[GRASS-SVN] r60321 - in grass/trunk/vector: v.edit v.lrs/v.lrs.create v.lrs/v.lrs.where v.net v.support
svn_grass at osgeo.org
Sun May 18 09:13:50 PDT 2014
Author: hcho
Date: 2014-05-18 09:13:50 -0700 (Sun, 18 May 2014)
New Revision: 60321
grass/trunk/vector/v.edit/args.c
grass/trunk/vector/v.lrs/v.lrs.create/main.c
grass/trunk/vector/v.lrs/v.lrs.where/main.c
grass/trunk/vector/v.net/args.c
grass/trunk/vector/v.support/main.c
v.edit, v.lrs.create, v.lrs.where, v.net, v.support: Option thresh => threshold for consistency
Modified: grass/trunk/vector/v.edit/args.c
--- grass/trunk/vector/v.edit/args.c 2014-05-18 16:12:52 UTC (rev 60320)
+++ grass/trunk/vector/v.edit/args.c 2014-05-18 16:13:50 UTC (rev 60321)
@@ -99,7 +99,7 @@
_("Difference in x,y,z direction for moving feature or vertex");
params->maxdist = G_define_option();
- params->maxdist->key = "thresh";
+ params->maxdist->key = "threshold";
params->maxdist->type = TYPE_DOUBLE;
params->maxdist->required = NO;
params->maxdist->multiple = YES;
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c 2014-05-18 16:12:52 UTC (rev 60320)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c 2014-05-18 16:13:50 UTC (rev 60321)
@@ -224,7 +224,7 @@
table_opt->description = _("New table is created by this module");
thresh_opt = G_define_option();
- thresh_opt->key = "thresh";
+ thresh_opt->key = "threshold";
thresh_opt->type = TYPE_DOUBLE;
thresh_opt->required = NO;
thresh_opt->answer = "1";
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c 2014-05-18 16:12:52 UTC (rev 60320)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c 2014-05-18 16:13:50 UTC (rev 60321)
@@ -101,7 +101,7 @@
table_opt->description = _("Name of the reference system table");
thresh_opt->answer = "1000";
Modified: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c 2014-05-18 16:12:52 UTC (rev 60320)
+++ grass/trunk/vector/v.net/args.c 2014-05-18 16:13:50 UTC (rev 60321)
@@ -63,7 +63,7 @@
opt->nfield_opt->guisection = _("Nodes");
opt->thresh_opt = G_define_option();
- opt->thresh_opt->key = "thresh";
+ opt->thresh_opt->key = "threshold";
opt->thresh_opt->type = TYPE_DOUBLE;
opt->thresh_opt->required = NO;
opt->thresh_opt->multiple = NO;
Modified: grass/trunk/vector/v.support/main.c
--- grass/trunk/vector/v.support/main.c 2014-05-18 16:12:52 UTC (rev 60320)
+++ grass/trunk/vector/v.support/main.c 2014-05-18 16:13:50 UTC (rev 60321)
@@ -95,7 +95,7 @@
zone->description = _("Vector map projection zone");
thresh = G_define_option();
- thresh->key = "thresh";
+ thresh->key = "threshold";
thresh->type = TYPE_DOUBLE;
thresh->required = NO;
thresh->description =
