[GRASS-SVN] r60173 - grass/trunk/lib/python/temporal
svn_grass at osgeo.org
Sat May 10 17:32:03 PDT 2014
Author: huhabla
Date: 2014-05-10 17:32:02 -0700 (Sat, 10 May 2014)
New Revision: 60173
grass/trunk/lib/python/temporal/aggregation.py
grass/trunk/lib/python/temporal/extract.py
grass/trunk/lib/python/temporal/mapcalc.py
grass/trunk/lib/python/temporal/space_time_datasets.py
Added offset option to aggregation function. Fixed wrong exit value checks of r.mapcalc runs.
Better error handling when loading map data. Added patch from ticket #2281 to speedup
r.series runs for aggregation.
Modified: grass/trunk/lib/python/temporal/aggregation.py
--- grass/trunk/lib/python/temporal/aggregation.py 2014-05-10 22:57:28 UTC (rev 60172)
+++ grass/trunk/lib/python/temporal/aggregation.py 2014-05-11 00:32:02 UTC (rev 60173)
@@ -102,7 +102,7 @@
def aggregate_raster_maps(inputs, base, start, end, count, method,
- register_null, dbif):
+ register_null, dbif, offset=0):
"""!Aggregate a list of raster input maps with r.series
@param inputs The names of the raster maps to be aggregated
@@ -117,12 +117,13 @@
@param register_null If true null maps will be registered in the space
time raster dataset, if false not
@param dbif The temporal database interface to use
+ @param offset Offset to be added to the map counter to create the map ids
msgr = get_tgis_message_interface()
msgr.verbose(_("Aggregate %s raster maps") % (len(inputs)))
- output = "%s_%i" % (base, count)
+ output = "%s_%i" % (base, int(offset) + count)
mapset = get_current_mapset()
map_id = output + "@" + mapset
@@ -151,10 +152,16 @@
file.write(string)
file.close()
# Run r.series
- ret = core.run_command("r.series", flags="z", file=filename,
- output=output, overwrite=core.overwrite(),
- method=method)
+ if len(inputs) > 1000 :
+ ret = core.run_command("r.series", flags="z", file=filename,
+ output=output, overwrite=core.overwrite(),
+ method=method)
+ else:
+ ret = core.run_command("r.series", file=filename,
+ method=method)
if ret != 0:
dbif.close()
Modified: grass/trunk/lib/python/temporal/extract.py
--- grass/trunk/lib/python/temporal/extract.py 2014-05-10 22:57:28 UTC (rev 60172)
+++ grass/trunk/lib/python/temporal/extract.py 2014-05-11 00:32:02 UTC (rev 60173)
@@ -152,7 +152,6 @@
for proc in proc_list:
proc.join()
exitcodes += proc.exitcode
if exitcodes != 0:
dbif.close()
msgr.fatal(_("Error while computation"))
@@ -248,18 +247,18 @@
def run_mapcalc2d(expr):
"""Helper function to run r.mapcalc in parallel"""
- return core.run_command("r.mapcalc", expression=expr,
- overwrite=core.overwrite(), quiet=True)
+ exit(core.run_command("r.mapcalc", expression=expr,
+ overwrite=core.overwrite(), quiet=True))
def run_mapcalc3d(expr):
"""Helper function to run r3.mapcalc in parallel"""
- return core.run_command("r3.mapcalc", expression=expr,
+ exit(core.run_command("r3.mapcalc", expression=expr,
def run_vector_extraction(input, output, layer, type, where):
- return core.run_command("v.extract", input=input, output=output,
+ exit(core.run_command("v.extract", input=input, output=output,
layer=layer, type=type, where=where,
Modified: grass/trunk/lib/python/temporal/mapcalc.py
--- grass/trunk/lib/python/temporal/mapcalc.py 2014-05-10 22:57:28 UTC (rev 60172)
+++ grass/trunk/lib/python/temporal/mapcalc.py 2014-05-11 00:32:02 UTC (rev 60173)
@@ -340,16 +340,16 @@
def _run_mapcalc2d(expr):
def _run_mapcalc3d(expr):
Modified: grass/trunk/lib/python/temporal/space_time_datasets.py
--- grass/trunk/lib/python/temporal/space_time_datasets.py 2014-05-10 22:57:28 UTC (rev 60172)
+++ grass/trunk/lib/python/temporal/space_time_datasets.py 2014-05-11 00:32:02 UTC (rev 60173)
@@ -286,37 +286,51 @@
self.get_mapset())
def load(self):
- """!Load all info from an existing raster map into the internal s
- tructure"""
+ """!Load all info from an existing raster map into the internal structure
+ This method checks first if the map exists, in case it exists
+ the metadata of the map is put into this object and True is returned.
