[GRASS-SVN] r60074 - in grass/trunk: general/g.mapsets gui/wxpython/modules
svn_grass at osgeo.org
Sun May 4 12:49:14 PDT 2014
Author: martinl
Date: 2014-05-04 12:49:14 -0700 (Sun, 04 May 2014)
New Revision: 60074
Added:
grass/trunk/gui/wxpython/modules/mapsets_picker.py
Removed:
grass/trunk/general/g.mapsets/g.mapsets_picker.py
grass/trunk/general/g.mapsets/Makefile
grass/trunk/general/g.mapsets/main.c
g.mapsets -s: major clean-up
Modified: grass/trunk/general/g.mapsets/Makefile
--- grass/trunk/general/g.mapsets/Makefile 2014-05-04 19:31:56 UTC (rev 60073)
+++ grass/trunk/general/g.mapsets/Makefile 2014-05-04 19:49:14 UTC (rev 60074)
@@ -2,17 +2,10 @@
MODULE_TOPDIR = ../..
PGM = g.mapsets
-GUI = $(GUIDIR)/scripts/g.mapsets_picker.py
LIBES = $(GISLIB)
DEPENDENCIES = $(GISDEP)
include $(MODULE_TOPDIR)/include/Make/Module.make
-default: cmd $(GUI)
-$(GUIDIR)/scripts/%: % | $(GUIDIR)/scripts
- $(INSTALL) $< $@
-$(GUIDIR)/scripts:
- $(MKDIR) $@
+default: cmd
Deleted: grass/trunk/general/g.mapsets/g.mapsets_picker.py
--- grass/trunk/general/g.mapsets/g.mapsets_picker.py 2014-05-04 19:31:56 UTC (rev 60073)
+++ grass/trunk/general/g.mapsets/g.mapsets_picker.py 2014-05-04 19:49:14 UTC (rev 60074)
@@ -1,163 +0,0 @@
-#!/usr/bin/env python
-import os
-import sys
-import pwd
-from grass.script import core as grass
-import wx
-import wx.lib.mixins.listctrl as listmix
-class MapsetsFrame(wx.Frame):
- def __init__(self):
- wx.Frame.__init__(self, parent = None, id = wx.ID_ANY,
- title = "Check mapsets to access")
- self.SetMinSize((350, 400))
- sizer = wx.BoxSizer(wx.VERTICAL)
- # list of mapsets
- self.mapsetlb = CheckListMapset(parent = self)
- self.mapsetlb.LoadData()
- sizer.Add(item = self.mapsetlb, proportion = 1,
- flag = wx.ALL | wx.EXPAND, border = 5)
- # dialog buttons
- line = wx.StaticLine(parent = self, id = wx.ID_ANY,
- style = wx.LI_HORIZONTAL)
- sizer.Add(item = line, proportion = 0,
- flag = wx.EXPAND | wx.ALIGN_CENTRE | wx.ALL, border = 5)
- btnsizer = wx.StdDialogButtonSizer()
- btnOK = wx.Button(self, wx.ID_OK)
- btnOK.Bind(wx.EVT_BUTTON, self.OnOK)
- btnOK.SetToolTipString("Close dialog and apply changes")
- btnOK.SetDefault()
- btnsizer.AddButton(btnOK)
- btnCancel = wx.Button(self, wx.ID_CANCEL)
- btnCancel.Bind(wx.EVT_BUTTON, self.OnCancel)
- btnCancel.SetToolTipString("Close dialog and ignore changes")
- btnsizer.AddButton(btnCancel)
- btnsizer.Realize()
- sizer.Add(item = btnsizer, proportion = 0,
- flag = wx.EXPAND | wx.ALIGN_RIGHT | wx.ALL, border = 5)
- # do layout
- self.Layout()
- self.SetSizer(sizer)
- sizer.Fit(self)
- def GetMapsets(self):
- """Get list of checked mapsets"""
- ms = []
- i = 0
- for mset in self.mapsetlb.mapsets:
- if self.mapsetlb.IsChecked(i):
- ms.append(mset)
- i += 1
- return ms
- def OnCancel(self, event):
- """Button 'Cancel' pressed"""
- self.Close()
- def OnOK(self, event):
- """Button 'OK' pressed"""
- mapsets = ','.join(self.GetMapsets())
- grass.run_command('g.mapsets',
- quiet = True,
- mapset = mapsets,
- operation = 'set')
- self.Close()
-class CheckListMapset(wx.ListCtrl, listmix.ListCtrlAutoWidthMixin, listmix.CheckListCtrlMixin):
- """List of mapset/owner/group"""
- def __init__(self, parent, pos = wx.DefaultPosition,
- log = None):
- self.parent = parent
- wx.ListCtrl.__init__(self, parent, wx.ID_ANY,
