/main.c:488
-#, fuzzy, c-format
-msgid "Unable to read header of 3D raster map <%s@%s>"
+#: ../raster/r.external.out/main.c:219
+msgid "Defines raster output format utilizing GDAL library."
+msgstr ""
+#: ../raster/r.external.out/main.c:223
+#, fuzzy
+msgid "Name of output directory"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:514 ../vector/v.out.postgis/main.c:110
-#, fuzzy, c-format
-msgid "Unable to open vector map <%s> on topological level"
+#: ../raster/r.external.out/main.c:230
+#, fuzzy
+msgid "Extension for output files"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:801
-#, fuzzy, c-format
-msgid "Unable to set region <%s>"
+#: ../raster/r.external.out/main.c:236
+#, fuzzy
+msgid "Format of output files"
msgstr "출력할 래스터맵"
-#: ../general/g.region/main.c:807
-msgid "Unable to update current region"
+#: ../raster/r.external.out/main.c:243 ../vector/v.external.out/args.c:38
+#: ../vector/v.out.postgis/args.c:52
+msgid "Creation options"
msgstr ""
-#: ../general/g.region/main.c:815
-msgid "Unable to change default region. The current mapset is not <PERMANENT>."
+#: ../raster/r.external.out/main.c:256
+msgid "Cease using GDAL and revert to native output"
msgstr ""
-#: ../general/g.region/printwindow.c:410
-msgid "You are already in Lat/Long. Use the -p flag instead."
+#: ../raster/r.external.out/main.c:261 ../vector/v.external.out/args.c:61
+msgid "Print current status"
msgstr ""
-#: ../general/g.region/printwindow.c:412
+#: ../raster/r.mode/main.c:58
msgid ""
-"You are in a simple XY location, projection to Lat/Lon is not possible. Use "
-"the -p flag instead."
+"Finds the mode of values in a cover map within areas assigned the same "
+"category value in a user-specified base map."
msgstr ""
-#: ../general/g.region/printwindow.c:637
-msgid ""
-"WGS84 output not possible as this location does not contain datum "
-"transformation parameters. Try running g.setproj."
+#: ../raster/r.mode/main.c:64
+msgid "Base map to be reclassified"
msgstr ""
-#: ../general/g.region/printwindow.c:783
-msgid "Lat/Long calculations are not possible from a simple XY system"
+#: ../raster/r.mode/main.c:71
+msgid "Coverage map"
msgstr ""
-#: ../general/g.pnmcomp/main.c:104
-msgid "Expecting PPM but got PGM"
+#: ../raster/r.mode/main.c:78
+msgid "Output map"
msgstr ""
-#: ../general/g.pnmcomp/main.c:109
-msgid "Expecting PGM but got PPM"
-msgstr ""
+#: ../raster/r.mode/main.c:91
+#, fuzzy, c-format
+msgid "%s: Unable to read category labels"
+msgstr "출력할 래스터맵"
-#: ../general/g.pnmcomp/main.c:112
-#, c-format
-msgid "Invalid magic number: 'P%c'"
+#: ../raster/r.mode/read_stats.c:14
+msgid "reading r.stats output"
msgstr ""
-#: ../general/g.pnmcomp/main.c:125 ../general/g.pnmcomp/main.c:142
-msgid "Invalid PGM file"
+#: ../raster/r.stats.zonal/main.c:104
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
msgstr ""
-#: ../general/g.pnmcomp/main.c:247
-msgid "Error writing PPM file"
+#: ../raster/r.stats.zonal/main.c:148 ../raster/r.stats.quantile/main.c:425
+msgid "Create reclass map with statistics as category labels"
msgstr ""
-#: ../general/g.pnmcomp/main.c:264
-msgid "Error writing PGM file"
-msgstr ""
-#: ../general/g.pnmcomp/main.c:285
-#, fuzzy
-msgid "Overlays multiple PPM image files."
+#: ../raster/r.stats.zonal/main.c:177
+#, fuzzy, c-format
+msgid "Unable to read category file of cover map <%s>"
msgstr "출력할 래스터맵"
-#: ../general/g.pnmcomp/main.c:296
+#: ../raster/r.stats.zonal/main.c:180 ../raster/r.stats.quantile/main.c:478
#, fuzzy
-msgid "Name of input mask file(s)"
+msgid "The base map must be an integer (CELL) map"
msgstr "출력할 래스터맵"
-#: ../general/g.pnmcomp/main.c:309
-#, fuzzy
-msgid "Name for output mask file"
+#: ../raster/r.stats.zonal/main.c:183 ../raster/r.stats.quantile/main.c:481
+#, fuzzy, c-format
+msgid "Unable to read range of base map <%s>"
msgstr "출력할 래스터맵"
-#: ../general/g.tempfile/main.c:41
-msgid "Creates a temporary file and prints it's file name."
+#: ../raster/r.stats.zonal/main.c:247
+msgid "First pass"
msgstr ""
-#: ../general/g.tempfile/main.c:47
-msgid "Process id to use when naming the tempfile"
+#: ../raster/r.stats.zonal/main.c:326
+msgid "Second pass"
msgstr ""
-#: ../general/g.tempfile/main.c:51
-msgid "Dry run - don't create a file, just prints it's file name"
-msgstr ""
+#: ../raster/r.stats.zonal/main.c:473
+#, fuzzy
+msgid "Generating reclass map"
+msgstr "출력할 래스터맵"
-#: ../general/g.parser/main.c:71
-msgid "Usage"
-msgstr ""
+#: ../raster/r.stats.zonal/main.c:495
+#, fuzzy
+msgid "Writing output map"
+msgstr "출력할 래스터맵"
-#: ../general/g.parser/main.c:81
+#: ../raster/r.in.ascii/main.c:74
#, fuzzy
-msgid "Unable to open script file"
+msgid "Converts a GRASS ASCII raster file to binary raster map."
msgstr "출력할 래스터맵"
-#: ../general/g.parser/main.c:96
-#, c-format
-msgid "Line too long or missing newline at line %d\n"
+#: ../raster/r.in.ascii/main.c:89
+msgid "Default: CELL for integer values, DCELL for floating-point values"
msgstr ""
-#: ../general/g.parser/main.c:133
+#: ../raster/r.in.ascii/main.c:101 ../raster/r.in.ascii/main.c:110
#, fuzzy
-msgid "Error closing script file"
+msgid "Default: read from header"
msgstr "출력할 래스터맵"
-#: ../general/g.parser/revoke.c:63
-msgid "G_spawn() failed"
+#: ../raster/r.in.ascii/main.c:111
+msgid "String representing NULL value data cell"
msgstr ""
-#: ../general/g.parser/revoke.c:71
-msgid "execl() failed"
+#: ../raster/r.in.ascii/main.c:112
+msgid "NULL data"
msgstr ""
-#: ../general/g.parser/parse.c:22
-#, c-format
-msgid "Unknown boolean value \"%s\" at line %d\n"
+#: ../raster/r.in.ascii/main.c:117
+msgid "SURFER (Golden Software) ASCII file will be imported"
msgstr ""
-#: ../general/g.parser/parse.c:65
-#, fuzzy, c-format
-msgid "Unknown command \"%s\" at line %d\n"
-msgstr "출력할 래스터맵"
-#: ../general/g.parser/parse.c:97
+#: ../raster/r.in.ascii/main.c:136
#, c-format
-msgid "Unknown module parameter \"%s\" at line %d\n"
+msgid "Wrong entry for multiplier: %s"
msgstr ""
-#: ../general/g.parser/parse.c:134
-#, c-format
-msgid "Unknown flag parameter \"%s\" at line %d\n"
+#: ../raster/r.in.ascii/main.c:161
+msgid "Unable to read input from stdin"
msgstr ""
-#: ../general/g.parser/parse.c:149
+#: ../raster/r.in.ascii/main.c:168
#, c-format
-msgid "Unknown type \"%s\" at line %d\n"
+msgid "Unable to read input from <%s>"
msgstr ""
-#: ../general/g.parser/parse.c:227
-#, c-format
-msgid "Unknown option parameter \"%s\" at line %d\n"
+#: ../raster/r.in.ascii/main.c:283
+msgid "Unable to write to file"
msgstr ""
-#: ../general/g.gisenv/main.c:45
-msgid "variables"
+#: ../raster/r.in.ascii/gethead.c:35
+msgid "input file is not a Surfer ascii grid file"
msgstr ""
-#: ../general/g.gisenv/main.c:47
-msgid "Outputs and modifies the user's current GRASS variable settings."
+#: ../raster/r.in.ascii/gethead.c:41
+msgid "error reading the column and row dimension from the Surfer grid file"
msgstr ""
-#: ../general/g.gisenv/main.c:48
-msgid "Prints all defined GRASS variables if no option is given."
+#: ../raster/r.in.ascii/gethead.c:47
+msgid "error reading the X range from the Surfer grid file"
msgstr ""
-#: ../general/g.gisenv/main.c:53
-msgid "GRASS variable to get"
+#: ../raster/r.in.ascii/gethead.c:53
+msgid "error reading the Y range from the Surfer grid file"
msgstr ""
-#: ../general/g.gisenv/main.c:56
-msgid "Get"
+#: ../raster/r.in.ascii/gethead.c:59
+msgid "error reading the Z range from the Surfer grid file"
msgstr ""
-#: ../general/g.gisenv/main.c:61
-msgid "GRASS variable to set"
+#: ../raster/r.in.ascii/gethead.c:105
+msgid "error getting file position"
msgstr ""
-#: ../general/g.gisenv/main.c:64 ../general/g.gisenv/main.c:72
-#: ../general/g.gisenv/main.c:81 ../db/db.connect/main.c:65
-#: ../db/db.connect/main.c:71 ../db/db.connect/main.c:76
-#: ../db/db.connect/main.c:80 ../db/db.connect/main.c:84
-#: ../db/db.connect/main.c:94 ../temporal/t.connect/main.c:49
-#: ../temporal/t.connect/main.c:55 ../temporal/t.connect/main.c:60
-#: ../temporal/t.connect/main.c:65 ../temporal/t.connect/main.c:69
-msgid "Set"
+#: ../raster/r.in.ascii/gethead.c:164
+msgid "illegal type field: using type int"
msgstr ""
-#: ../general/g.gisenv/main.c:69
-msgid "GRASS variable to unset"
+#: ../raster/r.in.ascii/gethead.c:169
+msgid "ignoring type filed in header, type is set on command line"
msgstr ""
-#: ../general/g.gisenv/main.c:79
-msgid "Where GRASS variable is stored"
+#: ../raster/r.in.ascii/gethead.c:176
+msgid "illegal multiplier field: using 1.0"
msgstr ""
-#: ../general/g.gisenv/main.c:85
-msgid "Use shell syntax (for \"eval\")"
+#: ../raster/r.in.ascii/gethead.c:181
+msgid "ignoring multiplier filed in header, multiplier is set on command line"
msgstr ""
-#: ../general/g.gisenv/main.c:86 ../general/g.gisenv/main.c:91
-#: ../db/db.select/main.c:226 ../db/db.select/main.c:232
-#: ../db/db.select/main.c:239 ../db/db.select/main.c:249
-#: ../db/db.select/main.c:259 ../vector/v.db.select/main.c:69
-#: ../vector/v.db.select/main.c:75 ../vector/v.db.select/main.c:82
-#: ../vector/v.db.select/main.c:99 ../vector/v.db.select/main.c:104
-msgid "Format"
+#: ../raster/r.in.ascii/gethead.c:189
+msgid "ignoring null filed in header, null string is set on command line"
msgstr ""
-#: ../general/g.gisenv/main.c:90
-msgid "Don't use shell syntax"
+#: ../raster/r.in.ascii/gethead.c:218
+msgid "error in ascii data format"
msgstr ""
-#: ../general/g.gisenv/main.c:97
+#: ../raster/r.in.ascii/gethead.c:253
#, c-format
-msgid "Flags -%c and -%c are mutually exclusive"
+msgid "Illegal \"%s\" value in header: %s"
msgstr ""
-#: ../general/g.gisenv/main.c:131 ../vector/v.colors/main.c:222
-#, c-format
-msgid "Options <%s>, <%s>, and <%s> are mutually exclusive"
+#: ../raster/r.to.rast3/main.c:79
+msgid "2d raster maps which represent the slices"
msgstr ""
-#: ../general/g.gisenv/main.c:161
-#, c-format
-msgid "Value '%s' ignored when unsetting the GRASS variable"
+#: ../raster/r.to.rast3/main.c:93
+msgid "Use 3D raster mask (if exists) with output map"
msgstr ""
-#: ../general/g.gisenv/main.c:198
-msgid "GRASS variable not defined"
+#: ../raster/r.to.rast3/main.c:201
+msgid "Converts 2D raster map slices to one 3D raster volume map."
msgstr ""
-#: ../general/g.gisenv/main.c:204
-#, c-format
-msgid "GRASS variable must be uppercase. Using '%s'."
+#: ../raster/r.to.rast3/main.c:213
+msgid "No output map"
msgstr ""
-#: ../general/g.mkfontcap/main.c:73
-msgid ""
-"Generates the font configuration file by scanning various directories for "
-"fonts."
+#: ../raster/r.to.rast3/main.c:262
+#, c-format
+msgid "Open raster map %s - one time for each depth (%d/%d)"
msgstr ""
-#: ../general/g.mkfontcap/main.c:79
-msgid "Overwrite font configuration file if already existing"
+#: ../raster/r.to.rast3/main.c:275
+msgid "Input maps have to be from the same type. CELL, FCELL or DCELL!"
msgstr ""
-#: ../general/g.mkfontcap/main.c:84
-msgid ""
-"Write font configuration file to standard output instead of $GISBASE/etc"
+#: ../raster/r.support.stats/check.c:43
+#, c-format
+msgid "Updating statistics for [%s]..."
msgstr ""
-#: ../general/g.mkfontcap/main.c:91
-msgid "List of extra directories to scan"
+#: ../raster/r.support.stats/check.c:56
+msgid "Updating histogram range..."
msgstr ""
-#: ../general/g.mkfontcap/main.c:93
-msgid ""
-"Comma-separated list of extra directories to scan for Freetype-compatible "
-"fonts as well as the defaults (see documentation)"
-msgstr ""
-#: ../general/g.mkfontcap/main.c:110
+#: ../raster/r.support.stats/check.c:88
#, c-format
-msgid ""
-"Fontcap file %s already exists; use -%c flag if you wish to overwrite it"
+msgid "Updating the number of categories for [%s]..."
msgstr ""
-#: ../general/g.mkfontcap/main.c:122
-msgid ""
-"This GRASS installation was compiled without Freetype support, extradirs "
-"parameter ignored"
+#: ../raster/r.support.stats/main.c:37
+msgid "Update raster map statistics"
msgstr ""
-#: ../general/g.mkfontcap/main.c:149
+#: ../raster/r.support.stats/main.c:49
#, fuzzy, c-format
-msgid "Cannot open %s for writing: %s"
+msgid "Statistics for <%s> updated"
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:53 ../db/db.describe/main.c:50
-#: ../db/db.columns/main.c:43 ../db/db.copy/main.c:100
-#, fuzzy, c-format
-msgid "Table <%s> not found in database <%s> using driver <%s>"
+#: ../raster/r.gwflow/main.c:57
+#, fuzzy
+msgid "Name of input raster map with initial piezometric head in [m]"
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:63 ../db/db.execute/main.c:57
-#, fuzzy, c-format
-msgid "Unable to open file <%s>: %s"
-msgstr "출력할 래스터맵"
+#: ../raster/r.gwflow/main.c:62
+msgid ""
+"Name of input raster map providing Boundary condition status: 0-inactive, 1-"
+"active, 2-dirichlet"
+msgstr ""
-#: ../db/db.select/main.c:81 ../db/db.execute/main.c:76
-#: ../db/db.describe/main.c:61 ../db/db.tables/main.c:47
-#: ../display/d.thematic.area/main.c:210 ../display/d.vect/opt.c:152
-#: ../vector/v.convert/att.c:74
-#, fuzzy, c-format
-msgid "Unable to open database <%s>"
-msgstr "출력할 래스터맵"
+#: ../raster/r.gwflow/main.c:67
+msgid ""
+"Name of input raster map with x-part of the hydraulic conductivity tensor in "
+"[m/s]"
+msgstr ""
-#: ../db/db.select/main.c:104
-#, c-format
-msgid "Test %s."
+#: ../raster/r.gwflow/main.c:72
+msgid ""
+"Name of input raster map with y-part of the hydraulic conductivity tensor in "
+"[m/s]"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
-#: ../imagery/i.rectify/report.c:10
-msgid "failed"
+#: ../raster/r.gwflow/main.c:77
+#, fuzzy
+msgid "Name of input raster map with water sources and sinks in [m^3/s]"
+msgstr "출력할 래스터맵"
+#: ../raster/r.gwflow/main.c:81
+msgid ""
+"Name of input raster map with storativity for confined or effective porosity "
+"for unconfined groundwater flow booth in [-] "
msgstr ""
-msgid "succeeded"
+#: ../raster/r.gwflow/main.c:86
+msgid "Recharge"
msgstr ""
-#: ../db/db.select/main.c:206
+#: ../raster/r.gwflow/main.c:88
#, fuzzy
-msgid "Name of file containing SQL select statement(s)"
+msgid "Recharge input raster map e.g: 6*10^-9 per cell in [m^3/s*m^2]"
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:211
+#: ../raster/r.gwflow/main.c:92
#, fuzzy
-msgid "Name of table to query"
+msgid ""
+"Name of input raster map describing the top surface of the aquifer in [m]"
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:218 ../db/db.select/main.c:223
-#: ../db/db.execute/main.c:144 ../db/db.execute/main.c:149
-#: ../db/db.execute/main.c:154 ../db/db.databases/main.c:78
-#: ../db/db.databases/main.c:89
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:16
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:26
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:28
-#: ../locale/scriptstrings/db.droptable_to_translate.c:7
-#: ../locale/scriptstrings/db.droptable_to_translate.c:10
+#: ../raster/r.gwflow/main.c:96
#, fuzzy
-msgid "Connection"
+msgid ""
+"Name of input raster map describing the bottom surface of the aquifer in [m]"
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:230
-msgid "Vertical record separator (requires -v flag)"
-msgstr ""
+#: ../raster/r.gwflow/main.c:100
+#, fuzzy
+msgid "Output raster map storing the numerical result [m]"
+msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:238 ../vector/v.db.select/main.c:81
-msgid "Null value indicator"
-msgstr ""
+#: ../raster/r.gwflow/main.c:106
+#, fuzzy
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in x "
+"direction [m/s]"
+msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:248 ../vector/v.db.select/main.c:98
-msgid "Do not include column names in output"
-msgstr ""
+#: ../raster/r.gwflow/main.c:112
+#, fuzzy
+msgid ""
+"Output raster map to store the groundwater filter velocity vector part in y "
+"direction [m/s]"
+msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:253
-msgid "Describe query only (don't run it)"
-msgstr ""
+#: ../raster/r.gwflow/main.c:118
+#, fuzzy
+msgid "Output raster map to store the groundwater budget for each cell [m^3/s]"
+msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:258 ../vector/v.db.select/main.c:103
-msgid "Vertical output (instead of horizontal)"
+#: ../raster/r.gwflow/main.c:126
+msgid "The type of groundwater flow"
msgstr ""
-#: ../db/db.select/main.c:263
-msgid "Only test query, do not execute"
-msgstr ""
+#: ../raster/r.gwflow/main.c:132
+#, fuzzy
+msgid "Name of input raster map providing the height of the river bed in [m]"
+msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:268 ../db/db.execute/main.c:125
-#: ../db/db.createdb/main.c:71 ../db/db.describe/main.c:129
-#: ../db/db.columns/main.c:97 ../db/db.connect/main.c:44
-#: ../db/db.login/main.c:39 ../db/db.databases/main.c:93
-#: ../db/db.drivers/main.c:71 ../db/db.copy/main.c:35
-#: ../db/db.dropdb/main.c:71 ../db/db.tables/main.c:94
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
-#: ../locale/scriptstrings/v.db.join_to_translate.c:4
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
-#: ../locale/scriptstrings/db.test_to_translate.c:2
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
-#: ../locale/scriptstrings/db.univar_to_translate.c:2
-#: ../locale/scriptstrings/v.db.update_to_translate.c:4
-#: ../locale/scriptstrings/db.droptable_to_translate.c:2
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
-#: ../temporal/t.connect/main.c:34 ../vector/v.db.select/main.c:54
-#: ../vector/v.vect.stats/main.c:130 ../vector/v.distance/main.c:89
-#: ../vector/v.to.db/main.c:38 ../vector/v.in.db/main.c:54
-#: ../vector/v.db.connect/main.c:53
-msgid "database"
+#: ../raster/r.gwflow/main.c:140
+msgid ""
+"Name of input raster map providing the water level (head) of the river with "
+"leakage connection in [m]"
msgstr ""
-#: ../db/db.select/main.c:269 ../db/db.execute/main.c:126
-#: ../db/db.createdb/main.c:72 ../db/db.describe/main.c:130
-#: ../db/db.columns/main.c:98 ../db/db.connect/main.c:45
-#: ../db/db.databases/main.c:94 ../db/db.copy/main.c:36
-#: ../db/db.dropdb/main.c:72 ../db/db.tables/main.c:95
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.join_to_translate.c:3
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/db.test_to_translate.c:3
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
-#: ../locale/scriptstrings/db.univar_to_translate.c:4
-#: ../locale/scriptstrings/v.db.update_to_translate.c:3
-#: ../locale/scriptstrings/db.droptable_to_translate.c:3
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
-#: ../temporal/t.connect/main.c:35 ../vector/v.what.rast3/main.c:69
-#: ../vector/v.db.select/main.c:53 ../vector/v.vect.stats/main.c:129
-#: ../vector/v.class/main.c:47 ../vector/v.distance/main.c:90
-#: ../vector/v.to.db/main.c:37 ../vector/v.what.rast/main.c:76
-#: ../vector/v.db.connect/main.c:52
+#: ../raster/r.gwflow/main.c:147
#, fuzzy
-msgid "attribute table"
+msgid ""
+"Name of input raster map providing the leakage coefficient of the river bed "
+"in [1/s]."
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:270 ../db/db.execute/main.c:127
-#: ../db/db.execute/main.c:134 ../db/db.execute/main.c:140
-#: ../db/db.createdb/main.c:73 ../db/db.databases/main.c:95
-#: ../db/db.copy/main.c:37 ../db/db.dropdb/main.c:73
-msgid "SQL"
-msgstr ""
+#: ../raster/r.gwflow/main.c:155
+#, fuzzy
+msgid ""
+"Name of input raster map providing the height of the drainage bed in [m]"
+msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:271
+#: ../raster/r.gwflow/main.c:162
#, fuzzy
-msgid "Selects data from attribute table."
+msgid ""
+"Name of input raster map providing the leakage coefficient of the drainage "
+"bed in [1/s]"
msgstr "출력할 래스터맵"
-#: ../db/db.select/main.c:272
-msgid "Performs SQL query statement(s)."
+#: ../raster/r.gwflow/main.c:167
+msgid "The maximum number of iterations in the linearization approach"
msgstr ""
-#: ../db/db.select/main.c:307
-#, c-format
-msgid "You must provide one of these options: <%s>, <%s>, or <%s>"
+#: ../raster/r.gwflow/main.c:176
+msgid ""
+"Allocate a full quadratic linear equation system, default is a sparse linear "
+"equation system."
msgstr ""
-#: ../db/db.execute/main.c:94 ../db/db.execute/main.c:99
-#, c-format
-msgid "Error while executing: '%s'"
+#: ../raster/r.gwflow/main.c:212
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
msgstr ""
-#: ../db/db.execute/main.c:128
-msgid "Executes any SQL statement."
+#: ../raster/r.gwflow/main.c:237
+msgid "Please provide river_head, river_leak and river_bed maps"
msgstr ""
-#: ../db/db.execute/main.c:129
-msgid "For SELECT statements use 'db.select'."
+#: ../raster/r.gwflow/main.c:249
+msgid "Please provide drain_head and drain_leak maps"
msgstr ""
-#: ../db/db.execute/main.c:132
-#, fuzzy
-msgid "SQL statement"
+#: ../raster/r.gwflow/main.c:263
+msgid ""
+"The cholesky solver dos not work with sparse matrices. You may choose a full "
+"filled quadratic matrix, flag -f."
+msgstr ""
+#: ../raster/r.gwflow/main.c:293
+#, fuzzy, c-format
+msgid "Calculation time: %g"
msgstr "출력할 래스터맵"
-#: ../db/db.execute/main.c:133
-msgid "Example: update rybniky set kapri = 'hodne' where kapri = 'malo'"
+#: ../raster/r.gwflow/main.c:380
+#, c-format
+msgid "Calculation of unconfined groundwater flow loop %i"
msgstr ""
-#: ../db/db.execute/main.c:138
+#: ../raster/r.gwflow/main.c:403
+#, c-format
+msgid "Maximum difference between this and last increment: %g"
+msgstr ""
+#: ../raster/r.surf.idw/main.c:108
#, fuzzy
-msgid "Name of file containing SQL statement(s)"
+msgid "Surface interpolation utility for raster map."
msgstr "출력할 래스터맵"
-#: ../db/db.execute/main.c:160
-msgid "Ignore SQL errors and continue"
+#: ../raster/r.surf.idw/main.c:123
+msgid "Output is the interpolation error"
msgstr ""
-#: ../db/db.execute/main.c:161 ../vector/v.build/main.c:51
-#: ../vector/v.build/main.c:77
-msgid "Errors"
-msgstr ""
-#: ../db/db.execute/main.c:167
+#: ../raster/r.surf.idw/main.c:129
#, c-format
-msgid "You must provide <%s> or <%s> option"
+msgid "Illegal value for '%s' (%s)"
msgstr ""
-#: ../db/db.createdb/main.c:74
-msgid "Creates an empty database."
-msgstr ""
-#: ../db/db.describe/main.c:67 ../doc/vector/v.example/main.c:137
-#: ../vector/v.in.ascii/main.c:409 ../vector/v.info/print.c:152
-#: ../vector/v.out.ogr/main.c:591 ../vector/v.out.svg/main.c:164
-#: ../vector/v.patch/main.c:142 ../vector/v.patch/main.c:180
-#: ../vector/v.out.vtk/writeVTK.c:654 ../vector/v.reclass/main.c:178
-#: ../vector/v.db.connect/main.c:227 ../vector/v.out.postgis/table.c:41
-#: ../vector/v.random/main.c:209
+#: ../raster/r.surf.idw/main.c:255
#, fuzzy, c-format
-msgid "Unable to describe table <%s>"
-msgstr "출력할 래스터맵"
+msgid "Interpolating raster map <%s> (%d row)..."
+msgid_plural "Interpolating raster map <%s> (%d rows)..."
-#: ../db/db.describe/main.c:108
-msgid "Print column names only instead of full column descriptions"
+#: ../raster/r.surf.random/main.c:40
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
msgstr ""
-#: ../db/db.describe/main.c:113
-msgid "Print table structure"
+#: ../raster/r.surf.random/main.c:46
+msgid "Minimum random value"
msgstr ""
-#: ../db/db.describe/main.c:131
-msgid "Describes a table in detail."
+#: ../raster/r.surf.random/main.c:52
+msgid "Maximum random value"
msgstr ""
-#: ../db/db.columns/main.c:99
-msgid "List all columns for a given table."
-msgstr ""
-#: ../db/db.connect/main.c:46 ../db/db.login/main.c:40
-#: ../db/db.drivers/main.c:72 ../temporal/t.connect/main.c:36
+#: ../raster/r.surf.random/main.c:58
#, fuzzy
-msgid "connection settings"
+msgid "Create an integer raster map"
msgstr "출력할 래스터맵"
-#: ../db/db.connect/main.c:48
-msgid "Prints/sets general DB connection for current mapset."
-msgstr ""
+#: ../raster/r.surf.random/main.c:66
+#, fuzzy, c-format
+msgid "Raster map <%s> generated."
+msgstr "출력할 래스터맵"
-#: ../db/db.connect/main.c:52 ../temporal/t.connect/main.c:42
-msgid "Print current connection parameters and exit"
-msgstr ""
+#: ../raster/r.category/cats.c:47
+#, fuzzy, c-format
+msgid "Reading <%s> in <%s>"
+msgstr "출력할 래스터맵"
-#: ../db/db.connect/main.c:53
-msgid "Substitute variables in database settings"
-msgstr ""
-#: ../db/db.connect/main.c:58
+#: ../raster/r.category/main.c:53 ../vector/v.category/main.c:76
#, fuzzy
-msgid "Print current connection parameters using shell style and exit"
+msgid "category"
msgstr "출력할 래스터맵"
-#: ../db/db.connect/main.c:64 ../temporal/t.connect/main.c:48
-msgid "Check connection parameters, set if uninitialized, and exit"
+#: ../raster/r.category/main.c:55
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
msgstr ""
-#: ../db/db.connect/main.c:69 ../temporal/t.connect/main.c:53
-msgid "Set from default settings and exit"
-msgstr ""
-#: ../db/db.connect/main.c:70
+#: ../raster/r.category/main.c:62 ../raster/r.category/main.c:71
+#: ../vector/v.edit/args.c:24 ../vector/v.edit/args.c:29
+#: ../vector/v.edit/args.c:112 ../vector/v.edit/args.c:116
+#: ../vector/v.edit/args.c:125 ../vector/v.edit/args.c:134
+#: ../vector/v.edit/args.c:143 ../vector/v.edit/args.c:146
+#: ../vector/v.edit/args.c:164 ../vector/v.edit/args.c:199
+#: ../vector/v.in.db/main.c:94 ../vector/v.drape/main.c:66
+#: ../vector/v.drape/main.c:69 ../vector/v.drape/main.c:72
+#: ../vector/v.drape/main.c:77 ../vector/v.to.points/main.c:67
+#: ../vector/v.to.points/main.c:71 ../vector/v.net.allpairs/main.c:75
+#: ../vector/v.net.allpairs/main.c:81 ../vector/v.net.allpairs/main.c:84
+#: ../vector/v.net.allpairs/main.c:87 ../vector/v.to.rast/main.c:57
+#: ../vector/v.to.rast/main.c:60 ../vector/v.to.rast/main.c:63
+#: ../vector/v.in.ogr/main.c:155 ../vector/v.in.ogr/main.c:168
+#: ../vector/v.in.ogr/main.c:173 ../vector/v.in.ogr/main.c:182
+#: ../vector/v.in.ogr/main.c:198 ../vector/v.in.ogr/main.c:280
+#: ../vector/v.generalize/main.c:92 ../vector/v.generalize/main.c:224
+#: ../vector/v.generalize/main.c:227 ../vector/v.db.select/main.c:60
+#: ../vector/v.db.select/main.c:63 ../vector/v.db.select/main.c:66
+#: ../vector/v.surf.rst/main.c:173 ../vector/v.surf.rst/main.c:185
+#: ../vector/v.random/main.c:129 ../vector/v.random/main.c:132
+#: ../vector/v.random/main.c:135 ../vector/v.random/main.c:138
+#: ../vector/v.category/main.c:85 ../vector/v.category/main.c:89
+#: ../vector/v.category/main.c:93 ../vector/v.select/args.c:18
+#: ../vector/v.select/args.c:23 ../vector/v.select/args.c:32
+#: ../vector/v.select/args.c:37 ../vector/v.select/args.c:104
+#: ../vector/v.buffer/main.c:231 ../vector/v.buffer/main.c:234
+#: ../vector/v.buffer/main.c:237 ../vector/v.buffer/main.c:242
+#: ../vector/v.clean/main.c:60 ../vector/v.clean/main.c:63
+#: ../vector/v.out.postgis/args.c:15 ../vector/v.out.postgis/args.c:19
+#: ../vector/v.reclass/main.c:77 ../vector/v.reclass/main.c:82
+#: ../vector/v.extract/main.c:95 ../vector/v.extract/main.c:100
+#: ../vector/v.extract/main.c:106 ../vector/v.extract/main.c:109
+#: ../vector/v.extract/main.c:112 ../vector/v.extract/main.c:122
+#: ../vector/v.extract/main.c:132 ../vector/v.extrude/main.c:84
+#: ../vector/v.extrude/main.c:87 ../vector/v.extrude/main.c:90
+#: ../vector/v.extrude/main.c:95 ../vector/v.out.ascii/args.c:24
+#: ../vector/v.out.ascii/args.c:28 ../vector/v.out.ascii/args.c:43
+#: ../vector/v.out.ascii/args.c:46 ../vector/v.net.centrality/main.c:121
+#: ../vector/v.net.centrality/main.c:123 ../vector/v.to.3d/args.c:19
+#: ../vector/v.to.3d/args.c:25 ../vector/v.out.ogr/args.c:12
+#: ../vector/v.out.ogr/args.c:22 ../vector/v.out.ogr/args.c:103
+#: ../vector/v.to.db/parse.c:45 ../display/d.vect.chart/main.c:74
+#: ../display/d.vect.chart/main.c:77 ../display/d.thematic.area/main.c:135
+#: ../display/d.thematic.area/main.c:138 ../display/d.vect/main.c:80
+#: ../display/d.vect/main.c:105 ../display/d.vect/main.c:108
+#: ../display/d.vect/main.c:111 ../display/d.vect/main.c:307
+#: ../display/d.rast/main.c:70 ../display/d.rast/main.c:87
+#: ../locale/scriptstrings/v.report_to_translate.c:5
+#: ../locale/scriptstrings/t.list_to_translate.c:6
+#: ../locale/scriptstrings/t.list_to_translate.c:7
+#: ../locale/scriptstrings/t.list_to_translate.c:13
+#: ../locale/scriptstrings/t.list_to_translate.c:14
#, fuzzy
-msgid "Overwrite current settings if already initialized"
+msgid "Selection"
msgstr "출력할 래스터맵"
-#: ../db/db.connect/main.c:92
-msgid "Default group of database users to which select privilege is granted"
+#: ../raster/r.category/main.c:69
+msgid "Comma separated value list"
msgstr ""
-#: ../db/db.connect/main.c:182
-msgid "Database connection not defined. Run db.connect."
+#: ../raster/r.category/main.c:70
+msgid "Example: 1.4,3.8,13"
msgstr ""
-#: ../db/db.connect/main.c:201 ../db/db.connect/main.c:223
-#: ../temporal/t.connect/main.c:133
-#, c-format
-msgid ""
-"Default driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+#: ../raster/r.category/main.c:87
+msgid "File containing category label rules (or \"-\" to read from stdin)"
msgstr ""
-#: ../db/db.connect/main.c:208
-msgid "Default driver is not set"
+#: ../raster/r.category/main.c:95
+msgid "Default label or format string for dynamic labeling"
msgstr ""
-#: ../db/db.connect/main.c:211
-msgid "Default database is not set"
+#: ../raster/r.category/main.c:97
+msgid "Used when no explicit label exists for the category"
msgstr ""
-#: ../db/db.login/main.c:41
-msgid "Sets user/password for DB driver/database."
+#: ../raster/r.category/main.c:105
+msgid "Dynamic label coefficients"
msgstr ""
-#: ../db/db.login/main.c:57
-#, fuzzy
-msgid "Username to set for DB connection"
-msgstr "출력할 래스터맵"
+#: ../raster/r.category/main.c:107
+msgid "Two pairs of category multiplier and offsets, for $1 and $2"
+msgstr ""
-#: ../db/db.login/main.c:65
-#, fuzzy
-msgid "Password to set for DB connection"
+#: ../raster/r.category/main.c:152
+#, fuzzy, c-format
+msgid "Category table for <%s> set from <%s>"
msgstr "출력할 래스터맵"
-#: ../db/db.login/main.c:73
-#, fuzzy
-msgid "Unable to set user/password"
-msgstr "출력할 래스터맵"
-#: ../db/db.login/main.c:77
+#: ../raster/r.category/main.c:211
#, c-format
-msgid "The password was stored in file (%s%cdblogin)"
+msgid ""
+"Incorrect format of input rules. Check separators. Invalid line is:\n"
+"%s"
msgstr ""
-#: ../db/db.databases/main.c:52
-#, fuzzy
-msgid "Unable to list databases"
+#: ../raster/r.category/main.c:267
+#, fuzzy, c-format
+msgid "Unable to read category file of raster map <%s> in <%s>"
msgstr "출력할 래스터맵"
-#: ../db/db.databases/main.c:61
-#, fuzzy
-msgid "No databases found"
-msgstr "출력할 래스터맵"
-#: ../db/db.databases/main.c:85
-#, fuzzy
-msgid "Location"
-msgstr "출력할 래스터맵"
-#: ../db/db.databases/main.c:86
-msgid "Path for SQLite driver, or connection string for PostgreSQL driver"
+#: ../raster/r.category/main.c:283
+msgid "The map is floating point! Ignoring cats list, using vals list"
msgstr ""
-#: ../db/db.databases/main.c:97
-msgid "Lists all databases for a given driver and location."
+#: ../raster/r.category/main.c:300
+msgid "vals argument is required for floating point map!"
msgstr ""
-#: ../db/drivers/ogr/cursor.c:65 ../db/drivers/odbc/cursor.c:36
-#, fuzzy
-msgid "Unable to allocate cursor"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/cursor.c:74
-#, fuzzy
-msgid "Unable to add new token"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/fetch.c:55 ../db/drivers/ogr/fetch.c:188
-#: ../db/drivers/sqlite/fetch.c:265 ../db/drivers/mysql/fetch.c:34
-#: ../db/drivers/mysql/fetch.c:276 ../db/drivers/postgres/fetch.c:33
-msgid "Cursor not found"
+#: ../raster/r.uslek/main.c:55
+msgid "soil"
msgstr ""
-#: ../db/drivers/ogr/fetch.c:71
-msgid "DB_PREVIOUS not supported"
+#: ../raster/r.uslek/main.c:57
+msgid "Computes USLE Soil Erodibility Factor (K)."
msgstr ""
-#: ../db/drivers/ogr/fetch.c:82
+#: ../raster/r.uslek/main.c:62
#, fuzzy
-msgid "DB_LAST not supported"
+msgid "Name of soil sand fraction raster map [0.0-1.0]"
msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/fetch.c:160 ../db/drivers/ogr/describe.c:200
-msgid "Unknown type"
-msgstr ""
-#: ../db/drivers/ogr/execute.c:56 ../vector/v.out.ogr/main.c:544
-#, fuzzy, c-format
-msgid "OGR layer <%s> not found"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/execute.c:69 ../vector/v.vect.stats/main.c:395
-#: ../vector/v.colors.out/make_colors.c:40 ../vector/v.colors/scan_attr.c:34
-#: ../vector/v.distance/main.c:436 ../vector/v.distance/main.c:477
-#: ../vector/v.to.3d/trans3.c:65 ../vector/v.to.3d/trans2.c:63
-#: ../vector/v.reclass/main.c:141
-#, c-format
-msgid "Column <%s> not found in table <%s>"
-msgstr ""
-#: ../db/drivers/ogr/listtab.c:49 ../db/drivers/sqlite/listtab.c:78
-msgid "Unable to db_alloc_string_array()"
-msgstr ""
-#: ../db/drivers/ogr/db.c:56
+#: ../raster/r.uslek/main.c:66
#, fuzzy
-msgid "Had to open data source read-only"
+msgid "Name of soil clay fraction raster map [0.0-1.0]"
msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/db.c:60
+#: ../raster/r.uslek/main.c:70
#, fuzzy
-msgid "Unable to open OGR data source"
+msgid "Name of soil silt fraction raster map [0.0-1.0]"
msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/select.c:50
+#: ../raster/r.uslek/main.c:74
#, fuzzy
-msgid "Unable to select: \n"
+msgid "Name of soil organic matter raster map [0.0-1.0]"
msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/select.c:58 ../db/drivers/ogr/describe.c:63
+#: ../raster/r.uslek/main.c:77
#, fuzzy
-msgid "Unable to describe table\n"
+msgid "Name for output USLE K factor raster map [t.ha.hr/ha.MJ.mm]"
msgstr "출력할 래스터맵"
-#: ../db/drivers/ogr/describe.c:55
-#, fuzzy, c-format
-msgid "OGR layer <%s> does not exist\n"
-msgstr "출력할 래스터맵"
+#: ../raster/r.describe/main.c:57
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
-#: ../db/drivers/ogr/describe.c:112
-#, c-format
-msgid "OGR driver: column '%s', OGR type %d is not supported"
+#: ../raster/r.describe/main.c:76
+msgid "Number of quantization steps"
msgstr ""
-#: ../db/drivers/ogr/describe.c:192
-#, c-format
-msgid ""
-"column '%s', type 'string': unknown width -> stored as varchar(250) some "
-"data may be lost"
+#: ../raster/r.describe/main.c:82
+msgid "Print the output one value per line"
msgstr ""
-#: ../db/drivers/odbc/cursor.c:55 ../db/drivers/sqlite/cursor.c:56
-#: ../db/drivers/postgres/cursor.c:50
-#, fuzzy
-msgid "Unable to add new token."
-msgstr "출력할 래스터맵"
+#: ../raster/r.describe/main.c:86
+msgid "Only print the range of the data"
+msgstr ""
-#: ../db/drivers/odbc/table.c:159
-#, fuzzy, c-format
-msgid "Table %s doesn't exist"
-msgstr "출력할 래스터맵"
+#: ../raster/r.describe/main.c:90
+msgid "Suppress reporting of any NULLs"
+msgstr ""
-#: ../db/drivers/odbc/table.c:176
-#, c-format
-msgid "Table %s isn't 'TABLE' or 'VIEW' but %s"
+#: ../raster/r.describe/main.c:94
+msgid "Use the current region"
msgstr ""
-#: ../db/drivers/odbc/listdb.c:29
-#, fuzzy
-msgid "Unable to allocate handle."
-msgstr "출력할 래스터맵"
+#: ../raster/r.describe/main.c:98
+msgid "Read fp map as integer"
+msgstr ""
-#: ../db/drivers/odbc/listdb.c:40 ../db/drivers/sqlite/listdb.c:147
-#: ../db/drivers/postgres/listdb.c:87
-#, fuzzy
-msgid "Unable to set handle"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/cursor.c:47
-#, fuzzy
-msgid "Unable to allocate cursor."
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/main.c:47
+#: ../raster/r.describe/main.c:110
#, c-format
-msgid "Busy SQLITE db, already waiting for %d seconds..."
+msgid "%s = %s -- must be greater than zero"
msgstr ""
-#: ../db/drivers/sqlite/listdb.c:45 ../db/drivers/postgres/listdb.c:37
-msgid "No path given"
-msgstr ""
-#: ../db/drivers/sqlite/listdb.c:99
+#: ../raster/r.describe/describe.c:94
#, fuzzy, c-format
-msgid "Unable to open directory '%s'"
+msgid "Reading <%s> ..."
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/listdb.c:117
-#, fuzzy, c-format
-msgid "SQLite database connection '%s' is still busy"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/fetch.c:72
+#: ../raster/r.what/main.c:99 ../raster/r.what.color/main.c:89
+#: ../vector/v.what.rast/main.c:75 ../vector/v.what.rast3/main.c:68
+#: ../vector/v.what/main.c:61 ../display/d.what.vect/main.c:59
+#: ../display/d.what.rast/main.c:52 ../display/d.where/main.c:46
+#: ../locale/scriptstrings/i.spectral_to_translate.c:3
#, fuzzy
-msgid "Unable to fetch:"
+msgid "querying"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/fetch.c:87
+#: ../raster/r.what/main.c:100 ../vector/v.what.rast/main.c:74
+#: ../vector/v.what.rast3/main.c:67 ../vector/v.what/main.c:62
+#: ../display/d.what.vect/main.c:58 ../display/d.what.rast/main.c:51
+#: ../display/d.where/main.c:45
#, fuzzy
-msgid "DB_PREVIOUS is not supported"
+msgid "position"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/fetch.c:93
+#: ../raster/r.what/main.c:102
#, fuzzy
-msgid "DB_LAST is not supported"
+msgid "Queries raster maps on their category values and category labels."
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/fetch.c:171 ../db/drivers/postgres/fetch.c:129
-#, fuzzy
-msgid "Unable to scan date:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.what/main.c:106
+msgid "Name of existing raster map(s) to query"
+msgstr ""
-#: ../db/drivers/sqlite/fetch.c:188 ../db/drivers/postgres/fetch.c:147
-#, fuzzy
-msgid "Unable to scan time:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.what/main.c:109 ../vector/v.what/main.c:75
+msgid "Coordinates for query"
+msgstr ""
-#: ../db/drivers/sqlite/fetch.c:203
-#, fuzzy
-msgid "Unable to scan timestamp:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/fetch.c:218
-msgid ""
-"SQLite driver: parsing of interval values not implemented; assuming seconds"
+#: ../raster/r.what/main.c:110 ../raster/r.what/main.c:116
+#: ../vector/v.to.db/parse.c:104 ../vector/v.to.db/parse.c:112
+#: ../db/db.select/main.c:202 ../db/db.select/main.c:208
+#: ../db/db.select/main.c:212 ../db/db.select/main.c:254
+#: ../db/db.select/main.c:264
+msgid "Query"
msgstr ""
-#: ../db/drivers/sqlite/fetch.c:223
+#: ../raster/r.what/main.c:114
#, fuzzy
-msgid "Unable to scan interval:"
+msgid "Name of vector points map for query"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/fetch.c:286
-#, fuzzy
-msgid "Unable to get number of rows:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.what/main.c:139
+msgid "Size of point cache"
+msgstr ""
-#: ../db/drivers/sqlite/create_table.c:122
-#: ../db/drivers/mysql/create_table.c:108
-#: ../db/drivers/postgres/create_table.c:103
-#, fuzzy
-msgid "Unable to create table:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/create_table.c:141 ../db/drivers/sqlite/execute.c:69
-#: ../db/drivers/sqlite/index.c:96 ../db/drivers/sqlite/select.c:80
-#: ../db/drivers/sqlite/describe.c:78 ../db/drivers/sqlite/describe.c:132
-msgid "Error in sqlite3_step():"
+#: ../raster/r.what/main.c:141 ../raster/r.what/main.c:166
+#: ../display/d.legend/main.c:105 ../display/d.legend/main.c:114
+#: ../display/d.legend/main.c:188 ../display/d.legend/main.c:193
+#: ../display/d.legend/main.c:198 ../display/d.legend/main.c:208
+msgid "Advanced"
msgstr ""
-#: ../db/drivers/sqlite/execute.c:53 ../db/drivers/sqlite/select.c:63
-#: ../db/drivers/sqlite/describe.c:60
-msgid "Error in sqlite3_prepare():"
+#: ../raster/r.what/main.c:145
+msgid "Output header row"
msgstr ""
-#: ../db/drivers/sqlite/execute.c:83
+#: ../raster/r.what/main.c:150
#, fuzzy
-msgid "Error in sqlite3_finalize():"
+msgid "Show the category labels of the grid cell(s)"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/execute.c:111
-#, fuzzy
-msgid "'BEGIN' transaction failed:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.what/main.c:155
+msgid "Output color values as RRR:GGG:BBB"
+msgstr ""
-#: ../db/drivers/sqlite/execute.c:139
-#, fuzzy
-msgid "'COMMIT' transaction failed:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.what/main.c:160
+msgid "Output integer category values, not cell values"
+msgstr ""
-#: ../db/drivers/sqlite/listtab.c:50 ../db/drivers/sqlite/listtab.c:66
-#, fuzzy
-msgid "Unable to list tables:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.what/main.c:165
+msgid "Turn on cache reporting"
+msgstr ""
-#: ../db/drivers/sqlite/db.c:98
+#: ../raster/r.what/main.c:205
#, fuzzy, c-format
-msgid "Unable to create directory '%s' for sqlite database"
+msgid "Can only do up to %d raster maps (%d given)"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/db.c:106
-#, fuzzy
-msgid "Unable to open database:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/db.c:130
-#, fuzzy
-msgid "SQLite database connection is still busy"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/db.c:151
+#: ../raster/r.what/main.c:221
#, fuzzy, c-format
-msgid "Database <%s> already exists"
+msgid "Unable to read category file for <%s>"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/db.c:158
-#, fuzzy
-msgid "Unable to create database:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/db.c:182
+#: ../raster/r.what/main.c:300
#, fuzzy, c-format
-msgid "Database <%s> not found"
+msgid "Unable to read vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/index.c:77 ../db/drivers/mysql/index.c:55
-#, fuzzy
-msgid "Unable to create index:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/select.c:95 ../db/drivers/sqlite/describe.c:92
-#: ../db/drivers/mysql/describe.c:32
-#, fuzzy
-msgid "Unable to describe table:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/sqlite/describe.c:194
+#: ../raster/r.what/main.c:304
#, c-format
-msgid "SQLite driver: column '%s', SQLite type %d is not supported"
+msgid "Line %d is not point or centroid, skipped"
msgstr ""
-#: ../db/drivers/mysql/cursor.c:44 ../db/drivers/postgres/cursor.c:41
-#, fuzzy
-msgid "Unable allocate cursor."
+#: ../raster/r.what/main.c:388
+#, fuzzy, c-format
+msgid "%s %s is outside your current region"
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/cursor.c:53
+#: ../raster/r.composite/main.c:73
+#: ../locale/scriptstrings/r.blend_to_translate.c:3
#, fuzzy
-msgid "Unable to add dnew token."
+msgid "composite"
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/dbe.c:45
-msgid "Unable parse MySQL embedded database name"
+#: ../raster/r.composite/main.c:76
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
msgstr ""
-#: ../db/drivers/mysql/dbe.c:61
-msgid "Cannot initialize MySQL embedded server"
+#: ../raster/r.composite/main.c:102
+msgid "Number of levels to be used for each component"
msgstr ""
-#: ../db/drivers/mysql/dbe.c:80
-msgid "Unable to connect to MySQL embedded server: "
+#: ../raster/r.composite/main.c:103 ../raster/r.composite/main.c:121
+msgid "Levels"
msgstr ""
-#: ../db/drivers/mysql/fetch.c:52
-msgid "Cursor position is not supported by MySQL driver"
+#: ../raster/r.composite/main.c:118
+#, c-format
+msgid "Number of levels to be used for <%s>"
msgstr ""
-#: ../db/drivers/mysql/fetch.c:191
-#, fuzzy
-msgid "Unable to scan timestamp: "
-msgstr "출력할 래스터맵"
+#: ../raster/r.composite/main.c:128
+msgid "Dither"
+msgstr ""
-#: ../db/drivers/mysql/fetch.c:200
-msgid "Unknown timestamp format: "
+#: ../raster/r.composite/main.c:132
+msgid "Use closest color"
msgstr ""
-#: ../db/drivers/mysql/fetch.c:215
-#, fuzzy
-msgid "Unable to scan date: "
+#: ../raster/r.composite/main.c:164
+#, fuzzy, c-format
+msgid "Unable to read color file of raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/fetch.c:229
+#: ../raster/r.composite/main.c:286
#, fuzzy
-msgid "Unable to scan time: "
+msgid "Creating color table for output raster map..."
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/fetch.c:245
-#, fuzzy
-msgid "Unable to scan datetime:"
+#: ../raster/r.topidx/new/topidx.c:277 ../raster/r.topidx/topidx.c:277
+#: ../raster/r.topidx/old/topidx.c:277
+#, fuzzy, c-format
+msgid "Number of sinks or boundaries: %d"
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/execute.c:41 ../db/drivers/postgres/execute.c:42
+#: ../raster/r.topidx/new/main.c:42 ../raster/r.topidx/main.c:42
+#: ../raster/r.topidx/old/main.c:42
#, fuzzy
-msgid "Unable to execute:"
+msgid "Creates topographic index map from elevation raster map."
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/execute.c:62
+#: ../raster/r.topidx/new/main.c:48 ../raster/r.topidx/main.c:48
+#: ../raster/r.topidx/old/main.c:48
#, fuzzy
-msgid "Unable to start transaction:"
+msgid "Name for output topographic index map"
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/execute.c:77
+#: ../raster/r.topidx/new/file_io.c:35 ../raster/r.topidx/old/file_io.c:35
+#: ../raster/r.topidx/file_io.c:35
+#, c-format
+msgid ""
+"The current region resolution [%s x %s] is finer than the input map's "
+"resolution [%s x %s]. The current region resolution must be identical to, or "
+"coarser than, the input map's resolution."
+msgstr ""
+#: ../raster/r.topidx/new/file_io.c:42 ../raster/r.topidx/old/file_io.c:42
+#: ../raster/r.topidx/file_io.c:42
#, fuzzy
-msgid "Unable to commit transaction:"
+msgid "Reading elevation map..."
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/listtab.c:37
+#: ../raster/r.topidx/new/file_io.c:87 ../raster/r.topidx/old/file_io.c:87
+#: ../raster/r.topidx/file_io.c:87
#, fuzzy
-msgid "Unable get list of tables:"
+msgid "Writing topographic index map..."
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/db.c:61 ../db/drivers/postgres/db.c:71
-#: ../db/drivers/postgres/db.c:249
+#: ../raster/r.out.vtk/main.c:62
#, fuzzy
-msgid "Connection failed."
+msgid "Converts raster maps into the VTK-ASCII format."
msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/parse.c:61
-msgid "Wrong port number in MySQL database definition: "
+#: ../raster/r.out.vtk/main.c:73
+msgid ""
+"No input maps specified. You need to specify at least one input map or three "
+"vector maps or three rgb maps."
msgstr ""
-#: ../db/drivers/mysql/parse.c:72 ../db/drivers/postgres/parse.c:59
-msgid "'user' in database definition is not supported, use db.login"
+#: ../raster/r.out.vtk/main.c:131 ../raster/r.out.vtk/main.c:191
+#: ../raster/r.out.vtk/main.c:212 ../raster/r.out.vtk/main.c:251
+#, c-format
+msgid "Open Raster file %s"
msgstr ""
-#: ../db/drivers/mysql/parse.c:76 ../db/drivers/postgres/parse.c:63
-msgid "'password' in database definition is not supported, use db.login"
+#: ../raster/r.out.vtk/main.c:222
+msgid "Writing VTK ImageData\n"
msgstr ""
-#: ../db/drivers/mysql/parse.c:81
-msgid "Unknown option in database definition for MySQL: "
+#: ../raster/r.out.vtk/main.c:232
+msgid "Wrong RGB maps. Maps should have the same type! RGB output not added!"
msgstr ""
-#: ../db/drivers/mysql/select.c:42
-#, fuzzy
-msgid "Unable to select data:"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/select.c:64 ../db/drivers/postgres/describe.c:40
-#, fuzzy
-msgid "Unable to describe table."
-msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/describe.c:50 ../db/drivers/postgres/select.c:69
-#, fuzzy
-msgid "Unable to describe table"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/mysql/describe.c:121
-#, c-format
-msgid "MySQL driver: column '%s', type %d is not supported"
+#: ../raster/r.out.vtk/main.c:261
+msgid "Writing VTK Vector Data\n"
msgstr ""
-#: ../db/drivers/mysql/describe.c:127
-#, c-format
+#: ../raster/r.out.vtk/main.c:271
msgid ""
-"column '%s' : type BIGINT is stored as integer (4 bytes) some data may be "
-"damaged"
+"Wrong vector maps. Maps should have the same type! Vector output not added!"
msgstr ""
-#: ../db/drivers/dbf/cursor.c:47
-#, fuzzy
-msgid "Unable to allocate new cursor"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/main.c:283
+msgid "Error closing VTK-ASCII file"
+msgstr ""
-#: ../db/drivers/dbf/cursor.c:59
-#, fuzzy
-msgid "Unable to tokenize new cursor"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:75
+msgid "write_vtk_normal_header: Writing VTK-Header"
+msgstr ""
-#: ../db/drivers/dbf/table.c:117 ../db/drivers/dbf/table.c:170
-#, fuzzy
-msgid "Unable to open DBF file."
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:108
+msgid "write_vtk_structured_elevation_header: Writing VTK-Header"
+msgstr ""
-#: ../db/drivers/dbf/table.c:309
-#, fuzzy, c-format
-msgid "Unable to move '%s' to '%s'."
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:124
+msgid "write_vtk_polygonal_elevation_header: Writing VTK-Header"
+msgstr ""
-#: ../db/drivers/dbf/column.c:49
-#, c-format
-msgid "Column '%s' already exists (duplicate name)"
+#: ../raster/r.out.vtk/writeascii.c:139
+msgid "write_vtk_celldata_header: Writing VTK-DataHeader"
msgstr ""
-#: ../db/drivers/dbf/column.c:99
-#, fuzzy, c-format
-msgid "Column '%s' does not exist"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:148
+msgid "writeVTKPointHeader: Writing VTK-DataHeader"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:72
-msgid "SQL parser error"
+#: ../raster/r.out.vtk/writeascii.c:169
+msgid "write_vtk_structured_coordinates: Writing Coordinates"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:74
-#, fuzzy
-msgid "in statement:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:225
+msgid "write_vtk_polygonal_coordinates: Writing VTK Polygonal data"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:88
-#, fuzzy, c-format
-msgid "Table '%s' doesn't exist."
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:334
+msgid "write_vtk_data: Writing VTK-Data"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:96
-#, fuzzy
-msgid "Unable to load table head."
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.vtk/writeascii.c:384
+msgid "write_vtk_rgb_image_data: Writing VTK-ImageData"
+msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:106
-msgid "Unable to modify table, don't have write permission for DBF file."
+#: ../raster/r.out.vtk/writeascii.c:412
+msgid "Wrong map values! Values should in between 0 and 255!\n"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:121 ../db/drivers/dbf/dbfexe.c:1023
-#, fuzzy, c-format
-msgid "Column '%s' not found"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:145
-msgid "Incompatible value type."
+#: ../raster/r.out.vtk/writeascii.c:442
+msgid "write_vtk_vector_data: Writing VTK-vector data"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:161
+#: ../raster/r.out.vtk/parameters.c:34
#, fuzzy
-msgid "Unable to add column."
+msgid "Raster map(s) to be converted to VTK-ASCII data format"
msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:183
-#, fuzzy
-msgid "Unable to delete column."
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:191
-#, fuzzy, c-format
-msgid "Table %s already exists"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:206
-#, fuzzy
-msgid "Unable to create table."
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:263 ../db/drivers/dbf/dbfexe.c:273
-#: ../db/drivers/dbf/dbfexe.c:303
-#, fuzzy
-msgid "Error in selecting rows"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:552
-#, fuzzy
-msgid "Cannot load table."
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:567
-msgid "Incompatible types in WHERE condition."
+#: ../raster/r.out.vtk/parameters.c:47
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:7
+msgid "Value to represent no data cell"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:572
-msgid "Result of WHERE condition is not of type BOOL."
+#: ../raster/r.out.vtk/parameters.c:55
+msgid "Elevation (if no elevation map is specified)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:588
-msgid "Error in evaluation of WHERE condition."
+#: ../raster/r.out.vtk/parameters.c:61
+#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:8
+msgid ""
+"Create VTK point data instead of VTK cell data (if no elevation map is given)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:600
-#, c-format
-msgid "Unknown result (%d) of WHERE evaluation"
+#: ../raster/r.out.vtk/parameters.c:71
+msgid ""
+"Three (r,g,b) raster maps to create rgb values [redmap,greenmap,bluemap]"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:607
-msgid "Unknown WHERE condition type (bug in DBF driver)."
+#: ../raster/r.out.vtk/parameters.c:81
+msgid "Three (x,y,z) raster maps to create vector values [xmap,ymap,zmap]"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:633
-#, fuzzy, c-format
-msgid "Unable to find order column '%s'"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:778
-msgid "Division by zero"
+#: ../raster/r.out.vtk/parameters.c:106
+msgid "Use structured grid for elevation (not recommended)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:917
-msgid "Value operand for AND"
+#: ../raster/r.out.vtk/parameters.c:112
+msgid "Use polydata-trianglestrips for elevation grid creation"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:931
-msgid "Value operand for OR"
+#: ../raster/r.out.vtk/parameters.c:118
+msgid ""
+"Use polydata-vertices for elevation grid creation (to use with vtkDelauny2D)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:946
-msgid "Value operand for NOT"
+#: ../raster/r.out.vtk/parameters.c:124
+msgid "Scale factor effects the origin (if no elevation map is given)"
msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:954 ../db/drivers/dbf/dbfexe.c:1151
+#: ../raster/r.texture/main.c:67
#, fuzzy, c-format
-msgid "Unknown operator %d"
+msgid "Unknown measure <%s>"
msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:1061
-msgid "Arithmetical operation with strings is not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1083
-msgid "Comparison between string and number is not allowed"
-msgstr ""
-#: ../db/drivers/dbf/dbfexe.c:1098
-#, fuzzy, c-format
-msgid "Comparison '%s' between strings not allowed"
+#: ../raster/r.texture/main.c:104
+#, fuzzy
+msgid "texture"
msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/dbfexe.c:1112
-msgid "Match (~) between numbers not allowed"
+#: ../raster/r.texture/main.c:106
+msgid "Generate images with textural features from a raster map."
msgstr ""
-#: ../db/drivers/dbf/create_table.c:22
+#: ../raster/r.texture/main.c:117
#, fuzzy
-msgid "Unable to create table"
+msgid "Prefix for output raster map(s)"
msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/execute.c:32
-#, fuzzy
-msgid "Unable to execute statement."
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/main.c:124
+msgid "The size of moving window (odd and >= 3)"
+msgstr ""
-#: ../db/drivers/dbf/db.c:93
-#, fuzzy, c-format
-msgid "Unable create DBF database: %s"
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/main.c:134
+msgid "The distance between two samples (>= 1)"
+msgstr ""
-#: ../db/drivers/dbf/db.c:101
-#, fuzzy, c-format
-msgid "Cannot open DBF database directory: %s"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/db.c:109
-#, fuzzy, c-format
-msgid "Unable to open DBF database: %s"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/select.c:44
+#: ../raster/r.texture/main.c:150
#, fuzzy
-msgid "Unable to open cursor."
+msgid "Textural measurement method"
msgstr "출력할 래스터맵"
-#: ../db/drivers/dbf/describe.c:34
-#, fuzzy, c-format
-msgid "Table '%s' doesn't exist"
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/main.c:154
+msgid "Separate output for each angle (0, 45, 90, 135)"
+msgstr ""
-#: ../db/drivers/postgres/priv.c:53
+#: ../raster/r.texture/main.c:158
#, fuzzy
-msgid "Unable grant on table:"
+msgid "Calculate all textural measurements"
msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/listdb.c:56
-#, fuzzy
-msgid "Unable to connect to Postgres:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/main.c:167
+msgid "Size of the moving window must be > 0"
+msgstr ""
-#: ../db/drivers/postgres/listdb.c:67
-#, fuzzy
-msgid "Unable to select from Postgres:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/main.c:169
+msgid "Size of the moving window must be odd"
+msgstr ""
-#: ../db/drivers/postgres/fetch.c:166
-msgid "Unable to scan timestamp (no idea how to process time zone):"
+#: ../raster/r.texture/main.c:172
+msgid "The distance between two samples must be > 0"
msgstr ""
-#: ../db/drivers/postgres/fetch.c:174
-msgid "Unable to scan timestamp (not enough arguments):"
+#: ../raster/r.texture/main.c:193
+msgid "Nothing to compute. Use at least one textural measure."
msgstr ""
-#: ../db/drivers/postgres/fetch.c:188
-#, fuzzy
-msgid "Unable to recognize boolean value"
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/main.c:331
+#, fuzzy, c-format
+msgid "Calculating %d texture measure"
+msgid_plural "Calculating %d texture measures"
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../db/drivers/postgres/fetch.c:206
-#, fuzzy
-msgid "Taken not found"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/create_table.c:90
+#: ../raster/r.texture/main.c:334
#, fuzzy, c-format
-msgid "Unknown column type (%s)"
+msgid "Calculating %s"
msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/create_table.c:132
-#, fuzzy
-msgid "Unable to grant select on table:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.texture/h_measure.c:123
+#, c-format
+msgid ""
+"Too many categories (found: %i, max: %i). Try to rescale or reclassify the "
+"map"
+msgstr ""
-#: ../db/drivers/postgres/execute.c:68
-#, fuzzy
-msgid "Unable to 'BEGIN' transaction"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.surface/main.c:61
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
-#: ../db/drivers/postgres/execute.c:88
+#: ../raster/r.random.surface/main.c:68
#, fuzzy
-msgid "Unable to 'COMMIT' transaction"
+msgid "Name for output raster map(s)"
msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/listtab.c:38
-#, fuzzy
-msgid "Unable to select table names."
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.surface/main.c:77
+msgid "Maximum distance of spatial correlation (value >= 0.0)"
+msgstr ""
-#: ../db/drivers/postgres/listtab.c:65
-#, fuzzy
-msgid "Unable to select view names."
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.surface/main.c:85
+msgid "Distance decay exponent (value > 0.0)"
+msgstr ""
-#: ../db/drivers/postgres/db.c:99
-#, fuzzy
-msgid "Unable to set schema:"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.surface/main.c:94
+msgid "Distance filter remains flat before beginning exponent"
+msgstr ""
-#: ../db/drivers/postgres/db.c:117
-#, fuzzy
-msgid "Unable to select data types"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.surface/main.c:102
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX), default [random]"
+msgstr ""
-#: ../db/drivers/postgres/db.c:268
-#, fuzzy, c-format
-msgid "Unable to create database <%s>"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.surface/main.c:108
+msgid "Maximum cell value of distribution"
+msgstr ""
-#: ../db/drivers/postgres/db.c:270
+#: ../raster/r.random.surface/main.c:113
+msgid "Uniformly distributed cell values"
+msgstr ""
+#: ../raster/r.random.surface/main.c:128 ../raster/r.random.cells/init.c:89
#, fuzzy, c-format
-msgid "Unable to drop database <%s>"
+msgid "Generating raster map <%s>..."
msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/index.c:59
-#, fuzzy
-msgid "Unable to create index:\n"
-msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/parse.c:68
-msgid "Unknown option in database definition for PostgreSQL: "
+#: ../raster/r.random.surface/init.c:73
+#, c-format
+msgid "High (%d) must be greater than 1"
msgstr ""
-#: ../db/drivers/postgres/select.c:31
-msgid "Unable set DATESTYLE"
-msgstr ""
+#: ../raster/r.random.surface/init.c:82
+#, fuzzy, c-format
+msgid "Rastar map <%s> repeated, maps must be unique"
+msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/select.c:55
+#: ../raster/r.random.surface/init.c:92
#, fuzzy
-msgid "Unable to select:"
+msgid "Output raster map required"
msgstr "출력할 래스터맵"
-#: ../db/drivers/postgres/describe.c:123
+#: ../raster/r.random.surface/init.c:108
#, c-format
-msgid "PostgreSQL driver: column '%s', type %d is not supported"
+msgid "Seed (%d) larger than maximum (%d)"
msgstr ""
-#: ../db/drivers/postgres/describe.c:130
+#: ../raster/r.random.surface/init.c:111 ../raster/r.random.surface/init.c:120
#, c-format
-msgid ""
-"column '%s' : type int8 (bigint) is stored as integer (4 bytes) some data "
-"may be damaged"
+msgid " seed is set to %d"
msgstr ""
-#: ../db/drivers/postgres/describe.c:134
+#: ../raster/r.random.surface/init.c:116
#, c-format
-msgid ""
-"column '%s' : type character varying is stored as varchar(250) some data may "
-"be lost"
+msgid "Seed (%d) smaller than minimum (%d)"
msgstr ""
-#: ../db/drivers/postgres/describe.c:140
+#: ../raster/r.random.surface/init.c:159
#, c-format
-msgid ""
-"column '%s' : type bool (boolean) is stored as char(1), values: 0 (false), 1 "
-"(true)"
+msgid "Distance value (%d): %lf must be >= 0.0"
msgstr ""
-#: ../db/db.drivers/main.c:39
-#, fuzzy
-msgid "Unable to read dbmscap file"
-msgstr "출력할 래스터맵"
-#: ../db/db.drivers/main.c:63
-msgid "Full output"
+#: ../raster/r.random.surface/init.c:187
+#, c-format
+msgid "Exponent value (%lf) must be > 0.0"
msgstr ""
-#: ../db/db.drivers/main.c:67
-#, fuzzy
-msgid "Print drivers and exit"
-msgstr "출력할 래스터맵"
-#: ../db/db.drivers/main.c:73
-msgid "Lists all database drivers."
+#: ../raster/r.random.surface/init.c:211
+#, c-format
+msgid "Flat value (%lf) must be less than distance value (%lf)"
msgstr ""
-#: ../db/db.copy/main.c:38
-#, fuzzy
-msgid "Copy a table."
-msgstr "출력할 래스터맵"
-#: ../db/db.copy/main.c:40
-msgid ""
-"Either 'from_table' (optionally with 'where') can be used or 'select' "
-"option, but not 'from_table' and 'select' at the same time."
+#: ../raster/r.random.surface/init.c:232
+msgid "Must have a distance value for each filter"
msgstr ""
-#: ../db/db.copy/main.c:46
-msgid "Input driver name"
+#: ../raster/r.random.surface/init.c:264
+msgid "Must have a exponent value for each filter"
msgstr ""
-#: ../db/db.copy/main.c:52
-msgid "Input database name"
+#: ../raster/r.random.surface/init.c:281
+msgid "Must have a weight value for each filter"
msgstr ""
-#: ../db/db.copy/main.c:59
-msgid "Input table name (only, if 'select' is not used)"
+#: ../raster/r.out.gridatb/main.c:70
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
msgstr ""
-#: ../db/db.copy/main.c:65
-msgid "Output driver name"
+#: ../raster/r.le/r.le.trace/main.c:57
+msgid ""
+"Displays the boundary of each r.le patch and shows how the boundary is "
+"traced, displays the attribute, size, perimeter and shape indices for each "
+"patch and saves the data in an output file."
msgstr ""
-#: ../db/db.copy/main.c:71
-msgid "Output database name"
+#: ../raster/r.le/r.le.trace/user_input.c:35
+msgid "Include sampling area boundary as perimeter"
msgstr ""
-#: ../db/db.copy/main.c:78
-msgid "Output table name"
+#: ../raster/r.le/r.le.trace/user_input.c:39
+msgid "Use 4 neighbor tracing instead of 8 neighbor"
msgstr ""
-#: ../db/db.copy/main.c:87
-msgid "Full select statement (only, if 'from_table' and 'where' is not used)"
-msgstr ""
+#: ../raster/r.le/r.le.trace/user_input.c:42
+#, fuzzy
+msgid "Raster map to be analyzed"
+msgstr "출력할 래스터맵"
-#: ../db/db.copy/main.c:88
-msgid "E.g.: SELECT dedek FROM starobince WHERE obec = 'Frimburg'"
-msgstr ""
+#: ../raster/r.le/r.le.trace/user_input.c:45
+#, fuzzy
+msgid "Name of output file to store patch data"
+msgstr "출력할 래스터맵"
-#: ../db/db.copy/main.c:96
-msgid "Cannot combine 'from_table' and 'select' options"
+#: ../raster/r.le/r.le.patch/main.c:50
+msgid ""
+"Calculates attribute, patch size, core (interior) size, shape, fractal "
+"dimension, and perimeter measures for sets of patches in a landscape."
msgstr ""
-#: ../db/db.copy/main.c:122
-msgid "Either 'from_table' or 'select' option must be given."
+#: ../raster/r.le/r.le.setup/main.c:59
+msgid ""
+"Interactive tool used to setup the sampling and analysis framework that will "
+"be used by the other r.le programs."
msgstr ""
-#: ../db/db.copy/main.c:125
-msgid "Cannot combine 'select' and 'where' options"
-msgstr ""
-#: ../db/db.copy/main.c:135
-msgid "Copy table failed"
-msgstr ""
-#: ../db/db.dropdb/main.c:74
+#: ../raster/r.le/r.le.setup/main.c:63
#, fuzzy
-msgid "Removes an existing database."
+msgid "Raster map to use to setup sampling"
msgstr "출력할 래스터맵"
-#: ../db/db.tables/main.c:51
-#, fuzzy, c-format
-msgid "Unable to list tables from database <%s>"
+#: ../raster/r.le/r.le.setup/main.c:67
+#, fuzzy
+msgid "Vector map to overlay"
msgstr "출력할 래스터맵"
-#: ../db/db.tables/main.c:57
+#: ../raster/r.le/r.le.setup/sample.c:1050
#, fuzzy
-msgid "No tables found"
+msgid "Cannot read vector"
msgstr "출력할 래스터맵"
-#: ../db/db.tables/main.c:86
-msgid "Print tables and exit"
+#: ../raster/r.le/r.le.pixel/main.c:47
+msgid ""
+"Contains a set of measures for attributes, diversity, texture, "
+"juxtaposition, and edge."
msgstr ""
-#: ../db/db.tables/main.c:90
-msgid "System tables instead of user tables"
-msgstr ""
+#: ../raster/r.mfilter/getrow.c:23
+#, fuzzy
+msgid "Error reading temporary file"
+msgstr "출력할 래스터맵"
-#: ../db/db.tables/main.c:96
-msgid "Lists all tables for a given database."
-msgstr ""
+#: ../raster/r.mfilter/main.c:60
+#, fuzzy
+msgid "Performs raster map matrix filter."
+msgstr "출력할 래스터맵"
-#: ../doc/raster/r.example/main.c:84 ../doc/vector/v.example/main.c:51
-msgid "keyword2"
-msgstr ""
+#: ../raster/r.mfilter/main.c:71
+#, fuzzy
+msgid "Path to filter file"
+msgstr "출력할 래스터맵"
-#: ../doc/raster/r.example/main.c:85 ../doc/vector/v.example/main.c:52
-msgid "keyword3"
+#: ../raster/r.mfilter/main.c:79
+msgid "Number of times to repeat the filter"
msgstr ""
-#: ../doc/raster/r.example/main.c:86
-msgid "My first raster module"
+#: ../raster/r.mfilter/main.c:86
+msgid "Output raster map title"
msgstr ""
-#: ../doc/vector/v.example/main.c:53
-msgid "My first vector module"
+#: ../raster/r.mfilter/main.c:98
+msgid "Apply filter only to null data values"
msgstr ""
-#: ../doc/vector/v.example/main.c:81
+#: ../raster/r.mfilter/main.c:125
#, fuzzy
-msgid "Unable to set predetermined vector open level"
+msgid "Raster map too small for the size of the filter"
msgstr "출력할 래스터맵"
-#: ../doc/vector/v.example/main.c:105 ../display/d.thematic.area/plot1.c:105
-#: ../display/d.vect/shape.c:45 ../display/d.vect.chart/plot.c:37
-#: ../vector/v.extrude/main.c:219 ../vector/v.what.rast3/main.c:118
-#: ../vector/v.vect.stats/main.c:304 ../vector/v.vect.stats/main.c:380
-#: ../vector/v.univar/main.c:224 ../vector/v.colors/read_rgb.c:23
-#: ../vector/v.colors/scan_attr.c:24 ../vector/v.colors/write_rgb.c:20
-#: ../vector/v.surf.bspline/crosscorr.c:114 ../vector/v.buffer/main.c:401
-#: ../vector/v.distance/main.c:452 ../vector/v.overlay/main.c:383
-#: ../vector/v.edit/select.c:499 ../vector/v.what.rast/main.c:136
-#: ../vector/v.to.rast/support.c:126 ../vector/v.to.rast/support.c:284
-#: ../vector/v.to.rast/support.c:435 ../vector/v.generalize/misc.c:160
-#, c-format
-msgid "Database connection not defined for layer %d"
-msgstr ""
+#: ../raster/r.mfilter/perform.c:40 ../raster/r.mfilter/perform.c:51
+#, fuzzy
+msgid "Unable to create temporary file"
+msgstr "출력할 래스터맵"
-#: ../doc/vector/v.example/main.c:170
+#: ../raster/r.mfilter/perform.c:81
#, fuzzy, c-format
-msgid "Unable to get attribute data for cat %d"
+msgid "Writing raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../doc/vector/v.example/main.c:179
-#, c-format
-msgid "Error while retrieving database record for cat %d"
-msgstr ""
-#: ../doc/vector/v.example/main.c:212
+#: ../raster/r.mfilter/getfilt.c:27
#, fuzzy, c-format
-msgid "Unable to copy attribute table to vector map <%s>"
+msgid "Cannot open filter file '%s'"
msgstr "출력할 래스터맵"
-#: ../misc/m.measure/main.c:45
-msgid "Measures the lengths and areas of features."
+#: ../raster/r.mfilter/getfilt.c:47
+msgid "Illegal filter matrix size specified"
msgstr ""
-#: ../misc/m.measure/main.c:46 ../misc/m.transform/main.c:316
-#: ../misc/m.cogo/main.c:227 ../misc/m.nviz.script/main.c:69
-#: ../locale/scriptstrings/m.proj_to_translate.c:2
-msgid "miscellaneous"
+#: ../raster/r.mfilter/getfilt.c:50
+msgid "Even filter matrix size specified"
msgstr ""
-#: ../misc/m.measure/main.c:47
-msgid "measurement"
+#: ../raster/r.mfilter/getfilt.c:72
+msgid "Illegal filter matrix"
msgstr ""
-#: ../misc/m.measure/main.c:54
-msgid "Units"
+#: ../raster/r.mfilter/getfilt.c:80 ../raster/r.mfilter/getfilt.c:107
+#: ../raster/r.mfilter/getfilt.c:124
+msgid "Filter file format error"
msgstr ""
-#: ../misc/m.measure/main.c:55
-msgid "Default: location map units"
+#: ../raster/r.mfilter/getfilt.c:83
+msgid "Duplicate filter divisor specified"
msgstr ""
-#: ../misc/m.measure/main.c:59
-#, fuzzy
-msgid "Shell script style"
-msgstr "출력할 래스터맵"
-#: ../misc/m.measure/main.c:102
-msgid "Length:"
+#: ../raster/r.mfilter/getfilt.c:101
+msgid "Illegal divisor matrix"
msgstr ""
-#: ../misc/m.measure/main.c:113
-msgid "Area:"
+#: ../raster/r.mfilter/getfilt.c:110
+msgid "Duplicate filter type specified"
msgstr ""
-#: ../misc/m.transform/main.c:92
-#, c-format
-msgid "Not enough points, %d are required"
+#: ../raster/r.mfilter/getfilt.c:117
+msgid "Illegal filter type specified"
msgstr ""
-#: ../misc/m.transform/main.c:96
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:93
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:136
-#, fuzzy, c-format
-msgid "Error conducting transform (%d)"
-msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:194
-msgid "Poorly placed control points"
+#: ../raster/r.mfilter/getfilt.c:127
+msgid "Duplicate filter start specified"
msgstr ""
-#: ../misc/m.transform/main.c:196
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:255
-msgid "Insufficient memory"
+#: ../raster/r.mfilter/getfilt.c:135
+#, c-format
+msgid "Filter start %s ignored, using UL"
msgstr ""
-#: ../misc/m.transform/main.c:198
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:257
-msgid "Parameter error"
+#: ../raster/r.mfilter/getfilt.c:157
+msgid "Illegal filter file format"
msgstr ""
-#: ../misc/m.transform/main.c:200
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:259
-msgid "No active control points"
-msgstr ""
-#: ../misc/m.transform/main.c:295
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:367
-#, fuzzy, c-format
-msgid "Invalid coordinates: [%s]"
+#: ../raster/r.cost/main.c:143
+#, fuzzy
+msgid "cost allocation"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:320
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:393
-msgid "Computes a coordinate transformation based on the control points."
+#: ../raster/r.cost/main.c:145
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
msgstr ""
-#: ../misc/m.transform/main.c:329
-msgid "Rectification polynomial order"
-msgstr ""
+#: ../raster/r.cost/main.c:152
+#, fuzzy
+msgid "Name of input raster map containing grid cell cost information"
+msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:340
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:406
+#: ../raster/r.cost/main.c:160
#, fuzzy
-msgid "point index"
+msgid "Name for output raster map with nearest start point"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:341
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:407
+#: ../raster/r.cost/main.c:161 ../raster/r.cost/main.c:168
+#: ../raster/r.walk/main.c:206
#, fuzzy
-msgid "source coordinates"
+msgid "Optional outputs"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:342
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:408
+#: ../raster/r.cost/main.c:167 ../raster/r.walk/main.c:205
#, fuzzy
-msgid "destination coordinates"
+msgid "Name for output raster map to contain movement directions"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:343
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:409
-msgid "forward coordinates (destination)"
-msgstr ""
-#: ../misc/m.transform/main.c:344
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:410
+#: ../raster/r.cost/main.c:173 ../raster/r.walk/main.c:211
#, fuzzy
-msgid "reverse coordinates (source)"
+msgid "Name of starting vector points map"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:345
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:411
-msgid "forward coordinates difference (destination)"
-msgstr ""
-#: ../misc/m.transform/main.c:346
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:412
-msgid "reverse coordinates difference (source)"
-msgstr ""
-#: ../misc/m.transform/main.c:347
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:413
+#: ../raster/r.cost/main.c:179 ../raster/r.walk/main.c:217
#, fuzzy
-msgid "forward error (destination)"
+msgid "Name of stopping vector points map"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:348
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:414
-msgid "reverse error (source)"
+#: ../raster/r.cost/main.c:180 ../raster/r.cost/main.c:200
+#: ../raster/r.walk/main.c:218 ../raster/r.walk/main.c:238
+msgid "Stop"
msgstr ""
-#: ../misc/m.transform/main.c:351
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:417
-#: ../vector/v.out.ascii/args.c:55
-msgid "Output format"
-msgstr ""
-#: ../misc/m.transform/main.c:355
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:421
-msgid "Display summary information"
-msgstr ""
-#: ../misc/m.transform/main.c:361
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:427
+#: ../raster/r.cost/main.c:185 ../raster/r.walk/main.c:223
#, fuzzy
-msgid "File containing coordinates to transform (\"-\" to read from stdin)"
+msgid "Name of starting raster points map"
msgstr "출력할 래스터맵"
-#: ../misc/m.transform/main.c:362
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:428
-msgid "Local x,y coordinates to target east,north"
+#: ../raster/r.cost/main.c:199 ../raster/r.walk/main.c:237
+msgid "Coordinates of stopping point(s) (E,N)"
msgstr ""
-#: ../misc/m.transform/main.c:366
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:432
-msgid "Reverse transform of coords file or coeff. dump"
+#: ../raster/r.cost/main.c:209 ../raster/r.walk/main.c:246
+msgid "Maximum cumulative cost"
msgstr ""
-#: ../misc/m.transform/main.c:367
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:433
-msgid "Target east,north coordinates to local x,y"
+#: ../raster/r.cost/main.c:218 ../raster/r.walk/main.c:254
+msgid "Cost assigned to null cells. By default, null cells are excluded"
msgstr ""
-#: ../misc/m.transform/main.c:371
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:437
-msgid "Display transform matrix coefficients"
+#: ../raster/r.cost/main.c:219 ../raster/r.cost/main.c:239
+#: ../raster/r.walk/main.c:255 ../raster/r.walk/main.c:305
+msgid "NULL cells"
msgstr ""
-#: ../misc/m.cogo/main.c:229
-msgid ""
-"A simple utility for converting bearing and distance measurements to "
-"coordinates and vice versa."
+#: ../raster/r.cost/main.c:234 ../raster/r.walk/main.c:300
+msgid "Use the 'Knight's move'; slower, but more accurate"
msgstr ""
-#: ../misc/m.cogo/main.c:231
-msgid "It assumes a cartesian coordinate system"
-msgstr ""
+#: ../raster/r.cost/main.c:238
+#, fuzzy
+msgid "Keep null values in output raster map"
+msgstr "출력할 래스터맵"
-#: ../misc/m.cogo/main.c:235
-msgid "Lines are labelled"
+#: ../raster/r.cost/main.c:243 ../raster/r.walk/main.c:309
+msgid "Start with values in raster map"
msgstr ""
-#: ../misc/m.cogo/main.c:239
-msgid "Suppress warnings"
+#: ../raster/r.cost/main.c:248
+msgid "Print info about disk space and memory requirements and exit"
msgstr ""
-#: ../misc/m.cogo/main.c:244
-msgid "Convert from coordinates to bearing and distance"
+#: ../raster/r.cost/main.c:298 ../raster/r.walk/main.c:363
+msgid "Must specify exactly one of start_points, start_rast or coordinate"
msgstr ""
-#: ../misc/m.cogo/main.c:249
-msgid "Repeat the starting coordinate at the end to close a loop"
+#: ../raster/r.cost/main.c:303 ../raster/r.cost/main.c:709
+#: ../raster/r.walk/main.c:368
+msgid "No start points"
msgstr ""
-#: ../misc/m.cogo/main.c:264
-msgid "Starting coordinate pair"
-msgstr ""
-#: ../misc/m.cogo/main.c:274
+#: ../raster/r.cost/main.c:310 ../raster/r.walk/main.c:375
#, c-format
-msgid "Couldn't open COGO file <%s>"
+msgid "Inappropriate maximum cost: %d"
msgstr ""
-#: ../misc/m.cogo/main.c:283
+#: ../raster/r.cost/main.c:314 ../raster/r.walk/main.c:379
#, c-format
-msgid "Couldn't open output file <%s>"
+msgid "Inappropriate percent memory: %d"
msgstr ""
-#: ../misc/m.cogo/main.c:313 ../misc/m.cogo/main.c:316
-msgid "Converting starting coordinate pair"
+#: ../raster/r.cost/main.c:332
+msgid "Assigning negative cost to null cell. Null cells excluded."
msgstr ""
-#: ../misc/m.cogo/main.c:332
+#: ../raster/r.cost/main.c:410 ../raster/r.cost/main.c:419
+#: ../raster/r.walk/main.c:523 ../raster/r.walk/main.c:533
#, c-format
-msgid "Input parse error on line %d"
+msgid "Will need at least %.2f MB of disk space"
msgstr ""
-#: ../misc/m.nviz.image/cplane.c:40
-#, fuzzy, c-format
-msgid "Cutting plane number <%d> not found"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/main.c:50 ../misc/m.nviz.script/main.c:74
-#: ../visualization/ximgview/main.c:294
-#, fuzzy
-msgid "visualization"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/main.c:51 ../misc/m.nviz.script/main.c:70
-#: ../locale/scriptstrings/d.redraw_to_translate.c:3
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:3
-#: ../display/d.rgb/main.c:54 ../display/d.erase/main.c:30
-#: ../display/d.vect/main.c:71 ../display/d.info/main.c:32
-#: ../display/d.mon/main.c:39 ../display/d.his/main.c:63
-#: ../display/d.rast/main.c:54 ../visualization/ximgview/main.c:291
-msgid "graphics"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:55
-msgid "Creates a 3D rendering of GIS data."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:56
-msgid ""
-"Renders surfaces (raster data), 2D/3D vector data, and volumes (3D raster "
-"data) in 3D."
-msgstr ""
-#: ../misc/m.nviz.image/main.c:82
-#, fuzzy
-msgid "Unable to render data"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/main.c:141
+#: ../raster/r.cost/main.c:412 ../raster/r.cost/main.c:420
+#: ../raster/r.walk/main.c:524 ../raster/r.walk/main.c:534
#, c-format
-msgid "Vertical exaggeration not given, using calculated value %.0f"
+msgid "Will need at least %.2f MB of memory"
msgstr ""
-#: ../misc/m.nviz.image/main.c:153
-#, c-format
-msgid "Viewpoint height not given, using calculated value %.0f"
-msgstr ""
-#: ../misc/m.nviz.image/main.c:239
+#: ../raster/r.cost/main.c:424 ../raster/r.walk/main.c:545
#, fuzzy
-msgid "Unsupported output format"
+msgid "Creating some temporary files..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/main.c:241 ../imagery/i.cluster/main.c:337
+#: ../raster/r.cost/main.c:438
#, fuzzy, c-format
-msgid "File <%s> created."
