[GRASS-SVN] r60248 - grass/branches/develbranch_6/vector/v.external
svn_grass at osgeo.org
Thu May 15 03:28:39 PDT 2014
Author: martinl
Date: 2014-05-15 03:28:39 -0700 (Thu, 15 May 2014)
New Revision: 60248
grass/branches/develbranch_6/vector/v.external/main.c
v.external: remove formats from module description (see #2159)
backport -f flag from trunk
Modified: grass/branches/develbranch_6/vector/v.external/main.c
--- grass/branches/develbranch_6/vector/v.external/main.c 2014-05-15 10:21:58 UTC (rev 60247)
+++ grass/branches/develbranch_6/vector/v.external/main.c 2014-05-15 10:28:39 UTC (rev 60248)
@@ -25,16 +25,20 @@
#include <grass/glocale.h>
#include "ogr_api.h"
+static int cmp(const void *, const void *);
+static void list_formats(void);
+static char **format_list(int *, size_t *);
int main(int argc, char *argv[])
int i;
struct GModule *module;
struct Option *dsn_opt, *layer_opt, *out_opt;
+ struct Flag* format_flag;
char buf[2000];
FILE *fd;
struct Map_info Map;
OGRDataSourceH Ogr_ds;
- OGRSFDriverH Ogr_driver;
OGRLayerH Ogr_layer;
OGRFeatureDefnH Ogr_featuredefn;
int nlayers;
@@ -43,27 +47,14 @@
G_gisinit(argv[0]);
- OGRRegisterAll();
- /* Module options */
- sprintf(buf, "Available drivers: ");
- for (i = 0; i < OGRGetDriverCount(); i++) {
- Ogr_driver = OGRGetDriver(i);
- if (i == 0)
- sprintf(buf, "%s%s", buf, OGR_Dr_GetName(Ogr_driver));
- else
- sprintf(buf, "%s,%s", buf, OGR_Dr_GetName(Ogr_driver));
module = G_define_module();
module->keywords = _("vector, external, import");
- module->label =
+ module->description =
_("Creates a new vector as a read-only link to OGR layer.");
- module->description = G_store(buf);
dsn_opt = G_define_option();
dsn_opt->key = "dsn";
dsn_opt->type = TYPE_STRING;
- dsn_opt->required = YES;
dsn_opt->gisprompt = "old_file,file,dsn";
dsn_opt->description = "OGR datasource name. Examples:\n"
"\t\tESRI Shapefile: directory containing shapefiles\n"
@@ -84,9 +75,25 @@
"\t\tESRI Shapefile: shapefile name\n"
"\t\tMapInfo File: mapinfo file name");
+ format_flag = G_define_flag();
+ format_flag->key = 'f';
+ format_flag->description = _("List supported formats and exit");
+ format_flag->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ OGRRegisterAll();
+ if (format_flag->answer) {
+ /* list formats */
+ list_formats();
+ exit(EXIT_SUCCESS);
+ if (!dsn_opt)
+ G_fatal_error(_("Name of OGR data source not specified"));
if (!out_opt->answer && layer_opt->answer)
G_fatal_error(_("Output vector name was not specified"));
@@ -121,7 +128,7 @@
if (!layer_opt->answer) {
fprintf(stdout, "\n");
- exit(0);
if (layer == -1) {
@@ -163,3 +170,62 @@
exit(EXIT_SUCCESS);
+void list_formats(void)
+ int i, count;
+ char **list;
+ G_message(_("List of supported formats:"));
+ list = format_list(&count, NULL);
+ for (i = 0; i < count; i++)
+ fprintf(stdout, "%s\n", list[i]);
+ fflush(stdout);
+ G_free(list);
+char **format_list(int *count, size_t *len)
+ int i;
+ char **list;
+ list = NULL;
+ *count = 0;
+ if (len)
+ *len = 0;
+ char buf[2000];
+ OGRSFDriverH Ogr_driver;
+ /* Open OGR DSN */
+ OGRRegisterAll();
+ G_debug(2, "driver count = %d", OGRGetDriverCount());
+ for (i = 0; i < OGRGetDriverCount(); i++) {
+ Ogr_driver = OGRGetDriver(i);
+ G_debug(2, "driver %d/%d : %s", i, OGRGetDriverCount(),
+ OGR_Dr_GetName(Ogr_driver));
+ list = G_realloc(list, ((*count) + 1) * sizeof(char *));
+ /* chg white space to underscore in OGR driver names */
+ sprintf(buf, "%s", OGR_Dr_GetName(Ogr_driver));
+ G_strchg(buf, ' ', '_');
+ list[(*count)++] = G_store(buf);
+ if (len)
+ *len += strlen(buf) + 1; /* + ',' */
+ /* order formats by name */
+ qsort(list, *count, sizeof(char *), cmp);
+ return list;
+int cmp(const void *a, const void *b)
+ return strcmp(*(char **)a, *(char **)b);