- style = wx.LC_REPORT)
- listmix.CheckListCtrlMixin.__init__(self)
- self.log = log
- # setup mixins
- listmix.ListCtrlAutoWidthMixin.__init__(self)
- def LoadData(self):
- """Load data into list"""
- self.InsertColumn(0, 'Mapset')
- self.InsertColumn(1, 'Owner')
- ### self.InsertColumn(2, 'Group')
- gisenv = grass.gisenv()
- locationPath = os.path.join(gisenv['GISDBASE'], gisenv['LOCATION_NAME'])
- self.curr_mapset = gisenv['MAPSET']
- ret = grass.read_command('g.mapsets',
- quiet = True,
- flags = 'l',
- sep = 'newline')
- self.mapsets = []
- if ret:
- self.mapsets = ret.splitlines()
- quiet = True,
- flags = 'p',
- sep = 'newline')
- mapsets_access = []
- if ret:
- mapsets_access = ret.splitlines()
- for mapset in self.mapsets:
- index = self.InsertStringItem(sys.maxint, mapset)
- mapsetPath = os.path.join(locationPath,
- mapset)
- stat_info = os.stat(mapsetPath)
- if os.name in ('posix', 'mac'):
- self.SetStringItem(index, 1, "%s" % pwd.getpwuid(stat_info.st_uid)[0])
- # FIXME: get group name
- ### self.SetStringItem(index, 2, "%-8s" % stat_info.st_gid)
- else:
- # FIXME: no pwd under MS Windows (owner: 0, group: 0)
- self.SetStringItem(index, 1, "%-8s" % stat_info.st_uid)
- if mapset in mapsets_access:
- self.CheckItem(self.mapsets.index(mapset), True)
- self.SetColumnWidth(col = 0, width = wx.LIST_AUTOSIZE)
- self.SetColumnWidth(col = 1, width = wx.LIST_AUTOSIZE)
- def OnCheckItem(self, index, flag):
- """Mapset checked/unchecked"""
- mapset = self.mapsets[index]
- if mapset == 'PERMANENT' or mapset == self.curr_mapset:
- self.CheckItem(index, True)
-class MyApp(wx.App):
- def OnInit(self):
- frame = MapsetsFrame()
- frame.CentreOnScreen()
- frame.Show()
- self.SetTopWindow(frame)
- return True
-if __name__ == "__main__":
- app = MyApp(0)
- app.MainLoop()
Modified: grass/trunk/general/g.mapsets/main.c
--- grass/trunk/general/g.mapsets/main.c 2014-05-04 19:31:56 UTC (rev 60073)
+++ grass/trunk/general/g.mapsets/main.c 2014-05-04 19:49:14 UTC (rev 60074)
@@ -158,8 +158,8 @@
if (opt.dialog->answer) {
if (opt.mapset->answer)
G_warning(_("Option <%s> ignored"), opt.mapset->key);
- sprintf(path_buf, "%s/gui/scripts/g.mapsets_picker.py", G_gisbase());
- G_spawn(getenv("GRASS_PYTHON"), "g.mapsets_picker.py", path_buf, NULL);
+ sprintf(path_buf, "%s/gui/wxpython/modules/mapsets_picker.py", G_gisbase());
+ G_spawn(getenv("GRASS_PYTHON"), "mapsets_picker.py", path_buf, NULL);
exit(EXIT_SUCCESS);
Copied: grass/trunk/gui/wxpython/modules/mapsets_picker.py (from rev 60058, grass/trunk/general/g.mapsets/g.mapsets_picker.py)
--- grass/trunk/gui/wxpython/modules/mapsets_picker.py (rev 0)
+++ grass/trunk/gui/wxpython/modules/mapsets_picker.py 2014-05-04 19:49:14 UTC (rev 60074)
@@ -0,0 +1,33 @@
+#!/usr/bin/env python
+import os
+import sys
+import pwd
+from grass.script import core as grass
+import wx
+import wx.lib.mixins.listctrl as listmix
+from core.gcmd import RunCommand
+from core.utils import _, GuiModuleMain
+from gui_core.preferences import MapsetAccess
+def main():
+ app = wx.App()
+ dlg = MapsetAccess(parent = None)
+ dlg.CenterOnScreen()
+ if dlg.ShowModal() == wx.ID_OK:
+ ms = dlg.GetMapsets()
+ RunCommand('g.mapsets',
+ parent = None,
+ mapset = '%s' % ','.join(ms),
+ operation = 'set')
+ app.MainLoop()
+if __name__ == "__main__":
+ GuiModuleMain(main)