+msgid "Reading raster map <%s>, initializing output..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/surface.c:67
+#: ../raster/r.cost/main.c:483
#, c-format
-msgid "Missing topography attribute for surface %d"
+msgid ""
+"Negative cell value found at row %d, col %d. Setting negative value to "
+"null_cost value"
msgstr ""
-#: ../misc/m.nviz.image/surface.c:131 ../misc/m.nviz.image/volume.c:159
-#, c-format
-msgid "Color attribute not defined, using default <%s>"
-msgstr ""
-#: ../misc/m.nviz.image/surface.c:137
-#, fuzzy, c-format
-msgid "Missing color attribute for surface %d"
+#: ../raster/r.cost/main.c:500
+#, fuzzy
+msgid "Initializing directional output..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/surface.c:217
+#: ../raster/r.cost/main.c:579
#, fuzzy, c-format
-msgid "Surface id %d doesn't exist"
+msgid "No start points found in vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/surface.c:264 ../misc/m.nviz.image/surface.c:271
+#: ../raster/r.cost/main.c:581
#, fuzzy, c-format
-msgid "Unable to set draw mode for surface id %d"
-msgstr "출력할 래스터맵"
+msgid "%d point found"
+msgid_plural "%d points found"
-#: ../misc/m.nviz.image/volume.c:42 ../misc/m.nviz.image/volume.c:133
+#: ../raster/r.cost/main.c:595 ../raster/r.walk/main.c:748
#, fuzzy, c-format
-msgid "3d raster map <%s> not found"
+msgid "Reading vector map <%s> with stop points..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/volume.c:96 ../misc/m.nviz.image/volume.c:256
+#: ../raster/r.cost/main.c:649 ../raster/r.walk/main.c:802
#, fuzzy, c-format
-msgid "Error tokenize '%s'"
+msgid "No stop points found in vector <%s>"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/volume.c:103 ../misc/m.nviz.image/volume.c:271
+#: ../raster/r.cost/main.c:672
#, fuzzy, c-format
-msgid "Volume set number %d is not available"
+msgid "Reading raster map <%s> with start points..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/volume.c:108
-#, fuzzy, c-format
-msgid "Unable to add isosurface (volume set %d)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.cost/main.c:723 ../raster/r.walk/main.c:875
+msgid "Specified starting location outside database window"
+msgstr ""
-#: ../misc/m.nviz.image/volume.c:119 ../misc/m.nviz.image/volume.c:140
-#: ../misc/m.nviz.image/volume.c:153 ../misc/m.nviz.image/volume.c:172
-#: ../misc/m.nviz.image/volume.c:182 ../misc/m.nviz.image/volume.c:195
-#: ../misc/m.nviz.image/volume.c:205
-#, fuzzy, c-format
-msgid "Unable to set isosurface (%d) attribute (%d) of volume %d"
+#: ../raster/r.cost/main.c:744
+#, fuzzy
+msgid "Finding cost path..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/volume.c:267
-#, fuzzy, c-format
-msgid "Wrong name for axis: %s"
-msgstr "출력할 래스터맵"
+#: ../raster/r.cost/main.c:1019 ../raster/r.walk/main.c:1367
+msgid "Error, ct == pres_cell"
+msgstr ""
-#: ../misc/m.nviz.image/volume.c:276
+#: ../raster/r.cost/main.c:1045
#, fuzzy, c-format
-msgid "Unable to add slice (volume set %d)"
+msgid "Writing raster map with nearest start point <%s>..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/volume.c:288
+#: ../raster/r.cost/main.c:1140
#, fuzzy, c-format
-msgid "Unable to set slice (%d) position of volume %d"
+msgid "Writing output movement direction raster map <%s>..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/volume.c:294
-#, fuzzy, c-format
-msgid "Unable to set slice (%d) transparency of volume %d"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:51
-msgid "Use draw mode for all loaded surfaces"
+#: ../raster/r.cost/main.c:1206 ../raster/r.walk/main.c:1492
+#, c-format
+msgid "Peak cost value: %f."
msgstr ""
-#: ../misc/m.nviz.image/args.c:52 ../misc/m.nviz.image/args.c:130
-#: ../misc/m.nviz.image/args.c:140 ../misc/m.nviz.image/args.c:147
-#: ../misc/m.nviz.image/args.c:153 ../misc/m.nviz.image/args.c:161
-#: ../misc/m.nviz.image/args.c:170 ../misc/m.nviz.image/args.c:180
-#: ../misc/m.nviz.image/args.c:188 ../misc/m.nviz.image/args.c:198
-#: ../misc/m.nviz.image/args.c:206 ../misc/m.nviz.image/args.c:216
-msgid "Surfaces"
+#: ../raster/r.cost/main.c:1228 ../raster/r.walk/main.c:1517
+#, c-format
+msgid "Illegal x coordinate <%s>"
msgstr ""
-#: ../misc/m.nviz.image/args.c:89
-#, fuzzy
-msgid "Name for output image file (without extension)"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:90 ../misc/m.nviz.image/args.c:104
-#: ../misc/m.nviz.image/args.c:114
-msgid "Image"
+#: ../raster/r.cost/main.c:1230 ../raster/r.walk/main.c:1519
+#, c-format
+msgid "Illegal y coordinate <%s>"
msgstr ""
-#: ../misc/m.nviz.image/args.c:102
-#: ../locale/scriptstrings/d.out.file_to_translate.c:5
-msgid "Graphics file format"
+#: ../raster/r.cost/main.c:1234 ../raster/r.walk/main.c:1523
+#, c-format
+msgid "Warning, ignoring point outside window: %.4f,%.4f"
msgstr ""
-#: ../misc/m.nviz.image/args.c:112
-msgid "Size (width, height) of output image"
+#: ../raster/r.in.mat/main.c:94
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
msgstr ""
-#: ../misc/m.nviz.image/args.c:129
+#: ../raster/r.in.mat/main.c:101
#, fuzzy
-msgid "Name of raster map(s) for elevation"
+msgid "Name of input MAT-File(v4)"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:139
-msgid "Constant elevation value(s) to use instead of a raster DEM"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:146
+#: ../raster/r.in.mat/main.c:105
#, fuzzy
-msgid "Name of raster map(s) for color"
+msgid "Name for output raster map (override)"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:152
-msgid "Color value(s)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:160
+#: ../raster/r.in.mat/main.c:149
#, fuzzy
-msgid "Name of raster map(s) for mask"
+msgid "Reading MAT-File..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:169
-#, fuzzy
-msgid "Name of raster map(s) for transparency"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:175
+msgid "Array contains no data"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:179
-msgid "Transparency value(s)"
+#: ../raster/r.in.mat/main.c:180
+msgid "Array contains imaginary data"
msgstr ""
-#: ../misc/m.nviz.image/args.c:187
-#, fuzzy
-msgid "Name of raster map(s) for shininess"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:186
+msgid "Invalid array name"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:197
-msgid "Shininess value(s)"
+#: ../raster/r.in.mat/main.c:206
+msgid "Invalid 'map_name' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:205
-#, fuzzy
-msgid "Name of raster map(s) for emission"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:216
+msgid "Error reading 'map_name' array"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:215
-msgid "Emission value(s)"
+#: ../raster/r.in.mat/main.c:227
+msgid "Invalid 'map_northern_edge' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:227
-msgid "Draw mode"
+#: ../raster/r.in.mat/main.c:236
+msgid "Invalid 'map_southern_edge' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:230 ../misc/m.nviz.image/args.c:241
-#: ../misc/m.nviz.image/args.c:252 ../misc/m.nviz.image/args.c:264
-#: ../misc/m.nviz.image/args.c:276 ../misc/m.nviz.image/args.c:285
-#: ../misc/m.nviz.image/args.c:295 ../misc/m.nviz.image/args.c:605
-#: ../misc/m.nviz.image/args.c:617 ../display/d.grid/main.c:121
-#: ../display/d.grid/main.c:127 ../display/d.grid/main.c:132
-#: ../display/d.grid/main.c:137 ../display/d.grid/main.c:142
-msgid "Draw"
+#: ../raster/r.in.mat/main.c:245
+msgid "Invalid 'map_eastern_edge' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:239
-msgid "Fine resolution"
+#: ../raster/r.in.mat/main.c:254
+msgid "Invalid 'map_western_edge' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:250
-msgid "Coarse resolution"
+#: ../raster/r.in.mat/main.c:262
+msgid "Invalid 'map_title' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:261
-msgid "Draw style"
+#: ../raster/r.in.mat/main.c:272
+msgid "Error reading 'map_title' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:273
-msgid "Shading"
+#: ../raster/r.in.mat/main.c:285
+msgid "Invalid 'map_data' array"
msgstr ""
-#: ../misc/m.nviz.image/args.c:282
-msgid "Wire color"
+#: ../raster/r.in.mat/main.c:311 ../raster/r.in.mat/main.c:443
+#: ../raster/r.in.mat/main.c:522
+msgid "Please contact the GRASS development team"
msgstr ""
-#: ../misc/m.nviz.image/args.c:294
-#, fuzzy
-msgid "Surface position"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:316
+#, c-format
+msgid "Skipping unknown array '%s'"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:306
-#, fuzzy
-msgid "Name of line vector overlay map(s)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:344
+#, c-format
+msgid "No 'map_data' array found in <%s>"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:307 ../misc/m.nviz.image/args.c:315
-#: ../misc/m.nviz.image/args.c:327 ../misc/m.nviz.image/args.c:336
-#: ../misc/m.nviz.image/args.c:345 ../misc/m.nviz.image/args.c:352
-#: ../misc/m.nviz.image/args.c:366 ../misc/m.nviz.image/args.c:376
-#: ../misc/m.nviz.image/args.c:388
-#, fuzzy
-msgid "Vector lines"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:351
+#, c-format
+msgid "Setting map name to <%s> which overrides <%s>"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:314 ../misc/m.nviz.image/args.c:407
-#, fuzzy
-msgid "Layer number or name for thematic mapping"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:358
+#, c-format
+msgid "Setting map name to <%s>"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:326
-#, fuzzy
-msgid "Vector line width"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.mat/main.c:362
+msgid "No 'map_name' array found; using <MatFile>"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:334 ../misc/m.nviz.image/args.c:446
-#, fuzzy
-msgid "Name of width definition column"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:342
-#, fuzzy
-msgid "Vector line color"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:350 ../misc/m.nviz.image/args.c:462
-#, fuzzy
-msgid "Name of color definition column"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:361
-msgid "Vector line display mode"
+#: ../raster/r.in.mat/main.c:373
+msgid "Missing bound"
msgstr ""
-#: ../misc/m.nviz.image/args.c:363
-msgid "surface;drape on raster surface;flat;draw at constant elevation"
+#: ../raster/r.in.mat/main.c:377
+msgid "Using default bounds"
msgstr ""
-#: ../misc/m.nviz.image/args.c:375
-msgid "Vector line height"
+#: ../raster/r.in.mat/main.c:391
+#, c-format
+msgid "Map <%s> bounds set to:"
msgstr ""
-#: ../misc/m.nviz.image/args.c:387
+#: ../raster/r.in.mat/main.c:408
#, fuzzy
-msgid "Vector lines position"
+msgid "Writing new raster map..."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:399
-#, fuzzy
-msgid "Name of point vector overlay map(s)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.random.cells/random.c:50
+#, c-format
+msgid "RAN1: j == %d shouldn't happen"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:400 ../misc/m.nviz.image/args.c:408
-#: ../misc/m.nviz.image/args.c:420 ../misc/m.nviz.image/args.c:429
-#: ../misc/m.nviz.image/args.c:439 ../misc/m.nviz.image/args.c:448
-#: ../misc/m.nviz.image/args.c:457 ../misc/m.nviz.image/args.c:464
-#: ../misc/m.nviz.image/args.c:477 ../misc/m.nviz.image/args.c:485
-#: ../misc/m.nviz.image/args.c:500 ../misc/m.nviz.image/args.c:510
+#: ../raster/r.random.cells/main.c:48
#, fuzzy
-msgid "Vector points"
+msgid "autocorrelation"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:419
-msgid "Icon size (map units)"
+#: ../raster/r.random.cells/main.c:50
+msgid "Generates random cell values with spatial dependence."
msgstr ""
-#: ../misc/m.nviz.image/args.c:427
-#, fuzzy
-msgid "Name of size definition column"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:438
-msgid "Icon width"
+#: ../raster/r.random.cells/main.c:60
+msgid "Maximum distance of spatial correlation (value(s) >= 0.0)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:454
-msgid "Icon color"
+#: ../raster/r.random.cells/main.c:67
+msgid "Random seed (SEED_MIN >= value >= SEED_MAX) (default [random])"
msgstr ""
-#: ../misc/m.nviz.image/args.c:473
-msgid "Icon marker"
+#: ../raster/r.random.cells/init.c:70
+msgid "Distance must be >= 0.0"
msgstr ""
-#: ../misc/m.nviz.image/args.c:483
+#: ../raster/r.ros/main.c:216
#, fuzzy
-msgid "Name of marker definition column"
+msgid "rate of spread"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:494
+#: ../raster/r.ros/main.c:218
#, fuzzy
-msgid "3D vector point display mode"
+msgid "Generates rate of spread raster maps."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:496
-msgid "surface;drape on raster surface;3D;place at 3D point's z-elevation"
+#: ../raster/r.ros/main.c:220
+msgid ""
+"Generates three, or four raster map layers showing the base (perpendicular) "
+"rate of spread (ROS), the maximum (forward) ROS, the direction of the "
+"maximum ROS, and optionally the maximum potential spotting distance for fire "
+"spread simulation."
msgstr ""
-#: ../misc/m.nviz.image/args.c:509
+#: ../raster/r.ros/main.c:227
#, fuzzy
-msgid "Vector points position"
+msgid "Raster map containing fuel models"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:526
-msgid "Viewpoint position (x,y model coordinates)"
+#: ../raster/r.ros/main.c:229
+msgid ""
+"Name of an existing raster map layer in the user's current mapset search "
+"path containing the standard fuel models defined by the USDA Forest Service. "
+"Valid values are 1-13; other numbers are recognized as barriers by r.ros."
msgstr ""
-#: ../misc/m.nviz.image/args.c:527 ../misc/m.nviz.image/args.c:539
-#: ../misc/m.nviz.image/args.c:549 ../misc/m.nviz.image/args.c:561
-#: ../misc/m.nviz.image/args.c:583
-msgid "Viewpoint"
+#: ../raster/r.ros/main.c:238
+msgid "Raster map containing the 1-hour fuel moisture (%)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:538
-msgid "Viewpoint height (in map units)"
+#: ../raster/r.ros/main.c:248
+msgid "Raster map containing the 10-hour fuel moisture (%)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:548
-msgid "Viewpoint field of view (in degrees)"
+#: ../raster/r.ros/main.c:250
+msgid ""
+"path containing the 10-hour (.25-1\") fuel moisture (percentage content "
+"multiplied by 100)."
msgstr ""
-#: ../misc/m.nviz.image/args.c:560
-msgid "Viewpoint twist angle (in degrees)"
+#: ../raster/r.ros/main.c:258
+msgid "Raster map containing the 100-hour fuel moisture (%)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:582
-msgid "Focus to point on surface (from SW corner in map units)"
+#: ../raster/r.ros/main.c:260
+msgid ""
+"path containing the 100-hour (1-3\") fuel moisture (percentage content "
msgstr ""
-#: ../misc/m.nviz.image/args.c:592 ../misc/m.nviz.image/args.c:627
-#: ../misc/m.nviz.image/args.c:639 ../misc/m.nviz.image/args.c:649
-#: ../misc/m.nviz.image/args.c:658 ../misc/m.nviz.image/args.c:666
-#: ../misc/m.nviz.image/args.c:675 ../misc/m.nviz.image/args.c:686
-#: ../misc/m.nviz.image/args.c:695 ../misc/m.nviz.image/args.c:706
-#: ../misc/m.nviz.image/args.c:713 ../misc/m.nviz.image/args.c:719
-#: ../misc/m.nviz.image/args.c:731 ../misc/m.nviz.image/args.c:741
-#: ../misc/m.nviz.image/args.c:752
-msgid "Volumes"
+#: ../raster/r.ros/main.c:267
+msgid "Raster map containing live fuel moisture (%)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:602
-msgid "Volume draw mode"
+#: ../raster/r.ros/main.c:269
+msgid ""
+"path containing live (herbaceous) fuel moisture (percentage content "
msgstr ""
-#: ../misc/m.nviz.image/args.c:614
-msgid "Volume shading"
+#: ../raster/r.ros/main.c:277
+msgid "Raster map containing midflame wind velocitys (ft/min)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:626
-msgid "Volume position"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:637
-msgid "Volume resolution"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:648
-msgid "Isosurface level"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:657
+#: ../raster/r.ros/main.c:287
#, fuzzy
-msgid "Name of volume for isosurface color"
+msgid "Name of raster map containing wind directions (degree)"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:665
-#, fuzzy
-msgid "Isosurface color"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:674
-#, fuzzy
-msgid "Name of 3D raster map(s) for isosurface transparency"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:685
-msgid "Transparency value(s)for isosurfaces"
+#: ../raster/r.ros/main.c:289
+msgid ""
+"path containing wind direction, clockwise from north (degree)."
msgstr ""
-#: ../misc/m.nviz.image/args.c:694
+#: ../raster/r.ros/main.c:297
#, fuzzy
-msgid "Name of 3D raster map(s) for shininess"
+msgid "Name of raster map containing slope (degree)"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:705
-msgid "Shininess value(s) for isosurfaces"
+#: ../raster/r.ros/main.c:299
+msgid ""
+"path containing topographic slope (degree)."
msgstr ""
-#: ../misc/m.nviz.image/args.c:712
-msgid "Toggles normal direction of all isosurfaces (changes light effect)"
+#: ../raster/r.ros/main.c:307
+msgid "Raster map containing aspect (degree, CCW from E)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:718
-msgid "Draw volume box"
+#: ../raster/r.ros/main.c:309
+msgid ""
+"path containing topographic aspect, counterclockwise from east (GRASS "
+"convention) in degrees."
msgstr ""
-#: ../misc/m.nviz.image/args.c:730
-msgid "Volume slice parallel to given axis (x, y, z)"
+#: ../raster/r.ros/main.c:317
+#, fuzzy
+msgid "Raster map containing elevation (m, required with -s)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.ros/main.c:319
+msgid ""
+"path containing elevation (meters). Option is required from spotting "
+"distance computation (when -s flag is enabled)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:740
+#: ../raster/r.ros/main.c:326
#, fuzzy
-msgid "Volume slice position"
+msgid "Prefix for output raster maps (.base, .max, .maxdir, .spotdist)"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:751
-msgid "Volume slice transparency"
+#: ../raster/r.ros/main.c:330
+msgid "Also produce maximum spotting distance"
msgstr ""
-#: ../misc/m.nviz.image/args.c:768
-msgid "Light position (x,y,z model coordinates)"
+#: ../raster/r.ros/main.c:345
+msgid ""
+"No dead fuel moisture is given. At least one of the 1-h, 10-h, 100-h "
+"moisture layers is required."
msgstr ""
-#: ../misc/m.nviz.image/args.c:769 ../misc/m.nviz.image/args.c:775
-#: ../misc/m.nviz.image/args.c:784 ../misc/m.nviz.image/args.c:794
-msgid "Lighting"
+#: ../raster/r.ros/main.c:369
+#, c-format
+msgid ""
+"A wind direction layer should be given if the wind velocity layer <%s> has "
+"been given"
msgstr ""
-#: ../misc/m.nviz.image/args.c:774
-msgid "Light color"
+#: ../raster/r.ros/main.c:374
+#, c-format
+msgid ""
+"A wind velocity layer should be given if the wind direction layer <%s> has "
+"been given"
msgstr ""
-#: ../misc/m.nviz.image/args.c:783
-msgid "Light brightness"
+#: ../raster/r.ros/main.c:388
+#, c-format
+msgid "An aspect layer should be given if the slope layer <%s> has been given"
msgstr ""
-#: ../misc/m.nviz.image/args.c:793
-msgid "Light ambient"
+#: ../raster/r.ros/main.c:393
+#, c-format
+msgid "A slope layer should be given if the aspect layer <%s> has been given"
msgstr ""
-#: ../misc/m.nviz.image/args.c:807
-msgid "Cutting plane index (0-5)"
+#: ../raster/r.ros/main.c:409
+msgid "An elevation layer should be given if considering spotting"
msgstr ""
-#: ../misc/m.nviz.image/args.c:808 ../misc/m.nviz.image/args.c:817
-#: ../misc/m.nviz.image/args.c:826 ../misc/m.nviz.image/args.c:838
-#: ../misc/m.nviz.image/args.c:849
-#, fuzzy
-msgid "Cutting planes"
+#: ../raster/r.ros/main.c:427 ../raster/r.ros/main.c:431
+#: ../raster/r.ros/main.c:435 ../raster/r.ros/main.c:442
+#, fuzzy, c-format
+msgid "Raster map <%s> already exists in mapset <%s>"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:816
-#, fuzzy
-msgid "Cutting plane x,y,z coordinates"
+#: ../raster/r.ros/main.c:863
+#, fuzzy, c-format
+msgid "Raster maps <%s>, <%s> and <%s> created."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:828
-msgid "Cutting plane rotation along the vertical axis"
-msgstr ""
+#: ../raster/r.recode/read_rules.c:20
+#, fuzzy, c-format
+msgid "Unable to read f_range for map %s"
+msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:839
+#: ../raster/r.recode/read_rules.c:24 ../display/d.colortable/main.c:149
#, fuzzy
-msgid "Cutting plane tilt"
+msgid "Data range is empty"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:851
-msgid "Cutting plane color (between two surfaces)"
+#: ../raster/r.recode/read_rules.c:30
+#, fuzzy, c-format
+msgid "Data range of %s is %s to %s (entire map)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.recode/read_rules.c:39
+#, fuzzy, c-format
+msgid "Integer data range of %s is empty"
+msgstr "출력할 래스터맵"
+#: ../raster/r.recode/read_rules.c:41
+#, fuzzy, c-format
+msgid "Integer data range of %s is %d to %d"
+msgstr "출력할 래스터맵"
+#: ../raster/r.recode/read_rules.c:60
+msgid "Enter the rule or 'help' for the format description"
msgstr ""
-#: ../misc/m.nviz.image/args.c:867
-msgid "North-West edge"
+#: ../raster/r.recode/read_rules.c:84
+msgid "Enter a rule in one of these formats:"
msgstr ""
-#: ../misc/m.nviz.image/args.c:868
-msgid "North-East edge"
+#: ../raster/r.recode/read_rules.c:86
+msgid "old_low:old_high:new_low:new_high"
msgstr ""
-#: ../misc/m.nviz.image/args.c:869
-msgid "South-West edge"
+#: ../raster/r.recode/read_rules.c:87
+msgid "old_low:old_high:new_val (i.e. new_high == new_low)"
msgstr ""
-msgid "South-East edge"
+#: ../raster/r.recode/read_rules.c:88
+msgid "*:old_val:new_val (interval [inf, old_val])"
msgstr ""
-#: ../misc/m.nviz.image/args.c:871
-#, fuzzy
-msgid "Fringe edges"
-msgstr "출력할 래스터맵"
+#: ../raster/r.recode/read_rules.c:89
+msgid "old_val:*:new_val (interval [old_val, inf])"
+msgstr ""
-#: ../misc/m.nviz.image/args.c:872 ../misc/m.nviz.image/args.c:878
-#: ../misc/m.nviz.image/args.c:887
-msgid "Fringe"
+#: ../raster/r.recode/read_rules.c:91
+msgid "When finished type \"end\"."
msgstr ""
-#: ../misc/m.nviz.image/args.c:877
+#: ../raster/r.recode/main.c:49
#, fuzzy
-msgid "Fringe color"
+msgid "recode categories"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:886
+#: ../raster/r.recode/main.c:50
#, fuzzy
-msgid "Fringe elevation"
+msgid "Recodes categorical raster maps."
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:900
-msgid ""
-"Place north arrow at given position \t(in screen coordinates from bottom "
-"left corner)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:902 ../misc/m.nviz.image/args.c:912
-#: ../misc/m.nviz.image/args.c:919
+#: ../raster/r.recode/main.c:53
#, fuzzy
-msgid "Decoration"
+msgid "Name of raster map to be recoded"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:911
-msgid "North arrow size (in map units)"
+#: ../raster/r.recode/main.c:59
+msgid "File containing recode rules"
msgstr ""
-#: ../misc/m.nviz.image/args.c:918
-msgid "North arrow color"
-msgstr ""
+#: ../raster/r.recode/main.c:70
+#, fuzzy
+msgid "Align the current region to the input raster map"
+msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/args.c:970
-#, c-format
-msgid "At least one <%s> or <%s> required"
+#: ../raster/r.recode/main.c:74
+msgid "Force output to 'double' raster map type (DCELL)"
msgstr ""
-#: ../misc/m.nviz.image/args.c:984 ../misc/m.nviz.image/args.c:1014
-#: ../misc/m.nviz.image/args.c:1020 ../misc/m.nviz.image/args.c:1026
-#: ../misc/m.nviz.image/args.c:1032 ../misc/m.nviz.image/args.c:1038
-#: ../misc/m.nviz.image/args.c:1044
+#: ../raster/r.recode/main.c:95
#, c-format
-msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d)"
+msgid "No rules specified. Raster map <%s> not created."
msgstr ""
-#: ../misc/m.nviz.image/args.c:1055
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 3)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1061 ../misc/m.nviz.image/args.c:1067
-#: ../misc/m.nviz.image/args.c:1079 ../misc/m.nviz.image/args.c:1086
-#: ../misc/m.nviz.image/args.c:1093 ../misc/m.nviz.image/args.c:1100
-#: ../misc/m.nviz.image/args.c:1107 ../misc/m.nviz.image/args.c:1119
-#: ../misc/m.nviz.image/args.c:1124 ../misc/m.nviz.image/args.c:1161
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1143 ../misc/m.nviz.image/args.c:1153
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d, <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1168
-#, c-format
-msgid "Inconsistent number of attributes (<%s>: %d vs. <%s>: %d x 6)"
-msgstr ""
-#: ../misc/m.nviz.image/args.c:1180
-#, c-format
-msgid "Inconsistent number of attributes (<%s/%s>: %d vs. <%s>: %d, <%s>: %d)"
-msgstr ""
-#: ../misc/m.nviz.image/vector.c:302 ../misc/m.nviz.image/vector.c:311
-#: ../misc/m.nviz.image/vector.c:321 ../misc/m.nviz.image/vector.c:331
-#, fuzzy, c-format
-msgid "Column <%s> in table <%s> not found"
-msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/vector.c:306
+#: ../raster/r.buffer/main.c:67 ../vector/v.parallel/main.c:51
+#: ../vector/v.buffer/main.c:223
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:4
#, fuzzy
-msgid "Data type of color column must be character"
+msgid "buffer"
msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.image/vector.c:316
-msgid "Data type of size column must be numeric"
+#: ../raster/r.buffer/main.c:69
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:1
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
msgstr ""
-#: ../misc/m.nviz.image/vector.c:326
-msgid "Data type of width column must be numeric"
+#: ../raster/r.buffer/main.c:81
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:6
+msgid "Distance zone(s)"
msgstr ""
-#: ../misc/m.nviz.image/vector.c:337
-msgid "Data type of marker column must be character"
+#: ../raster/r.buffer/main.c:88
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:7
+msgid "Units of distance"
msgstr ""
-#: ../misc/m.nviz.script/main.c:75
-msgid "Creates fly-through script to run in NVIZ."
+#: ../raster/r.buffer/main.c:94
+#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:5
+msgid "Ignore zero (0) data cells instead of NULL cells"
msgstr ""
-#: ../misc/m.nviz.script/main.c:80
-msgid "Name of output script"
+#: ../raster/r.buffer/main.c:131
+msgid "Parse distances error"
msgstr ""
-#: ../misc/m.nviz.script/main.c:86
-msgid "Prefix of output images (default = NVIZ)"
+#: ../raster/r.buffer/main.c:150
+#, c-format
+msgid "Pass %d (of %d)"
msgstr ""
-#: ../misc/m.nviz.script/main.c:94
-msgid "Route coordinates (east,north)"
+#: ../raster/r.buffer/parse_dist.c:54
+#, c-format
+msgid "%s: %s - illegal distance specification"
msgstr ""
-#: ../misc/m.nviz.script/main.c:100
-msgid "Camera layback distance (in map units)"
+#: ../raster/r.buffer/execute.c:34
+msgid "Finding buffer zones..."
msgstr ""
-#: ../misc/m.nviz.script/main.c:106
-msgid "Camera height above terrain"
-msgstr ""
+#: ../raster/r.in.gridatb/main.c:48
+#, fuzzy
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.script/main.c:112
-msgid "Number of frames"
+#: ../raster/r.in.gridatb/main.c:51
+msgid "GRIDATB i/o map file"
msgstr ""
-#: ../misc/m.nviz.script/main.c:118
-msgid "Start frame number (default=0)"
+#: ../raster/r.in.gridatb/main.c:68
+#, c-format
+msgid "File not found: %s"
msgstr ""
-#: ../misc/m.nviz.script/main.c:123
-msgid "Full render -- Save images"
+#: ../raster/r.in.gridatb/file_io.c:35
+msgid "Setting window header failed"
msgstr ""
-#: ../misc/m.nviz.script/main.c:127
-msgid "Fly at constant elevation (ht)"
+#: ../raster/r.in.gridatb/file_io.c:38
+msgid "Rows changed"
msgstr ""
-#: ../misc/m.nviz.script/main.c:132
-msgid "Include command in the script to output a KeyFrame file"
+#: ../raster/r.in.gridatb/file_io.c:41
+msgid "Cols changed"
msgstr ""
-#: ../misc/m.nviz.script/main.c:136
-msgid "Render images off-screen"
-msgstr ""
+#: ../raster/r.surf.gauss/main.c:42
+#, fuzzy
+msgid "Generates a raster map using gaussian random number generator."
+msgstr "출력할 래스터맵"
-#: ../misc/m.nviz.script/main.c:140
-msgid "Enable vector and sites drawing"
+#: ../raster/r.surf.gauss/main.c:44
+msgid ""
+"Mean and standard deviation of gaussian deviates can be expressed by the "
+"user."
msgstr ""
-#: ../misc/m.nviz.script/main.c:148
-msgid "Either -i flag and/or route parameter must be used"
+#: ../raster/r.surf.gauss/main.c:51
+msgid "Distribution mean"
msgstr ""
-#: ../misc/m.nviz.script/main.c:172
-msgid "Off-screen only available with full render mode"
+#: ../raster/r.surf.gauss/main.c:57
+msgid "Standard deviation"
msgstr ""
-#: ../misc/m.nviz.script/main.c:250
+#: ../raster/r.out.bin/main.c:139
#, c-format
-msgid "You must provide at least four points %d"
+msgid "Header File = %s"
msgstr ""
-#: ../misc/m.nviz.script/main.c:324
+#: ../raster/r.out.bin/main.c:223
#, c-format
-msgid "Created NVIZ script <%s>."
+msgid "World File = %s"
msgstr ""
-#: ../misc/m.nviz.script/main.c:439
-msgid ""
-"Skipping this point, selected point is outside region. Perhaps the camera "
-"setback distance puts it beyond the edge?"
+#: ../raster/r.out.bin/main.c:281
+msgid "Exports a GRASS raster to a binary array."
msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:1
-msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+#: ../raster/r.out.bin/main.c:297
+msgid "Name for output binary map (use output=- for stdout)"
msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:4
+#: ../raster/r.out.bin/main.c:323
#, fuzzy
-msgid "Input map is in Matlab format"
+msgid "Generate integer output"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:5
-msgid "Create a 3D vector points map from 3 column Matlab data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:6
+#: ../raster/r.out.bin/main.c:327
#, fuzzy
-msgid "Name of input file in Mapgen/Matlab format"
+msgid "Generate floating-point output"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.mapgen_to_translate.c:7
-#, fuzzy
-msgid "Name for output vector map (omit for display to stdout)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.bin/main.c:331
+msgid "Export array with GMT compatible header"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:1
-#, fuzzy
-msgid ""
-"Creates/modifies the color table associated with each raster map of the "
-"space time raster dataset."
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.bin/main.c:335
+msgid "Generate BIL world and header files"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:2
-#: ../locale/scriptstrings/t.select_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.topology_to_translate.c:2
-#: ../locale/scriptstrings/t.merge_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:2
-#: ../locale/scriptstrings/t.rename_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:2
-#: ../locale/scriptstrings/t.snap_to_translate.c:2
-#: ../locale/scriptstrings/t.info_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.shift_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:2
-#: ../locale/scriptstrings/t.create_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:2
-#: ../locale/scriptstrings/t.list_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:2
-#: ../locale/scriptstrings/t.unregister_to_translate.c:2
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:2
-#: ../locale/scriptstrings/t.sample_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:2
-#: ../locale/scriptstrings/t.register_to_translate.c:2
-#: ../locale/scriptstrings/t.support_to_translate.c:2
-#: ../locale/scriptstrings/t.remove_to_translate.c:2
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:2
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:2
-msgid "temporal"
+#: ../raster/r.out.bin/main.c:339
+msgid "Byte swap output"
msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:4
-#, fuzzy
-msgid "Name of color table (see r.color help)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.bin/main.c:367
+msgid "order= and -s are mutually exclusive"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.colors_to_translate.c:12
-#, fuzzy
-msgid "Remove existing color tables"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.select_to_translate.c:1
-msgid ""
-"Select maps from space time datasets by topological relationships to other "
-"space time datasets using temporal algebra."
+#: ../raster/r.out.bin/main.c:376
+msgid "-i and -f are mutually exclusive"
msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:4
-#: ../locale/scriptstrings/t.topology_to_translate.c:4
-#: ../locale/scriptstrings/t.rename_to_translate.c:5
-#: ../locale/scriptstrings/t.snap_to_translate.c:6
-#: ../locale/scriptstrings/t.info_to_translate.c:6
-#: ../locale/scriptstrings/t.shift_to_translate.c:6
-#: ../locale/scriptstrings/t.support_to_translate.c:5
-msgid "input"
+#: ../raster/r.out.bin/main.c:413
+msgid "GMT grid doesn't support 64-bit integers"
msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:5
-#: ../locale/scriptstrings/t.topology_to_translate.c:5
-#: ../locale/scriptstrings/t.merge_to_translate.c:5
-#: ../locale/scriptstrings/t.rename_to_translate.c:6
-#: ../locale/scriptstrings/t.snap_to_translate.c:7
-#: ../locale/scriptstrings/t.info_to_translate.c:7
-#: ../locale/scriptstrings/t.shift_to_translate.c:7
-#: ../locale/scriptstrings/t.sample_to_translate.c:5
-#: ../locale/scriptstrings/t.sample_to_translate.c:6
-#: ../locale/scriptstrings/t.support_to_translate.c:6
-msgid "Required"
+#: ../raster/r.out.bin/main.c:419
+msgid "Creating BIL support files..."
msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:6
-msgid "The temporal mapcalc expression"
+#: ../raster/r.out.bin/main.c:436
+#, c-format
+msgid "Exporting raster as floating values (bytes=%d)"
msgstr ""
-#: ../locale/scriptstrings/t.select_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:6
-msgid "Activate spatial topology."
+#: ../raster/r.out.bin/main.c:438
+msgid "Writing GMT float format ID=1"
msgstr ""
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:1
-#, fuzzy
-msgid ""
-"Renames a column in the attribute table connected to a given vector map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:5
-msgid "Old and new name of the column (old,new)"
+#: ../raster/r.out.bin/main.c:441
+#, c-format
+msgid "Exporting raster as integer values (bytes=%d)"
msgstr ""
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:1
-#, fuzzy
-msgid ""
-"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
-"points map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:4
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:4
-msgid "gazetteer"
+#: ../raster/r.out.bin/main.c:443
+msgid "Writing GMT integer format ID=2"
msgstr ""
-#: ../locale/scriptstrings/v.in.gns_to_translate.c:5
-#, fuzzy
-msgid "Name of input uncompressed GNS file from NGA (with .txt extension)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:1
-#, fuzzy
-msgid "Removes existing attribute table of a vector map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:5
-msgid "Force removal (required for actual deletion of table)"
+#: ../raster/r.out.bin/main.c:451
+#, c-format
+msgid "r=%d"
msgstr ""
-#: ../locale/scriptstrings/v.db.droptable_to_translate.c:6
-#, fuzzy
-msgid "Table name (default: vector map name)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:1
-#, fuzzy
-msgid "Drapes a color raster over a shaded relief map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:4
-#, fuzzy
-msgid "Name of shaded relief or aspect raster map"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:5
-#, fuzzy
-msgid "Name of raster to drape over relief raster map"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:6
-msgid "Percent to brighten"
+#: ../raster/r.out.bin/main.c:452
+#, c-format
+msgid "c=%d"
msgstr ""
-#: ../locale/scriptstrings/d.shadedmap_to_translate.c:7
+#: ../raster/r.walk/main.c:183
#, fuzzy
-msgid "Create raster map from result (optional)"
+msgid "Outputs a raster map showing the anisotropic cumulative cost."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:1
-#, fuzzy
+#: ../raster/r.walk/main.c:185
msgid ""
-"Calculates univariate statistics on selected table column for a GRASS vector "
-"map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:5
-#: ../locale/scriptstrings/db.univar_to_translate.c:5
-#, fuzzy
-msgid ""
-"Name of attribute column on which to calculate statistics (must be numeric)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:7
-#: ../locale/scriptstrings/db.univar_to_translate.c:7
-msgid "Extended statistics (quartiles and 90th percentile)"
+"Computes anisotropic cumulative cost of moving between different geographic "
+"locations on an input elevation raster map whose cell category values "
+"represent elevation combined with an input raster map layer whose cell "
+"values represent friction cost."
msgstr ""
-#: ../locale/scriptstrings/v.db.univar_to_translate.c:8
-#: ../locale/scriptstrings/db.univar_to_translate.c:8
-#, fuzzy
-msgid "Print stats in shell script style"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:1
-#, fuzzy
-msgid "Joins a database table to a vector map table."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:5
-#, fuzzy
-msgid "Vector map to which to join other table"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:6
-msgid "layer,column"
+#: ../raster/r.walk/main.c:196
+msgid "Name of input raster map containing friction costs"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:7
+#: ../raster/r.walk/main.c:199
#, fuzzy
-msgid "Layer where to join"
+msgid "Name for output raster map to contain walking costs"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.join_to_translate.c:8
-msgid "column"
+#: ../raster/r.walk/main.c:274
+msgid "Coefficients for walking energy formula parameters a,b,c,d"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:9
-msgid "Identifier column (e.g.: cat) in the vector table to be used for join"
+#: ../raster/r.walk/main.c:284
+msgid "Lambda coefficients for combining walking energy and friction cost"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:10
-msgid "Other table name"
+#: ../raster/r.walk/main.c:294
+msgid "Slope factor determines travel energy cost per height step"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:11
-msgid "ocolumn,scolumns"
+#: ../raster/r.walk/main.c:304
+msgid "Keep null values in output map"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:12
-msgid "Identifier column (e.g.: id) in the other table used for join"
+#: ../raster/r.walk/main.c:314
+msgid "Only print info about disk space and memory requirements"
msgstr ""
-#: ../locale/scriptstrings/v.db.join_to_translate.c:13
-#, fuzzy
-msgid "Subset of columns from the other table"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:1
-msgid ""
-"Detect accumulation pattern in temporally accumulated space time raster "
-"datasets created by t.rast.accumulate."
+#: ../raster/r.walk/main.c:384
+#, c-format
+msgid "Missing required value: got %d instead of 4"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:4
-msgid ""
-"Input space time raster dataset that specifies the minimum values to detect "
-"the accumulation pattern"
+#: ../raster/r.walk/main.c:387
+#, c-format
+msgid "Walking costs are a=%lf b=%lf c=%lf d=%lf"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:5
-msgid ""
-"Input space time raster dataset that specifies the maximum values to detect "
+#: ../raster/r.walk/main.c:392 ../raster/r.walk/main.c:400
+#, c-format
+msgid "Missing required value: %d"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:6
-msgid ""
-"The output space time raster dataset that stores the occurrence of the the "
-"accumulation pattern using the provided data range"
+#: ../raster/r.walk/main.c:395
+#, c-format
+msgid "Lambda is %lf"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:7
-msgid ""
-"The output space time raster dataset that stores the indication of the "
-"start, intermediate and end of the specified data range"
+#: ../raster/r.walk/main.c:403
+#, c-format
+msgid "Slope_factor is %lf"
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:6
-msgid "The temporal starting point to begin the accumulation, eg '2001-01-01'"
+#: ../raster/r.walk/main.c:422
+msgid "Warning: assigning negative cost to null cell. Null cells excluded."
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:9
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:7
-msgid "The temporal date to stop the accumulation, eg '2009-01-01'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:10
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:8
-msgid "The temporal cycle to restart the accumulation, eg '12 months'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:11
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:9
-msgid "The temporal offset to the begin of the next cycle, eg '6 months'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:12
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:4
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:4
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:5
-#, fuzzy
-msgid "Base name of the new generated output maps\""
+#: ../raster/r.walk/main.c:573
+#, fuzzy, c-format
+msgid "Reading raster maps <%s> and <%s>, initializing output..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:13
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:6
-msgid ""
-"A numerical suffix separated by an underscore will be attached to create a "
-"unique identifier"
+#: ../raster/r.walk/main.c:658
+msgid "Initializing directional output "
msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:14
-msgid ""
-"The minimum and maximum value of the occurrence of accumulated values, these "
-"values will be used if the min/max space time raster datasets are not "
-"specified"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:15
-msgid ""
-"The user defined values that indicate start, intermediate and end status in "
-"the indicator output space time raster dataset"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:16
-msgid ""
-"Register empty maps in the output space time raster datasets, otherwise they "
-"will be deleted"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accdetect_to_translate.c:17
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:18
-msgid "Reverse time direction in cyclic accumulation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:1
-#, fuzzy
-msgid "Extracts a subset of a space time raster datasets."
+#: ../raster/r.walk/main.c:736
+#, fuzzy, c-format
+msgid "No start points found in vector <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
-#: ../vector/v.extract/main.c:78
-#, fuzzy
-msgid "extract"
+#: ../raster/r.walk/main.c:824
+#, fuzzy, c-format
+msgid "Reading %s... "
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:4
-msgid "r.mapcalc expression assigned to all extracted raster maps"
+#: ../raster/r.walk/main.c:861
+#, c-format
+msgid "No start points found in raster <%s>"
msgstr ""
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:6
-msgid "Number of r.mapcalc processes to run in parallel"
+#: ../raster/r.walk/main.c:895
+msgid "Finding cost path"
msgstr ""
-#: ../locale/scriptstrings/t.rast.extract_to_translate.c:8
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:8
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:8
-#, fuzzy
-msgid "Register Null maps"
+#: ../raster/r.walk/main.c:1379
+#, fuzzy, c-format
+msgid "Writing output raster map %s... "
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:1
-#, fuzzy
-msgid ""
-"Drops a column from the attribute table connected to a given vector map."
+#: ../raster/r.walk/main.c:1443
+#, fuzzy, c-format
+msgid "Writing movement direction file %s..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:5
-#, fuzzy
-msgid "Name of attribute column(s) to drop"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.convert.all_to_translate.c:1
-#, fuzzy
+#: ../raster/r.resamp.rst/main.c:151
msgid ""
-"Converts all older versions of GRASS vector maps in current mapset to "
-"current format."
-msgstr "출력할 래스터맵"
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:1
-#, fuzzy
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster map of a space time raster dataset."
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.rst/main.c:162
+msgid "Desired east-west resolution"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:5
-msgid "Field separator character between the output columns"
+#: ../raster/r.resamp.rst/main.c:168
+msgid "Desired north-south resolution"
msgstr ""
-#: ../locale/scriptstrings/t.rast.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:11
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:9
-#: ../locale/scriptstrings/t.sample_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:10
-#, fuzzy
-msgid "Print column names"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.rst/main.c:175
+msgid "Output z-file (elevation) map"
+msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:1
-#, fuzzy
-msgid "Lists temporal topology of a space time dataset."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.topology_to_translate.c:3
-#: ../locale/scriptstrings/v.build.all_to_translate.c:3
-#: ../vector/v.info/main.c:39 ../vector/v.build/main.c:37
-#: ../vector/v.build.polylines/main.c:113 ../vector/v.clean/main.c:52
-#: ../vector/v.out.postgis/main.c:48
-msgid "topology"
+#: ../raster/r.resamp.rst/main.c:183
+msgid "Output slope map (or fx)"
msgstr ""
-#: ../locale/scriptstrings/t.topology_to_translate.c:6
-#, fuzzy
-msgid "Print temporal relationships and exit"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.topology_to_translate.c:7
-#, fuzzy
-msgid "Print spatio-temporal relationships and exit"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.merge_to_translate.c:1
-#, fuzzy
-msgid "Merge several space time datasets into a single one"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.merge_to_translate.c:3
-msgid "merge"
+#: ../raster/r.resamp.rst/main.c:191
+msgid "Output aspect map (or fy)"
msgstr ""
-#: ../locale/scriptstrings/t.merge_to_translate.c:4
-#: ../locale/scriptstrings/t.remove_to_translate.c:7
-msgid "inputs"
+#: ../raster/r.resamp.rst/main.c:199
+msgid "Output profile curvature map (or fxx)"
msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:1
-msgid "Test database driver, database must exist and set by db.connect."
+#: ../raster/r.resamp.rst/main.c:207
+msgid "Output tangential curvature map (or fyy)"
msgstr ""
-#: ../locale/scriptstrings/db.test_to_translate.c:4
-msgid "Test name"
+#: ../raster/r.resamp.rst/main.c:215
+msgid "Output mean curvature map (or fxy)"
msgstr ""
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:1
-#, fuzzy
-msgid "Imports SRTM HGT files into raster map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:4
-#, fuzzy
-msgid "Name of SRTM input tile (file without .hgt.zip extension)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:5
-#, fuzzy
-msgid "Name for output raster map (default: input tile)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.srtm_to_translate.c:6
-msgid "Input is a 1-arcsec tile (default: 3-arcsec)"
+#: ../raster/r.resamp.rst/main.c:223
+msgid "Name of raster map containing smoothing"
msgstr ""
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:1
-#, fuzzy
-msgid ""
-"Apply temporal and spatial oeprations on space time 3D raster datasets using "
-"temporal raster algebra."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:3
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:3
-#: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:3
-#, fuzzy
-msgid "mapalgebra"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:4
-#, fuzzy
-msgid ""
-"The mapcalc expression for temporal and spatial analysis of space time 3D "
-"raster datasets."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:5
-#, fuzzy
-msgid ""
-"The basename of raster maps that are stored within the result space time 3D "
-"raster dataset."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.mapcalc2_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:6
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:7
-msgid "Number of r3.mapcalc processes to run in parallel"
+#: ../raster/r.resamp.rst/main.c:231
+msgid "Name of raster map to be used as mask"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:1
-msgid ""
-"Displays spectral response at user specified locations in group or images."
+#: ../raster/r.resamp.rst/main.c:239
+msgid "Rows/columns overlap for segmentation"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:2
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:2
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:2
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:2
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:2
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:2
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:4
-#: ../locale/scriptstrings/i.oif_to_translate.c:2
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:88
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:47
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:63
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:56
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:388
-#: ../imagery/i.evapo.pt/main.c:66 ../imagery/i.landsat.acca/main.c:105
-#: ../imagery/i.vpoints/main.c:94 ../imagery/i.albedo/main.c:88
-#: ../imagery/i.emissivity/main.c:44 ../imagery/i.cluster/main.c:75
-#: ../imagery/i.class/main.c:91 ../imagery/i.evapo.mh/main.c:69
-#: ../imagery/i.eb.h_sebal01/main.c:83 ../imagery/i.modis.qc/main.c:118
-#: ../imagery/i.evapo.pm/main.c:58 ../imagery/i.maxlik/main.c:61
-#: ../imagery/i.his.rgb/main.c:46 ../imagery/i.smap/main.c:38
-#: ../imagery/i.gensigset/main.c:40 ../imagery/i.evapo.time/main.c:77
-#: ../imagery/i.zc/main.c:52 ../imagery/i.aster.toar/main.c:97
-#: ../imagery/i.vi/main.c:89 ../imagery/i.points/main.c:96
-#: ../imagery/i.group/main.c:52 ../imagery/i.eb.netrad/main.c:56
-#: ../imagery/i.fft/main.c:78 ../imagery/i.eb.soilheatflux/main.c:49
-#: ../imagery/i.eb.eta/main.c:43 ../imagery/i.gensig/main.c:39
-#: ../imagery/i.biomass/main.c:50 ../imagery/i.pca/main.c:72
-#: ../imagery/i.rectify/main.c:99 ../imagery/i.topo.corr/main.c:47
-#: ../imagery/i.segment/main.c:35 ../imagery/i.rgb.his/main.c:46
-#: ../imagery/i.landsat.toar/main.c:70 ../imagery/i.ifft/main.c:77
-#: ../imagery/i.cca/main.c:84 ../imagery/i.target/main.c:45
-#: ../imagery/i.eb.evapfr/main.c:47
-msgid "imagery"
+#: ../raster/r.resamp.rst/main.c:247
+msgid "Multiplier for z-values"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:5
-#: ../locale/scriptstrings/i.oif_to_translate.c:3
-msgid "multispectral"
+#: ../raster/r.resamp.rst/main.c:255
+msgid "Spline tension value"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:9
-#, fuzzy
-msgid "Name for output image"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:11
-#, fuzzy
-msgid "Graphics format for output file"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.spectral_to_translate.c:13
-msgid "Show sampling coordinates instead of numbering in the legend"
+#: ../raster/r.resamp.rst/main.c:262
+msgid "Anisotropy angle (in degrees)"
msgstr ""
-#: ../locale/scriptstrings/i.spectral_to_translate.c:14
-#, fuzzy
-msgid "Use gnuplot for display"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:1
-#, fuzzy
-msgid "Imports space time raster dataset."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:4
-msgid "Path to the extraction directory"
+#: ../raster/r.resamp.rst/main.c:263 ../raster/r.resamp.rst/main.c:270
+msgid "Anisotropy"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:5
-#: ../locale/scriptstrings/t.create_to_translate.c:7
-msgid "Title of the new space time dataset"
+#: ../raster/r.resamp.rst/main.c:269 ../vector/v.surf.rst/main.c:333
+msgid "Anisotropy scaling factor"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:6
-#: ../locale/scriptstrings/t.create_to_translate.c:8
-msgid "Description of the new space time dataset"
+#: ../raster/r.resamp.rst/main.c:274
+msgid "Use dnorm independent tension"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:9
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:7
-msgid ""
-"Create a new location and import the data into it. Please do not run this "
-"module in parallel or interrupt it when a new location should be created."
+#: ../raster/r.resamp.rst/main.c:279 ../vector/v.surf.rst/main.c:166
+msgid "Output partial derivatives instead of topographic parameters"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:10
+#: ../raster/r.resamp.rst/main.c:313
#, fuzzy
-msgid "Set the current region from the last map that was imported"
+msgid "Unable to read ew_res value"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:11
+#: ../raster/r.resamp.rst/main.c:316
#, fuzzy
-msgid "Link the raster files using r.external"
+msgid "Unable to read ns_res value"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:12
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:8
-msgid "Extend location extents based on new dataset"
+#: ../raster/r.resamp.rst/main.c:319
+msgid "Invalid value for tension"
msgstr ""
-#: ../locale/scriptstrings/t.rast.import_to_translate.c:14
-msgid ""
-"Create the location specified by the \"location\" parameter and exit. Do not "
-"import the space time raster datasets."
+#: ../raster/r.resamp.rst/main.c:322
+msgid "Invalid value for zmult"
msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:1
-msgid "Redraws the content of currently selected monitor."
+#: ../raster/r.resamp.rst/main.c:325
+msgid "Invalid value for overlap"
msgstr ""
-#: ../locale/scriptstrings/d.redraw_to_translate.c:4
-#: ../display/d.erase/main.c:31 ../display/d.info/main.c:33
-#: ../display/d.mon/main.c:40
-#, fuzzy
-msgid "monitors"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.rst/main.c:329
+msgid "Invalid value for theta"
+msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:1
-msgid "Displays the manual pages of GRASS modules."
+#: ../raster/r.resamp.rst/main.c:333
+msgid "Invalid value for scalex"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:3
-msgid "manual"
+#: ../raster/r.resamp.rst/main.c:335
+msgid "When using anisotropy both theta and scalex must be specified"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:4
-msgid "help"
+#: ../raster/r.resamp.rst/main.c:373
+#, c-format
+msgid "Map <%s> is the wrong resolution"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:5
-msgid "Display index"
+#: ../raster/r.resamp.rst/main.c:381
+msgid "Smoothing values can not be negative or NULL"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:6
-msgid "Display topics"
+#: ../raster/r.resamp.rst/main.c:387
+msgid "Input map resolution differs from current region resolution!"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:7
-msgid "Display as MAN text page instead of HTML page in browser"
+#: ../raster/r.resamp.rst/main.c:403
+msgid "Processing all selected output files will require"
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:8
-msgid "Display online manuals instead of locally installed"
+#: ../raster/r.resamp.rst/main.c:407
+#, c-format
+msgid "%.2f GB of disk space for temp files."
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:9
-msgid ""
-"Use online manuals available at http://grass.osgeo.org website. This flag "
-"has no effect when displaying MAN text pages."
+#: ../raster/r.resamp.rst/main.c:410
+#, c-format
+msgid "%.2f MB of disk space for temp files."
msgstr ""
-#: ../locale/scriptstrings/g.manual_to_translate.c:10
-#, fuzzy
-msgid "Manual entry to be displayed"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.buffer.lowmem_to_translate.c:2
-msgid "This is the low-memory alternative to the classic r.buffer module."
+#: ../raster/r.resamp.rst/main.c:413
+#, c-format
+msgid "%.2f KB of disk space for temp files."
msgstr ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:1
-#, fuzzy
-msgid "Imports geonames.org country files into a vector points map."
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.rst/main.c:416
+#, c-format
+msgid "%d byte of disk space for temp files."
+msgid_plural "%d bytes of disk space for temp files."
+msgstr[0] ""
+msgstr[1] ""
-#: ../locale/scriptstrings/v.in.geonames_to_translate.c:5
-#, fuzzy
-msgid "Name of uncompressed geonames file (with .txt extension)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.resamp.rst/main.c:452
+msgid "Maximum value of a raster map is NULL."
+msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:1
-msgid "Exports attribute tables into various formats."
+#: ../raster/r.resamp.rst/main.c:480
+msgid "Temporarily changing the region to desired resolution ..."
msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:4
-msgid "Table file to be exported or DB connection string"
+#: ../raster/r.resamp.rst/main.c:485
+msgid "Changing back to the original region ..."
msgstr ""
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:5
-#, fuzzy
-msgid "Table format"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.out.ogr_to_translate.c:6
-#, fuzzy
-msgid "Name for output table (defaut: input)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:1
-#, fuzzy
-msgid "Import a space time vector dataset archive file"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.import_to_translate.c:10
-msgid ""
-"import the space time vector datasets."
+#: ../raster/r.resamp.rst/main.c:506
+#, c-format
+msgid "dnorm in mainc after grid before out1= %f"
msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:1
-#, fuzzy
-msgid "Imports SPOT VGT NDVI data into a raster map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:4
-msgid "Also import quality map (SM status map layer) and filter NDVI map"
+#: ../raster/r.resamp.rst/main.c:510
+msgid "split_and_interpolate() failed"
msgstr ""
-#: ../locale/scriptstrings/i.in.spotvgt_to_translate.c:5
-#, fuzzy
-msgid "Name of input SPOT VGT NDVI HDF file"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:1
-msgid "Views BMP images from the PNG driver."
+#: ../raster/r.resamp.rst/main.c:525
+#, c-format
+msgid "dnorm in mainc after grid before out2= %f"
msgstr ""
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:5
+#: ../raster/r.resamp.rst/main.c:531
#, fuzzy
-msgid "Name of input image file"
+msgid "Unable to write raster maps -- try increasing cell size"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/wxpyimgview_to_translate.c:6
-#: ../visualization/ximgview/main.c:308
-msgid "Percentage of CPU time to use"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:1
-#, fuzzy
-msgid "Fills no-data areas in raster maps using spline interpolation."
+#: ../raster/r.resamp.rst/main.c:563 ../vector/v.surf.rst/main.c:829
+#, fuzzy, c-format
+msgid "Error writing temporary file <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:5
-msgid "Interpolation method"
+#: ../raster/r.out.tiff/main.c:95
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:6
-msgid "Spline tension parameter"
-msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:7
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:9
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:11
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:13
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:15
+#: ../raster/r.out.tiff/main.c:102
#, fuzzy
-msgid "RST options"
+msgid "Name for output TIFF file"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:8
-msgid "Spline smoothing parameter"
+#: ../raster/r.out.tiff/main.c:109
+msgid "TIFF file compression"
msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:10
-msgid "Width of hole edge used for interpolation (in cells)"
+#: ../raster/r.out.tiff/main.c:114
+msgid "TIFF Palette output (8bit instead of 24bit)."
msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
-#: ../vector/v.surf.rst/main.c:293 ../vector/v.vol.rst/main.c:322
-msgid "Minimum number of points for approximation in a segment (>segmax)"
+#: ../raster/r.out.tiff/main.c:123
+msgid "Output TIFF world file"
msgstr ""
-#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
-#: ../vector/v.surf.rst/main.c:284 ../vector/v.vol.rst/main.c:313
-msgid "Maximum number of points in a segment"
+#: ../raster/r.out.tiff/main.c:127
+msgid "Output Tiled TIFF"
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:1
-msgid "Performs ordinary or block kriging for vector maps."
+#: ../raster/r.out.tiff/main.c:175
+#, c-format
+msgid ""
+"Raster map <%s>> is a floating point map. Fractional values will be rounded "
+"to integer"
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:5
-msgid "kriging"
+#: ../raster/r.out.tiff/main.c:181
+msgid ""
+"Color map for palette must have less than 256 colors for the available range "
+"of data"
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:6
-#, fuzzy
-msgid "Name of point vector map containing sample data"
+#: ../raster/r.out.tiff/main.c:195
+#, fuzzy, c-format
+msgid "Unable to open TIFF file <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.krige_to_translate.c:7
-#, fuzzy
-msgid "Name of attribute column with numerical value to be interpolated"
-msgstr "출력할 래스터맵"
+#: ../raster/r.out.tiff/main.c:418
+msgid "Writing TIFF World file"
+msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:8
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:10
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:6
-#: ../imagery/i.ifft/main.c:94
+#: ../raster/r.out.tiff/main.c:426
#, fuzzy
-msgid "Name for output raster map"
+msgid "Unable to open TIFF world file for writing"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.krige_to_translate.c:9
-msgid "If omitted, will be <input name>_kriging"
+#: ../raster/r.covar/main.c:54
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:10
-msgid "R package to use"
+#: ../raster/r.covar/main.c:61
+msgid "Print correlation matrix"
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:11
-msgid "Variogram model(s)"
+#: ../raster/r.covar/main.c:86
+#, c-format
+msgid "%s: complete ... "
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:12
-msgid "Leave empty to test all models (requires automap)"
+#: ../raster/r.in.lidar/main.c:165
+msgid "Creates a raster map from LAS LiDAR points using univariate statistics."
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:13
-msgid "Block size (square block)"
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:14
-msgid "Block size. Used by block kriging."
-msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:15
+#: ../raster/r.in.lidar/main.c:168 ../vector/v.in.lidar/main.c:160
#, fuzzy
-msgid "Range value"
+msgid "LAS input file"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.krige_to_translate.c:16
-#: ../locale/scriptstrings/v.krige_to_translate.c:18
-#: ../locale/scriptstrings/v.krige_to_translate.c:20
-msgid "Automatically fixed if not set"
+#: ../raster/r.in.lidar/main.c:169 ../vector/v.in.lidar/main.c:161
+msgid "LiDAR input files in LAS format (*.las or *.laz)"
msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:17
+#: ../raster/r.in.lidar/main.c:237
#, fuzzy
-msgid "Nugget value"
+msgid "Output raster resolution"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.krige_to_translate.c:19
-#, fuzzy
-msgid "Sill value"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.lidar/main.c:242 ../vector/v.in.lidar/main.c:194
+msgid "Print LAS file info and exit"
+msgstr ""
-#: ../locale/scriptstrings/v.krige_to_translate.c:21
-#, fuzzy
-msgid "Name for output variance raster map"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.krige_to_translate.c:22
-msgid "If omitted, will be <input name>_kriging.var"
+#: ../raster/r.in.lidar/main.c:253 ../vector/v.in.lidar/main.c:203
+#: ../vector/v.in.ogr/main.c:276
+msgid "Override dataset projection (use location's projection)"
msgstr ""
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:1
-#, fuzzy
-msgid ""
-"Prints attributes of vector maps registered in a space time vector dataset."
+#: ../raster/r.in.lidar/main.c:279 ../vector/v.in.lidar/main.c:234
+#, fuzzy, c-format
+msgid "Input file <%s> does not exist"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:6
-#, fuzzy
-msgid "select"
-msgstr "출력할 래스터맵"
+#: ../raster/r.in.lidar/main.c:289 ../vector/v.in.lidar/main.c:241
+#, c-format
+msgid "Input file <%s> is not a LAS LiDAR point cloud"
+msgstr ""
-#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:5
-#, fuzzy
-msgid "Separator character between the output columns"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.univar_to_translate.c:1
-#, fuzzy
+#: ../raster/r.in.lidar/main.c:319 ../vector/v.in.lidar/main.c:371
+#: ../vector/v.in.ogr/main.c:697
msgid ""
-"Calculates univariate statistics of attributes for each registered vector "
-"map of a space time vector dataset"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:1
-msgid ""
-"Store raster map values at spatial and temporal positions of vector points "
-"as vector attributes."
+"Unable to convert input map projection information to GRASS format for "
+"checking"
msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:4
-msgid ""
-"Name of the vector column to be created and to store sampled raster values"
+#: ../raster/r.in.lidar/main.c:349 ../vector/v.in.lidar/main.c:401
+#: ../vector/v.in.ogr/main.c:727
+msgid "GRASS LOCATION PROJ_INFO is:\n"
msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:5
+#: ../raster/r.in.lidar/main.c:409 ../vector/v.in.lidar/main.c:461
+#: ../vector/v.in.ogr/main.c:787
+#, c-format
msgid ""
-"The use of a column name forces t.vect.what.rast to sample only values from "
-"the first map found in an interval. Otherwise the raster map names are used "
-"as column names"
+"\n"
+"You can use the -o flag to %s to override this projection check.\n"
msgstr ""
-#: ../locale/scriptstrings/t.vect.what.strds_to_translate.c:6
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:7
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:5
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:4
-#, fuzzy
-msgid "Aggregate operation to be performed on the raster maps"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:1
-#, fuzzy
+#: ../raster/r.in.lidar/main.c:412 ../vector/v.in.lidar/main.c:464
+#: ../vector/v.in.ogr/main.c:790
msgid ""
-"Converts all old GRASS < Ver5.7 sites maps in current mapset to vector maps."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
-#: ../vector/v.in.sites/main.c:59
-msgid "sites"
+"Consider generating a new location with 'location' parameter from input data "
+"set.\n"
msgstr ""
-msgid ""
-"Create a 3D raster map from an assemblage of many coordinates using "
-"univariate statistics"
+#: ../raster/r.in.lidar/main.c:554
+msgid "zrange will not be taken into account during scan"
msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:9
-#, fuzzy
-msgid "ASCII file containing input data"
+#: ../raster/r.in.lidar/main.c:575
+#, fuzzy, c-format
+msgid "Option '%s' must be > 0.0"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:14
+#: ../raster/r.in.lidar/main.c:653
#, fuzzy
-msgid "Field separator"
+msgid "Reading data ..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:20
+#: ../raster/r.in.lidar/main.c:670
#, fuzzy
-msgid "Column number of z coordinates in input file"
+msgid "Could not rewind input file"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:23
-msgid "If not given or set to 0, the data points' z-values are used"
+#: ../raster/r.in.lidar/main.c:800
+msgid "Writing to map ..."
msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:25
-msgid "Filter range for value column data (min,max)"
+#: ../raster/r.patch/main.c:55
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
msgstr ""
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:26
-#, fuzzy
-msgid "Scaling factor to apply to value column data"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r3.in.xyz_to_translate.c:32
-msgid "Number of parallel processes to launch"
+#: ../raster/r.patch/main.c:62
+msgid "Name of raster maps to be patched together"
msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:1
-msgid "Performs auto-balancing of colors for LANDSAT images."
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:3
-msgid "landsat"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:4
-msgid "colors"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:5
+#: ../raster/r.patch/main.c:65
#, fuzzy
-msgid "Name of LANDSAT red channel"
+msgid "Name for resultant raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:6
-msgid "Name of LANDSAT green channel"
+#: ../raster/r.patch/main.c:72
+msgid "Use zero (0) for transparency instead of NULL"
msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:7
-msgid "Name of LANDSAT blue channel"
+#: ../raster/r.patch/main.c:88
+msgid "The minimum number of input raster maps is two"
msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:8
-msgid "Cropping intensity (upper brightness level)"
-msgstr ""
+#: ../raster/r.patch/main.c:144
+#, fuzzy, c-format
+msgid "Creating support files for raster map <%s>"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:9
-msgid "Extend colors to full range of data on each channel"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:10
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:12
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:14
-#: ../display/d.vect/main.c:120 ../display/d.vect/main.c:130
-#: ../display/d.vect/main.c:137 ../display/d.vect/main.c:144
-#: ../display/d.vect/main.c:299 ../display/d.northarrow/main.c:66
-#: ../display/d.northarrow/main.c:72 ../display/d.rast.arrow/main.c:120
-#: ../display/d.rast.arrow/main.c:128 ../display/d.rast.arrow/main.c:137
-#: ../display/d.rast.arrow/main.c:146 ../display/d.barscale/main.c:113
-#: ../display/d.barscale/main.c:117 ../display/d.rast.num/main.c:88
-#: ../display/d.rast.num/main.c:93 ../display/d.rast.num/main.c:111
-#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
-#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
-#: ../vector/v.label/main.c:205 ../vector/v.label.sa/main.c:103
-#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
-#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
-#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
-msgid "Colors"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:11
-msgid "Preserve relative colors, adjust brightness only"
-msgstr ""
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:13
+#: ../raster/r.report/parse.c:47
#, fuzzy
-msgid "Reset to standard color range"
+msgid "Units to report"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:15
-#: ../locale/scriptstrings/i.oif_to_translate.c:7
-msgid "Process bands serially (default: run in parallel)"
+#: ../raster/r.report/parse.c:51
+msgid "area in square miles"
msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:1
-msgid "Draws polar diagram of angle map such as aspect or flow directions"
+#: ../raster/r.report/parse.c:52
+msgid "area in square meters"
msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:3
-#: ../locale/scriptstrings/d.correlate_to_translate.c:5
-msgid "diagram"
+#: ../raster/r.report/parse.c:53
+msgid "area in square kilometers"
msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:4
+#: ../raster/r.report/parse.c:54
#, fuzzy
-msgid "Name of raster angle map"
+msgid "area in acres"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.polar_to_translate.c:5
-msgid "Pixel value to be interpreted as undefined (different from NULL)"
+#: ../raster/r.report/parse.c:55
+msgid "area in hectares"
msgstr ""
-#: ../locale/scriptstrings/d.polar_to_translate.c:6
+#: ../raster/r.report/parse.c:56
#, fuzzy
-msgid "Name for optional EPS output file"
+msgid "number of cells"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.polar_to_translate.c:7
-msgid "Plot using Xgraph"
+#: ../raster/r.report/parse.c:57
+msgid "percent cover"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:1
-msgid ""
-"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
-"channels"
+#: ../raster/r.report/parse.c:67
+msgid "If no output given report is printed to standard output"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:3
-msgid "fusion"
+#: ../raster/r.report/parse.c:82
+#, c-format
+msgid "Page length (default: %d lines)"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:4
-msgid "sharpen"
+#: ../raster/r.report/parse.c:91
+#, c-format
+msgid "Page width (default: %d characters)"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:5
-msgid "Brovey"
+#: ../raster/r.report/parse.c:122
+msgid "Suppress page headers"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:6
-msgid "IHS"
+#: ../raster/r.report/parse.c:127
+msgid "Use formfeeds between pages"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:7
-msgid "HIS"
+#: ../raster/r.report/parse.c:132
+msgid "Scientific format"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:8
-#: ../imagery/i.pca/main.c:74
-msgid "PCA"
+#: ../raster/r.report/parse.c:196
+msgid "nsteps has to be > 0; using nsteps=255"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:9
-msgid "Choose pan sharpening method"
+#: ../raster/r.report/parse.c:203
+msgid "Illegal page length"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:10
-#, fuzzy
-msgid "Input raster map for red channel"
-msgstr "출력할 래스터맵"
+#: ../raster/r.report/parse.c:210
+msgid "Illegal page width"
+msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:11
-#, fuzzy
-msgid "Input raster map for green channel"
-msgstr "출력할 래스터맵"
+#: ../raster/r.report/parse.c:265
+#, c-format
+msgid "Only %d unit%s allowed"
+msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:12
-#, fuzzy
-msgid "Input raster map for blue channel"
+#: ../raster/r.report/parse.c:298
+#, fuzzy, c-format
+msgid "Unable to read fp range for raster map <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:13
-msgid "Input raster map for high resolution panchromatic channel"
+#: ../raster/r.report/label.c:13
+msgid "Page width is too small"
msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:14
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:15
-#: ../imagery/i.pca/main.c:84 ../imagery/i.landsat.toar/main.c:89
-#, fuzzy
-msgid "Prefix for output raster maps"
+#: ../raster/r.report/stats.c:93
+#, fuzzy, c-format
+msgid "Unable to open result file <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:15
-msgid "Serial processing rather than parallel processing"
-msgstr ""
-#: ../locale/scriptstrings/i.pansharpen_to_translate.c:16
-msgid "Rebalance blue channel for landsat maps"
-msgstr ""
-msgid ""
-"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:4
-#: ../imagery/i.landsat.acca/main.c:106 ../imagery/i.landsat.toar/main.c:75
-msgid "Landsat"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:5
+#: ../raster/r.report/main.c:69
#, fuzzy
-msgid "Tasseled Cap transformation"
+msgid "Reports statistics for raster maps."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:6
-msgid "Use transformation rules for LANDSAT-4"
+#: ../raster/r.latlong/main.c:57
+msgid "latitude"
msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:7
-msgid "Use transformation rules for LANDSAT-5"
+#: ../raster/r.latlong/main.c:58
+msgid "longitude"
msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:8
-msgid "Use transformation rules for LANDSAT-7"
-msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:9
+#: ../raster/r.latlong/main.c:60
#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 1)"
+msgid "Creates a latitude/longitude raster map."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:10
+#: ../raster/r.latlong/main.c:66
#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 2)"
+msgid "Name for output latitude or longitude raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:11
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 3)"
-msgstr "출력할 래스터맵"
+#: ../raster/r.latlong/main.c:70
+msgid "Longitude output"
+msgstr ""
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:12
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 4)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:13
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 5)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.tasscap_to_translate.c:14
-#, fuzzy
-msgid "Name of input raster map (LANDSAT channel 7)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:1
-#, fuzzy
-msgid ""
-"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
-"space time raster datasets."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:4
-msgid "Spatio-temporal mapcalc expression"
+#: ../raster/r.latlong/main.c:114 ../raster/r.sun/main.c:744
+#: ../raster/r.horizon/main.c:505 ../display/d.grid/plot.c:356
+#: ../display/d.grid/plot.c:383 ../display/d.where/main.c:120
+#: ../display/d.where/main.c:146 ../ps/ps.map/do_geogrid.c:278
+msgid "Unable to set up lat/long projection parameters"
msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc_to_translate.c:9
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:9
-msgid "Check spatial overlap"
+#: ../raster/r.latlong/main.c:133 ../raster/r.horizon/main.c:803
+#: ../raster/r.horizon/main.c:821 ../display/d.grid/plot.c:201
+#: ../display/d.grid/plot.c:207 ../display/d.grid/plot.c:260
+#: ../display/d.grid/plot.c:266 ../display/d.grid/plot.c:430
+#: ../display/d.grid/plot.c:446 ../display/d.grid/plot.c:463
+#: ../display/d.grid/plot.c:480 ../ps/ps.map/do_geogrid.c:86
+#: ../ps/ps.map/do_geogrid.c:91 ../ps/ps.map/do_geogrid.c:115
+#: ../ps/ps.map/do_geogrid.c:120 ../ps/ps.map/do_geogrid.c:189
+#: ../ps/ps.map/do_geogrid.c:230 ../ps/ps.map/do_geogrid.c:306
+#: ../ps/ps.map/do_geogrid.c:322 ../ps/ps.map/do_geogrid.c:339
+#: ../ps/ps.map/do_geogrid.c:356 ../ps/ps.map/do_geogrid.c:412
+#: ../ps/ps.map/do_geogrid.c:418 ../ps/ps.map/do_geogrid.c:422
+#: ../ps/ps.map/do_geogrid.c:430 ../ps/ps.map/do_geogrid.c:434
+msgid "Error in pj_do_proj"
msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:1
-msgid "Packs up a raster map and support files for copying."
+#: ../raster/r.stream.segment/io.c:444 ../raster/r.stream.stats/io.c:444
+#, c-format
+msgid "seg_read: Cannot segment put row %d for map %s"
msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:4
-#: ../locale/scriptstrings/r.unpack_to_translate.c:4
-msgid "copying"
+#: ../raster/r.stream.segment/stream_topology.c:50
+#: ../raster/r.stream.segment/stream_topology.c:99
+#: ../raster/r.stream.segment/stream_topology.c:175
+#: ../raster/r.stream.segment/stream_topology.c:291
+msgid "Error finding inits. Stream and direction maps probably do not match."
msgstr ""
-#: ../locale/scriptstrings/r.pack_to_translate.c:5
-#, fuzzy
-msgid "Name of raster map to pack up"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.pack_to_translate.c:6
-#: ../locale/scriptstrings/v.pack_to_translate.c:4
-#, fuzzy
-msgid "Name for output file (default is <input>.pack)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.pack_to_translate.c:7
-#: ../locale/scriptstrings/v.pack_to_translate.c:5
-msgid "Switch the compression off"
+#: ../raster/r.stream.segment/stream_topology.c:52
+#: ../raster/r.stream.segment/stream_topology.c:101
+#: ../raster/r.stream.order/stream_topology.c:21
+#: ../raster/r.stream.order/stream_topology.c:228
+msgid "Stream network may be too dense"
msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:1
+#: ../raster/r.stream.segment/stream_topology.c:167
+#: ../raster/r.stream.segment/stream_topology.c:280
#, fuzzy
-msgid "Exports space time raster dataset."
+msgid "Finding inits..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:4
+#: ../raster/r.stream.segment/stream_topology.c:254
+#: ../raster/r.stream.segment/stream_topology.c:384
#, fuzzy
-msgid "Name of a space time raster dataset archive"
+msgid "To much points in stream line"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:5
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:5
-msgid "Path to the work directory, default is /tmp"
+#: ../raster/r.stream.segment/stream_segment.c:260
+#, c-format
+msgid "Network topology error: cannot identify stream join for stream %d"
msgstr ""
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:6
-#, fuzzy
-msgid "Compression method of the tar archive"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.export_to_translate.c:7
+#: ../raster/r.stream.segment/main.c:56
msgid ""
-"The export format of a single raster map. Supported are GTiff, AAIGrid via r."
-"out.gdal and the GRASS package format of r.pack."
+"Divides network into near straight-line segments and calculate its order."
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:1
-#, fuzzy
-msgid ""
-"Temporally aggregates the maps of a space time raster dataset by a user "
-"defined granularity."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.aggregate_to_translate.c:6
-msgid ""
-"Aggregation granularity, format absolute time \"x years, x months, x weeks, "
-"x days, x hours, x minutes, x seconds\" or an integer value for relative time"
+#: ../raster/r.stream.segment/main.c:60
+msgid "stream divide"
msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:1
+#: ../raster/r.stream.segment/main.c:75 ../raster/r.stream.segment/main.c:80
#, fuzzy
-msgid "Imports attribute tables in various formats."
+msgid "Name for output vector map to write segment attributes"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:4
-msgid "Table file to be imported or DB connection string"
-msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:5
+#: ../raster/r.stream.segment/main.c:84
#, fuzzy
-msgid "Name of table from given DB to be imported"
+msgid "Search length to calculate direction"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:6
-#, fuzzy
-msgid "Name for output table"
-msgstr "출력할 래스터맵"
+#: ../raster/r.stream.segment/main.c:91
+msgid "Skip segments shorter than"
+msgstr ""
-#: ../locale/scriptstrings/db.in.ogr_to_translate.c:7
+#: ../raster/r.stream.segment/main.c:92
#, fuzzy
-msgid "Name for auto-generated unique key column"
+msgid "Must be >= 0"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:1
-#, fuzzy
-msgid ""
-"Creates and connects a new attribute table to a given layer of an existing "
-"vector map."
-msgstr "출력할 래스터맵"
+#: ../raster/r.stream.segment/main.c:98
+msgid "Max angle (degrees) between stream segments"
+msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:5
+#: ../raster/r.stream.segment/main.c:108 ../raster/r.stream.segment/main.c:118
#, fuzzy
-msgid "Name of new attribute table (default: vector map name)"
+msgid "Memory setings"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:6
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:8
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:9
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:12
-#, fuzzy
-msgid "Definition"
-msgstr "출력할 래스터맵"
+#: ../raster/r.stream.segment/main.c:113
+msgid "Output angles in radians (default: degrees)"
+msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:7
+#: ../raster/r.stream.segment/main.c:130
#, fuzzy
-msgid "Layer number where to add new attribute table"
+msgid "Search's length must be > 0"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:10
-msgid "Name and type of the new column(s)"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addtable_to_translate.c:11
-msgid ""
-"Types depend on database backend, but all support VARCHAR(), INT, DOUBLE "
-"PRECISION and DATE. Example: \"label varchar(250), type integer\""
-msgstr ""
-#: ../locale/scriptstrings/t.rename_to_translate.c:1
+#: ../raster/r.stream.segment/main.c:132
#, fuzzy
-msgid "Renames a space time dataset"
+msgid "Threshold must be between 0 and 180"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:1
+#: ../raster/r.stream.segment/main.c:134
#, fuzzy
-msgid "Imports E00 file into a vector map."
+msgid "Segment's length must be >= 0"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.e00_to_translate.c:4
+#: ../raster/r.stream.segment/main.c:149 ../raster/r.stream.order/main.c:170
+#: ../raster/r.stream.stats/main.c:117
#, fuzzy
-msgid "Name of input E00 file"
+msgid "All in RAM calculation..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:1
+#: ../raster/r.stream.segment/main.c:187 ../raster/r.stream.order/main.c:224
+#: ../raster/r.stream.stats/main.c:155
#, fuzzy
-msgid "Drops a column from selected attribute table."
+msgid "Memory swap calculation (may take some time)..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:1
+#: ../raster/r.stream.segment/main.c:238
#, fuzzy
-msgid ""
-"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgid "Creating sectors and calculating attributes..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.neighbors_to_translate.c:8
-#, fuzzy
-msgid "Number of r.neighbor processes to run in parallel"
+#: ../raster/r.stream.segment/stream_vector.c:98
+#, fuzzy, c-format
+msgid "Unable to create create index on table <%s>"
msgstr "출력할 래스터맵"
-#, fuzzy
-msgid "Compute cyclic accumulations of a space time raster dataset"
+#: ../raster/r.stream.segment/stream_vector.c:143
+#: ../raster/r.stream.order/stream_vector.c:356
+#, fuzzy, c-format
+msgid "Unable to inset new row: '%s'"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:4
-msgid ""
-"Input space time raster dataset that defines the lower threshold, values "
-"lower this threshold are excluded from accumulation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:5
-msgid ""
-"Input space time raster dataset that defines the upper threshold, values "
-"upper this threshold are excluded from accumulation"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:10
-msgid "The granularity for accumulation '1 day'"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:13
-msgid ""
-"Use these limits in case lower and/or upper input space time raster "
-"datasets are not defined"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:14
-#, fuzzy
-msgid "Scale factor for input space time raster dataset"
+#: ../raster/r.stream.segment/stream_vector.c:258
+#, fuzzy, c-format
+msgid "Unable to create table '%s'"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:15
-#, fuzzy
-msgid "Shift factor for input space time raster dataset"
+#: ../raster/r.stream.segment/stream_vector.c:266
+#, fuzzy, c-format
+msgid "Unable grant privileges on table <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:16
-msgid ""
-"This method will be applied to compute the accumulative values from the "
-"input maps"
+#: ../raster/r.out.vrml/put_grid.c:38
+msgid "Writing vertices..."
msgstr ""
-#: ../locale/scriptstrings/t.rast.accumulate_to_translate.c:17
-msgid ""
-"Register empty maps in the output space time raster dataset, otherwise they "
-"will be deleted"
+#: ../raster/r.out.vrml/put_grid.c:83
+msgid "Writing color file..."
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:1
-msgid ""
-"Produces tilings of the source projection for use in the destination region "
-"and projection."
+#: ../raster/r.out.vrml/main.c:49
+msgid "VRML"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:4
-msgid "Produces shell script output"
+#: ../raster/r.out.vrml/main.c:51
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:5
-msgid "Produces web map server query string output"
+#: ../raster/r.out.vrml/main.c:58
+msgid "Name of elevation map"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:6
-msgid ""
-"Name of region to use instead of current region for bounds and resolution"
+#: ../raster/r.out.vrml/main.c:65
+msgid "Name of color file"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:7
+#: ../raster/r.out.vrml/main.c:76
#, fuzzy
-msgid "Source projection"
+msgid "Name for output VRML file"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:8
-#: ../locale/scriptstrings/r.tileset_to_translate.c:10
-msgid "Conversion factor from units to meters in source projection"
+#: ../raster/r.out.vrml/main.c:95
+#, c-format
+msgid "Range info for [%s] not available (run r.support)"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:9
-msgid "Destination projection, defaults to this location's projection"
+#: ../raster/r.out.vrml/main.c:104
+#, fuzzy, c-format
+msgid "Range info for <%s> not available (run r.support)"
+msgstr "출력할 래스터맵"
+#: ../raster/r.out.vrml/main.c:136
+#, c-format
+msgid "Opening %s for writing... "
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:11
-#, fuzzy
-msgid "Maximum number of columns for a tile in the source projection"
+#: ../raster/r.in.png/main.c:297
+#, fuzzy, c-format
+msgid "Unable to open PNG file '%s'"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.tileset_to_translate.c:12
-msgid "Maximum number of rows for a tile in the source projection"
+#: ../raster/r.in.png/main.c:300
+msgid "Input file empty or too short"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:13
-msgid "Number of cells tiles should overlap in each direction"
+#: ../raster/r.in.png/main.c:303
+msgid "Input file not a PNG file"
msgstr ""
-#: ../locale/scriptstrings/r.tileset_to_translate.c:14
-msgid "Output field separator"
+#: ../raster/r.in.png/main.c:314
+msgid "PNG error"
msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:1
-msgid "Reports geometry statistics for vector maps."
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:6
+#: ../raster/r.in.png/main.c:522
#, fuzzy
-msgid "Value to calculate"
+msgid "Imports non-georeferenced PNG format image."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.report_to_translate.c:7
-msgid "Sort the result"
-msgstr ""
-#: ../locale/scriptstrings/v.report_to_translate.c:8
-msgid "asc;Sort in ascending order;desc;Sort in descending order"
-msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:1
+#: ../raster/r.in.png/main.c:533
#, fuzzy
-msgid "Temporally snap the maps of a space time dataset."
+msgid "Title for created raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.snap_to_translate.c:3
-msgid "snap"
-msgstr ""
-#: ../locale/scriptstrings/t.snap_to_translate.c:4
-#: ../locale/scriptstrings/t.shift_to_translate.c:4
+#: ../raster/r.in.png/main.c:539
#, fuzzy
-msgid "Name of an existing space time dataset"
+msgid "Display gamma"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.snap_to_translate.c:5
-#: ../locale/scriptstrings/t.info_to_translate.c:5
-#: ../locale/scriptstrings/t.shift_to_translate.c:5
-msgid "Type of the dataset, default is strds (space time raster dataset)"
+#: ../raster/r.in.png/main.c:545
+msgid "Alpha threshold"
msgstr ""
-#: ../locale/scriptstrings/v.db.droprow_to_translate.c:1
-msgid "Removes a vector feature from a vector map through attribute selection."
-msgstr ""
-#: ../locale/scriptstrings/t.info_to_translate.c:1
+#: ../raster/r.in.png/main.c:549
#, fuzzy
-msgid "Lists information about space time datasets and maps."
+msgid "Create floating-point map (0.0 - 1.0)"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.info_to_translate.c:4
+#: ../raster/r.in.png/main.c:553
#, fuzzy
-msgid "Name of an existing space time dataset or map"
+msgid "Output image file header only and exit"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.info_to_translate.c:8
+#: ../raster/r.stream.order/io.c:297
#, fuzzy
-msgid "Print information in shell style"
+msgid "Uunrecognisable data type"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.info_to_translate.c:9
-#, fuzzy
-msgid ""
-"Print history information in human readable shell style for space time "
-"datasets"
+#: ../raster/r.stream.order/io.c:314
+#, fuzzy, c-format
+msgid "Unable re-open file '%s'"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.info_to_translate.c:10
-msgid "Print information about the temporal DBMI interface and exit"
+#: ../raster/r.stream.order/stream_topology.c:18
+#: ../raster/r.stream.order/stream_topology.c:65
+#: ../raster/r.stream.order/stream_topology.c:77
+#: ../raster/r.stream.order/stream_topology.c:90
+#: ../raster/r.stream.order/stream_topology.c:225
+#: ../raster/r.stream.order/stream_topology.c:283
+#: ../raster/r.stream.order/stream_topology.c:295
+#: ../raster/r.stream.order/stream_topology.c:309
+msgid "Error finding nodes. Stream and direction maps probably do not match."
msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:1
+#: ../raster/r.stream.order/stream_topology.c:126
+#: ../raster/r.stream.order/stream_topology.c:350
#, fuzzy
-msgid "Extracts a subset of a space time raster3d dataset."
+msgid "Finding longest streams..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:4
-msgid "The r3.mapcalc expression assigned to all extracted raster3d maps"
-msgstr ""
-#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:5
+#: ../raster/r.stream.order/stream_order.c:16
#, fuzzy
-msgid "Base name of the new created raster3d maps"
+msgid "Calculating Strahler's stream order..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:1
+#: ../raster/r.stream.order/stream_order.c:68
msgid ""
-"Dissolves boundaries between adjacent areas sharing a common category number "
-"or attribute."
+"Calculating Shreve's stream magnitude, Scheidegger's consistent integer and "
+"Drwal's streams hierarchy (old style)..."
msgstr ""
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:3
-msgid "dissolve"
-msgstr ""
+#: ../raster/r.stream.order/stream_order.c:122
+#, fuzzy
+msgid "Calculating Hortons's stream order..."
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
-#: ../locale/scriptstrings/v.centroids_to_translate.c:4
-#: ../vector/v.category/main.c:699
-msgid "area"
-msgstr ""
+#: ../raster/r.stream.order/stream_order.c:211
+#, fuzzy
+msgid "Calculating Hack's main streams and topological dimension..."
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:5
+#: ../raster/r.stream.order/main.c:33 ../raster/r.stream.stats/main.c:64
#, fuzzy
-msgid "Layer number or name."
+msgid "Name of input flow direction raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.dissolve_to_translate.c:6
+#: ../raster/r.stream.order/main.c:34
#, fuzzy
-msgid "Name of attribute column used to dissolve common boundaries"
+msgid "Name of input elevation raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:1
-msgid "Creates a MASK for limiting raster operation."
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:3
-#: ../raster3d/r3.mask/main.c:133
-msgid "mask"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:4
+#: ../raster/r.stream.order/main.c:45
#, fuzzy
-msgid "Name of raster map to use as mask"
+msgid "Name for output Strahler's stream order raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:6
+#: ../raster/r.stream.order/main.c:46
#, fuzzy
-msgid "Raster values to use for mask"
+msgid "Name for output original Hortons's stream order raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:7
-msgid "format: 1 2 3 thru 7 *"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:9
+#: ../raster/r.stream.order/main.c:47
#, fuzzy
-msgid "Name of vector map to use as mask"
+msgid "Name for output Shereve's stream magnitude raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:10
-#: ../locale/scriptstrings/r.mask_to_translate.c:12
-#: ../locale/scriptstrings/r.mask_to_translate.c:14
-#: ../locale/scriptstrings/r.mask_to_translate.c:16
-msgid "Vector"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:11
+#: ../raster/r.stream.order/main.c:48
#, fuzzy
-msgid "Layer number or name (vector)"
+msgid "Name for output Hack's streams or Gravelius stream hierarchy raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:13
+#: ../raster/r.stream.order/main.c:49
#, fuzzy
-msgid "Category values (vector)"
+msgid "Name for output topological dimension of streams raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:15
-msgid "WHERE conditions of SQL statement without 'where' keyword (vector)"
-msgstr ""
-#: ../locale/scriptstrings/r.mask_to_translate.c:17
+#: ../raster/r.stream.order/main.c:72
#, fuzzy
-msgid "Create inverse mask"
+msgid "Calculates Strahler's and more streams hierarchy."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.mask_to_translate.c:19
-msgid "Remove existing mask (overrides other options)"
+#: ../raster/r.stream.order/main.c:74
+msgid "Basic module for topological analysis of drainage network."
msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:1
+#: ../raster/r.stream.order/main.c:78
+msgid "stream order"
+msgstr ""
+#: ../raster/r.stream.order/main.c:92
#, fuzzy
-msgid "Temporally shift the maps of a space time dataset."
+msgid "Name for output vector map to write stream attributes"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.shift_to_translate.c:3
-msgid "shift"
+#: ../raster/r.stream.order/main.c:113
+msgid "Create zero-valued background instead of NULL"
msgstr ""
-#: ../locale/scriptstrings/t.shift_to_translate.c:8
-msgid ""
-"Shift granularity, format absolute time \"x years, x months, x weeks, x "
-"days, x hours, x minutes, x seconds\" or an integer value for relative time"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:1
+#: ../raster/r.stream.order/main.c:123
#, fuzzy
-msgid "Displays thematic vector map"
+msgid "Use flow accumulation to trace horton and hack models"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:3
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:3
-#: ../display/d.graph/main.c:59 ../display/d.legend/main.c:86
-#: ../display/d.grid/main.c:52 ../display/d.linegraph/main.c:120
-#: ../display/d.thematic.area/main.c:78 ../display/d.text/main.c:139
-#: ../display/d.northarrow/main.c:43 ../display/d.barscale/main.c:55
-#: ../display/d.vect.chart/main.c:64 ../display/d.title/main.c:50
-msgid "cartography"
+#: ../raster/r.stream.order/main.c:140
+msgid ""
+"To calculate vector map both accumulation and elevation raster maps are "
+"required"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:5
-msgid "thematic"
+#: ../raster/r.stream.order/main.c:143
+msgid "Flag -a (use accumulation) accumulation raster map is required"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:6
-msgid "legend"
+#: ../raster/r.stream.order/main.c:152
+msgid ""
+"You must select one or more output orders raster maps or insert the table "
+"name"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:7
+#: ../raster/r.stream.order/stream_vector.c:80
+#: ../raster/r.stream.order/stream_vector.c:174
+#, fuzzy, c-format
+msgid "Unable to add attribute table to vector map <%s>"
+msgstr "출력할 래스터맵"
+#: ../raster/r.stream.order/stream_vector.c:253
+#: ../raster/r.stream.order/stream_vector.c:332
#, fuzzy
-msgid "Name of attribute column to use for thematic display (must be numeric)"
+msgid "Error with number of tributuaries"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:8
+#: ../raster/r.stream.order/stream_init.c:8
#, fuzzy
-msgid "Type of thematic display"
+msgid "Empty stream input raster map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:9
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:11
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:14
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:23
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:43
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:49
-msgid "Theme"
-msgstr ""
+#: ../raster/r.stream.order/stream_init.c:10
+#, fuzzy
+msgid "Stream map has negative values"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:10
-msgid "Thematic divisions of data for display"
-msgstr ""
+#: ../raster/r.water.outlet/main.c:66
+#, fuzzy
+msgid "Creates watershed basins from a drainage direction map."
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:12
-msgid "Break points for custom breaks option"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:13
-msgid "Separate values by spaces (0 10 20 30 ...)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:15
+#: ../raster/r.water.outlet/main.c:72
#, fuzzy
-msgid "Vector point icon for point data"
+msgid "Name of input drainage direction map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:17
+#: ../raster/r.water.outlet/main.c:75
#, fuzzy
-msgid "Icon size for point data"
+msgid "Name for output watershed basin map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:18
-msgid "Minimum icon size/line width for graduated points/lines)"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:20
-msgid "Maximum icon size/line width for graduated points and lines"
-msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:22
+#: ../raster/r.water.outlet/main.c:78
#, fuzzy
-msgid "Number of classes for interval theme (integer)"
+msgid "Coordinates of outlet point"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:24
-msgid "Color scheme for graduated color mapping"
-msgstr ""
+#: ../raster/r.water.outlet/main.c:91
+#, fuzzy, c-format
+msgid "Illegal east coordinate '%s'"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:25
-msgid "Select 'single_color' for graduated point/line display"
-msgstr ""
+#: ../raster/r.water.outlet/main.c:93
+#, fuzzy, c-format
+msgid "Illegal north coordinate '%s'"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:26
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:29
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:32
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:35
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:38
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:51
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:53
-#: ../display/d.grid/main.c:92 ../display/d.grid/main.c:97
-#: ../display/d.grid/main.c:103
-msgid "Color"
+#: ../raster/r.water.outlet/main.c:98
+#, c-format
+msgid "Ignoring point outside computation region: %.4f,%.4f"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:27
-msgid "Color for graduated points map"
+#: ../raster/r.what.color/main.c:91
+msgid "Queries colors for a raster map layer."
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:28
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color"
-msgstr ""
+#: ../raster/r.what.color/main.c:99
+#, fuzzy
+msgid "Name of existing raster map to query colors"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:30
-msgid "Color for graduated lines or point/area outlines"
+#: ../raster/r.what.color/main.c:106
+msgid "Values to query colors for"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:31
-msgid "GRASS named color or R:G:B triplet. Set color scheme to single color."
+#: ../raster/r.what.color/main.c:113
+msgid "Output format (printf-style)"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:33
-msgid "Beginning color for custom color gradient"
+#: ../raster/r.what.color/main.c:117
+msgid "Read values from stdin"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:34
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:37
-msgid "Must be expressed as R:G:B triplet"
+#: ../raster/r.what.color/main.c:123
+msgid "Either \"-i\" or \"value=\" must be given"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:36
-msgid "Ending color for custom color gradient"
+#: ../raster/r.sun/main.c:239
+msgid "sun energy"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:39
-msgid "Select WXGUI display monitor for legend"
+#: ../raster/r.sun/main.c:240
+msgid "Solar irradiance and irradiation model."
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:40
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:55
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:57
-msgid "Misc"
+#: ../raster/r.sun/main.c:242
+msgid ""
+"Computes direct (beam), diffuse and reflected solar irradiation raster maps "
+"for given day, latitude, surface and atmospheric conditions. Solar "
+"parameters (e.g. sunrise, sunset times, declination, extraterrestrial "
+"irradiance, daylight length) are saved in the map history file. "
+"Alternatively, a local time can be specified to compute solar incidence "
+"angle and/or irradiance raster maps. The shadowing effect of the topography "
+"is optionally incorporated."
