[GRASS-SVN] r60186 - grass/trunk/mswindows/external/rbatch
svn_grass at osgeo.org
Sun May 11 12:43:04 PDT 2014
Author: hellik
Date: 2014-05-11 12:43:04 -0700 (Sun, 11 May 2014)
New Revision: 60186
Added:
grass/trunk/mswindows/external/rbatch/R.bat
grass/trunk/mswindows/external/rbatch/Rpathset.bat
R-batch files update to rev 149 - step 2
Added: grass/trunk/mswindows/external/rbatch/R.bat
--- grass/trunk/mswindows/external/rbatch/R.bat (rev 0)
+++ grass/trunk/mswindows/external/rbatch/R.bat 2014-05-11 19:43:04 UTC (rev 60186)
@@ -0,0 +1,589 @@
+ at Echo OFF
+:: Software and documentation is (c) 2013 GKX Associates Inc. and
+:: licensed under [GPL 2.0](http://www.gnu.org/licenses/gpl-2.0.html).
+:: Help is at bottom of script or just run script with single argument: help
+:: can optionally uncomment and change these to force certain values. This
+:: is normally unnecessary. Rather one can usually rely on the heuristics to
+:: set them.
+:: set R_CMD=R
+:: set R_HOME=%ProgramFiles%\R\R-2.14.0
+:: set R_ARCH=64
+:: set R_MIKTEX_PATH=%ProgramFiles%\MiKTeX 2.9\miktex\bin
+:: set R_TOOLS=C:\Rtools
+:: set MYSQL_HOME=%ProgramFiles%\MySQL\MysQL Server 5.1
+:: 1 means read registry and 0 means ignore registry
+if not defined R_REGISTRY set R_REGISTRY=1
+set CYGWIN=nodosfilewarning
+SetLocal EnableExtensions EnableDelayedExpansion
+:: R_CMD
+:: 1. if 1st arg is CMD then set R_CMD to R
+:: 2. else if 1st arg is Rshow, Rpath, Rgui, Rcmd, R or Rscript set R_CMD to it
+:: and remove it from args
+:: 3. else use R_CMD if set
+:: 4. else use %0
+set args=%*
+set cmd=
+if /i "%~1"=="registry" goto:Rregistry
+if /i "%~1"=="cd" set cmd=Rcd
+if /i "%~1"=="CMD" set cmd=Rcmd
+if /i "%~1"=="dir" set cmd=Rdir
+if /i "%~1"=="ls" set cmd=Rdir
+if /i "%~1"=="gui" set cmd=Rgui
+if /i "%~1"=="help" goto:Rhelp
+if /i "%~1"=="path" set cmd=Rpath
+if /i "%~1"=="R" set cmd=R
+if /i "%~1"=="script" set cmd=Rscript
+if /i "%~1"=="show" set cmd=RShow
+if /i "%~1"=="SetReg" set cmd=RSetReg
+if /i "%~1"=="tools" set cmd=Rtools
+if /i "%~1"=="touch" set cmd=Rtouch
+if "%cmd%"=="" goto:R_CMD_cont
+if "%2"=="" (set args=) && goto:R_CMD_cont
+set args=xxx%*
+call set args=%%args:xxx%1=%%
+:R_CMD_cont
+if defined cmd set R_CMD=%cmd%
+if not defined R_CMD set R_CMD=%0
+:: set "R_CMD=%R_CMD:.bat=%"
+for %%i in ("%R_CMD%") do set R_CMD=%%~ni
+if /i "%R_CMD%"=="#Rscript" set R_CMD=Rscript
+rem echo R_CMD:%R_CMD% args=[%args%]
+:: 1. If .\Rgui.exe exist use implied R_PATH and skip remaining points.
+:: 2. If .\{x64,i386}\Rgui.exe or .\bin\{x64,i386}\Rgui.exe exists use implied R_HOME.
+:: 3. if R_HOME defined then derive any of R_ROOT and R_VER that
+:: are not already defined.
