[GRASS-SVN] r60159 - grass-addons/grass7/imagery/i.feo_tio2
svn_grass at osgeo.org
Fri May 9 08:06:24 PDT 2014
Author: ychemin
Date: 2014-05-09 08:06:24 -0700 (Fri, 09 May 2014)
New Revision: 60159
grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c
grass-addons/grass7/imagery/i.feo_tio2/feo.c
grass-addons/grass7/imagery/i.feo_tio2/main.c
fixed bugs, added Zhang et al. (2013) real equation
Modified: grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c
--- grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c 2014-05-09 14:56:00 UTC (rev 60158)
+++ grass-addons/grass7/imagery/i.feo_tio2/clementine_mapplanet.c 2014-05-09 15:06:24 UTC (rev 60159)
@@ -3,7 +3,7 @@
double feolucey2000(double uvvis2, double uvvis4){
//\cite{lucey2000lunar}
- return(17.427*(-atan2f(((uvvis4/uvvis2)-1.19)/(uvvis2-0.08)))-7.565);
+ return(17.427*(-atan2f(((uvvis4/uvvis2)-1.19),(uvvis2-0.08)))-7.565);
double feolawrence2002(double uvvis2, double uvvis4){
@@ -28,6 +28,6 @@
double tio2lucey2000(double uvvis1, double uvvis2){
- return(3.708*pow((atan2f(((uvvis1/uvvis2)-0.42)/(uvvis2-0.0))),5.979));
+ return(3.708*pow((atan2f(((uvvis1/uvvis2)-0.42),(uvvis2-0.0))),5.979));
Modified: grass-addons/grass7/imagery/i.feo_tio2/feo.c
--- grass-addons/grass7/imagery/i.feo_tio2/feo.c 2014-05-09 14:56:00 UTC (rev 60158)
+++ grass-addons/grass7/imagery/i.feo_tio2/feo.c 2014-05-09 15:06:24 UTC (rev 60159)
@@ -7,3 +7,16 @@
return (-137.97 *( r750 * sin(theta) + (r950/r750) * cos(theta) ) + 57.46);
+/*@inproceedings{zhang2013mapping,
+ title={Mapping lunar TiO2 and FeO with Chandrayaan-1 M3 Data},
+ author={Zhang, W and Bowles, NE},
+ booktitle={Lunar and Planetary Institute Science Conference Abstracts},
+ volume={44},
+ pages={1212},
+ year={2013}
+double feozhang2013(double r750, double r950)
+ return ( 17.83 * (-atan2f( ((r950/r750)-1.26),(r750-0.01) )) - 6.82);
Modified: grass-addons/grass7/imagery/i.feo_tio2/main.c
--- grass-addons/grass7/imagery/i.feo_tio2/main.c 2014-05-09 14:56:00 UTC (rev 60158)
+++ grass-addons/grass7/imagery/i.feo_tio2/main.c 2014-05-09 15:06:24 UTC (rev 60159)
@@ -23,6 +23,7 @@
#define MAXFILES 8
double feo(double r750, double r950, double theta);
double tio2(double r415, double r750, double y0Ti, double s0Ti);
+double feozhang2013(double r750, double r950);
double feolucey2000(double uvvis2, double uvvis4);
double feolawrence2002(double uvvis2, double uvvis4);
@@ -37,8 +38,9 @@
int nrows, ncols;
int row, col;
char *equationflag; /*Switch for particular equation */
+ char *desc;
struct GModule *module;
- struct Option *in0, *in1, *output, *param0, *param1;
+ struct Option *in0, *in1, *output, *param0, *param1, *eqname;
struct Flag *flag1;
struct History history; /*metadata */
struct Colors colors; /*Color rules */
@@ -61,7 +63,9 @@
G_add_keyword(_("imagery"));
G_add_keyword(_("Moon"));
G_add_keyword(_("Clementine"));
+ G_add_keyword(_("Chandrayaan1"));
G_add_keyword(_("UVVIS"));
+ G_add_keyword(_("M3"));
G_add_keyword(_("FeO"));
G_add_keyword(_("TiO2"));
G_add_keyword(_("reflectance"));
@@ -70,11 +74,11 @@
/* Define the different options */
in0 = G_define_standard_option(G_OPT_R_INPUT);
in0->key = "band0";
- in0->description = _("reflectance band at 750 nm (UVVIS 2)");
+ in0->description = _("reflectance band at 750 nm (UVVIS 2, M3 9)");
in1 = G_define_standard_option(G_OPT_R_INPUT);
in1->key = "band1";
- in1->description = _("reflectance band at 950 nm (UVVIS 4 for FeO/OMAT) or at 415 nm (UVVIS 1 for TiO2)");
+ in1->description = _("reflectance band at 950 nm (UVVIS 4 for FeO/OMAT, M3 19) or at 415 nm (UVVIS 1 for TiO2)");
output = G_define_standard_option(G_OPT_R_OUTPUT);
@@ -92,28 +96,29 @@
param1->description = _("Value of s0Ti (TiO2)");
param1->guisection = _("Parameters");
- opt.eqname = G_define_option();
- opt.eqname->key = "eqname";
- opt.eqname->type = TYPE_STRING;
- opt.eqname->required = YES;
- opt.eqname->description = _("Type of equation");
+ eqname = G_define_option();
+ eqname->key = "eqname";
+ eqname->type = TYPE_STRING;
+ eqname->required = YES;
+ eqname->description = _("Type of equation");
desc = NULL;
G_asprintf(&desc,
"feolucey2000;%s;feolawrence2002;%s;feowilcox2005_setparam;%s;"
- "feowilcox2005;%s;omatlucey2000;%s;omatwilcox2005;%s;"
+ "feowilcox2005;%s;feozhang2013;%s;omatlucey2000;%s;omatwilcox2005;%s;"
"tio2lucey2000_setparam;%s;tio2lucey2000;%s",
_("FeO (Lucey et al., 2000)"),
_("FeO (lawrence et al., 2002)"),
_("FeO (Wilcox et al., 2005) set parameter theta"),
_("FeO (Wilcox et al., 2005)"),
+ _("FeO (Zhang et al., 2013)"),
_("OMAT (Lucey et al., 2000)"),
_("OMAT (Wilcox et al., 2005)"),
_("TiO2 (Lucey et al., 2000) set parameters"),
_("TiO2 (Lucey et al., 2000)"));
- opt.eqname->descriptions = desc;
- opt.eqname->options = "feolucey2000,feolawrence2002,feowilcox2005_setparam,feowilcox2005,omatlucey2000,omatwilcox2005,tio2lucey2000_setparam,tio2lucey2000";
- opt.eqname->answer = "feolucey2000";
- opt.eqname->key_desc = _("type");
+ eqname->descriptions = desc;
+ eqname->options = "feolucey2000,feolawrence2002,feowilcox2005_setparam,feowilcox2005,feozhang2013,omatlucey2000,omatwilcox2005,tio2lucey2000_setparam,tio2lucey2000";
+ eqname->answer = "feolucey2000";
+ eqname->key_desc = _("type");
/* Define the different flags */
flag1 = G_define_flag();
@@ -179,6 +184,8 @@
outrast[col] = feolawrence2002(d0, d1);
if (!strcasecmp(equationflag, "feolucey2000"))
outrast[col] = feolucey2000(d0, d1);
+ if (!strcasecmp(equationflag, "feozhang2013"))
+ outrast[col] = feozhang2013(d0, d1);
if (!strcasecmp(equationflag, "omatwilcox2005"))
outrast[col] = omatwilcox2005(d0, d1);
if (!strcasecmp(equationflag, "omatlucey2000"))
