[GRASS-SVN] r60493 - grass-addons/grass7/raster/r.hants
svn_grass at osgeo.org
Mon May 26 10:50:19 PDT 2014
Author: mmetz
Date: 2014-05-26 10:50:19 -0700 (Mon, 26 May 2014)
New Revision: 60493
grass-addons/grass7/raster/r.hants/main.c
grass-addons/grass7/raster/r.hants/r.hants.html
r.hants: add amplitude and phase output, optimize
Modified: grass-addons/grass7/raster/r.hants/main.c
--- grass-addons/grass7/raster/r.hants/main.c 2014-05-26 14:25:03 UTC (rev 60492)
+++ grass-addons/grass7/raster/r.hants/main.c 2014-05-26 17:50:19 UTC (rev 60493)
@@ -116,6 +116,8 @@
struct
struct Option *input, *file, *suffix,
+ *amp, /* prefix for amplitude output */
+ *phase, /* prefix for phase output */
*nf, /* number of harmonics */
*fet, /* fit error tolerance */
*dod, /* degree of over-determination */
@@ -133,17 +135,20 @@
struct input *inputs = NULL;
int num_outputs;
struct output *outputs = NULL;
+ struct output *out_amp = NULL;
+ struct output *out_phase = NULL;
char *suffix;
struct History history;
- DCELL *values = NULL, *rc = NULL, *amp = NULL, *phase = NULL;
+ DCELL *values = NULL, *rc = NULL;
int nrows, ncols;
int row, col;
double lo, hi, fet, *cs, *sn, *ts, delta;
int bl;
- double **mat, **mat_t, **A, *za, *zr, maxerrlo, maxerrhi;
+ double **mat, **mat_t, **A, *Azero, *za, *zr, maxerrlo, maxerrhi;
+ int asize;
int dod, nf, nr, nout, noutmax;
int rejlo, rejhi, *useval;
- int do_amp_phase, dumped;
+ int do_amp, do_phase;
G_gisinit(argv[0]);
@@ -171,6 +176,18 @@
parm.suffix->label = _("Suffix for output maps");
parm.suffix->description = _("The suffix will be appended to input map names");
+ parm.amp = G_define_option();
+ parm.amp->key = "amplitude";
+ parm.amp->type = TYPE_STRING;
+ parm.amp->required = NO;
+ parm.amp->label = _("Prefix for output amplitude maps");
+ parm.phase = G_define_option();
+ parm.phase->key = "phase";
+ parm.phase->type = TYPE_STRING;
+ parm.phase->required = NO;
+ parm.phase->label = _("Prefix for output phase maps");
parm.nf = G_define_option();
parm.nf->key = "nf";
parm.nf->type = TYPE_INTEGER;
@@ -237,6 +254,14 @@
if (!parm.input->answer && !parm.file->answer)
G_fatal_error(_("Please specify input= or file="));
+ if (parm.amp->answer && parm.phase->answer) {
+ if (strcmp(parm.amp->answer, parm.phase->answer) == 0)
+ G_fatal_error(_("'%s' and '%s' options must be different"),
+ parm.amp->key, parm.phase->key);
+ do_amp = parm.amp->answer != NULL;
+ do_phase = parm.phase->answer != NULL;
nf = atoi(parm.nf->answer);
if (nf < 1)
G_fatal_error(_("The number of frequencies must be > 0"));
@@ -344,6 +369,7 @@
else
bl = num_inputs;
+ /* open output maps */
num_outputs = num_inputs;
outputs = G_calloc(num_outputs, sizeof(struct output));
@@ -363,6 +389,56 @@
out->fd = Rast_open_new(output_name, DCELL_TYPE);
+ nr = 2 * nf + 1;
+ if (nr > num_inputs)
+ G_fatal_error(_("The maximum number of frequencies for %d input maps is %d."),
+ num_inputs, (num_inputs - 1) / 2);
+ noutmax = num_inputs - nr - dod;
+ if (noutmax < 0)
+ G_fatal_error(_("The degree of overdetermination can not be larger than %d "
+ "for %d input maps and %d frequencies."),
+ dod + noutmax, num_inputs, nf);
+ if (noutmax == 0)
+ G_warning(_("Missing values can not be reconstructed, "
+ "please reduce either '%s' or '%s'"),
+ parm.nf->key, parm.dod->key);
+ if (do_amp) {
+ /* open output amplitude */
+ out_amp = G_calloc(nf, sizeof(struct output));
+ for (i = 0; i < nf; i++) {
+ struct output *out = &out_amp[i];
+ char output_name[GNAME_MAX];
+ sprintf(output_name, "%s.%d", parm.amp->answer, i);
+ out->name = G_store(output_name);
+ out->buf = Rast_allocate_d_buf();
+ out->fd = Rast_open_new(output_name, DCELL_TYPE);
+ if (do_phase) {
+ /* open output phase */
+ out_phase = G_calloc(nf, sizeof(struct output));