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:41
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:46
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:48
-msgid "Files"
+#: ../raster/r.sun/main.c:256 ../raster/r.horizon/main.c:198
+msgid "Name of the input elevation raster map [meters]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:42
-msgid "Save thematic map commands to group file for GIS Manager"
+#: ../raster/r.sun/main.c:265
+msgid ""
+"Name of the input aspect map (terrain aspect or azimuth of the solar panel) "
+"[decimal degrees]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:44
-msgid "Root for the name of psmap instruction files to be in current directory"
+#: ../raster/r.sun/main.c:274
+msgid "A single value of the orientation (aspect), 270 is south"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:45
-msgid "If not set, no psmap instruction files will be created)"
+#: ../raster/r.sun/main.c:283
+msgid ""
+"Name of the input slope raster map (terrain slope or solar panel "
+"inclination) [decimal degrees]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:47
-msgid "Name of group file where thematic map commands will be saved"
+#: ../raster/r.sun/main.c:291
+msgid "A single value of inclination (slope)"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:50
-msgid "Create graphic legend in x11 display monitor"
+#: ../raster/r.sun/main.c:300
+msgid ""
+"Name of the Linke atmospheric turbidity coefficient input raster map [-]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:52
-msgid "Only draw fills (no outlines) for areas and points"
+#: ../raster/r.sun/main.c:310
+msgid "A single value of the Linke atmospheric turbidity coefficient [-]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:54
-msgid "Update color values to GRASSRGB column in attribute table"
+#: ../raster/r.sun/main.c:320
+msgid "Name of the ground albedo coefficient input raster map [-]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:56
-msgid "Output legend for GIS Manager (for scripting use only)"
+#: ../raster/r.sun/main.c:330
+msgid "A single value of the ground albedo coefficient [-]"
msgstr ""
-#: ../locale/scriptstrings/d.vect.thematic_to_translate.c:58
-msgid "Use math notation brackets in legend"
-msgstr ""
-#: ../locale/scriptstrings/db.univar_to_translate.c:1
+#: ../raster/r.sun/main.c:340
#, fuzzy
-msgid "Calculates univariate statistics on selected table column."
+msgid "Name of input raster map containing latitudes [decimal degrees]"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:1
+#: ../raster/r.sun/main.c:349
#, fuzzy
-msgid "Lists registered maps of a space time raster dataset."
+msgid "Name of input raster map containing longitudes [decimal degrees]"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:6
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:5
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:6
+#: ../raster/r.sun/main.c:358
#, fuzzy
-msgid "Order the space time dataset by category"
+msgid ""
+"Name of real-sky beam radiation coefficient (thick cloud) input raster map "
+"[0-1]"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:7
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:6
+#: ../raster/r.sun/main.c:367
#, fuzzy
-msgid "Select columns to be printed to stdout"
+msgid ""
+"Name of real-sky diffuse radiation coefficient (haze) input raster map [0-1]"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:8
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:7
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:8
-#, fuzzy
-msgid "Method used for data listing"
-msgstr "출력할 래스터맵"
+#: ../raster/r.sun/main.c:375
+msgid "The horizon information input map prefix"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:9
-msgid ""
-"The granule to be used for listing. The granule must be specified as string "
-"eg.: absolute time \"1 months\" or relative time \"1\""
+#: ../raster/r.sun/main.c:383 ../raster/r.horizon/main.c:215
+msgid "Angle step size for multidirectional horizon [degrees]"
msgstr ""
-#: ../locale/scriptstrings/t.rast.list_to_translate.c:10
-#: ../locale/scriptstrings/t.list_to_translate.c:15
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:8
-msgid "Separator character between the columns, default is tabular \"\t\""
+#: ../raster/r.sun/main.c:392
+msgid "Output incidence angle raster map (mode 1 only)"
msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:1
-msgid "Sets color rules based on stddev from a raster map's mean value."
+#: ../raster/r.sun/main.c:401
+msgid ""
+"Output beam irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:4
-msgid "Color using standard deviation bands"
+#: ../raster/r.sun/main.c:410
+msgid ""
+"Output diffuse irradiance [W.m-2] (mode 1) or irradiation raster map [Wh.m-2."
+"day-1] (mode 2)"
msgstr ""
-#: ../locale/scriptstrings/r.colors.stddev_to_translate.c:5
-msgid "Force center at zero"
+#: ../raster/r.sun/main.c:419
+msgid ""
+"Output ground reflected irradiance [W.m-2] (mode 1) or irradiation raster "
+"map [Wh.m-2.day-1] (mode 2)"
msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:1
-msgid "Mosaics several images and extends colormap."
+#: ../raster/r.sun/main.c:428
+msgid ""
+"Output global (total) irradiance/irradiation [W.m-2] (mode 1) or irradiance/"
+"irradiation raster map [Wh.m-2.day-1] (mode 2)"
msgstr ""
-#: ../locale/scriptstrings/i.image.mosaic_to_translate.c:4
-msgid "mosaicking"
+#: ../raster/r.sun/main.c:437
+msgid "Output insolation time raster map [h] (mode 2 only)"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:1
-msgid "Downloads and imports data from WMS/WMTS/NASA OnEarth server."
+#: ../raster/r.sun/main.c:444
+msgid "No. of day of the year (1-365)"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:4
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:4
-msgid "OGC web services"
+#: ../raster/r.sun/main.c:453
+msgid "Time step when computing all-day radiation sums [decimal hours]"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:5
-msgid "Typically starts with \"http://\""
+#: ../raster/r.sun/main.c:460
+msgid "Declination value (overriding the internally computed value) [radians]"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:7
-#, fuzzy
-msgid "Layer(s) to request from the map server"
-msgstr "출력할 래스터맵"
+#: ../raster/r.sun/main.c:468
+msgid "Local (solar) time (to be set for mode 1 only) [decimal hours]"
+msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:8
-#, fuzzy
-msgid "Layer style(s) to request from the map server"
-msgstr "출력할 래스터맵"
+#: ../raster/r.sun/main.c:491 ../raster/r.horizon/main.c:290
+msgid "Sampling distance step coefficient (0.5-1.5)"
+msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:9
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:34
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:40
-msgid "Map style"
+#: ../raster/r.sun/main.c:499
+msgid "Read the input files in this number of chunks"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:10
-msgid "Image format requested from the server"
+#: ../raster/r.sun/main.c:506
+msgid "Civil time zone value, if none, the time will be local solar time"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:11
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:13
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:18
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:20
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:22
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:24
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:31
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:38
-msgid "Request"
+#: ../raster/r.sun/main.c:512
+msgid "Do not incorporate the shadowing effect of terrain"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:12
-msgid "EPSG code of requested source projection"
+#: ../raster/r.sun/main.c:517
+msgid "Use the low-memory version of the program"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:14
-msgid "Driver used to communication with server"
+#: ../raster/r.sun/main.c:558
+msgid "You must give the longitude raster if you use civil time"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:15
-msgid ""
-"WMS_GDAL;Download data using GDAL WMS driver;WMS_GRASS;Download data using "
-"native GRASS-WMS driver;WMTS_GRASS;Download data using native GRASS-WMTS "
-"driver;OnEarth_GRASS;Download data using native GRASS-OnEarth driver;"
+#: ../raster/r.sun/main.c:561
+#, fuzzy
+msgid "Error reading civil time zone value"
+msgstr "출력할 래스터맵"
+#: ../raster/r.sun/main.c:564
+msgid "Invalid civil time zone value"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:17
-msgid "WMS standard version"
+#: ../raster/r.sun/main.c:589
+msgid "insol_time and incidout are incompatible options"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:19
+#: ../raster/r.sun/main.c:594
#, fuzzy
-msgid "Maximum columns to request at a time"
+msgid "Error reading time step size"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:21
+#: ../raster/r.sun/main.c:596
#, fuzzy
-msgid "Maximum rows to request at a time"
+msgid "Invalid time step size"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:23
-msgid "Additional query parameters to pass to the server"
-msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:25
+#: ../raster/r.sun/main.c:600
#, fuzzy
-msgid "Username for server connection"
+msgid "Error reading horizon step size"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:27
-msgid "Password for server connection"
+#: ../raster/r.sun/main.c:604
+msgid "The horizon step size must be greater than 0."
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:29
-msgid "Interpolation method to use in reprojection"
+#: ../raster/r.sun/main.c:607
+msgid ""
+"If you use the horizon option you must also set the 'horizonstep' parameter."
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:30
-msgid "Request data for this named region instead of the current region bounds"
+#: ../raster/r.sun/main.c:613
+msgid "Time and insol_time are incompatible options"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
-#: ../display/d.path/main.c:116 ../vector/v.label/main.c:187
-#: ../vector/v.label.sa/main.c:124 ../vector/v.lrs/v.lrs.label/main.c:229
-msgid "Background color"
+#: ../raster/r.sun/main.c:615
+msgid ""
+"Mode 1: instantaneous solar incidence angle & irradiance using a set local "
+"time"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:33
-msgid "Format: 0xRRGGBB"
+#: ../raster/r.sun/main.c:620
+msgid "incidout requires time parameter to be set"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:35
-msgid ""
-"Capabilities file to parse (input). It is relevant for WMTS_GRASS and "
-"OnEarth_GRASS drivers"
+#: ../raster/r.sun/main.c:622
+msgid "Mode 2: integrated daily irradiation for a given day of the year"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:36
-msgid "File in which the server capabilities will be saved ('c' flag)"
+#: ../raster/r.sun/main.c:668
+msgid "If you use -s and no horizon rasters, numpartitions must be =1"
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:37
-msgid "Get the server capabilities then exit"
+#: ../raster/r.sun/main.c:681
+msgid ""
+"If you want to save memory and to use shadows, you must use pre-calculated "
+"horizons."
msgstr ""
-#: ../locale/scriptstrings/r.in.wms_to_translate.c:39
-msgid "Don't request transparent data"
+#: ../raster/r.sun/main.c:748
+msgid "latin and longin raster maps have no effect when in a Lat/Lon location"
msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:1
-#, fuzzy
-msgid "Extracts a subset of a space time vector dataset."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:6
-msgid ""
-"The number of v.extract processes to run in parallel. Use only if database "
-"backend is used which supports concurrent writing"
+#: ../raster/r.sun/main.c:753
+msgid "Both latin and longin raster maps must be given, or neither"
msgstr ""
-#: ../locale/scriptstrings/t.vect.extract_to_translate.c:7
-#, fuzzy
-msgid "Register empty maps"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:1
-#, fuzzy
-msgid "Updates a column in the attribute table connected to a vector map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:5
-#, fuzzy
-msgid "Name of attribute column to update"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.update_to_translate.c:6
-msgid "Literal value to update the column with"
+#: ../raster/r.stream.stats/io.c:531
+#, c-format
+msgid "ram_null:Cannot convert to null at: %d %d"
msgstr ""
-#: ../locale/scriptstrings/v.db.update_to_translate.c:7
+#: ../raster/r.stream.stats/main.c:52
msgid ""
-"Name of other attribute column to query, can be combination of columns (e.g. "
-"co1+col2)"
+"Calculates Horton's statistics for Strahler and Horton ordered networks "
+"created with r.stream.order."
msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:1
+#: ../raster/r.stream.stats/main.c:56
#, fuzzy
-msgid "Drops an attribute table."
+msgid "Horton's statistics"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:5
+#: ../raster/r.stream.stats/main.c:78
#, fuzzy
-msgid "Name of database driver"
+msgid "Name for output file (if omitted output to stdout)"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:6
-msgid "If not given then default driver is used"
+#: ../raster/r.stream.stats/main.c:88
+msgid "Print only catchment's statistics"
msgstr ""
-#: ../locale/scriptstrings/db.droptable_to_translate.c:8
+#: ../raster/r.stream.stats/main.c:93
#, fuzzy
-msgid "Name of database"
+msgid "Print only orders' statistics"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:9
-#, fuzzy
-msgid "If not given then default database is used"
+#: ../raster/r.stream.stats/main.c:106 ../vector/v.rectify/main.c:183
+#: ../vector/v.net.salesman/main.c:521
+#, fuzzy, c-format
+msgid "Unable to open file '%s' for writing"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/db.droptable_to_translate.c:11
-#, fuzzy
-msgid "Name of table to drop"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.create_to_translate.c:1
-#, fuzzy
-msgid "Creates a space time dataset."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.create_to_translate.c:4
-#, fuzzy
-msgid "create"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.create_to_translate.c:5
-#, fuzzy
-msgid "The output type of the space time dataset"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.create_to_translate.c:6
-#: ../locale/scriptstrings/t.support_to_translate.c:4
-#, fuzzy
-msgid "Semantic type of the space time dataset"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:1
-msgid "Rebuilds or removes all locally installed GRASS Addons extensions."
+#: ../raster/r.horizon/main.c:182
+msgid "Horizon angle computation from a digital elevation model."
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:2
+#: ../raster/r.horizon/main.c:184
msgid ""
-"By default only extensions built against different GIS Library are rebuilt."
+"Computes horizon angle height from a digital elevation model. The module has "
+"two different modes of operation: 1. Computes the entire horizon around a "
+"single point whose coordinates are given with the 'coord' option. The "
+"horizon height (in radians). 2. Computes one or more raster maps of the "
+"horizon height in a single direction. The input for this is the angle (in "
+"degrees), which is measured counterclockwise with east=0, north=90 etc. The "
+"output is the horizon height in radians."
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:4
-#: ../locale/scriptstrings/g.extension_to_translate.c:4
-msgid "installation"
+#: ../raster/r.horizon/main.c:207
+msgid "Direction in which you want to know the horizon height"
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:5
-#: ../locale/scriptstrings/g.extension_to_translate.c:5
-msgid "extensions"
+#: ../raster/r.horizon/main.c:223
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer around the present "
+"region"
msgstr ""
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
-#: ../locale/scriptstrings/g.extension_to_translate.c:8
-#: ../vector/v.net/args.c:36
-#, fuzzy
-msgid "Operation to be performed"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/g.extension.all_to_translate.c:7
-msgid "Force operation (required for removal)"
+#: ../raster/r.horizon/main.c:231
+msgid ""
+"For horizon rasters, read from the DEM an extra buffer eastward the present "
+"region"
msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:1
+#: ../raster/r.horizon/main.c:239
msgid ""
-"Performs different aggregation algorithms from r.series on all or a subset "
-"of raster maps in a space time raster dataset."
+"For horizon rasters, read from the DEM an extra buffer westward the present "
+"region"
msgstr ""
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:5
-#, fuzzy
-msgid "Sort the maps by category"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.series_to_translate.c:6
-#, fuzzy
+#: ../raster/r.horizon/main.c:247
msgid ""
-"Do not assign the space time raster dataset start and end time to the output "
-"map"
-msgstr "출력할 래스터맵"
+"For horizon rasters, read from the DEM an extra buffer northward the present "
+"region"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:1
-#, fuzzy
+#: ../raster/r.horizon/main.c:255
msgid ""
-"Apply temporal and spatial oeprations on space time raster datasets using "
-"temporal raster algebra."
-msgstr "출력할 래스터맵"
+"For horizon rasters, read from the DEM an extra buffer southward the present "
+"region"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:4
-#, fuzzy
-msgid ""
-"The mapcalc expression for temporal and spatial analysis of space time "
-"raster datasets."
-msgstr "출력할 래스터맵"
+#: ../raster/r.horizon/main.c:263
+msgid "The maximum distance to consider when finding the horizon height"
+msgstr ""
-#: ../locale/scriptstrings/t.rast.mapcalc2_to_translate.c:5
+#: ../raster/r.horizon/main.c:272
#, fuzzy
-msgid ""
-"The basename of raster maps that are stored within the result space time "
-"raster dataset."
+msgid "Prefix of the horizon raster output maps"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.to.rast3_to_translate.c:1
-#, fuzzy
-msgid "Converts a space time raster dataset into a raster3d map."
-msgstr "출력할 래스터맵"
+#: ../raster/r.horizon/main.c:282
+msgid "Coordinate for which you want to calculate the horizon"
+msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:1
-msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+#: ../raster/r.horizon/main.c:302
+msgid "Write output in degrees (default is radians)"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:4
-#, fuzzy
-msgid "Input coordinates to reproject"
-msgstr "출력할 래스터맵"
+#: ../raster/r.horizon/main.c:350
+msgid "Can't read the coordinates from the \"coordinate\" option."
+msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:5
-#: ../locale/scriptstrings/m.proj_to_translate.c:8
-#: ../locale/scriptstrings/m.proj_to_translate.c:13
-#, fuzzy
-msgid "Input coordinates"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/m.proj_to_translate.c:6
-#, fuzzy
-msgid "Name of input coordinate file"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/m.proj_to_translate.c:7
-#, fuzzy
-msgid "'-' to read from standard input"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/m.proj_to_translate.c:9
-#, fuzzy
-msgid "Name for output coordinate file (omit to send to stdout)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/m.proj_to_translate.c:11
-msgid "Field separator (format: input[,output])"
+#: ../raster/r.horizon/main.c:377
+msgid "You didn't specify a direction value or step size. Aborting."
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:12
-msgid "Valid field separators are also \"space\", \"tab\", or \"comma\""
+#: ../raster/r.horizon/main.c:382
+msgid "You didn't specify a horizon raster name. Aborting."
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:14
-msgid "Input projection parameters (PROJ.4 style)"
+#: ../raster/r.horizon/main.c:392
+msgid "You didn't specify an angle step size. Aborting."
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:15
-#: ../locale/scriptstrings/m.proj_to_translate.c:17
-#: ../locale/scriptstrings/m.proj_to_translate.c:19
-#: ../locale/scriptstrings/m.proj_to_translate.c:21
+#: ../raster/r.horizon/main.c:405
#, fuzzy
-msgid "Projections"
+msgid "Could not read bufferzone size. Aborting."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/m.proj_to_translate.c:16
-msgid "Output projection parameters (PROJ.4 style)"
+#: ../raster/r.horizon/main.c:410 ../raster/r.horizon/main.c:416
+#: ../raster/r.horizon/main.c:423 ../raster/r.horizon/main.c:430
+#, c-format
+msgid "Could not read %s bufferzone size. Aborting."
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:18
-msgid "Use LL WGS84 as input and current location as output projection"
+#: ../raster/r.horizon/main.c:411
+msgid "east"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:20
-msgid "Use current location as input and LL WGS84 as output projection"
+#: ../raster/r.horizon/main.c:417
+msgid "west"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:22
-msgid ""
-"Output long/lat in decimal degrees, or other projections with many decimal "
-"places"
+#: ../raster/r.horizon/main.c:424
+msgid "south"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:24
-msgid "Include input coordinates in output file"
+#: ../raster/r.horizon/main.c:431
+msgid "north"
msgstr ""
-#: ../locale/scriptstrings/m.proj_to_translate.c:26
-msgid "Include column names in output file"
+#: ../raster/r.horizon/main.c:436
+msgid "Could not read maximum distance. Aborting."
msgstr ""
-#, fuzzy
-msgid "List space time datasets and maps registered in the temporal database."
-msgstr "출력할 래스터맵"
+#: ../raster/r.horizon/main.c:441
+msgid "The distance value must be 0.5-1.5. Aborting."
+msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:5
-#, fuzzy
-msgid "Type of the space time dataset or map, default is strds"
+#: ../raster/r.horizon/main.c:1122
+#, fuzzy, c-format
+msgid "Calculating map %01d of %01d (angle %.2f, raster map <%s>)"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.list_to_translate.c:8
-#: ../locale/scriptstrings/t.list_to_translate.c:11
-msgid ""
-"Columns number_of_maps and granularity only available for space time datasets"
-msgstr ""
-#: ../locale/scriptstrings/t.list_to_translate.c:9
+#: ../raster/r.stats.quantile/main.c:76
#, fuzzy
-msgid "Sort the space time dataset by category"
+msgid "Computing histograms"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.list_to_translate.c:12
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:7
+#: ../raster/r.stats.quantile/main.c:242
#, fuzzy
-msgid "Columns to be printed to stdout"
+msgid "Printing quantiles"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.list_to_translate.c:17
-msgid "Print the column names as first row"
-msgstr ""
-#: ../locale/scriptstrings/t.vect.list_to_translate.c:1
+#: ../raster/r.stats.quantile/main.c:294
#, fuzzy
-msgid "Lists registered maps of a space time vector dataset."
+msgid "Generating reclass maps"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:1
-msgid ""
-"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
-"using gdalwarp."
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:5
-#: ../imagery/i.aster.toar/main.c:99
-msgid "Terra-ASTER"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:6
+#: ../raster/r.stats.quantile/main.c:333
#, fuzzy
-msgid "Name of input ASTER image"
+msgid "Writing output maps"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:7
-msgid "ASTER imagery processing type (Level 1A, Level 1B, or relative DEM)"
+#: ../raster/r.stats.quantile/main.c:391
+msgid "Compute category quantiles using two passes."
msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:8
-msgid ""
-"List L1A or L1B band to translate (1,2,3n,...), or enter 'all' to translate "
-"all bands"
-msgstr ""
-#: ../locale/scriptstrings/r.in.aster_to_translate.c:9
+#: ../raster/r.stats.quantile/main.c:418
#, fuzzy
-msgid ""
-"Base name for output raster map (band number will be appended to base name)"
+msgid "Resultant raster map(s)"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.unpack_to_translate.c:1
-msgid "Unpacks a vector map packed with v.pack."
+#: ../raster/r.stats.quantile/main.c:430
+msgid "Don't create output maps; just print statistics"
msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:2
-msgid "vector, import, copying"
-msgstr ""
-#: ../locale/scriptstrings/v.unpack_to_translate.c:3
-#: ../locale/scriptstrings/r.unpack_to_translate.c:5
+#: ../raster/r.stats.quantile/main.c:442
#, fuzzy
-msgid "Name of input pack file"
+msgid "Either -p or output= must be given"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.unpack_to_translate.c:4
-#, fuzzy
-msgid "Name for output vector map"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.unpack_to_translate.c:5
-#, fuzzy
-msgid "Default: taken from input file internals"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.unpack_to_translate.c:6
-#: ../locale/scriptstrings/r.unpack_to_translate.c:8
-msgid "Override projection check (use current location's projection)"
+#: ../raster/r.stats.quantile/main.c:445
+msgid "-p and output= are mutually exclusive"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:1
-msgid "Displays a raster map and its legend on a graphics window"
+#: ../raster/r.stats.quantile/main.c:469
+#, c-format
+msgid "Number of quantiles (%d) does not match number of output maps (%d)"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:4
-#: ../display/d.legend/main.c:207
-msgid "Flip legend"
+#: ../raster/r.stats.quantile/main.c:486
+#, c-format
+msgid "Base map <%s> has too many categories (max: %d)"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:5
-msgid "Omit entries with missing label"
+#: ../vector/v.in.sites/main.c:59
+#: ../locale/scriptstrings/v.in.sites.all_to_translate.c:2
+msgid "sites"
msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:6
+#: ../vector/v.in.sites/main.c:61
#, fuzzy
-msgid "Name of raster map to display"
+msgid "Converts a GRASS site_lists file into a vector map."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:7
-#: ../display/d.legend/main.c:202
-msgid "Draw smooth gradient"
-msgstr ""
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:8
-#, fuzzy
-msgid "Number of lines to appear in the legend"
+#: ../vector/v.in.sites/main.c:85
+#, fuzzy, c-format
+msgid "Site file <%s> not found"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.rast.leg_to_translate.c:9
-#, fuzzy
-msgid "Name of input raster map to generate legend from"
+#: ../vector/v.in.sites/main.c:88
+#, fuzzy, c-format
+msgid "Unable to open site file <%s@%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from a raster map based on vector polygon "
-"map and uploads statistics to new attribute columns."
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:7
-msgid "Continue if upload column(s) already exist"
-msgstr ""
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:8
+#: ../vector/v.in.sites/main.c:91
#, fuzzy
-msgid "Name of input raster map to calculate statistics from"
+msgid "Unable to guess site_list format"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:9
+#: ../vector/v.in.sites/main.c:94
#, fuzzy
-msgid "Column prefix for new attribute columns"
+msgid "Failed to allocate site structure"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.rast.stats_to_translate.c:10
-msgid "The methods to use"
+#: ../vector/v.in.sites/main.c:96
+#, c-format
+msgid "Input format: dimension: %d strings: %d FP: %d"
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:1
-msgid ""
-"Aggregated data of an existing space time raster dataset using the time "
-"intervals of a second space time dataset."
+#: ../vector/v.in.sites/main.c:100
+msgid "Floating point category values, using sequential integer for category"
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:4
-msgid ""
-"Time intervals from this space time dataset (raster, vector or raster3d) are "
-"used for aggregation computation"
+#: ../vector/v.in.sites/main.c:103
+msgid "No category values, using sequential integer for category"
msgstr ""
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:5
+#: ../vector/v.in.sites/main.c:187
#, fuzzy
-msgid "Type of the aggregation space time dataset, default is strds"
+msgid "Transferring sites to vector point map..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.aggregate.ds_to_translate.c:8
-#, fuzzy
-msgid "Aggregate operation to be peformed on the raster maps"
+#: ../vector/v.in.sites/main.c:244 ../vector/v.in.dxf/write_vect.c:70
+#: ../vector/v.in.ascii/points.c:409 ../vector/v.mkgrid/main.c:308
+#, fuzzy, c-format
+msgid "Unable to insert new record: %s"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:1
-msgid ""
-"Reclasses a raster map greater or less than user specified area size (in "
-"hectares)."
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:5
-msgid "Lesser value option that sets the <= area size limit [hectares]"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:6
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:8
-msgid "Area"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:7
-msgid "Greater value option that sets the >= area size limit [hectares]"
-msgstr ""
-#: ../locale/scriptstrings/r.reclass.area_to_translate.c:9
-#, fuzzy
-msgid "Input map is clumped"
+#: ../vector/v.in.sites/main.c:259
+#, fuzzy, c-format
+msgid "%d sites written."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:1
-msgid "Uploads vector values at positions of vector points to the table."
-msgstr ""
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
-#: ../vector/v.what.rast3/main.c:75 ../vector/v.what.rast/main.c:82
-#, fuzzy
-msgid "Name of vector points map for which to edit attributes"
+#: ../vector/v.colors.out/scan_cats.c:24
+#: ../vector/v.colors.out/make_colors.c:27 ../vector/v.surf.rst/main.c:538
+#: ../vector/v.colors/main.c:272 ../vector/v.out.ascii/main.c:104
+#, fuzzy, c-format
+msgid "Layer <%s> not found"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
-#: ../vector/v.what.rast3/main.c:86 ../vector/v.what.rast/main.c:97
+#: ../vector/v.colors.out/scan_cats.c:28 ../vector/v.to.rast/do_lines.c:36
+#: ../vector/v.voronoi/main.c:207 ../vector/v.colors/scan_cats.c:19
+#: ../vector/v.colors/scan_z.c:31 ../vector/v.to.db/lines.c:75
+#: ../vector/v.to.db/query.c:23
#, fuzzy
-msgid "Name of attribute column to be updated with the query result"
+msgid "Reading features..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:8
+#: ../vector/v.colors.out/main.c:53
#, fuzzy
-msgid "Name of vector map to be queried"
+msgid "Exports the color table associated with a vector map."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:9
+#: ../vector/v.colors.out/main.c:66
#, fuzzy
-msgid "Name of attribute column to be queried"
+msgid "Name of attribute (numeric) column to which refer color rules"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.what.vect_to_translate.c:10
-msgid "Maximum query distance in map units"
+#: ../vector/v.colors.out/main.c:67
+msgid "If not given color rules are refered to categories"
msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:1
-#, fuzzy
-msgid "Exports space time raster dataset as VTK time series."
+#: ../vector/v.colors.out/main.c:85
+#, fuzzy, c-format
+msgid "Unable to read color table for vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:5
-msgid "VTK"
-msgstr ""
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:6
-#, fuzzy
-msgid "Path to the export directory"
+#: ../vector/v.colors.out/main.c:88
+#, fuzzy, c-format
+msgid "No color table defined for vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.out.vtk_to_translate.c:10
-msgid ""
-"Export files using the space time dataset granularity for equidistant time "
-"between maps, where statement will be ignored"
+#: ../vector/v.colors.out/make_colors.c:31 ../vector/v.to.rast/vect2rast.c:55
+#: ../vector/v.db.select/main.c:154 ../vector/v.db.connect/main.c:213
+#: ../vector/v.distance/main.c:423 ../vector/v.distance/main.c:504
+#: ../vector/v.extract/main.c:252 ../vector/v.to.3d/trans3.c:51
+#: ../vector/v.to.3d/trans2.c:49 ../vector/v.to.rast3/main.c:80
+#: ../vector/v.info/print.c:138
+#, c-format
+msgid "Database connection not defined for layer <%s>"
msgstr ""
-#: ../locale/scriptstrings/v.build.all_to_translate.c:1
-#, fuzzy
-msgid "Rebuilds topology on all vector maps in the current mapset."
+#: ../vector/v.colors.out/make_colors.c:41 ../vector/v.in.db/main.c:187
+#: ../vector/v.db.connect/main.c:289 ../vector/v.distance/main.c:441
+#: ../vector/v.distance/main.c:482 ../vector/v.reclass/main.c:144
+#: ../vector/v.colors/scan_attr.c:34 ../vector/v.to.3d/trans3.c:65
+#: ../vector/v.to.3d/trans2.c:63 ../vector/v.vect.stats/main.c:397
+#: ../vector/v.transform/trans_digit.c:101 ../db/drivers/ogr/execute.c:69
+#, c-format
+msgid "Column <%s> not found in table <%s>"
+msgstr ""
+#: ../vector/v.colors.out/make_colors.c:44 ../vector/v.colors/scan_attr.c:37
+#, fuzzy, c-format
+msgid "Column <%s> is not numeric"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:1
+#: ../vector/v.colors.out/make_colors.c:51 ../vector/v.colors/scan_attr.c:44
#, fuzzy
-msgid "Adds missing centroids to closed boundaries."
+msgid "No data selected"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:3
-#: ../vector/v.category/main.c:695
-msgid "centroid"
-msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:5
+#: ../vector/v.what.rast/main.c:76 ../vector/v.db.select/main.c:53
+#: ../vector/v.db.connect/main.c:52 ../vector/v.class/main.c:47
+#: ../vector/v.distance/main.c:90 ../vector/v.what.rast3/main.c:69
+#: ../vector/v.vect.stats/main.c:129 ../vector/v.to.db/main.c:37
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:3
+#: ../locale/scriptstrings/v.db.update_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:3
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:3
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.univar_to_translate.c:4
+#: ../locale/scriptstrings/v.db.join_to_translate.c:3
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:5
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:3
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:3
+#: ../locale/scriptstrings/db.droptable_to_translate.c:3
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:3
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:3
+#: ../locale/scriptstrings/db.univar_to_translate.c:4
+#: ../locale/scriptstrings/db.test_to_translate.c:3 ../db/db.copy/main.c:36
+#: ../db/db.columns/main.c:98 ../db/db.select/main.c:269
+#: ../db/db.describe/main.c:130 ../db/db.connect/main.c:44
+#: ../db/db.createdb/main.c:72 ../db/db.dropdb/main.c:72
+#: ../db/db.databases/main.c:94 ../db/db.tables/main.c:95
+#: ../db/db.execute/main.c:126 ../temporal/t.connect/main.c:35
#, fuzzy
-msgid "Action to be taken"
+msgid "attribute table"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.centroids_to_translate.c:6
-msgid "Category number starting value"
+#: ../vector/v.what.rast/main.c:78
+msgid "Uploads raster values at positions of vector points to the table."
msgstr ""
-#: ../locale/scriptstrings/v.centroids_to_translate.c:7
-#: ../vector/v.category/main.c:134
-msgid "Category increment"
-msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:1
-msgid "Packs up a vector map and support files for copying."
-msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:2
-msgid "vector, export, copying"
-msgstr ""
-#: ../locale/scriptstrings/v.pack_to_translate.c:3
+#: ../vector/v.what.rast/main.c:82 ../vector/v.what.rast3/main.c:75
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:6
#, fuzzy
-msgid "Name of vector map to pack up"
+msgid "Name of vector points map for which to edit attributes"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:1
-msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+#: ../vector/v.what.rast/main.c:92
+msgid "Name of existing raster map to be queried"
msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:4
-msgid "Create a 3D line from 3 column data"
-msgstr ""
-#: ../locale/scriptstrings/v.in.lines_to_translate.c:5
+#: ../vector/v.what.rast/main.c:97 ../vector/v.what.rast3/main.c:86
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:7
#, fuzzy
-msgid "Name of input file (or \"-\" to read from stdin)"
+msgid "Name of attribute column to be updated with the query result"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/i.oif_to_translate.c:1
-msgid "Calculates Optimum-Index-Factor table for spectral bands"
+#: ../vector/v.what.rast/main.c:104
+msgid "Interpolate values from the nearest four cells"
msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:1
-msgid ""
-"Unregisters raster, vector and raster3d maps from the temporal database or a "
-"specific space time dataset."
+#: ../vector/v.what.rast/main.c:109
+msgid "Print categories and values instead of updating the database"
msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:4
-msgid "unregister"
+#: ../vector/v.what.rast/main.c:137 ../vector/v.edit/select.c:502
+#: ../vector/v.surf.bspline/crosscorr.c:114 ../vector/v.to.rast/support.c:127
+#: ../vector/v.to.rast/support.c:286 ../vector/v.to.rast/support.c:439
+#: ../vector/v.generalize/misc.c:160 ../vector/v.univar/main.c:226
+#: ../vector/v.overlay/main.c:388 ../vector/v.buffer/main.c:405
+#: ../vector/v.distance/main.c:457 ../vector/v.extrude/main.c:224
+#: ../vector/v.colors/scan_attr.c:24 ../vector/v.colors/write_rgb.c:20
+#: ../vector/v.colors/read_rgb.c:23 ../vector/v.what.rast3/main.c:119
+#: ../vector/v.vect.stats/main.c:306 ../vector/v.vect.stats/main.c:382
+#: ../display/d.vect.chart/plot.c:37 ../display/d.thematic.area/plot1.c:105
+#: ../display/d.vect/shape.c:45 ../doc/vector/v.example/main.c:105
+#, c-format
+msgid "Database connection not defined for layer %d"
msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:5
-#, fuzzy
-msgid "Input file with map names, one per line"
-msgstr "출력할 래스터맵"
+#: ../vector/v.what.rast/main.c:168 ../vector/v.to.rast/support.c:318
+#: ../vector/v.to.rast/support.c:471 ../vector/v.to.rast/vect2rast.c:68
+#: ../vector/v.what.rast3/main.c:139
+#, c-format
+msgid "Column <%s> not found"
+msgstr ""
-#: ../locale/scriptstrings/t.unregister_to_translate.c:6
-#: ../locale/scriptstrings/t.register_to_translate.c:7
-#, fuzzy
-msgid "input,maps"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.unregister_to_translate.c:7
-#, fuzzy
-msgid "Name(s) of existing raster, vector or raster3d map(s) to unregister"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.correlate_to_translate.c:1
-msgid "Prints a graph of the correlation between raster maps (in pairs)."
+#: ../vector/v.what.rast/main.c:171 ../vector/v.surf.bspline/main.c:389
+#: ../vector/v.surf.bspline/crosscorr.c:133 ../vector/v.univar/main.c:353
+#: ../vector/v.class/main.c:129 ../vector/v.buffer/main.c:426
+#: ../vector/v.sample/main.c:237 ../vector/v.surf.idw/read_sites.c:65
+#: ../vector/v.to.rast3/main.c:98
+msgid "Column type not supported"
msgstr ""
-#: ../locale/scriptstrings/d.correlate_to_translate.c:6
-#, fuzzy
-msgid "correlation"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/g.extension_to_translate.c:1
-msgid "Maintains GRASS Addons extensions in local GRASS installation."
+#: ../vector/v.what.rast/main.c:174
+msgid "Raster type is integer and column type is float"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:2
-msgid ""
-"Downloads, installs extensions from GRASS Addons SVN repository into local "
-"GRASS installation or removes installed extensions."
+#: ../vector/v.what.rast/main.c:177
+msgid "Raster type is float and column type is integer, some data lost!!"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:6
+#: ../vector/v.what.rast/main.c:193 ../vector/v.what.rast3/main.c:156
#, fuzzy
-msgid "Name of extension to install or remove"
+msgid "Reading features from vector map..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/g.extension_to_translate.c:7
-msgid "Name of toolbox (set of extensions) when -t flag is given"
+#: ../vector/v.what.rast/main.c:261
+#, c-format
+msgid "%d points outside current region were skipped"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:9
-msgid "SVN Addons repository URL"
+#: ../vector/v.what.rast/main.c:265
+#, c-format
+msgid "%d points without category were skipped"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:10
-msgid "Prefix where to install extension (ignored when flag -s is given)"
+#: ../vector/v.what.rast/main.c:536 ../vector/v.what.rast/main.c:576
+#, c-format
+msgid "Multiple points (%d) of category %d, value set to 'NULL'"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:11
-msgid "Set the proxy with: \"http=<value>,ftp=<value>\""
-msgstr ""
+#: ../vector/v.what.rast/main.c:589 ../vector/v.vol.rst/user1.c:172
+#: ../vector/v.label/main.c:325 ../vector/v.buffer/main.c:512
+#: ../vector/v.buffer/main.c:613 ../vector/v.sample/main.c:223
+#: ../vector/v.sample/main.c:231 ../vector/v.label.sa/labels.c:165
+#: ../vector/v.what.rast3/main.c:270
+#, fuzzy, c-format
+msgid "No record for category %d in table <%s>"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/g.extension_to_translate.c:12
-msgid "List available extensions in the GRASS Addons SVN repository"
+#: ../vector/v.what.rast/main.c:644
+#, c-format
+msgid "%d categories loaded from vector"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:14
-msgid ""
-"List available extensions in the GRASS Addons SVN repository including "
-"module description"
+#: ../vector/v.what.rast/main.c:646
+#, c-format
+msgid "%d duplicate categories in vector"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:16
-msgid ""
-"List available extensions in the GRASS Addons SVN repository (shell script "
-"style)"
+#: ../vector/v.what.rast/main.c:649
+#, c-format
+msgid "%d categories loaded from table"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:18
-msgid "List locally installed extensions"
+#: ../vector/v.what.rast/main.c:650
+#, c-format
+msgid "%d categories from vector missing in table"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:20
-msgid "Install system-wide (may need system administrator rights)"
+#: ../vector/v.what.rast/main.c:653 ../vector/v.distance/main.c:1600
+#: ../vector/v.vect.stats/main.c:710
+#, c-format
+msgid "%d update errors"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:21
-#: ../locale/scriptstrings/g.extension_to_translate.c:23
-#: ../locale/scriptstrings/g.extension_to_translate.c:25
-msgid "Install"
-msgstr ""
+#: ../vector/v.what.rast/main.c:655 ../vector/v.distance/main.c:1602
+#, fuzzy, c-format
+msgid "%d records updated."
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/g.extension_to_translate.c:22
-msgid "Download source code and exit"
+#: ../vector/v.edit/close.c:56 ../vector/v.edit/snap.c:111
+#, fuzzy, c-format
+msgid "Unable to rewrite line %d"
+msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:57
+#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
+msgid "editing"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:24
-msgid "Don't install new extension, just compile it"
+#: ../vector/v.edit/main.c:58 ../vector/v.to.points/main.c:56
+msgid "node"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:26
-msgid "Force removal when uninstalling extension (operation=remove)"
+#: ../vector/v.edit/main.c:59 ../vector/v.to.points/main.c:57
+msgid "vertex"
msgstr ""
-#: ../locale/scriptstrings/g.extension_to_translate.c:28
-msgid "Operate on toolboxes instead of single modules (experimental)"
+#: ../vector/v.edit/main.c:60
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:1
-#, fuzzy
-msgid "Splits a raster map into red, green and blue maps."
+#: ../vector/v.edit/main.c:69
+#, fuzzy, c-format
+msgid "Unable to get category list <%s>"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.rgb_to_translate.c:3
-msgid "RGB"
+#: ../vector/v.edit/main.c:96 ../vector/v.in.lidar/main.c:483
+#: ../vector/v.in.ogr/main.c:499 ../vector/v.kernel/main.c:227
+#, fuzzy, c-format
+msgid "Vector map <%s> already exists"
+msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:116
+msgid "Supported feature types for non-native formats:"
msgstr ""
-#: ../locale/scriptstrings/r.rgb_to_translate.c:4
-#, fuzzy
-msgid "Prefix for output raster maps (default: input)"
+#: ../vector/v.edit/main.c:137
+#, fuzzy, c-format
+msgid ""
+"Unable to open vector map <%s> on topological level. Try to rebuild vector "
+"topology by v.build."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:1
-#, fuzzy
+#: ../vector/v.edit/main.c:157
+#, fuzzy, c-format
msgid ""
-"Replace gaps in a space time raster dataset with interpolated raster maps."
+"Unable to open vector map <%s> as the background map. It is given as vector "
+"map to be edited."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:6
-#, fuzzy
-msgid "Number of interpolation processes to run in parallel"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast.gapfill_to_translate.c:7
-msgid ""
-"Assign the space time raster dataset start and end time to the output map"
+#: ../vector/v.edit/main.c:168
+#, c-format
+msgid "Background vector map <%s> registered"
msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:1
-msgid ""
-"Exports a raster map to a text file as x,y,z values based on cell centers."
+#: ../vector/v.edit/main.c:204
+msgid "Threshold for snapping must be > 0. No snapping applied."
msgstr ""
-#: ../locale/scriptstrings/r.out.xyz_to_translate.c:4
-msgid "ASCII"
-msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:1
+#: ../vector/v.edit/main.c:211
#, fuzzy
-msgid ""
-"Adds one or more columns to the attribute table connected to a given vector "
-"map."
+msgid "Selecting features..."
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:5
-#, fuzzy
-msgid "Layer number where to add column(s)"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:6
-msgid "Name and type of the new column(s) ('name type [,name type, ...]')"
+#: ../vector/v.edit/main.c:223
+msgid "No features selected, nothing to edit"
msgstr ""
-#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:7
+#: ../vector/v.edit/main.c:231
+#, c-format
msgid ""
-"Data types depend on database backend, but all support VARCHAR(), INT, "
-"DOUBLE PRECISION and DATE"
+"Vector map <%s> is not 3D. Tool '%s' requires 3D vector map. Please convert "
+"the vector map to 3D using e.g. %s."
msgstr ""
-#: ../locale/scriptstrings/t.sample_to_translate.c:1
-#, fuzzy
-msgid ""
-"Samples the input space time dataset(s) with a sample space time dataset and "
-"print the result to stdout."
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:273
+#, fuzzy, c-format
+msgid "%d feature added"
+msgid_plural "%d features added"
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../locale/scriptstrings/t.sample_to_translate.c:4
-#, fuzzy
-msgid "Name of the sample space time dataset"
+#: ../vector/v.edit/main.c:281 ../vector/v.edit/main.c:310
+#: ../vector/v.edit/main.c:321 ../vector/v.edit/main.c:353
+#: ../vector/v.edit/main.c:399
+#, fuzzy, c-format
+msgid "Threshold value for snapping is %.2f"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.sample_to_translate.c:7
-#, fuzzy
-msgid "Type of the sample space time dataset"
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:293
+#, fuzzy, c-format
+msgid "%d boundary closed"
+msgid_plural "%d boundaries closed"
-#: ../locale/scriptstrings/t.sample_to_translate.c:8
-msgid ""
-"Separator character between the output columns, default is tabular \" | \". "
-"Do not use \",\" as this char is reserved to list several map ids in a "
-"sample granule"
-msgstr ""
+#: ../vector/v.edit/main.c:302
+#, fuzzy, c-format
+msgid "%d feature deleted"
+msgid_plural "%d features deleted"
-#: ../locale/scriptstrings/t.sample_to_translate.c:10
-#, fuzzy
-msgid "Check spatial overlap to perform spatio-temporal sampling"
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:313
+#, fuzzy, c-format
+msgid "%d feature moved"
+msgid_plural "%d features moved"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:1
-#, fuzzy
-msgid "Imports GetFeature from a WFS server."
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:324
+#, fuzzy, c-format
+msgid "%d vertex moved"
+msgid_plural "%d vertices moved"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:5
-msgid "Base URL starting with 'http' and ending in '?'"
-msgstr ""
+#: ../vector/v.edit/main.c:330
+#, fuzzy, c-format
+msgid "%d vertex added"
+msgid_plural "%d vertices added"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:6
-msgid "Comma separated names of data layers to download"
-msgstr ""
+#: ../vector/v.edit/main.c:336
+#, fuzzy, c-format
+msgid "%d vertex removed"
+msgid_plural "%d vertices removed"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:7
-msgid "Specify alternate spatial reference system (example: EPSG:4326)"
-msgstr ""
+#: ../vector/v.edit/main.c:348
+#, fuzzy, c-format
+msgid "%d line broken"
+msgid_plural "%d lines broken"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:8
-msgid ""
-"The given code must be supported by the server, consult the capabilities file"
-msgstr ""
+#: ../vector/v.edit/main.c:356
+#, fuzzy, c-format
+msgid "%d line connected"
+msgid_plural "%d lines connected"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:9
-#, fuzzy
-msgid "Maximum number of features to download"
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/main.c:362
+#, fuzzy, c-format
+msgid "%d line merged"
+msgid_plural "%d lines merged"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:10
-msgid "(default: unlimited)"
-msgstr ""
+#: ../vector/v.edit/main.c:371 ../vector/v.edit/main.c:377
+#, fuzzy, c-format
+msgid "%d feature modified"
+msgid_plural "%d features modified"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:11
-msgid "Skip earlier feature IDs and start downloading at this one"
+#: ../vector/v.edit/main.c:384
+#, c-format
+msgid ""
+"Multiple background maps were given. Selected features will be copied only "
+"from vector map <%s>."
msgstr ""
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:12
-msgid "(default: start with the first feature)"
-msgstr ""
+#: ../vector/v.edit/main.c:394
+#, fuzzy, c-format
+msgid "%d feature copied"
+msgid_plural "%d features copied"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:13
-msgid ""
-"Download server capabilities to 'wms_capabilities.xml' in the current "
-"directory and exit"
-msgstr ""
+#: ../vector/v.edit/main.c:405
+#, fuzzy, c-format
+msgid "%d line flipped"
+msgid_plural "%d lines flipped"
-#: ../locale/scriptstrings/v.in.wfs_to_translate.c:14
-msgid "Restrict fetch to features which touch the current region"
-msgstr ""
+#: ../vector/v.edit/main.c:426
+#, fuzzy, c-format
+msgid "%d line labeled"
+msgid_plural "%d lines labeled"
-#: ../locale/scriptstrings/r.grow_to_translate.c:3
-msgid "Radius is in map units rather than cells"
-msgstr ""
+#: ../vector/v.edit/main.c:435
+#, fuzzy, c-format
+msgid "%d feature converted"
+msgid_plural "%d features converted"
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:1
+#: ../vector/v.edit/main.c:440
#, fuzzy
-msgid "Export a space time vector dataset.as GRASS specific archive file"
+msgid "No feature modified"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:4
-#, fuzzy
-msgid "Name of a space time vector dataset archive"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.export_to_translate.c:7
-msgid ""
-"The export format of a single raster map. Supported are GML via v.out.ogr "
-"and the GRASS package format of v.pack."
+#: ../vector/v.edit/main.c:447
+#, c-format
+msgid "Select feature %d is not centroid, ignoring..."
msgstr ""
-#: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:1
-msgid ""
-"Apply temporal and spatial oeprations on space time vector datasets using "
-"temporal vector algebra."
+#: ../vector/v.edit/main.c:454
+#, fuzzy, c-format
+msgid "%d area removed"
+msgid_plural "%d areas removed"
+#: ../vector/v.edit/main.c:460
+msgid "Operation not implemented"
msgstr ""
-#: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:4
+#: ../vector/v.edit/args.c:20
#, fuzzy
-msgid ""
-"vector datasets."
+msgid "Name of vector map to edit"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.mapcalc_to_translate.c:5
+#: ../vector/v.edit/args.c:36
+msgid "Tool"
+msgstr ""
+#: ../vector/v.edit/args.c:58
#, fuzzy
-msgid ""
-"The basename of vector maps that are stored within the result space time "
-"vector dataset."
+msgid "Create new (empty) vector map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.blend_to_translate.c:1
-msgid "Blends color components of two raster maps by a given ratio."
-msgstr ""
-#: ../locale/scriptstrings/r.blend_to_translate.c:4
+#: ../vector/v.edit/args.c:59
#, fuzzy
-msgid "Name of first raster map for blending"
+msgid "Add new features to existing vector map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.blend_to_translate.c:5
+#: ../vector/v.edit/args.c:60
#, fuzzy
-msgid "Name of second raster map for blending"
+msgid "Delete selected features from vector map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.blend_to_translate.c:6
+#: ../vector/v.edit/args.c:61
#, fuzzy
-msgid "Prefix for red, green and blue output raster maps containing"
+msgid "Move selected features in vector map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.blend_to_translate.c:7
+#: ../vector/v.edit/args.c:62
+msgid "Move vertex of selected vector lines"
+msgstr ""
+#: ../vector/v.edit/args.c:63
#, fuzzy
-msgid "Percentage weight of first map for color blending"
+msgid "Remove vertex from selected vector lines"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.blend_to_translate.c:8
-msgid "Combine resulting R,G,B layers into single output map"
+#: ../vector/v.edit/args.c:64
+msgid "Add new vertex to selected vector lines"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:1
+#: ../vector/v.edit/args.c:65
#, fuzzy
-msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgid "Merge selected vector lines"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.register_to_translate.c:4
+#: ../vector/v.edit/args.c:66
#, fuzzy
-msgid "register"
+msgid "Break/split vector lines"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.register_to_translate.c:9
-msgid ""
-"Input file with map names, one per line. Additionally the start time and the "
-"end time can be specified per line"
+#: ../vector/v.edit/args.c:67
+msgid "Select lines and print their ID's"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:11
-msgid ""
-"Valid start date and time of the first map. Format absolute time: \"yyyy-mm-"
-"dd HH:MM:SS +HHMM\", relative time is of type integer)."
+#: ../vector/v.edit/args.c:68
+msgid "Set new categories to selected vector features for defined layer"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:12
-#: ../locale/scriptstrings/t.register_to_translate.c:14
-#: ../locale/scriptstrings/t.register_to_translate.c:16
-#: ../locale/scriptstrings/t.register_to_translate.c:18
-#: ../locale/scriptstrings/t.register_to_translate.c:22
-msgid "Time & Date"
+#: ../vector/v.edit/args.c:70
+msgid "Delete categories from selected vector features for defined layer"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:13
-msgid ""
-"Valid end date and time of all map. Format absolute time: \"yyyy-mm-dd HH:MM:"
-"SS +HHMM\", relative time is of type integer)."
-msgstr ""
+#: ../vector/v.edit/args.c:72
+#, fuzzy
+msgid "Copy selected features"
+msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.register_to_translate.c:15
-msgid "Unit must be set in case of relative time stamps"
+#: ../vector/v.edit/args.c:73
+msgid "Snap vector features in given threshold"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:17
-msgid ""
-"Time increment between maps for valid time interval creation (format "
-"absolute: NNN seconds, minutes, hours, days, weeks, months, years; format "
-"relative is integer: 5)"
+#: ../vector/v.edit/args.c:74
+msgid "Flip direction of selected vector lines"
msgstr ""
-#: ../locale/scriptstrings/t.register_to_translate.c:19
+#: ../vector/v.edit/args.c:75
#, fuzzy
-msgid "Field separator character of the input file"
+msgid "Connect two lines"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.register_to_translate.c:21
-msgid ""
-"Create an interval (start and end time) in case an increment is provided"
+#: ../vector/v.edit/args.c:76
+msgid "Z bulk-labeling (automated assignment of z coordinate to vector lines)"
msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:1
-msgid "Saves the contents of the active display monitor to a graphics file."
+#: ../vector/v.edit/args.c:78
+msgid "Change feature type (point<->centroid, line<->boundary)"
msgstr ""
-#: ../locale/scriptstrings/d.out.file_to_translate.c:6
-#, fuzzy
-msgid "Width and height of output image"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.out.file_to_translate.c:7
-msgid "Images"
+#: ../vector/v.edit/args.c:79
+msgid "Delete selected areas from vector map (based on selected centroids)"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:1
+#: ../vector/v.edit/args.c:87
#, fuzzy
-msgid "Modifies the metadata of a space time dataset."
+msgid "Name of file containing data in GRASS ASCII vector format"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.support_to_translate.c:7
+#: ../vector/v.edit/args.c:89
#, fuzzy
-msgid "Title of the space time dataset"
+msgid "\"-\" reads from standard input"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.support_to_translate.c:8
-#, fuzzy
-msgid "Description of the space time dataset"
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/args.c:99
+msgid "Difference in x,y,z direction for moving feature or vertex"
+msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:9
-msgid ""
-"Update the metadata information and spatial extent of registered maps from "
-"the grass spatial database. Check for removed maps and delete them from the "
-"temporal database and all effected space time datasets."
+#: ../vector/v.edit/args.c:106
+msgid "Threshold distance (coords,snap,query)"
msgstr ""
-#: ../locale/scriptstrings/t.support_to_translate.c:10
-msgid ""
-"Update metadata information, temporal and spatial extent from registered maps"
+#: ../vector/v.edit/args.c:108
+msgid "'-1' for threshold based on the current resolution settings"
msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:1
-#, fuzzy
-msgid "Removes space time datasets from temporal database."
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/args.c:124
+msgid "List of point coordinates"
+msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:6
-msgid "Type of the space time dataset, default is strds"
+#: ../vector/v.edit/args.c:133
+msgid "Bounding box for selecting features"
msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:9
-#, fuzzy
-msgid "Input file with dataset names, one per line"
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/args.c:142
+msgid "Polygon for selecting features"
+msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:11
-#, fuzzy
-msgid "Remove all registered maps from the temporal and spatial database"
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/args.c:152
+msgid "Query tool"
+msgstr ""
-#: ../locale/scriptstrings/t.remove_to_translate.c:12
-msgid "Force recursive removing"
+#: ../vector/v.edit/args.c:154
+msgid "For 'shorter' use negative threshold value, positive value for 'longer'"
msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:1
-#, fuzzy
-msgid ""
-"Reconnects attribute tables for all vector maps from the current mapset to a "
-"new database."
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/args.c:160
+msgid "Select only lines or boundaries shorter/longer than threshold distance"
+msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:5
-msgid "Copy attribute tables to the target database if not exist"
+#: ../vector/v.edit/args.c:162
+msgid "Select dangles shorter/longer than threshold distance"
msgstr ""
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:6
+#: ../vector/v.edit/args.c:169
#, fuzzy
-msgid "Delete attribute tables from the source database"
+msgid "Name of background vector map(s)"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:7
-#, fuzzy
-msgid "Name of source database"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:8
-#, fuzzy
-msgid "Name of source database schema"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:9
-#, fuzzy
-msgid "Name for target driver"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:10
-#, fuzzy
-msgid "Name for target database"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:11
-#, fuzzy
-msgid "Name for target database schema"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.plane_to_translate.c:1
-#, fuzzy
+#: ../vector/v.edit/args.c:176
msgid ""
-"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
-"point."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/r.plane_to_translate.c:4
-msgid "Dip of plane in degrees"
+"Snap added or modified features in the given threshold to the nearest "
+"existing feature"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:5
-msgid "Azimuth of the plane in degrees"
+#: ../vector/v.edit/args.c:182
+msgid "Not apply snapping"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:6
-msgid "Easting coordinate of a point on the plane"
+#: ../vector/v.edit/args.c:183
+msgid "Snap only to node"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:7
-msgid "Northing coordinate of a point on the plane"
+#: ../vector/v.edit/args.c:184
+msgid "Allow snapping also to vertex"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:8
-msgid "Elevation coordinate of a point on the plane"
+#: ../vector/v.edit/args.c:192
+msgid "Starting value and step for z bulk-labeling"
msgstr ""
-#: ../locale/scriptstrings/r.plane_to_translate.c:9
-#, fuzzy
-msgid "Type of raster map to be created"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:1
-msgid ""
-"Observes specific locations in a space time raster dataset over a period of "
-"time using vector points."
+#: ../vector/v.edit/args.c:193
+msgid "Pair: value,step (e.g. 1100,10)"
msgstr ""
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:4
-#, fuzzy
-msgid ""
-"Name of the new created vector map that stores the sampled values in "
-"different layers"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.vect.observe.strds_to_translate.c:5
-msgid ""
-"Names of the vector columns to be created and to store sampled raster "
-"values, one name for each STRDS"
+#: ../vector/v.edit/args.c:198 ../vector/v.select/args.c:103
+#: ../vector/v.extract/main.c:94
+msgid "Reverse selection"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:1
-#, fuzzy
-msgid "Edits cell values in a raster map."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:3
-#: ../vector/v.edit/main.c:57
-msgid "editing"
+#: ../vector/v.edit/args.c:204
+msgid "Close added boundaries (using threshold distance)"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:6
-msgid "Width of display canvas"
+#: ../vector/v.edit/args.c:208
+msgid "Do not expect header of input data"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:7
-msgid "Height of display canvas"
+#: ../vector/v.edit/args.c:216
+msgid "Modify only first found feature in bounding box"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:8
-msgid "Minimum size of each cell"
+#: ../vector/v.edit/args.c:228
+msgid "Polygon must have at least 3 coordinate pairs"
msgstr ""
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:9
-#, fuzzy
-msgid "Maximum number of rows to load"
+#: ../vector/v.edit/args.c:292
+#, fuzzy, c-format
+msgid "Operation '%s' not implemented"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/d.rast.edit_to_translate.c:10
-#, fuzzy
-msgid "Maximum number of columns to load"
+#: ../vector/v.edit/args.c:301
+#, fuzzy, c-format
+msgid "At least one option from %s must be specified"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.univar_to_translate.c:1
-msgid ""
-"Calculates univariate statistics from the non-null cells for each registered "
-"raster3d map of a space time raster3d dataset."
+#: ../vector/v.edit/args.c:307 ../vector/v.edit/args.c:316
+#: ../vector/v.edit/args.c:323 ../vector/v.edit/args.c:330
+#: ../vector/v.edit/args.c:334
+#, c-format
+msgid "Tool %s requires option %s"
msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:1
-msgid "Unpacks a raster map packed with r.pack."
+#: ../vector/v.edit/select.c:73
+#, c-format
+msgid "Threshold value for coordinates is %.2f"
msgstr ""
-#: ../locale/scriptstrings/r.unpack_to_translate.c:6
-#, fuzzy
-msgid "Name for output raster map (default: taken from input file internals)"
+#: ../vector/v.edit/select.c:160
+#, fuzzy, c-format
+msgid "Threshold value for querying is %.2f"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:1
-#, fuzzy
-msgid "Lists registered maps of a space time raster3d dataset."
-msgstr "출력할 래스터맵"
+#: ../vector/v.edit/select.c:176
+#, fuzzy, c-format
+msgid "%d of %d feature selected from vector map <%s>"
+msgid_plural "%d of %d features selected from vector map <%s>"
-#: ../locale/scriptstrings/t.rast3d.list_to_translate.c:9
-msgid ""
-"Separator character between the output columns, default is tabular \"\t\""
+#: ../vector/v.edit/select.c:496
+msgid "Layer must be > 0 for 'where'"
msgstr ""
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:1
-#, fuzzy
+#: ../vector/v.surf.bspline/main.c:96
msgid ""
-"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
-msgstr "출력할 래스터맵"
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:4
-msgid "GPS"
+#: ../vector/v.surf.bspline/main.c:105 ../vector/v.lidar.correction/main.c:75
+#: ../vector/v.outlier/main.c:75 ../vector/v.lidar.edgedetection/main.c:80
+msgid "Estimate point density and distance"
msgstr ""
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:5
-#, fuzzy
-msgid "Export as waypoints"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:6
-#, fuzzy
-msgid "Export as routes"
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:7
-msgid "Export as tracks"
+#: ../vector/v.surf.bspline/main.c:107 ../vector/v.lidar.correction/main.c:77
+#: ../vector/v.outlier/main.c:77 ../vector/v.lidar.edgedetection/main.c:82
+msgid ""
+"Estimate point density and distance for the input vector points within the "
+"current region extends and quit"
msgstr ""
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:8
+#: ../vector/v.surf.bspline/main.c:110 ../vector/v.voronoi/main.c:130
+#: ../vector/v.sample/main.c:82
#, fuzzy
-msgid "Name for output file or GPS device"
+msgid "Name of input vector point map"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:9
+#: ../vector/v.surf.bspline/main.c:118
#, fuzzy
-msgid "GPSBabel supported output format"
+msgid "Name of input vector map with sparse points"
msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:10
-#: ../locale/scriptstrings/v.out.gps_to_translate.c:11
-#: ../display/d.legend/main.c:142 ../display/d.legend/main.c:151
-msgid "Subset"
+#: ../vector/v.surf.bspline/main.c:129
+msgid "Raster map to use for masking (applies to raster output only)"
msgstr ""
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:1
-#, fuzzy
-msgid ""
-"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
-"datasets."
-msgstr "출력할 래스터맵"
-#: ../locale/scriptstrings/t.rast3d.mapcalc_to_translate.c:4
-msgid "r3.mapcalc expression applied to each time step of the sampled data"
+#: ../vector/v.surf.bspline/main.c:139
+msgid "Length of each spline step in the east-west direction"
msgstr ""
-#: ../display/d.path/main.c:49 ../vector/v.net.connectivity/main.c:53
-#: ../vector/v.net.bridge/main.c:48 ../vector/v.net.distance/main.c:65
-#: ../vector/v.net/main.c:46 ../vector/v.net.salesman/main.c:127
-#: ../vector/v.net.path/main.c:41 ../vector/v.net.allpairs/main.c:62
-#: ../vector/v.net.visibility/main.c:46 ../vector/v.net.flow/main.c:59
-#: ../vector/v.net.alloc/main.c:61 ../vector/v.net.spanningtree/main.c:47
-#: ../vector/v.net.steiner/main.c:346 ../vector/v.net.iso/main.c:73
-#: ../vector/v.net.timetable/main.c:261 ../vector/v.net.components/main.c:72
-#: ../vector/v.net.centrality/main.c:97
-msgid "network"
+#: ../vector/v.surf.bspline/main.c:148
+msgid "Length of each spline step in the north-south direction"
msgstr ""
-#: ../display/d.path/main.c:50 ../vector/v.net.distance/main.c:66
-#: ../vector/v.net.path/main.c:42 ../vector/v.net.allpairs/main.c:63
-#: ../vector/v.net.visibility/main.c:47 ../vector/v.net.timetable/main.c:262
-msgid "shortest path"
+#: ../vector/v.surf.bspline/main.c:174 ../vector/v.surf.rst/main.c:179
+msgid "Name of the attribute column with values to be used for approximation"
msgstr ""
-#: ../display/d.path/main.c:52
-msgid "Finds shortest path for selected starting and ending node."
+#: ../vector/v.surf.bspline/main.c:175
+msgid "If not given and input is 3D vector map then z-coordinates are used."
msgstr ""
-#: ../display/d.path/main.c:59 ../vector/v.net.distance/main.c:86
-#: ../vector/v.net.salesman/main.c:141 ../vector/v.net.path/main.c:51
-#: ../vector/v.net.alloc/main.c:76 ../vector/v.net.steiner/main.c:361
-#: ../vector/v.net.iso/main.c:86
-msgid "Arc type"
+#: ../vector/v.surf.bspline/main.c:191
+msgid "Maximum memory to be used for raster output (in MB)"
msgstr ""
-#: ../display/d.path/main.c:66 ../display/d.rhumbline/main.c:53
-#: ../display/d.geodesic/main.c:55
-msgid "Starting and ending coordinates"
+#: ../vector/v.surf.bspline/main.c:203
+msgid "Choose either vector or raster output, not both"
msgstr ""
-#: ../display/d.path/main.c:71 ../vector/v.net.connectivity/main.c:64
-#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.distance/main.c:80
-#: ../vector/v.net/args.c:55 ../vector/v.net.salesman/main.c:145
-#: ../vector/v.net.path/main.c:56 ../vector/v.net.allpairs/main.c:74
-#: ../vector/v.net.flow/main.c:70 ../vector/v.net.alloc/main.c:81
-#: ../vector/v.net.spanningtree/main.c:59 ../vector/v.net.steiner/main.c:366
-#: ../vector/v.net.iso/main.c:90 ../vector/v.net.timetable/main.c:274
-#: ../vector/v.net.components/main.c:83 ../vector/v.net.centrality/main.c:109
-msgid "Arc layer"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:206
+#, fuzzy
+msgid "No raster or vector or cross-validation output"
+msgstr "출력할 래스터맵"
-#: ../display/d.path/main.c:76 ../vector/v.net.connectivity/main.c:70
-#: ../vector/v.net.bridge/main.c:66 ../vector/v.net.distance/main.c:92
-#: ../vector/v.net/args.c:62 ../vector/v.net.path/main.c:61
-#: ../vector/v.net.allpairs/main.c:80 ../vector/v.net.flow/main.c:76
-#: ../vector/v.net.alloc/main.c:86 ../vector/v.net.spanningtree/main.c:65
-#: ../vector/v.net.iso/main.c:95 ../vector/v.net.timetable/main.c:280
-#: ../vector/v.net.components/main.c:89 ../vector/v.net.centrality/main.c:115
-msgid "Node layer"
+#: ../vector/v.surf.bspline/main.c:221
+msgid "No default DB driver defined"
msgstr ""
-#: ../display/d.path/main.c:82 ../vector/v.net.path/main.c:74
-msgid "Arc forward/both direction(s) cost column"
+#: ../vector/v.surf.bspline/main.c:224
+msgid "No default DB defined"
msgstr ""
-#: ../display/d.path/main.c:88 ../vector/v.net.path/main.c:80
-msgid "Arc backward direction cost column"
+#: ../vector/v.surf.bspline/main.c:240 ../vector/v.surf.bspline/main.c:406
+#: ../vector/v.lidar.correction/main.c:165
+#: ../vector/v.lidar.correction/main.c:225
+#: ../vector/v.lidar.growing/main.c:163 ../vector/v.outlier/main.c:183
+#: ../vector/v.outlier/main.c:249 ../vector/v.lidar.edgedetection/main.c:189
+#: ../vector/v.lidar.edgedetection/main.c:201
+#: ../vector/v.lidar.edgedetection/main.c:251
+#, c-format
+msgid "No database connection for driver <%s> is defined. Run db.connect."
msgstr ""
-#: ../display/d.path/main.c:94 ../vector/v.net.path/main.c:86
-msgid "Node cost column"
+#: ../vector/v.surf.bspline/main.c:243
+msgid "Old auxiliary table could not be dropped"
msgstr ""
-#: ../display/d.path/main.c:100 ../display/d.extract/main.c:65
-msgid "Original line color"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:253 ../vector/v.surf.bspline/main.c:321
+#: ../vector/v.outlier/main.c:193
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s> at the topological level"
+msgstr "출력할 래스터맵"
-#: ../display/d.path/main.c:102 ../display/d.path/main.c:110
-#: ../display/d.path/main.c:118 ../display/d.path/main.c:128
-msgid "Rendering"
+#: ../vector/v.surf.bspline/main.c:263 ../vector/v.surf.rst/main.c:542
+msgid ""
+"Input is 3D: using attribute values instead of z-coordinates for "
+"approximation"
msgstr ""
-#: ../display/d.path/main.c:108 ../display/d.extract/main.c:71
-msgid "Highlight color"
+#: ../vector/v.surf.bspline/main.c:265 ../vector/v.surf.rst/main.c:544
+msgid "Input is 3D: using z-coordinates for approximation"
msgstr ""
-#: ../display/d.path/main.c:123 ../vector/v.net.distance/main.c:156
-#: ../vector/v.net.salesman/main.c:180 ../vector/v.net.path/main.c:103
-#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.alloc/main.c:118
-#: ../vector/v.net.spanningtree/main.c:84 ../vector/v.net.steiner/main.c:396
-#: ../vector/v.net.iso/main.c:128 ../vector/v.net.centrality/main.c:188
-msgid "Use geodesic calculation for longitude-latitude locations"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:269
+#, fuzzy, c-format
+msgid "Input vector map is 2D. Parameter <%s> required."
+msgstr "출력할 래스터맵"
-#: ../display/d.path/main.c:127
-msgid "Render bold lines"
+#: ../vector/v.surf.bspline/main.c:280
+#, c-format
+msgid "Estimated point density: %.4g"
msgstr ""
-#: ../display/d.path/main.c:141 ../display/d.rhumbline/main.c:80
-#: ../display/d.geodesic/main.c:80
-msgid "No coordinates given"
+#: ../vector/v.surf.bspline/main.c:281
+#, c-format
+msgid "Estimated mean distance between points: %.4g"
msgstr ""
-#: ../display/d.path/main.c:144 ../display/d.path/main.c:148
+#: ../vector/v.surf.bspline/main.c:284
+#, fuzzy, c-format
+msgid "No points in current region"
+msgstr "출력할 래스터맵"
+#: ../vector/v.surf.bspline/main.c:304
#, c-format
-msgid "%s - illegal x value"
+msgid "Cross validation finished for sie = %f and sin = %f"
msgstr ""
-#: ../display/d.path/main.c:146 ../display/d.path/main.c:150
+#: ../vector/v.surf.bspline/main.c:313
+#, fuzzy, c-format
+msgid "Vector map <%s> of sparse points will be interpolated"
+msgstr "출력할 래스터맵"
+#: ../vector/v.surf.bspline/main.c:329
#, c-format
-msgid "%s - illegal y value"
+msgid ""
+"Sorry, the <%s> driver is not compatible with the vector output of this "
+"module. Try with raster output or another driver."
msgstr ""
-#: ../display/d.path/main.c:154 ../display/d.graph/main.c:98
-#: ../display/d.rhumbline/main.c:96 ../display/d.legend/main.c:294
-#: ../display/d.labels/main.c:117 ../display/d.rgb/main.c:82
-#: ../display/d.grid/main.c:253 ../display/d.linegraph/main.c:268
-#: ../display/d.thematic.area/main.c:371 ../display/d.erase/main.c:45
-#: ../display/d.vect/main.c:323 ../display/d.geodesic/main.c:96
-#: ../display/d.where/main.c:170 ../display/d.fontlist/main.c:54
-#: ../display/d.text/main.c:286 ../display/d.colortable/main.c:141
-#: ../display/d.info/main.c:70 ../display/d.northarrow/main.c:130
-#: ../display/d.profile/main.c:263 ../display/d.rast.arrow/main.c:224
-#: ../display/d.barscale/main.c:221 ../display/d.histogram/main.c:190
-#: ../display/d.rast.num/main.c:190 ../display/d.font/main.c:85
-#: ../display/d.mon/main.c:200 ../display/d.his/main.c:119
-#: ../display/d.vect.chart/main.c:253 ../display/d.rast/main.c:97
-msgid "No graphics device selected. Use d.mon to select graphics device."
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:352
+#, fuzzy, c-format
+msgid "Points in input vector map <%s> will be interpolated"
+msgstr "출력할 래스터맵"
-#: ../display/d.path/main.c:181 ../vector/v.net.distance/main.c:189
-#: ../vector/v.net.path/main.c:121 ../vector/v.net.allpairs/main.c:142
-#: ../vector/v.net.spanningtree/main.c:113
-#: ../vector/v.net.centrality/main.c:222
-msgid "The current projection is not longitude-latitude"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:363
+#, fuzzy, c-format
+msgid "Cells for raster map <%s> will be interpolated"
+msgstr "출력할 래스터맵"
-#: ../display/d.path/select.c:84 ../display/d.path/select.c:101
-#, c-format
-msgid "Node %d: %f %f\n"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:369
+#, fuzzy
+msgid "Reading values from attribute table..."
+msgstr "출력할 래스터맵"
-#: ../display/d.path/select.c:122
-#, c-format
-msgid "Destination unreachable\n"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:373
+#, fuzzy
+msgid "Cannot read layer info"
+msgstr "출력할 래스터맵"
-#: ../display/d.path/select.c:125
-#, c-format
-msgid "Costs on the network = %f\n"
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:392 ../vector/v.univar/main.c:356
+#: ../vector/v.class/main.c:132 ../vector/v.normal/main.c:135
+#: ../vector/v.sample/main.c:151 ../vector/v.surf.idw/read_sites.c:68
+#: ../vector/v.to.rast3/main.c:94 ../ps/ps.map/catval.c:66
+#: ../ps/ps.map/catval.c:131 ../ps/ps.map/catval.c:198
+#, fuzzy
+msgid "Unable to select data from table"
+msgstr "출력할 래스터맵"
-#: ../display/d.path/select.c:126
+#: ../vector/v.surf.bspline/main.c:394 ../vector/v.normal/main.c:136
#, c-format
-msgid ""
-" Distance to the network = %f, distance from the network = %f\n"
-"\n"
+msgid "%d records selected from table"
msgstr ""
-#: ../display/d.graph/do_graph.c:65 ../display/d.graph/do_graph.c:81
+#: ../vector/v.surf.bspline/main.c:413
#, c-format
-msgid "Problem parsing coordinates [%s]"
+msgid "Interpolation: Creating table: It was impossible to create table <%s>."
msgstr ""
-#: ../display/d.graph/do_graph.c:98
-msgid "Unable to read color"
+#: ../vector/v.surf.bspline/main.c:481
+msgid "Load masking map"
msgstr ""
-#: ../display/d.graph/do_graph.c:129 ../display/d.graph/do_graph.c:195
-#: ../display/d.graph/do_graph.c:216 ../display/d.graph/do_graph.c:267
-#: ../display/d.graph/do_graph.c:334 ../display/d.graph/graphics.c:60
+#: ../vector/v.surf.bspline/main.c:538
#, c-format
-msgid "Problem parsing command [%s]"
+msgid "Adjusted EW splines %d"
msgstr ""
-#: ../display/d.graph/do_graph.c:377 ../imagery/i.vpoints/plot.c:56
-#: ../imagery/i.vpoints/plot.c:126
-msgid "Cannot read symbol, cannot display points"
+#: ../vector/v.surf.bspline/main.c:539
+#, c-format
+msgid "Adjusted NS splines %d"
msgstr ""
-#: ../display/d.graph/main.c:61
-msgid ""
-"Program for generating and displaying simple graphics on the display monitor."
-msgstr ""
+#: ../vector/v.surf.bspline/main.c:610
+#, fuzzy, c-format
+msgid "Processing subregion %d of %d..."
+msgstr "출력할 래스터맵"
-#: ../display/d.graph/main.c:66
-msgid ""
-"Name of file containing graphics commands, if not given reads from standard "
-"input"
+#: ../vector/v.surf.bspline/main.c:694
+#, fuzzy, c-format
+msgid "%d points found in this subregion"
+msgstr "출력할 래스터맵"
+#: ../vector/v.surf.bspline/main.c:741
+#, c-format
+msgid "Interpolation: (%d,%d): No record for point (cat = %d)"
msgstr ""
-#: ../display/d.graph/main.c:73
-msgid "Color to draw with, either a standard GRASS color or R:G:B triplet"
+#: ../vector/v.surf.bspline/main.c:877
+msgid "No data within this subregion. Consider increasing spline step values."
msgstr ""
-#: ../display/d.graph/main.c:80
-msgid "Coordinates are given in map units"
+#: ../vector/v.surf.bspline/main.c:930
+msgid "Auxiliary table could not be dropped"
msgstr ""
-#: ../display/d.graph/main.c:91
+#: ../vector/v.surf.bspline/crosscorr.c:75
#, c-format
-msgid "Graph file <%s> not found"
+msgid "%d are too many points. The cross validation would take too much time."
msgstr ""
-#: ../display/d.rhumbline/main.c:46
-msgid "Displays the rhumbline joining two longitude/latitude coordinates."
-msgstr ""
+#: ../vector/v.surf.bspline/crosscorr.c:84
+#, fuzzy, c-format
+msgid "%d points read in region"
+msgstr "출력할 래스터맵"
-#: ../display/d.rhumbline/main.c:59 ../display/d.geodesic/main.c:61
-#: ../display/d.northarrow/main.c:65
-msgid "Line color"
+#: ../vector/v.surf.bspline/crosscorr.c:88
+msgid ""
+"Maybe, it takes too long. It will depend on how many points you are "
+"considering."
msgstr ""
-#: ../display/d.rhumbline/main.c:68 ../display/d.legend/main.c:95
-#: ../display/d.grid/main.c:102 ../vector/v.label/main.c:151
-#: ../vector/v.label.sa/main.c:98 ../vector/v.lrs/v.lrs.label/main.c:194
-msgid "Text color"
+#: ../vector/v.surf.bspline/crosscorr.c:119
+#, c-format
+msgid "CrossCorrelation: driver=%s db=%s"
msgstr ""
-#: ../display/d.rhumbline/main.c:76 ../display/d.geodesic/main.c:77
+#: ../vector/v.surf.bspline/crosscorr.c:136
#, fuzzy, c-format
-msgid "Location is not %s"
+msgid "No records selected from table <%s> "
msgstr "출력할 래스터맵"
-#: ../display/d.rhumbline/main.c:83 ../display/d.rhumbline/main.c:86
-#: ../display/d.rhumbline/main.c:89 ../display/d.rhumbline/main.c:92
-#: ../display/d.geodesic/main.c:83 ../display/d.geodesic/main.c:86
-#: ../display/d.geodesic/main.c:89 ../display/d.geodesic/main.c:92
-#, fuzzy, c-format
-msgid "%s - illegal longitude"
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.bspline/crosscorr.c:169
+#, c-format
+msgid "Beginning cross validation with lambda_i=%.4f ... (%d of %d)"
+msgstr ""
-#: ../display/d.legend/main.c:88
-msgid ""
-"Displays a legend for a raster map in the active frame of the graphics "
-"monitor."
+#: ../vector/v.surf.bspline/crosscorr.c:220
+#: ../vector/v.surf.idw/read_sites.c:107
+#, c-format
+msgid "No record for point (cat = %d)"
msgstr ""
-#: ../display/d.legend/main.c:92 ../display/d.zoom/main.c:76
-msgid "Name of raster map"
+#: ../vector/v.surf.bspline/crosscorr.c:296
+#, c-format
+msgid "Root Mean Square (RMS) = %.5lf"
msgstr ""
-#: ../display/d.legend/main.c:96 ../display/d.legend/main.c:158
-#: ../display/d.legend/main.c:168 ../display/d.legend/main.c:175
-#: ../display/d.legend/main.c:183 ../display/d.legend/main.c:213
+#: ../vector/v.surf.bspline/crosscorr.c:323
#, fuzzy
-msgid "Font settings"
+msgid "Table of results:"
msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:104
-msgid "Number of text lines (useful for truncating long legends)"
+#: ../vector/v.surf.bspline/crosscorr.c:324
+#, c-format
+msgid " lambda | mean | rms |\n"
msgstr ""
-#: ../display/d.legend/main.c:113
-msgid "Thinning factor (thin=10 gives cats 0,10,20...)"
+#: ../vector/v.in.db/main.c:54 ../vector/v.db.select/main.c:54
+#: ../vector/v.db.connect/main.c:53 ../vector/v.distance/main.c:89
+#: ../vector/v.vect.stats/main.c:130 ../vector/v.to.db/main.c:38
+#: ../locale/scriptstrings/t.vect.db.select_to_translate.c:5
+#: ../locale/scriptstrings/v.db.update_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addcolumn_to_translate.c:4
+#: ../locale/scriptstrings/db.dropcolumn_to_translate.c:2
+#: ../locale/scriptstrings/v.db.droptable_to_translate.c:4
+#: ../locale/scriptstrings/db.out.ogr_to_translate.c:2
+#: ../locale/scriptstrings/v.db.dropcolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.join_to_translate.c:4
+#: ../locale/scriptstrings/v.what.vect_to_translate.c:4
+#: ../locale/scriptstrings/v.db.renamecolumn_to_translate.c:4
+#: ../locale/scriptstrings/v.db.addtable_to_translate.c:4
+#: ../locale/scriptstrings/v.db.droprow_to_translate.c:4
+#: ../locale/scriptstrings/db.droptable_to_translate.c:2
+#: ../locale/scriptstrings/v.db.reconnect.all_to_translate.c:4
+#: ../locale/scriptstrings/db.in.ogr_to_translate.c:2
+#: ../locale/scriptstrings/db.univar_to_translate.c:2
+#: ../locale/scriptstrings/db.test_to_translate.c:2 ../db/db.copy/main.c:35
+#: ../db/db.columns/main.c:97 ../db/db.select/main.c:268
+#: ../db/db.drivers/main.c:71 ../db/db.login/main.c:39
+#: ../db/db.describe/main.c:129 ../db/db.connect/main.c:43
+#: ../db/db.createdb/main.c:71 ../db/db.dropdb/main.c:71
+#: ../db/db.databases/main.c:93 ../db/db.tables/main.c:94
+#: ../db/db.execute/main.c:125 ../temporal/t.connect/main.c:34
+msgid "database"
msgstr ""
-#: ../display/d.legend/main.c:121
-msgid "Number of text labels for smooth gradient legend"
-msgstr ""
-#: ../display/d.legend/main.c:122 ../display/d.legend/main.c:203
+#: ../vector/v.in.db/main.c:55 ../vector/v.normal/main.c:76
+#: ../vector/v.kcv/main.c:64
#, fuzzy
-msgid "Gradient"
+msgid "points"
msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:131
+#: ../vector/v.in.db/main.c:57
msgid ""
-"Size and placement as percentage of screen coordinates (0,0 is lower left)"
+"Creates new vector (points) map from database table containing coordinates."
msgstr ""
-#: ../display/d.legend/main.c:140
-msgid "List of discrete category numbers/values for legend"
+#: ../vector/v.in.db/main.c:61
+msgid "Input table name"
msgstr ""
-#: ../display/d.legend/main.c:150
-msgid "Use a subset of the map range for the legend (min,max)"
-msgstr ""
+#: ../vector/v.in.db/main.c:66 ../vector/v.in.db/main.c:70
+#, fuzzy
+msgid "Input DB"
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:157 ../display/d.vect/main.c:256
-#: ../display/d.text/main.c:218 ../vector/v.label/main.c:122
-msgid "Font name"
+#: ../vector/v.in.db/main.c:75
+msgid "Name of column containing x coordinate"
msgstr ""
-#: ../display/d.legend/main.c:167
-msgid "Font scaling factor for floating point legends"
+#: ../vector/v.in.db/main.c:80
+msgid "Name of column containing y coordinate"
msgstr ""
-#: ../display/d.legend/main.c:173 ../display/d.text/main.c:223
-msgid "Path to font file"
+#: ../vector/v.in.db/main.c:84
+msgid "Name of column containing z coordinate"
msgstr ""
-#: ../display/d.legend/main.c:182 ../display/d.text/main.c:231
-msgid "Text encoding (only applicable to TrueType fonts)"
+#: ../vector/v.in.db/main.c:85 ../vector/v.random/main.c:147
+#: ../vector/v.random/main.c:156 ../vector/v.random/main.c:169
+#: ../vector/v.random/main.c:179 ../vector/v.random/main.c:184
+msgid "3D output"
msgstr ""
-#: ../display/d.legend/main.c:187
-msgid "Do not show category labels"
+#: ../vector/v.in.db/main.c:90
+msgid "Name of column containing category number"
msgstr ""
-#: ../display/d.legend/main.c:192
-msgid "Do not show category numbers"
+#: ../vector/v.in.db/main.c:91
+msgid "Must refer to an integer column"
msgstr ""
-#: ../display/d.legend/main.c:197
-msgid "Skip categories with no label"
-msgstr ""
+#: ../vector/v.in.db/main.c:101
+#, fuzzy
+msgid "Use imported table as attribute table for new map"
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:212 ../display/d.text/main.c:255
-msgid "Font size is height in pixels"
+#: ../vector/v.in.db/main.c:141
+#, c-format
+msgid ""
+"Vector map <%s> cannot be overwritten because input table <%s> is linked to "
+"this map."
msgstr ""
-#: ../display/d.legend/main.c:289 ../display/d.histogram/main.c:177
-#: ../ps/ps.map/ps_clrtbl.c:39
+#: ../vector/v.in.db/main.c:177
#, c-format
-msgid "Category file for <%s> not available"
+msgid ""
+"Output vector map, table <%s> (driver: <%s>, database: <%s>) already exists"
msgstr ""
-#: ../display/d.legend/main.c:348
-msgid "Legend box lies outside of frame. Text may not display properly."
+#: ../vector/v.in.db/main.c:190 ../vector/v.db.connect/main.c:295
+msgid "Data type of key column must be integer"
msgstr ""
-#: ../display/d.legend/main.c:352
-msgid "Drawing horizontal legend as box width exceeds height"
-msgstr ""
+#: ../vector/v.in.db/main.c:194
+#, fuzzy, c-format
+msgid "Option <%s> must be specified when -%c flag is given"
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:363
+#: ../vector/v.in.db/main.c:199
#, c-format
-msgid "Range information for <%s> not available (run r.support)"
+msgid ""
+"Unable to define key column. This operation is not supported by <%s> driver. "
+"You need to define <%s> option."
msgstr ""
-#: ../display/d.legend/main.c:368
+#: ../vector/v.in.db/main.c:225 ../display/d.vect.chart/plot.c:84
+#: ../display/d.vect/attr.c:110
+#, fuzzy, c-format
+msgid "Unable to open select cursor: '%s'"
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.db/main.c:235 ../vector/v.voronoi/main.c:321
#, fuzzy
-msgid "Input map contains no data"
+msgid "Writing features..."
msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:381
-msgid "Requested range exceeds lower limit of actual data"
+#: ../vector/v.in.db/main.c:243
+msgid "Key column must be integer"
msgstr ""
-#: ../display/d.legend/main.c:387
-msgid "Requested range exceeds upper limit of actual data"
+#: ../vector/v.in.db/main.c:256
+msgid "x/y/z column must be integer or double"
msgstr ""
-#: ../display/d.legend/main.c:446
-#, c-format
-msgid "use=%s out of range [%d,%d] (extend with range= ?)"
-msgstr ""
+#: ../vector/v.in.db/main.c:282 ../vector/v.net/main.c:150
+#: ../vector/v.to.3d/main.c:96 ../vector/v.to.3d/main.c:117
+#: ../vector/v.transform/main.c:282
+#, fuzzy
+msgid "Copying attributes..."
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:487
-msgid "Nothing to draw! (no categories with labels? out of range?)"
-msgstr ""
+#: ../vector/v.in.db/main.c:288
+#, fuzzy
+msgid "Unable to copy table"
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:497
-msgid "Forcing a smooth legend: too many categories for current window height"
-msgstr ""
+#: ../vector/v.in.db/main.c:312
+#, fuzzy, c-format
+msgid "Unable to add key column <%s>: SERIAL type is not supported by <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:527 ../display/d.histogram/main.c:180
-#, c-format
-msgid "Range information for <%s> not available"
-msgstr ""
+#: ../vector/v.in.db/main.c:323
+#, fuzzy, c-format
+msgid "Failed to update key column <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.legend/main.c:541
-msgid "Color range exceeds lower limit of actual data"
+#: ../vector/v.in.db/main.c:339
+#, fuzzy, c-format
+msgid "%d point written to vector map."
+msgid_plural "%d points written to vector map."
+#: ../vector/v.in.lidar/main.c:157
+#, fuzzy
+msgid "Converts LAS LiDAR point clouds to a GRASS vector map with libLAS."
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.lidar/main.c:171 ../vector/v.in.ogr/main.c:167
+msgid "Import subregion only"
msgstr ""
-#: ../display/d.legend/main.c:545
-msgid "Color range exceeds upper limit of actual data"
+#: ../vector/v.in.lidar/main.c:172 ../vector/v.in.lidar/main.c:207
+msgid "Subregion"
msgstr ""
-#: ../display/d.legend/main.c:552
-#, c-format
-msgid "use=%s out of range [%.3f, %.3f] (extend with range= ?)"
+#: ../vector/v.in.lidar/main.c:174 ../vector/v.in.ogr/main.c:170
+msgid "Format: xmin,ymin,xmax,ymax - usually W,S,E,N"
msgstr ""
-#: ../display/d.legend/main.c:926
-msgid "Nothing to draw! (no categories with labels?)"
+#: ../vector/v.in.lidar/main.c:187
+msgid "Only import points of selected return type"
msgstr ""
-#: ../display/d.labels/do_labels.c:142
-#, c-format
-msgid "Error: %s\n"
+#: ../vector/v.in.lidar/main.c:188
+msgid "If not specified, all points are imported"
msgstr ""
-#: ../display/d.labels/main.c:44 ../vector/v.label/main.c:60
-#: ../vector/v.label.sa/main.c:39
-msgid "paint labels"
+#: ../vector/v.in.lidar/main.c:208 ../vector/v.in.ogr/main.c:281
+msgid "Limit import to the current region"
msgstr ""
-#: ../display/d.labels/main.c:46
+#: ../vector/v.in.lidar/main.c:218
msgid ""
-"Displays text labels (created with v.label) to the active frame on the "
-"graphics monitor."
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector file."
msgstr ""
-#: ../display/d.labels/main.c:52
-msgid "Ignore rotation setting and draw horizontally"
-msgstr ""
+#: ../vector/v.in.lidar/main.c:281
+#, fuzzy, c-format
+msgid "Unknown filter option <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.labels/main.c:59
-msgid "Name of label file"
+#: ../vector/v.in.lidar/main.c:286 ../vector/v.in.ogr/main.c:545
+msgid "Select either the current region flag or the spatial option, not both"
msgstr ""
-#: ../display/d.labels/main.c:66
-msgid "Minimum region size (diagonal) when labels are displayed"
+#: ../vector/v.in.lidar/main.c:314 ../vector/v.in.ogr/main.c:600
+msgid "4 parameters required for 'spatial' parameter"
msgstr ""
-#: ../display/d.labels/main.c:73
-msgid "Maximum region size (diagonal) when labels are displayed"
+#: ../vector/v.in.lidar/main.c:480 ../vector/v.kernel/main.c:224
+#, c-format
+msgid "Vector map <%s> already exists and will be overwritten"
msgstr ""
-#: ../display/d.labels/main.c:85
+#: ../vector/v.in.lidar/main.c:597 ../vector/v.in.ogr/main.c:1054
#, fuzzy, c-format
-msgid "Label file <%s> not found"
+msgid "Unable open database <%s> by driver <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.labels/main.c:97
-msgid "Region size is lower than minreg, nothing displayed."
-msgstr ""
-#: ../display/d.labels/main.c:105
-msgid "Region size is greater than maxreg, nothing displayed."
-msgstr ""
-#: ../display/d.labels/main.c:114 ../vector/v.lrs/v.lrs.label/main.c:300
+#: ../vector/v.in.lidar/main.c:631
#, fuzzy, c-format
-msgid "Unable to open label file <%s>"
+msgid "Importing %d points..."
msgstr "출력할 래스터맵"
-#: ../display/d.rgb/main.c:58
-msgid ""
-"Displays three user-specified raster maps as red, green, and blue overlays "
-"in the active graphics frame."
-msgstr ""
-#: ../display/d.rgb/main.c:63 ../display/d.rast/main.c:81
-msgid "Make null cells opaque"
-msgstr ""
-#: ../display/d.rgb/main.c:64 ../display/d.rast/main.c:77
-#: ../display/d.rast/main.c:82
-msgid "Null cells"
-msgstr ""
-#: ../display/d.rgb/main.c:69
+#: ../vector/v.in.lidar/main.c:786
#, fuzzy, c-format
-msgid "Name of raster map to be used for '%s'"
+msgid "%d points imported"
msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:54
-msgid ""
-"Overlays a user-specified grid in the active display frame on the graphics "
-"monitor."
