[GRASS-SVN] r60557 - grass-addons/grass7/raster/r.roughness.vector
Wed May 28 11:29:28 PDT 2014
Author: hellik
Date: 2014-05-28 11:29:27 -0700 (Wed, 28 May 2014)
New Revision: 60557
   grass-addons/grass7/raster/r.roughness.vector/Makefile
   grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
   grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
r.roughness.vector: add pythonized grass6 addon (on behalf of Carlos Grohmann) - step 4 - svn propset
Modified: grass-addons/grass7/raster/r.roughness.vector/Makefile
--- grass-addons/grass7/raster/r.roughness.vector/Makefile	2014-05-28 18:24:57 UTC (rev 60556)
+++ grass-addons/grass7/raster/r.roughness.vector/Makefile	2014-05-28 18:29:27 UTC (rev 60557)
@@ -1,7 +1,7 @@
-MODULE_TOPDIR = ../..
-PGM = r.roughness.vector
-include $(MODULE_TOPDIR)/include/Make/Script.make
-default: script
+MODULE_TOPDIR = ../..
+PGM = r.roughness.vector
+include $(MODULE_TOPDIR)/include/Make/Script.make
+default: script
Property changes on: grass-addons/grass7/raster/r.roughness.vector/Makefile
___________________________________________________________________
Added: svn:mime-type
   + text/x-makefile
Added: svn:eol-style
   + native
Modified: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
--- grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html	2014-05-28 18:24:57 UTC (rev 60556)
+++ grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html	2014-05-28 18:29:27 UTC (rev 60557)
@@ -48,7 +48,7 @@
 Helmut Kudrnovsky - http://www.alectoria.at
 <p>
-<i>Last changed: $Date: 2006/04/20 02:43:23 $</i>
+<i>Last changed: $Date$</i>
 </p><hr><p><a href="index.html">Main
 index</a> - <a href="raster.html">raster index</a>
 - <a href="full_index.html">Full index</a></p>
Property changes on: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.html
   + text/html
Added: svn:keywords
   + Author Date Id
   + native
Modified: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
--- grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py	2014-05-28 18:24:57 UTC (rev 60556)
+++ grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py	2014-05-28 18:29:27 UTC (rev 60557)
@@ -1,352 +1,352 @@
-#!/usr/bin/env python
-#-*- coding:utf-8 -*-
-# MODULE:	r.roughness.vector.py
-# AUTHOR(S):	Carlos H. Grohmann <carlos dot grohmann at gmail dot com >
-#               Helmut Kudrnovsky <alectoria at gmx dot at>
-# PURPOSE:	Calculates surface roughness from DEMs.
-#       Python version of r.roughness.vector.sh
-#		In this script surface roughness is taken as the dispersion
-#		of vectors normal to surface areas (pixels). Normal vectors
-#		are defined by slope and aspect.
-#		Reference:
-#		Hobson, R.D., 1972. Surface roughness in topography:
-#		quantitative approach. In: Chorley, R.J. (ed) Spatial
-#		analysis in geomorphology. Methuer, London, p.225-245.
-#		This script will create several temporary maps, for the
-#		directional cosines in each direction (x,y,z), for the sum
-#		of these cosines and vector strengh.
-#		If the user does not specify the output map name, it will be
-#		set to INPUT_MAP_roughness_vector_NxN
-#		where N is the window size.
-# COPYRIGHT:	(C) 2014 by the GRASS Development Team
-#		This program is free software under the GNU General Public
-#		License (>=v2). Read the file COPYING that comes with GRASS
-#		for details.
