[GRASS-SVN] r60075 - grass/branches/releasebranch_7_0/locale/po
svn_grass at osgeo.org
Sun May 4 13:13:58 PDT 2014
Author: neteler
Date: 2014-05-04 13:13:58 -0700 (Sun, 04 May 2014)
New Revision: 60075
Added:
grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
Added grasswxpy_ko.po (backport of r60061)
Added: grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po
--- grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po (rev 0)
+++ grass/branches/releasebranch_7_0/locale/po/grasswxpy_ko.po 2014-05-04 20:13:58 UTC (rev 60075)
@@ -0,0 +1,17168 @@
+# translation of grasswxpy_ko.po to Korean
+# Korean translation
+# This file is distributed under the same license as the GRASS package.
+# Copyright (C) 2005, 2014 GRASS Development Team
+# Huidae Cho <grass4u at gmail.com>, 2005, 2014.
+#: ../gui/wxpython/gis_set.py:122
+#, fuzzy
+msgid ""
+msgstr ""
+"Project-Id-Version: grasswxpy_ko\n"
+"Report-Msgid-Bugs-To: \n"
+"POT-Creation-Date: 2014-05-03 16:44-0400\n"
+"PO-Revision-Date: 2014-05-03 16:44-0400\n"
+"Last-Translator: Huidae Cho <grass4u at gmail.com>\n"
+"Language-Team: Korean <grass-translations at lists.osgeo.org>\n"
+"Language: ko\n"
+"MIME-Version: 1.0\n"
+"Content-Type: text/plain; charset=UTF-8\n"
+"Content-Transfer-Encoding: 8bit\n"
+#: ../gui/wxpython/animation/toolbars.py:28
+msgid "Change animation speed"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:29
+msgid "Play forward"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:30
+msgid "Play back"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:31 ../gui/wxpython/nviz/tools.py:409
+msgid "Stop"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:32 ../gui/wxpython/nviz/tools.py:407
+msgid "Pause"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:33
+msgid "Repeat"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:35
+msgid "Play back and forward"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:36
+#: ../gui/wxpython/animation/toolbars.py:37
+#: ../gui/wxpython/animation/dialogs.py:272
+msgid "Add new animation"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:38
+#: ../gui/wxpython/animation/toolbars.py:39
+msgid "Add, edit or remove animation"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:40
+#: ../gui/wxpython/animation/toolbars.py:41
+#: ../gui/wxpython/animation/dialogs.py:740
+msgid "Export animation"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:49
+msgid "Add space-time dataset or series of map layers"
+msgstr ""
+#: ../gui/wxpython/animation/toolbars.py:50
+msgid "Add space-time dataset or series of map layers for animation"
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:69 ../gui/wxpython/animation/utils.py:75
+#: ../gui/wxpython/animation/temporal_manager.py:225
+#: ../gui/wxpython/timeline/frame.py:399
+#, python-format
+msgid "Space time dataset <%s> not found."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:93
+#: ../gui/wxpython/animation/utils.py:101
+#: ../gui/wxpython/mapswipe/frame.py:392
+#: ../gui/wxpython/lmgr/layertree.py:1612 ../gui/wxpython/gis_set.py:539
+#, python-format
+msgid "Map <%s> not found."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:156
+msgid "The number of maps in space-time datasets has to be the same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:160
+msgid ""
+"The temporal type (absolute/relative) of space-time datasets has to be the "
+"same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:164
+msgid ""
+"The map type (point/interval) of space-time datasets has to be the same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:168
+msgid ""
+"The temporal extents of maps in space-time datasets have to be the same."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:176
+msgid "The number of maps to animate has to be the same for each map series."
+msgstr ""
+#: ../gui/wxpython/animation/utils.py:180
+msgid ""
+"The number of maps to animate has to be the same as the number of maps in "
+"temporal dataset."
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:50
+msgid "GRASS GIS Animation tool"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:146
+#: ../gui/wxpython/mapswipe/frame.py:278
+msgid "Main Toolbar"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:156
+msgid "Animation Toolbar"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:167
+#: ../gui/wxpython/mapswipe/frame.py:290 ../gui/wxpython/lmgr/frame.py:147
+msgid "Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:264
+msgid "Loading data"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:273
+msgid " ({c} out of {p})"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:574
+#: ../gui/wxpython/animation/controller.py:527
+#, python-format
+msgid "%(from)s %(dash)s %(to)s"
+msgstr ""
+#: ../gui/wxpython/animation/frame.py:577
+#, python-format
+msgid "to %(to)s"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:43 ../gui/wxpython/lmgr/layertree.py:869
+#: ../gui/wxpython/mapdisp/toolbars.py:82 ../gui/wxpython/mapdisp/frame.py:264
+#: ../gui/wxpython/mapdisp/frame.py:323 ../gui/wxpython/mapdisp/frame.py:503
+msgid "2D view"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:44 ../gui/wxpython/lmgr/frame.py:356
+#: ../gui/wxpython/mapdisp/toolbars.py:88
+msgid "3D view"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:64
+msgid "No animation name selected."
+msgstr ""
+#: ../gui/wxpython/animation/data.py:130
+msgid "No workspace file selected."
+msgstr ""
+#: ../gui/wxpython/animation/data.py:133
+#, python-format
+msgid "File %s not found"
+msgstr ""
+#: ../gui/wxpython/animation/data.py:142
+#, python-format
+msgid "Animation %d"
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:219
+#, python-format
+msgid "Maximum number of animations is %s."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:240
+#: ../gui/wxpython/animation/dialogs.py:725
+msgid ""
+"More animations are using one window. Please select different window for "
+"each animation."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:272
+#: ../gui/wxpython/animation/dialogs.py:597
+#: ../gui/wxpython/wxplot/dialogs.py:495 ../gui/wxpython/psmap/dialogs.py:440
+#: ../gui/wxpython/psmap/dialogs.py:1035 ../gui/wxpython/psmap/dialogs.py:1057
+#: ../gui/wxpython/psmap/dialogs.py:1107 ../gui/wxpython/psmap/dialogs.py:3637
+msgid "Invalid input"
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:399
+msgid "Failed to display legend."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:430
+msgid "Inconsistent number of maps, please check input data."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:453
+msgid "No animation to export."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:488
+msgid "Preparing export, please wait..."
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:533
+#, python-format
+msgid "%(start)s %(unit)s"
+msgstr ""
+#: ../gui/wxpython/animation/controller.py:548
+msgid "Exporting animation, please wait..."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:103
+msgid ""
+"It is not allowed to display data with different temporal types (absolute "
+"and relative)."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:117
+#, python-format
+msgid "It is not allowed to display data with different units (%s)."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:128
+msgid ""
+"You are going to display data with different temporal types of maps "
+"(interval and point). It is recommended to use data of one temporal type to "
+"avoid confusion."
+msgstr ""
+#: ../gui/wxpython/animation/temporal_manager.py:327
+#, python-format
+msgid "Topology of Space time dataset %s is invalid."
+msgstr ""
+#: ../gui/wxpython/animation/g.gui.animation.py:87
+msgid "Options 'rast', 'vect', 'strds' and 'stvds' are mutually exclusive."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:51
+msgid "Adjust speed of animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:96
+msgid "Simple mode"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:100
+msgid "Frame duration:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:101
+#: ../gui/wxpython/animation/dialogs.py:124
+msgid "ms"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:118
+msgid "Temporal mode"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:122
+msgid "Time unit:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:123
+msgid "Duration of time unit:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:175
+msgid "year"
+msgstr ""
+msgid "month"
+msgstr ""
+msgid "day"
+msgstr ""
+msgid "hour"
+msgstr ""
+msgid "minute"
+msgstr ""
+msgid "second"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:237
+msgid "Animation speed is too high."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:274
+msgid "Edit animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:285
+#: ../gui/wxpython/animation/dialogs.py:1483
+#: ../gui/wxpython/gmodeler/preferences.py:47
+#: ../gui/wxpython/gui_core/preferences.py:246
+#: ../gui/wxpython/vdigit/preferences.py:122
+msgid "General"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:286
+msgid "Advanced"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:310
+msgid "top left"
+msgstr ""
+msgid "top right"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:311
+msgid "bottom left"
+msgstr ""
+msgid "bottom right"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:325
+msgid "Select 2D or 3D view"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:329
+#: ../gui/wxpython/gmodeler/preferences.py:549
+#: ../gui/wxpython/vnet/dialogs.py:1474
+#: ../gui/wxpython/gui_core/gselect.py:1427
+#: ../gui/wxpython/gui_core/gselect.py:1437
+#: ../gui/wxpython/gui_core/gselect.py:1438
+#: ../gui/wxpython/gui_core/widgets.py:1058
+msgid "Name:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:332
+msgid "Window position:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:335
+msgid "View mode:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:341
+msgid ""
+"For 3D animation, please select only one space-time dataset\n"
+"or one series of map layers."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:367
+#: ../gui/wxpython/psmap/dialogs.py:2486
+msgid "Show raster legend"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:369
+#: ../gui/wxpython/lmgr/layertree.py:105
+msgid "Set options"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:386
+msgid "3D view parameters"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:393
+msgid "Workspace file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:394
+msgid "Choose workspace file to import 3D view parameters"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:396
+#: ../gui/wxpython/animation/dialogs.py:856
+#: ../gui/wxpython/animation/dialogs.py:927
+#: ../gui/wxpython/animation/dialogs.py:950
+#: ../gui/wxpython/animation/dialogs.py:967
+#: ../gui/wxpython/animation/dialogs.py:990
+#: ../gui/wxpython/location_wizard/wizard.py:102
+#: ../gui/wxpython/location_wizard/wizard.py:1168
+#: ../gui/wxpython/location_wizard/wizard.py:1242
+#: ../gui/wxpython/location_wizard/wizard.py:1328
+#: ../gui/wxpython/gui_core/gselect.py:1071
+#: ../gui/wxpython/gui_core/gselect.py:1377
+#: ../gui/wxpython/gui_core/gselect.py:1390
+#: ../gui/wxpython/gui_core/gselect.py:1429
+#: ../gui/wxpython/gui_core/gselect.py:1452
+#: ../gui/wxpython/gui_core/dialogs.py:2041
+#: ../gui/wxpython/gui_core/forms.py:1480
+#: ../gui/wxpython/gui_core/forms.py:1536
+#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+#: ../gui/wxpython/psmap/dialogs.py:4121 ../gui/wxpython/nviz/tools.py:483
+msgid "Browse"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:401
+msgid "Parameter for animation:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:423
+msgid "Animate region change (2D view only)"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:427
+msgid "Start region:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:434
+msgid "End region:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:438
+msgid "Zoom value:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:439
+msgid "N-S/E-W distances in map units used to gradually reduce region."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:446
+msgid "N-S:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:449
+msgid "E-W:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:541
+msgid "Only one series or space-time dataset is accepted for 3D mode."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:549
+msgid "No map series or space-time dataset added."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:577
+msgid "Region information is not complete"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:606
+msgid "Add, edit or remove animations"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:614
+msgid "List of animations"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:623 ../gui/wxpython/dbmgr/base.py:2064
+#: ../gui/wxpython/psmap/dialogs.py:1293
+msgid "Add"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:625
+msgid "Edit"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:627
+#: ../gui/wxpython/animation/dialogs.py:818
+#: ../gui/wxpython/lmgr/layertree.py:396
+#: ../gui/wxpython/gmodeler/frame.py:1283 ../gui/wxpython/menustrings.py:940
+#: ../gui/wxpython/menustrings.py:1867 ../gui/wxpython/rlisetup/frame.py:130
+#: ../gui/wxpython/gui_core/simplelmgr.py:411
+msgid "Remove"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:678
+#, python-format
+msgid "Maximum number of animations is %d."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:757
+#: ../gui/wxpython/psmap/dialogs.py:384
+msgid "Format"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:758 ../gui/wxpython/nviz/tools.py:610
+msgid "Decorations"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:763
+#: ../gui/wxpython/lmgr/layertree.py:557 ../gui/wxpython/menustrings.py:968
+#: ../gui/wxpython/menustrings.py:1895
+msgid "Export"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:809
+msgid "Add time stamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2049
+msgid "Add image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2047
+msgid "Add text"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:829
+msgid "Add time stamp, image or text decoration by one of the buttons above."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:831
+msgid "Add image or text decoration by one of the buttons above."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:840
+msgid "Font settings:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:842
+msgid "Sample text"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:845
+#: ../gui/wxpython/mapwin/decorations.py:361
+#: ../gui/wxpython/gui_core/preferences.py:394
+#: ../gui/wxpython/gui_core/preferences.py:589
+msgid "Set font"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:854
+msgid "Image file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:855
+msgid "Choose image file"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:863
+msgid "Text:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:876
+msgid "Placement as percentage of screen coordinates (X: 0, Y: 0 is top left):"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:885
+#: ../gui/wxpython/psmap/dialogs.py:208
+msgid "X:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:887
+#: ../gui/wxpython/psmap/dialogs.py:209
+msgid "Y:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:899
+msgid "image sequence"
+msgstr ""
+msgid "animated GIF"
+msgstr ""
+msgid "SWF"
+msgstr ""
+msgid "AVI"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:903
+msgid "Export to:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:918 ../gui/wxpython/nviz/tools.py:486
+msgid "File prefix:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:919
+msgid "animation_"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:920 ../gui/wxpython/nviz/tools.py:491
+msgid "File format:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:925
+#: ../gui/wxpython/gui_core/gselect.py:1388
+#: ../gui/wxpython/gui_core/gselect.py:1450
+msgid "Directory:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:926
+msgid "Choose directory for export"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:948
+msgid "GIF file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:949
+#: ../gui/wxpython/animation/dialogs.py:966
+#: ../gui/wxpython/animation/dialogs.py:989
+msgid "Choose file to save animation"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:965
+msgid "SWF file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:982
+msgid ""
+"Program 'ffmpeg' was not found.\n"
+"Please install it first and make sure\n"
+"it's in the PATH variable."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:988
+msgid "AVI file:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:992
+msgid "Video codec:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:994
+msgid "Additional options:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:996
+msgid ""
+"Consider adding '-sameq' or '-qscale 1' if not satisfied with video quality. "
+"Options depend on ffmpeg version."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1018
+#, python-format
+msgid "Current frame rate: %.2f fps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1136
+#, python-format
+msgid "File %s not found."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1138
+msgid "Decoration image file is missing."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1145
+#, python-format
+msgid "Directory %s not found."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1147
+msgid "Export directory is missing."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1151
+#: ../gui/wxpython/animation/dialogs.py:1155
+msgid "Export file is missing."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1192
+msgid "Time stamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2048 ../gui/wxpython/psmap/toolbars.py:92
+#: ../gui/wxpython/psmap/dialogs.py:4061 ../gui/wxpython/psmap/dialogs.py:4109
+msgid "Image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2046 ../gui/wxpython/psmap/toolbars.py:84
+#: ../gui/wxpython/psmap/dialogs.py:3705 ../gui/wxpython/psmap/dialogs.py:3710
+msgid "Text"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1263
+msgid "Add space-time dataset layer"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1281
+msgid "Multiple raster maps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1282
+msgid "Multiple vector maps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1283
+msgid "Multiple 3D raster maps"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1284
+msgid "Space time raster dataset"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1285
+msgid "Space time vector dataset"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1286
+msgid "Space time 3D raster dataset"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1325
+msgid "Input data type:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1400
+msgid "Select raster/vector maps."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1427
+msgid "Please select maps or dataset first."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1455
+msgid "Animation Tool settings"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1491
+#: ../gui/wxpython/web_services/widgets.py:264
+#: ../gui/wxpython/gui_core/preferences.py:652
+#: ../gui/wxpython/nviz/preferences.py:178 ../gui/wxpython/nviz/tools.py:354
+msgid "Background color:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1513
+#: ../gui/wxpython/timeline/frame.py:270
+msgid "Time"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1521
+msgid "Absolute time format:"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1532
+msgid ""
+"Click and then press key up or down to preview different date and time "
+"formats. Type custom format string."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1541
+msgid "Learn more about formatting options"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1550
+msgid "Display instances with no data"
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1551
+msgid ""
+"When animating instant-based data which have irregular timestamps you can "
+"display 'no data frame' (checked option) or keep last frame."
+msgstr ""
+#: ../gui/wxpython/animation/dialogs.py:1573
+msgid "Invalid"
+msgstr ""
+#: ../gui/wxpython/animation/provider.py:362
+msgid "Rendering map layers"
+msgstr ""
+#: ../gui/wxpython/animation/provider.py:458
+msgid "Overlaying map layers"
+msgstr ""
+#: ../gui/wxpython/animation/provider.py:675
+msgid "Directory {t} not removed."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:42 ../gui/wxpython/lmgr/frame.py:1174
+#, python-format
+msgid ""
+"Reading workspace file <%s> failed.\n"
+"Invalid file, unable to parse XML document."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:51
+#, python-format
+msgid "No 3d view information in workspace file <%s>."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:259
+msgid "Please add only one layer in the list."
+msgstr ""
+#: ../gui/wxpython/animation/nviztask.py:265
+msgid "No map series nor space-time dataset is added."
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:27
+#: ../gui/wxpython/modules/vclean.py:455
+msgid "Tools"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:28
+msgid "Quit Map Swipe"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:29
+#: ../gui/wxpython/mapswipe/dialogs.py:42
+msgid "Select raster maps"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:104
+msgid "Swipe mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:233
+msgid "Mirror mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:113
+msgid "Choose view mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:137
+msgid "Switch orientation"
+msgstr ""
+#: ../gui/wxpython/mapswipe/toolbars.py:139
+msgid "Switch maps"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:41
+msgid "GRASS GIS Map Swipe"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:266 ../gui/wxpython/mapdisp/frame.py:467
+#: ../gui/wxpython/gcp/mapdisplay.py:248 ../gui/wxpython/iclass/frame.py:289
+#: ../gui/wxpython/rlisetup/sampling_frame.py:99
+msgid "Map Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:390
+#, python-format
+msgid "Map <%s> not found. "
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:509 ../gui/wxpython/mapdisp/frame.py:657
+#: ../gui/wxpython/gcp/mapdisplay.py:368
+msgid "Nothing to render (empty map). Operation canceled."
+msgstr ""
+#: ../gui/wxpython/mapswipe/frame.py:515
+#: ../gui/wxpython/modules/histogram.py:420
+#: ../gui/wxpython/mapdisp/frame.py:580 ../gui/wxpython/gcp/mapdisplay.py:383
+#: ../gui/wxpython/gmodeler/frame.py:570
+msgid "Choose a file name to save the image (no need to add extension)"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:119
+msgid "Name of top/left raster map:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:123
+msgid "Name of bottom/right raster map:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:156
+msgid "Switch to advanced mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:157
+msgid "Cancel"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:161
+msgid "Switch to simple mode"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:162 ../gui/wxpython/menustrings.py:13
+#: ../gui/wxpython/menustrings.py:1977
+msgid "Close"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:185
+msgid "Name of the first map is missing."
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:187
+msgid "Name of the second map is missing."
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:218
+msgid "Map Swipe settings"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:236
+msgid "Mirrored cursor"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:242 ../gui/wxpython/gcp/manager.py:2472
+#: ../gui/wxpython/gui_core/preferences.py:1068
+#: ../gui/wxpython/psmap/dialogs.py:1777 ../gui/wxpython/psmap/dialogs.py:1880
+#: ../gui/wxpython/nviz/preferences.py:334
+#: ../gui/wxpython/nviz/preferences.py:491
+#: ../gui/wxpython/nviz/preferences.py:545 ../gui/wxpython/nviz/tools.py:1147
+#: ../gui/wxpython/nviz/tools.py:1789 ../gui/wxpython/nviz/tools.py:1910
+msgid "Color:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:255
+msgid "Shape:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:270 ../gui/wxpython/gcp/manager.py:2563
+#: ../gui/wxpython/vnet/dialogs.py:1162
+#: ../gui/wxpython/gui_core/preferences.py:1004
+#: ../gui/wxpython/psmap/dialogs.py:4900
+msgid "Line width:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/dialogs.py:283
+#: ../gui/wxpython/nviz/preferences.py:516
+msgid "Size:"
+msgstr ""
+#: ../gui/wxpython/mapswipe/g.gui.mapswipe.py:76
+#: ../gui/wxpython/modules/histogram.py:349
+#: ../gui/wxpython/iclass/g.gui.iclass.py:80
+#: ../gui/wxpython/nviz/wxnviz.py:329 ../gui/wxpython/nviz/wxnviz.py:340
+#, python-format
+msgid "Raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:70
+msgid "GRASS GIS Attribute Table Manager - "
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:72
+msgid "READONLY - "
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:85
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. You can "
+"define new connection in 'Manage layers' tab."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:90
+msgid "Please wait, loading attribute data..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:99
+msgid "Browse data"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:105
+msgid "Manage tables"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:110
+msgid "Manage layers"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:121
+msgid "Close Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:123
+msgid "Reload attribute data (selected layer only)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/manager.py:188 ../gui/wxpython/dbmgr/base.py:275
+#: ../gui/wxpython/dbmgr/base.py:803 ../gui/wxpython/dbmgr/base.py:960
+#: ../gui/wxpython/dbmgr/base.py:1262 ../gui/wxpython/dbmgr/base.py:1848
+#, python-format
+msgid "Number of loaded records: %d"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:142 ../gui/wxpython/iscatt/controllers.py:142
+msgid "Loading data..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:149
+#, python-format
+msgid ""
+"Attribute table <%s> not found. For creating the table switch to 'Manage "
+"layers' tab."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:160
+#, python-format
+msgid "Column <%(column)s> not found in in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:233
+msgid "Can display only 256 columns."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:248
+#, python-format
+msgid "Inconsistent number of columns in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:258
+msgid "Viewing limit: 100000 records."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:299
+msgid "Unknown value"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:305
+msgid "Unable to decode value. Set encoding in GUI preferences ('Attributes')."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:314
+#, python-format
+msgid ""
+"Error loading attribute data. Record number: %(rec)d. Unable to convert "
+"value '%(val)s' in key column (%(key)s) to integer.\n"
+"\n"
+"Details: %(detail)s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:407
+msgid "Sort ascending"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:408
+msgid "Sort descending"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:411
+msgid "Calculate (only numeric columns)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:413
+msgid "Field calculator"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:418 ../gui/wxpython/dbmgr/base.py:2022
+#: ../gui/wxpython/modules/colorrules.py:1020
+msgid "Add column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:429
+msgid "Area size"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:430
+msgid "Line length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:431
+msgid "Compactness of an area"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:432
+msgid "Fractal dimension of boundary defining a polygon"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:433
+msgid "Perimeter length of an area"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:434
+msgid "Number of features for each category"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:435
+msgid "Slope steepness of 3D line"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:436
+msgid "Line sinuousity"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:437
+msgid "Line azimuth"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:532
+#, python-format
+msgid "Add column to table <%s>"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:902
+msgid "Unable to add column to the table. No column name defined."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:915
+#, python-format
+msgid "Column <%(column)s> already exists in table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:989
+msgid "Attribute data - right-click to edit/manage records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1004 ../gui/wxpython/dbmgr/base.py:1983
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2707
+#: ../gui/wxpython/dbmgr/base.py:2960
+msgid "Table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1006 ../gui/wxpython/dbmgr/base.py:1985
+msgid " (readonly)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1020
+msgid "SQL Query"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1049
+msgid "Simple"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1052
+msgid "Apply SELECT statement and reload data records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1066 ../gui/wxpython/dbmgr/base.py:1083
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:415
+#, python-format
+msgid "Example: %s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1074
+msgid "Builder"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1076
+msgid "SQL Builder"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1227 ../gui/wxpython/core/settings.py:846
+msgid "Edit selected record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1231 ../gui/wxpython/dbmgr/base.py:1406
+msgid "Insert new record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1232
+msgid "Delete selected record(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1233
+msgid "Delete all records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1239 ../gui/wxpython/gui_core/dialogs.py:673
+#: ../gui/wxpython/gui_core/dialogs.py:726
+#: ../gui/wxpython/gui_core/dialogs.py:1431
+#: ../gui/wxpython/gui_core/widgets.py:799
+msgid "Select all"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1240 ../gui/wxpython/gui_core/dialogs.py:1433
+#: ../gui/wxpython/gui_core/widgets.py:800
+msgid "Deselect all"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1242
+#: ../gui/wxpython/gui_core/preferences.py:1061
+msgid "Highlight selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1243
+msgid "Highlight selected features and zoom"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1247 ../gui/wxpython/dbmgr/base.py:1727
+msgid "Extract selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1248
+msgid "Delete selected features"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1256 ../gui/wxpython/dbmgr/base.py:2249
+#: ../gui/wxpython/gmodeler/dialogs.py:777
+#: ../gui/wxpython/gmodeler/dialogs.py:925
+#: ../gui/wxpython/vdigit/dialogs.py:280
+msgid "Reload"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1309
+msgid "Update existing record"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1335 ../gui/wxpython/dbmgr/base.py:1440
+#, python-format
+msgid "Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1349
+#, python-format
+msgid ""
+"Unable to update existing record.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1417
+#, python-format
+msgid "Record with category number %d already exists in the table."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1427
+#, python-format
+msgid "Category number (column %s) is missing."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1452
+#, python-format
+msgid ""
+"Unable to insert new record.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1503
+#, python-format
+msgid ""
+"Selected data records (%d) will be permanently deleted from table. Do you "
+"want to delete them?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1506 ../gui/wxpython/dbmgr/base.py:1552
+msgid "Delete records"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1549
+#, python-format
+msgid ""
+"All data records (%d) will be permanently deleted from table. Do you want to "
+"delete them?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1723
+msgid "Nothing to extract."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1756
+msgid "Nothing to delete."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1808 ../gui/wxpython/dbmgr/base.py:1833
+#, python-format
+msgid ""
+"Loading attribute data failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1821
+#, python-format
+msgid ""
+"Invalid SQL select statement.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:1999 ../gui/wxpython/dbmgr/sqlbuilder.py:83
+msgid "Database connection"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2011
+#, python-format
+msgid "Table <%s> - right-click to delete column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2030 ../gui/wxpython/dbmgr/base.py:2081
+#: ../gui/wxpython/dbmgr/dialogs.py:750
+msgid "Column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2045 ../gui/wxpython/dbmgr/dialogs.py:757
+#: ../gui/wxpython/web_services/widgets.py:851
+#: ../gui/wxpython/gmodeler/preferences.py:209
+msgid "Type"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2057 ../gui/wxpython/dbmgr/dialogs.py:764
+msgid "Length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2073 ../gui/wxpython/menustrings.py:924
+#: ../gui/wxpython/menustrings.py:1851
+msgid "Rename column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2093 ../gui/wxpython/gmodeler/dialogs.py:311
+msgid "To"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2100
+msgid "&Rename"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2193
+msgid "Unable to rename column. No column name defined."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2201
+#, python-format
+msgid ""
+"Unable to rename column <%(column)s> to <%(columnTo)s>. Column already "
+"exists in the table <%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2217
+#, python-format
+msgid ""
+"Unable to rename column. Column <%(column)s> doesn't exist in the table <"
+"%(table)s>."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2244
+msgid "Drop selected column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2247
+msgid "Drop all columns"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2276
+#, python-format
+msgid ""
+"Selected column %s will PERMANENTLY removed from table. Do you want to drop "
+"the column?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2279 ../gui/wxpython/dbmgr/base.py:2316
+msgid "Drop column(s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2313
+#, python-format
+msgid ""
+"Selected columns\n"
+"%s\n"
+"will PERMANENTLY removed from table. Do you want to drop the columns?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2401
+msgid "List of layers"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2481 ../gui/wxpython/dbmgr/base.py:2883
+#: ../gui/wxpython/dbmgr/base.py:3303
+#, python-format
+msgid "Drop also linked attribute table (%s)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2522
+msgid "Column name"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2522 ../gui/wxpython/gmodeler/frame.py:1432
+#: ../gui/wxpython/gmodeler/frame.py:1483
+msgid "Data type"
+msgstr ""
+msgid "Data length"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2690
+#: ../gui/wxpython/dbmgr/base.py:2940 ../gui/wxpython/dbmgr/dialogs.py:491
+#: ../gui/wxpython/vdigit/dialogs.py:113 ../gui/wxpython/vdigit/dialogs.py:557
+#: ../gui/wxpython/vdigit/preferences.py:379
+#: ../gui/wxpython/vdigit/preferences.py:381
+msgid "Layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2696
+#: ../gui/wxpython/dbmgr/base.py:2948
+msgid "Driver"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2576 ../gui/wxpython/dbmgr/base.py:2701
+#: ../gui/wxpython/dbmgr/base.py:2954 ../gui/wxpython/gui_core/gselect.py:1316
+msgid "Database"
+msgstr ""
+msgid "Key"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2672
+msgid "Add layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2682
+msgid "Layer description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2712 ../gui/wxpython/dbmgr/base.py:2750
+#: ../gui/wxpython/dbmgr/base.py:2966
+msgid "Key column"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2717
+msgid "Insert record for each category into table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2732
+msgid "You need to add categories by v.category module."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2737
+msgid "Table description"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2745
+msgid "Table name"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2758
+msgid "&Create table"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2762
+#: ../gui/wxpython/web_services/dialogs.py:487
+msgid "&Add layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2766
+msgid "&Set default"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2866
+msgid "Remove layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2869
+msgid "Layer to remove"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2890
+msgid "&Remove layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:2933
+msgid "Modify layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3005
+msgid "&Modify layer"
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3053
+msgid ""
+"Unable to get list of tables.\n"
+"Please use db.connect to set database parameters."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3150
+msgid "Unable to create new table. Table name or key column name is missing."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3156
+#, python-format
+msgid "Unable to create new table. Table <%s> already exists in the database."
+msgstr ""
+#: ../gui/wxpython/dbmgr/base.py:3194
+#, python-format
+msgid ""
+"Unable to add new layer to vector map <%(vector)s>. Layer %(layer)d already "
+"exists."
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:74
+#, python-format
+msgid ""
+"No attribute table found.\n"
+"\n"
+"Do you want to create a new attribute table and defined a link to vector map "
+"<%s>?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:77
+msgid "Create table?"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:97
+msgid "Close dialog on submit"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:109
+msgid "No attributes found"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:115 ../gui/wxpython/menustrings.py:695
+#: ../gui/wxpython/menustrings.py:1622
+msgid "Update attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:117
+msgid "Define attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:119
+msgid "Display attributes"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:123
+msgid "&Reload"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:124 ../gui/wxpython/dbmgr/dialogs.py:595
+msgid "&Submit"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:142 ../gui/wxpython/vdigit/dialogs.py:168
+msgid "Feature id:"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:226
+#, python-format
+msgid "Column <%(col)s>: Value '%(value)s' needs to be entered as %(type)s."
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:434
+msgid "Unknown"
+msgstr ""
+#: ../gui/wxpython/dbmgr/dialogs.py:492 ../gui/wxpython/dbmgr/dialogs.py:610
+#: ../gui/wxpython/vdigit/dialogs.py:120 ../gui/wxpython/vdigit/dialogs.py:558
+msgid "Category"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:95 ../gui/wxpython/menustrings.py:906
+#: ../gui/wxpython/menustrings.py:1833
+msgid "Query"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:111
+msgid "Set SQL statement to default"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:113
+msgid "Apply SQL statement in Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:115
+msgid "Close the dialog"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:166
+msgid "Columns"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:177
+msgid "Interactive insertion"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:191
+msgid "Values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:201
+msgid "Get all values"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:204
+msgid "Get sample"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:205
+msgid "Get first 256 unique values as sample"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:221
+msgid "Go to:"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:234
+msgid "Close dialog on apply"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:399
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:541
+#, python-format
+msgid "GRASS SQL Builder (%(type)s) - <%(map)s>"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:402
+msgid "Column to show (SELECT clause)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:403
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:545
+msgid "Constraint for query (WHERE clause)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:418
+msgid "Verify"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:419
+msgid "Verify SQL statement"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:427
+msgid "SQL statement not verified"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:471
+msgid "SQL statement is not valid"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:473
+#, python-format
+msgid ""
+"SQL statement is not valid.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:475
+msgid "SQL statement is valid"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:544
+msgid "Column to set (SET clause)"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:546
+msgid "Calculate column value to set"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:601
+msgid "Functions"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:634
+msgid "SQL statement was not applied"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:636
+msgid "SQL statement applied"
+msgstr ""
+#: ../gui/wxpython/dbmgr/sqlbuilder.py:669
+msgid "Dbf driver does not support usage of SQL functions."
+msgstr ""
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:44
+#: ../gui/wxpython/iclass/g.gui.iclass.py:85
+#: ../gui/wxpython/nviz/wxnviz.py:417
+#, python-format
+msgid "Vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:47
+#, python-format
+msgid "Loading attribute data for vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/dbmgr/g.gui.dbmgr.py:49
+msgid "GRASS GIS Attribute Table Manager"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:320
+#, python-format
+msgid "Vector map <%(map)s>: %(msg)s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:547
+#, python-format
+msgid "failed to open '%s'"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:842
+#, python-format
+msgid "ERROR: Unable to determine GRASS version. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:877
+#, python-format
+msgid "Unable to open file '%s'\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:884
+#, python-format
+msgid ""
+"%s: line skipped - unable to parse '%s'\n"
+"Reason: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:889
+#, python-format
+msgid "Duplicated key: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:905
+#, python-format
+msgid "Unable to create file '%s'\n"
+msgstr ""
+#: ../gui/wxpython/core/utils.py:979 ../gui/wxpython/gui_core/forms.py:1416
+msgid "Select Color"
+msgstr ""
+#: ../gui/wxpython/core/ws.py:48
+msgid ""
+"Unable to load GDAL Python bindings.\n"
+"WMS layers can not be displayed without the bindings.\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:485
+msgid "Segment break"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:551
+msgid "Data point"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:625
+msgid "animation"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:839
+msgid "Collapse all except PERMANENT and current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:840
+msgid "Collapse all except PERMANENT"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:841
+msgid "Collapse all except current"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:842
+msgid "Collapse all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:843
+msgid "Expand all"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:847
+msgid "Display selected"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:855
+msgid "Classic (labels only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:856
+msgid "Combined (labels and module names)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:857
+msgid "Expert (module names only)"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:862
+msgid "Basic top"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:863
+msgid "Basic left"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:864
+msgid "Fancy green"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:865
+msgid "List left"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:869
+msgid "Zoom and recenter"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:870
+msgid "Zoom to mouse cursor"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:871
+msgid "Nothing"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:872
+msgid "Scroll forward to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:873
+msgid "Scroll back to zoom in"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:906 ../gui/wxpython/core/settings.py:918
+msgid "box"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:907
+msgid "sphere"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:908
+msgid "cube"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:909
+msgid "diamond"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:910
+msgid "aster"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:911
+msgid "gyro"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:912
+msgid "histogram"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:917
+msgid "cross"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:919
+msgid "circle"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:951
+#, python-format
+msgid "Unable to read settings file <%s>\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:975
+#, python-format
+msgid ""
+"Error: Reading settings from file <%(file)s> failed.\n"
+"\t\tDetails: %(detail)s\n"
+"\t\tLine: '%(line)s'\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:994
+msgid "Unable to create settings directory"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1030
+#, python-format
+msgid ""
+"Writing settings to file <%(file)s> failed.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1129
+msgid "Unable to set "
+msgstr ""
+#: ../gui/wxpython/core/settings.py:1165 ../gui/wxpython/core/settings.py:1175
+#, python-format
+msgid "Unable to parse settings '%s'"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1312
+#, python-format
+msgid "Unable to open file <%s> for reading."
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1313 ../gui/wxpython/core/gcmd.py:115
+#: ../gui/wxpython/lmgr/layertree.py:724 ../gui/wxpython/gmodeler/frame.py:952
+#: ../gui/wxpython/location_wizard/dialogs.py:114
+#: ../gui/wxpython/location_wizard/dialogs.py:131
+#: ../gui/wxpython/location_wizard/dialogs.py:439
+#: ../gui/wxpython/location_wizard/wizard.py:539
+#: ../gui/wxpython/location_wizard/wizard.py:723
+#: ../gui/wxpython/location_wizard/wizard.py:1501
+#: ../gui/wxpython/location_wizard/wizard.py:1567
+#: ../gui/wxpython/gui_core/preferences.py:212
+#: ../gui/wxpython/gui_core/preferences.py:1385
+#: ../gui/wxpython/gui_core/preferences.py:1414
+#: ../gui/wxpython/gui_core/preferences.py:1423
+#: ../gui/wxpython/gui_core/preferences.py:1432
+#: ../gui/wxpython/psmap/dialogs.py:3951 ../gui/wxpython/gis_set.py:230
+#: ../gui/wxpython/gis_set.py:598 ../gui/wxpython/gis_set.py:635
+#: ../gui/wxpython/vdigit/dialogs.py:243 ../gui/wxpython/vdigit/dialogs.py:435
+msgid "Error"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1325
+#, python-format
+msgid ""
+"Some lines were skipped when reading settings from file <%(file)s>.\n"
+"See 'Command output' window for details.\n"
+"\n"
+"Number of skipped lines: %(line)d"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1329 ../gui/wxpython/core/gcmd.py:140
+#: ../gui/wxpython/wxplot/dialogs.py:802
+#: ../gui/wxpython/mapwin/buffered.py:1888
+msgid "Warning"
+msgstr ""
+#: ../gui/wxpython/core/workspace.py:1543
+#, python-format
+msgid " row %d:"
+msgstr ""
+#: ../gui/wxpython/core/render.py:135
+#, python-format
+msgid "<%(name)s>: layer type <%(type)s> is not supported"
+msgstr ""
+#: ../gui/wxpython/core/render.py:156
+#, python-format
+msgid "Command '%s' failed\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:158
+#, python-format
+msgid "Details: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:259
+#, python-format
+msgid "Unsupported map layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/core/render.py:401
+msgid "Trying to recover from default region..."
+msgstr ""
+#: ../gui/wxpython/core/render.py:447
+msgid "GISBASE not set. You must be in GRASS GIS to run this program."
+msgstr ""
+#: ../gui/wxpython/core/render.py:460
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:88
+#: ../gui/wxpython/gui_core/mapdisp.py:107
+#, python-format
+msgid "GRASS module '%s' not found. Unable to start map display window."