+:: 4. if R_PATH defined then derive any of R_ROOT, R_HOME, R_VER and R_ARCH that
+:: 4a. If R_REGISTRY=1 and R found in registry derive any of R_HOME, R_ROOT and
+:: R_VER that are not already defined.
+:: 5. If R_ROOT not defined try %ProgramFiles%\R\*, %ProgramFiles(x86)%\R\*
+:: and then %SystemRoot%\R else error
+:: 6. If R_VER not defined use last directory in cd %R_ROOT% & dir /od
+:: 7. if R_ARCH not defined try %R_ROOT%\%R_VER%\bin\x64\Rgui.exe and then
+:: %R_ROOT%\%R_VER%\bin\i386\Rgui.exe
+:: 8. If R_ROOT, R_VER and R_ARCH defined skip remaining points.
+:: 9. If Rgui.exe found on PATH use implied R_PATH.
+:: 1
+if exist Rgui.exe (
+ pushd ..\..
+ set R_HOME=!CD!
+ popd
+ goto:R_exe_end
+:: 2
+if exist x64\Rgui.exe (
+ pushd ..
+ set R_PATH=!CD!\bin\x64
+ popd
+ goto:R_exe_end
+if exist i386\Rgui.exe (
+ pushd ..
+ set R_PATH=!CD!\bin\i386
+ popd
+ goto:R_exe_end
+if exist bin\x64\Rgui.exe set R_PATH=%CD%\bin\x64 & goto:R_exe_end
+if exist bin\i386\Rgui.exe set R_PATH=%CD%\bin\i386
+:R_exe_end
+:: 3
+if defined R_HOME (
+ pushd
+ cd %R_HOME%
+ if not defined R_VER for /f "delims=" %%a in ("!CD!") do set R_VER=%%~na
+ cd ..
+ if not defined R_ROOT set R_ROOT=!CD!
+ popd
+:: 4
+if defined R_PATH (
+ pushd
+ cd %R_PATH%
+ if not defined R_ARCH for /f "delims=" %%a in ("!CD!") do set R_ARCH=%%~na
+ cd ..\..
+ if not defined R_HOME set R_HOME=!CD!
+ cd ..
+ popd
+:: 4a
+if not defined R_HOME for /f "tokens=2*" %%a in (
+ 'reg query hklm\software\wow6432Node\r-core\r /v InstallPath 2^>NUL ^| findstr InstallPath'
+ ) do set R_HOME=%%~b
+ 'reg query hklm\software\R-core\R /v InstallPath 2^>NUL ^| findstr InstallPath'
+ if not defined R_ROOT (
+ pushd %R_HOME%
+ cd ..
+ set R_ROOT=!CD!
+ popd
+ if not defined R_VER (
+ for /f "delims=" %%a in ("%R_HOME%") do set R_VER=%%~nxa
+:: 5
+if defined R_ROOT goto:R_ROOT_end
+if exist "%ProgramFiles%\R" set R_ROOT=%ProgramFiles%\R
+if exist %SystemDrive%\R set R_ROOT=%SystemDrive%\R
+:R_ROOT_end
+:: 6
+if defined R_VER goto:R_VER_end
+for /f "delims=" %%a in (
+ 'dir /b /od /ad "%R_ROOT%" 2^>NUL'
+) do set R_VER=%%a
+:R_VER_end
+:: do we need this?