-#%Module
-#% description: Calculates surface roughness with a moving-window approach
-#% keywords: raster
-#% keywords: terrain
-#% keywords: aspect
-#% keywords: slope
-#% keywords: roughness
-#%end
-#%option G_OPT_R_ELEV
-#% key: elevation
-#% description: Name of elevation raster map
-#% required: yes
-#%end
-#%option
-#% key: slope
-#% type: string
-#% gisprompt: old,cell,raster
-#% description: Input raster slope map
-#% required : yes
-#%end
-#%option
-#% key: aspect
-#% type: string
-#% description: Input raster aspect map
-#% required : yes
-#%end
-#%option
-#% key: window
-#% type: integer
-#% description: Window size (3,5,7,...,25)
-#% required : no
-#% answer : 3
-#%end
-#%option
-#% key: strength
-#% type: string
-#% description: Output vector strength map
-#% required : no
-#%end
-#%option
-#% key: fisher
-#% type: string
-#% description: Output Fischer's K parameter map
-#% required : no
-#%end
-#%option
-#% key: compass
-#% type: string
-#% description: OPTIONAL INPUT: Compass aspect values (longitude)
-#% required : no
-#%end
-#%option
-#% key: colatitude
-#% type: string
-#% description: OPTIONAL INPUT: Colatitude values (90 - slope)
-#% required : no
-#%end
-#%option
-#% key: xcos
-#% type: string
-#% description: OPTIONAL INPUT: X directional cosine map
-#% required : no
-#%end
-#%option
-#% key: ycos
-#% type: string
-#% description: OPTIONAL INPUT: Y directional cosine map
-#% required : no
-#%end
-#%option
-#% key: zcos
-#% type: string
-#% description: OPTIONAL INPUT: Z directional cosine map
-#% required : no
-#%end
-import sys
-import atexit
-import grass.script as grass
-# cleaning up tem files
-def cleanup():
-    rasts = ['aspect_compass','colat_angle','cosine_x','cosine_y','cosine_z','sum_Xcosine','sum_Ycosine','sum_Zcosine']
-    grass.run_command('g.remove', flags = 'f', rast = rasts, quiet = True)
-def main():
-#set options
-    elevmap = options['elevation']          # input
-    slope = options['slope']                # input
-    aspect = options['aspect']              # input
-    window = options['window']              # input
-    strength = options['strength']          # output
-    fisher = options['fisher']              # output
-    compass = options['compass']            # temporary
-    colatitude = options['colatitude']      # temporary
-    xcos = options['xcos']                  # temporary
-    ycos = options['ycos']                  # temporary
-    zcos = options['zcos']                  # temporary
-# check if input files exist
-    grass.message( "----" )
-    grass.message( "Check if input files exist ..." )
-    find_elev = grass.find_file(elevmap, element = 'cell')
-    if find_elev['name'] == "":
-        print "Map %s not found! Aborting." % elevmap
-        sys.exit()
-    find_slope = grass.find_file(slope, element = 'cell')
-    if find_slope['name'] == "":
-        print "Map %s not found! Aborting." % slope
-        sys.exit()
-    find_aspect = grass.find_file(aspect, element = 'cell')
-    if find_aspect['name'] == "":
-        print "Map %s not found! Aborting." % aspect
-        sys.exit()
-#ACERTAR O NOME DOS ARQUIVOS - TIRAR TUDO DESDE O @!!!!
-# give default names to outputs, in case the user doesn't provide them
-    grass.message( "Define default output names when not defined by user ..." )
-    if strength == "":
-        strength = "%s_vector_strength_%sx%s" % (find_elev['name'],window,window)
-    if fisher == "":
-        fisher = "%s_fisher_1K_%sx%s" % (find_elev['name'],window,window)
-# calculate compass-oriented aspect and colatitude
-# (temp rasters)
-# correct aspect angles from cartesian (GRASS default) to compass angles
-#   if(A==0,0,if(A < 90, 90-A, 360+90-A))
-    grass.message( "Calculate compass aspect values ..." )
-    if compass == "":
-        aspect_compass = 'aspect_compass'
-#        print "Calculating compass aspect values (longitude)"
-#        aspect_compass = grass.tempfile()
-        grass.mapcalc("${out} = if(${rast1}==0,0,if(${rast1} < 90, 90-${rast1}, 360+90-${rast1}))",
-            out = aspect_compass,
-            rast1 = aspect)
-    else:
-        grass.message( "Using previous calculated compass aspect values (longitude)" )
-        # print "Using previous calculated compass aspect values (longitude)"
-        aspect_compass = compass
-# calculates colatitude (90-slope)
-    grass.message( "Calculate colatitude ..." )
-    if colatitude == "":
-        colat_angle = 'colat_angle'
-#        print "Calculating colatitude (90-slope)"
-#        colat_angle = grass.tempfile()
-        grass.mapcalc("${out} = 90 - ${rast1}",
-            out = colat_angle,
-            rast1 = slope)
-    else:
-        grass.message( "Using previous calculated colatitude values" )
-        # print "Using previous calculated colatitude values"
-        colat_angle = colatitude
-# calculate direction cosines
-# direction cosines relative to axis oriented north, east and up
-# direction cosine calculation according to McKean & Roering (2004), Geomorphology, 57:331-351.
