[GRASS-SVN] r60174 - in grass/trunk/temporal: t.rast.aggregate t.rast.aggregate.ds t.rast.extract t.rast.mapcalc t.register
Sat May 10 17:33:35 PDT 2014
Author: huhabla
Date: 2014-05-10 17:33:35 -0700 (Sat, 10 May 2014)
New Revision: 60174
   grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
   grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh
   grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
   grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh
   grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
   grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
   grass/trunk/temporal/t.register/test.t.register.raster.sh
Added offset option to aggregation modules and tests. More tests that check correct
error handling in case r.mapcalc fails in spatio-temporal processing.
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py	2014-05-11 00:33:35 UTC (rev 60174)
@@ -54,6 +54,15 @@
 #% answer: average
 #%end
+#%option
+#% key: offset
+#% type: integer
+#% description: Offset that is used to create the output map ids, output map id is generated as: basename_ (count + offset)
+#% required: no
+#% multiple: no
+#% answer: 0
+#%end
 #%option G_OPT_T_SAMPLE
 #%end
@@ -82,6 +91,7 @@
     register_null = flags["n"]
     method = options["method"]
     sampling = options["sampling"]
+    offset = options["offset"]
     # Make sure the temporal database exists
     tgis.init()
@@ -143,7 +153,7 @@
         if input_map_names:
             new_map = tgis.aggregate_raster_maps(
                 input_map_names, base, start, end,
-                count, method, register_null, dbif)
+                count, method, register_null, dbif,  offset)
             if new_map:
                 # Set the time stamp and write it to the raster map
Modified: grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh
--- grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.rast.aggregate/test.t.rast.aggregate.sh	2014-05-11 00:33:35 UTC (rev 60174)
@@ -2,29 +2,37 @@
 # Space time raster dataset aggregation
 # We need to set a specific region in the
 # @preprocess step of this test.
+export GRASS_OVERWRITE=1
 # The region setting should work for UTM and LL test locations
 g.region s=0 n=80 w=0 e=120 b=0 t=50 res=10 res3=10 -p3
 # Generate data
-r.mapcalc --o expr="prec_1 = rand(0, 550)"
-r.mapcalc --o expr="prec_2 = rand(0, 450)"
-r.mapcalc --o expr="prec_3 = rand(0, 320)"
-r.mapcalc --o expr="prec_4 = rand(0, 510)"
-r.mapcalc --o expr="prec_5 = rand(0, 300)"
-r.mapcalc --o expr="prec_6 = rand(0, 650)"
+r.mapcalc expr="prec_1 = rand(0, 550)"
+r.mapcalc expr="prec_2 = rand(0, 450)"
+r.mapcalc expr="prec_3 = rand(0, 320)"
+r.mapcalc expr="prec_4 = rand(0, 510)"
+r.mapcalc expr="prec_5 = rand(0, 300)"
+r.mapcalc expr="prec_6 = rand(0, 650)"
-t.create --o type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-15 12:05:45" increment="14 days"
+t.create type=strds temporaltype=absolute output=precip_abs1 title="A test" descr="A test"
+t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
+    start="2001-01-15 12:05:45" increment="14 days"
 # The first @test
-t.rast.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity="2 days" method=average sampling=start,during
+t.rast.aggregate --v input=precip_abs1 output=precip_abs2 \
+    base=prec_sum granularity="2 days" method=average sampling=start,during
 t.info type=strds input=precip_abs2
-t.rast.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity="1 months" method=maximum sampling=start,during
+    base=prec_sum granularity="1 months" method=maximum sampling=start,during
-t.rast.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity="2 months" method=minimum sampling=start,during
+t.rast.aggregate --v input=precip_abs1 output=precip_abs3 offset=10 \
+    base=prec_sum granularity="2 months" method=minimum sampling=start,during
-t.rast.aggregate --o --v input=precip_abs1 output=precip_abs2 base=prec_sum granularity="3 months" method=sum sampling=start,during
+t.rast.list input=precip_abs3
+t.rast.aggregate --v input=precip_abs1 output=precip_abs4 offset=100 \
+    base=prec_sum granularity="3 months" method=sum sampling=start,during
+t.rast.list input=precip_abs4
-t.unregister type=rast maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
-t.remove type=strds input=precip_abs1,precip_abs2
+t.remove -rf type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py	2014-05-11 00:33:35 UTC (rev 60174)
@@ -55,6 +55,15 @@
 #% answer: average
 #%end
+#%option
+#% key: offset
+#% type: integer
+#% required: no
+#% multiple: no
+#% answer: 0
+#%end
 #%end
@@ -80,6 +89,7 @@
     type = options["type"]
     tgis.init()
@@ -125,7 +135,7 @@
         if input_map_names:
             new_map = tgis.aggregate_raster_maps(input_map_names, base,
                                                  start, end, count, method,
-                                                 register_null, dbif)
+                                                 register_null, dbif,  offset)
             if new_map:
Modified: grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh
--- grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.rast.aggregate.ds/test.t.rast.aggregate.ds.sh	2014-05-11 00:33:35 UTC (rev 60174)
@@ -1,21 +1,23 @@
 #!/bin/sh
 # Aggregate a dataset by a second one
-r.mapcalc --o expr="prec_1 = 100"
-r.mapcalc --o expr="prec_2 = 150"
-r.mapcalc --o expr="prec_3 = 250"
-r.mapcalc --o expr="prec_4 = 250"
-r.mapcalc --o expr="prec_5 = 150"
-r.mapcalc --o expr="prec_6 = 100"
+r.mapcalc expr="prec_1 = 100"
+r.mapcalc expr="prec_2 = 150"
+r.mapcalc expr="prec_3 = 250"
+r.mapcalc expr="prec_4 = 250"
+r.mapcalc expr="prec_5 = 150"
+r.mapcalc expr="prec_6 = 100"
-v.random --o -z output=soil_1 n=20 zmin=0 zmax=100 column=height
-v.random --o -z output=soil_2 n=20 zmin=0 zmax=100 column=height
-v.random --o -z output=soil_3 n=20 zmin=0 zmax=100 column=height
+v.random -z output=soil_1 n=20 zmin=0 zmax=100 column=height
+v.random -z output=soil_2 n=20 zmin=0 zmax=100 column=height
+v.random -z output=soil_3 n=20 zmin=0 zmax=100 column=height
 n1=`g.tempfile pid=1 -d`
@@ -25,15 +27,18 @@
 soil_3|2001-08-01|2001-12-01
 EOF
-t.create --o type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
+t.create type=stvds temporaltype=absolute output=soil_abs1 title="A test" descr="A test"
 t.register type=vect input=soil_abs1 file="${n1}"
-t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-03-01 00:00:00" increment="1 months"
+t.register -i type=rast input=precip_abs1 \
+    maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 \
+    start="2001-03-01 00:00:00" increment="1 months"
 # The @test
-t.rast.aggregate.ds --o --v input=precip_abs1 output=precip_abs2 base=prec_sum type=stvds sample=soil_abs1 method=sum sampling=start,during
+t.rast.aggregate.ds --v input=precip_abs1 output=precip_abs2 base=prec_sum \
+    type=stvds sample=soil_abs1 method=sum sampling=start,during offset=100
 t.rast.list input=precip_abs2 method=deltagap
@@ -41,6 +46,5 @@
 t.unregister type=vect maps=soil_1,soil_2,soil_3
 t.remove type=stvds input=soil_abs1
 g.remove vect=soil_1,soil_2,soil_3
Modified: grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh
--- grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.rast.extract/test.t.rast.extract.sh	2014-05-11 00:33:35 UTC (rev 60174)
@@ -26,8 +26,12 @@
            expression=" if(precip_abs1 > 400, precip_abs1, null())" base=new_prec nprocs=4
 t.info type=strds input=precip_abs3
-t.rast.extract --o --v input=precip_abs1 output=precip_abs4 where="start_time > '2001-06-01'"
+# Let the test fail
+g.remove rast=prec_1
+t.rast.extract --o --v input=precip_abs1 output=precip_abs4 \
+          where="start_time > '2001-01-01'" expr="precip_abs1/1.0"\
+          base=new_test
 t.info type=strds input=precip_abs4
-t.remove type=strds input=precip_abs1,precip_abs2,precip_abs3,precip_abs4
Modified: grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh
--- grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.rast.mapcalc/test.t.rast.mapcalc.sh	2014-05-11 00:33:35 UTC (rev 60174)
@@ -1,49 +1,55 @@
 #!/bin/sh
 # Test for t.rast.mapcalc
 # @preprocess step of this test. We generate
 # raster with r.mapcalc and create several space time raster datasets
-t.create --o type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
-t.register -i --o type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
-t.register --o type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
+t.create type=strds temporaltype=absolute output=precip_abs2 title="A test" descr="A test"
+t.register -i type=rast input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 months"
+t.register type=rast input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6
 t.info precip_abs1
 t.info precip_abs2
 # The first @test
-t.rast.mapcalc --o -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
+t.rast.mapcalc -n inputs=precip_abs1,precip_abs2 output=precip_abs3 \
            expression=" precip_abs1 + precip_abs2" base=new_prec \
            method=equal nprocs=5
-t.rast.mapcalc --o -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
+t.rast.mapcalc -s inputs=precip_abs1,precip_abs2,precip_abs3 output=precip_abs4 \
            expression=" (precip_abs1 + precip_abs2) / precip_abs2" base=new_prec \
-t.rast.mapcalc --o -s inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+t.rast.mapcalc -s inputs=precip_abs1,precip_abs2 output=precip_abs4 \
            expression=" (precip_abs1 + precip_abs2) * null()" base=new_prec \
-t.rast.mapcalc --o -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+t.rast.mapcalc -sn inputs=precip_abs1,precip_abs2 output=precip_abs4 \
+           expression=" (precip_abs1 + precip_abs2) * null()" base=new_prec \
+           method=equal nprocs=5
 # @postprocess
-t.unregister type=rast maps=new_prec_1,new_prec_2,new_prec_3,new_prec_4,new_prec_5,new_prec_6
Modified: grass/trunk/temporal/t.register/test.t.register.raster.sh
--- grass/trunk/temporal/t.register/test.t.register.raster.sh	2014-05-11 00:32:02 UTC (rev 60173)
+++ grass/trunk/temporal/t.register/test.t.register.raster.sh	2014-05-11 00:33:35 UTC (rev 60174)