+if defined R_ROOT if defined R_VER set R_HOME=%R_ROOT%\%R_VER%
+:: 7
+if defined R_ARCH goto:R_ARCH_cont
+set R_ARCH=i386
+if exist "%R_HOME%\bin\x64" set R_ARCH=x64
+if exist "%R_ROOT%\%R_VER%\bin\x64" set R_ARCH=x64
+:R_ARCH_cont
+if "%R_ARCH%"=="64" set R_ARCH=x64
+if "%R_ARCH%"=="32" set R_ARCH=i386
+if "%R_ARCH%"=="386" set R_ARCH=i386
+:: 8
+if not defined R_ROOT goto:where
+if not defined R_VER goto:where
+if not defined R_ARCH goto:where
+set R_PATH=%R_ROOT%\%R_VER%\bin\%R_ARCH%
+goto:path_end
+echo "R not found" & exit /b 1
+:: 9
+:where
+where Rgui.exe 1>NUL 2>NUL
+if not errorlevel 1 for /f "delims=" %%a in ('where Rgui.exe') do set R_PATH=%%~pa
+:path_end
+:: R_TOOLS
+:: 1. use R_TOOLS if defined. If not
+:: 2. check if ls.exe, rsync.exe and gcc.exe are on PATH. If not
+:: 3. check if Rtools found in registry. If not
+:: 4. check if C:\Rtools exists. If not
+:: 5. R_TOOLS not found.
+if defined R_TOOLS goto:RtoolsEnd
+where ls.exe 1> NUL 2> NUL
+if errorlevel 1 goto:RtoolsNotOnPATH
+where rsync.exe 1> NUL 2> NUL
+where gcc.exe 1> NUL 2> NUL
+for /f "delims=" %%a in ('where rsync.exe') do set R_TOOLS=%%~pa
+pushd %R_TOOLS%
+cd ..
+set R_TOOLS=%CD%
+popd
+goto:RtoolsEnd
+:RtoolsNotOnPATH
+if not defined R_TOOLS for /f "tokens=2*" %%a in (
+ 'reg query hklm\software\R-core\Rtools /v InstallPath 2^>NUL ^| findstr InstallPath'
+ ) do set R_TOOLS=%%~b
+ 'reg query hklm\software\wow6432Node\Rtools /v InstallPath 2^>NUL ^| findstr InstallPath'
+if exist "C:\Rtools" set R_TOOLS=C:\Rtools
+:RToolsEnd
+:: R_TOOLS_PATH
+:: Extract path from: %R_TOOLS%\unins000.dat
+if defined R_TOOLS call :extract_string {app} %R_TOOLS%\unins000.dat
+call set R_TOOLS_PATH=%%final:{app}=%R_TOOLS%%%
+call :trimPath:R_TOOLS_PATH
+if defined R_TOOLS for /f "tokens=3" %%a in (%R_TOOLS%\Version.txt) do set R_TOOLS_VERSION=%%a
+:: R_MIKTEX
+:: If R_MIKTEX defined use that
+:: else if pdflatex.exe on PATH use that else
+:: check %ProgramFiles%\miktex* else
+:: check %ProgramFiles(x86)%\miktex* else
+:: check %SystemDrive%\miktex*
+if defined R_MIKTEX_PATH goto:miktex_end
+:: if pdflatex.exe found in PATH use implied path
+where pdflatex.exe 1>NUL 2>NUL
+if errorlevel 1 goto:miktex_continue
+set MIKTEX_ALREADY_ON_PATH=1
+for /f "delims=" %%a in ('where pdflatex.exe') do set R_MIKTEX_PATH=%%~pa
+:: remove trailing \, if any
+IF "%R_MIKTEX_PATH:~-1%"=="\" SET R_MIKTEX_PATH=%R_MIKTEX_PATH:~0,-1%
+goto:miktex_end
+:miktex_continue
+if not defined R_MIKTEX_PATH for /f "delims=" %%a in (
+ 'dir /b /on "%ProgramFiles%"\miktex* 2^>NUL'
+) do set R_MIKTEX_PATH=%ProgramFiles%\%%a\miktex\bin
+ 'dir /b /on "%ProgramFiles(x86)%"\miktex* 2^>NUL'