+ struct output *out = &out_phase[i];
+ sprintf(output_name, "%s.%d", parm.phase->answer, i);
/* initialise variables */
values = G_malloc(num_inputs * sizeof(DCELL));
@@ -375,12 +451,6 @@
rc = G_malloc(num_inputs * sizeof(DCELL));
useval = G_malloc(num_inputs * sizeof(int));
- do_amp_phase = 0;
- if (do_amp_phase) {
- amp = G_malloc((nf + 1) * sizeof(DCELL));
- phase = G_malloc((nf + 1) * sizeof(DCELL));
if (parm.ts->answer) {
for (i = 0; parm.ts->answers[i]; i++);
if (i != num_inputs)
@@ -393,31 +463,19 @@
ts[i] = i;
- if (2 * nf + 1 < num_inputs)
- nr = 2 * nf + 1;
- else
- nr = num_inputs;
- noutmax = num_inputs - nr - dod;
- if (noutmax < 0)
- G_fatal_error(_("For %d input maps and %d frequencies, "
- "the degree of overdetermination can not be larger than %d"),
- num_inputs, nf, dod + noutmax);
- if (noutmax == 0)
- G_warning(_("Missing values can not be reconstructed, "
- "please reduce either '%s' or '%s'"),
- parm.nf->key, parm.dod->key);
mat = G_alloc_matrix(nr, num_inputs);
mat_t = G_alloc_matrix(num_inputs, nr);
A = G_alloc_matrix(nr, nr);
+ Azero = G_alloc_vector(nr * nr);
+ asize = nr * nr * sizeof(double);
za = G_alloc_vector(nr);
zr = G_alloc_vector(nr);
rc = G_alloc_vector(num_inputs);
+ for (i = 0; i < nr * nr; i++)
+ Azero[i] = 0;
for (i = 0; i < bl; i++) {
double ang = 2.0 * M_PI * i / bl;
@@ -453,8 +511,6 @@
/* process the data */
G_message(_("Harmonic analysis of %d input maps..."), num_inputs);
- dumped = 1;
for (row = 0; row < nrows; row++) {
G_percent(row, nrows, 4);
@@ -510,22 +566,21 @@
* A temp: nr, num_inputs
* A: nr, nr */
+ memcpy(*A, Azero, asize);
for (i = 0; i < nr; i++) {
za[i] = 0;
for (j = 0; j < num_inputs; j++) {
- if (useval[j])
+ if (useval[j]) {
za[i] += mat[i][j] * values[j];
- for (j = 0; j < nr; j++) {
- A[i][j] = 0;
- for (k = 0; k < num_inputs; k++) {
- if (useval[k])
- A[i][j] += mat[i][k] * mat_t[k][j];
+ for (k = 0; k < nr; k++)
+ A[i][k] += mat[i][j] * mat_t[j][k];
- if (i > 0)
+ if (i > 0) {
A[i][i] += delta;
/* zr = A \ za
@@ -589,30 +644,26 @@
out->buf[col] = rc[i];
- /* DEBUG
- * dump original and approximated values for one cell to stdout */
- if (non_null >= 20 && done == 1 && !dumped &&
- row > nrows / 3 && col > ncols / 2 ) {
- for (i = 0; i < num_inputs; i++) {
- fprintf(stdout, "%g;%g\n", values[i], rc[i]);
- dumped = 1;
+ if (do_amp || do_phase) {
+ /* amplitude and phase */
+ /* skip constant */
- /* amplitude and phase */
- amp[0] = zr[0];
- phase[0] = 0;
for (i = 1; i < nr; i += 2) {
- int ifr = (i + 1) / 2;
- double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
+ int ifr = i >> 1;
- if (angle < 0)
- angle += 360;
- phase[ifr] = angle;
- amp[ifr] = sqrt(zr[i] * zr[i] + zr[i + 1] * zr[i + 1]);
+ if (do_amp) {
+ out_amp[ifr].buf[col] = sqrt(zr[i] * zr[i] +
+ if (do_phase) {
+ double angle = atan2(zr[i + 1], zr[i]) * 180 / M_PI;
+ if (angle < 0)
+ angle += 360;
+ out_phase[ifr].buf[col] = angle;
@@ -622,15 +673,38 @@
Rast_set_d_null_value(&out->buf[col], 1);
+ if (do_amp)
+ Rast_set_d_null_value(&out_amp[i].buf[col], 1);
+ if (do_phase)
+ Rast_set_d_null_value(&out_phase[i].buf[col], 1);
for (i = 0; i < num_outputs; i++)
Rast_put_d_row(outputs[i].fd, outputs[i].buf);
+ if (do_amp)
+ Rast_put_d_row(out_amp[i].fd, out_amp[i].buf);
+ if (do_phase)
+ Rast_put_d_row(out_phase[i].fd, out_phase[i].buf);
G_percent(row, nrows, 2);
+ /* Close input maps */
+ if (!flag.lazy->answer) {
+ for (i = 0; i < num_inputs; i++)
+ Rast_close(inputs[i].fd);
/* close output maps */
for (i = 0; i < num_outputs; i++) {
struct output *out = &outputs[i];
@@ -642,11 +716,31 @@
Rast_write_history(out->name, &history);
- /* Close input maps */
- if (!flag.lazy->answer) {
- Rast_close(inputs[i].fd);
+ if (do_amp) {