+#: ../vector/v.in.lidar/main.c:788
+#, c-format
+msgid "%d input points were not valid"
msgstr ""
-#: ../display/d.grid/main.c:62
-msgid "Size of grid to be drawn (in map units)"
+#: ../vector/v.in.lidar/main.c:790
+#, c-format
+msgid "%d input points were outside of the selected area"
msgstr ""
-#: ../display/d.grid/main.c:63
-msgid ""
-"0 for north-south resolution of the current region. In map units or DDD:MM:"
-"SS format. Example: \"1000\" or \"0:10\""
+#: ../vector/v.in.lidar/main.c:792
+#, c-format
+msgid "%d input points were filtered by return number"
msgstr ""
-#: ../display/d.grid/main.c:71
-msgid "Lines of the grid pass through this coordinate"
+#: ../vector/v.drape/main.c:59 ../vector/v.surf.rst/main.c:145
+#: ../vector/v.hull/main.c:54 ../vector/v.out.postgis/main.c:49
+#: ../vector/v.extrude/main.c:70 ../vector/v.to.3d/main.c:38
+msgid "3D"
msgstr ""
-#: ../display/d.grid/main.c:80
-msgid "Draw only east-west lines, north-south lines, or both "
-msgstr ""
+#: ../vector/v.drape/main.c:61
+#, fuzzy
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:81 ../display/d.grid/main.c:147
-#: ../display/d.grid/main.c:152 ../display/d.grid/main.c:157
-msgid "Disable"
-msgstr ""
+#: ../vector/v.drape/main.c:82 ../vector/v.extrude/main.c:124
+#, fuzzy
+msgid "Elevation raster map for height extraction"
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:87
+#: ../vector/v.drape/main.c:86 ../vector/v.drape/main.c:93
+#: ../vector/v.drape/main.c:100 ../vector/v.extrude/main.c:79
+#: ../vector/v.extrude/main.c:125 ../vector/v.extrude/main.c:129
+#: ../vector/v.extrude/main.c:136 ../vector/v.extrude/main.c:143
#, fuzzy
-msgid "Grid line width"
+msgid "Elevation"
msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:91
-msgid "Grid color"
-msgstr ""
+#: ../vector/v.drape/main.c:91 ../vector/v.extrude/main.c:134
+#, fuzzy
+msgid "Scale factor sampled raster values"
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:96 ../vector/v.label/main.c:193
-#: ../vector/v.label.sa/main.c:144 ../vector/v.lrs/v.lrs.label/main.c:238
-msgid "Border color"
+#: ../vector/v.drape/main.c:99 ../vector/v.extrude/main.c:142
+msgid "Height for sampled raster NULL values"
msgstr ""
-#: ../display/d.grid/main.c:111
-msgid "Font size for gridline coordinate labels"
+#: ../vector/v.drape/main.c:149 ../vector/v.random/main.c:223
+#: ../vector/v.buffer/main.c:341
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s' or '%s' specified, assuming layer "
+"'1'."
msgstr ""
-#: ../display/d.grid/main.c:115
+#: ../vector/v.drape/main.c:176 ../vector/v.category/main.c:332
+#: ../vector/v.select/select.c:40
#, fuzzy
-msgid "Align the origin to the east-north corner of the current region"
+msgid "Processing features..."
msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:120
-msgid "Draw geographic grid (referenced to current ellipsoid)"
-msgstr ""
+#: ../vector/v.drape/main.c:198
+#, fuzzy, c-format
+msgid "Undefined height for feature %d. Skipping."
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:126
-msgid "Draw geographic grid (referenced to WGS84 ellipsoid)"
-msgstr ""
+#: ../vector/v.drape/main.c:203
+#, fuzzy
+msgid "Copying attribute tables..."
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:131
-msgid "Draw '+' marks instead of grid lines"
+#: ../vector/v.split/main.c:57
+msgid "Splits vector lines to shorter segments."
msgstr ""
-#: ../display/d.grid/main.c:136
-msgid "Draw '.' marks instead of grid lines"
+#: ../vector/v.split/main.c:70
+msgid "Maximum segment length"
msgstr ""
-#: ../display/d.grid/main.c:141
-msgid "Draw fiducial marks instead of grid lines"
+#: ../vector/v.split/main.c:79
+msgid "Length units"
msgstr ""
-#: ../display/d.grid/main.c:146
-msgid "Disable grid drawing"
+#: ../vector/v.split/main.c:86
+msgid "Maximum number of vertices in segment"
msgstr ""
-#: ../display/d.grid/main.c:151
-msgid "Disable border drawing"
+#: ../vector/v.split/main.c:90
+msgid "Add new vertices, but do not split"
msgstr ""
-#: ../display/d.grid/main.c:156
-msgid "Disable text drawing"
+#: ../vector/v.split/main.c:91
+msgid "Applies only to 'length' option"
msgstr ""
-#: ../display/d.grid/main.c:166
-msgid "Both grid and border drawing are disabled"
+#: ../vector/v.split/main.c:98
+msgid "Use either length or vertices"
msgstr ""
-#: ../display/d.grid/main.c:170
-msgid "Geo-Grid option is not available for LL projection"
+#: ../vector/v.split/main.c:105
+#, c-format
+msgid "Length must be positive but is %g"
msgstr ""
-#: ../display/d.grid/main.c:172
-msgid "Geo-Grid option is not available for XY projection"
-msgstr ""
+#: ../vector/v.split/main.c:121
+#, fuzzy, c-format
+msgid "Unknown unit %s"
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:191
-msgid "Choose a single mark style"
-msgstr ""
+#: ../vector/v.split/main.c:139
+#, fuzzy
+msgid "Can not get projection units"
+msgstr "출력할 래스터맵"
-#: ../display/d.grid/main.c:221
+#: ../vector/v.split/main.c:146
#, c-format
-msgid "Invalid geo-grid size <%s>"
+msgid "Length in map units: %g"
msgstr ""
-#: ../display/d.grid/main.c:226
+#: ../vector/v.split/main.c:148
#, c-format
-msgid "Invalid grid size <%s>"
+msgid "Length in meters: %g"
msgstr ""
-#: ../display/d.grid/fiducial.c:61
+#: ../vector/v.split/main.c:154
#, fuzzy
-msgid "Reading symbol"
+msgid "Number of vertices must be at least 2"
msgstr "출력할 래스터맵"
-#: ../display/d.grid/plot.c:370
-msgid ""
-"WGS84 grid output not possible as this location does not contain\n"
-"datum transformation parameters. Try running g.setproj."
+#: ../vector/v.split/main.c:232
+#, c-format
+msgid "Unable to make line segment: %f - %f (line length = %f)"
msgstr ""
-#: ../display/d.grid/plot.c:538
-msgid "Error in pj_do_proj1"
+#: ../vector/v.lidar.correction/correction.c:93
+#: ../vector/v.lidar.correction/correction.c:127
+#: ../vector/v.lidar.correction/correction.c:151
+#: ../vector/v.lidar.correction/correction.c:163
+#: ../vector/v.lidar.correction/correction.c:187
+#: ../vector/v.outlier/outlier.c:86 ../vector/v.outlier/outlier.c:123
+#: ../vector/v.outlier/outlier.c:148 ../vector/v.outlier/outlier.c:161
+#: ../vector/v.outlier/outlier.c:185
+msgid "Impossible to read the database"
msgstr ""
-#: ../display/d.grid/plot.c:544
-msgid "Error in pj_do_proj2"
+#: ../vector/v.lidar.correction/correction.c:97
+#: ../vector/v.lidar.correction/correction.c:155
+#: ../vector/v.outlier/outlier.c:90 ../vector/v.outlier/outlier.c:152
+msgid "Impossible to update the database"
msgstr ""
-#: ../display/d.grid/plot.c:548
-msgid "Error in pj_do_proj3"
+#: ../vector/v.lidar.correction/correction.c:107
+#: ../vector/v.lidar.correction/correction.c:115
+#: ../vector/v.lidar.correction/correction.c:210
+#: ../vector/v.outlier/outlier.c:101 ../vector/v.outlier/outlier.c:110
+#: ../vector/v.outlier/outlier.c:207
+msgid "Impossible to write in the database"
msgstr ""
-#: ../display/d.grid/plot.c:556
-msgid "Error in pj_do_proj5"
+#: ../vector/v.lidar.correction/main.c:71
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
msgstr ""
-#: ../display/d.grid/plot.c:560
-msgid "Error in pj_do_proj6"
+#: ../vector/v.lidar.correction/main.c:81
+msgid "Input observation vector map name (v.lidar.growing output)"
msgstr ""
-#: ../display/d.linegraph/main.c:122
-msgid ""
-"Generates and displays simple line graphs in the active graphics monitor "
-"display frame."
+#: ../vector/v.lidar.correction/main.c:84
+msgid "Output classified vector map name"
msgstr ""
-#: ../display/d.linegraph/main.c:126
-msgid "Name of data file for X axis of graph"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:93
+#, fuzzy
+msgid "Only 'terrain' points output vector map"
+msgstr "출력할 래스터맵"
-#: ../display/d.linegraph/main.c:132
-msgid "Name of data file(s) for Y axis of graph"
+#: ../vector/v.lidar.correction/main.c:101 ../vector/v.outlier/main.c:105
+#: ../vector/v.lidar.edgedetection/main.c:94
+msgid "Interpolation spline step value in east direction"
msgstr ""
-#: ../display/d.linegraph/main.c:139
-msgid "Path to file location"
+#: ../vector/v.lidar.correction/main.c:109 ../vector/v.outlier/main.c:113
+#: ../vector/v.lidar.edgedetection/main.c:103
+msgid "Interpolation spline step value in north direction"
msgstr ""
-#: ../display/d.linegraph/main.c:147
-msgid "Color for Y data"
+#: ../vector/v.lidar.correction/main.c:116
+msgid "Regularization weight in reclassification evaluation"
msgstr ""
-#: ../display/d.linegraph/main.c:156
-msgid "Color for axis, tics, numbers, and title"
+#: ../vector/v.lidar.correction/main.c:124
+msgid "High threshold for object to terrain reclassification"
msgstr ""
-#: ../display/d.linegraph/main.c:164
-msgid "Title for X data"
+#: ../vector/v.lidar.correction/main.c:132
+msgid "Low threshold for terrain to object reclassification"
msgstr ""
-#: ../display/d.linegraph/main.c:171
-msgid "Title for Y data"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:148 ../vector/v.outlier/main.c:144
+#: ../vector/v.lidar.edgedetection/main.c:169
+#, fuzzy
+msgid "Unable to read name of database"
+msgstr "출력할 래스터맵"
-#: ../display/d.linegraph/main.c:178
-msgid "Title for Graph"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:151 ../vector/v.outlier/main.c:147
+#: ../vector/v.lidar.edgedetection/main.c:172
+#, fuzzy
+msgid "Unable to read name of driver"
+msgstr "출력할 래스터맵"
-#: ../display/d.linegraph/main.c:226
-msgid "Maximum of 10 Y data files exceeded"
+#: ../vector/v.lidar.correction/main.c:168 ../vector/v.outlier/main.c:186
+#: ../vector/v.lidar.edgedetection/main.c:192
+#: ../vector/v.lidar.edgedetection/main.c:204
+msgid "Old auxiliar table could not be dropped"
msgstr ""
-#: ../display/d.linegraph/main.c:255
-#, c-format
-msgid "Only <%d> colors given for <%d> lines"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:186 ../vector/v.outlier/main.c:198
+#: ../vector/v.lidar.edgedetection/main.c:223
+#, fuzzy, c-format
+msgid "Input vector map <%s> is not 3D!"
+msgstr "출력할 래스터맵"
-#: ../display/d.linegraph/main.c:310
-#, c-format
-msgid "Y input file <%s> contains fewer data points than the X input file"
-msgstr ""
+#: ../vector/v.lidar.correction/main.c:196 ../vector/v.outlier/main.c:208
+#: ../vector/v.lidar.edgedetection/main.c:233
+#, fuzzy
+msgid "No points in current region!"
+msgstr "출력할 래스터맵"
-#: ../display/d.linegraph/main.c:314
+#: ../vector/v.lidar.correction/main.c:274
#, c-format
-msgid "Y input file <%s> contains more data points than the X input file"
-msgstr ""
+msgid "adjusted EW spline %d"
+msgid_plural "adjusted EW splines %d"
+msgstr[0] ""
+msgstr[1] ""
-#: ../display/d.linegraph/main.c:319
+#: ../vector/v.lidar.correction/main.c:277
#, c-format
-msgid "The last point will be ignored"
-msgid_plural "The last %d points will be ignored"
+msgid "adjusted NS spline %d"
+msgid_plural "adjusted NS splines %d"
msgstr[0] ""
msgstr[1] ""
-#: ../display/d.linegraph/main.c:382
+#: ../vector/v.lidar.correction/main.c:325
#, c-format
-msgid "Problem reading X data file at line %d"
+msgid "nsply = %d"
msgstr ""
-#: ../display/d.linegraph/main.c:392
+#: ../vector/v.lidar.correction/main.c:358
#, c-format
-msgid "Problem reading <%s> data file at line %d"
+msgid "nsplx = %d"
msgstr ""
-#: ../display/d.thematic.area/main.c:79
-msgid "choropleth map"
+#: ../vector/v.lidar.correction/main.c:361
+msgid "read vector region map"
msgstr ""
-#: ../display/d.thematic.area/main.c:81
-msgid ""
-"Displays a thematic vector area map in the active frame on the graphics "
-"monitor."
+#: ../vector/v.lidar.correction/main.c:366
+#, c-format
+msgid "npoints = %d, nterrain = %d"
msgstr ""
-#: ../display/d.thematic.area/main.c:91
-msgid "Data to be classified: column name or expression"
+#: ../vector/v.lidar.correction/main.c:372
+msgid "Mean calculation"
msgstr ""
-#: ../display/d.thematic.area/main.c:98
-msgid "Class breaks, without minimum and maximum"
+#: ../vector/v.lidar.correction/main.c:386
+msgid "Only TERRAIN points"
msgstr ""
-#: ../display/d.thematic.area/main.c:106 ../vector/v.class/main.c:68
-msgid "Algorithm to use for classification"
+#: ../vector/v.lidar.correction/main.c:416
+msgid "Correction and creation of terrain vector"
msgstr ""
-#: ../display/d.thematic.area/main.c:110 ../vector/v.class/main.c:76
-msgid "simple intervals"
+#: ../vector/v.lidar.correction/main.c:429 ../vector/v.outlier/main.c:439
+#: ../vector/v.lidar.edgedetection/main.c:456
+msgid "No data within this subregion. Consider changing the spline step."
msgstr ""
-#: ../display/d.thematic.area/main.c:111 ../vector/v.class/main.c:77
-msgid "standard deviations"
+#: ../vector/v.lidar.correction/main.c:438
+#: ../vector/v.lidar.edgedetection/main.c:464
+#, c-format
+msgid "Dropping <%s>"
msgstr ""
-#: ../display/d.thematic.area/main.c:112 ../vector/v.class/main.c:78
-#, fuzzy
-msgid "quantiles"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lidar.correction/main.c:440 ../vector/v.outlier/main.c:449
+#: ../vector/v.lidar.edgedetection/main.c:466
+msgid "Auxiliar table could not be dropped"
+msgstr ""
-#: ../display/d.thematic.area/main.c:113 ../vector/v.class/main.c:79
-msgid "equiprobable (normal distribution)"
+#: ../vector/v.to.points/main.c:59
+msgid "Creates points along input lines in new vector map with 2 layers."
msgstr ""
-#: ../display/d.thematic.area/main.c:122 ../vector/v.class/main.c:88
-msgid "Number of classes to define"
+#: ../vector/v.to.points/main.c:79
+msgid "Use line nodes or vertices only"
msgstr ""
-#: ../display/d.thematic.area/main.c:129
-msgid "Colors (one per class)."
+#: ../vector/v.to.points/main.c:87
+msgid "Maximum distance between points in map units"
msgstr ""
-#: ../display/d.thematic.area/main.c:134
-msgid "Layer number. If -1, all layers are displayed."
+#: ../vector/v.to.points/main.c:91
+msgid "Interpolate points between line vertices (only for use=vertex)"
msgstr ""
-#: ../display/d.thematic.area/main.c:144 ../display/d.thematic.area/main.c:152
-#, fuzzy
-msgid "Boundaries"
+#: ../vector/v.to.points/main.c:155 ../vector/v.generalize/misc.c:174
+#: ../vector/v.extract/copy_tab.c:104
+#, fuzzy, c-format
+msgid "Unable to copy table <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:145
-msgid "Boundary width"
-msgstr ""
-#: ../display/d.thematic.area/main.c:151
-msgid "Boundary color"
-msgstr ""
-#: ../display/d.thematic.area/main.c:158
-msgid "File in which to save d.graph instructions for legend display"
-msgstr ""
-#: ../display/d.thematic.area/main.c:164 ../display/d.vect.chart/main.c:149
-msgid "Create legend information and send to stdout"
-msgstr ""
-#: ../display/d.thematic.area/main.c:169
+#: ../vector/v.to.points/main.c:232
+#, c-format
msgid ""
-"When printing legend info , include extended statistical info from "
-"classification algorithm"
+"%d features without category in layer <%d> skipped. Note that features "
+"without category (usually boundaries) are not skipped when '%s=-1' is given."
msgstr ""
-#: ../display/d.thematic.area/main.c:173
-msgid "Do not draw map, only output the legend"
-msgstr ""
-#: ../display/d.thematic.area/main.c:192
+#: ../vector/v.to.points/main.c:282
#, fuzzy, c-format
-msgid "%s: You must build topology on vector map. Run v.build."
+msgid "%d points written to output vector map."
msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:199
-msgid "'layer' must be > 0"
+#: ../vector/v.vol.rst/user1.c:95 ../vector/v.class/main.c:111
+#: ../vector/v.label/main.c:274 ../vector/v.label.sa/labels.c:75
+#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110
+#: ../ps/ps.map/catval.c:176
+msgid "Unable to get layer info for vector map"
msgstr ""
-#: ../display/d.thematic.area/main.c:201 ../display/d.vect/opt.c:143
-#: ../display/d.what.vect/what.c:413 ../vector/v.db.connect/main.c:176
-#, c-format
-msgid "Database connection not defined"
+#: ../vector/v.vol.rst/user1.c:109
+msgid "Column type of wcolumn is not supported (must be integer or double)"
msgstr ""
-#: ../display/d.thematic.area/main.c:225
-#, c-format
-msgid "Data (%s) not numeric. Column must be numeric."
-msgstr ""
-#: ../display/d.thematic.area/main.c:229
-#: ../display/d.thematic.area/plot1.c:134
-#: ../display/d.thematic.area/plot1.c:162
-#, c-format
-msgid "Cannot select data (%s) from table"
-msgstr ""
-#: ../display/d.thematic.area/main.c:292
-#, c-format
-msgid "Unknown color: [%s]"
-msgstr ""
-#: ../display/d.thematic.area/main.c:303
+#: ../vector/v.vol.rst/user1.c:128
msgid ""
-"You gave both manual breaks and a classification algorithm or a number of "
-"classes. The manual breaks have precedence and will thus be used."
+"Column type of smooth column is not supported (must be integer or double)"
msgstr ""
-#: ../display/d.thematic.area/main.c:340
-msgid "You must either give classbreaks or a classification algorithm"
+#: ../vector/v.vol.rst/main.c:242
+msgid "RST"
msgstr ""
-#: ../display/d.thematic.area/main.c:353
-#, c-format
+#: ../vector/v.vol.rst/main.c:244
msgid ""
-"Not enough colors or error in color specifications.\n"
-"Need %i colors."
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
msgstr ""
-#: ../display/d.thematic.area/main.c:358
-#, fuzzy, c-format
-msgid "Error interpreting color %s"
+#: ../vector/v.vol.rst/main.c:249
+#, fuzzy
+msgid "Name of input 3D vector points map"
msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:377
-msgid "Plotting ..."
-msgstr ""
+#: ../vector/v.vol.rst/main.c:256
+#, fuzzy
+msgid "Name of input surface raster map for cross-section"
+msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:384
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn."
-msgstr ""
+#: ../vector/v.vol.rst/main.c:263
+#, fuzzy
+msgid "Name of column containing w attribute to interpolate"
+msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:434
-#, c-format
-msgid ""
-"\n"
-"Total number of records: %.0f\n"
+#: ../vector/v.vol.rst/main.c:270 ../vector/v.surf.rst/main.c:261
+msgid "Tension parameter"
msgstr ""
-#: ../display/d.thematic.area/main.c:436
-#, c-format
-msgid "Classification of %s into %i classes\n"
+#: ../vector/v.vol.rst/main.c:278 ../vector/v.surf.rst/main.c:268
+msgid "Smoothing parameter"
msgstr ""
-#: ../display/d.thematic.area/main.c:438 ../vector/v.class/main.c:202
-#, c-format
-msgid "Using algorithm: *** %s ***\n"
-msgstr ""
+#: ../vector/v.vol.rst/main.c:285
+#, fuzzy
+msgid "Name of column with smoothing parameters"
+msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:440 ../vector/v.class/main.c:203
-#, c-format
-msgid "Mean: %f\tStandard deviation = %f\n"
-msgstr ""
+#: ../vector/v.vol.rst/main.c:293
+#, fuzzy
+msgid "Name for output deviations vector map"
+msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:444
-#, c-format
-msgid "Last chi2 = %f\n"
-msgstr ""
+#: ../vector/v.vol.rst/main.c:299
+#, fuzzy
+msgid "Name for output cross-validation vector map"
+msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/main.c:447 ../vector/v.class/main.c:210
-#, c-format
-msgid "Stdev multiplied by %.4f to define step\n"
-msgstr ""
-#: ../display/d.thematic.area/plot1.c:119
+#: ../vector/v.vol.rst/main.c:305
#, fuzzy
-msgid "Color definition column not specified"
+msgid "Name of input raster map used as mask"
msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/plot1.c:129
-#, c-format
-msgid ""
-"Color definition column (%s) not a string. Column must be of form RRR:GGG:"
-"BBB where RGB values range 0-255."
+#: ../vector/v.vol.rst/main.c:313 ../vector/v.surf.rst/main.c:284
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:14
+msgid "Maximum number of points in a segment"
msgstr ""
-#: ../display/d.thematic.area/plot1.c:147
-msgid "Line width column not specified."
+#: ../vector/v.vol.rst/main.c:322 ../vector/v.surf.rst/main.c:293
+#: ../locale/scriptstrings/r.fillnulls_to_translate.c:12
+msgid "Minimum number of points for approximation in a segment (>segmax)"
msgstr ""
-#: ../display/d.thematic.area/plot1.c:158
-#, c-format
-msgid "Line width column (%s) not a number."
-msgstr ""
+#: ../vector/v.vol.rst/main.c:331
+#, fuzzy
+msgid "Maximum number of points for approximation in a segment (>npmin)"
+msgstr "출력할 래스터맵"
-#: ../display/d.thematic.area/plot1.c:203
-#, c-format
-msgid ""
-"\n"
-"ERROR: vector map - can't read\n"
+#: ../vector/v.vol.rst/main.c:339 ../vector/v.surf.rst/main.c:301
+msgid "Minimum distance between points (to remove almost identical points)"
msgstr ""
-#: ../display/d.thematic.area/plot1.c:278
-#, c-format
-msgid ""
-"Error in color definition column (%s), element %d with cat %d: colorstring "
-"[%s]"
+#: ../vector/v.vol.rst/main.c:348
+msgid "Conversion factor for w-values used for interpolation"
msgstr ""
-#: ../display/d.thematic.area/plot1.c:285
-#, c-format
-msgid "Error in color definition column (%s), element %d with cat %d"
+#: ../vector/v.vol.rst/main.c:356
+msgid "Conversion factor for z-values"
msgstr ""
-#: ../display/d.thematic.area/plot1.c:353
-#, c-format
-msgid ""
-"Error in line width column (%s), element %d with cat %d: line width [%d]"
-msgstr ""
+#: ../vector/v.vol.rst/main.c:362
+#, fuzzy
+msgid "Name for output cross-section raster map"
+msgstr "출력할 래스터맵"
-#: ../display/d.erase/main.c:33
-msgid ""
-"Erases the contents of the active graphics display frame with user defined "
-"color."
-msgstr ""
+#: ../vector/v.vol.rst/main.c:368
+#, fuzzy
+msgid "Name for output elevation 3D raster map"
+msgstr "출력할 래스터맵"
-#: ../display/d.erase/main.c:39
-msgid "Remove all frames and erase the screen"
-msgstr ""
+#: ../vector/v.vol.rst/main.c:374
+#, fuzzy
+msgid "Name for output gradient magnitude 3D raster map"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/opt.c:126
-#, c-format
-msgid "Unknown color: '%s'"
-msgstr ""
+#: ../vector/v.vol.rst/main.c:381
+#, fuzzy
+msgid "Name for output gradient horizontal angle 3D raster map"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/zcoor.c:19
+#: ../vector/v.vol.rst/main.c:387
#, fuzzy
-msgid "Vector map is not 3D. Unable to display z-coordinates."
+msgid "Name for output gradient vertical angle 3D raster map"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/lines.c:107 ../display/d.vect/lines.c:335
-#, fuzzy, c-format
-msgid "Unable to read symbol <%s>, unable to display points"
+#: ../vector/v.vol.rst/main.c:393
+#, fuzzy
+msgid "Name for output change of gradient 3D raster map"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/lines.c:121
+#: ../vector/v.vol.rst/main.c:399
#, fuzzy
-msgid ""
-"Unable to display features by id, topology not available. Please try to "
-"rebuild topology using v.build or v.build.all."
+msgid "Name for output gaussian curvature 3D raster map"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/lines.c:169
-#, fuzzy, c-format
-msgid "%d invalid color rule for lines skipped"
-msgid_plural "%d invalid color rules for lines skipped"
-msgstr[0] "출력할 래스터맵"
-msgstr[1] "출력할 래스터맵"
+#: ../vector/v.vol.rst/main.c:405
+#, fuzzy
+msgid "Name for output mean curvature 3D raster map"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/lines.c:175
-#, fuzzy, c-format
-msgid "%d point plotted"
-msgid_plural "%d points plotted"
+#: ../vector/v.vol.rst/main.c:411
+msgid "Perform a cross-validation procedure without volume interpolation"
+msgstr ""
-#: ../display/d.vect/lines.c:177
-#, fuzzy, c-format
-msgid "%d line plotted"
-msgid_plural "%d lines plotted"
+#: ../vector/v.vol.rst/main.c:474
+msgid "Smoothing must be a positive value"
+msgstr ""
-#: ../display/d.vect/lines.c:179
+#: ../vector/v.vol.rst/main.c:480
#, fuzzy, c-format
-msgid "%d centroid plotted"
-msgid_plural "%d centroids plotted"
+msgid "Both crossvalidation options (-%c, %s) must be specified"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/lines.c:181
-#, fuzzy, c-format
-msgid "%d boundary plotted"
-msgid_plural "%d boundaries plotted"
+#: ../vector/v.vol.rst/main.c:483
+#, fuzzy
+msgid "Both crossvalidation and deviations must be specified"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/lines.c:183
+#: ../vector/v.vol.rst/main.c:566
+#, fuzzy
+msgid "Vector is not 3D"
+msgstr "출력할 래스터맵"
+#: ../vector/v.vol.rst/main.c:609
#, fuzzy, c-format
-msgid "%d face plotted"
-msgid_plural "%d faces plotted"
+msgid "Unable To create table: %s"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:73
-msgid "Displays user-specified vector map in the active graphics frame."
+#: ../vector/v.vol.rst/main.c:637 ../vector/v.vol.rst/main.c:661
+#: ../vector/v.vol.rst/main.c:679 ../vector/v.vol.rst/main.c:697
+#: ../vector/v.vol.rst/main.c:715 ../vector/v.vol.rst/main.c:733
+#: ../vector/v.vol.rst/main.c:751 ../vector/v.vol.rst/main.c:769
+msgid "Not enough disk space - cannot write temp files"
msgstr ""
-#: ../display/d.vect/main.c:89
-msgid "Display"
+#: ../vector/v.vol.rst/main.c:650 ../vector/v.vol.rst/main.c:668
+#: ../vector/v.vol.rst/main.c:686 ../vector/v.vol.rst/main.c:704
+#: ../vector/v.vol.rst/main.c:722 ../vector/v.vol.rst/main.c:740
+#: ../vector/v.vol.rst/main.c:758
+msgid "Not enough memory"
msgstr ""
-#: ../display/d.vect/main.c:93
+#: ../vector/v.vol.rst/main.c:655 ../vector/v.vol.rst/main.c:673
+#: ../vector/v.vol.rst/main.c:691 ../vector/v.vol.rst/main.c:709
+#: ../vector/v.vol.rst/main.c:727 ../vector/v.vol.rst/main.c:745
+#: ../vector/v.vol.rst/main.c:763
+#, fuzzy, c-format
+msgid "Unable to open temp file '%s'"
+msgstr "출력할 래스터맵"
+#: ../vector/v.vol.rst/main.c:876
#, fuzzy
-msgid "Display geometry of features"
+msgid "Interpolation failed"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:94
-msgid "Display category numbers of features"
+#: ../vector/v.proj/main.c:69
+msgid "Re-projects a vector map from one location to the current location."
msgstr ""
-#: ../display/d.vect/main.c:95
-msgid "Display topology information (nodes, edges)"
-msgstr ""
-#: ../display/d.vect/main.c:96
+#: ../vector/v.proj/main.c:75
#, fuzzy
-msgid "Display vertices of features"
+msgid "Name of input vector map to re-project"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:97
-msgid "Display direction of linear features"
+#: ../vector/v.proj/main.c:83
+msgid "Location containing input vector map"
msgstr ""
-#: ../display/d.vect/main.c:98
-msgid "Display z-coordinate of features (only for 3D vector maps)"
+#: ../vector/v.proj/main.c:88
+msgid "Mapset containing input vector map"
msgstr ""
-#: ../display/d.vect/main.c:119
+#: ../vector/v.proj/main.c:89
#, fuzzy
-msgid "Feature color"
+msgid "Default: name of current mapset"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:123 ../display/d.vect/main.c:133
-#: ../display/d.vect/main.c:233 ../display/d.vect/main.c:243
-msgid "Either a standard GRASS color, R:G:B triplet, or \"none\""
-msgstr ""
+#: ../vector/v.proj/main.c:97
+#, fuzzy
+msgid "Default: path to the current GRASS database"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:129
-msgid "Area fill color"
-msgstr ""
+#: ../vector/v.proj/main.c:104
+#, fuzzy
+msgid "Name for output vector map (default: input)"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:138
+#: ../vector/v.proj/main.c:109
#, fuzzy
-msgid "Colorize features according color definition column"
+msgid "List vector maps in input mapset and exit"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:139
+#: ../vector/v.proj/main.c:113
#, fuzzy
-msgid "Color definition in R:G:B form"
+msgid "3D vector maps only"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:143
-msgid "Colorize point or area features according to z-coordinate"
+#: ../vector/v.proj/main.c:115
+msgid "Assume z coordinate is ellipsoidal height and transform if possible"
msgstr ""
-#: ../display/d.vect/main.c:151 ../display/d.vect/main.c:156
-#: ../display/d.vect/main.c:164
-msgid "Lines"
+#: ../vector/v.proj/main.c:121
+msgid "Latlon output only, default is -180,180"
msgstr ""
-#: ../display/d.vect/main.c:152 ../display/d.northarrow/main.c:78
-msgid "Line width"
+#: ../vector/v.proj/main.c:123
+msgid "Disable wrapping to -180,180 for latlon output"
msgstr ""
-#: ../display/d.vect/main.c:157
+#: ../vector/v.proj/main.c:187
#, fuzzy
-msgid "Name of numeric column containing line width"
+msgid "No vector maps found"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:158
-msgid "These values will be scaled by width_scale"
-msgstr ""
+#: ../vector/v.proj/main.c:200
+#, fuzzy, c-format
+msgid "Vector map <%s> in location <%s> mapset <%s> not found"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:165
-msgid "Scale factor for width_column"
+#: ../vector/v.proj/main.c:230
+#, c-format
+msgid "Mapset <%s> in input location <%s> - permission denied"
msgstr ""
-#: ../display/d.vect/main.c:173 ../display/d.vect/main.c:183
-#: ../display/d.vect/main.c:190 ../display/d.vect/main.c:196
-#: ../display/d.vect/main.c:316
-msgid "Symbols"
-msgstr ""
+#: ../vector/v.proj/main.c:233
+#, fuzzy, c-format
+msgid "Mapset <%s> in input location <%s> not found"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:177
-msgid "Point and centroid symbol"
-msgstr ""
+#: ../vector/v.proj/main.c:277 ../vector/v.proj/main.c:399
+#: ../vector/v.rectify/main.c:246
+#, fuzzy
+msgid "Reading input vector map"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:184
-msgid "Symbol size"
-msgstr ""
+#: ../vector/v.proj/main.c:300
+#, fuzzy, c-format
+msgid "Input vector map <%s> is empty"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:186
-msgid "When used with the size_column option this becomes the scale factor"
+#: ../vector/v.proj/main.c:308 ../vector/v.proj/main.c:319
+#: ../vector/v.proj/main.c:334 ../vector/v.proj/main.c:349
+msgid "Error in pj_do_transform"
msgstr ""
-#: ../display/d.vect/main.c:192
+#: ../vector/v.proj/main.c:390
#, fuzzy
-msgid "Name of numeric column containing symbol size"
+msgid "Reprojecting primitives ..."
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:198
+#: ../vector/v.proj/main.c:405
+#, fuzzy, c-format
+msgid "Unable to re-project vector map <%s> from <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.proj/main.c:415 ../vector/v.rectify/main.c:289
+#: ../vector/v.type/main.c:152 ../vector/v.build.polylines/main.c:240
+#: ../vector/v.category/main.c:771 ../vector/v.net/main.c:152
+#: ../vector/v.transform/main.c:284
#, fuzzy
-msgid "Name of numeric column containing symbol rotation angle"
+msgid "Failed to copy attribute table to output map"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:200
-msgid "Measured in degrees CCW from east"
+#: ../vector/v.proj/main.c:423
+msgid "Try to disable wrapping to -180,180 if topological errors occurred"
msgstr ""
-#: ../display/d.vect/main.c:206 ../display/d.vect/main.c:213
-#: ../display/d.vect/main.c:221 ../display/d.vect/main.c:229
-#: ../display/d.vect/main.c:239 ../display/d.vect/main.c:249
-#: ../display/d.vect/main.c:255 ../display/d.vect/main.c:261
-#: ../display/d.vect/main.c:267 ../display/d.vect/main.c:275
-msgid "Labels"
+#: ../vector/v.rectify/main.c:73
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
msgstr ""
-#: ../display/d.vect/main.c:208
-msgid "Layer number for labels (default: the given layer number)"
-msgstr ""
+#: ../vector/v.rectify/main.c:88
+#, fuzzy
+msgid "Name of input file with control points"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:214
+#: ../vector/v.rectify/main.c:93
#, fuzzy
-msgid "Name of column to be displayed as a label"
+msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:220
-msgid "Label color"
+#: ../vector/v.rectify/main.c:105
+#, fuzzy
+msgid "Field separator for RMS report"
+msgstr "출력할 래스터맵"
+#: ../vector/v.rectify/main.c:109
+#, fuzzy
+msgid "Perform 3D transformation"
+msgstr "출력할 래스터맵"
+#: ../vector/v.rectify/main.c:113
+#, fuzzy
+msgid "Perform orthogonal 3D transformation"
+msgstr "출력할 래스터맵"
+#: ../vector/v.rectify/main.c:117
+msgid "Print RMS errors"
msgstr ""
-#: ../display/d.vect/main.c:223 ../display/d.rast/main.c:76
-msgid "Either a standard color name or R:G:B triplet"
+#: ../vector/v.rectify/main.c:118
+msgid "Print RMS errors and exit without rectifying the input map"
msgstr ""
-#: ../display/d.vect/main.c:230
-msgid "Label background color"
+#: ../vector/v.rectify/main.c:136
+msgid "Please select a group or give an input file."
msgstr ""
-#: ../display/d.vect/main.c:240
-msgid "Label border color"
+#: ../vector/v.rectify/main.c:138
+msgid "Points in group will be ignored, GCPs in input file are used."
msgstr ""
-#: ../display/d.vect/main.c:250
-msgid "Label size (pixels)"
+#: ../vector/v.rectify/main.c:154
+msgid "3D transformation requires a 3D vector"
msgstr ""
-#: ../display/d.vect/main.c:262
-msgid "Text encoding"
+#: ../vector/v.rectify/main.c:157
+msgid "A file with 3D control points is needed for 3D transformation"
msgstr ""
-#: ../display/d.vect/main.c:270
-msgid "Label horizontal justification"
+#: ../vector/v.rectify/main.c:214
+#, fuzzy, c-format
+msgid "The vector map <%s> already exists in"
+msgstr "출력할 래스터맵"
+#: ../vector/v.rectify/main.c:217
+msgid "Rectification cancelled."
msgstr ""
-#: ../display/d.vect/main.c:278
-msgid "Label vertical justification"
+#: ../vector/v.rectify/main.c:287 ../vector/v.category/main.c:769
+#, fuzzy
+msgid "Copying attribute table(s)..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.rectify/cp.c:307 ../vector/v.rectify/cp.c:331
+#, fuzzy, c-format
+msgid "Can not open file <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.rectify/cp.c:314 ../vector/v.rectify/cp.c:338
+#, fuzzy, c-format
+msgid "Bad format in control point file <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.net.allpairs/main.c:62 ../vector/v.net.timetable/main.c:261
+#: ../vector/v.net.salesman/main.c:127 ../vector/v.net.visibility/main.c:46
+#: ../vector/v.net.spanningtree/main.c:47 ../vector/v.net.bridge/main.c:48
+#: ../vector/v.net.flow/main.c:59 ../vector/v.net.alloc/main.c:61
+#: ../vector/v.net.steiner/main.c:346 ../vector/v.net.iso/main.c:73
+#: ../vector/v.net/main.c:46 ../vector/v.net.centrality/main.c:97
+#: ../vector/v.net.components/main.c:72 ../vector/v.net.distance/main.c:65
+#: ../vector/v.net.path/main.c:41 ../vector/v.net.connectivity/main.c:53
+#: ../display/d.path/main.c:49
+msgid "network"
msgstr ""
-#: ../display/d.vect/main.c:285
-msgid ""
-"Minimum region size (average from height and width) when map is displayed"
+#: ../vector/v.net.allpairs/main.c:63 ../vector/v.net.timetable/main.c:262
+#: ../vector/v.net.visibility/main.c:47 ../vector/v.net.distance/main.c:66
+#: ../vector/v.net.path/main.c:42 ../display/d.path/main.c:50
+msgid "shortest path"
msgstr ""
-#: ../display/d.vect/main.c:293
-msgid ""
-"Maximum region size (average from height and width) when map is displayed"
+#: ../vector/v.net.allpairs/main.c:65
+msgid "Computes the shortest path between all pairs of nodes in the network."
msgstr ""
-#: ../display/d.vect/main.c:301
-msgid ""
-"Random colors according to category number (or layer number if 'layer=-1' is "
-"given)"
+#: ../vector/v.net.allpairs/main.c:74 ../vector/v.net.timetable/main.c:274
+#: ../vector/v.net.salesman/main.c:145 ../vector/v.net.spanningtree/main.c:59
+#: ../vector/v.net.bridge/main.c:60 ../vector/v.net.flow/main.c:70
+#: ../vector/v.net.alloc/main.c:81 ../vector/v.net.steiner/main.c:366
+#: ../vector/v.net.iso/main.c:90 ../vector/v.net/args.c:55
+#: ../vector/v.net.centrality/main.c:109 ../vector/v.net.components/main.c:83
+#: ../vector/v.net.distance/main.c:80 ../vector/v.net.path/main.c:56
+#: ../vector/v.net.connectivity/main.c:64 ../display/d.path/main.c:71
+msgid "Arc layer"
msgstr ""
-#: ../display/d.vect/main.c:308
-msgid "Use values from 'cats' option as feature id"
+#: ../vector/v.net.allpairs/main.c:80 ../vector/v.net.timetable/main.c:280
+#: ../vector/v.net.spanningtree/main.c:65 ../vector/v.net.bridge/main.c:66
+#: ../vector/v.net.flow/main.c:76 ../vector/v.net.alloc/main.c:86
+#: ../vector/v.net.iso/main.c:95 ../vector/v.net/args.c:62
+#: ../vector/v.net.centrality/main.c:115 ../vector/v.net.components/main.c:89
+#: ../vector/v.net.distance/main.c:92 ../vector/v.net.path/main.c:61
+#: ../vector/v.net.connectivity/main.c:70 ../display/d.path/main.c:76
+msgid "Node layer"
msgstr ""
-#: ../display/d.vect/main.c:312
-msgid "Use square root of the value of size_column"
+#: ../vector/v.net.allpairs/main.c:93 ../vector/v.net.timetable/main.c:288
+#: ../vector/v.net.salesman/main.c:157 ../vector/v.net.spanningtree/main.c:72
+#: ../vector/v.net.bridge/main.c:73 ../vector/v.net.flow/main.c:90
+#: ../vector/v.net.alloc/main.c:93 ../vector/v.net.iso/main.c:100
+#: ../vector/v.net.centrality/main.c:129 ../vector/v.net.components/main.c:96
+#: ../vector/v.net.distance/main.c:138 ../vector/v.net.connectivity/main.c:77
+msgid "Arc forward/both direction(s) cost column (number)"
msgstr ""
-#: ../display/d.vect/main.c:314
-msgid ""
-"This makes circle areas proportionate to the size_column values instead of "
-"circle radius"
+#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
+#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.timetable/main.c:275
+#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
+#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
+#: ../vector/v.net.spanningtree/main.c:60
+#: ../vector/v.net.spanningtree/main.c:66
+#: ../vector/v.net.spanningtree/main.c:73
+#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.bridge/main.c:61
+#: ../vector/v.net.bridge/main.c:67 ../vector/v.net.bridge/main.c:74
+#: ../vector/v.net.bridge/main.c:80 ../vector/v.net.bridge/main.c:87
+#: ../vector/v.net.flow/main.c:71 ../vector/v.net.flow/main.c:77
+#: ../vector/v.net.flow/main.c:91 ../vector/v.net.flow/main.c:97
+#: ../vector/v.net.flow/main.c:103 ../vector/v.net.centrality/main.c:110
+#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
+#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
+#: ../vector/v.net.components/main.c:84 ../vector/v.net.components/main.c:90
+#: ../vector/v.net.components/main.c:97 ../vector/v.net.components/main.c:103
+#: ../vector/v.net.components/main.c:110 ../vector/v.net.distance/main.c:81
+#: ../vector/v.net.distance/main.c:87 ../vector/v.net.distance/main.c:93
+#: ../vector/v.net.distance/main.c:139 ../vector/v.net.distance/main.c:145
+#: ../vector/v.net.distance/main.c:151 ../vector/v.net.connectivity/main.c:65
+#: ../vector/v.net.connectivity/main.c:71
+#: ../vector/v.net.connectivity/main.c:78
+#: ../vector/v.net.connectivity/main.c:84
+#: ../vector/v.net.connectivity/main.c:92
+msgid "Cost"
msgstr ""
-#: ../display/d.vect/main.c:334
-msgid "Region size is lower than minreg, nothing displayed"
+#: ../vector/v.net.allpairs/main.c:99 ../vector/v.net.timetable/main.c:295
+#: ../vector/v.net.bridge/main.c:79 ../vector/v.net.flow/main.c:96
+#: ../vector/v.net.alloc/main.c:99 ../vector/v.net.iso/main.c:104
+#: ../vector/v.net.centrality/main.c:135 ../vector/v.net.components/main.c:102
+#: ../vector/v.net.distance/main.c:144 ../vector/v.net.connectivity/main.c:83
+msgid "Arc backward direction cost column (number)"
msgstr ""
-#: ../display/d.vect/main.c:342
-msgid "Region size is greater than maxreg, nothing displayed"
+#: ../vector/v.net.allpairs/main.c:106 ../vector/v.net.timetable/main.c:302
+#: ../vector/v.net.spanningtree/main.c:78 ../vector/v.net.bridge/main.c:86
+#: ../vector/v.net.flow/main.c:102 ../vector/v.net.alloc/main.c:105
+#: ../vector/v.net.iso/main.c:108 ../vector/v.net.centrality/main.c:142
+#: ../vector/v.net.components/main.c:109 ../vector/v.net.distance/main.c:150
+#: ../vector/v.net.connectivity/main.c:91
+msgid "Node cost column (number)"
msgstr ""
-#: ../display/d.vect/main.c:355
-#, c-format
-msgid ""
-"The -%c flag and <%s> option cannot be used together, the -%c flag will be "
-"ignored!"
+#: ../vector/v.net.allpairs/main.c:112 ../vector/v.net.salesman/main.c:180
+#: ../vector/v.net.spanningtree/main.c:84 ../vector/v.net.alloc/main.c:118
+#: ../vector/v.net.steiner/main.c:396 ../vector/v.net.iso/main.c:128
+#: ../vector/v.net.centrality/main.c:188 ../vector/v.net.distance/main.c:156
+#: ../vector/v.net.path/main.c:103 ../display/d.path/main.c:123
+msgid "Use geodesic calculation for longitude-latitude locations"
msgstr ""
-#: ../display/d.vect/main.c:379 ../display/d.vect/main.c:385
-#, fuzzy, c-format
-msgid "Option <%s> must be > 0"
-msgstr "출력할 래스터맵"
+#: ../vector/v.net.allpairs/main.c:142 ../vector/v.net.spanningtree/main.c:113
+#: ../vector/v.net.centrality/main.c:222 ../vector/v.net.distance/main.c:189
+#: ../vector/v.net.path/main.c:121 ../display/d.path/main.c:181
+msgid "The current projection is not longitude-latitude"
+msgstr ""
-#: ../display/d.vect/main.c:389
-#, fuzzy, c-format
-msgid "%d error in cat option"
-msgid_plural "%d errors in cat option"
+#: ../vector/v.net.allpairs/main.c:182 ../vector/v.net.timetable/main.c:107
+#: ../vector/v.db.connect/main.c:336 ../vector/v.sample/main.c:190
+#: ../vector/v.net.flow/main.c:184 ../vector/v.net.centrality/main.c:270
+#: ../vector/v.net.components/main.c:193 ../vector/v.net.distance/main.c:266
+#: ../vector/v.net.path/path.c:113 ../vector/v.kcv/main.c:198
+msgid "Cannot create index"
+msgstr ""
-#: ../display/d.vect/main.c:405
+#: ../vector/v.net.allpairs/main.c:186 ../vector/v.net.timetable/main.c:112
+#: ../vector/v.net.flow/main.c:188 ../vector/v.net.centrality/main.c:274
+#: ../vector/v.net.components/main.c:197 ../vector/v.net.distance/main.c:270
+#: ../vector/v.net.path/path.c:117
+#, c-format
+msgid "Cannot grant privileges on table <%s>"
+msgstr ""
+#: ../vector/v.net.allpairs/main.c:207
#, fuzzy
-msgid "Plotting..."
+msgid "Writing node points..."
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:413
+#: ../vector/v.net.allpairs/main.c:241
#, fuzzy
-msgid ""
-"The bounding box of the map is outside the current region, nothing drawn"
+msgid "Collecting shortest paths..."
msgstr "출력할 래스터맵"
-#: ../display/d.vect/main.c:479
+#: ../vector/v.net.allpairs/main.c:295
#, fuzzy
-msgid "Rendering failed"
+msgid "Writing shortest paths..."
msgstr "출력할 래스터맵"
-#: ../display/d.vect/topo.c:18
-msgid ""
-"Unable to display topology, not available.Please try to rebuild topology "
-"using v.build or v.build.all."
+#: ../vector/v.in.dwg/main.c:84
+msgid "Converts DWG/DXF to GRASS vector map"
msgstr ""
-#: ../display/d.vect/area.c:37
+#: ../vector/v.in.dwg/main.c:87
#, fuzzy
-msgid ""
-"Unable to display areas, topology not available. Please try to rebuild "
-"topology using v.build or v.build.all."
+msgid "Name of DWG or DXF file"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/area.c:137
-#, fuzzy, c-format
-msgid "Invalid area %d skipped (not enough points)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.dwg/main.c:97
+msgid "List of layers to import"
+msgstr ""
-#: ../display/d.vect/area.c:236
-#, fuzzy, c-format
-msgid "%d invalid color rule for areas skipped"
-msgid_plural "%d invalid color rules for areas skipped"
+#: ../vector/v.in.dwg/main.c:102
+msgid "Invert selection by layers (don't import layers in list)"
+msgstr ""
-#: ../display/d.vect/label.c:33
+#: ../vector/v.in.dwg/main.c:106 ../vector/v.in.ascii/main.c:146
#, fuzzy
-msgid "Topology level required for drawing centroids for OGR layers"
+msgid "Create 3D vector map"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:62
-#, c-format
-msgid "Both color table and <%s> option detected. Color table will ignored."
+#: ../vector/v.in.dwg/main.c:110
+msgid "Write circles as points (centre)"
msgstr ""
-#: ../display/d.vect/shape.c:77
-#, c-format
-msgid ""
-"Color definition column ('%s') not a string. Column must be of form 'RRR:GGG:"
-"BBB' where RGB values range 0-255. You can use '%s' module to define color "
-"rules. Unable to colorize features."
+#: ../vector/v.in.dwg/main.c:114
+msgid "List available layers and exit"
msgstr ""
-#: ../display/d.vect/shape.c:86 ../display/d.vect/shape.c:109
-#: ../display/d.vect/shape.c:140 ../display/d.vect/shape.c:171
-#, fuzzy, c-format
-msgid "Unable to select data ('%s') from table"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.dwg/main.c:118
+msgid "Use numeric type for attribute \"layer\""
+msgstr ""
-#: ../display/d.vect/shape.c:94
-#, fuzzy
-msgid "Line width column not specified"
-msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:105
+#: ../vector/v.in.dwg/main.c:138
#, fuzzy, c-format
-msgid "Line width column ('%s') not a number"
+msgid "Unable to initialize OpenDWG Toolkit, error: %d: %s."
msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:125
-#, fuzzy
-msgid "Symbol size column not specified"
-msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:136
+#: ../vector/v.in.dwg/main.c:141
#, fuzzy, c-format
-msgid "Symbol size column ('%s') is not numeric"
+msgid "%s Cannot open %s"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:156
-#, fuzzy
-msgid "Symbol rotation column not specified"
-msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:167
+#: ../vector/v.in.dwg/main.c:149
#, fuzzy, c-format
-msgid "Symbol rotation column ('%s') is not numeric"
+msgid "Unable to open input file <%s>. Error %d: %s"
msgstr "출력할 래스터맵"
-#: ../display/d.vect/shape.c:194
-msgid ""
-"Vector map is not 3D. Unable to colorize features based on z-coordinates."
+#: ../vector/v.in.dwg/main.c:285
+#, c-format
+msgid "%d elements skipped (layer name was not in list)"
msgstr ""
-#: ../display/d.vect/shape.c:198
+#: ../vector/v.in.dwg/main.c:288
#, c-format
-msgid ""
-"Options <%s> and <%s> are mutually exclusive. Option <%s> will be ignored."
+msgid "%d elements processed"
msgstr ""
-#: ../display/d.vect/shape.c:341
-#, fuzzy, c-format
-msgid "Invalid negative value - feature %d with category %d"
-msgstr "출력할 래스터맵"
-#: ../display/d.vect/attr.c:28
-msgid "attrcol not specified, cannot display attributes"
+#: ../vector/v.type/main.c:41
+msgid "Changes type of vector features."
msgstr ""
-#: ../display/d.vect/attr.c:110 ../display/d.vect.chart/plot.c:84
-#: ../vector/v.in.db/main.c:190
-#, fuzzy, c-format
-msgid "Unable to open select cursor: '%s'"
-msgstr "출력할 래스터맵"
-#: ../display/d.vect/attr.c:129
-#, c-format
-msgid "No attribute found for cat %d: %s"
+#: ../vector/v.type/main.c:54
+msgid "Feature type to convert from"
msgstr ""
-#: ../display/d.geodesic/main.c:46
-msgid ""
-"Displays a geodesic line, tracing the shortest distance between two "
-"geographic points along a great circle, in a longitude/latitude data set."
+#: ../vector/v.type/main.c:62
+msgid "Feature type to convert to"
msgstr ""
-#: ../display/d.geodesic/main.c:69
-msgid "Text color or \"none\""
+#: ../vector/v.type/main.c:117
+msgid "Incompatible types"
msgstr ""
-#: ../display/d.where/main.c:48
-msgid ""
-"Identifies the geographic coordinates associated with point locations given "
-"in display coordinates."
+#: ../vector/v.in.dxf/read_dxf.c:57
+msgid "end of file while looking for HEADER"
msgstr ""
-#: ../display/d.where/main.c:58
-msgid "Display coordinates to convert"
-msgstr ""
-#: ../display/d.where/main.c:63
+#: ../vector/v.in.dxf/main.c:68
#, fuzzy
-msgid "File from which to read coordinates (\"-\" to read from stdin)"
+msgid "Converts file in DXF format to GRASS vector map."
msgstr "출력할 래스터맵"
-#: ../display/d.where/main.c:67
-msgid "Output lat/long in decimal degree"
+#: ../vector/v.in.dxf/main.c:72
+msgid "Ignore the map extent of DXF file"
msgstr ""
-#: ../display/d.where/main.c:72
-msgid "Output lat/long referenced to current ellipsoid"
+#: ../vector/v.in.dxf/main.c:80
+msgid "Import polyface meshes as 3D wire frame"
msgstr ""
-#: ../display/d.where/main.c:77
-msgid ""
-"Output lat/long referenced to WGS84 ellipsoid using datum transformation "
-"parameters defined in current location (if available)"
+#: ../vector/v.in.dxf/main.c:84
+msgid "List available DXF layers and exit"
msgstr ""
-#: ../display/d.where/main.c:83
-msgid "Output frame coordinates of current display monitor (percentage)"
+#: ../vector/v.in.dxf/main.c:85 ../vector/v.in.dxf/main.c:92
+#: ../vector/v.in.dxf/main.c:97 ../vector/v.in.dxf/main.c:110
+msgid "DXF layers"
msgstr ""
-#: ../display/d.where/main.c:91
-msgid "Ambiguous request for lat/long ellipsoids"
+#: ../vector/v.in.dxf/main.c:91
+msgid "Invert selection by DXF layers (don't import layers in list)"
msgstr ""
-#: ../display/d.where/main.c:94
-msgid "Please specify a lat/long ellipsoid with -l or -w"
+#: ../vector/v.in.dxf/main.c:96
+msgid "Import all objects into one layer"
msgstr ""
-#: ../display/d.where/main.c:136
-msgid ""
-"WGS84 output not possible as this location does not contain\n"
-msgstr ""
-#: ../display/d.where/where.c:29
-#, fuzzy, c-format
-msgid "Invalid coordinates <%s,%s>"
+#: ../vector/v.in.dxf/main.c:100
+#, fuzzy
+msgid "Path to input DXF file"
msgstr "출력할 래스터맵"
-#: ../display/d.fontlist/main.c:40
-msgid "Lists the available fonts."
+#: ../vector/v.in.dxf/main.c:109
+msgid "List of DXF layers to import (default: all)"
msgstr ""
-#: ../display/d.fontlist/main.c:44
-msgid "List fonts (default; provided for compatibility with d.font)"
+#: ../vector/v.in.dxf/main.c:124
+msgid "Please specify list of DXF layers to exclude"
msgstr ""
-#: ../display/d.fontlist/main.c:48 ../display/d.font/main.c:78
-msgid "List fonts verbosely"
-msgstr ""
+#: ../vector/v.in.dxf/main.c:128
+#, fuzzy, c-format
+msgid "Unable to open DXF file <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.text/main.c:141
-msgid ""
-"Draws text in the active display frame on the graphics monitor using the "
-"current font."
+#: ../vector/v.in.dxf/main.c:131
+msgid "Layer number: layer name / GRASS compliant name"
msgstr ""
-#: ../display/d.text/main.c:147
-msgid "Text to display"
+#: ../vector/v.in.dxf/main.c:165
+msgid "Building topology failed"
msgstr ""
-#: ../display/d.text/main.c:156
-msgid "Height of letters in percentage of available frame height"
+#: ../vector/v.in.dxf/main.c:171
+msgid "Failed to import DXF file!"
msgstr ""
-#: ../display/d.text/main.c:164
-msgid "Text color, either a standard GRASS color or R:G:B triplet"
+#: ../vector/v.in.dxf/layer_list.c:16
+#, c-format
+msgid "Layer %d: %s\n"
msgstr ""
-#: ../display/d.text/main.c:172
-msgid "Text background color, either a standard GRASS color or R:G:B triplet"
+#: ../vector/v.in.dxf/add_polyline.c:47
+msgid "vertices following flag missing"
msgstr ""
-#: ../display/d.text/main.c:181
-msgid "The screen line number on which text will begin to be drawn"
+#: ../vector/v.in.dxf/write_vect.c:52
+msgid "Entity handle truncated to 16 characters."
msgstr ""
-#: ../display/d.text/main.c:189
-msgid ""
-"Screen position at which text will begin to be drawn (percentage, [0,0] is "
-"lower left)"
+#: ../vector/v.in.dxf/write_vect.c:91
+msgid "No DXF layers found!"
msgstr ""
-#: ../display/d.text/main.c:197
-msgid "Text alignment"
+#: ../vector/v.in.dxf/write_vect.c:100
+msgid "Following DXF layers found:"
msgstr ""
-#: ../display/d.text/main.c:205
-msgid "Rotation angle in degrees (counter-clockwise)"
+#: ../vector/v.in.dxf/write_vect.c:104
+#, c-format
+msgid "Layer %d: %s"
msgstr ""
-#: ../display/d.text/main.c:212
-msgid "Line spacing"
-msgstr ""
+#: ../vector/v.in.dxf/write_vect.c:245
+#, fuzzy, c-format
+msgid "Unable to add database link for vector map <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.text/main.c:235
-msgid "Input file"
+#: ../vector/v.to.rast/do_lines.c:59 ../vector/v.to.rast/do_lines.c:67
+#: ../vector/v.to.rast3/main.c:144
+#, c-format
+msgid "No record for line (cat = %d)"
msgstr ""
-#: ../display/d.text/main.c:239
-msgid "Screen position in pixels ([0,0] is top left)"
+#: ../vector/v.to.rast/do_lines.c:73 ../vector/v.to.rast/do_areas.c:64
+msgid "Unable to use column specified"
msgstr ""
-#: ../display/d.text/main.c:243
-msgid "Screen position in geographic coordinates"
-msgstr ""
-#: ../display/d.text/main.c:247
-msgid "Use bold text"
-msgstr ""
-#: ../display/d.text/main.c:251
-msgid "Use radians instead of degrees for rotation"
-msgstr ""
-#: ../display/d.text/main.c:266
-msgid "Please choose only one placement method"
-msgstr ""
-#: ../display/d.text/main.c:327
-msgid "Invalid coordinates"
-msgstr ""
-#: ../display/d.text/main.c:371
+#: ../vector/v.to.rast/do_lines.c:133
#, c-format
-msgid ""
-"\n"
-"Please enter text instructions. Enter EOF (ctrl-d) on last line to quit\n"
+msgid "%d lines with varying height were not written to raster"
msgstr ""
-#: ../display/d.text/main.c:562
-#, c-format
-msgid "[%s]: No such color. Use '%s'"
-msgstr ""
-#: ../display/d.colortable/main.c:63
-msgid "Displays the color table associated with a raster map layer."
-msgstr ""
-#: ../display/d.colortable/main.c:67
+#: ../vector/v.to.rast/do_areas.c:34 ../vector/v.to.db/areas.c:28
#, fuzzy
-msgid "Name of raster map whose color table is to be displayed"
+msgid "Reading areas..."
msgstr "출력할 래스터맵"
-#: ../display/d.colortable/main.c:75
-msgid "Color of lines separating the colors of the color table"
+#: ../vector/v.to.rast/do_areas.c:50 ../vector/v.to.rast/do_areas.c:58
+#, c-format
+msgid "No record for area (cat = %d)"
msgstr ""
-#: ../display/d.colortable/main.c:81
-#, fuzzy
-msgid "Number of lines to appear in the color table"
+#: ../vector/v.to.rast/do_areas.c:79
+#, fuzzy, c-format
+msgid "Get area %d failed"
msgstr "출력할 래스터맵"
-#: ../display/d.colortable/main.c:87
-#, fuzzy
-msgid "Number of columns to appear in the color table"
-msgstr "출력할 래스터맵"
-#: ../display/d.colortable/main.c:92
-msgid "Don't draw a collar showing the NULL color in FP maps"
+#: ../vector/v.to.rast/do_areas.c:117
+msgid "Area without centroid (OK for island)"
msgstr ""
-#: ../display/d.colortable/main.c:114
-#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [lines] and drawing continuous color ramp"
+#: ../vector/v.to.rast/do_areas.c:127
+msgid "Area centroid without category"
msgstr ""
-#: ../display/d.colortable/main.c:128
-#, c-format
-msgid ""
-"<%s> is floating-point; ignoring [cols] and drawing continuous color ramp"
-msgstr ""
-#: ../display/d.colortable/main.c:139
+#: ../vector/v.to.rast/support.c:142 ../vector/v.to.rast/support.c:301
+#: ../vector/v.to.rast/support.c:454
#, fuzzy, c-format
-msgid "Range file for <%s> not available"
+msgid "Unknown column <%s> in table <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.info/main.c:35
-#, fuzzy
-msgid "Displays information about the active display monitor."
+#: ../vector/v.to.rast/support.c:146 ../vector/v.to.rast/support.c:305
+#: ../vector/v.to.rast/support.c:458 ../vector/v.to.rast/vect2rast.c:77
+#: ../vector/v.reclass/main.c:231
+#, fuzzy, c-format
+msgid "No records selected from table <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.info/main.c:37
-msgid "Display monitors are maintained by d.mon."
+#: ../vector/v.to.rast/support.c:163 ../vector/v.to.rast/support.c:330
+msgid "No records selected"
msgstr ""
-#: ../display/d.info/main.c:42
-msgid "Display screen rectangle (left, right, top, bottom)"
+#: ../vector/v.to.rast/support.c:176
+#, c-format
+msgid "Error in color definition column (%s) with cat %d: colorstring [%s]"
msgstr ""
-#: ../display/d.info/main.c:46
-msgid "Display screen dimensions (width, height)"
+#: ../vector/v.to.rast/support.c:179
+msgid "Color set to [200:200:200]"
msgstr ""
-#: ../display/d.info/main.c:50
-msgid "Display active frame rectangle"
+#: ../vector/v.to.rast/support.c:184
+#, c-format
+msgid "Error in color definition column (%s), with cat %d"
msgstr ""
-#: ../display/d.info/main.c:54
-msgid "Display screen rectangle of current region"
+#: ../vector/v.to.rast/support.c:273
+msgid "Label column was not specified, no labels will be written"
msgstr ""
-#: ../display/d.info/main.c:59
-msgid "Display geographic coordinates and resolution of entire screen"
+#: ../vector/v.to.rast/support.c:353 ../vector/v.to.rast/support.c:500
+#, c-format
+msgid "Column type (%s) not supported"
msgstr ""
-#: ../display/d.info/main.c:66
-msgid "No flag given"
+#: ../vector/v.to.rast/support.c:576 ../vector/v.to.rast/vect2rast.c:121
+#, c-format
+msgid "Unknown use type: %d"
msgstr ""
-#: ../display/d.northarrow/main.c:44
+#: ../vector/v.to.rast/vect2rast.c:36
#, fuzzy
-msgid "Displays a north arrow on the graphics monitor."
+msgid "Loading data..."
msgstr "출력할 래스터맵"
-#: ../display/d.northarrow/main.c:48
-msgid "North arrow style"
-msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:48 ../vector/v.colors/main.c:268
+#, fuzzy, c-format
+msgid "Vector map <%s> is not 3D"
+msgstr "출력할 래스터맵"
-#: ../display/d.northarrow/main.c:51 ../display/d.barscale/main.c:74
-msgid "Style"
+#: ../vector/v.to.rast/vect2rast.c:73
+#, c-format
+msgid "Column type (%s) not supported (did you mean 'labelcolumn'?)"
msgstr ""
-#: ../display/d.northarrow/main.c:61 ../display/d.barscale/main.c:108
-msgid "Screen coordinates of the rectangle's top-left corner"
-msgstr ""
+#: ../vector/v.to.rast/vect2rast.c:103
+#, fuzzy, c-format
+msgid "Unable to use column <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.northarrow/main.c:62 ../display/d.barscale/main.c:109
-msgid "(0,0) is lower-left of the display frame"
+#: ../vector/v.to.rast/vect2rast.c:132
+msgid "Unknown raster map type"
msgstr ""
-#: ../display/d.northarrow/main.c:70
-#, fuzzy
-msgid "Fill color"
+#: ../vector/v.to.rast/vect2rast.c:140
+#, fuzzy, c-format
+msgid "No areas selected from vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.northarrow/main.c:71
-msgid "black"
+#: ../vector/v.to.rast/vect2rast.c:156
+#, c-format
+msgid "Pass %d of %d:"
msgstr ""
-#: ../display/d.northarrow/main.c:86 ../display/d.barscale/main.c:132
-msgid "Font size"
+#: ../vector/v.to.rast/vect2rast.c:164
+#, c-format
+msgid "Problem processing areas from vector map <%s>, continuing..."
msgstr ""
-#: ../display/d.northarrow/main.c:87 ../display/d.northarrow/main.c:92
-#: ../display/d.barscale/main.c:65 ../display/d.barscale/main.c:124
-#: ../display/d.barscale/main.c:133
-msgid "Text"
+#: ../vector/v.to.rast/vect2rast.c:176
+#, c-format
+msgid "Problem processing lines from vector map <%s>, continuing..."
msgstr ""
-#: ../display/d.northarrow/main.c:91
-msgid "Draw the symbol without text"
+#: ../vector/v.to.rast/vect2rast.c:201
+#, fuzzy
+msgid "Creating support files for raster map..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.to.rast/vect2rast.c:208
+msgid "Color can be updated from database only if use=attr"
msgstr ""
-#: ../display/d.northarrow/draw_n_arrow.c:80
-#: ../display/d.northarrow/draw_n_arrow.c:139
-msgid "Could not parse symbol"
+#: ../vector/v.to.rast/vect2rast.c:228
+#, c-format
+msgid "Converted areas: %d of %d"
msgstr ""
-#: ../display/d.northarrow/draw_n_arrow.c:157
-#: ../display/d.barscale/draw_scale.c:563
+#: ../vector/v.to.rast/vect2rast.c:230
#, c-format
-msgid "Could not read symbol \"%s\""
+msgid "Converted points/lines: %d of %d"
msgstr ""
-#: ../display/d.profile/main.c:68
-#, fuzzy, c-format
-msgid "Unable to read range for %s"
+#: ../vector/v.to.rast/main.c:47
+#, fuzzy
+msgid "rasterization"
msgstr "출력할 래스터맵"
-#: ../display/d.profile/main.c:79
-#, fuzzy, c-format
-msgid "Unable to read FP range for %s"
+#: ../vector/v.to.rast/main.c:48
+#, fuzzy
+msgid "Converts (rasterize) a vector map into a raster map."
msgstr "출력할 래스터맵"
-#: ../display/d.profile/main.c:194
-msgid "Plots profile of a transect."
-msgstr ""
+#: ../vector/v.to.rast/main.c:73
+#, fuzzy
+msgid "Source of raster values"
+msgstr "출력할 래스터맵"
-#: ../display/d.profile/main.c:198
+#: ../vector/v.to.rast/main.c:77
#, fuzzy
-msgid "Raster map to be profiled"
+msgid "read values from attribute table"
msgstr "출력할 래스터맵"
-#: ../display/d.profile/main.c:210
-msgid "Use map's range recorded range"
-msgstr ""
-#: ../display/d.profile/main.c:259
+#: ../vector/v.to.rast/main.c:78 ../vector/v.colors/main.c:74
#, fuzzy
-msgid "At least two points are required"
+msgid "use category values"
msgstr "출력할 래스터맵"
-#: ../display/d.what.rast/what.c:56
-msgid "You are clicking outside the map"
+#: ../vector/v.to.rast/main.c:79
+msgid "use value specified by value option"
msgstr ""
-#: ../display/d.what.rast/main.c:54
-msgid ""
-"Allows the user to interactively query the category contents of multiple "
-"raster map layers at user specified locations within the current geographic "
-"region."
+#: ../vector/v.to.rast/main.c:80
+msgid "use z coordinate (points or contours only)"
msgstr ""
-#: ../display/d.what.rast/main.c:75
-msgid "Field separator (terse mode only)"
+#: ../vector/v.to.rast/main.c:81
+msgid "output as flow direction (lines only)"
msgstr ""
-#: ../display/d.what.rast/main.c:80 ../display/d.what.vect/main.c:68
-msgid "Identify just one location"
-msgstr ""
-#: ../display/d.what.rast/main.c:84 ../display/d.what.vect/main.c:81
-msgid "Terse output. For parsing by programs"
-msgstr ""
-#: ../display/d.what.rast/main.c:89
-msgid "Print out col/row for the entire map in grid resolution of the region"
-msgstr ""
-#: ../display/d.what.rast/main.c:99 ../display/d.what.vect/main.c:145
-#: ../display/d.extract/main.c:79 ../display/d.measure/main.c:85
-#: ../display/d.zoom/main.c:218 ../display/d.zoom/redraw.c:38
-#: ../imagery/i.class/main.c:131 ../imagery/i.points/main.c:124
-#: ../vector/v.label/main.c:233
-msgid "No graphics device selected"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:96 ../display/d.rast.num/main.c:76
+#: ../vector/v.to.rast/main.c:87
#, fuzzy
-msgid "map annotations"
+msgid "Name of column for 'attr' parameter (data type must be numeric)"
msgstr "출력할 래스터맵"
-#: ../display/d.rast.arrow/main.c:99
-msgid ""
-"Draws arrows representing cell aspect direction for a raster map containing "
-"aspect data."
+#: ../vector/v.to.rast/main.c:93
+msgid "Name of color definition column (with RRR:GGG:BBB entries)"
msgstr ""
-#: ../display/d.rast.arrow/main.c:103
-msgid "Name of raster aspect map to be displayed"
+#: ../vector/v.to.rast/main.c:99
+msgid "Name of column used as raster category labels"
msgstr ""
-#: ../display/d.rast.arrow/main.c:111
-msgid "Type of existing raster aspect map"
+#: ../vector/v.to.rast/main.c:108
+msgid "Raster value (for use=val)"
msgstr ""
-#: ../display/d.rast.arrow/main.c:119
-msgid "Color for drawing arrows"
+#: ../vector/v.to.rast/main.c:120
+msgid "Create densified lines (default: thin lines)"
msgstr ""
-#: ../display/d.rast.arrow/main.c:127
-msgid "Color for drawing grid or \"none\""
+#: ../vector/v.to.rast/main.c:121
+msgid ""
+"All cells touched by the line will be set, not only those on the render path"
msgstr ""
-#: ../display/d.rast.arrow/main.c:136
-msgid "Color for drawing X's (null values)"
+#: ../vector/v.to.rast/main.c:134
+msgid "Column parameter missing (or use value parameter)"
msgstr ""
-#: ../display/d.rast.arrow/main.c:145
-msgid "Color for showing unknown information"
+#: ../vector/v.to.rast/main.c:139
+msgid "Column parameter cannot be combined with use of category values option"
msgstr ""
-#: ../display/d.rast.arrow/main.c:153
-msgid "Draw arrow every Nth grid cell"
+#: ../vector/v.to.rast/main.c:144
+msgid "Column parameter cannot be combined with use of value option"
msgstr ""
-#: ../display/d.rast.arrow/main.c:162
-msgid "Raster map containing values used for arrow length"
+#: ../vector/v.to.rast/main.c:149
+msgid "Column parameter cannot be combined with use of z coordinate"
msgstr ""
-#: ../display/d.rast.arrow/main.c:169
-msgid "Scale factor for arrows (magnitude map)"
+#: ../vector/v.to.rast/main.c:155
+#, c-format
+msgid "Unknown option '%s'"
msgstr ""
-#: ../display/d.rast.arrow/main.c:173 ../display/d.rast.num/main.c:106
-msgid "Align grids with raster cells"
+#: ../vector/v.voronoi/skeleton.c:293 ../vector/v.voronoi/skeleton.c:400
+#, c-format
+msgid "Pass %d"
msgstr ""
-#: ../display/d.rast.arrow/main.c:205
-msgid "Illegal value for scale factor"
+#: ../vector/v.voronoi/skeleton.c:509
+msgid "Node is outside any input area"
msgstr ""
-#: ../display/d.rast.arrow/main.c:209
-msgid "Illegal value for skip factor"
-msgstr ""
+#: ../vector/v.voronoi/main.c:125 ../vector/v.delaunay/main.c:87
+#, fuzzy
+msgid "triangulation"
+msgstr "출력할 래스터맵"
-#: ../display/d.rast.arrow/main.c:214
-msgid "Magnitude is only supported for GRASS and compass aspect maps."
+#: ../vector/v.voronoi/main.c:126
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
msgstr ""
-#: ../display/d.rast.arrow/main.c:219
-msgid "Scale option requires magnitude_map"
-msgstr ""
-#: ../display/d.rast.arrow/main.c:272
+#: ../vector/v.voronoi/main.c:140
#, fuzzy
-msgid "Problem reading range file"
+msgid "Factor for output smoothness"
msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:152 ../display/d.what.vect/what.c:154
-#: ../vector/v.what/what.c:201
-#, c-format
-msgid "Nothing Found.\n"
+#: ../vector/v.voronoi/main.c:141
+msgid ""
+"Applies to input areas only. Smaller values produce smoother output but can "
+"cause numerical instability."
msgstr ""
-#: ../display/d.what.vect/what.c:213
-#, c-format
-msgid "Line: %d Type: %s Left: %d Right: %d "
+#: ../vector/v.voronoi/main.c:148
+msgid "Maximum dangle length of skeletons"
msgstr ""
-#: ../display/d.what.vect/what.c:217 ../vector/v.what/what.c:263
-#: ../vector/v.what/what.c:319
-#, c-format
-msgid "Length: %f\n"
+#: ../vector/v.voronoi/main.c:149
+msgid ""
+"Applies only to skeleton extraction. Default = -1 will extract the center "
+"line."
msgstr ""
-#: ../display/d.what.vect/what.c:234
-#, c-format
-msgid " Node[%d]: %d Number of lines: %d Coordinates: %.6f, %.6f, %.6f\n"
+#: ../vector/v.voronoi/main.c:155
+msgid "Create Voronoi diagram for input areas"
msgstr ""
-#: ../display/d.what.vect/what.c:243
-#, c-format
-msgid " Line: %5d Angle: %.8f\n"
+#: ../vector/v.voronoi/main.c:160
+msgid "Extract skeletons for input areas"
msgstr ""
-#: ../display/d.what.vect/what.c:252
-#, c-format
-msgid "length %f\n"
+#: ../vector/v.voronoi/main.c:165
+msgid "Output tessellation as a graph (lines), not areas"
msgstr ""
-#: ../display/d.what.vect/what.c:272 ../vector/v.what/what.c:333
-#, c-format
-msgid "Point height: %f\n"
-msgstr ""
+#: ../vector/v.voronoi/main.c:181
+#, fuzzy, c-format
+msgid "Option '%s' is too small, set to %g"
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:290 ../vector/v.what/what.c:350
-#, c-format
-msgid "Line height: %f\n"
-msgstr ""
+#: ../vector/v.voronoi/main.c:225
+#, fuzzy, c-format
+msgid "Voronoi triangulation for %d point..."
+msgid_plural "Voronoi triangulation for %d points..."
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:299
-#, c-format
-msgid "Line height min: %f max: %f\n"
-msgstr ""
+#: ../vector/v.voronoi/main.c:229 ../vector/v.delaunay/in_out.c:93
+#, fuzzy
+msgid "Writing edges..."
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:315
-#, c-format
-msgid "Area height: %f\n"
+#: ../vector/v.voronoi/main.c:238
+msgid "Thin skeletons ..."
msgstr ""
-#: ../display/d.what.vect/what.c:324
-#, c-format
-msgid "Area\n"
-msgstr ""
+#: ../vector/v.voronoi/main.c:395
+#, fuzzy
+msgid "No table"
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:346
-#, c-format
-msgid "Area: %d Number of isles: %d\n"
+#: ../vector/v.voronoi/main.c:410
+msgid "Cannot copy table"
msgstr ""
-#: ../display/d.what.vect/what.c:351
+#: ../vector/v.voronoi/sw_main.c:188
#, c-format
-msgid " Isle[%d]: %d\n"
-msgstr ""
+msgid "Found %d point/centroid in <%s>, but at least 2 are needed"
+msgid_plural "Found %d points/centroids in <%s>, but at least 2 are needed"
+msgstr[0] ""
+msgstr[1] ""
-#: ../display/d.what.vect/what.c:358
-#, c-format
-msgid "Island: %d In area: %d\n"
+#: ../vector/v.voronoi/sw_main.c:410 ../vector/v.voronoi/sw_main.c:436
+msgid "All boundaries in the list should be valid"
msgstr ""
-#: ../display/d.what.vect/what.c:365 ../display/d.what.vect/what.c:373
-#, c-format
-msgid "Size - Sq Meters: %.3f\t\tHectares: %.3f\n"
+#: ../vector/v.voronoi/sw_main.c:416 ../vector/v.voronoi/sw_main.c:442
+msgid "Boundary is degenerate"
msgstr ""
-#: ../display/d.what.vect/what.c:369 ../display/d.what.vect/what.c:377
+#: ../vector/v.voronoi/sw_main.c:468
#, c-format
-msgid " Acres: %.3f\t\tSq Miles: %.4f\n"
-msgstr ""
+msgid "Found %d vertex in <%s>, but at least 2 are needed"
+msgid_plural "Found %d vertices in <%s>, but at least 2 are needed"
+msgstr[0] ""
+msgstr[1] ""
-#: ../display/d.what.vect/what.c:400
-#, c-format
-msgid ""
-"Layer: %d\n"
-"category: %d\n"
+#: ../vector/v.voronoi/clean_topo.c:20
+msgid "Searching for topology errors..."
msgstr ""
-#: ../display/d.what.vect/what.c:425
-#, c-format
-msgid ""
-"driver: %s\n"
-"database: %s\n"
-"table: %s\n"
-"key column: %s\n"
-msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:78
+#, fuzzy
+msgid "Cleaning output topology"
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:479
-#, c-format
-msgid ""
-"\n"
-"Click mouse button on desired location\n"
-"\n"
-msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:87 ../vector/v.in.ogr/main.c:1274
+#: ../vector/v.buffer/main.c:743
+#, fuzzy
+msgid "Removing dangles..."
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:484
-#, c-format
-msgid "Buttons\n"
-msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:89 ../vector/v.in.ogr/main.c:1289
+#: ../vector/v.buffer/main.c:746
+#, fuzzy
+msgid "Removing bridges..."
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:485
-#, c-format
-msgid " Left: what's here\n"
-msgstr ""
+#: ../vector/v.voronoi/clean_topo.c:115
+#, fuzzy
+msgid "Removing incorrect boundaries from output"
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/what.c:486
-#, c-format
-msgid " Right: quit\n"
+#: ../vector/v.in.ogr/main.c:134
+#, fuzzy
+msgid "Imports vector data into a GRASS vector map using OGR library."
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/main.c:140
+msgid "OGR datasource name"
msgstr ""
-#: ../display/d.what.vect/main.c:61
+#: ../vector/v.in.ogr/main.c:141
msgid ""
-"Allows the user to interactively query a vector map layer at user-selected "
-"locations within the current geographic region."
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing shapefiles\n"
+"\t\tMapInfo File: directory containing mapinfo files"
msgstr ""
-#: ../display/d.what.vect/main.c:77
-msgid "Name of existing vector map"
+#: ../vector/v.in.ogr/main.c:151
+msgid "OGR layer name. If not given, all available layers are imported"
msgstr ""
-#: ../display/d.what.vect/main.c:86
-msgid "Print information as plain text to terminal window"
+#: ../vector/v.in.ogr/main.c:153
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name"
msgstr ""
-#: ../display/d.what.vect/main.c:90 ../vector/v.what/main.c:88
-msgid "Print topological information (debugging)"
+#: ../vector/v.in.ogr/main.c:181
+msgid "Minimum size of area to be imported (square units)"
msgstr ""
-#: ../display/d.what.vect/main.c:94
-msgid "Open form in edit mode"
+#: ../vector/v.in.ogr/main.c:183
+msgid "Smaller areas and islands are ignored. Should be greater than snap^2"
msgstr ""
-#: ../display/d.what.vect/main.c:136
-#, c-format
-msgid "%s: You must build topology on vector map"
+#: ../vector/v.in.ogr/main.c:189
+msgid "Optionally change default input type"
msgstr ""
-#: ../display/d.what.vect/main.c:139
-msgid "Building spatial index..."
-msgstr ""
+#: ../vector/v.in.ogr/main.c:193
+#, fuzzy
+msgid "import area centroids as points"
+msgstr "출력할 래스터맵"
-#: ../display/d.what.vect/openvect.c:11
-#, c-format
-msgid "warning: %s - vector map not found\n"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:194
+#, fuzzy
+msgid "import area boundaries as lines"
+msgstr "출력할 래스터맵"
-#: ../display/d.barscale/main.c:56
+#: ../vector/v.in.ogr/main.c:195
#, fuzzy
-msgid "Displays a barscale on the graphics monitor."
+msgid "import lines as area boundaries"
msgstr "출력할 래스터맵"
-#: ../display/d.barscale/main.c:60
-msgid "Use feet/miles instead of meters"
-msgstr ""
-#: ../display/d.barscale/main.c:64
-msgid "Draw the scale bar without text"
-msgstr ""
-#: ../display/d.barscale/main.c:69
+#: ../vector/v.in.ogr/main.c:196
#, fuzzy
-msgid "Type of barscale to draw"
+msgid "import points as centroids"
msgstr "출력할 래스터맵"
-#: ../display/d.barscale/main.c:88
-msgid "Classic style"
+#: ../vector/v.in.ogr/main.c:205 ../vector/v.overlay/main.c:133
+msgid "Snapping threshold for boundaries"
msgstr ""
-#: ../display/d.barscale/main.c:89
-msgid "Line style"
+#: ../vector/v.in.ogr/main.c:206
+msgid "'-1' for no snap"
msgstr ""
-#: ../display/d.barscale/main.c:90
+#: ../vector/v.in.ogr/main.c:221
+msgid ""
+"List of column names to be used instead of original names, first is used for "
+"category column"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:230
#, fuzzy
-msgid "Solid style"
+msgid "Encoding value for attribute data"
msgstr "출력할 래스터맵"
-#: ../display/d.barscale/main.c:91
-msgid "Hollow style"
+#: ../vector/v.in.ogr/main.c:232
+msgid "Overrides encoding interpretation, useful when importing ESRI Shapefile"
msgstr ""
-#: ../display/d.barscale/main.c:92
+#: ../vector/v.in.ogr/main.c:240
#, fuzzy
-msgid "Full checker style"
+msgid "Name of column used for categories"
msgstr "출력할 래스터맵"
-#: ../display/d.barscale/main.c:93
-msgid "Part checker style"
+#: ../vector/v.in.ogr/main.c:242
+msgid ""
+"If not given, categories are generated as unique values and stored in 'cat' "
+"column"
msgstr ""
-#: ../display/d.barscale/main.c:94
-msgid "Mixed checker style"
+#: ../vector/v.in.ogr/main.c:248
+msgid "List supported OGR formats and exit"
msgstr ""
-#: ../display/d.barscale/main.c:95
-msgid "Tail checker style"
+#: ../vector/v.in.ogr/main.c:254
+msgid "List available OGR layers in data source and exit"
msgstr ""
-#: ../display/d.barscale/main.c:96
-msgid "Up ticks style"
+#: ../vector/v.in.ogr/main.c:261
+msgid "Do not clean polygons (not recommended)"
msgstr ""
-#: ../display/d.barscale/main.c:97
-msgid "Down ticks style"
+#: ../vector/v.in.ogr/main.c:266
+msgid "Force 2D output even if input is 3D"
msgstr ""
-#: ../display/d.barscale/main.c:98
-msgid "Both ticks style"
+#: ../vector/v.in.ogr/main.c:267 ../vector/v.out.postgis/args.c:78
+#: ../vector/v.out.ogr/args.c:115
+msgid "Useful if input is 3D but all z coordinates are identical"
msgstr ""
-#: ../display/d.barscale/main.c:99
-msgid "Arrow ends style"
+#: ../vector/v.in.ogr/main.c:293
+msgid "Change column names to lowercase characters"
msgstr ""
-#: ../display/d.barscale/main.c:112
-#, fuzzy
-msgid "Bar scale and text color"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/main.c:299
+msgid ""
+"Create the location specified by the \"location\" parameter and exit. Do not "
+"import the vector data."
+msgstr ""
-#: ../display/d.barscale/main.c:116
-msgid "Background color (drawn behind the bar)"
+#: ../vector/v.in.ogr/main.c:318
+msgid "Available OGR Drivers:"
msgstr ""
-#: ../display/d.barscale/main.c:121
-#, fuzzy
-msgid "Text position"
+#: ../vector/v.in.ogr/main.c:349
+msgid ""
+"Database not defined, please check default connection settings by db.connect"
+msgstr ""
+#: ../vector/v.in.ogr/main.c:418
+#, fuzzy, c-format
+msgid "Unable to open data source <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.barscale/main.c:141
+#: ../vector/v.in.ogr/main.c:427
#, c-format
-msgid "%s does not work with a latitude-longitude location"
+msgid "Encoding value not supported by OGR driver <%s>"
msgstr ""
-#: ../display/d.barscale/main.c:184 ../display/d.barscale/main.c:201
-#: ../display/d.barscale/draw_scale.c:211
-msgid "Programmer error"
+#: ../vector/v.in.ogr/main.c:436
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layers:"
msgstr ""
-#: ../display/d.histogram/main.c:85
-#, fuzzy
-msgid "histogram"
+#: ../vector/v.in.ogr/main.c:475 ../vector/v.external/main.c:133
+#, fuzzy, c-format
+msgid "Layer <%s> not available"
msgstr "출력할 래스터맵"
-#: ../display/d.histogram/main.c:88
-msgid ""
-"Displays a histogram in the form of a pie or bar chart for a user-specified "
-"raster map."
-msgstr ""
-#: ../display/d.histogram/main.c:92
+#: ../vector/v.in.ogr/main.c:491
#, fuzzy
-msgid "Raster map for which histogram will be displayed"
+msgid "No OGR layers available"
msgstr "출력할 래스터맵"
-#: ../display/d.histogram/main.c:96
-msgid "Indicate if a pie or bar chart is desired"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:494
+#, fuzzy, c-format
+msgid "All available OGR layers will be imported into vector map <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.histogram/main.c:105
-msgid "Color for text and axes"
+#: ../vector/v.in.ogr/main.c:547
+msgid "The region flag is applied only to the first OGR layer"
msgstr ""
-#: ../display/d.histogram/main.c:113
-msgid "Indicate if cell counts or map areas should be displayed"
+#: ../vector/v.in.ogr/main.c:554
+msgid "The current region does not overlap with OGR input. Nothing to import."
msgstr ""
-#: ../display/d.histogram/main.c:123
-msgid "Number of steps to divide the data range into (fp maps only)"
+#: ../vector/v.in.ogr/main.c:581
+msgid "The 'spatial' option is applied only to the first OGR layer"
msgstr ""
-#: ../display/d.histogram/main.c:130
-msgid "Display information for null cells"
+#: ../vector/v.in.ogr/main.c:612
+msgid ""
+"The 'spatial' parameters do not overlap with OGR input. Nothing to import."
msgstr ""
-#: ../display/d.histogram/main.c:134
-msgid "Gather the histogram quietly"
+#: ../vector/v.in.ogr/main.c:646
+msgid "The 'where' option is applied only to the first OGR layer"
msgstr ""
-#: ../display/d.histogram/main.c:139
-msgid "Report for ranges defined in cats file (fp maps only)"
+#: ../vector/v.in.ogr/main.c:820
+#, c-format
+msgid "Check if OGR layer <%s> contains polygons..."
msgstr ""
-#: ../display/d.histogram/main.c:163
+#: ../vector/v.in.ogr/main.c:844
#, c-format
-msgid "Invalid number of steps: %s"
+msgid "Boundary splitting distance in map units: %G"
msgstr ""
-#: ../display/d.histogram/main.c:168
-msgid "When -C flag is set, the nsteps argument is ignored"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:872 ../vector/v.overlay/main.c:217
+#: ../vector/v.buffer/main.c:393
+#, fuzzy
+msgid "Unable to create temporary vector map"
+msgstr "출력할 래스터맵"
-#: ../display/d.rast.num/main.c:79
-msgid ""
-"Overlays cell category values on a raster map displayed in the active "
-"graphics frame."
-msgstr ""
+#: ../vector/v.in.ogr/main.c:874
+#, fuzzy, c-format
+msgid "Using temporary vector <%s>"
+msgstr "출력할 래스터맵"
-#: ../display/d.rast.num/main.c:87
-msgid "Color for drawing grid, or \"none\""
-msgstr ""
+#: ../vector/v.in.ogr/main.c:904
+#, fuzzy, c-format
+msgid "Key column '%s' not found"
+msgstr "출력할 래스터맵"
-#: ../display/d.rast.num/main.c:92
-msgid "Color for drawing text"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:912
+#, fuzzy, c-format
+msgid "Key column '%s' is not integer"
+msgstr "출력할 래스터맵"
-#: ../display/d.rast.num/main.c:110
-msgid "Get text color from cell color value"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:976
+#, fuzzy, c-format
+msgid "Column name <%s> renamed to <%s>"
+msgstr "출력할 래스터맵"
-#. GTC %s will be replaced by strings "X rows" and "Y cols"
-#: ../display/d.rast.num/main.c:176
+#: ../vector/v.in.ogr/main.c:1000
#, c-format
-msgid ""
-"Current region size: %s X %s\n"
-"Your current region setting may be too large. Cells displayed on your "
-"graphics window may be too small for cell category number to be visible."
+msgid "Writing column <%s> with fixed length %d chars (may be truncated)"
msgstr ""
-#: ../display/d.rast.num/main.c:181
-#, fuzzy, c-format
-msgid "%d col"
-msgid_plural "%d cols"
-#: ../display/d.rast.num/main.c:184
-msgid "Aborting (region larger then 200 rows X 200 cols is not allowed)"
-msgstr ""
-#: ../display/d.font/main.c:48
+#: ../vector/v.in.ogr/main.c:1023
+#, c-format
msgid ""
-"Selects the font in which text will be displayed on the user's graphics "
-"monitor."
+"Width for column %s set to 255 (was not specified by OGR), some strings may "
+"be truncated!"
msgstr ""
-#: ../display/d.font/main.c:56
-msgid "Choose new current font"
-msgstr ""
-#: ../display/d.font/main.c:62
-msgid "Path to Freetype-compatible font including file name"
-msgstr ""
-#: ../display/d.font/main.c:70
-msgid "Character encoding"
-msgstr ""
-#: ../display/d.font/main.c:74
-msgid "List fonts"
-msgstr ""
-#: ../display/d.font/main.c:105
-#, fuzzy, c-format
-msgid "Unable to access font path %s: %s"
-msgstr "출력할 래스터맵"
-#: ../display/d.font/main.c:109
+#: ../vector/v.in.ogr/main.c:1035
#, c-format
-msgid "Font path %s is not a file"
+msgid "Writing column %s with fixed length %d chars (may be truncated)"
msgstr ""
-#: ../display/d.font/main.c:126
+#: ../vector/v.in.ogr/main.c:1039
#, c-format
-msgid ""
-"Font name <%s> is invalid. Check font name or consider running 'g.mkfontcap'"
+msgid "Column type not supported (%s)"
msgstr ""
-#: ../display/d.mon/start.c:68
+#: ../vector/v.in.ogr/main.c:1082
#, fuzzy, c-format
-msgid "Monitor <%s> already running"
+msgid "Importing %d features (OGR layer <%s>)..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/start.c:78
+#: ../vector/v.in.ogr/main.c:1190
#, fuzzy, c-format
-msgid "Unable to create file '%s'"
+msgid "%d %s without geometry skipped"
msgstr "출력할 래스터맵"
-#: ../display/d.mon/start.c:109
-#, c-format
-msgid "Staring monitor <%s> with env file '%s'"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1217
+#, fuzzy
+msgid "Cleaning polygons"
+msgstr "출력할 래스터맵"
-#: ../display/d.mon/stop.c:18 ../display/d.mon/select.c:30
+#: ../vector/v.in.ogr/main.c:1221
#, fuzzy, c-format
-msgid "Monitor <%s> is not running"
+msgid "Snapping boundaries (threshold = %.3e)..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/stop.c:37
+#: ../vector/v.in.ogr/main.c:1235 ../vector/v.buffer/main.c:722
#, fuzzy
-msgid "Env file not found"
+msgid "Breaking polygons..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/stop.c:55
+#: ../vector/v.in.ogr/main.c:1240 ../vector/v.in.ogr/main.c:1254
+#: ../vector/v.overlay/area_area.c:113 ../vector/v.buffer/main.c:725
+#: ../vector/v.buffer/main.c:732 ../vector/v.delaunay/main.c:144
#, fuzzy
-msgid "PID file not found"
+msgid "Removing duplicates..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:41
-msgid "Controls graphics display monitors from the command line."