+ 'dir /b /on %SystemDrive%:\miktex* 2^>NUL'
+) do set R_MIKTEX_PATH=%SystemDrive%:\%%a\mixtex\bin
+:miktex_end
+:: MySQL
+:: If MYSQL_HOME defined use that else
+:: check %ProgramFiles%\MySQL\* else
+:: check %SystemDrive%:\MySQL\*
+:: if not defined MYSQL_HOME for /f "delims=" %%a in (
+:: 'dir /b /on "%ProgramFiles%"\MySQL\* 2^>NUL'
+:: ) do set MYSQL_HOME=%ProgramFiles%\MySQL\%%a
+:: 'dir /b /on %SystemDrive%:\MySQL* 2^>NUL'
+:: ) do set R_MIKTEX=%SystemDrive%:\MySQL\%%a
+:: get name by which program was called - $0
+:: or use R_CMD environment variable if that was defined (mainly for testing)
+if not defined R_CMD (set R_CMD=%0)
+if /i "%R_CMD%"=="dir" goto:Rdir
+if /i "%R_CMD%"=="cd" goto:Rcd
+if /i "%R_CMD%"=="touch" goto:Rtouch
+if /i "%R_CMD%"=="Rversions" goto:RSetReg
+:: add MiKTeX to PATH if not already on it
+if not defined R_MIKTEX_PATH goto :miktex_add_path_end
+echo %PATH% | findstr /i miktex 1>NUL 2>NUL
+if errorlevel 1 path %R_MIKTEX_PATH%;%PATH%
+:miktex_add_path_end
+:: add Rtools paths to PATH if not already on it
+if not defined R_TOOLS_PATH goto :Rtools_add_path_end
+echo %PATH% | findstr /i Rtools 1>NUL 2>NUL
+if errorlevel 1 path %R_TOOLS_PATH%;%PATH%
+:Rtools_add_path_end
+if /i "%R_CMD%"=="Rpath" goto:Rpath
+if /i "%R_CMD%"=="Rtools" goto:Rtools
+if /i "%R_CMD%"=="Rcd" goto:Rcd
+if /i "%R_CMD%"=="Rdir" goto:Rdir
+if /i "%R_CMD%"=="Rshow" goto:Rshow
+if /i "%R_CMD%"=="Rtouch" goto:Rtouch
+if /i "%R_CMD%"=="RSetReg" goto:RSetReg
+if /i not "%R_CMD%"=="Rgui" goto:notRgui
+start "Rgui.exe" "%R_PATH%\Rgui.exe" %args%
+goto:eof
+:notRgui
+"%R_PATH%\%R_CMD%.exe" %args%
+goto:eof
+:: output the set statements
+:Rshow
+ set old=%CD%
+ cd %R_PATH%
+ for /f "delims=" %%a in ("!CD!") do set R_ARCH=%%~nxa
+ cd ..\..
+ set R_HOME=!CD!
+ for /f "delims=" %%a in ("!CD!") do set R_VER=%%~nxa
+ cd ..
+ set R_ROOT=!CD!
+ cd !old!
+:: echo set R_PATH=%R_PATH%
+:: echo set R_HOME=%R_HOME%
+:: echo set R_ROOT=%R_ROOT%
+:; echo set R_VER=%R_VER%
+:: echo set R_ARCH=%R_ARCH%
+:: echo set R_TOOLS=%R_TOOLS%
+:: echo set R_TOOLS_PATH=%R_TOOLS_PATH%
+:: :: echo set MYSQL_HOME=%MYSQL_HOME%
+::echo set R_MIKTEX_PATH=%R_MIKTEX_PATH%
+set R
+goto:eof
+:Rcd
+endlocal & cd %R_ROOT%
+goto:eof
+:Rdir
+dir/od "%R_ROOT%"
+goto:eof
+:RSetReg
+cd %R_PATH%
+RSetReg %args%
+goto:eof
+:: if not XP then check if running with Admin privs. If not give msg and exit.
+:Rtouch
+ver | findstr XP >NUL
+if not errorlevel 1 goto:Rtouch_next
+if not exist "%ProgramFiles%\R" goto:Rtouch_next
+reg query "HKU\S-1-5-19" >NUL 2>&1 && ( goto Rtouch_next ) || (
+ echo Please run this as Administator.
