[GRASS-SVN] r60492 - grass/branches/releasebranch_7_0/gui/wxpython/gui_core
svn_grass at osgeo.org
Mon May 26 07:25:03 PDT 2014
Author: annakrat
Date: 2014-05-26 07:25:03 -0700 (Mon, 26 May 2014)
New Revision: 60492
grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py
wxGUI/import dlg: fix closing dialog, #2243 (merged from trunk, r59571)
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py 2014-05-26 13:49:09 UTC (rev 60491)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py 2014-05-26 14:25:03 UTC (rev 60492)
@@ -1794,6 +1794,11 @@
pass
+ def OnCmdDone(self, cmd, returncode):
+ """!Do what has to be done after importing"""
+ pass
class GdalImportDialog(ImportDialog):
def __init__(self, parent, giface, ogr = False, link = False):
"""!Dialog for bulk import of various raster/vector data
@@ -1857,12 +1862,12 @@
ext = self.dsnInput.GetFormatExt()
# determine data driver for PostGIS links
- popOGR = False
+ self.popOGR = False
if self.importType == 'ogr' and \
self.dsnInput.GetType() == 'db' and \
self.dsnInput.GetFormat() == 'PostgreSQL' and \
'GRASS_VECTOR_OGR' not in os.environ:
- popOGR = True
+ self.popOGR = True
os.environ['GRASS_VECTOR_OGR'] = '1'
for layer, output in data:
@@ -1906,14 +1911,21 @@
cmd.append('--overwrite')
# run in Layer Manager
- self._giface.RunCmd(cmd, onDone=self.AddLayers)
- if popOGR:
+ self._giface.RunCmd(cmd, onDone=self.OnCmdDone)
+ """!Load layers and close if required"""
+ if not hasattr(self, 'AddLayers'):
+ return
+ self.AddLayers(cmd, returncode)
+ if self.popOGR:
os.environ.pop('GRASS_VECTOR_OGR')
- if self.closeOnFinish.IsChecked():
+ if returncode == 0 and self.closeOnFinish.IsChecked():
self.Close()
def _getCommand(self):
"""!Get command"""
if self.link:
@@ -2068,10 +2080,18 @@
- self.Close()
+ return
+ if self.closeOnFinish.IsChecked():
+ self.Close()
def OnSetDsn(self, event):
"""!Input DXF file defined, update list of layer widget"""
path = event.GetString()