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1250 ../vector/v.buffer/main.c:729
+#, fuzzy
+msgid "Breaking boundaries..."
+msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:46
+#: ../vector/v.in.ogr/main.c:1258 ../vector/v.overlay/area_area.c:116
#, fuzzy
-msgid "Name of monitor to start"
+msgid "Cleaning boundaries at nodes..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:48 ../display/d.mon/main.c:55
-#: ../display/d.mon/main.c:62 ../display/d.mon/main.c:115
-#: ../display/d.mon/main.c:120
-msgid "Manage"
-msgstr ""
+#: ../vector/v.in.ogr/main.c:1265
+#, fuzzy
+msgid "Merging boundaries..."
+msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:53
+#: ../vector/v.in.ogr/main.c:1270
#, fuzzy
-msgid "Name of monitor to stop"
+msgid "Changing boundary dangles to lines..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:60
+#: ../vector/v.in.ogr/main.c:1283
#, fuzzy
-msgid "Name of monitor to select"
+msgid "Changing boundary bridges to lines..."
msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:66
-msgid "Width for display monitor if not set by GRASS_WIDTH"
+#: ../vector/v.in.ogr/main.c:1311 ../vector/v.category/main.c:364
+#: ../vector/v.delaunay/main.c:172
+#, fuzzy
+msgid "Unable to calculate area centroid"
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/main.c:1327
+#, fuzzy, c-format
+msgid "Finding centroids for OGR layer <%s>..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/main.c:1351 ../vector/v.overlay/area_area.c:218
+#, fuzzy
+msgid "Writing centroids..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/main.c:1394
+#, c-format
+msgid ""
+"%d areas represent more (overlapping) features, because polygons overlap in "
+"input layer(s). Such areas are linked to more than 1 row in attribute table. "
+"The number of features for those areas is stored as category in layer %d"
msgstr ""
-#: ../display/d.mon/main.c:67
-msgid "Default value: 640"
+#: ../vector/v.in.ogr/main.c:1404
+#, c-format
+msgid "%d input polygons\n"
msgstr ""
-#: ../display/d.mon/main.c:74
-msgid "Height for display monitor if not set by GRASS_HEIGHT"
+#: ../vector/v.in.ogr/main.c:1405
+#, c-format
+msgid "%d input polygons"
msgstr ""
-#: ../display/d.mon/main.c:75
-msgid "Default value: 480"
+#: ../vector/v.in.ogr/main.c:1408
+#, c-format
+msgid "Total area: %G (%d areas)\n"
msgstr ""
-#: ../display/d.mon/main.c:82
-msgid "Dimensions of display monitor versus current size"
+#: ../vector/v.in.ogr/main.c:1409
+#, c-format
+msgid "Total area: %G (%d areas)"
msgstr ""
-#: ../display/d.mon/main.c:83
-msgid "Example: resolution=2 enlarge display monitor twice to 1280x960"
+#: ../vector/v.in.ogr/main.c:1412
+#, c-format
+msgid "Overlapping area: %G (%d areas)\n"
msgstr ""
-#: ../display/d.mon/main.c:93
-#, fuzzy
-msgid "Name for output file (when starting new monitor)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/main.c:1415
+#, c-format
+msgid "Overlapping area: %G (%d areas)"
+msgstr ""
-#: ../display/d.mon/main.c:94
-msgid "Ignored for 'wx' monitors"
+#: ../vector/v.in.ogr/main.c:1420
+#, c-format
+msgid "Area without category: %G (%d areas)\n"
msgstr ""
-#: ../display/d.mon/main.c:99
-msgid "List running monitors and exit"
+#: ../vector/v.in.ogr/main.c:1423
+#, c-format
+msgid "Area without category: %G (%d areas)"
msgstr ""
-#: ../display/d.mon/main.c:104
-msgid "Print name of currently selected monitor and exit"
+#: ../vector/v.in.ogr/main.c:1493
+msgid "Errors were encountered during the import"
msgstr ""
-#: ../display/d.mon/main.c:109
-msgid "Print commands for currently selected monitor and exit"
+#: ../vector/v.in.ogr/main.c:1496
+#, c-format
+msgid "Try to import again, snapping with at least %g: 'snap=%g'"
msgstr ""
-#: ../display/d.mon/main.c:114
-msgid "Do not automatically select when starting"
+#: ../vector/v.in.ogr/main.c:1500
+#, c-format
+msgid "Try to import again, snapping with %g: 'snap=%g'"
msgstr ""
-#: ../display/d.mon/main.c:119
-#, fuzzy
-msgid "Release and stop currently selected monitor and exit"
+#: ../vector/v.in.ogr/main.c:1518
+#, fuzzy, c-format
+msgid "Unable to drop table: '%s'"
msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:124
+#: ../vector/v.in.ogr/main.c:1557
+msgid ""
+"Input data contains 3D features. Created vector is 2D only, disable -2 flag "
+"to import 3D vector."
+msgstr ""
+#: ../vector/v.in.ogr/geom.c:195 ../vector/v.in.ogr/geom.c:216
#, fuzzy
-msgid "Disable true colors"
+msgid "Unable to read part of geometry"
msgstr "출력할 래스터맵"
-#: ../display/d.mon/main.c:129
-msgid "Open output file in update mode"
+#: ../vector/v.in.ogr/geom.c:257 ../vector/v.in.ogr/geom.c:271
+#: ../vector/v.in.ogr/geom.c:300 ../vector/v.in.ogr/geom.c:347
+msgid "Skipping empty geometry feature"
msgstr ""
-#: ../display/d.mon/main.c:130
-msgid "Requires --overwrite flag. If not given the output file is overwritten."
-msgstr ""
-#: ../display/d.mon/main.c:142
-msgid "Currently selected monitor:"
-msgstr ""
-#: ../display/d.mon/main.c:146
+#: ../vector/v.in.ogr/geom.c:317
#, c-format
-msgid "List of commands for monitor <%s>:"
+msgid "Feature (cat %d): degenerated polygon (%d vertices)"
msgstr ""
-#: ../display/d.mon/main.c:151
+#: ../vector/v.in.ogr/geom.c:361
#, c-format
-msgid "Monitor <%s> released"
+msgid "Degenerate island ([%d] vertices)"
msgstr ""
-#: ../display/d.mon/main.c:156
-msgid "No monitor selected"
+#: ../vector/v.in.ogr/geom.c:395
+#, fuzzy
+msgid "Unable calculate centroid"
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.ogr/geom.c:426
+msgid "No centroid written for polygon with 0 vertices"
msgstr ""
-#: ../display/d.mon/main.c:175
-#, fuzzy, c-format
-msgid "Either <%s>, <%s> or <%s> must be given"
+#: ../vector/v.in.ogr/geom.c:447
+#, fuzzy
+msgid "Unable to write part of geometry"
msgstr "출력할 래스터맵"
-#: ../display/d.mon/list.c:45
-msgid "List of running monitors:"
+#: ../vector/v.in.ogr/geom.c:453
+msgid "Unknown geometry type"
msgstr ""
-#: ../display/d.mon/list.c:47
-msgid "No monitors running"
+#: ../vector/v.out.vtk/writeVTK.c:196
+msgid ""
+"No coordinates to generate the output! Maybe an empty vector type chosen?"
msgstr ""
-#: ../display/d.mon/list.c:82
+#: ../vector/v.out.vtk/writeVTK.c:585 ../vector/v.out.ogr/attrb.c:48
+#, c-format
+msgid "Cannot select attributes for cat = %d"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:589 ../vector/v.overlay/main.c:469
+#: ../vector/v.lrs/v.lrs.label/main.c:350 ../vector/v.out.svg/main.c:400
+#: ../vector/v.out.ogr/attrb.c:53
#, fuzzy
-msgid "Command file not found"
+msgid "Unable to fetch data from table"
msgstr "출력할 래스터맵"
-#: ../display/d.mon/list.c:86
+#: ../vector/v.out.vtk/writeVTK.c:632
+msgid "Cannot export attribute table fields for layer < 1. Skipping export"
+msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:640
#, fuzzy
-msgid "Unable to read command file"
+msgid "No attribute table found"
msgstr "출력할 래스터맵"
-#: ../display/d.mon/select.c:14
+#: ../vector/v.out.vtk/writeVTK.c:654 ../vector/v.in.ascii/main.c:411
+#: ../vector/v.db.connect/main.c:228 ../vector/v.random/main.c:287
+#: ../vector/v.out.postgis/table.c:41 ../vector/v.reclass/main.c:181
+#: ../vector/v.out.svg/main.c:165 ../vector/v.patch/main.c:144
+#: ../vector/v.patch/main.c:183 ../vector/v.out.ogr/main.c:617
+#: ../vector/v.info/print.c:152 ../db/db.describe/main.c:67
+#: ../doc/vector/v.example/main.c:137
#, fuzzy, c-format
-msgid "Monitor <%s> is already selected"
+msgid "Unable to describe table <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.his/main.c:69
-msgid ""
-"Displays the result obtained by combining hue, intensity, and saturation "
-"(his) values from user-specified input raster map layers."
+#: ../vector/v.out.vtk/writeVTK.c:672
+msgid "No numerical attributes found. Skipping export"
msgstr ""
-#: ../display/d.his/main.c:97
-msgid "Percent to brighten intensity channel"
-msgstr ""
+#: ../vector/v.out.vtk/writeVTK.c:733 ../vector/v.out.vtk/writeVTK.c:766
+#: ../vector/v.out.vtk/writeVTK.c:799 ../vector/v.out.vtk/writeVTK.c:830
+#, fuzzy, c-format
+msgid "Error reading value of attribute '%s'"
+msgstr "출력할 래스터맵"
-#: ../display/d.extract/main.c:52
-msgid "Selects and extracts vectors with mouse into new vector map."
-msgstr ""
+#: ../vector/v.out.vtk/main.c:51
+#, fuzzy
+msgid "Converts a vector map to VTK ASCII output."
+msgstr "출력할 래스터맵"
-#: ../display/d.extract/main.c:117
+#: ../vector/v.out.vtk/main.c:57
#, fuzzy
-msgid "Copying tables..."
+msgid "Name for output VTK file"
msgstr "출력할 래스터맵"
-#: ../display/d.extract/main.c:125
-msgid "Cannot get db link info -> cannot copy table."
+#: ../vector/v.out.vtk/main.c:82
+msgid "Layer number"
msgstr ""
-#: ../display/d.extract/extract.c:43
-msgid "Select vector(s) with mouse"
+#: ../vector/v.out.vtk/main.c:92
+msgid "Export numeric attribute table fields as VTK scalar variables"
msgstr ""
-#: ../display/d.extract/extract.c:44
-msgid " - L: draw box with left mouse button to select"
+#: ../vector/v.out.vtk/main.c:156 ../vector/v.out.ascii/args.c:109
+msgid "Failed to interpret 'dp' parameter as an integer"
msgstr ""
-#: ../display/d.extract/extract.c:45
-msgid " - M: draw box with middle mouse button to remove from display"
+#: ../vector/v.out.vtk/main.c:158
+msgid "dp has to be from 0 to 8"
msgstr ""
-#: ../display/d.extract/extract.c:46
-msgid " - R: quit and save selected vectors to new map\n"
+#: ../vector/v.out.vtk/main.c:167
+msgid "Failed to interpret 'layer' parameter as an integer"
msgstr ""
-#: ../display/d.extract/extract.c:48
-msgid "L: add M: remove R: quit and save\n"
+#: ../vector/v.out.vtk/main.c:186
+#, c-format
+msgid ""
+"Export of areas requires topology. Please adjust '%s' option or rebuild "
+"topology."
msgstr ""
-#: ../display/d.vect.chart/main.c:65
+#: ../vector/v.out.vtk/head.c:27
+msgid "writeVTKHeader: Writing VTK-Header"
+msgstr ""
+#: ../vector/v.generalize/displacement.c:199
#, fuzzy
-msgid "chart maps"
+msgid "Inverting matrix..."
msgstr "출력할 래스터맵"
-#: ../display/d.vect.chart/main.c:67
-msgid ""
-"Displays charts of vector data in the active frame on the graphics monitor."
-msgstr ""
+#: ../vector/v.generalize/displacement.c:201
+#, fuzzy
+msgid "Unable to calculate the inverse matrix"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect.chart/main.c:86
-msgid "Chart type"
-msgstr ""
+#: ../vector/v.generalize/displacement.c:204
+#, fuzzy
+msgid "Resolving conflicts..."
+msgstr "출력할 래스터맵"
-#: ../display/d.vect.chart/main.c:87 ../display/d.vect.chart/main.c:98
-#: ../display/d.vect.chart/main.c:106 ../display/d.vect.chart/main.c:113
-#: ../display/d.vect.chart/main.c:121 ../display/d.vect.chart/main.c:130
-#: ../display/d.vect.chart/main.c:136
-msgid "Chart properties"
+#: ../vector/v.generalize/smoothing.c:135
+#: ../vector/v.generalize/smoothing.c:225
+msgid "Look ahead parameter must be odd"
msgstr ""
-#: ../display/d.vect.chart/main.c:91
-msgid "Attribute columns containing data"
-msgstr ""
+#: ../vector/v.generalize/smoothing.c:664
+#, fuzzy
+msgid "Unable to find the inverse matrix"
+msgstr "출력할 래스터맵"
-#: ../display/d.vect.chart/main.c:97
-msgid "Column used for pie chart size"
+#: ../vector/v.generalize/smoothing.c:671
+#, fuzzy
+msgid "Unable to calculate the output vectors"
+msgstr "출력할 래스터맵"
+#: ../vector/v.generalize/main.c:77
+#, fuzzy
+msgid "generalization"
+msgstr "출력할 래스터맵"
+#: ../vector/v.generalize/main.c:78
+msgid "simplification"
msgstr ""
-#: ../display/d.vect.chart/main.c:105
-msgid "Size of chart (diameter for pie, total width for bar)"
+#: ../vector/v.generalize/main.c:79
+msgid "smoothing"
msgstr ""
-#: ../display/d.vect.chart/main.c:112
-msgid "Scale for size (to get size in pixels)"
+#: ../vector/v.generalize/main.c:80
+msgid "displacement"
msgstr ""
-#: ../display/d.vect.chart/main.c:119
-msgid "Outline color"
+#: ../vector/v.generalize/main.c:81
+msgid "network generalization"
msgstr ""
-#: ../display/d.vect.chart/main.c:128
-msgid "Colors used to fill charts"
+#: ../vector/v.generalize/main.c:82
+msgid "Performs vector based generalization."
msgstr ""
-#: ../display/d.vect.chart/main.c:135
-msgid "Center the bar chart around a data point"
+#: ../vector/v.generalize/main.c:119
+msgid "Douglas-Peucker Algorithm"
msgstr ""
-#: ../display/d.vect.chart/main.c:144
-msgid "Maximum value used for bar plot reference"
+#: ../vector/v.generalize/main.c:120
+msgid "Douglas-Peucker Algorithm with reduction parameter"
msgstr ""
-#: ../display/d.measure/main.c:49
-msgid ""
-"Measures the lengths and areas of features drawn by the user in the active "
-"display frame on the graphics monitor."
+#: ../vector/v.generalize/main.c:121
+msgid "Lang Simplification Algorithm"
msgstr ""
-#: ../display/d.measure/main.c:55
-msgid "Line color 1"
+#: ../vector/v.generalize/main.c:122
+msgid "Vertex Reduction Algorithm eliminates points close to each other"
msgstr ""
-#: ../display/d.measure/main.c:63
-msgid "Line color 2"
+#: ../vector/v.generalize/main.c:123
+msgid "Reumann-Witkam Algorithm"
msgstr ""
-#: ../display/d.measure/main.c:71
-msgid "Suppress clear screen"
+#: ../vector/v.generalize/main.c:124
+msgid "Boyle's Forward-Looking Algorithm"
msgstr ""
-#: ../display/d.measure/main.c:75
-msgid "Output in meters only"
+#: ../vector/v.generalize/main.c:125
+msgid "McMaster's Sliding Averaging Algorithm"
msgstr ""
-#: ../display/d.measure/main.c:79
-msgid "Output in kilometers as well"
+#: ../vector/v.generalize/main.c:126
+msgid "McMaster's Distance-Weighting Algorithm"
msgstr ""
-#: ../display/d.title/main.c:52
-msgid ""
-"Create a TITLE for a raster map in a form suitable for display with d.text."
+#: ../vector/v.generalize/main.c:127
+msgid "Chaiken's Algorithm"
msgstr ""
-#: ../display/d.title/main.c:63
-msgid "Sets the text color"
+#: ../vector/v.generalize/main.c:128
+msgid "Interpolation by Cubic Hermite Splines"
msgstr ""
-#: ../display/d.title/main.c:71
-msgid "Sets the text size as percentage of the frame's height"
+#: ../vector/v.generalize/main.c:129
+msgid "Snakes method for line smoothing"
msgstr ""
-#: ../display/d.title/main.c:75
+#: ../vector/v.generalize/main.c:130
#, fuzzy
-msgid "Draw title on current display"
+msgid "Network generalization"
msgstr "출력할 래스터맵"
-#: ../display/d.title/main.c:79
-msgid "Do a fancier title"
+#: ../vector/v.generalize/main.c:131
+msgid "Displacement of lines close to each other"
msgstr ""
-#: ../display/d.title/main.c:84
-msgid "Do a simple title"
+#: ../vector/v.generalize/main.c:134
+msgid "Generalization algorithm"
msgstr ""
-#: ../display/d.title/main.c:102
-msgid "Title can be fancy or simple, not both"
+#: ../vector/v.generalize/main.c:141
+msgid "Maximal tolerance value"
msgstr ""
-#: ../display/d.title/main.c:105
-msgid "No map name given"
+#: ../vector/v.generalize/main.c:148
+msgid "Look-ahead parameter"
msgstr ""
-#: ../display/d.zoom/main.c:62
-msgid "zoom"
+#: ../vector/v.generalize/main.c:157
+msgid "Percentage of the points in the output of 'douglas_reduction' algorithm"
msgstr ""
-#: ../display/d.zoom/main.c:64
-msgid ""
-"Allows the user to change the current geographic region settings "
-"interactively, with a mouse."
+#: ../vector/v.generalize/main.c:166
+msgid "Slide of computed point toward the original point"
msgstr ""
-#: ../display/d.zoom/main.c:84 ../vector/v.build/main.c:44
-msgid "Name of vector map"
+#: ../vector/v.generalize/main.c:175
+msgid "Minimum angle between two consecutive segments in Hermite method"
msgstr ""
-#: ../display/d.zoom/main.c:92
-msgid "Magnification: >1.0 zooms in, <1.0 zooms out"
+#: ../vector/v.generalize/main.c:183
+msgid "Degree threshold in network generalization"
msgstr ""
-#: ../display/d.zoom/main.c:102
-msgid "Full menu (zoom + pan) & Quit menu"
+#: ../vector/v.generalize/main.c:192
+msgid "Closeness threshold in network generalization"
msgstr ""
-#: ../display/d.zoom/main.c:106
-msgid "Pan mode"
+#: ../vector/v.generalize/main.c:200
+msgid "Betweeness threshold in network generalization"
msgstr ""
-#: ../display/d.zoom/main.c:110
-msgid "Handheld mode"
+#: ../vector/v.generalize/main.c:207
+msgid "Snakes alpha parameter"
msgstr ""
-#: ../display/d.zoom/main.c:114
-msgid "Return to previous zoom"
+#: ../vector/v.generalize/main.c:214
+msgid "Snakes beta parameter"
msgstr ""
-#: ../display/d.zoom/main.c:120
-msgid "Please choose only one mode of operation"
-msgstr ""
+#: ../vector/v.generalize/main.c:221
+#, fuzzy
+msgid "Number of iterations"
+msgstr "출력할 래스터맵"
-#: ../display/d.zoom/main.c:223
-#, c-format
-msgid "%d raster%s, %d vector%s\n"
+#: ../vector/v.generalize/main.c:231
+msgid "Disable loop support"
msgstr ""
-#: ../display/d.zoom/main.c:232
-msgid "No previous zoom available"
+#: ../vector/v.generalize/main.c:232
+msgid "Do not modify end points of lines forming a closed loop"
msgstr ""
-#: ../display/d.zoom/main.c:236
-msgid "Returning to previous zoom"
+#: ../vector/v.generalize/main.c:235
+#, fuzzy
+msgid "Do not copy attributes"
+msgstr "출력할 래스터맵"
+#: ../vector/v.generalize/main.c:289
+msgid "Unknown method"
msgstr ""
-#: ../display/d.zoom/main.c:271
-msgid "Zooming complete."
+#: ../vector/v.generalize/main.c:343
+#, fuzzy
+msgid "Displacement..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.generalize/main.c:352
+msgid "Network generalization..."
msgstr ""
-#: ../display/d.zoom/pan.c:16 ../display/d.zoom/zoom.c:14
-#, c-format
-msgid ""
-"\n"
-"\n"
-"Buttons:\n"
+#: ../vector/v.generalize/main.c:367
+msgid "Attributes are needed for 'where' option, copying table"
msgstr ""
-#: ../display/d.zoom/pan.c:17
+#: ../vector/v.generalize/main.c:384
#, c-format
-msgid "Left: Pan\n"
+msgid "Generalization (%s)..."
msgstr ""
-#: ../display/d.zoom/pan.c:18
+#: ../vector/v.generalize/main.c:515
#, c-format
-msgid "Right: Quit\n"
+msgid "Method '%s' did not preserve first point"
msgstr ""
-#: ../display/d.zoom/zoom.c:15
+#: ../vector/v.generalize/main.c:520
#, c-format
-msgid "Left: Zoom menu\n"
+msgid "Method '%s' did not preserve last point"
msgstr ""
-#: ../display/d.zoom/zoom.c:16
+#: ../vector/v.generalize/main.c:527
#, c-format
-msgid "Middle: Pan\n"
+msgid "Method '%s' did not preserve loop"
msgstr ""
-#: ../display/d.zoom/zoom.c:17
+#: ../vector/v.generalize/main.c:555
#, c-format
-msgid "Right: Quit menu\n"
+msgid ""
+"%d boundaries were not modified because modification would damage topology"
msgstr ""
-#: ../display/d.zoom/zoom.c:39
+#: ../vector/v.generalize/main.c:558
#, c-format
-msgid ""
-"This region now saved as current region.\n"
-"\n"
+msgid "%d lines/boundaries were not modified due to over-simplification"
msgstr ""
-#: ../display/d.zoom/zoom.c:41
+#: ../vector/v.generalize/main.c:573
#, c-format
-msgid "Note: run 'd.erase' for the new region to affect the graphics.\n"
+msgid "Number of vertices for selected features %s from %d to %d (%d%%)."
msgstr ""
-#: ../display/d.rast/main.c:56
-msgid "Displays user-specified raster map in the active graphics frame."
+#: ../vector/v.generalize/main.c:574
+msgid "reduced"
msgstr ""
-#: ../display/d.rast/main.c:61 ../imagery/i.class/main.c:103
-#, fuzzy
-msgid "Name of raster map to be displayed"
-msgstr "출력할 래스터맵"
-#: ../display/d.rast/main.c:69
-#, fuzzy
-msgid "List of categories or values to be displayed"
-msgstr "출력할 래스터맵"
-#: ../display/d.rast/main.c:75
-msgid "Background color (for null)"
+msgid "changed"
msgstr ""
-#: ../display/d.rast/main.c:86
-msgid "Invert value list"
+#: ../vector/v.generalize/misc.c:156
+#, c-format
+msgid "Layer %d"
msgstr ""
-#: ../display/d.rast/main.c:206
+#: ../vector/v.generalize/network.c:89 ../vector/v.net.timetable/main.c:405
+#: ../vector/v.net.spanningtree/main.c:124 ../vector/v.net.bridge/main.c:134
+#: ../vector/v.net.flow/main.c:225 ../vector/v.net.centrality/main.c:284
+#: ../vector/v.net.components/main.c:162 ../vector/v.net.distance/main.c:238
+#: ../vector/v.net.connectivity/main.c:178
#, fuzzy, c-format
-msgid "[%s]: illegal category specified"
+msgid "Unable to build graph for vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../display/d.rast/main.c:237
-#, fuzzy, c-format
-msgid "[%s]: illegal value specified"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.info/r3.info.main.c:80
-msgid "Outputs basic information about a user-specified 3D raster map layer."
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:86
+#: ../vector/v.generalize/network.c:166
#, fuzzy
-msgid "Print raster3d information in shell style"
+msgid "Calculating centrality measures..."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.info/r3.info.main.c:90
+#: ../vector/v.in.ascii/points.c:83
#, fuzzy
-msgid "Print range in shell style only"
+msgid "Scanning input for column types..."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.info/r3.info.main.c:103
+#: ../vector/v.in.ascii/points.c:164 ../vector/v.in.ascii/points.c:183
+#, c-format
+msgid ""
+"Current row %d:\n"
+"%s\n"
+msgstr ""
+#: ../vector/v.in.ascii/points.c:165
#, fuzzy, c-format
-msgid "3D Raster map <%s> not found"
+msgid "Unparsable longitude value in column num %d: %s"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.info/r3.info.main.c:328
-#: ../raster3d/r3.info/r3.info.main.c:444 ../raster3d/r3.mkdspf/main.c:170
+#: ../vector/v.in.ascii/points.c:184
#, fuzzy, c-format
-msgid "Unable to read range of 3D raster map <%s>"
+msgid "Unparsable latitude value in column num %d: %s"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.info/r3.info.main.c:472
-msgid "Error while reading history file"
-msgstr ""
-#: ../raster3d/r3.info/r3.info.main.c:479 ../raster3d/r3.cross.rast/main.c:343
-#: ../raster3d/r3.out.vtk/errorHandling.c:65 ../raster3d/r3.null/main.c:168
+#: ../vector/v.in.ascii/points.c:265
#, fuzzy, c-format
-msgid "Unable to close 3D raster map <%s>"
-msgstr "출력할 래스터맵"
+msgid "Skipping %d of %d row falling outside of current region"
+msgid_plural "Skipping %d of %d rows falling outside of current region"
-#: ../raster3d/r3.cross.rast/main.c:55 ../raster3d/r3.in.bin/main.c:474
-#: ../raster3d/r3.in.ascii/main.c:355 ../raster3d/r3.out.vtk/main.c:252
-#: ../raster3d/r3.out.vtk/main.c:338 ../raster3d/r3.out.netcdf/main.c:648
-#: ../raster3d/r3.out.v5d/main.c:54 ../raster3d/r3.out.v5d/main.c:325
-#: ../raster3d/r3.out.ascii/main.c:62 ../raster3d/r3.out.ascii/main.c:370
-#: ../raster3d/r3.to.rast/main.c:55 ../raster3d/r3.to.rast/main.c:383
-#: ../raster3d/r3.gwflow/main.c:412 ../raster3d/r3.in.v5d/main.c:219
+#: ../vector/v.in.ascii/points.c:295
#, fuzzy
-msgid "Unable to close 3D raster map"
+msgid "Importing points..."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.cross.rast/main.c:90
-msgid "Input 3D raster map for cross section."
+#: ../vector/v.in.ascii/main.c:53
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:97
-msgid "2D elevation map used to create the cross section map"
+#: ../vector/v.in.ascii/main.c:71
+msgid "simple x,y[,z] list"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:104
-msgid "Resulting cross section 2D raster map"
+#: ../vector/v.in.ascii/main.c:72
+msgid "GRASS vector ASCII format"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:233
-msgid ""
-"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
-"map"
+#: ../vector/v.in.ascii/main.c:75
+msgid "Input file format"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:259
-msgid ""
-"The 2D and 3D region settings are different. Using the 3D raster map "
-"settings to adjust the 2D region."
+#: ../vector/v.in.ascii/main.c:76 ../vector/v.in.ascii/main.c:79
+#: ../vector/v.in.ascii/main.c:157
+msgid "Input format"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:302
-msgid "Output map already exists. Will be overwritten!"
+#: ../vector/v.in.ascii/main.c:88
+msgid "Number of header lines to skip at top of input file (points mode)"
msgstr ""
-#: ../raster3d/r3.cross.rast/main.c:338
-#, fuzzy
-msgid "Wrong 3D raster datatype! Cannot create raster map"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.ascii/main.c:97
+msgid "Column definition in SQL style (points mode)"
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:73
-#, fuzzy
-msgid "Error reading binary data"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.ascii/main.c:98
+msgid ""
+"For example: 'x double precision, y double precision, cat int, name varchar"
+"(10)'"
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:154
-#, c-format
-msgid "Loading %s data with %i bytes ... (%dx%dx%d)"
+#: ../vector/v.in.ascii/main.c:110 ../vector/v.in.ascii/main.c:120
+msgid "First column is 1"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:202 ../raster3d/r3.neighbors/main.c:305
+#: ../vector/v.in.ascii/main.c:119
#, fuzzy
-msgid "Error flushing tiles"
+msgid "Number of column used as y coordinate (points mode)"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.bin/main.c:255
+#: ../vector/v.in.ascii/main.c:129
#, fuzzy
-msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgid "Number of column used as z coordinate (points mode)"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.bin/main.c:258
-#, fuzzy
-msgid "Name of binary 3D raster file to be imported"
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.ascii/main.c:130
+msgid "First column is 1. If 0, z coordinate is not used"
+msgstr ""
-#: ../raster3d/r3.in.bin/main.c:268 ../raster3d/r3.out.bin/main.c:227
+#: ../vector/v.in.ascii/main.c:140
#, fuzzy
-msgid "Number of bytes per cell in binary file"
+msgid "Number of column used as category (points mode)"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.bin/main.c:276
-msgid "Byte order in binary file"
+#: ../vector/v.in.ascii/main.c:142
+msgid ""
+"First column is 1. If 0, unique category is assigned to each row and written "
+"to new column 'cat'"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:316
-msgid "Bottom limit of geographic region (outer edge)"
+#: ../vector/v.in.ascii/main.c:151
+msgid "Create a new empty vector map and exit. Nothing is read from input."
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:323
-msgid "Top limit of geographic region (outer edge)"
+#: ../vector/v.in.ascii/main.c:156
+msgid "Don't expect a header when reading in standard format"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:344
-#, fuzzy
-msgid "Number of depths"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.bin/main.c:356 ../raster3d/r3.out.bin/main.c:240
-#: ../raster3d/r3.out.ascii/main.c:109
-msgid "Switch the row order in output from north->south to south->north"
+#: ../vector/v.in.ascii/main.c:161
+msgid "Do not create table in points mode"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:361 ../raster3d/r3.out.bin/main.c:245
-#: ../raster3d/r3.out.ascii/main.c:113
-msgid "Switch the depth order in output from bottom->top to top->bottom"
+#: ../vector/v.in.ascii/main.c:171
+msgid "Only import points falling within current region (points mode)"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:367
-msgid "Binary data is of type integer"
+#: ../vector/v.in.ascii/main.c:188
+msgid "Please specify z column"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:402
-#, c-format
-msgid "bytes=%d; must be 4 or 8 in case of floating point input"
+#: ../vector/v.in.ascii/main.c:199
+msgid "Please specify reasonable z column"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:449
-#, c-format
-msgid "File Size %lld ... Total Bytes %lld"
+#: ../vector/v.in.ascii/main.c:204
+msgid "Column numbers must not be negative"
msgstr ""
-#: ../raster3d/r3.in.bin/main.c:466 ../raster3d/r3.in.ascii/main.c:349
-#: ../raster3d/r3.in.v5d/main.c:214
-#, fuzzy
-msgid "Unable to open 3D raster map"
+#: ../vector/v.in.ascii/main.c:208
+#, fuzzy, c-format
+msgid "Unable to open ASCII file <%s>"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.stats/main.c:570
-#, fuzzy
-msgid "Generates volume statistics for 3D raster maps."
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.stats/main.c:581
-#, fuzzy
-msgid "Number of subranges to collect stats from"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.stats/main.c:587
-msgid "Calculate statistics based on equal value groups"
+#: ../vector/v.in.ascii/main.c:263
+#, c-format
+msgid "Maximum input row length: %d"
msgstr ""
-#: ../raster3d/r3.stats/main.c:607
-msgid "The number of subranges has to be equal or greater than 1"
+#: ../vector/v.in.ascii/main.c:265
+#, c-format
+msgid "Maximum number of columns: %d"
msgstr ""
-#: ../raster3d/r3.stats/main.c:666
-msgid "Sort non-null values"
+#: ../vector/v.in.ascii/main.c:266
+#, c-format
+msgid "Minimum number of columns: %d"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:94
-msgid "String representing NULL value data cell (use 'none' if no such value)"
-msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:184
+#: ../vector/v.in.ascii/main.c:269
#, fuzzy, c-format
-msgid "Unsupported GRASS version %s"
+msgid "Number of columns: %d"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.ascii/main.c:227
+#: ../vector/v.in.ascii/main.c:274 ../vector/v.in.ascii/main.c:278
+#: ../vector/v.in.ascii/main.c:283 ../vector/v.in.ascii/main.c:288
#, c-format
-msgid "Loading data ... (%dx%dx%d)"
+msgid ""
+"'%s' column number > minimum last column number (incorrect field separator "
+"or format?)"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:260
-msgid "End of file reached while still loading data."
+#: ../vector/v.in.ascii/main.c:293 ../vector/v.in.ascii/main.c:296
+#: ../vector/v.in.ascii/main.c:299 ../vector/v.in.ascii/main.c:302
+#, fuzzy, c-format
+msgid "'%s' column is not of number type"
+msgstr "출력할 래스터맵"
+#: ../vector/v.in.ascii/main.c:342
+msgid "Category column is not of integer type"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:272
-#, fuzzy
-msgid "Invalid value detected"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.ascii/main.c:284
+#: ../vector/v.in.ascii/main.c:419
#, c-format
msgid ""
-"Data exists in input file after fully importing expected data. [%.4f ...]"
+"Number of columns defined (%d) does not match number of columns (%d) in input"
msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:322
-#, fuzzy
-msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
-msgstr "출력할 래스터맵"
+#: ../vector/v.in.ascii/main.c:447
+#, c-format
+msgid "Column number %d <%s> defined as double has only integer values"
+msgstr ""
-#: ../raster3d/r3.in.ascii/main.c:365
-#, fuzzy
-msgid "Unable to close ASCII file"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:117
-msgid "Specify top and bottom map"
+#: ../vector/v.in.ascii/main.c:452
+#, c-format
+msgid "Column number %d <%s> defined as string has only integer values"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:124
+#: ../vector/v.in.ascii/main.c:459
#, c-format
-msgid "Top cell map <%s> not found"
+msgid "Column number %d <%s> defined as integer has double values"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:133
+#: ../vector/v.in.ascii/main.c:464
#, c-format
-msgid "Bottom cell map <%s> not found"
+msgid "Column number %d <%s> defined as string has double values"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:152
-#, fuzzy, c-format
-msgid "3D raster map RGB map <%s> not found"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:155
-#, fuzzy
-msgid "Please provide three RGB 3D raster maps"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:165
-#, fuzzy, c-format
-msgid "3D vector map <%s> not found"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:168
-#, fuzzy
-msgid "Please provide three 3D raster maps for the xyz-vector maps [x,y,z]"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:175
-msgid ""
-"No 3D raster data, RGB or xyz-vector maps are provided! Will only write the "
-"geometry."
+#: ../vector/v.in.ascii/main.c:471
+#, c-format
+msgid "Column number %d <%s> defined as integer has string values"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:209
-msgid "No RGB Data will be created."
+#: ../vector/v.in.ascii/main.c:476
+#, c-format
+msgid "Column number %d <%s> defined as double has string values"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:294
-msgid "No vector data will be created."
+#: ../vector/v.in.ascii/main.c:481
+#, c-format
+msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:381
-#, fuzzy
-msgid "Converts 3D raster maps into the VTK-ASCII format."
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:392
-msgid "failed to interpret dp as an integer"
+#: ../vector/v.in.ascii/main.c:521
+msgid "Populating table..."
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:451 ../raster3d/r3.to.rast/main.c:271
+#: ../vector/v.in.ascii/main.c:527
msgid ""
-"The 2D and 3D region settings are different. Using the 2D window settings to "
-"adjust the 2D part of the 3D region."
+"Could not close attribute table. The DBMI driver did not accept all "
+"attributes"
msgstr ""
-#: ../raster3d/r3.out.vtk/main.c:542
+#: ../vector/v.in.ascii/main.c:536 ../vector/v.in.ascii/main.c:539
#, fuzzy
-msgid "Unable to close 3D raster map, the VTK file may be incomplete"
+msgid "Import failed"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/main.c:557
-#, fuzzy
-msgid "Unable to close VTK-ASCII file"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/errorHandling.c:105
-#, fuzzy
-msgid "Unable to close input raster maps"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/writeVTKData.c:122
-msgid "write_vtk_points: Writing point coordinates"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:256
-msgid "write_vtk_unstructured_grid_cells: Writing the cells"
-msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:335
+#: ../vector/v.external.out/link.c:26 ../vector/v.out.ogr/main.c:95
#, c-format
msgid ""
-"write_vtk_data: Writing Celldata %s with rows %i cols %i depths %i to vtk-"
-"ascii file"
+"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
+"\" given)"
msgstr ""
-#: ../raster3d/r3.out.vtk/writeVTKData.c:441
-msgid "Wrong 3D raster map values! Values should in between 0 and 255!"
+#: ../vector/v.external.out/link.c:46 ../vector/v.external/main.c:72
+msgid ""
+"Environment variable GRASS_VECTOR_OGR defined, but GRASS is compiled with "
+"OGR support. Using GRASS-PostGIS data driver instead."
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:30
-msgid "RASTER3D map(s) to be converted to VTK-ASCII data format"
+#: ../vector/v.external.out/link.c:53 ../vector/v.external/main.c:77
+msgid ""
+"GRASS is not compiled with PostgreSQL support. Using OGR-PostgreSQL driver "
+"instead of native GRASS-PostGIS data driver."
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:41
-msgid "Float value to represent no data cell/points"
-msgstr ""
+#: ../vector/v.external.out/link.c:141 ../vector/v.out.postgis/create.c:27
+#, fuzzy, c-format
+msgid "Unable to create <%s> file"
+msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/parameters.c:47
-msgid "Create VTK pointdata instead of VTK celldata (celldata is default)"
-msgstr ""
+#: ../vector/v.external.out/link.c:144 ../vector/v.out.postgis/create.c:89
+#, fuzzy, c-format
+msgid "Error writing <%s> file"
+msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.vtk/parameters.c:56
-msgid "top surface 2D raster map"
+#: ../vector/v.external.out/link.c:149
+#, c-format
+msgid "Switched to OGR format (%s)"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:65
-msgid "bottom surface 2D raster map"
+#: ../vector/v.external.out/link.c:152
+msgid "Switched to PostGIS format"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:71
-msgid ""
-"Create 3d elevation output with a top and a bottom surface, both raster maps "
-"are required."
+#: ../vector/v.external.out/link.c:188
+#, c-format
+msgid "Invalid option '%s=%s' ignored (allowed values: '%s', '%s')"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:82
-msgid ""
-"Three (R,G,B) 3D raster maps to create RGB values [redmap,greenmap,bluemap]"
+#: ../vector/v.external.out/status.c:22
+#, c-format
+msgid "format: native\n"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:92
-msgid "Three (x,y,z) 3D raster maps to create vector values [xmap,ymap,zmap]"
+#: ../vector/v.external.out/status.c:56
+msgid "OGR datasource (dsn) not defined"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:116
-msgid "Use 3D raster mask (if exists) with input maps"
+#: ../vector/v.external.out/status.c:61
+msgid "OGR format not defined"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:121
-msgid "Scale factor effects the origin"
+#: ../vector/v.external.out/status.c:69
+msgid "PG connection info (conninfo) not defined"
msgstr ""
-#: ../raster3d/r3.out.vtk/parameters.c:133
-msgid ""
-"Do not convert the top-bottom resolution in case of lat long projection to "
-"meters"
-msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:81
-#, fuzzy, c-format
-msgid "Unable to close 3D raster map while catching error: %s"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.netcdf/main.c:97
+#: ../vector/v.external.out/main.c:49
#, fuzzy
-msgid "Name for netCDF output file"
+msgid "Defines vector output format."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.netcdf/main.c:106
-msgid "The value to be used for null values, default is the netCDF standard"
+#: ../vector/v.external.out/main.c:63
+msgid "Switched from OGR to native format"
msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:111
-#, fuzzy
-msgid "Export projection information as wkt and proj4 parameter"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.netcdf/main.c:588
-msgid "netCDF"
+#: ../vector/v.external.out/main.c:67
+msgid "Switched from PostGIS to native format"
msgstr ""
-#: ../raster3d/r3.out.netcdf/main.c:589
+#: ../vector/v.external.out/args.c:14 ../vector/v.external/args.c:14
#, fuzzy
-msgid "Export a 3D raster map as netCDF file."
+msgid "Name of input OGR or PostGIS data source"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.v5d/main.c:72
-msgid "3D raster map to be converted to Vis5D (V5D) file"
+#: ../vector/v.external.out/args.c:15 ../vector/v.external/args.c:15
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: directory containing a shapefile\n"
+"\t\tMapInfo File: directory containing a mapinfo file\n"
+"\t\tPostGIS database: connection string, eg. 'PG:dbname=db user=grass'"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:76
+#: ../vector/v.external.out/args.c:24
#, fuzzy
-msgid "Name for V5D output file"
+msgid "Format for output vector data"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.v5d/main.c:146
-#, c-format
-msgid "Vis5D allows %d columns, %d columns found"
+#: ../vector/v.external.out/args.c:39
+msgid ""
+"Examples:\n"
+"\t\t'SHPT=POINTZ': create 3D point Shapefile data\n"
+"\t\t'GEOM_TYPE=geography': use geography PostGIS data\n"
+"\t\t'SCHEMA=grass': create new PostGIS tables in 'grass' schema"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:149
-#, c-format
-msgid "Vis5D allows %d rows, %d rows found"
+#: ../vector/v.external.out/args.c:55
+msgid "Cease using OGR/PostGIS, revert to native output and exit"
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:256
-#, fuzzy, c-format
-msgid "Unable to create V5D file <%s>"
+#: ../vector/v.external.out/args.c:57
+msgid "Native"
+msgstr ""
+#: ../vector/v.external.out/args.c:67
+#, fuzzy
+msgid "Print current status in shell script style"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.v5d/main.c:261
+#: ../vector/v.external.out/list.c:102 ../vector/v.external/list.c:94
#, fuzzy
-msgid "Failed writing V5D file"
+msgid "List of supported formats:"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.v5d/main.c:287
-msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+#: ../vector/v.univar/main.c:95
+msgid "Calculates univariate statistics for attribute."
msgstr ""
-#: ../raster3d/r3.out.v5d/main.c:294
-msgid "Use map coordinates instead of xyz coordinates"
+#: ../vector/v.univar/main.c:96
+msgid ""
+"Variance and standard deviation is calculated only for points if specified."
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:207
-#, fuzzy
-msgid "Exports a GRASS 3D raster map to a binary array."
-msgstr "출력할 래스터맵"
+#: ../vector/v.univar/main.c:131
+msgid "Weigh by line length or area size"
+msgstr ""
-#: ../raster3d/r3.out.bin/main.c:250
-#, fuzzy
-msgid "Write data as integer"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.bin/main.c:328
-#, c-format
-msgid "top=%f"
+#: ../vector/v.univar/main.c:135
+msgid "Calculate geometry distances instead of table data."
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:329
+#: ../vector/v.univar/main.c:144 ../vector/v.to.db/parse.c:141
+#: ../vector/v.to.db/parse.c:144 ../ps/ps.map/main.c:213
+#: ../ps/ps.map/main.c:232
#, c-format
-msgid "bottom=%f"
+msgid ""
+"Required parameter <%s> not set:\n"
+"\t(%s)"
msgstr ""
-#: ../raster3d/r3.out.bin/main.c:332
+#: ../vector/v.univar/main.c:189
#, c-format
-msgid "depths=%d"
+msgid "Geometry distances are not supported for areas. Use '%s' instead."
msgstr ""
-#: ../raster3d/r3.neighbors/main.c:137
+#: ../vector/v.univar/main.c:192
msgid ""
-"The size of the window in x, y and z direction, values must be odd integer "
-"numbers, eg: 3,3,3"
+"Incompatible vector type(s) specified, only number of features, minimum, "
+"maximum and range can be calculated"
msgstr ""
-#: ../raster3d/r3.neighbors/main.c:209
-msgid "neighbor"
+#: ../vector/v.univar/main.c:197
+msgid "Extended statistics is currently supported only for points/centroids"
msgstr ""
-#: ../raster3d/r3.neighbors/main.c:214
-msgid ""
-"Makes each voxel value a function of the values assigned to the voxels "
-"around it, and stores new voxel values in an output 3D raster map"
+#: ../vector/v.univar/main.c:222
+msgid "'layer' must be > 0 for 'where'."
msgstr ""
-#: ../raster3d/r3.neighbors/main.c:283
-#, fuzzy
-msgid "Unable to allocate buffer"
+#: ../vector/v.univar/main.c:237
+#, fuzzy, c-format
+msgid "Unable select categories from table <%s>"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mkdspf/main.c:82
-msgid ""
-"Creates a display file from an existing grid3 file according to specified "
-"threshold levels."
+#: ../vector/v.univar/main.c:336
+#, c-format
+msgid " Database connection not defined for layer <%s>"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:90
-msgid "Name of an existing 3d raster map"
+#: ../vector/v.univar/main.c:640
+msgid "Cannot sort the key/value array"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:95
+#: ../vector/v.db.select/main.c:55
#, fuzzy
-msgid "Name for output display file"
+msgid "Prints vector map attributes."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mkdspf/main.c:102
-msgid "List of thresholds for isosurfaces"
+#: ../vector/v.db.select/main.c:73
+msgid "Output vertical record separator"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:108
-msgid "Minimum isosurface level"
+#: ../vector/v.db.select/main.c:81 ../db/db.select/main.c:238
+msgid "Null value indicator"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:114
-msgid "Maximum isosurface level"
+#: ../vector/v.db.select/main.c:93
+msgid ""
+"Print minimal region extent of selected vector features instead of attributes"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:120
-msgid "Positive increment between isosurface levels"
-msgstr ""
+#: ../vector/v.db.select/main.c:94
+#, fuzzy
+msgid "Region"
+msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mkdspf/main.c:127
-msgid "Number of isosurface threshold levels"
+#: ../vector/v.db.select/main.c:98 ../db/db.select/main.c:248
+msgid "Do not include column names in output"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:131
-msgid "Suppress progress report & min/max information"
+#: ../vector/v.db.select/main.c:103 ../db/db.select/main.c:258
+msgid "Vertical output (instead of horizontal)"
msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:135
-msgid "Use flat shading rather than gradient"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:143
-#, c-format
-msgid "Region from getWindow: %d %d %d"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:155
-#, c-format
-msgid "Not able to find grid3 file for [%s]"
-msgstr ""
-#: ../raster3d/r3.mkdspf/main.c:199
+#: ../vector/v.db.select/main.c:147
#, fuzzy, c-format
-msgid "Unable to open display file <%s>"
+msgid ""
+"Unable to open vector map <%s> at topology level. Flag '%c' requires "
+"topology level."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mkdspf/main.c:220
-#, c-format
-msgid "Writing %s from %s..."
-msgstr ""
-#: ../raster3d/r3.retile/main.c:49
+#: ../vector/v.db.select/main.c:181
#, fuzzy
-msgid "Unable to close the 3D raster map"
+msgid "Unable to open select cursor"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.retile/main.c:71
-#, fuzzy
-msgid "Name of the retiled 3D raster map"
+#: ../vector/v.db.select/main.c:202 ../vector/v.reclass/main.c:257
+#, fuzzy, c-format
+msgid "Unable to fetch data from table <%s>"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.retile/main.c:99
-msgid ""
-"Retiles an existing 3D raster map with user defined x, y and z tile size."
-msgstr ""
-#: ../raster3d/r3.retile/main.c:135
-msgid "Rast3d_get_standard3d_params: tile dimension value invalid"
-msgstr ""
-#: ../raster3d/r3.retile/main.c:148
-#, fuzzy
-msgid "Error closing 3D raster map"
+#: ../vector/v.db.select/main.c:248
+#, fuzzy, c-format
+msgid "Unable to get bounding box of area %d"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.ascii/main.c:81
-#, fuzzy
-msgid "3D raster map to be converted to ASCII"
+#: ../vector/v.db.select/main.c:254
+#, fuzzy, c-format
+msgid "Unable to get bounding box of line %d"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.ascii/main.c:85
-msgid "Name for ASCII output file"
+#: ../vector/v.net.timetable/main.c:218
+#, c-format
+msgid "Could not find a path between stops %d and %d"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:94
-msgid "Number of decimal places for floats"
+#: ../vector/v.net.timetable/main.c:263
+msgid "Finds shortest path using timetables."
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:117
-msgid "Print grass6 compatible format. Flags -d and -r are ignored."
+#: ../vector/v.net.timetable/main.c:309
+msgid "Layer number or name with walking connections or -1"
msgstr ""
-#: ../raster3d/r3.out.ascii/main.c:311
+#: ../vector/v.net.timetable/main.c:315
#, fuzzy
-msgid "Converts a 3D raster map layer into a ASCII text file."
+msgid "Name of column with route ids"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.out.ascii/main.c:374
+#: ../vector/v.net.timetable/main.c:322
#, fuzzy
-msgid "Unable to close new ASCII file"
+msgid "Name of column with stop timestamps"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.support/main.c:51
-msgid ""
-"Allows creation and/or modification of raster3d map layer support files."
-msgstr ""
-#: ../raster3d/r3.support/main.c:75
-msgid "The map data unit"
-msgstr ""
-#: ../raster3d/r3.support/main.c:81
-msgid "The vertical unit of the map"
-msgstr ""
-#: ../raster3d/r3.support/main.c:124
-msgid "Update range"
-msgstr ""
-#: ../raster3d/r3.support/check.c:20
-#, fuzzy, c-format
-msgid "Updating statistics for <%s>"
+#: ../vector/v.net.timetable/main.c:328
+#, fuzzy
+msgid "Name of column with stop ids"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.support/check.c:36
-#, fuzzy, c-format
-msgid "Updating the number of categories for <%s>"
+#: ../vector/v.net.timetable/main.c:334
+#, fuzzy
+msgid "Name of column with walk lengths"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.to.rast/main.c:80
-msgid "3D raster map(s) to be converted to 2D raster slices"
+#: ../vector/v.net.timetable/main.c:381
+msgid "Could not initialize the timetables"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:86
-msgid "Basename for resultant raster slice maps"
+#: ../vector/v.net.timetable/main.c:459 ../vector/v.net.timetable/main.c:490
+#: ../vector/v.net.timetable/main.c:498
+#, c-format
+msgid "No stop with category: %d"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:96
-msgid ""
-"Use the same resolution as the input 3D raster map for the 2D output maps, "
-"independent of the current region settings"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:210
-msgid "Converts 3D raster maps to 2D raster maps"
-msgstr ""
-#: ../raster3d/r3.to.rast/main.c:297
+#: ../vector/v.net.timetable/main.c:482 ../vector/v.net.path/path.c:149
#, c-format
-msgid "Creating %i raster maps"
+msgid "Wrong input format: %s"
msgstr ""
-#: ../raster3d/r3.to.rast/main.c:303
-#, fuzzy, c-format
-msgid "Raster map %i Filename: %s"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.to.rast/main.c:308
-#, fuzzy, c-format
-msgid ""
-"Raster map %d Filename: %s already exists. Use the flag --o to overwrite."
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:54
-msgid "Input 3D raster map with initial piezometric heads in [m]"
+#: ../vector/v.net.timetable/main.c:505
+msgid "'From' and 'To' stops are the same"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:60
-msgid ""
-"Input 3D raster map providing the status for each cell, = 0 - inactive, 1 - "
-"active, 2 - dirichlet"
+#: ../vector/v.net.timetable/main.c:514
+msgid "No path between the stops"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:65
-msgid ""
-"Input 3D raster map with the x-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../vector/v.net.salesman/main.c:128
+msgid "salesman"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:70
-msgid ""
-"Input 3D raster map with the y-part of the hydraulic conductivity tensor in "
-"[m/s]"
+#: ../vector/v.net.salesman/main.c:130
+msgid "Creates a cycle connecting given nodes (Traveling salesman problem)."
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:75
+#: ../vector/v.net.salesman/main.c:132
msgid ""
-"Input 3D raster map with the z-part of the hydraulic conductivity tensor in "
-"[m/s]"
+"Note that TSP is NP-hard, heuristic algorithm is used by this module and "
+"created cycle may be sub optimal"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:80
-#, fuzzy
-msgid "Input 3D raster map with sources and sinks in [m^3/s]"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:84
-#, fuzzy
-msgid "Specific yield [1/m] input 3D raster map"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:89
-#, fuzzy
-msgid "Recharge input 3D raster map in m^3/s"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:93
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the piezometric head result of the numerical "
-"calculation"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:99
-#, fuzzy
-msgid ""
-"Output 3D raster map storing the groundwater filter velocity vector part in "
-"x direction [m/s]"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:105
-#, fuzzy
-msgid ""
-"y direction [m/s]"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:111
-#, fuzzy
-msgid ""
-"z direction [m/s]"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:117
-#, fuzzy
-msgid ""
-"Output 3D raster map Storing the groundwater budget for each cell [m^3/s]\n"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.gwflow/main.c:127
-msgid "Use RASTER3D mask (if exists)"
+#: ../vector/v.net.salesman/main.c:141 ../vector/v.net.alloc/main.c:76
+#: ../vector/v.net.steiner/main.c:361 ../vector/v.net.iso/main.c:86
+#: ../vector/v.net.distance/main.c:86 ../vector/v.net.path/main.c:51
+#: ../display/d.path/main.c:59
+msgid "Arc type"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:163
-msgid ""
-"Numerical calculation program for transient, confined groundwater flow in "
-"three dimensions."
+#: ../vector/v.net.salesman/main.c:150
+msgid "Node layer (used for cities)"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:180
-msgid ""
-"The cholesky solver does not work with sparse matrices.\n"
-"Consider to choose a full filled quadratic matrix with flag -f "
+#: ../vector/v.net.salesman/main.c:163
+msgid "EXPERIMENTAL: Arc backward direction cost column (number)"
msgstr ""
-#: ../raster3d/r3.gwflow/main.c:365
-#, fuzzy, c-format
-msgid "Unable to create 3D raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../raster3d/r3.in.v5d/main.c:195
-msgid "Import 3-dimensional Vis5D files."
-msgstr ""
-#: ../raster3d/r3.mask/main.c:74
+#: ../vector/v.net.salesman/main.c:169
#, fuzzy
-msgid "Unable to open 3D raster mask file"
+msgid "Name for output file holding node sequence (\"-\" for stdout)"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mask/main.c:103
-msgid "makeMask: error flushing tiles in cube"
+#: ../vector/v.net.salesman/main.c:174
+msgid "Categories of points ('cities') on nodes (layer is specified by nlayer)"
msgstr ""
-#: ../raster3d/r3.mask/main.c:108
-msgid "makeMask: error flushing all tiles"
-msgstr ""
-#: ../raster3d/r3.mask/main.c:116
+#: ../vector/v.net.salesman/main.c:242 ../vector/v.net.alloc/main.c:164
+#: ../vector/v.net.steiner/main.c:444 ../vector/v.net.iso/main.c:200
#, fuzzy
-msgid "Unable to close 3D raster mask file"
+msgid "Point is not connected to the network"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mask/main.c:118
+#: ../vector/v.net.salesman/main.c:250
#, fuzzy, c-format
-msgid "Unable to close raster map <%s>"
+msgid "Number of cities: %d"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mask/main.c:136
-msgid "Establishes the current working 3D raster mask."
+#: ../vector/v.net.salesman/main.c:252
+msgid "Not enough cities (< 2)"
msgstr ""
-#: ../raster3d/r3.mask/main.c:144
+#: ../vector/v.net.salesman/main.c:288
#, fuzzy
-msgid "3D raster map with reference values"
+msgid "Creating cost cache..."
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mask/main.c:152
-msgid "List of cell values to be masked out"
-msgstr ""
+#: ../vector/v.net.salesman/main.c:309 ../vector/v.net.salesman/main.c:319
+#, fuzzy, c-format
+msgid "No point at node %d"
+msgstr "출력할 래스터맵"
-#: ../raster3d/r3.mask/main.c:158
-msgid "Cannot create mask file: RASTER3D_MASK already exists"
-msgstr ""
-#: ../raster3d/r3.null/main.c:54
-msgid "3d raster map for which to modify null values"
-msgstr ""
-#: ../raster3d/r3.null/main.c:84
-msgid "Illegal value for null"
-msgstr ""
-#: ../raster3d/r3.null/main.c:121
-msgid "modifyNull: error opening tmp file"
-msgstr ""
-#: ../raster3d/r3.null/main.c:155
-msgid "modifyNull: error flushing tiles in cube"
-msgstr ""
-#: ../raster3d/r3.null/main.c:160
-msgid "modifyNull: error flushing all tiles"
-msgstr ""
-#: ../raster3d/r3.null/main.c:170
-#, fuzzy
-msgid "modifyNull: Unable to close tmp file"
+#: ../vector/v.net.salesman/main.c:313 ../vector/v.net.salesman/main.c:323
+#, fuzzy, c-format
+msgid "No category for point at node %d"
msgstr "출력할 래스터맵"
-#: ../raster3d/r3.null/main.c:188
-msgid "Explicitly create the 3D NULL-value bitmap file."
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:46
-msgid "Print/add/remove a timestamp for a 3D raster map"
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:55
-msgid "Datetime, datetime1/datetime2, or none"
-msgstr ""
-#: ../raster3d/r3.timestamp/r3.timestamp.main.c:88
-msgid "Timestamp format is invalid"
-msgstr ""
-#: ../ps/ps.map/do_psfiles.c:20
+#: ../vector/v.net.salesman/main.c:325
#, c-format
-msgid "Reading PostScript include file <%s> ..."
+msgid "Destination node [cat %d] is unreachable from node [cat %d]"
msgstr ""
-#: ../ps/ps.map/do_labels.c:44
-#, c-format
-msgid "Can't open label file <%s> in mapset <%s>"
+#: ../vector/v.net.salesman/main.c:368
+msgid "Searching for the shortest cycle..."
msgstr ""
-#: ../ps/ps.map/do_labels.c:48
+#: ../vector/v.net.salesman/main.c:496
#, c-format
-msgid "Reading labels file <%s in %s> ..."
+msgid "Cycle with total cost %.3f"
msgstr ""
-#: ../ps/ps.map/do_labels.c:66
-#, c-format
-msgid "Can't open temporary label file <%s>"
+#: ../vector/v.db.connect/main.c:54 ../vector/v.category/main.c:77
+msgid "layer"
msgstr ""
-#: ../ps/ps.map/do_labels.c:69
-msgid "Reading text file ..."
+#: ../vector/v.db.connect/main.c:56
+msgid "Prints/sets DB connection for a vector map to attribute table."
msgstr ""
-#: ../ps/ps.map/do_labels.c:162
-msgid "Text labels: 'fontsize' given so ignoring 'size'"
+#: ../vector/v.db.connect/main.c:78
+msgid "Format: layer number[/layer name]"
msgstr ""
-#: ../ps/ps.map/r_info.c:48 ../ps/ps.map/r_vlegend.c:49
-#: ../ps/ps.map/r_colortable.c:65
-msgid "illegal where request"
+#: ../vector/v.db.connect/main.c:82
+msgid "Field separator for shell script style output"
msgstr ""
-#: ../ps/ps.map/r_info.c:67 ../ps/ps.map/ps_outline.c:87
-#: ../ps/ps.map/r_header.c:65 ../ps/ps.map/getgrid.c:61
-#: ../ps/ps.map/getgrid.c:85 ../ps/ps.map/getgrid.c:171
-#: ../ps/ps.map/getgrid.c:195
-#, fuzzy
-msgid "Unsupported color request"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_info.c:69 ../ps/ps.map/ps_outline.c:89
-#: ../ps/ps.map/r_header.c:67 ../ps/ps.map/r_instructions.c:149
-#: ../ps/ps.map/r_instructions.c:464 ../ps/ps.map/getgrid.c:63
-#: ../ps/ps.map/getgrid.c:87 ../ps/ps.map/getgrid.c:173
-#: ../ps/ps.map/getgrid.c:197
-msgid "illegal color request"
+#: ../vector/v.db.connect/main.c:87
+msgid "Print all map connection parameters and exit"
msgstr ""
-#: ../ps/ps.map/r_info.c:81
-msgid "illegal bgcolor request"
+#: ../vector/v.db.connect/main.c:92
+msgid "Print all map connection parameters in shell script style and exit"
msgstr ""
-#: ../ps/ps.map/r_info.c:93 ../ps/ps.map/r_vlegend.c:86
-msgid "illegal border color request"
+#: ../vector/v.db.connect/main.c:94
+msgid "Format: layer[/layer name] table key database driver"
msgstr ""
-#: ../ps/ps.map/r_info.c:103
-msgid "illegal mapinfo sub-request"
+#: ../vector/v.db.connect/main.c:100
+msgid "Print types/names of table columns for specified layer and exit"
msgstr ""
-#: ../ps/ps.map/r_vlegend.c:97
-msgid "illegal vlegend sub-request"
+#: ../vector/v.db.connect/main.c:107
+msgid "Overwrite connection parameter for certain layer"
msgstr ""
-#: ../ps/ps.map/makeprocs.c:29
-#, c-format
-msgid "Unable to open prolog <%s>"
+#: ../vector/v.db.connect/main.c:112
+msgid "Delete connection for certain layer (not the table)"
msgstr ""
-#: ../ps/ps.map/ps_outline.c:43
-#, fuzzy, c-format
-msgid "Outlining areas in raster map <%s in %s> ..."
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/ps_outline.c:100 ../ps/ps.map/r_colortable.c:73
-#: ../ps/ps.map/r_colortable.c:89
-msgid "illegal width request"
+#: ../vector/v.db.connect/main.c:146
+msgid "Please choose only one print style"
msgstr ""
-#: ../ps/ps.map/ps_outline.c:107
+#: ../vector/v.db.connect/main.c:155 ../vector/v.kcv/main.c:191
#, fuzzy
-msgid "illegal outline sub-request"
+msgid "Unable to modify vector map stored in other mapset"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/eps.c:18
+#: ../vector/v.db.connect/main.c:163
#, fuzzy, c-format
-msgid "Can't open eps file <%s>"
+msgid "Map <%s> is not connected to a database"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/eps.c:37
+#: ../vector/v.db.connect/main.c:172
#, fuzzy, c-format
-msgid "Bounding box in eps file <%s> was not found"
+msgid "Vector map <%s> is connected by:\n"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_header.c:77
-#, fuzzy
-msgid "illegal header sub-request"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/scale.c:136
-msgid "PSmap: do_scale(): shouldn't happen"
+#: ../vector/v.db.connect/main.c:177 ../display/d.what.vect/what.c:413
+#: ../display/d.thematic.area/main.c:201 ../display/d.vect/opt.c:143
+#, c-format
+msgid "Database connection not defined"
msgstr ""
-#: ../ps/ps.map/ps_vlines.c:56 ../ps/ps.map/ps_vareas.c:161
-#: ../ps/ps.map/ps_vpoints.c:70
-#, fuzzy
-msgid "Cannot load data from table"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/ps_vlines.c:84 ../ps/ps.map/ps_vareas.c:67
-#: ../ps/ps.map/ps_vareas.c:78
-msgid "Read error in vector map"
+#: ../vector/v.db.connect/main.c:197
+#, c-format
+msgid ""
+"layer <%d/%s> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
-#: ../ps/ps.map/ps_vlines.c:119 ../ps/ps.map/ps_vareas.c:102
-#: ../ps/ps.map/ps_vpoints.c:159 ../ps/ps.map/ps_vpoints.c:170
-#: ../ps/ps.map/ps_vpoints.c:194 ../ps/ps.map/ps_vpoints.c:235
-#: ../ps/ps.map/ps_vpoints.c:245
+#: ../vector/v.db.connect/main.c:203
#, c-format
-msgid "No record for category [%d]"
+msgid ""
+"layer <%d> table <%s> in database <%s> through driver <%s> with key <%s>\n"
msgstr ""
-#: ../ps/ps.map/ps_vlines.c:125 ../ps/ps.map/ps_vareas.c:108
-#: ../ps/ps.map/ps_vpoints.c:200
+#: ../vector/v.db.connect/main.c:266
#, c-format
-msgid "Invalid RGB color definition in column <%s> for category [%d]"
+msgid "Use -o to overwrite existing link for layer <%d>"
msgstr ""
-#: ../ps/ps.map/catval.c:48 ../ps/ps.map/catval.c:110
-#: ../ps/ps.map/catval.c:176 ../vector/v.label/main.c:273
-#: ../vector/v.vol.rst/user1.c:95 ../vector/v.label.sa/labels.c:74
-#: ../vector/v.class/main.c:110
-msgid "Unable to get layer info for vector map"
+#: ../vector/v.db.connect/main.c:274 ../vector/v.db.connect/main.c:314
+#, c-format
+msgid "Table <%s> does not exist in database <%s>"
msgstr ""
-#: ../ps/ps.map/catval.c:63
-msgid "Column type not supported (must be string)"
+#: ../vector/v.db.connect/main.c:302 ../vector/v.db.connect/main.c:320
+#, c-format
+msgid ""
+"The table <%s> is now part of vector map <%s> and may be deleted or "
+"overwritten by GRASS modules"
msgstr ""
-#: ../ps/ps.map/catval.c:66 ../ps/ps.map/catval.c:131
-#: ../ps/ps.map/catval.c:198 ../vector/v.sample/main.c:148
-#: ../vector/v.univar/main.c:354 ../vector/v.surf.idw/read_sites.c:66
-#: ../vector/v.class/main.c:131 ../vector/v.surf.bspline/main.c:392
-#: ../vector/v.to.rast3/main.c:92 ../vector/v.normal/main.c:133
-#, fuzzy
-msgid "Unable to select data from table"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/catval.c:128
-msgid "Size column type must be numeric"
+#: ../vector/v.db.connect/main.c:341 ../vector/v.kcv/main.c:202
+#, c-format
+msgid "Cannot grant privileges on table %s"
msgstr ""
-#: ../ps/ps.map/catval.c:195
-msgid "Rotation column type must be numeric"
+#: ../vector/v.db.connect/main.c:344 ../vector/v.kcv/main.c:205
+msgid "Select privileges were granted on the table"
msgstr ""
-#: ../ps/ps.map/main.c:93
-msgid "postscript"
+#: ../vector/v.db.connect/main.c:351
+msgid ""
+"For defining a new connection you have to specify these parameters: driver, "
+"database, table [, key [, layer]]"
msgstr ""
-#: ../ps/ps.map/main.c:94
-msgid "printing"
+#: ../vector/v.class/main.c:50
+msgid "Classifies attribute data, e.g. for thematic mapping"
msgstr ""
-#: ../ps/ps.map/main.c:95
-msgid "Produces hardcopy PostScript map output."
+#: ../vector/v.class/main.c:58
+msgid "Column name or expression"
msgstr ""
-#: ../ps/ps.map/main.c:99
-msgid "Rotate plot 90 degrees"
+#: ../vector/v.class/main.c:68 ../display/d.thematic.area/main.c:106
+msgid "Algorithm to use for classification"
msgstr ""
-#: ../ps/ps.map/main.c:105
-msgid "List paper formats (name width height left right top bottom(margin))"
+#: ../vector/v.class/main.c:76 ../display/d.thematic.area/main.c:110
+msgid "simple intervals"
msgstr ""
-#: ../ps/ps.map/main.c:107 ../ps/ps.map/main.c:120
-msgid "Utility"
+#: ../vector/v.class/main.c:77 ../display/d.thematic.area/main.c:111
+msgid "standard deviations"
msgstr ""
-#: ../ps/ps.map/main.c:112
-msgid "Create EPS (Encapsulated PostScript) instead of PostScript file"
+#: ../vector/v.class/main.c:78 ../display/d.thematic.area/main.c:112
+#, fuzzy
+msgid "quantiles"
+msgstr "출력할 래스터맵"
+#: ../vector/v.class/main.c:79 ../display/d.thematic.area/main.c:113
+msgid "equiprobable (normal distribution)"
msgstr ""
-#: ../ps/ps.map/main.c:118
-msgid ""
-"Describe map-box's position on the page and exit (inches from top-left of "
-"paper)"
+#: ../vector/v.class/main.c:88 ../display/d.thematic.area/main.c:122
+msgid "Number of classes to define"
msgstr ""
-#: ../ps/ps.map/main.c:123
-#, fuzzy
-msgid "File containing mapping instructions"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/main.c:124
-msgid "Use '-' to enter instructions from keyboard)"
+#: ../vector/v.class/main.c:93
+msgid "Print only class breaks (without min and max)"
msgstr ""
-#: ../ps/ps.map/main.c:127
+#: ../vector/v.class/main.c:138
#, fuzzy
-msgid "Name for PostScript output file"
+msgid "Unable to sort array of values"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/main.c:133
-msgid "Number of copies to print"
+#: ../vector/v.class/main.c:172
+msgid ""
+"The discontinuities algorithm indicates that some class breaks are not "
+"statistically significant at alpha=0.05. You are advised to reduce the "
+"number of classes."
msgstr ""
-#: ../ps/ps.map/main.c:205
-#, fuzzy, c-format
-msgid "Unable to open file '%s': %s"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/main.c:213 ../ps/ps.map/main.c:232
-#: ../vector/v.univar/main.c:144 ../vector/v.to.db/parse.c:141
-#: ../vector/v.to.db/parse.c:144
+#: ../vector/v.class/main.c:201
#, c-format
msgid ""
-"Required parameter <%s> not set:\n"
-"\t(%s)"
+"\n"
+"Classification of %s into %i classes\n"
msgstr ""
-#: ../ps/ps.map/main.c:220 ../ps/ps.map/r_instructions.c:129
-msgid "illegal copies request"
+#: ../vector/v.class/main.c:203 ../display/d.thematic.area/main.c:438
+#, c-format
+msgid "Using algorithm: *** %s ***\n"
msgstr ""
-#: ../ps/ps.map/main.c:273
+#: ../vector/v.class/main.c:204 ../display/d.thematic.area/main.c:440
#, c-format
-msgid "PostScript file '%s' successfully written."
+msgid "Mean: %f\tStandard deviation = %f\n"
msgstr ""
-#: ../ps/ps.map/do_plt.c:38
-msgid "Reading point/line file ..."
+#: ../vector/v.class/main.c:208
+#, c-format
+msgid "Lowest chi2 = %f\n"
msgstr ""
-#: ../ps/ps.map/do_plt.c:169 ../ps/ps.map/ps_vpoints.c:86
-msgid "Cannot read symbol, using default icon"
+#: ../vector/v.class/main.c:211 ../display/d.thematic.area/main.c:447
+#, c-format
+msgid "Stdev multiplied by %.4f to define step\n"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:62
-msgid "Data exist after final 'end' instruction!"
+#: ../vector/v.class/main.c:214
+#, c-format
+msgid ""
+"%15s%15s%15s\n"
+"\n"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:80
+#: ../vector/v.class/main.c:226
+#, c-format
+msgid ""
+"\n"
+"Note: Minimum of first class is including\n"
+"\n"
+msgstr ""
+#: ../vector/v.overlay/line_area.c:255 ../vector/v.overlay/area_area.c:109
#, fuzzy
-msgid "no file specified"
+msgid "Breaking lines..."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:84
+#: ../vector/v.overlay/line_area.c:272
#, fuzzy
-msgid "unable to open"
+msgid "Selecting lines..."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:115
+#: ../vector/v.overlay/line_area.c:354 ../vector/v.overlay/line_area.c:382
+#: ../vector/v.overlay/area_area.c:208 ../vector/v.overlay/area_area.c:290
+#: ../vector/v.overlay/area_area.c:318
#, fuzzy
-msgid "illegal maploc request"
+msgid "Attribute not found"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:144 ../ps/ps.map/r_instructions.c:340
+#: ../vector/v.overlay/area_area.c:51
+#, fuzzy, c-format
+msgid "Snapping boundaries with %g ..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.overlay/area_area.c:99
+#, fuzzy, c-format
+msgid "%d boundary snapped"
+msgid_plural "%d boundaries snapped"
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
+#: ../vector/v.overlay/area_area.c:154
#, fuzzy
-msgid "no raster map selected yet"
+msgid "Merging lines..."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:160
+#: ../vector/v.overlay/area_area.c:158 ../vector/v.buffer/main.c:749
#, fuzzy
-msgid "illegal value list"
+msgid "Attaching islands..."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:196
-msgid "scalebar is not appropriate for this projection"
+#: ../vector/v.overlay/area_area.c:171 ../vector/v.buffer/main.c:770
+msgid "Cannot calculate area centroid"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:204
-msgid "Bad scalebar length"
+#: ../vector/v.overlay/area_area.c:181
+#, fuzzy, c-format
+msgid "Querying vector map <%s>..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.overlay/main.c:64 ../vector/v.select/main.c:49
+msgid "spatial query"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:220
+#: ../vector/v.overlay/main.c:65
#, fuzzy
-msgid "illegal text request"
+msgid "Overlays two vector maps."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:234
+#: ../vector/v.overlay/main.c:68 ../vector/v.select/args.c:12
#, fuzzy
-msgid "illegal point request"
+msgid "Name of input vector map (A)"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:248
+#: ../vector/v.overlay/main.c:72
#, fuzzy
-msgid "illegal eps request"
+msgid "Layer number or name (vector map A)"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:265
+#: ../vector/v.overlay/main.c:76 ../vector/v.select/args.c:21
#, fuzzy
-msgid "illegal line request"
+msgid "Feature type (vector map A)"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:282
+#: ../vector/v.overlay/main.c:82 ../vector/v.select/args.c:26
#, fuzzy
-msgid "illegal rectangle request"
+msgid "Name of input vector map (B)"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:293
+#: ../vector/v.overlay/main.c:86
#, fuzzy
-msgid "illegal comments request"
+msgid "Layer number or name (vector map B)"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:309
+#: ../vector/v.overlay/main.c:90 ../vector/v.select/args.c:35
#, fuzzy
-msgid "illegal scale request"
+msgid "Feature type (vector map B)"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:369
+#: ../vector/v.overlay/main.c:101
#, fuzzy
-msgid "group not found"
+msgid "Operator defines features written to output vector map"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_instructions.c:411
-msgid "illegal grid spacing"
+#: ../vector/v.overlay/main.c:104
+msgid ""
+"Feature is written to output if the result of operation 'ainput operator "
+"binput' is true. Input feature is considered to be true, if category of "
+"given layer is defined."
msgstr ""
-#: ../ps/ps.map/r_instructions.c:422
-msgid "geogrid is not available for this projection"
+#: ../vector/v.overlay/main.c:111
+msgid "also known as 'intersection' in GIS"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:432
-msgid "illegal geo-grid spacing"
+#: ../vector/v.overlay/main.c:112
+msgid "also known as 'union' in GIS (only for atype=area)"
msgstr ""
-#: ../ps/ps.map/r_instructions.c:469
-#, fuzzy
-msgid "illegal request"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/ps_clrtbl.c:35 ../ps/ps.map/ps_fclrtbl.c:46
-#, fuzzy, c-format
-msgid "Creating color table for <%s in %s>..."
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/ps_clrtbl.c:44 ../ps/ps.map/ps_fclrtbl.c:69
-msgid "Unable to read colors for colorbar"
+#: ../vector/v.overlay/main.c:113
+msgid "features from ainput not overlayed by features from binput"
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:54
+#: ../vector/v.overlay/main.c:114
msgid ""
-"Your cats/ file is invalid. A cats/ file with categories and labels is "
-"required for 'colortable' when using categorical legends; see the r.category "
-"help page. Colortable creation has been skipped."
+"features from either ainput or binput but not those from ainput overlayed by "
+"binput (only for atype=area)"
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:69 ../ps/ps.map/ps_fclrtbl.c:93
-#: ../ps/ps.map/ps_fclrtbl.c:98
-msgid "Colorbar y location beyond page margins. Adjusting."
+#: ../vector/v.overlay/main.c:125
+msgid "Output layer for new category, ainput and binput"
msgstr ""
-#: ../ps/ps.map/ps_clrtbl.c:75 ../ps/ps.map/ps_fclrtbl.c:104
-#: ../ps/ps.map/ps_fclrtbl.c:109
-msgid "Colorbar x location beyond page margins. Adjusting."
+#: ../vector/v.overlay/main.c:126
+msgid "If 0 or not given, the category is not written"
msgstr ""
-#: ../ps/ps.map/do_scalebar.c:192
-msgid "meters"
+#: ../vector/v.overlay/main.c:134
+msgid "Disable snapping with snap <= 0"
msgstr ""
-#: ../ps/ps.map/do_scalebar.c:194
-msgid "kilometers"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:196
-msgid "feet"
-msgstr ""
-#: ../ps/ps.map/do_scalebar.c:198
-#, fuzzy
-msgid "miles"
+#: ../vector/v.overlay/main.c:168 ../vector/v.select/main.c:84
+#, fuzzy, c-format
+msgid "Unknown operator '%s'"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/do_scalebar.c:200
-msgid "nautical miles"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:81
-msgid "illegal height request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:106
-msgid "illegal range request"
-msgstr ""
-#: ../ps/ps.map/r_colortable.c:122
-#, fuzzy
-msgid "illegal columns request"
+#: ../vector/v.overlay/main.c:185
+#, fuzzy, c-format
+msgid "Unable to determine feature type for <%s>"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_colortable.c:141
-#, fuzzy
-msgid "Unsupported color request (colortable)"
+#: ../vector/v.overlay/main.c:191
+#, fuzzy, c-format
+msgid "Invalid feature type (%d) for <%s>. Only '%s' or '%s' supported."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_colortable.c:143
-msgid "illegal color request (colortable)"
+#: ../vector/v.overlay/main.c:199
+#, c-format
+msgid "Operator '%s' is not supported for type line"
msgstr ""
-#: ../ps/ps.map/r_colortable.c:170
-#, fuzzy
-msgid "illegal colortable sub-request"
+#: ../vector/v.overlay/main.c:254
+#, fuzzy, c-format
+msgid "Copying vector features from <%s>..."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_colortable.c:181
-#, fuzzy
-msgid "No raster selected for colortable!"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/ps_vpoints.c:176
+#: ../vector/v.overlay/main.c:335
#, c-format
-msgid "Attribute is of invalid size [%.3f] for category [%d]"
+msgid "No %s features found in vector map <%s>. Verify '%s' parameter."
msgstr ""
-#: ../ps/ps.map/getgrid.c:95 ../ps/ps.map/getgrid.c:206
+#: ../vector/v.overlay/main.c:384
#, fuzzy
-msgid "illegal numbers request"
+msgid "Collecting input attributes..."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/getgrid.c:126 ../ps/ps.map/getgrid.c:234
+#: ../vector/v.overlay/main.c:405 ../vector/v.label/main.c:319
+#: ../vector/v.label.sa/labels.c:161
#, fuzzy
-msgid "illegal grid width request"
+msgid "Unable to select attributes"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/getgrid.c:132
-#, fuzzy
-msgid "illegal request (grid)"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/getgrid.c:240
-#, fuzzy
-msgid "illegal request (geogrid)"
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/ps_raster.c:42
-msgid "Can't create temporary PostScript mask file."
-msgstr ""
-#: ../ps/ps.map/ps_raster.c:105
+#: ../vector/v.overlay/main.c:456
#, fuzzy, c-format
-msgid "Reading raster maps in group <%s>..."
+msgid "Unknown column type '%s' of column '%s'"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/r_group.c:29
-msgid "Can't get group information"
+#: ../vector/v.overlay/main.c:521
+#, c-format
+msgid "Unknown column type '%s' of column '%s', values lost"
msgstr ""
-#: ../ps/ps.map/r_plt.c:173
+#: ../vector/v.neighbors/main.c:54
#, fuzzy
-msgid "Can't open eps file"
+msgid "Neighborhood analysis tool for vector point maps."
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/do_vectors.c:33
-#, fuzzy, c-format
-msgid "Reading vector map <%s in %s> ..."
-msgstr "출력할 래스터맵"
-#: ../ps/ps.map/do_vectors.c:137
-#, c-format
-msgid "Reading vector points file <%s in %s> ..."
+#: ../vector/v.neighbors/main.c:55
+msgid ""
+"Makes each cell value a function of the attribute values assigned to the "
+"vector points or centroids around it, and stores new cell values in an "
+"output raster map."
msgstr ""
-#: ../ps/ps.map/do_masking.c:23
-msgid "Can't open temporary PostScript mask file."
+#: ../vector/v.neighbors/main.c:77
+msgid "Neighborhood diameter in map units"
msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:51
-msgid "Range information not available (run r.support)"
-msgstr ""
-#: ../ps/ps.map/ps_fclrtbl.c:64
-msgid "A floating point colortable must contain a range of values"
-msgstr ""
-#: ../ps/ps.map/map_setup.c:82
-#, fuzzy, c-format
-msgid "Scale set to %s"
+#: ../vector/v.neighbors/main.c:160 ../vector/v.normal/main.c:196
+#: ../vector/v.surf.idw/main.c:176
+#, fuzzy
+msgid "No points found"
msgstr "출력할 래스터맵"
-#: ../ps/ps.map/read_cfg.c:64
+#: ../vector/v.mapcalc/map.c:68
#, c-format
-msgid "Paper '%s' not found, using defaults"
+msgid "Performing 1 arg map function on map %s"
msgstr ""
-#: ../temporal/t.connect/main.c:38
-msgid ""
-"Prints/sets general temporal GIS database connection for current mapset."
+#: ../vector/v.mapcalc/map.c:79
+#, c-format
+msgid "Performing 2 arg map function on maps %s and %s"
msgstr ""
-#: ../temporal/t.connect/main.c:54
-#, fuzzy
-msgid "Overwrite current settings if initialized"
-msgstr "출력할 래스터맵"
-#: ../temporal/t.connect/main.c:59
-#, fuzzy
-msgid "Print current connection parameter in shell style and exit"
-msgstr "출력할 래스터맵"
-#: ../temporal/t.connect/main.c:83 ../temporal/t.connect/main.c:95
-msgid "Temporal GIS database connection not defined. Run t.connect."
-msgstr ""
-#: ../temporal/t.connect/main.c:111
+#: ../vector/v.mapcalc/map.c:91
#, c-format
-msgid ""
-"Default TGIS driver / database set to:\n"
-"driver: %s\n"
-"database: %s"
+msgid "Performing map %s + %s"
msgstr ""
-#: ../temporal/t.connect/main.c:118
-msgid "Default TGIS driver is not set"
+#: ../vector/v.mapcalc/map.c:265
+msgid "Can't call bad map-function"
msgstr ""
-#: ../temporal/t.connect/main.c:121
-msgid "Default TGIS database is not set"
+#: ../vector/v.mapcalc/map.c:277
+#, c-format
+msgid "Bad arguments to mapfunc %s (argc = %d)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:13
+#: ../vector/v.mapcalc/map.c:301
#, c-format
-msgid ""
-"Control Z Point file for group [%s] in [%s] \n"
-" \n"
+msgid "No function defined to perform map %c map"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:16
-#, fuzzy
-msgid "Computing equations..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:22
-msgid "Poorly placed Control Points!\n"
+#: ../vector/v.mapcalc/vector.c:245
+msgid "Can't call bad function"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:23
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:28
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:52
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:58
-#, fuzzy
-msgid "Can not generate the transformation equation.\n"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:24
-msgid "Run OPTION 7 of i.ortho.photo again!\n"
+#: ../vector/v.mapcalc/vector.c:282
+#, c-format
+msgid "Bad arguments to pointfunc %s"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:27
-msgid "No active Control Points!\n"
+#: ../vector/v.mapcalc/vector.c:305 ../vector/v.mapcalc/number.c:218
+#, c-format
+msgid "No function defined to perform ``point %c point''"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:29
-msgid "Run OPTION 7 of i.ortho.photo!\n"
+#: ../vector/v.mapcalc/number.c:161
+msgid "Can't call bad num-function"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:45
+#: ../vector/v.mapcalc/number.c:191
#, c-format
-msgid ""
-"Reference Point file for group [%s] in [%s] \n"
-" \n"
+msgid "Bad arguments to numfunc %s"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:51
-msgid "Poorly placed Reference Points!\n"
+#: ../vector/v.mapcalc/number.c:215
+#, c-format
+msgid "No function defined to perform ``number %c number''"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:53
-msgid "Run OPTION 5 of i.ortho.photo again!\n"
+#: ../vector/v.mapcalc/any.c:117
+msgid "Can't call bad any-function"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:57
-msgid "No active Reference Points!\n"
+#: ../vector/v.mapcalc/any.c:129
+#, c-format
+msgid "Bad arguments to anyfunc %s (argc = %d)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/cp.c:59
-msgid "Run OPTION 5 of i.ortho.photo!\n"
+#: ../vector/v.surf.rst/main.c:146
+msgid "Performs surface interpolation from vector points map by splines."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:10
-#: ../imagery/i.rectify/report.c:10
-msgid "complete"
+#: ../vector/v.surf.rst/main.c:148
+msgid ""
+"Spatial approximation and topographic analysis from given point or isoline "
+"data in vector format to floating point raster format using regularized "
+"spline with tension."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:20
-#: ../imagery/i.rectify/report.c:20
-#, c-format
-msgid "%d rows, %d cols (%ld cells) completed in"
+#: ../vector/v.surf.rst/main.c:155
+msgid "Perform cross-validation procedure without raster approximation"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:23
-#: ../imagery/i.rectify/report.c:23
-#, c-format
-msgid "%d:%02d:%02ld hours"
+#: ../vector/v.surf.rst/main.c:160
+msgid "Use scale dependent tension"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:25
-#: ../imagery/i.rectify/report.c:25
-#, c-format
-msgid "%d:%02ld minutes"
+#: ../vector/v.surf.rst/main.c:180 ../vector/v.surf.idw/main.c:102
+msgid ""
+"If not given and input is 2D vector map then category values are used. If "
+"input is 3D vector map then z-coordinates are used."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/report.c:27
-#: ../imagery/i.rectify/report.c:27
-#, c-format
-msgid "%.1f cells per minute"
-msgstr ""
+#: ../vector/v.surf.rst/main.c:190
+#, fuzzy
+msgid "Name for output surface elevation raster map"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:42
-#: ../imagery/i.rectify/rectify.c:41
-#, fuzzy, c-format
-msgid "Rectify <%s@%s> (location <%s>)"
+#: ../vector/v.surf.rst/main.c:220
+#, fuzzy
+msgid "Name for output mean curvature raster map"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:46
-#: ../imagery/i.rectify/rectify.c:44
-#, fuzzy, c-format
-msgid "into <%s@%s> (location <%s>) ..."
+#: ../vector/v.surf.rst/main.c:226
+#, fuzzy
+msgid "Name for output deviations vector point map"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:80
-#, c-format
-msgid "No elevation available at row = %d, col = %d"
-msgstr ""
+#: ../vector/v.surf.rst/main.c:233
+#, fuzzy
+msgid "Name for output cross-validation errors vector point map"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:126
-#: ../imagery/i.rectify/rectify.c:108
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: projection don't match current settings"
+#: ../vector/v.surf.rst/main.c:240
+#, fuzzy
+msgid "Name for output vector map showing quadtree segmentation"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/rectify.c:132
-#: ../imagery/i.rectify/rectify.c:114
-#, fuzzy, c-format
-msgid "Raster map <%s@%s>: zone don't match current settings"
+#: ../vector/v.surf.rst/main.c:247
+#, fuzzy
+msgid "Name for output vector map showing overlapping windows"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:89
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:48
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:64
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:57
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:389
-msgid "orthorectify"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:91
-msgid ""
-"Orthorectifies an image by using the image to photo coordinate "
-"transformation matrix."
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:103
-#: ../imagery/i.rectify/main.c:116
+#: ../vector/v.surf.rst/main.c:253
#, fuzzy
-msgid "Output raster map(s) suffix"
+msgid "Name of raster map used as mask"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:109
-#: ../imagery/i.rectify/main.c:130
-msgid "Target resolution (ignored if -c flag used)"
+#: ../vector/v.surf.rst/main.c:276
+msgid "Name of the attribute column with smoothing parameters"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:117
-#: ../imagery/i.rectify/main.c:138
-msgid "Amount of memory to use in MB"
+#: ../vector/v.surf.rst/main.c:309
+msgid ""
+"Maximum distance between points on isoline (to insert additional points)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:132
-msgid "Raster map with camera angle relative to ground surface"
+#: ../vector/v.surf.rst/main.c:318
+msgid "Conversion factor for values used for approximation"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:137
-#: ../imagery/i.rectify/main.c:153
-msgid ""
-"Use current region settings in target location (def.=calculate smallest area)"
+#: ../vector/v.surf.rst/main.c:326
+msgid "Anisotropy angle (in degrees counterclockwise from East)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:141
-#: ../imagery/i.rectify/main.c:157
-#, fuzzy
-msgid "Rectify all raster maps in group"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:180
-#: ../imagery/i.pca/main.c:151
+#: ../vector/v.surf.rst/main.c:389 ../vector/v.surf.rst/main.c:394
+#: ../vector/v.surf.rst/main.c:399 ../vector/v.surf.rst/main.c:404
#, fuzzy, c-format
-msgid "Group <%s> not found"
+msgid "Output vector map name <%s> is not valid map name"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:184
-#, fuzzy, c-format
-msgid "Could not read REF file for group <%s>"
+#: ../vector/v.surf.rst/main.c:417
+#, fuzzy
+msgid "You are not outputting any raster or vector maps"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:187
-#: ../imagery/i.rectify/main.c:212
-#, c-format
-msgid "Group <%s> contains no raster maps; run i.group"
+#: ../vector/v.surf.rst/main.c:426
+msgid ""
+"Both cross-validation options (-c flag and cvdev vector output) must be "
+"specified"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:241
-#, c-format
-msgid "No camera reference file selected for group <%s>"
+#: ../vector/v.surf.rst/main.c:429
+msgid ""
+"The cross-validation cannot be computed simultaneously with output raster or "
+"devi file"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:245
-#, fuzzy, c-format
-msgid "Bad format in camera file for group <%s>"
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:447
+msgid "Using anisotropy - both theta and scalex have to be specified"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:251
-#, fuzzy, c-format
-msgid "Bad format in initial exposure station file for group <%s>"
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:455
+msgid "Both smatt and smooth options specified - using constant"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:281
-#: ../imagery/i.rectify/main.c:287
-#, fuzzy, c-format
-msgid "Extension <%s> is illegal"
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:465
+msgid "The computation will last too long - lower npmin is suggested"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:284
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:293
-#: ../imagery/i.rectify/main.c:290
-#, fuzzy
-msgid "The following raster map already exists in"
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:483
+msgid "Not enough memory for az"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:285
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:294
-#: ../imagery/i.rectify/main.c:291 ../vector/v.rectify/main.c:214
-#, c-format
-msgid "target LOCATION %s, MAPSET %s:"
+#: ../vector/v.surf.rst/main.c:488
+msgid "Not enough memory for adx"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:288
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:297
-#: ../imagery/i.rectify/main.c:294
-msgid "Orthorectification cancelled."