+ @return True is the map exists and the metadata was filled successfully
+ and getting the data was successfull, False otherwise
+ if self.map_exists() is not True:
+ return False
# Fill base information
self.base.set_creator(str(getpass.getuser()))
kvp = self.ciface.read_raster_info(self.get_name(),
self.get_mapset())
- # Fill spatial extent
- self.set_spatial_extent_from_values(north=kvp["north"],
- south=kvp["south"],
- east=kvp["east"],
- west=kvp["west"])
+ if kvp:
+ # Fill spatial extent
+ self.set_spatial_extent_from_values(north=kvp["north"],
+ south=kvp["south"],
+ east=kvp["east"],
+ west=kvp["west"])
- # Fill metadata
- self.metadata.set_nsres(kvp["nsres"])
- self.metadata.set_ewres(kvp["ewres"])
- self.metadata.set_datatype(kvp["datatype"])
- self.metadata.set_min(kvp["min"])
- self.metadata.set_max(kvp["max"])
+ # Fill metadata
+ self.metadata.set_nsres(kvp["nsres"])
+ self.metadata.set_ewres(kvp["ewres"])
+ self.metadata.set_datatype(kvp["datatype"])
+ self.metadata.set_min(kvp["min"])
+ self.metadata.set_max(kvp["max"])
- rows = int(kvp["rows"])
- cols = int(kvp["cols"])
+ rows = int(kvp["rows"])
+ cols = int(kvp["cols"])
- ncells = cols * rows
+ ncells = cols * rows
- self.metadata.set_cols(cols)
- self.metadata.set_rows(rows)
- self.metadata.set_number_of_cells(ncells)
+ self.metadata.set_cols(cols)
+ self.metadata.set_rows(rows)
+ self.metadata.set_number_of_cells(ncells)
+ return True
+ return False
class Raster3DDataset(AbstractMapDataset):
@@ -598,8 +612,18 @@
self.get_mapset())
def load(self):
- """!Load all info from an existing raster3d map into the internal structure"""
+ """!Load all info from an existing 3d raster map into the internal structure
+ return False
@@ -607,29 +631,34 @@
kvp = self.ciface.read_raster3d_info(self.get_name(),
self.get_mapset())
- self.set_spatial_extent_from_values(north=kvp["north"], south=kvp["south"],
- east=kvp["east"], west=kvp["west"],
- top=kvp["top"], bottom=kvp["bottom"])
+ if kvp:
+ self.set_spatial_extent_from_values(north=kvp["north"], south=kvp["south"],
+ east=kvp["east"], west=kvp["west"],
+ top=kvp["top"], bottom=kvp["bottom"])
- # Fill metadata
- self.metadata.set_tbres(kvp["tbres"])
+ # Fill metadata
+ self.metadata.set_tbres(kvp["tbres"])
- depths = int(kvp["depths"])
+ depths = int(kvp["depths"])
- ncells = cols * rows * depths
+ ncells = cols * rows * depths
- self.metadata.set_depths(depths)
+ self.metadata.set_depths(depths)
+ return True
+ return False
class VectorDataset(AbstractMapDataset):
@@ -869,9 +898,20 @@
def load(self):
- """!Load all info from an existing vector map into the internal
- structure"""
+ """!Load all info from an existing vector map into the internal structure
+ return False
@@ -880,26 +920,31 @@
kvp = self.ciface.read_vector_info(self.get_name(),
self.get_mapset())
+ if kvp:
- # Fill metadata
- self.metadata.set_3d_info(kvp["map3d"])
- self.metadata.set_number_of_points(kvp["points"])
- self.metadata.set_number_of_lines(kvp["lines"])
- self.metadata.set_number_of_boundaries(kvp["boundaries"])
- self.metadata.set_number_of_centroids(kvp["centroids"])
- self.metadata.set_number_of_faces(kvp["faces"])
- self.metadata.set_number_of_kernels(kvp["kernels"])
- self.metadata.set_number_of_primitives(kvp["primitives"])
- self.metadata.set_number_of_nodes(kvp["nodes"])
- self.metadata.set_number_of_areas(kvp["areas"])
- self.metadata.set_number_of_islands(kvp["islands"])
- self.metadata.set_number_of_holes(kvp["holes"])
- self.metadata.set_number_of_volumes(kvp["volumes"])
+ # Fill metadata
+ self.metadata.set_3d_info(kvp["map3d"])
+ self.metadata.set_number_of_points(kvp["points"])
+ self.metadata.set_number_of_lines(kvp["lines"])
+ self.metadata.set_number_of_boundaries(kvp["boundaries"])
+ self.metadata.set_number_of_centroids(kvp["centroids"])
+ self.metadata.set_number_of_faces(kvp["faces"])
+ self.metadata.set_number_of_kernels(kvp["kernels"])
+ self.metadata.set_number_of_primitives(kvp["primitives"])
+ self.metadata.set_number_of_nodes(kvp["nodes"])
+ self.metadata.set_number_of_areas(kvp["areas"])
+ self.metadata.set_number_of_islands(kvp["islands"])
+ self.metadata.set_number_of_holes(kvp["holes"])
+ self.metadata.set_number_of_volumes(kvp["volumes"])
+ return True
+ return False
class SpaceTimeRasterDataset(AbstractSpaceTimeDataset):