+ /* close output amplitudes */
+ Rast_close(out->fd);
+ Rast_short_history(out->name, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(out->name, &history);
+ if (do_phase) {
+ /* close output phases */
exit(EXIT_SUCCESS);
Modified: grass-addons/grass7/raster/r.hants/r.hants.html
--- grass-addons/grass7/raster/r.hants/r.hants.html 2014-05-26 14:25:03 UTC (rev 60492)
+++ grass-addons/grass7/raster/r.hants/r.hants.html 2014-05-26 17:50:19 UTC (rev 60493)
@@ -15,7 +15,7 @@
frequencies should be at least 5 when analysing one year.
<p>The number of frequencies should also not be too large. With a large
-number of frequencies, outliers can not longer be identified because the
+number of frequencies, outliers can no longer be identified because the
fit is "too good", outliers can be represented by the estimate.
The number of frequencies should also be smaller than <em>n input maps / 2</em>
if missing values should be reconstructed.
@@ -23,8 +23,20 @@
<h2>NOTES</h2>
+The optional <em>amplitude</em> and <em>phase</em> output maps contain
+the amplitude and phase for each frequency. The amplitude maps can be
+used to identify the dominant frequency with <em>r.series
+method=max_raster</em>. The baseline frequeny (base period) has the
+suffix <em>.0</em>, its first harmonic has the suffix <em>.1</em>, its
+second harmonic has the suffix <em>.2</em>, etc. The value of the
+output of <em>r.series method=max_raster</em> is identical to the
+number of the suffix. With the <em>amplitude</em> output maps for NDVI
+input, this can be used to determine the number of peaks in vegetation
+growth within the base period, where 0 (zero) means that the dominant
+frequency is the base period, i.e. one peak per base period.
<p>
-If the <em>range=</em> option is given, any values which fall outside
+If the <em>range</em> option is given, any values which fall outside
that range will be treated as if they were NULL.
The <em>range</em> parameter can be set to <em>low,high</em> thresholds:
values outside of this range are treated as NULL.
@@ -35,24 +47,25 @@
negative values, or <em>range=-inf,-200.4</em> to ignore values above -200.4).
<p>
-The number of raster maps to be processed is given by the limit of the
-operating system. For example, both the hard and soft limits for users are
-typically 1024. The soft limit can be changed with e.g. <tt>ulimit -n
-1500</tt> (UNIX-based operating systems) but not higher than the hard
-limit. If it is too low, you can as superuser add an entry in
+The maximum number of raster maps that can be processed is given by the
+per-user limit of the operating system. For example, the soft limits
+for users are typically 1024. The soft limit can be changed with e.g.
+<tt>ulimit -n 4096</tt> (UNIX-based operating systems) but not higher
+than the hard limit. If it is too low, you can as superuser add an
+entry in
<div class="code"><pre>
/etc/security/limits.conf
# <domain> <type> <item> <value>
-your_username hard nofile 1500
+your_username hard nofile 4096
</pre></div>
-This would raise the hard limit to 1500 file. Be warned that more
-files open need more RAM. Also have a look at the system-wide limit
+This would raise the hard limit to 4096 files. Also have a look at the
+overall limit of the operating system
cat /proc/sys/fs/file-max
</pre></div>
-which is on modern systems several 100,000 files.
+which is on modern Linux systems several 100,000 files.
<p>Use the <em>file</em> option to analyze large amount of raster maps
@@ -120,7 +133,10 @@
g.gui.animation rast=`g.mlist rast pattern="*tempmean_hants" sep=comma`
</pre></div>
+<h2>SEE ALSO</h2>
+<em><a href="r.series.html">r.series</a></em>
<h2>REFERENCES</h2>
<p>
Roerink, G. J., Menenti, M. and Verhoef, W., 2000. Reconstructing