+#: ../vector/v.surf.rst/main.c:492
+msgid "Not enough memory for ady"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:312
-#: ../imagery/i.rectify/main.c:309
-msgid "Target resolution must be > 0, ignored"
+#: ../vector/v.surf.rst/main.c:497
+msgid "Not enough memory for adxx"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:319
-#: ../imagery/i.rectify/main.c:320
-#, c-format
-msgid "Using region: N=%f S=%f, E=%f W=%f"
+#: ../vector/v.surf.rst/main.c:501
+msgid "Not enough memory for adyy"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:327
-#, c-format
-msgid "No target elevation model selected for group <%s>"
+#: ../vector/v.surf.rst/main.c:505
+msgid "Not enough memory for adxy"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:386
-#: ../imagery/i.rectify/main.c:335
-#, fuzzy, c-format
-msgid "Input raster map <%s> does not exist in group <%s>."
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:512
+msgid "Cannot create quaddata"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:388
-#: ../imagery/i.rectify/main.c:337
-msgid "Try:"
+#: ../vector/v.surf.rst/main.c:518
+msgid "Cannot create quadfunc"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/main.c:393
-#: ../imagery/i.rectify/main.c:342
-msgid "Exit!"
+#: ../vector/v.surf.rst/main.c:521
+msgid "Cannot create tree"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:13
-#: ../imagery/i.rectify/target.c:14 ../vector/v.rectify/target.c:18
-#, c-format
-msgid "Target information for group <%s> missing"
+#: ../vector/v.surf.rst/main.c:525
+msgid "Cannot create tree info"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/target.c:19
-#: ../imagery/i.rectify/target.c:20 ../vector/v.rectify/target.c:29
-#, fuzzy, c-format
-msgid "Target location <%s> not found"
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:548
+msgid "Input is 2D: using attribute values for approximation"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:36
-#, fuzzy
-msgid "Calculating camera angle to local surface..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.surf.rst/main.c:550
+msgid "Input is 2D: using category values for approximation"
+msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.rectify/angle.c:50
-#: ../imagery/i.ortho.photo/i.ortho.rectify/exec.c:43
+#: ../vector/v.surf.rst/main.c:665
+#, c-format
+msgid ""
+"Processing all selected output files will require %d bytes of disk space for "
+"temp files"
+msgstr ""
+#: ../vector/v.surf.rst/main.c:685
#, fuzzy
-msgid "Could not open elevation raster"
+msgid "Processing segments..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:50
-msgid ""
-"Interactively creates or modifies entries in a camera initial exposure "
-"station file for imagery group referenced by a sub-block."
+#: ../vector/v.surf.rst/main.c:691
+msgid "Interp_segmets failed"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:57
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:70
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:64
+#: ../vector/v.surf.rst/main.c:709
#, fuzzy
-msgid "Name of imagery group for ortho-rectification"
+msgid "Unable to write raster maps - try to increase resolution"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:62
+#: ../vector/v.timestamp/main.c:38
#, fuzzy
-msgid "Initial Camera Exposure X-coordinate"
+msgid "Modifies a timestamp for a vector map."
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:67
+#: ../vector/v.timestamp/main.c:39
#, fuzzy
-msgid "Initial Camera Exposure Y-coordinate"
+msgid "Print/add/remove a timestamp for a vector map."
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:72
-#, fuzzy
-msgid "Initial Camera Exposure Z-coordinate"
+#: ../vector/v.timestamp/main.c:65
+#, fuzzy, c-format
+msgid "Vector map <%s> not found %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:77
-msgid "X-coordinate standard deviation"
+#: ../vector/v.net.visibility/main.c:48
+msgid "visibility"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:82
-msgid "Y-coordinate standard deviation"
+#: ../vector/v.net.visibility/main.c:49
+msgid "Performs visibility graph construction."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:87
-msgid "Z-coordinate standard deviation"
-msgstr ""
+#: ../vector/v.net.visibility/main.c:61
+#, fuzzy
+msgid "One or more coordinates"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:92
-msgid "Initial Camera Omega (roll) degrees"
+#: ../vector/v.net.visibility/main.c:67
+msgid "Add points after computing the vis graph"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:97
-msgid "Initial Camera Phi (pitch) degrees"
-msgstr ""
+#: ../vector/v.net.visibility/main.c:91
+#, fuzzy, c-format
+msgid "Unable to copy elements from vector map <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:102
-msgid "Initial Camera Kappa (yaw) degrees"
-msgstr ""
+#: ../vector/v.net.visibility/main.c:96
+#, fuzzy
+msgid "Lat-long projection"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:107
-msgid "Omega (roll) standard deviation"
-msgstr ""
+#: ../vector/v.random/main.c:116
+#, fuzzy
+msgid "Generates random 2D/3D vector points."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:112
-msgid "Phi (pitch) standard deviation"
+#: ../vector/v.random/main.c:124
+#, fuzzy
+msgid "Number of points to be created"
+msgstr "출력할 래스터맵"
+#: ../vector/v.random/main.c:128
+#, fuzzy
+msgid "Restrict points to areas in input vector"
+msgstr "출력할 래스터맵"
+#: ../vector/v.random/main.c:145
+msgid "Minimum z height (needs -z flag or column name)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:117
-msgid "Kappa (yaw) standard deviation"
+#: ../vector/v.random/main.c:154
+msgid "Maximum z height (needs -z flag or column name)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:121
-msgid "Use initial values at run time"
+#: ../vector/v.random/main.c:163
+msgid ""
+"The seed to initialize the random generator. If not set the process id is "
+"used."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:125
+#: ../vector/v.random/main.c:166
#, fuzzy
-msgid "Print initial values"
+msgid "Name of column for z values"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:137
-#, fuzzy, c-format
-msgid "Group [%s] not found"
+#: ../vector/v.random/main.c:168
+#, fuzzy
+msgid "Writes z values to column"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:150
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:154
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:158
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:162
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:166
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:170
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:174
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:178
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:182
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:186
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:190
-#: ../imagery/i.ortho.photo/i.ortho.init/main.c:194
-#, fuzzy, c-format
-msgid "Option '%s' is required for new exposure info"
+#: ../vector/v.random/main.c:176
+#, fuzzy
+msgid "Type of column for z values"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:66
-msgid "Select or modify the target elevation model."
+#: ../vector/v.random/main.c:183
+msgid "Create 3D output"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:75
+#: ../vector/v.random/main.c:188
#, fuzzy
-msgid "Name of elevation map to use for ortho-rectification"
+msgid "Generate n points for each individual area"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:80
-msgid "List available raster maps in target mapset and exit"
+#: ../vector/v.random/main.c:192
+msgid "Use drand48() function instead of rand()"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:85
-#, fuzzy
-msgid "Print currently selected elevation map and exit"
+#: ../vector/v.random/main.c:207
+#, fuzzy, c-format
+msgid "Number of points must be > 0 (%d given)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:108
-#, c-format
-msgid "Please select a target for group [%s] first"
-msgstr ""
+#: ../vector/v.random/main.c:233
+#, fuzzy, c-format
+msgid "No areas in vector map <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:114
+#: ../vector/v.random/main.c:238
#, fuzzy, c-format
-msgid "Target location [%s] not found\n"
+msgid "The <-%c> flag requires an input vector with areas"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:147
-#, c-format
-msgid "Elevation map name is missing. Please set '%s' option"
+#: ../vector/v.random/main.c:291
+msgid "Table should contain only two columns"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:162
+#: ../vector/v.random/main.c:300
+msgid ""
+"You have created unsupported column type. This module supports only INTEGER "
+"and DOUBLE PRECISION column types."
+msgstr ""
+#: ../vector/v.random/main.c:373
#, fuzzy, c-format
-msgid "Elevation for group <%s> is already set to <%s>"
+msgid ""
+"Selected areas in input vector <%s> do not overlap with the current region"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:175
+#: ../vector/v.random/main.c:385
#, fuzzy, c-format
-msgid "Mapset [%s] in target location [%s] - %s "
+msgid "Input vector <%s> does not overlap with the current region"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.elev/main.c:177
+#: ../vector/v.random/main.c:410
#, fuzzy
-msgid "permission denied\n"
+msgid "Generating points..."
msgstr "출력할 래스터맵"
-#, fuzzy
-msgid "not found\n"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:59
-msgid "Select and modify the imagery group camera reference file."
+#: ../vector/v.support/main.c:41
+msgid "Updates vector map metadata."
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:71
-#, fuzzy
-msgid "Name of camera reference file"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:77
-msgid "Camera name"
+#: ../vector/v.support/main.c:52
+msgid "Organization where vector map was created"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:83
-msgid "Camera id"
+#: ../vector/v.support/main.c:61
+msgid "Date of vector map digitization (e.g., \"15 Mar 2007\")"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:89
-msgid "Calibrated focal length"
+#: ../vector/v.support/main.c:68
+msgid "Person who created vector map"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:94
+#: ../vector/v.support/main.c:75
#, fuzzy
-msgid "Principal point coordinates"
+msgid "Vector map title"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:100
-#, fuzzy
-msgid "Fiducial coordinates"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:129
-#, fuzzy, c-format
-msgid "Can not read camera file '%s'"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:132
-#, c-format
-msgid "Replacing camera name '%s' with '%s'"
+#: ../vector/v.support/main.c:83
+msgid "Date when the source map was originally produced"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:138
-#, c-format
-msgid "Replacing camera cam_id '%s' with '%s'"
+#: ../vector/v.support/main.c:89
+msgid "Vector map scale number (e.g., 24000)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:146
-#, c-format
-msgid "Replacing calibrated focal length '%g' with '%g'"
-msgstr ""
+#: ../vector/v.support/main.c:95
+#, fuzzy
+msgid "Vector map projection zone"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:153
-#, c-format
-msgid ""
-"Replacing coordinates of principal point '%.17g, %.17g' with '%.17g, %.17g'"
+#: ../vector/v.support/main.c:102
+msgid "Vector map digitizing threshold number (e.g., 0.5)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:164
-msgid "Please provide a camera name for a new camera definition"
+#: ../vector/v.support/main.c:110
+msgid "Text to append to the comment line of the map's metadata file"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:168
-msgid "Please provide a camera ID for a new camera definition"
+#: ../vector/v.support/main.c:118
+msgid ""
+"Command line to store into vector map history file (used for vector scripts)"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:172
-msgid "Please provide calibrated focal length for a new camera definition"
+#: ../vector/v.support/main.c:122
+msgid "Replace comment instead of appending it"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:176
-msgid "Using default coordinates 0.0, 0.0 for the principal point"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:190
-msgid "Too many fiducials!"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:212
+#: ../vector/v.support/main.c:183
#, fuzzy, c-format
-msgid "No group '%s' in current mapset"
+msgid "Unable to open history file for vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.camera/main.c:217
+#: ../vector/v.kernel/main.c:68
#, c-format
-msgid "Group [%s] in location [%s] mapset [%s] now uses camera file [%s]"
+msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:251
-msgid "Poorly placed image to photo control points"
+#: ../vector/v.kernel/main.c:110
+msgid "kernel density"
msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:253
-msgid "Poorly placed image to target control points"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:391
-msgid "GCP"
-msgstr ""
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:452
-#, fuzzy, c-format
-msgid "Can not read reference points for group <%s>"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ortho.photo/i.ortho.transform/main.c:456
-#, fuzzy, c-format
-msgid "Can not read control points for group <%s>"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pt/main.c:67 ../imagery/i.evapo.mh/main.c:70
-#: ../imagery/i.evapo.pm/main.c:59 ../imagery/i.evapo.time/main.c:78
+#: ../vector/v.kernel/main.c:112
#, fuzzy
-msgid "evapotranspiration"
+msgid "Generates a raster density map from vector points map."
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pt/main.c:69
+#: ../vector/v.kernel/main.c:113
msgid ""
-"Computes evapotranspiration calculation Prestley and Taylor formulation, "
-"1972."
+"Density is computed using a moving kernel. Optionally generates a vector "
+"density map on a vector network."
msgstr ""
-#: ../imagery/i.evapo.pt/main.c:75
+#: ../vector/v.kernel/main.c:117
#, fuzzy
-msgid "Name of input net radiation raster map [W/m2]"
+msgid "Name of input vector map with training points"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pt/main.c:79
+#: ../vector/v.kernel/main.c:122
#, fuzzy
-msgid "Name of input soil heat flux raster map [W/m2]"
+msgid "Name of input network vector map"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pt/main.c:83
+#: ../vector/v.kernel/main.c:125 ../vector/v.kernel/main.c:154
+#: ../vector/v.kernel/main.c:162 ../vector/v.kernel/main.c:184
+#: ../vector/v.kernel/main.c:209 ../vector/v.kernel/main.c:215
+msgid "Network"
+msgstr ""
+#: ../vector/v.kernel/main.c:132
#, fuzzy
-msgid "Name of input air temperature raster map [K]"
+msgid "Name for output raster/vector map"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pt/main.c:87
+#: ../vector/v.kernel/main.c:133
#, fuzzy
-msgid "Name of input atmospheric pressure raster map [millibars]"
+msgid "Outputs vector map if network map is given, otherwise raster map"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pt/main.c:93
-msgid "Prestley-Taylor coefficient"
+#: ../vector/v.kernel/main.c:139
+msgid "Kernel radius in map units"
msgstr ""
-#: ../imagery/i.evapo.pt/main.c:97
-#, fuzzy
-msgid "Name of output evapotranspiration raster map [mm/d]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.kernel/main.c:145
+msgid "Discretization error in map units"
+msgstr ""
-#: ../imagery/i.evapo.pt/main.c:102 ../imagery/i.evapo.mh/main.c:105
-msgid "Set negative ETa to zero"
+#: ../vector/v.kernel/main.c:152
+msgid "Maximum length of segment on network"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:70
-#, c-format
-msgid ""
-"Input raster map <%s> is not floating point (process DN using i.landsat.toar "
-"to radiance first)"
+#: ../vector/v.kernel/main.c:160
+msgid "Maximum distance from point to network"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:104
-msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+#: ../vector/v.kernel/main.c:168
+msgid "Multiply the density result by this number"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:111 ../imagery/i.landsat.toar/main.c:82
-#, fuzzy
-msgid "Base name of input raster bands"
-msgstr "출력할 래스터맵"
+#: ../vector/v.kernel/main.c:175
+msgid "Node method"
+msgstr ""
-#: ../imagery/i.landsat.acca/main.c:112 ../imagery/i.landsat.toar/main.c:83
-msgid "Example: 'B.' for B.1, B.2, ..."
+#: ../vector/v.kernel/main.c:181
+msgid "No method applied at nodes with more than 2 arcs"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:122
-msgid "B56composite (step 6)"
+#: ../vector/v.kernel/main.c:182
+msgid "Equal split (Okabe 2009) applied at nodes"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:129
-msgid "B45ratio: Desert detection (step 10)"
+#: ../vector/v.kernel/main.c:190
+msgid "Kernel function"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:137
-#, fuzzy
-msgid "Number of classes in the cloud temperature histogram"
-msgstr "출력할 래스터맵"
+#: ../vector/v.kernel/main.c:198
+msgid ""
+"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
+"maximum (experimental)"
+msgstr ""
-#: ../imagery/i.landsat.acca/main.c:139 ../imagery/i.landsat.acca/main.c:154
-#: ../imagery/i.landsat.acca/main.c:160 ../imagery/i.landsat.acca/main.c:165
-#, fuzzy
-msgid "Cloud settings"
-msgstr "출력할 래스터맵"
+#: ../vector/v.kernel/main.c:203
+msgid "Only calculate optimal standard deviation and exit (no map is written)"
+msgstr ""
-#: ../imagery/i.landsat.acca/main.c:143
-msgid "Data is Landsat-5 TM"
+#: ../vector/v.kernel/main.c:208
+msgid ""
+"In network mode, normalize values by sum of density multiplied by length of "
+"each segment. Integral over the output map then gives 1.0 * mult"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:144
-msgid "I.e. Thermal band is '.6' not '.61')"
+#: ../vector/v.kernel/main.c:214
+msgid "In network mode, multiply the result by number of input points"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:149
-msgid "Apply post-processing filter to remove small holes"
+#: ../vector/v.kernel/main.c:253
+msgid "Unknown node method"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:153
-msgid "Always use cloud signature (step 14)"
+#: ../vector/v.kernel/main.c:271
+msgid "Unknown kernel function"
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:159
+#: ../vector/v.kernel/main.c:277
msgid ""
-"Bypass second-pass processing, and merge warm (not ambiguous) and cold clouds"
+"Optimal standard deviation calculation is supported only for node method "
+"'none' and kernel function 'gaussian'."
msgstr ""
-#: ../imagery/i.landsat.acca/main.c:164
-msgid "Include a category for cloud shadows"
+#: ../vector/v.kernel/main.c:281
+msgid ""
+"Optimal standard deviation calculation is supported only for kernel function "
+"'gaussian'."
msgstr ""
-#: ../imagery/i.landsat.acca/tools.c:138
-msgid "Filling small holes in clouds..."
+#: ../vector/v.kernel/main.c:298
+#, c-format
+msgid "Standard deviation: %f"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:124
-msgid "Preliminary scene analysis:"
-msgstr ""
+#. GTC First argument is resolution, second - number of rows as a text, third - number of columns as a text.
+#: ../vector/v.kernel/main.c:302
+#, fuzzy, c-format
+msgid "Output raster map: resolution: %f\t%s\t%s"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.acca/algorithm.c:125
+#: ../vector/v.kernel/main.c:349
+#, fuzzy, c-format
+msgid "%d point outside threshold"
+msgid_plural "%d points outside threshold"
+#: ../vector/v.kernel/main.c:372
#, c-format
-msgid "* Desert index: %.2lf"
+msgid ""
+"Automatic choice of smoothing parameter (standard deviation), maximum "
+"possible value of standard deviation is set to %f"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:126
+#: ../vector/v.kernel/main.c:379
#, c-format
-msgid "* Snow cover: %.2lf %%"
+msgid "Using maximum distance between points: %f"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:127
+#: ../vector/v.kernel/main.c:393
#, c-format
-msgid "* Cloud cover: %.2lf %%"
+msgid "Number of input points: %d."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:128
-msgid "* Temperature of clouds:"
-msgstr ""
+#: ../vector/v.kernel/main.c:394
+#, fuzzy, c-format
+msgid "%d distance read from the map."
+msgid_plural "%d distances read from the map."
-#: ../imagery/i.landsat.acca/algorithm.c:129
+#: ../vector/v.kernel/main.c:399
#, c-format
-msgid "** Maximum: %.2lf K"
+msgid ""
+"Distances between all points are beyond %e (4 * standard deviation), unable "
+"to calculate optimal value."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:130
+#: ../vector/v.kernel/main.c:410
#, c-format
-msgid "** Mean (%s cloud): %.2lf K"
+msgid "Optimal smoothing parameter (standard deviation): %f."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:132
+#: ../vector/v.kernel/main.c:441
#, c-format
-msgid "** Minimum: %.2lf K"
+msgid "Writing output vector map using smooth parameter %f"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:142
-msgid "Histogram cloud signature:"
+#: ../vector/v.kernel/main.c:443 ../vector/v.kernel/main.c:553
+#, c-format
+msgid "Normalising factor %f"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:148
+#: ../vector/v.kernel/main.c:551
+#, fuzzy, c-format
+msgid "Writing output raster map using smooth parameter %f"
+msgstr "출력할 래스터맵"
+#: ../vector/v.kernel/main.c:603
#, c-format
-msgid "* Mean temperature: %.2lf K"
+msgid "Maximum value in output: %e."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:149
-#, c-format
-msgid "* Standard deviation: %.2lf"
+#: ../vector/v.build.polylines/main.c:113 ../vector/v.clean/main.c:52
+#: ../vector/v.out.postgis/main.c:48 ../vector/v.build/main.c:37
+#: ../vector/v.info/main.c:39
+#: ../locale/scriptstrings/t.topology_to_translate.c:3
+#: ../locale/scriptstrings/v.build.all_to_translate.c:3
+msgid "topology"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:150
-#, c-format
-msgid "* Skewness: %.2lf"
+#: ../vector/v.build.polylines/main.c:115
+msgid "Builds polylines from lines or boundaries."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:151
-#, c-format
-msgid "* Histogram classes: %d"
+#: ../vector/v.build.polylines/main.c:125
+msgid "Category number mode"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:163
-#, c-format
-msgid "* 98.75 percentile: %.2lf K"
+#: ../vector/v.build.polylines/main.c:130
+msgid "Do not assign any category number to polyline"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:164
-#, c-format
-msgid "* 97.50 percentile: %.2lf K"
+#: ../vector/v.build.polylines/main.c:131
+msgid "Assign category number of first line to polyline"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:165
-#, c-format
-msgid "* 83.50 percentile: %.2lf K"
+#: ../vector/v.build.polylines/main.c:132
+msgid "Assign multiple category numbers to polyline"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:186
-msgid "Maximum temperature:"
+#: ../vector/v.build.polylines/main.c:228
+#, fuzzy, c-format
+msgid "%d line or boundaries found in input vector map"
+msgid_plural "%d lines or boundaries found in input vector map"
+#: ../vector/v.build.polylines/main.c:232
+#, fuzzy, c-format
+msgid "%d polyline stored in output vector map"
+msgid_plural "%d polylines stored in output vector map"
+#: ../vector/v.normal/main.c:77
+msgid "Tests for normality for vector points."
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:187
-#, c-format
-msgid "* Cold cloud: %.2lf K"
+#: ../vector/v.normal/main.c:89
+msgid "Lists of tests (1-15)"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:188
-#, c-format
-msgid "* Warm cloud: %.2lf K"
+#: ../vector/v.normal/main.c:90
+msgid "E.g. 1,3-8,13"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:193
-msgid "Result: Scene with clouds"
+#: ../vector/v.normal/main.c:97 ../vector/v.delaunay/main.c:98
+msgid "Use only points in current region"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:200
-msgid "Result: Scene cloud free"
+#: ../vector/v.normal/main.c:101
+msgid "Lognormality instead of normality"
msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:237
-#, fuzzy
-msgid "Processing first pass..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.normal/main.c:132
+msgid "Only numeric column type supported"
+msgstr ""
-#: ../imagery/i.landsat.acca/algorithm.c:391
-#, fuzzy
-msgid "Removing ambiguous pixels..."
+#: ../vector/v.normal/main.c:175 ../vector/v.normal/main.c:183
+#, fuzzy, c-format
+msgid "No record for cat %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.acca/algorithm.c:393
-#, fuzzy
-msgid "Pass two processing..."
+#: ../vector/v.normal/main.c:193
+#, fuzzy, c-format
+msgid "Number of points: %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vpoints/main.c:97
-msgid ""
-"Set registration points for an imagery group from a vector map or keyboard "
-"entry."
+#: ../vector/v.normal/main.c:199
+msgid "Too small sample"
msgstr ""
-#: ../imagery/i.vpoints/main.c:105 ../imagery/i.points/main.c:106
-msgid "Name of imagery group to be registered"
+#: ../vector/v.normal/main.c:207
+msgid "Negative or very small point values set to -10.0"
msgstr ""
-#: ../imagery/i.vpoints/main.c:128 ../imagery/i.points/main.c:131
+#: ../vector/v.normal/main.c:224
#, c-format
-msgid "[%s] Only local groups may be used"
+msgid "Moments \\sqrt{b_1} and b_2: "
msgstr ""
-#: ../imagery/i.vpoints/main.c:137 ../imagery/i.vpoints/main.c:141
-#: ../imagery/i.points/main.c:140 ../imagery/i.points/main.c:144
+#: ../vector/v.normal/main.c:229
#, c-format
-msgid "Group [%s] contains no maps, run i.group"
+msgid "Geary's a-statistic & an approx. normal: "
msgstr ""
-#: ../imagery/i.vpoints/main.c:256 ../imagery/i.points/main.c:250
+#: ../vector/v.normal/main.c:234
#, c-format
-msgid "ERROR: %s"
+msgid "Extreme normal deviates: "
msgstr ""
-#: ../imagery/i.vpoints/main.c:258 ../imagery/i.points/main.c:252
+#: ../vector/v.normal/main.c:239
#, c-format
-msgid "WARNING: %s (click mouse to continue)"
+msgid "D'Agostino's D & an approx. normal: "
msgstr ""
-#: ../imagery/i.albedo/main.c:89 ../imagery/i.eb.netrad/main.c:65
-#: ../imagery/i.eb.netrad/main.c:67
-msgid "albedo"
+#: ../vector/v.normal/main.c:245
+#, c-format
+msgid "Kuiper's V (regular & modified for normality): "
msgstr ""
-#: ../imagery/i.albedo/main.c:90 ../imagery/i.modis.qc/main.c:120
-#: ../imagery/i.aster.toar/main.c:101 ../imagery/i.landsat.toar/main.c:73
-#: ../imagery/i.landsat.toar/main.c:577
-#, fuzzy
-msgid "reflectance"
-msgstr "출력할 래스터맵"
+#: ../vector/v.normal/main.c:251
+#, c-format
+msgid "Watson's U^2 (regular & modified for normality): "
+msgstr ""
-#: ../imagery/i.albedo/main.c:91
-msgid "Computes broad band albedo from surface reflectance."
+#: ../vector/v.normal/main.c:257
+#, c-format
+msgid "Durbin's Exact Test (modified Kolmogorov): "
msgstr ""
-#: ../imagery/i.albedo/main.c:104
-msgid "Modis (7 input bands:1,2,3,4,5,6,7)"
+#: ../vector/v.normal/main.c:263
+#, c-format
+msgid "Anderson-Darling's A^2 (regular & modified for normality): "
msgstr ""
-#: ../imagery/i.albedo/main.c:108
-msgid "NOAA AVHRR (2 input bands:1,2)"
+#: ../vector/v.normal/main.c:269
+#, c-format
+msgid "Cramer-Von Mises W^2(regular & modified for normality): "
msgstr ""
-#: ../imagery/i.albedo/main.c:112
-msgid "Landsat (6 input bands:1,2,3,4,5,7)"
+#: ../vector/v.normal/main.c:275
+#, c-format
+msgid "Kolmogorov-Smirnov's D (regular & modified for normality): "
msgstr ""
-#: ../imagery/i.albedo/main.c:116
-msgid "Aster (6 input bands:1,3,5,6,8,9)"
+#: ../vector/v.normal/main.c:281
+#, c-format
+msgid "Chi-Square stat (equal probability classes) and d.f.: "
msgstr ""
-#: ../imagery/i.albedo/main.c:120
-msgid "Agressive mode (Landsat)"
+#: ../vector/v.normal/main.c:287
+msgid "Shapiro-Wilk's W cannot be used for n > 50"
msgstr ""
-#: ../imagery/i.albedo/main.c:122 ../imagery/i.albedo/main.c:129
-msgid ""
-"Albedo dry run to calculate some water to beach/sand/desert stretching, a "
-"kind of simple atmospheric correction"
+#: ../vector/v.normal/main.c:289
+msgid "Use Weisberg-Binghams's W''"
msgstr ""
-#: ../imagery/i.albedo/main.c:127
-msgid "Soft mode (Modis)"
+#: ../vector/v.normal/main.c:292
+#, c-format
+msgid "Shapiro-Wilk W: "
msgstr ""
-#: ../imagery/i.albedo/main.c:150 ../imagery/i.aster.toar/main.c:229
+#: ../vector/v.normal/main.c:299
+msgid "Weisberg-Bingham's W'' cannot be used for n < 50 or n > 99"
+msgstr ""
+#: ../vector/v.normal/main.c:301
#, c-format
-msgid "Too many input maps. Only %d allowed."
+msgid "Weisberg-Bingham's W'': "
msgstr ""
-#: ../imagery/i.albedo/main.c:164
-#, fuzzy
-msgid "At least two raster maps are required"
-msgstr "출력할 래스터맵"
+#: ../vector/v.normal/main.c:308
+msgid "Royston only extended Shapiro-Wilk's W up to n = 2000"
+msgstr ""
-#: ../imagery/i.emissivity/main.c:45 ../imagery/i.eb.netrad/main.c:93
-#: ../imagery/i.eb.netrad/main.c:95
-msgid "emissivity"
+#: ../vector/v.normal/main.c:310
+#, c-format
+msgid "Shapiro-Wilk W'': "
msgstr ""
-#: ../imagery/i.emissivity/main.c:46
-msgid "land flux"
+#: ../vector/v.normal/main.c:316
+#, c-format
+msgid "Kotz' T'_f (Lognormality vs. Normality): "
msgstr ""
-#: ../imagery/i.emissivity/main.c:47 ../imagery/i.eb.h_sebal01/main.c:84
-#: ../imagery/i.eb.netrad/main.c:57 ../imagery/i.eb.soilheatflux/main.c:50
-#: ../imagery/i.eb.eta/main.c:44 ../imagery/i.eb.evapfr/main.c:48
-msgid "energy balance"
+#: ../vector/v.category/main.c:79
+msgid "Attaches, deletes or reports vector categories to map geometry."
msgstr ""
-#: ../imagery/i.emissivity/main.c:49
-msgid "Computes emissivity from NDVI, generic method for sparse land."
+#: ../vector/v.category/main.c:92
+msgid "Feature ids (by default all features are processed)"
msgstr ""
-#: ../imagery/i.emissivity/main.c:53
+#: ../vector/v.category/main.c:104
#, fuzzy
-msgid "Name of the NDVI map [-]"
+msgid "Action to be done"
msgstr "출력할 래스터맵"
-#: ../imagery/i.emissivity/main.c:56
+#: ../vector/v.category/main.c:115
#, fuzzy
-msgid "Name of the output emissivity layer"
+msgid "add a new category"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/print4.c:16
-#, c-format
-msgid "class centroids (sum/count=mean)\n"
+#: ../vector/v.category/main.c:116
+msgid "delete category (cat=-1 to delete all categories of given layer)"
msgstr ""
-#: ../imagery/i.cluster/print4.c:18
-#, c-format
-msgid "band %d"
+#: ../vector/v.category/main.c:117
+msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
msgstr ""
-#: ../imagery/i.cluster/print3.c:16
-#, c-format
+#: ../vector/v.category/main.c:118
+msgid "add the value specified by cat option to the current category value"
+msgstr ""
+#: ../vector/v.category/main.c:119
msgid ""
-"\n"
-"initial means for each band\n"
-"\n"
+"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
+"layer 1 to layer 2 and 3)"
msgstr ""
-#: ../imagery/i.cluster/print3.c:19
-#, c-format
-msgid "class %-3d "
+#: ../vector/v.category/main.c:120
+msgid "print report (statistics), in shell style: layer type count min max"
msgstr ""
-#: ../imagery/i.cluster/print2.c:18
-#, c-format
-msgid ""
-"\n"
-"class means/stddev for each band\n"
-"\n"
+#: ../vector/v.category/main.c:121
+msgid "print category values, more cats in the same layer are separated by '/'"
msgstr ""
-#: ../imagery/i.cluster/print2.c:22
-#, c-format
-msgid "class %d (%d)\n"
+#: ../vector/v.category/main.c:122
+#, fuzzy
+msgid "print only layer numbers"
+msgstr "출력할 래스터맵"
+#: ../vector/v.category/main.c:134
+#: ../locale/scriptstrings/v.centroids_to_translate.c:7
+msgid "Category increment"
msgstr ""
-#: ../imagery/i.cluster/print2.c:23
-#, c-format
-msgid " means "
+#: ../vector/v.category/main.c:138
+msgid "Shell script style, currently only for report"
msgstr ""
-#: ../imagery/i.cluster/print2.c:28
-#, c-format
-msgid " stddev"
+#: ../vector/v.category/main.c:139
+msgid "Format: layer type count min max"
msgstr ""
-#: ../imagery/i.cluster/main.c:77 ../imagery/i.class/main.c:93
-#: ../imagery/i.gensigset/main.c:44 ../imagery/i.gensig/main.c:44
+#: ../vector/v.category/main.c:142
#, fuzzy
-msgid "signatures"
+msgid "Do not copy attribute table(s)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/main.c:79
+#: ../vector/v.category/main.c:160
msgid ""
-"Generates spectral signatures for land cover types in an image using a "
-"clustering algorithm."
+"Database connection and attribute tables for concerned layers are not changed"
msgstr ""
-#: ../imagery/i.cluster/main.c:82
+#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:250
+#: ../vector/v.category/main.c:258 ../vector/v.kcv/main.c:120
+#: ../vector/v.kcv/main.c:209
+#, fuzzy, c-format
+msgid "Unable to open vector map <%s> at topological level %d"
+msgstr "출력할 래스터맵"
+#: ../vector/v.category/main.c:208
msgid ""
-"The resulting signature file is used as input for i.maxlik, to generate an "
-"unsupervised image classification."
+"Invalid category number (must be equal to or greater than 0). Normally "
+"category number starts at 1."
msgstr ""
-#: ../imagery/i.cluster/main.c:95 ../imagery/i.gensigset/parse.c:25
-#: ../imagery/i.gensig/parse.c:26
+#: ../vector/v.category/main.c:217
+#, fuzzy, c-format
+msgid "%d error in id option"
+msgid_plural "%d errors in id option"
+#: ../vector/v.category/main.c:228
#, fuzzy
-msgid "Name for output file containing result signatures"
+msgid "Output vector wasn't entered"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/main.c:102
-msgid "Initial number of classes"
+#: ../vector/v.category/main.c:275
+msgid "Too many layers for this operation"
msgstr ""
-#: ../imagery/i.cluster/main.c:111
-#, fuzzy
-msgid "Name of file containing initial signatures"
+#: ../vector/v.category/main.c:278 ../vector/v.category/main.c:281
+msgid "2 layers must be specified"
+msgstr ""
+#: ../vector/v.category/main.c:289
+#, fuzzy, c-format
+msgid "Categories already exist in layer %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/main.c:119
-msgid "Sampling intervals (by row and col); default: ~10,000 pixels"
+#: ../vector/v.category/main.c:378
+#, fuzzy, c-format
+msgid "%d new centroid placed in output map"
+msgid_plural "%d new centroids placed in output map"
+#: ../vector/v.category/main.c:680
+msgid "Layer/table"
msgstr ""
-#: ../imagery/i.cluster/main.c:126 ../imagery/i.segment/parse_args.c:101
-msgid "Maximum number of iterations"
+#: ../vector/v.category/main.c:684
+msgid "Layer"
msgstr ""
-#: ../imagery/i.cluster/main.c:135
-msgid "Percent convergence"
+#: ../vector/v.category/main.c:686
+#, c-format
+msgid "type count min max\n"
msgstr ""
-#: ../imagery/i.cluster/main.c:143
-msgid "Cluster separation"
+#: ../vector/v.category/main.c:687
+msgid "point"
msgstr ""
-#: ../imagery/i.cluster/main.c:151
-msgid "Minimum number of pixels in a class"
+#: ../vector/v.category/main.c:691
+msgid "line"
msgstr ""
-#: ../imagery/i.cluster/main.c:158
+#: ../vector/v.category/main.c:695
#, fuzzy
-msgid "Name for output file containing final report"
+msgid "boundary"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/main.c:177
-#, fuzzy, c-format
-msgid "Illegal number of initial classes (%s)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.category/main.c:699
+#: ../locale/scriptstrings/v.centroids_to_translate.c:3
+msgid "centroid"
+msgstr ""
-#: ../imagery/i.cluster/main.c:188
-#, c-format
-msgid "Illegal value(s) of sample intervals (%s)"
+#: ../vector/v.category/main.c:703
+#: ../locale/scriptstrings/v.dissolve_to_translate.c:4
+#: ../locale/scriptstrings/v.centroids_to_translate.c:4
+msgid "area"
msgstr ""
-#: ../imagery/i.cluster/main.c:202
-#, fuzzy, c-format
-msgid "Illegal value of iterations (%s)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.category/main.c:707
+msgid "face"
+msgstr ""
-#: ../imagery/i.cluster/main.c:208
-#, fuzzy, c-format
-msgid "Illegal value of convergence (%s)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.category/main.c:711
+msgid "kernel"
+msgstr ""
-#: ../imagery/i.cluster/main.c:213
-#, fuzzy, c-format
-msgid "Illegal value of separation (%s)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.category/main.c:715
+msgid "all"
+msgstr ""
-#: ../imagery/i.cluster/main.c:218
+#: ../vector/v.category/main.c:779
#, fuzzy, c-format
-msgid "Illegal value of min_size (%s)"
+msgid "Categories copied from layer %d to layer %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/main.c:227
+#: ../vector/v.category/main.c:781
#, fuzzy, c-format
-msgid "Unable to create report file <%s>"
-msgstr "출력할 래스터맵"
+msgid "%d feature modified."
+msgid_plural "%d features modified."
-#: ../imagery/i.cluster/main.c:235
-#, c-format
-msgid ""
-"#################### CLUSTER (%s) ####################\n"
-"\n"
+#: ../vector/v.label/main.c:60 ../vector/v.label.sa/main.c:39
+#: ../display/d.labels/main.c:44
+msgid "paint labels"
msgstr ""
-#: ../imagery/i.cluster/main.c:237
-#, c-format
-msgid "Location: %s\n"
+#: ../vector/v.label/main.c:62
+msgid "Creates paint labels for a vector map from attached attributes."
msgstr ""
-#: ../imagery/i.cluster/main.c:238
-#, c-format
-msgid "Mapset: %s\n"
+#: ../vector/v.label/main.c:67 ../vector/v.label.sa/main.c:61
+msgid "Name for new paint-label file"
msgstr ""
-#: ../imagery/i.cluster/main.c:239
-#, c-format
-msgid "Group: %s\n"
+#: ../vector/v.label/main.c:69
+msgid "If not given the name of the input map is used"
msgstr ""
-#: ../imagery/i.cluster/main.c:240
-#, c-format
-msgid "Subgroup: %s\n"
+#: ../vector/v.label/main.c:78 ../vector/v.label.sa/main.c:57
+msgid "Name of attribute column to be used for labels"
msgstr ""
-#: ../imagery/i.cluster/main.c:242
-#, c-format
-msgid " %s\n"
+#: ../vector/v.label/main.c:89
+msgid "Rotate labels to align with lines"
msgstr ""
-#: ../imagery/i.cluster/main.c:245
-#, c-format
-msgid "Result signature file: %s\n"
+#: ../vector/v.label/main.c:94
+msgid "Curl labels along lines"
msgstr ""
-#: ../imagery/i.cluster/main.c:247
-#, c-format
-msgid "Region\n"
+#: ../vector/v.label/main.c:99
+msgid "Offset label in x-direction"
msgstr ""
-#: ../imagery/i.cluster/main.c:248
-#, c-format
-msgid " North: %12.2f East: %12.2f\n"
+#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
+#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
+msgid "Placement"
msgstr ""
-#: ../imagery/i.cluster/main.c:250
-#, c-format
-msgid " South: %12.2f West: %12.2f\n"
+#: ../vector/v.label/main.c:106
+msgid "Offset label in y-direction"
msgstr ""
-#: ../imagery/i.cluster/main.c:252
-#, c-format
-msgid " Res: %12.2f Res: %12.2f\n"
+#: ../vector/v.label/main.c:113 ../vector/v.lrs/v.lrs.label/main.c:174
+msgid "Reference position"
msgstr ""
-#: ../imagery/i.cluster/main.c:254
-#, c-format
-msgid " Rows: %12d Cols: %12d Cells: %d\n"
+#: ../vector/v.label/main.c:122 ../display/d.legend/main.c:157
+#: ../display/d.text/main.c:218 ../display/d.vect/main.c:256
+msgid "Font name"
msgstr ""
-#: ../imagery/i.cluster/main.c:256
-#, c-format
-msgid "Mask: %s\n"
+#: ../vector/v.label/main.c:125 ../vector/v.label/main.c:132
+#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
+#: ../vector/v.lrs/v.lrs.label/main.c:181 ../vector/v.label.sa/main.c:72
+#: ../vector/v.label.sa/main.c:80
+msgid "Font"
msgstr ""
-#: ../imagery/i.cluster/main.c:258
-#, c-format
-msgid "Cluster parameters\n"
+#: ../vector/v.label/main.c:129 ../vector/v.lrs/v.lrs.label/main.c:187
+#: ../vector/v.label.sa/main.c:77
+msgid "Label size (in map-units)"
msgstr ""
-#: ../imagery/i.cluster/main.c:259
-#, c-format
-msgid " Number of initial classes: %d"
+#: ../vector/v.label/main.c:137
+msgid "Space between letters for curled labels (in map-units)"
msgstr ""
-#: ../imagery/i.cluster/main.c:261
-#, c-format
-msgid " [from signature file %s]"
+#: ../vector/v.label/main.c:144
+msgid "Label size (in points)"
msgstr ""
-#: ../imagery/i.cluster/main.c:263
-#, c-format
-msgid " Minimum class size: %d\n"
+#: ../vector/v.label/main.c:151 ../vector/v.lrs/v.lrs.label/main.c:194
+#: ../vector/v.label.sa/main.c:98 ../display/d.legend/main.c:95
+#: ../display/d.grid/main.c:102 ../display/d.rhumbline/main.c:68
+msgid "Text color"
msgstr ""
-#: ../imagery/i.cluster/main.c:264
-#, c-format
-msgid " Minimum class separation: %f\n"
+#: ../vector/v.label/main.c:152 ../vector/v.label/main.c:176
+#: ../vector/v.label/main.c:189 ../vector/v.label/main.c:195
+#: ../vector/v.label/main.c:205 ../vector/v.label.sa/main.c:103
+#: ../vector/v.label.sa/main.c:113 ../vector/v.label.sa/main.c:120
+#: ../vector/v.label.sa/main.c:130 ../vector/v.label.sa/main.c:140
+#: ../vector/v.label.sa/main.c:150 ../vector/v.label.sa/main.c:157
+#: ../display/d.northarrow/main.c:66 ../display/d.northarrow/main.c:72
+#: ../display/d.rast.arrow/main.c:120 ../display/d.rast.arrow/main.c:128
+#: ../display/d.rast.arrow/main.c:137 ../display/d.rast.arrow/main.c:146
+#: ../display/d.vect/main.c:120 ../display/d.vect/main.c:130
+#: ../display/d.vect/main.c:137 ../display/d.vect/main.c:144
+#: ../display/d.vect/main.c:299 ../display/d.barscale/main.c:113
+#: ../display/d.barscale/main.c:117 ../display/d.rast.num/main.c:89
+#: ../display/d.rast.num/main.c:94 ../display/d.rast.num/main.c:112
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:10
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:12
+#: ../locale/scriptstrings/i.landsat.rgb_to_translate.c:14
+msgid "Colors"
msgstr ""
-#: ../imagery/i.cluster/main.c:265
-#, c-format
-msgid " Percent convergence: %f\n"
+#: ../vector/v.label/main.c:156
+msgid "Rotation angle (degrees counter-clockwise)"
msgstr ""
-#: ../imagery/i.cluster/main.c:266
-#, c-format
-msgid " Maximum number of iterations: %d\n"
+#: ../vector/v.label/main.c:166
+msgid "Border width"
msgstr ""
-#: ../imagery/i.cluster/main.c:268
-#, c-format
-msgid " Row sampling interval: %d\n"
+#: ../vector/v.label/main.c:174 ../vector/v.lrs/v.lrs.label/main.c:211
+#: ../vector/v.label.sa/main.c:107
+msgid "Highlight color for text"
msgstr ""
-#: ../imagery/i.cluster/main.c:269
-#, c-format
-msgid " Col sampling interval: %d\n"
+#: ../vector/v.label/main.c:180 ../vector/v.label.sa/main.c:117
+msgid "Width of highlight coloring"
msgstr ""
-#: ../imagery/i.cluster/main.c:278 ../imagery/i.gensigset/read_data.c:22
-#: ../imagery/i.ifft/main.c:142
-#, fuzzy
-msgid "Reading raster maps..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.label/main.c:187 ../vector/v.lrs/v.lrs.label/main.c:229
+#: ../vector/v.label.sa/main.c:124 ../display/d.path/main.c:116
+#: ../locale/scriptstrings/r.in.wms_to_translate.c:32
+msgid "Background color"
+msgstr ""
-#: ../imagery/i.cluster/main.c:288
-msgid "Out of Memory. Please run again and choose a smaller sample size."
+#: ../vector/v.label/main.c:193 ../vector/v.lrs/v.lrs.label/main.c:238
+#: ../vector/v.label.sa/main.c:144 ../display/d.grid/main.c:96
+msgid "Border color"
msgstr ""
-#: ../imagery/i.cluster/main.c:294
-#, c-format
-msgid "Sample size: %d points\n"
+#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
+msgid "Opaque to vector (only relevant if background color is selected)"
msgstr ""
-#: ../imagery/i.cluster/main.c:297
+#: ../vector/v.label/main.c:251
msgid ""
-"Not enough sample points. Please run again and choose a larger sample size."
+"size and space options vary significantly which may lead to crummy output"
msgstr ""
-#: ../imagery/i.cluster/main.c:301
-msgid ""
-"Not enough non-zero sample data points. Check your current region (and mask)."
+#: ../vector/v.label/main.c:259
+msgid "Too many parameters for <reference>"
msgstr ""
-#: ../imagery/i.cluster/main.c:314
+#: ../vector/v.label/main.c:438
#, c-format
-msgid ""
-"\n"
-"########## final results #############\n"
+msgid "Labeled %d lines."
msgstr ""
-#: ../imagery/i.cluster/main.c:315
-#, c-format
-msgid "%d classes (convergence=%.1f%%)\n"
+#: ../vector/v.out.pov/main.c:49
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
msgstr ""
-#: ../imagery/i.cluster/main.c:326
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s> for group <%s>, subsgroup <%s>"
+#: ../vector/v.out.pov/main.c:60
+#, fuzzy
+msgid "Name for output POV file"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/main.c:331
-#, c-format
-msgid ""
-"\n"
-"\n"
-"#################### CLASSES ####################\n"
+#: ../vector/v.out.pov/main.c:67
+msgid "Radius of sphere for points and tube for lines"
msgstr ""
-#: ../imagery/i.cluster/main.c:332
-#, c-format
-msgid ""
-"\n"
-"%d classes, %.2f%% points stable\n"
+#: ../vector/v.out.pov/main.c:68
+msgid "May be also variable, e.g. grass_r."
msgstr ""
-#: ../imagery/i.cluster/main.c:334
-#, c-format
-msgid ""
-"\n"
-"######## CLUSTER END (%s) ########\n"
-msgstr ""
+#: ../vector/v.out.pov/main.c:74
+#, fuzzy
+msgid "Modifier for z coordinates"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/print5.c:15
-#, c-format
+#: ../vector/v.out.pov/main.c:75
msgid ""
-"\n"
-"class separability matrix\n"
-"\n"
+"This string is appended to each z coordinate. Examples: '*10', '+1000', "
+"'*10+100', '*exaggeration'"
msgstr ""
-#: ../imagery/i.cluster/print1.c:12
-#, c-format
-msgid ""
-"means and standard deviations for %d band%s\n"
-"\n"
+#: ../vector/v.out.pov/main.c:82
+msgid "Object modifier (OBJECT_MODIFIER in POV-Ray documentation)"
msgstr ""
-#: ../imagery/i.cluster/print1.c:14
-#, c-format
-msgid " means "
+#: ../vector/v.out.pov/main.c:83
+msgid "Example: \"pigment { color red 0 green 1 blue 0 }\""
msgstr ""
-#: ../imagery/i.cluster/print1.c:18
-#, c-format
-msgid " stddev "
-msgstr ""
-#: ../imagery/i.cluster/print6.c:11
-#, c-format
-msgid "class distribution"
-msgstr ""
-#: ../imagery/i.cluster/open_files.c:18 ../imagery/i.maxlik/open.c:17
-#: ../imagery/i.smap/parse.c:61 ../imagery/i.gensigset/parse.c:47
-#: ../imagery/i.gensig/parse.c:41
+#: ../vector/v.out.pov/main.c:104
#, fuzzy, c-format
-msgid "Group <%s> not found in current mapset"
+msgid "Unable to create output file <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:22 ../imagery/i.maxlik/open.c:20
-#: ../imagery/i.smap/parse.c:64 ../imagery/i.gensigset/parse.c:50
-#: ../imagery/i.gensig/parse.c:44
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> not found"
+#: ../vector/v.out.pov/main.c:175 ../vector/v.select/select.c:166
+#, fuzzy
+msgid "Processing areas..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:34
+#: ../vector/v.out.pov/main.c:218
#, fuzzy, c-format
-msgid "Raster map <%s> do not exists in subgroup <%s>"
-msgstr "출력할 래스터맵"
+msgid "%d feature written."
+msgid_plural "%d features written."
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:39
-#, fuzzy
-msgid "No raster maps found"
+#: ../vector/v.select/copy_tabs.c:49
+#, fuzzy, c-format
+msgid "No table for layer %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:43
+#: ../vector/v.select/copy_tabs.c:64
#, fuzzy, c-format
-msgid "Subgroup <%s> doesn't have any raster maps"
+msgid "Unable to copy table for layer %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:46
-#, c-format
-msgid "Subgroup <%s> only has 1 raster map"
+#: ../vector/v.select/main.c:51
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
msgstr ""
-#: ../imagery/i.cluster/open_files.c:47
-msgid "Subgroup must have at least 2 raster maps"
+#: ../vector/v.select/main.c:93
+msgid "Operator can only be 'overlap'"
msgstr ""
-#: ../imagery/i.cluster/open_files.c:64
+#: ../vector/v.select/main.c:124
+msgid "Output from v.select"
+msgstr ""
+#: ../vector/v.select/main.c:180
#, fuzzy, c-format
-msgid "Unable to open seed signature file <%s>"
+msgid "%d features without category skipped"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:70 ../imagery/i.maxlik/open.c:53
-#: ../imagery/i.smap/read_sig.c:23
+#: ../vector/v.select/main.c:183
#, fuzzy, c-format
-msgid "Unable to read signature file <%s>"
+msgid "%d features written to output."
msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/open_files.c:74 ../imagery/i.maxlik/open.c:57
-#, c-format
-msgid "<%s> has too many signatures (limit is 255)"
-msgstr ""
+#: ../vector/v.select/write.c:26
+#, fuzzy
+msgid "Writing selected features..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/checkpt.c:16
-#, c-format
-msgid "using seed means (%d files)\n"
-msgstr ""
+#: ../vector/v.select/args.c:16
+#, fuzzy
+msgid "Layer number (vector map A)"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.cluster/checkpt.c:28
-#, c-format
+#: ../vector/v.select/args.c:30
+#, fuzzy
+msgid "Layer number (vector map B)"
+msgstr "출력할 래스터맵"
+#: ../vector/v.select/args.c:47
+#, fuzzy
+msgid "Operator defines required relation between features"
+msgstr "출력할 래스터맵"
+#: ../vector/v.select/args.c:49
msgid ""
-"\n"
-"######## iteration %d ###########\n"
+"A feature is written to output if the result of operation 'ainput operator "
+"binput' is true. An input feature is considered to be true, if category of "
+"given layer is defined."
msgstr ""
-#: ../imagery/i.cluster/checkpt.c:30
-#, c-format
-msgid "%d classes, %.2f%% points stable\n"
+#: ../vector/v.select/args.c:57 ../vector/v.select/args.c:73
+msgid "features partially or completely overlap"
msgstr ""
-#: ../imagery/i.cluster/checkpt.c:40
-#, c-format
-msgid "Iteration %.2d: convergence %.2f%% (%s elapsed, %s left)"
+#: ../vector/v.select/args.c:74
+msgid "features are spatially equals (using GEOS)"
msgstr ""
-#: ../imagery/i.class/curses.c:22
-#, c-format
-msgid "make_window(%d,%d,%d,%d): illegal screen values."
+#: ../vector/v.select/args.c:75
+msgid "features do not spatially intersect (using GEOS)"
msgstr ""
-#: ../imagery/i.class/curses.c:153
-#, c-format
-msgid "%s"
+#: ../vector/v.select/args.c:76
+msgid "features spatially intersect (using GEOS)"
msgstr ""
-#: ../imagery/i.class/analyze_sig.c:12
-msgid "Cannot analyze until region is completed."
+#: ../vector/v.select/args.c:77
+msgid "features spatially touches (using GEOS)"
msgstr ""
-#: ../imagery/i.class/draw_reg.c:89
-#, c-format
-msgid ""
-"\n"
-"Orig:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
+#: ../vector/v.select/args.c:78
+msgid "features spatially crosses (using GEOS)"
msgstr ""
-#: ../imagery/i.class/draw_reg.c:97
-#, c-format
-msgid ""
-"\n"
-"New:(x1 y1), (x2 y2) = (%d %d), (%d %d)"
+#: ../vector/v.select/args.c:79
+msgid "feature A is completely inside feature B (using GEOS)"
msgstr ""
-#: ../imagery/i.class/save_reg.c:14
-msgid "Region is not complete, can not save."
+#: ../vector/v.select/args.c:80
+msgid "feature B is completely inside feature A (using GEOS)"
msgstr ""
-#: ../imagery/i.class/main.c:94 ../imagery/i.maxlik/main.c:63
-#: ../imagery/i.gensig/main.c:42
-msgid "Maximum Likelihood Classification"
+#: ../vector/v.select/args.c:81
+msgid "features spatially overlap (using GEOS)"
msgstr ""
-#: ../imagery/i.class/main.c:96
+#: ../vector/v.select/args.c:82
msgid ""
-"Generates spectral signatures for an image by allowing the user to outline "
-"regions of interest."
+"feature A is spatially related to feature B (using GEOS, requires 'relate' "
+"option)"
msgstr ""
-#: ../imagery/i.class/main.c:99
-msgid ""
-"The resulting signature file can be used as input for i.maxlik or as a seed "
-"signature file for i.cluster."
+#: ../vector/v.select/args.c:92
+msgid "Intersection Matrix Pattern used for 'relate' operator"
msgstr ""
-#: ../imagery/i.class/main.c:113 ../imagery/i.cca/main.c:95
-msgid "Name of input imagery subgroup"
-msgstr ""
+#: ../vector/v.select/args.c:99
+#, fuzzy
+msgid "Do not skip features without category"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.class/main.c:118
-msgid "File to contain result signatures"
-msgstr ""
+#: ../vector/v.select/select.c:63
+#, fuzzy, c-format
+msgid "Unable to read line id %d from vector map <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.class/main.c:123
-msgid "File containing input signatures (seed)"
-msgstr ""
-#: ../imagery/i.class/main.c:135
-msgid "You have a mask set. Unset mask and run again"
-msgstr ""
-#: ../imagery/i.class/main.c:144 ../imagery/i.group/main.c:117
-#: ../imagery/i.target/main.c:80
-#, fuzzy
-msgid "Group must exist in the current mapset"
+#: ../vector/v.select/select.c:189
+#, fuzzy, c-format
+msgid "Unable to read area id %d from vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.class/main.c:253
-#, c-format
-msgid "** The following raster maps in subgroup [%s] do not exist:"
+#: ../vector/v.parallel/main.c:52
+msgid "Creates parallel line to input vector lines."
msgstr ""
-#: ../imagery/i.class/main.c:262
-#, c-format
-msgid "Subgroup [%s] does not have any files"
+#: ../vector/v.parallel/main.c:67
+msgid "Offset along major axis in map units"
msgstr ""
-#: ../imagery/i.class/main.c:263 ../imagery/i.class/main.c:267
-msgid "The subgroup must have at least 2 files to run"
+#: ../vector/v.parallel/main.c:75
+msgid "Offset along minor axis in map units"
msgstr ""
-#: ../imagery/i.class/main.c:266
-#, c-format
-msgid "Subgroup [%s] only has 1 file"
+#: ../vector/v.parallel/main.c:83 ../vector/v.buffer/main.c:267
+msgid "Angle of major axis in degrees"
msgstr ""
-#: ../imagery/i.class/main.c:275
-msgid ""
-"\n"
-"RESULT SIGNATURE"
+#: ../vector/v.parallel/main.c:92
+msgid "Side"
msgstr ""
-#: ../imagery/i.class/main.c:280
-#, c-format
-msgid "Unable to open output signature file '%s'"
+#: ../vector/v.parallel/main.c:96
+msgid "Parallel line is on the left"
msgstr ""
-#: ../imagery/i.class/main.c:287
-msgid ""
-"\n"
-"SEED SIGNATURES"
+#: ../vector/v.parallel/main.c:97
+msgid "Parallel line is on the right"
msgstr ""
-#: ../imagery/i.class/main.c:292
-#, c-format
-msgid "Unable to read signature file [%s]"
+#: ../vector/v.parallel/main.c:98
+msgid "Parallel lines on both sides"
msgstr ""
-#: ../imagery/i.class/main.c:295
-#, c-format
-msgid "** Unable to read signature file [%s] **"
+#: ../vector/v.parallel/main.c:107
+msgid "Tolerance of arc polylines in map units"
msgstr ""
-#: ../imagery/i.class/main.c:302
-#, c-format
-msgid "%s has too many signatures"
+#: ../vector/v.parallel/main.c:111
+msgid "Make outside corners round"
msgstr ""
-#: ../imagery/i.class/add_point.c:22
-#, c-format
-msgid "Can't mark another point. Only %d points allowed. Sorry."
+#: ../vector/v.parallel/main.c:115
+msgid "Create buffer-like parallel lines"
msgstr ""
-#: ../imagery/i.class/remove_mask.c:15
-msgid "Error while removing the old MASK cell map."
+#: ../vector/v.buffer/main.c:226
+msgid "Creates a buffer around vector features of given type."
msgstr ""
-#: ../imagery/i.class/signature.c:50 ../imagery/i.class/signature.c:55
-msgid "Unable to allocate space for signature statistics."
+#: ../vector/v.buffer/main.c:251
+msgid "Buffer distance along major axis in map units"
msgstr ""
-#: ../imagery/i.class/signature.c:82
-msgid "prepare_signature: outline has odd number of points."
+#: ../vector/v.buffer/main.c:252 ../vector/v.buffer/main.c:260
+#: ../vector/v.buffer/main.c:268 ../vector/v.buffer/main.c:274
+#: ../vector/v.buffer/main.c:282 ../vector/v.buffer/main.c:291
+msgid "Distance"
msgstr ""
-#: ../imagery/i.class/signature.c:113
-#, c-format
-msgid "prepare_signature: scan line %d has odd number of points."
+#: ../vector/v.buffer/main.c:259
+msgid "Buffer distance along minor axis in map units"
msgstr ""
-#: ../imagery/i.class/signature.c:123
-msgid "signature: perimeter points out of order."
-msgstr ""
+#: ../vector/v.buffer/main.c:273
+#, fuzzy
+msgid "Name of column to use for buffer distances"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.class/signature.c:132
-msgid "prepare_signature: data error."
+#: ../vector/v.buffer/main.c:281
+msgid "Scaling factor for attribute column values"
msgstr ""
-#: ../imagery/i.class/signature.c:234
-msgid "Unknown Menu selection in show_signature()."
+#: ../vector/v.buffer/main.c:290
+msgid ""
+"Maximum distance between theoretical arc and polygon segments as multiple of "
+"buffer"
msgstr ""
-#: ../imagery/i.class/complete_reg.c:12
-msgid "Too few points for region. Must have at least 3 points."
+#: ../vector/v.buffer/main.c:295
+msgid "Make outside corners straight"
msgstr ""
-#: ../imagery/i.class/complete_reg.c:14
-msgid "Area already completed."
+#: ../vector/v.buffer/main.c:299
+msgid "Don't make caps at the ends of polylines"
msgstr ""
-#: ../imagery/i.class/erase_reg.c:10
-msgid "Can not erase an undefined region."
-msgstr ""
+#: ../vector/v.buffer/main.c:303
+#, fuzzy
+msgid "Transfer categories and attributes"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.class/outline.c:57
-msgid "Absurd polygon."
+#: ../vector/v.buffer/main.c:323
+msgid "Select a buffer distance/minordistance/angle or column, but not both."
msgstr ""
-#: ../imagery/i.class/outline.c:99
-msgid "Outlined area is too large."
+#: ../vector/v.buffer/main.c:352
+msgid "The bufcol option requires a valid layer."
msgstr ""
-#: ../imagery/i.class/restore_reg.c:15
-msgid "No region is saved, can not restore."
+#: ../vector/v.buffer/main.c:356
+msgid "The tolerance must be > 0."
msgstr ""
-#: ../imagery/i.class/redisplay.c:56
-msgid "No zoom window is defined."
+#: ../vector/v.buffer/main.c:359
+#, c-format
+msgid "The tolerance was reset to %g"
msgstr ""
-#: ../imagery/i.evapo.mh/main.c:72
-msgid ""
-"Computes evapotranspiration calculation modified or original Hargreaves "
-"formulation, 2001."
-msgstr ""
-#: ../imagery/i.evapo.mh/main.c:78
+#: ../vector/v.buffer/main.c:363
#, fuzzy
-msgid "Name of input diurnal net radiation raster map [W/m2/d]"
+msgid "Illegal scale value"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.mh/main.c:82
-#, fuzzy
-msgid "Name of input average air temperature raster map [C]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.buffer/main.c:380
+#, c-format
+msgid "The tolerance in map units = %g"
+msgstr ""
-#: ../imagery/i.evapo.mh/main.c:86
-#, fuzzy
-msgid "Name of input minimum air temperature raster map [C]"
+#: ../vector/v.buffer/main.c:420
+#, fuzzy, c-format
+msgid "Unable to select data from table <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.mh/main.c:90
-#, fuzzy
-msgid "Name of input maximum air temperature raster map [C]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.buffer/main.c:456
+msgid ""
+"No features available for buffering. Check type option and features "
+"available in the input vector."
+msgstr ""
-#: ../imagery/i.evapo.mh/main.c:96
-#, fuzzy
-msgid "Name of precipitation raster map [mm/month]"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.mh/main.c:97
-msgid "Disabled for original Hargreaves (1985)"
+#: ../vector/v.buffer/main.c:472
+msgid ""
+"Negative distances for internal buffers are not supported and converted to "
+"positive values."
msgstr ""
-#: ../imagery/i.evapo.mh/main.c:100
+#: ../vector/v.buffer/main.c:482
#, fuzzy
-msgid "Name for output raster map [mm/d]"
+msgid "Buffering areas..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.mh/main.c:109
-msgid "Use original Hargreaves (1985)"
+#: ../vector/v.buffer/main.c:518 ../vector/v.buffer/main.c:619
+#, c-format
+msgid "Attribute is of invalid size (%.3f) for category %d"
msgstr ""
-#: ../imagery/i.evapo.mh/main.c:113
-msgid "Use Hargreaves-Samani (1985)"
+#: ../vector/v.buffer/main.c:532 ../vector/v.buffer/main.c:637
+#, c-format
+msgid "The tolerance in map units: %g"
msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:85 ../imagery/i.eb.evapfr/main.c:49
-msgid "soil moisture"
-msgstr ""
+#: ../vector/v.buffer/main.c:577
+#, fuzzy
+msgid "Buffering features..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:86 ../imagery/i.eb.evapfr/main.c:50
-msgid "evaporative fraction"
+#: ../vector/v.buffer/main.c:580 ../vector/v.buffer/main.c:629
+msgid "Negative distances are only supported for areas"
msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:87 ../imagery/i.eb.netrad/main.c:59
-#: ../imagery/i.eb.soilheatflux/main.c:52 ../imagery/i.eb.eta/main.c:46
-#: ../imagery/i.eb.evapfr/main.c:51
-msgid "SEBAL"
-msgstr ""
+#: ../vector/v.buffer/main.c:702
+#, fuzzy
+msgid "Cleaning buffers..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:88
-msgid "Computes sensible heat flux iteration SEBAL 01."
-msgstr ""
+#: ../vector/v.buffer/main.c:705
+#, fuzzy
+msgid "Building parts of topology..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:94
+#: ../vector/v.buffer/main.c:719
#, fuzzy
-msgid "Name of instantaneous Net Radiation raster map [W/m2]"
+msgid "Snapping boundaries..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:99
+#: ../vector/v.buffer/main.c:735
#, fuzzy
-msgid "Name of instantaneous soil heat flux raster map [W/m2]"
+msgid "Cleaning boundaries at nodes"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:104
+#: ../vector/v.buffer/main.c:756
#, fuzzy
-msgid "Name of aerodynamic resistance to heat momentum raster map [s/m]"
+msgid "Calculating centroids for all areas..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:109
+#: ../vector/v.buffer/main.c:787
#, fuzzy
-msgid "Name of altitude corrected surface temperature raster map [K]"
+msgid "Generating list of boundaries to be deleted..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:117
-msgid "Value of the height independent friction velocity (u*) [m/s]"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:125
+#: ../vector/v.buffer/main.c:820
#, fuzzy
-msgid "Value of the actual vapour pressure (e_act) [KPa]"
+msgid "Deleting boundaries..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:132
-msgid "Row value of the wet pixel"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:139
-msgid "Column value of the wet pixel"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:146
-msgid "Row value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:153
-msgid "Column value of the dry pixel"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:157
+#: ../vector/v.buffer/main.c:852
#, fuzzy
-msgid "Name for output sensible heat flux raster map [W/m2]"
+msgid "Calculating centroids for areas..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:162
-msgid "Automatic wet/dry pixel (careful!)"
-msgstr ""
+#: ../vector/v.buffer/main.c:865
+#, fuzzy, c-format
+msgid "Unable to calculate centroid for area %d"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:167
-msgid "Dry/Wet pixels coordinates are in image projection, not row/col"
+#: ../vector/v.buffer/geos.c:19
+msgid "Invalid GEOS geometry!"
msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:195
-msgid "Either auto-mode either wet/dry pixels coordinates should be provided!"
+#: ../vector/v.buffer/geos.c:25
+msgid "No coordinates in GEOS geometry (can be ok for negative distance)!"
msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:198
-msgid "Manual wet/dry pixels in image coordinates"
-msgstr ""
+#: ../vector/v.buffer/geos.c:33
+#, fuzzy, c-format
+msgid "Invalid x coordinate %f"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.h_sebal01/main.c:199
-#, c-format
-msgid "Wet Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:200
-#, c-format
-msgid "Dry Pixel=> x:%f y:%f"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:204
-msgid "Automatic mode selected"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:206
-#, c-format
-msgid "Wet Pixel=> row:%.0f col:%.0f"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:207
-#, c-format
-msgid "Dry Pixel=> row:%.0f col:%.0f"
-msgstr ""
-#: ../imagery/i.eb.h_sebal01/main.c:212
+#: ../vector/v.buffer/geos.c:35
#, fuzzy, c-format
-msgid "<%s> is an illegal name"
+msgid "Invalid y coordinate %f"
msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:119
-msgid "imagery quality assessment"
+#: ../vector/v.buffer/geos.c:107
+msgid "Corrupt GEOS geometry"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:121
+#: ../vector/v.buffer/geos.c:135
#, fuzzy
-msgid "land surface temperature"
+msgid "Unknown GEOS geometry type"
msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:122
+#: ../vector/v.buffer/geos.c:164
#, fuzzy
-msgid "vegetation"
+msgid "Buffering failed"
msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:123
-msgid "MODIS"
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:125
-msgid "Extracts quality control parameters from Modis QC layers."
-msgstr ""
-#: ../imagery/i.modis.qc/main.c:130
-#, fuzzy
-msgid "Name of input surface reflectance QC layer [bit array]"
+#: ../vector/v.clean/rmline.c:64
+#, fuzzy, c-format
+msgid "Lines / boundaries removed: %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:135
+#: ../vector/v.clean/main.c:54
#, fuzzy
-msgid "Name for output QC type classification layer"
+msgid "Toolset for cleaning topology of vector map."
msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:141
-msgid "Name of MODIS product type"
+#: ../vector/v.clean/main.c:69
+msgid "Name of output map where errors are written"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:152
-msgid "surf. refl. 250m 8-days"
+#: ../vector/v.clean/main.c:80
+msgid "Cleaning tool"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:153
-msgid "surf. refl. 500m 8-days"
+#: ../vector/v.clean/main.c:96
+msgid "break lines at each intersection"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:154
-msgid "surf. refl. 500m 8-days, State QA"
+#: ../vector/v.clean/main.c:97
+msgid "remove duplicate geometry features (pay attention to categories!)"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:155
-msgid "LST 1Km daily (Day/Night)"
+#: ../vector/v.clean/main.c:98
+msgid "remove dangles, threshold ignored if < 0"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:156
-msgid "LST 1Km 8-days (Day/Night)"
+#: ../vector/v.clean/main.c:99
+msgid ""
+"change the type of boundary dangle to line, threshold ignored if < 0, input "
+"line type is ignored"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:157
-msgid "VI 1Km 16-days"
+#: ../vector/v.clean/main.c:101
+msgid "remove bridges connecting area and island or 2 islands"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:158
-msgid "Brdf-Albedo Quality (Ancillary SDS) 1Km 8-days"
+#: ../vector/v.clean/main.c:102
+msgid ""
+"change the type of bridges connecting area and island or 2 islands from "
+"boundary to line"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:159
-msgid "Brdf-Albedo Quality (BRDF SDS) 1Km 8-days"
+#: ../vector/v.clean/main.c:104
+msgid "snap lines to vertex in threshold"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:168
+#: ../vector/v.clean/main.c:105
#, fuzzy
-msgid "Name of QC type to extract"
+msgid "remove duplicate area centroids ('type' option ignored)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:209
-msgid "mod09: Adjacency Correction"
+#: ../vector/v.clean/main.c:106
+msgid ""
+"break (topologically clean) polygons (imported from non topological format, "
+"like ShapeFile). Boundaries are broken on each point shared between 2 and "
+"more polygons where angles of segments are different"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:210
-msgid "mod09: Atmospheric Correction"
+#: ../vector/v.clean/main.c:109
+msgid ""
+"remove vertices in threshold from lines and boundaries, boundary is pruned "
+"only if topology is not damaged (new intersection, changed attachment of "
+"centroid), first and last segment of the boundary is never changed"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:211
-msgid "mod09: Cloud State"
+#: ../vector/v.clean/main.c:113
+msgid "remove small areas, the longest boundary with adjacent area is removed"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:212
-msgid "mod09: Band-Wise Data Quality Flag"
+#: ../vector/v.clean/main.c:114
+msgid "remove all lines or boundaries of zero length, threshold is ignored"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:213
-msgid "mod09: 250m Band is at Different Orbit than 500m"
+#: ../vector/v.clean/main.c:115
+msgid "remove small angles between lines at nodes"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:214
-msgid "mod09: MODIS Land General Quality Assessment"
+#: ../vector/v.clean/main.c:123
+msgid "Threshold in map units, one value for each tool"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:215
-msgid "mod11A1: MODIS Land General Quality Assessment"
+#: ../vector/v.clean/main.c:124
+msgid "Default: 0.0[,0.0,...])"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:216
-msgid "mod11A1: Detailed Quality Indications"
+#: ../vector/v.clean/main.c:129
+msgid "Don't build topology for the output vector"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:217
-msgid "mod11A1: Average Emissivity Error Classes"
+#: ../vector/v.clean/main.c:134
+msgid "Combine tools with recommended follow-up tools"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:218
-msgid "mod11A1: Average LST Error Classes"
+#: ../vector/v.clean/main.c:155
+msgid "You must select at least one tool"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:219
-msgid "mod11A2: Detailed Quality Indications"
+#: ../vector/v.clean/main.c:190
+msgid "Tool doesn't exist"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:220
-msgid "mod11A2: Average Emissivity Error Classes"
+#: ../vector/v.clean/main.c:210
+#, c-format
+msgid "Threshold for tool %d may not be > 0, set to 0"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:221
-msgid "mod11A2: MODIS Land General Quality Assessment"
+#: ../vector/v.clean/main.c:219
+msgid "Tool: Threshold"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:222
-msgid "mod11A2: Average LST Error Classes"
+#: ../vector/v.clean/main.c:224
+msgid "Break"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:223 ../imagery/i.modis.qc/main.c:224
-#: ../imagery/i.modis.qc/main.c:225 ../imagery/i.modis.qc/main.c:226
-#: ../imagery/i.modis.qc/main.c:227 ../imagery/i.modis.qc/main.c:228
-#: ../imagery/i.modis.qc/main.c:229 ../imagery/i.modis.qc/main.c:230
-#: ../imagery/i.modis.qc/main.c:231 ../imagery/i.modis.qc/main.c:232
-#: ../imagery/i.modis.qc/main.c:233
-msgid "mod09A1s: StateQA Internal Snow Mask"
+#: ../vector/v.clean/main.c:227
+msgid "Remove duplicates"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:234
-msgid "mod13A2: MODIS Land General Quality Assessment"
+#: ../vector/v.clean/main.c:230
+msgid "Remove dangles"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:235
-msgid "mod13A2: Quality estimation of the pixel"
+#: ../vector/v.clean/main.c:233
+msgid "Change type of boundary dangles"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:236
-msgid "mod13A2: Quantity range of Aerosol"
+#: ../vector/v.clean/main.c:237
+msgid "Remove bridges"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:237
-msgid "mod13A2: if pixel is a cloud neighbour"
+#: ../vector/v.clean/main.c:240
+msgid "Change type of boundary bridges"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:238
-msgid "mod13A2: if BRDF correction performed"
+#: ../vector/v.clean/main.c:244
+msgid "Snap vertices"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:239
-msgid "mod13A2: if pixel mixed with clouds"
+#: ../vector/v.clean/main.c:247
+msgid "Remove duplicate area centroids"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:240
-msgid "mod13A2: separate land from various water objects"
+#: ../vector/v.clean/main.c:251
+msgid "Break polygons"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:241
-msgid "mod13A2: if snow/ice present in pixel"
+#: ../vector/v.clean/main.c:254
+msgid "Prune"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:242
-msgid "mod13A2: if shadow is present in pixel"
+#: ../vector/v.clean/main.c:257
+msgid "Remove small areas"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:243 ../imagery/i.modis.qc/main.c:244
-#: ../imagery/i.modis.qc/main.c:245
-msgid "mcd43B2: Quality of BRDF correction performed"
+#: ../vector/v.clean/main.c:260
+msgid "Remove small angles at nodes"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:246
-msgid "mcd43B2q: Quality of BRDF correction performed"
+#: ../vector/v.clean/main.c:265
+msgid "Remove all lines or boundaries of zero length"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:256
-msgid ""
-"Band number of Modis product (mod09Q1=[1,2],mod09A1=[1-7], mcd43B2q=[1-7])"
+#: ../vector/v.clean/main.c:309
+msgid "Topological cleaning works best with native GRASS vector format"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:260
-msgid "Band 1: Red"
-msgstr ""
+#: ../vector/v.clean/main.c:320
+#, fuzzy
+msgid "Failed to copy attribute table to output vector map"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:261
-msgid "Band 2: NIR"
+#: ../vector/v.clean/main.c:335 ../vector/v.clean/main.c:346
+msgid "Rebuilding parts of topology..."
msgstr ""
-#: ../imagery/i.modis.qc/main.c:262
-msgid "Band 3: Blue"
-msgstr ""
+#: ../vector/v.clean/main.c:355 ../vector/v.clean/main.c:400
+#: ../vector/v.clean/main.c:451
+#, fuzzy
+msgid "Tool: Split lines"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.modis.qc/main.c:263
-msgid "Band 4: Green"
+#: ../vector/v.clean/main.c:358 ../vector/v.clean/main.c:404
+#: ../vector/v.clean/main.c:457
+msgid "Tool: Break lines at intersections"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:264
-msgid "Band 5: SWIR 1"
+#: ../vector/v.clean/main.c:361 ../vector/v.clean/main.c:370
+#: ../vector/v.clean/main.c:406 ../vector/v.clean/main.c:422
+#: ../vector/v.clean/main.c:459
+msgid "Tool: Remove duplicates"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:265
-msgid "Band 6: SWIR 2"
+#: ../vector/v.clean/main.c:364 ../vector/v.clean/main.c:413
+#: ../vector/v.clean/main.c:464
+#, fuzzy
+msgid "Tool: Merge lines"
+msgstr "출력할 래스터맵"
+#: ../vector/v.clean/main.c:374
+msgid "Tool: Remove dangles"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:266
-msgid "Band 7: SWIR 3"
+#: ../vector/v.clean/main.c:378
+msgid "Tool: Change type of boundary dangles"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:285
-msgid "This flag is only available for MOD09Q1 @ 250m products"
+#: ../vector/v.clean/main.c:382
+msgid "Tool: Remove bridges"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:289 ../imagery/i.modis.qc/main.c:319
-msgid "Band number out of allowed range [1-7]"
+#: ../vector/v.clean/main.c:386
+msgid "Tool: Change type of boundary bridges"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:291
-msgid "mod09Q1 product only has 2 bands"
+#: ../vector/v.clean/main.c:390
+msgid "Tool: Remove duplicate area centroids"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:302
-msgid "This flag is only available for MOD09A1s @ 500m products"
+#: ../vector/v.clean/main.c:394
+msgid "Tool: Snap line to vertex in threshold"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:309
-msgid "This flag is only available for MOD13A2 @ 1Km products"
+#: ../vector/v.clean/main.c:408 ../vector/v.clean/main.c:442
+#: ../vector/v.clean/main.c:461
+msgid "Tool: Remove small angles at nodes"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:315
-msgid "This flag is only available for MCD43B2 @ 1Km products"
+#: ../vector/v.clean/main.c:419
+msgid "Tool: Break polygons"
msgstr ""
-#: ../imagery/i.modis.qc/main.c:504
-msgid "Unknown names and/or combination, please check spelling"
+#: ../vector/v.clean/main.c:427
+msgid "Tool: Prune lines/boundaries"
msgstr ""
-#: ../imagery/i.evapo.pm/main.c:61
-msgid ""
-"Computes potential evapotranspiration calculation with hourly Penman-"
-"Monteith."
+#: ../vector/v.clean/main.c:431
+msgid "Tool: Remove small areas"
msgstr ""
-#: ../imagery/i.evapo.pm/main.c:65
+#: ../vector/v.clean/main.c:437
#, fuzzy
-msgid "Name of input elevation raster map [m a.s.l.]"
+msgid "Tool: Merge boundaries"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:69
+#: ../vector/v.clean/main.c:470
+msgid "Tool: Remove all lines and boundaries of zero length"
+msgstr ""
+#: ../vector/v.clean/main.c:479
#, fuzzy
-msgid "Name of input temperature raster map [C]"
+msgid "Rebuilding topology for output vector map..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:73
+#: ../vector/v.clean/main.c:490
#, fuzzy
-msgid "Name of input relative humidity raster map [%]"
+msgid "Building topology for error vector map..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:77
+#: ../vector/v.clean/split.c:85
+#, c-format
+msgid "Line splits: %d"
+msgstr ""
+#: ../vector/v.clean/rmdac.c:60
+#, fuzzy, c-format
+msgid "Duplicate area centroids: %d"
+msgstr "출력할 래스터맵"
+#: ../vector/v.clean/prune.c:216
+#, c-format
+msgid ""
+"%d vertices from input %d (vertices of given type) removed, i.e. %.2f %%"
+msgstr ""
+#: ../vector/v.clean/prune.c:220
+#, c-format
+msgid "%d boundaries not pruned because pruning would damage topology"
+msgstr ""
+#: ../vector/v.sample/main.c:79
#, fuzzy
-msgid "Name of input wind speed raster map [m/s]"
+msgid "Samples a raster map at vector point locations."
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:82
+#: ../vector/v.sample/main.c:89
#, fuzzy
-msgid "Name of input net solar radiation raster map [MJ/m2/h]"
+msgid "Name of attribute column to use for comparison"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:86
+#: ../vector/v.sample/main.c:92
#, fuzzy
-msgid "Name of input crop height raster map [m]"
+msgid "Name for output vector map to store differences"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:89
+#: ../vector/v.sample/main.c:96
#, fuzzy
-msgid "Name for output raster map [mm/h]"
+msgid "Name of raster map to be sampled"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:93
+#: ../vector/v.sample/main.c:107
#, fuzzy
-msgid "Set negative evapotranspiration to zero"
+msgid "Scaling factor for values read from raster map"
msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.pm/main.c:97
-msgid "Use Night-time"
+#: ../vector/v.sample/main.c:109
+msgid "Sampled values will be multiplied by this factor"
msgstr ""
-#: ../imagery/i.maxlik/invert.c:28
+#: ../vector/v.sample/main.c:133 ../vector/v.reclass/main.c:128
+#: ../vector/v.surf.idw/read_sites.c:50
#, c-format
-msgid "Signature %d is not valid (ill-conditioned) - ignored"
+msgid "Database connection not defined for layer %s"
msgstr ""
-#: ../imagery/i.maxlik/invert.c:31
+#: ../vector/v.sample/main.c:147
#, c-format
-msgid "Signature %d is not valid (singular) - ignored"
+msgid "Column type <%s> not supported (must be integer or double precision)"
msgstr ""
-#: ../imagery/i.maxlik/main.c:66
-msgid "Classifies the cell spectral reflectances in imagery data."
-msgstr ""
+#: ../vector/v.sample/main.c:153
+#, fuzzy, c-format
+msgid "%d record selected from table"
+msgid_plural "%d records selected from table"
-#: ../imagery/i.maxlik/main.c:68
-msgid ""
-"Classification is based on the spectral signature information generated by "
-"either i.cluster, i.class, or i.gensig."
-msgstr ""
-#: ../imagery/i.maxlik/main.c:81 ../imagery/i.smap/parse.c:20
-#, fuzzy
-msgid "Name of input file containing signatures"
+#: ../vector/v.sample/main.c:187 ../vector/v.patch/main.c:298
+#, fuzzy, c-format
+msgid "Unable to create table <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.maxlik/main.c:82
-msgid "Generated by either i.cluster, g.gui.iclass, or i.gensig"
-msgstr ""
-#: ../imagery/i.maxlik/main.c:86 ../imagery/i.smap/parse.c:28
+#: ../vector/v.sample/main.c:197
#, fuzzy
-msgid "Name for output raster map holding classification results"
+msgid "Reading points..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.maxlik/main.c:92
-#, fuzzy
-msgid "Name for output raster map holding reject threshold results"
+#: ../vector/v.sample/main.c:260 ../vector/v.kcv/main.c:307
+#, fuzzy, c-format
+msgid "Unable to insert row: %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.maxlik/open.c:27
-#, c-format
-msgid ""
-"Subgroup <%s> of group <%s> doesn't have any raster maps. The subgroup must "
-"have at least 2 raster maps."
+#: ../vector/v.lidar.growing/ConvexHull.c:269
+msgid "...now exiting to system..."
msgstr ""
-#: ../imagery/i.maxlik/open.c:30
-#, c-format
+#: ../vector/v.lidar.growing/main.c:78
msgid ""
-"Subgroup <%s> of group <%s> only has 1 raster map. The subgroup must have at "
-"least 2 raster maps."
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
msgstr ""
-#: ../imagery/i.maxlik/open.c:47
+#: ../vector/v.lidar.growing/main.c:83
+msgid "Input vector (v.lidar.edgedetection output"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:93
+msgid "Name of the first pulse vector map"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:100
+msgid "Threshold for cell object frequency in region growing"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:108
+msgid "Threshold for double pulse in region growing"
+msgstr ""
+#: ../vector/v.lidar.growing/main.c:176
#, fuzzy, c-format
-msgid "Unable to open signature file <%s>"
+msgid "Unable to open table <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.his.rgb/main.c:52
-msgid ""
-"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
-"RGB (Red-Green-Blue) color space."
+#: ../vector/v.lidar.growing/main.c:201
+msgid "Setting regions and boxes"
msgstr ""
-#: ../imagery/i.his.rgb/main.c:58
-#, fuzzy
-msgid "Name of input raster map (hue)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lidar.growing/main.c:267
+#, c-format
+msgid "Rows = %d"
+msgstr ""
-#: ../imagery/i.his.rgb/main.c:62
-#, fuzzy
-msgid "Name of input raster map (intensity)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lidar.growing/main.c:268
+#, c-format
+msgid "Columns = %d"
+msgstr ""
-#: ../imagery/i.his.rgb/main.c:66
+#: ../vector/v.lidar.growing/main.c:288
#, fuzzy
-msgid "Name of input raster map (saturation)"
+msgid "read points in input vector"
msgstr "출력할 래스터맵"
-#: ../imagery/i.his.rgb/main.c:70
+#: ../vector/v.lidar.growing/main.c:437
#, fuzzy
-msgid "Name for output raster map (red)"
+msgid "Region Growing"
msgstr "출력할 래스터맵"
-#: ../imagery/i.his.rgb/main.c:74
+#: ../vector/v.lrs/v.lrs.create/main.c:122
+#: ../vector/v.lrs/v.lrs.label/main.c:103
+#: ../vector/v.lrs/v.lrs.segment/main.c:72
+#: ../vector/v.lrs/v.lrs.where/main.c:58
+msgid "Linear Reference System"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:123
+#: ../vector/v.lrs/v.lrs.label/main.c:104
+#: ../vector/v.lrs/v.lrs.segment/main.c:73
+#: ../vector/v.lrs/v.lrs.where/main.c:59
+msgid "networking"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:124
#, fuzzy
-msgid "Name for output raster map (green)"
+msgid "Creates a linear reference system."
msgstr "출력할 래스터맵"
-#: ../imagery/i.his.rgb/main.c:78
+#: ../vector/v.lrs/v.lrs.create/main.c:128
+#: ../vector/v.lrs/v.lrs.label/main.c:109
+#: ../vector/v.lrs/v.lrs.segment/main.c:79
+#: ../vector/v.lrs/v.lrs.where/main.c:66
#, fuzzy
-msgid "Name for output raster map (blue)"
+msgid "Input vector map containing lines"
msgstr "출력할 래스터맵"
-#: ../imagery/i.smap/interp.c:233
-msgid "Invalid parameter values"
+#: ../vector/v.lrs/v.lrs.create/main.c:133
+msgid "Output vector map where oriented lines are written"
msgstr ""
-#: ../imagery/i.smap/main.c:40 ../imagery/i.gensigset/main.c:42
-#: ../imagery/i.gensig/main.c:41
+#: ../vector/v.lrs/v.lrs.create/main.c:138
#, fuzzy
-msgid "supervised classification"
+msgid "Output vector map of errors"
msgstr "출력할 래스터맵"
-#: ../imagery/i.smap/main.c:41 ../imagery/i.segment/main.c:36
+#: ../vector/v.lrs/v.lrs.create/main.c:143
#, fuzzy
-msgid "segmentation"
+msgid "Input vector map containing reference points"
msgstr "출력할 래스터맵"
-#: ../imagery/i.smap/main.c:42 ../imagery/i.gensigset/main.c:43
-msgid "SMAP"
+#: ../vector/v.lrs/v.lrs.create/main.c:147
+#: ../vector/v.lrs/v.lrs.label/main.c:118
+#: ../vector/v.lrs/v.lrs.segment/main.c:88
+#: ../vector/v.lrs/v.lrs.where/main.c:75
+msgid "Line layer"
msgstr ""
-#: ../imagery/i.smap/main.c:44
-msgid ""
-"Performs contextual image classification using sequential maximum a "
-"posteriori (SMAP) estimation."
+#: ../vector/v.lrs/v.lrs.create/main.c:151
+#: ../vector/v.lrs/v.lrs.where/main.c:80
+msgid "Point layer"
msgstr ""
-#: ../imagery/i.smap/segment.c:67
-#, fuzzy
-msgid "Number of classes must be < 256"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:158
+msgid "Column containing line identifiers for lines"
+msgstr ""
-#: ../imagery/i.smap/segment.c:102
-#, c-format
-msgid "Processing rows %d-%d (of %d)..."
+#: ../vector/v.lrs/v.lrs.create/main.c:165
+msgid "Column containing line identifiers for points"
msgstr ""
-#: ../imagery/i.smap/openfiles.c:18 ../imagery/i.smap/read_sig.c:13
-#: ../imagery/i.gensigset/openfiles.c:18 ../imagery/i.gensig/openfiles.c:19
-#, fuzzy, c-format
-msgid "Unable to read REF file for subgroup <%s> in group <%s>"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:173
+msgid "Column containing milepost position for the beginning of next segment"
+msgstr ""
-#: ../imagery/i.smap/openfiles.c:22 ../imagery/i.smap/read_sig.c:17
-#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:182
+msgid ""
+"Column containing offset from milepost for the beginning of next segment"
+msgstr ""
-#: ../imagery/i.smap/write_img.c:15
-#, fuzzy
-msgid "Writing output raster map(s)..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:191
+msgid "Column containing milepost position for the end of previous segment"
+msgstr ""
-#: ../imagery/i.smap/model.c:43
-#, c-format
-msgid "Nonsymetric covariance for class %d subclass %d"
+#: ../vector/v.lrs/v.lrs.create/main.c:200
+msgid "Column containing offset from milepost for the end of previous segment"
msgstr ""
-#: ../imagery/i.smap/model.c:55
-#, c-format
-msgid "Nonpositive eigenvalues for class %d subclass %d"
+#: ../vector/v.lrs/v.lrs.create/main.c:207
+#: ../vector/v.lrs/v.lrs.label/main.c:124
+#: ../vector/v.lrs/v.lrs.segment/main.c:94
+#: ../vector/v.lrs/v.lrs.where/main.c:86
+msgid "Driver name for reference system table"
msgstr ""
-#: ../imagery/i.smap/parse.c:21
-msgid "Generated by i.gensigset"
+#: ../vector/v.lrs/v.lrs.create/main.c:215
+#: ../vector/v.lrs/v.lrs.label/main.c:132
+#: ../vector/v.lrs/v.lrs.segment/main.c:102
+#: ../vector/v.lrs/v.lrs.where/main.c:94
+msgid "Database name for reference system table"
msgstr ""
-#: ../imagery/i.smap/parse.c:33
-#, fuzzy
-msgid "Name for output raster map holding goodness of fit (lower is better)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:223
+msgid "Name of table where the reference system will be written"
+msgstr ""
-#: ../imagery/i.smap/parse.c:37
-msgid "Size of submatrix to process at one time"
+#: ../vector/v.lrs/v.lrs.create/main.c:224
+msgid "New table is created by this module"
msgstr ""
-#: ../imagery/i.smap/parse.c:45
-msgid "Use maximum likelihood estimation (instead of smap)"
+#: ../vector/v.lrs/v.lrs.create/main.c:231
+msgid "Maximum distance of point to line allowed"
msgstr ""
-#: ../imagery/i.smap/read_sig.c:27
+#: ../vector/v.lrs/v.lrs.create/main.c:286
+msgid "Cannot get layer info for lines"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:289
+msgid "Cannot get layer info for points"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:313
+#: ../vector/v.lrs/v.lrs.label/main.c:311
+#: ../vector/v.lrs/v.lrs.segment/main.c:155
+#: ../vector/v.lrs/v.lrs.where/main.c:147
+#, fuzzy
+msgid "Unable to open database for reference table"
+msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:324
#, fuzzy, c-format
-msgid "Signature file <%s> is invalid"
+msgid "Unable to drop table: %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.smap/read_sig.c:30
+#: ../vector/v.lrs/v.lrs.create/main.c:343
#, fuzzy, c-format
-msgid "Signature file <%s> is empty"
+msgid "Unable to select line id values from %s.%s."
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensigset/subcluster.c:76
+#: ../vector/v.lrs/v.lrs.create/main.c:353
+msgid "Line id column must be integer"
+msgstr ""
+#: ../vector/v.lrs/v.lrs.create/main.c:364
+#: ../vector/v.lrs/v.lrs.create/main.c:466
+#, fuzzy
+msgid "Unable to fetch line id from line table"
+msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:416
#, c-format
-msgid "Not enough pixels in class %d"
+msgid "Line [%d] without category (layer [%d])"
msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:86
+#: ../vector/v.lrs/v.lrs.create/main.c:436
#, c-format
-msgid "Too many subclasses for class index %d"
+msgid "No lines selected for line id [%d]"
msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:88
+#: ../vector/v.lrs/v.lrs.create/main.c:456
#, fuzzy, c-format
-msgid "Number of subclasses set to %d"
+msgid "Unable to select point attributes from <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensigset/subcluster.c:106
+#: ../vector/v.lrs/v.lrs.create/main.c:487
#, c-format
-msgid "Combining subclasses (%d,%d)..."