+ goto :eof
+:Rtouch_next
+if not defined R_HOME set R_HOME=%R_ROOT%\%R_VER%
+pushd %R_HOME%
+echo > dummy.txt
+del dummy.txt
+popd
+goto:eof
+:: set path
+:Rpath
+endlocal & PATH %PATH%;%R_PATH%
+goto:eof
+:Rtools
+goto:eof
+:: list R versions
+:Rversions
+if defined args goto:Rversions_cont
+pushd %R_HOME%
+cd ..
+echo R packages found. Most recent (last listed) is default:
+for /f "delims=" %%a in ('dir/b /od') do echo %%~fa
+popd
+goto:eof
+:Rversions_cont
+set args=###%args%
+set args=%args:### =%
+set args=%args:###=%
+pushd %R_HOME%
+cd ..
+(for /f "delims=" %%a in ('dir /b /od') do echo %%~fa) | findstr /L /C:"%args%" 1>NUL 2>NUL
+if errorlevel 1 echo %args% not found & goto:eof
+echo Run the following command (may need an elevated cmd window):
+for /f "delims=" %%a in ('dir /b /on ^| findstr /L /C:"%args%"') do @echo echo ^> "%%~fa\dummy.txt" /Y
+popd
+goto:eof
+:: list registry entries
+:Rregistry
+reg query hklm\software\R-core\R /v InstallPath 2>NUL | findstr InstallPath
+reg query hklm\software\wow6432Node\r-core\r /v InstallPath 2>NUL | findstr InstallPath
+goto:eof
+:: Extract text from file:
+:: %1 = input string that starts text
+:: %2 = input file
+:: final = output variable holding text from and including %1 until
+:: binary data encountered
+:: Needs: SetLocal EnableExtensions EnableDelayedExpansion
+:: Example:
+:: call :extract_string {app} C:\Rtools\unins000.dat
+:: echo %final%
+:: where {app} is the string that starts extraction and
+:: C:\Rtoolsiunins000.dat is the file
+:: Based on code by Frank Westlake, https://github.com/FrankWestlake
+ :extract_string
+ SetLocal EnableExtensions EnableDelayedExpansion
+ Set "string=%1"
+ Set "file=%2"
+ For /F "delims=" %%a in (
+ 'findstr /C:"%string%" "%file%"^|MORE'
+ ) Do (
+ Set "$=%%~a"
+ If /I "!$:~0,5!" EQU "%string%" (
+ Set $=!$:;=" "!
+ For %%b in ("!$!") Do (
+ Set "#=%%~b"
+ If "!#:~0,5!" EQU "%string%" (
+ CALL :work "!#!"
+ endlocal & set final=%final%
+ Goto :EOF
+ :work
+ set final=%final%!#!;
+ Goto :EOF
+ :trimPath:<variable to trim> [segment to add]
+ :: Eliminates redundant path segments from the variable and
+ :: optionally adds new segmants.
+ :: Example: CALL :trimPath:PATH
+ :: Example: CALL :trimPath:PATH "C:\A & B" C:\a\b\c
+ :: Note that only a colon separates the subroutine name and
+ :: the name of the variable to be edited.
+ :: - Frank Westlake, https://github.com/FrankWestlake
+ For /F "tokens=2 delims=:" %%a in ("%0") Do (
+ For %%a in (%* !%%a!) Do (
+ Set "#=%%~a"
+ For %%b in (!new!) Do If /I "!#!" EQU "%%~b" Set "#="
+ If DEFINED # (
+ If DEFINED new (Set "new=!new!;!#!") Else ( Set "new=!#!")
+ EndLocal & For /F "tokens=2 delims=:" %%a in ("%0") Do Set "%%a=%new%"
+ Goto :EOF
+:Rhelp
+echo (c) 2013 G. Grothendieck
+echo License: GPL 2.0 ( http://www.gnu.org/licenses/gpl-2.0.html )
+echo Launch script for R and associated functions.
