[GRASS-SVN] r60472 - grass/trunk/db/db.login
svn_grass at osgeo.org
Sun May 25 01:55:14 PDT 2014
Author: martinl
Date: 2014-05-25 01:55:14 -0700 (Sun, 25 May 2014)
New Revision: 60472
grass/trunk/db/db.login/main.c
db.login: implement print flag
Modified: grass/trunk/db/db.login/main.c
--- grass/trunk/db/db.login/main.c 2014-05-25 08:54:54 UTC (rev 60471)
+++ grass/trunk/db/db.login/main.c 2014-05-25 08:55:14 UTC (rev 60472)
@@ -30,6 +30,7 @@
int main(int argc, char *argv[])
struct Option *driver, *database, *user, *password;
+ struct Flag *print;
struct GModule *module;
/* Initialize the GIS calls */
@@ -65,9 +66,20 @@
password->description = _("Password to set for DB connection");
password->guisection = _("Settings");
+ print = G_define_flag();
+ print->key = 'p';
+ print->description = _("Print connection settings and exit");
+ print->guisection = _("Print");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
+ if (print->answer) {
+ /* print all settings to standard output and exit */
+ db_get_login_dump(stdout);
+ exit(EXIT_SUCCESS);
if (db_set_login(driver->answer, database->answer, user->answer,
password->answer) == DB_FAILED) {
G_fatal_error(_("Unable to set user/password"));
