[GRASS-SVN] r60281 - grass-addons/grass6/raster/r.out.mbtiles_prep
svn_grass at osgeo.org
Sat May 17 01:47:41 PDT 2014
Author: hamish
Date: 2014-05-17 01:47:41 -0700 (Sat, 17 May 2014)
New Revision: 60281
grass-addons/grass6/raster/r.out.mbtiles_prep/description.html
grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
the blogs were wrong, do not warp to pseudo-merc first;
bump dpi up to tablet/smartphone values;
add another level of fine detail to the autozoom calc to allow a bit of overzoom;
add second example to help page & (commented out) instructions on export GPX companions.
Modified: grass-addons/grass6/raster/r.out.mbtiles_prep/description.html
--- grass-addons/grass6/raster/r.out.mbtiles_prep/description.html 2014-05-17 01:25:51 UTC (rev 60280)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/description.html 2014-05-17 08:47:41 UTC (rev 60281)
@@ -2,7 +2,7 @@
<em>r.out.mbtiles_prep</em> creates a TMS tileset and support files ready to
load into software like Geopaparazzi which will make the final conversion to
-a mbtiles spatialite database file.
+a MBTiles SQLite database file.
<h2>NOTES</h2>
@@ -11,10 +11,15 @@
<p>
If not specified the zoom level will be automatically chosen.
<p>
+When finished, copy the <b>output</b> directory and mapurl file to
+<tt>/sdcard/maps/</tt> on your Android device and select the mapurl file
+as the tile source in <em>Geopaparazzi</em>. The MBTiles SQLite
+database will then be populated in the background.
<h2>EXAMPLE</h2>
+Example 1:
Creates a tileset for the North Carolina sample dataset's <tt>soilsID</tt> raster
map at automatically chosen zoom levels 11-14.
@@ -23,7 +28,36 @@
r.out.mbtiles_prep in=soilsID out=soil_tiles format=jpeg
</pre></div>
+<p>
+Example 2:
+Drape the soils map over a shaded relief of the elevation map, and bundle
+it up into a tarball for easier copying.
+<div class="code"><pre>
+g.region rast=soilsID
+d.mon x0
+d.resize w=750 h=675
+r.colors -e elevation_shade color=sepia
+d.shadedmap relief=elevation_shade drape=soilsID output=shaded_soilsID
+r.out.mbtiles_prep -t in=shaded_soilsID out=shaded_soil_tiles format=jpeg
+</pre></div>
+<!-- prep companion data for North Carolina
+# in lat/lon location
+v.proj in=usgsgages map=PERMANENT loc=nc_spm_08
+v.proj in=geodetic_swwake_pts map=PERMANENT loc=nc_spm_08
+v.proj in=roadsmajor map=PERMANENT loc=nc_spm_08
+v.out.ogr in=usgsgages dsn=usgsgages.gpx \
+ format=GPX type=point dsco='GPX_USE_EXTENSIONS=YES'
+v.out.ogr in=geodetic_swwake_pts dsn=geodetic_swwake_pts.gpx \
+v.out.ogr in=roadsmajor dsn=roadsmajor.gpx \
+ format=GPX type=line dsco='GPX_USE_EXTENSIONS=YES'
<h2>SEE ALSO</h2>
<em><a href="i.group.html">i.group</a></em>
@@ -35,8 +69,8 @@
<h2>AUTHOR</h2>
Hamish Bowman<br>
-<i>Geology Dept.<br>
-University of Otago<BT>
+<i>Department of Geology<br>
+University of Otago<br>
Dunedin, New Zealand</i>
<p>
Modified: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-17 01:25:51 UTC (rev 60280)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-17 08:47:41 UTC (rev 60281)
@@ -4,7 +4,7 @@
# MODULE: r.out.mbtiles_prep
# AUTHOR(S): M. Hamish Bowman, Dunedin, New Zealand
# PURPOSE: Export a raster map into a TMS bundle ready for conversion
-# to mbtiles format
+# to MBTiles SQLite format
# COPYRIGHT: (C) 2014 Hamish Bowman, and the GRASS Development Team
# This program is free software; you can redistribute it and/or modify
@@ -146,14 +146,23 @@
TMP_GMERC="$TMP_DIR"/`basename "$TMP_GTIFF" .tif`_gmerc.tif
-# TMS tiles need to be reprojected into the funny google merc projection
+if [ -n "$GRASS_VERBOSE" ] && [ "$GRASS_VERBOSE" -eq 0 ] ; then
+ QUIET="-q"
+else
+ QUIET=""
+fi
+# ?? do the source of TMS tiles sometimes need to be reprojected into the
+# funny google merc projection first?