+msgid "Milepost (start) %f+%f used as %f+%f (change MP to integer)"
msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:318
+#: ../vector/v.lrs/v.lrs.create/main.c:509
#, c-format
-msgid "Subsignature %d only contains %.0f pixels"
+msgid "Milepost (end) %f+%f used as %f+%f (change MP to integer)"
msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:552
-msgid "Unreliable clustering. Try a smaller initial number of clusters"
+#: ../vector/v.lrs/v.lrs.create/main.c:535
+#, c-format
+msgid "Point [%d] without category (layer [%d])"
msgstr ""
-#: ../imagery/i.gensigset/subcluster.c:561
+#: ../vector/v.lrs/v.lrs.create/main.c:582
#, c-format
-msgid "Removed a singular subsignature number %d (%d remain)"
+msgid "Point [%d] cat [%d] is out of threshold (distance = %f)"
msgstr ""
-#: ../imagery/i.gensigset/get_train.c:35 ../imagery/i.gensig/get_train.c:32
-#, fuzzy
-msgid "Finding training classes..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.gensigset/get_train.c:58 ../imagery/i.gensig/get_train.c:55
+#: ../vector/v.lrs/v.lrs.create/main.c:714
#, c-format
-msgid "Training class %d only has one cell - this class will be ignored"
+msgid "End > start for point cat [%d]"
msgstr ""
-#: ../imagery/i.gensigset/get_train.c:63 ../imagery/i.gensig/get_train.c:60
-#, fuzzy
-msgid "Training map has no classes"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:731
+msgid "Start of 1. MP >= end of 2. MP for points' cats %[d], [%d]"
+msgstr ""
-#: ../imagery/i.gensigset/get_train.c:79 ../imagery/i.gensig/get_train.c:75
-#, fuzzy
-msgid "1 class found"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:748
+#, c-format
+msgid "Start of 1. MP >= start of 2. MP for points' cats [%d], [%d]"
+msgstr ""
-#: ../imagery/i.gensigset/get_train.c:81 ../imagery/i.gensig/get_train.c:77
-#, fuzzy, c-format
-msgid "%d classes found"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:758
+#, c-format
+msgid "Distance along line identical for points' cats [%d], [%d]"
+msgstr ""
-#: ../imagery/i.gensigset/main.c:46
-#, fuzzy
-msgid "Generates statistics for i.smap from raster map."
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:772
+#, c-format
+msgid "Not enough points (%d) attached to the line (cat %d), line skip."
+msgstr ""
-#: ../imagery/i.gensigset/main.c:56
-#, fuzzy, c-format
-msgid "Clustering class %d (%d pixels)..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:777
+#, c-format
+msgid "Unable to guess direction for the line (cat %d), line skip."
+msgstr ""
-#: ../imagery/i.gensigset/main.c:59
-#, fuzzy, c-format
-msgid "Number of subclasses is %d"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.create/main.c:781
+#, c-format
+msgid "Incorrect order of points along line cat [%d]"
+msgstr ""
-#: ../imagery/i.gensigset/openfiles.c:22 ../imagery/i.gensig/openfiles.c:23
+#: ../vector/v.lrs/v.lrs.create/main.c:831
#, fuzzy, c-format
-msgid "Subgroup <%s> in group <%s> contains no raster maps."
+msgid "Unable to insert reference records: %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensigset/write_sig.c:13 ../imagery/i.gensig/write_sig.c:15
-#, fuzzy, c-format
-msgid "Unable to create signature file <%s>"
+#: ../vector/v.lrs/v.lrs.create/main.c:872
+#, fuzzy
+msgid "Building topology for output (out_lines) map..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensigset/write_sig.c:16 ../imagery/i.gensig/write_sig.c:18
+#: ../vector/v.lrs/v.lrs.create/main.c:883
#, fuzzy
-msgid "Writing signatures..."
+msgid "Building topology for error (err) map..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensigset/parse.c:13 ../imagery/i.gensig/parse.c:14
-msgid "Ground truth training map"
+#: ../vector/v.lrs/v.lrs.label/main.c:105
+msgid "Creates stationing from input lines, and linear reference system."
msgstr ""
-#: ../imagery/i.gensigset/parse.c:29
-msgid "Maximum number of sub-signatures in any class"
+#: ../vector/v.lrs/v.lrs.label/main.c:113
+msgid "Output vector map where stationing will be written"
msgstr ""
-#: ../imagery/i.gensigset/parse.c:54
-#, fuzzy, c-format
-msgid "Illegal number of sub-signatures (%s)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.label/main.c:139
+#: ../vector/v.lrs/v.lrs.segment/main.c:109
+#: ../vector/v.lrs/v.lrs.where/main.c:101
+msgid "Name of the reference system table"
+msgstr ""
-#: ../imagery/i.evapo.time/main.c:79
-msgid ""
-"Computes temporal integration of satellite ET actual (ETa) following the "
-"daily ET reference (ETo) from meteorological station(s)."
+#: ../vector/v.lrs/v.lrs.label/main.c:147
+msgid "Label file"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:86
-#, fuzzy
-msgid "Names of satellite ETa raster maps [mm/d or cm/d]"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.evapo.time/main.c:91
-msgid "Names of satellite ETa Day of Year (DOY) raster maps [0-400] [-]"
+#: ../vector/v.lrs/v.lrs.label/main.c:156
+msgid "PM left, MP right, stationing left, stationing right offset"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:96
-msgid "Names of meteorological station ETo raster maps [0-400] [mm/d or cm/d]"
+#: ../vector/v.lrs/v.lrs.label/main.c:161
+msgid "Offset label in label x-direction in map units"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:102
-msgid "Value of DOY for ETo first day"
+#: ../vector/v.lrs/v.lrs.label/main.c:168
+msgid "Offset label in label y-direction in map units"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:108
-msgid "Value of DOY for the first day of the period studied"
+#: ../vector/v.lrs/v.lrs.label/main.c:203
+msgid "Line width of text"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:114
-msgid "Value of DOY for the last day of the period studied"
+#: ../vector/v.lrs/v.lrs.label/main.c:204
+#: ../vector/v.lrs/v.lrs.label/main.c:212
+#: ../vector/v.lrs/v.lrs.label/main.c:222
+msgid "Only for d.label output"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:142
-msgid "The DOY for end_period can not be smaller than start_period"
+#: ../vector/v.lrs/v.lrs.label/main.c:221
+msgid "Line width of highlight color"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:146
-msgid "The DOY for start_period can not be smaller than eto_doy_min"
+#: ../vector/v.lrs/v.lrs.label/main.c:247
+msgid "Opaque to vector"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:151
-#, c-format
-msgid "Too many ETa files. Only %d allowed."
+#: ../vector/v.lrs/v.lrs.label/main.c:248
+msgid "Only relevant if background color is selected"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:162 ../imagery/i.evapo.time/main.c:178
-#: ../imagery/i.evapo.time/main.c:200
-msgid "The min specified input map is two"
+#: ../vector/v.lrs/v.lrs.label/main.c:302 ../display/d.labels/main.c:114
+#, fuzzy, c-format
+msgid "Unable to open label file <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.label/main.c:341
+#, fuzzy, c-format
+msgid "Unable to select records from LRS table: %s"
+msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.label/main.c:431
+msgid "No record in LR table"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:167
-#, c-format
-msgid "Too many ETa_doy files. Only %d allowed."
+#: ../vector/v.lrs/v.lrs.label/main.c:435
+msgid "More than one record in LR table"
msgstr ""
-#: ../imagery/i.evapo.time/main.c:183
-msgid "ETa and ETa_DOY file numbers are not equal!"
+#: ../vector/v.lrs/v.lrs.segment/main.c:75
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
msgstr ""
-#: ../imagery/i.evapo.time/main.c:189
-#, c-format
-msgid "Too many ETo files. Only %d allowed."
+#: ../vector/v.lrs/v.lrs.segment/main.c:83
+msgid "Output vector map where segments will be written"
msgstr ""
-#: ../imagery/i.zc/main.c:53 ../vector/v.lidar.edgedetection/main.c:74
-msgid "edges"
+#: ../vector/v.lrs/v.lrs.segment/main.c:114
+msgid "Name of file containing segment rules. If not given, read from stdin."
msgstr ""
-#: ../imagery/i.zc/main.c:55
-msgid "Zero-crossing \"edge detection\" raster function for image processing."
+#: ../vector/v.lrs/v.lrs.segment/main.c:183
+#: ../vector/v.lrs/v.lrs.segment/main.c:237
+#, c-format
+msgid "Cannot read input: %s"
msgstr ""
-#: ../imagery/i.zc/main.c:73
-#, fuzzy
-msgid "Zero crossing raster map"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.zc/main.c:80
-msgid "x-y extent of the Gaussian filter"
+#: ../vector/v.lrs/v.lrs.segment/main.c:195
+#, c-format
+msgid "No record in LR table for: %s"
msgstr ""
-#: ../imagery/i.zc/main.c:88
-msgid "Sensitivity of Gaussian filter"
+#: ../vector/v.lrs/v.lrs.segment/main.c:199
+#, c-format
+msgid "More than one record in LR table for: %s"
msgstr ""
-#: ../imagery/i.zc/main.c:96
-#, fuzzy
-msgid "Number of azimuth directions categorized"
+#: ../vector/v.lrs/v.lrs.segment/main.c:206
+#: ../vector/v.lrs/v.lrs.segment/main.c:293
+#, fuzzy, c-format
+msgid "Unable to find line of cat [%d]"
msgstr "출력할 래스터맵"
-#: ../imagery/i.zc/main.c:108
-msgid "Threshold less than or equal to zero not allowed"
+#: ../vector/v.lrs/v.lrs.segment/main.c:216
+#, c-format
+msgid ""
+"Cannot get point on line: cat = [%d] distance = [%f] (line length = %f)\n"
+"%s"
msgstr ""
-#: ../imagery/i.zc/main.c:114
-msgid "Width less than or equal to zero not allowed"
+#: ../vector/v.lrs/v.lrs.segment/main.c:252
+#, c-format
+msgid ""
+"No record in LRS table for 1. point of:\n"
+" %s"
msgstr ""
-#: ../imagery/i.zc/main.c:118
-msgid "Fewer than 1 orientation classes not allowed"
+#: ../vector/v.lrs/v.lrs.segment/main.c:257
+#, c-format
+msgid ""
+"Using last from more offsets found for 1. point of:\n"
+" %s"
msgstr ""
-#: ../imagery/i.zc/main.c:132
+#: ../vector/v.lrs/v.lrs.segment/main.c:261
#, c-format
-msgid "Power 2 values : %d rows %d columns"
+msgid ""
+"Requested offset for the 1. point not found, using nearest found:\n"
+" %s"
msgstr ""
-#: ../imagery/i.zc/main.c:142
-msgid "Initializing data..."
+#: ../vector/v.lrs/v.lrs.segment/main.c:272
+#, c-format
+msgid ""
+"No record in LRS table for 2. point of:\n"
+" %s"
msgstr ""
-#: ../imagery/i.zc/main.c:172
-msgid "Writing transformed data to file..."
+#: ../vector/v.lrs/v.lrs.segment/main.c:277
+#, c-format
+msgid ""
+"Requested offset for the 2. point not found, using nearest found:\n"
+" %s"
msgstr ""
-#: ../imagery/i.zc/main.c:192
-msgid "Transform successful"
+#: ../vector/v.lrs/v.lrs.segment/main.c:281
+#, c-format
+msgid ""
+"Using first from more offsets found for 2. point of:\n"
+" %s"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:98 ../imagery/i.landsat.toar/main.c:71
-msgid "radiometric conversion"
+#: ../vector/v.lrs/v.lrs.segment/main.c:286
+msgid "Segment over 2 (or more) segments, not yet supported"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:100 ../imagery/i.landsat.toar/main.c:72
-#: ../imagery/i.landsat.toar/main.c:575
-#, fuzzy
-msgid "radiance"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.aster.toar/main.c:102 ../imagery/i.landsat.toar/main.c:74
-msgid "brightness temperature"
+#: ../vector/v.lrs/v.lrs.segment/main.c:303
+#, c-format
+msgid "End of segment > line length (%e) -> cut"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:104
+#: ../vector/v.lrs/v.lrs.segment/main.c:312
+#, c-format
msgid ""
-"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
-"from ASTER DN.\n"
+"Cannot make line segment: cat = %d : %f - %f (line length = %f)\n"
+"%s"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:108
-msgid "Names of ASTER DN layers (15 layers)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:335 ../vector/v.segment/main.c:250
+#, c-format
+msgid "Incorrect segment type: %s"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:115
-#, fuzzy
-msgid "Day of Year of satellite overpass [0-366]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.lrs/v.lrs.segment/main.c:355
+#: ../vector/v.lrs/v.lrs.where/main.c:222
+#, fuzzy, c-format
+msgid "[%d] point read from input"
+msgid_plural "[%d] points read from input"
-#: ../imagery/i.aster.toar/main.c:122
-msgid "Sun elevation angle (degrees, < 90.0)"
+#. GTC Number of lost points
+#. GTC Number of lost lines
+#: ../vector/v.lrs/v.lrs.segment/main.c:358
+#: ../vector/v.lrs/v.lrs.segment/main.c:370 ../vector/v.segment/main.c:261
+#: ../vector/v.segment/main.c:272
+#, c-format
+msgid "%d lost"
+msgid_plural "%d lost"
+msgstr[0] ""
+msgstr[1] ""
+#. GTC %s will be replaced with a message about lost points.
+#: ../vector/v.lrs/v.lrs.segment/main.c:362
+#, fuzzy, c-format
+msgid "[%d] point written to output map (%s)"
+msgid_plural "[%d] points written to output map (%s)"
+#: ../vector/v.lrs/v.lrs.segment/main.c:367
+#, fuzzy, c-format
+msgid "[%d] line read from input"
+msgid_plural "[%d] lines read from input"
+#. GTC %s will be replaced with a message about lost lines.
+#: ../vector/v.lrs/v.lrs.segment/main.c:374
+#, fuzzy, c-format
+msgid "[%d] line written to output map (%s)"
+msgid_plural "[%d] lines written to output map (%s)"
+#: ../vector/v.lrs/v.lrs.where/main.c:61
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
msgstr ""
-#: ../imagery/i.aster.toar/main.c:125
+#: ../vector/v.lrs/v.lrs.where/main.c:70
#, fuzzy
-msgid "Base name of the output layers (will add .x)"
+msgid "Input vector map containing points"
msgstr "출력할 래스터맵"
-#: ../imagery/i.aster.toar/main.c:130
-msgid "Output is radiance (W/m2)"
+#: ../vector/v.lrs/v.lrs.where/main.c:108
+msgid "Maximum distance to nearest line"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:134
-msgid "VNIR is High Gain"
-msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:225
+#, fuzzy, c-format
+msgid "[%d] position found"
+msgid_plural "[%d] positions found"
-#: ../imagery/i.aster.toar/main.c:138
-msgid "SWIR is High Gain"
-msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:229
+#, fuzzy, c-format
+msgid "[%d] point outside threshold"
+msgid_plural "[%d] points outside threshold"
-#: ../imagery/i.aster.toar/main.c:142
-msgid "VNIR is Low Gain 1"
-msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:233
+#, fuzzy, c-format
+msgid "[%d] point - no record found"
+msgid_plural "[%d] points - no record found"
-#: ../imagery/i.aster.toar/main.c:146
-msgid "SWIR is Low Gain 1"
-msgstr ""
+#: ../vector/v.lrs/v.lrs.where/main.c:237
+#, c-format
+msgid "[%d] point - too many records found"
+msgid_plural "[%d] points - too many records found"
+msgstr[0] ""
+msgstr[1] ""
-#: ../imagery/i.aster.toar/main.c:150
-msgid "SWIR is Low Gain 2"
+#: ../vector/v.net.spanningtree/main.c:48
+msgid "spanning tree"
msgstr ""
-#: ../imagery/i.aster.toar/main.c:244
-msgid "The input band number should be 15"
+#: ../vector/v.net.spanningtree/main.c:50
+msgid "Computes minimum spanning tree for the network."
msgstr ""
-#: ../imagery/i.vi/main.c:90
+#: ../vector/v.hull/hull.c:107
#, fuzzy
-msgid "vegetation index"
+msgid "Simple planar hulls not implemented yet"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:91
-msgid "biophysical parameters"
-msgstr ""
+#: ../vector/v.hull/chull.c:212
+#, fuzzy
+msgid "Reading 3D vertices..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:93
-msgid "Calculates different types of vegetation indices."
+#: ../vector/v.hull/chull.c:396
+msgid "Constructing 3D hull..."
msgstr ""
-#: ../imagery/i.vi/main.c:94
-msgid ""
-"Uses red and nir bands mostly, and some indices require additional bands."
+#: ../vector/v.hull/main.c:56
+msgid "Produces a 2D/3D convex hull for a given vector map."
msgstr ""
-#: ../imagery/i.vi/main.c:101
+#: ../vector/v.hull/main.c:70
#, fuzzy
-msgid "Name of input red channel surface reflectance map"
+msgid "Limit to current region"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:102 ../imagery/i.vi/main.c:141
-#: ../imagery/i.vi/main.c:149 ../imagery/i.vi/main.c:157
-#: ../imagery/i.vi/main.c:165 ../imagery/i.vi/main.c:173
-msgid "Range: [0.0;1.0]"
+#: ../vector/v.hull/main.c:75
+msgid "Create a 'flat' 2D hull even if the input is 3D points"
msgstr ""
-#: ../imagery/i.vi/main.c:108
-#, fuzzy
-msgid "Type of vegetation index"
+#: ../vector/v.hull/main.c:100
+#, fuzzy, c-format
+msgid "Error loading vector points from <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:113
-msgid "Atmospherically Resistant Vegetation Indices"
+#: ../vector/v.hull/main.c:103
+#, c-format
+msgid "Convex hull calculation requires at least three points (%d found)"
msgstr ""
-#: ../imagery/i.vi/main.c:114
-#, fuzzy
-msgid "Difference Vegetation Index"
+#: ../vector/v.hull/main.c:105
+#, fuzzy, c-format
+msgid "%d points read from vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:115
-#, fuzzy
-msgid "Enhanced Vegetation Index"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:116
-#, fuzzy
-msgid "Enhanced Vegetation Index 2"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:117
-#, fuzzy
-msgid "Green Vegetation Index"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:118
-#, fuzzy
-msgid "Green Atmospherically Resistant Vegetation Index"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:119
-msgid "Global Environmental Monitoring Index"
+#: ../vector/v.distance/main.c:92
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
msgstr ""
-#: ../imagery/i.vi/main.c:120
+#: ../vector/v.distance/main.c:96
#, fuzzy
-msgid "Infrared Percentage Vegetation Index"
+msgid "Name of existing vector map (from)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:121
-msgid "Modified Soil Adjusted Vegetation Index"
+#: ../vector/v.distance/main.c:97 ../vector/v.distance/main.c:102
+#: ../vector/v.distance/main.c:109 ../vector/v.distance/main.c:188
+#: ../vector/v.net.distance/main.c:98 ../vector/v.net.distance/main.c:103
+#: ../vector/v.net.distance/main.c:109
+msgid "From"
msgstr ""
-#: ../imagery/i.vi/main.c:122
-msgid "second Modified Soil Adjusted Vegetation Index"
-msgstr ""
-#: ../imagery/i.vi/main.c:123
+#: ../vector/v.distance/main.c:101
#, fuzzy
-msgid "Normalized Difference Vegetation Index"
+msgid "Layer number or name (from)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:124
+#: ../vector/v.distance/main.c:108
#, fuzzy
-msgid "Perpendicular Vegetation Index"
+msgid "Feature type (from)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:125
+#: ../vector/v.distance/main.c:113
#, fuzzy
-msgid "Soil Adjusted Vegetation Index"
+msgid "Name of existing vector map (to)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:126
-#, fuzzy
-msgid "Simple Ratio"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:127
-msgid "Visible Atmospherically Resistant Index"
+#: ../vector/v.distance/main.c:114 ../vector/v.distance/main.c:119
+#: ../vector/v.distance/main.c:126 ../vector/v.distance/main.c:194
+#: ../vector/v.net.distance/main.c:114 ../vector/v.net.distance/main.c:121
+#: ../vector/v.net.distance/main.c:126 ../vector/v.net.distance/main.c:132
+msgid "To"
msgstr ""
-#: ../imagery/i.vi/main.c:128
+#: ../vector/v.distance/main.c:118
#, fuzzy
-msgid "Weighted Difference Vegetation Index"
+msgid "Layer number or name (to)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:132
+#: ../vector/v.distance/main.c:125
#, fuzzy
-msgid "type"
+msgid "Feature type (to)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:140
+#: ../vector/v.distance/main.c:131
#, fuzzy
-msgid "Name of input nir channel surface reflectance map"
+msgid "Name for output vector map containing lines connecting nearest elements"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:142 ../imagery/i.vi/main.c:150
-#: ../imagery/i.vi/main.c:158 ../imagery/i.vi/main.c:166
-#: ../imagery/i.vi/main.c:174 ../vector/v.vol.rst/main.c:257
-#: ../vector/v.vol.rst/main.c:306
-#, fuzzy
-msgid "Optional inputs"
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:139
+msgid "Maximum distance or -1 for no limit"
+msgstr ""
-#: ../imagery/i.vi/main.c:148
-#, fuzzy
-msgid "Name of input green channel surface reflectance map"
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:146
+msgid "Minimum distance or -1 for no limit"
+msgstr ""
-#: ../imagery/i.vi/main.c:156
-#, fuzzy
-msgid "Name of input blue channel surface reflectance map"
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:155
+msgid "Values describing the relation between two nearest features"
+msgstr ""
-#: ../imagery/i.vi/main.c:164
-#, fuzzy
-msgid "Name of input 5th channel surface reflectance map"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:172
-#, fuzzy
-msgid "Name of input 7th channel surface reflectance map"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:180
-msgid "Value of the slope of the soil line (MSAVI2 only)"
+#: ../vector/v.distance/main.c:165
+msgid "category of the nearest feature"
msgstr ""
-#: ../imagery/i.vi/main.c:181 ../imagery/i.vi/main.c:188
-#: ../imagery/i.vi/main.c:195
+#: ../vector/v.distance/main.c:166
#, fuzzy
-msgid "MSAVI2 seetings"
+msgid "minimum distance to nearest feature"
msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:187
-msgid "Value of the intercept of the soil line (MSAVI2 only)"
+#: ../vector/v.distance/main.c:167
+msgid "x coordinate of the nearest point on the 'to' feature"
msgstr ""
-#: ../imagery/i.vi/main.c:194
-msgid "Value of the factor of reduction of soil noise (MSAVI2 only)"
+#: ../vector/v.distance/main.c:168
+msgid "y coordinate of the nearest point on the 'to' feature"
msgstr ""
-#: ../imagery/i.vi/main.c:201
-msgid "Maximum bits for digital numbers"
+#: ../vector/v.distance/main.c:169
+msgid ""
+"distance to the nearest point on the 'to' feature along that linear feature"
msgstr ""
-#: ../imagery/i.vi/main.c:202
+#: ../vector/v.distance/main.c:171
msgid ""
-"If data is in Digital Numbers (i.e. integer type), give the max bits (i.e. 8 "
-"for Landsat -> [0-255])"
+"angle along the nearest linear feature in the 'to' map, measured CCW from "
+"the +x axis, in radians, between -Pi and Pi inclusive"
msgstr ""
-#: ../imagery/i.vi/main.c:227
-msgid "sr index requires red and nir maps"
+#: ../vector/v.distance/main.c:174
+msgid "attribute of nearest feature given by to_column option"
msgstr ""
-#: ../imagery/i.vi/main.c:230
-msgid "ndvi index requires red and nir maps"
+#: ../vector/v.distance/main.c:187
+msgid ""
+"Column name(s) where values specified by 'upload' option will be uploaded"
msgstr ""
-#: ../imagery/i.vi/main.c:233
-msgid "ipvi index requires red and nir maps"
+#: ../vector/v.distance/main.c:193
+msgid "Column name of nearest feature (used with upload=to_attr)"
msgstr ""
-#: ../imagery/i.vi/main.c:236
-msgid "dvi index requires red and nir maps"
+#: ../vector/v.distance/main.c:199
+msgid "Name of table created when the 'distance to all' flag is used"
msgstr ""
-#: ../imagery/i.vi/main.c:239
-msgid "pvi index requires red and nir maps"
+#: ../vector/v.distance/main.c:204
+msgid "Print output to stdout, don't update attribute table"
msgstr ""
-#: ../imagery/i.vi/main.c:242
-msgid "wdvi index requires red and nir maps"
+#: ../vector/v.distance/main.c:206
+msgid "First column is always category of 'from' feature called from_cat"
msgstr ""
-#: ../imagery/i.vi/main.c:245
-msgid "savi index requires red and nir maps"
+#: ../vector/v.distance/main.c:211
+msgid "Calculate distances to all features within the threshold"
msgstr ""
-#: ../imagery/i.vi/main.c:248
-msgid "msavi index requires red and nir maps"
-msgstr ""
-#: ../imagery/i.vi/main.c:253
+#: ../vector/v.distance/main.c:213
msgid ""
-"msavi2 index requires red and nir maps, and 3 parameters related to soil line"
+"Output is written to stdout but may be uploaded to a new table created by "
+"this module; multiple 'upload' options may be used."
msgstr ""
-#: ../imagery/i.vi/main.c:256
-msgid "gemi index requires red and nir maps"
+#: ../vector/v.distance/main.c:268
+msgid "to_column option missing"
msgstr ""
-#: ../imagery/i.vi/main.c:260
-msgid "arvi index requires blue, red and nir maps"
+#: ../vector/v.distance/main.c:280
+msgid "Too many column names"
msgstr ""
-#: ../imagery/i.vi/main.c:264
-msgid "evi index requires blue, red and nir maps"
+#: ../vector/v.distance/main.c:287
+msgid "Not enough column names"
msgstr ""
-#: ../imagery/i.vi/main.c:267
-msgid "evi2 index requires red and nir maps"
-msgstr ""
+#: ../vector/v.distance/main.c:305 ../vector/v.distance/main.c:323
+#, fuzzy, c-format
+msgid "No features of selected type found in <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.vi/main.c:271
-msgid "vari index requires blue, green and red maps"
+#: ../vector/v.distance/main.c:386
+msgid "dmin can not be larger than dmax"
msgstr ""
-#: ../imagery/i.vi/main.c:275
-msgid "gari index requires blue, green, red and nir maps"
+#: ../vector/v.distance/main.c:525
+msgid "Incompatible column types"
msgstr ""
-#: ../imagery/i.vi/main.c:280
-msgid "gvi index requires blue, green, red, nir, chan5 and chan7 maps"
-msgstr ""
+#: ../vector/v.distance/main.c:573
+#, fuzzy
+msgid "No categories for 'from' for slected type and layer"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.points/main.c:99
-msgid "Mark ground control points on image to be rectified."
-msgstr ""
+#: ../vector/v.distance/main.c:597
+#, fuzzy
+msgid "Finding nearest features..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:55
-msgid "Creates, edits, and lists groups of imagery data."
+#: ../vector/v.distance/main.c:695 ../vector/v.distance/main.c:968
+#, c-format
+msgid "More cats found in to_layer (line=%d)"
msgstr ""
-#: ../imagery/i.group/main.c:59
-msgid "Name of imagery group"
+#: ../vector/v.distance/main.c:772 ../vector/v.distance/main.c:1115
+#, c-format
+msgid "More cats found in to_layer (area=%d)"
msgstr ""
-#: ../imagery/i.group/main.c:63
+#: ../vector/v.distance/main.c:871
#, fuzzy
-msgid "Name of imagery subgroup"
+msgid "Finding nearest features for areas..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:67
+#: ../vector/v.distance/main.c:1223
+msgid "DATETIME type not yet supported, no attributes will be uploaded"
+msgstr ""
+#: ../vector/v.distance/main.c:1241
#, fuzzy
-msgid "Name of raster map(s) to include in group"
+msgid "Unable to open default database"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:68 ../imagery/i.group/main.c:74
-msgid "Maps"
+#: ../vector/v.distance/main.c:1571
+#, c-format
+msgid "%d categories with more than 1 feature in vector map <%s>"
msgstr ""
-#: ../imagery/i.group/main.c:73
-msgid "Remove selected files from specified group or subgroup"
+#: ../vector/v.distance/main.c:1574
+#, c-format
+msgid "%d categories - no nearest feature found"
msgstr ""
-#: ../imagery/i.group/main.c:78
-msgid "List files from specified (sub)group"
+#: ../vector/v.distance/main.c:1583
+#, c-format
+msgid "%d distances calculated"
msgstr ""
-#: ../imagery/i.group/main.c:83
-msgid "List subgroups from specified group"
+#: ../vector/v.distance/main.c:1584
+#, c-format
+msgid "%d records inserted"
msgstr ""
-#: ../imagery/i.group/main.c:109
-#, fuzzy
-msgid "No input raster map(s) specified"
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:1586
+#, c-format
+msgid "%d insert errors"
+msgstr ""
-#: ../imagery/i.group/main.c:128 ../imagery/i.group/main.c:150
-#, fuzzy
-msgid "Specified group does not exist in current mapset"
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:1590
+#, c-format
+msgid "%d categories read from the map"
+msgstr ""
-#: ../imagery/i.group/main.c:132
-#, fuzzy, c-format
-msgid "Removing raster maps from subgroup <%s>..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:1592
+#, c-format
+msgid "%d categories exist in the table"
+msgstr ""
-#: ../imagery/i.group/main.c:137
-#, fuzzy, c-format
-msgid "Removing raster maps from group <%s>..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:1594
+#, c-format
+msgid "%d categories read from the map exist in the table"
+msgstr ""
-#: ../imagery/i.group/main.c:158
-#, fuzzy, c-format
-msgid "Subgroup <%s> of group <%s> references the following raster maps:"
-msgstr "출력할 래스터맵"
+#: ../vector/v.distance/main.c:1597
+#, c-format
+msgid "%d categories read from the map don't exist in the table"
+msgstr ""
-#: ../imagery/i.group/main.c:173
-#, fuzzy, c-format
-msgid "Group <%s> references the following raster maps:"
+#: ../vector/v.distance/distance.c:358
+#, fuzzy
+msgid "At least one point is really inside the area!"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:185
-#, fuzzy, c-format
-msgid "Group <%s> does not yet exist. Creating..."
+#: ../vector/v.out.postgis/main.c:46
+msgid "PostGIS"
+msgstr ""
+#: ../vector/v.out.postgis/main.c:47
+#, fuzzy
+msgid "simple features"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:189 ../imagery/i.group/main.c:198
-#, fuzzy, c-format
-msgid "Adding raster maps to group <%s>..."
+#: ../vector/v.out.postgis/main.c:52
+#, fuzzy
+msgid "Exports a vector map layer to PostGIS feature table."
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:193
+#: ../vector/v.out.postgis/main.c:103
#, fuzzy, c-format
-msgid "Adding raster maps to subgroup <%s>..."
+msgid "Vector map <%s> is not in native format. Export cancelled."
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:219 ../imagery/i.group/main.c:261
+#: ../vector/v.out.postgis/main.c:134
#, fuzzy, c-format
-msgid "Raster map <%s> not found. Skipped."
+msgid "Unable to create PostGIS layer <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:224
+#: ../vector/v.out.postgis/main.c:141
#, fuzzy, c-format
-msgid "Adding raster map <%s> to group"
+msgid "Feature type %d is not supported"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:230
-#, fuzzy, c-format
-msgid "Raster map <%s> exists in group. Skipped."
+#: ../vector/v.out.postgis/main.c:151
+#, fuzzy
+msgid "Copying features failed"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:267
+#: ../vector/v.out.postgis/main.c:159
#, fuzzy, c-format
-msgid "Adding raster map <%s> to subgroup"
+msgid "Building %s topology failed"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:274
+#: ../vector/v.out.postgis/main.c:163
#, c-format
-msgid "Raster map <%s> exists in subgroup. Skipping..."
+msgid "No features exported. PostGIS layer <%s> not created."
msgstr ""
-#: ../imagery/i.group/main.c:323
+#: ../vector/v.out.postgis/main.c:167
#, fuzzy, c-format
-msgid "Removing raster map <%s> from group"
-msgstr "출력할 래스터맵"
+msgid "%d feature (%s type) written to <%s>."
+msgid_plural "%d features (%s type) written to <%s>."
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../imagery/i.group/main.c:340 ../imagery/i.group/main.c:399
-#, fuzzy
-msgid "No raster map removed"
-msgstr "출력할 래스터맵"
+#: ../vector/v.out.postgis/main.c:173
+#, fuzzy, c-format
+msgid "%d primitive written to <%s>."
+msgid_plural "%d primitives written to <%s>."
-#: ../imagery/i.group/main.c:382
+#: ../vector/v.out.postgis/main.c:212
#, fuzzy, c-format
-msgid "Removing raster map <%s> from subgroup"
+msgid "Unable to drop table <%s.%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:418
+#: ../vector/v.out.postgis/main.c:220
#, fuzzy, c-format
-msgid "Group <%s> does not contain any subgroup.\n"
+msgid "Unable to drop topology schema <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.group/main.c:429
+#: ../vector/v.out.postgis/table.c:27
#, fuzzy, c-format
-msgid "group <%s> references the following subgroups\n"
+msgid "No database connection for layer <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:58
-#, fuzzy
-msgid "net radiation"
-msgstr "출력할 래스터맵"
+#: ../vector/v.out.postgis/table.c:50
+#, c-format
+msgid ""
+"Invalid FID column (%s). FID column must be integer. Please specify "
+"different FID column by 'options=\"FID=<name>\"'."
+msgstr ""
-#: ../imagery/i.eb.netrad/main.c:61
-msgid "Net radiation approximation (Bastiaanssen, 1995)."
+#: ../vector/v.out.postgis/table.c:57
+#, c-format
+msgid ""
+"Column (%s) already exists in the table. Please specify different geometry "
+"column by 'options=\"GEOMETRY_NAME=<name>\"'."
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:66
+#: ../vector/v.out.postgis/args.c:25
#, fuzzy
-msgid "Name of the Albedo map [0.0;1.0]"
+msgid "Name for output PostGIS datasource"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:70 ../imagery/i.eb.netrad/main.c:72
-msgid "ndvi"
+#: ../vector/v.out.postgis/args.c:27
+msgid "Starts with 'PG' prefix, eg. 'PG:dbname=grass'"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:71
+#: ../vector/v.out.postgis/args.c:35
#, fuzzy
-msgid "Name of the NDVI map [-1.0;+1.0]"
+msgid "Name for output PostGIS layer"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:75 ../imagery/i.landsat.toar/main.c:577
-msgid "temperature"
+#: ../vector/v.out.postgis/args.c:37
+msgid "If not specified, input name is used"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:77
+#: ../vector/v.out.postgis/args.c:44
#, fuzzy
-msgid "Name of the surface temperature map [K]"
+msgid ""
+"Name for output vector map defined as a link to the PostGIS feature table"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:78
-msgid "tempk"
+#: ../vector/v.out.postgis/args.c:46
+msgid ""
+"If not specified, the vector link is not created. The link can be also "
+"manually created by 'v.external' module."
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:81
-msgid "localutctime"
+#: ../vector/v.out.postgis/args.c:53
+msgid ""
+"Examples:\n"
+"\t\t'FID=cat': define feature id column 'cat'\n"
+"\t\t'GEOMETRY_NAME=wkb_geometry': define geometry column 'wkb_geometry'\n"
+"\t\t'SPATIAL_INDEX=NO': do not create spatial index on geometry column"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:83
+#: ../vector/v.out.postgis/args.c:66
#, fuzzy
-msgid "Name of the map of local UTC time of satellite overpass [hh.hhh]"
+msgid "Don't export attribute table"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:84
-msgid "time"
+#: ../vector/v.out.postgis/args.c:72
+msgid "Export PostGIS topology instead of simple features"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:87
-msgid "temperaturedifference2m"
+#: ../vector/v.out.postgis/args.c:77
+msgid "Force 2D output even if input is 3D "
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:89
-msgid ""
-"Name of the difference map of temperature from surface skin to about 2 m "
-"height [K]"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:90
-msgid "dtair"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:94
-#, fuzzy
-msgid "Name of the emissivity map [-]"
+#: ../vector/v.out.postgis/create.c:62
+#, fuzzy, c-format
+msgid "Invalid option skipped: %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:98
-msgid "transmissivitysingleway"
-msgstr ""
-#: ../imagery/i.eb.netrad/main.c:100
+#: ../vector/v.reclass/main.c:69
#, fuzzy
-msgid "Name of the single-way atmospheric transmissivitymap [-]"
+msgid "attributes"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:101
-msgid "tsw"
+#: ../vector/v.reclass/main.c:71
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:104
-msgid "dayofyear"
+#: ../vector/v.reclass/main.c:88
+msgid "The name of the column whose values are to be used as new categories"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:105
-#, fuzzy
-msgid "Name of the Day Of Year (DOY) map [-]"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:106
-msgid "doy"
+#: ../vector/v.reclass/main.c:89
+msgid "The source for the new key column must be type integer or string"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:109
-msgid "sunzenithangle"
+#: ../vector/v.reclass/main.c:94
+msgid "Full path to the reclass rule file"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:110
-#, fuzzy
-msgid "Name of the sun zenith angle map [degrees]"
+#: ../vector/v.reclass/main.c:104
+#, fuzzy, c-format
+msgid "Either '%s' or '%s' must be specified"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.netrad/main.c:111
-msgid "sunzangle"
+#: ../vector/v.reclass/main.c:244
+msgid "Key column type is not integer"
msgstr ""
-#: ../imagery/i.eb.netrad/main.c:114
-#, fuzzy
-msgid "Name of the output net radiation layer"
+#: ../vector/v.reclass/main.c:290
+#, fuzzy, c-format
+msgid "Cannot insert data: [%s]"
msgstr "출력할 래스터맵"
-#: ../imagery/i.fft/main.c:80 ../imagery/i.ifft/main.c:79
-msgid "Fast Fourier Transform"
+#: ../vector/v.reclass/main.c:327
+msgid "Column type must be integer or string"
msgstr ""
-#: ../imagery/i.fft/main.c:82
-msgid "Fast Fourier Transform (FFT) for image processing."
-msgstr ""
-#: ../imagery/i.fft/main.c:91
-#, fuzzy
-msgid "Name for output real part arrays stored as raster map"
+#: ../vector/v.reclass/main.c:339
+#, fuzzy, c-format
+msgid "Unable to open rule file <%s>"
msgstr "출력할 래스터맵"
-#: ../imagery/i.fft/main.c:95
-#, fuzzy
-msgid "Name for output imaginary part arrays stored as raster map"
+#: ../vector/v.reclass/main.c:355
+#, fuzzy, c-format
+msgid "Category %d overwritten by '%s'"
msgstr "출력할 래스터맵"
-#: ../imagery/i.fft/main.c:107
-msgid "Raster MASK found, consider to remove (see man-page). Will continue..."
+#: ../vector/v.reclass/main.c:359
+#, c-format
+msgid "Category '%s' invalid"
msgstr ""
-#: ../imagery/i.fft/main.c:130
+#: ../vector/v.reclass/main.c:363
#, fuzzy, c-format
-msgid "Reading the raster map <%s>..."
+msgid "Label '%s' overwritten by '%s'"
msgstr "출력할 래스터맵"
-#: ../imagery/i.fft/main.c:146
-msgid "Starting FFT..."
+#: ../vector/v.reclass/main.c:369
+#, c-format
+msgid "Condition '%s' overwritten by '%s'"
msgstr ""
-#: ../imagery/i.fft/main.c:167 ../imagery/i.ifft/main.c:192
-msgid "Rotating data..."
+#: ../vector/v.reclass/main.c:374
+#, c-format
+msgid "Unknown rule option: '%s'"
msgstr ""
-#: ../imagery/i.fft/main.c:175
+#: ../vector/v.reclass/main.c:388
#, fuzzy
-msgid "Writing transformed data..."
+msgid "Cannot select values from database"
msgstr "출력할 래스터맵"
-#: ../imagery/i.fft/main.c:201
-msgid " "
+#: ../vector/v.reclass/main.c:404
+#, c-format
+msgid "%d previously set categories overwritten by new category %d"
msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:51
-msgid "soil heat flux"
+#: ../vector/v.reclass/main.c:430
+msgid "Incomplete rule"
msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:53
-msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:58
-#, fuzzy
-msgid "Name of Albedo raster map [0.0;1.0]"
+#: ../vector/v.reclass/main.c:466
+#, fuzzy, c-format
+msgid "%d features reclassed."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.soilheatflux/main.c:62
+#: ../vector/v.net.bridge/main.c:49
#, fuzzy
-msgid "Name of NDVI raster map [-1.0;+1.0]"
+msgid "articulation points"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.soilheatflux/main.c:67
-#, fuzzy
-msgid "Name of Surface temperature raster map [K]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.net.bridge/main.c:51
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
-#: ../imagery/i.eb.soilheatflux/main.c:71 ../imagery/i.eb.evapfr/main.c:59
+#: ../vector/v.net.bridge/main.c:98
#, fuzzy
-msgid "Name of Net Radiation raster map [W/m2]"
+msgid "Finds bridges"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.soilheatflux/main.c:76
+#: ../vector/v.net.bridge/main.c:99
#, fuzzy
-msgid "Name of time of satellite overpass raster map [local time in UTC]"
+msgid "Finds articulation points"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.soilheatflux/main.c:83
-msgid "HAPEX-Sahel empirical correction (Roerink, 1995)"
+#: ../vector/v.net.bridge/main.c:101 ../vector/v.vect.stats/main.c:149
+#: ../vector/v.to.db/parse.c:41
+msgid "Feature type"
msgstr ""
-#: ../imagery/i.eb.eta/main.c:45
-msgid "actual evapotranspiration"
+#: ../vector/v.external/main.c:53
+msgid ""
+"Creates a new pseudo-vector map as a link to an OGR-supported layer or a "
+"PostGIS feature table."
msgstr ""
-#: ../imagery/i.eb.eta/main.c:48
-msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
-msgstr ""
-#: ../imagery/i.eb.eta/main.c:53
-#, fuzzy
-msgid "Name of the diurnal Net Radiation map [W/m2]"
+#: ../vector/v.external/main.c:158
+#, fuzzy, c-format
+msgid "Unable to delete '%s'"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.eta/main.c:58
-#, fuzzy
-msgid "Name of the evaporative fraction map [-]"
+#: ../vector/v.external/main.c:165
+#, fuzzy, c-format
+msgid "Unable to create file '%s/%s'"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.eta/main.c:63
-#, fuzzy
-msgid "Name of the surface skin temperature [K]"
+#: ../vector/v.external/main.c:196
+#, fuzzy, c-format
+msgid "Link to vector map <%s> created."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.eta/main.c:68
+#: ../vector/v.external/args.c:26
#, fuzzy
-msgid "Name of the output actual evapotranspiration layer [mm/d]"
+msgid "Name of OGR layer or PostGIS feature table to be linked"
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensig/covariance.c:30
-msgid "Calculating class covariance matrices..."
+#: ../vector/v.external/args.c:27
+msgid ""
+"Examples:\n"
+"\t\tESRI Shapefile: shapefile name\n"
+"\t\tMapInfo File: mapinfo file name\n"
+"\t\tPostGIS database: table name"
msgstr ""
-#: ../imagery/i.gensig/main.c:46
+#: ../vector/v.external/args.c:36
#, fuzzy
-msgid "Generates statistics for i.maxlik from raster map."
+msgid "Name for output GRASS vector map (default: input layer)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.gensig/check.c:21
-#, c-format
-msgid "Signature %d not invertible"
+#: ../vector/v.external/args.c:46
+msgid "List available layers in data source and exit"
msgstr ""
-#: ../imagery/i.gensig/check.c:27
-#, c-format
-msgid "Signature %d unable to get eigen values"
+#: ../vector/v.external/args.c:52
+msgid "List available layers including feature type in data source and exit"
msgstr ""
-#: ../imagery/i.gensig/check.c:33
-#, c-format
-msgid "Signature %d not positive definite"
+#: ../vector/v.external/args.c:54
+msgid "Format: layer name,type,projection check"
msgstr ""
-#: ../imagery/i.gensig/means.c:26
-#, fuzzy
-msgid "Calculating class means..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.find/main.c:63
-#, c-format
-msgid "usage: %s location mapset element file."
+#: ../vector/v.external/list.c:111
+msgid "GRASS is not compiled with PostgreSQL support"
msgstr ""
-#: ../imagery/i.find/main.c:83
-msgid "Unable to open temp file."
+#: ../vector/v.external/list.c:117
+msgid "GRASS is not compiled with OGR support"
msgstr ""
-#: ../imagery/i.biomass/main.c:51
-msgid "biomass"
-msgstr ""
-#: ../imagery/i.biomass/main.c:53
-msgid "yield"
-msgstr ""
-#: ../imagery/i.biomass/main.c:55
-msgid "Computes biomass growth, precursor of crop yield calculation."
-msgstr ""
-#: ../imagery/i.biomass/main.c:60
+#: ../vector/v.external/list.c:158
#, fuzzy
-msgid "Name of fPAR raster map"
+msgid "Connection to PostgreSQL database failed."
msgstr "출력할 래스터맵"
-#: ../imagery/i.biomass/main.c:65
+#: ../vector/v.external/list.c:168
#, fuzzy
-msgid "Name of light use efficiency raster map (UZB:cotton=1.9)"
+msgid "No feature tables found in database."
msgstr "출력할 래스터맵"
-#: ../imagery/i.biomass/main.c:69
-#, fuzzy
-msgid "Name of degree latitude raster map [dd.ddd]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.external/list.c:179
+#, c-format
+msgid "PostGIS database <%s> contains %d feature table:"
+msgid_plural "PostGIS database <%s> contains %d feature tables:"
+msgstr[0] ""
+msgstr[1] ""
-#: ../imagery/i.biomass/main.c:73
-#, fuzzy
-msgid "Name of Day of Year raster map [1-366]"
+#: ../vector/v.external/list.c:259
+#, fuzzy, c-format
+msgid "Unable to open data source '%s'"
msgstr "출력할 래스터맵"
-#: ../imagery/i.biomass/main.c:78
-#, fuzzy
-msgid "Name of single-way transmissivity raster map [0.0-1.0]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.external/list.c:266
+#, c-format
+msgid "Data source <%s> (format '%s') contains %d layer:"
+msgid_plural "Data source <%s> (format '%s') contains %d layers:"
+msgstr[0] ""
+msgstr[1] ""
-#: ../imagery/i.biomass/main.c:83
-#, fuzzy
-msgid "Value of water availability raster map [0.0-1.0]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.external/list.c:295
+#, c-format
+msgid ""
+"Unable to convert input map projection to GRASS format. Projection check "
+"cannot be provided for OGR layer <%s>"
+msgstr ""
-#: ../imagery/i.biomass/main.c:87
-#, fuzzy
-msgid "Name for output daily biomass growth raster map [kg/ha/d]"
-msgstr "출력할 래스터맵"
+#: ../vector/v.net.flow/main.c:60
+msgid "flow"
+msgstr ""
-#: ../imagery/i.pca/main.c:75
-msgid "Principal components analysis (PCA) for image processing."
+#: ../vector/v.net.flow/main.c:62
+msgid "Computes the maximum flow between two sets of nodes in the network."
msgstr ""
-#: ../imagery/i.pca/main.c:81
+#: ../vector/v.net.flow/main.c:84
#, fuzzy
-msgid "Name of two or more input raster maps or imagery group"
+msgid "Name for output vector map containing a minimum cut"
msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/main.c:86
-msgid "A numerical suffix will be added for each component map"
-msgstr ""
-#: ../imagery/i.pca/main.c:99
+#: ../vector/v.net.flow/main.c:107
#, fuzzy
-msgid "Rescaling range for output maps"
+msgid "Source category values"
msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/main.c:101
-msgid "For no rescaling use 0,0"
+#: ../vector/v.net.flow/main.c:113
+msgid "Source WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
-#: ../imagery/i.pca/main.c:102
-msgid "Rescale"
-msgstr ""
-#: ../imagery/i.pca/main.c:111
-msgid "Cumulative percent importance for filtering"
-msgstr ""
-#: ../imagery/i.pca/main.c:116
-msgid "Normalize (center and scale) input maps"
-msgstr ""
-#: ../imagery/i.pca/main.c:117
-msgid "Default: center only"
-msgstr ""
-#: ../imagery/i.pca/main.c:121
+#: ../vector/v.net.flow/main.c:118
#, fuzzy
-msgid "Output will be filtered input bands"
+msgid "Sink category values"
msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/main.c:122
-msgid "Applies inverse PCA after PCA"
+#: ../vector/v.net.flow/main.c:119 ../vector/v.net.flow/main.c:125
+msgid "Sink"
msgstr ""
-#: ../imagery/i.pca/main.c:157
-msgid "Sorry, at least 2 input bands must be provided"
+#: ../vector/v.net.flow/main.c:124
+msgid "Sink WHERE conditions of SQL statement without 'where' keyword"
msgstr ""
-#: ../imagery/i.pca/main.c:172
+#: ../vector/v.net.flow/main.c:198
#, c-format
-msgid "'%s' must be positive"
+msgid "No source features selected. Please check options '%s', '%s'."
msgstr ""
-#: ../imagery/i.pca/main.c:174
-#, fuzzy, c-format
-msgid "'%s' must be < 100"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/main.c:236
-msgid "Not enough principal components left for filtering"
-msgstr ""
-#: ../imagery/i.pca/main.c:238
+#: ../vector/v.net.flow/main.c:205
#, c-format
-msgid "Using %d of %d principal components for filtering"
+msgid "No sink features selected. Please check options '%s', '%s'."
msgstr ""
-#: ../imagery/i.pca/main.c:300
-msgid "Scale range length should be > 0. Using default values: 0,255."
-msgstr ""
-#: ../imagery/i.pca/main.c:346
+#: ../vector/v.net.flow/main.c:214
#, fuzzy
-msgid "Computing covariance matrix..."
+msgid "No sources"
msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/main.c:459
-#, fuzzy, c-format
-msgid "Rescaling to range %d,%d..."
-msgstr "출력할 래스터맵"
+#: ../vector/v.net.flow/main.c:217
+msgid "No sinks"
+msgstr ""
-#: ../imagery/i.pca/main.c:467
+#: ../vector/v.net.flow/main.c:241
#, fuzzy
-msgid "Calculating principal components..."
+msgid "Writing the output..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.pca/support.c:50
-msgid "Eigen values, (vectors), and [percent importance]:"
+#: ../vector/v.label.sa/main.c:41
+msgid "Create optimally placed labels for vector map(s)"
msgstr ""
-#: ../imagery/i.rectify/get_wind.c:124
-#, c-format
-msgid "Region N=%f S=%f E=%f W=%f"
+#: ../vector/v.label.sa/main.c:71
+msgid "Name of TrueType font (as listed in the fontcap)"
msgstr ""
-#: ../imagery/i.rectify/get_wind.c:126
-#, c-format
-msgid "Resolution EW=%f NS=%f"
+#: ../vector/v.label.sa/main.c:84
+msgid "Icon size of point features (in map-units)"
msgstr ""
-#: ../imagery/i.rectify/cp.c:14 ../vector/v.rectify/cp.c:350
-#, c-format
-msgid "Control Point file for group <%s@%s> - "
+#: ../vector/v.label.sa/main.c:154
+msgid "Border width (only for ps.map output)"
msgstr ""
-#: ../imagery/i.rectify/cp.c:21
+#: ../vector/v.label.sa/labels.c:68
#, c-format
-msgid "Not enough active control points for thin plate spline."
+msgid "Cannot allocate %lu bytes of memory"
msgstr ""
-#: ../imagery/i.rectify/cp.c:24 ../imagery/i.rectify/cp.c:51
-#: ../vector/v.rectify/cp.c:363
-msgid "Poorly placed control points."
+#: ../vector/v.label.sa/labels.c:86
+msgid "Unable to initialise FreeType"
msgstr ""
-#: ../imagery/i.rectify/cp.c:25 ../imagery/i.rectify/cp.c:52
-#: ../vector/v.rectify/cp.c:364
-#, fuzzy
-msgid " Can not generate the transformation equation."
+#: ../vector/v.label.sa/labels.c:89
+#, fuzzy, c-format
+msgid "Unable to find font '%s'\n"
msgstr "출력할 래스터맵"
-#: ../imagery/i.rectify/cp.c:28 ../imagery/i.rectify/cp.c:55
-#: ../vector/v.rectify/cp.c:367
-#, fuzzy
-msgid "Not enough memory to solve for transformation equation"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.rectify/cp.c:31 ../imagery/i.rectify/cp.c:58
-#: ../vector/v.rectify/cp.c:370
-msgid "Invalid order"
-msgstr ""
-#: ../imagery/i.rectify/cp.c:47 ../vector/v.rectify/cp.c:359
+#: ../vector/v.label.sa/labels.c:91
#, c-format
-msgid "Not enough active control points for current order, %d are required."
+msgid "Font '%s' is not a FreeType font\n"
msgstr ""
-#: ../imagery/i.rectify/main.c:100 ../vector/v.rectify/main.c:71
-msgid "rectify"
+#: ../vector/v.label.sa/labels.c:95
+msgid "Font file format is not supported by FreeType"
msgstr ""
-#: ../imagery/i.rectify/main.c:102
-msgid ""
-"Rectifies an image by computing a coordinate transformation for each pixel "
-"in the image based on the control points."
+#: ../vector/v.label.sa/labels.c:97
+msgid "Font file can not be loaded"
msgstr ""
-#: ../imagery/i.rectify/main.c:124 ../vector/v.rectify/main.c:102
-msgid "Rectification polynom order (1-3)"
+#: ../vector/v.label.sa/labels.c:106
+msgid "Unable to set font size"
msgstr ""
-#: ../imagery/i.rectify/main.c:161
-msgid "Use thin plate spline"
+#: ../vector/v.label.sa/labels.c:127
+msgid "Cannot allocate more memory"
msgstr ""
-#: ../imagery/i.rectify/main.c:199 ../vector/v.rectify/main.c:143
+#: ../vector/v.label.sa/labels.c:243
#, c-format
-msgid "Invalid order (%d); please enter 1 to %d"
+msgid "Cannot load glyph for '%c'"
msgstr ""
-#: ../imagery/i.rectify/main.c:206
-#, fuzzy, c-format
-msgid "Location: %s"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.rectify/main.c:207
-#, c-format
-msgid "Mapset: %s"
-msgstr ""
-#: ../imagery/i.rectify/main.c:208
-#, fuzzy, c-format
-msgid "Group <%s> does not exist"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.rectify/target.c:35 ../vector/v.rectify/target.c:43
-msgid "Please run i.target for group."
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:49
-msgid "topographic correction"
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:50
-msgid "Computes topographic correction of reflectance."
-msgstr ""
-#: ../imagery/i.topo.corr/main.c:58
+#: ../vector/v.out.svg/main.c:76
#, fuzzy
-msgid "Name of reflectance raster maps to be corrected topographically"
+msgid "Exports a vector map to SVG file."
msgstr "출력할 래스터맵"
-#: ../imagery/i.topo.corr/main.c:62
+#: ../vector/v.out.svg/main.c:85
#, fuzzy
-msgid "Name (flag -i) or prefix for output raster maps"
+msgid "Name for SVG output file"
msgstr "출력할 래스터맵"
-#: ../imagery/i.topo.corr/main.c:66
-#, fuzzy
-msgid "Name of input base raster map (elevation or illumination)"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.topo.corr/main.c:72
-msgid "Solar zenith in degrees"
+#: ../vector/v.out.svg/main.c:94
+msgid "Output type"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:78
-msgid "Solar azimuth in degrees (only if flag -i)"
+#: ../vector/v.out.svg/main.c:95
+msgid "Defines which feature-type will be extracted"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:85
-msgid "Topographic correction method"
+#: ../vector/v.out.svg/main.c:103
+msgid "Coordinate precision"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:90
-msgid "Output sun illumination terrain model"
+#: ../vector/v.out.svg/main.c:109
+msgid "Attribute(s) to include in output SVG"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:94
-msgid "Scale output to input and copy color rules"
+#: ../vector/v.out.svg/main.c:130
+msgid "Precision must not be negative"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:100
-msgid "Solar azimuth is necessary to calculate illumination terrain model"
+#: ../vector/v.out.svg/main.c:133
+msgid "Precision must not be higher than 15"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:104
-msgid "Reflectance maps are necessary to make topographic correction"
-msgstr ""
+#: ../vector/v.out.svg/main.c:201
+#, fuzzy, c-format
+msgid "Unable to create SVG file <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.topo.corr/main.c:164
-msgid "Illumination model is of CELL type"
-msgstr ""
+#: ../vector/v.out.svg/main.c:218
+#, fuzzy, c-format
+msgid "No areas found, skipping %s"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.topo.corr/main.c:167
+#: ../vector/v.out.svg/main.c:233 ../vector/v.extrude/main.c:275
#, c-format
-msgid "Band %s: "
+msgid "Skipping area %d without centroid"
msgstr ""
-#: ../imagery/i.topo.corr/main.c:175
-#, c-format
-msgid "Reflectance of <%s> is not of DCELL type - ignored."
-msgstr ""
-#: ../imagery/i.segment/main.c:38
-msgid "object recognition"
-msgstr ""
-#: ../imagery/i.segment/main.c:40
-msgid "Identifies segments (objects) from imagery data."
-msgstr ""
-#: ../imagery/i.segment/main.c:46
-#, fuzzy
-msgid "Error in reading data"
+#: ../vector/v.out.svg/main.c:259
+#, fuzzy, c-format
+msgid "%d areas extracted"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/main.c:50
-#, fuzzy
-msgid "Error in creating segments"
+#: ../vector/v.out.svg/main.c:266
+#, fuzzy, c-format
+msgid "No points found, skipping %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/main.c:54
-#, fuzzy
-msgid "Error in writing data"
+#: ../vector/v.out.svg/main.c:295
+#, fuzzy, c-format
+msgid "%d points extracted"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/main.c:59
+#: ../vector/v.out.svg/main.c:302
#, fuzzy, c-format
-msgid "Number of segments created: %d"
+msgid "No lines found, skipping %s"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/create_isegs.c:244
+#: ../vector/v.out.svg/main.c:329
#, fuzzy, c-format
-msgid "Processing pass %d..."
+msgid "%d lines extracted"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/create_isegs.c:522
+#: ../vector/v.out.svg/main.c:396
#, c-format
-msgid ""
-"Segmentation processes stopped at %d due to reaching max iteration limit, "
-"more merges may be possible"
+msgid "Cannot select attributes for cat=%d"
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:524
-#, c-format
-msgid "Segmentation converged after %d iterations"
-msgstr ""
+#: ../vector/v.net.alloc/main.c:62
+#, fuzzy
+msgid "allocation"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/create_isegs.c:532
-#, c-format
-msgid "Merging segments smaller than %d cells..."
+#: ../vector/v.net.alloc/main.c:64
+msgid "Allocate subnets for nearest centers (direction from center)."
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1075
-#, c-format
-msgid "Region stats should go in tree, %d >= %d"
+#: ../vector/v.net.alloc/main.c:66
+msgid ""
+"center node must be opened (costs >= 0). Costs of center node are used in "
+"calculation"
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1082
-msgid "Region ids are different"
+#: ../vector/v.net.alloc/main.c:111
+msgid ""
+"Categories of centers (points on nodes) to which net will be allocated, "
+"layer for this categories is given by nlayer option"
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1086
-msgid "Region consists of only one cell, nothing to update"
-msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1130
-#: ../imagery/i.segment/create_isegs.c:1555
+#: ../vector/v.net.alloc/main.c:190
#, c-format
-msgid "Region size is larger than 2: %d"
+msgid "Number of centers: [%d] (nlayer: [%d])"
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1197
-#, c-format
-msgid "Region size is %d, should be %d"
+#: ../vector/v.net.alloc/main.c:193
+msgid "Not enough centers for selected nlayer. Nothing will be allocated."
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1420
-#, c-format
-msgid "Candidate flag is already %s"
-msgstr ""
+#: ../vector/v.net.alloc/main.c:204
#, fuzzy
-msgid "set"
+msgid "Calculating costs from centers ..."
msgstr "출력할 래스터맵"
-msgid "unset"
+#: ../vector/v.net.alloc/main.c:346 ../vector/v.net.alloc/main.c:357
+#: ../vector/v.net.iso/main.c:512
+msgid "Cannot get line segment, segment out of line"
msgstr ""
-#: ../imagery/i.segment/create_isegs.c:1640
-#, c-format
-msgid "Region of size %d should be in search tree"
+#: ../vector/v.patch/main.c:70
+msgid "Creates a new vector map by combining other vector maps."
msgstr ""
-#: ../imagery/i.segment/parse_args.c:30
-msgid "Difference threshold between 0 and 1"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:31
-msgid "Threshold = 0 merges only identical segments; threshold = 1 merges all"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:41
+#: ../vector/v.patch/main.c:81
#, fuzzy
-msgid "Segmentation method"
+msgid ""
+"Name for output vector map where bounding boxes of input vector maps are "
+"written to"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:50
-msgid "Similarity calculation method"
+#: ../vector/v.patch/main.c:85
+msgid ""
+"Append files to existing file (overwriting existing files must be activated)"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:59
+#: ../vector/v.patch/main.c:90
#, fuzzy
-msgid "Minimum number of cells in a segment"
+msgid "Copy also attribute table"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:61
-msgid "The final step will merge small segments with their best neighbor"
+#: ../vector/v.patch/main.c:92
+msgid "Only the table of layer 1 is currently supported"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:72
-msgid "Importance of radiometric (input raster) values relative to shape"
+#: ../vector/v.patch/main.c:195
+msgid "Missing table"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:82
-msgid "Importance of smoothness relative to compactness"
+#: ../vector/v.patch/main.c:199
+msgid "Key columns differ"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:91
-msgid "Memory in MB"
+#: ../vector/v.patch/main.c:205
+msgid "Number of columns differ"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:109
-#, fuzzy
-msgid "Name for input raster map with starting seeds"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:115
-#, fuzzy
-msgid "Name of input bounding/constraining raster map"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:117
-msgid ""
-"Must be integer values, each area will be segmented independent of the others"
+#: ../vector/v.patch/main.c:217
+msgid "Column names differ"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:123
-#, fuzzy
-msgid "Name for output goodness of fit estimate map"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:128
-msgid ""
-"Use 8 neighbors (3x3 neighborhood) instead of the default 4 neighbors for "
-"each pixel"
+#: ../vector/v.patch/main.c:225
+msgid "Column types differ"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:134
-msgid "Weighted input, do not perform the default scaling of input raster maps"
+#: ../vector/v.patch/main.c:230
+msgid "Length of string columns differ"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:153
-msgid "Threshold should be >= 0 and <= 1"
+#: ../vector/v.patch/main.c:244
+msgid "Key column not found"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:159
+#: ../vector/v.patch/main.c:256
#, fuzzy
-msgid "Unable to assign segmentation method"
+msgid "The output map is not 3D"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:169
-msgid "Invalid similarity method"
-msgstr ""
-#: ../imagery/i.segment/parse_args.c:175
+#: ../vector/v.patch/main.c:322
#, fuzzy, c-format
-msgid "Option '%s' must be > 0"
+msgid "Patching vector map <%s>..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:177 ../imagery/i.segment/parse_args.c:182
-#, fuzzy, c-format
-msgid "Option '%s' must be <= 1"
-msgstr "출력할 래스터맵"
+#: ../vector/v.patch/main.c:346
+#, c-format
+msgid "Error reading vector map <%s> - some data may not be correct"
+msgstr ""
-#: ../imagery/i.segment/parse_args.c:180
+#: ../vector/v.patch/main.c:389
#, fuzzy, c-format
-msgid "Option '%s' must be >= 0"
+msgid "Building topology for vector map <%s>..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:208
-#, fuzzy
-msgid "Seeds raster map not found"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:212
-#, fuzzy
-msgid "Seeeds raster map must be CELL type (integers)"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:222
-#, fuzzy
-msgid "Segmentation constraint/boundary raster map not found"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:226
-msgid "Segmentation constraint raster map must be CELL type (integers)"
+#: ../vector/v.patch/main.c:395
+msgid "Intersections at borders will have to be snapped"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:241
-msgid "Invalid output raster name for goodness of fit"
+#: ../vector/v.patch/main.c:396
+msgid "Lines common between files will have to be edited"
msgstr ""
-#: ../imagery/i.segment/parse_args.c:249
-#, fuzzy
-msgid "Invalid number of iterations, 100 will be used"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/parse_args.c:259
-msgid "Invalid number of MB, 300 will be used"
+#: ../vector/v.patch/main.c:397
+msgid "The header information also may have to be edited"
msgstr ""
-#: ../imagery/i.segment/write_output.c:31
-#, fuzzy
-msgid "Writing out segment IDs..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/write_output.c:95 ../imagery/i.segment/open_files.c:40
+#: ../vector/v.patch/main.c:399
#, fuzzy, c-format
-msgid "Unable to read REF file for group <%s>"
+msgid "%d vector maps patched"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/write_output.c:98 ../imagery/i.segment/open_files.c:44
-#, fuzzy, c-format
-msgid "Group <%s> contains no raster maps"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/write_output.c:110
-msgid "Writing out goodness of fit"
+#: ../vector/v.patch/main.c:422
+#, c-format
+msgid "Cannot open select cursor: '%s'"
msgstr ""
-#: ../imagery/i.segment/open_files.c:69 ../imagery/i.segment/open_files.c:228
-#: ../imagery/i.segment/open_files.c:236
-#, fuzzy, c-format
-msgid "No min/max found in raster map <%s>"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:117
-#, c-format
-msgid "Non-NULL cells: %ld"
+#: ../vector/v.patch/main.c:433
+msgid "Cannot fetch row"
msgstr ""
-#: ../imagery/i.segment/open_files.c:119
-msgid "Insufficient number of non-NULL cells in current region"
+#: ../vector/v.patch/main.c:484
+msgid "Unknown column type"
msgstr ""
-#: ../imagery/i.segment/open_files.c:140
-#, fuzzy
-msgid "Loading input bands..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:142
-#, fuzzy
-msgid "Loading input band..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:174 ../imagery/i.segment/open_files.c:201
-#: ../imagery/i.segment/open_files.c:260 ../imagery/i.segment/open_files.c:347
-#: ../imagery/i.segment/open_files.c:373 ../imagery/i.segment/open_files.c:413
-#: ../imagery/i.segment/open_files.c:469
-#, fuzzy
-msgid "Unable to write to temporary file"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:267
+#: ../vector/v.patch/main.c:492
#, c-format
-msgid "There are no boundary constraints in '%s'"
+msgid "Cannot insert new record: '%s'"
msgstr ""
-#: ../imagery/i.segment/open_files.c:322
+#: ../vector/v.extract/copy_tab.c:86
#, fuzzy, c-format
-msgid "Loading seeds from '%s'"
+msgid "Writing attributes for layer %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:352
+#: ../vector/v.extract/copy_tab.c:91
#, fuzzy, c-format
-msgid "No seeds found in '%s'!"
+msgid "No attribute table for layer %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:489
-#, fuzzy, c-format
-msgid "Segment %d is already registered!"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.segment/open_files.c:538
+#: ../vector/v.extract/extract.c:171
#, c-format
-msgid "Regions with at least %d cells are stored in memory"
+msgid "No category found for area %d. Skipping."
msgstr ""
-#: ../imagery/i.segment/open_files.c:563
+#: ../vector/v.extract/extract.c:175
#, c-format
-msgid "Number of segments in memory: %d of %d total"
+msgid "More categories (%d) found for area %d. Using first found category %d"
msgstr ""
-#: ../imagery/i.segment/rclist.c:17
-msgid "rclist out of memory"
-msgstr ""
-#: ../imagery/i.segment/flag.c:21 ../imagery/i.segment/flag.c:28
-#: ../vector/v.distance/main.c:703 ../vector/v.distance/main.c:780
-#: ../vector/v.distance/main.c:976
-msgid "Out of memory!"
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:52
+#: ../vector/v.extract/extract.c:225
+#, fuzzy
msgid ""
-"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
-"Intensity-Saturation) color space."
-msgstr ""
-#: ../imagery/i.rgb.his/main.c:58
-#, fuzzy
-msgid "Name of input raster map (red)"
+"Topology level required for extracting areas for OGR layers. Areas will be "
+"not processed."
msgstr "출력할 래스터맵"
-#: ../imagery/i.rgb.his/main.c:62
+#: ../vector/v.extract/main.c:78
+#: ../locale/scriptstrings/t.vect.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast3d.extract_to_translate.c:3
+#: ../locale/scriptstrings/t.rast.extract_to_translate.c:3
#, fuzzy
-msgid "Name of input raster map (green)"
+msgid "extract"
msgstr "출력할 래스터맵"
-#: ../imagery/i.rgb.his/main.c:66
-#, fuzzy
-msgid "Name of input raster map (blue)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.extract/main.c:80
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
-#: ../imagery/i.rgb.his/main.c:70
-#, fuzzy
-msgid "Name for output raster map (hue)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.extract/main.c:85
+msgid "Dissolve common boundaries (default is no)"
+msgstr ""
-#: ../imagery/i.rgb.his/main.c:74
-#, fuzzy
-msgid "Name for output raster map (intensity)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.extract/main.c:89
+msgid "Do not copy attributes (see also 'new' parameter)"
+msgstr ""
-#: ../imagery/i.rgb.his/main.c:78
+#: ../vector/v.extract/main.c:105
#, fuzzy
-msgid "Name for output raster map (saturation)"
+msgid "Types to be extracted"
msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:69
-msgid ""
-"Calculates top-of-atmosphere radiance or reflectance and temperature for "
-"Landsat MSS/TM/ETM+/OLI"
+#: ../vector/v.extract/main.c:120
+msgid "Input text file with category numbers/number ranges to be extracted"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:76
-msgid "atmospheric correction"
+#: ../vector/v.extract/main.c:121
+msgid "If '-' given reads from standard input"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:91
-msgid "Example: 'B.toar.' generates B.toar.1, B.toar.2, ..."
+#: ../vector/v.extract/main.c:129
+msgid "Number of random categories matching vector objects to extract"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:98
-msgid "Name of Landsat metadata file (.met or MTL.txt)"
+#: ../vector/v.extract/main.c:131
+msgid "Number must be smaller than unique cat count in layer"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:104
-msgid "Spacecraft sensor"
+#: ../vector/v.extract/main.c:139
+msgid "Desired new category value (enter -1 to keep original categories)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:105
-msgid "Required only if 'metfile' not given (recommended for sanity)"
+#: ../vector/v.extract/main.c:141
+msgid "If new >= 0, attributes is not copied"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:110
-msgid "Landsat-1 MSS"
+#: ../vector/v.extract/main.c:158
+#, c-format
+msgid ""
+"Options <%s>, <%s>, <%s> and <%s> options are exclusive. Please specify only "
+"one of them."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:111
-msgid "Landsat-2 MSS"
-msgstr ""
+#: ../vector/v.extract/main.c:205
+#, fuzzy, c-format
+msgid "Category value in '%s' not valid"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:112
-msgid "Landsat-3 MSS"
+#: ../vector/v.extract/main.c:221
+#, c-format
+msgid "Process file <%s> for category numbers..."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:113
-msgid "Landsat-4 MSS"
-msgstr ""
+#: ../vector/v.extract/main.c:226
+#, fuzzy, c-format
+msgid "Unable to open specified file <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:114
-msgid "Landsat-5 MSS"
+#: ../vector/v.extract/main.c:237
+#, c-format
+msgid "Ignored text entry: %s"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:115
-msgid "Landsat-4 TM"
-msgstr ""
+#: ../vector/v.extract/main.c:256
+#, fuzzy, c-format
+msgid "Loading categories from table <%s>..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:116
-msgid "Landsat-5 TM"
-msgstr ""
+#: ../vector/v.extract/main.c:266
+#, fuzzy, c-format
+msgid "Unable select records from table <%s>"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:117
-msgid "Landsat-7 ETM+"
+#: ../vector/v.extract/main.c:268
+#, fuzzy, c-format
+msgid "%d category loaded"
+msgid_plural "%d categories loaded"
+#: ../vector/v.extract/main.c:283
+msgid ""
+"This map has no categories attached. Use v.category to attach categories to "
+"this vector map."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:118
-msgid "Landsat_8 OLI/TIRS"
+#: ../vector/v.extract/main.c:290
+msgid "Please specify random number larger than 0"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:128 ../imagery/i.landsat.toar/main.c:129
-msgid "Atmospheric correction method"
+#: ../vector/v.extract/main.c:294
+#, c-format
+msgid ""
+"Random category count must be smaller than feature count. There are only %d "
+"features of type(s): %s"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:138
-msgid "Image acquisition date (yyyy-mm-dd)"
+#: ../vector/v.extract/main.c:317
+#, c-format
+msgid ""
+"Random category count is larger or equal to uniq <%s> feature category count "
+"%d"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:139 ../imagery/i.landsat.toar/main.c:147
-#: ../imagery/i.landsat.toar/main.c:156 ../imagery/i.landsat.toar/main.c:164
-msgid "Required only if 'metfile' not given"
+#: ../vector/v.extract/main.c:322
+msgid ""
+"There are more categories than random number generator can reach. Report "
+"this as a GRASS bug."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:146
+#: ../vector/v.extract/main.c:355
#, fuzzy
-msgid "Sun elevation in degrees"
+msgid "Extracting features..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:155
-msgid "Image creation date (yyyy-mm-dd)"
+#: ../vector/v.extract/main.c:379
+msgid "Removing duplicate centroids..."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:163
-msgid "Gain (H/L) of all Landsat ETM+ bands (1-5,61,62,7,8)"
+#: ../vector/v.net.steiner/main.c:58
+#, c-format
+msgid "Init costs from node %d"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:171
-msgid "Percent of solar radiance in path radiance"
-msgstr ""
+#: ../vector/v.net.steiner/main.c:347
+#, fuzzy
+msgid "steiner tree"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:172 ../imagery/i.landsat.toar/main.c:182
-msgid "Required only if 'method' is any DOS"
+#: ../vector/v.net.steiner/main.c:349
+msgid "Creates Steiner tree for the network and given terminals."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:181
-msgid "Minimum pixels to consider digital number as dark object"
+#: ../vector/v.net.steiner/main.c:351
+msgid ""
+"Note that 'Minimum Steiner Tree' problem is NP-hard and heuristic algorithm "
+"is used in this module so the result may be sub optimal."
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:190
-msgid "Rayleigh atmosphere (diffuse sky irradiance)"
+#: ../vector/v.net.steiner/main.c:371
+msgid "Node layer (used for terminals)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:191
-msgid "Required only if 'method' is DOS3"
+#: ../vector/v.net.steiner/main.c:377
+msgid "Arcs' cost column (for both directions)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:200
-msgid "return value stored for a given metadata"
+#: ../vector/v.net.steiner/main.c:383
+msgid "Categories of points on terminals (layer is specified by nlayer)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:201
-msgid "Required only if 'metfile' and -p given"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:207
-msgid "Landsat Number"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:208
+#: ../vector/v.net.steiner/main.c:391
#, fuzzy
-msgid "Creation timestamp"
+msgid "Number of steiner points (-1 for all possible)"
msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:209
-msgid "Date"
+#: ../vector/v.net.steiner/main.c:458
+msgid "Not enough terminals (< 2)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:210
-#, fuzzy
-msgid "Sun Elevation"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:211
-msgid "Sensor"
+#: ../vector/v.net.steiner/main.c:464
+msgid "Requested number of Steiner points > than possible"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:212
-msgid "Bands count"
+#: ../vector/v.net.steiner/main.c:516
+#, c-format
+msgid "Terminal at node [%d] cannot be connected to terminal at node [%d]"
msgstr ""
-msgid "Sun Zenith Angle"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:220
-msgid "Output at-sensor radiance instead of reflectance for all bands"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:225
+#: ../vector/v.net.steiner/main.c:532
+#, c-format
msgid ""
-"Input raster maps use as extension the number of the band instead the code"
+"[%d] (not reachable) nodes removed from list of Steiner point candidates"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:229
-msgid "Print output metadata info"
+#: ../vector/v.net.steiner/main.c:537
+#, c-format
+msgid "MST costs = %f"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:255 ../imagery/i.landsat.toar/main.c:263
+#: ../vector/v.net.steiner/main.c:543
#, c-format
-msgid "Illegal date format: [%s] (yyyy-mm-dd)"
+msgid "Search for [%d]. Steiner point"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:284
-msgid "Please use a metadata keyword with -p"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:321
-msgid "Failed to identify satellite"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:335
+#: ../vector/v.net.steiner/main.c:564
#, c-format
-msgid "Lacking '%s' and/or '%s' for this satellite"
+msgid "Steiner point at node [%d] was added to terminals (MST costs = %f)"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:341
-msgid "Landsat-7 requires band gain with 9 (H/L) characters"
+#: ../vector/v.net.steiner/main.c:576
+msgid "No Steiner point found -> leaving cycle"
msgstr ""
-#: ../imagery/i.landsat.toar/main.c:361
-#, c-format
-msgid "Unknown satellite type (defined by '%s')"
-msgstr ""
-#: ../imagery/i.landsat.toar/main.c:408 ../imagery/i.landsat.toar/main.c:557
+#: ../vector/v.extrude/db.c:27
#, fuzzy, c-format
-msgid "Unable to read data type of raster map <%s>"
+msgid "Unable to select attributes category %d"
msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:550
-#, fuzzy, c-format
-msgid "Raster map <%s> exists. Skipping."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/main.c:573
-#, fuzzy, c-format
-msgid "Writing %s of <%s> to <%s>..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.landsat.toar/landsat_met.c:117
-#, fuzzy, c-format
-msgid "Metadata file <%s> not found"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ifft/main.c:81
-msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+#: ../vector/v.extrude/main.c:72
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height."
msgstr ""
-#: ../imagery/i.ifft/main.c:86
-#, fuzzy
-msgid "Name of input raster map (image fft, real part)"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ifft/main.c:90
-#, fuzzy
-msgid "Name of input raster map (image fft, imaginary part"
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ifft/main.c:116
-msgid "The real and imaginary original windows did not match"
+#: ../vector/v.extrude/main.c:74
+msgid ""
+"Optionally the height can be derived from sampling of elevation raster map."
msgstr ""
-#: ../imagery/i.ifft/main.c:158
-#, fuzzy
-msgid "Masking raster maps..."
-msgstr "출력할 래스터맵"
-#: ../imagery/i.ifft/main.c:201
-msgid "Starting Inverse FFT..."
+#: ../vector/v.extrude/main.c:78
+msgid "Trace elevation"
msgstr ""
-#: ../imagery/i.cca/transform.c:24
-msgid "Unable to allocate cell buffers."
+#: ../vector/v.extrude/main.c:101 ../vector/v.transform/main.c:120
+msgid "Shifting value for z coordinates"
msgstr ""
-#: ../imagery/i.cca/transform.c:58
-msgid "Transform completed.\n"
+#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
+#: ../vector/v.extrude/main.c:119 ../vector/v.to.3d/args.c:33
+#: ../vector/v.to.3d/args.c:41
+msgid "Height"
msgstr ""
-#: ../imagery/i.cca/main.c:88
-msgid "Canonical components analysis (CCA) program for image processing."
+#: ../vector/v.extrude/main.c:112 ../vector/v.to.3d/args.c:40
+msgid "Fixed height for 3D vector features"
msgstr ""
-#: ../imagery/i.cca/main.c:102
+#: ../vector/v.extrude/main.c:118
#, fuzzy
-msgid "File containing spectral signatures"
+msgid "Name of attribute column with feature height"
msgstr "출력할 래스터맵"
-#: ../imagery/i.cca/main.c:105
-msgid "Output raster map prefix name"
+#: ../vector/v.extrude/main.c:151
+#, c-format
+msgid "One of '%s' or '%s' parameters must be set"
msgstr ""
-#: ../imagery/i.cca/main.c:113
-msgid "Unknown imagery group."
+#: ../vector/v.extrude/main.c:202
+#, c-format
+msgid ""
+"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
+"layer '1'."
msgstr ""
-#: ../imagery/i.cca/main.c:116
-msgid "Unable to find subgroup reference information."
-msgstr ""
+#: ../vector/v.extrude/main.c:234
+#, fuzzy, c-format
+msgid "Column <%s> does not exist"
+msgstr "출력할 래스터맵"
-#: ../imagery/i.cca/main.c:122
-msgid "Unable to open the signature file"
+#: ../vector/v.extrude/main.c:243
+#, c-format
+msgid "Column <%s>: invalid data type"
msgstr ""
-#: ../imagery/i.cca/main.c:126
-msgid "Error while reading the signatures file."
-msgstr ""
+#: ../vector/v.extrude/main.c:265
+#, fuzzy
+msgid "Extruding areas..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.cca/main.c:131
-msgid "Need at least two signatures in signature file."
+#: ../vector/v.extrude/main.c:287
+#, c-format
+msgid "No category defined for area %d. Using default fixed height %f."
msgstr ""
-#: ../imagery/i.cca/main.c:225
+#: ../vector/v.extrude/main.c:293
#, c-format
-msgid "The output cell map <%s.%d> has values outside the 0-255 range."
+msgid ""
+"Unable to fetch height from DB for area %d. Using default fixed height %f."
msgstr ""
-#: ../imagery/i.target/main.c:48
-msgid "Targets an imagery group to a GRASS location and mapset."
-msgstr ""
+#: ../vector/v.extrude/main.c:319
+#, fuzzy
+msgid "Extruding features..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.target/main.c:57
-msgid "Name of imagery target location"
+#: ../vector/v.extrude/main.c:340
+#, c-format
+msgid "No category defined for feature %d. Using default fixed height %f."
msgstr ""
-#: ../imagery/i.target/main.c:63
-msgid "Name of target mapset"
+#: ../vector/v.extrude/main.c:346
+#, c-format
+msgid ""
+"Unable to fetch height from DB for line %d. Using default fixed height %f."
msgstr ""
-#: ../imagery/i.target/main.c:68
-msgid "Set current location and mapset as target for of imagery group"
-msgstr ""
+#: ../vector/v.extrude/main.c:364
+#, fuzzy
+msgid "Copying attribute table..."
+msgstr "출력할 래스터맵"
-#: ../imagery/i.target/main.c:90 ../imagery/i.target/main.c:107
-#: ../imagery/i.target/main.c:116
+#: ../vector/v.colors/scan_attr.c:58 ../vector/v.colors/scan_z.c:68
#, c-format
-msgid "Group <%s> targeted for location [%s], mapset [%s]"
+msgid "Min value (%f) is out of range %f,%f"
msgstr ""
-#: ../imagery/i.target/main.c:93
+#: ../vector/v.colors/scan_attr.c:64 ../vector/v.colors/scan_z.c:74
#, c-format
-msgid "Group <%s> has no target"
+msgid "Max value (%f) is out of range %f,%f"
msgstr ""
-#: ../imagery/i.target/main.c:101
-msgid ""
-"Use either the Current Mapset and Location Flag (-c)\n"
-" OR\n"
-" manually enter the variables"
+#: ../vector/v.colors/scan_attr.c:76 ../vector/v.colors/scan_cats.c:43
+#, c-format
+msgid "Min value (%d) is out of range %d,%d"
msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:53
-msgid ""
-"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
-"moisture (Makin, Molden and Bastiaanssen, 2001)."
+#: ../vector/v.colors/scan_attr.c:82 ../vector/v.colors/scan_cats.c:49
+#, c-format
+msgid "Max value (%d) is out of range %d,%d"
msgstr ""
-#: ../imagery/i.eb.evapfr/main.c:63
+#: ../vector/v.colors/scan_attr.c:107
#, fuzzy
-msgid "Name of soil heat flux raster map [W/m2]"
+msgid "Converting color rules into categories..."
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.evapfr/main.c:67
+#: ../vector/v.colors/write_rgb.c:36
+#, fuzzy, c-format
+msgid "Unable to add column <%s> to table <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/write_rgb.c:59
+#, fuzzy, c-format
+msgid "Column <%s> added to table <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/write_rgb.c:63
+#, fuzzy, c-format
+msgid "Data type of column <%s> must be char"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/write_rgb.c:67
#, fuzzy
-msgid "Name of sensible heat flux raster map [W/m2]"
+msgid "No categories found"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.evapfr/main.c:72
+#: ../vector/v.colors/write_rgb.c:77
+#, fuzzy, c-format
+msgid "No color value defined for category %d"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/write_rgb.c:85
#, fuzzy
-msgid "Name for output evaporative fraction raster map"
+msgid "Unable to update RGB values"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.evapfr/main.c:78
+#: ../vector/v.colors/read_rgb.c:32
+#, fuzzy, c-format
+msgid "Data type of RGB column <%s> must be char"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/read_rgb.c:37
#, fuzzy
-msgid "Name for output root zone soil moisture raster map"
+msgid "No RGB values found"
msgstr "출력할 래스터맵"
-#: ../imagery/i.eb.evapfr/main.c:83
-msgid "Root zone soil moisture output (Makin, Molden and Bastiaanssen, 2001)"
-msgstr ""
+#: ../vector/v.colors/read_rgb.c:65
+#, fuzzy, c-format
+msgid "%d invalid RGB color values skipped"
+msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/main.c:84
+#: ../vector/v.colors/main.c:58
#, fuzzy
-msgid "Unable to get window attributes"
+msgid "Creates/modifies the color table associated with a vector map."
msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/main.c:258
+#: ../vector/v.colors/main.c:70
#, fuzzy
-msgid "Unable to open image file"
+msgid "Source values"
msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/main.c:261
+#: ../vector/v.colors/main.c:73
#, fuzzy
-msgid "Unable to read BMP header"
+msgid "read values from attribute table (requires <column> option)"
msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/main.c:264
-msgid "Invalid BMP header"
+#: ../vector/v.colors/main.c:75
+msgid "use z coordinate (3D points or centroids only)"
msgstr ""
-#: ../visualization/ximgview/main.c:270
+#: ../vector/v.colors/main.c:79
#, fuzzy
-msgid "Unable to map image file"
+msgid "Name of column containing numeric data"
msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/main.c:295
-msgid "View BMP images from the PNG driver."
+#: ../vector/v.colors/main.c:80
+msgid "Required for use=attr"
msgstr ""
-#: ../visualization/ximgview/main.c:301
-msgid "Image file"
+#: ../vector/v.colors/main.c:87
+msgid "Manually set range (refers to 'column' option)"
msgstr ""
-#: ../visualization/ximgview/color.c:90 ../visualization/ximgview/color.c:288
-#, c-format
-msgid "Unknown visual class [%d]."
+#: ../vector/v.colors/main.c:88
+msgid "Ignored when 'rules' given"
msgstr ""
-#: ../visualization/ximgview/color.c:239
-msgid "Unable to get sufficient gray shades."
-msgstr ""
+#: ../vector/v.colors/main.c:117
+#, fuzzy
+msgid "Name of color column to populate RGB values"
+msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/color.c:256
-msgid "Unable to get sufficient colors."
-msgstr ""
+#: ../vector/v.colors/main.c:118
+#, fuzzy
+msgid "If not given writes color table"
+msgstr "출력할 래스터맵"
-#: ../visualization/ximgview/color.c:269
-msgid "Using private colormap for DirectColor visual."
+#: ../vector/v.colors/main.c:153
+#, fuzzy
+msgid "Convert color rules from RGB values to color table"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/main.c:154
+msgid "Option 'rgb_column' with valid RGB values required"
msgstr ""
-#: ../vector/v.in.dxf/layer_list.c:16
+#: ../vector/v.colors/main.c:197
+#, fuzzy
+msgid "No vector map specified"
+msgstr "출력할 래스터맵"
+#: ../vector/v.colors/main.c:202
#, c-format
-msgid "Layer %d: %s\n"
+msgid "Option <%s> given, assuming <use=attr>..."
msgstr ""
-#: ../vector/v.in.dxf/add_polyline.c:47
-msgid "vertices following flag missing"
+#: ../vector/v.colors/main.c:207
+#, c-format
+msgid "Options <%s> and <%s> are mutually exclusive"
msgstr ""
-#: ../vector/v.in.dxf/main.c:68
-#, fuzzy
-msgid "Converts file in DXF format to GRASS vector map."
+#: ../vector/v.colors/main.c:217
+#, fuzzy, c-format
+msgid "One of -%c, -%c or options <%s>, <%s> or <%s> must be specified"
msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:72
-msgid "Ignore the map extent of DXF file"
-msgstr ""
+#: ../vector/v.colors/main.c:231
+#, fuzzy, c-format
+msgid "Option <%s> required for flag -%c"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:80
-msgid "Import polyface meshes as 3D wire frame"
-msgstr ""
+#: ../vector/v.colors/main.c:246
+#, fuzzy, c-format
+msgid "Unable to remove color table of vector map <%s>"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:84
-msgid "List available DXF layers and exit"
-msgstr ""
+#: ../vector/v.colors/main.c:248
+#, fuzzy, c-format
+msgid "Color table of vector map <%s> not found"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:85 ../vector/v.in.dxf/main.c:92
-#: ../vector/v.in.dxf/main.c:97 ../vector/v.in.dxf/main.c:110
-msgid "DXF layers"
+#: ../vector/v.colors/main.c:256
+msgid "Color table exists. Exiting."
msgstr ""
-#: ../vector/v.in.dxf/main.c:91
-msgid "Invert selection by DXF layers (don't import layers in list)"
+#: ../vector/v.colors/main.c:278
+#, c-format
+msgid "Option <%s>: min must be greater or equal to max"
msgstr ""
-#: ../vector/v.in.dxf/main.c:96
-msgid "Import all objects into one layer"
-msgstr ""
+#: ../vector/v.colors/main.c:290
+#, fuzzy, c-format
+msgid "Color table <%s> not found"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:100
+#: ../vector/v.colors/main.c:348
#, fuzzy
-msgid "Path to input DXF file"
+msgid "Writing color rules..."
msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:109
-msgid "List of DXF layers to import (default: all)"
-msgstr ""
+#: ../vector/v.colors/main.c:364
+#, fuzzy, c-format
+msgid "Color table for vector map <%s> set to '%s'"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:124
-msgid "Please specify list of DXF layers to exclude"
-msgstr ""
+#: ../vector/v.colors/make_colors.c:14
+#, fuzzy, c-format
+msgid "Color table '%s' is not supported for floating point attributes"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:128
+#: ../vector/v.colors/make_colors.c:18 ../vector/v.colors/make_colors.c:25
#, fuzzy, c-format
-msgid "Unable to open DXF file <%s>"
+msgid "Color table <%s> not supported"
msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:131
-msgid "Layer number: layer name / GRASS compliant name"
+#: ../vector/v.what.rast3/main.c:71
+msgid "Uploads 3d raster values at positions of vector points to the table."
msgstr ""
-#: ../vector/v.in.dxf/main.c:165
-msgid "Building topology failed"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:81
+#, fuzzy
+msgid "Name of existing 3d raster map to be queried"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.dxf/main.c:171
-msgid "Failed to import DXF file!"
+#: ../vector/v.what.rast3/main.c:133
+#, c-format
+msgid "Error opening 3d raster map <%s>"
msgstr ""
-#: ../vector/v.in.dxf/read_dxf.c:57
-msgid "end of file while looking for HEADER"
+#: ../vector/v.what.rast3/main.c:142
+msgid "Column type not supported, please use a column with double type"
msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:52
-msgid "Entity handle truncated to 16 characters."