+msgstr ""
+#: ../gui/wxpython/core/render.py:492
+#, python-format
+msgid "Error: Unable to open '%(file)s'. Reason: %(ret)s. wxGUI exited.\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:500
+#, python-format
+msgid ""
+"\n"
+"ERROR: Unable to read WIND file: %s\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:597
+#, python-format
+msgid "Invalid map size %d,%d\n"
+msgstr ""
+#: ../gui/wxpython/core/render.py:680
+#, python-format
+msgid "Unable to zoom to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:681 ../gui/wxpython/core/render.py:684
+#: ../gui/wxpython/core/render.py:687 ../gui/wxpython/core/gcmd.py:397
+msgid "Details:"
+msgstr ""
+#: ../gui/wxpython/core/render.py:683
+#, python-format
+msgid "Unable to zoom to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:686
+#, python-format
+msgid "Unable to zoom to 3d raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:689
+msgid ""
+"Unable to get current geographic extent. Force quiting wxGUI. Please "
+"manually run g.region to fix the problem."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1006
+#, python-format
+msgid "ERROR: Rendering failed. Details: %s"
+msgstr ""
+#: ../gui/wxpython/core/render.py:1063 ../gui/wxpython/core/render.py:1158
+#, python-format
+msgid "Unable to render map layer <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1267 ../gui/wxpython/core/render.py:1306
+#, python-format
+msgid "Unable to render overlay <%s>."
+msgstr ""
+#: ../gui/wxpython/core/render.py:1403
+msgid "Downloading data "
+msgstr ""
+#: ../gui/wxpython/core/render.py:1413
+msgid "Rendering & "
+msgstr ""
+#: ../gui/wxpython/core/render.py:1415
+msgid "Rendering..."
+msgstr ""
+#: ../gui/wxpython/core/menutree.py:135
+#, python-format
+msgid "Unknow tag %s"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:486
+#, python-format
+msgid ""
+"Unable to run command:\n"
+"%(cmd)s\n"
+"\n"
+"Option <%(opt)s>: read from standard input is not supported by wxGUI"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:606
+#, python-format
+msgid "%d sec"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:609
+#, python-format
+msgid "%(min)d min %(sec)d sec"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:613 ../gui/wxpython/gmodeler/model.py:1055
+#: ../gui/wxpython/gmodeler/model.py:1152
+#: ../gui/wxpython/gui_core/ghelp.py:212
+msgid "unknown"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:617
+msgid ""
+"Please note that the data are left in inconsistent state and may be corrupted"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:619
+msgid "Command aborted"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:621
+msgid "Command finished"
+msgstr ""
+#: ../gui/wxpython/core/gconsole.py:682
+#: ../gui/wxpython/gui_core/goutput.py:440
+#, python-format
+msgid ""
+"Unable to write file '%(filePath)s'.\n"
+"\n"
+"Details: %(error)s"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:128
+msgid "Unable to parse user toolboxes XML files. Default files will be loaded."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:168
+msgid "Unable to create toolboxes directory."
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:382
+msgid "Custom toolboxes"
+msgstr ""
+#: ../gui/wxpython/core/toolboxes.py:448
+msgid "Addons"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:128
+msgid "Reason"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:149 ../gui/wxpython/lmgr/frame.py:2160
+#: ../gui/wxpython/gis_set.py:586 ../gui/wxpython/gis_set.py:622
+msgid "Message"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:394
+msgid "Execution failed:"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:399 ../gui/wxpython/core/gcmd.py:403
+#: ../gui/wxpython/gis_set.py:432
+msgid "Error: "
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:478
+#, python-format
+msgid "Unable to exectute command: '%s'"
+msgstr ""
+#: ../gui/wxpython/core/gcmd.py:702 ../gui/wxpython/gui_core/forms.py:2211
+#, python-format
+msgid "Error in %s"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:34
+#, python-format
+msgid "Unknown iconset '%s', using default 'grass'...\n"
+msgstr ""
+#: ../gui/wxpython/icons/icon.py:51
+#, python-format
+msgid "Unable to load icon theme. Reason: %s. Quiting wxGUI..."
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:46
+msgid "Start new map display"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:48
+msgid "Create new workspace (Ctrl+N)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:50
+msgid "Open existing workspace file (Ctrl+O)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:52
+msgid "Save current workspace to file (Ctrl+S)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:81
+msgid "Add multiple raster or vector map layers (Ctrl+Shift+L)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:82
+msgid "Add raster map layer (Ctrl+Shift+R)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:84
+msgid "Add various raster map layers (RGB, HIS, shaded relief...)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:85
+msgid "Add vector map layer (Ctrl+Shift+V)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:87
+msgid "Add various vector map layers (thematic, chart...)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:89
+msgid "Add web service layer (WMS, WMTS, NASA OnEarth)"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:91
+msgid "Add group"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:93
+msgid "Add various overlays"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:95
+msgid "Remove selected map layer(s) from layer tree"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:136
+msgid "Import/link raster or vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:138
+msgid "Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:140 ../gui/wxpython/gui_core/forms.py:1183
+msgid "Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:142
+msgid "Georectifier"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:144 ../gui/wxpython/menustrings.py:214
+#: ../gui/wxpython/menustrings.py:1964
+msgid "Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:146
+msgid "Launch user-defined script"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:180
+msgid "GUI settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:181
+msgid "GRASS manual"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:206
+msgid "Edit selected vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:208
+msgid "Show attribute data for selected vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:237
+msgid "Generate command for m.nviz.image"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:238
+msgid "Generate command for m.nviz.image based on current state"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:240
+msgid "3D view mode settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:241
+msgid "Show 3D view mode settings dialog"
+msgstr ""
+#: ../gui/wxpython/lmgr/toolbars.py:243
+msgid "Show 3D view mode manual"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:95 ../gui/wxpython/lmgr/frame.py:1024
+#: ../gui/wxpython/mapdisp/frame.py:245 ../gui/wxpython/gui_core/ghelp.py:100
+#: ../gui/wxpython/gui_core/ghelp.py:809
+msgid "Unable to get GRASS version\n"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:97
+#, python-format
+msgid "GRASS GIS %s Layer Manager"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:141
+msgid "Workspace Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:144
+msgid "Data Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:150
+msgid "Tools Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:153
+msgid "Vector Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:156
+msgid "3D view Toolbar"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:260 ../gui/wxpython/lmgr/frame.py:1433
+msgid "Rename Map Display"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:288
+msgid "Map layers"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:299
+msgid "Command console"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:316
+msgid "Search modules"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:323
+#: ../gui/wxpython/gui_core/preferences.py:292
+msgid "Python shell"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:395
+#, python-format
+msgid ""
+"Location <%s> created.\n"
+"\n"
+"Do you want to switch to the new location?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:398
+msgid "Switch to new location?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:414 ../gui/wxpython/lmgr/frame.py:901
+#, python-format
+msgid ""
+"Current location is <%(loc)s>.\n"
+"Current mapset is <%(mapset)s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:420 ../gui/wxpython/gis_set.py:492
+msgid "Do you want to set the default region extents and resolution now?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:422 ../gui/wxpython/gis_set.py:491
+#, python-format
+msgid "Location <%s> created"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:500
+msgid "Choose model to run"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:502 ../gui/wxpython/gmodeler/frame.py:390
+#: ../gui/wxpython/gmodeler/frame.py:434
+msgid "GRASS Model File (*.gxm)|*.gxm"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:558 ../gui/wxpython/lmgr/frame.py:2119
+msgid "Do you want to save changes in the workspace?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:560 ../gui/wxpython/lmgr/frame.py:2121
+msgid "Do you want to store current settings to workspace file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:568
+#, python-format
+msgid "Close Map Display %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:643
+#, python-format
+msgid ""
+"Command '%s' not yet implemented in the WxGUI. Try adding it as a command "
+"layer instead."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:794 ../gui/wxpython/lmgr/frame.py:1656
+msgid "Selected map layer is not vector."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:799
+msgid "Editing is allowed only for vector maps from the current mapset."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:823
+msgid "Choose script file to run"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:825
+msgid "Python script (*.py)|*.py|Bash script (*.sh)|*.sh"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:836
+#, python-format
+msgid "Script file '%s' doesn't exist. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:843
+#, python-format
+msgid ""
+"Script <%s> is not executable. Do you want to set the permissions that "
+"allows you to run this script (note that you must be the owner of the file)?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:848
+msgid "Set permission?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:857
+msgid "Unable to set permission. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:868
+#, python-format
+msgid ""
+"Directory '%s' is not defined in GRASS_ADDON_PATH. Do you want add this "
+"directory to GRASS_ADDON_PATH?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:871
+msgid "Update Addons path?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:877
+#, python-format
+msgid "Launching script '%s'..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:889
+msgid "No location/mapset provided. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:908 ../gui/wxpython/gis_set.py:848
+msgid "Enter name for new mapset:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:909 ../gui/wxpython/menustrings.py:247
+#: ../gui/wxpython/gis_set.py:479 ../gui/wxpython/gis_set.py:849
+msgid "Create new mapset"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:915 ../gui/wxpython/lmgr/frame.py:936
+msgid "No mapset provided. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:924 ../gui/wxpython/lmgr/frame.py:943
+#, python-format
+msgid "Current mapset is <%s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:961
+#, python-format
+msgid ""
+"Working directory changed to:\n"
+"\"%s\""
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:975
+msgid "Changes current working directory for this GUI."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:977
+msgid "Usage: cd [directory]"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:989
+msgid "Choose a working directory"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1033
+msgid "System Info"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1048
+msgid "GRASS version"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1048 ../gui/wxpython/gui_core/ghelp.py:114
+msgid "unknown version"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1049
+msgid "GRASS SVN Revision"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1050 ../gui/wxpython/gui_core/ghelp.py:152
+msgid "Build Date"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1051
+msgid "Build Platform"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1056
+msgid "Platform"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1112
+msgid ""
+"Current workspace is not empty. Do you want to store current settings to "
+"workspace file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1115
+msgid "Create new workspace?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1141
+msgid "Choose workspace file"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1142 ../gui/wxpython/lmgr/frame.py:1331
+msgid "GRASS Workspace File (*.gxw)|*.gxw"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1178 ../gui/wxpython/lmgr/frame.py:1308
+msgid "Please wait, loading workspace..."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1292
+msgid "Choose GRC file to load"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1293
+msgid "Old GRASS Workspace File (*.grc)|*.grc"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1330
+msgid "Choose file to save current workspace"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1345 ../gui/wxpython/lmgr/frame.py:1361
+#, python-format
+msgid "Workspace file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1347 ../gui/wxpython/lmgr/frame.py:1364
+#: ../gui/wxpython/menustrings.py:10
+msgid "Save workspace"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1385
+msgid "Writing current settings to workspace file failed."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1396 ../gui/wxpython/gmodeler/frame.py:951
+#, python-format
+msgid "Unable to open file <%s> for writing."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1432
+msgid "Enter new name:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1438
+msgid "GRASS GIS %(version) Map Display: %(name)s - Location: %(loc)s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1516
+#, python-format
+msgid ""
+"Unable to launch \"Supervised Classification Tool\".\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1764
+msgid "Add selected map layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1798 ../gui/wxpython/lmgr/frame.py:1845
+#, python-format
+msgid "Unsupported map layer type <%s>."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:1974
+msgid ""
+"Note that cell values can only be displayed for regions of less than 10,000 "
+"cells."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2048 ../gui/wxpython/lmgr/layertree.py:1594
+msgid "opacity:"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2056
+#, python-format
+msgid ""
+"Do you want to remove map layer(s)\n"
+"%s\n"
+"from layer tree?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2059
+msgid "Do you want to remove selected map layer(s) from layer tree?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2063
+msgid "Remove map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2128
+msgid "Quit GRASS GUI"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2159
+msgid "No map layer selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2169
+msgid ""
+"Display resolution is currently not constrained to computational settings. "
+"It's suggested to constrain map to region geometry. Do you want to constrain "
+"the resolution?"
+msgstr ""
+#: ../gui/wxpython/lmgr/frame.py:2178
+msgid "Constrain map to region geometry?"
+msgstr ""
+#: ../gui/wxpython/lmgr/menudata.py:42
+msgid ""
+"Unable to parse user toolboxes XML files. Default main menu will be loaded."
+msgstr ""
+#: ../gui/wxpython/lmgr/menudata.py:64
+msgid ""
+"Unable to parse user toolboxes XML files. Default module tree will be loaded."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:36
+#, python-format
+msgid "Welcome to wxGUI Interactive Python Shell %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:37
+#, python-format
+msgid "Type %s for more GRASS scripting related information."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:38
+#, python-format
+msgid "Type %s to add raster or vector to the layer tree."
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:48
+msgid "Delete all text from the shell"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:98
+#, python-format
+msgid "Raster or vector map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:105
+#, python-format
+msgid "Raster map <%s> added"
+msgstr ""
+#: ../gui/wxpython/lmgr/pyshell.py:107
+#, python-format
+msgid "Vector map <%s> added"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:56 ../gui/wxpython/menustrings.py:30
+#: ../gui/wxpython/menustrings.py:1037
+#: ../gui/wxpython/gui_core/dialogs.py:1827
+msgid "Import raster data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:58 ../gui/wxpython/menustrings.py:164
+#: ../gui/wxpython/menustrings.py:1171
+#: ../gui/wxpython/gui_core/dialogs.py:1825
+msgid "Link external raster data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:60
+msgid "Set raster output format"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:62 ../gui/wxpython/menustrings.py:60
+#: ../gui/wxpython/menustrings.py:1067
+#: ../gui/wxpython/gui_core/dialogs.py:1821
+msgid "Import vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:64 ../gui/wxpython/menustrings.py:166
+#: ../gui/wxpython/menustrings.py:1173
+#: ../gui/wxpython/gui_core/dialogs.py:1819
+msgid "Link external vector data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:66
+msgid "Set vector output format"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:68
+msgid "Import data from WMS server"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:70
+msgid "Add command layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:72 ../gui/wxpython/menustrings.py:2031
+#: ../gui/wxpython/gui_core/toolbars.py:73
+msgid "Quit"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:74
+#: ../gui/wxpython/gui_core/toolbars.py:75
+msgid "Add raster map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:76 ../gui/wxpython/iclass/toolbars.py:49
+msgid "Add RGB map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:78
+msgid "Add HIS map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:80
+msgid "Add shaded relief map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:82
+msgid "Add raster flow arrows"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:84
+msgid "Add raster cell numbers"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:86
+#: ../gui/wxpython/gui_core/toolbars.py:77
+msgid "Add vector map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:88
+msgid "Add thematic area (choropleth) map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:90
+msgid "Add thematic chart layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:92
+msgid "Add grid layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:94
+msgid "Add geodesic line layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:96
+msgid "Add rhumbline layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:98 ../gui/wxpython/psmap/toolbars.py:104
+msgid "Add labels"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:100
+#: ../gui/wxpython/gui_core/simplelmgr.py:426
+#: ../gui/wxpython/gui_core/simplelmgr.py:427
+msgid "Add 3D raster map layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:101
+msgid "Note that 3D raster data are rendered only in 3D view mode"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:103
+msgid "Add WMS layer."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:107
+msgid "Editing mode"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:109
+msgid "Background vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:186
+msgid "Map Layers"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:402 ../gui/wxpython/menustrings.py:179
+#: ../gui/wxpython/menustrings.py:938 ../gui/wxpython/menustrings.py:1186
+#: ../gui/wxpython/menustrings.py:1865 ../gui/wxpython/rlisetup/frame.py:136
+msgid "Rename"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:420 ../gui/wxpython/iscatt/frame.py:540
+msgid "Change opacity level"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:424
+#: ../gui/wxpython/gmodeler/frame.py:1323
+msgid "Properties"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:430
+msgid "3D view properties"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:435
+msgid "Zoom to selected map(s)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:440
+msgid "Set computational region from selected map(s)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:454
+msgid "Export common formats"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:463
+msgid "Export PostGIS"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:472 ../gui/wxpython/lmgr/layertree.py:566
+msgid "Make a copy in the current mapset"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:477 ../gui/wxpython/lmgr/layertree.py:571
+#: ../gui/wxpython/lmgr/layertree.py:603
+msgid "Set color table"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:480
+msgid "Show attribute data"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:492
+msgid "Start editing"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:495
+msgid "Stop editing"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:511
+msgid "Rebuild topology"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:541 ../gui/wxpython/lmgr/layertree.py:595
+#: ../gui/wxpython/lmgr/layertree.py:611
+#: ../gui/wxpython/gmodeler/preferences.py:515
+msgid "Metadata"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:549
+msgid "Zoom to selected map(s) (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:551
+msgid "Set computational region from selected map(s) (ignore NULLs)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:574 ../gui/wxpython/menustrings.py:764
+#: ../gui/wxpython/menustrings.py:1691
+msgid "Histogram"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:579 ../gui/wxpython/lmgr/layertree.py:606
+#: ../gui/wxpython/menustrings.py:545 ../gui/wxpython/menustrings.py:1472
+msgid "Univariate raster statistics"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:584
+msgid "Report raster statistics"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:590
+msgid "Profile"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:618
+msgid "Save web service layer"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:722
+msgid "Unable to create profile of raster map."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:752
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for GRASS map. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:755 ../gui/wxpython/gis_set.py:985
+msgid "Invalid name"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:765 ../gui/wxpython/menustrings.py:2036
+#: ../gui/wxpython/psmap/dialogs.py:1144
+#: ../gui/wxpython/nviz/mapwindow.py:1672 ../gui/wxpython/nviz/tools.py:652
+msgid "Raster map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:768 ../gui/wxpython/menustrings.py:2038
+#: ../gui/wxpython/psmap/dialogs.py:2617 ../gui/wxpython/nviz/tools.py:1177
+msgid "Vector map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:771 ../gui/wxpython/nviz/tools.py:1529
+msgid "3D raster map"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:773
+#, python-format
+msgid "Unsupported map type <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:778
+#, python-format
+msgid "Enter name for the new %s in the current mapset:"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:779
+#, python-format
+msgid "Make a copy of %s <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:793
+#, python-format
+msgid ""
+"%s <%s> already exists in the current mapset. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:796
+#: ../gui/wxpython/gui_core/dialogs.py:422
+msgid "Overwrite?"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:803
+#, python-format
+msgid "Unable to make copy of <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:810
+#, python-format
+msgid "Unable to make copy of <%s>. Mapset <%s> is not current mapset."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:827
+msgid "Unable to display histogram of raster map. No map name defined."
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:871 ../gui/wxpython/mapdisp/frame.py:266
+#, python-format
+msgid ""
+"Unable to start wxGUI vector digitizer.\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:928
+#: ../gui/wxpython/gui_core/simplelmgr.py:259
+#, python-format
+msgid "Set opacity of <%s>"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1031
+msgid "Layer group:"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1036
+#: ../gui/wxpython/lmgr/layertree.py:1519
+msgid "Click to edit layer settings"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1088
+msgid "(double click to set properties)"
+msgstr ""
+#: ../gui/wxpython/lmgr/layertree.py:1323
+msgid "Please wait, updating data..."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:90
+msgid " Server settings "
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:93
+msgid "Server:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:97
+msgid "&Connect"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:98
+msgid "Connect to the server"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:102
+msgid "Show advanced connection settings"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:103
+msgid "Hide advanced connection settings"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:118
+msgid " Layer Manager Settings "
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:121
+msgid "Output layer name:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:132
+#: ../gui/wxpython/web_services/dialogs.py:818
+#: ../gui/wxpython/gcp/manager.py:2410 ../gui/wxpython/vnet/dialogs.py:1188
+#: ../gui/wxpython/gui_core/dialogs.py:1665
+#: ../gui/wxpython/gui_core/dialogs.py:1969
+#: ../gui/wxpython/iscatt/dialogs.py:361
+msgid "Close dialog"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:236
+msgid "Username:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:240
+msgid "Password:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:281
+#: ../gui/wxpython/gui_core/gselect.py:1784
+msgid "No data source defined, settings are not saved."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:354
+#, python-format
+msgid "Connecting to <%s>..."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:420
+msgid "Available web services"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:428
+#, python-format
+msgid "Connected to <%s>"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:433
+#, python-format
+msgid "Unable to connect to <%s>"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:477
+msgid "Add web service layer"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:488
+msgid "Add selected web service layers as map layer into layer tree"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:581
+msgid "Web service layer properties"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:626
+msgid "&Apply"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:627
+#: ../gui/wxpython/psmap/dialogs.py:359 ../gui/wxpython/vdigit/dialogs.py:144
+msgid "Apply changes"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:631
+msgid "&OK"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:632
+#: ../gui/wxpython/vdigit/dialogs.py:148
+msgid "Apply changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:792
+msgid "Name for output raster map:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:798
+#: ../gui/wxpython/menustrings.py:223
+msgid "Region"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:807
+msgid "Overwrite existing raster map"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:811
+msgid "Choose named region:"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:820
+msgid "&Save layer"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:821
+msgid "Save web service layer as raster map"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:936
+msgid "Missing output raster."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:940
+msgid "Output map can be added only to current mapset."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:944
+#, python-format
+msgid "Output map <%s> already exists"
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:965
+#, python-format
+msgid "Region <%s> does not exists."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:989
+msgid "Downloading data..."
+msgstr ""
+#: ../gui/wxpython/web_services/dialogs.py:1016
+msgid "Unable to fetch data.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:140
+msgid " Requested data settings "
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:150
+msgid "Request"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:155
+msgid "List of layers "
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:171
+msgid "Source projection:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:216
+msgid "Advanced request settings"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:223
+msgid "Order of layers in raster"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:226
+#: ../gui/wxpython/psmap/dialogs.py:1313 ../gui/wxpython/psmap/dialogs.py:2635
+msgid "Up"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:227
+#: ../gui/wxpython/psmap/dialogs.py:1314 ../gui/wxpython/psmap/dialogs.py:2636
+msgid "Down"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:233
+msgid "Reprojection method:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:237
+msgid "Nearest neighbor"
+msgstr ""
+msgid "Linear interpolation"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:238
+msgid "Cubic interpolation"
+msgstr ""
+msgid "Cubic spline interpolation"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:241
+msgid "Maximum columns to request from server at time:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:245
+msgid "Maximum rows to request from server at time:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:260
+msgid "Do not request transparent data"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:273
+msgid "Additional query parameters for server:"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:475
+#, python-format
+msgid ""
+"Unable to download %s capabilities file\n"
+"from <%s>:\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:489
+#, python-format
+msgid ""
+"%s web service was not found in fetched capabilities file from <%s>:\n"
+"%s\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:763
+msgid "Source image format"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:796
+msgid "Select layer in layer list.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:801
+msgid "Select source image format.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:806
+msgid "Select source projection.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:810
+msgid "Choose output layer name.\n"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:850
+#: ../gui/wxpython/gmodeler/frame.py:1432
+#: ../gui/wxpython/gmodeler/frame.py:1476
+#: ../gui/wxpython/gui_core/ghelp.py:343 ../gui/wxpython/gui_core/ghelp.py:345
+#: ../gui/wxpython/gui_core/ghelp.py:408
+msgid "Name"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:853
+#: ../gui/wxpython/gui_core/dialogs.py:1616
+msgid "Layer name"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:889
+msgid "layer"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:909
+msgid "style"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:1080
+msgid "Add default servers"
+msgstr ""
+#: ../gui/wxpython/web_services/widgets.py:1097
+#, python-format
+msgid ""
+"User defined server with same name as default server <%s> already exists.\n"
+"Keeping user defined server"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:39
+msgid "Fetch & install extension from GRASS Addons"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:50
+msgid "Repository"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:52
+msgid "List of extensions - double-click to install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:68
+#: ../gui/wxpython/gui_core/dialogs.py:1626
+msgid "Options"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:95
+msgid "&Fetch"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:96
+msgid "Fetch list of available modules from GRASS Addons SVN repository"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:100
+msgid "&Install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:101
+msgid "Install selected add-ons GRASS module"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:104
+msgid "Show g.extension manual page"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:168
+msgid "Extension not defined"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:191
+msgid "Fetching list of modules from GRASS-Addons SVN (be patient)..."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:210
+msgid "Install"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:213
+msgid "Show manual page"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:312
+#, python-format
+msgid "Unable to load extensions. %s"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:353
+msgid "Manage installed GRASS Addons extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:362
+msgid "List of installed extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:368
+msgid "Uninstall selected AddOns extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:370
+msgid "Reinstall selected AddOns extensions"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:407
+msgid "No extension selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:424
+#, python-format
+msgid ""
+"List of files to be removed:\n"
+"%(files)s\n"
+"\n"
+"Do you want really to remove <%(ext)s> extension?"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:427
+msgid "Remove extension"
+msgstr ""
+#: ../gui/wxpython/modules/extensions.py:458
+msgid "Extension"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:31 ../gui/wxpython/modules/vclean.py:113
+msgid "Set up vector cleaning tools"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:68
+msgid "break lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:69
+msgid "remove duplicates"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:70
+msgid "remove dangles"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:71
+msgid "change boundary dangles to lines"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:72
+msgid "remove bridges"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:73
+msgid "change bridges to lines"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:74
+msgid "snap lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:75
+msgid "remove duplicate area centroids"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:76
+msgid "break polygons"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:77
+msgid "prune lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:78
+msgid "remove small areas"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:79
+msgid "remove lines/boundaries of zero length"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:80
+msgid "remove small angles at nodes"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:115
+msgid "Choose cleaning tools and set thresholds"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:119
+msgid "Select input vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:125
+msgid " Feature type: "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:129
+msgid "Select output vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:137
+#: ../gui/wxpython/modules/mcalc_builder.py:231
+#: ../gui/wxpython/scripts/vkrige.py:137
+#: ../gui/wxpython/gmodeler/preferences.py:529
+#: ../gui/wxpython/gui_core/dialogs.py:1652
+#: ../gui/wxpython/gui_core/preferences.py:816
+msgid "Allow output files to overwrite existing files"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:158
+#: ../gui/wxpython/modules/mcalc_builder.py:135
+#: ../gui/wxpython/scripts/vkrige.py:151
+#: ../gui/wxpython/gmodeler/frame.py:1665
+#: ../gui/wxpython/gmodeler/model.py:2535 ../gui/wxpython/gui_core/menu.py:156
+#: ../gui/wxpython/gui_core/forms.py:502
+msgid "&Run"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:161
+msgid "Copy the current command string to the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:196 ../gui/wxpython/psmap/utils.py:94
+msgid "point"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:197
+msgid "line"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:198
+msgid "boundary"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:199
+msgid "centroid"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:200
+#: ../gui/wxpython/vdigit/preferences.py:433
+msgid "area"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:201
+msgid "face"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:353
+#, python-format
+msgid "%s. cleaning tool removed, will be ignored"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:355
+msgid "Please select a cleaning tool to remove"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:376
+#, python-format
+msgid "%s. cleaning tool moved up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:378
+msgid "1. cleaning tool can not be moved up "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:380
+msgid "Please select a cleaning tool to move up"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:402
+#, python-format
+msgid "%s. cleaning tool moved down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:404
+msgid "Last cleaning tool can not be moved down "
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:406
+msgid "Please select a cleaning tool to move down"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:417
+#, python-format
+msgid "cleaning tool: '%s'"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:425
+#, python-format
+msgid "Threshold for %(num)s. tool '%(tool)s': %(thresh)s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:453
+msgid "Name of input vector map"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:454
+msgid "Name for output vector map"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:456
+msgid "Threshold"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:458
+#, python-format
+msgid "'%s' not defined"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:460
+#, python-format
+msgid ""
+"Some parameters not defined. Operation canceled.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:465
+msgid "Executing selected cleaning operations..."
+msgstr ""
+#: ../gui/wxpython/modules/vclean.py:521
+msgid "Vector cleaning command copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:52
+msgid "GRASS GIS Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:55
+msgid "GRASS GIS 3D Raster Map Calculator"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:66
+msgid "mapcalc statement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:122
+msgid "Operators"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:124
+#: ../gui/wxpython/scripts/vkrige.py:113 ../gui/wxpython/vnet/dialogs.py:302
+msgid "Output"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:126
+msgid "Operands"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:128
+msgid "Expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:140
+msgid "Save expression to file"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:142
+#: ../gui/wxpython/gui_core/forms.py:1507
+msgid "&Load"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:143
+msgid "Load expression from file"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:145
+#: ../gui/wxpython/gui_core/forms.py:509
+msgid "Copy the current command string to the clipboard"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:149
+msgid "exponent"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:151
+msgid "divide"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:153
+msgid "add"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:155
+msgid "subtract"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:157
+msgid "modulus"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:159
+msgid "multiply"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:164
+msgid "left shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:166
+msgid "right shift"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:168
+msgid "right shift (unsigned)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:170
+msgid "greater than"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:172
+msgid "greater than or equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:174
+msgid "less than"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:176
+msgid "less than or equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:178
+msgid "equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:180
+msgid "not equal to"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:183
+msgid "one's complement"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:185
+msgid "NOT"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:187
+msgid "bitwise AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:189
+msgid "bitwise OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:191
+msgid "logical AND"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:193
+msgid "logical AND (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:195
+msgid "logical OR"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:197
+msgid "logical OR (ignores NULLs)"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:199
+msgid "conditional"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:212
+msgid "Name for new 3D raster map to create"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:214
+msgid "Name for new raster map to create"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:218
+msgid "Insert existing 3D raster map"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:220
+msgid "Insert existing raster map"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:224
+msgid "Insert mapcalc function"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:235
+msgid "Add created raster map into layer tree"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:508
+msgid "You must enter the name of a new raster map to create."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:518
+msgid "You must enter an expression to create a new raster map."
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:557
+msgid "Choose a file name to save the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:558
+#: ../gui/wxpython/modules/mcalc_builder.py:579
+msgid "Expression file (*)|*"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:578
+msgid "Choose a file name to load the expression"
+msgstr ""
+#: ../gui/wxpython/modules/mcalc_builder.py:613
+msgid "'{cmd}' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:74
+msgid "Check all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:77
+msgid "Clear all"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:133
+msgid "Enter vector attribute values"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:290
+msgid "Bad color format. Use color format '0:0:0'"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:381
+#: ../gui/wxpython/wxplot/dialogs.py:370
+msgid "Select raster map:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:383
+msgid "Select vector map:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:400
+msgid "Import or export color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:405
+msgid "Choose file to load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:406
+msgid "Load"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:407
+msgid "Type filename or click to choose file and load color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:413
+msgid "Choose file to save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:414
+msgid "Type filename or click to choose file and save color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:416 ../gui/wxpython/menustrings.py:9
+#: ../gui/wxpython/menustrings.py:1973
+msgid "Save"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:422
+msgid "&Set"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:429
+msgid "Load color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:433
+msgid "Load color table from file:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:436
+msgid "Save color table to file:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:465
+msgid "Reload default table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:523
+#: ../gui/wxpython/iclass/toolbars.py:66
+msgid "Preview"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:527
+msgid "Show preview of map (current Map Display extent is used)."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:557
+#: ../gui/wxpython/modules/colorrules.py:1714
+msgid "No valid color rules given."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:607
+#: ../gui/wxpython/gui_core/forms.py:1861
+msgid "Nothing to save."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:640
+msgid "Invalid color table format"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:717
+#, python-format
+msgid "Invalid rule value '%s'. Unable to apply color table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:795
+msgid "Create new color table for raster map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:871
+msgid "Enter raster category values or percents"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:875
+#: ../gui/wxpython/modules/colorrules.py:1497
+#: ../gui/wxpython/modules/colorrules.py:1500
+#: ../gui/wxpython/psmap/dialogs.py:2562
+msgid "range"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:877
+msgid "fp range"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:878
+#, python-format
+msgid "Enter raster category values or percents (%(range)s = %(min)d-%(max)d)"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:966
+msgid "Create new color rules for vector map"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:978
+#: ../gui/wxpython/modules/colorrules.py:1509
+msgid "Enter vector attribute values or percents:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:980
+#: ../gui/wxpython/modules/colorrules.py:1511
+msgid "Enter vector attribute values:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:991
+msgid "Select vector columns"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:993
+msgid "Layer:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:995
+msgid "Attribute column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:998
+msgid "Load color from column:"
+msgstr ""
+msgid "Save color to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1000
+msgid "Load size from column:"
+msgstr ""
+msgid "Save size to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1002
+msgid "Load width from column:"
+msgstr ""
+msgid "Save width to column:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1006
+msgid "Use color column instead of color table:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1021
+msgid "Add GRASSRGB column to current attribute table."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1076
+#: ../gui/wxpython/modules/colorrules.py:1125
+msgid "Import or export color table"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1137
+#, python-format
+msgid ""
+"Database connection for vector map <%s> is not defined in DB file. Do you "
+"want to create and connect new attribute table?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1140
+msgid "No database connection defined"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1212
+#, python-format
+msgid ""
+"Selected map <%(map)s> is not in current mapset <%(mapset)s>. Attribute "
+"table cannot be edited."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1365
+#, python-format
+msgid "%s column already exists."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1397
+msgid "Please wait, loading data from attribute table..."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1458
+#, python-format
+msgid ""
+"Number of loaded records reached %d, displaying all the records will be time-"
+"consuming and may lead to computer freezing, do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1462
+msgid "Too many records"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1504
+#, python-format
+msgid "Enter vector attribute values or percents %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1506
+#, python-format
+msgid "Enter vector attribute values %s:"
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1648
+msgid "Please select column to save values to."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1684
+msgid "No color column defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/modules/colorrules.py:1699
+msgid "Thematic mapping for vector map in 3D view"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:178
+#: ../gui/wxpython/mapwin/buffered.py:592
+msgid "Please wait, exporting image..."
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:269
+msgid "GRASS GIS Histogramming Tool (d.histogram)"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:374
+msgid "Select font for histogram text"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:449
+#: ../gui/wxpython/mapdisp/frame.py:668 ../gui/wxpython/wxplot/base.py:558
+#: ../gui/wxpython/gcp/mapdisplay.py:412 ../gui/wxpython/menustrings.py:2019
+#: ../gui/wxpython/psmap/toolbars.py:69
+msgid "Page setup"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:453
+#: ../gui/wxpython/mapdisp/frame.py:672 ../gui/wxpython/wxplot/base.py:559
+#: ../gui/wxpython/gcp/mapdisplay.py:416
+msgid "Print preview"
+msgstr ""
+#: ../gui/wxpython/modules/histogram.py:457
+#: ../gui/wxpython/mapdisp/frame.py:676 ../gui/wxpython/wxplot/base.py:560
+#: ../gui/wxpython/gcp/mapdisplay.py:420
+#: ../gui/wxpython/gui_core/toolbars.py:67
+msgid "Print display"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:29
+msgid "Query raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:30
+msgid "Query selected raster/vector map(s)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:32
+msgid "Show/hide scale bar"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:34
+msgid "Show/hide legend"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:36
+msgid "Show/hide north arrow"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:38
+msgid "Analyze map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:39
+msgid "Measuring, profiling, histogramming, ..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:41
+msgid "Measure distance"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:43
+msgid "Measure area"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:45
+msgid "Profile surface map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:47
+msgid "Create bivariate scatterplot of raster maps"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:49
+#: ../gui/wxpython/mapdisp/frame.py:1152
+msgid "Add text layer"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:51
+msgid "Create histogram of raster map"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:53 ../gui/wxpython/menustrings.py:651
+#: ../gui/wxpython/menustrings.py:1578
+msgid "Vector network analysis tool"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:58
+msgid "Rotate 3D scene"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:59
+msgid "Drag with mouse to rotate 3D scene"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:61
+#: ../gui/wxpython/nviz/preferences.py:209
+msgid "Fly-through mode"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:62
+msgid ""
+"Drag with mouse, hold Ctrl down for different mode or Shift to accelerate"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:64
+msgid "Click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:65
+msgid "Click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:93
+msgid "3D view mode not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:94
+#: ../gui/wxpython/mapdisp/toolbars.py:108
+#, python-format
+msgid "Reason: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:99 ../gui/wxpython/mapdisp/frame.py:476
+#: ../gui/wxpython/vdigit/toolbars.py:898
+msgid "Digitize"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:107
+msgid "Vector digitizer not available"
+msgstr ""
+#: ../gui/wxpython/mapdisp/toolbars.py:109
+msgid ""
+"Note that the wxGUI's vector digitizer is currently disabled (hopefully this "
+"will be fixed soon). Please keep an eye out for updated versions of GRASS. "
+"In the meantime you can use \"v.digit\" from the Develop Vector menu."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:70
+msgid "GRASS GIS - Map display"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:248
+#, python-format
+msgid ""
+"GRASS GIS %(version)s Map Display: %(id)s - Location: %(loc)s@%(mapset)s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:304
+msgid "Vector Digitizer Toolbar"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:325
+#, python-format
+msgid ""
+"Unable to switch to 3D display mode.\n"
+"The Nviz python extension was not found or loaded properly.\n"
+"Switching back to 2D display mode.\n"
+"\n"
+"Details: %s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:351
+msgid "Starting 3D view mode..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:352
+msgid "Please wait, loading data..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:424
+msgid "Please wait, unloading data..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:426
+msgid "Switching back to 2D view mode..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:737
+#, python-format
+msgid "Vector map <%s> opened for editing - skipped."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:743
+msgid "No raster or vector map layer selected for querying."
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1249 ../gui/wxpython/gcp/mapdisplay.py:463
+msgid "Zoom to default region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1250 ../gui/wxpython/gcp/mapdisplay.py:467
+msgid "Zoom to saved region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1252
+msgid "Set computational region from display extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1253
+msgid "Set computational region from named region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1255 ../gui/wxpython/gcp/mapdisplay.py:475
+msgid "Save display geometry to named region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/frame.py:1256
+msgid "Save computational region to named region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/gprint.py:150
+msgid ""
+"There was a problem printing.\n"
+"Perhaps your current printer is not set correctly?"
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:121
+#, python-format
+msgid "Unsupported command %s."
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:183
+#, python-format
+msgid "Unable to read cmdfile '%(cmd)s'. Details: %(det)s"
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:436
+#, python-format
+msgid "Starting map display <%s>..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/main.py:447
+#, python-format
+msgid "Stopping map display <%s>..."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:395
+msgid "Render"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:399
+msgid "Enable/disable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:429
+msgid "Show comp. extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:433
+msgid "Show computational extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:436
+msgid ""
+"Show/hide computational region extent (set with g.region). Display region "
+"drawn as a blue box inside the computational region, computational region "
+"inside a display region as a red box)."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:484
+msgid "Display mode"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:488
+#: ../gui/wxpython/gui_core/preferences.py:671
+msgid "Align region extent based on display size"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:491
+msgid ""
+"Align region extent based on display size from center point. Default value "
+"for new map displays can be set up in 'User GUI settings' dialog."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:524
+msgid "Display resolution"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:527
+#: ../gui/wxpython/gui_core/preferences.py:684
+msgid "Constrain display resolution to computational settings"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:530
+msgid ""
+"Constrain display resolution to computational region settings. Default value "
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:567
+msgid "Map scale"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:581
+msgid ""
+"As everyone's monitors and resolutions are set differently these values are "
+"not true map scales, but should get you into the right neighborhood."
