[GRASS-SVN] r60558 - grass-addons/grass7/raster/r.roughness.vector
svn_grass at osgeo.org
Wed May 28 11:37:52 PDT 2014
Author: hellik
Date: 2014-05-28 11:37:52 -0700 (Wed, 28 May 2014)
New Revision: 60558
grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
r.roughness.vector: add pythonized grass6 addon (on behalf of Carlos Grohmann) - step 5 - cleanup script
Modified: grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py
--- grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py 2014-05-28 18:29:27 UTC (rev 60557)
+++ grass-addons/grass7/raster/r.roughness.vector/r.roughness.vector.py 2014-05-28 18:37:52 UTC (rev 60558)
@@ -43,13 +43,11 @@
#% keywords: slope
#% keywords: roughness
#%end
#%option G_OPT_R_ELEV
#% key: elevation
#% description: Name of elevation raster map
#% required: yes
#%end
#%option
#% key: slope
#% type: string
@@ -197,14 +195,12 @@
if compass == "":
aspect_compass = 'aspect_compass'
-# print "Calculating compass aspect values (longitude)"
# aspect_compass = grass.tempfile()
grass.mapcalc("${out} = if(${rast1}==0,0,if(${rast1} < 90, 90-${rast1}, 360+90-${rast1}))",
out = aspect_compass,
rast1 = aspect)
else:
grass.message( "Using previous calculated compass aspect values (longitude)" )
- # print "Using previous calculated compass aspect values (longitude)"
aspect_compass = compass
# calculates colatitude (90-slope)
@@ -214,14 +210,12 @@
if colatitude == "":
colat_angle = 'colat_angle'
-# print "Calculating colatitude (90-slope)"
# colat_angle = grass.tempfile()
grass.mapcalc("${out} = 90 - ${rast1}",
out = colat_angle,
rast1 = slope)
else:
grass.message( "Using previous calculated colatitude values" )
- # print "Using previous calculated colatitude values"
colat_angle = colatitude
@@ -235,7 +229,6 @@
# X cosine
if xcos == "":
cosine_x = 'cosine_x'
-# print "Calculating X direction cosine"
# cosine_x = grass.tempfile()
grass.mapcalc("${out} = sin(${rast1}) * cos(${rast2})",
out = 'cosine_x',
@@ -243,13 +236,11 @@
rast2 = colat_angle)
else:
grass.message( "Using previous calculated X direction cosine value" )
- # print "Using previous calculated X direction cosine values"
cosine_x = xcos
# Y cosine
if ycos == "":
cosine_y = 'cosine_y'
-# print "Calculating Y direction cosine"
# cosine_y = grass.tempfile()
grass.mapcalc("${out} = sin(${rast1}) * sin(${rast2})",
out = 'cosine_y',
@@ -257,20 +248,17 @@
else:
grass.message( "Using previous calculated Y direction cosine values" )
- # print "Using previous calculated Y direction cosine values"
cosine_y = ycos
# Z cosine
if zcos == "":
cosine_z = 'cosine_z'
# cosine_z = grass.tempfile()
grass.mapcalc("${out} = cos(${rast1})",
out = 'cosine_z',
rast1 = aspect_compass)
else:
cosine_z = zcos
@@ -280,7 +268,6 @@
grass.message( "Calculate sum of direction cosines ..." )
grass.message( "Calculating sum of X direction cosines ..." )
- # print "Calculating sum of X direction cosines"
# sum_Xcosine = grass.tempfile()
grass.run_command("r.neighbors",
input=cosine_x,
@@ -290,7 +277,6 @@
overwrite=True)
grass.message( "Calculating sum of Y direction cosines ..." )
-# print "Calculating sum of Y direction cosines"
# sum_Ycosine = grass.tempfile()
input=cosine_y,
@@ -300,7 +286,6 @@
overwrite=True)
grass.message( "Calculating sum of Z direction cosines ..." )
-# print "Calculating sum of Z direction cosines"
# sum_Zcosine = grass.tempfile()
input=cosine_z,
@@ -315,7 +300,6 @@
grass.message( "----" )
grass.message( "Calculate vector strength ..." )
-# print "Calculating vector strength"
# print strength
grass.mapcalc("${out} = sqrt(exp(${rast1},2) + exp(${rast2},2) + exp(${rast3},2))",
out = strength,
@@ -330,7 +314,6 @@
grass.message( "Calculate inverted Fisher's K parameter ..." )
w = int(window)
-# print "Calculating Inverted Fisher's K parameter"
grass.mapcalc("${out} = ($w * $w - ${rast1}) / ($w * $w - 1)",
out = fisher,
rast1 = strength,