-msgstr ""
+#: ../vector/v.what.rast3/main.c:213
+#, fuzzy, c-format
+msgid "%d point outside current region was skipped"
+msgid_plural "%d points outside current region were skipped"
-#: ../vector/v.in.dxf/write_vect.c:70 ../vector/v.in.ascii/points.c:407
-#: ../vector/v.in.sites/main.c:242 ../vector/v.mkgrid/main.c:308
+#: ../vector/v.what.rast3/main.c:218
#, fuzzy, c-format
-msgid "Unable to insert new record: %s"
-msgstr "출력할 래스터맵"
+msgid "%d point without category was skipped"
+msgid_plural "%d points without category were skipped"
-#: ../vector/v.in.dxf/write_vect.c:91
-msgid "No DXF layers found!"
+#: ../vector/v.what.rast3/main.c:257
+#, c-format
+msgid "More points (%d) of category %d, value set to 'NULL'"
msgstr ""
-#: ../vector/v.in.dxf/write_vect.c:100
-msgid "Following DXF layers found:"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:327
+#, fuzzy, c-format
+msgid "%d category loaded from table"
+msgid_plural "%d categories loaded from table"
-#: ../vector/v.in.dxf/write_vect.c:104
-#, c-format
-msgid "Layer %d: %s"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:330
+#, fuzzy, c-format
+msgid "%d category loaded from vector"
+msgid_plural "%d categories loaded from vector"
-#: ../vector/v.in.dxf/write_vect.c:245
+#: ../vector/v.what.rast3/main.c:333
#, fuzzy, c-format
-msgid "Unable to add database link for vector map <%s>"
-msgstr "출력할 래스터맵"
+msgid "%d category from vector missing in table"
+msgid_plural "%d categories from vector missing in table"
-#: ../vector/v.kernel/main.c:68
+#: ../vector/v.what.rast3/main.c:337
#, c-format
-msgid "\tScore Value=%f\tsmoothing parameter (standard deviation)=%f"
-msgstr ""
+msgid "%d duplicate category in vector"
+msgid_plural "%d duplicate categories in vector"
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.kernel/main.c:109
-msgid "kernel density"
-msgstr ""
+#: ../vector/v.what.rast3/main.c:341
+#, fuzzy, c-format
+msgid "%d update error"
+msgid_plural "%d update errors"
-#: ../vector/v.kernel/main.c:111
-#, fuzzy
-msgid "Generates a raster density map from vector points map."
-msgstr "출력할 래스터맵"
+#: ../vector/v.what.rast3/main.c:345
+#, fuzzy, c-format
+msgid "%d record updated."
+msgid_plural "%d records updated."
-#: ../vector/v.kernel/main.c:112
-msgid ""
-"Density is computed using a moving kernel. Optionally generates a vector "
-"density map on a vector network."
-msgstr ""
-#: ../vector/v.kernel/main.c:116
-#, fuzzy
-msgid "Name of input vector map with training points"
+#: ../vector/v.surf.idw/read_sites.c:37
+#, fuzzy, c-format
+msgid "Input vector map <%s> is 2D - using categories to interpolate"
msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:121
-#, fuzzy
-msgid "Name of input network vector map"
+#: ../vector/v.surf.idw/read_sites.c:40
+#, fuzzy, c-format
+msgid "Input vector map <%s> is 3D - using z-coordinates to interpolate"
msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:124 ../vector/v.kernel/main.c:153
-#: ../vector/v.kernel/main.c:161 ../vector/v.kernel/main.c:183
-#: ../vector/v.kernel/main.c:208 ../vector/v.kernel/main.c:214
-msgid "Network"
+#: ../vector/v.surf.idw/read_sites.c:70
+#, fuzzy, c-format
+msgid "One record selected from table"
+msgid_plural "%d records selected from table"
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
+#: ../vector/v.surf.idw/read_sites.c:123
+#, fuzzy, c-format
+msgid "%ld point loaded"
+msgid_plural "%ld points loaded"
+#: ../vector/v.surf.idw/main.c:92
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+"Squared Weighting."
msgstr ""
-#: ../vector/v.kernel/main.c:131
+#: ../vector/v.surf.idw/main.c:101
#, fuzzy
-msgid "Name for output raster/vector map"
+msgid "Name of attribute column with values to interpolate"
msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:132
-#, fuzzy
-msgid "Outputs vector map if network map is given, otherwise raster map"
-msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:138
-msgid "Kernel radius in map units"
+#: ../vector/v.surf.idw/main.c:104
+msgid "Values"
msgstr ""
-#: ../vector/v.kernel/main.c:144
-msgid "Discretization error in map units"
+#: ../vector/v.surf.idw/main.c:121
+msgid "Power parameter"
msgstr ""
-#: ../vector/v.kernel/main.c:151
-msgid "Maximum length of segment on network"
+#: ../vector/v.surf.idw/main.c:123
+msgid "Greater values assign greater influence to closer points"
msgstr ""
-#: ../vector/v.kernel/main.c:159
-msgid "Maximum distance from point to network"
+#: ../vector/v.surf.idw/main.c:128
+msgid "Don't index points by raster cell"
msgstr ""
-#: ../vector/v.kernel/main.c:167
-msgid "Multiply the density result by this number"
+#: ../vector/v.surf.idw/main.c:129
+msgid ""
+"Slower but uses less memory and includes points from outside region in the "
+"interpolation"
msgstr ""
-#: ../vector/v.kernel/main.c:174
-msgid "Node method"
-msgstr ""
+#: ../vector/v.surf.idw/main.c:139
+#, fuzzy, c-format
+msgid "Illegal number (%s) of interpolation points"
+msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:180
-msgid "No method applied at nodes with more than 2 arcs"
-msgstr ""
+#. GTC First argument is map name, second - message about number of rows, third - columns.
+#: ../vector/v.surf.idw/main.c:263
+#, fuzzy, c-format
+msgid "Interpolating raster map <%s> (%s, %s)..."
+msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:181
-msgid "Equal split (Okabe 2009) applied at nodes"
+#: ../vector/v.net.iso/main.c:71
+msgid "Splits net by cost isolines."
msgstr ""
-#: ../vector/v.kernel/main.c:189
-msgid "Kernel function"
-msgstr ""
+#: ../vector/v.net.iso/main.c:74
+#, fuzzy
+msgid "isolines"
+msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:197
+#: ../vector/v.net.iso/main.c:76
msgid ""
-"Try to calculate an optimal standard deviation with 'stddeviation' taken as "
-"maximum (experimental)"
+"Splits net to bands between cost isolines (direction from centre). Centre "
+"node must be opened (costs >= 0). Costs of centre node are used in "
+"calculation."
msgstr ""
-#: ../vector/v.kernel/main.c:202
-msgid "Only calculate optimal standard deviation and exit (no map is written)"
-msgstr ""
-#: ../vector/v.kernel/main.c:207
+#: ../vector/v.net.iso/main.c:114
msgid ""
-"In network mode, normalize values by sum of density multiplied by length of "
-"each segment. Integral over the output map then gives 1.0 * mult"
+"Categories of centres (points on nodes) to which net will be allocated. "
+"Layer for this categories is given by nlayer option."
msgstr ""
-#: ../vector/v.kernel/main.c:213
-msgid "In network mode, multiply the result by number of input points"
+#: ../vector/v.net.iso/main.c:123
+msgid "Costs for isolines"
msgstr ""
-#: ../vector/v.kernel/main.c:223 ../vector/v.in.lidar/main.c:480
+#: ../vector/v.net.iso/main.c:160
#, c-format
-msgid "Vector map <%s> already exists and will be overwritten"
+msgid "Wrong iso cost: %f"
msgstr ""
-#: ../vector/v.kernel/main.c:226 ../vector/v.in.lidar/main.c:483
-#: ../vector/v.edit/main.c:96 ../vector/v.in.ogr/main.c:445
-#, fuzzy, c-format
-msgid "Vector map <%s> already exists"
-msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:252
-msgid "Unknown node method"
+#: ../vector/v.net.iso/main.c:163
+#, c-format
+msgid "Iso cost: %f less than previous"
msgstr ""
-#: ../vector/v.kernel/main.c:270
-msgid "Unknown kernel function"
+#: ../vector/v.net.iso/main.c:165
+#, c-format
+msgid "Iso cost %d: %f"
msgstr ""
-#: ../vector/v.kernel/main.c:276
-msgid ""
-"Optimal standard deviation calculation is supported only for node method "
-"'none' and kernel function 'gaussian'."
+#: ../vector/v.net.iso/main.c:172
+msgid "Not enough costs, everything reachable falls to first band"
msgstr ""
-#: ../vector/v.kernel/main.c:280
-msgid ""
-"Optimal standard deviation calculation is supported only for kernel function "
-"'gaussian'."
+#: ../vector/v.net.iso/main.c:208
+msgid "Centre at closed node (costs = -1) ignored"
msgstr ""
-#: ../vector/v.kernel/main.c:297
+#: ../vector/v.net.iso/main.c:226
#, c-format
-msgid "Standard deviation: %f"
+msgid "Number of centres: %d (nlayer %d)"
msgstr ""
-#: ../vector/v.kernel/main.c:298
+#: ../vector/v.net.iso/main.c:229
+msgid "Not enough centres for selected nlayer. Nothing will be allocated."
+msgstr ""
+#: ../vector/v.net.iso/main.c:249
#, fuzzy, c-format
-msgid "Output raster map: res: %f\trows: %d\tcols: %d"
+msgid "Calculating costs from centre %d..."
msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:337
-#, c-format
-msgid "%d points outside threshold"
-msgstr ""
+#: ../vector/v.outlier/main.c:71
+#, fuzzy
+msgid "Removes outliers from vector point data."
+msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:358
-#, c-format
-msgid ""
-"Automatic choice of smoothing parameter (standard deviation), maximum "
-"possible value of standard deviation is set to %f"
+#: ../vector/v.outlier/main.c:89
+msgid "Name of output outlier vector map"
msgstr ""
-#: ../vector/v.kernel/main.c:365
-#, c-format
-msgid "Using maximum distance between points: %f"
-msgstr ""
+#: ../vector/v.outlier/main.c:97
+#, fuzzy
+msgid "Name of vector map for visualization in QGIS"
+msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:379
-#, c-format
-msgid "Number of input points: %d."
+#: ../vector/v.outlier/main.c:119
+msgid "Tykhonov regularization weight"
msgstr ""
-#: ../vector/v.kernel/main.c:380
-#, c-format
-msgid "%d distances read from the map."
+#: ../vector/v.outlier/main.c:126
+msgid "Threshold for the outliers"
msgstr ""
-#: ../vector/v.kernel/main.c:383
-#, c-format
-msgid ""
-"Distances between all points are beyond %e (4 * standard deviation), unable "
-"to calculate optimal value."
+#: ../vector/v.outlier/main.c:133
+#, fuzzy
+msgid "Filtering option"
+msgstr "출력할 래스터맵"
+#: ../vector/v.outlier/main.c:255
+#, fuzzy, c-format
+msgid "It was impossible to create <%s> table."
+msgstr "출력할 래스터맵"
+#: ../vector/v.outlier/main.c:346
+msgid "No subregions found! Check values for 'soe' and 'son' parameters"
msgstr ""
-#: ../vector/v.kernel/main.c:394
-#, c-format
-msgid "Optimal smoothing parameter (standard deviation): %f."
+#: ../vector/v.outlier/main.c:419
+msgid "Outlier detection"
msgstr ""
-#: ../vector/v.kernel/main.c:425
-#, c-format
-msgid "Writing output vector map using smooth parameter %f"
+#: ../vector/v.out.ascii/main.c:51
+msgid "Exports a vector map to a GRASS ASCII vector representation."
msgstr ""
-#: ../vector/v.kernel/main.c:427 ../vector/v.kernel/main.c:537
-#, c-format
-msgid "Normalising factor %f"
+#: ../vector/v.out.ascii/main.c:52
+msgid ""
+"By default only features with category are exported. To export all features "
+"use 'layer=-1'."
msgstr ""
-#: ../vector/v.kernel/main.c:535
+#: ../vector/v.out.ascii/main.c:60
#, fuzzy, c-format
-msgid "Writing output raster map using smooth parameter %f"
+msgid "Parameter '%s' ignored in standard mode"
msgstr "출력할 래스터맵"
-#: ../vector/v.kernel/main.c:587
+#: ../vector/v.out.ascii/main.c:69
+#, fuzzy, c-format
+msgid "Format '%s' is not supported for old version"
+msgstr "출력할 래스터맵"
+#: ../vector/v.out.ascii/main.c:73
#, c-format
-msgid "Maximum value in output: %e."
+msgid "Parameter '%s' must be given for old version"
msgstr ""
-#: ../vector/v.rectify/cp.c:307 ../vector/v.rectify/cp.c:331
+#: ../vector/v.out.ascii/main.c:80
#, fuzzy, c-format
-msgid "Can not open file <%s>"
+msgid ""
+"Unable to open vector map <%s> at topology level. Areas will not be "
+"processed."
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/cp.c:314 ../vector/v.rectify/cp.c:338
+#: ../vector/v.out.ascii/main.c:107
#, fuzzy, c-format
-msgid "Bad format in control point file <%s>"
-msgstr "출력할 래스터맵"
+msgid "%d error in <%s> option"
+msgid_plural "%d errors in <%s> option"
-#: ../vector/v.rectify/main.c:73
-msgid ""
-"Rectifies a vector by computing a coordinate transformation for each object "
-"in the vector based on the control points."
+#: ../vector/v.out.ascii/main.c:141
+msgid "dig_att file already exist"
msgstr ""
-#: ../vector/v.rectify/main.c:88
-#, fuzzy
-msgid "Name of input file with control points"
+#: ../vector/v.out.ascii/main.c:144
+#, fuzzy, c-format
+msgid "Unable to open dig_att file <%s>"
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/main.c:93
+#: ../vector/v.out.ascii/main.c:149
#, fuzzy
-msgid "Name of output file with RMS errors (if omitted or '-' output to stdout"
+msgid "Fetching data..."
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/main.c:105
-#, fuzzy
-msgid "Field separator for RMS report"
-msgstr "출력할 래스터맵"
+#: ../vector/v.out.ascii/main.c:156
+msgid "No points found, nothing to be exported"
+msgstr ""
-#: ../vector/v.rectify/main.c:109
+#: ../vector/v.out.ascii/main.c:159
+msgid "No features found, nothing to be exported"
+msgstr ""
+#: ../vector/v.out.ascii/args.c:31
#, fuzzy
-msgid "Perform 3D transformation"
+msgid "Name for output ASCII file or ASCII vector name if '-o' is defined"
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/main.c:113
+#: ../vector/v.out.ascii/args.c:33
#, fuzzy
-msgid "Perform orthogonal 3D transformation"
+msgid "If not given or '-' then standard output"
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/main.c:117
-msgid "Print RMS errors"
+#: ../vector/v.out.ascii/args.c:38
+msgid "Name of attribute column(s) to be exported (point mode)"
msgstr ""
-#: ../vector/v.rectify/main.c:118
-msgid "Print RMS errors and exit without rectifying the input map"
+#: ../vector/v.out.ascii/args.c:39
+msgid "\"*\" for all columns"
msgstr ""
-#: ../vector/v.rectify/main.c:136
-msgid "Please select a group or give an input file."
+#: ../vector/v.out.ascii/args.c:59
+msgid "Simple point format (point per row)"
msgstr ""
-#: ../vector/v.rectify/main.c:138
-msgid "Points in group will be ignored, GCPs in input file are used."
+#: ../vector/v.out.ascii/args.c:60
+#, fuzzy
+msgid "GRASS ASCII vector format"
+msgstr "출력할 래스터맵"
+#: ../vector/v.out.ascii/args.c:61
+msgid "OGC well-known text"
msgstr ""
-#: ../vector/v.rectify/main.c:153
-msgid "3D transformation requires a 3D vector"
+#: ../vector/v.out.ascii/args.c:65
+msgid "Field separator (points mode)"
msgstr ""
-#: ../vector/v.rectify/main.c:156
-msgid "A file with 3D control points is needed for 3D transformation"
+#: ../vector/v.out.ascii/args.c:80
+msgid "Create old (version 4) ASCII file"
msgstr ""
-#: ../vector/v.rectify/main.c:213
-#, fuzzy, c-format
-msgid "The vector map <%s> already exists in"
-msgstr "출력할 래스터맵"
+#: ../vector/v.out.ascii/args.c:85
+msgid "Include column names in output (points mode)"
+msgstr ""
-#: ../vector/v.rectify/main.c:216
-msgid "Rectification cancelled."
+#: ../vector/v.out.ascii/args.c:91
+msgid "Only export points falling within current 3D region (points mode)"
msgstr ""
-#: ../vector/v.rectify/main.c:242 ../vector/v.proj/main.c:276
-#: ../vector/v.proj/main.c:395
+#: ../vector/v.convert/att.c:37
+msgid "No category labels (dig_cats) found, no table created"
+msgstr ""
+#: ../vector/v.convert/att.c:42
#, fuzzy
-msgid "Reading input vector map"
+msgid "Unable to open dig_cats file"
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/main.c:283 ../vector/v.category/main.c:765
-#, fuzzy
-msgid "Copying attribute table(s)..."
+#: ../vector/v.convert/att.c:68 ../vector/v.info/print.c:142
+#, fuzzy, c-format
+msgid "Unable to open driver <%s>"
msgstr "출력할 래스터맵"
-#: ../vector/v.rectify/main.c:285 ../vector/v.transform/main.c:282
-#: ../vector/v.category/main.c:767 ../vector/v.proj/main.c:411
-#: ../vector/v.type/main.c:148 ../vector/v.net/main.c:152
-#: ../vector/v.build.polylines/main.c:234
-#, fuzzy
-msgid "Failed to copy attribute table to output map"
+#: ../vector/v.convert/att.c:74 ../display/d.thematic.area/main.c:210
+#: ../display/d.vect/opt.c:152 ../db/db.select/main.c:81
+#: ../db/db.describe/main.c:61 ../db/db.tables/main.c:47
+#: ../db/db.execute/main.c:76
+#, fuzzy, c-format
+msgid "Unable to open database <%s>"
msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:70 ../vector/v.surf.rst/main.c:145
-#: ../vector/v.drape/main.c:59 ../vector/v.hull/main.c:54
-#: ../vector/v.to.3d/main.c:38 ../vector/v.out.postgis/main.c:49
-msgid "3D"
+#: ../vector/v.convert/main.c:39
+msgid "Imports older versions of GRASS vector maps."
msgstr ""
-#: ../vector/v.extrude/main.c:72
-msgid ""
-"Extrudes flat vector features to 3D vector features with defined height."
-msgstr ""
+#: ../vector/v.convert/main.c:56
+#, fuzzy
+msgid "Endian of input vector map"
+msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:74
-msgid ""
-"Optionally the height can be derived from sampling of elevation raster map."
-msgstr ""
-#: ../vector/v.extrude/main.c:78
-msgid "Trace elevation"
-msgstr ""
-#: ../vector/v.extrude/main.c:79 ../vector/v.extrude/main.c:125
-#: ../vector/v.extrude/main.c:129 ../vector/v.extrude/main.c:136
-#: ../vector/v.extrude/main.c:143 ../vector/v.drape/main.c:86
-#: ../vector/v.drape/main.c:93 ../vector/v.drape/main.c:100
+#: ../vector/v.convert/read.c:44
#, fuzzy
-msgid "Elevation"
+msgid "Reading dig file..."
msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:101 ../vector/v.transform/main.c:120
-msgid "Shifting value for z coordinates"
+#: ../vector/v.convert/read.c:85
+msgid "Input file is version 3."
msgstr ""
-#: ../vector/v.extrude/main.c:105 ../vector/v.extrude/main.c:113
-#: ../vector/v.extrude/main.c:119 ../vector/v.to.3d/args.c:33
-#: ../vector/v.to.3d/args.c:41
-msgid "Height"
+#: ../vector/v.convert/read.c:89
+msgid "Input file is version 4."
msgstr ""
-#: ../vector/v.extrude/main.c:112 ../vector/v.to.3d/args.c:40
-msgid "Fixed height for 3D vector features"
+#: ../vector/v.convert/read.c:99
+msgid "Input file is portable."
msgstr ""
-#: ../vector/v.extrude/main.c:118
-#, fuzzy
-msgid "Name of attribute column with feature height"
-msgstr "출력할 래스터맵"
+#: ../vector/v.convert/read.c:102
+msgid ""
+"Input file is not portable. We will attempt to convert anyway but conversion "
+"may fail. Please read manual for detail information."
+msgstr ""
-#: ../vector/v.extrude/main.c:124 ../vector/v.drape/main.c:82
-#, fuzzy
-msgid "Elevation raster map for height extraction"
-msgstr "출력할 래스터맵"
+#: ../vector/v.convert/read.c:188
+#, c-format
+msgid "[%d] points read to memory"
+msgstr ""
-#: ../vector/v.extrude/main.c:134 ../vector/v.drape/main.c:91
-#, fuzzy
-msgid "Scale factor sampled raster values"
-msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:142 ../vector/v.drape/main.c:99
-msgid "Height for sampled raster NULL values"
+#: ../vector/v.convert/read.c:189
+#, c-format
+msgid "[%d] lines read to memory"
msgstr ""
-#: ../vector/v.extrude/main.c:151
+#: ../vector/v.convert/read.c:192
#, c-format
-msgid "One of '%s' or '%s' parameters must be set"
+msgid "[%d] points read and written to output"
msgstr ""
-#: ../vector/v.extrude/main.c:197
+#: ../vector/v.convert/read.c:193
#, c-format
-msgid ""
-"Invalid layer number (%d). Parameter '%s', '%s' or '%s' specified, assuming "
-"layer '1'."
+msgid "[%d] lines read and written to output"
msgstr ""
-#: ../vector/v.extrude/main.c:229
-#, fuzzy, c-format
-msgid "Column <%s> does not exist"
-msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:238
+#: ../vector/v.convert/read.c:195
#, c-format
-msgid "Column <%s>: invalid data type"
+msgid "[%d] area boundaries read and written to output"
msgstr ""
-#: ../vector/v.extrude/main.c:260
-#, fuzzy
-msgid "Extruding areas..."
-msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:270 ../vector/v.out.svg/main.c:232
+#: ../vector/v.convert/read.c:196
#, c-format
-msgid "Skipping area %d without centroid"
+msgid "[%d] dead points skipped"
msgstr ""
-#: ../vector/v.extrude/main.c:282
+#: ../vector/v.convert/read.c:197
#, c-format
-msgid "No category defined for area %d. Using default fixed height %f."
+msgid "[%d] dead lines skipped"
msgstr ""
-#: ../vector/v.extrude/main.c:288
+#: ../vector/v.convert/read.c:198
#, c-format
-msgid ""
-"Unable to fetch height from DB for area %d. Using default fixed height %f."
+msgid "[%d] dead area boundaries skipped"
msgstr ""
-#: ../vector/v.extrude/main.c:314
-#, fuzzy
-msgid "Extruding features..."
-msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/main.c:335
+#: ../vector/v.convert/read.c:199
#, c-format
-msgid "No category defined for feature %d. Using default fixed height %f."
+msgid "[%d] elements of unknown type skipped"
msgstr ""
-#: ../vector/v.extrude/main.c:341
+#: ../vector/v.convert/read.c:201
#, c-format
-msgid ""
-"Unable to fetch height from DB for line %d. Using default fixed height %f."
+msgid "[%d] elements read to memory"
msgstr ""
-#: ../vector/v.extrude/main.c:359
+#: ../vector/v.convert/read.c:244
#, fuzzy
-msgid "Copying attribute table..."
+msgid "Reading dig_att file..."
msgstr "출력할 래스터맵"
-#: ../vector/v.extrude/db.c:27
-#, fuzzy, c-format
-msgid "Unable to select attributes category %d"
-msgstr "출력할 래스터맵"
-#: ../vector/v.label/main.c:62
-msgid "Creates paint labels for a vector map from attached attributes."
+#: ../vector/v.convert/read.c:252
+#, c-format
+msgid "Error: %s"
msgstr ""
-#: ../vector/v.label/main.c:67 ../vector/v.label.sa/main.c:61
-msgid "Name for new paint-label file"
+#: ../vector/v.convert/read.c:273
+#, c-format
+msgid "Unknown type: %c"
msgstr ""
-#: ../vector/v.label/main.c:69
-msgid "If not given the name of the input map is used"
+#: ../vector/v.convert/read.c:296
+#, c-format
+msgid "[%d] point categories read"
msgstr ""
-#: ../vector/v.label/main.c:78 ../vector/v.label.sa/main.c:57
-msgid "Name of attribute column to be used for labels"
+#: ../vector/v.convert/read.c:297
+#, c-format
+msgid "[%d] line categories read"
msgstr ""
-#: ../vector/v.label/main.c:89
-msgid "Rotate labels to align with lines"
+#: ../vector/v.convert/read.c:298
+#, c-format
+msgid "[%d] centroids read"
msgstr ""
-#: ../vector/v.label/main.c:94
-msgid "Curl labels along lines"
+#: ../vector/v.convert/read.c:299
+#, c-format
+msgid "[%d] dead point categories skipped"
msgstr ""
-#: ../vector/v.label/main.c:99
-msgid "Offset label in x-direction"
+#: ../vector/v.convert/read.c:300
+#, c-format
+msgid "[%d] dead line categories skipped"
msgstr ""
-#: ../vector/v.label/main.c:102 ../vector/v.label/main.c:109
-#: ../vector/v.label/main.c:118 ../vector/v.label/main.c:162
-msgid "Placement"
+#: ../vector/v.convert/read.c:301
+#, c-format
+msgid "[%d] dead centroids skipped"
msgstr ""
-#: ../vector/v.label/main.c:106
-msgid "Offset label in y-direction"
+#: ../vector/v.convert/read.c:302
+#, c-format
+msgid "[%d] categories of unknown type skipped"
msgstr ""
-#: ../vector/v.label/main.c:113 ../vector/v.lrs/v.lrs.label/main.c:174
-msgid "Reference position"
+#: ../vector/v.convert/read.c:304
+#, c-format
+msgid "[%d] categories read into memory"
msgstr ""
-#: ../vector/v.label/main.c:125 ../vector/v.label/main.c:132
-#: ../vector/v.label/main.c:140 ../vector/v.label/main.c:148
-#: ../vector/v.label.sa/main.c:72 ../vector/v.label.sa/main.c:80
-#: ../vector/v.lrs/v.lrs.label/main.c:181
-msgid "Font"
+#: ../vector/v.convert/old2new.c:31
+msgid "Failed opening input dig file."
msgstr ""
-#: ../vector/v.label/main.c:129 ../vector/v.label.sa/main.c:77
-#: ../vector/v.lrs/v.lrs.label/main.c:187
-msgid "Label size (in map-units)"
+#: ../vector/v.convert/old2new.c:45
+msgid "dig_att file doesn't exist."
msgstr ""
-#: ../vector/v.label/main.c:137
-msgid "Space between letters for curled labels (in map-units)"
+#: ../vector/v.convert/old2new.c:49
+msgid "Failed opening input dig_att file."
msgstr ""
-#: ../vector/v.label/main.c:144
-msgid "Label size (in points)"
+#: ../vector/v.convert/old2new.c:71
+msgid "Attaching categories..."
msgstr ""
-#: ../vector/v.label/main.c:156
-msgid "Rotation angle (degrees counter-clockwise)"
+#: ../vector/v.convert/old2new.c:88
+#, c-format
+msgid "Failed to attach an attribute (category %d) to a line."
msgstr ""
-#: ../vector/v.label/main.c:166
-msgid "Border width"
+#: ../vector/v.convert/old2new.c:93
+#, c-format
+msgid "Line %d label: %d matched another label: %d."
msgstr ""
-#: ../vector/v.label/main.c:174 ../vector/v.label.sa/main.c:107
-#: ../vector/v.lrs/v.lrs.label/main.c:211
-msgid "Highlight color for text"
+#: ../vector/v.convert/old2new.c:102
+msgid "Writing new file..."
msgstr ""
-#: ../vector/v.label/main.c:180 ../vector/v.label.sa/main.c:117
-msgid "Width of highlight coloring"
+#: ../vector/v.convert/old2new.c:124
+#, c-format
+msgid "[%d] points and lines written to output file."
msgstr ""
-#: ../vector/v.label/main.c:200 ../vector/v.label.sa/main.c:135
-msgid "Opaque to vector (only relevant if background color is selected)"
+#: ../vector/v.convert/old2new.c:138
+#, c-format
+msgid "[%d] centroids written to output file."
msgstr ""
-#: ../vector/v.label/main.c:251
-msgid ""
-"size and space options vary significantly which may lead to crummy output"
+#: ../vector/v.convert/type.c:29
+#, c-format
+msgid "OLD_T_NEW Got a bad type code [%x]"
msgstr ""
-#: ../vector/v.label/main.c:259
-msgid "Too many parameters for <reference>"
+#: ../vector/v.convert/type.c:50
+#, c-format
+msgid "NEW_T_OLD Got a bad type code [%x]"
msgstr ""
-#: ../vector/v.label/main.c:318 ../vector/v.label.sa/labels.c:160
-#: ../vector/v.overlay/main.c:400
+#: ../vector/v.build/main.c:39
#, fuzzy
-msgid "Unable to select attributes"
+msgid "Creates topology for vector map."
msgstr "출력할 래스터맵"
-#: ../vector/v.label/main.c:324 ../vector/v.what.rast3/main.c:266
-#: ../vector/v.sample/main.c:215 ../vector/v.sample/main.c:223
-#: ../vector/v.vol.rst/user1.c:172 ../vector/v.label.sa/labels.c:164
-#: ../vector/v.buffer/main.c:508 ../vector/v.buffer/main.c:609
-#: ../vector/v.what.rast/main.c:588
-#, fuzzy, c-format
-msgid "No record for category %d in table <%s>"
-msgstr "출력할 래스터맵"
+#: ../vector/v.build/main.c:40
+msgid "Optionaly also checks for topological errors."
+msgstr ""
-#: ../vector/v.label/main.c:437
-#, c-format
-msgid "Labeled %d lines."
+#: ../vector/v.build/main.c:44 ../display/d.zoom/main.c:84
+msgid "Name of vector map"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:54
+#: ../vector/v.build/main.c:49
#, fuzzy
-msgid "connectivity"
+msgid ""
+"Name for output vector map where erroneous vector features are written to"
msgstr "출력할 래스터맵"
-#: ../vector/v.net.connectivity/main.c:56
-msgid "Computes vertex connectivity between two sets of nodes in the network."
+#: ../vector/v.build/main.c:51 ../vector/v.build/main.c:77
+#: ../db/db.execute/main.c:161
+msgid "Errors"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:65
-#: ../vector/v.net.connectivity/main.c:71
-#: ../vector/v.net.connectivity/main.c:78
-#: ../vector/v.net.connectivity/main.c:84
-#: ../vector/v.net.connectivity/main.c:92 ../vector/v.net.bridge/main.c:61
-#: ../vector/v.net.bridge/main.c:67 ../vector/v.net.bridge/main.c:74
-#: ../vector/v.net.bridge/main.c:80 ../vector/v.net.bridge/main.c:87
-#: ../vector/v.net.distance/main.c:81 ../vector/v.net.distance/main.c:87
-#: ../vector/v.net.distance/main.c:93 ../vector/v.net.distance/main.c:139
-#: ../vector/v.net.distance/main.c:145 ../vector/v.net.distance/main.c:151
-#: ../vector/v.net.allpairs/main.c:94 ../vector/v.net.allpairs/main.c:100
-#: ../vector/v.net.allpairs/main.c:107 ../vector/v.net.flow/main.c:71
-#: ../vector/v.net.flow/main.c:77 ../vector/v.net.flow/main.c:91
-#: ../vector/v.net.flow/main.c:97 ../vector/v.net.flow/main.c:103
-#: ../vector/v.net.spanningtree/main.c:60
-#: ../vector/v.net.spanningtree/main.c:66
-#: ../vector/v.net.spanningtree/main.c:73
-#: ../vector/v.net.spanningtree/main.c:79 ../vector/v.net.timetable/main.c:275
-#: ../vector/v.net.timetable/main.c:281 ../vector/v.net.timetable/main.c:289
-#: ../vector/v.net.timetable/main.c:296 ../vector/v.net.timetable/main.c:303
-#: ../vector/v.net.components/main.c:84 ../vector/v.net.components/main.c:90
-#: ../vector/v.net.components/main.c:97 ../vector/v.net.components/main.c:103
-#: ../vector/v.net.components/main.c:110 ../vector/v.net.centrality/main.c:110
-#: ../vector/v.net.centrality/main.c:116 ../vector/v.net.centrality/main.c:130
-#: ../vector/v.net.centrality/main.c:136 ../vector/v.net.centrality/main.c:143
-msgid "Cost"
+#: ../vector/v.build/main.c:61
+msgid "Build topology or dump topology or indeces to standard output"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:77 ../vector/v.net.bridge/main.c:73
-#: ../vector/v.net.distance/main.c:138 ../vector/v.net.salesman/main.c:157
-#: ../vector/v.net.allpairs/main.c:93 ../vector/v.net.flow/main.c:90
-#: ../vector/v.net.alloc/main.c:93 ../vector/v.net.spanningtree/main.c:72
-#: ../vector/v.net.iso/main.c:100 ../vector/v.net.timetable/main.c:288
-#: ../vector/v.net.components/main.c:96 ../vector/v.net.centrality/main.c:129
-msgid "Arc forward/both direction(s) cost column (number)"
-msgstr ""
+#: ../vector/v.build/main.c:65
+#, fuzzy
+msgid "build topology"
+msgstr "출력할 래스터맵"
-#: ../vector/v.net.connectivity/main.c:83 ../vector/v.net.bridge/main.c:79
-#: ../vector/v.net.distance/main.c:144 ../vector/v.net.allpairs/main.c:99
-#: ../vector/v.net.flow/main.c:96 ../vector/v.net.alloc/main.c:99
-#: ../vector/v.net.iso/main.c:104 ../vector/v.net.timetable/main.c:295
-#: ../vector/v.net.components/main.c:102 ../vector/v.net.centrality/main.c:135
-msgid "Arc backward direction cost column (number)"
-msgstr ""
+#: ../vector/v.build/main.c:66
+#, fuzzy
+msgid "write topology to stdout"
+msgstr "출력할 래스터맵"
-#: ../vector/v.net.connectivity/main.c:91 ../vector/v.net.bridge/main.c:86
-#: ../vector/v.net.distance/main.c:150 ../vector/v.net.allpairs/main.c:106
-#: ../vector/v.net.flow/main.c:102 ../vector/v.net.alloc/main.c:105
-#: ../vector/v.net.spanningtree/main.c:78 ../vector/v.net.iso/main.c:108
-#: ../vector/v.net.timetable/main.c:302 ../vector/v.net.components/main.c:109
-#: ../vector/v.net.centrality/main.c:142
-msgid "Node cost column (number)"
+#: ../vector/v.build/main.c:67
+msgid "write spatial index to stdout"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:96
+#: ../vector/v.build/main.c:68
#, fuzzy
-msgid "Set1 category values"
+msgid "write category index to stdout"
msgstr "출력할 래스터맵"
-#: ../vector/v.net.connectivity/main.c:97
-#: ../vector/v.net.connectivity/main.c:103
-msgid "Set1"
+#: ../vector/v.build/main.c:69
+msgid "write feature index to stdout (OGR simple-feature-based formats only)"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:102
-msgid "Set1 WHERE conditions of SQL statement without 'where' keyword"
+#: ../vector/v.build/main.c:75
+msgid "Extensive checks for topological errors"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:107
-#, fuzzy
-msgid "Set2 category values"
-msgstr "출력할 래스터맵"
-#: ../vector/v.net.connectivity/main.c:108
-#: ../vector/v.net.connectivity/main.c:114
-msgid "Set2"
+#: ../vector/v.build/main.c:76
+msgid "Perform in-depth checks for topological errors when building topology"
msgstr ""
-#: ../vector/v.net.connectivity/main.c:113
-msgid "Set2 WHERE conditions of SQL statement without 'where' keyword"
-msgstr ""
-#: ../vector/v.net.connectivity/main.c:146
-#: ../vector/v.net.connectivity/main.c:153
+#: ../vector/v.build/main.c:106
#, c-format
-msgid "No features for %s selected. Please check options '%s', '%s'."
+msgid ""
+"Direct read access to OGR layers is not supported by this module. Run %s to "
+"create a link as GRASS vector map in the current mapset."
msgstr ""
-#: ../vector/v.net.connectivity/main.c:167
-#: ../vector/v.net.connectivity/main.c:170
+#: ../vector/v.build/main.c:111
#, fuzzy, c-format
-msgid "%s is empty"
+msgid "Vector map <%s> is not in current mapset"
msgstr "출력할 래스터맵"
-#: ../vector/v.net.connectivity/main.c:178 ../vector/v.net.bridge/main.c:134
-#: ../vector/v.net.distance/main.c:238 ../vector/v.net.flow/main.c:225
-#: ../vector/v.net.spanningtree/main.c:124
-#: ../vector/v.net.timetable/main.c:405 ../vector/v.net.components/main.c:162
-#: ../vector/v.net.centrality/main.c:284 ../vector/v.generalize/network.c:89
+#: ../vector/v.net/arcs.c:42
#, fuzzy, c-format
-msgid "Unable to build graph for vector map <%s>"
+msgid "Error reading file: '%s'"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.dxf/write_dxf.c:21
+#: ../vector/v.net/arcs.c:48
#, c-format
-msgid "The file '%s' already exists."
+msgid "Skipping arc %d"
msgstr ""
-#: ../vector/v.out.dxf/write_dxf.c:23
+#: ../vector/v.net/arcs.c:85
#, c-format
-msgid "The file '%s' already exists and will be overwritten."
+msgid "No point with category %d found"
msgstr ""
-#: ../vector/v.out.dxf/write_dxf.c:27
+#: ../vector/v.net/arcs.c:89
#, c-format
-msgid "%s: Cannot write dxf file."
+msgid "More points with category %d found"
msgstr ""
-#: ../vector/v.out.dxf/main.c:59
-#, fuzzy
-msgid "Exports vector map to DXF file format."
-msgstr "출력할 래스터맵"
+#: ../vector/v.net/report.c:37
+#, c-format
+msgid "Line %d has no category"
+msgstr ""
-#: ../vector/v.out.dxf/main.c:67
-#, fuzzy
-msgid "Name for DXF output file"
-msgstr "출력할 래스터맵"
-#: ../vector/v.out.dxf/main.c:91
+#: ../vector/v.net/report.c:67
#, fuzzy, c-format
-msgid "%d features written to '%s'."
+msgid "%d points found: %g %g %g line category: %d"
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:74
-msgid ""
-"Performs an affine transformation (shift, scale and rotate) on vector map."
+#: ../vector/v.net/report.c:94
+#, c-format
+msgid "Duplicate nodes at x=%g y=%g z=%g "
msgstr ""
-#: ../vector/v.transform/main.c:79
-msgid "Shift all z values to bottom=0"
-msgstr ""
-#: ../vector/v.transform/main.c:84
-msgid "Swap coordinates x, y and then apply other parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:88
+#: ../vector/v.net/connect.c:72
#, fuzzy
-msgid "Do not build topology for output"
+msgid "Failed to find intersection segment"
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:93 ../vector/v.transform/main.c:104
-#: ../vector/v.transform/main.c:113 ../vector/v.transform/main.c:122
-#: ../vector/v.transform/main.c:131 ../vector/v.transform/main.c:140
-#: ../vector/v.transform/main.c:149 ../vector/v.transform/main.c:159
-#: ../vector/v.transform/main.c:166
-msgid "Custom"
+#: ../vector/v.net/main.c:47
+msgid "network maintenance"
msgstr ""
-#: ../vector/v.transform/main.c:102
-msgid "Shifting value for x coordinates"
+#: ../vector/v.net/main.c:48
+msgid "Performs network maintenance."
msgstr ""
-#: ../vector/v.transform/main.c:111
-msgid "Shifting value for y coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:129
-msgid "Scaling factor for x coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:138
-msgid "Scaling factor for y coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:147
-msgid "Scaling factor for z coordinates"
-msgstr ""
-#: ../vector/v.transform/main.c:157
-msgid "Rotation around z axis in degrees counterclockwise"
-msgstr ""
-#: ../vector/v.transform/main.c:163
-msgid "Name of attribute column(s) used as transformation parameters"
-msgstr ""
-#: ../vector/v.transform/main.c:165
-msgid "Format: parameter:column, e.g. xshift:xs,yshift:ys,zrot:zr"
-msgstr ""
-#: ../vector/v.transform/main.c:181
-#, c-format
-msgid "Columns require a valid layer. Please use '%s' parameter."
-msgstr ""
-#: ../vector/v.transform/main.c:211
+#: ../vector/v.net/main.c:119
#, fuzzy, c-format
-msgid "Unknown column parameter '%s'"
+msgid "Unable to open vector map <%s> at topology level %d"
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:222
+#: ../vector/v.net/main.c:135
#, fuzzy, c-format
-msgid "Unable to tokenize column string: [%s]"
+msgid "%d new points (nodes) written to output."
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:275
-#, fuzzy
-msgid "Tranforming features..."
+#: ../vector/v.net/main.c:146
+#, fuzzy, c-format
+msgid "%d lines (network arcs) written to output."
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:280 ../vector/v.net/main.c:150
-#: ../vector/v.to.3d/main.c:96 ../vector/v.to.3d/main.c:117
-#: ../vector/v.in.db/main.c:247
+#: ../vector/v.net/args.c:14
#, fuzzy
-msgid "Copying attributes..."
+msgid "Name of input vector line map (arcs)"
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:288
-#, fuzzy, c-format
-msgid "New vector map <%s> boundary coordinates:"
-msgstr "출력할 래스터맵"
-#: ../vector/v.transform/main.c:290
-#, c-format
-msgid " N: %-10.3f S: %-10.3f"
+#: ../vector/v.net/args.c:15
+msgid "Required for operation 'nodes', 'connect', 'report' and 'nreport'"
msgstr ""
-#: ../vector/v.transform/main.c:291
-#, c-format
-msgid " E: %-10.3f W: %-10.3f"
+#: ../vector/v.net/args.c:17 ../vector/v.net/args.c:56
+msgid "Arcs"
msgstr ""
-#: ../vector/v.transform/main.c:292
-#, c-format
-msgid " B: %6.3f T: %6.3f"
-msgstr ""
-#: ../vector/v.transform/trans_digit.c:101 ../vector/v.in.db/main.c:152
-#: ../vector/v.db.connect/main.c:288
-#, fuzzy, c-format
-msgid "Missing column <%s> in table <%s>"
+#: ../vector/v.net/args.c:21
+#, fuzzy
+msgid "Name of input vector point map (nodes)"
msgstr "출력할 래스터맵"
-#: ../vector/v.transform/trans_digit.c:104
-#, c-format
-msgid "Unsupported column type of <%s>"
+#: ../vector/v.net/args.c:23
+msgid "Required for operation 'connect' and 'arcs'"
msgstr ""
-#: ../vector/v.transform/trans_digit.c:112
-#, c-format
-msgid ""
-"Unable to select value for category %d from table <%s>, column <%s>. For "
-"category %d using default transformation parameter %.3f."
+#: ../vector/v.net/args.c:25 ../vector/v.net/args.c:63
+#: ../vector/v.net/args.c:85 ../vector/v.net/args.c:92
+msgid "Nodes"
msgstr ""
-#: ../vector/v.transform/trans_digit.c:123
-msgid "No category number defined. Using default transformation parameters."
-msgstr ""
+#: ../vector/v.net/args.c:36
+#: ../locale/scriptstrings/g.extension_to_translate.c:8
+#: ../locale/scriptstrings/g.extension.all_to_translate.c:6
+#, fuzzy
+msgid "Operation to be performed"
+msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:53
-msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+#: ../vector/v.net/args.c:40
+msgid "new point is placed on each node (line end) if doesn't exist"
msgstr ""
-#: ../vector/v.in.ascii/main.c:71
-msgid "simple x,y[,z] list"
+#: ../vector/v.net/args.c:42
+msgid ""
+"connect still unconnected points to vector network by inserting new line(s)"
msgstr ""
-#: ../vector/v.in.ascii/main.c:72
-msgid "GRASS vector ASCII format"
+#: ../vector/v.net/args.c:44
+msgid "new line is created from start point to end point"
msgstr ""
-#: ../vector/v.in.ascii/main.c:75
-msgid "Input file format"
+#: ../vector/v.net/args.c:46
+msgid ""
+"print to standard output {line_category start_point_category "
+"end_point_category}"
msgstr ""
-#: ../vector/v.in.ascii/main.c:76 ../vector/v.in.ascii/main.c:79
-#: ../vector/v.in.ascii/main.c:157
-msgid "Input format"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:88
-msgid "Number of header lines to skip at top of input file (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:97
-msgid "Column definition in SQL style (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:98
+#: ../vector/v.net/args.c:48
msgid ""
-"For example: 'x double precision, y double precision, cat int, name "
-"varchar(10)'"
+"print to standard output {point_category line_category[,line_category...]}"
msgstr ""
-#: ../vector/v.in.ascii/main.c:110 ../vector/v.in.ascii/main.c:120
-msgid "First column is 1"
+#: ../vector/v.net/args.c:72
+msgid "Required for operation 'connect'. Connect points in given threshold."
msgstr ""
-#: ../vector/v.in.ascii/main.c:119
+#: ../vector/v.net/args.c:76
#, fuzzy
-msgid "Number of column used as y coordinate (points mode)"
+msgid "Name of input file"
msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:129
-#, fuzzy
-msgid "Number of column used as z coordinate (points mode)"
-msgstr "출력할 래스터맵"
+#: ../vector/v.net/args.c:78
+msgid "Required for operation 'arcs'. '-' for standard input."
+msgstr ""
-#: ../vector/v.in.ascii/main.c:130
-msgid "First column is 1. If 0, z coordinate is not used"
+#: ../vector/v.net/args.c:83
+msgid "Assign unique categories to new points"
msgstr ""
-#: ../vector/v.in.ascii/main.c:140
-#, fuzzy
-msgid "Number of column used as category (points mode)"
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:142
-msgid ""
-"First column is 1. If 0, unique category is assigned to each row and written "
-"to new column 'cat'"
+#: ../vector/v.net/args.c:84
+msgid "For operation 'nodes'"
msgstr ""
-#: ../vector/v.in.ascii/main.c:146 ../vector/v.in.dwg/main.c:106
+#: ../vector/v.net/args.c:89
#, fuzzy
-msgid "Create 3D vector map"
+msgid "Snap points to network"
msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:151
-msgid "Create a new empty vector map and exit. Nothing is read from input."
+#: ../vector/v.net/args.c:91
+msgid ""
+"For operation 'connect'. By default, a new line from the point to the "
+"network is created."
msgstr ""
-#: ../vector/v.in.ascii/main.c:156
-msgid "Don't expect a header when reading in standard format"
+#: ../vector/v.net/args.c:113
+msgid "Unknown operation"
msgstr ""
-#: ../vector/v.in.ascii/main.c:161
-msgid "Do not create table in points mode"
+#: ../vector/v.net/args.c:140
+msgid "Threshold value must be >= 0"
msgstr ""
-#: ../vector/v.in.ascii/main.c:171
-msgid "Only import points falling within current region (points mode)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:188
-msgid "Please specify z column"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:199
-msgid "Please specify reasonable z column"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:204
-msgid "Column numbers must not be negative"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:208
-#, fuzzy, c-format
-msgid "Unable to open ASCII file <%s>"
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:261
+#: ../vector/v.what/what.c:201 ../display/d.what.vect/what.c:152
+#: ../display/d.what.vect/what.c:154
#, c-format
-msgid "Maximum input row length: %d"
+msgid "Nothing Found.\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:263
+#: ../vector/v.what/what.c:258
#, c-format
-msgid "Maximum number of columns: %d"
+msgid ""
+"Id: %d\n"
+"Type: %s\n"
+"Left: %d\n"
+"Right: %d\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:264
+#: ../vector/v.what/what.c:263 ../vector/v.what/what.c:319
+#: ../display/d.what.vect/what.c:217
#, c-format
-msgid "Minimum number of columns: %d"
+msgid "Length: %f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:267
-#, fuzzy, c-format
-msgid "Number of columns: %d"
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:272 ../vector/v.in.ascii/main.c:276
-#: ../vector/v.in.ascii/main.c:281 ../vector/v.in.ascii/main.c:286
+#: ../vector/v.what/what.c:282
#, c-format
msgid ""
-"'%s' column number > minimum last column number (incorrect field separator "
-"or format?)"
+"Node[%d]=%d\n"
+"Number_lines=%d\n"
+"Coordinates=%.6f,%.6f,%.6f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:291 ../vector/v.in.ascii/main.c:294
-#: ../vector/v.in.ascii/main.c:297 ../vector/v.in.ascii/main.c:300
-#, fuzzy, c-format
-msgid "'%s' column is not of number type"
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/main.c:340
-msgid "Category column is not of integer type"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:417
+#: ../vector/v.what/what.c:287
#, c-format
msgid ""
-"Number of columns defined (%d) does not match number of columns (%d) in input"
+"Node[%d]: %d\n"
+"Number of lines: %d\n"
+"Coordinates: %.6f, %.6f, %.6f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:445
+#: ../vector/v.what/what.c:301
#, c-format
-msgid "Column number %d <%s> defined as double has only integer values"
+msgid ""
+"Id: %5d\n"
+"Angle: %.8f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:450
+#: ../vector/v.what/what.c:316
#, c-format
-msgid "Column number %d <%s> defined as string has only integer values"
+msgid "Type: %s\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:457
+#: ../vector/v.what/what.c:317
#, c-format
-msgid "Column number %d <%s> defined as integer has double values"
+msgid "Id: %d\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:462
+#: ../vector/v.what/what.c:333 ../display/d.what.vect/what.c:272
#, c-format
-msgid "Column number %d <%s> defined as string has double values"
+msgid "Point height: %f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:469
+#: ../vector/v.what/what.c:350 ../display/d.what.vect/what.c:290
#, c-format
-msgid "Column number %d <%s> defined as integer has string values"
+msgid "Line height: %f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:474
+#: ../vector/v.what/what.c:361
#, c-format
-msgid "Column number %d <%s> defined as double has string values"
+msgid ""
+"Line height min: %f\n"
+"Line height max: %f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:479
+#: ../vector/v.what/what.c:375
#, c-format
-msgid "Length of column %d <%s> (%d) is less than maximum value length (%d)"
-msgstr ""
-#: ../vector/v.in.ascii/main.c:519
-msgid "Populating table..."
-msgstr ""
-#: ../vector/v.in.ascii/main.c:525
msgid ""
-"Could not close attribute table. The DBMI driver did not accept all "
-"attributes"
+"Type: Area\n"
+"Area height: %f\n"
msgstr ""
-#: ../vector/v.in.ascii/main.c:534 ../vector/v.in.ascii/main.c:537
-#, fuzzy
-msgid "Import failed"
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/points.c:83
-#, fuzzy
-msgid "Scanning input for column types..."
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/points.c:164 ../vector/v.in.ascii/points.c:183
+#: ../vector/v.what/what.c:383
#, c-format
-msgid ""
-"Current row %d:\n"
-"%s\n"
+msgid "Type: Area\n"
msgstr ""
-#: ../vector/v.in.ascii/points.c:165
+#: ../vector/v.what/what.c:405
#, fuzzy, c-format
-msgid "Unparsable longitude value in column num %d: %s"
+msgid ""
+"Area: %d\n"
+"Number of isles: %d\n"
msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/points.c:184
-#, fuzzy, c-format
-msgid "Unparsable latitude value in column num %d: %s"
-msgstr "출력할 래스터맵"
-#: ../vector/v.in.ascii/points.c:265
+#: ../vector/v.what/what.c:415
#, c-format
-msgid "Skipping %d of %d rows falling outside of current region"
+msgid "Isle[%d]: %d\n"
msgstr ""
-#: ../vector/v.in.ascii/points.c:293
-#, fuzzy
-msgid "Importing points..."
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:146
-msgid "Performs surface interpolation from vector points map by splines."
+#: ../vector/v.what/what.c:428
+#, c-format
+msgid "Island: %d In area: %d\n"
msgstr ""
-#: ../vector/v.surf.rst/main.c:148
+#: ../vector/v.what/what.c:441
+#, c-format
msgid ""
-"Spatial approximation and topographic analysis from given point or isoline "
-"data in vector format to floating point raster format using regularized "
-"spline with tension."
+"Sq Meters: %.3f\n"
+"Hectares: %.3f\n"
msgstr ""
-#: ../vector/v.surf.rst/main.c:155
-msgid "Perform cross-validation procedure without raster approximation"
+#: ../vector/v.what/what.c:443
+#, c-format
+msgid ""
+"Acres: %.3f\n"
+"Sq Miles: %.4f\n"
msgstr ""
-#: ../vector/v.surf.rst/main.c:160
-msgid "Use scale dependent tension"
+#: ../vector/v.what/what.c:466
+#, c-format
+msgid ""
+"Layer: %d\n"
+"Category: %d\n"
msgstr ""
-#: ../vector/v.surf.rst/main.c:179 ../vector/v.surf.bspline/main.c:174
-msgid "Name of the attribute column with values to be used for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:180 ../vector/v.surf.idw/main.c:101
+#: ../vector/v.what/what.c:478
+#, c-format
msgid ""
-"If not given and input is 2D vector map then category values are used. If "
-"input is 3D vector map then z-coordinates are used."
+"\n"
+"Driver: %s\n"
+"Database: %s\n"
+"Table: %s\n"
+"Key column: %s\n"
msgstr ""
-#: ../vector/v.surf.rst/main.c:190
+#: ../vector/v.what/main.c:63
#, fuzzy
-msgid "Name for output surface elevation raster map"
+msgid "Queries a vector map at given locations."
msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:220
+#: ../vector/v.what/main.c:76
#, fuzzy
-msgid "Name for output mean curvature raster map"
+msgid "\"-\" to read from standard input"
msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:226
-#, fuzzy
-msgid "Name for output deviations vector point map"
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:233
-#, fuzzy
-msgid "Name for output cross-validation errors vector point map"
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:240
-#, fuzzy
-msgid "Name for output vector map showing quadtree segmentation"
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:247
-#, fuzzy
-msgid "Name for output vector map showing overlapping windows"
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:253
-#, fuzzy
-msgid "Name of raster map used as mask"
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:261 ../vector/v.vol.rst/main.c:270
-msgid "Tension parameter"
+#: ../vector/v.what/main.c:83
+msgid "Query threshold distance"
msgstr ""
-#: ../vector/v.surf.rst/main.c:268 ../vector/v.vol.rst/main.c:278
-msgid "Smoothing parameter"
+#: ../vector/v.what/main.c:84
+msgid "Threshold"
msgstr ""
-#: ../vector/v.surf.rst/main.c:276
-msgid "Name of the attribute column with smoothing parameters"
+#: ../vector/v.what/main.c:88 ../display/d.what.vect/main.c:90
+msgid "Print topological information (debugging)"
msgstr ""
-#: ../vector/v.surf.rst/main.c:301 ../vector/v.vol.rst/main.c:339
-msgid "Minimum distance between points (to remove almost identical points)"
+#: ../vector/v.what/main.c:93
+msgid "Print attribute information"
msgstr ""
-#: ../vector/v.surf.rst/main.c:309
-msgid ""
-"Maximum distance between points on isoline (to insert additional points)"
-msgstr ""
+#: ../vector/v.what/main.c:113
+#, fuzzy
+msgid "No input vector maps!"
+msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:318
-msgid "Conversion factor for values used for approximation"
+#: ../vector/v.what/main.c:158
+#, c-format
+msgid "Number of given vector maps (%d) differs from number of layers (%d)"
msgstr ""
-#: ../vector/v.surf.rst/main.c:326
-msgid "Anisotropy angle (in degrees counterclockwise from East)"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:389 ../vector/v.surf.rst/main.c:394
-#: ../vector/v.surf.rst/main.c:399 ../vector/v.surf.rst/main.c:404
+#: ../vector/v.what/main.c:167
#, fuzzy, c-format
-msgid "Output vector map name <%s> is not valid map name"
+msgid "You must build topology on vector map <%s>"
msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:417
-#, fuzzy
-msgid "You are not outputting any raster or vector maps"
-msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:426
-msgid ""
-"Both cross-validation options (-c flag and cvdev vector output) must be "
-"specified"
+#: ../vector/v.what/main.c:184
+#, c-format
+msgid "Unknown input format, skipping: '%s'"
msgstr ""
-#: ../vector/v.surf.rst/main.c:429
-msgid ""
-"The cross-validation cannot be computed simultaneously with output raster or "
-"devi file"
+#: ../vector/v.perturb/normalrs.c:31
+msgid "normalsv: restoration of unitialized block"
msgstr ""
-#: ../vector/v.surf.rst/main.c:447
-msgid "Using anisotropy - both theta and scalex have to be specified"
-msgstr ""
+#: ../vector/v.perturb/main.c:67
+#, fuzzy
+msgid "Random location perturbations of vector points."
+msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:455
-msgid "Both smatt and smooth options specified - using constant"
+#: ../vector/v.perturb/main.c:81
+msgid "Distribution of perturbation"
msgstr ""
-#: ../vector/v.surf.rst/main.c:465
-msgid "The computation will last too long - lower npmin is suggested"
+#: ../vector/v.perturb/main.c:88
+msgid "Parameter(s) of distribution"
msgstr ""
-#: ../vector/v.surf.rst/main.c:483
-msgid "Not enough memory for az"
+#: ../vector/v.perturb/main.c:89
+msgid ""
+"If the distribution is uniform, only one parameter, the maximum, is needed. "
+"For a normal distribution, two parameters, the mean and standard deviation, "
+"are required."
msgstr ""
-#: ../vector/v.surf.rst/main.c:488
-msgid "Not enough memory for adx"
+#: ../vector/v.perturb/main.c:99
+msgid "Minimum deviation in map units"
msgstr ""
-#: ../vector/v.surf.rst/main.c:492
-msgid "Not enough memory for ady"
+#: ../vector/v.perturb/main.c:106
+msgid "Seed for random number generation"
msgstr ""
-#: ../vector/v.surf.rst/main.c:497
-msgid "Not enough memory for adxx"
+#: ../vector/v.perturb/main.c:127 ../vector/v.perturb/main.c:134
+msgid "Error scanning arguments"
msgstr ""
-#: ../vector/v.surf.rst/main.c:501
-msgid "Not enough memory for adyy"
+#: ../vector/v.perturb/main.c:130
+msgid "Maximum of uniform distribution must be >= zero"
msgstr ""
-#: ../vector/v.surf.rst/main.c:505
-msgid "Not enough memory for adxy"
+#: ../vector/v.perturb/main.c:137
+msgid "Standard deviation of normal distribution must be >= zero"
msgstr ""
-#: ../vector/v.surf.rst/main.c:512
-msgid "Cannot create quaddata"
+#: ../vector/v.perturb/main.c:242
+msgid "Cannot get db link info"
msgstr ""
-#: ../vector/v.surf.rst/main.c:518
-msgid "Cannot create quadfunc"
+#: ../vector/v.perturb/normalsv.c:29
+msgid "normalsv: save of unitialized block"
msgstr ""
-#: ../vector/v.surf.rst/main.c:521
-msgid "Cannot create tree"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:525
-msgid "Cannot create tree info"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:538 ../vector/v.out.ascii/main.c:104
-#: ../vector/v.colors.out/scan_cats.c:22
-#: ../vector/v.colors.out/make_colors.c:26 ../vector/v.colors/main.c:270
-#, fuzzy, c-format
-msgid "Layer <%s> not found"
+#: ../vector/v.net.centrality/main.c:98
+#, fuzzy
+msgid "centrality measures"
msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:542 ../vector/v.surf.bspline/main.c:263
+#: ../vector/v.net.centrality/main.c:100
msgid ""
-"Input is 3D: using attribute values instead of z-coordinates for "
-"approximation"
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
msgstr ""
-#: ../vector/v.surf.rst/main.c:544 ../vector/v.surf.bspline/main.c:265
-msgid "Input is 3D: using z-coordinates for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:548
-msgid "Input is 2D: using attribute values for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:550
-msgid "Input is 2D: using category values for approximation"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:662
-#, c-format
-msgid ""
-"Processing all selected output files will require %d bytes of disk space for "
-"temp files"
-msgstr ""
-#: ../vector/v.surf.rst/main.c:682
+#: ../vector/v.net.centrality/main.c:148
#, fuzzy
-msgid "Processing segments..."
+msgid "Name of degree centrality column"
msgstr "출력할 래스터맵"
-#: ../vector/v.surf.rst/main.c:688
-msgid "Interp_segmets failed"
+#: ../vector/v.net.centrality/main.c:149 ../vector/v.net.centrality/main.c:155
+#: ../vector/v.net.centrality/main.c:161 ../vector/v.net.centrality/main.c:167
+msgid "Columns"
msgstr ""
-#: ../vector/v.surf.rst/main.c:706
+#: ../vector/v.net.centrality/main.c:154
#, fuzzy
-msgid "Unable to write raster maps - try to increase resolution"
+msgid "Name of closeness centrality column"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:130
-#, c-format
-msgid "Database connection for map <%s> is not defined in DB file"
-msgstr ""
-#: ../vector/v.info/print.c:134
-#, c-format
-msgid "Displaying column types/names for database connection of layer <%s>:"
-msgstr ""
-#: ../vector/v.info/print.c:138 ../vector/v.db.select/main.c:153
-#: ../vector/v.colors.out/make_colors.c:30 ../vector/v.extract/main.c:250
-#: ../vector/v.to.rast3/main.c:78 ../vector/v.distance/main.c:418
-#: ../vector/v.distance/main.c:499 ../vector/v.to.3d/trans3.c:51
-#: ../vector/v.to.3d/trans2.c:49 ../vector/v.to.rast/vect2rast.c:53
-#: ../vector/v.db.connect/main.c:212
-#, c-format
-msgid "Database connection not defined for layer <%s>"
-msgstr ""
-#: ../vector/v.info/print.c:142 ../vector/v.convert/att.c:68
-#, fuzzy, c-format
-msgid "Unable to open driver <%s>"
+#: ../vector/v.net.centrality/main.c:160
+#, fuzzy
+msgid "Name of betweenness centrality column"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:305
-msgid "Name:"
-msgstr ""
-#: ../vector/v.info/print.c:308
-msgid "Mapset:"
-msgstr ""
-#: ../vector/v.info/print.c:312
-msgid "Location:"
-msgstr ""
-#: ../vector/v.info/print.c:315
-msgid "Database:"
-msgstr ""
-#: ../vector/v.info/print.c:319
-msgid "Title:"
-msgstr ""
-#: ../vector/v.info/print.c:322
-msgid "Map scale:"
-msgstr ""
-#: ../vector/v.info/print.c:326
+#: ../vector/v.net.centrality/main.c:166
#, fuzzy
-msgid "Name of creator:"
+msgid "Name of eigenvector centrality column"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:329
-msgid "Organization:"
+#: ../vector/v.net.centrality/main.c:175
+msgid "Maximum number of iterations to compute eigenvector centrality"
msgstr ""
-#: ../vector/v.info/print.c:332
-msgid "Source date:"
+#: ../vector/v.net.centrality/main.c:183
+msgid "Cummulative error tolerance for eigenvector centrality"
msgstr ""
-#: ../vector/v.info/print.c:339
-msgid "Timestamp (first layer): "
-msgstr ""
-#: ../vector/v.info/print.c:343
-msgid "Timestamp (first layer): none"
-msgstr ""
-#: ../vector/v.info/print.c:351 ../vector/v.info/print.c:375
-#: ../vector/v.info/print.c:415
-msgid "Map format:"
-msgstr ""
-#: ../vector/v.info/print.c:356
-msgid "OGR layer:"
-msgstr ""
-#: ../vector/v.info/print.c:359
-msgid "OGR datasource:"
-msgstr ""
-#: ../vector/v.info/print.c:362 ../vector/v.info/print.c:391
+#: ../vector/v.net.centrality/main.c:192 ../vector/v.net.components/main.c:130
#, fuzzy
-msgid "Feature type:"
+msgid "Add points on nodes"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:380
+#: ../vector/v.net.centrality/main.c:321
#, fuzzy
-msgid "DB table:"
+msgid "Computing degree centrality measure"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:383
-msgid "DB name:"
+#: ../vector/v.net.centrality/main.c:325
+msgid "Computing betweenness and/or closeness centrality measure"
msgstr ""
-#: ../vector/v.info/print.c:387
-msgid "Geometry column:"
-msgstr ""
-#: ../vector/v.info/print.c:401 ../vector/v.info/print.c:410
+#: ../vector/v.net.centrality/main.c:332
#, fuzzy
-msgid "Topology:"
+msgid "Computing eigenvector centrality measure"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:402
-msgid "schema:"
-msgstr ""
-#: ../vector/v.info/print.c:406
-msgid "Topology column:"
-msgstr ""
-#: ../vector/v.info/print.c:424
+#: ../vector/v.net.centrality/main.c:339
#, fuzzy
-msgid "Type of map"
+msgid "Writing data into the table..."
msgstr "출력할 래스터맵"
-msgid "level"
+#: ../vector/v.segment/main.c:63
+msgid "Creates points/segments from input vector lines and positions."
msgstr ""
-#: ../vector/v.info/print.c:431
+#: ../vector/v.segment/main.c:66
#, fuzzy
-msgid "Number of points:"
+msgid "Name of input vector lines map"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:433
+#: ../vector/v.segment/main.c:75
#, fuzzy
-msgid "Number of centroids:"
+msgid "Name of file containing segment rules"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:438
-#, fuzzy
-msgid "Number of lines:"
+#: ../vector/v.segment/main.c:142 ../vector/v.segment/main.c:186
+#, fuzzy, c-format
+msgid "Unable to read input: %s"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:440
-#, fuzzy
-msgid "Number of boundaries:"
+#: ../vector/v.segment/main.c:153 ../vector/v.segment/main.c:197
+#, fuzzy, c-format
+msgid "Unable to find line of cat %d"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:445
-#, fuzzy
-msgid "Number of areas:"
-msgstr "출력할 래스터맵"
+#: ../vector/v.segment/main.c:168
+#, c-format
+msgid ""
+"Unable to get point on line: cat = %d offset = %f (line length = %.15g)\n"
+"%s"
+msgstr ""
-#: ../vector/v.info/print.c:447
-#, fuzzy
-msgid "Number of islands:"
-msgstr "출력할 래스터맵"
+#: ../vector/v.segment/main.c:222
+msgid "End of segment > line length -> cut"
+msgstr ""
-#: ../vector/v.info/print.c:453
-#, fuzzy
-msgid "Number of faces:"
-msgstr "출력할 래스터맵"
+#: ../vector/v.segment/main.c:228
+#, c-format
+msgid ""
+"Unable to make line segment: cat = %d : %f - %f (line length = %.15g)\n"
+"%s"
+msgstr ""
-#: ../vector/v.info/print.c:455
-#, fuzzy
-msgid "Number of kernels:"
-msgstr "출력할 래스터맵"
+#: ../vector/v.segment/main.c:257
+#, fuzzy, c-format
+msgid "%d point read from input"
+msgid_plural "%d points read from input"
-#: ../vector/v.info/print.c:460
-#, fuzzy
-msgid "Number of volumes:"
-msgstr "출력할 래스터맵"
+#. GTC %s is replaced with message indicating number of lost points.
+#: ../vector/v.segment/main.c:263
+#, fuzzy, c-format
+msgid "%d point written to output map (%s)"
+msgid_plural "%d points written to output map (%s)"
-#: ../vector/v.info/print.c:462
-#, fuzzy
-msgid "Number of holes:"
-msgstr "출력할 래스터맵"
+#: ../vector/v.segment/main.c:268
+#, fuzzy, c-format
+msgid "%d line read from input"
+msgid_plural "%d lines read from input"
-#: ../vector/v.info/print.c:469
-msgid "Map is 3D:"
-msgstr ""
+#. GTC %s is replaced with message indicating number of lost lines.
+#: ../vector/v.segment/main.c:274
+#, fuzzy, c-format
+msgid "%d line written to output map (%s)"
+msgid_plural "%d lines written to output map (%s)"
-#: ../vector/v.info/print.c:470
-msgid "Yes"
+#: ../vector/v.to.3d/trans3.c:45 ../vector/v.to.3d/trans2.c:43
+#, c-format
+msgid "Invalid layer number %d, assuming 1"
msgstr ""
-msgid "No"
+#: ../vector/v.to.3d/trans3.c:69 ../vector/v.to.3d/trans2.c:67
+msgid "Column must be numeric"
msgstr ""
-#: ../vector/v.info/print.c:473
+#: ../vector/v.to.3d/trans3.c:75
#, fuzzy
-msgid "Number of dblinks:"
+msgid "Reading categories..."
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:486
-msgid "invalid"
-msgstr ""
-#: ../vector/v.info/print.c:488
+#: ../vector/v.to.3d/trans3.c:80 ../vector/v.to.3d/trans2.c:79
#, fuzzy
-msgid "unspecified"
+msgid "Transforming features..."
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:493 ../vector/v.info/print.c:498
-#, fuzzy
-msgid "Projection"
+#: ../vector/v.to.3d/trans3.c:101
+#, fuzzy, c-format
+msgid "Feature id %d has no category - skipping"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/print.c:494
-msgid "zone"
+#: ../vector/v.to.3d/trans3.c:104
+#, c-format
+msgid "Feature id %d has more categories. Using category %d."
msgstr ""
-#: ../vector/v.info/print.c:527
-msgid "Digitization threshold"
+#: ../vector/v.to.3d/trans3.c:130 ../vector/v.to.db/update.c:221
+#, c-format
+msgid "Record (cat %d) does not exist (not updated)"
msgstr ""
-#: ../vector/v.info/print.c:529
-msgid "Comment"
+#: ../vector/v.to.3d/main.c:40
+msgid "Performs transformation of 2D vector features to 3D."
msgstr ""
-#: ../vector/v.info/main.c:42
-#, fuzzy
-msgid "attribute columns"
+#: ../vector/v.to.3d/main.c:52
+#, fuzzy, c-format
+msgid "Either '%s' or '%s' parameter have to be used"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/main.c:45
-#, fuzzy
-msgid "Outputs basic information about a vector map."
+#: ../vector/v.to.3d/main.c:58
+#, fuzzy, c-format
+msgid "Parameters '%s' ignored"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/parse.c:24
-msgid "Print history instead of info and exit"
-msgstr ""
-#: ../vector/v.info/parse.c:30
-msgid ""
-"Print types/names of table columns for specified layer instead of info and "
-"exit"
-msgstr ""
-#: ../vector/v.info/parse.c:35
+#: ../vector/v.to.3d/main.c:63
#, fuzzy
-msgid "Print region info in shell script style"
+msgid "Attribute table required"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/parse.c:40
-#, fuzzy
-msgid "Print extended metadata info in shell script style"
+#: ../vector/v.to.3d/main.c:76
+#, fuzzy, c-format
+msgid "Vector map <%s> is 2D"
msgstr "출력할 래스터맵"
-#: ../vector/v.info/parse.c:45
-#, fuzzy
-msgid "Print topology info in shell script style"
+#: ../vector/v.to.3d/main.c:80
+#, fuzzy, c-format
+msgid "Vector map <%s> is 3D"
msgstr "출력할 래스터맵"
-#: ../vector/v.net.bridge/main.c:49
+#: ../vector/v.to.3d/main.c:98 ../vector/v.to.3d/main.c:119
#, fuzzy
-msgid "articulation points"
+msgid "Unable to copy attributes"
msgstr "출력할 래스터맵"
-#: ../vector/v.net.bridge/main.c:51
-msgid "Computes bridges and articulation points in the network."
+#: ../vector/v.to.3d/main.c:128
+#, c-format
+msgid "Vertical extent of vector map <%s>: B: %f T: %f"
msgstr ""
-#: ../vector/v.net.bridge/main.c:98
-#, fuzzy
-msgid "Finds bridges"
-msgstr "출력할 래스터맵"
+#: ../vector/v.to.3d/args.c:11
+msgid "Reverse transformation; 3D vector features to 2D"
+msgstr ""
-#: ../vector/v.net.bridge/main.c:99
+#: ../vector/v.to.3d/args.c:14
#, fuzzy
-msgid "Finds articulation points"
+msgid "Do not copy attribute table"
msgstr "출력할 래스터맵"
-#: ../vector/v.net.bridge/main.c:101 ../vector/v.vect.stats/main.c:149
-#: ../vector/v.to.db/parse.c:41
-msgid "Feature type"
+#: ../vector/v.to.3d/args.c:30
+msgid "Name of attribute column used for height"
msgstr ""
-#: ../vector/v.what.rast3/main.c:71
-msgid "Uploads 3d raster values at positions of vector points to the table."
+#: ../vector/v.to.3d/args.c:32
+msgid "Can be used for reverse transformation, to store height of points"
msgstr ""
-#: ../vector/v.what.rast3/main.c:81
+#: ../vector/v.to.3d/trans2.c:70
+#, fuzzy, c-format
+msgid "Fetching height from <%s> column..."
+msgstr "출력할 래스터맵"
+#: ../vector/v.to.3d/trans2.c:101
#, fuzzy
-msgid "Name of existing 3d raster map to be queried"
+msgid "Skipping feature without category"
msgstr "출력할 래스터맵"
-#: ../vector/v.what.rast3/main.c:132
-#, c-format
-msgid "Error opening 3d raster map <%s>"
-msgstr ""
+#: ../vector/v.to.3d/trans2.c:116
+#, fuzzy, c-format
+msgid "Unable to get height for feature category %d"
+msgstr "출력할 래스터맵"
-#: ../vector/v.what.rast3/main.c:138 ../vector/v.what.rast/main.c:167
-#: ../vector/v.to.rast/vect2rast.c:66 ../vector/v.to.rast/support.c:316
-#: ../vector/v.to.rast/support.c:467
-#, c-format
-msgid "Column <%s> not found"
+#: ../vector/v.vect.stats/main.c:133
+msgid "Count points in areas, calculate statistics from point attributes."
msgstr ""
-#: ../vector/v.what.rast3/main.c:141
-msgid "Column type not supported, please use a column with double type"
-msgstr ""
+#: ../vector/v.vect.stats/main.c:137
+#, fuzzy
+msgid "Name of existing vector map with points"
+msgstr "출력할 래스터맵"
-#: ../vector/v.what.rast3/main.c:155 ../vector/v.what.rast/main.c:192
+#: ../vector/v.vect.stats/main.c:142
#, fuzzy
-msgid "Reading features from vector map..."
+msgid "Name of existing vector map with areas"
msgstr "출력할 래스터맵"
-#: ../vector/v.what.rast3/main.c:212 ../vector/v.what.rast/main.c:260
-#, c-format
-msgid "%d points outside current region were skipped"
-msgstr ""
+#: ../vector/v.vect.stats/main.c:154
+#, fuzzy
+msgid "Layer number for points map"
+msgstr "출력할 래스터맵"
-#: ../vector/v.what.rast3/main.c:216 ../vector/v.what.rast/main.c:264
-#, c-format
-msgid "%d points without category were skipped"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:253
-#, c-format
-msgid "More points (%d) of category %d, value set to 'NULL'"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:323 ../vector/v.what.rast/main.c:648
-#, c-format
-msgid "%d categories loaded from table"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:324 ../vector/v.what.rast/main.c:643
-#, c-format
-msgid "%d categories loaded from vector"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:325 ../vector/v.what.rast/main.c:649
-#, c-format
-msgid "%d categories from vector missing in table"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:327 ../vector/v.what.rast/main.c:645
-#, c-format
-msgid "%d duplicate categories in vector"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:329 ../vector/v.vect.stats/main.c:708
-#: ../vector/v.distance/main.c:1594 ../vector/v.what.rast/main.c:652
-#, c-format
-msgid "%d update errors"
-msgstr ""
-#: ../vector/v.what.rast3/main.c:331 ../vector/v.distance/main.c:1596
-#: ../vector/v.what.rast/main.c:654
-#, fuzzy, c-format
-msgid "%d records updated."
+#: ../vector/v.vect.stats/main.c:158
+#, fuzzy
+msgid "Layer number for area map"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:77 ../vector/v.db.connect/main.c:54
-msgid "layer"
-msgstr ""
-#: ../vector/v.category/main.c:79
-msgid "Attaches, deletes or reports vector categories to map geometry."
-msgstr ""
-#: ../vector/v.category/main.c:92
-msgid "Feature ids (by default all features are processed)"
-msgstr ""
-#: ../vector/v.category/main.c:104
+#: ../vector/v.vect.stats/main.c:174
#, fuzzy
-msgid "Action to be done"
+msgid "Method for aggregate statistics"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:115
+#: ../vector/v.vect.stats/main.c:181
#, fuzzy
-msgid "add a new category"
+msgid "Column name of points map to use for statistics"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:116
-msgid "delete category (cat=-1 to delete all categories of given layer)"
+#: ../vector/v.vect.stats/main.c:182
+msgid "Column of points map must be numeric"
msgstr ""
-#: ../vector/v.category/main.c:117
-msgid "change layer number (e.g. layer=3,1 changes layer 3 to layer 1)"
+#: ../vector/v.vect.stats/main.c:189
+msgid "Column name to upload points count"
msgstr ""
-#: ../vector/v.category/main.c:118
-msgid "add the value specified by cat option to the current category value"
-msgstr ""
-#: ../vector/v.category/main.c:119
+#: ../vector/v.vect.stats/main.c:191
msgid ""
-"copy values from one layer to another (e.g. layer=1,2,3 copies values from "
-"layer 1 to layer 2 and 3)"
+"Column to hold points count, must be of type integer, will be created if not "
+"existing"
msgstr ""
-#: ../vector/v.category/main.c:120
-msgid "print report (statistics), in shell style: layer type count min max"
-msgstr ""
-#: ../vector/v.category/main.c:121
-msgid "print category values, more cats in the same layer are separated by '/'"
-msgstr ""
-#: ../vector/v.category/main.c:122
+#: ../vector/v.vect.stats/main.c:198
#, fuzzy
-msgid "print only layer numbers"
+msgid "Column name to upload statistics"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:138
-msgid "Shell script style, currently only for report"
+#: ../vector/v.vect.stats/main.c:200
+msgid ""
+"Column to hold statistics, must be of type double, will be created if not "
+"existing"
msgstr ""
-#: ../vector/v.category/main.c:139
-msgid "Format: layer type count min max"
+#: ../vector/v.vect.stats/main.c:207
+msgid "Print output to stdout, do not update attribute table"
msgstr ""
-#: ../vector/v.category/main.c:142
-#, fuzzy
-msgid "Do not copy attribute table(s)"
-msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:160
-msgid ""
-"Database connection and attribute tables for concerned layers are not changed"
+#: ../vector/v.vect.stats/main.c:208
+msgid "First column is always area category"
msgstr ""
-#: ../vector/v.category/main.c:186 ../vector/v.category/main.c:248
-#: ../vector/v.category/main.c:256 ../vector/v.kcv/main.c:120
-#: ../vector/v.kcv/main.c:209
+#: ../vector/v.vect.stats/main.c:263
#, fuzzy, c-format
-msgid "Unable to open vector map <%s> at topological level %d"
+msgid "Vector map <%s> is not in user mapset and cannot be updated"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:208
-msgid ""
-"Invalid category number (must be equal to or greater than 0). Normally "
-"category number starts at 1."
+#: ../vector/v.vect.stats/main.c:311 ../vector/v.vect.stats/main.c:387
+#, fuzzy, c-format
+msgid "Unable to open database <%s> with driver <%s>"
+msgstr "출력할 래스터맵"
+#: ../vector/v.vect.stats/main.c:315
+msgid "ccolumn is required to upload point counts"
msgstr ""
-#: ../vector/v.category/main.c:217
-#, c-format
-msgid "%d errors in id option"
+#: ../vector/v.vect.stats/main.c:324
+msgid "ccolumn must be of type integer"
msgstr ""
-#: ../vector/v.category/main.c:226
-#, fuzzy
-msgid "Output vector wasn't entered"
+#: ../vector/v.vect.stats/main.c:337 ../vector/v.vect.stats/main.c:367
+#, fuzzy, c-format
+msgid "Unable to add column <%s>"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:273
-msgid "Too many layers for this operation"
+#: ../vector/v.vect.stats/main.c:343
+msgid "scolumn is required to upload point stats"
msgstr ""
-#: ../vector/v.category/main.c:276 ../vector/v.category/main.c:279
-msgid "2 layers must be specified"
+#: ../vector/v.vect.stats/main.c:354
+msgid "scolumn must be of type double"
msgstr ""
-#: ../vector/v.category/main.c:287
-#, fuzzy, c-format
-msgid "Categories already exist in layer %d"
+#: ../vector/v.vect.stats/main.c:378
+#, fuzzy
+msgid "collecting attributes from points vector..."
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:330 ../vector/v.drape/main.c:171
-#: ../vector/v.select/select.c:40
+#: ../vector/v.vect.stats/main.c:410
#, fuzzy
-msgid "Processing features..."
+msgid "column for points vector must be numeric"
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:362 ../vector/v.delaunay/main.c:171
-#: ../vector/v.in.ogr/main.c:1222
+#: ../vector/v.vect.stats/main.c:483
#, fuzzy
-msgid "Unable to calculate area centroid"
+msgid "Selecting points for each area..."
msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:376
+#: ../vector/v.vect.stats/main.c:580
#, c-format
-msgid "%d new centroids placed in output map"
+msgid "could not find area category %d"
msgstr ""
-#: ../vector/v.category/main.c:676
-msgid "Layer/table"
-msgstr ""
-#: ../vector/v.category/main.c:680
-msgid "Layer"
-msgstr ""
-#: ../vector/v.category/main.c:682
+#: ../vector/v.vect.stats/main.c:708
#, c-format
-msgid "type count min max\n"
+msgid "%d records updated"
msgstr ""
-#: ../vector/v.category/main.c:683
-msgid "point"
+#: ../vector/v.in.region/main.c:43
+msgid "Creates a vector polygon from the current region extent."
msgstr ""
-#: ../vector/v.category/main.c:687
-msgid "line"
+#: ../vector/v.in.region/main.c:51
+msgid "Select type: line or area"
msgstr ""
-#: ../vector/v.category/main.c:691
-#, fuzzy
-msgid "boundary"
-msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:703
-msgid "face"
+#: ../vector/v.in.region/main.c:58
+msgid "Densify lines using region resolution"
msgstr ""
-#: ../vector/v.category/main.c:707
-msgid "kernel"
-msgstr ""
-#: ../vector/v.category/main.c:711
-msgid "all"
-msgstr ""
-#: ../vector/v.category/main.c:775
-#, fuzzy, c-format
-msgid "Categories copied from layer %d to layer %d"
-msgstr "출력할 래스터맵"
-#: ../vector/v.category/main.c:777
-#, fuzzy, c-format
-msgid "%d features modified."
-msgstr "출력할 래스터맵"
#: ../vector/v.out.ogr/export_lines.c:170
#: ../vector/v.out.ogr/export_areas.c:148
#, fuzzy, c-format
@@ -32087,281 +32584,283 @@
msgid "By default a vector map layer is exported to Esri Shapefile format."
msgstr ""
-#: ../vector/v.out.ogr/main.c:95 ../vector/v.external.out/link.c:26
-#, c-format
-msgid ""
-"Data source starts with \"PG:\" prefix, expecting \"PostgreSQL\" format (\"%s"
-"\" given)"
-msgstr ""
-#: ../vector/v.out.ogr/main.c:160
+#: ../vector/v.out.ogr/main.c:163
msgid "Volumes will be exported as sets of faces"
msgstr ""
-#: ../vector/v.out.ogr/main.c:178
+#: ../vector/v.out.ogr/main.c:181
#, fuzzy
msgid "Unable to determine input map's vector feature type(s)."
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:244
+#: ../vector/v.out.ogr/main.c:247
msgid "The combination of types is not supported by all formats."
msgstr ""
-#: ../vector/v.out.ogr/main.c:273
+#: ../vector/v.out.ogr/main.c:276
#, c-format
msgid "OGR layer <%s> created in datasource <%s> (format '%s')"
msgstr ""
-#: ../vector/v.out.ogr/main.c:285
+#: ../vector/v.out.ogr/main.c:288
msgid ""
"The map contains islands. With the -c flag, islands will appear as filled "
"areas, not holes in the output map."
msgstr ""
-#: ../vector/v.out.ogr/main.c:291
+#: ../vector/v.out.ogr/main.c:294
#, c-format
msgid ""
-"%d point(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+"%d point found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d points found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:296
+#: ../vector/v.out.ogr/main.c:302
#, c-format
msgid ""
+"%d line found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
"%d line(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:302
+#: ../vector/v.out.ogr/main.c:311
#, c-format
msgid ""
-"%d boundary(ies) found, but not requested to be exported. Verify 'type' "
+"%d boundary found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d boundaries found, but not requested to be exported. Verify 'type' "
"parameter."
-msgstr ""
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:308
+#: ../vector/v.out.ogr/main.c:320
#, c-format
msgid ""
-"%d centroid(s) found, but not requested to be exported. Verify 'type' "
+"%d centroid found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d centroids found, but not requested to be exported. Verify 'type' "
"parameter."
-msgstr ""
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:313
+#: ../vector/v.out.ogr/main.c:328
#, c-format
msgid ""
-"%d area(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+"%d area found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d areas found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:317
+#: ../vector/v.out.ogr/main.c:336
#, c-format
msgid ""
-"%d face(s) found, but not requested to be exported. Verify 'type' parameter."
-msgstr ""
+"%d face found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d faces found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:322
+#: ../vector/v.out.ogr/main.c:344
#, c-format
msgid ""
-"%d volume(s) found, but not requested to be exported. Verify 'type' "
-"parameter."
-msgstr ""
+"%d volume found, but not requested to be exported. Verify 'type' parameter."
+msgid_plural ""
+"%d volumes found, but not requested to be exported. Verify 'type' parameter."
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:328
+#: ../vector/v.out.ogr/main.c:354
msgid ""
"No points found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:337
+#: ../vector/v.out.ogr/main.c:363
msgid ""
"No lines found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:347
+#: ../vector/v.out.ogr/main.c:373
msgid ""
"No boundaries found, but requested to be exported. Will skip this feature "
"type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:356
+#: ../vector/v.out.ogr/main.c:382
msgid ""
"No areas found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:366
+#: ../vector/v.out.ogr/main.c:392
msgid ""
"No centroids found, but requested to be exported. Will skip this feature "
"type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:375
+#: ../vector/v.out.ogr/main.c:401
msgid ""
"No faces found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:384
+#: ../vector/v.out.ogr/main.c:410
msgid ""
"No kernels found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:393
+#: ../vector/v.out.ogr/main.c:419
msgid ""
"No volumes found, but requested to be exported. Will skip this feature type."
msgstr ""
-#: ../vector/v.out.ogr/main.c:418
+#: ../vector/v.out.ogr/main.c:444
#, fuzzy, c-format
msgid "OGR driver <%s> not found"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:422
+#: ../vector/v.out.ogr/main.c:448
#, c-format
msgid ""
"Append existing layer requires opening data source in update mode, forcing '-"
"%c' flag"
msgstr ""
-#: ../vector/v.out.ogr/main.c:440
+#: ../vector/v.out.ogr/main.c:466
#, fuzzy, c-format
msgid "Unable to open OGR data source '%s'"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:454
+#: ../vector/v.out.ogr/main.c:480
#, fuzzy, c-format
msgid "Layer <%s> already exists in OGR data source '%s'"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:458
+#: ../vector/v.out.ogr/main.c:484
#, fuzzy, c-format
msgid "OGR layer <%s> already exists and will be overwritten"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:465
+#: ../vector/v.out.ogr/main.c:491
#, fuzzy, c-format
msgid "OGR layer <%s> doesn't exists, creating new OGR layer instead"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:493
+#: ../vector/v.out.ogr/main.c:519
msgid "Overriding existing user-defined 'SHPT=' LCO."
msgstr ""
-#: ../vector/v.out.ogr/main.c:508
+#: ../vector/v.out.ogr/main.c:534
#, c-format
msgid ""
"Vector map <%s> is 3D. Use format specific layer creation options SHPT "
"(parameter 'lco') or '-z' flag to export in 3D rather than 2D (default)"
msgstr ""
-#: ../vector/v.out.ogr/main.c:520
+#: ../vector/v.out.ogr/main.c:546
#, c-format
msgid ""
"Vector map <%s> is 3D. Use format specific layer creation options DIM "
"(parameter 'lco') to export in 3D rather than 2D (default)."
msgstr ""
-#: ../vector/v.out.ogr/main.c:527
+#: ../vector/v.out.ogr/main.c:553
#, c-format
msgid ""
"Vector map <%s> is 3D. Use format specific layer creation options (parameter "
"'lco') to export <in 3D rather than 2D (default)."
msgstr ""
-#: ../vector/v.out.ogr/main.c:546
+#: ../vector/v.out.ogr/main.c:570 ../db/drivers/ogr/execute.c:56
+#, fuzzy, c-format
+msgid "OGR layer <%s> not found"
+msgstr "출력할 래스터맵"
+#: ../vector/v.out.ogr/main.c:572
#, fuzzy
msgid "Unable to create OGR layer"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:558
+#: ../vector/v.out.ogr/main.c:584
msgid "No attribute table found -> using only category numbers as attributes"
msgstr ""
-#: ../vector/v.out.ogr/main.c:562
+#: ../vector/v.out.ogr/main.c:588
msgid "Exporting 'cat' anyway, as it is the only attribute table field"
msgstr ""
-#: ../vector/v.out.ogr/main.c:571 ../vector/v.out.ogr/main.c:643
+#: ../vector/v.out.ogr/main.c:597 ../vector/v.out.ogr/main.c:669
#, fuzzy, c-format
msgid "New attribute column <%s> added to the table"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:655
+#: ../vector/v.out.ogr/main.c:681
#, fuzzy, c-format
msgid "Key column <%s> not found"
msgstr "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:668
+#: ../vector/v.out.ogr/main.c:694
#, fuzzy, c-format
-msgid "Exporting %d features..."
-msgstr "출력할 래스터맵"
+msgid "Exporting %d feature..."
+msgid_plural "Exporting %d features..."
+msgstr[0] "출력할 래스터맵"
+msgstr[1] "출력할 래스터맵"
-#: ../vector/v.out.ogr/main.c:680
+#: ../vector/v.out.ogr/main.c:709
#, fuzzy, c-format
-msgid "Exporting %d areas (may take some time)..."
-msgstr "출력할 래스터맵"
+msgid "Exporting %d area (may take some time)..."
+msgid_plural "Exporting %d areas (may take some time)..."
-#: ../vector/v.out.ogr/main.c:697
+#: ../vector/v.out.ogr/main.c:728
#, fuzzy, c-format
-msgid "Exporting %d volumes..."
-msgstr "출력할 래스터맵"
+msgid "Exporting %d volume..."
+msgid_plural "Exporting %d volumes..."
-#: ../vector/v.out.ogr/main.c:698
+#: ../vector/v.out.ogr/main.c:732
msgid "Export of volumes not implemented yet. Skipping."
msgstr ""
-#: ../vector/v.out.ogr/main.c:715
+#: ../vector/v.out.ogr/main.c:749
#, fuzzy, c-format
-msgid "%d features without category were written"
-msgstr "출력할 래스터맵"
+msgid "%d feature without category was written"
+msgid_plural "%d features without category were written"
-#: ../vector/v.out.ogr/main.c:717
+#: ../vector/v.out.ogr/main.c:753
#, fuzzy, c-format
-msgid "%d features without attributes were written"
-msgstr "출력할 래스터맵"
+msgid "%d feature without attributes was written"
+msgid_plural "%d features without attributes were written"
-#: ../vector/v.out.ogr/main.c:720
+#: ../vector/v.out.ogr/main.c:758
#, c-format
msgid ""
+"%d feature without category was skipped. Features without category are "
+"written only when -%c flag is given."
+msgid_plural ""
"%d features without category were skipped. Features without category are "
-msgstr ""
+msgstr[0] ""
+msgstr[1] ""
-#: ../vector/v.out.ogr/main.c:733
+#: ../vector/v.out.ogr/main.c:774
msgid "Output layer is empty, no features written"
msgstr ""