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:634
+msgid "Go to"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:655
+#: ../gui/wxpython/mapdisp/statusbar.py:719
+#: ../gui/wxpython/mapdisp/statusbar.py:925
+#: ../gui/wxpython/mapdisp/statusbar.py:991
+msgid "Projection not defined (check the settings)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:733
+#: ../gui/wxpython/mapdisp/statusbar.py:938
+#: ../gui/wxpython/mapdisp/statusbar.py:1021
+msgid "Error in projection (check the settings)"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:765
+#: ../gui/wxpython/gui_core/preferences.py:1192
+msgid "Projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:767
+msgid "Use defined projection"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:779
+msgid ""
+"Reproject coordinates displayed in the statusbar. Projection can be defined "
+"in GUI preferences dialog (tab 'Projection')"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:804
+msgid "MASK"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:848
+msgid "Display geometry"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:870
+msgid "Coordinates"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:950
+msgid "Extent"
+msgstr ""
+#: ../gui/wxpython/mapdisp/statusbar.py:1045
+msgid "Computational region"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:129
+msgid "Map window test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:148
+msgid "Map display test"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:157
+msgid "Map window API test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:187
+msgid "Map window distance measurement test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:218
+msgid "Map window profile tool test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:265
+msgid "Map window rlisetup test frame"
+msgstr ""
+#: ../gui/wxpython/mapdisp/test_mapdisp.py:326
+#, python-format
+msgid "Unknown value %s of test parameter."
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:44
+msgid "GRASS Bivariate Scatterplot Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:51
+msgid "Bivariate Scatterplot"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:52 ../gui/wxpython/wxplot/scatter.py:53
+#: ../gui/wxpython/wxplot/histogram.py:52
+#: ../gui/wxpython/wxplot/histogram.py:138
+msgid "Raster cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:85 ../gui/wxpython/wxplot/scatter.py:230
+msgid "Nothing to plot."
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:95
+msgid "At least 2 raster maps must be specified"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:116
+msgid "Bivariate Scatterplot of "
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:134 ../gui/wxpython/wxplot/scatter.py:135
+#, python-format
+msgid "Raster <%s> cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:139 ../gui/wxpython/wxplot/scatter.py:143
+#, python-format
+msgid ": %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:236
+msgid "Regression Statistics for Scatterplot(s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/scatter.py:248
+#, python-format
+msgid ""
+"Regression equation for raster map <%(rast1)s> vs. <%(rast2)s>:\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:39
+msgid "Draw/re-draw plot"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:41
+msgid "Draw transect in map display window to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:43
+msgid "Plot options"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:45
+msgid "Plot statistics"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:47
+msgid "Save profile data to CSV file"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:48
+msgid "Quit plot tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:439
+msgid "Left Mouse Down at Point:"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:466 ../gui/wxpython/wxplot/base.py:532
+#: ../gui/wxpython/wxplot/dialogs.py:556
+msgid "Text settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:470 ../gui/wxpython/wxplot/base.py:546
+#: ../gui/wxpython/wxplot/dialogs.py:823
+msgid "Plot settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:483
+msgid "This feature is not yet functional"
+msgstr ""
+#: ../gui/wxpython/wxplot/base.py:484
+msgid "Under Construction"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:35
+msgid "Select raster maps to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:64
+msgid "Select raster map(s) to profile:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:106
+msgid "Select pairs of raster maps for scatterplots"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:142
+msgid "Select pairs of raster maps for bivariate scatterplots:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:157 ../gui/wxpython/wxplot/dialogs.py:404
+msgid "Number of bins (for FP maps)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:241
+msgid "Statistics"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:292
+msgid "C&opy"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:293
+msgid "Copy regression statistics the clipboard (Ctrl+C)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:322
+msgid "Regression statistics copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:331
+msgid "Select raster map or imagery group to histogram"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:357
+msgid "Histogram single raster"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:358
+msgid "Histogram imagery group"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:389
+msgid "Select image group:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:415
+msgid "Histogram type"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:494
+msgid "Selected group must be in current mapset"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:563
+msgid "Profile title:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:573
+msgid "Title font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:584
+msgid "X-axis label:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:594
+msgid "Y-axis label:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:604
+msgid "Label font size (pts):"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:619
+#: ../gui/wxpython/gui_core/preferences.py:376
+#: ../gui/wxpython/gui_core/preferences.py:574
+#: ../gui/wxpython/gui_core/preferences.py:1538
+#: ../gui/wxpython/psmap/dialogs.py:2788 ../gui/wxpython/psmap/dialogs.py:3265
+#: ../gui/wxpython/psmap/dialogs.py:3721
+msgid "Font settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:626
+msgid "Font family:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:640
+msgid "Style:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:654
+msgid "Weight:"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:685
+#: ../gui/wxpython/wxplot/dialogs.py:1134 ../gui/wxpython/gcp/manager.py:2406
+#: ../gui/wxpython/vnet/dialogs.py:1184
+#: ../gui/wxpython/gui_core/preferences.py:90
+#: ../gui/wxpython/iscatt/dialogs.py:357
+msgid "Apply changes for the current session"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:687
+#: ../gui/wxpython/wxplot/dialogs.py:1135
+msgid "Apply changes for the current session and close dialog"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:690
+#: ../gui/wxpython/wxplot/dialogs.py:1136 ../gui/wxpython/gcp/manager.py:2408
+#: ../gui/wxpython/vnet/dialogs.py:1186
+#: ../gui/wxpython/gui_core/preferences.py:92
+#: ../gui/wxpython/iscatt/dialogs.py:359
+msgid ""
+"Apply and save changes to user settings file (default for next sessions)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:692
+#: ../gui/wxpython/wxplot/dialogs.py:1137
+#: ../gui/wxpython/gmodeler/preferences.py:539
+#: ../gui/wxpython/gui_core/preferences.py:95
+#: ../gui/wxpython/psmap/dialogs.py:355
+#: ../gui/wxpython/vdigit/preferences.py:62
+msgid "Close dialog and ignore changes"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:743
+#, python-format
+msgid "Plot text sizes saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:801
+msgid "No map or image group selected to plot."
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:843
+msgid "Map/image plotted"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:855
+msgid "Settings for selected map"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:871
+msgid "Line color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:878
+#: ../gui/wxpython/vdigit/preferences.py:134
+msgid "Line width"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:888 ../gui/wxpython/psmap/dialogs.py:2115
+#: ../gui/wxpython/psmap/dialogs.py:4897
+msgid "Line style"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:897 ../gui/wxpython/wxplot/dialogs.py:940
+#: ../gui/wxpython/wxplot/dialogs.py:990 ../gui/wxpython/psmap/toolbars.py:88
+msgid "Legend"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:912
+msgid "Transect segment marker settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:917 ../gui/wxpython/wxplot/dialogs.py:967
+#: ../gui/wxpython/gmodeler/preferences.py:90
+#: ../gui/wxpython/gmodeler/preferences.py:328
+#: ../gui/wxpython/gmodeler/preferences.py:413
+#: ../gui/wxpython/iclass/dialogs.py:357 ../gui/wxpython/psmap/dialogs.py:4597
+#: ../gui/wxpython/psmap/dialogs.py:4852 ../gui/wxpython/nviz/tools.py:788
+#: ../gui/wxpython/nviz/tools.py:2399
+msgid "Color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:923 ../gui/wxpython/wxplot/dialogs.py:973
+#: ../gui/wxpython/psmap/dialogs.py:1996 ../gui/wxpython/psmap/dialogs.py:2707
+#: ../gui/wxpython/psmap/dialogs.py:3471
+msgid "Size"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:932 ../gui/wxpython/wxplot/dialogs.py:982
+#: ../gui/wxpython/psmap/dialogs.py:1796 ../gui/wxpython/psmap/dialogs.py:1900
+msgid "Fill"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:947 ../gui/wxpython/wxplot/dialogs.py:997
+#: ../gui/wxpython/psmap/dialogs.py:3524
+msgid "Style"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:962
+msgid "Scatterplot points"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1013
+msgid "Axis settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1019
+msgid "X-Axis"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1020
+msgid "Y-Axis"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1029
+msgid "Scale"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1033
+msgid ""
+"Automatic axis scaling, custom max and min, or scale matches data range (min)"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1038
+msgid "Custom min"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1046
+msgid "Custom max"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1054
+msgid "Log scale"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1078
+msgid "Grid and Legend settings"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1083
+msgid "Grid color"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1090
+msgid "Show grid"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1096
+msgid "Legend font size"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1106
+msgid "Show legend"
+msgstr ""
+#: ../gui/wxpython/wxplot/dialogs.py:1246
+#, python-format
+msgid "Plot settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:43
+msgid "GRASS GIS Histogramming Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:51
+msgid "Histogram of"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:53
+#: ../gui/wxpython/wxplot/histogram.py:143
+msgid "Cell counts"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:124
+#, python-format
+msgid "Histogram of image group <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:127
+#, python-format
+msgid "Histogram of raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:129
+msgid "Histogram of selected raster maps"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:136
+#, python-format
+msgid "Raster cell values %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:144
+msgid "Percent of total cells"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:145
+msgid "Area"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:228
+msgid "Statistics for Map(s) Histogrammed"
+msgstr ""
+#: ../gui/wxpython/wxplot/histogram.py:232
+#, python-format
+msgid "Statistics for raster map <%s>"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:34 ../gui/wxpython/nviz/wxnviz.py:32
+msgid ""
+"This module requires the NumPy module, which could not be imported. It "
+"probably is not installed (it's not part of the standard Python "
+"distribution). See the Numeric Python site (http://numpy.scipy.org) for "
+"information on downloading source or binaries."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:58
+msgid "GRASS Profile Analysis Tool"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:73 ../gui/wxpython/wxplot/profile.py:164
+msgid "Profile of"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:89
+#, python-format
+msgid "Distance (%s)"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:91
+msgid "Distance along transect"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:92
+msgid "Cell values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:157
+msgid "Not all points of profile lie inside computational region."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:224
+msgid "Raster values"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:275
+msgid "You must draw a transect to profile in the map display window."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:276
+msgid "Nothing to profile"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:338
+msgid "Choose prefix for file(s) where to save profile values..."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:340
+msgid "Comma separated value (*.csv)|*.csv"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:348
+#: ../gui/wxpython/gmodeler/frame.py:1751
+#, python-format
+msgid "File <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:350
+msgid "Overwrite file?"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:361
+#, python-format
+msgid ""
+"Unable to open file <%s> for writing.\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:373
+#, python-format
+msgid ""
+"%d files created:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:375
+msgid "No files generated."
+msgstr ""
+#: ../gui/wxpython/wxplot/profile.py:383
+msgid "Statistics for Profile(s)"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:172
+#: ../gui/wxpython/mapwin/decorations.py:219
+msgid ""
+"Please install Python Imaging Library (PIL)\n"
+"for better control of legend and other decorations."
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:321
+msgid "Show text object"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:331
+#: ../gui/wxpython/psmap/dialogs.py:3713
+msgid "Enter text:"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:348
+#: ../gui/wxpython/nviz/tools.py:1008
+msgid "Rotation:"
+msgstr ""
+#: ../gui/wxpython/mapwin/decorations.py:372
+msgid ""
+"Drag text with mouse in pointer mode to position.\n"
+"Double-click to change options"
+msgstr ""
+#: ../gui/wxpython/mapwin/graphics.py:247
+#: ../gui/wxpython/mapwin/graphics.py:368
+#, python-format
+msgid "Property does not exist: %s"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:218
+#: ../gui/wxpython/mapwin/analysis.py:330
+msgid "Measuring finished"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:233
+#: ../gui/wxpython/mapwin/analysis.py:340
+#, python-format
+msgid ""
+"Click and drag with left mouse button to measure.%sDouble click with left "
+"button to clear."
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:239
+msgid "Measuring distance"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:242
+msgid "Measuring distance:"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:250
+#, python-format
+msgid ""
+"Geodesic distance calculation is not available.\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:284
+#: ../gui/wxpython/mapwin/analysis.py:290
+msgid "segment"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:285
+#: ../gui/wxpython/mapwin/analysis.py:291
+msgid "total distance"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:286
+msgid "bearing"
+msgstr ""
+msgid "degrees (clockwise from grid-north)"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:344
+msgid "Measuring area:"
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:357
+msgid "Units not recognized, measurement failed."
+msgstr ""
+#: ../gui/wxpython/mapwin/analysis.py:362
+#: ../gui/wxpython/mapwin/analysis.py:364
+msgid "Area: {area} {unit}\n"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:152
+msgid "legend"
+msgstr ""
+msgid "scale bar"
+msgstr ""
+msgid "north arrow"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:231
+msgid "Copy coordinates to clipboard"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:241
+msgid "Hide {overlay}"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:248
+msgid "Resize legend"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:867
+msgid "Unable to draw registered graphics. The graphics was unregistered."
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1831
+msgid "Zoom to saved region extents"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1833
+msgid "Set compulational region from named region"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1845
+#, python-format
+msgid "Region <%s> not found. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1874
+msgid "Save display extents to region file"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1876
+msgid "Save computational region to region file"
+msgstr ""
+#: ../gui/wxpython/mapwin/buffered.py:1886
+#, python-format
+msgid "Region file <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:194
+#, python-format
+msgid ""
+"Error occured during calling of handler: %s \n"
+"Handler was unregistered."
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:273
+#, python-format
+msgid ""
+"Error occured during unregistration of handler: %s \n"
+" Handler was unregistered."
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:302
+#, python-format
+msgid "Handler: %s was not registered"
+msgstr ""
+#: ../gui/wxpython/mapwin/base.py:306
+#, python-format
+msgid ""
+" Handler was unregistered"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:136
+msgid "Setup for georectification"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:169 ../gui/wxpython/gcp/manager.py:173
+msgid "Georectifying setup canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:315
+msgid "Select map type and location/mapset"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:328
+msgid "Map type to georectify"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:329 ../gui/wxpython/gmodeler/frame.py:1445
+#: ../gui/wxpython/gui_core/dialogs.py:1314
+#: ../gui/wxpython/gui_core/dialogs.py:1545
+#: ../gui/wxpython/psmap/dialogs.py:696
+msgid "raster"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:329 ../gui/wxpython/gmodeler/frame.py:1446
+#: ../gui/wxpython/psmap/dialogs.py:697
+msgid "vector"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:336
+msgid "Select source location:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:345
+msgid "Select source mapset:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:399
+msgid "You must select a valid location before selecting a mapset"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:412
+msgid "You must select a valid location and mapset in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:431
+msgid "Select image/map group to georectify"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:449
+msgid "Select group:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:460
+msgid "Create group if none exists"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:464 ../gui/wxpython/iclass/dialogs.py:72
+msgid "Create/edit group..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:465
+msgid "Add vector map to group..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:477 ../gui/wxpython/gcp/manager.py:2665
+msgid "Extension for output maps:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:537
+msgid "You must select a valid image/map group in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:544
+msgid "You must enter an map name extension in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:610
+msgid "Select maps to display for ground control point (GCP) creation"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:618 ../gui/wxpython/gcp/manager.py:2601
+msgid "Select source map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:629 ../gui/wxpython/gcp/manager.py:2606
+msgid "Select target raster map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:640 ../gui/wxpython/gcp/manager.py:2611
+msgid "Select target vector map to display:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:703
+msgid "You must select a source map in order to continue"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:729 ../gui/wxpython/gcp/manager.py:759
+#, python-format
+msgid ""
+"No maps in selected group <%s>.\n"
+"Please edit group or select another group."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:787
+msgid "Manage Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1040
+#, python-format
+msgid "At least %d GCPs required. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1172
+msgid "source"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1174
+msgid "target"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1176
+msgid "Set GCP coordinates"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1177
+#, python-format
+msgid ""
+"Set %(coor)s coordinates for GCP No. %(key)s? \n"
+"\n"
+"East: %(coor0)s \n"
+"North: %(coor1)s"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1243
+msgid "Writing POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1252
+#, python-format
+msgid "POINTS file saved for group <%s>"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1267
+msgid "source mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1272
+msgid "target mapwin not defined"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1300
+msgid "Reading POINTS file failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1382
+msgid ""
+"Insufficient points defined and active (checked) for selected rectification "
+"method.\n"
+"3+ points needed for 1st order,\n"
+"6+ points for 2nd order, and\n"
+"10+ points for 3rd order."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1409
+msgid "Rectifying images, please wait..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1449
+#, python-format
+msgid "Transforming <%s>..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1453
+#, python-format
+msgid "Rectifying vector map <%s>, please wait..."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1486
+#, python-format
+msgid "Georectification of vector map <%s> failed"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1493
+msgid "GCP Manager settings"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1538
+msgid "Quit GCP Manager"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1539
+msgid "Save ground control points?"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1618
+msgid ""
+"Could not calculate RMS Error.\n"
+"Possible error with m.transform."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1742
+msgid ""
+"Could not calculate new extends.\n"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1871
+msgid "Adjust source display to target display"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1875
+msgid "Adjust target display to source display"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1948 ../gui/wxpython/gcp/manager.py:1965
+#: ../gui/wxpython/vnet/vnet_data.py:237 ../gui/wxpython/vnet/widgets.py:85
+msgid "use"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1949 ../gui/wxpython/gcp/manager.py:1966
+msgid "source E"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1950 ../gui/wxpython/gcp/manager.py:1967
+msgid "source N"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1951 ../gui/wxpython/gcp/manager.py:1968
+msgid "target E"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1952 ../gui/wxpython/gcp/manager.py:1969
+msgid "target N"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1953 ../gui/wxpython/gcp/manager.py:1970
+msgid "Forward error"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:1954 ../gui/wxpython/gcp/manager.py:1971
+msgid "Backward error"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2106
+msgid "Invalid coordinate value. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2150
+msgid "Create vector map group"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2223
+msgid "Select vector map(s) to add to group:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2270
+msgid "Edit GCP"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2281
+msgid "Ground Control Point No."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2300
+msgid "source E:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2301
+msgid "target E:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2302
+msgid "source N:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2303
+msgid "target N:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2432 ../gui/wxpython/psmap/dialogs.py:1954
+#: ../gui/wxpython/vdigit/preferences.py:84
+msgid "Symbology"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2440
+msgid "Highlight highest RMS error only"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2446
+msgid "Highlight RMS error > M + SD * factor:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2447
+msgid ""
+"Highlight GCPs with an RMS error larger than \n"
+"mean + standard deviation * given factor. \n"
+"Recommended values for this factor are between 1 and 2."
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2464
+msgid "Symbol settings"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2489
+msgid "Color for high RMS error:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2506
+msgid "Color for selected GCP:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2523
+msgid "Color for unused GCPs:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2539
+msgid "Show unused GCPs"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2548
+#: ../gui/wxpython/gui_core/preferences.py:1016
+msgid "Symbol size:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2632
+msgid "Rectification"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2638
+msgid "Select rectification order"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2639
+msgid "1st order"
+msgstr ""
+msgid "2nd order"
+msgstr ""
+msgid "3rd order"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2647
+msgid "Select interpolation method:"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2659
+msgid "clip to computational region in target location"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2699
+msgid "RMS threshold factor must be > 0"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2702
+msgid ""
+"RMS threshold factor is < 1\n"
+"Too many points might be highlighted"
+msgstr ""
+#: ../gui/wxpython/gcp/manager.py:2849
+#, python-format
+msgid "GCP Manager settings saved to file '%s'."
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:48
+msgid "GRASS GIS Manage Ground Control Points"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:163
+msgid "GCP List"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:168
+msgid "Source Display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:172
+msgid "Target Display"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:261
+msgid "GCP Display toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:274
+msgid "GCP Manager toolbar"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:459
+msgid "Zoom to computational region (set with g.region)"
+msgstr ""
+#: ../gui/wxpython/gcp/mapdisplay.py:471
+msgid "Set computational region from display"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:36
+msgid "Go to GCP No."
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:53
+msgid "Valid Range:"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:118
+msgid "RMS error"
+msgstr ""
+#: ../gui/wxpython/gcp/statusbar.py:122
+#, python-format
+msgid "Forward: %(forw)s, Backward: %(back)s"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:32
+msgid "No GRASS-python library found."
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:62
+msgid "Input Data"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:68
+msgid "Point dataset:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:80
+msgid "Numeric column:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:91
+msgid "Kriging"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:102 ../gui/wxpython/gmodeler/frame.py:129
+#: ../gui/wxpython/gui_core/forms.py:1777
+msgid "Command output"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:116
+msgid "Name for the output raster map:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:124
+msgid "Export variance map as well: "
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:276
+msgid "Kriging Module"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:280
+msgid "Ready."
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:304
+msgid "Variogram fitting"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:314
+msgid "Plot/refresh variogram"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:325
+msgid ":"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:350
+msgid "Kriging techniques"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:364
+msgid "Block size:"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:397
+msgid "Auto-fit variogram"
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:421
+msgid "Model: "
+msgstr ""
+#: ../gui/wxpython/scripts/vkrige.py:510
+msgid "Work in progress! No functionality provided."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:62
+msgid "GRASS GIS Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:125
+msgid "Model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:126
+msgid "Items"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:127
+#: ../gui/wxpython/gmodeler/model.py:2579
+msgid "Variables"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:128
+msgid "Python editor"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:198
+msgid "Python script contains local modifications"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:200
+#: ../gui/wxpython/gmodeler/frame.py:1812
+msgid "Python script is up-to-date"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:215
+msgid "Redrawing model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:251
+msgid "Do you want to save changes in the model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:253
+msgid "Do you want to store current model settings to model file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:259
+msgid "Quit Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:313
+msgid "No intermediate data to delete."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:317
+#, python-format
+msgid "Do you want to permanently delete data?%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:318
+msgid "Delete intermediate data?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:332
+#, python-format
+msgid "%d maps deleted from current mapset"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:347 ../gui/wxpython/gmodeler/frame.py:473
+msgid ""
+"Current model is not empty. Do you want to store current settings to model "
+"file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:350 ../gui/wxpython/gmodeler/frame.py:476
+msgid "Create new model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:388
+msgid "Choose model file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:406
+#, python-format
+msgid "%(items)d items (%(actions)d actions) loaded into model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:413 ../gui/wxpython/gmodeler/frame.py:450
+#, python-format
+msgid "Model file <%s> already exists. Do you want to overwrite this file?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:416 ../gui/wxpython/menustrings.py:1974
+msgid "Save model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:423 ../gui/wxpython/gmodeler/frame.py:463
+#, python-format
+msgid "File <%s> saved"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:432
+msgid "Choose file to save current model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:452 ../gui/wxpython/iclass/frame.py:1008
+msgid "File already exists"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:524
+msgid "Model is empty. Nothing to validate."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:528 ../gui/wxpython/gmodeler/model.py:583
+msgid "Validating model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:534
+#, python-format
+msgid ""
+"Model is not valid.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:537
+msgid "Model is valid."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:598 ../gui/wxpython/gmodeler/frame.py:605
+#, python-format
+msgid "Model exported to <%s>"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:734
+#: ../gui/wxpython/gmodeler/frame.py:1357
+#: ../gui/wxpython/gmodeler/dialogs.py:202
+msgid "Comment:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:734 ../gui/wxpython/menustrings.py:1999
+msgid "Add comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:739
+msgid "Empty comment. Nothing to add to the model."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:771
+msgid "wxGUI Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:866
+#, python-format
+msgid ""
+"Reading model file <%s> failed.\n"
+"Invalid file, unable to parse XML document.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:875
+msgid "Please wait, loading model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:941
+msgid "Writing current settings to model file failed."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1287
+msgid "Disable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1290
+msgid "Enable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1295
+#: ../gui/wxpython/gmodeler/frame.py:1345
+msgid "Set label"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1298
+msgid "Set comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1303
+msgid "Add control point"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1305
+msgid "Remove control point"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1312
+msgid "Intermediate"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:198
+msgid "Label:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1429
+msgid "List of variables - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1433
+#: ../gui/wxpython/gmodeler/frame.py:1489
+msgid "Default value"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1496
+#: ../gui/wxpython/location_wizard/wizard.py:351
+#: ../gui/wxpython/location_wizard/wizard.py:852
+#: ../gui/wxpython/location_wizard/wizard.py:1024
+#: ../gui/wxpython/location_wizard/wizard.py:1335
+msgid "Description"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1438
+msgid "Add new variable"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1442
+msgid "integer"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1443
+msgid "float"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1444
+msgid "string"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1447
+msgid "region"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1448
+msgid "mapset"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1449
+#: ../gui/wxpython/gui_core/forms.py:1479
+msgid "file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1456
+msgid "Add new variable to the model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1576
+msgid "List of items - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1579
+#: ../gui/wxpython/gmodeler/dialogs.py:436
+#: ../gui/wxpython/gmodeler/dialogs.py:539
+#: ../gui/wxpython/psmap/dialogs.py:2618
+msgid "Label"
+msgstr ""
+msgid "In loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1580
+#: ../gui/wxpython/gmodeler/dialogs.py:160
+#: ../gui/wxpython/gmodeler/dialogs.py:437
+#: ../gui/wxpython/gmodeler/dialogs.py:540
+#: ../gui/wxpython/gmodeler/preferences.py:85
+msgid "Command"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1628
+msgid "No items to selected."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1662
+msgid "Python script"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1666
+msgid "Run python script"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1669
+msgid "Save python script to file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1672
+msgid ""
+"Refresh python script based on the model.\n"
+"It will discards all local changes."
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1710
+#, python-format
+msgid "Unable to launch Python script. %s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1734
+msgid "Choose file to save"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1737
+msgid "Python script (*.py)|*.py"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1753
+msgid "Save file"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1788
+msgid ""
+"Python script is locally modificated. Refresh will discard all changes. Do "
+"you really want to continue?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/frame.py:1791
+msgid "Update"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:47
+msgid "Data properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:76
+#: ../gui/wxpython/iclass/dialogs.py:239
+msgid "Name of raster map:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:78
+#: ../gui/wxpython/iclass/dialogs.py:241
+#: ../gui/wxpython/gui_core/dialogs.py:211
+msgid "Name of vector map:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:81
+#: ../gui/wxpython/gmodeler/dialogs.py:94
+msgid "Name of element:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:89
+msgid "Type of element:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:141
+msgid "Add GRASS command to the model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:162
+msgid "Label and comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:254
+msgid ""
+"Command not defined.\n"
+"\n"
+"Unable to add new action to the model."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:260
+#, python-format
+msgid ""
+"'%s' is not a GRASS module.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:292
+msgid "Relation properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:309
+msgid "From"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:353
+#, python-format
+msgid "Data: %s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:359
+msgid "Command:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:365
+msgid "Option:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:380
+msgid ""
+"Relation doesn't start with data item.\n"
+"Unable to add relation."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:387
+msgid ""
+"Relation doesn't point to GRASS command.\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:400
+msgid ""
+"No relevant option found.\n"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:431
+msgid "Condition"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:457
+msgid "Loop properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:463
+msgid "List of items in loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:466
+msgid "Series"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:467
+msgid "Define map series as condition for the loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:511
+msgid "Define series of maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:526
+msgid "If-else properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:532
+msgid "List of items in 'if' block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:537
+msgid "List of items in 'else' block"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:700
+#, python-format
+msgid "Variable <%s> already exists in the model. Adding variable failed."
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:729
+msgid "Do you want to delete all variables from the model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:731
+msgid "Delete variables"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:770
+#: ../gui/wxpython/gmodeler/dialogs.py:921
+#: ../gui/wxpython/vdigit/dialogs.py:274
+msgid "Delete selected"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:771
+#: ../gui/wxpython/vdigit/dialogs.py:278
+msgid "Delete all"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:836
+#: ../gui/wxpython/location_wizard/wizard.py:776
+#: ../gui/wxpython/gui_core/gselect.py:1918
+msgid "No"
+msgstr ""
+#: ../gui/wxpython/gmodeler/dialogs.py:838
+#: ../gui/wxpython/gui_core/gselect.py:1920
+msgid "Yes"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:63
+msgid "model"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:64
+msgid "Script generated by wxGUI Graphical Modeler."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:460 ../gui/wxpython/gmodeler/model.py:522
+#, python-format
+msgid "undefined variable '%s'"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:555
+msgid "Running model..."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:574
+msgid "Model is empty. Nothing to run."
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:589
+#, python-format
+msgid ""
+"Model is not valid. Do you want to run the model anyway?\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:591
+msgid "Run model?"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:626
+msgid "Variables below not defined:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:736
+msgid "Raster maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:739
+msgid "3D raster maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:742 ../gui/wxpython/psmap/dialogs.py:1271
+msgid "Vector maps"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1397
+msgid "<not defined>"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1506
+msgid "Condition: "
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1508
+msgid "Condition: not defined"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:1627
+msgid "if-else"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2510
+msgid "Model parameters"
+msgstr ""
+#: ../gui/wxpython/gmodeler/model.py:2527
+msgid "Delete intermediate data when finish"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:29
+#: ../gui/wxpython/menustrings.py:1987
+msgid "Modeler settings"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:52
+msgid "Item properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:59
+msgid "Disabled:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:97
+#: ../gui/wxpython/gmodeler/preferences.py:335
+#: ../gui/wxpython/gmodeler/preferences.py:420
+msgid "Valid:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:114
+msgid "Invalid:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:131
+msgid "Running:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:152
+#: ../gui/wxpython/gmodeler/preferences.py:271
+#: ../gui/wxpython/gmodeler/preferences.py:356
+#: ../gui/wxpython/gmodeler/preferences.py:441
+msgid "Shape size"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:159
+#: ../gui/wxpython/gmodeler/preferences.py:278
+#: ../gui/wxpython/gmodeler/preferences.py:363
+#: ../gui/wxpython/gmodeler/preferences.py:448
+#: ../gui/wxpython/gui_core/dialogs.py:2369
+#: ../gui/wxpython/psmap/dialogs.py:2723
+#: ../gui/wxpython/nviz/preferences.py:476
+msgid "Width:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:177
+#: ../gui/wxpython/gmodeler/preferences.py:296
+#: ../gui/wxpython/gmodeler/preferences.py:381
+#: ../gui/wxpython/gmodeler/preferences.py:466
+#: ../gui/wxpython/gui_core/dialogs.py:2373
+#: ../gui/wxpython/psmap/dialogs.py:2735 ../gui/wxpython/psmap/dialogs.py:2873
+#: ../gui/wxpython/psmap/dialogs.py:3476 ../gui/wxpython/nviz/tools.py:284
+#: ../gui/wxpython/nviz/tools.py:1040 ../gui/wxpython/nviz/tools.py:1767
+msgid "Height:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:204
+#: ../gui/wxpython/nviz/tools.py:92
+msgid "Data"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:216
+msgid "Raster:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:233
+msgid "3D raster:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:250
+msgid "Vector:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:323
+msgid "Loop"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:408
+msgid "Comment"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:508
+#: ../gui/wxpython/menustrings.py:2003
+msgid "Model properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:517
+msgid "Commands"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:537
+msgid "Apply properties"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:558
+msgid "Description:"
+msgstr ""
+#: ../gui/wxpython/gmodeler/preferences.py:567
+msgid "Author(s):"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:38
+msgid "The Timeline Tool needs \"Matplotlib\" package to be installed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:70
+msgid "GRASS GIS Timeline Tool"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:126
+#: ../gui/wxpython/nviz/preferences.py:368 ../gui/wxpython/nviz/tools.py:675
+#: ../gui/wxpython/nviz/tools.py:1552
+msgid "Draw"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:128 ../gui/wxpython/menustrings.py:2012
+#: ../gui/wxpython/menustrings.py:2055
+msgid "Help"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:131
+msgid "3D plot of spatio-temporal extents"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:134
+msgid "3D plot of spatio-temporal extents (matplotlib >= 1.0.0)"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:139
+msgid "Select space time dataset(s):"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:162
+#, python-format
+msgid "Dataset <%s> not found in temporal database"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:174
+msgid ""
+"Datasets have different temporal type (absolute x relative), which is not "
+"allowed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:189
+msgid "Datasets have different time unit which is not allowed."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:264
+#, python-format
+msgid "X [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:265
+#, python-format
+msgid "Y [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:267
+msgid "X"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:268
+msgid "Y"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:325
+#, python-format
+msgid "Time [%s]"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:348 ../gui/wxpython/timeline/frame.py:439
+msgid "Invalid input data"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:412
+#, python-format
+msgid "Please specify the space time dataset <%s>."
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:413
+msgid "Ambiguous dataset name"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:491
+#, python-format
+msgid "Space time raster dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:493
+#, python-format
+msgid "Space time vector dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:495
+#, python-format
+msgid "Space time 3D raster dataset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:497
+#, python-format
+msgid "Mapset: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:498
+#, python-format
+msgid "Map name: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:499
+#, python-format
+msgid "Start time: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:500
+#, python-format
+msgid "End time: %s"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:503
+msgid "WARNING: invalid topology"
+msgstr ""
+#: ../gui/wxpython/timeline/frame.py:505
+msgid ""
+"\n"
+"Press Del to dismiss."
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:50
+msgid "Insert points from Map Display"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:52
+msgid "Activate snapping to nodes"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:54
+msgid "Activate mode for turns editing"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:56
+msgid "Activate mode for global turns editing"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:58
+msgid "Add new point"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:60
+msgid "Delete selected point"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:110
+msgid "Execute analysis"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:112
+msgid "Go to previous analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:114
+msgid "Go to next analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:116
+msgid "Show analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:118
+msgid "Save temporary result"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:119
+msgid "Vector network analysis settings"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:121
+#: ../gui/wxpython/gui_core/toolbars.py:71
+#: ../gui/wxpython/iscatt/toolbars.py:46
+msgid "Show manual"
+msgstr ""
+#: ../gui/wxpython/vnet/toolbars.py:184
+msgid "Availiable analyses"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:144
+#, python-format
+msgid "Module <%s> does not support turns costs."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:150
+#, python-format
+msgid "Vector map '%s' does not exist."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:152
+msgid "Vector map was not chosen."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:161
+msgid "arc layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:162
+msgid "node layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:163
+msgid "turntable layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:164
+msgid "unique categories layer"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:170
+#, python-format
+msgid "Chosen %s '%s' does not exist in vector map '%s'.\n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:173
+#, python-format
+msgid "Choose existing %s.\n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:183
+#, python-format
+msgid ""
+"Chosen column '%s' does not exist in attribute table of layer '%s' of vector "
+"map '%s'.\n"
+msgstr ""
+msgid "type"
+msgstr ""
+msgid "topology"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:238 ../gui/wxpython/vnet/vnet_data.py:684
+msgid "Start point"
+msgstr ""
+msgid "End Point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:491 ../gui/wxpython/vnet/vnet_data.py:500
+#: ../gui/wxpython/vnet/vnet_data.py:503
+msgid "new point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:661
+msgid "Arc forward/both direction(s) cost column:"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:662
+msgid "arc forward/both"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:665
+msgid "Arc backward direction cost column:"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:666
+msgid "arc backward"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:669
+msgid "Arcs' cost column (for both directions):"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:670
+msgid "arc"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:674
+msgid "Node cost column:"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:675
+msgid "node"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:681
+#, python-format
+msgid "Shortest path %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:685
+msgid "End point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:701
+#, python-format
+msgid "Traveling salesman %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:717
+#, python-format
+msgid "Maximum flow %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:720
+msgid "Source point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:721
+msgid "Sink point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:736
+#, python-format
+msgid "Subnets for nearest centers %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:752
+#, python-format
+msgid "Steiner tree for the network and given terminals %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:766
+#, python-format
+msgid "Shortest distance via the network %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:785
+#, python-format
+msgid "Cost isolines %s"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_data.py:871
+msgid "Overwrite map layer"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:67
+msgid "GRASS GIS Vector Network Analysis Tool"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:165
+msgid "Point list toolbar"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:172
+msgid "Analysis toolbar"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:203
+msgid "Points for analysis:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:206
+msgid "Points"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:219
+msgid "Analysis settings:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:222
+msgid "Maximum distance of point to the network:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:234
+msgid "Iso lines:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:319
+msgid "Parameters"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:350
+msgid "Add vector map into layer tree"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:469
+msgid "Input tables"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:495
+msgid "Result tables"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:507
+msgid "Loading tables..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:640
+msgid "Creating turntable..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:793
+msgid "Input vector map does not exists."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:811
+msgid "Analysing..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:867 ../gui/wxpython/gui_core/toolbars.py:84
+#: ../gui/wxpython/gui_core/widgets.py:997
+#: ../gui/wxpython/iscatt/toolbars.py:44
+#: ../gui/wxpython/iscatt/toolbars.py:135 ../gui/wxpython/nviz/tools.py:1892
+msgid "Settings"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:934
+msgid "Computing nodes..."
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1129
+#, python-format
+msgid "Color table style %s:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1140
+#, python-format
+msgid "Invert colors %s:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1145
+msgid "Line color:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1146
+msgid "Color for unused point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1147
+msgid "Color for Start/From/Source/Used point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1148
+msgid "Color for End/To/Sink point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1149
+msgid "Color for selected point:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1163
+msgid "Point size:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1164
+msgid "Point width:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1165 ../gui/wxpython/iscatt/dialogs.py:338
+msgid "Snapping treshold in pixels:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1166
+msgid "Maximum number of results in history:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1198
+msgid "Analysis result style:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1228
+msgid "Point style:"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1250
+msgid "Other settings"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1325
+msgid "New vector map with turntable"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1464
+msgid "Save analysis result"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1575
+msgid "Edit intersection turns costs"
+msgstr ""
+#: ../gui/wxpython/vnet/dialogs.py:1607
+msgid "Define Global Turn Costs"
+msgstr ""
+#: ../gui/wxpython/vnet/widgets.py:373
+msgid "Invalid value inserted. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vnet/widgets.py:519
+msgid "Edit point"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:105
+msgid "Unable to perform analysis."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:210
+#, python-format
+msgid "Temporary map '%s' with result "
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:215
+msgid "Result changed outside"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:252
+msgid "Map can be created only in current mapset"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:259 ../gui/wxpython/vnet/vnet_core.py:336
+#, python-format
+msgid "Vector map %s already exists. "
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:262 ../gui/wxpython/vnet/vnet_core.py:339
+msgid "Overwrite vector map"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:288
+msgid "Creation of turntable failed."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:308
+msgid "Vector map with analysis result does not exist."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:329
+msgid "Map can be saved only to currently set mapset"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:408 ../gui/wxpython/vnet/vnet_core.py:608
+#, python-format
+msgid "Please choose '%s' and '%s' point."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:615
+msgid "Please choose at least two points."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:894
+#, python-format
+msgid "Input map '%s' for analysis was changed outside "
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:899
+msgid "Input changed outside"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:974
+#, python-format
+msgid "Temporary map %s already exists.\n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1000
+msgid "Unable to use ctypes. \n"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1001
+#: ../gui/wxpython/vnet/vnet_core.py:1023
+msgid "Snapping mode can not be activated."
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1032
+msgid "Do you really want to activate snapping and overwrite it?"
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1039
+#, python-format
+msgid "Temporary map '%s' was changed outside "
+msgstr ""
+#: ../gui/wxpython/vnet/vnet_core.py:1044
+msgid "Overwrite map"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:36
+msgid "Set default region extent and resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:83
+msgid "&Set region"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:113
+msgid "Invalid location selected."