if [ "$MAP_TYPE" = "raster" ] ; then
r.out.tiff -t input="$MAP_NAME" output="$TMP_GTIFF"
- gdalwarp -s_srs "`g.proj -jf`" -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+ #gdalwarp -s_srs "`g.proj -jf`" -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+ gdal_translate $QUIET -a_srs "`g.proj -jf`" "$TMP_GTIFF" "$TMP_GMERC"
else
r.out.gdal input="$MAP_NAME" output="$TMP_GTIFF" format=GTiff
- gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+ #gdalwarp -t_srs EPSG:900913 -dstalpha "$TMP_GTIFF" "$TMP_GMERC"
+ mv "$TMP_GTIFF" "$TMP_GMERC"
fi
## gdalwarp -srcnodata -dstnodata -dstalpha ?
@@ -167,13 +176,21 @@
rm -f "$TMP_GTIFF"
+if [ 0 -eq 1 ] ; then
+## I don't think we need to do the gdalwarp, but it's worth keeping this
+## next bit of code for parsing the lat/lon bbox out of gdalinfo for a
+## rainy day.
#### we need to find the bounding box in lat/lon of the post-warped geotiff
# -- parse gdalinfo --
gdalinfo -noct -nomd "$TMP_GMERC" > "$TMPFILE.warpinfo"
IN_PROJ="+proj=longlat +datum=WGS84"
OUT_PROJ="+proj=longlat +datum=WGS84"
+#?OUT_PROJ="+proj=longlat +ellps=sphere +a=6378137 +b=6378137 +nadgrids=@null"
UL_DMS=`grep '^Upper Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
sed -e 's/^ //' -e 's/, / /' -e 's/)$//'`
LL_DMS=`grep '^Lower Left ' "$TMPFILE.warpinfo" | cut -f3- -d'(' | \
@@ -205,6 +222,10 @@
WARP_W=`echo "$W1 $W2" | awk '{ if ($1 < $2) {print $1} else {print $2} }'`
+# then this would go in the mapurl file:
+#center=$CENTER_DDD
+#bounds=$WARP_W $WARP_S $WARP_E $WARP_N
+fi
# Screen DPI is monitor/device dependent, and therefore a crude one
@@ -259,8 +280,9 @@
eval `g.region -gu`
eval `g.region -legu`
- # adjust as needed:
- SCREEN_DPI=96
+ # adjust as needed depending if you are working on a desktop monitor or mobile device:
+ # a value of 96 might be appropriate for desktop, 225 for tablet or smartphone. YMMV.
+ SCREEN_DPI=225
#SCALE_NS=$ns_extent/(($rows/$DPI)*$INCH2METER)
#SCALE_EW=$ew_extent/(($cols/$DPI)*$INCH2METER)
@@ -277,7 +299,7 @@
zoomscale=`calc_webtile_scale $center_lat $zoom $SCREEN_DPI`
#echo "[$zoom 1 : $zoomscale]" # @ ${SCREEN_DPI}dpi]"
if [ "$zoomscale" -gt "$MAP_SCALE" ] ; then
- maxzoom=`expr "$zoom" + 1`
+ maxzoom=`expr "$zoom" + 2`
minzoom=`expr "$maxzoom" - 3`
fi
done
@@ -308,7 +330,6 @@
VERBOSE=""
fi
OUT_DIR="$TMP_DIR"/`basename "$TMP_GMERC" .tif`
g.message "Generating tiles for zoom level(s) $ZOOM"
@@ -328,6 +349,9 @@
#### write out .mapurl file
+# get max extent bbox in lat/lon
+eval `g.region -bgu`
URLFILE="$OUT_DIR"/`basename "$OUTFILE"`.mapurl
@@ -341,13 +365,13 @@
url=$OUTFILE/ZZZ/XXX/YYY.$ext
minzoom=$minzoom
maxzoom=$maxzoom
-center=$CENTER_DDD
-bounds=$WARP_W $WARP_S $WARP_E $WARP_N
+center=$ll_clon $ll_clat
+bounds=$ll_w $ll_s $ll_e $ll_n
type=tms
mbtiles=$OUTFILE/$OUTFILE.mbtiles
name=$TITLE
description=Exported zoom level(s) $ZOOM from GRASS GIS r.out.mbtiles_prep
-defaultzoom=`expr $maxzoom - 1`
+defaultzoom=`expr $maxzoom - 2`
format=$ext
request_type=run,fill,load,reset_metadata
EOF
@@ -400,5 +424,5 @@
g.message "Done."
g.message "Next copy the '$OUTFILE' directory and mapurl file to \
/sdcard/maps/ on your Android device and select the mapurl file as the \
-tile source in Geopaparazzi. The mbtiles spatialite database will then \
+tile source in Geopaparazzi. The MBTiles SQLite database will then \
be populated in the background."