+echo Usage: R.bat [subcommand] [arguments]
+echo Subcommands where (0) means takes no arguments; (A) means may need Admin priv
+echo cd - cd to R_ROOT, typically to C:\Program Files\R (0)
+echo cmd - Run Rcmd.exe
+echo dir - List contents of R_ROOT in chronological order showing R versions (0)
+echo gui - Run Rgui.exe
+echo help - Help info (0)
+echo path - Add R_TOOLS, R_MIKTEX ^& R_PATH to path for this cmd line session (0)
+echo R - Run R.exe (0)
+echo script - Run Rscript.exe
+echo show - Show R_ variable values used. R_PATH, etc. (0)
+echo SetReg - Run RSetReg; see 2.17 in R FAQ for Windows (A)
+echo tools - Add R_TOOLS and R_MIKTEX to path for this cmd line session (0)
+echo touch - Change date on R_HOME to now (0) (A)
+echo Examples
+echo R -- invoke R.exe R gui -- invoke Rgui.exe
+echo R dir -- show R versions R show -- show R_ variables
+echo R CMD build mypkg -- builds mypkg
+echo cmd /c set R_VER=R-2.14.0 ^& R gui -- run indicated Rgui version
+echo cmd /c set R_ARCH=32 ^^^& R gui -- run 32 bit Rgui
+echo cmd /c R_VER=R-2.14.0 ^^^& R setreg - make 2.14.0 current in registry
+echo cmd /c R_VER=R-2.14.0 ^^^& R.bat touch - change date on R-2.14.0 dir to now
+goto:eof
+echo.
+echo Run Rgui using a different version of R. R_HOME only affects R session
+echo but not cmd line session.
+echo cmd /c set R_HOME=%ProgramFiles%\R\R-2.14.0 ^& R gui
+echo
+echo Launch a new cmd line window in which R_HOME is as set and launch R:
+echo start set R_HOME=%ProgramFiles%\R\R-2.14.0 ^& R gui
+echo
+echo ==Customization by renaming==
+echo.
+echo If the optional first argument is missing then it uses the value of
+echo the environment variable R_CMD or if that is not set it uses the name of
+echo the script file as the default first argument. The idea is one could have
+echo multiple versions of the script called R.bat, Rgui.bat, etc. which invoke
+echo the corresponding functionality without having to specify first argument.
+echo.
+echo ==Customization by setting environment variables at top of script==
+echo.
+echo It can be customized by setting any of R_CMD, R_HOME, R_ARCH,
+echo R_MIKTEX_PATH, R_TOOLS after the @echo off command at the top of the
+echo script. R_CMD will be used as the default first argument (instead of the
+echo script name).
+echo.
+echo e.g. use the following after @echo off to force 32-bit
+echo set R_ARCH=32
+echo.
+echo e.g. use the following after @echo off to force a particular version of
+echo R to be used
+echo set R_HOME=%ProgramFiles%\R\R-2.14.0
+echo.
+echo e.g. use the following after @echo off to change the default command to
+echo Rgui even if the script is called myRgui.bat, say:
+echo set R_CMD=Rgui
+echo.
+echo ==Installation==
+echo.
+echo The script is self contained so just place it anywhere on your Windows
+echo PATH. (From the Windows cmd line the command PATH shows your current
+echo Windows path.) You may optionally make copies of this script with names
+echo like R.bat, Rscript.bat, Rcmd.bat so that each has a different default.
+echo.
Added: grass/trunk/mswindows/external/rbatch/Rpathset.bat
--- grass/trunk/mswindows/external/rbatch/Rpathset.bat (rev 0)
+++ grass/trunk/mswindows/external/rbatch/Rpathset.bat 2014-05-11 19:43:04 UTC (rev 60186)
@@ -0,0 +1,92 @@
+:: Purpose: setup path to use R, Rtools and other utilities from cmd line.