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:130
+msgid "Invalid region"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:160
+msgid "Click here to show 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:161
+msgid "Click here to hide 3D settings"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:184
+#: ../gui/wxpython/location_wizard/dialogs.py:466
+#, python-format
+msgid "Rows: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:185
+#: ../gui/wxpython/location_wizard/dialogs.py:467
+#, python-format
+msgid "Cols: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:186
+#: ../gui/wxpython/location_wizard/dialogs.py:468
+#, python-format
+msgid "Cells: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:228
+#: ../gui/wxpython/location_wizard/dialogs.py:470
+#, python-format
+msgid "Depth: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:229
+#: ../gui/wxpython/location_wizard/dialogs.py:471
+#, python-format
+msgid "3D Cells: %d"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:232
+#: ../gui/wxpython/psmap/dialogs.py:385
+msgid "Top"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:240
+msgid "Bottom"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:248
+msgid "T-B resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:311
+msgid "North"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:319
+msgid "West"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:339
+msgid "East"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:348
+msgid "South"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:352
+msgid "N-S resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:360
+msgid "E-W resolution"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:438
+#, python-format
+msgid "Invalid value: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:522
+msgid "Select datum transformation"
+msgstr ""
+#: ../gui/wxpython/location_wizard/dialogs.py:547
+msgid "Select from list of datum transformations"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:95
+msgid "Define GRASS Database and Location Name"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:111
+#: ../gui/wxpython/gis_set.py:119
+msgid "GIS Data Directory:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:127
+msgid "Project Location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:128
+msgid "Name of location directory in GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:139
+msgid "Location Title"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:140
+msgid "Optional location title, you can leave this field blank."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:160
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for location. Please use only ASCII "
+"characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:163
+msgid "Invalid location name"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:178
+msgid "Choose GRASS data directory:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:189
+#: ../gui/wxpython/location_wizard/wizard.py:2059
+msgid "Location already exists in GRASS Database."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:193
+msgid "Unable to create location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:206
+msgid ""
+"Title of the location is limited only to one line and 256 characters. The "
+"rest of the text will be ignored."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:213
+msgid "Choose method for creating a new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:220
+msgid "Select coordinate system parameters from a list"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:223
+msgid "Select EPSG code of spatial reference system"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:225
+msgid "Read projection and datum terms from a georeferenced data file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:228
+msgid "Read projection and datum terms from a Well Known Text (WKT) .prj file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:231
+msgid "Specify projection and datum terms using custom PROJ.4 parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:234
+msgid "Create a generic Cartesian coordinate system (XY)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:335
+msgid "Choose projection"
+msgstr ""
+msgid "Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:355
+msgid "Projection code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:363
+#: ../gui/wxpython/location_wizard/wizard.py:865
+#: ../gui/wxpython/location_wizard/wizard.py:1041
+msgid "Search in description:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:538
+#, python-format
+msgid "Unable to read list: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:641
+msgid "Choose projection parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:655
+msgid "Select datum or ellipsoid (next page)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:662
+msgid "Datum with associated ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:665
+msgid "Ellipsoid only"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:722
+#, python-format
+msgid "You must enter a value for %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:734
+#: ../gui/wxpython/location_wizard/wizard.py:753
+#, python-format
+msgid " Enter parameters for %s projection "
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:830
+msgid "Specify geodetic datum"
+msgstr ""
+msgid "Ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:856
+msgid "Datum code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:995
+msgid "Specify ellipsoid"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1012
+msgid "Earth based"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1015
+msgid "Planetary bodies"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1029
+msgid "Ellipsoid code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1161
+#: ../gui/wxpython/location_wizard/wizard.py:1221
+msgid "Select georeferenced file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1166
+msgid "Georeferenced file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1235
+#: ../gui/wxpython/location_wizard/wizard.py:1292
+msgid "Select Well Known Text (WKT) .prj file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1240
+msgid "WKT .prj file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1309
+msgid "Choose EPSG Code"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1317
+msgid "Path to the EPSG-codes file:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1319
+#: ../gui/wxpython/gui_core/preferences.py:1222
+msgid "EPSG code:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1471
+msgid "Choose EPSG codes file"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1500
+#, python-format
+msgid "Unable to read EPGS codes: %s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1518
+msgid "Choose method of specifying georeferencing parameters"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1526
+msgid "Enter PROJ.4 parameters string:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1582
+#: ../gui/wxpython/location_wizard/wizard.py:1586
+msgid "Datum transform is required."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1621
+#: ../gui/wxpython/rlisetup/wizard.py:1535
+msgid "Summary"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1662
+msgid "GRASS Database:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1668
+msgid "Location Name:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1674
+msgid "Location Title:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1680
+msgid "Projection:"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1686
+msgid ""
+"PROJ.4 definition:\n"
+" (non-definitive)"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1780
+#: ../gui/wxpython/psmap/dialogs.py:507 ../gui/wxpython/psmap/dialogs.py:528
+msgid "custom"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1789
+#, python-format
+msgid "Do you want to create GRASS location <%s>?"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1790
+msgid "Create new location?"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1834
+msgid "Define new GRASS Location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1926
+#, python-format
+msgid ""
+"Unable to create new location. Location <%(loc)s> not created.\n"
+"\n"
+"Details: %(err)s"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:1934
+msgid "Location wizard canceled. Location not created."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2057
+msgid "Unable to create new location"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2076
+#, python-format
+msgid ""
+"Location <%(loc)s> will be created in GIS data directory <%(dir)s>. You will "
+"need to change the default GIS data directory in the GRASS startup screen."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2081
+msgid "New GIS data directory"
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2112
+msgid "EPSG code missing."
+msgstr ""
+#: ../gui/wxpython/location_wizard/wizard.py:2123
+#: ../gui/wxpython/location_wizard/wizard.py:2132
+#, python-format
+msgid "File <%s> not found."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:3 ../gui/wxpython/menustrings.py:1968
+#: ../gui/wxpython/menustrings.py:2018
+msgid "&File"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:4
+msgid "Workspace"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:5 ../gui/wxpython/menustrings.py:1969
+#: ../gui/wxpython/nviz/tools.py:1094
+msgid "New"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:6
+msgid "Create new workspace"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:7 ../gui/wxpython/menustrings.py:1971
+msgid "Open"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:8
+msgid "Load workspace from file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:11 ../gui/wxpython/menustrings.py:1975
+msgid "Save as"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:12
+msgid "Save workspace to file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:14
+msgid "Close workspace file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:15
+msgid "Load GRC file (Tcl/Tk GUI)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:16
+msgid "Load map layers from GRC file to layer tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:17
+msgid "Map display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:18
+msgid "Add raster"
+msgstr ""
+msgid "Add raster map layer to current display"
+msgstr ""
+msgid "Add vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:21
+msgid "Add vector map layer to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:22
+msgid "Add multiple rasters or vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:23
+msgid "Add multiple raster or vector map layers to current display"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:24
+msgid "New map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:25
+msgid "Open new map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:26 ../gui/wxpython/menustrings.py:27
+msgid "Close current map display window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:28 ../gui/wxpython/menustrings.py:29
+msgid "Close all open map display windows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:31 ../gui/wxpython/menustrings.py:1038
+msgid "Common formats import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:32 ../gui/wxpython/menustrings.py:1039
+msgid "Import raster data into a GRASS map layer using GDAL."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:33 ../gui/wxpython/menustrings.py:1040
+msgid "ASCII x,y,z point import and gridding"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:34 ../gui/wxpython/menustrings.py:1041
+msgid ""
+"Creates a raster map from an assemblage of many coordinates using univariate "
+"statistics."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:35 ../gui/wxpython/menustrings.py:1042
+msgid "ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:36 ../gui/wxpython/menustrings.py:1043
+msgid "Converts a GRASS ASCII raster file to binary raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:37 ../gui/wxpython/menustrings.py:1044
+msgid "ASCII polygons, lines, and point import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:38 ../gui/wxpython/menustrings.py:1045
+msgid "Creates raster maps from ASCII polygon/line/point data files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:39 ../gui/wxpython/menustrings.py:1046
+msgid "Raw binary array import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:40 ../gui/wxpython/menustrings.py:1047
+msgid "Import a binary raster file into a GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:41 ../gui/wxpython/menustrings.py:1048
+msgid "ESRI ASCII grid import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:42 ../gui/wxpython/menustrings.py:1049
+msgid ""
+"Converts an ESRI ARC/INFO ascii raster file (GRID) into a GRASS raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:43 ../gui/wxpython/menustrings.py:1050
+msgid "GRIDATB.FOR import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:44 ../gui/wxpython/menustrings.py:1051
+msgid "Imports GRIDATB.FOR map file (TOPMODEL) into a GRASS raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:45 ../gui/wxpython/menustrings.py:1052
+msgid "Matlab 2D array import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:46 ../gui/wxpython/menustrings.py:1053
+msgid "Imports a binary MAT-File(v4) to a GRASS raster."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:47 ../gui/wxpython/menustrings.py:1054
+msgid "PNG import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:48 ../gui/wxpython/menustrings.py:1055
+msgid "Imports non-georeferenced PNG format image."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:49 ../gui/wxpython/menustrings.py:1056
+msgid "SPOT NDVI import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:50 ../gui/wxpython/menustrings.py:1057
+msgid "Imports SPOT VGT NDVI data into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:51 ../gui/wxpython/menustrings.py:1058
+msgid "SRTM HGT import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:52 ../gui/wxpython/menustrings.py:1059
+msgid "Imports SRTM HGT files into raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:53 ../gui/wxpython/menustrings.py:1060
+msgid "Terra ASTER HDF import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:54 ../gui/wxpython/menustrings.py:1061
+msgid ""
+"Georeference, rectify, and import Terra-ASTER imagery and relative DEMs "
+"using gdalwarp."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:55 ../gui/wxpython/menustrings.py:84
+#: ../gui/wxpython/menustrings.py:1062 ../gui/wxpython/menustrings.py:1091
+msgid "LAS LiDAR points import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:56 ../gui/wxpython/menustrings.py:1063
+msgid "Unpack raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:57 ../gui/wxpython/menustrings.py:1064
+msgid "Unpacks a raster map packed with r.pack."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:58 ../gui/wxpython/menustrings.py:293
+#: ../gui/wxpython/menustrings.py:1065 ../gui/wxpython/menustrings.py:1220
+msgid "Reproject raster map from different GRASS location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:59 ../gui/wxpython/menustrings.py:294
+#: ../gui/wxpython/menustrings.py:1066 ../gui/wxpython/menustrings.py:1221
+msgid "Re-projects a raster map from given location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:61 ../gui/wxpython/menustrings.py:1068
+msgid "Common import formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:62 ../gui/wxpython/menustrings.py:1069
+msgid "Converts vector layers into a GRASS vector map using OGR."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:63 ../gui/wxpython/menustrings.py:1070
+msgid "ASCII points or GRASS ASCII format"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:64 ../gui/wxpython/menustrings.py:1071
+msgid "Creates a vector map from an ASCII points file or ASCII vector file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:65 ../gui/wxpython/menustrings.py:1072
+msgid "ASCII points as a vector lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:66 ../gui/wxpython/menustrings.py:1073
+msgid "Imports ASCII x,y[,z] coordinates as a series of lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:67 ../gui/wxpython/menustrings.py:1074
+msgid "Historical GRASS vector import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:68 ../gui/wxpython/menustrings.py:1075
+msgid "Imports older versions of GRASS vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:69 ../gui/wxpython/menustrings.py:1076
+msgid "Historical GRASS vector import (all maps)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:70 ../gui/wxpython/menustrings.py:1077
+msgid ""
+"Converts all older versions of GRASS vector maps in current mapset to "
+"current format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:71 ../gui/wxpython/menustrings.py:1078
+msgid "DXF import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:72 ../gui/wxpython/menustrings.py:1079
+msgid "Converts files in DXF format to GRASS vector map format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:73 ../gui/wxpython/menustrings.py:1080
+msgid "WFS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:74 ../gui/wxpython/menustrings.py:1081
+msgid "Imports GetFeature from a WFS server."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:75 ../gui/wxpython/menustrings.py:1082
+msgid "ESRI e00 import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:76 ../gui/wxpython/menustrings.py:1083
+msgid "Imports E00 file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:77 ../gui/wxpython/menustrings.py:1084
+msgid "GPS data import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:78 ../gui/wxpython/menustrings.py:1085
+msgid "Geonames import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:79 ../gui/wxpython/menustrings.py:1086
+msgid "Imports geonames.org country files into a vector points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:80 ../gui/wxpython/menustrings.py:1087
+msgid "GEOnet import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:81 ../gui/wxpython/menustrings.py:1088
+msgid ""
+"Imports US-NGA GEOnet Names Server (GNS) country files into a GRASS vector "
+"points map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:82 ../gui/wxpython/menustrings.py:1089
+msgid "Matlab array or Mapgen format import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:83 ../gui/wxpython/menustrings.py:1090
+msgid "Imports Mapgen or Matlab-ASCII vector maps into GRASS."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:85 ../gui/wxpython/menustrings.py:1092
+msgid "Unpack vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:86 ../gui/wxpython/menustrings.py:1093
+msgid "Unpacks a vector map packed with v.pack."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:87 ../gui/wxpython/menustrings.py:582
+#: ../gui/wxpython/menustrings.py:1094 ../gui/wxpython/menustrings.py:1509
+msgid "Reproject vector map from different GRASS location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:88 ../gui/wxpython/menustrings.py:583
+#: ../gui/wxpython/menustrings.py:1095 ../gui/wxpython/menustrings.py:1510
+msgid "Re-projects a vector map from one location to the current location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:89 ../gui/wxpython/menustrings.py:1096
+msgid "Import 3D raster data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:90 ../gui/wxpython/menustrings.py:1097
+msgid "ASCII 3D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:91 ../gui/wxpython/menustrings.py:1098
+msgid "Converts a 3D ASCII raster text file into a (binary) 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:92 ../gui/wxpython/menustrings.py:1099
+msgid "Raw binary array 3D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:93 ../gui/wxpython/menustrings.py:1100
+msgid "Imports a binary raster file into a GRASS 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:94 ../gui/wxpython/menustrings.py:1101
+msgid "Vis5D import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:95 ../gui/wxpython/menustrings.py:1102
+msgid "Import 3-dimensional Vis5D files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:96 ../gui/wxpython/menustrings.py:1103
+msgid "Import database table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:97 ../gui/wxpython/menustrings.py:1104
+msgid "Multiple import formats using OGR"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:98 ../gui/wxpython/menustrings.py:1105
+msgid "Imports attribute tables in various formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:99 ../gui/wxpython/menustrings.py:1106
+msgid "Export raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:100 ../gui/wxpython/menustrings.py:133
+#: ../gui/wxpython/menustrings.py:1107 ../gui/wxpython/menustrings.py:1140
+msgid "Common export formats"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:101 ../gui/wxpython/menustrings.py:1108
+msgid "Exports GRASS raster maps into GDAL supported formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:102 ../gui/wxpython/menustrings.py:1109
+msgid "ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:103 ../gui/wxpython/menustrings.py:1110
+msgid "Converts a raster map layer into a GRASS ASCII text file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:104 ../gui/wxpython/menustrings.py:1111
+msgid "ASCII x,y,z points export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:105 ../gui/wxpython/menustrings.py:1112
+msgid ""
+"Exports a raster map to a text file as x,y,z values based on cell centers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:106 ../gui/wxpython/menustrings.py:1113
+msgid "ESRI ASCII grid export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:107 ../gui/wxpython/menustrings.py:1114
+msgid "Converts a raster map layer into an ESRI ARCGRID file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:108 ../gui/wxpython/menustrings.py:1115
+msgid "GRIDATB.FOR export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:109 ../gui/wxpython/menustrings.py:1116
+msgid "Exports GRASS raster map to GRIDATB.FOR map file (TOPMODEL)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:110 ../gui/wxpython/menustrings.py:1117
+msgid "Matlab 2D array export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:111 ../gui/wxpython/menustrings.py:1118
+msgid "Exports a GRASS raster to a binary MAT-File."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:112 ../gui/wxpython/menustrings.py:1119
+msgid "Raw binary array export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:113 ../gui/wxpython/menustrings.py:1120
+msgid "Exports a GRASS raster to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:114 ../gui/wxpython/menustrings.py:1121
+msgid "MPEG-1 export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:115 ../gui/wxpython/menustrings.py:1122
+msgid "Converts raster map series to MPEG movie."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:116 ../gui/wxpython/menustrings.py:1123
+msgid "PNG export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:117 ../gui/wxpython/menustrings.py:1124
+msgid "Export a GRASS raster map as a non-georeferenced PNG image."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:118 ../gui/wxpython/menustrings.py:1125
+msgid "PPM export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:119 ../gui/wxpython/menustrings.py:1126
+msgid "Converts a GRASS raster map to a PPM image file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:120 ../gui/wxpython/menustrings.py:1127
+msgid "PPM from RGB export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:121 ../gui/wxpython/menustrings.py:1128
+msgid "Converts 3 GRASS raster layers (R,G,B) to a PPM image file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:122 ../gui/wxpython/menustrings.py:143
+#: ../gui/wxpython/menustrings.py:1129 ../gui/wxpython/menustrings.py:1150
+msgid "POV-Ray export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:123 ../gui/wxpython/menustrings.py:1130
+msgid "Converts a raster map layer into a height-field file for POV-Ray."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:124 ../gui/wxpython/menustrings.py:1131
+msgid "TIFF export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:125 ../gui/wxpython/menustrings.py:1132
+msgid "Exports a GRASS raster map to a 8/24bit TIFF image file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:126 ../gui/wxpython/menustrings.py:1133
+msgid "VRML export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:127 ../gui/wxpython/menustrings.py:1134
+msgid "Exports a raster map to the Virtual Reality Modeling Language (VRML)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:128 ../gui/wxpython/menustrings.py:147
+#: ../gui/wxpython/menustrings.py:158 ../gui/wxpython/menustrings.py:1135
+#: ../gui/wxpython/menustrings.py:1154 ../gui/wxpython/menustrings.py:1165
+msgid "VTK export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:129 ../gui/wxpython/menustrings.py:1136
+msgid "Converts raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:130 ../gui/wxpython/menustrings.py:1137
+msgid "Pack raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:131 ../gui/wxpython/menustrings.py:1138
+msgid "Packs up a raster map and support files for copying."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:132 ../gui/wxpython/menustrings.py:1139
+msgid "Export vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:134 ../gui/wxpython/menustrings.py:1141
+msgid ""
+"Exports a vector map layer to any of the supported OGR vector formats. By "
+"default a vector map layer is exported to Esri Shapefile format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:135 ../gui/wxpython/menustrings.py:1142
+msgid "ASCII points or GRASS ASCII vector export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:136 ../gui/wxpython/menustrings.py:1143
+msgid ""
+"Exports a vector map to a GRASS ASCII vector representation. By default only "
+"features with category are exported. To export all features use 'layer=-1'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:137 ../gui/wxpython/menustrings.py:1144
+msgid "DXF export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:138 ../gui/wxpython/menustrings.py:1145
+msgid "Exports vector map to DXF file format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:139 ../gui/wxpython/menustrings.py:1146
+msgid "Multiple GPS export formats using GPSBabel"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:140 ../gui/wxpython/menustrings.py:1147
+msgid ""
+"Exports a vector map to a GPS receiver or file format supported by GPSBabel."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:141 ../gui/wxpython/menustrings.py:1148
+msgid "PostGIS export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:142 ../gui/wxpython/menustrings.py:1149
+msgid "Exports a vector map layer to PostGIS feature table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:144 ../gui/wxpython/menustrings.py:1151
+msgid "Converts GRASS x,y,z points to POV-Ray x,z,y format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:145 ../gui/wxpython/menustrings.py:1152
+msgid "SVG export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:146 ../gui/wxpython/menustrings.py:1153
+msgid "Exports a vector map to SVG file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:148 ../gui/wxpython/menustrings.py:1155
+msgid "Converts a vector map to VTK ASCII output."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:149 ../gui/wxpython/menustrings.py:1156
+msgid "Pack vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:150 ../gui/wxpython/menustrings.py:1157
+msgid "Packs up a vector map and support files for copying."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:151 ../gui/wxpython/menustrings.py:1158
+msgid "Export 3D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:152 ../gui/wxpython/menustrings.py:1159
+msgid "ASCII 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:153 ../gui/wxpython/menustrings.py:1160
+msgid "Converts a 3D raster map layer into a ASCII text file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:154 ../gui/wxpython/menustrings.py:1161
+msgid "Raw binary array 3D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:155 ../gui/wxpython/menustrings.py:1162
+msgid "Exports a GRASS 3D raster map to a binary array."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:156 ../gui/wxpython/menustrings.py:1163
+msgid "Vis5D export"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:157 ../gui/wxpython/menustrings.py:1164
+msgid "Exports GRASS 3D raster map to 3-dimensional Vis5D file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:159 ../gui/wxpython/menustrings.py:1166
+msgid "Converts 3D raster maps into the VTK-ASCII format."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:160 ../gui/wxpython/menustrings.py:1167
+msgid "Export database table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:161 ../gui/wxpython/menustrings.py:1168
+msgid "Common export formats using OGR"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:162 ../gui/wxpython/menustrings.py:1169
+msgid "Exports attribute tables into various formats."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:163 ../gui/wxpython/menustrings.py:1170
+msgid "Link external data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:165 ../gui/wxpython/menustrings.py:1172
+msgid "Link GDAL supported raster data as a pseudo GRASS raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:167 ../gui/wxpython/menustrings.py:1174
+msgid "Creates a new pseudo-vector map as a link to an OGR-supported layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:168 ../gui/wxpython/menustrings.py:1175
+msgid "Output format for raster data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:169 ../gui/wxpython/menustrings.py:1176
+msgid "Defines raster output format utilizing GDAL library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:170 ../gui/wxpython/menustrings.py:1177
+msgid "Output format for vector data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:171 ../gui/wxpython/menustrings.py:1178
+msgid "Defines vector output format utilizing OGR library."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:172 ../gui/wxpython/menustrings.py:1179
+msgid "Manage maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:173 ../gui/wxpython/menustrings.py:1180
+msgid "Copy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:174 ../gui/wxpython/menustrings.py:1181
+msgid ""
+"Copies available data files in the current mapset search path to the user's "
+"current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:175 ../gui/wxpython/menustrings.py:950
+#: ../gui/wxpython/menustrings.py:1182 ../gui/wxpython/menustrings.py:1877
+msgid "List"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:176 ../gui/wxpython/menustrings.py:1183
+msgid "Lists available GRASS data base files of the user-specified data type."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:177 ../gui/wxpython/menustrings.py:1184
+msgid "List filtered"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:178 ../gui/wxpython/menustrings.py:1185
+msgid ""
+"Lists available GRASS data base files of the user-specified data type "
+"optionally using the search pattern."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:180 ../gui/wxpython/menustrings.py:1187
+msgid "Renames data base element files in the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:181 ../gui/wxpython/menustrings.py:1188
+#: ../gui/wxpython/menustrings.py:2052 ../gui/wxpython/psmap/dialogs.py:1315
+#: ../gui/wxpython/nviz/tools.py:1098 ../gui/wxpython/nviz/tools.py:1976
+#: ../gui/wxpython/nviz/tools.py:2024
+msgid "Delete"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:182 ../gui/wxpython/menustrings.py:1189
+msgid "Removes data base element files from the user's current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:183 ../gui/wxpython/menustrings.py:1190
+msgid "Delete filtered"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:184 ../gui/wxpython/menustrings.py:1191
+msgid ""
+"Removes data base element files from the user's current mapset using regular "
+"expressions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:185 ../gui/wxpython/menustrings.py:317
+#: ../gui/wxpython/menustrings.py:620 ../gui/wxpython/menustrings.py:853
+#: ../gui/wxpython/menustrings.py:1244 ../gui/wxpython/menustrings.py:1547
+#: ../gui/wxpython/menustrings.py:1780
+msgid "Map type conversions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:186 ../gui/wxpython/menustrings.py:318
+#: ../gui/wxpython/menustrings.py:1245
+msgid "Raster to vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:187 ../gui/wxpython/menustrings.py:319
+#: ../gui/wxpython/menustrings.py:1246
+msgid "Converts a raster map into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:188 ../gui/wxpython/menustrings.py:320
+#: ../gui/wxpython/menustrings.py:1247
+msgid "Raster series to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:189 ../gui/wxpython/menustrings.py:321
+#: ../gui/wxpython/menustrings.py:1248
+msgid "Converts 2D raster map slices to one 3D raster volume map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:190 ../gui/wxpython/menustrings.py:322
+#: ../gui/wxpython/menustrings.py:1249
+msgid "Raster 2.5D to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:191 ../gui/wxpython/menustrings.py:323
+#: ../gui/wxpython/menustrings.py:1250
+msgid "Creates a 3D volume map based on 2D elevation and value raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:192 ../gui/wxpython/menustrings.py:621
+#: ../gui/wxpython/menustrings.py:1548
+msgid "Vector to raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:193 ../gui/wxpython/menustrings.py:622
+#: ../gui/wxpython/menustrings.py:1549
+msgid "Converts (rasterize) a vector map into a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:194 ../gui/wxpython/menustrings.py:623
+#: ../gui/wxpython/menustrings.py:1550
+msgid "Vector to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:195 ../gui/wxpython/menustrings.py:624
+#: ../gui/wxpython/menustrings.py:1551
+msgid "Converts a vector map (only points) into a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:196 ../gui/wxpython/menustrings.py:625
+#: ../gui/wxpython/menustrings.py:1552
+msgid "2D vector to 3D vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:197 ../gui/wxpython/menustrings.py:626
+#: ../gui/wxpython/menustrings.py:1553
+msgid "Performs transformation of 2D vector features to 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:198 ../gui/wxpython/menustrings.py:627
+#: ../gui/wxpython/menustrings.py:1554
+msgid "Sites to vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:199 ../gui/wxpython/menustrings.py:628
+#: ../gui/wxpython/menustrings.py:1555
+msgid "Converts a GRASS site_lists file into a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:200 ../gui/wxpython/menustrings.py:854
+#: ../gui/wxpython/menustrings.py:1781
+msgid "Volume to raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:201 ../gui/wxpython/menustrings.py:855
+#: ../gui/wxpython/menustrings.py:1782
+msgid "Converts 3D raster maps to 2D raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:202 ../gui/wxpython/menustrings.py:1956
+msgid "Georectify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:203 ../gui/wxpython/menustrings.py:1957
+msgid "Manage Ground Control Points for Georectification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:204 ../gui/wxpython/menustrings.py:1958
+msgid "Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:205 ../gui/wxpython/menustrings.py:1959
+msgid "Launch Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:206 ../gui/wxpython/menustrings.py:2007
+msgid "Run model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:207
+msgid "Run model prepared by Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:208
+msgid "3D image rendering"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:209
+msgid ""
+"Creates a 3D rendering of GIS data. Renders surfaces (raster data), 2D/3D "
+"vector data, and volumes (3D raster data) in 3D."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:210 ../gui/wxpython/menustrings.py:1022
+#: ../gui/wxpython/menustrings.py:1949 ../gui/wxpython/menustrings.py:1953
+msgid "Animation tool"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:211 ../gui/wxpython/menustrings.py:1023
+#: ../gui/wxpython/menustrings.py:1950 ../gui/wxpython/menustrings.py:1954
+msgid "Launch animation tool."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:212
+msgid "Bearing/distance to coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:213
+msgid ""
+"A simple utility for converting bearing and distance measurements to "
+"coordinates and vice versa. It assumes a cartesian coordinate system"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:215 ../gui/wxpython/menustrings.py:1965
+msgid "Launch Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:216 ../gui/wxpython/menustrings.py:1962
+msgid "Map Swipe"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:217 ../gui/wxpython/menustrings.py:1963
+msgid "Launch Map Swipe"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:218
+msgid "Launch script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:219
+msgid "Launches script file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:220
+msgid "Exit GUI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:221
+msgid "Quit the GRASS wxGUI session."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:222 ../gui/wxpython/menustrings.py:1985
+msgid "&Settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:224
+msgid "Display region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:225 ../gui/wxpython/menustrings.py:227
+msgid "Manages the boundary definitions for the geographic region."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:226
+msgid "Set region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:228
+msgid "GRASS working environment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:229
+msgid "Mapset access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:230
+msgid "Set/unset access to other mapsets in current location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:231
+msgid "User access"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:232
+msgid ""
+"Controls access to the current mapset for other users on the system. If no "
+"option given, prints current status."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:233
+msgid "Change working environment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:234
+msgid ""
+"Changes/reports current mapset. Optionally create new mapset or list "
+"available mapsets in given location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:235
+msgid "Change location and mapset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:236
+msgid "Change current location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:237
+msgid "Change mapset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:238
+msgid "Change current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:239 ../gui/wxpython/menustrings.py:240
+msgid "Change working directory"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:241
+msgid "Show settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:242
+msgid "Outputs and modifies the user's current GRASS variable settings."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:243
+msgid "Change settings"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:244
+msgid ""
+"Outputs and modifies the user's current GRASS variable settings. Prints all "
+"defined GRASS variables if no option is given."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:245
+msgid "Create new location"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:246
+msgid "Launches location wizard to create new GRASS location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:248
+msgid "Creates new mapset in the current location, changes current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:249
+msgid "Version and copyright"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:250
+msgid "Displays version and copyright information."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:251
+msgid "Map projections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:252
+msgid "Display map projection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:253
+msgid ""
+"Converts co-ordinate system descriptions (i.e. projection information) "
+"between various formats (including GRASS format)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:254
+msgid "Manage projections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:255
+msgid ""
+"Prints and manipulates GRASS projection information files (in various co-"
+"ordinate system descriptions). Can also be used to create new GRASS "
+"locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:256
+msgid "Convert coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:257
+msgid "Converts coordinates from one projection to another (cs2cs frontend)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:258
+msgid "Addons extensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:259
+msgid "Install extension from addons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:260
+msgid "Installs new extension from GRASS AddOns SVN repository."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:261
+msgid "Manage installed extension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:262
+msgid "Updates or removes installed GRASS AddOns extension(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:263 ../gui/wxpython/menustrings.py:1986
+msgid "Preferences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:264
+msgid "User GUI preferences (display font, commands, digitizer, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:265 ../gui/wxpython/menustrings.py:1192
+msgid "&Raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:266 ../gui/wxpython/menustrings.py:1193
+msgid "Develop raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:267 ../gui/wxpython/menustrings.py:1194
+msgid "Compress/decompress"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:268 ../gui/wxpython/menustrings.py:1195
+msgid "Compresses and decompresses raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:269 ../gui/wxpython/menustrings.py:1196
+msgid "Region boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:270 ../gui/wxpython/menustrings.py:1197
+msgid "Sets the boundary definitions for a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:271 ../gui/wxpython/menustrings.py:1198
+msgid "Manage NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:272 ../gui/wxpython/menustrings.py:1199
+msgid "Manages NULL-values of given raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:273 ../gui/wxpython/menustrings.py:1200
+msgid "Quantization"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:274 ../gui/wxpython/menustrings.py:1201
+msgid "Produces the quantization file for a floating-point map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:275 ../gui/wxpython/menustrings.py:1202
+msgid "Timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:276 ../gui/wxpython/menustrings.py:1203
+msgid ""
+"Modifies a timestamp for a raster map. Print/add/remove a timestamp for a "
+"raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:277 ../gui/wxpython/menustrings.py:1204
+msgid "Resample using aggregate statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:278 ../gui/wxpython/menustrings.py:1205
+msgid "Resamples raster map layers to a coarser grid using aggregation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:279 ../gui/wxpython/menustrings.py:1206
+msgid "Resample using multiple methods"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:280 ../gui/wxpython/menustrings.py:1207
+msgid "Resamples raster map to a finer grid using interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:281 ../gui/wxpython/menustrings.py:1208
+msgid "Resample using nearest neighbor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:282 ../gui/wxpython/menustrings.py:1209
+msgid "GRASS raster map layer data resampling capability."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:283 ../gui/wxpython/menustrings.py:1210
+msgid "Resample using spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:284 ../gui/wxpython/menustrings.py:1211
+msgid ""
+"Reinterpolates and optionally computes topographic analysis from input "
+"raster map to a new raster map (possibly with different resolution) using "
+"regularized spline with tension and smoothing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:285 ../gui/wxpython/menustrings.py:1212
+msgid "Resample using bspline"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:286 ../gui/wxpython/menustrings.py:1213
+msgid ""
+"Performs bilinear or bicubic spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:287 ../gui/wxpython/menustrings.py:1214
+msgid "Resample using analytic kernel"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:288 ../gui/wxpython/menustrings.py:1215
+msgid "Resamples raster map layers using an analytic kernel."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:289 ../gui/wxpython/menustrings.py:584
+#: ../gui/wxpython/menustrings.py:1216 ../gui/wxpython/menustrings.py:1511
+msgid "Support file maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:290 ../gui/wxpython/menustrings.py:1217
+msgid "Allows creation and/or modification of raster map layer support files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:291 ../gui/wxpython/menustrings.py:1218
+msgid "Update map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:292 ../gui/wxpython/menustrings.py:1219
+msgid "Update raster map statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:295 ../gui/wxpython/menustrings.py:1222
+msgid "Tiling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:296 ../gui/wxpython/menustrings.py:1223
+msgid ""
+"Produces tilings of the source projection for use in the destination region "
+"and projection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:297 ../gui/wxpython/menustrings.py:603
+#: ../gui/wxpython/menustrings.py:1224 ../gui/wxpython/menustrings.py:1530
+msgid "Manage colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:298 ../gui/wxpython/menustrings.py:604
+#: ../gui/wxpython/menustrings.py:1225 ../gui/wxpython/menustrings.py:1531
+msgid "Color tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:299 ../gui/wxpython/menustrings.py:1226
+msgid "Creates/modifies the color table associated with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:300 ../gui/wxpython/menustrings.py:1227
+msgid "Color tables (stddev)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:301 ../gui/wxpython/menustrings.py:1228
+msgid "Sets color rules based on stddev from a raster map's mean value."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:302 ../gui/wxpython/menustrings.py:606
+#: ../gui/wxpython/menustrings.py:1229 ../gui/wxpython/menustrings.py:1533
+msgid "Manage color rules interactively"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:303 ../gui/wxpython/menustrings.py:1230
+msgid "Interactive management of raster color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:304 ../gui/wxpython/menustrings.py:608
+#: ../gui/wxpython/menustrings.py:1231 ../gui/wxpython/menustrings.py:1535
+msgid "Export color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:305 ../gui/wxpython/menustrings.py:1232
+msgid "Exports the color table associated with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:306 ../gui/wxpython/menustrings.py:1233
+msgid "Blend 2 color rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:307 ../gui/wxpython/menustrings.py:1234
+msgid "Blends color components of two raster maps by a given ratio."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:308 ../gui/wxpython/menustrings.py:1235
+msgid "Create RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:309 ../gui/wxpython/menustrings.py:1236
+msgid ""
+"Combines red, green and blue raster maps into a single composite raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:310 ../gui/wxpython/menustrings.py:760
+#: ../gui/wxpython/menustrings.py:1237 ../gui/wxpython/menustrings.py:1687
+msgid "RGB to HIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:311 ../gui/wxpython/menustrings.py:1238
+msgid ""
+"Generates red, green and blue raster map layers combining hue, intensity and "
+"saturation (HIS) values from user-specified input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:312 ../gui/wxpython/menustrings.py:1239
+msgid "Query raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:313 ../gui/wxpython/menustrings.py:1240
+msgid "Query values by coordinates"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:314 ../gui/wxpython/menustrings.py:1241
+msgid "Queries raster maps on their category values and category labels."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:315 ../gui/wxpython/menustrings.py:1242
+msgid "Query colors by value"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:316 ../gui/wxpython/menustrings.py:1243
+msgid "Queries colors for a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:324 ../gui/wxpython/menustrings.py:1251
+msgid "Buffer rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:325 ../gui/wxpython/menustrings.py:1252
+msgid ""
+"Creates a raster map showing buffer zones surrounding cells that contain non-"
+"NULL category values."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:326 ../gui/wxpython/menustrings.py:1253
+msgid "Concentric circles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:327 ../gui/wxpython/menustrings.py:1254
+msgid "Creates a raster map containing concentric rings around a given point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:328 ../gui/wxpython/menustrings.py:1255
+msgid "Closest points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:329 ../gui/wxpython/menustrings.py:1256
+msgid "Locates the closest points between objects in two raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:330 ../gui/wxpython/menustrings.py:1257
+#: ../gui/wxpython/psmap/dialogs.py:1727 ../gui/wxpython/nviz/tools.py:789
+#: ../gui/wxpython/nviz/tools.py:2400
+msgid "Mask"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:331 ../gui/wxpython/menustrings.py:1258
+msgid "Creates a MASK for limiting raster operation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:332 ../gui/wxpython/menustrings.py:1259
+msgid "Raster map calculator"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:333 ../gui/wxpython/menustrings.py:1260
+msgid "Raster map calculator."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:334 ../gui/wxpython/menustrings.py:1261
+msgid "Neighborhood analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:335 ../gui/wxpython/menustrings.py:1262
+#: ../gui/wxpython/rlisetup/wizard.py:737
+msgid "Moving window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:336 ../gui/wxpython/menustrings.py:1263
+msgid ""
+"Makes each cell category value a function of the category values assigned to "
+"the cells around it, and stores new cell values in an output raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:337 ../gui/wxpython/menustrings.py:1264
+msgid "Neighborhood points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:338 ../gui/wxpython/menustrings.py:1265
+msgid ""
+"Neighborhood analysis tool for vector point maps. Makes each cell value a "
+"function of the attribute values assigned to the vector points or centroids "
+"around it, and stores new cell values in an output raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:339 ../gui/wxpython/menustrings.py:1266
+msgid "Overlay rasters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:340 ../gui/wxpython/menustrings.py:1267
+msgid "Cross product"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:341 ../gui/wxpython/menustrings.py:1268
+msgid ""
+"Creates a cross product of the category values from multiple raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:342 ../gui/wxpython/menustrings.py:1269
+msgid "Raster series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:343 ../gui/wxpython/menustrings.py:1270
+msgid ""
+"Makes each output cell value a function of the values assigned to the "
+"corresponding cells in the input raster map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:344 ../gui/wxpython/menustrings.py:1271
+msgid "Patch raster maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:345 ../gui/wxpython/menustrings.py:1272
+msgid ""
+"Creates a composite raster map layer by using known category values from one "
+"(or more) map layer(s) to fill in areas of \"no data\" in another map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:346 ../gui/wxpython/menustrings.py:1273
+msgid "Statistical overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:347 ../gui/wxpython/menustrings.py:1274
+msgid ""
+"Calculates category or object oriented statistics (accumulator-based "
+"statistics)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:348 ../gui/wxpython/menustrings.py:1275
+msgid "Quantiles overlay"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:349 ../gui/wxpython/menustrings.py:1276
+msgid "Compute category quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:350 ../gui/wxpython/menustrings.py:1277
+msgid "Solar radiance and shadows"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:351 ../gui/wxpython/menustrings.py:1278
+msgid "LatLong map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:352 ../gui/wxpython/menustrings.py:1279
+msgid "Creates a latitude/longitude raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:353 ../gui/wxpython/menustrings.py:1280
+msgid "Solar irradiance and irradiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:354 ../gui/wxpython/menustrings.py:1281
+msgid ""
+"Solar irradiance and irradiation model. Computes direct (beam), diffuse and "
+"reflected solar irradiation raster maps for given day, latitude, surface and "
+"atmospheric conditions. Solar parameters (e.g. sunrise, sunset times, "
+"declination, extraterrestrial irradiance, daylight length) are saved in the "
+"map history file. Alternatively, a local time can be specified to compute "
+"solar incidence angle and/or irradiance raster maps. The shadowing effect of "
+"the topography is optionally incorporated."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:355 ../gui/wxpython/menustrings.py:1282
+msgid "Shadows map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:356 ../gui/wxpython/menustrings.py:1283
+msgid ""
+"Calculates cast shadow areas from sun position and elevation raster map. "
+"Either exact sun position (A) is specified, or date/time to calculate the "
+"sun position (B) by r.sunmask itself."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:357 ../gui/wxpython/menustrings.py:1284
+msgid "Sunshine hours and solar angles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:358 ../gui/wxpython/menustrings.py:1285
+msgid ""
+"Calculates solar elevation, solar azimuth, and sun hours. Solar elevation: "
+"the angle between the direction of the geometric center of the sun's "
+"apparent disk and the (idealized) horizon. Solar azimuth: the angle from due "
+"north in clockwise direction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:359 ../gui/wxpython/menustrings.py:1286
+msgid "Terrain analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:360 ../gui/wxpython/menustrings.py:1287
+msgid "Generate contour lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:361 ../gui/wxpython/menustrings.py:1288
+msgid "Produces a vector map of specified contours from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:362 ../gui/wxpython/menustrings.py:1289
+msgid "Cost surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:363 ../gui/wxpython/menustrings.py:1290
+msgid ""
+"Creates a raster map showing the cumulative cost of moving between different "
+"geographic locations on an input raster map whose cell category values "
+"represent cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:364 ../gui/wxpython/menustrings.py:1291
+msgid "Cumulative movement costs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:365 ../gui/wxpython/menustrings.py:1292
+msgid ""
+"Outputs a raster map showing the anisotropic cumulative cost. Computes "
+"anisotropic cumulative cost of moving between different geographic locations "
+"on an input elevation raster map whose cell category values represent "
+"elevation combined with an input raster map layer whose cell values "
+"represent friction cost."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:366 ../gui/wxpython/menustrings.py:1293
+msgid "Least cost route or flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:367 ../gui/wxpython/menustrings.py:1294
+msgid ""
