[GRASS-SVN] r60280 - grass-addons/grass6/raster/r.out.mbtiles_prep
svn_grass at osgeo.org
Fri May 16 18:25:51 PDT 2014
Author: hamish
Date: 2014-05-16 18:25:51 -0700 (Fri, 16 May 2014)
New Revision: 60280
grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
fixes for jpeg;
georeference from warped image not original region;
add georef to single band rasters exported as an image with r.out.tiff;
add instructions on what to do with the output.
Modified: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-16 21:13:06 UTC (rev 60279)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-17 01:25:51 UTC (rev 60280)
@@ -146,16 +146,17 @@
TMP_GMERC="$TMP_DIR"/`basename "$TMP_GTIFF" .tif`_gmerc.tif
+# TMS tiles need to be reprojected into the funny google merc projection
if [ "$MAP_TYPE" = "raster" ] ; then
r.out.tiff -t input="$MAP_NAME" output="$TMP_GTIFF"
+ gdalwarp -s_srs "`g.proj -jf`" -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
else
r.out.gdal input="$MAP_NAME" output="$TMP_GTIFF" format=GTiff
+ gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
fi
+## gdalwarp -srcnodata -dstnodata -dstalpha ?
-# TMS tiles need to be in funny google merc projection
-gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
-## -srcnodata -dstnodata -dstalpha
if [ $? -ne 0 ] ; then
g.message -e "Problem running gdalwarp"
cleanup
@@ -166,6 +167,46 @@
rm -f "$TMP_GTIFF"
+#### we need to find the bounding box in lat/lon of the post-warped geotiff
+# -- parse gdalinfo --
+gdalinfo -noct -nomd "$TMP_GMERC" > "$TMPFILE.warpinfo"
+IN_PROJ="+proj=longlat +datum=WGS84"
+OUT_PROJ="+proj=longlat +datum=WGS84"
+UL_DMS=`grep '^Upper Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+ sed -e 's/^ //' -e 's/, / /' -e 's/)$//'`
+LL_DMS=`grep '^Lower Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+UR_DMS=`grep '^Upper Right ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+LR_DMS=`grep '^Lower Right ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+# FIXME: will this work for geographic coords?
+CENTER_DMS=`grep '^Center ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
+N1=`echo "$UL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+N2=`echo "$UR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+S1=`echo "$LL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+S2=`echo "$LR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f2 -d'|'`
+E1=`echo "$UR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+E2=`echo "$LR_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+W1=`echo "$UL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+W2=`echo "$LL_DMS" | m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" --quiet | cut -f1 -d'|'`
+CENTER_DDD=`echo "$CENTER_DMS" | \
+ m.proj -dg proj_in="$IN_PROJ" proj_out="$OUT_PROJ" fs=' ' --quiet | \
+ cut -f1,2 -d ' '`
+WARP_N=`echo "$N1 $N2" | awk '{ if ($1 > $2) {print $1} else {print $2} }'`
+WARP_S=`echo "$S1 $S2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
+WARP_E=`echo "$E1 $E2" | awk '{ if ($1 > $2) {print $1} else {print $2} }'`
+WARP_W=`echo "$W1 $W2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
# Screen DPI is monitor/device dependent, and therefore a crude one
# size fits none.
# a: major radius of Earth (WGS84)
@@ -261,7 +302,6 @@
TITLE="$MAP_NAME"
fi
if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -gt 1 ] ; then
VERBOSE="-v"
else
@@ -269,7 +309,6 @@
fi
OUT_DIR="$TMP_DIR"/`basename "$TMP_GMERC" .tif`
g.message "Generating tiles for zoom level(s) $ZOOM"
@@ -277,9 +316,7 @@
gdal2tiles.py $VERBOSE -r bilinear -z "$ZOOM" -w none -t "$TITLE" \
"$TMP_GMERC" "$OUT_DIR"
-if [ $? -eq 0 ] ; then
- G2T_OK=1
-else
+if [ $? -ne 0 ] ; then
g.message -e "gdal2tiles failed."
cleanup
exit 1
@@ -291,23 +328,27 @@
#### write out .mapurl file
-# get max extent bbox in lat/lon
-eval `g.region -bgu`
URLFILE="$OUT_DIR"/`basename "$OUTFILE"`.mapurl
+if [ "$GIS_OPT_FORMAT" = "jpeg" ] ; then
+ ext=jpg
+else
+ ext=png
+fi
cat << EOF > "$URLFILE"
-url=$OUTFILE/ZZZ/XXX/YYY.png
+url=$OUTFILE/ZZZ/XXX/YYY.$ext
minzoom=$minzoom
maxzoom=$maxzoom
-center=$ll_clon $ll_clat
-bounds=$ll_w $ll_s $ll_e $ll_n
+center=$CENTER_DDD
+bounds=$WARP_W $WARP_S $WARP_E $WARP_N
type=tms
mbtiles=$OUTFILE/$OUTFILE.mbtiles
name=$TITLE
description=Exported zoom level(s) $ZOOM from GRASS GIS r.out.mbtiles_prep
defaultzoom=`expr $maxzoom - 1`
-format=png
+format=$ext
request_type=run,fill,load,reset_metadata
EOF
@@ -315,6 +356,16 @@
g.message "Converting to JPEG ..."
+ pgms="pngtopnm pnmtojpeg"
+ for pgm in $pgms ; do
+ if [ ! -x "`which $pgm`" ] ; then
+ g.message -e "$pgm is required, please install the NetPBM tools."
+ cleanup
+ exit 1
+ fi
+ done
cd "$OUT_DIR"
for file in `find . | grep '.png$'` ; do
outfile=`echo "$file" | sed -e 's/\.png$/.jpg/'`
@@ -331,10 +382,6 @@
tilemapresource.xml.tmp > tilemapresource.xml
rm tilemapresource.xml.tmp
- mv "$URLFILE" "$URLFILE".tmp
- sed -e 's+^format=png+format=jpg+' "$URLFILE".tmp > "$URLFILE"
- rm "$URLFILE".tmp
cd - > /dev/null
fi
@@ -349,4 +396,9 @@
tar cf `basename "$OUTFILE"`.tar `basename "$OUTFILE"` `basename "$OUTFILE"`.mapurl
fi
+g.message message=""
g.message "Done."
+g.message "Next copy the '$OUTFILE' directory and mapurl file to \
+/sdcard/maps/ on your Android device and select the mapurl file as the \
+tile source in Geopaparazzi. The mbtiles spatialite database will then \
+be populated in the background."