-    grass.message( "Calculate direction cosines ..." )
-# X cosine
-    if xcos == "":
-        cosine_x = 'cosine_x'
-#        print "Calculating X direction cosine"
-#        cosine_x = grass.tempfile()
-        grass.mapcalc("${out} = sin(${rast1}) * cos(${rast2})",
-            out = 'cosine_x',
-            rast1 = aspect_compass,
-            rast2 = colat_angle)
-    else:
-        grass.message( "Using previous calculated X direction cosine value" )
-        # print "Using previous calculated X direction cosine values"
-        cosine_x = xcos
-# Y cosine
-    if ycos == "":
-        cosine_y = 'cosine_y'
-#        print "Calculating Y direction cosine"
-#        cosine_y = grass.tempfile()
-        grass.mapcalc("${out} = sin(${rast1}) * sin(${rast2})",
-            out = 'cosine_y',
-    else:
-        grass.message( "Using previous calculated Y direction cosine values" )
-        # print "Using previous calculated Y direction cosine values"
-        cosine_y = ycos
-# Z cosine
-    if zcos == "":
-        cosine_z = 'cosine_z'
-#        cosine_z = grass.tempfile()
-        grass.mapcalc("${out} = cos(${rast1})",
-            out = 'cosine_z',
-            rast1 = aspect_compass)
-    else:
-        cosine_z = zcos
-# calculate SUM of direction cosines
-    grass.message( "Calculate sum of direction cosines ..." )
-    grass.message( "Calculating sum of X direction cosines ..." )
-    # print "Calculating sum of X direction cosines"
-#    sum_Xcosine = grass.tempfile()
-    grass.run_command("r.neighbors",
-            input=cosine_x,
-			output='sum_Xcosine',
-			method='sum',
-			size=window,
-			overwrite=True)
-    grass.message( "Calculating sum of Y direction cosines ..." )
-#    print "Calculating sum of Y direction cosines"
-#    sum_Ycosine = grass.tempfile()
-            input=cosine_y,
-			output='sum_Ycosine',
-			method='sum',
-			size=window,
-			overwrite=True)
-    grass.message( "Calculating sum of Z direction cosines ..." )
-#    print "Calculating sum of Z direction cosines"
-#    sum_Zcosine = grass.tempfile()
-            input=cosine_z,
-			output='sum_Zcosine',
-			method='sum',
-			size=window,
-			overwrite=True)
-# calculate vector strength
-    grass.message( "Calculate vector strength ..." )
-#    print "Calculating vector strength"
-#    print strength
-    grass.mapcalc("${out} = sqrt(exp(${rast1},2) + exp(${rast2},2) + exp(${rast3},2))",
-            out = strength,
-            rast1 = 'sum_Xcosine',
-            rast2 = 'sum_Ycosine',
-            rast3 = 'sum_Zcosine')
-# calculate Inverted Fisher's K parameter
-# k=1/((N-1)/(N-R))
-    grass.message( "Calculate inverted Fisher's K parameter ..." )
-    w = int(window)
-#    print "Calculating Inverted Fisher's K parameter"
-    grass.mapcalc("${out} = ($w * $w - ${rast1}) / ($w * $w - 1)",
-            out = fisher,
-            rast1 = strength,
-            w = int(window))
-#    calculations done
-    grass.message( "Result maps:" )
-    grass.message( strength )
-    grass.message( fisher )
-    grass.message( "Calculations done." )
-# this "if" condition instructs execution of code contained in this script, *only* if the script is being executed directly
-if __name__ == "__main__": # this allows the script to be used as a module in other scripts or as a standalone script
-    options, flags = grass.parser() #
-    atexit.register(cleanup)
-    sys.exit(main()) #
+#!/usr/bin/env python
+#-*- coding:utf-8 -*-
+# MODULE:	r.roughness.vector.py
+# AUTHOR(S):	Carlos H. Grohmann <carlos dot grohmann at gmail dot com >
+#               Helmut Kudrnovsky <alectoria at gmx dot at>
+# PURPOSE:	Calculates surface roughness from DEMs.
+#       Python version of r.roughness.vector.sh
+#		In this script surface roughness is taken as the dispersion
+#		of vectors normal to surface areas (pixels). Normal vectors
+#		are defined by slope and aspect.
+#		Reference:
+#		Hobson, R.D., 1972. Surface roughness in topography:
+#		quantitative approach. In: Chorley, R.J. (ed) Spatial
+#		analysis in geomorphology. Methuer, London, p.225-245.
+#		This script will create several temporary maps, for the
+#		directional cosines in each direction (x,y,z), for the sum
+#		of these cosines and vector strengh.
+#		If the user does not specify the output map name, it will be
+#		set to INPUT_MAP_roughness_vector_NxN
+#		where N is the window size.
