[GRASS-SVN] r60247 - grass/trunk/raster/r.in.lidar
svn_grass at osgeo.org
Thu May 15 03:21:58 PDT 2014
Author: neteler
Date: 2014-05-15 03:21:58 -0700 (Thu, 15 May 2014)
New Revision: 60247
grass/trunk/raster/r.in.lidar/main.c
grass/trunk/raster/r.in.lidar/r.in.lidar.html
r.in.lidar: return filter added (from v.in.lidar)
Modified: grass/trunk/raster/r.in.lidar/main.c
--- grass/trunk/raster/r.in.lidar/main.c 2014-05-15 09:51:23 UTC (rev 60246)
+++ grass/trunk/raster/r.in.lidar/main.c 2014-05-15 10:21:58 UTC (rev 60247)
@@ -26,6 +26,7 @@
#include <grass/raster.h>
#include <grass/gprojects.h>
#include <grass/glocale.h>
+#include <liblas/capi/liblas.h>
#include "local_proto.h"
struct node
@@ -39,6 +40,10 @@
int max_nodes = 0;
struct node *nodes;
+#define LAS_ALL 0
+#define LAS_FIRST 1
+#define LAS_LAST 2
+#define LAS_MID 3
int new_node(void)
@@ -138,7 +143,7 @@
int r_low, r_up;
struct GModule *module;
- struct Option *input_opt, *output_opt, *percent_opt, *type_opt;
+ struct Option *input_opt, *output_opt, *percent_opt, *type_opt, *filter_opt;
struct Option *method_opt, *zrange_opt, *zscale_opt;
struct Option *trim_opt, *pth_opt, *res_opt;
struct Flag *print_flag, *scan_flag, *shell_style, *over_flag, *extents_flag;
@@ -148,12 +153,14 @@
LASHeaderH LAS_header;
LASSRSH LAS_srs;
LASPointH LAS_point;
+ int return_filter;
struct Key_Value *loc_proj_info = NULL, *loc_proj_units = NULL;
struct Key_Value *proj_info, *proj_units;
const char *projstr;
struct Cell_head cellhd, loc_wind;
+ unsigned int n_filtered;
G_gisinit(argv[0]);
@@ -236,6 +243,14 @@
res_opt->description =
_("Output raster resolution");
+ filter_opt = G_define_option();
+ filter_opt->key = "filter";
+ filter_opt->type = TYPE_STRING;
+ filter_opt->required = NO;
+ filter_opt->label = _("Only import points of selected return type");
+ filter_opt->description = _("If not specified, all points are imported");
+ filter_opt->options = "first,last,mid";
print_flag = G_define_flag();
print_flag->key = 'p';
print_flag->description =
@@ -304,6 +319,18 @@
exit(EXIT_SUCCESS);
+ return_filter = LAS_ALL;
+ if (filter_opt->answer) {
+ if (strcmp(filter_opt->answer, "first") == 0)
+ return_filter = LAS_FIRST;
+ else if (strcmp(filter_opt->answer, "last") == 0)
+ return_filter = LAS_LAST;
+ else if (strcmp(filter_opt->answer, "mid") == 0)
+ return_filter = LAS_MID;
+ else
+ G_fatal_error(_("Unknown filter option <%s>"), filter_opt->answer);
/* Fetch input map projection in GRASS form. */
proj_info = NULL;
proj_units = NULL;
@@ -321,7 +348,7 @@
/* Does the projection of the current location match the dataset? */
/* G_get_window seems to be unreliable if the location has been changed */
- G_get_set_window(&loc_wind);
+ G_get_set_window(&loc_wind); /* TODO: v.in.lidar uses G_get_default_window() */
/* fetch LOCATION PROJ info */
if (loc_wind.proj != PROJECTION_XY) {
loc_proj_info = G_get_projinfo();
@@ -736,6 +763,34 @@
y = LASPoint_GetY(LAS_point);
z = LASPoint_GetZ(LAS_point);
+ if (return_filter != LAS_ALL) {
+ int return_no = LASPoint_GetReturnNumber(LAS_point);
+ int n_returns = LASPoint_GetNumberOfReturns(LAS_point);
+ int skipme = 1;
+ if (n_returns > 1) {
+ switch (return_filter) {
+ case LAS_FIRST:
+ if (return_no == 1)
+ skipme = 0;
+ break;
+ case LAS_LAST:
+ if (return_no == n_returns)
+ skipme = 0;
+ break;
+ case LAS_MID:
+ if (return_no > 1 && return_no < n_returns)
+ skipme = 0;
+ break;
+ if (skipme) {
+ n_filtered++;
+ continue;
if (y <= pass_south || y > pass_north) {
continue;
Modified: grass/trunk/raster/r.in.lidar/r.in.lidar.html
--- grass/trunk/raster/r.in.lidar/r.in.lidar.html 2014-05-15 09:51:23 UTC (rev 60246)
+++ grass/trunk/raster/r.in.lidar/r.in.lidar.html 2014-05-15 10:21:58 UTC (rev 60247)
@@ -84,8 +84,14 @@
for use with arbitrarily large input files<!-- without a small value for percent= -->.
<!-- explained: memory use for regular stats will be based solely on region size,
but for the aggregate fns it will also depend on the number of data points. (?) -->
<p>
+A LiDAR pulse can have multiple returns. The first return values can be
+used to obtain a digital surface model (DSM) where e.g. canopy cover is
+represented. The last return values can be used to obtain a digital
+terrain model (DTM) where e.g. the forest floor instead of canopy
+cover is represented. The <b>filter</b> option allows to select one of
+first, mid, or last returns.
+<p>
The default map <b>type</b>=<tt>FCELL</tt> is intended as compromise between
preserving data precision and limiting system resource consumption.