+"Traces a flow through an elevation model or cost surface on a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:368 ../gui/wxpython/menustrings.py:1295
+msgid "Shaded relief"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:369 ../gui/wxpython/menustrings.py:1296
+msgid "Creates shaded relief map from an elevation map (DEM). "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:370 ../gui/wxpython/menustrings.py:1297
+msgid "Slope and aspect"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:371 ../gui/wxpython/menustrings.py:1298
+msgid ""
+"Generates raster maps of slope, aspect, curvatures and partial derivatives "
+"from an elevation raster map. Aspect is calculated counterclockwise from "
+"east."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:372 ../gui/wxpython/menustrings.py:1299
+msgid "Terrain parameters"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:373 ../gui/wxpython/menustrings.py:1300
+msgid ""
+"Extracts terrain parameters from a DEM. Uses a multi-scale approach by "
+"taking fitting quadratic parameters to any size window (via least squares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:374 ../gui/wxpython/menustrings.py:1301
+msgid "Textural features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:375 ../gui/wxpython/menustrings.py:1302
+msgid "Generate images with textural features from a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:376 ../gui/wxpython/menustrings.py:1303
+msgid "Visibility"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:377 ../gui/wxpython/menustrings.py:1304
+msgid ""
+"Computes the viewshed of a point on an elevation raster map. Default format: "
+"NULL (invisible), vertical angle wrt viewpoint (visible)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:378 ../gui/wxpython/menustrings.py:1305
+msgid "Visibility [DEPRECATED]"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:379 ../gui/wxpython/menustrings.py:1306
+msgid "Line-of-sight raster analysis program."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:380 ../gui/wxpython/menustrings.py:1307
+msgid "Distance to features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:381 ../gui/wxpython/menustrings.py:1308
+msgid "Generates a raster map containing distances to nearest raster features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:382 ../gui/wxpython/menustrings.py:1309
+msgid "Horizon angle"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:383 ../gui/wxpython/menustrings.py:1310
+msgid ""
+"Horizon angle computation from a digital elevation model. Computes horizon "
+"angle height from a digital elevation model. The module has two different "
+"modes of operation: 1. Computes the entire horizon around a single point "
+"whose coordinates are given with the 'coord' option. The horizon height (in "
+"radians). 2. Computes one or more raster maps of the horizon height in a "
+"single direction. The input for this is the angle (in degrees), which is "
+"measured counterclockwise with east=0, north=90 etc. The output is the "
+"horizon height in radians."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:384 ../gui/wxpython/menustrings.py:1311
+msgid "Transform features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:385 ../gui/wxpython/menustrings.py:1312
+msgid "Clump"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:386 ../gui/wxpython/menustrings.py:1313
+msgid ""
+"Recategorizes data in a raster map by grouping cells that form physically "
+"discrete areas into unique categories."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:387 ../gui/wxpython/menustrings.py:1314
+msgid "Grow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:388 ../gui/wxpython/menustrings.py:1315
+msgid "Generates a raster map layer with contiguous areas grown by one cell."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:389 ../gui/wxpython/menustrings.py:1316
+msgid "Thin"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:390 ../gui/wxpython/menustrings.py:1317
+msgid "Thins non-zero cells that denote linear features in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:391 ../gui/wxpython/menustrings.py:1318
+msgid "Hydrologic modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:392 ../gui/wxpython/menustrings.py:1319
+msgid "Carve stream channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:393 ../gui/wxpython/menustrings.py:1320
+msgid ""
+"Generates stream channels. Takes vector stream data, transforms it to raster "
+"and subtracts depth from the output DEM."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:394 ../gui/wxpython/menustrings.py:1321
+msgid "Fill lake"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:395 ../gui/wxpython/menustrings.py:1322
+msgid "Fills lake at given point to given level."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:396 ../gui/wxpython/menustrings.py:1323
+msgid "Depressionless map and flowlines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:397 ../gui/wxpython/menustrings.py:1324
+msgid ""
+"Filters and generates a depressionless elevation map and a flow direction "
+"map from a given elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:398 ../gui/wxpython/menustrings.py:1325
+msgid "Flow accumulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:399 ../gui/wxpython/menustrings.py:1326
+msgid "Flow computation for massive grids (float version)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:400 ../gui/wxpython/menustrings.py:1327
+msgid "Flow lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:401 ../gui/wxpython/menustrings.py:1328
+msgid ""
+"Constructs flowlines. Computes flowlines, flowpath lengths, and "
+"flowaccumulation (contributing areas) from a elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:402 ../gui/wxpython/menustrings.py:1329
+msgid "Watershed analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:403 ../gui/wxpython/menustrings.py:1330
+msgid "Calculates hydrological parameters and RUSLE factors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:404 ../gui/wxpython/menustrings.py:1331
+msgid "Watershed subbasins"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:405 ../gui/wxpython/menustrings.py:1332
+msgid "Generates watershed subbasins raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:406 ../gui/wxpython/menustrings.py:1333
+msgid "Watershed basin creation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:407 ../gui/wxpython/menustrings.py:1334
+msgid "Creates watershed basins from a drainage direction map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:408 ../gui/wxpython/menustrings.py:1335
+msgid "Stream channel characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:409 ../gui/wxpython/menustrings.py:1336
+msgid "Calculates local parameters for individual streams."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:410 ../gui/wxpython/menustrings.py:1337
+msgid "Stream distance and elevation characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:411 ../gui/wxpython/menustrings.py:1338
+msgid ""
+"Calculates distance to and elevation above streams and outlet. The module "
+"can work in stream mode where target are streams and outlets mode where "
+"targets are outlets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:412 ../gui/wxpython/menustrings.py:1339
+msgid "Extraction of stream networks"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:413 ../gui/wxpython/menustrings.py:1340
+msgid "Performs stream network extraction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:414 ../gui/wxpython/menustrings.py:1341
+msgid "Stream ordering and hierarchy"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:415 ../gui/wxpython/menustrings.py:1342
+msgid ""
+"Calculates Strahler's and more streams hierarchy. Basic module for "
+"topological analysis of drainage network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:416 ../gui/wxpython/menustrings.py:1343
+msgid "Stream segment characteristics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:417 ../gui/wxpython/menustrings.py:1344
+msgid ""
+"Divides network into near straight-line segments and calculate its order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:418 ../gui/wxpython/menustrings.py:1345
+msgid "Stream elevation change"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:419 ../gui/wxpython/menustrings.py:1346
+msgid "Calculates local parameters for slope subsystem."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:420 ../gui/wxpython/menustrings.py:1347
+msgid "Position correction of water outlet point"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:421 ../gui/wxpython/menustrings.py:1348
+msgid ""
+"Snap point to modelled stream network. Input can be stream network, point "
+"vector map with outlets or outlet coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:422 ../gui/wxpython/menustrings.py:1349
+msgid "Horton's statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:423 ../gui/wxpython/menustrings.py:1350
+msgid ""
+"Calculates Horton's statistics for Strahler and Horton ordered networks "
+"created with r.stream.order."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:424 ../gui/wxpython/menustrings.py:1351
+msgid "SIMWE Overland flow modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:425 ../gui/wxpython/menustrings.py:1352
+msgid "Overland flow hydrologic simulation using path sampling method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:426 ../gui/wxpython/menustrings.py:1353
+msgid "SIMWE Sediment flux modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:427 ../gui/wxpython/menustrings.py:1354
+msgid ""
+"Sediment transport and erosion/deposition simulation using path sampling "
+"method (SIMWE)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:428 ../gui/wxpython/menustrings.py:1355
+msgid "Topographic index map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:429 ../gui/wxpython/menustrings.py:1356
+msgid "Creates topographic index map from elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:430 ../gui/wxpython/menustrings.py:1357
+msgid "TOPMODEL simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:431 ../gui/wxpython/menustrings.py:1358
+msgid "Simulates TOPMODEL which is a physically based hydrologic model."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:432 ../gui/wxpython/menustrings.py:1359
+msgid "USLE K-factor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:433 ../gui/wxpython/menustrings.py:1360
+msgid "Computes USLE Soil Erodibility Factor (K)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:434 ../gui/wxpython/menustrings.py:1361
+msgid "USLE R-factor"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:435 ../gui/wxpython/menustrings.py:1362
+msgid "Computes USLE R factor, Rainfall erosivity index."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:436 ../gui/wxpython/menustrings.py:866
+#: ../gui/wxpython/menustrings.py:1363 ../gui/wxpython/menustrings.py:1793
+msgid "Groundwater modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:437 ../gui/wxpython/menustrings.py:1364
+msgid "Groundwater flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:438 ../gui/wxpython/menustrings.py:1365
+msgid ""
+"Numerical calculation program for transient, confined and unconfined "
+"groundwater flow in two dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:439 ../gui/wxpython/menustrings.py:1366
+msgid "Groundwater solute transport"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:440 ../gui/wxpython/menustrings.py:1367
+msgid ""
+"Numerical calculation program for transient, confined and unconfined solute "
+"transport in two dimensions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:441 ../gui/wxpython/menustrings.py:1368
+msgid "Landscape structure modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:442 ../gui/wxpython/menustrings.py:1369
+msgid "Analyze landscape"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:443 ../gui/wxpython/menustrings.py:1370
+msgid "Analyze patches"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:444 ../gui/wxpython/menustrings.py:1371
+msgid "Landscape patch analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:445 ../gui/wxpython/menustrings.py:1372
+msgid "Set up sampling and analysis framework"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:446 ../gui/wxpython/menustrings.py:1373
+msgid "Configuration editor for r.li.'index'"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:447 ../gui/wxpython/menustrings.py:1374
+msgid "Edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:448 ../gui/wxpython/menustrings.py:1375
+msgid ""
+"Calculates edge density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:449 ../gui/wxpython/menustrings.py:1376
+msgid "Contrast weighted edge density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:450 ../gui/wxpython/menustrings.py:1377
+msgid "Calculates contrast weighted edge density index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:451 ../gui/wxpython/menustrings.py:1378
+msgid "Patch area mean"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:452 ../gui/wxpython/menustrings.py:1379
+msgid ""
+"Calculates mean patch size index on a raster map, using a 4 neighbour "
+"algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:453 ../gui/wxpython/menustrings.py:1380
+msgid "Patch area range"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:454 ../gui/wxpython/menustrings.py:1381
+msgid "Calculates range of patch area size on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:455 ../gui/wxpython/menustrings.py:1382
+msgid "Patch area Std Dev"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:456 ../gui/wxpython/menustrings.py:1383
+msgid "Calculates standard deviation of patch area a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:457 ../gui/wxpython/menustrings.py:1384
+msgid "Patch area Coeff Var"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:458 ../gui/wxpython/menustrings.py:1385
+msgid "Calculates coefficient of variation of patch area on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:459 ../gui/wxpython/menustrings.py:1386
+msgid "Patch density"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:460 ../gui/wxpython/menustrings.py:1387
+msgid ""
+"Calculates patch density index on a raster map, using a 4 neighbour algorithm"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:461 ../gui/wxpython/menustrings.py:1388
+msgid "Patch number"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:462 ../gui/wxpython/menustrings.py:1389
+msgid ""
+"Calculates patch number index on a raster map, using a 4 neighbour algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:463 ../gui/wxpython/menustrings.py:1390
+msgid "Dominance's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:464 ../gui/wxpython/menustrings.py:1391
+msgid "Calculates dominance's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:465 ../gui/wxpython/menustrings.py:1392
+msgid "Shannon's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:466 ../gui/wxpython/menustrings.py:1393
+msgid "Calculates Shannon's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:467 ../gui/wxpython/menustrings.py:1394
+msgid "Simpson's diversity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:468 ../gui/wxpython/menustrings.py:1395
+msgid "Calculates Simpson's diversity index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:469 ../gui/wxpython/menustrings.py:1396
+msgid "Richness"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:470 ../gui/wxpython/menustrings.py:1397
+msgid "Calculates richness index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:471 ../gui/wxpython/menustrings.py:1398
+msgid "Shape index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:472 ../gui/wxpython/menustrings.py:1399
+msgid "Calculates shape index on a raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:473 ../gui/wxpython/menustrings.py:1400
+msgid "Wildfire modeling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:474 ../gui/wxpython/menustrings.py:1401
+msgid "Rate of spread"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:475 ../gui/wxpython/menustrings.py:1402
+msgid ""
+"Generates rate of spread raster maps. Generates three, or four raster map "
+"layers showing the base (perpendicular) rate of spread (ROS), the maximum "
+"(forward) ROS, the direction of the maximum ROS, and optionally the maximum "
+"potential spotting distance for fire spread simulation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:476 ../gui/wxpython/menustrings.py:1403
+msgid "Least-cost spread paths"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:477 ../gui/wxpython/menustrings.py:1404
+msgid ""
+"Recursively traces the least cost path backwards to cells from which the "
+"cumulative cost was determined."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:478 ../gui/wxpython/menustrings.py:1405
+msgid "Anisotropic spread simulation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:479 ../gui/wxpython/menustrings.py:1406
+msgid ""
+"Simulates elliptically anisotropic spread. Generates a raster map of the "
+"cumulative time of spread, given raster maps containing the rates of spread "
+"(ROS), the ROS directions and the spread origins. It optionally produces "
+"raster maps to contain backlink UTM coordinates for tracing spread paths. "
+"Usable for fire spread simulations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:480 ../gui/wxpython/menustrings.py:1407
+msgid "Change category values and labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:481 ../gui/wxpython/menustrings.py:1408
+msgid "Interactively edit category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:482 ../gui/wxpython/menustrings.py:1409
+msgid "Edits cell values in a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:483 ../gui/wxpython/menustrings.py:1410
+msgid "Reclassify by size"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:484 ../gui/wxpython/menustrings.py:1411
+msgid ""
+"Reclasses a raster map greater or less than user specified area size (in "
+"hectares)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:485 ../gui/wxpython/menustrings.py:693
+#: ../gui/wxpython/menustrings.py:1412 ../gui/wxpython/menustrings.py:1620
+msgid "Reclassify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:486 ../gui/wxpython/menustrings.py:1413
+msgid ""
+"Reclassify raster map based on category values. Creates a new raster map "
+"whose category values are based upon a reclassification of the categories in "
+"an existing raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:487 ../gui/wxpython/menustrings.py:1414
+msgid "Recode"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:488 ../gui/wxpython/menustrings.py:1415
+msgid "Recodes categorical raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:489 ../gui/wxpython/menustrings.py:1416
+msgid "Rescale"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:490 ../gui/wxpython/menustrings.py:1417
+msgid "Rescales the range of category values in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:491 ../gui/wxpython/menustrings.py:1418
+msgid "Rescale with histogram"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:492 ../gui/wxpython/menustrings.py:1419
+msgid ""
+"Rescales histogram equalized the range of category values in a raster map "
+"layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:493 ../gui/wxpython/menustrings.py:1420
+msgid "Generate random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:494 ../gui/wxpython/menustrings.py:1421
+msgid "Random cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:495 ../gui/wxpython/menustrings.py:1422
+msgid "Generates random cell values with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:496 ../gui/wxpython/menustrings.py:1423
+msgid "Random cells and vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:497 ../gui/wxpython/menustrings.py:1424
+msgid ""
+"Creates a raster map layer and vector point map containing randomly located "
+"points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:498 ../gui/wxpython/menustrings.py:1425
+msgid "Generate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:499 ../gui/wxpython/menustrings.py:1426
+msgid "Fractal surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:500 ../gui/wxpython/menustrings.py:1427
+msgid "Creates a fractal surface of a given fractal dimension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:501 ../gui/wxpython/menustrings.py:1428
+msgid "Gaussian kernel density surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:502 ../gui/wxpython/menustrings.py:1429
+msgid ""
+"Generates a raster density map from vector points map. Density is computed "
+"using a moving kernel. Optionally generates a vector density map on a vector "
+"network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:503 ../gui/wxpython/menustrings.py:1430
+msgid "Gaussian deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:504 ../gui/wxpython/menustrings.py:1431
+msgid ""
+"Generates a raster map using gaussian random number generator. Mean and "
+"standard deviation of gaussian deviates can be expressed by the user."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:505 ../gui/wxpython/menustrings.py:1432
+#: ../gui/wxpython/nviz/tools.py:4587
+msgid "Plane"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:506 ../gui/wxpython/menustrings.py:1433
+msgid ""
+"Creates raster plane map given dip (inclination), aspect (azimuth) and one "
+"point."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:507 ../gui/wxpython/menustrings.py:1434
+msgid "Random deviates surface"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:508 ../gui/wxpython/menustrings.py:1435
+msgid ""
+"Produces a raster surface map of uniform random deviates with defined range."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:509 ../gui/wxpython/menustrings.py:1436
+msgid "Random surface with spatial dependence"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:510 ../gui/wxpython/menustrings.py:1437
+msgid "Generates random surface(s) with spatial dependence."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:511 ../gui/wxpython/menustrings.py:1438
+msgid "Interpolate surfaces"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:512 ../gui/wxpython/menustrings.py:1439
+msgid "Bilinear and bicubic from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:513 ../gui/wxpython/menustrings.py:1440
+msgid ""
+"Performs bicubic or bilinear spline interpolation with Tykhonov "
+"regularization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:514 ../gui/wxpython/menustrings.py:1441
+msgid "IDW from raster points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:515 ../gui/wxpython/menustrings.py:1442
+msgid "Surface interpolation utility for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:516 ../gui/wxpython/menustrings.py:1443
+msgid "IDW from raster points (alternate method for sparse points)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:517 ../gui/wxpython/menustrings.py:1444
+msgid "Surface generation program."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:518 ../gui/wxpython/menustrings.py:1445
+msgid "IDW from vector points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:519 ../gui/wxpython/menustrings.py:1446
+msgid ""
+"Provides surface interpolation from vector point data by Inverse Distance "
+"Squared Weighting."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:520 ../gui/wxpython/menustrings.py:1447
+msgid "Raster contours"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:521 ../gui/wxpython/menustrings.py:1448
+msgid "Generates surface raster map from rasterized contours."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:522 ../gui/wxpython/menustrings.py:1449
+msgid "Regularized spline tension"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:523 ../gui/wxpython/menustrings.py:1450
+msgid ""
+"Performs surface interpolation from vector points map by splines. Spatial "
+"approximation and topographic analysis from given point or isoline data in "
+"vector format to floating point raster format using regularized spline with "
+"tension."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:524 ../gui/wxpython/menustrings.py:1451
+msgid "Ordinary or block kriging"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:525 ../gui/wxpython/menustrings.py:1452
+msgid "Performs ordinary or block kriging."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:526 ../gui/wxpython/menustrings.py:1453
+msgid "Fill NULL cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:527 ../gui/wxpython/menustrings.py:1454
+msgid "Fills no-data areas in raster maps using spline interpolation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:528 ../gui/wxpython/menustrings.py:732
+#: ../gui/wxpython/menustrings.py:840 ../gui/wxpython/menustrings.py:1010
+#: ../gui/wxpython/menustrings.py:1455 ../gui/wxpython/menustrings.py:1659
+#: ../gui/wxpython/menustrings.py:1767 ../gui/wxpython/menustrings.py:1937
+msgid "Reports and statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:529 ../gui/wxpython/menustrings.py:1456
+msgid "Basic raster metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:530 ../gui/wxpython/menustrings.py:1457
+msgid "Outputs basic information about a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:531 ../gui/wxpython/menustrings.py:1458
+msgid "Manage category information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:532 ../gui/wxpython/menustrings.py:1459
+msgid ""
+"Manages category values and labels associated with user-specified raster map "
+"layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:533 ../gui/wxpython/menustrings.py:1460
+msgid "General statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:534 ../gui/wxpython/menustrings.py:1461
+msgid "Generates area statistics for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:535 ../gui/wxpython/menustrings.py:1462
+msgid "Quantiles for large data sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:536 ../gui/wxpython/menustrings.py:1463
+msgid "Compute quantiles using two passes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:537 ../gui/wxpython/menustrings.py:1464
+msgid "Range of category values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:538 ../gui/wxpython/menustrings.py:1465
+msgid "Prints terse list of category values found in a raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:539 ../gui/wxpython/menustrings.py:1466
+msgid "Sum area by raster map and category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:540 ../gui/wxpython/menustrings.py:1467
+msgid "Reports statistics for raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:541 ../gui/wxpython/menustrings.py:1468
+msgid "Statistics for clumped cells"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:542 ../gui/wxpython/menustrings.py:1469
+msgid ""
+"Calculates the volume of data \"clumps\". Optionally produces a GRASS vector "
+"points map containing the calculated centroids of these clumps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:543 ../gui/wxpython/menustrings.py:1470
+msgid "Total corrected area"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:544 ../gui/wxpython/menustrings.py:1471
+msgid "Prints estimation of surface area for raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:546 ../gui/wxpython/menustrings.py:1473
+msgid ""
+"Calculates univariate statistics from the non-null cells of a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:547 ../gui/wxpython/menustrings.py:1474
+msgid "Sample transects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:548 ../gui/wxpython/menustrings.py:1475
+msgid "Outputs the raster map layer values lying on user-defined line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:549 ../gui/wxpython/menustrings.py:1476
+msgid "Sample transects (bearing/distance)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:550 ../gui/wxpython/menustrings.py:1477
+msgid ""
+"Outputs raster map layer values lying along user defined transect line(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:551 ../gui/wxpython/menustrings.py:1478
+msgid "Covariance/correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:552 ../gui/wxpython/menustrings.py:1479
+msgid ""
+"Outputs a covariance/correlation matrix for user-specified raster map layer"
+"(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:553 ../gui/wxpython/menustrings.py:1480
+msgid "Linear regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:554 ../gui/wxpython/menustrings.py:1481
+msgid "Calculates linear regression from two raster maps: y = a + b*x."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:555 ../gui/wxpython/menustrings.py:1482
+msgid "Multiple regression"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:556 ../gui/wxpython/menustrings.py:1483
+msgid "Calculates multiple linear regression from raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:557 ../gui/wxpython/menustrings.py:1484
+msgid "Mutual category occurrences"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:558 ../gui/wxpython/menustrings.py:1485
+msgid ""
+"Tabulates the mutual occurrence (coincidence) of categories for two raster "
+"map layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:559 ../gui/wxpython/menustrings.py:1486
+msgid "&Vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:560 ../gui/wxpython/menustrings.py:1487
+msgid "Develop vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:561 ../gui/wxpython/menustrings.py:1488
+#: ../gui/wxpython/gui_core/dialogs.py:234
+#: ../gui/wxpython/gui_core/dialogs.py:353
+msgid "Create new vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:562 ../gui/wxpython/menustrings.py:1489
+msgid "Create new empty vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:563 ../gui/wxpython/menustrings.py:1490
+msgid "Edit vector map (non-interactively)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:564 ../gui/wxpython/menustrings.py:1491
+msgid ""
+"Edits a vector map, allows adding, deleting and modifying selected vector "
+"features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:565 ../gui/wxpython/menustrings.py:1492
+msgid "Convert object types"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:566 ../gui/wxpython/menustrings.py:1493
+msgid "Changes type of vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:567 ../gui/wxpython/menustrings.py:1494
+msgid "Parallel lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:568 ../gui/wxpython/menustrings.py:1495
+msgid "Creates parallel line to input vector lines."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:569 ../gui/wxpython/menustrings.py:1496
+msgid "Dissolve boundaries"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:570 ../gui/wxpython/menustrings.py:1497
+msgid ""
+"Dissolves boundaries between adjacent areas sharing a common category number "
+"or attribute."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:571 ../gui/wxpython/menustrings.py:1498
+msgid "Create 3D vector over raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:572 ../gui/wxpython/menustrings.py:1499
+msgid "Converts 2D vector features to 3D by sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:573 ../gui/wxpython/menustrings.py:1500
+msgid "Extrude 3D vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:574 ../gui/wxpython/menustrings.py:1501
+msgid ""
+"Extrudes flat vector features to 3D vector features with defined height. "
+"Optionally the height can be derived from sampling of elevation raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:575 ../gui/wxpython/menustrings.py:1502
+msgid "Create labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:576 ../gui/wxpython/menustrings.py:1503
+msgid "Creates paint labels for a vector map from attached attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:577 ../gui/wxpython/menustrings.py:1504
+msgid "Create optimally placed labels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:578 ../gui/wxpython/menustrings.py:1505
+msgid "Reposition vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:579 ../gui/wxpython/menustrings.py:1506
+msgid ""
+"Performs an affine transformation (shift, scale and rotate) on vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:580 ../gui/wxpython/menustrings.py:1507
+msgid "Rectify vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:581 ../gui/wxpython/menustrings.py:1508
+msgid ""
+"Rectifies a vector by computing a coordinate transformation for each object "
+"in the vector based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:585 ../gui/wxpython/menustrings.py:1512
+msgid "Updates vector map metadata."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:586 ../gui/wxpython/menustrings.py:1513
+msgid "Topology maintenance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:587 ../gui/wxpython/menustrings.py:1514
+msgid "Create or rebuild topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:588 ../gui/wxpython/menustrings.py:1515
+msgid ""
+"Creates topology for vector map. Optionaly also checks for topological "
+"errors."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:589 ../gui/wxpython/menustrings.py:1516
+msgid "Rebuild topology on all vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:590 ../gui/wxpython/menustrings.py:1517
+msgid "Rebuilds topology on all vector maps in the current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:591 ../gui/wxpython/menustrings.py:1518
+msgid "Build polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:592 ../gui/wxpython/menustrings.py:1519
+msgid "Builds polylines from lines or boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:593 ../gui/wxpython/menustrings.py:1520
+msgid "Split lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:594 ../gui/wxpython/menustrings.py:1521
+msgid "Splits vector lines to shorter segments."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:595 ../gui/wxpython/menustrings.py:1522
+msgid "Split polylines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:596 ../gui/wxpython/menustrings.py:1523
+msgid "Creates points/segments from input vector lines and positions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:597 ../gui/wxpython/menustrings.py:1524
+msgid "Clean vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:598 ../gui/wxpython/menustrings.py:1525
+msgid "Toolset for cleaning topology of vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:599 ../gui/wxpython/menustrings.py:1526
+msgid "Smooth or simplify"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:600 ../gui/wxpython/menustrings.py:1527
+msgid "Performs vector based generalization."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:601 ../gui/wxpython/menustrings.py:1528
+msgid "Add centroids"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:602 ../gui/wxpython/menustrings.py:1529
+msgid "Adds missing centroids to closed boundaries."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:605 ../gui/wxpython/menustrings.py:1532
+msgid "Creates/modifies the color table associated with a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:607 ../gui/wxpython/menustrings.py:1534
+msgid "Interactive management of vector color tables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:609 ../gui/wxpython/menustrings.py:1536
+msgid "Exports the color table associated with a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:610 ../gui/wxpython/menustrings.py:1537
+msgid "Query vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:611 ../gui/wxpython/menustrings.py:1538
+msgid "Query with coordinate(s)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:612 ../gui/wxpython/menustrings.py:1539
+msgid "Queries a vector map at given locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:613 ../gui/wxpython/menustrings.py:909
+#: ../gui/wxpython/menustrings.py:1540 ../gui/wxpython/menustrings.py:1836
+msgid "Query vector attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:614 ../gui/wxpython/menustrings.py:910
+#: ../gui/wxpython/menustrings.py:1541 ../gui/wxpython/menustrings.py:1837
+msgid "Prints vector map attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:615 ../gui/wxpython/menustrings.py:1542
+msgid "Feature selection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:616 ../gui/wxpython/menustrings.py:1543
+msgid "Select by attributes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:617 ../gui/wxpython/menustrings.py:1544
+msgid ""
+"Selects vector features from an existing vector map and creates a new vector "
+"map containing only the selected features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:618 ../gui/wxpython/menustrings.py:1545
+msgid "Select by another map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:619 ../gui/wxpython/menustrings.py:1546
+msgid ""
+"Selects features from vector map (A) by features from other vector map (B)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:629 ../gui/wxpython/menustrings.py:1556
+msgid "Buffer vectors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:630 ../gui/wxpython/menustrings.py:1557
+msgid "Lidar analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:631 ../gui/wxpython/menustrings.py:1558
+msgid "Identify and remove outliers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:632 ../gui/wxpython/menustrings.py:729
+#: ../gui/wxpython/menustrings.py:1559 ../gui/wxpython/menustrings.py:1656
+msgid "Removes outliers from vector point data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:633 ../gui/wxpython/menustrings.py:1560
+msgid "Detect edges"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:634 ../gui/wxpython/menustrings.py:1561
+msgid "Detects the object's edges from a LIDAR data set."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:635 ../gui/wxpython/menustrings.py:1562
+msgid "Detect interiors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:636 ../gui/wxpython/menustrings.py:1563
+msgid ""
+"Building contour determination and Region Growing algorithm for determining "
+"the building inside"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:637 ../gui/wxpython/menustrings.py:1564
+msgid "Correct and reclassify objects"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:638 ../gui/wxpython/menustrings.py:1565
+msgid ""
+"Correction of the v.lidar.growing output. It is the last of the three "
+"algorithms for LIDAR filtering."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:639 ../gui/wxpython/menustrings.py:1566
+msgid "Linear referencing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:640 ../gui/wxpython/menustrings.py:1567
+msgid "Create LRS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:641 ../gui/wxpython/menustrings.py:1568
+msgid "Creates a linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:642 ../gui/wxpython/menustrings.py:1569
+msgid "Create stationing"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:643 ../gui/wxpython/menustrings.py:1570
+msgid "Creates stationing from input lines, and linear reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:644 ../gui/wxpython/menustrings.py:1571
+msgid "Create points/segments"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:645 ../gui/wxpython/menustrings.py:1572
+msgid ""
+"Creates points/segments from input lines, linear reference system and "
+"positions read from stdin or a file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:646 ../gui/wxpython/menustrings.py:1573
+msgid "Find line id and offset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:647 ../gui/wxpython/menustrings.py:1574
+msgid ""
+"Finds line id and real km+offset for given points in vector map using linear "
+"reference system."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:648 ../gui/wxpython/menustrings.py:1575
+msgid "Nearest features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:649 ../gui/wxpython/menustrings.py:1576
+msgid ""
+"Finds the nearest element in vector map 'to' for elements in vector map "
+"'from'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:650 ../gui/wxpython/menustrings.py:1577
+msgid "Network analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:652 ../gui/wxpython/menustrings.py:1579
+msgid "Tool for interactive vector network analysis."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:653 ../gui/wxpython/menustrings.py:1580
+msgid "Network preparation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:654 ../gui/wxpython/menustrings.py:1581
+msgid "Performs network maintenance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:655 ../gui/wxpython/menustrings.py:1582
+msgid "Allocate subnets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:656 ../gui/wxpython/menustrings.py:1583
+msgid ""
+"Allocate subnets for nearest centers (direction from center). center node "
+"must be opened (costs >= 0). Costs of center node are used in calculation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:657 ../gui/wxpython/menustrings.py:1584
+msgid "Split net"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:658 ../gui/wxpython/menustrings.py:1585
+msgid ""
+"Splits net by cost isolines. Splits net to bands between cost isolines "
+"(direction from centre). Centre node must be opened (costs >= 0). Costs of "
+"centre node are used in calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:659 ../gui/wxpython/menustrings.py:1586
+msgid "Shortest path"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:660 ../gui/wxpython/menustrings.py:1587
+msgid "Finds shortest path on vector network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:661 ../gui/wxpython/menustrings.py:1588
+msgid "Shortest path for sets of features"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:662 ../gui/wxpython/menustrings.py:1589
+msgid ""
+"Computes shortest distance via the network between the given sets of "
+"features. Finds the shortest paths from each 'from' point to the nearest "
+"'to' feature and various information about this relation are uploaded to the "
+"attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:663 ../gui/wxpython/menustrings.py:1590
+msgid "Shortest path using timetables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:664 ../gui/wxpython/menustrings.py:1591
+msgid "Finds shortest path using timetables."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:665 ../gui/wxpython/menustrings.py:1592
+msgid "Shortest path for all pairs"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:666 ../gui/wxpython/menustrings.py:1593
+msgid "Computes the shortest path between all pairs of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:667 ../gui/wxpython/menustrings.py:1594
+msgid "Visibility network"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:668 ../gui/wxpython/menustrings.py:1595
+msgid "Performs visibility graph construction."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:669 ../gui/wxpython/menustrings.py:1596
+msgid "Bridges and articulation points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:670 ../gui/wxpython/menustrings.py:1597
+msgid "Computes bridges and articulation points in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:671 ../gui/wxpython/menustrings.py:1598
+msgid "Maximum flow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:672 ../gui/wxpython/menustrings.py:1599
+msgid "Computes the maximum flow between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:673 ../gui/wxpython/menustrings.py:1600
+msgid "Vertex connectivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:674 ../gui/wxpython/menustrings.py:1601
+msgid "Computes vertex connectivity between two sets of nodes in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:675 ../gui/wxpython/menustrings.py:1602
+msgid "Components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:676 ../gui/wxpython/menustrings.py:1603
+msgid "Computes strongly and weakly connected components in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:677 ../gui/wxpython/menustrings.py:1604
+msgid "Centrality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:678 ../gui/wxpython/menustrings.py:1605
+msgid ""
+"Computes degree, centrality, betweeness, closeness and eigenvector "
+"centrality measures in the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:679 ../gui/wxpython/menustrings.py:1606
+msgid "Steiner tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:680 ../gui/wxpython/menustrings.py:1607
+msgid ""
+"Creates Steiner tree for the network and given terminals. Note that 'Minimum "
+"Steiner Tree' problem is NP-hard and heuristic algorithm is used in this "
+"module so the result may be sub optimal."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:681 ../gui/wxpython/menustrings.py:1608
+msgid "Minimum spanning tree"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:682 ../gui/wxpython/menustrings.py:1609
+msgid "Computes minimum spanning tree for the network."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:683 ../gui/wxpython/menustrings.py:1610
+msgid "Traveling salesman analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:684 ../gui/wxpython/menustrings.py:1611
+msgid ""
+"Creates a cycle connecting given nodes (Traveling salesman problem). Note "
+"that TSP is NP-hard, heuristic algorithm is used by this module and created "
+"cycle may be sub optimal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:685 ../gui/wxpython/menustrings.py:686
+#: ../gui/wxpython/menustrings.py:1612 ../gui/wxpython/menustrings.py:1613
+msgid "Overlay vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:687 ../gui/wxpython/menustrings.py:1614
+msgid "Overlays two vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:688 ../gui/wxpython/menustrings.py:1615
+msgid "Patch vector maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:689 ../gui/wxpython/menustrings.py:1616
+msgid "Creates a new vector map by combining other vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:690 ../gui/wxpython/menustrings.py:1617
+msgid "Manage categories"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:691 ../gui/wxpython/menustrings.py:1618
+msgid "Change or report categories"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:692 ../gui/wxpython/menustrings.py:1619
+msgid "Attaches, deletes or reports vector categories to map geometry."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:694 ../gui/wxpython/menustrings.py:1621
+msgid ""
+"Changes vector category values for an existing vector map according to "
+"results of SQL queries or a value in attribute table column."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:696 ../gui/wxpython/menustrings.py:1623
+msgid "Update area attributes from raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:697 ../gui/wxpython/menustrings.py:1624
+msgid ""
+"Calculates univariate statistics from a raster map based on vector polygon "
+"map and uploads statistics to new attribute columns."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:698 ../gui/wxpython/menustrings.py:1625
+msgid "Update area attributes from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:699 ../gui/wxpython/menustrings.py:1626
+msgid "Count points in areas, calculate statistics from point attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:700 ../gui/wxpython/menustrings.py:1627
+msgid "Update point attributes from areas"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:701 ../gui/wxpython/menustrings.py:1628
+msgid "Uploads vector values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:702 ../gui/wxpython/menustrings.py:1629
+msgid "Update database values from vector"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:703 ../gui/wxpython/menustrings.py:1630
+msgid "Populates attribute values from vector features."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:704 ../gui/wxpython/menustrings.py:1631
+msgid "Sample raster maps at point locations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:705 ../gui/wxpython/menustrings.py:1632
+msgid "Uploads raster values at positions of vector points to the table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:706 ../gui/wxpython/menustrings.py:1633
+msgid "Sample raster neighborhood around points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:707 ../gui/wxpython/menustrings.py:1634
+msgid "Samples a raster map at vector point locations."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:708 ../gui/wxpython/menustrings.py:1635
+msgid "Generate area for current region"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:709 ../gui/wxpython/menustrings.py:1636
+msgid "Creates a vector polygon from the current region extent."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:710 ../gui/wxpython/menustrings.py:1637
+msgid "Generate areas from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:711 ../gui/wxpython/menustrings.py:1638
+msgid "Convex hull"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:712 ../gui/wxpython/menustrings.py:1639
+msgid "Produces a 2D/3D convex hull for a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:713 ../gui/wxpython/menustrings.py:1640
+msgid "Delaunay triangles"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:714 ../gui/wxpython/menustrings.py:1641
+msgid ""
+"Creates a Delaunay triangulation from an input vector map containing points "
+"or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:715 ../gui/wxpython/menustrings.py:1642
+msgid "Voronoi diagram/Thiessen polygons"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:716 ../gui/wxpython/menustrings.py:1643
+msgid ""
+"Creates a Voronoi diagram in current region from an input vector map "
+"containing points or centroids."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:717 ../gui/wxpython/menustrings.py:1644
+msgid "Generate grid"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:718 ../gui/wxpython/menustrings.py:1645
+msgid "Creates a vector map of a user-defined grid."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:719 ../gui/wxpython/menustrings.py:1646
+msgid "Generate points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:720 ../gui/wxpython/menustrings.py:1647
+msgid "Generate from database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:721 ../gui/wxpython/menustrings.py:1648
+msgid ""
+"Creates new vector (points) map from database table containing coordinates."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:722 ../gui/wxpython/menustrings.py:1649
+msgid "Generate points along lines"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:723 ../gui/wxpython/menustrings.py:1650
+msgid "Creates points along input lines in new vector map with 2 layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:724 ../gui/wxpython/menustrings.py:1651
+msgid "Generate random points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:725 ../gui/wxpython/menustrings.py:1652
+msgid "Generates random 2D/3D vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:726 ../gui/wxpython/menustrings.py:1653
+msgid "Perturb points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:727 ../gui/wxpython/menustrings.py:1654
+msgid "Random location perturbations of vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:728 ../gui/wxpython/menustrings.py:1655
+msgid "Remove outliers in point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:730 ../gui/wxpython/menustrings.py:1657
+msgid "Test/training point sets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:731 ../gui/wxpython/menustrings.py:1658
+msgid "Randomly partition points into test/train sets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:733 ../gui/wxpython/menustrings.py:1660
+msgid "Basic vector metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:734 ../gui/wxpython/menustrings.py:1661
+msgid "Outputs basic information about a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:735 ../gui/wxpython/menustrings.py:1662
+msgid "Classify attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:736 ../gui/wxpython/menustrings.py:1663
+msgid "Classifies attribute data, e.g. for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:737 ../gui/wxpython/menustrings.py:1664
+msgid "Report topology by category"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:738 ../gui/wxpython/menustrings.py:1665
+msgid "Reports geometry statistics for vector maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:739 ../gui/wxpython/menustrings.py:1666
+msgid "Univariate attribute statistics for points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:740 ../gui/wxpython/menustrings.py:1667
+msgid ""
+"Calculates univariate statistics for attribute. Variance and standard "
+"deviation is calculated only for points if specified."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:741 ../gui/wxpython/menustrings.py:1668
+msgid "Univariate statistics for attribute columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:742 ../gui/wxpython/menustrings.py:1669
+msgid ""
+"Calculates univariate statistics on selected table column for a GRASS vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:743 ../gui/wxpython/menustrings.py:1670
+msgid "Quadrat indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:744 ../gui/wxpython/menustrings.py:1671
+msgid "Indices for quadrat counts of sites lists."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:745 ../gui/wxpython/menustrings.py:1672
+msgid "Test normality"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:746 ../gui/wxpython/menustrings.py:1673
+msgid "Tests for normality for vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:747 ../gui/wxpython/menustrings.py:1674
+msgid "&Imagery"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:748 ../gui/wxpython/menustrings.py:1675
+msgid "Develop images and groups"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:749 ../gui/wxpython/menustrings.py:1676
+msgid "Create/edit group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:750 ../gui/wxpython/menustrings.py:1677
+msgid "Creates, edits, and lists groups of imagery files."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:751 ../gui/wxpython/menustrings.py:1678
+msgid "Target group"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:752 ../gui/wxpython/menustrings.py:1679
+msgid "Targets an imagery group to a GRASS location and mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:753 ../gui/wxpython/menustrings.py:1680
+msgid "Mosaic images"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:754 ../gui/wxpython/menustrings.py:1681
+msgid "Mosaics several images and extends colormap."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:755 ../gui/wxpython/menustrings.py:1682
+msgid "Manage image colors"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:756 ../gui/wxpython/menustrings.py:1683
+msgid "Color balance for RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:757 ../gui/wxpython/menustrings.py:1684
+msgid "Performs auto-balancing of colors for LANDSAT images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:758 ../gui/wxpython/menustrings.py:1685
+msgid "HIS to RGB"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:759 ../gui/wxpython/menustrings.py:1686
+msgid ""
+"Transforms raster maps from HIS (Hue-Intensity-Saturation) color space to "
+"RGB (Red-Green-Blue) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:761 ../gui/wxpython/menustrings.py:1688
+msgid ""
+"Transforms raster maps from RGB (Red-Green-Blue) color space to HIS (Hue-"
+"Intensity-Saturation) color space."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:762 ../gui/wxpython/menustrings.py:1689
+msgid "Rectify image or raster"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:763 ../gui/wxpython/menustrings.py:1690
+msgid ""
+"Rectifies an image by computing a coordinate transformation for each pixel "
+"in the image based on the control points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:765 ../gui/wxpython/menustrings.py:1692
+msgid "Generate histogram of image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:766 ../gui/wxpython/menustrings.py:1693
+msgid "Spectral response"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:767 ../gui/wxpython/menustrings.py:1694
+msgid ""
+"Displays spectral response at user specified locations in group or images."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:768 ../gui/wxpython/menustrings.py:1695
+msgid "Pan sharpening"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:769 ../gui/wxpython/menustrings.py:1696
+msgid ""
+"Image fusion algorithms to sharpen multispectral with high-res panchromatic "
+"channels"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:770 ../gui/wxpython/menustrings.py:1697
+msgid "Classify image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:771 ../gui/wxpython/menustrings.py:1698
+msgid "Clustering input for unsupervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:772 ../gui/wxpython/menustrings.py:1699
+msgid ""
+"Generates spectral signatures for land cover types in an image using a "
+"clustering algorithm. The resulting signature file is used as input for i."
