[GRASS-SVN] r60473 - grass/trunk/scripts/db.test
svn_grass at osgeo.org
Sun May 25 02:22:29 PDT 2014
Author: neteler
Date: 2014-05-25 02:22:29 -0700 (Sun, 25 May 2014)
New Revision: 60473
grass/trunk/scripts/db.test/db.test.py
db.test: print which DB driver is tested
Modified: grass/trunk/scripts/db.test/db.test.py
--- grass/trunk/scripts/db.test/db.test.py 2014-05-25 08:55:14 UTC (rev 60472)
+++ grass/trunk/scripts/db.test/db.test.py 2014-05-25 09:22:29 UTC (rev 60473)
@@ -29,6 +29,7 @@
import sys
import os
from grass.script import core as grass
+from grass.script import db as grassdb
def main():
test_file = options['test']
@@ -36,6 +37,9 @@
expected = grass.tempfile()
result = grass.tempfile()
+ dbconn = grassdb.db_connection()
+ grass.message(_("Using DB driver: %s") % dbconn['driver'])
infile = os.path.join(os.environ['GISBASE'], 'etc', 'db.test', test_file)
inf = file(infile)