+# COPYRIGHT:	(C) 2014 by the GRASS Development Team
+#		This program is free software under the GNU General Public
+#		License (>=v2). Read the file COPYING that comes with GRASS
+#		for details.
+#%Module
+#% description: Calculates surface roughness with a moving-window approach
+#% keywords: raster
+#% keywords: terrain
+#% keywords: aspect
+#% keywords: slope
+#% keywords: roughness
+#%end
+#%option G_OPT_R_ELEV
+#% key: elevation
+#% description: Name of elevation raster map
+#% required: yes
+#%end
+#%option
+#% key: slope
+#% type: string
+#% gisprompt: old,cell,raster
+#% description: Input raster slope map
+#% required : yes
+#%end
+#%option
+#% key: aspect
+#% type: string
+#% description: Input raster aspect map
+#% required : yes
+#%end
+#%option
+#% key: window
+#% type: integer
+#% description: Window size (3,5,7,...,25)
+#% required : no
+#% answer : 3
+#%end
+#%option
+#% key: strength
+#% type: string
+#% description: Output vector strength map
+#% required : no
+#%end
+#%option
+#% key: fisher
+#% type: string
+#% description: Output Fischer's K parameter map
+#% required : no
+#%end
+#%option
+#% key: compass
+#% type: string
+#% description: OPTIONAL INPUT: Compass aspect values (longitude)
+#% required : no
+#%end
+#%option
+#% key: colatitude
+#% type: string
+#% description: OPTIONAL INPUT: Colatitude values (90 - slope)
+#% required : no
+#%end
+#%option
+#% key: xcos
+#% type: string
+#% description: OPTIONAL INPUT: X directional cosine map
+#% required : no
+#%end
+#%option
+#% key: ycos
+#% type: string
+#% description: OPTIONAL INPUT: Y directional cosine map
+#% required : no
+#%end
+#%option
+#% key: zcos
+#% type: string
+#% description: OPTIONAL INPUT: Z directional cosine map
+#% required : no
+#%end
+import sys
+import atexit
+import grass.script as grass
+# cleaning up tem files
+def cleanup():
+    rasts = ['aspect_compass','colat_angle','cosine_x','cosine_y','cosine_z','sum_Xcosine','sum_Ycosine','sum_Zcosine']
+    grass.run_command('g.remove', flags = 'f', rast = rasts, quiet = True)
+def main():
+#set options
+    elevmap = options['elevation']          # input
+    slope = options['slope']                # input
+    aspect = options['aspect']              # input
+    window = options['window']              # input
+    strength = options['strength']          # output
+    fisher = options['fisher']              # output
+    compass = options['compass']            # temporary
+    colatitude = options['colatitude']      # temporary
+    xcos = options['xcos']                  # temporary
+    ycos = options['ycos']                  # temporary
+    zcos = options['zcos']                  # temporary
+# check if input files exist
+    grass.message( "----" )
+    grass.message( "Check if input files exist ..." )
+    find_elev = grass.find_file(elevmap, element = 'cell')
+    if find_elev['name'] == "":
+        print "Map %s not found! Aborting." % elevmap
+        sys.exit()
+    find_slope = grass.find_file(slope, element = 'cell')
+    if find_slope['name'] == "":
+        print "Map %s not found! Aborting." % slope
+        sys.exit()
+    find_aspect = grass.find_file(aspect, element = 'cell')
+    if find_aspect['name'] == "":
+        print "Map %s not found! Aborting." % aspect
+        sys.exit()
+#ACERTAR O NOME DOS ARQUIVOS - TIRAR TUDO DESDE O @!!!!
+# give default names to outputs, in case the user doesn't provide them
+    grass.message( "Define default output names when not defined by user ..." )
+    if strength == "":
+        strength = "%s_vector_strength_%sx%s" % (find_elev['name'],window,window)
+    if fisher == "":
+        fisher = "%s_fisher_1K_%sx%s" % (find_elev['name'],window,window)
+# calculate compass-oriented aspect and colatitude
+# (temp rasters)
+# correct aspect angles from cartesian (GRASS default) to compass angles
+#   if(A==0,0,if(A < 90, 90-A, 360+90-A))
+    grass.message( "Calculate compass aspect values ..." )
+    if compass == "":
+        aspect_compass = 'aspect_compass'
+#        print "Calculating compass aspect values (longitude)"
+#        aspect_compass = grass.tempfile()
+        grass.mapcalc("${out} = if(${rast1}==0,0,if(${rast1} < 90, 90-${rast1}, 360+90-${rast1}))",
+            out = aspect_compass,
+            rast1 = aspect)
+    else:
+        grass.message( "Using previous calculated compass aspect values (longitude)" )
+        # print "Using previous calculated compass aspect values (longitude)"
+        aspect_compass = compass
+# calculates colatitude (90-slope)
+    grass.message( "Calculate colatitude ..." )
+    if colatitude == "":
+        colat_angle = 'colat_angle'
+#        print "Calculating colatitude (90-slope)"
+#        colat_angle = grass.tempfile()
+        grass.mapcalc("${out} = 90 - ${rast1}",
+            out = colat_angle,
+            rast1 = slope)
+    else:
+        grass.message( "Using previous calculated colatitude values" )
+        # print "Using previous calculated colatitude values"
+        colat_angle = colatitude
+# calculate direction cosines
+# direction cosines relative to axis oriented north, east and up
+# direction cosine calculation according to McKean & Roering (2004), Geomorphology, 57:331-351.
