[GRASS-SVN] r60361 - grass/branches/releasebranch_7_0/scripts/v.report
svn_grass at osgeo.org
Mon May 19 20:36:58 PDT 2014
Author: hcho
Date: 2014-05-19 20:36:58 -0700 (Mon, 19 May 2014)
New Revision: 60361
grass/branches/releasebranch_7_0/scripts/v.report/v.report.py
v.report: cat mismatch bug fixed (merge from 60359)
Modified: grass/branches/releasebranch_7_0/scripts/v.report/v.report.py
--- grass/branches/releasebranch_7_0/scripts/v.report/v.report.py 2014-05-20 03:35:13 UTC (rev 60360)
+++ grass/branches/releasebranch_7_0/scripts/v.report/v.report.py 2014-05-20 03:36:58 UTC (rev 60361)
@@ -4,6 +4,7 @@
# MODULE: v.report
# AUTHOR(S): Markus Neteler, converted to Python by Glynn Clements
+# Bug fixed by Huidae Cho <grass4u gmail.com>
# PURPOSE: Reports geometry statistics for vector maps
# COPYRIGHT: (C) 2005, 2007-2009 by MN and the GRASS Development Team
@@ -67,7 +68,6 @@
grass.fatal(_("Vector map <%s> not found") % mapname)
colnames = grass.vector_columns(mapname, layer, getDict = False, stderr = nuldev)
if not colnames:
colnames = ['cat']
@@ -124,7 +124,11 @@
records2.sort()
#make pre-table
- records3 = [r1 + r2[1:] for r1, r2 in zip(records1, records2)]
+ # len(records1) may not be the same as len(records2) because
+ # v.db.select can return attributes that are not linked to features.
+ records3 = []
+ for r2 in records2:
+ records3.append(filter(lambda r1: r1[0] == r2[0], records1)[0] + r2[1:])
else:
records1 = []
p = grass.pipe_command('v.category', inp = mapname, layer = layer, option = 'print')