+"maxlik, to generate an unsupervised image classification."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:773 ../gui/wxpython/menustrings.py:1700
+msgid "Input for supervised MLC"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:774 ../gui/wxpython/menustrings.py:1701
+msgid "Generates statistics for i.maxlik from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:775 ../gui/wxpython/menustrings.py:1702
+msgid "Maximum likelihood classification (MLC)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:776 ../gui/wxpython/menustrings.py:1703
+msgid ""
+"Classifies the cell spectral reflectances in imagery data. Classification is "
+"based on the spectral signature information generated by either i.cluster, i."
+"class, or i.gensig."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:777 ../gui/wxpython/menustrings.py:1704
+#: ../gui/wxpython/menustrings.py:1960
+msgid "Interactive input for supervised classification"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:778 ../gui/wxpython/menustrings.py:1705
+#: ../gui/wxpython/menustrings.py:1961
+msgid ""
+"Generates spectral signatures by allowing the user to outline training areas."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:779 ../gui/wxpython/menustrings.py:1706
+msgid "Input for supervised SMAP"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:780 ../gui/wxpython/menustrings.py:1707
+msgid "Generates statistics for i.smap from raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:781 ../gui/wxpython/menustrings.py:1708
+msgid "Sequential maximum a posteriori classification (SMAP)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:782 ../gui/wxpython/menustrings.py:1709
+msgid ""
+"Performs contextual image classification using sequential maximum a "
+"posteriori (SMAP) estimation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:783 ../gui/wxpython/menustrings.py:1710
+msgid "Object segmentation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:784 ../gui/wxpython/menustrings.py:1711
+msgid "Identifies segments (objects) from imagery data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:785 ../gui/wxpython/menustrings.py:1712
+msgid "Filter image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:786 ../gui/wxpython/menustrings.py:1713
+msgid "Edge detection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:787 ../gui/wxpython/menustrings.py:1714
+msgid "Zero-crossing \"edge detection\" raster function for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:788 ../gui/wxpython/menustrings.py:1715
+msgid "Matrix/convolving filter"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:789 ../gui/wxpython/menustrings.py:1716
+msgid "Performs raster map matrix filter."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:790 ../gui/wxpython/menustrings.py:1717
+msgid "Transform image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:791 ../gui/wxpython/menustrings.py:1718
+msgid "Canonical correlation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:792 ../gui/wxpython/menustrings.py:1719
+msgid "Canonical components analysis (CCA) program for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:793 ../gui/wxpython/menustrings.py:1720
+msgid "Principal components"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:794 ../gui/wxpython/menustrings.py:1721
+msgid "Principal components analysis (PCA) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:795 ../gui/wxpython/menustrings.py:1722
+msgid "Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:796 ../gui/wxpython/menustrings.py:1723
+msgid "Fast Fourier Transform (FFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:797 ../gui/wxpython/menustrings.py:1724
+msgid "Inverse Fast Fourier"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:798 ../gui/wxpython/menustrings.py:1725
+msgid "Inverse Fast Fourier Transform (IFFT) for image processing."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:799 ../gui/wxpython/menustrings.py:1726
+msgid "Satellite images tools"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:800 ../gui/wxpython/menustrings.py:1727
+msgid "Aster DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:801 ../gui/wxpython/menustrings.py:1728
+msgid ""
+"Calculates Top of Atmosphere Radiance/Reflectance/Brightness Temperature "
+"from ASTER DN."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:802 ../gui/wxpython/menustrings.py:1729
+msgid "Landsat DN to radiance/reflectance"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:803 ../gui/wxpython/menustrings.py:1730
+msgid ""
+"Calculates top-of-atmosphere radiance or reflectance and temperature for "
+"Landsat MSS/TM/ETM+/OLI"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:804 ../gui/wxpython/menustrings.py:1731
+msgid "Landsat cloud cover assessment"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:805 ../gui/wxpython/menustrings.py:1732
+msgid "Performs Landsat TM/ETM+ Automatic Cloud Cover Assessment (ACCA)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:806 ../gui/wxpython/menustrings.py:1733
+msgid "Modis quality control"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:807 ../gui/wxpython/menustrings.py:1734
+msgid "Extracts quality control parameters from Modis QC layers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:808 ../gui/wxpython/menustrings.py:1735
+msgid "Atmospheric correction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:809 ../gui/wxpython/menustrings.py:1736
+msgid ""
+"Performs atmospheric correction using the 6S algorithm. 6S - Second "
+"Simulation of Satellite Signal in the Solar Spectrum."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:810 ../gui/wxpython/menustrings.py:1737
+msgid "Satellite images products"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:811 ../gui/wxpython/menustrings.py:1738
+msgid "Vegetation indices"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:812 ../gui/wxpython/menustrings.py:1739
+msgid ""
+"Calculates different types of vegetation indices. Uses red and nir bands "
+"mostly, and some indices require additional bands."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:813 ../gui/wxpython/menustrings.py:1740
+msgid "Tasseled cap vegetation index"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:814 ../gui/wxpython/menustrings.py:1741
+msgid ""
+"Performs Tasseled Cap (Kauth Thomas) transformation for LANDSAT-TM data."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:815 ../gui/wxpython/menustrings.py:1742
+msgid "Albedo"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:816 ../gui/wxpython/menustrings.py:1743
+msgid "Computes broad band albedo from surface reflectance."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:817 ../gui/wxpython/menustrings.py:1744
+msgid "Emissivity"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:818 ../gui/wxpython/menustrings.py:1745
+msgid "Computes emissivity from NDVI, generic method for sparse land."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:819 ../gui/wxpython/menustrings.py:1746
+msgid "Biomass growth"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:820 ../gui/wxpython/menustrings.py:1747
+msgid "Computes biomass growth, precursor of crop yield calculation."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:821 ../gui/wxpython/menustrings.py:1748
+msgid "Evapotranspiration calculation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:822 ../gui/wxpython/menustrings.py:1749
+msgid "Instantaneaous Net Radiation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:823 ../gui/wxpython/menustrings.py:1750
+msgid "Net radiation approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:824 ../gui/wxpython/menustrings.py:1751
+msgid "Soil heat flux"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:825 ../gui/wxpython/menustrings.py:1752
+msgid "Soil heat flux approximation (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:826 ../gui/wxpython/menustrings.py:1753
+msgid "Sensible heat flux"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:827 ../gui/wxpython/menustrings.py:1754
+msgid "Computes sensible heat flux iteration SEBAL 01."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:828 ../gui/wxpython/menustrings.py:1755
+msgid "Evaporative fraction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:829 ../gui/wxpython/menustrings.py:1756
+msgid ""
+"Computes evaporative fraction (Bastiaanssen, 1995) and root zone soil "
+"moisture (Makin, Molden and Bastiaanssen, 2001)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:830 ../gui/wxpython/menustrings.py:1757
+msgid "Actual Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:831 ../gui/wxpython/menustrings.py:1758
+msgid "Actual evapotranspiration for diurnal period (Bastiaanssen, 1995)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:832 ../gui/wxpython/menustrings.py:1759
+msgid "Temporal integration of ETa"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:833 ../gui/wxpython/menustrings.py:1760
+msgid ""
+"Computes temporal integration of satellite ET actual (ETa) following the "
+"daily ET reference (ETo) from meteorological station(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:834 ../gui/wxpython/menustrings.py:1761
+msgid "Hargreaves methods Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:835 ../gui/wxpython/menustrings.py:1762
+msgid ""
+"Computes evapotranspiration calculation modified or original Hargreaves "
+"formulation, 2001."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:836 ../gui/wxpython/menustrings.py:1763
+msgid "Penman-Monteith Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:837 ../gui/wxpython/menustrings.py:1764
+msgid ""
+"Computes potential evapotranspiration calculation with hourly Penman-"
+"Monteith."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:838 ../gui/wxpython/menustrings.py:1765
+msgid "Priestley-Taylor Evapotranspiration"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:839 ../gui/wxpython/menustrings.py:1766
+msgid ""
+"Computes evapotranspiration calculation Prestley and Taylor formulation, "
+"1972."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:841 ../gui/wxpython/menustrings.py:1768
+msgid "Bit pattern comparison "
+msgstr ""
+#: ../gui/wxpython/menustrings.py:842 ../gui/wxpython/menustrings.py:1769
+msgid "Compares bit patterns with a raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:843 ../gui/wxpython/menustrings.py:1770
+msgid "Kappa analysis"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:844 ../gui/wxpython/menustrings.py:1771
+msgid ""
+"Calculates error matrix and kappa parameter for accuracy assessment of "
+"classification result."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:845 ../gui/wxpython/menustrings.py:1772
+msgid "OIF for LandSat TM"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:846 ../gui/wxpython/menustrings.py:1773
+msgid "Calculates Optimum-Index-Factor table for spectral bands"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:847 ../gui/wxpython/menustrings.py:1774
+msgid "V&olumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:848 ../gui/wxpython/menustrings.py:1775
+msgid "Develop volumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:849 ../gui/wxpython/menustrings.py:1776
+msgid "Manage 3D NULL values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:850 ../gui/wxpython/menustrings.py:1777
+msgid "Explicitly create the 3D NULL-value bitmap file."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:851 ../gui/wxpython/menustrings.py:1778
+msgid "Manage timestamp"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:852 ../gui/wxpython/menustrings.py:1779
+msgid "Print/add/remove a timestamp for a 3D raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:856 ../gui/wxpython/menustrings.py:1783
+msgid "3D color tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:857 ../gui/wxpython/menustrings.py:1784
+msgid "Creates/modifies the color table associated with a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:858 ../gui/wxpython/menustrings.py:1785
+msgid "Export 3D color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:859 ../gui/wxpython/menustrings.py:1786
+msgid "Exports the color table associated with a 3D raster map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:860 ../gui/wxpython/menustrings.py:1787
+msgid "3D Mask"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:861 ../gui/wxpython/menustrings.py:1788
+msgid "Establishes the current working 3D raster mask."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:862 ../gui/wxpython/menustrings.py:1789
+msgid "Volume calculator"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:863 ../gui/wxpython/menustrings.py:1790
+msgid "3D raster map calculator."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:864 ../gui/wxpython/menustrings.py:1791
+msgid "Cross section"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:865 ../gui/wxpython/menustrings.py:1792
+msgid ""
+"Creates cross section 2D raster map from 3D raster map based on 2D elevation "
+"map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:867 ../gui/wxpython/menustrings.py:1794
+msgid ""
+"Numerical calculation program for transient, confined groundwater flow in "
+"three dimensions."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:868 ../gui/wxpython/menustrings.py:1795
+msgid "Interpolate volume from points"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:869 ../gui/wxpython/menustrings.py:1796
+msgid ""
+"Interpolates point data to a 3D raster map using regularized spline with "
+"tension (RST) algorithm."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:870 ../gui/wxpython/menustrings.py:1797
+msgid "Reports and Statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:871 ../gui/wxpython/menustrings.py:1798
+msgid "Basic volume metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:872 ../gui/wxpython/menustrings.py:1799
+msgid "Outputs basic information about a user-specified 3D raster map layer."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:873 ../gui/wxpython/menustrings.py:1800
+msgid "Voxel statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:874 ../gui/wxpython/menustrings.py:1801
+msgid "Generates volume statistics for 3D raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:875 ../gui/wxpython/menustrings.py:1802
+msgid "Univariate statistics for volumes"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:876 ../gui/wxpython/menustrings.py:1803
+msgid ""
+"Calculates univariate statistics from the non-null 3d cells of a raster3d "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:877 ../gui/wxpython/menustrings.py:1804
+msgid "&Database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:878 ../gui/wxpython/menustrings.py:1805
+msgid "Database information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:879 ../gui/wxpython/menustrings.py:1806
+msgid "List databases"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:880 ../gui/wxpython/menustrings.py:1807
+msgid "Lists all databases for a given driver and location."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:881 ../gui/wxpython/menustrings.py:1808
+msgid "List drivers"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:882 ../gui/wxpython/menustrings.py:1809
+msgid "Lists all database drivers."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:883 ../gui/wxpython/menustrings.py:1810
+msgid "List tables"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:884 ../gui/wxpython/menustrings.py:1811
+msgid "Lists all tables for a given database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:885 ../gui/wxpython/menustrings.py:1812
+msgid "Describe table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:886 ../gui/wxpython/menustrings.py:1813
+msgid "Describes a table in detail."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:887 ../gui/wxpython/menustrings.py:1814
+msgid "List columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:888 ../gui/wxpython/menustrings.py:1815
+msgid "List all columns for a given table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:889 ../gui/wxpython/menustrings.py:1816
+msgid "Manage databases"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:890 ../gui/wxpython/menustrings.py:1817
+msgid "Connect"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:891 ../gui/wxpython/menustrings.py:1818
+msgid "Prints/sets general DB connection for current mapset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:892 ../gui/wxpython/menustrings.py:1819
+msgid "Login"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:893 ../gui/wxpython/menustrings.py:1820
+msgid "Sets user/password for DB driver/database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:894 ../gui/wxpython/menustrings.py:1821
+msgid "Create database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:895 ../gui/wxpython/menustrings.py:1822
+msgid "Creates an empty database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:896 ../gui/wxpython/menustrings.py:1823
+msgid "Drop database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:897 ../gui/wxpython/menustrings.py:1824
+msgid "Removes an existing database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:898 ../gui/wxpython/menustrings.py:1825
+msgid "Drop table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:899 ../gui/wxpython/menustrings.py:1826
+msgid "Drops an attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:900 ../gui/wxpython/menustrings.py:1827
+msgid "Copy table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:901 ../gui/wxpython/menustrings.py:1828
+msgid ""
+"Copy a table. Either 'from_table' (optionally with 'where') can be used or "
+"'select' option, but not 'from_table' and 'select' at the same time."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:902 ../gui/wxpython/menustrings.py:922
+#: ../gui/wxpython/menustrings.py:1829 ../gui/wxpython/menustrings.py:1849
+msgid "Drop column"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:903 ../gui/wxpython/menustrings.py:1830
+msgid "Drops a column from selected attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:904 ../gui/wxpython/menustrings.py:1831
+msgid "Test"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:905 ../gui/wxpython/menustrings.py:1832
+msgid "Test database driver, database must exist and set by db.connect."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:907 ../gui/wxpython/menustrings.py:1834
+msgid "Query any table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:908 ../gui/wxpython/menustrings.py:1835
+msgid "Selects data from attribute table. Performs SQL query statement(s)."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:911 ../gui/wxpython/menustrings.py:1838
+msgid "SQL statement"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:912 ../gui/wxpython/menustrings.py:1839
+msgid "Executes any SQL statement. For SELECT statements use 'db.select'."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:913 ../gui/wxpython/menustrings.py:1840
+msgid "Vector database connections"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:914 ../gui/wxpython/menustrings.py:1841
+msgid "New table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:915 ../gui/wxpython/menustrings.py:1842
+msgid ""
+"Creates and connects a new attribute table to a given layer of an existing "
+"vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:916 ../gui/wxpython/menustrings.py:1843
+msgid "Remove table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:917 ../gui/wxpython/menustrings.py:1844
+msgid "Removes existing attribute table of a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:918 ../gui/wxpython/menustrings.py:1845
+msgid "Join table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:919 ../gui/wxpython/menustrings.py:1846
+msgid "Joins a database table to a vector map table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:920 ../gui/wxpython/menustrings.py:1847
+msgid "Add columns"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:921 ../gui/wxpython/menustrings.py:1848
+msgid ""
+"Adds one or more columns to the attribute table connected to a given vector "
+"map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:923 ../gui/wxpython/menustrings.py:1850
+msgid ""
+"Drops a column from the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:925 ../gui/wxpython/menustrings.py:1852
+msgid ""
+"Renames a column in the attribute table connected to a given vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:926 ../gui/wxpython/menustrings.py:1853
+msgid "Change values"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:927 ../gui/wxpython/menustrings.py:1854
+msgid "Updates a column in the attribute table connected to a vector map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:928 ../gui/wxpython/menustrings.py:1855
+msgid "Drop row"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:929 ../gui/wxpython/menustrings.py:1856
+msgid "Removes a vector feature from a vector map through attribute selection."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:930 ../gui/wxpython/menustrings.py:1857
+msgid "Reconnect vectors to database"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:931 ../gui/wxpython/menustrings.py:1858
+msgid ""
+"Reconnects attribute tables for all vector maps from the current mapset to a "
+"new database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:932 ../gui/wxpython/menustrings.py:1859
+msgid "Set vector map - database connection"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:933 ../gui/wxpython/menustrings.py:1860
+msgid "Prints/sets DB connection for a vector map to attribute table."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:934 ../gui/wxpython/menustrings.py:1861
+msgid "Temporal"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:935 ../gui/wxpython/menustrings.py:1862
+msgid "Manage datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:936 ../gui/wxpython/menustrings.py:1863
+#: ../gui/wxpython/rlisetup/frame.py:133
+msgid "Create"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:937 ../gui/wxpython/menustrings.py:1864
+msgid "Creates a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:939 ../gui/wxpython/menustrings.py:1866
+msgid "Renames a space time dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:941 ../gui/wxpython/menustrings.py:1868
+msgid "Removes space time datasets from temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:942 ../gui/wxpython/menustrings.py:1869
+msgid "Update metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:943 ../gui/wxpython/menustrings.py:1870
+msgid "Modifies the metadata of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:944 ../gui/wxpython/menustrings.py:1871
+msgid "Merge"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:945 ../gui/wxpython/menustrings.py:1872
+msgid "Merge several space time datasets into a single one"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:946 ../gui/wxpython/menustrings.py:1873
+msgid "Temporally shift"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:947 ../gui/wxpython/menustrings.py:1874
+msgid "Temporally shift the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:948 ../gui/wxpython/menustrings.py:1875
+msgid "Snap maps of dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:949 ../gui/wxpython/menustrings.py:1876
+msgid "Temporally snap the maps of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:951 ../gui/wxpython/menustrings.py:1878
+msgid "Lists space time datasets and maps registered in the temporal database."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:952 ../gui/wxpython/menustrings.py:1879
+msgid "Manage maps in datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:953 ../gui/wxpython/menustrings.py:1880
+msgid "Register maps in datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:954 ../gui/wxpython/menustrings.py:1881
+msgid "Registers raster, vector and raster3d maps in a space time datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:955 ../gui/wxpython/menustrings.py:1882
+msgid "Unregister maps from datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:956 ../gui/wxpython/menustrings.py:1883
+msgid ""
+"Unregisters raster, vector and raster3d maps from the temporal database or a "
+"specific space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:957 ../gui/wxpython/menustrings.py:1884
+msgid "List raster dataset maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:958 ../gui/wxpython/menustrings.py:1885
+msgid "Lists registered maps of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:959 ../gui/wxpython/menustrings.py:1886
+msgid "List vector dataset maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:960 ../gui/wxpython/menustrings.py:1887
+msgid "Lists registered maps of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:961 ../gui/wxpython/menustrings.py:1888
+msgid "List raster3D dataset maps"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:962 ../gui/wxpython/menustrings.py:1889
+msgid "Lists registered maps of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:963 ../gui/wxpython/menustrings.py:1890
+msgid "Import"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:964 ../gui/wxpython/menustrings.py:1891
+msgid "Import raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:965 ../gui/wxpython/menustrings.py:1892
+msgid "Imports space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:966 ../gui/wxpython/menustrings.py:1893
+msgid "Import vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:967 ../gui/wxpython/menustrings.py:1894
+msgid "Import a space time vector dataset archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:969 ../gui/wxpython/menustrings.py:1896
+msgid "Export raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:970 ../gui/wxpython/menustrings.py:1897
+msgid "Exports space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:971 ../gui/wxpython/menustrings.py:1898
+msgid "Export raster dataset as VTK time series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:972 ../gui/wxpython/menustrings.py:1899
+msgid "Exports space time raster dataset as VTK time series."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:973 ../gui/wxpython/menustrings.py:1900
+msgid "Export vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:974 ../gui/wxpython/menustrings.py:1901
+msgid "Export a space time vector dataset.as GRASS specific archive file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:975 ../gui/wxpython/menustrings.py:1902
+msgid "Convert raster dataset to volume"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:976 ../gui/wxpython/menustrings.py:1903
+msgid "Converts a space time raster dataset into a raster3d map."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:977 ../gui/wxpython/menustrings.py:1904
+msgid "Extraction"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:978 ../gui/wxpython/menustrings.py:1905
+msgid "Extract subset of raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:979 ../gui/wxpython/menustrings.py:1906
+msgid "Extracts a subset of a space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:980 ../gui/wxpython/menustrings.py:1907
+msgid "Extract subset of vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:981 ../gui/wxpython/menustrings.py:1908
+msgid "Extracts a subset of a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:982 ../gui/wxpython/menustrings.py:1909
+msgid "Extract subset of raster3D dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:983 ../gui/wxpython/menustrings.py:1910
+msgid "Extracts a subset of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:984 ../gui/wxpython/menustrings.py:1911
+msgid "Query vector dataset attribute data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:985 ../gui/wxpython/menustrings.py:1912
+msgid ""
+"Prints attributes of vector maps registered in a space time vector dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:986 ../gui/wxpython/menustrings.py:1913
+msgid "Raster dataset color table"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:987 ../gui/wxpython/menustrings.py:1914
+msgid ""
+"Creates/modifies the color table associated with each raster map of the "
+"space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:988 ../gui/wxpython/menustrings.py:1915
+msgid "Raster calculations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:989 ../gui/wxpython/menustrings.py:1916
+msgid ""
+"Perform spatio-temporal mapcalc expressions on temporal sampled maps of "
+"space time raster datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:990 ../gui/wxpython/menustrings.py:1917
+msgid "Raster3D calculations"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:991 ../gui/wxpython/menustrings.py:1918
+msgid ""
+"Performs r3.mapcalc expressions on maps of sampled space time raster3d "
+"datasets."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:992 ../gui/wxpython/menustrings.py:1919
+msgid "Interpolate gaps in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:993 ../gui/wxpython/menustrings.py:1920
+msgid ""
+"Replace gaps in a space time raster dataset with interpolated raster maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:994 ../gui/wxpython/menustrings.py:1921
+msgid "Aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:995 ../gui/wxpython/menustrings.py:1922
+msgid "Neighborhood analysis in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:996 ../gui/wxpython/menustrings.py:1923
+msgid ""
+"Performs a neighborhood analysis for each map in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:997 ../gui/wxpython/menustrings.py:1924
+msgid "Aggregation in raster datasets"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:998 ../gui/wxpython/menustrings.py:1925
+msgid ""
+"Performs different aggregation algorithms from r.series on all or a subset "
+"of raster maps in a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:999 ../gui/wxpython/menustrings.py:1926
+msgid "Temporal aggregation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1000 ../gui/wxpython/menustrings.py:1927
+msgid ""
+"Temporally aggregates the maps of a space time raster dataset by a user "
+"defined granularity."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1001 ../gui/wxpython/menustrings.py:1928
+msgid "Temporal aggregation by dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1002 ../gui/wxpython/menustrings.py:1929
+msgid ""
+"Aggregated data of an existing space time raster dataset using the time "
+"intervals of a second space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1003 ../gui/wxpython/menustrings.py:1930
+msgid "Sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1004 ../gui/wxpython/menustrings.py:1931
+msgid "Temporal sampling"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1005 ../gui/wxpython/menustrings.py:1932
+msgid ""
+"Samples the input space time dataset(s) with a sample space time dataset and "
+"print the result to stdout."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1006 ../gui/wxpython/menustrings.py:1933
+msgid "Query raster dataset by vector points dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1007 ../gui/wxpython/menustrings.py:1934
+msgid ""
+"Store raster map values at spatial and temporal positions of vector points "
+"as vector attributes."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1008 ../gui/wxpython/menustrings.py:1935
+msgid "Observe specific locations in raster dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1009 ../gui/wxpython/menustrings.py:1936
+msgid ""
+"Observes specific locations in a space time raster dataset over a period of "
+"time using vector points."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1011 ../gui/wxpython/menustrings.py:1938
+msgid "Space time datasets metadata"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1012 ../gui/wxpython/menustrings.py:1939
+msgid "Lists information about space time datasets and maps."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1013 ../gui/wxpython/menustrings.py:1940
+msgid "Univariate raster dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1014 ../gui/wxpython/menustrings.py:1941
+msgid ""
+"Calculates univariate statistics from the non-null cells for each registered "
+"raster map of a space time raster dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1015 ../gui/wxpython/menustrings.py:1942
+msgid "Univariate vector dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1016 ../gui/wxpython/menustrings.py:1943
+msgid ""
+"Calculates univariate statistics of attributes for each registered vector "
+"map of a space time vector dataset"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1017 ../gui/wxpython/menustrings.py:1944
+msgid "Univariate raster3D dataset statistics"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1018 ../gui/wxpython/menustrings.py:1945
+msgid ""
+"raster3d map of a space time raster3d dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1019 ../gui/wxpython/menustrings.py:1946
+msgid "Report temporal topology"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1020 ../gui/wxpython/menustrings.py:1947
+msgid "Lists temporal topology of a space time dataset."
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1021 ../gui/wxpython/menustrings.py:1948
+#: ../gui/wxpython/menustrings.py:1952
+msgid "GUI tools"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1024 ../gui/wxpython/menustrings.py:1951
+msgid "Plot temporal extents"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1025 ../gui/wxpython/menustrings.py:2011
+#: ../gui/wxpython/menustrings.py:2054
+msgid "&Help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1026
+msgid "GRASS help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1027 ../gui/wxpython/menustrings.py:1029
+msgid "Display the HTML man pages of GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1028
+msgid "GUI help"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1030
+msgid "About system"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1031
+msgid "Prints system information"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1032 ../gui/wxpython/menustrings.py:1033
+#: ../gui/wxpython/gui_core/ghelp.py:47
+msgid "About GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1036
+msgid "Import, export and link data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1955
+msgid "Attribute table manager"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1970
+msgid "Create new model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1972
+msgid "Load model from file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1976
+msgid "Save model to file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1978
+msgid "Close model file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1979
+msgid "Export to image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1980
+msgid "Export model to image"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1981
+msgid "Export to Python"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1982
+msgid "Export model to Python script"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1983
+msgid "Quit modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1984
+msgid "Close modeler window"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1988
+msgid "&Model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1989
+msgid "Add command"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1990
+msgid "Add action (GRASS command) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1991
+msgid "Add data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1992
+msgid "Add data item to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1993
+msgid "Define relation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1994
+msgid "Define relation between data and action items"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1995
+msgid "Add loop / series"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1996
+msgid "Adds loop (series) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1997
+msgid "Add condition"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:1998
+msgid "Adds condition (if/else) to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2000
+msgid "Adds comment to model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2001
+msgid "Remove item"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2002
+msgid "Remove action/data from model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2004
+msgid "Model properties (name, purpose, etc.)"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2005
+msgid "Delete intermediate data"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2006
+msgid "Delete intermediate data defined in the model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2008
+msgid "Run entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2009
+msgid "Validate model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2010
+msgid "Validate entire model"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2013
+msgid "Display the HTML man pages of Graphical modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2014
+msgid "About Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2015
+msgid "Display information about Graphical Modeler"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2020 ../gui/wxpython/psmap/toolbars.py:70
+msgid "Specify paper size, margins and orientation"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2021
+msgid "Load instruction file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2022 ../gui/wxpython/psmap/toolbars.py:63
+msgid "Load text file with mapping instructions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2023
+msgid "Export instruction file"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2024 ../gui/wxpython/psmap/toolbars.py:61
+msgid "Generate text file with mapping instructions"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2025
+msgid "Export to PostScript"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2026 ../gui/wxpython/psmap/toolbars.py:65
+msgid "Generate PostScript output"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2027
+msgid "Export to PDF"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2028 ../gui/wxpython/psmap/toolbars.py:67
+msgid "Generate PDF output"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2029 ../gui/wxpython/menustrings.py:2030
+msgid "Launch ps.map dialog"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2032
+msgid "Close Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2033
+msgid "&Insert"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2034 ../gui/wxpython/psmap/toolbars.py:75
+#: ../gui/wxpython/psmap/dialogs.py:619 ../gui/wxpython/psmap/dialogs.py:674
+msgid "Map frame"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2035
+msgid "Add or edit map frame"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2037
+msgid "Add or edit raster map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2039
+msgid "Add or edit vector map"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2040
+msgid "Map legend"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2041
+msgid "Add or edit raster and vector legend"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2042 ../gui/wxpython/psmap/toolbars.py:86
+msgid "Map info"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2043
+msgid "Add or edit map info"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2044 ../gui/wxpython/psmap/toolbars.py:90
+#: ../gui/wxpython/nviz/tools.py:1991
+msgid "Scale bar"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2045
+msgid "Add or edit scale bar"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2050 ../gui/wxpython/psmap/toolbars.py:94
+#: ../gui/wxpython/psmap/dialogs.py:4494 ../gui/wxpython/nviz/tools.py:1946
+msgid "North Arrow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2051
+msgid "Add north arrow"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2053 ../gui/wxpython/psmap/toolbars.py:78
+msgid "Delete selected object"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2056
+msgid "Display the HTML man pages of Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2057
+msgid "About Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/menustrings.py:2058
+msgid "Display information about Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:33
+msgid "Set opacity level"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:35 ../gui/wxpython/iclass/dialogs.py:261
+msgid "Class manager"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:37 ../gui/wxpython/iclass/dialogs.py:42
+#: ../gui/wxpython/iscatt/toolbars.py:43
+msgid "Select imagery group"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:39
+msgid "Run analysis, update histogram and coincidence plots"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:41
+msgid "Save signature file for i.maxlik"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:43
+msgid "Remove selected map layer"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:45
+msgid "Export training areas to vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:47
+msgid "Import training areas from vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:66
+msgid "Training"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:70
+msgid "Set map canvas for "
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:72
+msgid "/ Zoom to map"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:244
+#: ../gui/wxpython/iclass/toolbars.py:249
+msgid "std dev"
+msgstr ""
+#: ../gui/wxpython/iclass/toolbars.py:319
+msgid "Add raster map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:39
+#, python-format
+msgid ""
+"Loading imagery lib failed.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:75
+msgid "GRASS GIS Supervised Classification Tool"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:301
+msgid "IClass Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:313
+msgid "IClass Misc Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:330
+msgid "Digitization Toolbar"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:354
+msgid "Plots"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:374
+msgid "Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:377
+msgid "Training Areas Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:445
+msgid "Adjust Training Area Display to Preview Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:446
+msgid "Adjust Preview display to Training Area Display"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:447
+msgid "Display synchronization ON"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:448
+msgid "Display synchronization OFF"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:518
+msgid "All changes will be lost. Do you want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:526
+msgid "Import vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:545
+#, python-format
+msgid "No areas in vector map <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:547
+#, python-format
+msgid "Vector map <%s> contains points or lines, these features are ignored."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:572
+#, python-format
+msgid "Unable to open vector map <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:579
+#, python-format
+msgid "Unable to copy vector features from <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:589
+msgid "Unable to open temporary vector map"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:679
+msgid "No training areas to export."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:691
+#, python-format
+msgid "%d training areas (%d classes) exported to vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:890
+msgid "Failed to create temporary vector map."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:966
+#, python-format
+msgid "No area in category %s. Category skipped."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:969
+msgid "Analysis failed."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:976
+msgid "results"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:982
+msgid "No imagery group selected."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:987
+msgid ""
+"Due to recent changes in classes, signatures can be outdated and should be "
+"recalculated. Do you still want to continue?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:990
+msgid "Outdated signatures"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1006
+#, python-format
+msgid ""
+"A signature file named %s already exists.\n"
+"Do you want to replace it?"
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1054
+msgid "No imagery group selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1063
+#, python-format
+msgid ""
+"Group <%(group)s> does not have enough files (it has %(files)d files). "
+"Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1072
+msgid "No areas given. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/frame.py:1087
+msgid "Vector features are outside raster layers. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/iclass/statistics.py:29
+msgid "Loading imagery lib failed"
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:57
+msgid ""
+"You are trying to create a training area outside the computational region. "
+"Please, use g.region to set the appropriate region first."