+:: Makes no permanent system changes. Does not read or write registry.
+:: Temporarily prepends to PATH and sets environment variables for current
+:: Windows cmd line session only.
+:: Use: Run this each time you launch cmd.exe and want to use R or Rtools.
+:: Can also use it like this: Rpathset Rgui
+:: where Rgui may be replaced with R, Rscript, etc.
+:: Install: Modify set statements appropriately for your installation.
+:: and then place this batch script anywhre on your existing path.
+:: (The Windows commandline command PATH shows the current PATH.)
+:: In many cases no changes are needed at all in this file.
+:: R_HOME and R_ARCH are the most likely that may need to be changed.
+:: Report bugs to:
+:: ggrothendieck at gmail.com
+:: License: GPL 2.0
+:: Go into R and issue this command: normalizePath(R.home())
+:: and use its output as the value here. If you upgrade R to another
+:: version R_HOME will change.
+:: R is available from: http://www.r-project.org
+set R_HOME=C:\Program Files\R\R-3.1.0
+:: 32 or 64 bit version of R.
+:: (If you wish to use both versions of R make two versions of this file.)
+:: set R_ARCH=i386
+set R_ARCH=x64
+:: If in future R changes where it puts its executables then change accordingly
+set R_PATH=%R_HOME%\bin\%R_ARCH%
+:: directory path where Rtools was installed. Usually best to use default
+:: which is the one shown below. Note that different versions of R may
+:: require different versions of Rtools.
+:: Rtools is available from: http://cran.r-project.org/bin/windows/Rtools/
+set R_TOOLS=C:\Rtools
+:: If in future Rtools changes the required paths then modify accordingly.
+:: To check, run the following findstr command which lists the R_TOOLS_PATH
+:: (plus some garbage):
+:: findstr {app} %R_TOOLS%\unins000.dat
+set R_TOOLS_PATH=%R_TOOLS%\bin;%R_TOOLS%\gcc-4.6.3\bin
+:: From within R, the R_USER directory path can be viewed like this:
+:: cat(normalizePath('~'))
+:: It contains your personal .Rprofile, if any, and unless set otherwise
+:: %R_USER%\R\win-library contains your personal R library of packages
+:: (from CRAN and elsewhere).
+set R_USER=%userprofile%\Documents
+:: This reduces the verbosity of certain Cygwin tools
+:: (Unfortunately, it seems to have no effect on some Windows systems.)
+:: Displays Rtools version in use
+type %R_TOOLS%\version.txt
+:: MiKTeX path. Used to build R packages from source.
+:: This is the directory containing pdflatex.exe
+:: MiKTeX is available from http://miktex.org
+set R_MIKTEX_PATH=C:\Program Files (x86)\MiKTeX 2.9\miktex\bin
+:: This is only needed when building RMySQL package from source
+:: It is not needed to run RMySQL once its built.
+:: set MYSQL_HOME=C:\Program Files\MySQL\MySQL Server 5.1
+:: This is only needed to run JGR and Deducer.
+:: R_LIBS is the system library.
+:: If you have installed at least one package (at which point R will ask to
+:: set up a personal library -- which you should allow) then R_LIBS_USER
+:: is similar to output of .libPaths() with first comnponent being your
+:: personal library and second compnent being library holding packages that
+:: come with R.
+:: Be sure NOT to store the packages that you downloaded from CRAN
+:: in the %R_HOME%\library directory.
+:: set R_LIBS=%R_USER%\R\win-library\2.15
+:: set R_LIBS_USER=%R_LIBS%;%R_HOME%\library
+:: adds directory to path for the remainder of current cmd line session
+path %R_TOOLS_PATH%;%R_MIKTEX_PATH%;%PATH%;%R_PATH%
+:: if there are no arguments we are done; else run the argument
+if "%1"=="" goto:eof