+    grass.message( "Calculate direction cosines ..." )
+# X cosine
+    if xcos == "":
+        cosine_x = 'cosine_x'
+#        print "Calculating X direction cosine"
+#        cosine_x = grass.tempfile()
+        grass.mapcalc("${out} = sin(${rast1}) * cos(${rast2})",
+            out = 'cosine_x',
+            rast1 = aspect_compass,
+            rast2 = colat_angle)
+    else:
+        grass.message( "Using previous calculated X direction cosine value" )
+        # print "Using previous calculated X direction cosine values"
+        cosine_x = xcos
+# Y cosine
+    if ycos == "":
+        cosine_y = 'cosine_y'
+#        print "Calculating Y direction cosine"
+#        cosine_y = grass.tempfile()
+        grass.mapcalc("${out} = sin(${rast1}) * sin(${rast2})",
+            out = 'cosine_y',
+    else:
+        grass.message( "Using previous calculated Y direction cosine values" )
+        # print "Using previous calculated Y direction cosine values"
+        cosine_y = ycos
+# Z cosine
+    if zcos == "":
+        cosine_z = 'cosine_z'
+#        cosine_z = grass.tempfile()
+        grass.mapcalc("${out} = cos(${rast1})",
+            out = 'cosine_z',
+            rast1 = aspect_compass)
+    else:
+        cosine_z = zcos
+# calculate SUM of direction cosines
+    grass.message( "Calculate sum of direction cosines ..." )
+    grass.message( "Calculating sum of X direction cosines ..." )
+    # print "Calculating sum of X direction cosines"
+#    sum_Xcosine = grass.tempfile()
+    grass.run_command("r.neighbors",
+            input=cosine_x,
+			output='sum_Xcosine',
+			method='sum',
+			size=window,
+			overwrite=True)
+    grass.message( "Calculating sum of Y direction cosines ..." )
+#    print "Calculating sum of Y direction cosines"
+#    sum_Ycosine = grass.tempfile()
+            input=cosine_y,
+			output='sum_Ycosine',
+			method='sum',
+			size=window,
+			overwrite=True)
+    grass.message( "Calculating sum of Z direction cosines ..." )
+#    print "Calculating sum of Z direction cosines"
+#    sum_Zcosine = grass.tempfile()
+            input=cosine_z,
+			output='sum_Zcosine',
+			method='sum',
+			size=window,
+			overwrite=True)
+# calculate vector strength
+    grass.message( "Calculate vector strength ..." )
+#    print "Calculating vector strength"
+#    print strength
+    grass.mapcalc("${out} = sqrt(exp(${rast1},2) + exp(${rast2},2) + exp(${rast3},2))",
+            out = strength,
+            rast1 = 'sum_Xcosine',
+            rast2 = 'sum_Ycosine',
+            rast3 = 'sum_Zcosine')
+# calculate Inverted Fisher's K parameter
+# k=1/((N-1)/(N-R))
+    grass.message( "Calculate inverted Fisher's K parameter ..." )
+    w = int(window)
+#    print "Calculating Inverted Fisher's K parameter"
+    grass.mapcalc("${out} = ($w * $w - ${rast1}) / ($w * $w - 1)",
+            out = fisher,
+            rast1 = strength,
+            w = int(window))
+#    calculations done
+    grass.message( "Result maps:" )
+    grass.message( strength )
+    grass.message( fisher )
+    grass.message( "Calculations done." )
+# this "if" condition instructs execution of code contained in this script, *only* if the script is being executed directly
+if __name__ == "__main__": # this allows the script to be used as a module in other scripts or as a standalone script
+    options, flags = grass.parser() #
+    atexit.register(cleanup)
+    sys.exit(main()) #
Property changes on: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
   + text/x-python
   + native