@@ -4,6 +4,8 @@
 # The raster maps will be registered in different space time raster
 # datasets.
@@ -11,81 +13,81 @@
 # The first @test
 # We create the space time raster inputs and register the raster maps with absolute time interval
-t.create --o type=strds temporaltype=absolute output=precip_abs3 title="A test" descr="A test"
-t.create --o type=strds temporaltype=absolute output=precip_abs4 title="A test" descr="A test"
-t.create --o type=strds temporaltype=absolute output=precip_abs5 title="A test" descr="A test"
-t.create --o type=strds temporaltype=absolute output=precip_abs6 title="A test" descr="A test"
-t.create --o type=strds temporaltype=absolute output=precip_abs7 title="A test" descr="A test"
+t.create  type=strds temporaltype=absolute output=precip_abs3 title="A test" descr="A test"
+t.create  type=strds temporaltype=absolute output=precip_abs4 title="A test" descr="A test"
+t.create  type=strds temporaltype=absolute output=precip_abs5 title="A test" descr="A test"
+t.create  type=strds temporaltype=absolute output=precip_abs6 title="A test" descr="A test"
+t.create  type=strds temporaltype=absolute output=precip_abs7 title="A test" descr="A test"
-t.register --o -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
+t.register  -i input=precip_abs1 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="1 seconds"
 t.info type=strds input=precip_abs1
 t.info -g type=strds input=precip_abs1
 r.info map=prec_1
 t.rast.list input=precip_abs1
 t.topology input=precip_abs1
-t.register --o -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
+t.register  -i input=precip_abs2 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 seconds, 5 minutes"
 t.info -g type=strds input=precip_abs2
 r.info map=prec_1
 t.topology input=precip_abs2
-t.register --o -i input=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
+t.register  -i input=precip_abs3 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="8 hours"
 t.info -g type=strds input=precip_abs3
 r.info map=prec_1
 t.topology input=precip_abs3
-t.register --o input=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
+t.register  input=precip_abs4 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="3 days"
 t.info -g type=strds input=precip_abs4
 r.info map=prec_1
 t.topology input=precip_abs4
-t.register --o input=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
+t.register  input=precip_abs5 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="4 weeks"
 t.info -g type=strds input=precip_abs5
 r.info map=prec_1
 t.rast.list input=precip_abs5
 t.topology input=precip_abs5
-t.register --o input=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
+t.register  input=precip_abs6 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-08-01" increment="2 months"
 t.info -g type=strds input=precip_abs6
 r.info map=prec_1
 t.rast.list input=precip_abs6
 t.topology input=precip_abs6
-t.register --o input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
+t.register  input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="20 years, 3 months, 1 days, 4 hours"
 t.info -g type=strds input=precip_abs7
 r.info map=prec_1
 t.rast.list input=precip_abs7
 t.topology input=precip_abs7
 # Register with different valid time again
-t.register --o input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.register  input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
 r.info map=prec_1
 # Register with different valid time again creating an interval
-t.register --o -i input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
+t.register  -i input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="99 years, 9 months, 9 days, 9 hours"
 r.info map=prec_1
-t.register --o input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" end="2002-01-01"
+t.register  input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" end="2002-01-01"
 r.info map=prec_1
@@ -93,7 +95,7 @@
 # Check for correct errors
 # Increment format error
-t.register -i --o input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="months"
+t.register -i  input=precip_abs7 maps=prec_1,prec_2,prec_3,prec_4,prec_5,prec_6 start="2001-01-01" increment="months"