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:66
+msgid ""
+"In order to create a training area, you have to select class first.\n"
+"\n"
+"There is no class yet, do you want to create one?"
+msgstr ""
+#: ../gui/wxpython/iclass/digit.py:70
+#: ../gui/wxpython/iscatt/controllers.py:407
+msgid "No class selected"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:78
+msgid "Name of imagery group is missing."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:85
+msgid "Name of imagery group:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:97
+msgid "Name of imagery subgroup:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:171
+msgid "Please choose a subgroup."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:174
+#, python-format
+msgid "Subgroup <%s> not found in group <%s>"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:180
+#, python-format
+msgid ""
+"No data found in subgroup <%s> of group <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:185
+#, python-format
+msgid ""
+"No data found in group <%s>.\n"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:189
+#: ../gui/wxpython/iclass/g.gui.iclass.py:72
+#, python-format
+msgid "Group <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:232
+msgid "Name of map is missing."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:276 ../gui/wxpython/iscatt/frame.py:129
+msgid "Classes"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:356 ../gui/wxpython/iscatt/frame.py:375
+msgid "Class name"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:389 ../gui/wxpython/iscatt/frame.py:412
+msgid "Please use only ASCII characters."
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:499
+msgid "Zoom to training areas of selected class"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:556
+msgid "Save signature file"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:613
+msgid "Enter name of signature file:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:622
+msgid "Signature file path:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:664
+msgid "Export training areas"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:708 ../gui/wxpython/iscatt/dialogs.py:253
+msgid "Enter name of new vector map:"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:718
+msgid "Export attribute table"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:720
+msgid "Export attribute table containing computed statistical data"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:758
+#, python-format
+msgid "Vector map <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/iclass/dialogs.py:760
+#, python-format
+msgid "Vector <%s> exists"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:66
+msgid "Histograms"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:67
+msgid "Coincident plots"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:68
+msgid "Scatter plots"
+msgstr ""
+#: ../gui/wxpython/iclass/plots.py:83
+#, python-format
+msgid ""
+"Scatter plot functionality is disabled.\n"
+"\n"
+"Reason: Unable to import packages needed for scatter plot.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:69
+msgid "Name of subgroup required"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:74
+#, python-format
+msgid "Subgroup <%s> not found"
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:107
+#, python-format
+msgid "Loading raster map <%s>..."
+msgstr ""
+#: ../gui/wxpython/iclass/g.gui.iclass.py:110
+#, python-format
+msgid "Loading training map <%s>..."
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:205
+#: ../gui/wxpython/rlisetup/sampling_frame.py:308
+#, python-format
+msgid "The raster file %s already exists, please change name"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:229
+msgid "Raster map not created. Please redraw region."
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:330
+msgid "Raster map not created. redraw region again."
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:382
+#: ../gui/wxpython/rlisetup/wizard.py:676
+msgid "Draw sampling frame"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:383
+msgid "Draw sampling frame by clicking and dragging"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:385
+msgid "Draw sampling rectangle"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:386
+msgid "Draw sampling rectangle by clicking and dragging"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:388
+msgid "Draw sampling circle"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:389
+msgid "Draw sampling circle radius by clicking and dragging"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:391
+#: ../gui/wxpython/rlisetup/wizard.py:964
+#: ../gui/wxpython/rlisetup/wizard.py:1308
+msgid "Draw sampling region"
+msgstr ""
+#: ../gui/wxpython/rlisetup/sampling_frame.py:392
+msgid "Draw sampling region by polygon. Right Double click to end drawing"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:22
+msgid "Modify the configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:35
+msgid "View and modify the configuration file '{name}'"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:84
+msgid ""
+"Are you sure that you want modify r.li configuration file {name}?\n"
+"You could broke the configuration file..."
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:88
+msgid "WARNING"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:105
+msgid "GRASS GIS Setup for r.li modules"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:122
+msgid "Available sampling area configuration files"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:131
+msgid "Remove a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:134
+msgid "Create a new configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:137
+msgid "Rename a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:139
+msgid "View/Edit"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:140
+msgid "View and edit a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:213
+#, python-format
+msgid "Do you want remove r.li configuration file <%s>?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:215
+msgid "Remove new r.li configuration file?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:238 ../gui/wxpython/rlisetup/frame.py:258
+msgid "You have to select a configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:241
+#, python-format
+msgid ""
+"Set te new name for %s \" "
+"\"configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/frame.py:243
+msgid "Rename configuration file"
+msgstr ""
+#: ../gui/wxpython/rlisetup/functions.py:107
+#: ../gui/wxpython/rlisetup/wizard.py:1510
+msgid "The polygon seems to have 0 areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:52
+msgid "Create new configuration file for r.li modules"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:116
+#, python-format
+msgid "Do you want to create r.li configuration file <%s>?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:118
+msgid "Create new r.li configuration file?"
+msgstr ""
+msgid "r.li.setup wizard canceled. Configuration file not created."
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:429
+msgid "Select maps and define name"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:440
+msgid "Name for new configuration file to create"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:452
+msgid "Raster map to use to select areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:462
+msgid "Vector map to use to select areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:472
+msgid "Define sampling region (region for analysis)"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:474
+#: ../gui/wxpython/rlisetup/wizard.py:734
+msgid "Whole map layer"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:475
+msgid "Keyboard setting"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:476
+msgid "Draw the sampling frame"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:508
+#, python-format
+msgid "The configuration file %s already exists, please change name"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:564
+msgid "Insert sampling frame parameter"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:575
+msgid "Column of upper left corner"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:588
+msgid "Row of upper left corner"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:601
+#: ../gui/wxpython/rlisetup/wizard.py:613
+msgid "Row lenght of sampling frame"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:728
+msgid "Insert sampling areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:735
+msgid "Regions"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:736
+msgid "Sample units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:738
+msgid ""
+"Select areas from the\n"
+"overlayed vector map"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:747
+msgid "Choose a method"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:748
+msgid "Use keyboard to enter sampling area"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:749
+msgid "Use mouse to draw sampling area"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:753
+msgid "This option is not supported yet"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:765
+msgid "Number of regions to draw:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:779
+msgid "Do you want to check vector areas?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:781
+msgid "Select if use area by area"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:783
+msgid "All the features will be used"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:796
+msgid "Analysing all vector features..."
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:888
+msgid "Analysing vector"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:902
+msgid "All feature are been analyzed."
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:906
+msgid "An error occurred"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:937
+msgid "Draw sampling regions"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:954
+msgid "Draw sample region "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:962
+#: ../gui/wxpython/rlisetup/wizard.py:1302
+msgid "Draw moving windows region"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1002
+msgid "Select sample units from keyboard"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1016
+#: ../gui/wxpython/rlisetup/wizard.py:1180
+#: ../gui/wxpython/rlisetup/wizard.py:1261
+msgid "Select type of shape"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1017
+#: ../gui/wxpython/rlisetup/wizard.py:1181
+#: ../gui/wxpython/rlisetup/wizard.py:1262
+#: ../gui/wxpython/psmap/toolbars.py:100
+msgid "Rectangle"
+msgstr ""
+msgid "Circle"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1039
+#: ../gui/wxpython/rlisetup/wizard.py:1206
+msgid "Width size (in cells)? "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1040
+#: ../gui/wxpython/rlisetup/wizard.py:1207
+msgid "What radius size (in meters)? "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1041
+#: ../gui/wxpython/rlisetup/wizard.py:1208
+msgid "Height size (in cells)? "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1042
+#: ../gui/wxpython/rlisetup/wizard.py:1209
+msgid "Name of the circle mask"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1048
+msgid "Select method of sampling unit distribution"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1049
+msgid "Random non overlapping"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1050
+msgid "Systematic contiguos"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1051
+msgid "Stratified random"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1052
+msgid "Systematic non contiguos"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1053
+msgid "Centered over sites"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1060
+#: ../gui/wxpython/rlisetup/wizard.py:1120
+msgid "What number of Sampling Units to use?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1134
+msgid "Insert number of row strates"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1135
+msgid "Insert number of column strates"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1141
+msgid "Insert distance between units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1171
+msgid "Set sample units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1192
+msgid "Width size (in cells) ?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1199
+msgid "Height size (in cells) ?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1219
+msgid "Set moving windows"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1255
+#: ../gui/wxpython/rlisetup/wizard.py:1354
+msgid "Draw sampling units"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1273
+msgid "Number of sampling area to draw:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1371
+msgid "Draw Sampling "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1426
+msgid "Select sampling areas"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1435
+msgid "Is this area ok?"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1456
+msgid "Select sample area "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1513
+msgid "Select sample area 1 of "
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1543
+msgid "Configuration file name:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1553
+msgid "Raster name:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1563
+msgid "Vector name:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1573
+msgid "Region type:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1593
+msgid "Sampling area type:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1659
+msgid "Region keyboard values:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1673
+#: ../gui/wxpython/rlisetup/wizard.py:1698
+#: ../gui/wxpython/rlisetup/wizard.py:1702
+msgid "Type of shape:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1676
+#: ../gui/wxpython/rlisetup/wizard.py:1705
+msgid "Radius size:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1677
+#: ../gui/wxpython/rlisetup/wizard.py:1706
+msgid "Name circle mask:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1679
+#: ../gui/wxpython/rlisetup/wizard.py:1708
+msgid "Width size:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1680
+#: ../gui/wxpython/rlisetup/wizard.py:1709
+msgid "Heigth size:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1683
+msgid "Method of distribution:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1686
+msgid "Number sampling units:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1689
+msgid "Distance between units:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1692
+msgid "Number row strates:"
+msgstr ""
+#: ../gui/wxpython/rlisetup/wizard.py:1694
+msgid "Number column strates:"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:36
+msgid "Display map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:37
+msgid "Re-render modified map layers only"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:39
+msgid "Render map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:40
+msgid "Force re-rendering all map layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:42
+msgid "Erase display"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:43
+msgid "Erase display canvas with given background color"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:45
+msgid "Pointer"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:47
+msgid "Zoom in"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:48
+msgid "Drag or click mouse to zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:50
+msgid "Zoom out"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:51
+msgid "Drag or click mouse to unzoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:53
+msgid "Return to previous zoom"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:55
+msgid "Various zoom options"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:56
+msgid "Zoom to default or saved region, save to named region, ..."
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:58
+msgid "Zoom to selected map layer(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:60
+msgid "Zoom to computational region extent"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:62
+msgid "Pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:63
+msgid "Drag with mouse to pan"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:65
+msgid "Save display to file"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:69
+msgid "Select font"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:79
+msgid "Add map elements"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:80
+msgid "Overlay elements like scale and legend onto map"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:82
+msgid "Create histogram with d.histogram"
+msgstr ""
+#: ../gui/wxpython/gui_core/toolbars.py:255
+msgid "Select graphics tool"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:58
+msgid "Info"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:59
+msgid "Copyright"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:60
+msgid "License"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:61
+msgid "Authors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:62
+msgid "Contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:63
+msgid "Extra contributors"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:64
+msgid "Translators"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:65
+msgid "Translation status"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:130
+msgid "Official GRASS site:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:141
+msgid "Code Revision"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:204 ../gui/wxpython/gui_core/ghelp.py:416
+msgid "Language"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:233 ../gui/wxpython/gui_core/ghelp.py:257
+#: ../gui/wxpython/gui_core/ghelp.py:281 ../gui/wxpython/gui_core/ghelp.py:338
+#: ../gui/wxpython/gui_core/ghelp.py:400 ../gui/wxpython/gui_core/ghelp.py:549
+#, python-format
+msgid "%s file missing"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:324 ../gui/wxpython/gui_core/ghelp.py:386
+#, python-format
+msgid "Error when reading file '%s'."
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:325 ../gui/wxpython/gui_core/ghelp.py:387
+msgid "Lines:"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:343 ../gui/wxpython/gui_core/ghelp.py:345
+#: ../gui/wxpython/gui_core/ghelp.py:412
+msgid "E-mail"
+msgstr ""
+msgid "Country"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:345
+msgid "OSGeo_ID"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:420
+msgid "Nation"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:454
+#, python-format
+msgid " %d translated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:458 ../gui/wxpython/gui_core/ghelp.py:484
+#, python-format
+msgid " %d fuzzy"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:462 ../gui/wxpython/gui_core/ghelp.py:493
+#, python-format
+msgid " %d untranslated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:475
+#, python-format
+msgid "%d translated"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:546
+#, python-format
+msgid "File <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:700
+msgid "&Next"
+msgstr ""
+#: ../gui/wxpython/gui_core/ghelp.py:703
+msgid "&Previous"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:139
+msgid "Double-click or Ctrl-Enter to run selected module"
+msgstr ""
+#: ../gui/wxpython/gui_core/menu.py:157
+msgid "Run selected module from the tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:57
+#, python-format
+msgid ""
+"Unable to import pyGRASS: %s\n"
+"Some functionality will be not accessible"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:456
+msgid "Not selectable element"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:493
+#: ../gui/wxpython/gui_core/preferences.py:1760
+msgid "Mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:504
+msgid "Type: "
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:515
+#, python-format
+msgid "GSelect: invalid item: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1070 ../gui/wxpython/gis_set.py:835
+msgid "Choose GIS Data Directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1289
+msgid "Output settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1291
+msgid "Source settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1302
+msgid "Native"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1308
+msgid "File"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1312
+#: ../gui/wxpython/gui_core/forms.py:1535
+msgid "Directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1320
+msgid "Protocol"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1331
+msgid "Output type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1333
+msgid "Source type"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1365
+msgid "ZIP files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1366
+msgid "GZIP files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1367
+msgid "TAR files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1368
+msgid "TARGZ files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1369
+msgid "All files"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1375
+msgid "File:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1376
+msgid "Choose file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1389
+#: ../gui/wxpython/gui_core/gselect.py:1451
+msgid "Choose input directory"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1403
+msgid "Extension:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1428
+msgid "Choose file"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1440
+#: ../gui/wxpython/gui_core/gselect.py:2107
+msgid "Feature type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1441
+msgid "simple features"
+msgstr ""
+msgid "topological"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1547
+#: ../gui/wxpython/gui_core/gselect.py:1578
+#: ../gui/wxpython/gui_core/gselect.py:1629
+#: ../gui/wxpython/gui_core/gselect.py:1667
+msgid "Creation options:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1561
+#: ../gui/wxpython/gui_core/gselect.py:1600
+#: ../gui/wxpython/gui_core/gselect.py:1652
+msgid "Format:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1659
+msgid "Protocol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:1682
+msgid "No settings available"
+msgstr ""
+#: ../gui/wxpython/gui_core/gselect.py:2099
+#: ../gui/wxpython/psmap/toolbars.py:96 ../gui/wxpython/psmap/dialogs.py:4526
+#: ../gui/wxpython/vdigit/preferences.py:536
+msgid "Point"
+msgstr ""
+msgid "LineString"
+msgstr ""
+msgid "Polygon"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:95
+msgid "Toolbar"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:131
+msgid "Copy map names to clipboard (top to bottom)"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:132
+msgid "Copy map names to clipboard (bottom to top)"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:412
+msgid "Remove selected map(s) from list"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:414
+msgid "Layer up"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:415
+msgid "Move selected layer(s) up"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:417
+msgid "Layer down"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:418
+msgid "Move selected layer(s) down"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:420
+#: ../gui/wxpython/gui_core/simplelmgr.py:421
+msgid "Edit layer properties"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:423
+msgid "Change opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/simplelmgr.py:424
+msgid "Change layer opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:76
+msgid "Required item is not set."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:106
+msgid "Select GRASS location and mapset"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:118
+msgid "Location or mapset is not defined."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:125
+msgid "Name of GRASS location:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:131
+#: ../gui/wxpython/gui_core/dialogs.py:178
+msgid "Name of mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:156
+msgid "Select mapset in GRASS location"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:170
+msgid "Name of mapset is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:189
+#: ../gui/wxpython/vdigit/toolbars.py:801
+#: ../gui/wxpython/vdigit/toolbars.py:939
+#: ../gui/wxpython/vdigit/toolbars.py:1026
+msgid "Select vector map"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:205
+msgid "Name of vector map is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:256
+msgid "Create attribute table"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:271
+#: ../gui/wxpython/gui_core/preferences.py:836
+msgid "Add created map into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:280
+msgid "Name of new vector map is missing."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:289
+msgid "Name for new vector map:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:303
+#: ../gui/wxpython/gui_core/preferences.py:1165
+msgid "Key column:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:386
+#, python-format
+msgid "Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:391
+#, python-format
+msgid ""
+"Invalid or empty key column.\n"
+"Unable to create vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:419
+#, python-format
+msgid ""
+"Vector map <%s> already exists in the current mapset. Do you want to "
+"overwrite it?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:502
+msgid "Load region:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:506
+msgid "Save region:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:548
+msgid "Create or edit imagery groups"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:581
+msgid "Apply changes to selected group and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:582
+msgid "Apply changes to selected group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:583
+msgid "Close dialog, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:624
+#: ../gui/wxpython/gui_core/dialogs.py:1369
+msgid ""
+"Put here a regular expression. Characters '.*' stand for anything, character "
+"'^' stands for the beginning and '$' for the end."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:631
+msgid "Select existing group or enter name of new group:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:642
+msgid "Edit/create subgroup"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:651
+msgid "Select existing subgroup or enter name of new subgroup:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:679
+#: ../gui/wxpython/gui_core/dialogs.py:732
+#: ../gui/wxpython/gui_core/dialogs.py:1356
+msgid "Pattern:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:694
+#: ../gui/wxpython/gui_core/dialogs.py:746
+#: ../gui/wxpython/gui_core/dialogs.py:1375
+msgid "List of maps:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:704
+msgid "Select map layers and add them to the list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:708
+msgid "Remove selected layer(s) from list."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:751
+msgid "Check maps from group to be included into subgroup."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:909
+msgid "Add selected map layers into group"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1044
+#, python-format
+msgid "Group <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1046
+#: ../gui/wxpython/gui_core/dialogs.py:1058
+msgid "Unapplied changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1056
+#, python-format
+msgid "Subgroup <%s> was changed, do you want to apply changes?"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1112
+msgid "No raster maps selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1141
+#, python-format
+msgid "No changes to apply in group <%s>."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1144
+#, python-format
+msgid "Group <%s> was successfully created."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1146
+#, python-format
+msgid "Group <%s> was successfully changed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1149
+#, python-format
+msgid "Creating of new group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1151
+#, python-format
+msgid "Changing of group <%s> failed."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1189
+msgid "No group selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1195
+msgid "No subgroup selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1298
+msgid "Use fully-qualified map names"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1314
+msgid "3D raster"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1324
+msgid "Map type:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1339
+msgid "Select toggle"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1346
+msgid "Mapset:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1432
+msgid "Invert selection"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1566
+#, python-format
+msgid "Dynamic series (%s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1591
+msgid "Multiple import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1607
+msgid "List of raster layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1609
+msgid "List of vector layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1611
+#, python-format
+msgid "List of %s layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1612
+msgid "right click to (un)select all"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1615
+msgid "Layer id"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1617
+msgid "Name for output GRASS map (editable)"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1619
+#: ../gui/wxpython/psmap/dialogs.py:1648
+msgid "Feature type"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1620
+msgid "Projection match"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1657
+#: ../gui/wxpython/gui_core/forms.py:571
+msgid "Close dialog on finish"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1668
+#: ../gui/wxpython/gui_core/dialogs.py:1847
+msgid "&Import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1669
+#: ../gui/wxpython/gui_core/dialogs.py:1848
+msgid "Import selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1833
+msgid "this might not work for multiple bands"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1835
+msgid "Add linked layers into layer tree ({mightNotWork})"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1838
+msgid "Add imported layers into layer tree ({mightNotWork})"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1844
+msgid "&Link"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1845
+msgid "Link selected layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1857
+msgid "No layers selected. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1961
+msgid "Define output format for vector data"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1963
+msgid "Define output format for raster data"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:1971
+msgid "Set external format and close dialog"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2023
+msgid "No data source selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2036
+msgid "Import DXF layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2040
+msgid "Choose DXF file to import"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2046
+msgid "Add imported layers into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2060
+msgid "No layers selected."
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2197
+msgid "Set Map Layer Opacity"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2222
+#: ../gui/wxpython/psmap/dialogs.py:4604 ../gui/wxpython/psmap/dialogs.py:4619
+#: ../gui/wxpython/psmap/dialogs.py:4858 ../gui/wxpython/psmap/dialogs.py:4879
+msgid "transparent"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2225
+msgid "opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2321
+msgid "Set image size"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2330
+msgid "Image size"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2377
+msgid "Template:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2415
+msgid "GRASS GIS SQL Query Utility"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2426
+msgid " SQL statement "
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2471
+msgid "Symbols"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2498
+msgid "Symbol directory:"
+msgstr ""
+#: ../gui/wxpython/gui_core/dialogs.py:2506
+msgid "Symbol name:"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:466
+msgid "Enter parameters for '"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:477
+msgid "Close this window without executing the command (Ctrl+Q)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:503
+msgid "Run the command (Ctrl+R)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:525
+msgid "Show manual page of the command (Ctrl+H)"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:556
+msgid "Add created map(s) into layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:573
+msgid ""
+"Close dialog when command is successfully finished. Change this settings in "
+"Preferences dialog ('Command' tab)."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:740
+#, python-format
+msgid "'%s' copied to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:807 ../gui/wxpython/gui_core/forms.py:820
+msgid "Required"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:810 ../gui/wxpython/gui_core/forms.py:820
+msgid "Optional"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:889
+#: ../gui/wxpython/gui_core/forms.py:1601
+msgid "Parameterized in model"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:966
+msgid "[multiple]"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1015
+msgid "valid range"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1269
+msgid "Show graphical representation of temporal extent of dataset(s) ."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1449
+#: ../gui/wxpython/gui_core/preferences.py:973
+#: ../gui/wxpython/gui_core/preferences.py:995
+msgid "Transparent"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1478
+#: ../gui/wxpython/gui_core/forms.py:1534
+#, python-format
+msgid "Choose %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1509
+msgid "&Save as"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1513
+msgid "or enter values interactively"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1786
+msgid "Manual"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1827
+msgid "Nothing to load."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1835
+#, python-format
+msgid ""
+"Unable to load file.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:1865
+msgid "Save input as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2172
+msgid "No dataset given."
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2325
+#, python-format
+msgid "Unable to parse command '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2331
+#, python-format
+msgid "%(cmd)s: parameter '%(key)s' not available"
+msgstr ""
+#: ../gui/wxpython/gui_core/forms.py:2421
+msgid "Try to set up GRASS_ADDON_PATH or GRASS_ADDON_BASE variable."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:84
+msgid " (...)"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:862
+msgid "Fulltext search"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:863
+msgid "Type to search in all modules. Press Enter for next match."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:920
+msgid "Searching, please type more characters."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:929
+#, python-format
+msgid "%d modules match"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1003
+msgid "Save current settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1006
+msgid "Delete currently selected settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1027
+msgid "Load settings:"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1045
+#, python-format
+msgid "Settings <%s> not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1059
+#: ../gui/wxpython/gui_core/widgets.py:1075
+msgid "Save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1064
+msgid "Name not given, settings is not saved."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1073
+#, python-format
+msgid "Settings <%s> already exists. Do you want to overwrite the settings?"
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1122
+msgid "No settings is defined. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/gui_core/widgets.py:1156
+msgid "Unable to save settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:28
+msgid "Query results"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:40
+msgid "Right click to copy selected values to clipboard."
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:44
+msgid "Feature"
+msgstr ""
+msgid "Value"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:60
+msgid "Copy all to clipboard"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:63
+msgid "Redirect to console"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:111 ../gui/wxpython/gui_core/query.py:112
+#, python-format
+msgid "Copy from '%s' column"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:113
+msgid "Copy selected lines"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:116 ../gui/wxpython/gui_core/query.py:119
+#, python-format
+msgid "Copy '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:120
+msgid "Copy line"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:142
+msgid "Query results:"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:145
+msgid " "
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:222
+msgid "east, north"
+msgstr ""
+#: ../gui/wxpython/gui_core/query.py:233
+msgid "Nothing found"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:57
+msgid "User settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:80
+msgid "Set to default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:88
+msgid "Revert settings to default and apply changes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:153
+msgid "Settings applied to current session but not saved"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:211
+msgid "Key column cannot be empty string."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:225
+msgid "GUI Settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:252
+msgid "Layer Manager settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:262
+msgid "Ask when removing map layer from layer tree"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:272
+msgid "Ask when quiting wxGUI or closing display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:282
+#: ../gui/wxpython/gui_core/preferences.py:292
+#, python-format
+msgid "Hide '%s' tab (requires GUI restart)"
+msgstr ""
+msgid "Search module"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:305
+msgid "Automatically copy selected text to clipboard (in Command console)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:320
+msgid "Workspace settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:327
+msgid "Suppress positioning Map Display Window(s)"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:339
+msgid "Suppress positioning Layer Manager window"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:350
+msgid "Save current window layout as default"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:353
+msgid ""
+"Save current position and size of Layer Manager window and opened Map "
+"Display window(s) and use as default for next sessions."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:372
+#: ../gui/wxpython/nviz/tools.py:96
+msgid "Appearance"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:389
+msgid "Font for command output:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:403
+msgid "Language settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:412
+msgid "Choose language (requires to save and GRASS restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:437
+msgid "Appearance settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:447
+msgid "Element list:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:469
+msgid "Menu style (requires to save and GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:493
+msgid "Height of map selection popup window (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:517
+msgid "Icon theme (requires GUI restart):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:537
+msgid "Module dialog style:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:570
+msgid "Map Display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:584
+msgid "Default font for GRASS displays:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:602
+msgid "Default display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:612
+msgid "Display driver:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:632
+msgid "Statusbar mode:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:697
+msgid "Enable auto-rendering"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:710
+msgid "Enable auto-zooming to selected map layer"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:723
+msgid "Mouse wheel action:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:738
+msgid "Mouse scrolling direction:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:764
+msgid "Advanced display settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:770
+msgid "3D view depth buffer (possible values are 16, 24, 32):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:802
+msgid "Modules"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:805
+msgid "Module dialog settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:826
+msgid "Close dialog when module is successfully finished"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:847
+msgid "Allow interactive input"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:857
+msgid "Verbosity level:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:882
+msgid "Layers"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:888
+msgid "Default raster settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:898
+msgid "Make null cells opaque"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:909
+msgid "Default color table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:936
+msgid "Default vector settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:942
+msgid "Display:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:961
+msgid "Feature color:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:983
+msgid "Area fill color:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1026
+msgid "Symbol:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1053
+#: ../gui/wxpython/vdigit/preferences.py:361
+msgid "Attributes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1079
+msgid "Line width (in pixels):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1089
+msgid "Automatically hightlight selected features in map display"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1109
+msgid "Data browser"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1114
+msgid "Left mouse double click:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1126
+msgid "Encoding (e.g. utf-8, ascii, iso8859-1, koi8-r):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1137
+msgid "Ask when deleting data record(s) from table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1158
+msgid "Create table"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1199
+msgid "Projection statusbar settings"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1207
+msgid ""
+"\n"
+"Note: This only controls the coordinates displayed in the lower-left of the "
+"Map Display\n"
+"window's status bar. It is purely cosmetic and does not affect the working "
+"location's\n"
+"projection in any way. You will need to enable the Projection check box in "
+"the drop-down\n"
+"menu located at the bottom of the Map Display window.\n"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1239
+msgid "Proj.4 string (required):"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1255
+msgid "EPSG file:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1270
+msgid ""
+"Load EPSG codes (be patient), enter EPSG code or insert Proj.4 string "
+"directly."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1278
+msgid "&Load EPSG codes"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1290
+msgid "Coordinates format"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1298
+msgid "Lat/long projections"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1317
+msgid "Precision:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1384
+#, python-format
+msgid "Unable to read EPSG codes: %s"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1413
+#: ../gui/wxpython/gui_core/preferences.py:1422
+#: ../gui/wxpython/gui_core/preferences.py:1431
+#, python-format
+msgid "EPSG code %s not found"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1439
+msgid "Select default display font"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1544
+msgid "Select font:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1568
+msgid "Character encoding:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1586
+#: ../gui/wxpython/psmap/dialogs.py:292 ../gui/wxpython/psmap/dialogs.py:3555
+msgid "Font size:"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1674
+msgid "Manage access to mapsets"
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1687
+msgid ""
+"Check a mapset to make it accessible, uncheck it to hide it.\n"
+" Notes:\n"
+" - The current mapset is always accessible.\n"
+" - You may only write to the current mapset.\n"
+" - You may only write to mapsets which you own."
+msgstr ""
+#: ../gui/wxpython/gui_core/preferences.py:1761
+msgid "Owner"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:114
+msgid "Click here to show search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:115
+msgid "Click here to hide search module engine"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:130
+msgid "Command prompt"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:132
+msgid "Output window"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:139
+msgid "Clear output window content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:141
+msgid "Clear command prompt content"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:143
+msgid "Save output window content to the file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:145
+msgid "Abort running command"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:147
+msgid "&Log file"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:149
+msgid ""
+"Toggle to save list of executed commands into a file; content saved when "
+"switching off."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:372
+#: ../gui/wxpython/gui_core/goutput.py:459
+msgid "Save file as..."
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:374
+#: ../gui/wxpython/gui_core/goutput.py:461
+#, python-format
+msgid "%(txt)s (*.txt)|*.txt|%(files)s (*)|*"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:375
+#: ../gui/wxpython/gui_core/goutput.py:462
+msgid "Text files"
+msgstr ""
+msgid "Files"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:387
+#, python-format
+msgid ""
+"Unable to write file '%(path)s'.\n"
+"\n"
+"Details: %(error)s"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:390
+#, python-format
+msgid "Command output saved into '%s'"
+msgstr ""
+#: ../gui/wxpython/gui_core/goutput.py:445
+#, python-format
+msgid "Command log saved to '%s'"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:48
+msgid "Add scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:50
+msgid "Select area with polygon"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:52
+msgid "Pan mode for scatter plots"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:54
+msgid "Zoom mode for scatter plots (left mouse button, wheel)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:56
+msgid ""
+"Zoom to scatter plot data extend mode (click on scatter plot for zooming to "
+"extend)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:58
+msgid "Show/hide class manager"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:162
+#: ../gui/wxpython/iscatt/toolbars.py:163
+msgid "Include selected area to class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:165
+#: ../gui/wxpython/iscatt/toolbars.py:166
+msgid "Exclude selected area from class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:168
+msgid "Add new vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:169
+msgid "Add new vertex to polygon boundary scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:171
+msgid "Create selection polygon"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:172
+msgid "Add new vertex between last and first points of the boundary"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:174
+msgid "Move vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:175
+msgid "Move boundary vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:177
+msgid "Remove vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:178
+msgid "Remove boundary vertex"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:180
+msgid "Remove polygon (click on scatter plot for removing it's polygon)"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:257
+msgid "Add class"
+msgstr ""
+#: ../gui/wxpython/iscatt/toolbars.py:259
+msgid "Remove selected class"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:146
+msgid "GRASS GIS Interactive Scatter Plot Tool"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:361
+msgid "scatter plot"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:437
+msgid "Maximum limit of categories number was reached."
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:532
+msgid "Rename class"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:536
+msgid "Set color"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:544
+msgid "Hide"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:546
+msgid "Show"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:557
+msgid "Move to top"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:563
+msgid "Move to bottom"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:571
+msgid "Move category up"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:577
+msgid "Move category down"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:585
+msgid "Export class raster"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:657
+#, python-format
+msgid "Change opacity of class <%s>"
+msgstr ""
+#: ../gui/wxpython/iscatt/frame.py:679
+msgid "Empty name was inserted."
+msgstr ""
+#: ../gui/wxpython/iscatt/core_c.py:23
+msgid "Loading ctypes libs failed"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:38
+msgid "Add scatter plots"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:56
+msgid "x axis:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:62
+msgid "y axis:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:97
+msgid "Bands of scatter plots to be added (x y):"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:135
+msgid "No scatter plots selected."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:183
+msgid "Select both x and y bands."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:186
+msgid "Selected bands must be different."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:191
+msgid ""
+"Scatter plot with same bands combination (regardless x y order) has been "
+"already added into the list."
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:292
+#, python-format
+msgid "Raster map <%s> already exists. Do you want to overwrite it?"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:294
+#, python-format
+msgid "Raster <%s> exists"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:317
+msgid "Show confidence ellipses"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:323
+msgid "Selection polygon color:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:324
+msgid "Color of selection polygon vertex:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:325
+msgid "Selected area color:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:339
+msgid "Selected area opacity:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:371
+msgid "Selection style:"
+msgstr ""
+#: ../gui/wxpython/iscatt/dialogs.py:393
+msgid "Ellipses settings:"
+msgstr ""
+#: ../gui/wxpython/iscatt/plots.py:42
+#, python-format
+msgid ""
+"Unable to import matplotlib (try to install it).\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/plots.py:571
+msgid "Zoom to scatter plot extend"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:207
+msgid "No data set."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:223
+#, python-format
+msgid ""
+"Interactive Scatter Plot Tool can not be used.\n"
+"Number of cells (rows*cols) <%d> in current regionis higher than maximum "
+"limit <%d>.\n"
+"\n"
+"You can reduce number of cells in current region using <g.region> command."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:232
+#, python-format
+msgid ""
+"Number of cells (rows*cols) <%d> in current region is higher than "
+"recommended threshold <%d>.\n"
+"It is strongly advised to reduce number of cells in current region bellow "
+"recommend threshold.\n"
+" It can be done by <g.region> command.\n"
+"\n"
+"Do you want to continue using Interactive Scatter Plot Tool with this region?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:288
+msgid ""
+"Scatter plot with same band combination (regardless x y order) is already "
+"displayed."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:301
+#, python-format
+msgid "Band <%s> is not CELL (integer) type.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:304
+msgid "Scatter plot cannot be added.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:310
+#, python-format
+msgid ""
+"Scatter plot cannot be added.\n"
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than maximum limit <"
+"%d>.\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:318
+#, python-format
+msgid ""
+"Multiple of bands ranges <%s:%d * %s:%d = %d> is higher than recommended "
+"limit <%d>.\n"
+"It is strongly advised to reduce range extend of bands(e. g. using r."
+"rescale) bellow recommended threshold.\n"
+"\n"
+"Do you really want to add this scatter plot?"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:403
+msgid ""
+"In order to select arrea in scatter plot, you have to select class first.\n"
+"\n"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:437
+#, python-format
+msgid ""
+"Error occured during computation of scatter plot category:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:745
+#, python-format
+msgid "Export scatter plot raster of class <%s>"
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:762
+#, python-format
+msgid "Scatter plot raster of class <%s> exported to raster map <%s>."
+msgstr ""
+#: ../gui/wxpython/iscatt/controllers.py:765
+#, python-format
+msgid ""
+"Export of scatter plot raster of class <%s> to map <%s> failed.\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:107
+#: ../gui/wxpython/iscatt/iscatt_core.py:157
+msgid "Select category for editing."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:148
+msgid "Computing of scatter plots failed."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:286
+msgid "Patching category raster conditions file failed."
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:310
+#, python-format
+msgid ""
+"v.build failed:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/iscatt/iscatt_core.py:328
+#, python-format
+msgid ""
+"v.to.rast failed:\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:72
+msgid "Full extent"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:73
+msgid "Zoom to full extent"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:76
+msgid "Click and drag to place map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:80
+msgid "Show preview"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:82
+msgid "Quit Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:98
+#: ../gui/wxpython/vdigit/preferences.py:537
+msgid "Line"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:102
+msgid "Add overlays"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:192
+msgid "Add simple graphics: points"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:204
+msgid "Add simple graphics: lines"
+msgstr ""
+#: ../gui/wxpython/psmap/toolbars.py:216
+msgid "Add simple graphics: rectangles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:93
+msgid "inch"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:95
+msgid "centimeter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:96
+msgid "millimeter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:97
+msgid "meters"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:98
+msgid "kilometers"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:99
+msgid "feet"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:100
+msgid "miles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:101 ../gui/wxpython/psmap/utils.py:105
+msgid "nautical miles"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:103
+msgid "pixel"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:104
+msgid "meter"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:106
+msgid "degree"
+msgstr ""
+#: ../gui/wxpython/psmap/utils.py:346
+msgid "Unable to run `ps.map -b`"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:51
+msgid "GRASS GIS Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:182
+msgid ""
+"Python Imaging Library is not available.\n"
+"'Preview' functionality won't work."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:234
+msgid "Program ps2pdf is not available. Please install it first to create PDF."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:278
+msgid "Generating PDF..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:280
+msgid "Generating PostScript..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:282
+msgid "Generating preview..."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:292
+#, python-format
+msgid "Ps.map exited with return code %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:322
+#, python-format
+msgid "%(prg)s exited with return code %(code)s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:325
+msgid "PDF generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:328
+#, python-format
+msgid ""
+"Program ps2pdf is not available. Please install it to create PDF.\n"
+"\n"
+" %s"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:331
+msgid "PostScript file generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:337
+msgid "Generating preview, wait please"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:351
+msgid "Preview not available"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:352
+msgid "Preview is not available probably due to missing Ghostscript."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:354
+msgid "Please follow instructions on GRASS Trac Wiki."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:365
+msgid "Preview generated"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:395
+msgid "Save file as"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:437
+#, python-format
+msgid "Failed to read file %s."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:565 ../gui/wxpython/psmap/frame.py:588
+#: ../gui/wxpython/psmap/dialogs.py:1211
+msgid "Please, create map frame first."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:604
+msgid "Scalebar is not appropriate for this projection"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1024
+msgid "Press button with green triangle icon to generate preview."
