[GRASS-SVN] r60362 - grass-addons/grass6/raster/r.out.mbtiles_prep
svn_grass at osgeo.org
Mon May 19 21:59:03 PDT 2014
Author: hamish
Date: 2014-05-19 21:59:03 -0700 (Mon, 19 May 2014)
New Revision: 60362
grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
sorting the names is much more efficient than sorting the data, check if tar is installed, comment out redundant instructions
Modified: grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep
--- grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-20 03:36:58 UTC (rev 60361)
+++ grass-addons/grass6/raster/r.out.mbtiles_prep/r.out.mbtiles_prep 2014-05-20 04:59:03 UTC (rev 60362)
@@ -508,26 +508,21 @@
# perhaps try 'md5sum | sort | uniq -d' to weed out duplicates?
# see https://github.com/geopaparazzi/geopaparazzi/wiki/mbtiles-Implementation
- for file in `find "$OUTFILE" -name "*.$ext"` ; do
+ for file in `find "$OUTFILE" -name "*.$ext" | sort -n -t / -k 2` ; do
zoomcolrow=`echo "$file" | sed -e "s|.*$OUTFILE/||" -e "s|\.$ext||" -e 's|/|, |g'`
echo "INSERT INTO tiles VALUES ($zoomcolrow, X'`hexdump -v -e '1/1 "%.2x"' $file`');"
done
- ) > "${TMPFILE}_tiles.sql"
+ ) >> "$TMPFILE.sql"
- sort -n "${TMPFILE}_tiles.sql" >> "$TMPFILE.sql"
echo "COMMIT TRANSACTION;" >> "$TMPFILE.sql"
if [ `wc -l < "${TMPFILE}_tiles.sql"` -gt 65535 ] ; then
echo "FIXME: insert some 'COMMIT TRANSACTION; BEGIN TRANSACTION;' inline the sql every 65535 inserts or so"
fi
- mv "$TMPFILE.sql" "$OUTFILE.sql"
g.message "Populating SQLite database ..."
- cat "$OUTFILE.sql" | sqlite3 "$OUTFILE.mbtiles"
+ cat "$TMPFILE.sql" | sqlite3 "$OUTFILE.mbtiles"
fi
@@ -535,6 +530,11 @@
cleanup
if [ "$GIS_FLAG_T" -eq 1 ] ; then
+ if [ ! -x "`which tar`" ] ; then
+ g.message -e "tar is required, please install it first."
+ exit 1
+ fi
cd `dirname "$OUTFILE"`
tar cf `basename "$OUTFILE"`.tar `basename "$OUTFILE"` `basename "$OUTFILE"`.mapurl
fi
@@ -542,7 +542,9 @@
g.message message=""
g.message "Done."
-g.message "Next copy the '$OUTFILE' directory and mapurl file to \
-/sdcard/maps/ on your Android device and select the mapurl file as the \
-tile source in Geopaparazzi. The MBTiles SQLite database will then \
-be populated in the background."
+#g.message "Next copy the '$OUTFILE' directory and mapurl file to \
+# /sdcard/maps/ on your Android device and select the mapurl file as the \
+# tile source in Geopaparazzi. The MBTiles SQLite database will then \
+# be populated in the background."