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1048
+msgid "wxGUI Cartographic Composer"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1099
+msgid "MAP FRAME"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1100
+msgid "RASTER LEGEND"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1101
+msgid "VECTOR LEGEND"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1102
+msgid "MAP INFO"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1103
+msgid "SCALE BAR"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1104
+msgid "IMAGE"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1105
+msgid "NORTH ARROW"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:1353
+msgid "Click and drag to resize object"
+msgstr ""
+#: ../gui/wxpython/psmap/frame.py:2173
+msgid "labels: "
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:198
+msgid "Units:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:207
+msgid ""
+"Position of the top left corner\n"
+"from the top left edge of the paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:221
+msgid "Position is given:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:222
+msgid "relative to paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:223
+msgid "by map coordinates"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:237
+msgid ""
+"Position from the top left\n"
+"edge of the paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:291
+msgid "Font:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:305
+msgid "Choose color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:353
+msgid "Close dialog and apply changes"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:384
+msgid "Units"
+msgstr ""
+msgid "Orientation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:384 ../gui/wxpython/psmap/dialogs.py:2085
+msgid "Width"
+msgstr ""
+msgid "Height"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:385
+msgid "Left"
+msgstr ""
+msgid "Right"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:440
+msgid "Literal is not allowed!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:449
+msgid "Page size"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:451
+msgid "Margins"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:455
+msgid "Portrait"
+msgstr ""
+msgid "Landscape"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:557
+msgid "Map settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:563
+msgid "Map frame settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:680
+msgid "Map frame options:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:681
+msgid "fit frame to match selected map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:682
+msgid "fit frame to match saved region"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:683
+msgid "fit frame to match current computational region"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:684
+msgid "fixed scale and map center"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:692 ../gui/wxpython/psmap/dialogs.py:860
+msgid "Map selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:700 ../gui/wxpython/psmap/dialogs.py:1284
+msgid "Map:"
+msgstr ""
+msgid "Region:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:719
+msgid "Map scale and center"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:724
+msgid "Center:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:725
+msgid "E:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:726
+msgid "N:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:729 ../gui/wxpython/psmap/dialogs.py:4166
+msgid "Scale:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:730
+msgid "1 :"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:750
+msgid "Map max resolution (dpi):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:763 ../gui/wxpython/psmap/dialogs.py:2654
+msgid "Border"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:767
+msgid "draw border around map frame"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:773
+msgid "border color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:774
+msgid "border width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:868
+msgid ""
+"Region is set to match this map,\n"
+"raster or vector map must be added later"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:875
+msgid "Region selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1034
+msgid "No map selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1056
+msgid "No region selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1106
+msgid "Invalid scale or map center!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1166
+msgid "Choose raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1170
+msgid "no raster map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1171
+msgid "raster:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1280
+msgid "Add map"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1652
+msgid "points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1288 ../gui/wxpython/psmap/dialogs.py:1654
+msgid "lines"
+msgstr ""
+msgid "areas"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1290
+msgid "Data Type"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1305
+msgid "Manage vector maps"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1311
+msgid "The topmost vector map overlaps the others"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1316
+msgid "Properties..."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1518
+msgid "Raster map settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1555
+msgid "Vector maps settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1590
+#, python-format
+msgid "%s properties"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1641
+msgid "Data selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1652
+msgid "centroids"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1654
+msgid "boundaries"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1670
+msgid "Layer selection"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1676
+msgid "Database connection is not defined in DB file."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1677
+msgid "Select layer:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1700
+msgid "list of categories (e.g. 1,3,5-7)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1730
+msgid "Use current mask"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1747 ../gui/wxpython/psmap/dialogs.py:1846
+msgid "Colors"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1752 ../gui/wxpython/psmap/dialogs.py:1851
+msgid "Outline"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1756 ../gui/wxpython/psmap/dialogs.py:1860
+msgid "draw outline"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1759 ../gui/wxpython/psmap/dialogs.py:1864
+#: ../gui/wxpython/psmap/dialogs.py:3750 ../gui/wxpython/psmap/dialogs.py:3755
+msgid "Width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1800
+msgid "fill color"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1803 ../gui/wxpython/psmap/dialogs.py:1906
+msgid "choose color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1815 ../gui/wxpython/psmap/dialogs.py:1919
+msgid "color from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1862
+msgid "No effect for fill color from table column"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1904
+msgid "Color of lines:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1949 ../gui/wxpython/psmap/dialogs.py:2080
+#: ../gui/wxpython/psmap/dialogs.py:2149
+msgid "Size and style"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1958 ../gui/wxpython/nviz/tools.py:1419
+msgid "symbol:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1967
+msgid "eps file:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1971 ../gui/wxpython/psmap/dialogs.py:2160
+msgid "Type filename or click browse to choose file"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:1972 ../gui/wxpython/psmap/dialogs.py:2161
+msgid "Choose a file"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2000 ../gui/wxpython/nviz/tools.py:1362
+msgid "size:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2002
+msgid "size from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2004
+msgid "scale:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2037
+msgid "Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2042
+msgid "rotate symbols:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2043
+msgid "counterclockwise in degrees:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2045
+msgid "from map table column:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2089
+msgid "Set width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2098
+msgid "multiply width by category value"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2119
+msgid "Choose line style:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2129
+msgid "Choose linecap:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2154
+msgid "Pattern"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2158
+msgid "use pattern:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2159
+msgid "Choose pattern file:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2163
+msgid "pattern line width (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2165
+msgid "pattern scale factor:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2482
+msgid "Raster legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2492
+msgid "Source raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2497
+msgid "current raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2498
+msgid "select raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2505 ../gui/wxpython/psmap/dialogs.py:3190
+#, python-format
+msgid "%(rast)s: type %(type)s"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2524
+msgid "Type of legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2528
+msgid "discrete legend (categorical maps)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2530
+msgid "continuous color gradient legend (floating point map)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2541
+msgid "Advanced legend settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2545
+msgid "draw \"no data\" box"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2551
+msgid "draw ticks across color table"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2599
+msgid "Vector legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2603
+msgid "Show vector legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2609
+msgid "Source vector maps"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2613
+msgid "Choose vector maps and their order in legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2637 ../gui/wxpython/psmap/dialogs.py:2945
+msgid "Edit label"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2658
+msgid "draw border around legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2695
+msgid "Size and position"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2705 ../gui/wxpython/psmap/dialogs.py:3246
+#: ../gui/wxpython/psmap/dialogs.py:3441 ../gui/wxpython/psmap/dialogs.py:3815
+#: ../gui/wxpython/psmap/dialogs.py:3819 ../gui/wxpython/psmap/dialogs.py:4221
+#: ../gui/wxpython/psmap/dialogs.py:4226 ../gui/wxpython/psmap/dialogs.py:4679
+#: ../gui/wxpython/psmap/dialogs.py:4684 ../gui/wxpython/nviz/tools.py:857
+#: ../gui/wxpython/nviz/tools.py:1676
+msgid "Position"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2729
+msgid "Leave the edit field empty, to use default values."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2751
+msgid ""
+"Width of the color symbol (for lines)\n"
+"in front of the legend text"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2757 ../gui/wxpython/psmap/dialogs.py:2862
+msgid "Columns:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2761
+msgid "column span:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2763
+msgid ""
+"Column separation distance between the left edges\n"
+"of two columns in a multicolumn legend"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2945
+msgid "Edit legend label:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2986
+msgid "No raster map selected!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:2987
+msgid "No raster"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3221
+msgid "Mapinfo settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3283
+msgid "Color settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3289
+msgid "use border color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3290
+msgid "use background color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3430
+msgid ""
+"Units of current projection are not supported,\n"
+" meters will be used!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3431
+msgid "Unsupported units"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3475
+msgid "Length:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3479
+msgid "Scalebar length is given in map units"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3482
+msgid "Scalebar height is real height on paper"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3484
+msgid "default"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3529
+msgid "Type:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3545
+msgid "Number of segments:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3549
+msgid "Label every "
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3550
+msgid "segments"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3559
+msgid "transparent text background"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3636
+msgid "Length of scale bar is not defined"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3739
+msgid "Text effects"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3744
+msgid "text background"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3747
+msgid "highlight"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3752
+msgid "text border"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3829
+msgid "Offset"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3832
+msgid "horizontal (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3833
+msgid "vertical (pts):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3846
+msgid " Reference point"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3872
+msgid "Text rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3875
+msgid "rotate text (counterclockwise)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:3951
+msgid "No text entered!"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4119 ../gui/wxpython/nviz/tools.py:481
+msgid "Choose a directory:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4120
+msgid "Choose a directory with images"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4152
+msgid "Note: only EPS format supported"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4161
+msgid "Scale And Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4192 ../gui/wxpython/psmap/dialogs.py:4654
+msgid "Rotation angle (deg):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4201 ../gui/wxpython/psmap/dialogs.py:4663
+msgid "Counterclockwise rotation in degrees"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4299
+msgid ""
+"PIL\n"
+"missing"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4319
+#, python-format
+msgid "Unable to read file %s"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4378
+#, python-format
+msgid "size: %(width)s x %(height)s pts"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4400
+msgid "No image selected."
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4497
+msgid "North Arrow settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4508
+msgid "Compute convergence"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4564
+msgid "Symbol"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4569
+msgid "Select symbol:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4583
+msgid ""
+"Note: Selected symbol is not displayed\n"
+"in draft mode (only in preview mode)"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4602 ../gui/wxpython/psmap/dialogs.py:4856
+msgid "Outline color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4617 ../gui/wxpython/psmap/dialogs.py:4877
+msgid "Fill color:"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4640
+msgid "Size and Rotation"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4645
+msgid "Size (pt):"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4647
+msgid "Symbol size in points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4821
+msgid "Rectangle settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4823
+msgid "Line settings"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4909
+msgid "Line width in points"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4977
+msgid "Vector labels"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:4996
+msgid "Vector label files created beforehand by v.label module"
+msgstr ""
+#: ../gui/wxpython/psmap/dialogs.py:5004
+msgid "You can select multiple label files."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:133
+#, python-format
+msgid ""
+"Unable to open file\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:467
+#, python-format
+msgid "Instruction file will be loaded with following region: %s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:472
+#, python-format
+msgid ""
+"Region cannot be set\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:611
+#: ../gui/wxpython/psmap/instructions.py:761
+#: ../gui/wxpython/psmap/instructions.py:877
+#: ../gui/wxpython/psmap/instructions.py:935
+#: ../gui/wxpython/psmap/instructions.py:1076
+#: ../gui/wxpython/psmap/instructions.py:1131
+#: ../gui/wxpython/psmap/instructions.py:1190
+#: ../gui/wxpython/psmap/instructions.py:1259
+#: ../gui/wxpython/psmap/instructions.py:1365
+#: ../gui/wxpython/psmap/instructions.py:1490
+#: ../gui/wxpython/psmap/instructions.py:1541
+#: ../gui/wxpython/psmap/instructions.py:1850
+#, python-format
+msgid "Failed to read instruction %s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:625
+#, python-format
+msgid ""
+"Scale has changed, old value: %(old)s\n"
+"new value: %(new)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:628
+#, python-format
+msgid ""
+"Failed to read instruction %s.\n"
+"Use 1:25000 notation."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:636
+#, python-format
+msgid ""
+"Map frame position changed, old value: %(old1)s %(old2)s\n"
+"new value: %(new1)s %(new2)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:644
+#, python-format
+msgid ""
+"Map frame size changed, old value: %(old1)s %(old2)s\n"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:691
+#, python-format
+msgid ""
+"Failed to read instruction %(file)s.\n"
+"Unknown format %(for)s"
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:704
+#, python-format
+msgid "Failed to read instruction %s."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:818
+#: ../gui/wxpython/psmap/instructions.py:1700
+#, python-format
+msgid ""
+"Characters on position %s are not supported by ISO-8859-1 (Latin 1) encoding "
+"which is required by module ps.map."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:822
+#: ../gui/wxpython/psmap/instructions.py:1704
+msgid ""
+"Not all characters are supported by ISO-8859-1 (Latin 1) encoding which is "
+"required by module ps.map."
+msgstr ""
+#: ../gui/wxpython/psmap/instructions.py:938
+#, python-format
+msgid "Failed to read instruction %(inst)s: file %(file)s not found."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:224
+msgid ""
+"Opening 3D view was not successful. Please try to change the value of depth "
+"buffer in GUI Settings dialog > tab Map Display > Advanced and restart GUI."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:559
+#, python-format
+msgid ""
+"Image is too large, your OpenGL implementation supports maximum texture size "
+"%d px."
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1057
+msgid "Easting"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1058
+msgid "Northing"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1059
+msgid "Elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1065
+msgid "Surface map name"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1066
+msgid "Surface map elevation"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1067
+msgid "Surface map color"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1076
+msgid "XY distance from previous"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1077
+msgid "XYZ distance from previous"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1078
+msgid "Distance along surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1083
+msgid "Distance along exag. surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1090
+msgid "No point on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1547
+msgid "Loading raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1551
+msgid "Loading 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1557
+msgid "failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1559
+#, python-format
+msgid "Unsupported layer type '%s'"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1671
+msgid "Unable to unload raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1676
+msgid "Unable to unload 3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1677
+msgid "3d raster map"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1687
+msgid "unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1739
+#, python-format
+msgid "Loading vector map <%(name)s> (%(type)s) failed"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1798
+#, python-format
+msgid "Unable to unload vector map <%(name)s> (%(type)s)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:1801
+#, python-format
+msgid "Vector map <%(name)s> (%(type)s) unloaded successfully"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2154
+#, python-format
+msgid "Vector point layer not found (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2156
+#, python-format
+msgid "Unable to set data layer properties (id = %d)"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2159
+#, python-format
+msgid ""
+"Setting data layer properties failed.\n"
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/nviz/mapwindow.py:2214
+#: ../gui/wxpython/nviz/mapwindow.py:2232 ../gui/wxpython/nviz/tools.py:2275
+#: ../gui/wxpython/nviz/tools.py:2320 ../gui/wxpython/nviz/tools.py:4579
+msgid "constant#"
+msgstr ""
+#: ../gui/wxpython/nviz/wxnviz.py:482 ../gui/wxpython/nviz/wxnviz.py:494
+#, python-format
+msgid "3d raster map <%s> not found"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:32
+msgid "3D view default settings"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:49
+msgid "Revert settings to default, changes are not applied"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:56
+#: ../gui/wxpython/nviz/preferences.py:61 ../gui/wxpython/nviz/tools.py:88
+msgid "View"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:69 ../gui/wxpython/nviz/tools.py:252
+msgid "Perspective:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:72
+#: ../gui/wxpython/nviz/preferences.py:135
+#: ../gui/wxpython/nviz/preferences.py:153
+msgid "value:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:84
+msgid "step:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:99
+#: ../gui/wxpython/nviz/preferences.py:266
+msgid "Position:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:102
+#: ../gui/wxpython/nviz/preferences.py:269
+msgid "x:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:132
+msgid "Twist:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:150 ../gui/wxpython/nviz/tools.py:290
+msgid "Z-exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:172 ../gui/wxpython/nviz/tools.py:347
+msgid "Image Appearance"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:205
+msgid "Fly-through"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:215
+msgid "Move exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:227
+msgid "Turn exag:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:253 ../gui/wxpython/nviz/tools.py:598
+msgid "Lighting"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:258
+msgid "Light"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:293
+msgid "z:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:307 ../gui/wxpython/nviz/tools.py:1799
+msgid "Brightness:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:321 ../gui/wxpython/nviz/tools.py:1810
+msgid "Ambient:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:361 ../gui/wxpython/nviz/tools.py:546
+#: ../gui/wxpython/nviz/tools.py:1859
+msgid "Surface"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:374 ../gui/wxpython/nviz/tools.py:681
+#: ../gui/wxpython/nviz/tools.py:1559
+msgid "Mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:377 ../gui/wxpython/nviz/tools.py:684
+msgid "coarse"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:378 ../gui/wxpython/nviz/tools.py:685
+msgid "fine"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:379 ../gui/wxpython/nviz/tools.py:686
+msgid "both"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:389 ../gui/wxpython/nviz/tools.py:755
+msgid "Fine mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:393
+#: ../gui/wxpython/nviz/preferences.py:410 ../gui/wxpython/nviz/tools.py:719
+#: ../gui/wxpython/nviz/tools.py:759
+msgid "resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:406 ../gui/wxpython/nviz/tools.py:716
+msgid "Coarse mode:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:422 ../gui/wxpython/nviz/tools.py:732
+msgid "style:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:425 ../gui/wxpython/nviz/tools.py:735
+msgid "wire"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:426 ../gui/wxpython/nviz/tools.py:736
+msgid "surface"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:437
+msgid "wire color:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:463 ../gui/wxpython/nviz/tools.py:557
+msgid "Vector"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:469 ../gui/wxpython/nviz/tools.py:1211
+msgid "Vector lines"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:509 ../gui/wxpython/nviz/tools.py:1352
+msgid "Vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:531
+msgid "Marker:"
+msgstr ""
+#: ../gui/wxpython/nviz/preferences.py:629
+#, python-format
+msgid "3D view settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:100
+msgid "Analysis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:103 ../gui/wxpython/nviz/tools.py:385
+msgid "Animation"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:226
+msgid "Control View"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:247
+msgid "Adjusts the distance and angular perspective of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:260
+msgid "Tilts the plane of the surface from the horizontal"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:264 ../gui/wxpython/nviz/tools.py:1024
+msgid "Tilt:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:271
+msgid ""
+"Adjusts the viewing height above the surface (angle of view automatically "
+"adjusts to maintain the same center of view)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:276
+msgid "Adjusts the relative height of features above the plane of the surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:303
+msgid "Look:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:306
+msgid "here"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:309
+msgid ""
+"Allows you to select a point on the surface that becomes the new center of "
+"view. Click on the button and then on the surface."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:315
+msgid "center"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:318
+msgid "Resets the view to the original default center of view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:322
+msgid "top"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:325
+msgid ""
+"Sets the viewer directly over the scene's center position. This top view "
+"orients approximately north south."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:329
+msgid "reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:330
+msgid "Reset to default view"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:392
+msgid ""
+"Press 'Record' button and start changing the view. It is recommended to use "
+"fly-through mode (Map Display toolbar) to achieve smooth motion."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:403
+msgid "Record"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:405
+msgid "Play"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:421
+msgid "Total number of frames :"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:425
+msgid "Frame rate (FPS):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:431
+msgid "Frames are recorded with given frequency (FPS). "
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:474
+msgid "Save image sequence"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:482
+msgid "Choose a directory for images"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:490
+msgid ""
+"Generated files names will look like this: prefix_1.ppm, prefix_2.ppm, ..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:552 ../gui/wxpython/nviz/tools.py:1083
+msgid "Constant surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:563
+msgid "Volume"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:603
+msgid "Fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:630 ../gui/wxpython/nviz/tools.py:941
+msgid "Cutting planes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:695 ../gui/wxpython/nviz/tools.py:957
+#: ../gui/wxpython/nviz/tools.py:1573
+msgid "Shading:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:698 ../gui/wxpython/nviz/tools.py:1298
+#: ../gui/wxpython/nviz/tools.py:1576
+msgid "flat"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:699 ../gui/wxpython/nviz/tools.py:1577
+msgid "gouraud"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:707
+msgid "Set to all"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:708
+msgid "Use draw settings for all loaded surfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:748
+msgid "Change wire color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:781
+msgid "Surface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:790 ../gui/wxpython/nviz/tools.py:2401
+msgid "Transparency"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:791 ../gui/wxpython/nviz/tools.py:2402
+msgid "Shininess"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:797 ../gui/wxpython/nviz/tools.py:2413
+msgid "map"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:800 ../gui/wxpython/nviz/tools.py:2418
+msgid "unset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:805 ../gui/wxpython/nviz/tools.py:2423
+msgid "constant"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:862
+msgid "Changes the x, y, and z position of the current surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:872 ../gui/wxpython/nviz/tools.py:1059
+#: ../gui/wxpython/nviz/tools.py:1690 ../gui/wxpython/nviz/tools.py:2583
+msgid "Reset"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:873 ../gui/wxpython/nviz/tools.py:1691
+msgid "Reset to default position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:947
+msgid "Active cutting plane:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:959
+msgid "clear"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:960
+msgid "top color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:961
+msgid "bottom color"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:962
+msgid "blend"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:963
+msgid "shaded"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:975
+msgid "Horizontal X:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:977
+msgid "Sets the X coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:991
+msgid "Horizontal Y:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:993
+msgid "Sets the Y coordinate of the current cutting plane"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1010
+msgid "Rotates the current cutting plane about vertical axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1026
+msgid "Rotates the current cutting plane about horizontal axis"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1042
+msgid ""
+"Sets the Z coordinate of the current cutting plane (only meaningful when "
+"tilt is not 0)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1111
+msgid "Fine resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1123
+msgid "Value:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1135 ../gui/wxpython/nviz/tools.py:2572
+msgid "Transparency:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1201
+msgid "Show vector lines"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1217
+msgid "Line:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1220
+msgid "width:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1236 ../gui/wxpython/nviz/tools.py:1387
+msgid "color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1252 ../gui/wxpython/nviz/tools.py:1432
+msgid "use color for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1254
+msgid "use width for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1267 ../gui/wxpython/nviz/tools.py:1279
+#: ../gui/wxpython/nviz/tools.py:1445 ../gui/wxpython/nviz/tools.py:1454
+msgid "Set options..."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1292 ../gui/wxpython/nviz/tools.py:1466
+#: ../gui/wxpython/vdigit/preferences.py:129
+msgid "Display"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1297 ../gui/wxpython/nviz/tools.py:4848
+msgid "on surface(s):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1307 ../gui/wxpython/nviz/tools.py:1474
+msgid "Height above surface:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1343
+msgid "Show vector points"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1359
+msgid "Icon:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1434
+msgid "use size for thematic mapping"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1562
+msgid "isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1563
+msgid "slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1586
+msgid "Resolution:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1600
+msgid "Draw wire box"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1616 ../gui/wxpython/nviz/tools.py:3754
+msgid "List of isosurfaces"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1732
+msgid "Show light model"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1745
+msgid "Light source position"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1761
+msgid "Adjusts the light height"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1785
+msgid "Light color and intensity"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1801
+msgid "Adjusts the brightness of the light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1812
+msgid "Adjusts the ambient light"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1873
+msgid "Edges with fringe"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1875
+msgid "N && W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1876
+msgid "N && E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1877
+msgid "S && W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1878
+msgid "S && E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1898
+msgid "Elevation of fringe from bottom:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1951
+msgid "Arrow length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1961
+msgid "Arrow color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1970
+msgid "Place arrow"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:1996
+msgid "Scale bar length (in map units):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2006
+msgid "Scale bar color:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2015
+msgid "Place new scale bar"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2087
+msgid "Do you want to record new animation without saving the previous one?"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2090
+msgid "Animation already axists"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2252
+msgid "No file prefix given."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2256
+#, python-format
+msgid "Directory %s does not exist."
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2386
+msgid "Isosurface attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2392
+msgid "toggle normal direction"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2398
+msgid "Isosurface value"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2501
+msgid "Slice attributes"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2507
+msgid "Slice parallel to axis:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2640
+msgid "W"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2641
+msgid "N"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2642
+msgid "S"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2643
+msgid "E"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2644
+msgid "NW"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2645
+msgid "NE"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2646
+msgid "SE"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:2647
+msgid "SW"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3136 ../gui/wxpython/nviz/tools.py:4905
+msgid "Level"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3760
+msgid "List of slices"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3952 ../gui/wxpython/nviz/tools.py:3954
+msgid "Level {level}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:3961 ../gui/wxpython/nviz/tools.py:3963
+msgid "Slice parallel to {axis}"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4240 ../gui/wxpython/nviz/tools.py:4918
+msgid "Slice parallel to"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4450
+#, python-format
+msgid "Scalebar %d"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4585
+msgid "None"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4747
+msgid "Vector map is 3D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4750
+msgid "Vector map is 2D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4752
+#, python-format
+msgid "%(features)d features (%(points)d points)"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4848
+msgid "as 3D"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4850
+msgid "on surface"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:4938
+msgid "range:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5006 ../gui/wxpython/nviz/tools.py:5017
+msgid "North edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5007 ../gui/wxpython/nviz/tools.py:5018
+msgid "South edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5008 ../gui/wxpython/nviz/tools.py:5015
+#: ../gui/wxpython/nviz/tools.py:5024
+msgid "West edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5009 ../gui/wxpython/nviz/tools.py:5016
+#: ../gui/wxpython/nviz/tools.py:5025
+msgid "East edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5011 ../gui/wxpython/nviz/tools.py:5022
+#: ../gui/wxpython/nviz/tools.py:5030
+msgid "Northing (Y):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5012 ../gui/wxpython/nviz/tools.py:5021
+#: ../gui/wxpython/nviz/tools.py:5031
+msgid "Height (Z):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5013 ../gui/wxpython/nviz/tools.py:5020
+#: ../gui/wxpython/nviz/tools.py:5029
+msgid "Easting (X):"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5026
+msgid "Bottom edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5027
+msgid "Top edge:"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5132
+msgid "Adjusts the distance and direction of the image viewpoint"
+msgstr ""
+#: ../gui/wxpython/nviz/tools.py:5164
+msgid ""
+"Adjusts the light direction. Click and drag the puck to change the light "
+"direction."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:106
+msgid "Choose project location and mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:109
+msgid "Manage"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:111
+#, python-format
+msgid ""
+"Welcome to GRASS GIS %s%s\n"
+"The world's leading open source GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:115
+msgid ""
+"Select an existing project location and mapset\n"
+"or define a new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:132
+msgid ""
+"Project location\n"
+"(projection/coordinate system)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:135
+msgid ""
+"Accessible mapsets\n"
+"(directories of GIS files)"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:138
+msgid ""
+"Create new mapset\n"
+"in selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:141
+msgid "Define new location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:144
+msgid ""
+"Rename/delete selected\n"
+"mapset or location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:149
+msgid "Start &GRASS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:155
+msgid "&Browse"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:157
+msgid "&Create mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:159
+msgid "&Location wizard"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:160
+msgid ""
+"Start location wizard. After location is created successfully, GRASS session "
+"is started."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:164
+msgid "Rename mapset"
+msgstr ""
+msgid "Rename location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:165
+msgid "Delete mapset"
+msgstr ""
+msgid "Delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:207
+msgid "Welcome to GRASS GIS"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:215
+msgid "Enter GRASS session"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:231 ../gui/wxpython/gis_set.py:702
+msgid "Unable to set GRASS database. Check your locale settings."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:249
+#, python-format
+msgid "ERROR: Location <%s> not found\n"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:266
+#, python-format
+msgid "ERROR: Mapset <%s> not found\n"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:410
+#, python-format
+msgid "Invalid line in GISRC file (%s):%s\n"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:424
+msgid "Warning: "
+msgstr ""
+#: ../gui/wxpython/gis_set.py:461
+#, python-format
+msgid ""
+"Do you want to import <%(name)s> to the newly created location? The "
+"location's default region will be set from this imported map."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:466
+msgid "Import data?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:478
+msgid "Do you want to create new mapset?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:531
+#, python-format
+msgid ""
+"Import of <%(name)s> failed.\n"
+"Reason: %(msg)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:534
+#, python-format
+msgid "Data file <%(name)s> imported successfully."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:569
+msgid ""
+"Mapset <PERMANENT> is required for valid GRASS location.\n"
+"\n"
+"This mapset cannot be renamed."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:574 ../gui/wxpython/gis_set.py:610
+#, python-format
+msgid ""
+"Current name: %s\n"
+"\n"
+"Enter new name:"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:575
+msgid "Rename selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:587
+#, python-format
+msgid ""
+"Unable to rename mapset.\n"
+"\n"
+"Mapset <%s> already exists in location."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:599
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:611
+msgid "Rename selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:623
+#, python-format
+msgid ""
+"Unable to rename location.\n"
+"\n"
+"Location <%s> already exists in GRASS database."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:636
+#, python-format
+msgid ""
+"\n"
+"%s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:648
+msgid ""
+"\n"
+"This mapset cannot be deleted."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:652
+#, python-format
+msgid ""
+"Do you want to continue with deleting mapset <%(mapset)s> from location <"
+"%(location)s>?\n"
+"\n"
+"ALL MAPS included in this mapset will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:657
+msgid "Delete selected mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:666
+msgid "Unable to delete mapset"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:677
+#, python-format
+msgid ""
+"Do you want to continue with deleting location <%s>?\n"
+"\n"
+"ALL MAPS included in this location will be PERMANENTLY DELETED!"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:681
+msgid "Delete selected location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:692
+msgid "Unable to delete location"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:713
+#, python-format
+msgid "No GRASS location found in '%s'."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:820
+#, python-format
+msgid "Path '%s' doesn't exist."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:861
+#, python-format
+msgid "Mapset <%s> already exists."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:866
+#, python-format
+msgid ""
+"Mapset <%s> is reserved for direct read access to OGR layers. Please "
+"consider to use another name for your mapset.\n"
+"\n"
+"Are you really sure that you want to create this mapset?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:870
+msgid "Reserved mapset name"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:892
+#, python-format
+msgid "Unable to create new mapset: %s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:905
+#, python-format
+msgid ""
+"GRASS is already running in selected mapset <%(mapset)s>\n"
+"(file %(lock)s found).\n"
+"\n"
+"Concurrent use not allowed.\n"
+"\n"
+"Do you want to try to remove .gislock (note that you need permission for "
+"this operation) and continue?"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:911 ../gui/wxpython/gis_set.py:923
+msgid "Lock file found"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:919
+msgid ""
+"ARE YOU REALLY SURE?\n"
+"\n"
+"If you really are running another GRASS session doing this could corrupt "
+"your data. Have another look in the processor manager just to be sure..."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:934
+#, python-format
+msgid ""
+"Unable to remove '%(lock)s'.\n"
+"\n"
+"Details: %(reason)s"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:982
+#, python-format
+msgid ""
+"Name <%(name)s> is not a valid name for location or mapset. Please use only "
+"ASCII characters excluding %(chars)s and space."
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1050
+msgid "Starting GRASS for the first time"
+msgstr ""
+#: ../gui/wxpython/gis_set.py:1051
+msgid ""
+"GRASS needs a directory in which to store its data. Create one now if you "
+"have not already done so. A popular choice is \"grassdata\", located in your "
+"home directory."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:940
+#, python-format
+msgid ""
+"Topology for vector map <%s> is not available. Topology is required by "
+"digitizer. Do you want to rebuild topology (takes some time) and open the "
+"vector map for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdisplay.py:944
+msgid "Topology missing"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:96
+msgid "Select area/boundary/centroid tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:122
+msgid "Digitize new point"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:123
+#: ../gui/wxpython/vdigit/toolbars.py:132
+#: ../gui/wxpython/vdigit/toolbars.py:135
+msgid "Left: new point"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:125
+msgid "Digitize new line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:126
+#: ../gui/wxpython/vdigit/toolbars.py:129
+#: ../gui/wxpython/vdigit/toolbars.py:153
+msgid "Left: new point; Ctrl+Left: undo last point; Right: close line"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:128
+msgid "Digitize new boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:131
+msgid "Digitize new centroid"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:134
+msgid "Digitize new area (boundary without category)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:137
+msgid "Add new vertex to line or boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:138
+#: ../gui/wxpython/vdigit/toolbars.py:141
+#: ../gui/wxpython/vdigit/toolbars.py:144
+#: ../gui/wxpython/vdigit/toolbars.py:156
+#: ../gui/wxpython/vdigit/toolbars.py:159
+#: ../gui/wxpython/vdigit/toolbars.py:162
+#: ../gui/wxpython/vdigit/toolbars.py:171
+msgid "Left: Select; Ctrl+Left: Unselect; Right: Confirm"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:140
+msgid "Delete selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:143
+msgid "Delete selected area(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:146
+msgid "Display/update attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:147
+#: ../gui/wxpython/vdigit/toolbars.py:150
+msgid "Left: Select"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:149
+msgid "Display/update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:152
+msgid "Edit selected line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:155
+msgid "Move selected point(s), line(s), boundary(ies) or centroid(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:158
+msgid "Move selected vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:161
+msgid "Remove selected vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:163
+#: ../gui/wxpython/vdigit/preferences.py:31
+msgid "Digitization settings"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:164
+msgid "Quit digitizer"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:165
+msgid "Quit digitizer and save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:166
+msgid "Vector Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:167
+msgid "Show Vector Digitizer manual"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:169
+msgid "Additional tools (copy, flip, connect, etc.)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:173
+msgid "Undo"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:174
+msgid "Undo previous changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:176
+msgid "Redo"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:177
+msgid "Redo previous changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:523
+msgid "Break selected lines/boundaries at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:525
+msgid "Connect selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:527
+msgid "Copy categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:529
+msgid "Copy features from (background) vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:531
+msgid "Copy attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:533
+msgid "Feature type conversion"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:535
+msgid "Flip selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:537
+msgid "Merge selected lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:539
+msgid "Snap selected lines/boundaries (only to nodes)"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:541
+msgid "Split line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:543
+msgid "Query features"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:545
+msgid "Z bulk-labeling of 3D lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:567 ../gui/wxpython/vdigit/wxdigit.py:60
+msgid "No vector map open for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:571
+msgid "Select background vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:728
+msgid "Vector map is not 3D. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:830
+#, python-format
+msgid ""
+"digitizer.\n"
+"Do you want to rebuild topology (takes some time) and open the vector map "
+"for editing?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:834
+msgid "Digitizer error"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:854
+#, python-format
+msgid "Please wait, opening vector map <%s> for editing..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:886
+#, python-format
+msgid ""
+"Unsupported feature type '%(type)s'. Unable to edit OGR layer <%(layer)s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:947
+#, python-format
+msgid "Do you want to save changes in vector map <%s>?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:949
+msgid "Save changes?"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:956
+#, python-format
+msgid "Please wait, closing and rebuilding topology of vector map <%s>..."
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:970
+#, python-format
+msgid "Editing of vector map <%s> successfully finished"
+msgstr ""
+#: ../gui/wxpython/vdigit/toolbars.py:1033
+#: ../gui/wxpython/vdigit/toolbars.py:1038
+msgid "New vector map"
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:410
+msgid "Update categories"
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:534
+#: ../gui/wxpython/vdigit/mapwindow.py:904
+msgid "No vector map selected for editing."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:542
+msgid "Nothing to do. Choose appropriate tool from digitizer toolbar."
+msgstr ""
+#: ../gui/wxpython/vdigit/mapwindow.py:1040
+msgid "Z bulk-labeling dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:53
+msgid "Digitization Error"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:58
+#, python-format
+msgid "Unable to open vector map <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:61
+msgid "Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:68
+#, python-format
+msgid ""
+"Writing new feature failed. Operation canceled.\n"
+"\n"
+"Reason: %s"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:77
+#, python-format
+msgid "Reading feature id %d failed. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:85
+#, python-format
+msgid "Database link %d not available. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:93
+#, python-format
+msgid "Unable to start database driver <%s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:101
+#, python-format
+msgid ""
+"Unable to open database <%(db)s> by driver <%(driver)s>. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:109
+#, python-format
+msgid "Unable to execute SQL query '%s'. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:117
+#, python-format
+msgid "Feature id %d is marked as dead. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:125
+#, python-format
+msgid "Unsupported feature type %d. Operation canceled."
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:452
+#, python-format
+msgid "Unknown feature type '%s'"
+msgstr ""
+#: ../gui/wxpython/vdigit/wxdigit.py:457
+msgid "Not enough points for line"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:76
+msgid "List of categories - right-click to delete"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:107
+msgid "Add new category"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:146
+msgid "Ignore changes and close dialog"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:238 ../gui/wxpython/vdigit/dialogs.py:457
+#, python-format
+msgid ""
+"Unable to add new layer/category <%(layer)s/%(category)s>.\n"
+"Layer and category number must be integer.\n"
+"Layer number must be greater than zero."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:434
+msgid "Unable to update vector map."
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:594
+#, python-format
+msgid "%d lines selected for z bulk-labeling"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:597
+msgid "Set value"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:604
+msgid "Starting value"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:613
+msgid "Step"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:643
+msgid "List of duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:739
+msgid "Feature id"
+msgstr ""
+#: ../gui/wxpython/vdigit/dialogs.py:740
+msgid "Layer (Categories)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:57
+msgid "Apply changes for this session"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:60
+msgid "Close dialog and save changes to user settings file"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:152
+msgid "Snapping"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:158
+msgid "Snapping threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:165
+msgid "screen pixels"
+msgstr ""
+msgid "map units"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:174
+msgid "Snap also to vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:179
+#: ../gui/wxpython/vdigit/preferences.py:623
+#: ../gui/wxpython/vdigit/preferences.py:637
+#: ../gui/wxpython/vdigit/preferences.py:641
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:192
+msgid "Select vector features"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:209
+msgid "Select threshold"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:222
+msgid "Select only features inside of selection bounding box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:224
+msgid ""
+"By default are selected all features overlapping selection bounding box "
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:227
+msgid "Check for duplicates"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:239
+msgid "Digitize lines/boundaries"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:242
+msgid "Break lines at intersection"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:252
+msgid "Digitize areas"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:255
+msgid "Close boundary (snap to the start node)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:265
+msgid "Save changes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:268
+msgid "Save changes on exit"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:280
+msgid "Query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:287
+msgid "Choose query tool"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:292
+msgid "Select by box"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:301
+#: ../gui/wxpython/vdigit/preferences.py:432
+msgid "length"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:306
+msgid "Select lines"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:308
+#: ../gui/wxpython/vdigit/preferences.py:331
+msgid "shorter than"
+msgstr ""
+msgid "longer than"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:324
+msgid "dangle"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:329
+msgid "Select dangles"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:368
+msgid "Digitize new feature"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:373
+msgid "Add new record into table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:379
+msgid "Mode"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:401
+msgid "Next to use"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:389
+msgid "Category number"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:399
+msgid "Category mode"
+msgstr ""
+msgid "Manual entry"
+msgstr ""
+msgid "No category"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:414
+msgid "Delete existing feature(s)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:419
+msgid "Delete record from table"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:429
+msgid "Geometry attributes"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:434
+msgid "perimeter"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:503
+msgid ""
+"Note: These settings are stored in the workspace not in the vector digitizer "
+"preferences."
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:532
+msgid "Digitize new line segment"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:533
+msgid "Digitize new line/boundary"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:534
+msgid "Highlight"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:535
+msgid "Highlight (duplicates)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:538
+msgid "Boundary (no area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:539
+msgid "Boundary (one area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:540
+msgid "Boundary (two areas)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:541
+msgid "Centroid (in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:542
+msgid "Centroid (outside area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:543
+msgid "Centroid (duplicate in area)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:544
+msgid "Node (one line)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:545
+msgid "Node (two lines)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:546
+msgid "Vertex"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:547
+msgid "Area (closed boundary + centroid)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:548
+msgid "Direction"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:616
+msgid "Snapping disabled"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:618
+#, python-format
+msgid "Snapping threshold is %(value).1f %(units)s (based on comp. resolution)"
+msgstr ""
+#: ../gui/wxpython/vdigit/preferences.py:674
+#, python-format
+msgid "Vector digitizer settings saved to file <%s>."
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:53
+msgid "GRASS GIS Vector Digitizer"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:89
+#, python-format
+msgid "Vector digitizer not available. %s"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:94
+#, python-format
+msgid ""
+"Vector map <%s> not found in current mapset. New vector map can be created "
+"by providing '-c' flag."
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:97
+#, python-format
+msgid "New vector map <%s> created"
+msgstr ""
+#: ../gui/wxpython/vdigit/g.gui.vdigit.py:99
+#, python-format
+msgid "Unable to create new vector map <%s>"
+msgstr ""
